[U-Boot] [PATCH] imx: imx7d-sdb: Add DM QSPI support
On iMX7D SabreSD board, the QSPI has pins conflict with EPDC (default). To use QSPI, users have to rework the board (de-populate R388-R391, R396-R399 populate R392-R395, R299, R300). So we add new DTS file and new defconfig dedicated for QSPI.
Other changes to support the DM QSPI: - Add QSPI node and alias spi0. - Modify spi4 (spi-gpio) node and add alias spi5 for it to avoid req conflict - Add EPDC node in imx7d.dtsi and disable it in imx7d-sdb-qspi.dts, to present the conflict. - Remove iomux settings of qspi in board codes which is not needed for DM driver.
Signed-off-by: Ye Li ye.li@nxp.com --- arch/arm/dts/Makefile | 3 +- arch/arm/dts/imx7d-sdb-qspi.dts | 44 ++++++++++++++++ arch/arm/dts/imx7d-sdb.dts | 6 ++- arch/arm/dts/imx7d.dtsi | 12 +++++ arch/arm/dts/imx7s.dtsi | 22 ++++++-- board/freescale/mx7dsabresd/mx7dsabresd.c | 16 ------ configs/mx7dsabresd_qspi_defconfig | 83 +++++++++++++++++++++++++++++++ include/configs/mx7dsabresd.h | 4 +- 8 files changed, 165 insertions(+), 25 deletions(-) create mode 100644 arch/arm/dts/imx7d-sdb-qspi.dts create mode 100644 configs/mx7dsabresd_qspi_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 493652e..dfabec0 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -433,7 +433,8 @@ dtb-$(CONFIG_MX6UL) += \ dtb-$(CONFIG_MX6ULL) += imx6ull-14x14-evk.dtb
dtb-$(CONFIG_MX7) += imx7-colibri.dtb \ - imx7d-sdb.dtb + imx7d-sdb.dtb \ + imx7d-sdb-qspi.dtb
dtb-$(CONFIG_ARCH_MX7ULP) += imx7ulp-evk.dtb
diff --git a/arch/arm/dts/imx7d-sdb-qspi.dts b/arch/arm/dts/imx7d-sdb-qspi.dts new file mode 100644 index 0000000..38d69ec --- /dev/null +++ b/arch/arm/dts/imx7d-sdb-qspi.dts @@ -0,0 +1,44 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2015 Freescale Semiconductor, Inc. + * Copyright 2018 NXP + */ + +#include "imx7d-sdb.dts" + +/* disable epdc, conflict with qspi */ +&epdc { + status = "disabled"; +}; + +&iomuxc { + qspi1 { + pinctrl_qspi1_1: qspi1grp_1 { + fsl,pins = < + MX7D_PAD_EPDC_DATA00__QSPI_A_DATA0 0x51 + MX7D_PAD_EPDC_DATA01__QSPI_A_DATA1 0x51 + MX7D_PAD_EPDC_DATA02__QSPI_A_DATA2 0x51 + MX7D_PAD_EPDC_DATA03__QSPI_A_DATA3 0x51 + MX7D_PAD_EPDC_DATA05__QSPI_A_SCLK 0x51 + MX7D_PAD_EPDC_DATA06__QSPI_A_SS0_B 0x51 + >; + }; + }; +}; + +&qspi1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_qspi1_1>; + status = "okay"; + ddrsmp=<0>; + + flash0: mx25l51245g@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + spi-max-frequency = <29000000>; + /* take off one dummy cycle */ + spi-nor,ddr-quad-read-dummy = <5>; + reg = <0>; + }; +}; diff --git a/arch/arm/dts/imx7d-sdb.dts b/arch/arm/dts/imx7d-sdb.dts index bafcc79..76aa69a 100644 --- a/arch/arm/dts/imx7d-sdb.dts +++ b/arch/arm/dts/imx7d-sdb.dts @@ -11,11 +11,15 @@ model = "Freescale i.MX7 SabreSD Board"; compatible = "fsl,imx7d-sdb", "fsl,imx7d";
+ aliases { + spi5 = &soft_spi; + }; + memory { reg = <0x80000000 0x80000000>; };
- spi4 { + soft_spi: soft-spi { compatible = "spi-gpio"; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_spi1>; diff --git a/arch/arm/dts/imx7d.dtsi b/arch/arm/dts/imx7d.dtsi index f6dee41..30b0589 100644 --- a/arch/arm/dts/imx7d.dtsi +++ b/arch/arm/dts/imx7d.dtsi @@ -86,6 +86,18 @@ }; };
+&aips2 { + epdc: epdc@306f0000 { + compatible = "fsl,imx7d-epdc"; + interrupts = <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>; + reg = <0x306f0000 0x10000>; + clocks = <&clks IMX7D_CLK_DUMMY>, <&clks IMX7D_EPDC_PIXEL_ROOT_CLK>; + clock-names = "epdc_axi", "epdc_pix"; + epdc-ram = <&gpr 0x4 30>; + status = "disabled"; + }; +}; + &aips3 { usbotg2: usb@30b20000 { compatible = "fsl,imx7d-usb", "fsl,imx27-usb"; diff --git a/arch/arm/dts/imx7s.dtsi b/arch/arm/dts/imx7s.dtsi index a7d48e7..540de6c 100644 --- a/arch/arm/dts/imx7s.dtsi +++ b/arch/arm/dts/imx7s.dtsi @@ -81,10 +81,11 @@ serial4 = &uart5; serial5 = &uart6; serial6 = &uart7; - spi0 = &ecspi1; - spi1 = &ecspi2; - spi2 = &ecspi3; - spi3 = &ecspi4; + spi0 = &qspi1; + spi1 = &ecspi1; + spi2 = &ecspi2; + spi3 = &ecspi3; + spi4 = &ecspi4; };
cpus { @@ -966,6 +967,19 @@ status = "disabled"; };
+ qspi1: qspi@30bb0000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx7d-qspi"; + reg = <0x30bb0000 0x10000>, <0x60000000 0x10000000>; + reg-names = "QuadSPI", "QuadSPI-memory"; + interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_QSPI_ROOT_CLK>, + <&clks IMX7D_QSPI_ROOT_CLK>; + clock-names = "qspi_en", "qspi"; + status = "disabled"; + }; + sdma: sdma@30bd0000 { compatible = "fsl,imx7d-sdma", "fsl,imx35-sdma"; reg = <0x30bd0000 0x10000>; diff --git a/board/freescale/mx7dsabresd/mx7dsabresd.c b/board/freescale/mx7dsabresd/mx7dsabresd.c index 90e2d1a..191b59a 100644 --- a/board/freescale/mx7dsabresd/mx7dsabresd.c +++ b/board/freescale/mx7dsabresd/mx7dsabresd.c @@ -36,9 +36,6 @@ DECLARE_GLOBAL_DATA_PTR; #define LCD_PAD_CTRL (PAD_CTL_HYS | PAD_CTL_PUS_PU100KOHM | \ PAD_CTL_DSE_3P3V_49OHM)
-#define QSPI_PAD_CTRL \ - (PAD_CTL_DSE_3P3V_49OHM | PAD_CTL_PUE | PAD_CTL_PUS_PU47KOHM) - #define NAND_PAD_CTRL (PAD_CTL_DSE_3P3V_49OHM | PAD_CTL_SRE_SLOW | PAD_CTL_HYS)
#define SPI_PAD_CTRL \ @@ -278,21 +275,8 @@ int board_phy_config(struct phy_device *phydev) #endif
#ifdef CONFIG_FSL_QSPI -static iomux_v3_cfg_t const quadspi_pads[] = { - MX7D_PAD_EPDC_DATA00__QSPI_A_DATA0 | MUX_PAD_CTRL(QSPI_PAD_CTRL), - MX7D_PAD_EPDC_DATA01__QSPI_A_DATA1 | MUX_PAD_CTRL(QSPI_PAD_CTRL), - MX7D_PAD_EPDC_DATA02__QSPI_A_DATA2 | MUX_PAD_CTRL(QSPI_PAD_CTRL), - MX7D_PAD_EPDC_DATA03__QSPI_A_DATA3 | MUX_PAD_CTRL(QSPI_PAD_CTRL), - MX7D_PAD_EPDC_DATA05__QSPI_A_SCLK | MUX_PAD_CTRL(QSPI_PAD_CTRL), - MX7D_PAD_EPDC_DATA06__QSPI_A_SS0_B | MUX_PAD_CTRL(QSPI_PAD_CTRL), -}; - int board_qspi_init(void) { - /* Set the iomux */ - imx_iomux_v3_setup_multiple_pads(quadspi_pads, - ARRAY_SIZE(quadspi_pads)); - /* Set the clock */ set_clk_qspi();
diff --git a/configs/mx7dsabresd_qspi_defconfig b/configs/mx7dsabresd_qspi_defconfig new file mode 100644 index 0000000..a798804 --- /dev/null +++ b/configs/mx7dsabresd_qspi_defconfig @@ -0,0 +1,83 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX7=y +CONFIG_SYS_TEXT_BASE=0x87800000 +CONFIG_TARGET_MX7DSABRESD=y +CONFIG_ARMV7_BOOT_SEC_DEFAULT=y +# CONFIG_ARMV7_VIRT is not set +CONFIG_IMX_RDC=y +CONFIG_IMX_BOOTAUX=y +# CONFIG_CMD_BMODE is not set +CONFIG_DEFAULT_DEVICE_TREE="imx7d-sdb-qspi" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx7dsabresd/imximage.cfg" +# CONFIG_CONSOLE_MUX is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_HUSH_PARSER=y +# CONFIG_CMD_BOOTD is not set +CONFIG_CMD_BOOTZ=y +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_DFU=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_BMP=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DFU_MMC=y +CONFIG_DFU_RAM=y +CONFIG_DM_GPIO=y +CONFIG_DM_74X164=y +CONFIG_DM_I2C=y +CONFIG_DM_MMC=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_MMC_UHS_SUPPORT=y +CONFIG_MMC_HS200_SUPPORT=y +CONFIG_FSL_ESDHC=y +CONFIG_FSL_QSPI=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_EON=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_PHYLIB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX7=y +CONFIG_DM_PMIC=y +CONFIG_DM_PMIC_PFUZE100=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_PFUZE100=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SOFT_SPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_MXC_USB_OTG_HACTIVE=y +CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="FSL" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 +CONFIG_CI_UDC=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y +CONFIG_VIDEO=y +CONFIG_ERRNO_STR=y diff --git a/include/configs/mx7dsabresd.h b/include/configs/mx7dsabresd.h index 87d2b52..3cd32ea 100644 --- a/include/configs/mx7dsabresd.h +++ b/include/configs/mx7dsabresd.h @@ -227,9 +227,7 @@ #endif
#ifdef CONFIG_FSL_QSPI -#define CONFIG_SPI_FLASH -#define CONFIG_SPI_FLASH_MACRONIX -#define CONFIG_SPI_FLASH_BAR +#define CONFIG_SYS_FSL_QSPI_AHB #define CONFIG_SF_DEFAULT_BUS 0 #define CONFIG_SF_DEFAULT_CS 0 #define CONFIG_SF_DEFAULT_SPEED 40000000
Hello Ye,
Since you have converted the i.mx6,i.mx7 series to DM model. It will worth to test your code after removing non-DM code from fsl_qspi.c code as well. Attaching patch for same.
Regards Ashish
-----Original Message----- From: Ye Li Sent: Wednesday, June 27, 2018 12:39 PM To: sbabic@denx.de; Peng Fan peng.fan@nxp.com; Ashish Kumar ashish.kumar@nxp.com; Fabio Estevam fabio.estevam@nxp.com Cc: u-boot@lists.denx.de Subject: [PATCH] imx: imx7d-sdb: Add DM QSPI support
On iMX7D SabreSD board, the QSPI has pins conflict with EPDC (default). To use QSPI, users have to rework the board (de-populate R388-R391, R396- R399 populate R392-R395, R299, R300). So we add new DTS file and new defconfig dedicated for QSPI.
- imx7d-sdb.dtb
- imx7d-sdb.dtb \
- imx7d-sdb-qspi.dtb
- Copyright (C) 2015 Freescale Semiconductor, Inc.
- Copyright 2018 NXP
+&iomuxc {
- qspi1 {
fsl,pins = <
0x51
0x51
0x51
0x51
0x51
0x51
+&qspi1 {
- pinctrl-names = "default";
- pinctrl-0 = <&pinctrl_qspi1_1>;
- status = "okay";
- ddrsmp=<0>;
- flash0: mx25l51245g@0 {
#size-cells = <1>;
reg = <0>;
- aliases {
spi5 = &soft_spi;
- memory { reg = <0x80000000 0x80000000>; };
- spi4 {
- soft_spi: soft-spi { compatible = "spi-gpio"; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_spi1>;
+&aips2 {
- epdc: epdc@306f0000 {
spi0 = &ecspi1;
spi1 = &ecspi2;
spi2 = &ecspi3;
spi3 = &ecspi4;
spi0 = &qspi1;
spi1 = &ecspi1;
spi2 = &ecspi2;
spi3 = &ecspi3;
spi4 = &ecspi4;
cpus {
#size-cells = <0>;
0x10000000>;
diff --git a/configs/mx7dsabresd_qspi_defconfig b/configs/mx7dsabresd_qspi_defconfig new file mode 100644 index 0000000..a798804 --- /dev/null +++ b/configs/mx7dsabresd_qspi_defconfig @@ -0,0 +1,83 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX7=y +CONFIG_SYS_TEXT_BASE=0x87800000 +CONFIG_TARGET_MX7DSABRESD=y +CONFIG_ARMV7_BOOT_SEC_DEFAULT=y +# CONFIG_ARMV7_VIRT is not set +CONFIG_IMX_RDC=y +CONFIG_IMX_BOOTAUX=y +# CONFIG_CMD_BMODE is not set +CONFIG_DEFAULT_DEVICE_TREE="imx7d-sdb-qspi" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx7dsabresd/i mximage.cfg" +# CONFIG_CONSOLE_MUX is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_HUSH_PARSER=y +# CONFIG_CMD_BOOTD is not set +CONFIG_CMD_BOOTZ=y +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_DFU=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_BMP=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DFU_MMC=y +CONFIG_DFU_RAM=y +CONFIG_DM_GPIO=y +CONFIG_DM_74X164=y +CONFIG_DM_I2C=y +CONFIG_DM_MMC=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_MMC_UHS_SUPPORT=y +CONFIG_MMC_HS200_SUPPORT=y +CONFIG_FSL_ESDHC=y +CONFIG_FSL_QSPI=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_EON=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_PHYLIB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX7=y +CONFIG_DM_PMIC=y +CONFIG_DM_PMIC_PFUZE100=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_PFUZE100=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SOFT_SPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_MXC_USB_OTG_HACTIVE=y +CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="FSL" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 +CONFIG_CI_UDC=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y +CONFIG_VIDEO=y +CONFIG_ERRNO_STR=y diff --git a/include/configs/mx7dsabresd.h b/include/configs/mx7dsabresd.h index 87d2b52..3cd32ea 100644 --- a/include/configs/mx7dsabresd.h +++ b/include/configs/mx7dsabresd.h @@ -227,9 +227,7 @@ #endif
2.7.4
Ashish Kumar
Ye Li
