[U-Boot] [PATCH V3 1/3] imx-common/cmd_resetmode.c: add imx resetmode command
This is useful for forcing the ROM's usb downloader to activate upon a watchdog reset. Or, you can boot from either SD Card.
Currently, support added for MX53 and MX6Q Signed-off-by: Troy Kisky troy.kisky@boundarydevices.com
Note: MX53 support untested. --- arch/arm/cpu/armv7/imx-common/Makefile | 1 + arch/arm/cpu/armv7/imx-common/cmd_resetmode.c | 152 +++++++++++++++++++++++++ arch/arm/cpu/armv7/mx5/soc.c | 31 +++++ arch/arm/cpu/armv7/mx6/soc.c | 36 ++++++ arch/arm/include/asm/arch-mx5/imx-regs.h | 18 +++ arch/arm/include/asm/arch-mx6/imx-regs.h | 21 ++++ arch/arm/include/asm/imx-common/resetmode.h | 36 ++++++ 7 files changed, 295 insertions(+) create mode 100644 arch/arm/cpu/armv7/imx-common/cmd_resetmode.c create mode 100644 arch/arm/include/asm/imx-common/resetmode.h
V3 is same as V2, only a rebase.
diff --git a/arch/arm/cpu/armv7/imx-common/Makefile b/arch/arm/cpu/armv7/imx-common/Makefile index bf36be5..24f490e 100644 --- a/arch/arm/cpu/armv7/imx-common/Makefile +++ b/arch/arm/cpu/armv7/imx-common/Makefile @@ -29,6 +29,7 @@ LIB = $(obj)libimx-common.o
COBJS-y = iomux-v3.o timer.o cpu.o speed.o COBJS-$(CONFIG_I2C_MXC) += i2c.o +COBJS-$(CONFIG_CMD_RESETMODE) += cmd_resetmode.o COBJS := $(sort $(COBJS-y))
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) diff --git a/arch/arm/cpu/armv7/imx-common/cmd_resetmode.c b/arch/arm/cpu/armv7/imx-common/cmd_resetmode.c new file mode 100644 index 0000000..d1c50e1 --- /dev/null +++ b/arch/arm/cpu/armv7/imx-common/cmd_resetmode.c @@ -0,0 +1,152 @@ +/* + * Copyright (C) 2012 Boundary Devices Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> +#include <asm/errno.h> +#include <asm/io.h> +#include <asm/imx-common/resetmode.h> +#include <malloc.h> + +const struct reset_mode *modes[2]; + +const struct reset_mode *search_modes(char *arg) +{ + int i; + + for (i = 0; i < ARRAY_SIZE(modes); i++) { + const struct reset_mode *p = modes[i]; + if (p) { + while (p->name) { + if (!strcmp(p->name, arg)) + return p; + p++; + } + } + } + return NULL; +} + +int create_usage(char *dest) +{ + int i; + int size = 0; + + for (i = 0; i < ARRAY_SIZE(modes); i++) { + const struct reset_mode *p = modes[i]; + if (p) { + while (p->name) { + int len = strlen(p->name); + if (dest) { + memcpy(dest, p->name, len); + dest += len; + *dest++ = '|'; + } + size += len + 1; + p++; + } + } + } + if (dest) + dest[-1] = 0; + return size; +} + +int do_resetmode(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + const struct reset_mode *p; + + if (argc < 2) + return CMD_RET_USAGE; + p = search_modes(argv[1]); + if (!p) + return CMD_RET_USAGE; + reset_mode_apply(p->cfg_val); + return 0; +} + +U_BOOT_CMD( + resetmode, 2, 0, do_resetmode, + NULL, + ""); + +void add_board_resetmodes(const struct reset_mode *p) +{ + int size; + char *dest; + + if (__u_boot_cmd_resetmode.usage) { + free(__u_boot_cmd_resetmode.usage); + __u_boot_cmd_resetmode.usage = NULL; + } + + modes[0] = p; + modes[1] = soc_reset_modes; + size = create_usage(NULL); + dest = malloc(size); + if (dest) { + create_usage(dest); + __u_boot_cmd_resetmode.usage = dest; + } +} + +int do_resetmode_cmd(char *arg) +{ + const struct reset_mode *p; + + p = search_modes(arg); + if (!p) { + printf("%s not found\n", arg); + return CMD_RET_FAILURE; + } + reset_mode_apply(p->cfg_val); + do_reset(NULL, 0, 0, NULL); + return 0; +} + +int do_bootmmc0(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + return do_resetmode_cmd("mmc0"); +} + +int do_bootmmc1(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + return do_resetmode_cmd("mmc1"); +} + +int do_download_mode(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + return do_resetmode_cmd("usb"); +} + +U_BOOT_CMD( + bootmmc0, 1, 0, do_bootmmc0, + "boot to mmc 0", + ""); + +U_BOOT_CMD( + bootmmc1, 1, 0, do_bootmmc1, + "boot to mmc 1", + ""); + +U_BOOT_CMD( + download_mode, 1, 0, do_download_mode, + "start rom loader", + ""); diff --git a/arch/arm/cpu/armv7/mx5/soc.c b/arch/arm/cpu/armv7/mx5/soc.c index 3f5a4f7..9cd363b 100644 --- a/arch/arm/cpu/armv7/mx5/soc.c +++ b/arch/arm/cpu/armv7/mx5/soc.c @@ -30,6 +30,7 @@
#include <asm/errno.h> #include <asm/io.h> +#include <asm/imx-common/resetmode.h>
#if !(defined(CONFIG_MX51) || defined(CONFIG_MX53)) #error "CPU_TYPE not defined" @@ -115,3 +116,33 @@ void set_chipselect_size(int const cs_size)
writel(reg, &iomuxc_regs->gpr1); } + +#ifdef CONFIG_MX53 +void reset_mode_apply(unsigned cfg_val) +{ + writel(cfg_val, &((struct srtc_regs *)SRTC_BASE_ADDR)->lpgr); +} +/* + * cfg_val will be used for + * Boot_cfg3[7:0]:Boot_cfg2[7:0]:Boot_cfg1[7:0] + * + * If bit 28 of LPGR is set upon watchdog reset, + * bits[25:0] of LPGR will move to SBMR. + */ +const struct reset_mode soc_reset_modes[] = { + {"normal", MAKE_CFGVAL(0x00, 0x00, 0x00, 0x00)}, + /* usb or serial download */ + {"usb", MAKE_CFGVAL(0x00, 0x00, 0x00, 0x13)}, + {"sata", MAKE_CFGVAL(0x28, 0x00, 0x00, 0x12)}, + {"escpi1:0", MAKE_CFGVAL(0x38, 0x20, 0x00, 0x12)}, + {"escpi1:1", MAKE_CFGVAL(0x38, 0x20, 0x04, 0x12)}, + {"escpi1:2", MAKE_CFGVAL(0x38, 0x20, 0x08, 0x12)}, + {"escpi1:3", MAKE_CFGVAL(0x38, 0x20, 0x0c, 0x12)}, + /* 4 bit bus width */ + {"esdhc1", MAKE_CFGVAL(0x40, 0x20, 0x00, 0x12)}, + {"esdhc2", MAKE_CFGVAL(0x40, 0x20, 0x08, 0x12)}, + {"esdhc3", MAKE_CFGVAL(0x40, 0x20, 0x10, 0x12)}, + {"esdhc4", MAKE_CFGVAL(0x40, 0x20, 0x18, 0x12)}, + {NULL, 0}, +}; +#endif diff --git a/arch/arm/cpu/armv7/mx6/soc.c b/arch/arm/cpu/armv7/mx6/soc.c index 84b458c..7a7fb35 100644 --- a/arch/arm/cpu/armv7/mx6/soc.c +++ b/arch/arm/cpu/armv7/mx6/soc.c @@ -29,6 +29,7 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/clock.h> #include <asm/arch/sys_proto.h> +#include <asm/imx-common/resetmode.h>
u32 get_cpu_rev(void) { @@ -141,3 +142,38 @@ void imx_get_mac_from_fuse(int dev_id, unsigned char *mac)
} #endif + +void reset_mode_apply(unsigned cfg_val) +{ + unsigned reg; + struct src_regs *psrc = (struct src_regs *)SRC_BASE_ADDR; + writel(cfg_val, &psrc->gpr9); + reg = readl(&psrc->gpr10); + if (cfg_val) + reg |= 1 << 28; + else + reg &= ~(1 << 28); + writel(reg, &psrc->gpr10); +} +/* + * cfg_val will be used for + * Boot_cfg4[7:0]:Boot_cfg3[7:0]:Boot_cfg2[7:0]:Boot_cfg1[7:0] + * After reset, if GPR10[28] is 1, ROM will copy GPR9[25:0] + * to SBMR1, which will determine the boot device. + */ +const struct reset_mode soc_reset_modes[] = { + {"normal", MAKE_CFGVAL(0x00, 0x00, 0x00, 0x00)}, + /* reserved value should start rom usb */ + {"usb", MAKE_CFGVAL(0x01, 0x00, 0x00, 0x00)}, + {"sata", MAKE_CFGVAL(0x20, 0x00, 0x00, 0x00)}, + {"escpi1:0", MAKE_CFGVAL(0x30, 0x00, 0x00, 0x08)}, + {"escpi1:1", MAKE_CFGVAL(0x30, 0x00, 0x00, 0x18)}, + {"escpi1:2", MAKE_CFGVAL(0x30, 0x00, 0x00, 0x28)}, + {"escpi1:3", MAKE_CFGVAL(0x30, 0x00, 0x00, 0x38)}, + /* 4 bit bus width */ + {"esdhc1", MAKE_CFGVAL(0x40, 0x20, 0x00, 0x00)}, + {"esdhc2", MAKE_CFGVAL(0x40, 0x28, 0x00, 0x00)}, + {"esdhc3", MAKE_CFGVAL(0x40, 0x30, 0x00, 0x00)}, + {"esdhc4", MAKE_CFGVAL(0x40, 0x38, 0x00, 0x00)}, + {NULL, 0}, +}; diff --git a/arch/arm/include/asm/arch-mx5/imx-regs.h b/arch/arm/include/asm/arch-mx5/imx-regs.h index 7f66b61..c53465f 100644 --- a/arch/arm/include/asm/arch-mx5/imx-regs.h +++ b/arch/arm/include/asm/arch-mx5/imx-regs.h @@ -459,6 +459,24 @@ struct src { u32 simr; };
+struct srtc_regs { + u32 lpscmr; /* 0x00 */ + u32 lpsclr; /* 0x04 */ + u32 lpsar; /* 0x08 */ + u32 lpsmcr; /* 0x0c */ + u32 lpcr; /* 0x10 */ + u32 lpsr; /* 0x14 */ + u32 lppdr; /* 0x18 */ + u32 lpgr; /* 0x1c */ + u32 hpcmr; /* 0x20 */ + u32 hpclr; /* 0x24 */ + u32 hpamr; /* 0x28 */ + u32 hpalr; /* 0x2c */ + u32 hpcr; /* 0x30 */ + u32 hpisr; /* 0x34 */ + u32 hpienr; /* 0x38 */ +}; + /* CSPI registers */ struct cspi_regs { u32 rxdata; diff --git a/arch/arm/include/asm/arch-mx6/imx-regs.h b/arch/arm/include/asm/arch-mx6/imx-regs.h index 5d77603..dacb9ea 100644 --- a/arch/arm/include/asm/arch-mx6/imx-regs.h +++ b/arch/arm/include/asm/arch-mx6/imx-regs.h @@ -448,5 +448,26 @@ struct iomuxc_base_regs { u32 daisy[104]; /* 0x7b0..94c */ };
+struct src_regs { + u32 scr; /* 0x00 */ + u32 sbmr1; /* 0x04 */ + u32 srsr; /* 0x08 */ + u32 reserved1; /* 0x0c */ + u32 reserved2; /* 0x10 */ + u32 sisr; /* 0x14 */ + u32 simr; /* 0x18 */ + u32 sbmr2; /* 0x1c */ + u32 gpr1; /* 0x20 */ + u32 gpr2; /* 0x24 */ + u32 gpr3; /* 0x28 */ + u32 gpr4; /* 0x2c */ + u32 gpr5; /* 0x30 */ + u32 gpr6; /* 0x34 */ + u32 gpr7; /* 0x38 */ + u32 gpr8; /* 0x3c */ + u32 gpr9; /* 0x40 */ + u32 gpr10; /* 0x44 */ +}; + #endif /* __ASSEMBLER__*/ #endif /* __ASM_ARCH_MX6_IMX_REGS_H__ */ diff --git a/arch/arm/include/asm/imx-common/resetmode.h b/arch/arm/include/asm/imx-common/resetmode.h new file mode 100644 index 0000000..76216d0 --- /dev/null +++ b/arch/arm/include/asm/imx-common/resetmode.h @@ -0,0 +1,36 @@ +/* + * Copyright (C) 2012 Boundary Devices Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _ASM_RESETMODE_H +#define _ASM_RESETMODE_H +#define MAKE_CFGVAL(cfg1, cfg2, cfg3, cfg4) \ + ((cfg4) << 24) | ((cfg3) << 16) | ((cfg2) << 8) | (cfg1) + +struct reset_mode { + const char *name; + unsigned cfg_val; +}; + +void add_board_resetmodes(const struct reset_mode *p); +void reset_mode_apply(unsigned cfg_val); +extern const struct reset_mode soc_reset_modes[]; +#endif
This allows a watchdog reset to start the ROM's usb downloader, or boot from an sdcard.
Signed-off-by: Troy Kisky troy.kisky@boundarydevices.com --- board/freescale/mx6qsabrelite/mx6qsabrelite.c | 14 ++++++++++++++ include/configs/mx6qsabrelite.h | 3 +++ 2 files changed, 17 insertions(+)
diff --git a/board/freescale/mx6qsabrelite/mx6qsabrelite.c b/board/freescale/mx6qsabrelite/mx6qsabrelite.c index 01e5083..36e6f8f 100644 --- a/board/freescale/mx6qsabrelite/mx6qsabrelite.c +++ b/board/freescale/mx6qsabrelite/mx6qsabrelite.c @@ -29,6 +29,7 @@ #include <asm/gpio.h> #include <asm/imx-common/iomux-v3.h> #include <asm/imx-common/mxc_i2c.h> +#include <asm/imx-common/resetmode.h> #include <mmc.h> #include <fsl_esdhc.h> #include <micrel.h> @@ -487,10 +488,23 @@ static void preboot_keys(void) } #endif
+#ifdef CONFIG_CMD_RESETMODE +static const struct reset_mode board_reset_modes[] = { + /* 4 bit bus width */ + {"mmc0", MAKE_CFGVAL(0x40, 0x30, 0x00, 0x00)}, + {"mmc1", MAKE_CFGVAL(0x40, 0x38, 0x00, 0x00)}, + {NULL, 0}, +}; +#endif + int misc_init_r(void) { #ifdef CONFIG_PREBOOT preboot_keys(); #endif + +#ifdef CONFIG_CMD_RESETMODE + add_board_resetmodes(board_reset_modes); +#endif return 0; } diff --git a/include/configs/mx6qsabrelite.h b/include/configs/mx6qsabrelite.h index 0d376ba..8890286 100644 --- a/include/configs/mx6qsabrelite.h +++ b/include/configs/mx6qsabrelite.h @@ -117,6 +117,9 @@ #define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) #define CONFIG_MXC_USB_FLAGS 0
+/* Miscellaneous commands */ +#define CONFIG_CMD_RESETMODE + /* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE #define CONFIG_CONS_INDEX 1
This allows a watchdog reset to start the ROM's usb/serial downloader, or boot from an sdcard.
Compile tested only, I don't have a mx53evk. --- board/freescale/mx53evk/mx53evk.c | 13 +++++++++++++ include/configs/mx53evk.h | 3 +++ 2 files changed, 16 insertions(+)
diff --git a/board/freescale/mx53evk/mx53evk.c b/board/freescale/mx53evk/mx53evk.c index 8a6e31d..48499d6 100644 --- a/board/freescale/mx53evk/mx53evk.c +++ b/board/freescale/mx53evk/mx53evk.c @@ -28,6 +28,7 @@ #include <asm/arch/crm_regs.h> #include <asm/arch/iomux.h> #include <asm/errno.h> +#include <asm/imx-common/resetmode.h> #include <netdev.h> #include <i2c.h> #include <mmc.h> @@ -367,11 +368,23 @@ int board_init(void) return 0; }
+#ifdef CONFIG_CMD_RESETMODE +static const struct reset_mode board_reset_modes[] = { + /* 4 bit bus width */ + {"mmc0", MAKE_CFGVAL(0x40, 0x20, 0x00, 0x12)}, + {"mmc1", MAKE_CFGVAL(0x40, 0x20, 0x08, 0x12)}, + {NULL, 0}, +}; +#endif + int board_late_init(void) { setup_i2c(1); power_init();
diff --git a/include/configs/mx53evk.h b/include/configs/mx53evk.h index 67def93..44e0921 100644 --- a/include/configs/mx53evk.h +++ b/include/configs/mx53evk.h @@ -89,6 +89,9 @@ #define CONFIG_CMD_NET #define CONFIG_CMD_DATE
Hi Troy,
It can help me to understand your implementation if I can find in the documentation where this feature is implemented. I started wit MX53 and well, in the manual I see only that LPGR is a "general purpose register" and contains "user specific data".
Maybe I am searching in wrong places. Where can I find the description for the feature you have implemented ?
- Copyright (C) 2012 Boundary Devices Inc.
- project.
- MA 02111-1307 USA
- int i;
- for (i = 0; i < ARRAY_SIZE(modes); i++) {
if (p) {
while (p->name) {
return p;
p++;
- return NULL;
- int i;
- int size = 0;
if (p) {
while (p->name) {
if (dest) {
dest += len;
*dest++ = '|';
size += len + 1;
p++;
- if (dest)
dest[-1] = 0;
- return size;
- const struct reset_mode *p;
- if (argc < 2)
- p = search_modes(argv[1]);
- if (!p)
- reset_mode_apply(p->cfg_val);
+U_BOOT_CMD(
- resetmode, 2, 0, do_resetmode,
- NULL,
- int size;
- char *dest;
- if (__u_boot_cmd_resetmode.usage) {
- modes[0] = p;
- modes[1] = soc_reset_modes;
- size = create_usage(NULL);
- dest = malloc(size);
- if (dest) {
create_usage(dest);
- p = search_modes(arg);
- if (!p) {
- do_reset(NULL, 0, 0, NULL);
- return do_resetmode_cmd("mmc0");
- return do_resetmode_cmd("mmc1");
Why do you not pass the mode to do_resetmode_cmd() and let this function parse the argument, without these help functions ? Then we do not need to add new functions if we have, for example, mmc2 or mmc3.
Best regards, Stefano Babic
Hi Troy,
The only documentations I've found are in the freescale release of u-boot. cpu/arm_cortexa8/mx53/generic.c
void do_switch_mfgmode(void) { u32 reg; reg = readl(SRTC_BASE_ADDR + SRTC_LPGR); /* After set bit 28 of LPGR register of SRTC to 1, Set bit * [25:0] to specified value according to format of SBMR, * after trigger a watchdog reset, ROM will read Bit 28 and * then copy bit [25:0] of LPGR to SBMR, then ROM can enter * serial download mode.*/ reg |= 0x12000000; writel(reg, SRTC_BASE_ADDR + SRTC_LPGR); /* this watchdog reset will let chip enter mfgtool download * mode. */ do_reset(NULL, 0, 0, NULL); }
U_BOOT_CMD( download_mode, 1, 1, do_switch_mfgmode, "download_mode - enter i.MX serial/usb download mode\n", "");
and for mx6q by disassembling iMX6DQ_SPI_to_uSDHC3.bin and iMX6DQ_SPI_to_uSDHC4.bin
- project.
- MA 02111-1307 USA
- int i;
if (p) {
while (p->name) {
return p;
p++;
- return NULL;
- int i;
- int size = 0;
if (p) {
while (p->name) {
if (dest) {
dest += len;
*dest++ = '|';
size += len + 1;
p++;
- if (dest)
dest[-1] = 0;
- return size;
- if (argc < 2)
- if (!p)
+U_BOOT_CMD(
- NULL,
- int size;
- char *dest;
- modes[0] = p;
- if (dest) {
create_usage(dest);
- if (!p) {
These functions are requested shortcuts. "bootmmc0" is the same as "resetmode mmc0 && reset"
<snip>
Hi Troy,
As one of the few that made this request:
I take it back...
I was mostly after a single command that also performs 'reset', and agree with Stefano that an argument for the mode is a better implementation.
U-Boot> bootto usb U-Boot> bootto mmc
I'm also rethinking the request for 'resetmode' because of the conflict with 'reset' (i.e. 'res' is no longer a unique command-complete). The first implementation with 'rsmode' seemed to be an odd abbreviation.
Anybody else have a suggestion?
U-Boot> rstmode usb && reset U-Boot> bmode usb && reset
Regards,
Eric
Am 09/08/2012 21:29, schrieb Eric Nelson:
Hi Troy,
I take it back...
+1
Yes, there is no reason to have a conflict with "reset"
In Freescale documentation this is called "boot mode" - using the same terminology can reduce confusion. I do not discuss which name is better, but if someone reads the SOC's manual and then find a command for "boot mode", it is normal that he automatically knows what is going on. "Boot" conflicts with other u-boot command, then "bmode" is my first choice.
Hi Troy,
I take it back...
+1
O.K., how about this syntax
bmode mmc0|mmc1|usb|normal [noreset]
with immediate reset being the default. Perhaps, unless normal is specified, which won't reset?
Troy
<snip>
Hi Troy,
I take it back...
Regards,
Eric
How difficult would it be for someone to implement a general "alias" command ? ie. 'alias bootto "resetmode $1 && reset"'
Troy
<snip>
Hi Troy,
I take it back...
Regards,
Eric
It's usually a customer that asks the "How hard would it be?" question, but you can almost get there like this:
U-Boot> set mynewcommand "echo Hello" U-Boot> $mynewcommand Hello U-Boot> $mynewcommand World Hello World
That trailing "&&" is a problem though.
This does not work: you should issue "run $mynewcommand World"
And this let me slowly remember at:
http://www.denx.de/wiki/U-Boot/TaskHandleVarsLikeCommands
I completely forgotten this issue, and I have never update the status of my patch. Is ther estill some interest on this or have I missed something and now is the behavior in shell as in your example ?
Am 09/08/2012 20:48, schrieb Troy Kisky:
Well, it is sounds odd that we have to do reverse-engineering to implement features. Can some Freescalers here point out to some docs ? This feature is surely very useful - any hints to have more information ?
Eric Nelson
Stefano Babic
stefano babic
Troy Kisky
