[U-Boot] [PATCH 15/19] cmd_dasa_sim.c: Fix GCC 4.6 build warnings
Fix: cmd_dasa_sim.c: In function 'updatePci9054': cmd_dasa_sim.c:135:6: warning: variable 'val' set but not used [-Wunused-but-set-variable] cmd_dasa_sim.c: In function 'clearPci9054': cmd_dasa_sim.c:189:6: warning: variable 'val' set but not used [-Wunused-but-set-variable]
Signed-off-by: Stefan Roese sr@denx.de --- board/esd/dasa_sim/cmd_dasa_sim.c | 52 +++++++++++++++++-------------------- 1 files changed, 24 insertions(+), 28 deletions(-)
diff --git a/board/esd/dasa_sim/cmd_dasa_sim.c b/board/esd/dasa_sim/cmd_dasa_sim.c index 4946538..0014808 100644 --- a/board/esd/dasa_sim/cmd_dasa_sim.c +++ b/board/esd/dasa_sim/cmd_dasa_sim.c @@ -132,8 +132,6 @@ static void showPci9054 (void)
static void updatePci9054 (void) { - int val; - /* * Set EEPROM write-protect register to 0 */ @@ -141,44 +139,44 @@ static void updatePci9054 (void) in_be32 ((void *)(pci9054_iobase + 0x0c)) & 0xffff00ff);
/* Long Serial EEPROM Load Registers... */ - val = PciEepromWriteLongVPD (0x00, 0x905410b5); - val = PciEepromWriteLongVPD (0x04, 0x09800001); /* other input controller */ - val = PciEepromWriteLongVPD (0x08, 0x28140100); + PciEepromWriteLongVPD (0x00, 0x905410b5); + PciEepromWriteLongVPD (0x04, 0x09800001); /* other input controller */ + PciEepromWriteLongVPD (0x08, 0x28140100);
- val = PciEepromWriteLongVPD (0x0c, 0x00000000); /* MBOX0... */ - val = PciEepromWriteLongVPD (0x10, 0x00000000); + PciEepromWriteLongVPD (0x0c, 0x00000000); /* MBOX0... */ + PciEepromWriteLongVPD (0x10, 0x00000000);
/* las0: fpga access (0x0000.0000 ... 0x0003.ffff) */ - val = PciEepromWriteLongVPD (0x14, 0xfffc0000); /* LAS0RR... */ - val = PciEepromWriteLongVPD (0x18, 0x00000001); /* LAS0BA */ + PciEepromWriteLongVPD (0x14, 0xfffc0000); /* LAS0RR... */ + PciEepromWriteLongVPD (0x18, 0x00000001); /* LAS0BA */
- val = PciEepromWriteLongVPD (0x1c, 0x00200000); /* MARBR... */ - val = PciEepromWriteLongVPD (0x20, 0x00300500); /* LMISC/BIGEND */ + PciEepromWriteLongVPD (0x1c, 0x00200000); /* MARBR... */ + PciEepromWriteLongVPD (0x20, 0x00300500); /* LMISC/BIGEND */
- val = PciEepromWriteLongVPD (0x24, 0x00000000); /* EROMRR... */ - val = PciEepromWriteLongVPD (0x28, 0x00000000); /* EROMBA */ + PciEepromWriteLongVPD (0x24, 0x00000000); /* EROMRR... */ + PciEepromWriteLongVPD (0x28, 0x00000000); /* EROMBA */
- val = PciEepromWriteLongVPD (0x2c, 0x43030000); /* LBRD0... */ + PciEepromWriteLongVPD (0x2c, 0x43030000); /* LBRD0... */
- val = PciEepromWriteLongVPD (0x30, 0x00000000); /* DMRR... */ - val = PciEepromWriteLongVPD (0x34, 0x00000000); - val = PciEepromWriteLongVPD (0x38, 0x00000000); + PciEepromWriteLongVPD (0x30, 0x00000000); /* DMRR... */ + PciEepromWriteLongVPD (0x34, 0x00000000); + PciEepromWriteLongVPD (0x38, 0x00000000);
- val = PciEepromWriteLongVPD (0x3c, 0x00000000); /* DMPBAM... */ - val = PciEepromWriteLongVPD (0x40, 0x00000000); + PciEepromWriteLongVPD (0x3c, 0x00000000); /* DMPBAM... */ + PciEepromWriteLongVPD (0x40, 0x00000000);
/* Extra Long Serial EEPROM Load Registers... */ - val = PciEepromWriteLongVPD (0x44, 0x010212fe); /* PCISID... */ + PciEepromWriteLongVPD (0x44, 0x010212fe); /* PCISID... */
/* las1: 505-sram access (0x0004.0000 ... 0x001f.ffff) */ /* Offset to LAS1: Group 1: 0x00040000 */ /* Group 2: 0x00080000 */ /* Group 3: 0x000c0000 */ - val = PciEepromWriteLongVPD (0x48, 0xffe00000); /* LAS1RR */ - val = PciEepromWriteLongVPD (0x4c, 0x00040001); /* LAS1BA */ - val = PciEepromWriteLongVPD (0x50, 0x00000208); /* LBRD1 */ /* so wars bisher */ + PciEepromWriteLongVPD (0x48, 0xffe00000); /* LAS1RR */ + PciEepromWriteLongVPD (0x4c, 0x00040001); /* LAS1BA */ + PciEepromWriteLongVPD (0x50, 0x00000208); /* LBRD1 */ /* so wars bisher */
- val = PciEepromWriteLongVPD (0x54, 0x00004c06); /* HotSwap... */ + PciEepromWriteLongVPD (0x54, 0x00004c06); /* HotSwap... */
printf ("Finished writing defaults into PLX PCI9054 EEPROM!\n"); } @@ -186,8 +184,6 @@ static void updatePci9054 (void)
static void clearPci9054 (void) { - int val; - /* * Set EEPROM write-protect register to 0 */ @@ -195,8 +191,8 @@ static void clearPci9054 (void) in_be32 ((void *)(pci9054_iobase + 0x0c)) & 0xffff00ff);
/* Long Serial EEPROM Load Registers... */ - val = PciEepromWriteLongVPD (0x00, 0xffffffff); - val = PciEepromWriteLongVPD (0x04, 0xffffffff); /* other input controller */ + PciEepromWriteLongVPD (0x00, 0xffffffff); + PciEepromWriteLongVPD (0x04, 0xffffffff); /* other input controller */
printf ("Finished clearing PLX PCI9054 EEPROM!\n"); }
Dear Stefan Roese,
Applied, thanks.
Stefan Roese
