[U-Boot] [PATCH v2] socfpga: clean up sfp generation
From: Dalon Westergreen dalon.westergreen@intel.com
Move the sfp file generation entirely to the root Makefile. This means that the u-boot-spl.sfp will only be generated when required and only for the socfpga variants that require it.
sfp generation is now entirely controlled by CONFIG_BUILD_TARGET being set to either spl/u-boot-spl.sfp or more likely u-boot-with-spl.sfp
Signed-off-by: Dalon Westergreen dalon.westergreen@intel.com
--- v2: -> condense changes to 1 patch to avoid breaking git bisect --- Makefile | 11 ++++++++--- scripts/Makefile.spl | 12 ------------ 2 files changed, 8 insertions(+), 15 deletions(-)
diff --git a/Makefile b/Makefile index aadd1ec8c6..16ce14d071 100644 --- a/Makefile +++ b/Makefile @@ -1207,6 +1207,14 @@ u-boot.spr: spl/u-boot-spl.img u-boot.img FORCE $(call if_changed,pad_cat)
ifneq ($(CONFIG_ARCH_SOCFPGA),) +ifdef CONFIG_TARGET_SOCFPGA_ARRIA10 +MKIMAGEFLAGS_$(SPL_BIN).sfp = -T socfpgaimage_v1 +else +MKIMAGEFLAGS_$(SPL_BIN).sfp = -T socfpgaimage +endif +spl/u-boot-spl.sfp: spl/u-boot-spl.bin FORCE + $(call if_changed,mkimage) + quiet_cmd_socboot = SOCBOOT $@ cmd_socboot = cat spl/u-boot-spl.sfp spl/u-boot-spl.sfp \ spl/u-boot-spl.sfp spl/u-boot-spl.sfp \ @@ -1542,9 +1550,6 @@ spl/sunxi-spl.bin: spl/u-boot-spl spl/sunxi-spl-with-ecc.bin: spl/sunxi-spl.bin @:
-spl/u-boot-spl.sfp: spl/u-boot-spl - @: - spl/boot.bin: spl/u-boot-spl @:
diff --git a/scripts/Makefile.spl b/scripts/Makefile.spl index 7416abec62..a58113cee2 100644 --- a/scripts/Makefile.spl +++ b/scripts/Makefile.spl @@ -198,10 +198,6 @@ ifdef CONFIG_SAMSUNG ALL-y += $(obj)/$(BOARD)-spl.bin endif
-ifdef CONFIG_ARCH_SOCFPGA -ALL-y += $(obj)/$(SPL_BIN).sfp -endif - ifdef CONFIG_ARCH_SUNXI ALL-y += $(obj)/sunxi-spl.bin
@@ -324,14 +320,6 @@ LDFLAGS_$(SPL_BIN) += -Ttext $(CONFIG_SPL_TEXT_BASE) endif endif
-ifdef CONFIG_TARGET_SOCFPGA_ARRIA10 -MKIMAGEFLAGS_$(SPL_BIN).sfp = -T socfpgaimage_v1 -else -MKIMAGEFLAGS_$(SPL_BIN).sfp = -T socfpgaimage -endif -$(obj)/$(SPL_BIN).sfp: $(obj)/$(SPL_BIN).bin FORCE - $(call if_changed,mkimage) - quiet_cmd_mksunxiboot = MKSUNXI $@ cmd_mksunxiboot = $(objtree)/tools/mksunxiboot \ --default-dt $(CONFIG_DEFAULT_DEVICE_TREE) $< $@
v2:
Shouldn't that be ifneq ($(CONFIG....),) ?, just like the line above ?
Otherwise it looks good I think :)
On Sun, 2018-10-14 at 19:58 +0200, Marek Vasut wrote:
On 10/13/2018 12:13 AM, Dalon Westergreen wrote: From: Dalon Westergreen dalon.westergreen@intel.com Move the sfp file generation entirely to the root Makefile. Thismeans that the u-boot-spl.sfp will only be generated when requiredand only for the socfpga variants that require it. sfp generation is now entirely controlled by CONFIG_BUILD_TARGETbeing set to either spl/u-boot-spl.sfp or more likelyu-boot-with-spl.sfp Signed-off-by: Dalon Westergreen dalon.westergreen@intel.com ---v2: -> condense changes to 1 patch to avoid breaking git bisect--- Makefile | 11 ++++++++--- scripts/Makefile.spl | 12 ------------ 2 files changed, 8 insertions(+), 15 deletions(-) diff --git a/Makefile b/Makefileindex aadd1ec8c6..16ce14d071 100644--- a/Makefile+++ b/Makefile@@ -1207,6 +1207,14 @@ u-boot.spr: spl/u-boot-spl.img u-boot.img FORCE $(call if_changed,pad_cat) ifneq ($(CONFIG_ARCH_SOCFPGA),)+ifdef CONFIG_TARGET_SOCFPGA_ARRIA10 Shouldn't that be ifneq ($(CONFIG....),) ?, just like the line above ?
That was just cut and paste from scripts/Makefile.spl, but i will change it. --dalon
+MKIMAGEFLAGS_$(SPL_BIN).sfp = -T socfpgaimage_v1+else+MKIMAGEFLAGS_$(SPL_BIN).sfp = -T socfpgaimage+endif+spl/u-boot-spl.sfp: spl/u-boot-spl.bin FORCE+ $(call if_changed,mkimage) Otherwise it looks good I think :)
On 10/13/2018 12:13 AM, Dalon Westergreen wrote: From: Dalon Westergreen <dalon.westergreen@intel.com mailto:dalon.westergreen@intel.com>
Signed-off-by: Dalon Westergreen <dalon.westergreen@intel.com mailto:dalon.westergreen@intel.com>
v2:
Thanks
Dalon Westergreen
Westergreen, Dalon
