Re: [U-Boot] [PATCH 6/7 v5] TMU: Add TMU support in dtt command
Hi Akshay,
On Thu, Jan 24, 2013 at 4:02 AM, Akshay Saraswat akshay.s@samsung.comwrote:
Hi Simon,
If we create two versions of dtt_get_temp(), we have to declare unnecessarily few configs and their values like CONFIG_DTT_SENSORS and CONFIG_SYS_DTT_BUS_NUM when we can easily ignore them. That's why I thought of including TMU to dtt this way. I dont think we need both TMU and I2C bus sensors together anywhere. Please suggest which way is better.
(Sorry I am on holiday for a week so not very responsive. I get back next Thurs)
The thing is that these two implementations share no code at all. I think the way you have done it is good, I was just wondering whether it would be better to have do_dtt_i2c() and do_dtt_tmu() as separate function. But I suppose that is really not any better. The alternative would be to share the same do_dtt() function, with it avoiding the i2c code if CONFIG_SYS_DTT_BUS_NUM is defined, and using a single sensor number 0 if CONFIG_DTT_SENSORS is not defined. That could use much of the same code (perhaps with a weak function for dtt_init_one(). But that is probably trying too hard - if support for multiple TMU sensors is required in the future we can worry about it then.
Sorry for the trouble.
Regards,
Akshay
------- *Original Message* -------
*Sender* : Simon Glasssjg@chromium.org
*Date* : Jan 23, 2013 05:51 (GMT+09:00)
*Title* : Re: [PATCH 6/7 v5] TMU: Add TMU support in dtt command
Hi Akshay,
On Mon, Jan 21, 2013 at 3:11 AM, Akshay Saraswat **wrote:
Add generic TMU support alongwith i2c sensors in dtt command to enable temperature reading in cases where TMU is present instead of i2c sensors.
Signed-off-by: Akshay Saraswat **
Changes since v4: - Removed tmu command and added to dtt.
common/cmd_dtt.c | 19 +++++++++++++++++++ 1 file changed, 19 insertions(+)
diff --git a/common/cmd_dtt.c b/common/cmd_dtt.c index cd94423..715f4ba 100644 --- a/common/cmd_dtt.c +++ b/common/cmd_dtt.c @@ -28,6 +28,20 @@ #include ** #include **
+#if defined CONFIG_TMU_CMD_DTT +#include **
+void dtt_get_temp(void) +{
int cur_temp;
if (tmu_monitor(&cur_temp) == TMU_STATUS_INIT)
printf("TMU is in unknown state, temperature is invalid
\n");
puts()
Should return an error result here so that do_dtt() returns 1.
else
printf("Current temperature: %u degrees Celsius \n",
cur_temp);
+#else static unsigned long sensor_initialized;
static void _initialize_dtt(void) @@ -59,9 +73,13 @@ void dtt_init(void) /* switch back to original I2C bus */ I2C_SET_BUS(old_bus); } +#endif
int do_dtt (cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[]) { +#if defined CONFIG_TMU_CMD_DTT
dtt_get_temp();
+#else
How about creating two versions of the dtt_get_temp() function: one with your code and one with the old code? Then you don't have an #ifdef here.
int i; unsigned char sensors[] = CONFIG_DTT_SENSORS; int old_bus;
@@ -83,6 +101,7 @@ int do_dtt (cmd_tbl_t * cmdtp, int flag, int argc,
} /* do_dtt() */
1.7.9.5
