[U-Boot] [PATCH] powerpc/85xx: Add workaround for erratum CPU-A011 on e500mc cores
Issue: CoreNet bad data signal is not sent with shared data from L1 Data Cache when it has an error
Workaround: Run in write-shadow mode by setting L1CSR2[DCWS] = 1
By default we do NOT enable this, thus we have #undef in config_mpc85xx.h for this erratum.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/cpu/mpc85xx/cmd_errata.c | 3 +++ arch/powerpc/cpu/mpc85xx/cpu_init.c | 3 ++- arch/powerpc/cpu/mpc85xx/release.S | 3 ++- arch/powerpc/include/asm/config_mpc85xx.h | 3 +++ 4 files changed, 10 insertions(+), 2 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cmd_errata.c b/arch/powerpc/cpu/mpc85xx/cmd_errata.c index 49f03f1..47bb0d2 100644 --- a/arch/powerpc/cpu/mpc85xx/cmd_errata.c +++ b/arch/powerpc/cpu/mpc85xx/cmd_errata.c @@ -53,6 +53,9 @@ static int do_errata(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) #if defined(CONFIG_SYS_P4080_ERRATUM_CPU22) puts("Work-around for Erratum CPU22 enabled\n"); #endif +#if defined(CONFIG_SYS_FSL_ERRATUM_CPU_E500MC_A011) + puts("Work-around for Erratum CPU-A011 enabled\n"); +#endif #if defined(CONFIG_SYS_FSL_ERRATUM_DDR_MSYNC_IN) puts("Work-around for DDR MSYNC_IN Erratum enabled\n"); #endif diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init.c b/arch/powerpc/cpu/mpc85xx/cpu_init.c index f1ab28b..a32cada 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init.c @@ -305,7 +305,8 @@ int cpu_init_r(void) volatile fsl_lbc_t *lbc = LBC_BASE_ADDR; #endif
-#if defined(CONFIG_SYS_P4080_ERRATUM_CPU22) +#if defined(CONFIG_SYS_P4080_ERRATUM_CPU22) || \ + defined(CONFIG_SYS_FSL_ERRATUM_CPU_E500MC_A011) flush_dcache(); mtspr(L1CSR2, (mfspr(L1CSR2) | L1CSR2_DCWS)); sync(); diff --git a/arch/powerpc/cpu/mpc85xx/release.S b/arch/powerpc/cpu/mpc85xx/release.S index 6678ed4..272b3e6 100644 --- a/arch/powerpc/cpu/mpc85xx/release.S +++ b/arch/powerpc/cpu/mpc85xx/release.S @@ -137,7 +137,8 @@ __secondary_start_page: mtspr L1CSR2,r8 #endif
-#if defined(CONFIG_SYS_P4080_ERRATUM_CPU22) +#if defined(CONFIG_SYS_P4080_ERRATUM_CPU22) || \ + defined(CONFIG_SYS_FSL_ERRATUM_CPU_E500MC_A011) mfspr r8,L1CSR2 oris r8,r8,(L1CSR2_DCWS)@h mtspr L1CSR2,r8 diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index ff93367..484654c 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -311,6 +311,7 @@ #define CONFIG_SYS_FSL_USB1_PHY_ENABLE #define CONFIG_SYS_FSL_USB2_PHY_ENABLE #define CONFIG_SYS_FSL_USB_INTERNAL_UTMI_PHY +#undef CONFIG_SYS_FSL_ERRATUM_CPU_E500MC_A011 #define CONFIG_SYS_FSL_ERRATUM_ESDHC111 #define CONFIG_SYS_FSL_ERRATUM_USBxx
@@ -330,6 +331,7 @@ #define CONFIG_SYS_FSL_USB1_PHY_ENABLE #define CONFIG_SYS_FSL_USB2_PHY_ENABLE #define CONFIG_SYS_FSL_USB_INTERNAL_UTMI_PHY +#undef CONFIG_SYS_FSL_ERRATUM_CPU_E500MC_A011 #define CONFIG_SYS_FSL_ERRATUM_ESDHC111 #define CONFIG_SYS_FSL_ERRATUM_USBxx
@@ -349,6 +351,7 @@ #define CONFIG_SYS_FSL_USB1_PHY_ENABLE #define CONFIG_SYS_FSL_USB2_PHY_ENABLE #define CONFIG_SYS_FSL_USB_INTERNAL_UTMI_PHY +#undef CONFIG_SYS_FSL_ERRATUM_CPU_E500MC_A011 #define CONFIG_SYS_FSL_ERRATUM_ESDHC111 #define CONFIG_SYS_FSL_ERRATUM_USBxx
Dear Kumar Gala,
In message 1314443032-2811-1-git-send-email-galak@kernel.crashing.org you wrote:
NAK. Please do not undef what is not defined anyway.
On Aug 27, 2011, at 6:36 AM, Wolfgang Denk wrote:
Dear Kumar Gala,
Any suggestions on how to do this? - comment it out?
/* #define CONFIG_SYS_FSL_ERRATUM_CPU_E500MC_A011 */
- k
Dear Kumar Gala,
In message 8D21ECF0-CB7E-4DDE-9F18-E1828FF5E8C2@kernel.crashing.org you wrote:
That would be dead code.
You don't want to add all possible #defines to your config files, do you? This is not a good weay to document your code.
Apropos documentation - I did not see that you explain CONFIG_SYS_FSL_ERRATUM_CPU_E500MC_A011 (or any other of the ton of CONFIG_SYS_FSL_ERRATUM_* you have) in the readme, or elsewehere.
_This_ is what you should fix.
On Aug 27, 2011, at 8:41 AM, Wolfgang Denk wrote:
Dear Kumar Gala,
Gotcha.
I'll add a general comment about CONFIG_SYS_FSL_ERRATUM_* in README and a new doc/README.fsl-ppc-errata if that sounds good.
- k
Dear Kumar Gala,
In message 1A241F20-4DDB-4A57-8590-30735E9665A9@kernel.crashing.org you wrote:
Thanks, appreciated.
Kumar Gala
