[U-Boot] [PATCH] ppc4xx: Fix TLB reset problem with recent 44x images
Patch d873133f [ppc4xx: Add Sequoia RAM-booting target] broke "normal" booting on some 44x platforms. This breakage is only noticed in some cases while powercycling. As it seems, the code in question in start.S didn't invalidate TLB #0. This makes sense since this TLB is used for the bootrom mapping. With the patch mentioned above even TLB #0 got invalidated resulting in an error later on.
This patch now fixes this issue by only invalidating TLB #0 in the RAM- booting case.
Tested succesfully on Sequoia and Canyonlands.
Signed-off-by: Stefan Roese sr@denx.de Cc: Dirk Eibach Eibach@gdsys.de --- cpu/ppc4xx/start.S | 9 +++++++-- 1 files changed, 7 insertions(+), 2 deletions(-)
diff --git a/cpu/ppc4xx/start.S b/cpu/ppc4xx/start.S index 582c781..2f06914 100644 --- a/cpu/ppc4xx/start.S +++ b/cpu/ppc4xx/start.S @@ -450,9 +450,14 @@ skip_debug_init: /* Clear all TLB entries -- TID = 0, TS = 0 */ /*----------------------------------------------------------------*/ addis r0,0,0x0000 - li r1,0x003f /* 64 TLB entries */ - mtctr r1 +#ifdef CONFIG_SYS_RAMBOOT li r4,0 /* Start with TLB #0 */ +#else + li r4,1 /* Start with TLB #1 */ +#endif + li r1,64 /* 64 TLB entries */ + sub r1,r1,r4 /* calculate last TLB # */ + mtctr r1 rsttlb: #ifdef CONFIG_SYS_RAMBOOT tlbre r3,r4,0 /* Read contents from TLB word #0 to get EPN */
Applied to ppc4xx/master. Thanks.
Best regards, Stefan
Stefan Roese
