[U-Boot] [PATCH 5/5] add TI da8xx support: integration into build system
Add config, Makefile and common header changes to integrate DA8xx Support.
Creates a new config target: make ... da8xx_omapl1_evm_config
Tested build with Sourcery G++ Lite 2009q1-203 tool chain on an OMAP-L137 EVM board RevE with Rev1.1 DA830 silicon.
Signed-off-by: Nick Thompson nick.thompson@gefanuc.com --- Applies to u-boot-ti
Makefile | 4 + include/common.h | 3 + include/configs/da8xx_evm.h | 241 +++++++++++++++++++++++++++++++++++++++++++
diff --git a/Makefile b/Makefile index 449099a..26170db 100644 --- a/Makefile +++ b/Makefile @@ -2936,6 +2936,10 @@ davinci_dm365evm_config : unconfig davinci_dm6467evm_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm926ejs dm6467evm davinci davinci
+xtract_da8xx = $(subst da8xx_omapl1,da8xx,$(subst _config,,$1)) +da8xx_omapl1_evm_config : unconfig + @$(MKCONFIG) $(call xtract_da8xx,$@) arm arm926ejs da8xx-evm da8xx da8xx + imx27lite_config: unconfig @$(MKCONFIG) $(@:_config=) arm arm926ejs imx27lite logicpd mx27
diff --git a/include/common.h b/include/common.h index f7c93bf..5c8d609 100644 --- a/include/common.h +++ b/include/common.h @@ -107,6 +107,9 @@ typedef volatile unsigned char vu_char; #ifdef CONFIG_BLACKFIN #include <asm/blackfin.h> #endif +#ifdef CONFIG_DA8XX +#include <asm/arch/hardware.h> +#endif
#include <part.h> #include <flash.h> diff --git a/include/configs/da8xx_evm.h b/include/configs/da8xx_evm.h new file mode 100644 index 0000000..8bdbb71 --- /dev/null +++ b/include/configs/da8xx_evm.h @@ -0,0 +1,241 @@ +/* + * Copyright (C) 2008 Texas Instruments, Inc <www.ti.com> + * + * Based on davinci_dvevm.h. Original Copyrights follow: + * + * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H +#include <asm/sizes.h> +#include <asm/arch/clock.h> + +/*=======*/ +/* Board */ +/*=======*/ +/* #define CONFIG_USE_SPIFLASH */ +/* #define CONFIG_USE_NAND */ + +/*===================*/ +/* SoC Configuration */ +/*===================*/ +#define CONFIG_ARM926EJS /* arm926ejs CPU core */ +#define CONFIG_DA8XX /* TI DA8xx SoC */ +#define CONFIG_SYS_CLK_FREQ clk_get(DAVINCI_ARM_CLKID) /* Arm Clock */ +#define CONFIG_SYS_OSCIN_FREQ 24000000 +#define CONFIG_SYS_TIMERBASE DAVINCI_TIMER0_BASE /* use timer 0 */ +#define CONFIG_SYS_HZ_CLOCK clk_get(DAVINCI_AUXCLK_CLKID) /* Timer Input clock freq */ +#define CONFIG_SYS_HZ 1000 +#undef CONFIG_SKIP_LOWLEVEL_INIT /* U-Boot is _always_ loaded by a bootloader */ +#define CONFIG_SKIP_RELOCATE_UBOOT /* to a proper address, init done */ + +/*=============*/ +/* Memory Info */ +/*=============*/ +#define CONFIG_SYS_MALLOC_LEN (0x10000 + 1*1024*1024) /* malloc() len */ +#define CONFIG_SYS_GBL_DATA_SIZE 128 /* reserved for initial data */ +#define PHYS_SDRAM_1 DAVINCI_DDR_EMIF_DATA_BASE /* DDR Start */ +#define PHYS_SDRAM_1_SIZE 0x04000000 /* SDRAM size 64MB */ +#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM_1 /* memtest start address */ +#define CONFIG_SYS_MEMTEST_END (PHYS_SDRAM_1 + 16*1024*1024) /* 16MB RAM test */ +#define CONFIG_NR_DRAM_BANKS 1 /* we have 1 bank of DRAM */ +#define CONFIG_STACKSIZE (256*1024) /* regular stack */ +#define SDRAM_4BANKS_10COLS /* TODO: Update this! */ + +/*====================*/ +/* Serial Driver info */ +/*====================*/ +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE -4 /* NS16550 register size */ +#define CONFIG_SYS_NS16550_COM1 DAVINCI_UART2_BASE /* Base address of UART2 */ +#define CONFIG_SYS_NS16550_CLK clk_get(DAVINCI_UART2_CLKID) /* Input clock to NS16550 */ +#define CONFIG_CONS_INDEX 1 /* use UART0 for console */ +#define CONFIG_BAUDRATE 115200 /* Default baud rate */ +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/*===================*/ +/* I2C Configuration */ +/*===================*/ +#define CONFIG_HARD_I2C +#define CONFIG_DRIVER_DAVINCI_I2C +#define CONFIG_SYS_I2C_SPEED 25000 /* 100Kbps won't work, silicon bug */ +#define CONFIG_SYS_I2C_SLAVE 10 /* Bogus, master-only in U-Boot */ + +/*====================================================*/ +/* I2C EEPROM definitions for catalyst 24W256 EEPROM chip */ +/*====================================================*/ +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 6 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 20 + +/*==================================*/ +/* Network & Ethernet Configuration */ +/*==================================*/ +#define CONFIG_DRIVER_DA8XX_EMAC +#define CONFIG_MII +#define CONFIG_BOOTP_DEFAULT +#define CONFIG_BOOTP_DNS +#define CONFIG_BOOTP_DNS2 +#define CONFIG_BOOTP_SEND_HOSTNAME +#define CONFIG_NET_RETRY_COUNT 10 +#define CONFIG_NET_MULTI + +/*=====================*/ +/* Flash & Environment */ +/*=====================*/ +#ifdef CONFIG_USE_NAND +#undef CONFIG_ENV_IS_IN_FLASH +#define CONFIG_NAND_DAVINCI +#define CONFIG_SYS_NO_FLASH +#define CONFIG_ENV_IS_IN_NAND /* U-Boot env in NAND Flash */ +#define CONFIG_ENV_OFFSET 0x0 /* Block 0--not used by bootcode */ +#define CONFIG_ENV_SIZE SZ_128K +#define CONFIG_SYS_NAND_4BIT_HW_ECC_OOBFIRST +#define CONFIG_SYS_NAND_CS 3 +#define CONFIG_SYS_NAND_BASE DAVINCI_ASYNC_EMIF_DATA_CE3_BASE +#define CONFIG_SYS_CLE_MASK 0x10 +#define CONFIG_SYS_ALE_MASK 0x8 +#define CONFIG_SYS_NAND_HW_ECC +#define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND devices */ +#define NAND_MAX_CHIPS 1 +#define DEF_BOOTM "" +#endif + +#ifdef CONFIG_USE_NOR +#define CONFIG_ENV_IS_IN_FLASH +#undef CONFIG_SYS_NO_FLASH +#define CONFIG_SYS_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of flash banks */ +#define CONFIG_SYS_FLASH_SECT_SZ 0x10000 /* 64KB sect size AMD Flash */ +#define CONFIG_ENV_OFFSET (CONFIG_SYS_FLASH_SECT_SZ*3) +#define CONFIG_SYS_FLASH_BASE DAVINCI_ASYNC_EMIF_DATA_CE2_BASE +#define PHYS_FLASH_SIZE 0x2000000 /* Flash size 32MB */ +#define CONFIG_SYS_MAX_FLASH_SECT (PHYS_FLASH_SIZE/CONFIG_SYS_FLASH_SECT_SZ) +#define CONFIG_ENV_SECT_SIZE CONFIG_SYS_FLASH_SECT_SZ /* Env sector Size */ +#define CONFIG_SYS_FLASH_SPL_ACCESS +#endif + +#ifdef CONFIG_USE_SPIFLASH +#undef CONFIG_ENV_IS_IN_FLASH +#undef CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_SIZE SZ_16K +#define CONFIG_ENV_OFFSET SZ_256K +#define CONFIG_ENV_SECT_SIZE SZ_4K +#define CONFIG_SYS_NO_FLASH +#define CONFIG_SPI +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_WINBOND +#define CONFIG_DAVINCI_SPI +#define CONFIG_SYS_SPI_BASE DAVINCI_SPI0_BASE +#define CONFIG_SYS_SPI_CLK clk_get(DAVINCI_SPI0_CLKID) +#define CONFIG_SF_DEFAULT_SPEED 50000000 +#define CONFIG_SYS_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED +#endif + + +/*==============================*/ +/* U-Boot general configuration */ +/*==============================*/ +#undef CONFIG_USE_IRQ /* No IRQ/FIQ in U-Boot */ +#define CONFIG_MISC_INIT_R +#undef CONFIG_BOOTDELAY +#define CONFIG_BOOTFILE "uImage" /* Boot file name */ +#define CONFIG_SYS_PROMPT "U-Boot > " /* Monitor Command Prompt */ +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print buffer sz */ +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_MEMTEST_START + 0x700000) /* default Linux kernel load address */ +#define CONFIG_VERSION_VARIABLE +#define CONFIG_AUTO_COMPLETE /* Won't work with hush so far, may be later */ +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_CMDLINE_EDITING +#define CONFIG_SYS_LONGHELP +#define CONFIG_CRC32_VERIFY +#define CONFIG_MX_CYCLIC +/* #define CONFIG_USB_DA8XX */ +/* #define CONFIG_MUSB_HCD */ +#define CONFIG_USE_PINMUX + +/*===================*/ +/* Linux Information */ +/*===================*/ +#define LINUX_BOOT_PARAM_ADDR (CONFIG_SYS_MEMTEST_START + 0x100) +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_BOOTARGS "mem=32M console=ttyS2,115200n8 root=/dev/mtdblock/2 rw noinitrd ip=dhcp" +#define CONFIG_BOOTCOMMAND "" +#define CONFIG_BOOTDELAY 3 + +/*=================*/ +/* U-Boot commands */ +/*=================*/ +#include <config_cmd_default.h> +#define CONFIG_CMD_ENV +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_DIAG +#define CONFIG_CMD_MII +#define CONFIG_CMD_PING +#define CONFIG_CMD_SAVES +#define CONFIG_CMD_MEMORY +#undef CONFIG_CMD_BDI +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_SETGETDCR +#define CONFIG_CMD_EEPROM + +#ifdef CONFIG_USE_NAND +#undef CONFIG_CMD_FLASH +#undef CONFIG_CMD_IMLS +#define CONFIG_CMD_NAND +#define CONFIG_CMD_MTDPARTS +#define CONFIG_MTD_PARTITIONS +#define CONFIG_CMD_UBI +#define CONFIG_RBTREE +#endif + +#ifdef CONFIG_USE_SPIFLASH +#undef CONFIG_CMD_IMLS +#undef CONFIG_CMD_FLASH +#define CONFIG_CMD_SPI +#define CONFIG_CMD_SAVEENV +#endif + +#if !defined(CONFIG_USE_NAND) && !defined(CONFIG_USE_NOR) && !defined(CONFIG_USE_SPIFLASH) +#define CONFIG_ENV_IS_NOWHERE +#define CONFIG_SYS_NO_FLASH +#define CONFIG_ENV_SIZE SZ_16K +#undef CONFIG_CMD_IMLS +#undef CONFIG_CMD_FLASH +#undef CONFIG_CMD_ENV +#endif + +#ifdef CONFIG_USB_DA8XX +#define CONFIG_CMD_USB /* inclue support for usb */ +#define CONFIG_CMD_STORAGE /* inclue support for usb */ +#define CONFIG_CMD_FAT /* inclue support for FAT/storage*/ +#define CONFIG_DOS_PARTITION /* inclue support for FAT/storage*/ +#endif + +#endif /* __CONFIG_H */
Need to add target to MAKEALL Need to add yourself to board maintainers
What is the point of this ? Can you just call the config directly ?
- @$(MKCONFIG) $(call xtract_da8xx,$@) arm arm926ejs da8xx-evm da8xx da8xx
Who is the board manufacturer? The config name will likely have to change to be consistent with other davini configs.
Sandeep, Can you provide guidance here ?
- Copyright (C) 2008 Texas Instruments, Inc <www.ti.com>
- Based on davinci_dvevm.h. Original Copyrights follow:
- Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net
- MA 02111-1307 USA
Multiline comments
Why the commented out defines?
Trailing whitespace, fix globally
Yes update this ..
Convert to (128 << 10) See Sandeep's recent changes to remove SZ's Apply globally
You may want to change this to something less generic.
Lines above exceed 80 chars. Please fix
Remove if not needed
Tab
Extra space here
Spelling, change to 'include'
+#endif /* __CONFIG_H */ _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Tom
