[U-Boot] [PATCH] spi: fsl_qspi: Copy 16 byte aligned data in TX FIFO
In some of the QSPI controller version, there must be atleast 128bit data available in TX FIFO for any pop operation otherwise error bit will be set. The code will not make any behavior change for previous controller as the transfer data size in ipcr register is still the same.
Patch is tested on LS1046A which do not require 16 bytes aligned and LS1088A which require 16 bytes aligned data in TX FIFO
Signed-off-by: Suresh Gupta suresh.gupta@nxp.com Signed-off-by: Anupam Kumar anupam.kumar_1@nxp.com --- drivers/spi/fsl_qspi.c | 18 ++++++++---------- 1 file changed, 8 insertions(+), 10 deletions(-)
diff --git a/drivers/spi/fsl_qspi.c b/drivers/spi/fsl_qspi.c index e61c67b..d596377 100644 --- a/drivers/spi/fsl_qspi.c +++ b/drivers/spi/fsl_qspi.c @@ -659,22 +659,20 @@ static void qspi_op_write(struct fsl_qspi_priv *priv, u8 *txbuf, u32 len) tx_size = (len > TX_BUFFER_SIZE) ? TX_BUFFER_SIZE : len;
- size = tx_size / 4; - for (i = 0; i < size; i++) { + size = tx_size / 16; + /* + * There must be atleast 128bit data + * available in TX FIFO for any pop operation + */ + if (tx_size % 16) + size++; + for (i = 0; i < size * 4; i++) { memcpy(&data, txbuf, 4); data = qspi_endian_xchg(data); qspi_write32(priv->flags, ®s->tbdr, data); txbuf += 4; }
- size = tx_size % 4; - if (size) { - data = 0; - memcpy(&data, txbuf, size); - data = qspi_endian_xchg(data); - qspi_write32(priv->flags, ®s->tbdr, data); - } - qspi_write32(priv->flags, ®s->ipcr, (seqid << QSPI_IPCR_SEQID_SHIFT) | tx_size); while (qspi_read32(priv->flags, ®s->sr) & QSPI_SR_BUSY_MASK)
Can some one Tested and verified the result?
thanks!
Applied to u-boot-spi//master
thanks!
Jagan Teki
Suresh Gupta
