[U-Boot] [PATCH] arm/imx-common: Fix warning 'get_reset_cause' defined but not used
Fix below warning arch/arm/imx-common/cpu.c:29:14: warning: ‘get_reset_cause’ defined but not used static char *get_reset_cause(void)
Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com --- arch/arm/imx-common/cpu.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/imx-common/cpu.c b/arch/arm/imx-common/cpu.c index 067d08f..0cd08cb 100644 --- a/arch/arm/imx-common/cpu.c +++ b/arch/arm/imx-common/cpu.c @@ -24,6 +24,7 @@ #include <fsl_esdhc.h> #endif
+#if defined(CONFIG_DISPLAY_CPUINFO) static u32 reset_cause = -1;
static char *get_reset_cause(void) @@ -60,6 +61,7 @@ u32 get_imx_reset_cause(void) { return reset_cause; } +#endif
#if defined(CONFIG_MX53) || defined(CONFIG_MX6) #if defined(CONFIG_MX53)
Hi Prabhakar,
This makes the dependency clear, even if it's odd.
Reviewed-by: Eric Nelson eric.nelson@boundarydevices.com
Hi Prabhakar, Eric,
On 18/05/2015 16:44, Eric Nelson wrote:
Hi Prabhakar,
Yes, anyway this is what we already use for other SOCs (iMX31, iMX35,.. they have a local get_reset_cause() protected by this switch).
Acked-by: Stefano Babic sbabic@denx.de
Best regards, Stefano babic
Best regards, Stefano Babic
Eric Nelson
Prabhakar Kushwaha
Stefano Babic
