[U-Boot] [PATCH v2 2/7] EXYNOS: add LCD and MIPI DSI clock interface.
To sets up lcd and mipi clock in EXYNOS display driver, added clock interface.
Signed-off-by: Donghwa Lee dh09.lee@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Signed-off-by: Inki Dae inki.dae@samsung.com --- arch/arm/cpu/armv7/exynos/clock.c | 184 ++++++++++++++++++++++++++++++++ arch/arm/include/asm/arch-exynos/clk.h | 3 + 2 files changed, 187 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/clock.c b/arch/arm/cpu/armv7/exynos/clock.c index 2f7048b..330bd75 100644 --- a/arch/arm/cpu/armv7/exynos/clock.c +++ b/arch/arm/cpu/armv7/exynos/clock.c @@ -414,6 +414,170 @@ static void exynos5_set_mmc_clk(int dev_index, unsigned int div) writel(val, addr); }
+/* get_lcd_clk: return lcd clock frequency */ +static unsigned long exynos4_get_lcd_clk(void) +{ + struct exynos4_clock *clk = + (struct exynos4_clock *)samsung_get_base_clock(); + unsigned long pclk, sclk; + unsigned int sel; + unsigned int ratio; + + /* + * CLK_SRC_LCD0 + * FIMD0_SEL [3:0] + */ + sel = readl(&clk->src_lcd0); + sel = sel & 0xf; + + /* + * 0x6: SCLK_MPLL + * 0x7: SCLK_EPLL + * 0x8: SCLK_VPLL + */ + if (sel == 0x6) + sclk = get_pll_clk(MPLL); + else if (sel == 0x7) + sclk = get_pll_clk(EPLL); + else if (sel == 0x8) + sclk = get_pll_clk(VPLL); + else + return 0; + + /* + * CLK_DIV_LCD0 + * FIMD0_RATIO [3:0] + */ + ratio = readl(&clk->div_lcd0); + ratio = ratio & 0xf; + + pclk = sclk / (ratio + 1); + + return pclk; +} + +void exynos4_set_lcd_clk(void) +{ + struct exynos4_clock *clk = + (struct exynos4_clock *)samsung_get_base_clock(); + unsigned int cfg = 0; + + /* + * CLK_GATE_BLOCK + * CLK_CAM [0] + * CLK_TV [1] + * CLK_MFC [2] + * CLK_G3D [3] + * CLK_LCD0 [4] + * CLK_LCD1 [5] + * CLK_GPS [7] + */ + cfg = readl(&clk->gate_block); + cfg |= 1 << 4; + writel(cfg, &clk->gate_block); + + /* + * CLK_SRC_LCD0 + * FIMD0_SEL [3:0] + * MDNIE0_SEL [7:4] + * MDNIE_PWM0_SEL [8:11] + * MIPI0_SEL [12:15] + * set lcd0 src clock 0x6: SCLK_MPLL + */ + cfg = readl(&clk->src_lcd0); + cfg &= ~(0xf); + cfg |= 0x6; + writel(cfg, &clk->src_lcd0); + + /* + * CLK_GATE_IP_LCD0 + * CLK_FIMD0 [0] + * CLK_MIE0 [1] + * CLK_MDNIE0 [2] + * CLK_DSIM0 [3] + * CLK_SMMUFIMD0 [4] + * CLK_PPMULCD0 [5] + * Gating all clocks for FIMD0 + */ + cfg = readl(&clk->gate_ip_lcd0); + cfg |= 1 << 0; + writel(cfg, &clk->gate_ip_lcd0); + + /* + * CLK_DIV_LCD0 + * FIMD0_RATIO [3:0] + * MDNIE0_RATIO [7:4] + * MDNIE_PWM0_RATIO [11:8] + * MDNIE_PWM_PRE_RATIO [15:12] + * MIPI0_RATIO [19:16] + * MIPI0_PRE_RATIO [23:20] + * set fimd ratio + */ + cfg &= ~(0xf); + cfg |= 0x1; + writel(cfg, &clk->div_lcd0); +} + +void exynos4_set_mipi_clk(void) +{ + struct exynos4_clock *clk = + (struct exynos4_clock *)samsung_get_base_clock(); + unsigned int cfg = 0; + + /* + * CLK_SRC_LCD0 + * FIMD0_SEL [3:0] + * MDNIE0_SEL [7:4] + * MDNIE_PWM0_SEL [8:11] + * MIPI0_SEL [12:15] + * set mipi0 src clock 0x6: SCLK_MPLL + */ + cfg = readl(&clk->src_lcd0); + cfg &= ~(0xf << 12); + cfg |= (0x6 << 12); + writel(cfg, &clk->src_lcd0); + + /* + * CLK_SRC_MASK_LCD0 + * FIMD0_MASK [0] + * MDNIE0_MASK [4] + * MDNIE_PWM0_MASK [8] + * MIPI0_MASK [12] + * set src mask mipi0 0x1: Unmask + */ + cfg = readl(&clk->src_mask_lcd0); + cfg |= (0x1 << 12); + writel(cfg, &clk->src_mask_lcd0); + + /* + * CLK_GATE_IP_LCD0 + * CLK_FIMD0 [0] + * CLK_MIE0 [1] + * CLK_MDNIE0 [2] + * CLK_DSIM0 [3] + * CLK_SMMUFIMD0 [4] + * CLK_PPMULCD0 [5] + * Gating all clocks for MIPI0 + */ + cfg = readl(&clk->gate_ip_lcd0); + cfg |= 1 << 3; + writel(cfg, &clk->gate_ip_lcd0); + + /* + * CLK_DIV_LCD0 + * FIMD0_RATIO [3:0] + * MDNIE0_RATIO [7:4] + * MDNIE_PWM0_RATIO [11:8] + * MDNIE_PWM_PRE_RATIO [15:12] + * MIPI0_RATIO [19:16] + * MIPI0_PRE_RATIO [23:20] + * set mipi ratio + */ + cfg &= ~(0xf << 16); + cfg |= (0x1 << 16); + writel(cfg, &clk->div_lcd0); +} + unsigned long get_pll_clk(int pllreg) { if (cpu_is_exynos5()) @@ -453,3 +617,23 @@ void set_mmc_clk(int dev_index, unsigned int div) else exynos4_set_mmc_clk(dev_index, div); } + +unsigned long get_lcd_clk(void) +{ + if (cpu_is_exynos4()) + return exynos4_get_lcd_clk(); + else + return 0; +} + +void set_lcd_clk(void) +{ + if (cpu_is_exynos4()) + exynos4_set_lcd_clk(); +} + +void set_mipi_clk(void) +{ + if (cpu_is_exynos4()) + exynos4_set_mipi_clk(); +} diff --git a/arch/arm/include/asm/arch-exynos/clk.h b/arch/arm/include/asm/arch-exynos/clk.h index ff0f641..637fb4b 100644 --- a/arch/arm/include/asm/arch-exynos/clk.h +++ b/arch/arm/include/asm/arch-exynos/clk.h @@ -33,5 +33,8 @@ unsigned long get_arm_clk(void); unsigned long get_pwm_clk(void); unsigned long get_uart_clk(int dev_index); void set_mmc_clk(int dev_index, unsigned int div); +unsigned long get_lcd_clk(void); +void set_lcd_clk(void); +void set_mipi_clk(void);
#endif
Donghwa Lee
