[U-Boot] [PATCH V5 1/4] add TI DA8xx support: DA8xx includes
Provides initial support for TI OMAP-L1x/DA8xx SoC devices. See http://www.ti.com
The DA8xx devices are similar to DaVinci devices but have a differing memory map and updated peripheral versions.
Signed-off-by: Nick Thompson nick.thompson@gefanuc.com Signed-off-by: Sekhar Nori nsekhar@ti.com --- Applies to u-boot-ti
include/asm-arm/arch-davinci/hardware.h | 237 +++++++++++++++++++++++++++++++ include/asm-arm/arch-davinci/i2c_defs.h | 5 + 2 files changed, 242 insertions(+), 0 deletions(-)
diff --git a/include/asm-arm/arch-davinci/hardware.h b/include/asm-arm/arch-davinci/hardware.h index acf12ea..81cc8ab 100644 --- a/include/asm-arm/arch-davinci/hardware.h +++ b/include/asm-arm/arch-davinci/hardware.h @@ -49,6 +49,8 @@ typedef volatile unsigned int * dv_reg_p; * on other DaVinci chips. Double check them before you try * using the addresses ... or PSC module identifiers, etc. */ +#ifndef CONFIG_SOC_DA8XX + #define DAVINCI_DMA_3PCC_BASE (0x01c00000) #define DAVINCI_DMA_3PTC0_BASE (0x01c10000) #define DAVINCI_DMA_3PTC1_BASE (0x01c10400) @@ -116,10 +118,46 @@ typedef volatile unsigned int * dv_reg_p;
#endif
+#else /* CONFIG_SOC_DA8XX */ + +#define DAVINCI_UART0_BASE 0x01c42000 +#define DAVINCI_UART1_BASE 0x01d0c000 +#define DAVINCI_UART2_BASE 0x01d0d000 +#define DAVINCI_I2C0_BASE 0x01c22000 +#define DAVINCI_I2C1_BASE 0x01e28000 +#define DAVINCI_TIMER0_BASE 0x01c20000 +#define DAVINCI_TIMER1_BASE 0x01c21000 +#define DAVINCI_WDOG_BASE 0x01c21000 +#define DAVINCI_PLL_CNTRL0_BASE 0x01c11000 +#define DAVINCI_PSC0_BASE 0x01c10000 +#define DAVINCI_PSC1_BASE 0x01e27000 +#define DAVINCI_SPI0_BASE 0x01c41000 +#define DAVINCI_USB_OTG_BASE 0x01e00000 +#define DAVINCI_SPI1_BASE 0x01e12000 +#define DAVINCI_GPIO_BASE 0x01e26000 +#define DAVINCI_EMAC_CNTRL_REGS_BASE 0x01e23000 +#define DAVINCI_EMAC_WRAPPER_CNTRL_REGS_BASE 0x01e22000 +#define DAVINCI_EMAC_WRAPPER_RAM_BASE 0x01e20000 +#define DAVINCI_MDIO_CNTRL_REGS_BASE 0x01e24000 +#define DAVINCI_ASYNC_EMIF_CNTRL_BASE 0x68000000 +#define DAVINCI_ASYNC_EMIF_DATA_CE0_BASE 0x40000000 +#define DAVINCI_ASYNC_EMIF_DATA_CE2_BASE 0x60000000 +#define DAVINCI_ASYNC_EMIF_DATA_CE3_BASE 0x62000000 +#define DAVINCI_ASYNC_EMIF_DATA_CE4_BASE 0x64000000 +#define DAVINCI_ASYNC_EMIF_DATA_CE5_BASE 0x66000000 +#define DAVINCI_DDR_EMIF_CTRL_BASE 0xb0000000 +#define DAVINCI_DDR_EMIF_DATA_BASE 0xc0000000 +#define DAVINCI_INTC_BASE 0xfffee000 +#define DAVINCI_BOOTCFG_BASE 0x01c14000 + +#endif /* CONFIG_SOC_DA8XX */ + /* Power and Sleep Controller (PSC) Domains */ #define DAVINCI_GPSC_ARMDOMAIN 0 #define DAVINCI_GPSC_DSPDOMAIN 1
+#ifndef CONFIG_SOC_DA8XX + #define DAVINCI_LPSC_VPSSMSTR 0 #define DAVINCI_LPSC_VPSSSLV 1 #define DAVINCI_LPSC_TPCC 2 @@ -166,6 +204,52 @@ typedef volatile unsigned int * dv_reg_p; #define DAVINCI_DM646X_LPSC_UART0 26 #define DAVINCI_DM646X_LPSC_I2C 31
+#else /* CONFIG_SOC_DA8XX */ + +enum davinci_lpsc_ids { + DAVINCI_LPSC_TPCC = 0, + DAVINCI_LPSC_TPTC0, + DAVINCI_LPSC_TPTC1, + DAVINCI_LPSC_AEMIF, + DAVINCI_LPSC_SPI0, + DAVINCI_LPSC_MMC_SD, + DAVINCI_LPSC_AINTC, + DAVINCI_LPSC_ARM_RAM_ROM, + DAVINCI_LPSC_SECCTL_KEYMGR, + DAVINCI_LPSC_UART0, + DAVINCI_LPSC_SCR0, + DAVINCI_LPSC_SCR1, + DAVINCI_LPSC_SCR2, + DAVINCI_LPSC_DMAX, + DAVINCI_LPSC_ARM, + DAVINCI_LPSC_GEM, + /* for LPSCs in PSC1, offset from 32 for differentiation */ + DAVINCI_LPSC_PSC1_BASE = 32, + DAVINCI_LPSC_USB11, + DAVINCI_LPSC_USB20, + DAVINCI_LPSC_GPIO, + DAVINCI_LPSC_UHPI, + DAVINCI_LPSC_EMAC, + DAVINCI_LPSC_DDR_EMIF, + DAVINCI_LPSC_McASP0, + DAVINCI_LPSC_McASP1, + DAVINCI_LPSC_McASP2, + DAVINCI_LPSC_SPI1, + DAVINCI_LPSC_I2C1, + DAVINCI_LPSC_UART1, + DAVINCI_LPSC_UART2, + DAVINCI_LPSC_LCDC, + DAVINCI_LPSC_ePWM, + DAVINCI_LPSC_eCAP, + DAVINCI_LPSC_eQEP, + DAVINCI_LPSC_SCR_P0, + DAVINCI_LPSC_SCR_P1, + DAVINCI_LPSC_CR_P3, + DAVINCI_LPSC_L3_CBA_RAM +}; + +#endif /* CONFIG_SOC_DA8XX */ + void lpsc_on(unsigned int id); void dsp_on(void);
@@ -174,6 +258,8 @@ void davinci_enable_emac(void); void davinci_enable_i2c(void); void davinci_errata_workarounds(void);
+#ifndef CONFIG_SOC_DA8XX + /* Some PSC defines */ #define PSC_CHP_SHRTSW (0x01c40038) #define PSC_GBLCTL (0x01c41010) @@ -194,6 +280,39 @@ void davinci_errata_workarounds(void);
#define PSC_SILVER_BULLET (0x01c41a20)
+#else /* CONFIG_SOC_DA8XX */ + +#define PSC_PSC0_MODULE_ID_CNT 16 +#define PSC_PSC1_MODULE_ID_CNT 32 + +struct davinci_psc_regs { + dv_reg revid; + dv_reg rsvd0[71]; + dv_reg ptcmd; + dv_reg rsvd1; + dv_reg ptstat; + dv_reg rsvd2[437]; + union { + struct { + dv_reg mdstat[PSC_PSC0_MODULE_ID_CNT]; + dv_reg rsvd3[112]; + dv_reg mdctl[PSC_PSC0_MODULE_ID_CNT]; + } psc0; + struct { + dv_reg mdstat[PSC_PSC1_MODULE_ID_CNT]; + dv_reg rsvd3[96]; + dv_reg mdctl[PSC_PSC1_MODULE_ID_CNT]; + } psc1; + }; +}; + +#define davinci_psc0_regs ((struct davinci_psc_regs *)DAVINCI_PSC0_BASE) +#define davinci_psc1_regs ((struct davinci_psc_regs *)DAVINCI_PSC1_BASE) + +#endif /* CONFIG_SOC_DA8XX */ + +#ifndef CONFIG_SOC_DA8XX + /* Miscellania... */ #define VBPR (0x20000020)
@@ -206,4 +325,122 @@ void davinci_errata_workarounds(void); #define PINMUX3 0x01c4000c #define PINMUX4 0x01c40010
+#else /* CONFIG_SOC_DA8XX */ + +struct davinci_pllc_regs { + dv_reg revid; + dv_reg rsvd1[56]; + dv_reg rstype; + dv_reg rsvd2[6]; + dv_reg pllctl; + dv_reg ocsel; + dv_reg rsvd3[2]; + dv_reg pllm; + dv_reg prediv; + dv_reg plldiv1; + dv_reg plldiv2; + dv_reg plldiv3; + dv_reg oscdiv; + dv_reg postdiv; + dv_reg rsvd4[3]; + dv_reg pllcmd; + dv_reg pllstat; + dv_reg alnctl; + dv_reg dchange; + dv_reg cken; + dv_reg ckstat; + dv_reg systat; + dv_reg rsvd5[3]; + dv_reg plldiv4; + dv_reg plldiv5; + dv_reg plldiv6; + dv_reg plldiv7; + dv_reg rsvd6[32]; + dv_reg emucnt0; + dv_reg emucnt1; +}; + +#define davinci_pllc_regs ((struct davinci_pllc_regs *)DAVINCI_PLL_CNTRL0_BASE) +#define DAVINCI_PLLC_DIV_MASK 0x1f + +/* Clock IDs */ +enum davinci_clk_ids { + DAVINCI_SPI0_CLKID = 2, + DAVINCI_UART2_CLKID = 2, + DAVINCI_MDIO_CLKID = 4, + DAVINCI_ARM_CLKID = 6, + DAVINCI_PLLM_CLKID = 0xff, + DAVINCI_PLLC_CLKID = 0x100, + DAVINCI_AUXCLK_CLKID = 0x101 +}; + +int clk_get(enum davinci_clk_ids id); + +/* Boot config */ +struct davinci_syscfg_regs { + dv_reg revid; + dv_reg rsvd[71]; + dv_reg pinmux[20]; + dv_reg suspsrc; + dv_reg chipsig; + dv_reg chipsig_clr; + dv_reg cfgchip0; + dv_reg cfgchip1; + dv_reg cfgchip2; + dv_reg cfgchip3; + dv_reg cfgchip4; +}; + +#define davinci_syscfg_regs \ + ((struct davinci_syscfg_regs *)DAVINCI_BOOTCFG_BASE) + +/* Emulation suspend bits */ +#define DAVINCI_SYSCFG_SUSPSRC_EMAC (1 << 5) +#define DAVINCI_SYSCFG_SUSPSRC_I2C (1 << 16) +#define DAVINCI_SYSCFG_SUSPSRC_SPI0 (1 << 21) +#define DAVINCI_SYSCFG_SUSPSRC_UART2 (1 << 20) +#define DAVINCI_SYSCFG_SUSPSRC_TIMER0 (1 << 27) + +/* Interrupt controller */ +struct davinci_aintc_regs { + dv_reg revid; + dv_reg cr; + dv_reg dummy0[2]; + dv_reg ger; + dv_reg dummy1[219]; + dv_reg ecr1; + dv_reg ecr2; + dv_reg ecr3; + dv_reg dummy2[1117]; + dv_reg hier; +}; + +#define davinci_aintc_regs ((struct davinci_aintc_regs *)DAVINCI_INTC_BASE) + +struct davinci_uart_ctrl_regs { + dv_reg revid1; + dv_reg revid2; + dv_reg pwremu_mgmt; + dv_reg mdr; +}; + +#define DAVINCI_UART_CTRL_BASE 0x28 +#define DAVINCI_UART0_CTRL_ADDR (DAVINCI_UART0_BASE + DAVINCI_UART_CTRL_BASE) +#define DAVINCI_UART1_CTRL_ADDR (DAVINCI_UART1_BASE + DAVINCI_UART_CTRL_BASE) +#define DAVINCI_UART2_CTRL_ADDR (DAVINCI_UART2_BASE + DAVINCI_UART_CTRL_BASE) + +#define davinci_uart0_ctrl_regs \ + ((struct davinci_uart_ctrl_regs *)DAVINCI_UART0_CTRL_ADDR) +#define davinci_uart1_ctrl_regs \ + ((struct davinci_uart_ctrl_regs *)DAVINCI_UART1_CTRL_ADDR) +#define davinci_uart2_ctrl_regs \ + ((struct davinci_uart_ctrl_regs *)DAVINCI_UART2_CTRL_ADDR) + +/* UART PWREMU_MGMT definitions */ +#define DAVINCI_UART_PWREMU_MGMT_FREE (1 << 0) +#define DAVINCI_UART_PWREMU_MGMT_URRST (1 << 13) +#define DAVINCI_UART_PWREMU_MGMT_UTRST (1 << 14) + +#endif /* CONFIG_SOC_DA8XX */ + #endif /* __ASM_ARCH_HARDWARE_H */ diff --git a/include/asm-arm/arch-davinci/i2c_defs.h b/include/asm-arm/arch-davinci/i2c_defs.h index 2e902e1..24cd268 100644 --- a/include/asm-arm/arch-davinci/i2c_defs.h +++ b/include/asm-arm/arch-davinci/i2c_defs.h @@ -28,7 +28,11 @@ #define I2C_WRITE 0 #define I2C_READ 1
+#ifndef CONFIG_SOC_DA8XX #define I2C_BASE 0x01c21000 +#else +#define I2C_BASE 0x01c22000 +#endif
#define I2C_OA (I2C_BASE + 0x00) #define I2C_IE (I2C_BASE + 0x04) @@ -88,6 +92,7 @@ #define I2C_CON_XA (1 << 8) /* Expand address */ #define I2C_CON_STP (1 << 11) /* Stop condition (master mode only) */ #define I2C_CON_STT (1 << 13) /* Start condition (master mode only) */ +#define I2C_CON_FREE (1 << 14) /* Free run on emulation */
#define I2C_TIMEOUT 0xffff0000 /* Timeout mask for poll_i2c_irq() */
Pushed to u-boot-ti/master
http://git.denx.de/?p=u-boot/u-boot-ti.git;a=commit;h=32c39e2da8483093dea298...
modified the patch header a little.
Thanks, Sandeep
Dear "Paulraj, Sandeep",
In message 0554BEF07D437848AF01B9C9B5F0BC5D93F2F002@dlee01.ent.ti.com you wrote:
Argh...
Please do not push stuff to the master branch of the poublic repository so quickly. Please allow for a few days reviewing first.
I just NAKed this patch.
ti.git;a=commit;h=32c39e2da8483093dea29858a234ab2ec54e75bd
Argh...
Fine no issues with the NAK.
But this set is being discussed for a fortnight. There's a v5 in the patch header.
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de "I think they're going to take all this money that we spend now on war and death --" "And make them spend it on life." -- Edith Keeler and Kirk, "The City on the Edge of Forever", stardate unknown.
Argh...
Wolfgang,
I'm happy to submit a new patch to lowercase these enums if you think that would be a good idea. It might be inviting trouble, but I'm not aware of any outstanding patches that rely on these values directly.
I'm not thinking of process here, but we can catch if before it propagates anywhere.
Nick.
Dear Nick Thompson,
I'm sorry, but I was actually wrong here. I missed the fact that it was an enum. And the "CodingStyle" says: "Names of macros defining constants and labels in enums are capitalized.'
Sorry, my fault. I hereby withdraw my complaint and apologize for not being more careful.
Dear Nick Thompson,
- DAVINCI_LPSC_TPCC = 0,
- DAVINCI_LPSC_TPTC0,
- DAVINCI_LPSC_TPTC1,
- DAVINCI_LPSC_AEMIF,
- DAVINCI_LPSC_SPI0,
- DAVINCI_LPSC_MMC_SD,
- DAVINCI_LPSC_AINTC,
- DAVINCI_LPSC_ARM_RAM_ROM,
- DAVINCI_LPSC_SECCTL_KEYMGR,
- DAVINCI_LPSC_UART0,
- DAVINCI_LPSC_SCR0,
- DAVINCI_LPSC_SCR1,
- DAVINCI_LPSC_SCR2,
- DAVINCI_LPSC_DMAX,
- DAVINCI_LPSC_ARM,
- DAVINCI_LPSC_GEM,
- /* for LPSCs in PSC1, offset from 32 for differentiation */
- DAVINCI_LPSC_PSC1_BASE = 32,
- DAVINCI_LPSC_USB11,
- DAVINCI_LPSC_USB20,
- DAVINCI_LPSC_GPIO,
- DAVINCI_LPSC_UHPI,
- DAVINCI_LPSC_EMAC,
- DAVINCI_LPSC_DDR_EMIF,
- DAVINCI_LPSC_McASP0,
- DAVINCI_LPSC_McASP1,
- DAVINCI_LPSC_McASP2,
- DAVINCI_LPSC_SPI1,
- DAVINCI_LPSC_I2C1,
- DAVINCI_LPSC_UART1,
- DAVINCI_LPSC_UART2,
- DAVINCI_LPSC_LCDC,
- DAVINCI_LPSC_ePWM,
- DAVINCI_LPSC_eCAP,
- DAVINCI_LPSC_eQEP,
- DAVINCI_LPSC_SCR_P0,
- DAVINCI_LPSC_SCR_P1,
- DAVINCI_LPSC_CR_P3,
- DAVINCI_LPSC_L3_CBA_RAM
Variable names must be lower case. Please fix.
Also, it is good tradition to ad a comma to the last entry, too.
[snip]
I suspect the compiler would take issue if you tried to vary those constants...
-Scott
Nick Thompson
Paulraj, Sandeep
Scott Wood
