[U-Boot] [PATCH 1/3] OMAP3: Change some USB related MUX settings to values used by the kernel.
Signed-off-by: Alexander Holler holler@ahsoftware.de --- board/ti/beagle/beagle.h | 27 ++++++++++++++------------- 1 files changed, 14 insertions(+), 13 deletions(-)
diff --git a/board/ti/beagle/beagle.h b/board/ti/beagle/beagle.h index b22b653..abb69e7 100644 --- a/board/ti/beagle/beagle.h +++ b/board/ti/beagle/beagle.h @@ -273,18 +273,18 @@ const omap3_sysinfo sysinfo = { MUX_VAL(CP(MCSPI1_CS1), (IDIS | PTD | EN | M0)) /*McSPI1_CS1*/\ MUX_VAL(CP(MCSPI1_CS2), (IDIS | PTD | DIS | M4)) /*GPIO_176*/\ /* USB EHCI (port 2) */\ - MUX_VAL(CP(MCSPI1_CS3), (IEN | PTU | DIS | M3)) /*HSUSB2_DATA2*/\ - MUX_VAL(CP(MCSPI2_CLK), (IEN | PTU | DIS | M3)) /*HSUSB2_DATA7*/\ - MUX_VAL(CP(MCSPI2_SIMO), (IEN | PTU | DIS | M3)) /*HSUSB2_DATA4*/\ - MUX_VAL(CP(MCSPI2_SOMI), (IEN | PTU | DIS | M3)) /*HSUSB2_DATA5*/\ - MUX_VAL(CP(MCSPI2_CS0), (IEN | PTU | DIS | M3)) /*HSUSB2_DATA6*/\ - MUX_VAL(CP(MCSPI2_CS1), (IEN | PTU | DIS | M3)) /*HSUSB2_DATA3*/\ - MUX_VAL(CP(ETK_D10_ES2), (IDIS | PTU | DIS | M3)) /*HSUSB2_CLK*/\ - MUX_VAL(CP(ETK_D11_ES2), (IDIS | PTU | DIS | M3)) /*HSUSB2_STP*/\ - MUX_VAL(CP(ETK_D12_ES2), (IEN | PTU | DIS | M3)) /*HSUSB2_DIR*/\ - MUX_VAL(CP(ETK_D13_ES2), (IEN | PTU | DIS | M3)) /*HSUSB2_NXT*/\ - MUX_VAL(CP(ETK_D14_ES2), (IEN | PTU | DIS | M3)) /*HSUSB2_DATA0*/\ - MUX_VAL(CP(ETK_D15_ES2), (IEN | PTU | DIS | M3)) /*HSUSB2_DATA1*/\ + MUX_VAL(CP(MCSPI1_CS3), (IEN | PTD | EN | M3)) /*HSUSB2_DATA2*/\ + MUX_VAL(CP(MCSPI2_CLK), (IEN | PTD | EN | M3)) /*HSUSB2_DATA7*/\ + MUX_VAL(CP(MCSPI2_SIMO), (IEN | PTD | EN | M3)) /*HSUSB2_DATA4*/\ + MUX_VAL(CP(MCSPI2_SOMI), (IEN | PTD | EN | M3)) /*HSUSB2_DATA5*/\ + MUX_VAL(CP(MCSPI2_CS0), (IEN | PTD | EN | M3)) /*HSUSB2_DATA6*/\ + MUX_VAL(CP(MCSPI2_CS1), (IEN | PTD | EN | M3)) /*HSUSB2_DATA3*/\ + MUX_VAL(CP(ETK_D10_ES2), (IDIS | PTD | DIS | M3)) /*HSUSB2_CLK*/\ + MUX_VAL(CP(ETK_D11_ES2), (IDIS | PTD | DIS | M3)) /*HSUSB2_STP*/\ + MUX_VAL(CP(ETK_D12_ES2), (IEN | PTD | EN | M3)) /*HSUSB2_DIR*/\ + MUX_VAL(CP(ETK_D13_ES2), (IEN | PTD | EN | M3)) /*HSUSB2_NXT*/\ + MUX_VAL(CP(ETK_D14_ES2), (IEN | PTD | EN | M3)) /*HSUSB2_DATA0*/\ + MUX_VAL(CP(ETK_D15_ES2), (IEN | PTD | EN | M3)) /*HSUSB2_DATA1*/\ /*Control and debug */\ MUX_VAL(CP(SYS_32K), (IEN | PTD | DIS | M0)) /*SYS_32K*/\ MUX_VAL(CP(SYS_CLKREQ), (IEN | PTD | DIS | M0)) /*SYS_CLKREQ*/\ @@ -383,7 +383,8 @@ const omap3_sysinfo sysinfo = { MUX_VAL(CP(MCBSP3_CLKX), (IEN | PTD | DIS | M4)) /*GPIO_141*/\ MUX_VAL(CP(UART2_CTS), (IEN | PTU | EN | M0)) /*UART2_CTS*/\ MUX_VAL(CP(UART2_RTS), (IDIS | PTD | DIS | M0)) /*UART2_RTS*/\ - MUX_VAL(CP(UART2_TX), (IDIS | PTD | DIS | M0)) /*UART2_TX*/ + MUX_VAL(CP(UART2_TX), (IDIS | PTD | DIS | M0)) /*UART2_TX*/\ + MUX_VAL(CP(UART2_RX), (IDIS | PTU | EN | M4)) /*GPIO_147*/
#define MUX_BEAGLE_XM() \ MUX_VAL(CP(GPMC_NCS5), (IDIS | PTD | EN | M4)) /*GPIO_56*/\
Signed-off-by: Alexander Holler holler@ahsoftware.de --- arch/arm/cpu/armv7/omap3/clock.c | 20 ++++++++++++++++++ arch/arm/cpu/armv7/omap3/lowlevel_init.S | 22 ++++++++++++++++++++ arch/arm/include/asm/arch-omap3/clocks.h | 1 + arch/arm/include/asm/arch-omap3/clocks_omap3.h | 26 ++++++++++++++++++++++++ arch/arm/include/asm/arch-omap3/cpu.h | 21 ++++++++++++++---- 5 files changed, 85 insertions(+), 5 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap3/clock.c b/arch/arm/cpu/armv7/omap3/clock.c index 2238c52..3d38d08 100644 --- a/arch/arm/cpu/armv7/omap3/clock.c +++ b/arch/arm/cpu/armv7/omap3/clock.c @@ -278,6 +278,25 @@ static void dpll4_init_34xx(u32 sil_index, u32 clk_index) wait_on_value(ST_PERIPH_CLK, 2, &prcm_base->idlest_ckgen, LDELAY); }
+static void dpll5_init_34xx(u32 sil_index, u32 clk_index) +{ + struct prcm *prcm_base = (struct prcm *)PRCM_BASE; + dpll_param *ptr = (dpll_param *) get_per2_dpll_param(); + + /* Moving it to the right sysclk base */ + ptr = ptr + clk_index; + + /* PER2 DPLL (DPLL5) */ + sr32(&prcm_base->clken2_pll, 0, 3, PLL_STOP); + wait_on_value(1, 0, &prcm_base->idlest2_ckgen, LDELAY); + sr32(&prcm_base->clksel5_pll, 0, 5, ptr->m2); /* set M2 (usbtll_fck) */ + sr32(&prcm_base->clksel4_pll, 8, 11, ptr->m); /* set m (11-bit multiplier) */ + sr32(&prcm_base->clksel4_pll, 0, 7, ptr->n); /* set n (7-bit divider)*/ + sr32(&prcm_base->clken_pll, 4, 4, ptr->fsel); /* FREQSEL */ + sr32(&prcm_base->clken2_pll, 0, 3, PLL_LOCK); /* lock mode */ + wait_on_value(1, 1, &prcm_base->idlest2_ckgen, LDELAY); +} + static void mpu_init_34xx(u32 sil_index, u32 clk_index) { struct prcm *prcm_base = (struct prcm *)PRCM_BASE; @@ -587,6 +606,7 @@ void prcm_init(void)
dpll3_init_34xx(sil_index, clk_index); dpll4_init_34xx(sil_index, clk_index); + dpll5_init_34xx(sil_index, clk_index); iva_init_34xx(sil_index, clk_index); mpu_init_34xx(sil_index, clk_index);
diff --git a/arch/arm/cpu/armv7/omap3/lowlevel_init.S b/arch/arm/cpu/armv7/omap3/lowlevel_init.S index 109481e..1458072 100644 --- a/arch/arm/cpu/armv7/omap3/lowlevel_init.S +++ b/arch/arm/cpu/armv7/omap3/lowlevel_init.S @@ -360,6 +360,28 @@ get_per_dpll_param: adr r0, per_dpll_param mov pc, lr
+/* PER2 DPLL values */ +per2_dpll_param: +/* 12MHz */ +.word PER2_M_12, PER2_N_12, PER2_FSEL_12, PER2_M2_12 + +/* 13MHz */ +.word PER2_M_13, PER2_N_13, PER2_FSEL_13, PER2_M2_13 + +/* 19.2MHz */ +.word PER2_M_19P2, PER2_N_19P2, PER2_FSEL_19P2, PER2_M2_19P2 + +/* 26MHz */ +.word PER2_M_26, PER2_N_26, PER2_FSEL_26, PER2_M2_26 + +/* 38.4MHz */ +.word PER2_M_38P4, PER2_N_38P4, PER2_FSEL_38P4, PER2_M2_38P4 + +.globl get_per2_dpll_param +get_per2_dpll_param: + adr r0, per2_dpll_param + mov pc, lr + /* * Tables for 36XX/37XX devices * diff --git a/arch/arm/include/asm/arch-omap3/clocks.h b/arch/arm/include/asm/arch-omap3/clocks.h index 40f80ba..bed0002 100644 --- a/arch/arm/include/asm/arch-omap3/clocks.h +++ b/arch/arm/include/asm/arch-omap3/clocks.h @@ -68,6 +68,7 @@ extern dpll_param *get_mpu_dpll_param(void); extern dpll_param *get_iva_dpll_param(void); extern dpll_param *get_core_dpll_param(void); extern dpll_param *get_per_dpll_param(void); +extern dpll_param *get_per2_dpll_param(void);
extern dpll_param *get_36x_mpu_dpll_param(void); extern dpll_param *get_36x_iva_dpll_param(void); diff --git a/arch/arm/include/asm/arch-omap3/clocks_omap3.h b/arch/arm/include/asm/arch-omap3/clocks_omap3.h index 30ef690..ef600dd 100644 --- a/arch/arm/include/asm/arch-omap3/clocks_omap3.h +++ b/arch/arm/include/asm/arch-omap3/clocks_omap3.h @@ -282,6 +282,32 @@ #define PER_FSEL_38P4 0x07 #define PER_M2_38P4 0x09
+/* PER2 DPLL */ +#define PER2_M_12 0x78 +#define PER2_N_12 0x0B +#define PER2_FSEL_12 0x03 +#define PER2_M2_12 0x01 + +#define PER2_M_13 0x78 +#define PER2_N_13 0x0C +#define PER2_FSEL_13 0x03 +#define PER2_M2_13 0x01 + +#define PER2_M_19P2 0x2EE +#define PER2_N_19P2 0x0B +#define PER2_FSEL_19P2 0x06 +#define PER2_M2_19P2 0x0A + +#define PER2_M_26 0x78 +#define PER2_N_26 0x0C +#define PER2_FSEL_26 0x03 +#define PER2_M2_26 0x01 + +#define PER2_M_38P4 0x2EE +#define PER2_N_38P4 0x0B +#define PER2_FSEL_38P4 0x06 +#define PER2_M2_38P4 0x0A + /* 36XX PER DPLL */
#define PER_36XX_M_12 0x1B0 diff --git a/arch/arm/include/asm/arch-omap3/cpu.h b/arch/arm/include/asm/arch-omap3/cpu.h index 962d6d4..e944de7 100644 --- a/arch/arm/include/asm/arch-omap3/cpu.h +++ b/arch/arm/include/asm/arch-omap3/cpu.h @@ -347,10 +347,13 @@ struct prcm { u32 clksel2_pll_mpu; /* 0x944 */ u8 res6[0xb8]; u32 fclken1_core; /* 0xa00 */ - u8 res7[0xc]; + u32 res_fclken2_core; + u32 fclken3_core; /* 0xa08 */ + u8 res7[0x4]; u32 iclken1_core; /* 0xa10 */ u32 iclken2_core; /* 0xa14 */ - u8 res8[0x28]; + u32 iclken3_core; /* 0xa18 */ + u8 res8[0x24]; u32 clksel_core; /* 0xa40 */ u8 res9[0xbc]; u32 fclken_gfx; /* 0xb00 */ @@ -368,13 +371,17 @@ struct prcm { u32 clksel_wkup; /* 0xc40 */ u8 res16[0xbc]; u32 clken_pll; /* 0xd00 */ - u8 res17[0x1c]; + u32 clken2_pll; /* 0xd04 */ + u8 res17[0x18]; u32 idlest_ckgen; /* 0xd20 */ - u8 res18[0x1c]; + u32 idlest2_ckgen; /* 0xd24 */ + u8 res18[0x18]; u32 clksel1_pll; /* 0xd40 */ u32 clksel2_pll; /* 0xd44 */ u32 clksel3_pll; /* 0xd48 */ - u8 res19[0xb4]; + u32 clksel4_pll; /* 0xd4c */ + u32 clksel5_pll; /* 0xd50 */ + u8 res19[0xac]; u32 fclken_dss; /* 0xe00 */ u8 res20[0xc]; u32 iclken_dss; /* 0xe10 */ @@ -394,6 +401,10 @@ struct prcm { u32 clksel_per; /* 0x1040 */ u8 res28[0xfc]; u32 clksel1_emu; /* 0x1140 */ + u8 res29[0x2bc]; + u32 fclken_usbhost; /* 0x1400 */ + u8 res30[0xc]; + u32 iclken_usbhost; /* 0x1410 */ }; #else /* __ASSEMBLY__ */ #define CM_CLKSEL_CORE 0x48004a40
The reset sequence/configuration for ehci is highly board specific, so this will be done in the source for the board, instead of introducing several CONFIG_* which would be needed to make those few lines in beagle.c usable across different OMAP boards.
Signed-off-by: Alexander Holler holler@ahsoftware.de --- arch/arm/include/asm/arch-omap3/ehci_omap3.h | 58 ++++++++++++++ board/ti/beagle/beagle.c | 106 ++++++++++++++++++++++++++ include/configs/omap3_beagle.h | 6 ++ 3 files changed, 170 insertions(+), 0 deletions(-) create mode 100644 arch/arm/include/asm/arch-omap3/ehci_omap3.h
diff --git a/arch/arm/include/asm/arch-omap3/ehci_omap3.h b/arch/arm/include/asm/arch-omap3/ehci_omap3.h new file mode 100644 index 0000000..cd01f50 --- /dev/null +++ b/arch/arm/include/asm/arch-omap3/ehci_omap3.h @@ -0,0 +1,58 @@ +/* + * (C) Copyright 2011 + * Alexander Holler holler@ahsoftware.de + * + * Based on "drivers/usb/host/ehci-omap.c" from Linux 2.6.37 + * + * See there for additional Copyrights. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ +#ifndef _EHCI_OMAP3_H_ +#define _EHCI_OMAP3_H_ + +/* USB/EHCI registers */ +#define OMAP3_USBTLL_BASE 0x48062000UL +#define OMAP3_UHH_BASE 0x48064000UL +#define OMAP3_EHCI_BASE 0x48064800UL + +/* TLL Register Set */ +#define OMAP_USBTLL_SYSCONFIG (0x10) +#define OMAP_USBTLL_SYSCONFIG_SOFTRESET (1 << 1) +#define OMAP_USBTLL_SYSCONFIG_ENAWAKEUP (1 << 2) +#define OMAP_USBTLL_SYSCONFIG_SIDLEMODE (1 << 3) +#define OMAP_USBTLL_SYSCONFIG_CACTIVITY (1 << 8) + +#define OMAP_USBTLL_SYSSTATUS (0x14) +#define OMAP_USBTLL_SYSSTATUS_RESETDONE (1 << 0) + +/* UHH Register Set */ +#define OMAP_UHH_SYSCONFIG (0x10) +#define OMAP_UHH_SYSCONFIG_SOFTRESET (1 << 1) +#define OMAP_UHH_SYSCONFIG_CACTIVITY (1 << 8) +#define OMAP_UHH_SYSCONFIG_SIDLEMODE (1 << 3) +#define OMAP_UHH_SYSCONFIG_ENAWAKEUP (1 << 2) +#define OMAP_UHH_SYSCONFIG_MIDLEMODE (1 << 12) + +#define OMAP_UHH_HOSTCONFIG (0x40) +#define OMAP_UHH_HOSTCONFIG_INCR4_BURST_EN (1 << 2) +#define OMAP_UHH_HOSTCONFIG_INCR8_BURST_EN (1 << 3) +#define OMAP_UHH_HOSTCONFIG_INCR16_BURST_EN (1 << 4) + +#endif /* _EHCI_OMAP3_H_ */ diff --git a/board/ti/beagle/beagle.c b/board/ti/beagle/beagle.c index c066d6e..03242c1 100644 --- a/board/ti/beagle/beagle.c +++ b/board/ti/beagle/beagle.c @@ -37,8 +37,19 @@ #include <asm/arch/sys_proto.h> #include <asm/arch/gpio.h> #include <asm/mach-types.h> +#ifdef CONFIG_USB_EHCI +#include <usb.h> +#include <asm/arch/clocks.h> +#include <asm/arch/clocks_omap3.h> +#include <asm/arch/ehci_omap3.h> +/* from drivers/usb/host/ehci-core.h */ +extern struct ehci_hccr *hccr; +extern volatile struct ehci_hcor *hcor; +#endif #include "beagle.h"
+#define pr_debug(fmt, args...) debug(fmt, ##args) + #define TWL4030_I2C_BUS 0 #define EXPANSION_EEPROM_I2C_BUS 1 #define EXPANSION_EEPROM_I2C_ADDRESS 0x50 @@ -273,3 +284,98 @@ int board_mmc_init(bd_t *bis) return 0; } #endif + +#ifdef CONFIG_USB_EHCI + +#define GPIO_PHY_RESET 147 + +/* Reset is needed otherwise the kernel-driver will throw an error. */ +int ehci_hcd_stop(void) +{ + pr_debug("Resetting OMAP3 EHCI\n"); + omap_set_gpio_dataout(GPIO_PHY_RESET, 0); + writel(OMAP_UHH_SYSCONFIG_SOFTRESET, OMAP3_UHH_BASE + OMAP_UHH_SYSCONFIG); + return 0; +} + +/* Call usb_stop() before starting the kernel */ +void show_boot_progress(int val) +{ + if(val == 15) + usb_stop(); +} + +/* + * Initialize the OMAP3 EHCI controller and PHY on the BeagleBoard. + * Based on "drivers/usb/host/ehci-omap.c" from Linux 2.6.37. + * See there for additional Copyrights. + */ +int ehci_hcd_init(void) +{ + pr_debug("Initializing OMAP3 ECHI\n"); + + /* Put the PHY in RESET */ + omap_request_gpio(GPIO_PHY_RESET); + omap_set_gpio_direction(GPIO_PHY_RESET, 0); + omap_set_gpio_dataout(GPIO_PHY_RESET, 0); + + /* Hold the PHY in RESET for enough time till DIR is high */ + /* Refer: ISSUE1 */ + udelay(10); + + struct prcm *prcm_base = (struct prcm *)PRCM_BASE; + /* Enable USBHOST_L3_ICLK (USBHOST_MICLK) */ + sr32(&prcm_base->iclken_usbhost, 0, 1, 1); + /* + * Enable USBHOST_48M_FCLK (USBHOST_FCLK1) + * and USBHOST_120M_FCLK (USBHOST_FCLK2) + */ + sr32(&prcm_base->fclken_usbhost, 0, 2, 3); + /* Enable USBTTL_ICLK */ + sr32(&prcm_base->iclken3_core, 2, 1, 1); + /* Enable USBTTL_FCLK */ + sr32(&prcm_base->fclken3_core, 2, 1, 1); + pr_debug("USB clocks enabled\n"); + + /* perform TLL soft reset, and wait until reset is complete */ + writel(OMAP_USBTLL_SYSCONFIG_SOFTRESET, + OMAP3_USBTLL_BASE + OMAP_USBTLL_SYSCONFIG); + /* Wait for TLL reset to complete */ + while (!(readl(OMAP3_USBTLL_BASE + OMAP_USBTLL_SYSSTATUS) + & OMAP_USBTLL_SYSSTATUS_RESETDONE)); + pr_debug("TLL reset done\n"); + + writel(OMAP_USBTLL_SYSCONFIG_ENAWAKEUP | + OMAP_USBTLL_SYSCONFIG_SIDLEMODE | + OMAP_USBTLL_SYSCONFIG_CACTIVITY, + OMAP3_USBTLL_BASE + OMAP_USBTLL_SYSCONFIG); + + /* Put UHH in NoIdle/NoStandby mode */ + writel(OMAP_UHH_SYSCONFIG_ENAWAKEUP + | OMAP_UHH_SYSCONFIG_SIDLEMODE + | OMAP_UHH_SYSCONFIG_CACTIVITY + | OMAP_UHH_SYSCONFIG_MIDLEMODE, + OMAP3_UHH_BASE + OMAP_UHH_SYSCONFIG); + + /* setup burst configurations */ + writel(OMAP_UHH_HOSTCONFIG_INCR4_BURST_EN + | OMAP_UHH_HOSTCONFIG_INCR8_BURST_EN + | OMAP_UHH_HOSTCONFIG_INCR16_BURST_EN, + OMAP3_UHH_BASE + OMAP_UHH_HOSTCONFIG); + + /* + * Refer ISSUE1: + * Hold the PHY in RESET for enough time till + * PHY is settled and ready + */ + udelay(10); + omap_set_gpio_dataout(GPIO_PHY_RESET, 1); + + hccr = (struct ehci_hccr *)(OMAP3_EHCI_BASE); + hcor = (struct ehci_hcor *)(OMAP3_EHCI_BASE + 0x10); + + pr_debug("OMAP3 EHCI init done\n"); + return 0; +} + +#endif /* CONFIG_USB_EHCI */ diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index 5cfa4cb..ba34e8a 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -121,6 +121,11 @@ #define CONFIG_USB_TTY 1 #define CONFIG_SYS_CONSOLE_IS_IN_ENV 1
+/* USB EHCI */ +#define CONFIG_CMD_USB +#define CONFIG_USB_EHCI +#define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 3 + /* commands to include */ #include <config_cmd_default.h>
@@ -137,6 +142,7 @@
#define CONFIG_CMD_I2C /* I2C serial bus support */ #define CONFIG_CMD_MMC /* MMC support */ +#define CONFIG_USB_STORAGE /* USB storage support */ #define CONFIG_CMD_NAND /* NAND support */
#undef CONFIG_CMD_FLASH /* flinfo, erase, protect */
Alexander Holler
