[U-Boot] [PATCH 1/2][v3] armv8: ls2080a: Reorganise NAND_BOOT code in config flag
Add CONFIG_NAND_BOOT config flag to organise NAND_BOOT specific code in config flag like -nand-boot specfic errata errata_rcw_src() -CONFIG_SYS_NAND_U_BOOT_DST,etc
Signed-off-by: Santan Kumar santan.kumar@nxp.com Signed-off-by: Priyanka Jain priyanka.jain@nxp.com Signed-off-by: Abhimanyu Saini abhimanyu.saini@nxp.com --- Changes for v3: Rebased to latest codebase Incorporated York's comments to defined CONFIG_NAND_BOOT in new line
arch/arm/cpu/armv8/fsl-layerscape/soc.c | 2 +- configs/ls2080aqds_nand_defconfig | 1 + configs/ls2080ardb_nand_defconfig | 1 + include/configs/ls2080a_common.h | 5 +++++ include/configs/ls2080aqds.h | 4 +++- 5 files changed, 11 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index 9489f85..fa68baf 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -134,7 +134,7 @@ void erratum_a009635(void)
static void erratum_rcw_src(void) { -#if defined(CONFIG_SPL) +#if defined(CONFIG_SPL) && defined(CONFIG_NAND_BOOT) u32 __iomem *dcfg_ccsr = (u32 __iomem *)DCFG_BASE; u32 __iomem *dcfg_dcsr = (u32 __iomem *)DCFG_DCSR_BASE; u32 val; diff --git a/configs/ls2080aqds_nand_defconfig b/configs/ls2080aqds_nand_defconfig index 8910938..bc0b9b1 100644 --- a/configs/ls2080aqds_nand_defconfig +++ b/configs/ls2080aqds_nand_defconfig @@ -12,6 +12,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_NAND_BOOT=y CONFIG_SYS_EXTRA_OPTIONS="NAND, LS2080A" CONFIG_BOOTDELAY=10 CONFIG_SPL=y diff --git a/configs/ls2080ardb_nand_defconfig b/configs/ls2080ardb_nand_defconfig index 8223111..d449190 100644 --- a/configs/ls2080ardb_nand_defconfig +++ b/configs/ls2080ardb_nand_defconfig @@ -12,6 +12,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_NAND_BOOT=y CONFIG_SYS_EXTRA_OPTIONS="NAND, LS2080A" CONFIG_BOOTDELAY=10 CONFIG_SPL=y diff --git a/include/configs/ls2080a_common.h b/include/configs/ls2080a_common.h index 4173d9a..ae72939 100644 --- a/include/configs/ls2080a_common.h +++ b/include/configs/ls2080a_common.h @@ -216,6 +216,7 @@ unsigned long long get_qixis_addr(void);
#define CONFIG_PANIC_HANG /* do not reset board on panic */
+#ifdef CONFIG_SPL #define CONFIG_SPL_BSS_START_ADDR 0x80100000 #define CONFIG_SPL_BSS_MAX_SIZE 0x00100000 #define CONFIG_SPL_FRAMEWORK @@ -225,11 +226,15 @@ unsigned long long get_qixis_addr(void); #define CONFIG_SPL_TARGET "u-boot-with-spl.bin" #define CONFIG_SPL_TEXT_BASE 0x1800a000
+#ifdef CONFIG_NAND_BOOT +#define CONFIG_SPL_NAND_SUPPORT #define CONFIG_SYS_NAND_U_BOOT_DST 0x80400000 #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_NAND_U_BOOT_DST +#endif #define CONFIG_SYS_SPL_MALLOC_SIZE 0x00100000 #define CONFIG_SYS_SPL_MALLOC_START 0x80200000 #define CONFIG_SYS_MONITOR_LEN (640 * 1024) +#endif
#define CONFIG_SYS_BOOTM_LEN (64 << 20) /* Increase max gunzip size */
diff --git a/include/configs/ls2080aqds.h b/include/configs/ls2080aqds.h index 08d1586..93f6b51 100644 --- a/include/configs/ls2080aqds.h +++ b/include/configs/ls2080aqds.h @@ -197,7 +197,8 @@ unsigned long get_board_ddr_clk(void); FTIM2_GPCM_TWP(0x3E)) #define CONFIG_SYS_CS3_FTIM3 0x0
-#if defined(CONFIG_SPL) && defined(CONFIG_NAND) +#if defined(CONFIG_SPL) +#if defined(CONFIG_NAND_BOOT) #define CONFIG_SYS_CSPR1_EXT CONFIG_SYS_NOR0_CSPR_EXT #define CONFIG_SYS_CSPR1 CONFIG_SYS_NOR0_CSPR_EARLY #define CONFIG_SYS_CSPR1_FINAL CONFIG_SYS_NOR0_CSPR @@ -233,6 +234,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SPL_PAD_TO 0x20000 #define CONFIG_SYS_NAND_U_BOOT_OFFS (256 * 1024) #define CONFIG_SYS_NAND_U_BOOT_SIZE (640 * 1024) +#endif #else #define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NOR0_CSPR_EXT #define CONFIG_SYS_CSPR0 CONFIG_SYS_NOR0_CSPR_EARLY
Depends on York MMU patches: http://patchwork.ozlabs.org/bundle/yorksun/Rewrite_MMU/ For correct type of image creation: https://patchwork.ozlabs.org/patch/671466/
arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 6 +-- .../cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c | 6 +-- board/freescale/ls2080a/ls2080a.c | 6 +-- board/freescale/ls2080aqds/eth.c | 8 +--- board/freescale/ls2080aqds/ls2080aqds.c | 4 +- configs/ls2080aqds_sdcard_defconfig | 53 ++++++++++++++++++++++ include/configs/ls2080a_common.h | 9 ++++ include/configs/ls2080aqds.h | 33 ++++++++++++-- 8 files changed, 105 insertions(+), 20 deletions(-) create mode 100644 configs/ls2080aqds_sdcard_defconfig
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c index 17258a7..d9e2a90 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c @@ -435,7 +435,7 @@ int cpu_eth_init(bd_t *bis) { int error = 0;
-#ifdef CONFIG_FSL_MC_ENET +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) error = fsl_mc_ldpaa_init(bis); #endif #ifdef CONFIG_FMAN_ENET @@ -571,7 +571,7 @@ phys_size_t board_reserve_ram_top(phys_size_t ram_size) { phys_size_t ram_top = ram_size;
-#ifdef CONFIG_FSL_MC_ENET +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) /* The start address of MC reserved memory needs to be aligned. */ ram_top -= mc_get_dram_block_size(); ram_top &= ~(CONFIG_SYS_MC_RSV_MEM_ALIGN - 1); @@ -686,7 +686,7 @@ void dram_init_banksize(void) } #endif /* CONFIG_SYS_MEM_RESERVE_SECURE */
-#ifdef CONFIG_FSL_MC_ENET +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) /* Assign memory for MC */ #ifdef CONFIG_SYS_DDR_BLOCK3_BASE if (gd->bd->bi_dram[2].size >= diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c index 7faa86c..10d7f47 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c @@ -18,7 +18,7 @@ static u8 serdes1_prtcl_map[SERDES_PRCTL_COUNT]; static u8 serdes2_prtcl_map[SERDES_PRCTL_COUNT]; #endif
-#ifdef CONFIG_FSL_MC_ENET +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) int xfi_dpmac[XFI8 + 1]; int sgmii_dpmac[SGMII16 + 1]; #endif @@ -103,7 +103,7 @@ void serdes_init(u32 sd, u32 sd_addr, u32 sd_prctl_mask, u32 sd_prctl_shift, debug("Unknown SerDes lane protocol %d\n", lane_prtcl); else { serdes_prtcl_map[lane_prtcl] = 1; -#ifdef CONFIG_FSL_MC_ENET +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) switch (lane_prtcl) { case QSGMII_A: wriop_init_dpmac(sd, 5, (int)lane_prtcl); @@ -152,7 +152,7 @@ void serdes_init(u32 sd, u32 sd_addr, u32 sd_prctl_mask, u32 sd_prctl_shift,
void fsl_serdes_init(void) { -#ifdef CONFIG_FSL_MC_ENET +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) int i , j;
for (i = XFI1, j = 1; i <= XFI8; i++, j++) diff --git a/board/freescale/ls2080a/ls2080a.c b/board/freescale/ls2080a/ls2080a.c index ace5bf6..cff468b 100644 --- a/board/freescale/ls2080a/ls2080a.c +++ b/board/freescale/ls2080a/ls2080a.c @@ -64,13 +64,13 @@ int board_eth_init(bd_t *bis) error = smc91111_initialize(0, CONFIG_SMC91111_BASE); #endif
-#ifdef CONFIG_FSL_MC_ENET +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) error = cpu_eth_init(bis); #endif return error; }
-#ifdef CONFIG_FSL_MC_ENET +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) void fdt_fixup_board_enet(void *fdt) { int offset; @@ -128,7 +128,7 @@ int ft_board_setup(void *blob, bd_t *bd)
fdt_fixup_memory_banks(blob, base, size, 2);
-#ifdef CONFIG_FSL_MC_ENET +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) fdt_fixup_board_enet(blob); #endif
diff --git a/board/freescale/ls2080aqds/eth.c b/board/freescale/ls2080aqds/eth.c index 59361e9..302ff76 100644 --- a/board/freescale/ls2080aqds/eth.c +++ b/board/freescale/ls2080aqds/eth.c @@ -22,7 +22,7 @@
#define MC_BOOT_ENV_VAR "mcinitcmd"
-#ifdef CONFIG_FSL_MC_ENET +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) /* - In LS2080A there are only 16 SERDES lanes, spread across 2 SERDES banks. * Bank 1 -> Lanes A, B, C, D, E, F, G, H * Bank 2 -> Lanes A,B, C, D, E, F, G, H @@ -834,8 +834,8 @@ void ls2080a_handle_phy_interface_xsgmii(int i) int board_eth_init(bd_t *bis) { int error; +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) char *mc_boot_env_var; -#ifdef CONFIG_FSL_MC_ENET struct ccsr_gur __iomem *gur = (void *)CONFIG_SYS_FSL_GUTS_ADDR; int serdes1_prtcl = (in_le32(&gur->rcwsr[28]) & FSL_CHASSIS3_RCWSR28_SRDS1_PRTCL_MASK) @@ -918,7 +918,3 @@ int board_eth_init(bd_t *bis) error = pci_eth_init(bis); return error; } - -#ifdef CONFIG_FSL_MC_ENET - -#endif diff --git a/board/freescale/ls2080aqds/ls2080aqds.c b/board/freescale/ls2080aqds/ls2080aqds.c index 291df4c..2ed8b42 100644 --- a/board/freescale/ls2080aqds/ls2080aqds.c +++ b/board/freescale/ls2080aqds/ls2080aqds.c @@ -264,7 +264,7 @@ int arch_misc_init(void) } #endif
-#ifdef CONFIG_FSL_MC_ENET +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) void fdt_fixup_board_enet(void *fdt) { int offset; @@ -320,7 +320,7 @@ int ft_board_setup(void *blob, bd_t *bd)
fsl_fdt_fixup_dr_usb(blob, bd);
diff --git a/configs/ls2080aqds_sdcard_defconfig b/configs/ls2080aqds_sdcard_defconfig new file mode 100644 index 0000000..874d49e --- /dev/null +++ b/configs/ls2080aqds_sdcard_defconfig @@ -0,0 +1,53 @@ +CONFIG_ARM=y +CONFIG_TARGET_LS2080AQDS=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SPL_I2C_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_ENV_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2080a-qds" +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4, LS2080A" +CONFIG_SD_BOOT=y +CONFIG_BOOTDELAY=10 +CONFIG_SPL=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x8b0 +CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_OF_EMBED=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM=y +CONFIG_DM_SPI_FLASH=y +CONFIG_NETDEVICES=y +CONFIG_E1000=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y +CONFIG_SYS_NS16550=y +CONFIG_DM_SPI=y +CONFIG_FSL_QSPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_STORAGE=y +CONFIG_EFI_LOADER_BOUNCE_BUFFER=y diff --git a/include/configs/ls2080a_common.h b/include/configs/ls2080a_common.h index ae72939..610dfe9 100644 --- a/include/configs/ls2080a_common.h +++ b/include/configs/ls2080a_common.h @@ -200,9 +200,16 @@ unsigned long long get_qixis_addr(void); "earlycon=uart8250,mmio,0x21c0500 " \ "ramdisk_size=0x2000000 default_hugepagesz=2m" \ " hugepagesz=2m hugepages=256" +#if defined(CONFIG_SD_BOOT) +#define CONFIG_BOOTCOMMAND "mmcinfo;mmc read 0x80200000 0x3800 0x800;"\ + " fsl_mc apply dpl 0x80200000 &&" \ + " mmc read $kernel_load $kernel_start" \ + " $kernel_size && bootm $kernel_load" +#else #define CONFIG_BOOTCOMMAND "fsl_mc apply dpl 0x580700000 &&" \ " cp.b $kernel_start $kernel_load" \ " $kernel_size && bootm $kernel_load" +#endif
/* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ @@ -230,6 +237,8 @@ unsigned long long get_qixis_addr(void); #define CONFIG_SPL_NAND_SUPPORT #define CONFIG_SYS_NAND_U_BOOT_DST 0x80400000 #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_NAND_U_BOOT_DST +#elif defined(CONFIG_SD_BOOT) +#define CONFIG_SPL_MMC_SUPPORT #endif #define CONFIG_SYS_SPL_MALLOC_SIZE 0x00100000 #define CONFIG_SYS_SPL_MALLOC_START 0x80200000 diff --git a/include/configs/ls2080aqds.h b/include/configs/ls2080aqds.h index 93f6b51..d3eea59 100644 --- a/include/configs/ls2080aqds.h +++ b/include/configs/ls2080aqds.h @@ -116,7 +116,9 @@ unsigned long get_board_ddr_clk(void); CONFIG_SYS_FLASH_BASE + 0x40000000} #endif
+#ifndef CONFIG_FSL_QSPI #define CONFIG_NAND_FSL_IFC +#endif #define CONFIG_SYS_NAND_MAX_ECCPOS 256 #define CONFIG_SYS_NAND_MAX_OOBFREE 2
@@ -151,10 +153,12 @@ unsigned long get_board_ddr_clk(void); FTIM2_NAND_TWHRE(0x1e)) #define CONFIG_SYS_NAND_FTIM3 0x0
+#ifndef CONFIG_FSL_QSPI #define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE } #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_MTD_NAND_VERIFY_WRITE #define CONFIG_CMD_NAND +#endif
#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024)
@@ -165,12 +169,14 @@ unsigned long get_board_ddr_clk(void); #define QIXIS_LBMAP_DFLTBANK 0x00 #define QIXIS_LBMAP_ALTBANK 0x04 #define QIXIS_LBMAP_NAND 0x09 +#define QIXIS_LBMAP_SD 0x00 #define QIXIS_LBMAP_QSPI 0x0f #define QIXIS_RST_CTL_RESET 0x31 #define QIXIS_RCFG_CTL_RECONFIG_IDLE 0x20 #define QIXIS_RCFG_CTL_RECONFIG_START 0x21 #define QIXIS_RCFG_CTL_WATCHDOG_ENBLE 0x08 #define QIXIS_RCW_SRC_NAND 0x107 +#define QIXIS_RCW_SRC_SD 0x40 #define QIXIS_RCW_SRC_QSPI 0x62 #define QIXIS_RST_FORCE_MEM 0x01
@@ -234,6 +240,11 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SPL_PAD_TO 0x20000 #define CONFIG_SYS_NAND_U_BOOT_OFFS (256 * 1024) #define CONFIG_SYS_NAND_U_BOOT_SIZE (640 * 1024) +#elif defined(CONFIG_SD_BOOT) +#define CONFIG_ENV_OFFSET 0x200000 +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_ENV_SIZE 0x20000 #endif #else #define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NOR0_CSPR_EXT @@ -374,7 +385,23 @@ unsigned long get_board_ddr_clk(void); "esbc_validate 0x580cc0000;" \ "fsl_mc start mc 0x580300000" \ " 0x580800000 \0" -#else +#endif /* CONFIG_SECURE_BOOT */ +#ifdef CONFIG_SD_BOOT +#define CONFIG_EXTRA_ENV_SETTINGS \ + "hwconfig=fsl_ddr:bank_intlv=auto\0" \ + "loadaddr=0x80100000\0" \ + "kernel_addr=0x800\0" \ + "ramdisk_addr=0x800000\0" \ + "ramdisk_size=0x2000000\0" \ + "fdt_high=0xa0000000\0" \ + "initrd_high=0xffffffffffffffff\0" \ + "kernel_start=0x8800\0" \ + "kernel_load=0xa0000000\0" \ + "kernel_size=0x14000\0" \ + "mcinitcmd=mmcinfo;mmc read 0x80000000 0x1800 0x800;" \ + "mmc read 0x80100000 0x4000 0x800;" \ + "fsl_mc start mc 0x80000000 0x80100000\0" +#else /* NOR_BOOT */ #define CONFIG_EXTRA_ENV_SETTINGS \ "hwconfig=fsl_ddr:bank_intlv=auto\0" \ "loadaddr=0x80100000\0" \ @@ -388,10 +415,10 @@ unsigned long get_board_ddr_clk(void); "kernel_size=0x2800000\0" \ "mcinitcmd=fsl_mc start mc 0x580300000" \ " 0x580800000 \0" -#endif /* CONFIG_SECURE_BOOT */ +#endif
-#ifdef CONFIG_FSL_MC_ENET +#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) #define CONFIG_FSL_MEMAC #define CONFIG_PHYLIB #define CONFIG_PHYLIB_10G
+#ifdef CONFIG_SPL
Why this?
This is a Kconfig option. Please select it properly.
Since you are reorganizing NAND boot, can you comb through all Layerscape NAND boot and make them consistent in the sense of location in RAM, malloc space, etc.? Or even better, can you also take SD boot and make them consistent? I would like to see the RAM version at the same location, with plenty of space ahead of it (may be used for falcon boot).
York
-----Original Message----- From: york sun Sent: Saturday, March 25, 2017 10:30 PM To: Santan Kumar santan.kumar@nxp.com; u-boot@lists.denx.de Cc: Priyanka Jain priyanka.jain@nxp.com; Abhimanyu Saini abhimanyu.saini@nxp.com Subject: Re: [PATCH 1/2][v3] armv8: ls2080a: Reorganise NAND_BOOT code in config flag
code
line
+#ifdef CONFIG_SPL
Why this?
[Santan Kumar] yes we don't required this I will remove it.
[Santan Kumar] I will remove it since it is there in kconfig.
size */
York
[Santan Kumar] : To do this I need to have more understanding about the code. I will analyze this in detail and send a separate patch later. Is it fine?
On 03/30/2017 11:47 PM, Santan Kumar wrote:
<snip>
York
Yes. A follow up patch is my expectation.
York
Santan Kumar
york sun
