[U-Boot] [RFC PATCH v2 0/13] Enable driver model for GPIOs on Tegra
Now that driver model is part of U-Boot, the task of converting drivers over to it begins. GPIO is one of the easiest to convert, since it already has a sandbox driver and a uclass driver.
The Tegra GPIO driver is relatively simple since it has a linear numbering and already uses the generic GPIO framework.
Along the way some minor deficiencies were found with driver model - these are corrected in this series.
Also it was difficult to exhaustively test the new driver against the old, so a new 'iotrace' framework was created to make this easier for future driver authors.
This series has been tested on Trimslice (Tegra 20). I will try it on a beaver also.
Changes in v3: - Remove use of bool in header file to avoid exynos5 build failure - Create a symlink for each arch to dt-bindings - Bring in GPIO bindings for tegra{30,114,124} also - Fix typo in commit subject - Enable dm command in this patch instead of the next - Move dm command enable to previous patch - Use gpio number for the internal helper functions
Changes in v2: - Add a new patch for an I/O tracing feature - Add a new patch to enable iotrace for arm - Add a new patch to enable iotrace for sandbox - Add new patch to support include files for .dts files - Add new patch to bring in Tegra device tree files from linux - Update README to encourage conversion to driver model - Add new patch to use case-insensitive comparison for GPIO banks - Add new patch to add missing header files in lists and root - Add new patch to deal with const-ness of the global_data pointer - Add new patch to allow driver model tests only for sandbox - Add new patch to fix printf() strings in the 'dm' command - Split out a separate patch to enable driver model for tegra - Split out driver model changes into separate patches - Correct bugs found during testing
Simon Glass (13): Add an I/O tracing feature arm: Support iotrace feature sandbox: Support iotrace feature Makefile: Support include files for .dts files tegra: dts: Bring in GPIO bindings from linux dm: Update README to encourage conversion to driver model dm: Use case-insensitive comparison for GPIO banks dm: Add missing header files in lists and root dm: Cast away the const-ness of the global_data pointer dm: Allow driver model tests only for sandbox dm: Fix printf() strings in the 'dm' command tegra: Enable driver model tegra: Convert tegra GPIO driver to use driver model
README | 28 ++ arch/arm/dts/include/dt-bindings | 1 + arch/arm/dts/tegra114.dtsi | 21 +- arch/arm/dts/tegra124.dtsi | 23 +- arch/arm/dts/tegra20.dtsi | 15 +- arch/arm/dts/tegra30.dtsi | 21 +- arch/arm/include/asm/arch-tegra/gpio.h | 14 +- arch/arm/include/asm/io.h | 3 + arch/microblaze/dts/include/dt-bindings | 1 + arch/sandbox/dts/include/dt-bindings | 1 + arch/sandbox/include/asm/io.h | 10 + arch/x86/dts/include/dt-bindings | 1 + board/nvidia/seaboard/seaboard.c | 2 +- common/Makefile | 2 + common/cmd_iotrace.c | 73 +++++ common/iotrace.c | 169 +++++++++++ drivers/core/lists.c | 1 + drivers/core/root.c | 7 +- drivers/core/uclass.c | 2 +- drivers/gpio/gpio-uclass.c | 2 +- drivers/gpio/tegra_gpio.c | 313 +++++++++++++++++---- include/configs/sandbox.h | 3 + include/configs/tegra-common.h | 4 + include/dm/device-internal.h | 4 + include/dt-bindings/gpio/gpio.h | 15 + include/dt-bindings/gpio/tegra-gpio.h | 51 ++++ include/dt-bindings/interrupt-controller/arm-gic.h | 22 ++ include/dt-bindings/interrupt-controller/irq.h | 19 ++ include/iotrace.h | 104 +++++++ scripts/Makefile.lib | 1 + test/dm/Makefile | 2 + test/dm/cmd_dm.c | 19 +- 32 files changed, 849 insertions(+), 105 deletions(-) create mode 120000 arch/arm/dts/include/dt-bindings create mode 120000 arch/microblaze/dts/include/dt-bindings create mode 120000 arch/sandbox/dts/include/dt-bindings create mode 120000 arch/x86/dts/include/dt-bindings create mode 100644 common/cmd_iotrace.c create mode 100644 common/iotrace.c create mode 100644 include/dt-bindings/gpio/gpio.h create mode 100644 include/dt-bindings/gpio/tegra-gpio.h create mode 100644 include/dt-bindings/interrupt-controller/arm-gic.h create mode 100644 include/dt-bindings/interrupt-controller/irq.h create mode 100644 include/iotrace.h
When debugging drivers it is useful to see what I/O accesses were done and in what order.
Even if the individual accesses are of little interest it can be useful to verify that the access pattern is consistent each time an operation is performed. In this case a checksum can be used to characterise the operation of a driver. The checksum can be compared across different runs of the operation to verify that the driver is working properly.
In particular, when performing major refactoring of the driver, where the access pattern should not change, the checksum provides assurance that the refactoring work has not broken the driver.
Add an I/O tracing feature and associated commands to provide this facility. It works by sneaking into the io.h heder for an architecture and redirecting I/O accesses through its tracing mechanism.
For now no commands are provided to examine the trace buffer. The format is fairly simple, so 'md' is a reasonable substitute.
Note: The checksum feature is only useful for I/O regions where the contents do not change outside of software control. Where this is not suitable you can fall back to manually comparing the addresses. It might be useful to enhance tracing to only checksum the accesses and not the data read/written.
README | 23 +++++++ common/Makefile | 2 + common/cmd_iotrace.c | 73 ++++++++++++++++++++++ common/iotrace.c | 169 +++++++++++++++++++++++++++++++++++++++++++++++++++ include/iotrace.h | 104 +++++++++++++++++++++++++++++++ 5 files changed, 371 insertions(+) create mode 100644 common/cmd_iotrace.c create mode 100644 common/iotrace.c create mode 100644 include/iotrace.h
diff --git a/README b/README index b973344..b226458 100644 --- a/README +++ b/README @@ -987,6 +987,7 @@ The following options need to be configured: CONFIG_CMD_IMLS List all images found in NOR flash CONFIG_CMD_IMLS_NAND * List all images found in NAND flash CONFIG_CMD_IMMAP * IMMR dump support + CONFIG_CMD_IOTRACE * I/O tracing for debugging CONFIG_CMD_IMPORTENV * import an environment CONFIG_CMD_INI * import data from an ini file into the env CONFIG_CMD_IRQ * irqinfo @@ -1158,6 +1159,28 @@ The following options need to be configured: Note that if the GPIO device uses I2C, then the I2C interface must also be configured. See I2C Support, below.
+- I/O tracing: + When CONFIG_IO_TRACE is selected, U-Boot intercepts all I/O + accesses and can checksum them or write a list of them out + to memory. See the 'iotrace' command for details. This is + useful for testing device drivers since it can confirm that + the driver behaves the same way before and after a code + change. Currently this is supported on sandbox and arm. To + add support for your architecture, add '#include <iotrace.h>' + to the bottom of arch/<arch>/include/asm/io.h and test. + + Example output from the 'iotrace stats' command is below. + Note that if the trace buffer is exhausted, the checksum will + still continue to operate. + + iotrace is enabled + Start: 10000000 (buffer start address) + Size: 00010000 (buffer size) + Offset: 00000120 (current buffer offset) + Output: 10000120 (start + offset) + Count: 00000018 (number of trace records) + CRC32: 9526fb66 (CRC32 of all trace records) + - Timestamp Support:
When CONFIG_TIMESTAMP is selected, the timestamp diff --git a/common/Makefile b/common/Makefile index 7c853ae..0dccb90 100644 --- a/common/Makefile +++ b/common/Makefile @@ -96,6 +96,7 @@ obj-$(CONFIG_CMD_FUSE) += cmd_fuse.o obj-$(CONFIG_CMD_GETTIME) += cmd_gettime.o obj-$(CONFIG_CMD_GPIO) += cmd_gpio.o obj-$(CONFIG_CMD_I2C) += cmd_i2c.o +obj-$(CONFIG_CMD_IOTRACE) += cmd_iotrace.o obj-$(CONFIG_CMD_HASH) += cmd_hash.o obj-$(CONFIG_CMD_IDE) += cmd_ide.o obj-$(CONFIG_CMD_IMMAP) += cmd_immap.o @@ -240,6 +241,7 @@ obj-y += image.o obj-$(CONFIG_OF_LIBFDT) += image-fdt.o obj-$(CONFIG_FIT) += image-fit.o obj-$(CONFIG_FIT_SIGNATURE) += image-sig.o +obj-$(CONFIG_IO_TRACE) += iotrace.o obj-y += memsize.o obj-y += stdio.o
diff --git a/common/cmd_iotrace.c b/common/cmd_iotrace.c new file mode 100644 index 0000000..f54276d --- /dev/null +++ b/common/cmd_iotrace.c @@ -0,0 +1,73 @@ +/* + * Copyright (c) 2014 Google, Inc + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <command.h> +#include <iotrace.h> + +static void do_print_stats(void) +{ + ulong start, size, offset, count; + + printf("iotrace is %sabled\n", iotrace_get_enabled() ? "en" : "dis"); + iotrace_get_buffer(&start, &size, &offset, &count); + printf("Start: %08lx\n", start); + printf("Size: %08lx\n", size); + printf("Offset: %08lx\n", offset); + printf("Output: %08lx\n", start + offset); + printf("Count: %08lx\n", count); + printf("CRC32: %08lx\n", (ulong)iotrace_get_checksum()); +} + +static int do_set_buffer(int argc, char * const argv[]) +{ + ulong addr = 0, size = 0; + + if (argc == 2) { + addr = simple_strtoul(*argv++, NULL, 16); + size = simple_strtoul(*argv++, NULL, 16); + } else if (argc != 0) { + return CMD_RET_USAGE; + } + + iotrace_set_buffer(addr, size); + + return 0; +} + +int do_iotrace(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + const char *cmd = argc < 2 ? NULL : argv[1]; + + if (!cmd) + return cmd_usage(cmdtp); + switch (*cmd) { + case 'b': + return do_set_buffer(argc - 2, argv + 2); + case 'p': + iotrace_set_enabled(0); + break; + case 'r': + iotrace_set_enabled(1); + break; + case 's': + do_print_stats(); + break; + default: + return CMD_RET_USAGE; + } + + return 0; +} + +U_BOOT_CMD( + iotrace, 4, 1, do_iotrace, + "iotrace utility commands", + "stats - display iotrace stats\n" + "iotrace buffer <address> <size> - set iotrace buffer\n" + "iotrace pause - pause tracing\n" + "iotrace resume - resume tracing" +); diff --git a/common/iotrace.c b/common/iotrace.c new file mode 100644 index 0000000..ced426e --- /dev/null +++ b/common/iotrace.c @@ -0,0 +1,169 @@ +/* + * Copyright (c) 2014 Google, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#define IOTRACE_IMPL + +#include <common.h> +#include <asm/io.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* Support up to the machine word length for now */ +typedef ulong iovalue_t; + +enum iotrace_flags { + IOT_8 = 0, + IOT_16, + IOT_32, + + IOT_READ = 0 << 3, + IOT_WRITE = 1 << 3, +}; + +/** + * struct iotrace_record - Holds a single I/O trace record + * + * @flags: I/O access type + * @addr: Address of access + * @value: Value written or read + */ +struct iotrace_record { + enum iotrace_flags flags; + phys_addr_t addr; + iovalue_t value; +}; + +/** + * struct iotrace - current trace status and checksum + * + * @start: Start address of iotrace buffer + * @size: Size of iotrace buffer in bytes + * @offset: Current write offset into iotrace buffer + * @crc32: Current value of CRC chceksum of trace records + * @enabled: true if enabled, false if disabled + */ +static struct iotrace { + ulong start; + ulong size; + ulong offset; + u32 crc32; + bool enabled; +} iotrace; + +static void add_record(int flags, const void *ptr, ulong value) +{ + struct iotrace_record srec, *rec = &srec; + + /* + * We don't support iotrace before relocation. Since the trace buffer + * is set up by a command, it can't be enabled at present. To change + * this we would need to set the iotrace buffer at build-time. See + * lib/trace.c for how this might be done if you are interested. + */ + if (!(gd->flags & GD_FLG_RELOC) || !iotrace.enabled) + return; + + /* Store it if there is room */ + if (iotrace.offset + sizeof(*rec) < iotrace.size) { + rec = (struct iotrace_record *)map_sysmem( + iotrace.start + iotrace.offset, + sizeof(value)); + } + + rec->flags = flags; + rec->addr = map_to_sysmem(ptr); + rec->value = value; + + /* Update our checksum */ + iotrace.crc32 = crc32(iotrace.crc32, (unsigned char *)rec, + sizeof(*rec)); + + iotrace.offset += sizeof(struct iotrace_record); +} + +u32 iotrace_readl(const void *ptr) +{ + u32 v; + + v = readl(ptr); + add_record(IOT_32 | IOT_READ, ptr, v); + + return v; +} + +void iotrace_writel(ulong value, const void *ptr) +{ + add_record(IOT_32 | IOT_WRITE, ptr, value); + writel(value, ptr); +} + +u16 iotrace_readw(const void *ptr) +{ + u32 v; + + v = readw(ptr); + add_record(IOT_16 | IOT_READ, ptr, v); + + return v; +} + +void iotrace_writew(ulong value, const void *ptr) +{ + add_record(IOT_16 | IOT_WRITE, ptr, value); + writew(value, ptr); +} + +u8 iotrace_readb(const void *ptr) +{ + u32 v; + + v = readb(ptr); + add_record(IOT_8 | IOT_READ, ptr, v); + + return v; +} + +void iotrace_writeb(ulong value, const void *ptr) +{ + add_record(IOT_8 | IOT_WRITE, ptr, value); + writeb(value, ptr); +} + +void iotrace_reset_checksum(void) +{ + iotrace.crc32 = 0; +} + +u32 iotrace_get_checksum(void) +{ + return iotrace.crc32; +} + +void iotrace_set_enabled(int enable) +{ + iotrace.enabled = enable; +} + +int iotrace_get_enabled(void) +{ + return iotrace.enabled; +} + +void iotrace_set_buffer(ulong start, ulong size) +{ + iotrace.start = start; + iotrace.size = size; + iotrace.offset = 0; + iotrace.crc32 = 0; +} + +void iotrace_get_buffer(ulong *start, ulong *size, ulong *offset, ulong *count) +{ + *start = iotrace.start; + *size = iotrace.size; + *offset = iotrace.offset; + *count = iotrace.offset / sizeof(struct iotrace_record); +} diff --git a/include/iotrace.h b/include/iotrace.h new file mode 100644 index 0000000..9bd1f16 --- /dev/null +++ b/include/iotrace.h @@ -0,0 +1,104 @@ +/* + * Copyright (c) 2014 Google, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __IOTRACE_H +#define __IOTRACE_H + +#include <linux/types.h> + +/* + * This file is designed to be included in arch/<arch>/include/asm/io.h. + * It redirects all IO access through a tracing/checksumming feature for + * testing purposes. + */ + +#if defined(CONFIG_IO_TRACE) && !defined(IOTRACE_IMPL) && \ + !defined(CONFIG_SPL_BUILD) + +#undef readl +#define readl(addr) iotrace_readl((const void *)(addr)) + +#undef writel +#define writel(val, addr) iotrace_writel(val, (const void *)(addr)) + +#undef readw +#define readw(addr) iotrace_readw((const void *)(addr)) + +#undef writew +#define writew(val, addr) iotrace_writew(val, (const void *)(addr)) + +#undef readb +#define readb(addr) iotrace_readb((const void *)(addr)) + +#undef writeb +#define writeb(val, addr) iotrace_writeb(val, (const void *)(addr)) + +#endif + +/* Tracing functions which mirror their io.h counterparts */ +u32 iotrace_readl(const void *ptr); +void iotrace_writel(ulong value, const void *ptr); +u16 iotrace_readw(const void *ptr); +void iotrace_writew(ulong value, const void *ptr); +u8 iotrace_readb(const void *ptr); +void iotrace_writeb(ulong value, const void *ptr); + +/** + * iotrace_reset_checksum() - Reset the iotrace checksum + */ +void iotrace_reset_checksum(void); + +/** + * iotrace_get_checksum() - Get the current checksum value + * + * @return currect checksum value + */ +u32 iotrace_get_checksum(void); + +/** + * iotrace_set_enabled() - Set whether iotracing is enabled or not + * + * This controls whether the checksum is updated and a trace record added + * for each I/O access. + * + * @enable: true to enable iotracing, false to disable + */ +void iotrace_set_enabled(int enable); + +/** + * iotrace_get_enabled() - Get whether iotracing is enabled or not + * + * @return true if enabled, false if disabled + */ +int iotrace_get_enabled(void); + +/** + * iotrace_set_buffer() - Set position and size of iotrace buffer + * + * Defines where the iotrace buffer goes, and resets the output pointer to + * the start of the buffer. + * + * The buffer can be 0 size in which case the checksum is updated but no + * trace records are writen. If the buffer is exhausted, the offset will + * continue to increase but not new data will be written. + * + * @start: Start address of buffer + * @size: Size of buffer in bytes + */ +void iotrace_set_buffer(ulong start, ulong size); + +/** + * iotrace_get_buffer() - Get buffer information + * + * @start: Returns start address of buffer + * @size: Returns size of buffer in bytes + * @offset: Returns the byte offset where the next output trace record will + * @count: Returns the number of trace records recorded + * be written (or would be if the buffer was large enough) + */ +void iotrace_get_buffer(ulong *start, ulong *size, ulong *offset, ulong *count); + +#endif /* __IOTRACE_H */
Support the iotrace feature for ARM, when enabled.
Changes in v3: None Changes in v2: - Add a new patch to enable iotrace for arm
arch/arm/include/asm/io.h | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/arm/include/asm/io.h b/arch/arm/include/asm/io.h index 6a1f05a..9f35fd6 100644 --- a/arch/arm/include/asm/io.h +++ b/arch/arm/include/asm/io.h @@ -437,4 +437,7 @@ out:
#endif /* __mem_isa */ #endif /* __KERNEL__ */ + +#include <iotrace.h> + #endif /* __ASM_ARM_IO_H */
Support the iotrace feature for sandbox, and enable it, using some dummy I/O access methods.
Changes in v3: None Changes in v2: - Add a new patch to enable iotrace for sandbox
arch/sandbox/include/asm/io.h | 10 ++++++++++ include/configs/sandbox.h | 3 +++ 2 files changed, 13 insertions(+)
diff --git a/arch/sandbox/include/asm/io.h b/arch/sandbox/include/asm/io.h index 7956041..895fcb8 100644 --- a/arch/sandbox/include/asm/io.h +++ b/arch/sandbox/include/asm/io.h @@ -40,4 +40,14 @@ static inline void unmap_sysmem(const void *vaddr) /* Map from a pointer to our RAM buffer */ phys_addr_t map_to_sysmem(const void *ptr);
+/* Define nops for sandbox I/O access */ +#define readb(addr) 0 +#define readw(addr) 0 +#define readl(addr) 0 +#define writeb(v, addr) +#define writew(v, addr) +#define writel(v, addr) + +#include <iotrace.h> + #endif diff --git a/include/configs/sandbox.h b/include/configs/sandbox.h index fa62cb6..8ca2a55 100644 --- a/include/configs/sandbox.h +++ b/include/configs/sandbox.h @@ -16,6 +16,9 @@
#endif
+#define CONFIG_IO_TRACE +#define CONFIG_CMD_IO_TRACE + #define CONFIG_SYS_TIMER_RATE 1000000
#define CONFIG_BOOTSTAGE
Dear Simon Glass,
Simon Glass <sjg <at> chromium.org> writes:
Signed-off-by: Simon Glass <sjg <at> chromium.org>
<snipped>
diff --git a/include/configs/sandbox.h b/include/configs/sandbox.h index fa62cb6..8ca2a55 100644 --- a/include/configs/sandbox.h +++ b/include/configs/sandbox.h <at> <at> -16,6 +16,9 <at> <at>
#endif
s/CONFIG_CMD_IO_TRACE/CONFIG_CMD_IOTRACE/g
The common/Makefile shows CONFIG_CMD_IOTRACE triggers creation of cmd_iotrace.o.
All the best, Rommel
Hi Rommel,
On 12 May 2014 18:46, Rommel G Custodio sessyargc+u-boot@gmail.com wrote:
Dear Simon Glass,
<snipped>
#endif
Thanks - I didn't actually see your email - it's a good idea to keep the author in cc.
Linux supports this, and if we are to have compatible device tree files, U-Boot should also.
Avoid giving the device tree files access to U-Boot's include/ directory. Only include/dt-bindings is accessible.
Changes in v3: - Create a symlink for each arch to dt-bindings
Changes in v2: - Add new patch to support include files for .dts files
arch/arm/dts/include/dt-bindings | 1 + arch/microblaze/dts/include/dt-bindings | 1 + arch/sandbox/dts/include/dt-bindings | 1 + arch/x86/dts/include/dt-bindings | 1 + scripts/Makefile.lib | 1 + 5 files changed, 5 insertions(+) create mode 120000 arch/arm/dts/include/dt-bindings create mode 120000 arch/microblaze/dts/include/dt-bindings create mode 120000 arch/sandbox/dts/include/dt-bindings create mode 120000 arch/x86/dts/include/dt-bindings
diff --git a/arch/arm/dts/include/dt-bindings b/arch/arm/dts/include/dt-bindings new file mode 120000 index 0000000..0cecb3d --- /dev/null +++ b/arch/arm/dts/include/dt-bindings @@ -0,0 +1 @@ +../../../../include/dt-bindings \ No newline at end of file diff --git a/arch/microblaze/dts/include/dt-bindings b/arch/microblaze/dts/include/dt-bindings new file mode 120000 index 0000000..0cecb3d --- /dev/null +++ b/arch/microblaze/dts/include/dt-bindings @@ -0,0 +1 @@ +../../../../include/dt-bindings \ No newline at end of file diff --git a/arch/sandbox/dts/include/dt-bindings b/arch/sandbox/dts/include/dt-bindings new file mode 120000 index 0000000..0cecb3d --- /dev/null +++ b/arch/sandbox/dts/include/dt-bindings @@ -0,0 +1 @@ +../../../../include/dt-bindings \ No newline at end of file diff --git a/arch/x86/dts/include/dt-bindings b/arch/x86/dts/include/dt-bindings new file mode 120000 index 0000000..0cecb3d --- /dev/null +++ b/arch/x86/dts/include/dt-bindings @@ -0,0 +1 @@ +../../../../include/dt-bindings \ No newline at end of file diff --git a/scripts/Makefile.lib b/scripts/Makefile.lib index a04439d..722afed 100644 --- a/scripts/Makefile.lib +++ b/scripts/Makefile.lib @@ -153,6 +153,7 @@ ld_flags = $(LDFLAGS) $(ldflags-y) # Modified for U-Boot dtc_cpp_flags = -Wp,-MD,$(depfile).pre.tmp -nostdinc \ -I$(srctree)/arch/$(ARCH)/dts \ + -I$(srctree)/arch/$(ARCH)/dts/include \ -undef -D__DTS__
# Finds the multi-part object the current object will be linked into
Hi Simon,
Thanks!
Reviewed-by: Masahiro Yamada yamada.m@jp.panasonic.com
Best Regards Masahiro Yamada
Acked-by: Stephen Warren swarren@nvidia.com
These files are taken from Linux 3.14.
Changes in v3: - Bring in GPIO bindings for tegra{30,114,124} also
Changes in v2: - Add new patch to bring in Tegra device tree files from linux
arch/arm/dts/tegra114.dtsi | 21 +++++---- arch/arm/dts/tegra124.dtsi | 23 +++++----- arch/arm/dts/tegra20.dtsi | 15 ++++++- arch/arm/dts/tegra30.dtsi | 21 +++++---- include/dt-bindings/gpio/gpio.h | 15 +++++++ include/dt-bindings/gpio/tegra-gpio.h | 51 ++++++++++++++++++++++ include/dt-bindings/interrupt-controller/arm-gic.h | 22 ++++++++++ include/dt-bindings/interrupt-controller/irq.h | 19 ++++++++ 8 files changed, 157 insertions(+), 30 deletions(-) create mode 100644 include/dt-bindings/gpio/gpio.h create mode 100644 include/dt-bindings/gpio/tegra-gpio.h create mode 100644 include/dt-bindings/interrupt-controller/arm-gic.h create mode 100644 include/dt-bindings/interrupt-controller/irq.h
diff --git a/arch/arm/dts/tegra114.dtsi b/arch/arm/dts/tegra114.dtsi index f52fcf1..59434e0 100644 --- a/arch/arm/dts/tegra114.dtsi +++ b/arch/arm/dts/tegra114.dtsi @@ -1,3 +1,6 @@ +#include <dt-bindings/gpio/tegra-gpio.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> + #include "skeleton.dtsi"
/ { @@ -46,17 +49,17 @@ 0 143 0x04>; };
- gpio: gpio { + gpio: gpio@6000d000 { compatible = "nvidia,tegra114-gpio", "nvidia,tegra30-gpio"; reg = <0x6000d000 0x1000>; - interrupts = <0 32 0x04 - 0 33 0x04 - 0 34 0x04 - 0 35 0x04 - 0 55 0x04 - 0 87 0x04 - 0 89 0x04 - 0 125 0x04>; + interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 89 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>; #gpio-cells = <2>; gpio-controller; #interrupt-cells = <2>; diff --git a/arch/arm/dts/tegra124.dtsi b/arch/arm/dts/tegra124.dtsi index 18a8b24..a13cfe4 100644 --- a/arch/arm/dts/tegra124.dtsi +++ b/arch/arm/dts/tegra124.dtsi @@ -1,3 +1,6 @@ +#include <dt-bindings/gpio/tegra-gpio.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> + #include "skeleton.dtsi"
- gpio: gpio@6000d000 { + gpio: gpio@0,6000d000 { compatible = "nvidia,tegra124-gpio", "nvidia,tegra30-gpio"; - reg = <0x6000d000 0x1000>; - interrupts = <0 32 0x04 - 0 33 0x04 - 0 34 0x04 - 0 35 0x04 - 0 55 0x04 - 0 87 0x04 - 0 89 0x04 - 0 125 0x04>; + reg = <0x0 0x6000d000 0x0 0x1000>; + interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 89 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>; #gpio-cells = <2>; gpio-controller; #interrupt-cells = <2>; diff --git a/arch/arm/dts/tegra20.dtsi b/arch/arm/dts/tegra20.dtsi index 3805750..a524f6e 100644 --- a/arch/arm/dts/tegra20.dtsi +++ b/arch/arm/dts/tegra20.dtsi @@ -1,3 +1,6 @@ +#include <dt-bindings/gpio/tegra-gpio.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> + #include "skeleton.dtsi"
/ { @@ -139,10 +142,18 @@
gpio: gpio@6000d000 { compatible = "nvidia,tegra20-gpio"; - reg = < 0x6000d000 0x1000 >; - interrupts = < 64 65 66 67 87 119 121 >; + reg = <0x6000d000 0x1000>; + interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 89 IRQ_TYPE_LEVEL_HIGH>; #gpio-cells = <2>; gpio-controller; + #interrupt-cells = <2>; + interrupt-controller; };
pinmux: pinmux@70000000 { diff --git a/arch/arm/dts/tegra30.dtsi b/arch/arm/dts/tegra30.dtsi index fee1c36..7be3791 100644 --- a/arch/arm/dts/tegra30.dtsi +++ b/arch/arm/dts/tegra30.dtsi @@ -1,3 +1,6 @@ +#include <dt-bindings/gpio/tegra-gpio.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> + #include "skeleton.dtsi"
/ { @@ -47,17 +50,17 @@ clocks = <&tegra_car 34>; };
- gpio: gpio { + gpio: gpio@6000d000 { compatible = "nvidia,tegra30-gpio"; reg = <0x6000d000 0x1000>; - interrupts = <0 32 0x04 - 0 33 0x04 - 0 34 0x04 - 0 35 0x04 - 0 55 0x04 - 0 87 0x04 - 0 89 0x04 - 0 125 0x04>; + interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 89 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>; #gpio-cells = <2>; gpio-controller; #interrupt-cells = <2>; diff --git a/include/dt-bindings/gpio/gpio.h b/include/dt-bindings/gpio/gpio.h new file mode 100644 index 0000000..e6b1e0a --- /dev/null +++ b/include/dt-bindings/gpio/gpio.h @@ -0,0 +1,15 @@ +/* + * This header provides constants for most GPIO bindings. + * + * Most GPIO bindings include a flags cell as part of the GPIO specifier. + * In most cases, the format of the flags cell uses the standard values + * defined in this header. + */ + +#ifndef _DT_BINDINGS_GPIO_GPIO_H +#define _DT_BINDINGS_GPIO_GPIO_H + +#define GPIO_ACTIVE_HIGH 0 +#define GPIO_ACTIVE_LOW 1 + +#endif diff --git a/include/dt-bindings/gpio/tegra-gpio.h b/include/dt-bindings/gpio/tegra-gpio.h new file mode 100644 index 0000000..197dc28 --- /dev/null +++ b/include/dt-bindings/gpio/tegra-gpio.h @@ -0,0 +1,51 @@ +/* + * This header provides constants for binding nvidia,tegra*-gpio. + * + * The first cell in Tegra's GPIO specifier is the GPIO ID. The macros below + * provide names for this. + * + * The second cell contains standard flag values specified in gpio.h. + */ + +#ifndef _DT_BINDINGS_GPIO_TEGRA_GPIO_H +#define _DT_BINDINGS_GPIO_TEGRA_GPIO_H + +#include <dt-bindings/gpio/gpio.h> + +#define TEGRA_GPIO_BANK_ID_A 0 +#define TEGRA_GPIO_BANK_ID_B 1 +#define TEGRA_GPIO_BANK_ID_C 2 +#define TEGRA_GPIO_BANK_ID_D 3 +#define TEGRA_GPIO_BANK_ID_E 4 +#define TEGRA_GPIO_BANK_ID_F 5 +#define TEGRA_GPIO_BANK_ID_G 6 +#define TEGRA_GPIO_BANK_ID_H 7 +#define TEGRA_GPIO_BANK_ID_I 8 +#define TEGRA_GPIO_BANK_ID_J 9 +#define TEGRA_GPIO_BANK_ID_K 10 +#define TEGRA_GPIO_BANK_ID_L 11 +#define TEGRA_GPIO_BANK_ID_M 12 +#define TEGRA_GPIO_BANK_ID_N 13 +#define TEGRA_GPIO_BANK_ID_O 14 +#define TEGRA_GPIO_BANK_ID_P 15 +#define TEGRA_GPIO_BANK_ID_Q 16 +#define TEGRA_GPIO_BANK_ID_R 17 +#define TEGRA_GPIO_BANK_ID_S 18 +#define TEGRA_GPIO_BANK_ID_T 19 +#define TEGRA_GPIO_BANK_ID_U 20 +#define TEGRA_GPIO_BANK_ID_V 21 +#define TEGRA_GPIO_BANK_ID_W 22 +#define TEGRA_GPIO_BANK_ID_X 23 +#define TEGRA_GPIO_BANK_ID_Y 24 +#define TEGRA_GPIO_BANK_ID_Z 25 +#define TEGRA_GPIO_BANK_ID_AA 26 +#define TEGRA_GPIO_BANK_ID_BB 27 +#define TEGRA_GPIO_BANK_ID_CC 28 +#define TEGRA_GPIO_BANK_ID_DD 29 +#define TEGRA_GPIO_BANK_ID_EE 30 +#define TEGRA_GPIO_BANK_ID_FF 31 + +#define TEGRA_GPIO(bank, offset) \ + ((TEGRA_GPIO_BANK_ID_##bank * 8) + offset) + +#endif diff --git a/include/dt-bindings/interrupt-controller/arm-gic.h b/include/dt-bindings/interrupt-controller/arm-gic.h new file mode 100644 index 0000000..1ea1b70 --- /dev/null +++ b/include/dt-bindings/interrupt-controller/arm-gic.h @@ -0,0 +1,22 @@ +/* + * This header provides constants for the ARM GIC. + */ + +#ifndef _DT_BINDINGS_INTERRUPT_CONTROLLER_ARM_GIC_H +#define _DT_BINDINGS_INTERRUPT_CONTROLLER_ARM_GIC_H + +#include <dt-bindings/interrupt-controller/irq.h> + +/* interrupt specific cell 0 */ + +#define GIC_SPI 0 +#define GIC_PPI 1 + +/* + * Interrupt specifier cell 2. + * The flaggs in irq.h are valid, plus those below. + */ +#define GIC_CPU_MASK_RAW(x) ((x) << 8) +#define GIC_CPU_MASK_SIMPLE(num) GIC_CPU_MASK_RAW((1 << (num)) - 1) + +#endif diff --git a/include/dt-bindings/interrupt-controller/irq.h b/include/dt-bindings/interrupt-controller/irq.h new file mode 100644 index 0000000..33a1003 --- /dev/null +++ b/include/dt-bindings/interrupt-controller/irq.h @@ -0,0 +1,19 @@ +/* + * This header provides constants for most IRQ bindings. + * + * Most IRQ bindings include a flags cell as part of the IRQ specifier. + * In most cases, the format of the flags cell uses the standard values + * defined in this header. + */ + +#ifndef _DT_BINDINGS_INTERRUPT_CONTROLLER_IRQ_H +#define _DT_BINDINGS_INTERRUPT_CONTROLLER_IRQ_H + +#define IRQ_TYPE_NONE 0 +#define IRQ_TYPE_EDGE_RISING 1 +#define IRQ_TYPE_EDGE_FALLING 2 +#define IRQ_TYPE_EDGE_BOTH (IRQ_TYPE_EDGE_FALLING | IRQ_TYPE_EDGE_RISING) +#define IRQ_TYPE_LEVEL_HIGH 4 +#define IRQ_TYPE_LEVEL_LOW 8 + +#endif
- gpio: gpio@0,6000d000 { compatible = "nvidia,tegra124-gpio", "nvidia,tegra30-gpio";
That reg value and node name are for #address-cells=<2>, #size-cells=<2>. However, those properties are both =<1> in the U-Boot tegra124.dtsi, and I'm not sure whether U-Boot even supports 64-bit DT address values yet?
It'd probably be simplest to just use 32-bit address/size values in tegra124.dtsi now, and import the conversion to 64-bit later?
Aside from that, this patch looks, so assuming the change to those two lines above is reverted:
Add a note to encourage people to convert drivers to use driver model.
Changes in v3: None Changes in v2: - Update README to encourage conversion to driver model
README | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/README b/README index b226458..16485c3 100644 --- a/README +++ b/README @@ -5239,6 +5239,11 @@ Information structure as we define in include/asm-<arch>/u-boot.h, and make sure that your definition of IMAP_ADDR uses the same value as your U-Boot configuration in CONFIG_SYS_IMMR.
+Note that U-Boot now has a driver model, a unified model for drivers. +If you are adding a new driver, plumb it into driver model. If there +is no uclass available, you are encouraged to create one. See +doc/driver-model. +
Configuring the Linux kernel: -----------------------------
We want 'N0' and 'n0' to mean the same thing, so ensure that case is not considered when naming GPIO banks.
Changes in v3: None Changes in v2: - Add new patch to use case-insensitive comparison for GPIO banks
drivers/gpio/gpio-uclass.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/gpio/gpio-uclass.c b/drivers/gpio/gpio-uclass.c index 56bfd11..ec605dc 100644 --- a/drivers/gpio/gpio-uclass.c +++ b/drivers/gpio/gpio-uclass.c @@ -58,7 +58,7 @@ int gpio_lookup_name(const char *name, struct device **devp, uc_priv = dev->uclass_priv; len = uc_priv->bank_name ? strlen(uc_priv->bank_name) : 0;
- if (!strncmp(name, uc_priv->bank_name, len)) { + if (!strncasecmp(name, uc_priv->bank_name, len)) { if (strict_strtoul(name + len, 10, &offset)) continue; if (devp)
These files don't compile in some architectures. Fix it by adding the missing headers.
Changes in v3: None Changes in v2: - Add new patch to add missing header files in lists and root
drivers/core/lists.c | 1 + drivers/core/root.c | 1 + 2 files changed, 2 insertions(+)
diff --git a/drivers/core/lists.c b/drivers/core/lists.c index 4f2c126..6a53362 100644 --- a/drivers/core/lists.c +++ b/drivers/core/lists.c @@ -14,6 +14,7 @@ #include <dm/platdata.h> #include <dm/uclass.h> #include <dm/util.h> +#include <fdtdec.h> #include <linux/compiler.h>
struct driver *lists_driver_lookup_name(const char *name) diff --git a/drivers/core/root.c b/drivers/core/root.c index 407bc0d..88d2f45 100644 --- a/drivers/core/root.c +++ b/drivers/core/root.c @@ -10,6 +10,7 @@ #include <common.h> #include <errno.h> #include <malloc.h> +#include <libfdt.h> #include <dm/device.h> #include <dm/device-internal.h> #include <dm/lists.h>
In a very few cases we need to adjust the driver model root device, such as when setting it up at initialisation. Add a macro to make this easier.
Changes in v3: - Fix typo in commit subject
Changes in v2: - Add new patch to deal with const-ness of the global_data pointer
drivers/core/root.c | 6 +++--- drivers/core/uclass.c | 2 +- include/dm/device-internal.h | 4 ++++ 3 files changed, 8 insertions(+), 4 deletions(-)
diff --git a/drivers/core/root.c b/drivers/core/root.c index 88d2f45..4427b81 100644 --- a/drivers/core/root.c +++ b/drivers/core/root.c @@ -43,9 +43,9 @@ int dm_init(void) dm_warn("Virtual root driver already exists!\n"); return -EINVAL; } - INIT_LIST_HEAD(&gd->uclass_root); + INIT_LIST_HEAD(&DM_UCLASS_ROOT());
- ret = device_bind_by_name(NULL, &root_info, &gd->dm_root); + ret = device_bind_by_name(NULL, &root_info, &DM_ROOT()); if (ret) return ret;
@@ -56,7 +56,7 @@ int dm_scan_platdata(void) { int ret;
- ret = lists_bind_drivers(gd->dm_root); + ret = lists_bind_drivers(DM_ROOT()); if (ret == -ENOENT) { dm_warn("Some drivers were not found\n"); ret = 0; diff --git a/drivers/core/uclass.c b/drivers/core/uclass.c index 4df5a8b..afb5fdc 100644 --- a/drivers/core/uclass.c +++ b/drivers/core/uclass.c @@ -75,7 +75,7 @@ static int uclass_add(enum uclass_id id, struct uclass **ucp) uc->uc_drv = uc_drv; INIT_LIST_HEAD(&uc->sibling_node); INIT_LIST_HEAD(&uc->dev_head); - list_add(&uc->sibling_node, &gd->uclass_root); + list_add(&uc->sibling_node, &DM_UCLASS_ROOT());
if (uc_drv->init) { ret = uc_drv->init(uc); diff --git a/include/dm/device-internal.h b/include/dm/device-internal.h index c026e8e..e95b7a9 100644 --- a/include/dm/device-internal.h +++ b/include/dm/device-internal.h @@ -84,4 +84,8 @@ int device_remove(struct device *dev); */ int device_unbind(struct device *dev);
+/* Cast away any volatile pointer */ +#define DM_ROOT() (((gd_t *)gd)->dm_root) +#define DM_UCLASS_ROOT() (((gd_t *)gd)->uclass_root) + #endif
The GPIO tests require the sandbox GPIO driver, so cannot be run on other platforms. Similarly for the 'dm test' command.
Changes in v3: None Changes in v2: - Add new patch to allow driver model tests only for sandbox
test/dm/Makefile | 2 ++ test/dm/cmd_dm.c | 11 +++++++++-- 2 files changed, 11 insertions(+), 2 deletions(-)
diff --git a/test/dm/Makefile b/test/dm/Makefile index 4e9afe6..c0f2135 100644 --- a/test/dm/Makefile +++ b/test/dm/Makefile @@ -15,4 +15,6 @@ obj-$(CONFIG_DM_TEST) += ut.o # subsystem you must add sandbox tests here. obj-$(CONFIG_DM_TEST) += core.o obj-$(CONFIG_DM_TEST) += ut.o +ifneq ($(CONFIG_SANDBOX),) obj-$(CONFIG_DM_GPIO) += gpio.o +endif diff --git a/test/dm/cmd_dm.c b/test/dm/cmd_dm.c index a03fe20..62eccd6 100644 --- a/test/dm/cmd_dm.c +++ b/test/dm/cmd_dm.c @@ -93,16 +93,23 @@ static int do_dm_dump_uclass(cmd_tbl_t *cmdtp, int flag, int argc, return 0; }
+#ifdef CONFIG_DM_TEST static int do_dm_test(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { return dm_test_main(); } +#define TEST_HELP "\ndm test Run tests" +#else +#define TEST_HELP +#endif
static cmd_tbl_t test_commands[] = { U_BOOT_CMD_MKENT(tree, 0, 1, do_dm_dump_all, "", ""), U_BOOT_CMD_MKENT(uclass, 1, 1, do_dm_dump_uclass, "", ""), +#ifdef CONFIG_DM_TEST U_BOOT_CMD_MKENT(test, 1, 1, do_dm_test, "", ""), +#endif };
static int do_dm(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) @@ -128,6 +135,6 @@ U_BOOT_CMD( dm, 2, 1, do_dm, "Driver model low level access", "tree Dump driver model tree\n" - "dm uclass Dump list of instances for each uclass\n" - "dm test Run tests" + "dm uclass Dump list of instances for each uclass" + TEST_HELP );
The values here are int, but the map_to_sysmem() call can return a long. Add a cast to deal with this.
Changes in v3: None Changes in v2: - Add new patch to fix printf() strings in the 'dm' command
test/dm/cmd_dm.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/test/dm/cmd_dm.c b/test/dm/cmd_dm.c index 62eccd6..c6b2eb8 100644 --- a/test/dm/cmd_dm.c +++ b/test/dm/cmd_dm.c @@ -23,7 +23,7 @@ static int display_succ(struct device *in, char *buf) char local[16]; struct device *pos, *n, *prev = NULL;
- printf("%s- %s @ %08x", buf, in->name, map_to_sysmem(in)); + printf("%s- %s @ %08x", buf, in->name, (uint)map_to_sysmem(in)); if (in->flags & DM_FLAG_ACTIVATED) puts(" - activated"); puts("\n"); @@ -62,7 +62,7 @@ static int do_dm_dump_all(cmd_tbl_t *cmdtp, int flag, int argc, struct device *root;
root = dm_root(); - printf("ROOT %08x\n", map_to_sysmem(root)); + printf("ROOT %08x\n", (uint)map_to_sysmem(root)); return dm_dump(root); }
@@ -84,8 +84,8 @@ static int do_dm_dump_uclass(cmd_tbl_t *cmdtp, int flag, int argc, for (ret = uclass_first_device(id, &dev); dev; ret = uclass_next_device(&dev)) { - printf(" %s @ %08x:\n", dev->name, - map_to_sysmem(dev)); + printf(" %s @ %08x:\n", dev->name, + (uint)map_to_sysmem(dev)); } puts("\n"); }
Enable driver model for Tegra boards.
Changes in v3: - Enable dm command in this patch instead of the next
Changes in v2: - Split out a separate patch to enable driver model for tegra
include/configs/tegra-common.h | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/include/configs/tegra-common.h b/include/configs/tegra-common.h index ae786cf..24b909b 100644 --- a/include/configs/tegra-common.h +++ b/include/configs/tegra-common.h @@ -19,6 +19,9 @@
#include <asm/arch/tegra.h> /* get chip and board defs */
+#define CONFIG_DM +#define CONFIG_CMD_DM + #define CONFIG_SYS_TIMER_RATE 1000000 #define CONFIG_SYS_TIMER_COUNTER NV_PA_TMRUS_BASE
Seems fine to me, Acked-by: Stephen Warren swarren@nvidia.com
This is an implementation of GPIOs for Tegra that uses driver model. It has been tested on trimslice and also using the new iotrace feature.
The implementation uses a top-level GPIO device (which has no actual GPIOS). Under this all the banks are created as separate GPIO devices.
The GPIOs are named as per the Tegra datasheet/header files: A0..A7, B0..B7, ..., Z0..Z7, AA0..AA7, etc.
Since driver model is not yet available before relocation, or in SPL, a special function is provided for seaboard's SPL code.
This series is marked RFC since the Tegra driver may need further discussion. Signed-off-by: Simon Glass sjg@chromium.org ---
Changes in v3: - Move dm command enable to previous patch - Use gpio number for the internal helper functions
Changes in v2: - Split out driver model changes into separate patches - Correct bugs found during testing
arch/arm/include/asm/arch-tegra/gpio.h | 14 +- board/nvidia/seaboard/seaboard.c | 2 +- drivers/gpio/tegra_gpio.c | 313 +++++++++++++++++++++++++++------ include/configs/tegra-common.h | 1 + 4 files changed, 266 insertions(+), 64 deletions(-)
diff --git a/arch/arm/include/asm/arch-tegra/gpio.h b/arch/arm/include/asm/arch-tegra/gpio.h index d97190d..80e4a73 100644 --- a/arch/arm/include/asm/arch-tegra/gpio.h +++ b/arch/arm/include/asm/arch-tegra/gpio.h @@ -6,6 +6,8 @@ #ifndef _TEGRA_GPIO_H_ #define _TEGRA_GPIO_H_
+#define TEGRA_GPIOS_PER_PORT 8 +#define TEGRA_PORTS_PER_BANK 4 #define MAX_NUM_GPIOS (TEGRA_GPIO_PORTS * TEGRA_GPIO_BANKS * 8) #define GPIO_NAME_SIZE 20 /* gpio_request max label len */
@@ -14,11 +16,13 @@ #define GPIO_FULLPORT(x) ((x) >> 3) #define GPIO_BIT(x) ((x) & 0x7)
-/* - * Tegra-specific GPIO API +/** + * tegra_spl_gpio_direction_output() - set the output value of a GPIO + * + * This function is only used from SPL on seaboard, which needs to enable a + * GPIO to get the UART running. It could be done in U-Boot rather than SPL, + * but for now, this gets it working */ +int tegra_spl_gpio_direction_output(int gpio, int value);
-void gpio_info(void); - -#define gpio_status() gpio_info() #endif /* TEGRA_GPIO_H_ */ diff --git a/board/nvidia/seaboard/seaboard.c b/board/nvidia/seaboard/seaboard.c index ef4e481..e27efcd 100644 --- a/board/nvidia/seaboard/seaboard.c +++ b/board/nvidia/seaboard/seaboard.c @@ -22,7 +22,7 @@ void gpio_early_init_uart(void) #ifndef CONFIG_SPL_BUILD gpio_request(GPIO_PI3, NULL); #endif - gpio_direction_output(GPIO_PI3, 0); + tegra_spl_gpio_direction_output(GPIO_PI3, 0); } #endif
diff --git a/drivers/gpio/tegra_gpio.c b/drivers/gpio/tegra_gpio.c index 82b30d5..f03d4ed 100644 --- a/drivers/gpio/tegra_gpio.c +++ b/drivers/gpio/tegra_gpio.c @@ -12,10 +12,17 @@ */
#include <common.h> +#include <dm.h> +#include <malloc.h> +#include <errno.h> +#include <fdtdec.h> #include <asm/io.h> #include <asm/bitops.h> #include <asm/arch/tegra.h> #include <asm/gpio.h> +#include <dm/device-internal.h> + +DECLARE_GLOBAL_DATA_PTR;
enum { TEGRA_CMD_INFO, @@ -24,14 +31,18 @@ enum { TEGRA_CMD_INPUT, };
-static struct gpio_names { - char name[GPIO_NAME_SIZE]; -} gpio_names[MAX_NUM_GPIOS]; +struct tegra_gpio_platdata { + struct gpio_ctlr_bank *bank; + const char *port_name; /* Name of port, e.g. "B" */ + int base_port; /* Port number for this port (0, 1,.., n-1) */ +};
-static char *get_name(int i) -{ - return *gpio_names[i].name ? gpio_names[i].name : "UNKNOWN"; -} +/* Information about each port at run-time */ +struct tegra_port_info { + char label[TEGRA_GPIOS_PER_PORT][GPIO_NAME_SIZE]; + struct gpio_ctlr_bank *bank; + int base_port; /* Port number for this port (0, 1,.., n-1) */ +};
/* Return config of pin 'gpio' as GPIO (1) or SFPIO (0) */ static int get_config(unsigned gpio) @@ -121,38 +132,71 @@ static void set_level(unsigned gpio, int high) writel(u, &bank->gpio_out[GPIO_PORT(gpio)]); }
+static int check_reserved(struct device *dev, unsigned offset, + const char *func) +{ + struct tegra_port_info *state = dev_get_priv(dev); + struct gpio_dev_priv *uc_priv = dev->uclass_priv; + + if (!*state->label[offset]) { + printf("tegra_gpio: %s: error: gpio %s%d not reserved\n", + func, uc_priv->bank_name, offset); + return -EPERM; + } + + return 0; +} + +#ifdef CONFIG_SPL +/* set GPIO pin 'gpio' as an output, with polarity 'value' */ +int tegra_spl_gpio_direction_output(int gpio, int value) +{ + /* Configure GPIO output value. */ + set_level(gpio, value); + + /* Configure GPIO direction as output. */ + set_direction(gpio, value); + + return 0; +} +#endif /* CONFIG_SPL */ + /* * Generic_GPIO primitives. */
-int gpio_request(unsigned gpio, const char *label) +static int tegra_gpio_request(struct device *dev, unsigned offset, + const char *label) { - if (gpio >= MAX_NUM_GPIOS) - return -1; + struct tegra_port_info *state = dev_get_priv(dev);
- if (label != NULL) { - strncpy(gpio_names[gpio].name, label, GPIO_NAME_SIZE); - gpio_names[gpio].name[GPIO_NAME_SIZE - 1] = '\0'; - } + if (*state->label[offset]) + return -EBUSY; + + strncpy(state->label[offset], label, GPIO_NAME_SIZE); + state->label[offset][GPIO_NAME_SIZE - 1] = '\0';
/* Configure as a GPIO */ - set_config(gpio, 1); + set_config(state->base_port + offset, 1);
return 0; }
-int gpio_free(unsigned gpio) +static int tegra_gpio_free(struct device *dev, unsigned offset) { - if (gpio >= MAX_NUM_GPIOS) - return -1; + struct tegra_port_info *state = dev_get_priv(dev); + int ret; + + ret = check_reserved(dev, offset, __func__); + if (ret) + return ret; + state->label[offset][0] = '\0';
- gpio_names[gpio].name[0] = '\0'; - /* Do not configure as input or change pin mux here */ return 0; }
/* read GPIO OUT value of pin 'gpio' */ -static int gpio_get_output_value(unsigned gpio) +static int tegra_gpio_get_output_value(unsigned gpio) { struct gpio_ctlr *ctlr = (struct gpio_ctlr *)NV_PA_GPIO_BASE; struct gpio_ctlr_bank *bank = &ctlr->gpio_bank[GPIO_BANK(gpio)]; @@ -166,81 +210,234 @@ static int gpio_get_output_value(unsigned gpio) return (val >> GPIO_BIT(gpio)) & 1; }
+ /* set GPIO pin 'gpio' as an input */ -int gpio_direction_input(unsigned gpio) +static int tegra_gpio_direction_input(struct device *dev, unsigned offset) { - debug("gpio_direction_input: pin = %d (port %d:bit %d)\n", - gpio, GPIO_FULLPORT(gpio), GPIO_BIT(gpio)); + struct tegra_port_info *state = dev_get_priv(dev); + int ret; + + ret = check_reserved(dev, offset, __func__); + if (ret) + return ret;
/* Configure GPIO direction as input. */ - set_direction(gpio, 0); + set_direction(state->base_port + offset, 0);
return 0; }
/* set GPIO pin 'gpio' as an output, with polarity 'value' */ -int gpio_direction_output(unsigned gpio, int value) +static int tegra_gpio_direction_output(struct device *dev, unsigned offset, + int value) { - debug("gpio_direction_output: pin = %d (port %d:bit %d) = %s\n", - gpio, GPIO_FULLPORT(gpio), GPIO_BIT(gpio), - value ? "HIGH" : "LOW"); + struct tegra_port_info *state = dev_get_priv(dev); + int ret; + + ret = check_reserved(dev, offset, __func__); + if (ret) + return ret;
/* Configure GPIO output value. */ - set_level(gpio, value); + set_level(state->base_port + offset, value);
/* Configure GPIO direction as output. */ - set_direction(gpio, 1); + set_direction(state->base_port + offset, 1);
return 0; }
/* read GPIO IN value of pin 'gpio' */ -int gpio_get_value(unsigned gpio) +static int tegra_gpio_get_value(struct device *dev, unsigned offset) { - struct gpio_ctlr *ctlr = (struct gpio_ctlr *)NV_PA_GPIO_BASE; - struct gpio_ctlr_bank *bank = &ctlr->gpio_bank[GPIO_BANK(gpio)]; + struct tegra_port_info *state = dev_get_priv(dev); + int gpio = state->base_port + offset; + int ret; int val;
- debug("gpio_get_value: pin = %d (port %d:bit %d)\n", - gpio, GPIO_FULLPORT(gpio), GPIO_BIT(gpio)); + ret = check_reserved(dev, offset, __func__); + if (ret) + return ret; + + debug("%s: pin = %d (port %d:bit %d)\n", __func__, + gpio, GPIO_FULLPORT(gpio), GPIO_BIT(gpio));
- val = readl(&bank->gpio_in[GPIO_PORT(gpio)]); + val = readl(&state->bank->gpio_in[GPIO_PORT(gpio)]);
/* write GPIO OUT value to pin 'gpio' */ -int gpio_set_value(unsigned gpio, int value) +static int tegra_gpio_set_value(struct device *dev, unsigned offset, int value) { + struct tegra_port_info *state = dev_get_priv(dev); + int gpio = state->base_port + offset; + int ret; + + ret = check_reserved(dev, offset, __func__); + if (ret) + return ret; + debug("gpio_set_value: pin = %d (port %d:bit %d), value = %d\n", - gpio, GPIO_FULLPORT(gpio), GPIO_BIT(gpio), value); + gpio, GPIO_FULLPORT(gpio), GPIO_BIT(gpio), value);
return 0; }
-/* - * Display Tegra GPIO information +static int tegra_gpio_get_state(struct device *dev, unsigned int offset, + char *buf, int bufsize) +{ + struct gpio_dev_priv *uc_priv = dev->uclass_priv; + struct tegra_port_info *state = dev_get_priv(dev); + int gpio = state->base_port + offset; + const char *label; + int is_output; + int is_gpio; + int size; + + label = state->label[offset]; + is_gpio = get_config(state->base_port + offset); /* GPIO, not SFPIO */ + size = snprintf(buf, bufsize, "%s%d: ", + uc_priv->bank_name ? uc_priv->bank_name : "", offset); + buf += size; + bufsize -= size; + if (is_gpio) { + is_output = get_direction(gpio); + + snprintf(buf, bufsize, "%s: %d [%c]%s%s", + is_output ? "out" : " in", + is_output ? + tegra_gpio_get_output_value(gpio) : + tegra_gpio_get_value(dev, offset), + *label ? 'x' : ' ', + *label ? " " : "", + label); + } else { + snprintf(buf, bufsize, "sfpio"); + } + + return 0; +} + +static const struct dm_gpio_ops gpio_tegra_ops = { + .request = tegra_gpio_request, + .free = tegra_gpio_free, + .direction_input = tegra_gpio_direction_input, + .direction_output = tegra_gpio_direction_output, + .get_value = tegra_gpio_get_value, + .set_value = tegra_gpio_set_value, + .get_state = tegra_gpio_get_state, +}; + +/** + * Returns the name of a GPIO port + * + * GPIOs are named A, B, C, ..., Z, AA, BB, CC, ... + * + * @base_port: Base port number (0, 1..n-1) + * @return allocated string containing the name */ -void gpio_info(void) +static char *gpio_port_name(int base_port) { - unsigned c; - int type; + char *name, *s; + + name = malloc(3); + if (name) { + s = name; + *s++ = 'A' + (base_port % 26); + if (base_port >= 26) + *s++ = *name; + *s = '\0'; + } + + return name; +} + +static const struct device_id tegra_gpio_ids[] = { + { .compatible = "nvidia,tegra30-gpio" }, + { .compatible = "nvidia,tegra20-gpio" }, + { } +}; + +static int gpio_tegra_probe(struct device *dev) +{ + struct gpio_dev_priv *uc_priv = dev->uclass_priv; + struct tegra_port_info *priv = dev->priv; + struct tegra_gpio_platdata *plat = dev->platdata;
- for (c = 0; c < MAX_NUM_GPIOS; c++) { - type = get_config(c); /* GPIO, not SFPIO */ - if (type) { - printf("GPIO_%d:\t%s is an %s, ", c, - get_name(c), - get_direction(c) ? "OUTPUT" : "INPUT"); - if (get_direction(c)) - printf("value = %d", gpio_get_output_value(c)); - else - printf("value = %d", gpio_get_value(c)); - printf("\n"); - } else - continue; + /* Only child devices have ports */ + if (!plat) + return 0; + + priv->bank = plat->bank; + priv->base_port = plat->base_port; + + uc_priv->gpio_count = TEGRA_GPIOS_PER_PORT; + uc_priv->bank_name = plat->port_name; + + return 0; +} + +/** + * We have a top-level GPIO device with no actual GPIOs. It has a child + * device for each Tegra port. + */ +static int gpio_tegra_bind(struct device *parent) +{ + struct tegra_gpio_platdata *plat = parent->platdata; + struct gpio_ctlr *ctlr; + int bank_count; + int bank; + int ret; + int len; + + /* If this is a child device, there is nothing to do here */ + if (plat) + return 0; + + /* + * This driver does not make use of interrupts, other than to figure + * out the number of GPIO banks + */ + if (!fdt_getprop(gd->fdt_blob, parent->of_offset, "interrupts", &len)) + return -EINVAL; + bank_count = len / 3 / sizeof(u32); + ctlr = (struct gpio_ctlr *)fdtdec_get_addr(gd->fdt_blob, + parent->of_offset, "reg"); + for (bank = 0; bank < bank_count; bank++) { + int port; + + for (port = 0; port < TEGRA_PORTS_PER_BANK; port++) { + struct tegra_gpio_platdata *plat; + struct device *dev; + + plat = calloc(1, sizeof(*plat)); + if (!plat) + return -ENOMEM; + plat->bank = &ctlr->gpio_bank[bank]; + plat->base_port = bank * TEGRA_PORTS_PER_BANK + port; + plat->port_name = gpio_port_name(plat->base_port); + + ret = device_bind(parent, parent->driver, + plat->port_name, plat, -1, &dev); + if (ret) + return ret; + dev->of_offset = parent->of_offset; + } } + + return 0; } + +U_BOOT_DRIVER(gpio_tegra) = { + .name = "gpio_tegra", + .id = UCLASS_GPIO, + .of_match = tegra_gpio_ids, + .bind = gpio_tegra_bind, + .probe = gpio_tegra_probe, + .priv_auto_alloc_size = sizeof(struct tegra_port_info), + .ops = &gpio_tegra_ops, +}; diff --git a/include/configs/tegra-common.h b/include/configs/tegra-common.h index 24b909b..1069218 100644 --- a/include/configs/tegra-common.h +++ b/include/configs/tegra-common.h @@ -21,6 +21,7 @@
#define CONFIG_DM #define CONFIG_CMD_DM +#define CONFIG_DM_GPIO
I still believe that there is a single Tegra GPIO controller, and this should be represented by a single device in the U-Boot device model.
Hi Stephen,
It is possible that this is the best way to go, but it is far from certain. I have just had a try at implementing this for exynos now that the GPIO patches have been applied. I find a number of independent GPIO banks which fits nicely into the driver model idea of hierarchical devices. I'm on the fence with Tegra, but feel my approach is reasonable for now.
If we go with the route you suggest, we'll have to deal with a single device having multiple banks. That may be necessary/expedient at some point but for now I would prefer to add complexity/features as they are needed, and not before. Once we have a few more GPIO conversions done it should be clearer. It is very early days with driver model and we don't have a lot of information as to what is best. If we want to change the way GPIO drivers are done in a few months, it is not a big job and I will happily do it, I just don't want to build more complexity than we need early on.
There is also no need for a single hardware device to be a single U-Boot 'struct device'. In particular mfd devices have several children with different functions. One of the founding principles of U-Boot's driver model was to support child devices easily and in a general way. IMO we might as well take advantage of it.
One little update - region size increases:
$ ./tools/buildman/buildman -b us-gpio6 -sS seaboard ... 13: tegra: Enable driver model arm: (for 1/1 boards) all +5088.0 bss -4.0 data +182.0 rodata +766.0 spl/u-boot-spl:all +16.0 spl/u-boot-spl:data +16.0 text +4144.0 14: tegra: Convert tegra GPIO driver to use driver model arm: (for 1/1 boards) all -1422.0 bss -4480.0 data +88.0 rodata +330.0 spl/u-boot-spl:all +32.0 spl/u-boot-spl:text +32.0 text +2640.0
Masahiro Yamada
Rommel G Custodio
Stephen Warren
