[U-Boot] [PATCH] Revert "ARM: SPL: do not set gd again"
At the high level, the problem is that we set gd multiple times (and still do, even after the commit we're reverting). We set important parts of gd to the copy which is not above stack but rather in the data section. For the release, we're going to revert this change and for the next release we shall correct things to only, really, set gd once to an appropriate location and ensure that comments about it are correct too.
This reverts commit f0c3a6c4ad09210d5d4aeafe87685ee75e5683d6.
Acked-by: Albert Aribaud albert.u.boot@aribaud.net Signed-off-by: Tom Rini trini@ti.com --- arch/arm/lib/spl.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/arm/lib/spl.c b/arch/arm/lib/spl.c index 75ab546..dfcc596 100644 --- a/arch/arm/lib/spl.c +++ b/arch/arm/lib/spl.c @@ -28,6 +28,9 @@ void __weak board_init_f(ulong dummy) /* Clear the BSS. */ memset(__bss_start, 0, __bss_end - __bss_start);
+ /* Set global data pointer. */ + gd = &gdata; + board_init_r(NULL, 0); }
+Albert
Hi Tom,
Is this going to be un-reverted? I will need this done to apply the driver model SPL series.
On Mon, Nov 10, 2014 at 03:13:44PM -0700, Simon Glass wrote:
+Albert
Hi Tom,
So I've got am335x working again locally and now I'm trying to see if we need to introduce a SoC-specific board_init_f for SPL here or not or if I can shove save_omap_boot_params() into spl_board_init() and add preloader_console_init rather generically to the ARM board_init_f SPL function. Once I've got this clean enough I need to dust off some davinci and omap3 targets, do similar changes and then see if Hans was right about why my olimex Allwinner board was behaving badly, and if so, test the changes there too. That'll cover most of the ARM boards that re-set gd themselves when they can't with the above change re-introduced.
Hi Tom,
+Albert
Hi Tom,
OK thanks. I might pull in some of the non-dependent patches in the meantime.
Hi all,
+Albert
Hi Tom,
Any progress on this?
Regards, Jeroen
On Fri, Nov 28, 2014 at 10:48:37PM +0100, Jeroen Hofstee wrote:
Hi all,
+Albert
Hi Tom,
Not really. I got as far as the following (which of course breaks non-TI ARMv7 boards):
diff --git a/arch/arm/cpu/armv7/am33xx/board.c b/arch/arm/cpu/armv7/am33xx/board.c index 29b1d73..7681025 100644 --- a/arch/arm/cpu/armv7/am33xx/board.c +++ b/arch/arm/cpu/armv7/am33xx/board.c @@ -302,9 +302,6 @@ void s_init(void) gd->baudrate = CONFIG_BAUDRATE; serial_init(); gd->have_console = 1; -#elif defined(CONFIG_SPL_BUILD) - gd = &gdata; - preloader_console_init(); #endif #if defined(CONFIG_SPL_AM33XX_ENABLE_RTC32K_OSC) /* Enable RTC32K clock */ diff --git a/arch/arm/lib/spl.c b/arch/arm/lib/spl.c index dfcc596..1e0be2a 100644 --- a/arch/arm/lib/spl.c +++ b/arch/arm/lib/spl.c @@ -28,8 +28,16 @@ void __weak board_init_f(ulong dummy) /* Clear the BSS. */ memset(__bss_start, 0, __bss_end - __bss_start);
- /* Set global data pointer. */ - gd = &gdata; + /* + * Save the boot parameters passed from romcode. + * We cannot delay the saving further than this, + * to prevent overwrites. + */ +#ifdef CONFIG_SPL_BUILD + save_omap_boot_params(); +#endif + + preloader_console_init();
It needs testing on more TI boards to make sure there's nothing else missing (and there's probably some similar tweaks needed on other TI platforms even). That we can move the save_omap_boot_params call later (and duplicate calling it, even) bodes fairly well for an easy conversion to perphaps spl_board_init() on these boards.
Jeroen Hofstee
