[PATCH] ARM: uniphier: enable CONFIG_MMC_HS400_SUPPORT for uniphier_v8_defconfig
The eMMC controller on LD20 or later supports HS-400 mode. It works on a quick test. Enable it in case somebody may want to use it.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
configs/uniphier_v8_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/uniphier_v8_defconfig b/configs/uniphier_v8_defconfig index 25ab2c5a8158..4514468abf88 100644 --- a/configs/uniphier_v8_defconfig +++ b/configs/uniphier_v8_defconfig @@ -39,7 +39,7 @@ CONFIG_I2C_EEPROM=y CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS=10 CONFIG_SUPPORT_EMMC_RPMB=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_MMC_HS200_SUPPORT=y +CONFIG_MMC_HS400_SUPPORT=y CONFIG_MMC_UNIPHIER=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ADMA=y
On Thu, Feb 27, 2020 at 8:32 PM Masahiro Yamada yamada.masahiro@socionext.com wrote:
Applied to u-boot-uniphier.
diff --git a/configs/uniphier_v8_defconfig b/configs/uniphier_v8_defconfig index 25ab2c5a8158..4514468abf88 100644 --- a/configs/uniphier_v8_defconfig +++ b/configs/uniphier_v8_defconfig @@ -39,7 +39,7 @@ CONFIG_I2C_EEPROM=y CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS=10 CONFIG_SUPPORT_EMMC_RPMB=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_MMC_HS200_SUPPORT=y +CONFIG_MMC_HS400_SUPPORT=y CONFIG_MMC_UNIPHIER=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ADMA=y -- 2.17.1
Masahiro Yamada
Masahiro Yamada
