[PATCH] arm: mvebu: Clean up Thecus N2350 board DTS
- Update the Thecus N2350 DTS to conform with latest device-tree binding and styles. - Correct typo in mdio node.
Signed-off-by: Tony Dinh mibodhi@gmail.com ---
arch/arm/dts/armada-385-thecus-n2350.dts | 210 +++++++++++------------ 1 file changed, 98 insertions(+), 112 deletions(-)
diff --git a/arch/arm/dts/armada-385-thecus-n2350.dts b/arch/arm/dts/armada-385-thecus-n2350.dts index fc29c4d25a..2ad5158c0c 100644 --- a/arch/arm/dts/armada-385-thecus-n2350.dts +++ b/arch/arm/dts/armada-385-thecus-n2350.dts @@ -23,7 +23,7 @@ stdout-path = "serial0:115200n8"; };
- memory { + memory@0 { device_type = "memory"; reg = <0x00000000 0x40000000>; /* 1GB */ }; @@ -37,43 +37,43 @@
- usb3_0_phy: usb3_0_phy { + usb3_0_phy: usb-phy { compatible = "usb-nop-xceiv"; vcc-supply = <&usb3_0_power>; + #phy-cells = <0>; };
- usb3_1_phy: usb3_1_phy { + usb3_1_phy: usb-phy { compatible = "usb-nop-xceiv"; vcc-supply = <&usb3_1_power>; + #phy-cells = <0>; };
- gpio-keys { + keys { compatible = "gpio-keys"; - #address-cells = <1>; - #size-cells = <0>; pinctrl-0 = <&pmx_power_button &pmx_copy_button &pmx_reset_button>; pinctrl-names = "default";
- button@1 { + button-1 { label = "Power Button"; linux,code = <KEY_POWER>; gpios = <&gpio1 17 GPIO_ACTIVE_HIGH>; };
- button@2 { + button-2 { label = "Copy Button"; linux,code = <KEY_COPY>; gpios = <&gpio1 20 GPIO_ACTIVE_HIGH>; };
- button@3 { + button-3 { label = "Reset Button"; linux,code = <KEY_RESTART>; gpios = <&gpio1 18 GPIO_ACTIVE_HIGH>; }; };
- gpio-leds { + leds { compatible = "gpio-leds"; pinctrl-0 = <&pmx_sata1_white_led &pmx_sata1_red_led @@ -88,142 +88,132 @@
- white_sata1 { + led-1 { label = "n2350:white:sata1"; gpios = <&gpio0 20 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "ide-disk1"; };
- red_sata1 { + led-2 { label = "n2350:red:sata1"; gpios = <&gpio1 14 GPIO_ACTIVE_HIGH>; };
- white-sata2 { + led-3 { label = "n2350:white:sata2"; gpios = <&gpio0 19 GPIO_ACTIVE_HIGH>; };
- red-sata2 { + led-4 { label = "n2350:red:sata2"; gpios = <&gpio1 15 GPIO_ACTIVE_HIGH>; };
- white-sys { + led-5 { label = "n2350:white:sys"; gpios = <&gpio0 14 GPIO_ACTIVE_HIGH>; linux,default-trigger = "default-on"; };
- red-sys { + led-6 { label = "n2350:red:sys"; gpios = <&gpio0 15 GPIO_ACTIVE_HIGH>; };
- blue-pwr { + led-7 { label = "n2350:blue:pwr"; gpios = <&gpio1 11 GPIO_ACTIVE_HIGH>; };
- red-pwr { + led-8 { label = "n2350:red:pwr"; gpios = <&gpio0 18 GPIO_ACTIVE_HIGH>; };
- white-usb { + led-9 { label = "n2350:white:usb"; gpios = <&gpio0 16 GPIO_ACTIVE_HIGH>; };
- red-usb { + led-10 { label = "n2350:red:usb"; gpios = <&gpio0 17 GPIO_ACTIVE_HIGH>; }; };
- regulators { - compatible = "simple-bus"; - #address-cells = <1>; - #size-cells = <0>; - - usb3_0_power: regulator@1 { - compatible = "regulator-fixed"; - reg = <1>; - regulator-name = "USB3_0_Power"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - enable-active-high; - regulator-always-on; - regulator-boot-on; - gpio = <&gpio0 21 GPIO_ACTIVE_HIGH>; - }; - - usb3_1_power: regulator@2 { - compatible = "regulator-fixed"; - reg = <1>; - regulator-name = "USB3_1_Power"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - enable-active-high; - regulator-always-on; - regulator-boot-on; - gpio = <&gpio0 24 GPIO_ACTIVE_HIGH>; - }; + usb3_0_power: v5-vbus0 { + compatible = "regulator-fixed"; + regulator-name = "USB3_0_Power"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + enable-active-high; + regulator-always-on; + regulator-boot-on; + gpio = <&gpio0 21 GPIO_ACTIVE_HIGH>; + };
- reg_sata0: regulator@3 { - compatible = "regulator-fixed"; - regulator-name = "pwr_en_sata0"; - regulator-min-microvolt = <12000000>; - regulator-max-microvolt = <12000000>; - enable-active-high; - regulator-always-on; - regulator-boot-on; - gpio = <&gpio1 12 GPIO_ACTIVE_HIGH>; - }; + usb3_1_power: v5-vbus1 { + compatible = "regulator-fixed"; + regulator-name = "USB3_1_Power"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + enable-active-high; + regulator-always-on; + regulator-boot-on; + gpio = <&gpio0 24 GPIO_ACTIVE_HIGH>; + };
- reg_5v_sata0: v5-sata0 { - compatible = "regulator-fixed"; - regulator-name = "v5.0-sata0"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <®_sata0>; - }; + reg_sata0: pwr-sata0 { + compatible = "regulator-fixed"; + regulator-name = "pwr_en_sata0"; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + enable-active-high; + regulator-always-on; + regulator-boot-on; + gpio = <&gpio1 12 GPIO_ACTIVE_HIGH>; + };
- reg_12v_sata0: v12-sata0 { - compatible = "regulator-fixed"; - regulator-name = "v12.0-sata0"; - regulator-min-microvolt = <12000000>; - regulator-max-microvolt = <12000000>; - vin-supply = <®_sata0>; - }; + reg_5v_sata0: v5-sata0 { + compatible = "regulator-fixed"; + regulator-name = "v5.0-sata0"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <®_sata0>; + };
- reg_sata1: regulator@4 { - regulator-name = "pwr_en_sata1"; - compatible = "regulator-fixed"; - regulator-min-microvolt = <12000000>; - regulator-max-microvolt = <12000000>; - enable-active-high; - regulator-always-on; - regulator-boot-on; - gpio = <&gpio1 13 GPIO_ACTIVE_HIGH>; - }; + reg_12v_sata0: v12-sata0 { + compatible = "regulator-fixed"; + regulator-name = "v12.0-sata0"; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + vin-supply = <®_sata0>; + };
- reg_5v_sata1: v5-sata1 { - compatible = "regulator-fixed"; - regulator-name = "v5.0-sata1"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <®_sata1>; - }; + reg_sata1: pwr-sata0 { + regulator-name = "pwr_en_sata1"; + compatible = "regulator-fixed"; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + enable-active-high; + regulator-always-on; + regulator-boot-on; + gpio = <&gpio1 13 GPIO_ACTIVE_HIGH>; + };
- reg_12v_sata1: v12-sata1 { - compatible = "regulator-fixed"; - regulator-name = "v12.0-sata1"; - regulator-min-microvolt = <12000000>; - regulator-max-microvolt = <12000000>; - vin-supply = <®_sata1>; - }; + reg_5v_sata1: v5-sata1 { + compatible = "regulator-fixed"; + regulator-name = "v5.0-sata1"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <®_sata1>; + };
+ reg_12v_sata1: v12-sata1 { + compatible = "regulator-fixed"; + regulator-name = "v12.0-sata1"; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + vin-supply = <®_sata1>; };
gpio-poweroff { @@ -267,7 +257,7 @@ };
&mdio { - phy0: ethernet-phy@0 { + phy0: ethernet-phy@1 { reg = <1>; }; }; @@ -301,18 +291,14 @@
&pciec { status = "okay"; - /* - * The two PCIe units are accessible through - * standard PCIe slots on the board. - */ - pcie@1,0 { - /* Port 0, Lane 0 */ - status = "okay"; - }; - pcie@2,0 { - /* Port 1, Lane 0 */ - status = "okay"; - }; +}; + +&pcie1 { + status = "okay"; +}; + +&pcie2 { + status = "okay"; };
&pinctrl { @@ -408,10 +394,10 @@ status = "okay";
/* spi: 4M Flash Macronix MX25L3205D */ - spi-flash@0 { + flash@0 { #address-cells = <1>; #size-cells = <0>; - compatible = "macronix,mx25l3205d", "jedec,spi-nor"; + compatible = "jedec,spi-nor"; reg = <0>;
spi-max-frequency = <108000000>;
and styles.
Thanks, Stefan
- memory {
- memory@0 { device_type = "memory"; reg = <0x00000000 0x40000000>; /* 1GB */ };
@@ -37,43 +37,43 @@
- usb3_0_phy: usb-phy { compatible = "usb-nop-xceiv"; vcc-supply = <&usb3_0_power>;
};#phy-cells = <0>;
- usb3_1_phy: usb-phy { compatible = "usb-nop-xceiv"; vcc-supply = <&usb3_1_power>;
};#phy-cells = <0>;
- gpio-keys {
- keys { compatible = "gpio-keys";
#size-cells = <0>;
button@1 {
};button-1 { label = "Power Button"; linux,code = <KEY_POWER>; gpios = <&gpio1 17 GPIO_ACTIVE_HIGH>;
button@2 {
};button-2 { label = "Copy Button"; linux,code = <KEY_COPY>; gpios = <&gpio1 20 GPIO_ACTIVE_HIGH>;
button@3 {
}; };button-3 { label = "Reset Button"; linux,code = <KEY_RESTART>; gpios = <&gpio1 18 GPIO_ACTIVE_HIGH>;
- gpio-leds {
- leds { compatible = "gpio-leds"; pinctrl-0 = <&pmx_sata1_white_led &pmx_sata1_red_led
white_sata1 {
red_sata1 {
};led-2 { label = "n2350:red:sata1"; gpios = <&gpio1 14 GPIO_ACTIVE_HIGH>;
white-sata2 {
};led-3 { label = "n2350:white:sata2"; gpios = <&gpio0 19 GPIO_ACTIVE_HIGH>;
red-sata2 {
};led-4 { label = "n2350:red:sata2"; gpios = <&gpio1 15 GPIO_ACTIVE_HIGH>;
white-sys {
};led-5 { label = "n2350:white:sys"; gpios = <&gpio0 14 GPIO_ACTIVE_HIGH>; linux,default-trigger = "default-on";
red-sys {
};led-6 { label = "n2350:red:sys"; gpios = <&gpio0 15 GPIO_ACTIVE_HIGH>;
blue-pwr {
};led-7 { label = "n2350:blue:pwr"; gpios = <&gpio1 11 GPIO_ACTIVE_HIGH>;
red-pwr {
};led-8 { label = "n2350:red:pwr"; gpios = <&gpio0 18 GPIO_ACTIVE_HIGH>;
white-usb {
};led-9 { label = "n2350:white:usb"; gpios = <&gpio0 16 GPIO_ACTIVE_HIGH>;
red-usb {
}; };led-10 { label = "n2350:red:usb"; gpios = <&gpio0 17 GPIO_ACTIVE_HIGH>;
- regulators {
#size-cells = <0>;
reg = <1>;
enable-active-high;
regulator-boot-on;
reg = <1>;
enable-active-high;
regulator-boot-on;
- usb3_0_power: v5-vbus0 {
enable-active-high;
regulator-boot-on;
enable-active-high;
regulator-boot-on;
- usb3_1_power: v5-vbus1 {
enable-active-high;
regulator-boot-on;
- reg_sata0: pwr-sata0 {
enable-active-high;
regulator-boot-on;
enable-active-high;
regulator-boot-on;
- reg_sata1: pwr-sata0 {
enable-active-high;
regulator-boot-on;
gpio-poweroff {
&mdio {
- phy0: ethernet-phy@1 { reg = <1>; }; };
- pcie@1,0 {
status = "okay";
- pcie@2,0 {
status = "okay";
+&pcie1 {
- status = "okay";
+&pcie2 {
status = "okay"; };
&pinctrl {
- spi-flash@0 {
- flash@0 { #address-cells = <1>; #size-cells = <0>;
reg = <0>;
Viele Grüße, Stefan Roese
and styles.
Reviewed-by: Pali Rohár pali@kernel.org
- memory {
@@ -37,43 +37,43 @@
};#phy-cells = <0>;
};#phy-cells = <0>;
- gpio-keys {
#size-cells = <0>;
button@1 {
button@2 {
button@3 {
- gpio-leds {
white_sata1 {
red_sata1 {
white-sata2 {
red-sata2 {
white-sys {
red-sys {
blue-pwr {
red-pwr {
white-usb {
red-usb {
- regulators {
#size-cells = <0>;
reg = <1>;
enable-active-high;
regulator-boot-on;
reg = <1>;
enable-active-high;
regulator-boot-on;
enable-active-high;
regulator-boot-on;
enable-active-high;
regulator-boot-on;
enable-active-high;
regulator-boot-on;
enable-active-high;
regulator-boot-on;
enable-active-high;
regulator-boot-on;
enable-active-high;
regulator-boot-on;
gpio-poweroff {
&mdio {
- pcie@1,0 {
status = "okay";
- pcie@2,0 {
status = "okay";
+&pcie1 {
- status = "okay";
+&pcie2 {
- status = "okay";
- spi-flash@0 {
reg = <0>;
-- 2.39.2
and styles.
Applied to u-boot-marvell/master
Thanks, Stefan
- memory {
@@ -37,43 +37,43 @@
};#phy-cells = <0>;
};#phy-cells = <0>;
- gpio-keys {
#size-cells = <0>;
button@1 {
button@2 {
button@3 {
- gpio-leds {
white_sata1 {
red_sata1 {
white-sata2 {
red-sata2 {
white-sys {
red-sys {
blue-pwr {
red-pwr {
white-usb {
red-usb {
- regulators {
#size-cells = <0>;
reg = <1>;
enable-active-high;
regulator-boot-on;
reg = <1>;
enable-active-high;
regulator-boot-on;
enable-active-high;
regulator-boot-on;
enable-active-high;
regulator-boot-on;
enable-active-high;
regulator-boot-on;
enable-active-high;
regulator-boot-on;
enable-active-high;
regulator-boot-on;
enable-active-high;
regulator-boot-on;
gpio-poweroff {
&mdio {
- pcie@1,0 {
status = "okay";
- pcie@2,0 {
status = "okay";
+&pcie1 {
- status = "okay";
+&pcie2 {
status = "okay"; };
&pinctrl {
- spi-flash@0 {
reg = <0>;
Pali Rohár
Stefan Roese
Tony Dinh
