[U-Boot] V2 remove omap3 compiler warning wrt v7_flush_dcache_all
This is against the arm/next branch.
This fixes a problem with compile warnings for all OMAP3 targets.
As per feedback, v7_flush_dcache_all was renamed to the generic flush_dcache and moved to the omap3 level in the new file cache_flush.S.
The original fix of using sys_proto.h is still used to fix the warning for for get_device_type.
compile tested on MAKEALL arm. run tested on zoom1.
Since there is only one version of flushing the dcache for arm_cortex8, rename v7_flush_dcache_all to the the generic name flush_dcache. Because the function is intended for only omap3 boards, move the function to the new file cache_flush.S.
This change fixes the compiler warning all OMAP3 targets have
cpu.c: In function 'cleanup_before_linux': cpu.c:64: warning: implicit declaration of function 'v7_flush_dcache_all'
Signed-off-by: Tom Rix Tom.Rix@windriver.com --- cpu/arm_cortexa8/cpu.c | 2 +- cpu/arm_cortexa8/omap3/Makefile | 1 + cpu/arm_cortexa8/omap3/board.c | 2 +- cpu/arm_cortexa8/omap3/cache_flush.S | 118 ++++++++++++++++++++++++++++++++ cpu/arm_cortexa8/start.S | 87 ----------------------- include/asm-arm/arch-omap3/sys_proto.h | 1 - include/asm-arm/cache.h | 1 + 7 files changed, 122 insertions(+), 90 deletions(-) create mode 100644 cpu/arm_cortexa8/omap3/cache_flush.S
diff --git a/cpu/arm_cortexa8/cpu.c b/cpu/arm_cortexa8/cpu.c index fcb5775..7f57ee9 100644 --- a/cpu/arm_cortexa8/cpu.c +++ b/cpu/arm_cortexa8/cpu.c @@ -61,7 +61,7 @@ int cleanup_before_linux(void) /* turn off L2 cache */ l2_cache_disable(); /* invalidate L2 cache also */ - v7_flush_dcache_all(get_device_type()); + flush_dcache(get_device_type()); #endif i = 0; /* mem barrier to sync up things */ diff --git a/cpu/arm_cortexa8/omap3/Makefile b/cpu/arm_cortexa8/omap3/Makefile index 1fbd0dc..ea7a1cf 100644 --- a/cpu/arm_cortexa8/omap3/Makefile +++ b/cpu/arm_cortexa8/omap3/Makefile @@ -26,6 +26,7 @@ include $(TOPDIR)/config.mk LIB = $(obj)lib$(SOC).a
SOBJS := lowlevel_init.o +SOBJS += cache_flush.o
COBJS += board.o COBJS += cache.o diff --git a/cpu/arm_cortexa8/omap3/board.c b/cpu/arm_cortexa8/omap3/board.c index 439ea6a..c082d8f 100644 --- a/cpu/arm_cortexa8/omap3/board.c +++ b/cpu/arm_cortexa8/omap3/board.c @@ -201,7 +201,7 @@ void s_init(void) * Right now flushing at low MPU speed. * Need to move after clock init */ - v7_flush_dcache_all(get_device_type()); + flush_dcache(get_device_type()); #ifndef CONFIG_ICACHE_OFF icache_enable(); #endif diff --git a/cpu/arm_cortexa8/omap3/cache_flush.S b/cpu/arm_cortexa8/omap3/cache_flush.S new file mode 100644 index 0000000..0b5afc3 --- /dev/null +++ b/cpu/arm_cortexa8/omap3/cache_flush.S @@ -0,0 +1,118 @@ +/* + * armboot - Startup Code for OMAP3530/ARM Cortex CPU-core + * + * Copyright (c) 2004 Texas Instruments r-woodruff2@ti.com + * + * Copyright (c) 2001 Marius Gröger mag@sysgo.de + * Copyright (c) 2002 Alex Züpke azu@sysgo.de + * Copyright (c) 2002 Gary Jennejohn garyj@denx.de + * Copyright (c) 2003 Richard Woodruff r-woodruff2@ti.com + * Copyright (c) 2003 Kshitij kshitij@ti.com + * Copyright (c) 2006-2008 Syed Mohammed Khasim x0khasim@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * flush_dcache() + * + * Flush the whole D-cache. + * + * Corrupted registers: r0-r5, r7, r9-r11 + * + * - mm - mm_struct describing address space + */ + .align 5 +.global flush_dcache +flush_dcache: + stmfd r13!, {r0 - r5, r7, r9 - r12, r14} + + mov r7, r0 @ take a backup of device type + cmp r0, #0x3 @ check if the device type is + @ GP + moveq r12, #0x1 @ set up to invalide L2 +smi: .word 0x01600070 @ Call SMI monitor (smieq) + cmp r7, #0x3 @ compare again in case its + @ lost + beq finished_inval @ if GP device, inval done + @ above + + mrc p15, 1, r0, c0, c0, 1 @ read clidr + ands r3, r0, #0x7000000 @ extract loc from clidr + mov r3, r3, lsr #23 @ left align loc bit field + beq finished_inval @ if loc is 0, then no need to + @ clean + mov r10, #0 @ start clean at cache level 0 +inval_loop1: + add r2, r10, r10, lsr #1 @ work out 3x current cache + @ level + mov r1, r0, lsr r2 @ extract cache type bits from + @ clidr + and r1, r1, #7 @ mask of the bits for current + @ cache only + cmp r1, #2 @ see what cache we have at + @ this level + blt skip_inval @ skip if no cache, or just + @ i-cache + mcr p15, 2, r10, c0, c0, 0 @ select current cache level + @ in cssr + mov r2, #0 @ operand for mcr SBZ + mcr p15, 0, r2, c7, c5, 4 @ flush prefetch buffer to + @ sych the new cssr&csidr, + @ with armv7 this is 'isb', + @ but we compile with armv5 + mrc p15, 1, r1, c0, c0, 0 @ read the new csidr + and r2, r1, #7 @ extract the length of the + @ cache lines + add r2, r2, #4 @ add 4 (line length offset) + ldr r4, =0x3ff + ands r4, r4, r1, lsr #3 @ find maximum number on the + @ way size + clz r5, r4 @ find bit position of way + @ size increment + ldr r7, =0x7fff + ands r7, r7, r1, lsr #13 @ extract max number of the + @ index size +inval_loop2: + mov r9, r4 @ create working copy of max + @ way size +inval_loop3: + orr r11, r10, r9, lsl r5 @ factor way and cache number + @ into r11 + orr r11, r11, r7, lsl r2 @ factor index number into r11 + mcr p15, 0, r11, c7, c6, 2 @ invalidate by set/way + subs r9, r9, #1 @ decrement the way + bge inval_loop3 + subs r7, r7, #1 @ decrement the index + bge inval_loop2 +skip_inval: + add r10, r10, #2 @ increment cache number + cmp r3, r10 + bgt inval_loop1 +finished_inval: + mov r10, #0 @ swith back to cache level 0 + mcr p15, 2, r10, c0, c0, 0 @ select current cache level + @ in cssr + mcr p15, 0, r10, c7, c5, 4 @ flush prefetch buffer, + @ with armv7 this is 'isb', + @ but we compile with armv5 + + ldmfd r13!, {r0 - r5, r7, r9 - r12, pc} + + diff --git a/cpu/arm_cortexa8/start.S b/cpu/arm_cortexa8/start.S index 66b4820..c597d80 100644 --- a/cpu/arm_cortexa8/start.S +++ b/cpu/arm_cortexa8/start.S @@ -415,93 +415,6 @@ fiq:
#endif
-/* - * v7_flush_dcache_all() - * - * Flush the whole D-cache. - * - * Corrupted registers: r0-r5, r7, r9-r11 - * - * - mm - mm_struct describing address space - */ - .align 5 -.global v7_flush_dcache_all -v7_flush_dcache_all: - stmfd r13!, {r0 - r5, r7, r9 - r12, r14} - - mov r7, r0 @ take a backup of device type - cmp r0, #0x3 @ check if the device type is - @ GP - moveq r12, #0x1 @ set up to invalide L2 -smi: .word 0x01600070 @ Call SMI monitor (smieq) - cmp r7, #0x3 @ compare again in case its - @ lost - beq finished_inval @ if GP device, inval done - @ above - - mrc p15, 1, r0, c0, c0, 1 @ read clidr - ands r3, r0, #0x7000000 @ extract loc from clidr - mov r3, r3, lsr #23 @ left align loc bit field - beq finished_inval @ if loc is 0, then no need to - @ clean - mov r10, #0 @ start clean at cache level 0 -inval_loop1: - add r2, r10, r10, lsr #1 @ work out 3x current cache - @ level - mov r1, r0, lsr r2 @ extract cache type bits from - @ clidr - and r1, r1, #7 @ mask of the bits for current - @ cache only - cmp r1, #2 @ see what cache we have at - @ this level - blt skip_inval @ skip if no cache, or just - @ i-cache - mcr p15, 2, r10, c0, c0, 0 @ select current cache level - @ in cssr - mov r2, #0 @ operand for mcr SBZ - mcr p15, 0, r2, c7, c5, 4 @ flush prefetch buffer to - @ sych the new cssr&csidr, - @ with armv7 this is 'isb', - @ but we compile with armv5 - mrc p15, 1, r1, c0, c0, 0 @ read the new csidr - and r2, r1, #7 @ extract the length of the - @ cache lines - add r2, r2, #4 @ add 4 (line length offset) - ldr r4, =0x3ff - ands r4, r4, r1, lsr #3 @ find maximum number on the - @ way size - clz r5, r4 @ find bit position of way - @ size increment - ldr r7, =0x7fff - ands r7, r7, r1, lsr #13 @ extract max number of the - @ index size -inval_loop2: - mov r9, r4 @ create working copy of max - @ way size -inval_loop3: - orr r11, r10, r9, lsl r5 @ factor way and cache number - @ into r11 - orr r11, r11, r7, lsl r2 @ factor index number into r11 - mcr p15, 0, r11, c7, c6, 2 @ invalidate by set/way - subs r9, r9, #1 @ decrement the way - bge inval_loop3 - subs r7, r7, #1 @ decrement the index - bge inval_loop2 -skip_inval: - add r10, r10, #2 @ increment cache number - cmp r3, r10 - bgt inval_loop1 -finished_inval: - mov r10, #0 @ swith back to cache level 0 - mcr p15, 2, r10, c0, c0, 0 @ select current cache level - @ in cssr - mcr p15, 0, r10, c7, c5, 4 @ flush prefetch buffer, - @ with armv7 this is 'isb', - @ but we compile with armv5 - - ldmfd r13!, {r0 - r5, r7, r9 - r12, pc} - - .align 5 .global reset_cpu reset_cpu: diff --git a/include/asm-arm/arch-omap3/sys_proto.h b/include/asm-arm/arch-omap3/sys_proto.h index 7361d08..2881287 100644 --- a/include/asm-arm/arch-omap3/sys_proto.h +++ b/include/asm-arm/arch-omap3/sys_proto.h @@ -55,7 +55,6 @@ void secureworld_exit(void); void setup_auxcr(void); void try_unlock_memory(void); u32 get_boot_type(void); -void v7_flush_dcache_all(u32); void sr32(void *, u32, u32, u32); u32 wait_on_value(u32, u32, void *, u32); void sdelay(unsigned long); diff --git a/include/asm-arm/cache.h b/include/asm-arm/cache.h index d0518be..853e2d1 100644 --- a/include/asm-arm/cache.h +++ b/include/asm-arm/cache.h @@ -41,5 +41,6 @@ static inline void invalidate_l2_cache(void)
void l2_cache_enable(void); void l2_cache_disable(void); +void flush_dcache(u32 device_type);
#endif /* _ASM_CACHE_H */
When MAKEALL arm is run, the omap3 board *.ERR files contains this warning
cpu.c: In function 'cleanup_before_linux': cpu.c:64: warning: implicit declaration of function 'get_device_type'
To fix this warning, use the declaration of get_device_type in sys_proto.h
Signed-off-by: Tom Rix Tom.Rix@windriver.com --- cpu/arm_cortexa8/cpu.c | 3 +++ 1 files changed, 3 insertions(+), 0 deletions(-)
diff --git a/cpu/arm_cortexa8/cpu.c b/cpu/arm_cortexa8/cpu.c index 7f57ee9..ab59ab0 100644 --- a/cpu/arm_cortexa8/cpu.c +++ b/cpu/arm_cortexa8/cpu.c @@ -35,6 +35,9 @@ #include <command.h> #include <asm/system.h> #include <asm/cache.h> +#ifndef CONFIG_L2_OFF +#include <asm/arch/sys_proto.h> +#endif
static void cache_flush(void);
From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Tom Rix Sent: Monday, July 06, 2009 11:48 AM
Minor point is file name or function name might change to be more reflective of what it does (cache_ops.S, and invalidate_dcache()). As there is not really any 'flush' (cleaning out dirty entries to main memory).
Today the dcache is not even enabled in ARM ports. To do so requires MMU to be enabled to properly map IO regions as non-cached.
As such all we ever need to do is possibly invalidate icache at run time (say you use Kermit to download something and try to execute it).
The dcache invalidate today is only there to setup cache in clean state before calling the kernel.
Later on a dcache-flush/icache-invalidate might need to be added if Dcache is actually enabled.
Regards, Richard W.
I will change the name to cache_ops.S flush_dcache was chosen to match other boards/cpu's and one of the main reasons for this change. If Jean is ok changing flush_dcache to invalidate_dcache, I will make that change too. Tom
Regards, Richard W.
I prefer cache.S
invalidate_dcache is fine for me
Best Regards, J.
On 15:44 Tue 07 Jul , Tom wrote:
I prefer cache.S
cache.c is already taken.
and contain nearly only assembly so join everythink in cache.S will make more sense
Best Regards, J.
Dear Tom Rix,
In message 1246898879-6567-2-git-send-email-Tom.Rix@windriver.com you wrote:
--===============0808050101==
Sorry, this patch does not apply any more:
Applying: ARM Cortex8 Rename and move v7_flush_dcache_all to flush_dcache error: patch failed: cpu/arm_cortexa8/omap3/Makefile:26 error: cpu/arm_cortexa8/omap3/Makefile: patch does not apply error: patch failed: cpu/arm_cortexa8/start.S:415 error: cpu/arm_cortexa8/start.S: patch does not apply fatal: sha1 information is lacking or useless (cpu/arm_cortexa8/omap3/board.c). Repository lacks necessary blobs to fall back on 3-way merge. Cannot fall back to three-way merge. Patch failed at 0001.
Please rebase and resubmit (also patch 2/2).
Yes. Sorry about that. I will get something to you this week. Tom
Wolfgang Denk wrote:
Dear Tom Rix,
participants (5)
Tom
Tom Rix
Woodruff, Richard
