[U-Boot] [PATCH v1 00/18] Fixes on gdsys boards and some new functionality
Dirk Eibach (17): i2c: ihs_i2c: Dual channel support i2c: ihs_i2c: Use macro bestpractices i2c: ihs_i2c: Fix hold_bus control board: gdsys: Configure DP501 SPDIF input board: gdsys: Increase DP501 I2C retry interval board: gdsys: Consider DP501 limits on link training dlvision-10g: Support displayport controlcenterd: Disable sideband clocks hrcon: Remove CH7301 configuration mpc83xx: Add strider board hrcon: Use generic ioep-fpga support hrcon: Fix videoboard i2c setup hrcon: Add support for the DH variant hrcon: Add fan controllers board: gdsys: Add osdsize command board: gdsys: Enable osd on output only i2c: soft_i2c: Fix bus indizes
Reinhard Pfau (1): iocon: reset FPGAs in last_stage_init()
README | 9 + arch/powerpc/cpu/mpc83xx/Kconfig | 3 + board/gdsys/405ep/dlvision-10g.c | 67 ++-- board/gdsys/405ep/iocon.c | 8 +- board/gdsys/common/Makefile | 9 +- board/gdsys/common/adv7611.c | 177 ++++++++++ board/gdsys/common/adv7611.h | 13 + board/gdsys/common/ch7301.c | 64 ++++ board/gdsys/common/ch7301.h | 13 + board/gdsys/common/dp501.c | 27 +- board/gdsys/common/fanctrl.c | 32 ++ board/gdsys/common/fanctrl.h | 13 + board/gdsys/common/ioep-fpga.c | 232 +++++++++++++ board/gdsys/common/ioep-fpga.h | 14 + board/gdsys/common/osd.c | 194 +++++++---- board/gdsys/common/osd.h | 1 + board/gdsys/mpc8308/Kconfig | 13 + board/gdsys/mpc8308/MAINTAINERS | 4 + board/gdsys/mpc8308/Makefile | 1 + board/gdsys/mpc8308/hrcon.c | 293 +++-------------- board/gdsys/mpc8308/strider.c | 479 +++++++++++++++++++++++++++ board/gdsys/p1022/controlcenterd.c | 5 + configs/hrcon_dh_defconfig | 5 + configs/strider_con_defconfig | 7 + configs/strider_cpu_defconfig | 7 + drivers/i2c/ihs_i2c.c | 82 ++++- drivers/i2c/soft_i2c.c | 64 +++- include/configs/dlvision-10g.h | 18 +- include/configs/hrcon.h | 89 ++++- include/configs/strider.h | 653 +++++++++++++++++++++++++++++++++++++ include/gdsys_fpga.h | 101 +++++- 31 files changed, 2310 insertions(+), 387 deletions(-) create mode 100644 board/gdsys/common/adv7611.c create mode 100644 board/gdsys/common/adv7611.h create mode 100644 board/gdsys/common/ch7301.c create mode 100644 board/gdsys/common/ch7301.h create mode 100644 board/gdsys/common/fanctrl.c create mode 100644 board/gdsys/common/fanctrl.h create mode 100644 board/gdsys/common/ioep-fpga.c create mode 100644 board/gdsys/common/ioep-fpga.h create mode 100644 board/gdsys/mpc8308/strider.c create mode 100644 configs/hrcon_dh_defconfig create mode 100644 configs/strider_con_defconfig create mode 100644 configs/strider_cpu_defconfig create mode 100644 include/configs/strider.h
Support two i2c masters per FPGA.
Signed-off-by: Dirk Eibach dirk.eibach@gdsys.cc ---
README | 9 ++++++ drivers/i2c/ihs_i2c.c | 76 ++++++++++++++++++++++++++++++++++++++++++--------- include/gdsys_fpga.h | 12 ++++---- 3 files changed, 79 insertions(+), 18 deletions(-)
diff --git a/README b/README index 0dc657d..25bd711 100644 --- a/README +++ b/README @@ -2446,6 +2446,15 @@ CBFS (Coreboot Filesystem) support - CONFIG_SYS_I2C_IHS_CH3 activate hardware channel 3 - CONFIG_SYS_I2C_IHS_SPEED_3 speed channel 3 - CONFIG_SYS_I2C_IHS_SLAVE_3 slave addr channel 3 + - activate dual channel with CONFIG_SYS_I2C_IHS_DUAL + - CONFIG_SYS_I2C_IHS_SPEED_0_1 speed channel 0_1 + - CONFIG_SYS_I2C_IHS_SLAVE_0_1 slave addr channel 0_1 + - CONFIG_SYS_I2C_IHS_SPEED_1_1 speed channel 1_1 + - CONFIG_SYS_I2C_IHS_SLAVE_1_1 slave addr channel 1_1 + - CONFIG_SYS_I2C_IHS_SPEED_2_1 speed channel 2_1 + - CONFIG_SYS_I2C_IHS_SLAVE_2_1 slave addr channel 2_1 + - CONFIG_SYS_I2C_IHS_SPEED_3_1 speed channel 3_1 + - CONFIG_SYS_I2C_IHS_SLAVE_3_1 slave addr channel 3_1
additional defines:
diff --git a/drivers/i2c/ihs_i2c.c b/drivers/i2c/ihs_i2c.c index 19fbe59..737beaf 100644 --- a/drivers/i2c/ihs_i2c.c +++ b/drivers/i2c/ihs_i2c.c @@ -11,6 +11,28 @@
DECLARE_GLOBAL_DATA_PTR;
+#ifdef CONFIG_SYS_I2C_IHS_DUAL +#define I2C_SET_REG(fld, val) \ + { if (I2C_ADAP_HWNR & 0x10) \ + FPGA_SET_REG(I2C_ADAP_HWNR & 0xf, i2c1.fld, val); \ + else \ + FPGA_SET_REG(I2C_ADAP_HWNR, i2c0.fld, val); } +#else +#define I2C_SET_REG(fld, val) \ + FPGA_SET_REG(I2C_ADAP_HWNR, i2c0.fld, val); +#endif + +#ifdef CONFIG_SYS_I2C_IHS_DUAL +#define I2C_GET_REG(fld, val) \ + { if (I2C_ADAP_HWNR & 0x10) \ + FPGA_GET_REG(I2C_ADAP_HWNR & 0xf, i2c1.fld, val); \ + else \ + FPGA_GET_REG(I2C_ADAP_HWNR, i2c0.fld, val); } +#else +#define I2C_GET_REG(fld, val) \ + FPGA_GET_REG(I2C_ADAP_HWNR, i2c0.fld, val); +#endif + enum { I2CINT_ERROR_EV = 1 << 13, I2CINT_TRANSMIT_EV = 1 << 14, @@ -29,14 +51,14 @@ static int wait_for_int(bool read) u16 val; unsigned int ctr = 0;
- FPGA_GET_REG(I2C_ADAP_HWNR, i2c.interrupt_status, &val); + I2C_GET_REG(interrupt_status, &val); while (!(val & (I2CINT_ERROR_EV | (read ? I2CINT_RECEIVE_EV : I2CINT_TRANSMIT_EV)))) { udelay(10); if (ctr++ > 5000) { return 1; } - FPGA_GET_REG(I2C_ADAP_HWNR, i2c.interrupt_status, &val); + I2C_GET_REG(interrupt_status, &val); }
return (val & I2CINT_ERROR_EV) ? 1 : 0; @@ -47,30 +69,30 @@ static int ihs_i2c_transfer(uchar chip, uchar *buffer, int len, bool read, { u16 val;
- FPGA_SET_REG(I2C_ADAP_HWNR, i2c.interrupt_status, I2CINT_ERROR_EV + I2C_SET_REG(interrupt_status, I2CINT_ERROR_EV | I2CINT_RECEIVE_EV | I2CINT_TRANSMIT_EV); - FPGA_GET_REG(I2C_ADAP_HWNR, i2c.interrupt_status, &val); + I2C_GET_REG(interrupt_status, &val);
if (!read && len) { val = buffer[0];
if (len > 1) val |= buffer[1] << 8; - FPGA_SET_REG(I2C_ADAP_HWNR, i2c.write_mailbox_ext, val); + I2C_SET_REG(write_mailbox_ext, val); }
- FPGA_SET_REG(I2C_ADAP_HWNR, i2c.write_mailbox, - I2CMB_NATIVE - | (read ? 0 : I2CMB_WRITE) - | (chip << 1) - | ((len > 1) ? I2CMB_2BYTE : 0) - | (is_last ? 0 : I2CMB_HOLD_BUS)); + I2C_SET_REG(write_mailbox, + I2CMB_NATIVE + | (read ? 0 : I2CMB_WRITE) + | (chip << 1) + | ((len > 1) ? I2CMB_2BYTE : 0) + | (is_last ? 0 : I2CMB_HOLD_BUS));
if (wait_for_int(read)) return 1;
if (read) { - FPGA_GET_REG(I2C_ADAP_HWNR, i2c.read_mailbox_ext, &val); + I2C_GET_REG(read_mailbox_ext, &val); buffer[0] = val & 0xff; if (len > 1) buffer[1] = val >> 8; @@ -163,7 +185,7 @@ static int ihs_i2c_write(struct i2c_adapter *adap, uchar chip, uint addr, }
static unsigned int ihs_i2c_set_bus_speed(struct i2c_adapter *adap, - unsigned int speed) + unsigned int speed) { if (speed != adap->speed) return 1; @@ -179,6 +201,13 @@ U_BOOT_I2C_ADAP_COMPLETE(ihs0, ihs_i2c_init, ihs_i2c_probe, ihs_i2c_set_bus_speed, CONFIG_SYS_I2C_IHS_SPEED_0, CONFIG_SYS_I2C_IHS_SLAVE_0, 0) +#ifdef CONFIG_SYS_I2C_IHS_DUAL +U_BOOT_I2C_ADAP_COMPLETE(ihs0_1, ihs_i2c_init, ihs_i2c_probe, + ihs_i2c_read, ihs_i2c_write, + ihs_i2c_set_bus_speed, + CONFIG_SYS_I2C_IHS_SPEED_0_1, + CONFIG_SYS_I2C_IHS_SLAVE_0_1, 16) +#endif #endif #ifdef CONFIG_SYS_I2C_IHS_CH1 U_BOOT_I2C_ADAP_COMPLETE(ihs1, ihs_i2c_init, ihs_i2c_probe, @@ -186,6 +215,13 @@ U_BOOT_I2C_ADAP_COMPLETE(ihs1, ihs_i2c_init, ihs_i2c_probe, ihs_i2c_set_bus_speed, CONFIG_SYS_I2C_IHS_SPEED_1, CONFIG_SYS_I2C_IHS_SLAVE_1, 1) +#ifdef CONFIG_SYS_I2C_IHS_DUAL +U_BOOT_I2C_ADAP_COMPLETE(ihs1_1, ihs_i2c_init, ihs_i2c_probe, + ihs_i2c_read, ihs_i2c_write, + ihs_i2c_set_bus_speed, + CONFIG_SYS_I2C_IHS_SPEED_1_1, + CONFIG_SYS_I2C_IHS_SLAVE_1_1, 17) +#endif #endif #ifdef CONFIG_SYS_I2C_IHS_CH2 U_BOOT_I2C_ADAP_COMPLETE(ihs2, ihs_i2c_init, ihs_i2c_probe, @@ -193,6 +229,13 @@ U_BOOT_I2C_ADAP_COMPLETE(ihs2, ihs_i2c_init, ihs_i2c_probe, ihs_i2c_set_bus_speed, CONFIG_SYS_I2C_IHS_SPEED_2, CONFIG_SYS_I2C_IHS_SLAVE_2, 2) +#ifdef CONFIG_SYS_I2C_IHS_DUAL +U_BOOT_I2C_ADAP_COMPLETE(ihs2_1, ihs_i2c_init, ihs_i2c_probe, + ihs_i2c_read, ihs_i2c_write, + ihs_i2c_set_bus_speed, + CONFIG_SYS_I2C_IHS_SPEED_2_1, + CONFIG_SYS_I2C_IHS_SLAVE_2_1, 18) +#endif #endif #ifdef CONFIG_SYS_I2C_IHS_CH3 U_BOOT_I2C_ADAP_COMPLETE(ihs3, ihs_i2c_init, ihs_i2c_probe, @@ -200,4 +243,11 @@ U_BOOT_I2C_ADAP_COMPLETE(ihs3, ihs_i2c_init, ihs_i2c_probe, ihs_i2c_set_bus_speed, CONFIG_SYS_I2C_IHS_SPEED_3, CONFIG_SYS_I2C_IHS_SLAVE_3, 3) +#ifdef CONFIG_SYS_I2C_IHS_DUAL +U_BOOT_I2C_ADAP_COMPLETE(ihs3_1, ihs_i2c_init, ihs_i2c_probe, + ihs_i2c_read, ihs_i2c_write, + ihs_i2c_set_bus_speed, + CONFIG_SYS_I2C_IHS_SPEED_3_1, + CONFIG_SYS_I2C_IHS_SLAVE_3_1, 19) +#endif #endif diff --git a/include/gdsys_fpga.h b/include/gdsys_fpga.h index 8a5efe7..f8d8322 100644 --- a/include/gdsys_fpga.h +++ b/include/gdsys_fpga.h @@ -143,7 +143,7 @@ struct ihs_fpga { u16 reserved_2[2]; /* 0x001c */ struct ihs_io_ep ep; /* 0x0020 */ u16 reserved_3[9]; /* 0x002e */ - struct ihs_i2c i2c; /* 0x0040 */ + struct ihs_i2c i2c0; /* 0x0040 */ u16 reserved_4[10]; /* 0x004c */ u16 mc_int; /* 0x0060 */ u16 mc_int_en; /* 0x0062 */ @@ -177,7 +177,7 @@ struct ihs_fpga { u16 reserved_2[2]; /* 0x001c */ struct ihs_io_ep ep; /* 0x0020 */ u16 reserved_3[9]; /* 0x002e */ - struct ihs_i2c i2c; /* 0x0040 */ + struct ihs_i2c i2c0; /* 0x0040 */ u16 reserved_4[10]; /* 0x004c */ u16 mc_int; /* 0x0060 */ u16 mc_int_en; /* 0x0062 */ @@ -208,10 +208,12 @@ struct ihs_fpga { u16 reserved_1[29]; /* 0x001e */ u16 mpc3w_control; /* 0x0058 */ u16 reserved_2[3]; /* 0x005a */ - struct ihs_i2c i2c; /* 0x0060 */ - u16 reserved_3[205]; /* 0x0066 */ + struct ihs_i2c i2c0; /* 0x0060 */ + u16 reserved_3[2]; /* 0x006c */ + struct ihs_i2c i2c1; /* 0x0070 */ + u16 reserved_4[194]; /* 0x007c */ struct ihs_osd osd; /* 0x0200 */ - u16 reserved_4[761]; /* 0x020e */ + u16 reserved_5[761]; /* 0x020e */ u16 videomem[31736]; /* 0x0800 */ }; #endif
Hello Dirk,
Am 28.10.2015 um 11:46 schrieb dirk.eibach@gdsys.cc:
I twould be nice to see a patch, which converts this driver to DM ;-) As the hole patchserie goes not through the i2c tree:
Acked-by: Heiko Schocher hs@denx.de
bye, Heiko
additional defines:
- { if (I2C_ADAP_HWNR & 0x10) \
- else \
- else \
- enum { I2CINT_ERROR_EV = 1 << 13, I2CINT_TRANSMIT_EV = 1 << 14,
- I2C_GET_REG(interrupt_status, &val); while (!(val & (I2CINT_ERROR_EV | (read ? I2CINT_RECEIVE_EV : I2CINT_TRANSMIT_EV)))) { udelay(10); if (ctr++ > 5000) { return 1; }
- I2C_SET_REG(interrupt_status, I2CINT_ERROR_EV | I2CINT_RECEIVE_EV | I2CINT_TRANSMIT_EV);
}I2C_SET_REG(write_mailbox_ext, val);
I2CMB_NATIVE
| (chip << 1)
I2CMB_NATIVE
| (chip << 1)
if (read) {
buffer[0] = val & 0xff; if (len > 1) buffer[1] = val >> 8;I2C_GET_REG(read_mailbox_ext, &val);
unsigned int speed)
{ if (speed != adap->speed) return 1;unsigned int speed)
- struct ihs_i2c i2c0; /* 0x0040 */ u16 reserved_4[10]; /* 0x004c */ u16 mc_int; /* 0x0060 */ u16 mc_int_en; /* 0x0062 */
- struct ihs_i2c i2c0; /* 0x0060 */
- u16 reserved_3[2]; /* 0x006c */
- struct ihs_i2c i2c1; /* 0x0070 */
- u16 reserved_4[194]; /* 0x007c */ struct ihs_osd osd; /* 0x0200 */
- u16 reserved_5[761]; /* 0x020e */ u16 videomem[31736]; /* 0x0800 */ }; #endif
Hello Heiko,
2015-10-28 12:23 GMT+01:00 Heiko Schocher hs@denx.de:
me too ;) Are there any known good examples?
Cheers Dirk
Hello Dirk,
Am 28.10.2015 um 13:39 schrieb Dirk Eibach:
Hello Heiko,
hs@localhost:u-boot [20151012] $ grep -lr U_BOOT_DRIVER drivers/i2c/ drivers/i2c/i2c-uclass.c drivers/i2c/i2c-uniphier.c drivers/i2c/sandbox_i2c.c drivers/i2c/tegra_i2c.c drivers/i2c/s3c24x0_i2c.c drivers/i2c/i2c-gpio.c drivers/i2c/muxes/i2c-arb-gpio-challenge.c drivers/i2c/muxes/i2c-mux-uclass.c drivers/i2c/mxc_i2c.c drivers/i2c/cros_ec_tunnel.c drivers/i2c/i2c-uniphier-f.c drivers/i2c/rk_i2c.c drivers/i2c/cros_ec_ldo.c hs@localhost:u-boot [20151012] $
bye, Heiko
Signed-off-by: Dirk Eibach dirk.eibach@gdsys.cc Acked-by: Heiko Schocher hs@denx.de
Reinhard Pfau complained that macros in ihs_i2c do not follow best practices.
drivers/i2c/ihs_i2c.c | 24 ++++++++++++++---------- 1 file changed, 14 insertions(+), 10 deletions(-)
diff --git a/drivers/i2c/ihs_i2c.c b/drivers/i2c/ihs_i2c.c index 737beaf..e001459 100644 --- a/drivers/i2c/ihs_i2c.c +++ b/drivers/i2c/ihs_i2c.c @@ -13,24 +13,28 @@ DECLARE_GLOBAL_DATA_PTR;
#ifdef CONFIG_SYS_I2C_IHS_DUAL #define I2C_SET_REG(fld, val) \ - { if (I2C_ADAP_HWNR & 0x10) \ - FPGA_SET_REG(I2C_ADAP_HWNR & 0xf, i2c1.fld, val); \ - else \ - FPGA_SET_REG(I2C_ADAP_HWNR, i2c0.fld, val); } + do { \ + if (I2C_ADAP_HWNR & 0x10) \ + FPGA_SET_REG(I2C_ADAP_HWNR & 0xf, i2c1.fld, val); \ + else \ + FPGA_SET_REG(I2C_ADAP_HWNR, i2c0.fld, val); \ + } while (0) #else #define I2C_SET_REG(fld, val) \ - FPGA_SET_REG(I2C_ADAP_HWNR, i2c0.fld, val); + FPGA_SET_REG(I2C_ADAP_HWNR, i2c0.fld, val) #endif
#ifdef CONFIG_SYS_I2C_IHS_DUAL #define I2C_GET_REG(fld, val) \ - { if (I2C_ADAP_HWNR & 0x10) \ - FPGA_GET_REG(I2C_ADAP_HWNR & 0xf, i2c1.fld, val); \ - else \ - FPGA_GET_REG(I2C_ADAP_HWNR, i2c0.fld, val); } + do { \ + if (I2C_ADAP_HWNR & 0x10) \ + FPGA_GET_REG(I2C_ADAP_HWNR & 0xf, i2c1.fld, val); \ + else \ + FPGA_GET_REG(I2C_ADAP_HWNR, i2c0.fld, val); \ + } while (0) #else #define I2C_GET_REG(fld, val) \ - FPGA_GET_REG(I2C_ADAP_HWNR, i2c0.fld, val); + FPGA_GET_REG(I2C_ADAP_HWNR, i2c0.fld, val) #endif
enum {
Hello Dirk,
bye, Heiko
- else \
- do { \
else \
- } while (0) #else #define I2C_SET_REG(fld, val) \
#endif
- else \
- do { \
else \
- } while (0) #else #define I2C_GET_REG(fld, val) \
#endif
enum {
Bus has to be held for repeated start regardless of read/write access.
drivers/i2c/ihs_i2c.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/i2c/ihs_i2c.c b/drivers/i2c/ihs_i2c.c index e001459..b05c15f 100644 --- a/drivers/i2c/ihs_i2c.c +++ b/drivers/i2c/ihs_i2c.c @@ -135,7 +135,7 @@ static int ihs_i2c_access(struct i2c_adapter *adap, uchar chip, uint addr, if (len <= 0) return 1;
- if (ihs_i2c_address(chip, addr, alen, !read)) + if (ihs_i2c_address(chip, addr, alen, len)) return 1;
while (len) {
Hello Dirk,
bye, Heiko
while (len) {
board/gdsys/common/dp501.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/board/gdsys/common/dp501.c b/board/gdsys/common/dp501.c index 7eb15ed..baace38 100644 --- a/board/gdsys/common/dp501.c +++ b/board/gdsys/common/dp501.c @@ -77,6 +77,8 @@ void dp501_powerup(u8 addr) i2c_reg_write(addr + 2, 0x24, 0x02); /* clock input single ended */ #endif
+ i2c_reg_write(addr + 2, 0x1a, 0x04); /* SPDIF input method TTL */ + i2c_reg_write(addr + 2, 0x00, 0x18); /* driving strength */ i2c_reg_write(addr + 2, 0x03, 0x06); /* driving strength */ i2c_reg_write(addr, 0x2c, 0x00); /* configure N value */
Hello Dirk,
- i2c_reg_write(addr + 2, 0x1a, 0x04); /* SPDIF input method TTL */
- i2c_reg_write(addr + 2, 0x00, 0x18); /* driving strength */ i2c_reg_write(addr + 2, 0x03, 0x06); /* driving strength */ i2c_reg_write(addr, 0x2c, 0x00); /* configure N value */
Hmm... a lot of magical values ... some defines would be nice here.
Beside of this:
Reviewed-by: Heiko Schocher hs@denx.de
bye, Heiko
Hello Heiko,
2015-10-28 12:25 GMT+01:00 Heiko Schocher hs@denx.de:
Agreed. Documenting all the ugly mess Parade Technologies calls an interface would result in a list of enums, that would be as long as (at least) the driver itself. So I decided to comment line by line what happens. Since this is (at least as far I as know) the only open source code for DP501, I hope one day I will find some time to invest some more effort here.
Cheers Dirk
On Wed, Oct 28, 2015 at 11:46:25AM +0100, Dirk Eibach wrote:
Signed-off-by: Dirk Eibach dirk.eibach@gdsys.cc Reviewed-by: Heiko Schocher hs@denx.de
With Club 3D dual link adapter there are AUX-channel timeouts when EDID is read. Increasing retry interval time to max (400us) fixes this.
board/gdsys/common/dp501.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/board/gdsys/common/dp501.c b/board/gdsys/common/dp501.c index baace38..0389fd1 100644 --- a/board/gdsys/common/dp501.c +++ b/board/gdsys/common/dp501.c @@ -88,7 +88,8 @@ void dp501_powerup(u8 addr) dp501_setbits(addr, 0x78, 0x03); /* clear all interrupt */ i2c_reg_write(addr, 0x75, 0xf8); /* aux channel reset */ i2c_reg_write(addr, 0x75, 0x00); /* clear aux channel reset */ - i2c_reg_write(addr, 0x87, 0x70); /* set retry counter as 7 */ + i2c_reg_write(addr, 0x87, 0x7f); /* set retry counter as 7 + retry interval 400us */
if (dp501_detect_cable_adapter(addr)) { printf("DVI/HDMI cable adapter detected\n");
Hello Dirk,
except the same comment as patch before ... this file uses a lot of magic values ... maybe this should be fixed?
Hmm... and converting the hole board support to DM would be nice ;-)
bye, Heiko
DP501 only supports DP 1.1a. Limit settings for link bandwidth and lane count to values allowed by DP 1.1a.
board/gdsys/common/dp501.c | 22 ++++++++++++++++++++-- 1 file changed, 20 insertions(+), 2 deletions(-)
diff --git a/board/gdsys/common/dp501.c b/board/gdsys/common/dp501.c index 0389fd1..d35aee0 100644 --- a/board/gdsys/common/dp501.c +++ b/board/gdsys/common/dp501.c @@ -40,11 +40,29 @@ static int dp501_detect_cable_adapter(u8 addr) static void dp501_link_training(u8 addr) { u8 val; + u8 link_bw; + u8 max_lane_cnt; + u8 lane_cnt;
val = i2c_reg_read(addr, 0x51); - i2c_reg_write(addr, 0x5d, val); /* set link_bw */ + if (val >= 0x0a) + link_bw = 0x0a; + else + link_bw = 0x06; + if (link_bw != val) + printf("DP sink supports %d Mbps link rate, set to %d Mbps\n", + val * 270, link_bw * 270); + i2c_reg_write(addr, 0x5d, link_bw); /* set link_bw */ val = i2c_reg_read(addr, 0x52); - i2c_reg_write(addr, 0x5e, val); /* set lane_cnt */ + max_lane_cnt = val & 0x1f; + if (max_lane_cnt >= 4) + lane_cnt = 4; + else + lane_cnt = max_lane_cnt; + if (lane_cnt != max_lane_cnt) + printf("DP sink supports %d lanes, set to %d lanes\n", + max_lane_cnt, lane_cnt); + i2c_reg_write(addr, 0x5e, lane_cnt | (val & 0x80)); /* set lane_cnt */ val = i2c_reg_read(addr, 0x53); i2c_reg_write(addr, 0x5c, val); /* set downspread_ctl */
Support dlvision-10g hardware with displayport output.
board/gdsys/405ep/dlvision-10g.c | 67 ++++++++++++++++++++++------------------ board/gdsys/common/Makefile | 2 +- include/configs/dlvision-10g.h | 18 ++++++++--- 3 files changed, 51 insertions(+), 36 deletions(-)
diff --git a/board/gdsys/405ep/dlvision-10g.c b/board/gdsys/405ep/dlvision-10g.c index 35dfbbc..54c7eb3 100644 --- a/board/gdsys/405ep/dlvision-10g.c +++ b/board/gdsys/405ep/dlvision-10g.c @@ -25,17 +25,19 @@ #define LATCH2_MC2_PRESENT_N 0x0080
enum { - UNITTYPE_VIDEO_USER = 0, - UNITTYPE_MAIN_USER = 1, - UNITTYPE_VIDEO_SERVER = 2, - UNITTYPE_MAIN_SERVER = 3, + UNITTYPE_MAIN = 1<<0, + UNITTYPE_SERVER = 1<<1, + UNITTYPE_DISPLAYPORT = 1<<2, };
enum { HWVER_101 = 0, HWVER_110 = 1, - HWVER_120 = 2, - HWVER_130 = 3, + HWVER_130 = 2, + HWVER_140 = 3, + HWVER_150 = 4, + HWVER_160 = 5, + HWVER_170 = 6, };
enum { @@ -121,43 +123,48 @@ static void print_fpga_info(unsigned dev) feature_carriers = (fpga_features >> 2) & 0x0003; feature_video_channels = fpga_features & 0x0003;
- switch (unit_type) { - case UNITTYPE_VIDEO_USER: - printf("Videochannel Userside"); - break; + if (unit_type & UNITTYPE_MAIN) + printf("Mainchannel "); + else + printf("Videochannel ");
- case UNITTYPE_MAIN_USER: - printf("Mainchannel Userside"); - break; + if (unit_type & UNITTYPE_SERVER) + printf("Serverside "); + else + printf("Userside "); + + if (unit_type & UNITTYPE_DISPLAYPORT) + printf("DisplayPort"); + else + printf("DVI-DL");
- case UNITTYPE_VIDEO_SERVER: - printf("Videochannel Serverside"); + switch (hardware_version) { + case HWVER_101: + printf(" HW-Ver 1.01\n"); break;
- case UNITTYPE_MAIN_SERVER: - printf("Mainchannel Serverside"); + case HWVER_110: + printf(" HW-Ver 1.10-1.20\n"); break;
- default: - printf("UnitType %d(not supported)", unit_type); + case HWVER_130: + printf(" HW-Ver 1.30\n"); break; - }
- switch (hardware_version) { - case HWVER_101: - printf(" HW-Ver 1.01\n"); + case HWVER_140: + printf(" HW-Ver 1.40-1.43\n"); break;
- case HWVER_110: - printf(" HW-Ver 1.10-1.12\n"); + case HWVER_150: + printf(" HW-Ver 1.50\n"); break;
- case HWVER_120: - printf(" HW-Ver 1.20\n"); + case HWVER_160: + printf(" HW-Ver 1.60-1.61\n"); break;
- case HWVER_130: - printf(" HW-Ver 1.30\n"); + case HWVER_170: + printf(" HW-Ver 1.70\n"); break;
default: @@ -260,7 +267,7 @@ int last_stage_init(void) if (get_mc2_present()) print_fpga_info(1);
- if (((versions >> 4) & 0x000f) != UNITTYPE_MAIN_USER) + if (((versions >> 4) & 0x000f) & UNITTYPE_SERVER) return 0;
if (!get_fpga_state(0) || (get_hwver() == HWVER_101)) diff --git a/board/gdsys/common/Makefile b/board/gdsys/common/Makefile index 4957943..95e41de 100644 --- a/board/gdsys/common/Makefile +++ b/board/gdsys/common/Makefile @@ -10,6 +10,6 @@ obj-$(CONFIG_CMD_IOLOOP) += cmd_ioloop.o obj-$(CONFIG_IO) += miiphybb.o obj-$(CONFIG_IO64) += miiphybb.o obj-$(CONFIG_IOCON) += osd.o mclink.o dp501.o phy.o -obj-$(CONFIG_DLVISION_10G) += osd.o +obj-$(CONFIG_DLVISION_10G) += osd.o dp501.o obj-$(CONFIG_CONTROLCENTERD) += dp501.o obj-$(CONFIG_HRCON) += osd.o mclink.o dp501.o phy.o diff --git a/include/configs/dlvision-10g.h b/include/configs/dlvision-10g.h index e6bfe58..08cd1dd 100644 --- a/include/configs/dlvision-10g.h +++ b/include/configs/dlvision-10g.h @@ -69,7 +69,7 @@ #undef CONFIG_CMD_DIAG #undef CONFIG_CMD_EEPROM #undef CONFIG_CMD_ELF -#undef CONFIG_CMD_I2C +#define CONFIG_CMD_I2C #undef CONFIG_CMD_IRQ
/* @@ -107,17 +107,22 @@ #define CONFIG_SYS_I2C_PPC4XX_SLAVE_0 0x7F
#define CONFIG_SYS_I2C_IHS +#define CONFIG_SYS_I2C_IHS_DUAL #define CONFIG_SYS_I2C_IHS_CH0 #define CONFIG_SYS_I2C_IHS_SPEED_0 50000 #define CONFIG_SYS_I2C_IHS_SLAVE_0 0x7F +#define CONFIG_SYS_I2C_IHS_SPEED_0_1 50000 +#define CONFIG_SYS_I2C_IHS_SLAVE_0_1 0x7F #define CONFIG_SYS_I2C_IHS_CH1 #define CONFIG_SYS_I2C_IHS_SPEED_1 50000 #define CONFIG_SYS_I2C_IHS_SLAVE_1 0x7F +#define CONFIG_SYS_I2C_IHS_SPEED_1_1 50000 +#define CONFIG_SYS_I2C_IHS_SLAVE_1_1 0x7F
-#define CONFIG_SYS_SPD_BUS_NUM 2 +#define CONFIG_SYS_SPD_BUS_NUM 4
/* Temp sensor/hwmon/dtt */ -#define CONFIG_SYS_DTT_BUS_NUM 2 +#define CONFIG_SYS_DTT_BUS_NUM 4 #define CONFIG_DTT_LM63 1 /* National LM63 */ #define CONFIG_DTT_SENSORS { 0x4c, 0x4e, 0x18 } /* Sensor addresses */ #define CONFIG_DTT_PWM_LOOKUPTABLE \ @@ -125,8 +130,9 @@ { 54, 27 }, { 56, 31 }, { 58, 36 }, { 60, 40 } } #define CONFIG_DTT_TACH_LIMIT 0xa10
-#define CONFIG_SYS_ICS8N3QV01_I2C {0, 1} -#define CONFIG_SYS_SIL1178_I2C {0, 1} +#define CONFIG_SYS_ICS8N3QV01_I2C {1, 3} +#define CONFIG_SYS_SIL1178_I2C {0, 2} +#define CONFIG_SYS_DP501_I2C {0, 2}
/* EBC peripherals */
@@ -329,5 +335,7 @@ */ #define CONFIG_SYS_MPC92469AC #define CONFIG_SYS_OSD_SCREENS CONFIG_SYS_FPGA_COUNT +#define CONFIG_SYS_DP501_DIFFERENTIAL +#define CONFIG_SYS_DP501_VCAPCTRL0 0x01 /* DDR mode 0, DE for H/VSYNC */
#endif /* __CONFIG_H */
board/gdsys/p1022/controlcenterd.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/board/gdsys/p1022/controlcenterd.c b/board/gdsys/p1022/controlcenterd.c index 64d90dd..2f98e47 100644 --- a/board/gdsys/p1022/controlcenterd.c +++ b/board/gdsys/p1022/controlcenterd.c @@ -57,6 +57,8 @@ struct ihs_fpga { u32 versions; /* 0x0004 */ u32 fpga_version; /* 0x0008 */ u32 fpga_features; /* 0x000c */ + u32 reserved[4]; /* 0x0010 */ + u32 control; /* 0x0020 */ };
#ifndef CONFIG_TRAILBLAZER @@ -384,6 +386,9 @@ static void hydra_initialize(void) fpga = pci_map_bar(devno, PCI_BASE_ADDRESS_0, PCI_REGION_MEM);
+ /* disable sideband clocks */ + writel(1, &fpga->control); + versions = readl(&fpga->versions); fpga_version = readl(&fpga->fpga_version); fpga_features = readl(&fpga->fpga_features);
- Reset FPGAs in last_stage_init()
Signed-off-by: Reinhard Pfau pfau@gdsys.de Signed-off-by: Dirk Eibach dirk.eibach@gdsys.cc ---
board/gdsys/405ep/iocon.c | 8 +++++++- 1 file changed, 7 insertions(+), 1 deletion(-)
diff --git a/board/gdsys/405ep/iocon.c b/board/gdsys/405ep/iocon.c index 3a51d86..7484624 100644 --- a/board/gdsys/405ep/iocon.c +++ b/board/gdsys/405ep/iocon.c @@ -381,7 +381,7 @@ int last_stage_init(void) ch0_rgmii2_present = !pca9698_get_value(0x20, 30); }
- /* wait for FPGA done */ + /* wait for FPGA done; then reset FPGA */ for (k = 0; k < ARRAY_SIZE(mclink_controllers); ++k) { unsigned int ctr = 0;
@@ -396,6 +396,12 @@ int last_stage_init(void) break; } } + + pca953x_set_dir(mclink_controllers[k], MCFPGA_RESET_N, 0); + pca953x_set_val(mclink_controllers[k], MCFPGA_RESET_N, 0); + udelay(10); + pca953x_set_val(mclink_controllers[k], MCFPGA_RESET_N, + MCFPGA_RESET_N); }
if (!legacy && (feature_carrier_speed == CARRIER_SPEED_1G)) {
hrcon has no CH7301 DVI-transmitter. Probably not removed when copying from iocon.
include/configs/hrcon.h | 1 - 1 file changed, 1 deletion(-)
diff --git a/include/configs/hrcon.h b/include/configs/hrcon.h index 558edfc..f1a69a3 100644 --- a/include/configs/hrcon.h +++ b/include/configs/hrcon.h @@ -361,7 +361,6 @@ #define CONFIG_SYS_I2C_SOFT_SLAVE_4 0x7F
#define CONFIG_SYS_ICS8N3QV01_I2C {5, 6, 7, 8} -#define CONFIG_SYS_CH7301_I2C {5, 6, 7, 8} #define CONFIG_SYS_DP501_I2C {1, 2, 3, 4}
#ifndef __ASSEMBLY__
The gdsys strider board is based on a Freescale MPC8308 SOC. It boots from NOR-Flash, kernel and rootfs are stored on SD-Card.
On board peripherals include: - 1x 10/100 Mbit/s Ethernet (optional) - Lattice ECP3 FPGA connected via eLBC
arch/powerpc/cpu/mpc83xx/Kconfig | 3 + board/gdsys/common/Makefile | 4 +- board/gdsys/common/adv7611.c | 177 +++++++++++ board/gdsys/common/adv7611.h | 13 + board/gdsys/common/ch7301.c | 64 ++++ board/gdsys/common/ch7301.h | 13 + board/gdsys/common/ioep-fpga.c | 227 ++++++++++++++ board/gdsys/common/ioep-fpga.h | 14 + board/gdsys/common/osd.c | 43 +-- board/gdsys/common/osd.h | 1 + board/gdsys/mpc8308/Kconfig | 13 + board/gdsys/mpc8308/MAINTAINERS | 3 + board/gdsys/mpc8308/Makefile | 1 + board/gdsys/mpc8308/strider.c | 501 ++++++++++++++++++++++++++++++ configs/strider_con_defconfig | 7 + configs/strider_cpu_defconfig | 7 + include/configs/strider.h | 653 +++++++++++++++++++++++++++++++++++++++ include/gdsys_fpga.h | 63 ++++ 18 files changed, 1766 insertions(+), 41 deletions(-) create mode 100644 board/gdsys/common/adv7611.c create mode 100644 board/gdsys/common/adv7611.h create mode 100644 board/gdsys/common/ch7301.c create mode 100644 board/gdsys/common/ch7301.h create mode 100644 board/gdsys/common/ioep-fpga.c create mode 100644 board/gdsys/common/ioep-fpga.h create mode 100644 board/gdsys/mpc8308/strider.c create mode 100644 configs/strider_con_defconfig create mode 100644 configs/strider_cpu_defconfig create mode 100644 include/configs/strider.h
diff --git a/arch/powerpc/cpu/mpc83xx/Kconfig b/arch/powerpc/cpu/mpc83xx/Kconfig index 3fb901f..3ea62ca 100644 --- a/arch/powerpc/cpu/mpc83xx/Kconfig +++ b/arch/powerpc/cpu/mpc83xx/Kconfig @@ -67,6 +67,9 @@ config TARGET_TQM834X config TARGET_HRCON bool "Support hrcon"
+config TARGET_STRIDER + bool "Support strider" + endchoice
source "board/esd/vme8349/Kconfig" diff --git a/board/gdsys/common/Makefile b/board/gdsys/common/Makefile index 95e41de..ba48e8b 100644 --- a/board/gdsys/common/Makefile +++ b/board/gdsys/common/Makefile @@ -9,7 +9,9 @@ obj-$(CONFIG_SYS_FPGA_COMMON) += fpga.o obj-$(CONFIG_CMD_IOLOOP) += cmd_ioloop.o obj-$(CONFIG_IO) += miiphybb.o obj-$(CONFIG_IO64) += miiphybb.o -obj-$(CONFIG_IOCON) += osd.o mclink.o dp501.o phy.o +obj-$(CONFIG_IOCON) += osd.o mclink.o dp501.o phy.o ch7301.o obj-$(CONFIG_DLVISION_10G) += osd.o dp501.o obj-$(CONFIG_CONTROLCENTERD) += dp501.o obj-$(CONFIG_HRCON) += osd.o mclink.o dp501.o phy.o +obj-$(CONFIG_STRIDER) += mclink.o dp501.o phy.o ioep-fpga.o adv7611.o ch7301.o +obj-$(CONFIG_STRIDER_CON) += osd.o diff --git a/board/gdsys/common/adv7611.c b/board/gdsys/common/adv7611.c new file mode 100644 index 0000000..b728274 --- /dev/null +++ b/board/gdsys/common/adv7611.c @@ -0,0 +1,177 @@ +/* + * (C) Copyright 2014 + * Dirk Eibach, Guntermann & Drunck GmbH, eibach@gdsys.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <i2c.h> + +#define ADV7611_I2C_ADDR 0x4c +#define ADV7611_RDINFO 0x2051 + +/* + * ADV7611 I2C Addresses in u-boot notation + */ +enum { + CP_I2C_ADDR = 0x22, + DPLL_I2C_ADDR = 0x26, + KSV_I2C_ADDR = 0x32, + HDMI_I2C_ADDR = 0x34, + EDID_I2C_ADDR = 0x36, + INFOFRAME_I2C_ADDR = 0x3e, + CEC_I2C_ADDR = 0x40, + IO_I2C_ADDR = ADV7611_I2C_ADDR, +}; + +/* + * Global Control Registers + */ +enum { + IO_RD_INFO_MSB = 0xea, + IO_RD_INFO_LSB = 0xeb, + IO_CEC_ADDR = 0xf4, + IO_INFOFRAME_ADDR = 0xf5, + IO_DPLL_ADDR = 0xf8, + IO_KSV_ADDR = 0xf9, + IO_EDID_ADDR = 0xfa, + IO_HDMI_ADDR = 0xfb, + IO_CP_ADDR = 0xfd, +}; + +int adv7611_i2c[] = CONFIG_SYS_ADV7611_I2C; + +int adv7611_probe(unsigned int screen) +{ + int old_bus = i2c_get_bus_num(); + unsigned int rd_info; + int res = 0; + + i2c_set_bus_num(adv7611_i2c[screen]); + + rd_info = (i2c_reg_read(IO_I2C_ADDR, IO_RD_INFO_MSB) << 8) + | i2c_reg_read(IO_I2C_ADDR, IO_RD_INFO_LSB); + + if (rd_info != ADV7611_RDINFO) { + res = -1; + goto out; + } + + /* + * set I2C addresses to default values + */ + i2c_reg_write(IO_I2C_ADDR, IO_CEC_ADDR, CEC_I2C_ADDR << 1); + i2c_reg_write(IO_I2C_ADDR, IO_INFOFRAME_ADDR, INFOFRAME_I2C_ADDR << 1); + i2c_reg_write(IO_I2C_ADDR, IO_DPLL_ADDR, DPLL_I2C_ADDR << 1); + i2c_reg_write(IO_I2C_ADDR, IO_KSV_ADDR, KSV_I2C_ADDR << 1); + i2c_reg_write(IO_I2C_ADDR, IO_EDID_ADDR, EDID_I2C_ADDR << 1); + i2c_reg_write(IO_I2C_ADDR, IO_HDMI_ADDR, HDMI_I2C_ADDR << 1); + i2c_reg_write(IO_I2C_ADDR, IO_CP_ADDR, CP_I2C_ADDR << 1); + + /* + * do magic initialization sequence from + * "ADV7611 Register Settings Recommendations Revision 1.5" + * with most registers undocumented + */ + i2c_reg_write(CP_I2C_ADDR, 0x6c, 0x00); + i2c_reg_write(HDMI_I2C_ADDR, 0x9b, 0x03); + i2c_reg_write(HDMI_I2C_ADDR, 0x6f, 0x08); + i2c_reg_write(HDMI_I2C_ADDR, 0x85, 0x1f); + i2c_reg_write(HDMI_I2C_ADDR, 0x87, 0x70); + i2c_reg_write(HDMI_I2C_ADDR, 0x57, 0xda); + i2c_reg_write(HDMI_I2C_ADDR, 0x58, 0x01); + i2c_reg_write(HDMI_I2C_ADDR, 0x03, 0x98); + i2c_reg_write(HDMI_I2C_ADDR, 0x4c, 0x44); + + /* + * IO_REG_02, default 0xf0 + * + * INP_COLOR_SPACE (IO, Address 0x02[7:4]) + * default: 0b1111 auto + * set to : 0b0001 force RGB (range 0 to 255) input + * + * RGB_OUT (IO, Address 0x02[1]) + * default: 0 YPbPr color space output + * set to : 1 RGB color space output + */ + i2c_reg_write(IO_I2C_ADDR, 0x02, 0x12); + + /* + * IO_REG_03, default 0x00 + * + * OP_FORMAT_SEL (IO, Address 0x03[7:0]) + * default: 0x00 8-bit SDR ITU-656 mode + * set to : 0x40 24-bit 4:4:4 SDR mode + */ + i2c_reg_write(IO_I2C_ADDR, 0x03, 0x40); + + /* + * IO_REG_05, default 0x2c + * + * AVCODE_INSERT_EN (IO, Address 0x05[2]) + * default: 1 insert AV codes into data stream + * set to : 0 do not insert AV codes into data stream + */ + i2c_reg_write(IO_I2C_ADDR, 0x05, 0x28); + + /* + * IO_REG_0C, default 0x62 + * + * POWER_DOWN (IO, Address 0x0C[5]) + * default: 1 chip is powered down + * set to : 0 chip is operational + */ + i2c_reg_write(IO_I2C_ADDR, 0x0c, 0x42); + + /* + * IO_REG_15, default 0xbe + * + * TRI_SYNCS (IO, Address 0x15[3) + * TRI_LLC (IO, Address 0x15[2]) + * TRI_PIX (IO, Address 0x15[1]) + * default: 1 video output pins are tristate + * set to : 0 video output pins are active + */ + i2c_reg_write(IO_I2C_ADDR, 0x15, 0xb0); + + /* + * HDMI_REGISTER_02H, default 0xff + * + * CLOCK_TERMA_DISABLE (HDMI, Address 0x83[0]) + * default: 1 disable termination + * set to : 0 enable termination + * Future options are: + * - use the chips automatic termination control + * - set this manually on cable detect + * but at the moment this seems a safe default. + */ + i2c_reg_write(HDMI_I2C_ADDR, 0x83, 0xfe); + + /* + * HDMI_CP_CNTRL_1, default 0x01 + * + * HDMI_FRUN_EN (CP, Address 0xBA[0]) + * default: 1 Enable the free run feature in HDMI mode + * set to : 0 Disable the free run feature in HDMI mode + */ + i2c_reg_write(CP_I2C_ADDR, 0xba, 0x00); + + /* + * INT1_CONFIGURATION, default 0x20 + * + * INTRQ_DUR_SEL[1:0] (IO, Address 0x40[7:6]) + * default: 00 Interrupt signal is active for 4 Xtal periods + * set to : 11 Active until cleared + * + * INTRQ_OP_SEL[1:0] (IO, Address 0x40[1:0]) + * default: 00 Open drain + * set to : 10 Drives high when active + */ + i2c_reg_write(IO_I2C_ADDR, 0x40, 0xc2); + +out: + i2c_set_bus_num(old_bus); + + return res; +} diff --git a/board/gdsys/common/adv7611.h b/board/gdsys/common/adv7611.h new file mode 100644 index 0000000..25a8367 --- /dev/null +++ b/board/gdsys/common/adv7611.h @@ -0,0 +1,13 @@ +/* + * (C) Copyright 2014 + * Dirk Eibach, Guntermann & Drunck GmbH, dirk.eibach@gdsys.cc + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _ADV7611_H_ +#define _ADV7611_H_ + +int adv7611_probe(unsigned int screen); + +#endif diff --git a/board/gdsys/common/ch7301.c b/board/gdsys/common/ch7301.c new file mode 100644 index 0000000..c054e55 --- /dev/null +++ b/board/gdsys/common/ch7301.c @@ -0,0 +1,64 @@ +/* + * (C) Copyright 2014 + * Dirk Eibach, Guntermann & Drunck GmbH, dirk.eibach@gdsys.cc + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/* Chrontel CH7301C DVI Transmitter */ + +#include <common.h> +#include <asm/io.h> +#include <errno.h> +#include <i2c.h> + +#define CH7301_I2C_ADDR 0x75 + +enum { + CH7301_CM = 0x1c, /* Clock Mode Register */ + CH7301_IC = 0x1d, /* Input Clock Register */ + CH7301_GPIO = 0x1e, /* GPIO Control Register */ + CH7301_IDF = 0x1f, /* Input Data Format Register */ + CH7301_CD = 0x20, /* Connection Detect Register */ + CH7301_DC = 0x21, /* DAC Control Register */ + CH7301_HPD = 0x23, /* Hot Plug Detection Register */ + CH7301_TCTL = 0x31, /* DVI Control Input Register */ + CH7301_TPCP = 0x33, /* DVI PLL Charge Pump Ctrl Register */ + CH7301_TPD = 0x34, /* DVI PLL Divide Register */ + CH7301_TPVT = 0x35, /* DVI PLL Supply Control Register */ + CH7301_TPF = 0x36, /* DVI PLL Filter Register */ + CH7301_TCT = 0x37, /* DVI Clock Test Register */ + CH7301_TSTP = 0x48, /* Test Pattern Register */ + CH7301_PM = 0x49, /* Power Management register */ + CH7301_VID = 0x4a, /* Version ID Register */ + CH7301_DID = 0x4b, /* Device ID Register */ + CH7301_DSP = 0x56, /* DVI Sync polarity Register */ +}; + +int ch7301_i2c[] = CONFIG_SYS_CH7301_I2C; + +int ch7301_probe(unsigned screen, bool power) +{ + u8 value; + + i2c_set_bus_num(ch7301_i2c[screen]); + if (i2c_probe(CH7301_I2C_ADDR)) + return -1; + + value = i2c_reg_read(CH7301_I2C_ADDR, CH7301_DID); + if (value != 0x17) + return -1; + + if (power) { + i2c_reg_write(CH7301_I2C_ADDR, CH7301_TPCP, 0x08); + i2c_reg_write(CH7301_I2C_ADDR, CH7301_TPD, 0x16); + i2c_reg_write(CH7301_I2C_ADDR, CH7301_TPF, 0x60); + i2c_reg_write(CH7301_I2C_ADDR, CH7301_DC, 0x09); + i2c_reg_write(CH7301_I2C_ADDR, CH7301_PM, 0xc0); + } else { + i2c_reg_write(CH7301_I2C_ADDR, CH7301_DC, 0x00); + i2c_reg_write(CH7301_I2C_ADDR, CH7301_PM, 0x01); + } + + return 0; +} diff --git a/board/gdsys/common/ch7301.h b/board/gdsys/common/ch7301.h new file mode 100644 index 0000000..8383719 --- /dev/null +++ b/board/gdsys/common/ch7301.h @@ -0,0 +1,13 @@ +/* + * (C) Copyright 2014 + * Dirk Eibach, Guntermann & Drunck GmbH, dirk.eibach@gdsys.cc + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _CH7301_H_ +#define _CH7301_H_ + +int ch7301_probe(unsigned screen, bool power); + +#endif diff --git a/board/gdsys/common/ioep-fpga.c b/board/gdsys/common/ioep-fpga.c new file mode 100644 index 0000000..18d37dc --- /dev/null +++ b/board/gdsys/common/ioep-fpga.c @@ -0,0 +1,227 @@ +/* + * (C) Copyright 2014 + * Dirk Eibach, Guntermann & Drunck GmbH, eibach@gdsys.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> + +#include <gdsys_fpga.h> + +enum { + UNITTYPE_MAIN_SERVER = 0, + UNITTYPE_MAIN_USER = 1, + UNITTYPE_VIDEO_SERVER = 2, + UNITTYPE_VIDEO_USER = 3, +}; + +enum { + UNITTYPEPCB_DVI = 0, + UNITTYPEPCB_DP_165 = 1, + UNITTYPEPCB_DP_300 = 2, + UNITTYPEPCB_HDMI = 3, +}; + +enum { + COMPRESSION_NONE = 0, + COMPRESSION_TYPE1_DELTA = 1, + COMPRESSION_TYPE1_TYPE2_DELTA = 3, +}; + +enum { + AUDIO_NONE = 0, + AUDIO_TX = 1, + AUDIO_RX = 2, + AUDIO_RXTX = 3, +}; + +enum { + SYSCLK_147456 = 0, +}; + +enum { + RAM_DDR2_32 = 0, + RAM_DDR3_32 = 1, +}; + +enum { + CARRIER_SPEED_1G = 0, + CARRIER_SPEED_2_5G = 1, +}; + +bool ioep_fpga_has_osd(unsigned int fpga) +{ + u16 fpga_features; + unsigned feature_osd; + + FPGA_GET_REG(0, fpga_features, &fpga_features); + feature_osd = fpga_features & (1<<11); + + return feature_osd; +} + +void ioep_fpga_print_info(unsigned int fpga) +{ + u16 versions; + u16 fpga_version; + u16 fpga_features; + unsigned unit_type; + unsigned unit_type_pcb_video; + unsigned feature_compression; + unsigned feature_osd; + unsigned feature_audio; + unsigned feature_sysclock; + unsigned feature_ramconfig; + unsigned feature_carrier_speed; + unsigned feature_carriers; + unsigned feature_video_channels; + + FPGA_GET_REG(fpga, versions, &versions); + FPGA_GET_REG(fpga, fpga_version, &fpga_version); + FPGA_GET_REG(fpga, fpga_features, &fpga_features); + + unit_type = (versions & 0xf000) >> 12; + unit_type_pcb_video = (versions & 0x01c0) >> 6; + feature_compression = (fpga_features & 0xe000) >> 13; + feature_osd = fpga_features & (1<<11); + feature_audio = (fpga_features & 0x0600) >> 9; + feature_sysclock = (fpga_features & 0x0180) >> 7; + feature_ramconfig = (fpga_features & 0x0060) >> 5; + feature_carrier_speed = fpga_features & (1<<4); + feature_carriers = (fpga_features & 0x000c) >> 2; + feature_video_channels = fpga_features & 0x0003; + + switch (unit_type) { + case UNITTYPE_MAIN_SERVER: + case UNITTYPE_MAIN_USER: + printf("Mainchannel"); + break; + + case UNITTYPE_VIDEO_SERVER: + case UNITTYPE_VIDEO_USER: + printf("Videochannel"); + break; + + default: + printf("UnitType %d(not supported)", unit_type); + break; + } + + switch (unit_type) { + case UNITTYPE_MAIN_SERVER: + case UNITTYPE_VIDEO_SERVER: + printf(" Server"); + if (versions & (1<<4)) + printf(" UC"); + break; + + case UNITTYPE_MAIN_USER: + case UNITTYPE_VIDEO_USER: + printf(" User"); + break; + + default: + break; + } + + if (versions & (1<<5)) + printf(" Fiber"); + else + printf(" CAT"); + + switch (unit_type_pcb_video) { + case UNITTYPEPCB_DVI: + printf(" DVI,"); + break; + + case UNITTYPEPCB_DP_165: + printf(" DP 165MPix/s,"); + break; + + case UNITTYPEPCB_DP_300: + printf(" DP 300MPix/s,"); + break; + + case UNITTYPEPCB_HDMI: + printf(" HDMI,"); + break; + } + + printf(" FPGA V %d.%02d\n features:", + fpga_version / 100, fpga_version % 100); + + + switch (feature_compression) { + case COMPRESSION_NONE: + printf(" no compression"); + break; + + case COMPRESSION_TYPE1_DELTA: + printf(" type1-deltacompression"); + break; + + case COMPRESSION_TYPE1_TYPE2_DELTA: + printf(" type1-deltacompression, type2-inlinecompression"); + break; + + default: + printf(" compression %d(not supported)", feature_compression); + break; + } + + printf(", %sosd", feature_osd ? "" : "no "); + + switch (feature_audio) { + case AUDIO_NONE: + printf(", no audio"); + break; + + case AUDIO_TX: + printf(", audio tx"); + break; + + case AUDIO_RX: + printf(", audio rx"); + break; + + case AUDIO_RXTX: + printf(", audio rx+tx"); + break; + + default: + printf(", audio %d(not supported)", feature_audio); + break; + } + + puts(",\n "); + + switch (feature_sysclock) { + case SYSCLK_147456: + printf("clock 147.456 MHz"); + break; + + default: + printf("clock %d(not supported)", feature_sysclock); + break; + } + + switch (feature_ramconfig) { + case RAM_DDR2_32: + printf(", RAM 32 bit DDR2"); + break; + + case RAM_DDR3_32: + printf(", RAM 32 bit DDR3"); + break; + + default: + printf(", RAM %d(not supported)", feature_ramconfig); + break; + } + + printf(", %d carrier(s) %s", feature_carriers, + feature_carrier_speed ? "2.5Gbit/s" : "1Gbit/s"); + + printf(", %d video channel(s)\n", feature_video_channels); +} diff --git a/board/gdsys/common/ioep-fpga.h b/board/gdsys/common/ioep-fpga.h new file mode 100644 index 0000000..44f7139 --- /dev/null +++ b/board/gdsys/common/ioep-fpga.h @@ -0,0 +1,14 @@ +/* + * (C) Copyright 2014 + * Dirk Eibach, Guntermann & Drunck GmbH, dirk.eibach@gdsys.cc + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _IOEP_FPGA_H_ +#define _IOEP_FPGA_H_ + +void ioep_fpga_print_info(unsigned int fpga); +bool ioep_fpga_has_osd(unsigned int fpga); + +#endif diff --git a/board/gdsys/common/osd.c b/board/gdsys/common/osd.c index 55ecdf1..f11e26f 100644 --- a/board/gdsys/common/osd.c +++ b/board/gdsys/common/osd.c @@ -9,11 +9,10 @@ #include <i2c.h> #include <malloc.h>
+#include "ch7301.h" #include "dp501.h" #include <gdsys_fpga.h>
-#define CH7301_I2C_ADDR 0x75 - #define ICS8N3QV01_I2C_ADDR 0x6E #define ICS8N3QV01_FREF 114285000 #define ICS8N3QV01_FREF_LL 114285000LL @@ -29,27 +28,6 @@
#define PIXCLK_640_480_60 25180000
-enum { - CH7301_CM = 0x1c, /* Clock Mode Register */ - CH7301_IC = 0x1d, /* Input Clock Register */ - CH7301_GPIO = 0x1e, /* GPIO Control Register */ - CH7301_IDF = 0x1f, /* Input Data Format Register */ - CH7301_CD = 0x20, /* Connection Detect Register */ - CH7301_DC = 0x21, /* DAC Control Register */ - CH7301_HPD = 0x23, /* Hot Plug Detection Register */ - CH7301_TCTL = 0x31, /* DVI Control Input Register */ - CH7301_TPCP = 0x33, /* DVI PLL Charge Pump Ctrl Register */ - CH7301_TPD = 0x34, /* DVI PLL Divide Register */ - CH7301_TPVT = 0x35, /* DVI PLL Supply Control Register */ - CH7301_TPF = 0x36, /* DVI PLL Filter Register */ - CH7301_TCT = 0x37, /* DVI Clock Test Register */ - CH7301_TSTP = 0x48, /* Test Pattern Register */ - CH7301_PM = 0x49, /* Power Management register */ - CH7301_VID = 0x4a, /* Version ID Register */ - CH7301_DID = 0x4b, /* Device ID Register */ - CH7301_DSP = 0x56, /* DVI Sync polarity Register */ -}; - unsigned int base_width; unsigned int base_height; size_t bufsize; @@ -61,10 +39,6 @@ unsigned int max_osd_screen = CONFIG_SYS_OSD_SCREENS - 1; int ics8n3qv01_i2c[] = CONFIG_SYS_ICS8N3QV01_I2C; #endif
-#ifdef CONFIG_SYS_CH7301_I2C -int ch7301_i2c[] = CONFIG_SYS_CH7301_I2C; -#endif - #ifdef CONFIG_SYS_SIL1178_I2C int sil1178_i2c[] = CONFIG_SYS_SIL1178_I2C; #endif @@ -327,19 +301,8 @@ int osd_probe(unsigned screen) /* setup output driver */
#ifdef CONFIG_SYS_CH7301_I2C - i2c_set_bus_num(ch7301_i2c[screen]); - if (!i2c_probe(CH7301_I2C_ADDR)) { - u8 value = i2c_reg_read(CH7301_I2C_ADDR, CH7301_DID); - - if (value == 0x17) { - i2c_reg_write(CH7301_I2C_ADDR, CH7301_TPCP, 0x08); - i2c_reg_write(CH7301_I2C_ADDR, CH7301_TPD, 0x16); - i2c_reg_write(CH7301_I2C_ADDR, CH7301_TPF, 0x60); - i2c_reg_write(CH7301_I2C_ADDR, CH7301_DC, 0x09); - i2c_reg_write(CH7301_I2C_ADDR, CH7301_PM, 0xc0); - output_driver_present = true; - } - } + if (!ch7301_probe(screen, true)) + output_driver_present = true; #endif
#ifdef CONFIG_SYS_SIL1178_I2C diff --git a/board/gdsys/common/osd.h b/board/gdsys/common/osd.h index 440b276..5b3f14b 100644 --- a/board/gdsys/common/osd.h +++ b/board/gdsys/common/osd.h @@ -8,6 +8,7 @@ #ifndef _OSD_H_ #define _OSD_H_
+int ch7301_probe(unsigned screen, bool power); int osd_probe(unsigned screen);
#endif diff --git a/board/gdsys/mpc8308/Kconfig b/board/gdsys/mpc8308/Kconfig index 43e1663..9a1a3a2 100644 --- a/board/gdsys/mpc8308/Kconfig +++ b/board/gdsys/mpc8308/Kconfig @@ -10,3 +10,16 @@ config SYS_CONFIG_NAME default "hrcon"
endif + +if TARGET_STRIDER + +config SYS_BOARD + default "mpc8308" + +config SYS_VENDOR + default "gdsys" + +config SYS_CONFIG_NAME + default "strider" + +endif diff --git a/board/gdsys/mpc8308/MAINTAINERS b/board/gdsys/mpc8308/MAINTAINERS index a7853a5..35704bc 100644 --- a/board/gdsys/mpc8308/MAINTAINERS +++ b/board/gdsys/mpc8308/MAINTAINERS @@ -4,3 +4,6 @@ S: Maintained F: board/gdsys/mpc8308/ F: include/configs/hrcon.h F: configs/hrcon_defconfig +F: include/configs/strider.h +F: configs/strider_cpu_defconfig +F: configs/strider_con_defconfig diff --git a/board/gdsys/mpc8308/Makefile b/board/gdsys/mpc8308/Makefile index b5dfdbb..42702fb 100644 --- a/board/gdsys/mpc8308/Makefile +++ b/board/gdsys/mpc8308/Makefile @@ -7,3 +7,4 @@
obj-y := mpc8308.o sdram.o obj-$(CONFIG_HRCON) += hrcon.o +obj-$(CONFIG_STRIDER) += strider.o diff --git a/board/gdsys/mpc8308/strider.c b/board/gdsys/mpc8308/strider.c new file mode 100644 index 0000000..8e5d5de --- /dev/null +++ b/board/gdsys/mpc8308/strider.c @@ -0,0 +1,501 @@ +/* + * (C) Copyright 2014 + * Dirk Eibach, Guntermann & Drunck GmbH, eibach@gdsys.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <hwconfig.h> +#include <i2c.h> +#include <spi.h> +#include <libfdt.h> +#include <fdt_support.h> +#include <pci.h> +#include <mpc83xx.h> +#include <fsl_esdhc.h> +#include <asm/io.h> +#include <asm/fsl_serdes.h> +#include <asm/fsl_mpc83xx_serdes.h> + +#include "mpc8308.h" + +#include <gdsys_fpga.h> + +#include "../common/adv7611.h" +#include "../common/ch7301.h" +#include "../common/ioep-fpga.h" +#include "../common/mclink.h" +#include "../common/osd.h" +#include "../common/phy.h" + +#include <pca953x.h> +#include <pca9698.h> + +#include <miiphy.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define MAX_MUX_CHANNELS 2 + +enum { + MCFPGA_DONE = 1 << 0, + MCFPGA_INIT_N = 1 << 1, + MCFPGA_PROGRAM_N = 1 << 2, + MCFPGA_UPDATE_ENABLE_N = 1 << 3, + MCFPGA_RESET_N = 1 << 4, +}; + +enum { + GPIO_MDC = 1 << 14, + GPIO_MDIO = 1 << 15, +}; + +enum { + FAN_CONFIG = 0x03, + FAN_TACHLIM_LSB = 0x48, + FAN_TACHLIM_MSB = 0x49, + FAN_PWM_FREQ = 0x4D, +}; + +unsigned int mclink_fpgacount; +struct ihs_fpga *fpga_ptr[] = CONFIG_SYS_FPGA_PTR; + +struct { + u8 bus; + u8 addr; +} strider_fans[] = CONFIG_STRIDER_FANS; + +int fpga_set_reg(u32 fpga, u16 *reg, off_t regoff, u16 data) +{ + int res; + + switch (fpga) { + case 0: + out_le16(reg, data); + break; + default: + res = mclink_send(fpga - 1, regoff, data); + if (res < 0) { + printf("mclink_send reg %02lx data %04x returned %d\n", + regoff, data, res); + return res; + } + break; + } + + return 0; +} + +int fpga_get_reg(u32 fpga, u16 *reg, off_t regoff, u16 *data) +{ + int res; + + switch (fpga) { + case 0: + *data = in_le16(reg); + break; + default: + if (fpga > mclink_fpgacount) + return -EINVAL; + res = mclink_receive(fpga - 1, regoff, data); + if (res < 0) { + printf("mclink_receive reg %02lx returned %d\n", + regoff, res); + return res; + } + } + + return 0; +} + +int checkboard(void) +{ + char *s = getenv("serial#"); + bool hw_type_cat = pca9698_get_value(0x20, 18); + + puts("Board: "); + + printf("Strider %s", hw_type_cat ? "CAT" : "Fiber"); + + if (s != NULL) { + puts(", serial# "); + puts(s); + } + + puts("\n"); + + return 0; +} + +static void init_fan_controller(u8 addr) +{ + int val; + + /* set PWM Frequency to 2.5% resolution */ + i2c_reg_write(addr, FAN_PWM_FREQ, 20); + + /* set Tachometer Limit */ + i2c_reg_write(addr, FAN_TACHLIM_LSB, 0x10); + i2c_reg_write(addr, FAN_TACHLIM_MSB, 0x0a); + + /* enable Tach input */ + val = i2c_reg_read(addr, FAN_CONFIG) | 0x04; + i2c_reg_write(addr, FAN_CONFIG, val); +} + +int last_stage_init(void) +{ + int slaves; + unsigned int k; + unsigned int mux_ch; + unsigned char mclink_controllers[] = { 0x3c, 0x3d, 0x3e }; + bool hw_type_cat = pca9698_get_value(0x20, 18); + bool ch0_sgmii2_present = false; + + /* Turn on Analog Devices ADV7611 */ + pca9698_direction_output(0x20, 8, 0); + + /* Turn on Parade DP501 */ + pca9698_direction_output(0x20, 9, 1); + + ch0_sgmii2_present = !pca9698_get_value(0x20, 37); + + /* wait for FPGA done, then reset FPGA */ + for (k = 0; k < ARRAY_SIZE(mclink_controllers); ++k) { + unsigned int ctr = 0; + + if (i2c_probe(mclink_controllers[k])) + continue; + + while (!(pca953x_get_val(mclink_controllers[k]) + & MCFPGA_DONE)) { + udelay(100000); + if (ctr++ > 5) { + printf("no done for mclink_controller %d\n", k); + break; + } + } + + pca953x_set_dir(mclink_controllers[k], MCFPGA_RESET_N, 0); + pca953x_set_val(mclink_controllers[k], MCFPGA_RESET_N, 0); + udelay(10); + pca953x_set_val(mclink_controllers[k], MCFPGA_RESET_N, + MCFPGA_RESET_N); + } + + if (hw_type_cat) { + miiphy_register(bb_miiphy_buses[0].name, bb_miiphy_read, + bb_miiphy_write); + for (mux_ch = 0; mux_ch < MAX_MUX_CHANNELS; ++mux_ch) { + if ((mux_ch == 1) && !ch0_sgmii2_present) + continue; + + setup_88e1514(bb_miiphy_buses[0].name, mux_ch); + } + } + + /* give slave-PLLs and Parade DP501 some time to be up and running */ + udelay(500000); + + mclink_fpgacount = CONFIG_SYS_MCLINK_MAX; + slaves = mclink_probe(); + mclink_fpgacount = 0; + + ioep_fpga_print_info(0); + + if (!adv7611_probe(0)) + printf(" Advantiv ADV7611 HDMI Receiver\n"); + +#ifdef CONFIG_STRIDER_CON + if (ioep_fpga_has_osd(0)) + osd_probe(0); +#endif + +#ifdef CONFIG_STRIDER_CPU + ch7301_probe(0, false); +#endif + + if (slaves <= 0) + return 0; + + mclink_fpgacount = slaves; + + for (k = 1; k <= slaves; ++k) { + ioep_fpga_print_info(k); +#ifdef CONFIG_STRIDER_CON + if (ioep_fpga_has_osd(k)) + osd_probe(k); +#endif +#ifdef CONFIG_STRIDER_CPU + FPGA_SET_REG(k, extended_control, 0); /* enable video in*/ + if (!adv7611_probe(k)) + printf(" Advantiv ADV7611 HDMI Receiver\n"); + ch7301_probe(k, false); +#endif + if (hw_type_cat) { + miiphy_register(bb_miiphy_buses[k].name, + bb_miiphy_read, bb_miiphy_write); + setup_88e1514(bb_miiphy_buses[k].name, 0); + } + } + + for (k = 0; k < ARRAY_SIZE(strider_fans); ++k) { + i2c_set_bus_num(strider_fans[k].bus); + init_fan_controller(strider_fans[k].addr); + } + + return 0; +} + +/* + * provide access to fpga gpios (for I2C bitbang) + * (these may look all too simple but make iocon.h much more readable) + */ +void fpga_gpio_set(unsigned int bus, int pin) +{ + FPGA_SET_REG(bus, gpio.set, pin); +} + +void fpga_gpio_clear(unsigned int bus, int pin) +{ + FPGA_SET_REG(bus, gpio.clear, pin); +} + +int fpga_gpio_get(unsigned int bus, int pin) +{ + u16 val; + + FPGA_GET_REG(bus, gpio.read, &val); + + return val & pin; +} + +void mpc8308_init(void) +{ + pca9698_direction_output(0x20, 26, 1); +} + +void mpc8308_set_fpga_reset(unsigned state) +{ + pca9698_set_value(0x20, 26, state ? 0 : 1); +} + +void mpc8308_setup_hw(void) +{ + immap_t *immr = (immap_t *)CONFIG_SYS_IMMR; + + /* + * set "startup-finished"-gpios + */ + setbits_be32(&immr->gpio[0].dir, (1 << (31-11)) | (1 << (31-12))); + setbits_be32(&immr->gpio[0].dat, 1 << (31-12)); +} + +int mpc8308_get_fpga_done(unsigned fpga) +{ + return pca9698_get_value(0x20, 20); +} + +#ifdef CONFIG_FSL_ESDHC +int board_mmc_init(bd_t *bd) +{ + immap_t *immr = (immap_t *)CONFIG_SYS_IMMR; + sysconf83xx_t *sysconf = &immr->sysconf; + + /* Enable cache snooping in eSDHC system configuration register */ + out_be32(&sysconf->sdhccr, 0x02000000); + + return fsl_esdhc_mmc_init(bd); +} +#endif + +static struct pci_region pcie_regions_0[] = { + { + .bus_start = CONFIG_SYS_PCIE1_MEM_BASE, + .phys_start = CONFIG_SYS_PCIE1_MEM_PHYS, + .size = CONFIG_SYS_PCIE1_MEM_SIZE, + .flags = PCI_REGION_MEM, + }, + { + .bus_start = CONFIG_SYS_PCIE1_IO_BASE, + .phys_start = CONFIG_SYS_PCIE1_IO_PHYS, + .size = CONFIG_SYS_PCIE1_IO_SIZE, + .flags = PCI_REGION_IO, + }, +}; + +void pci_init_board(void) +{ + immap_t *immr = (immap_t *)CONFIG_SYS_IMMR; + sysconf83xx_t *sysconf = &immr->sysconf; + law83xx_t *pcie_law = sysconf->pcielaw; + struct pci_region *pcie_reg[] = { pcie_regions_0 }; + + fsl_setup_serdes(CONFIG_FSL_SERDES1, FSL_SERDES_PROTO_PEX, + FSL_SERDES_CLK_100, FSL_SERDES_VDD_1V); + + /* Deassert the resets in the control register */ + out_be32(&sysconf->pecr1, 0xE0008000); + udelay(2000); + + /* Configure PCI Express Local Access Windows */ + out_be32(&pcie_law[0].bar, CONFIG_SYS_PCIE1_BASE & LAWBAR_BAR); + out_be32(&pcie_law[0].ar, LBLAWAR_EN | LBLAWAR_512MB); + + mpc83xx_pcie_init(1, pcie_reg); +} + +ulong board_flash_get_legacy(ulong base, int banknum, flash_info_t *info) +{ + info->portwidth = FLASH_CFI_16BIT; + info->chipwidth = FLASH_CFI_BY16; + info->interface = FLASH_CFI_X16; + return 1; +} + +#if defined(CONFIG_OF_BOARD_SETUP) +int ft_board_setup(void *blob, bd_t *bd) +{ + ft_cpu_setup(blob, bd); + fdt_fixup_dr_usb(blob, bd); + fdt_fixup_esdhc(blob, bd); + + return 0; +} +#endif + +/* + * FPGA MII bitbang implementation + */ + +struct fpga_mii { + unsigned fpga; + int mdio; +} fpga_mii[] = { + { 0, 1}, + { 1, 1}, + { 2, 1}, + { 3, 1}, +}; + +static int mii_dummy_init(struct bb_miiphy_bus *bus) +{ + return 0; +} + +static int mii_mdio_active(struct bb_miiphy_bus *bus) +{ + struct fpga_mii *fpga_mii = bus->priv; + + if (fpga_mii->mdio) + FPGA_SET_REG(fpga_mii->fpga, gpio.set, GPIO_MDIO); + else + FPGA_SET_REG(fpga_mii->fpga, gpio.clear, GPIO_MDIO); + + return 0; +} + +static int mii_mdio_tristate(struct bb_miiphy_bus *bus) +{ + struct fpga_mii *fpga_mii = bus->priv; + + FPGA_SET_REG(fpga_mii->fpga, gpio.set, GPIO_MDIO); + + return 0; +} + +static int mii_set_mdio(struct bb_miiphy_bus *bus, int v) +{ + struct fpga_mii *fpga_mii = bus->priv; + + if (v) + FPGA_SET_REG(fpga_mii->fpga, gpio.set, GPIO_MDIO); + else + FPGA_SET_REG(fpga_mii->fpga, gpio.clear, GPIO_MDIO); + + fpga_mii->mdio = v; + + return 0; +} + +static int mii_get_mdio(struct bb_miiphy_bus *bus, int *v) +{ + u16 gpio; + struct fpga_mii *fpga_mii = bus->priv; + + FPGA_GET_REG(fpga_mii->fpga, gpio.read, &gpio); + + *v = ((gpio & GPIO_MDIO) != 0); + + return 0; +} + +static int mii_set_mdc(struct bb_miiphy_bus *bus, int v) +{ + struct fpga_mii *fpga_mii = bus->priv; + + if (v) + FPGA_SET_REG(fpga_mii->fpga, gpio.set, GPIO_MDC); + else + FPGA_SET_REG(fpga_mii->fpga, gpio.clear, GPIO_MDC); + + return 0; +} + +static int mii_delay(struct bb_miiphy_bus *bus) +{ + udelay(1); + + return 0; +} + +struct bb_miiphy_bus bb_miiphy_buses[] = { + { + .name = "board0", + .init = mii_dummy_init, + .mdio_active = mii_mdio_active, + .mdio_tristate = mii_mdio_tristate, + .set_mdio = mii_set_mdio, + .get_mdio = mii_get_mdio, + .set_mdc = mii_set_mdc, + .delay = mii_delay, + .priv = &fpga_mii[0], + }, + { + .name = "board1", + .init = mii_dummy_init, + .mdio_active = mii_mdio_active, + .mdio_tristate = mii_mdio_tristate, + .set_mdio = mii_set_mdio, + .get_mdio = mii_get_mdio, + .set_mdc = mii_set_mdc, + .delay = mii_delay, + .priv = &fpga_mii[1], + }, + { + .name = "board2", + .init = mii_dummy_init, + .mdio_active = mii_mdio_active, + .mdio_tristate = mii_mdio_tristate, + .set_mdio = mii_set_mdio, + .get_mdio = mii_get_mdio, + .set_mdc = mii_set_mdc, + .delay = mii_delay, + .priv = &fpga_mii[2], + }, + { + .name = "board3", + .init = mii_dummy_init, + .mdio_active = mii_mdio_active, + .mdio_tristate = mii_mdio_tristate, + .set_mdio = mii_set_mdio, + .get_mdio = mii_get_mdio, + .set_mdc = mii_set_mdc, + .delay = mii_delay, + .priv = &fpga_mii[3], + }, +}; + +int bb_miiphy_buses_num = sizeof(bb_miiphy_buses) / + sizeof(bb_miiphy_buses[0]); diff --git a/configs/strider_con_defconfig b/configs/strider_con_defconfig new file mode 100644 index 0000000..74ef69e --- /dev/null +++ b/configs/strider_con_defconfig @@ -0,0 +1,7 @@ +CONFIG_SYS_EXTRA_OPTIONS="STRIDER_CON" +CONFIG_PPC=y +CONFIG_MPC83xx=y +CONFIG_TARGET_STRIDER=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_STOP_STR=" " +# CONFIG_CMD_SETEXPR is not set diff --git a/configs/strider_cpu_defconfig b/configs/strider_cpu_defconfig new file mode 100644 index 0000000..fc0a823 --- /dev/null +++ b/configs/strider_cpu_defconfig @@ -0,0 +1,7 @@ +CONFIG_SYS_EXTRA_OPTIONS="STRIDER_CPU" +CONFIG_PPC=y +CONFIG_MPC83xx=y +CONFIG_TARGET_STRIDER=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_STOP_STR=" " +# CONFIG_CMD_SETEXPR is not set diff --git a/include/configs/strider.h b/include/configs/strider.h new file mode 100644 index 0000000..213efac --- /dev/null +++ b/include/configs/strider.h @@ -0,0 +1,653 @@ +/* + * (C) Copyright 2014 + * Dirk Eibach, Guntermann & Drunck GmbH, eibach@gdsys.de + * + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * High Level Configuration Options + */ +#define CONFIG_E300 1 /* E300 family */ +#define CONFIG_MPC83xx 1 /* MPC83xx family */ +#define CONFIG_MPC830x 1 /* MPC830x family */ +#define CONFIG_MPC8308 1 /* MPC8308 CPU specific */ +#define CONFIG_STRIDER 1 /* STRIDER board specific */ + +#define CONFIG_SYS_TEXT_BASE 0xFE000000 + +#ifdef CONFIG_STRIDER_CPU +#define CONFIG_IDENT_STRING " strider cpu 0.01" +#else +#define CONFIG_IDENT_STRING " strider con 0.01" +#endif + +#define CONFIG_SYS_GENERIC_BOARD + +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_BOARD_EARLY_INIT_R +#define CONFIG_LAST_STAGE_INIT + +/* new uImage format support */ +#define CONFIG_FIT 1 +#define CONFIG_FIT_VERBOSE 1 + +#define CONFIG_MMC +#define CONFIG_FSL_ESDHC +#define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC83xx_ESDHC_ADDR +#define CONFIG_SYS_FSL_ERRATUM_ESDHC111 + +#define CONFIG_CMD_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_DOS_PARTITION +#define CONFIG_CMD_EXT2 + +#define CONFIG_CMD_MEMTEST +#define CONFIG_SYS_ALT_MEMTEST + +#define CONFIG_CMD_FPGAD +#define CONFIG_CMD_IOLOOP + +/* + * System Clock Setup + */ +#define CONFIG_83XX_CLKIN 33333333 /* in Hz */ +#define CONFIG_SYS_CLK_FREQ CONFIG_83XX_CLKIN + +/* + * Hardware Reset Configuration Word + * if CLKIN is 66.66MHz, then + * CSB = 133MHz, DDRC = 266MHz, LBC = 133MHz + * We choose the A type silicon as default, so the core is 400Mhz. + */ +#define CONFIG_SYS_HRCW_LOW (\ + HRCWL_LCL_BUS_TO_SCB_CLK_1X1 |\ + HRCWL_DDR_TO_SCB_CLK_2X1 |\ + HRCWL_SVCOD_DIV_2 |\ + HRCWL_CSB_TO_CLKIN_4X1 |\ + HRCWL_CORE_TO_CSB_3X1) +/* + * There are neither HRCWH_PCI_HOST nor HRCWH_PCI1_ARBITER_ENABLE bits + * in 8308's HRCWH according to the manual, but original Freescale's + * code has them and I've expirienced some problems using the board + * with BDI3000 attached when I've tried to set these bits to zero + * (UART doesn't work after the 'reset run' command). + */ +#define CONFIG_SYS_HRCW_HIGH (\ + HRCWH_PCI_HOST |\ + HRCWH_PCI1_ARBITER_ENABLE |\ + HRCWH_CORE_ENABLE |\ + HRCWH_FROM_0XFFF00100 |\ + HRCWH_BOOTSEQ_DISABLE |\ + HRCWH_SW_WATCHDOG_DISABLE |\ + HRCWH_ROM_LOC_LOCAL_16BIT |\ + HRCWH_RL_EXT_LEGACY |\ + HRCWH_TSEC1M_IN_MII |\ + HRCWH_TSEC2M_IN_RGMII |\ + HRCWH_BIG_ENDIAN) + +/* + * System IO Config + */ +#define CONFIG_SYS_SICRH (\ + SICRH_ESDHC_A_SD |\ + SICRH_ESDHC_B_SD |\ + SICRH_ESDHC_C_SD |\ + SICRH_GPIO_A_GPIO |\ + SICRH_GPIO_B_GPIO |\ + SICRH_IEEE1588_A_GPIO |\ + SICRH_USB |\ + SICRH_GTM_GPIO |\ + SICRH_IEEE1588_B_GPIO |\ + SICRH_ETSEC2_GPIO |\ + SICRH_GPIOSEL_1 |\ + SICRH_TMROBI_V3P3 |\ + SICRH_TSOBI1_V2P5 |\ + SICRH_TSOBI2_V2P5) /* 0x0037f103 */ +#define CONFIG_SYS_SICRL (\ + SICRL_SPI_PF0 |\ + SICRL_UART_PF0 |\ + SICRL_IRQ_PF0 |\ + SICRL_I2C2_PF0 |\ + SICRL_ETSEC1_TX_CLK) /* 0x00000000 */ + +/* + * IMMR new address + */ +#define CONFIG_SYS_IMMR 0xE0000000 + +/* + * SERDES + */ +#define CONFIG_FSL_SERDES +#define CONFIG_FSL_SERDES1 0xe3000 + +/* + * Arbiter Setup + */ +#define CONFIG_SYS_ACR_PIPE_DEP 3 /* Arbiter pipeline depth is 4 */ +#define CONFIG_SYS_ACR_RPTCNT 3 /* Arbiter repeat count is 4 */ +#define CONFIG_SYS_SPCR_TSECEP 3 /* eTSEC emergency priority is highest */ + +/* + * DDR Setup + */ +#define CONFIG_SYS_DDR_BASE 0x00000000 /* DDR is system memory */ +#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_BASE +#define CONFIG_SYS_DDR_SDRAM_BASE CONFIG_SYS_DDR_BASE +#define CONFIG_SYS_DDR_SDRAM_CLK_CNTL DDR_SDRAM_CLK_CNTL_CLK_ADJUST_05 +#define CONFIG_SYS_DDRCDR_VALUE (DDRCDR_EN \ + | DDRCDR_PZ_LOZ \ + | DDRCDR_NZ_LOZ \ + | DDRCDR_ODT \ + | DDRCDR_Q_DRN) + /* 0x7b880001 */ +/* + * Manually set up DDR parameters + * consist of one chip NT5TU64M16HG from NANYA + */ + +#define CONFIG_SYS_DDR_SIZE 128 /* MB */ + +#define CONFIG_SYS_DDR_CS0_BNDS 0x00000007 +#define CONFIG_SYS_DDR_CS0_CONFIG (CSCONFIG_EN \ + | CSCONFIG_ODT_RD_NEVER \ + | CSCONFIG_ODT_WR_ONLY_CURRENT \ + | CSCONFIG_BANK_BIT_3 \ + | CSCONFIG_ROW_BIT_13 | CSCONFIG_COL_BIT_10) + /* 0x80010102 */ +#define CONFIG_SYS_DDR_TIMING_3 0 +#define CONFIG_SYS_DDR_TIMING_0 ((0 << TIMING_CFG0_RWT_SHIFT) \ + | (0 << TIMING_CFG0_WRT_SHIFT) \ + | (0 << TIMING_CFG0_RRT_SHIFT) \ + | (0 << TIMING_CFG0_WWT_SHIFT) \ + | (2 << TIMING_CFG0_ACT_PD_EXIT_SHIFT) \ + | (6 << TIMING_CFG0_PRE_PD_EXIT_SHIFT) \ + | (8 << TIMING_CFG0_ODT_PD_EXIT_SHIFT) \ + | (2 << TIMING_CFG0_MRS_CYC_SHIFT)) + /* 0x00260802 */ +#define CONFIG_SYS_DDR_TIMING_1 ((2 << TIMING_CFG1_PRETOACT_SHIFT) \ + | (6 << TIMING_CFG1_ACTTOPRE_SHIFT) \ + | (2 << TIMING_CFG1_ACTTORW_SHIFT) \ + | (7 << TIMING_CFG1_CASLAT_SHIFT) \ + | (9 << TIMING_CFG1_REFREC_SHIFT) \ + | (2 << TIMING_CFG1_WRREC_SHIFT) \ + | (2 << TIMING_CFG1_ACTTOACT_SHIFT) \ + | (2 << TIMING_CFG1_WRTORD_SHIFT)) + /* 0x26279222 */ +#define CONFIG_SYS_DDR_TIMING_2 ((0 << TIMING_CFG2_ADD_LAT_SHIFT) \ + | (4 << TIMING_CFG2_CPO_SHIFT) \ + | (3 << TIMING_CFG2_WR_LAT_DELAY_SHIFT) \ + | (2 << TIMING_CFG2_RD_TO_PRE_SHIFT) \ + | (2 << TIMING_CFG2_WR_DATA_DELAY_SHIFT) \ + | (3 << TIMING_CFG2_CKE_PLS_SHIFT) \ + | (5 << TIMING_CFG2_FOUR_ACT_SHIFT)) + /* 0x021848c5 */ +#define CONFIG_SYS_DDR_INTERVAL ((0x0824 << SDRAM_INTERVAL_REFINT_SHIFT) \ + | (0x0100 << SDRAM_INTERVAL_BSTOPRE_SHIFT)) + /* 0x08240100 */ +#define CONFIG_SYS_DDR_SDRAM_CFG (SDRAM_CFG_SREN \ + | SDRAM_CFG_SDRAM_TYPE_DDR2 \ + | SDRAM_CFG_DBW_16) + /* 0x43100000 */ + +#define CONFIG_SYS_DDR_SDRAM_CFG2 0x00401000 /* 1 posted refresh */ +#define CONFIG_SYS_DDR_MODE ((0x0440 << SDRAM_MODE_ESD_SHIFT) \ + | (0x0242 << SDRAM_MODE_SD_SHIFT)) + /* ODT 150ohm CL=4, AL=0 on SDRAM */ +#define CONFIG_SYS_DDR_MODE2 0x00000000 + +/* + * Memory test + */ +#define CONFIG_SYS_MEMTEST_START 0x00001000 /* memtest region */ +#define CONFIG_SYS_MEMTEST_END 0x07f00000 + +/* + * The reserved memory + */ +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */ + +#define CONFIG_SYS_MONITOR_LEN (384 * 1024) /* Reserve 384 kB for Mon */ +#define CONFIG_SYS_MALLOC_LEN (512 * 1024) /* Reserved for malloc */ + +/* + * Initial RAM Base Address Setup + */ +#define CONFIG_SYS_INIT_RAM_LOCK 1 +#define CONFIG_SYS_INIT_RAM_ADDR 0xE6000000 /* Initial RAM address */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM */ +#define CONFIG_SYS_GBL_DATA_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) + +/* + * Local Bus Configuration & Clock Setup + */ +#define CONFIG_SYS_LCRR_DBYP LCRR_DBYP +#define CONFIG_SYS_LCRR_CLKDIV LCRR_CLKDIV_2 +#define CONFIG_SYS_LBC_LBCR 0x00040000 + +/* + * FLASH on the Local Bus + */ +#if 1 +#define CONFIG_SYS_FLASH_CFI /* use the Common Flash Interface */ +#define CONFIG_FLASH_CFI_DRIVER /* use the CFI driver */ +#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT +#define CONFIG_FLASH_CFI_LEGACY +#define CONFIG_SYS_FLASH_LEGACY_512Kx16 +#else +#define CONFIG_SYS_NO_FLASH +#endif + +#define CONFIG_SYS_FLASH_BASE 0xFE000000 /* FLASH base address */ +#define CONFIG_SYS_FLASH_SIZE 8 /* FLASH size is up to 8M */ +#define CONFIG_SYS_FLASH_PROTECTION 1 /* Use h/w Flash protection. */ + +/* Window base at flash base */ +#define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_8MB) + +#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE \ + | BR_PS_16 /* 16 bit port */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) \ + | OR_UPM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_ACS_DIV2 \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET) + +#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ +#define CONFIG_SYS_MAX_FLASH_SECT 135 + +#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ +#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ + +/* + * FPGA + */ +#define CONFIG_SYS_FPGA0_BASE 0xE0600000 +#define CONFIG_SYS_FPGA0_SIZE 1 /* FPGA size is 1M */ + +/* Window base at FPGA base */ +#define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_FPGA0_BASE +#define CONFIG_SYS_LBLAWAR1_PRELIM (LBLAWAR_EN | LBLAWAR_1MB) + +#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_FPGA0_BASE \ + | BR_PS_16 /* 16 bit port */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR1_PRELIM (MEG_TO_AM(CONFIG_SYS_FPGA0_SIZE) \ + | OR_UPM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_ACS_DIV2 \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET) + +#define CONFIG_SYS_FPGA_BASE(k) CONFIG_SYS_FPGA0_BASE +#define CONFIG_SYS_FPGA_DONE(k) 0x0010 + +#define CONFIG_SYS_FPGA_COUNT 1 + +#define CONFIG_SYS_MCLINK_MAX 3 + +#define CONFIG_SYS_FPGA_PTR \ + { (struct ihs_fpga *)CONFIG_SYS_FPGA0_BASE, NULL, NULL, NULL } + +#define CONFIG_SYS_FPGA_NO_RFL_HI + +/* + * Serial Port + */ +#define CONFIG_CONS_INDEX 2 +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE 1 +#define CONFIG_SYS_NS16550_CLK get_bus_freq(0) + +#define CONFIG_SYS_BAUDRATE_TABLE \ + {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200} + +#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_IMMR + 0x4500) +#define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_IMMR + 0x4600) + +/* Use the HUSH parser */ +#define CONFIG_SYS_HUSH_PARSER + +/* Pass open firmware flat tree */ +#define CONFIG_OF_LIBFDT 1 +#define CONFIG_OF_BOARD_SETUP 1 +#define CONFIG_OF_STDOUT_VIA_ALIAS 1 + +/* I2C */ +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_FSL +#define CONFIG_SYS_FSL_I2C_SPEED 400000 +#define CONFIG_SYS_FSL_I2C_SLAVE 0x7F +#define CONFIG_SYS_FSL_I2C_OFFSET 0x3000 + +#define CONFIG_PCA953X /* NXP PCA9554 */ +#define CONFIG_PCA9698 /* NXP PCA9698 */ + +#define CONFIG_SYS_I2C_IHS +#define CONFIG_SYS_I2C_IHS_CH0 +#define CONFIG_SYS_I2C_IHS_SPEED_0 50000 +#define CONFIG_SYS_I2C_IHS_SLAVE_0 0x7F +#define CONFIG_SYS_I2C_IHS_CH1 +#define CONFIG_SYS_I2C_IHS_SPEED_1 50000 +#define CONFIG_SYS_I2C_IHS_SLAVE_1 0x7F +#define CONFIG_SYS_I2C_IHS_CH2 +#define CONFIG_SYS_I2C_IHS_SPEED_2 50000 +#define CONFIG_SYS_I2C_IHS_SLAVE_2 0x7F +#define CONFIG_SYS_I2C_IHS_CH3 +#define CONFIG_SYS_I2C_IHS_SPEED_3 50000 +#define CONFIG_SYS_I2C_IHS_SLAVE_3 0x7F + +/* + * Software (bit-bang) I2C driver configuration + */ +#define CONFIG_SYS_I2C_SOFT +#define CONFIG_SOFT_I2C_READ_REPEATED_START +#define CONFIG_SYS_I2C_SOFT_SPEED 50000 +#define CONFIG_SYS_I2C_SOFT_SLAVE 0x7F +#define I2C_SOFT_DECLARATIONS2 +#define CONFIG_SYS_I2C_SOFT_SPEED_2 50000 +#define CONFIG_SYS_I2C_SOFT_SLAVE_2 0x7F +#define I2C_SOFT_DECLARATIONS3 +#define CONFIG_SYS_I2C_SOFT_SPEED_3 50000 +#define CONFIG_SYS_I2C_SOFT_SLAVE_3 0x7F +#define I2C_SOFT_DECLARATIONS4 +#define CONFIG_SYS_I2C_SOFT_SPEED_4 50000 +#define CONFIG_SYS_I2C_SOFT_SLAVE_4 0x7F +#ifdef CONFIG_STRIDER_CON +#define I2C_SOFT_DECLARATIONS5 +#define CONFIG_SYS_I2C_SOFT_SPEED_5 50000 +#define CONFIG_SYS_I2C_SOFT_SLAVE_5 0x7F +#define I2C_SOFT_DECLARATIONS6 +#define CONFIG_SYS_I2C_SOFT_SPEED_6 50000 +#define CONFIG_SYS_I2C_SOFT_SLAVE_6 0x7F +#define I2C_SOFT_DECLARATIONS7 +#define CONFIG_SYS_I2C_SOFT_SPEED_7 50000 +#define CONFIG_SYS_I2C_SOFT_SLAVE_7 0x7F +#define I2C_SOFT_DECLARATIONS8 +#define CONFIG_SYS_I2C_SOFT_SPEED_8 50000 +#define CONFIG_SYS_I2C_SOFT_SLAVE_8 0x7F +#endif + +#ifdef CONFIG_STRIDER_CON +#define CONFIG_SYS_ICS8N3QV01_I2C {5, 6, 7, 8} +#define CONFIG_SYS_CH7301_I2C {5, 6, 7, 8} +#define CONFIG_SYS_ADV7611_I2C {5, 6, 7, 8} +#define CONFIG_SYS_DP501_I2C {1, 2, 3, 4} +#define CONFIG_STRIDER_FANS { {10, 0x4c}, {11, 0x4c}, \ + {12, 0x4c} } +#else +#define CONFIG_SYS_CH7301_I2C {1, 2, 3, 4} +#define CONFIG_SYS_ADV7611_I2C {1, 2, 3, 4} +#define CONFIG_SYS_DP501_I2C {1, 2, 3, 4} +#define CONFIG_STRIDER_FANS { {2, 0x18}, {3, 0x18}, \ + {4, 0x18} } +#endif + +#ifndef __ASSEMBLY__ +void fpga_gpio_set(unsigned int bus, int pin); +void fpga_gpio_clear(unsigned int bus, int pin); +int fpga_gpio_get(unsigned int bus, int pin); +#endif + +#ifdef CONFIG_STRIDER_CON +#define I2C_SDA_GPIO ((I2C_ADAP_HWNR > 3) ? 0x0200 : 0x0040) +#define I2C_SCL_GPIO ((I2C_ADAP_HWNR > 3) ? 0x0100 : 0x0020) +#define I2C_FPGA_IDX ((I2C_ADAP_HWNR > 3) ? \ + (I2C_ADAP_HWNR - 4) : I2C_ADAP_HWNR) +#else +#define I2C_SDA_GPIO 0x0040 +#define I2C_SCL_GPIO 0x0020 +#define I2C_FPGA_IDX I2C_ADAP_HWNR +#endif +#define I2C_ACTIVE { } +#define I2C_TRISTATE { } +#define I2C_READ \ + (fpga_gpio_get(I2C_FPGA_IDX, I2C_SDA_GPIO) ? 1 : 0) +#define I2C_SDA(bit) \ + do { \ + if (bit) \ + fpga_gpio_set(I2C_FPGA_IDX, I2C_SDA_GPIO); \ + else \ + fpga_gpio_clear(I2C_FPGA_IDX, I2C_SDA_GPIO); \ + } while (0) +#define I2C_SCL(bit) \ + do { \ + if (bit) \ + fpga_gpio_set(I2C_FPGA_IDX, I2C_SCL_GPIO); \ + else \ + fpga_gpio_clear(I2C_FPGA_IDX, I2C_SCL_GPIO); \ + } while (0) +#define I2C_DELAY udelay(25) /* 1/4 I2C clock duration */ + +/* + * Software (bit-bang) MII driver configuration + */ +#define CONFIG_BITBANGMII /* bit-bang MII PHY management */ +#define CONFIG_BITBANGMII_MULTI + +/* + * OSD Setup + */ +#define CONFIG_SYS_OSD_SCREENS 1 +#define CONFIG_SYS_DP501_DIFFERENTIAL +#define CONFIG_SYS_DP501_VCAPCTRL0 0x01 /* DDR mode 0, DE for H/VSYNC */ + +/* + * General PCI + * Addresses are mapped 1-1. + */ +#define CONFIG_SYS_PCIE1_BASE 0xA0000000 +#define CONFIG_SYS_PCIE1_MEM_BASE 0xA0000000 +#define CONFIG_SYS_PCIE1_MEM_PHYS 0xA0000000 +#define CONFIG_SYS_PCIE1_MEM_SIZE 0x10000000 +#define CONFIG_SYS_PCIE1_CFG_BASE 0xB0000000 +#define CONFIG_SYS_PCIE1_CFG_SIZE 0x01000000 +#define CONFIG_SYS_PCIE1_IO_BASE 0x00000000 +#define CONFIG_SYS_PCIE1_IO_PHYS 0xB1000000 +#define CONFIG_SYS_PCIE1_IO_SIZE 0x00800000 + +/* enable PCIE clock */ +#define CONFIG_SYS_SCCR_PCIEXP1CM 1 + +#define CONFIG_PCI +#define CONFIG_PCI_INDIRECT_BRIDGE +#define CONFIG_PCIE + +#define CONFIG_PCI_PNP /* do pci plug-and-play */ + +#define CONFIG_SYS_PCI_SUBSYS_VENDORID 0x1957 /* Freescale */ +#define CONFIG_83XX_GENERIC_PCIE_REGISTER_HOSES 1 + +/* + * TSEC + */ +#define CONFIG_TSEC_ENET /* TSEC ethernet support */ +#define CONFIG_SYS_TSEC1_OFFSET 0x24000 +#define CONFIG_SYS_TSEC1 (CONFIG_SYS_IMMR+CONFIG_SYS_TSEC1_OFFSET) + +/* + * TSEC ethernet configuration + */ +#define CONFIG_MII 1 /* MII PHY management */ +#define CONFIG_TSEC1 +#define CONFIG_TSEC1_NAME "eTSEC0" +#define TSEC1_PHY_ADDR 1 +#define TSEC1_PHYIDX 0 +#define TSEC1_FLAGS 0 + +/* Options are: eTSEC[0-1] */ +#define CONFIG_ETHPRIME "eTSEC0" + +/* + * Environment + */ +#if 1 +#define CONFIG_ENV_IS_IN_FLASH 1 +#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + \ + CONFIG_SYS_MONITOR_LEN) +#define CONFIG_ENV_SECT_SIZE 0x10000 /* 64K(one sector) for env */ +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE +#else +#define CONFIG_ENV_IS_NOWHERE +#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ +#endif + +#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ +#define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ + +/* + * Command line configuration. + */ +#define CONFIG_CMD_I2C +#define CONFIG_CMD_MII +#define CONFIG_CMD_PCI +#define CONFIG_CMD_PING + +#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ +#define CONFIG_AUTO_COMPLETE /* add autocompletion support */ + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ +#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1ms ticks */ + +#undef CONFIG_ZERO_BOOTDELAY_CHECK /* ignore keypress on bootdelay==0 */ + +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ + +#define CONFIG_SYS_CONSOLE_INFO_QUIET + +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +/* + * For booting Linux, the board info and command line data + * have to be in the first 256 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization. + */ +#define CONFIG_SYS_BOOTMAPSZ (256 << 20) /* Initial Memory map for Linux */ + +/* + * Core HID Setup + */ +#define CONFIG_SYS_HID0_INIT 0x000000000 +#define CONFIG_SYS_HID0_FINAL (HID0_ENABLE_MACHINE_CHECK | \ + HID0_ENABLE_INSTRUCTION_CACHE | \ + HID0_ENABLE_DYNAMIC_POWER_MANAGMENT) +#define CONFIG_SYS_HID2 HID2_HBE + +/* + * MMU Setup + */ + +/* DDR: cache cacheable */ +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_RW | \ + BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE | BATU_BL_128M | \ + BATU_VS | BATU_VP) +#define CONFIG_SYS_DBAT0L CONFIG_SYS_IBAT0L +#define CONFIG_SYS_DBAT0U CONFIG_SYS_IBAT0U + +/* IMMRBAR, PCI IO and FPGA: cache-inhibit and guarded */ +#define CONFIG_SYS_IBAT1L (CONFIG_SYS_IMMR | BATL_PP_RW | \ + BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT1U (CONFIG_SYS_IMMR | BATU_BL_8M | BATU_VS | \ + BATU_VP) +#define CONFIG_SYS_DBAT1L CONFIG_SYS_IBAT1L +#define CONFIG_SYS_DBAT1U CONFIG_SYS_IBAT1U + +/* FLASH: icache cacheable, but dcache-inhibit and guarded */ +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_FLASH_BASE | BATL_PP_RW | \ + BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT2U (CONFIG_SYS_FLASH_BASE | BATU_BL_8M | \ + BATU_VS | BATU_VP) +#define CONFIG_SYS_DBAT2L (CONFIG_SYS_FLASH_BASE | BATL_PP_RW | \ + BATL_CACHEINHIBIT | \ + BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_DBAT2U CONFIG_SYS_IBAT2U + +/* Stack in dcache: cacheable, no memory coherence */ +#define CONFIG_SYS_IBAT3L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_RW) +#define CONFIG_SYS_IBAT3U (CONFIG_SYS_INIT_RAM_ADDR | BATU_BL_128K | \ + BATU_VS | BATU_VP) +#define CONFIG_SYS_DBAT3L CONFIG_SYS_IBAT3L +#define CONFIG_SYS_DBAT3U CONFIG_SYS_IBAT3U + +/* + * Environment Configuration + */ + +#define CONFIG_ENV_OVERWRITE + +#if defined(CONFIG_TSEC_ENET) +#define CONFIG_HAS_ETH0 +#endif + +#define CONFIG_BAUDRATE 115200 + +#define CONFIG_LOADADDR 800000 /* default location for tftp and bootm */ + +#define CONFIG_BOOTDELAY 5 /* -1 disables auto-boot */ + +#define CONFIG_HOSTNAME hrcon +#define CONFIG_ROOTPATH "/opt/nfsroot" +#define CONFIG_BOOTFILE "uImage" + +#define CONFIG_PREBOOT /* enable preboot variable */ + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "netdev=eth0\0" \ + "consoledev=ttyS1\0" \ + "u-boot=u-boot.bin\0" \ + "kernel_addr=1000000\0" \ + "fdt_addr=C00000\0" \ + "fdtfile=hrcon.dtb\0" \ + "load=tftp ${loadaddr} ${u-boot}\0" \ + "update=protect off " __stringify(CONFIG_SYS_MONITOR_BASE) \ + " +${filesize};era " __stringify(CONFIG_SYS_MONITOR_BASE)\ + " +${filesize};cp.b ${fileaddr} " \ + __stringify(CONFIG_SYS_MONITOR_BASE) " ${filesize}\0" \ + "upd=run load update\0" \ + +#define CONFIG_NFSBOOTCOMMAND \ + "setenv bootargs root=/dev/nfs rw " \ + "nfsroot=$serverip:$rootpath " \ + "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "tftp ${kernel_addr} $bootfile;" \ + "tftp ${fdt_addr} $fdtfile;" \ + "bootm ${kernel_addr} - ${fdt_addr}" + +#define CONFIG_MMCBOOTCOMMAND \ + "setenv bootargs root=/dev/mmcblk0p3 rw rootwait " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "ext2load mmc 0:2 ${kernel_addr} $bootfile;" \ + "ext2load mmc 0:2 ${fdt_addr} $fdtfile;" \ + "bootm ${kernel_addr} - ${fdt_addr}" + +#define CONFIG_BOOTCOMMAND CONFIG_MMCBOOTCOMMAND + + +#endif /* __CONFIG_H */ diff --git a/include/gdsys_fpga.h b/include/gdsys_fpga.h index f8d8322..69d248f 100644 --- a/include/gdsys_fpga.h +++ b/include/gdsys_fpga.h @@ -197,6 +197,69 @@ struct ihs_fpga { }; #endif
+#ifdef CONFIG_STRIDER_CPU +struct ihs_fpga { + u16 reflection_low; /* 0x0000 */ + u16 versions; /* 0x0002 */ + u16 fpga_version; /* 0x0004 */ + u16 fpga_features; /* 0x0006 */ + u16 reserved_0[1]; /* 0x0008 */ + u16 top_interrupt; /* 0x000a */ + u16 reserved_1[3]; /* 0x000c */ + u16 extended_control; /* 0x0012 */ + struct ihs_gpio gpio; /* 0x0014 */ + u16 mpc3w_control; /* 0x001a */ + u16 reserved_2[2]; /* 0x001c */ + struct ihs_io_ep ep; /* 0x0020 */ + u16 reserved_3[9]; /* 0x002e */ + u16 mc_int; /* 0x0040 */ + u16 mc_int_en; /* 0x0042 */ + u16 mc_status; /* 0x0044 */ + u16 mc_control; /* 0x0046 */ + u16 mc_tx_data; /* 0x0048 */ + u16 mc_tx_address; /* 0x004a */ + u16 mc_tx_cmd; /* 0x004c */ + u16 mc_res; /* 0x004e */ + u16 mc_rx_cmd_status; /* 0x0050 */ + u16 mc_rx_data; /* 0x0052 */ + u16 reserved_4[62]; /* 0x0054 */ + struct ihs_i2c i2c0; /* 0x00d0 */ +}; +#endif + +#ifdef CONFIG_STRIDER_CON +struct ihs_fpga { + u16 reflection_low; /* 0x0000 */ + u16 versions; /* 0x0002 */ + u16 fpga_version; /* 0x0004 */ + u16 fpga_features; /* 0x0006 */ + u16 reserved_0[1]; /* 0x0008 */ + u16 top_interrupt; /* 0x000a */ + u16 reserved_1[4]; /* 0x000c */ + struct ihs_gpio gpio; /* 0x0014 */ + u16 mpc3w_control; /* 0x001a */ + u16 reserved_2[2]; /* 0x001c */ + struct ihs_io_ep ep; /* 0x0020 */ + u16 reserved_3[9]; /* 0x002e */ + struct ihs_i2c i2c0; /* 0x0040 */ + u16 reserved_4[10]; /* 0x004c */ + u16 mc_int; /* 0x0060 */ + u16 mc_int_en; /* 0x0062 */ + u16 mc_status; /* 0x0064 */ + u16 mc_control; /* 0x0066 */ + u16 mc_tx_data; /* 0x0068 */ + u16 mc_tx_address; /* 0x006a */ + u16 mc_tx_cmd; /* 0x006c */ + u16 mc_res; /* 0x006e */ + u16 mc_rx_cmd_status; /* 0x0070 */ + u16 mc_rx_data; /* 0x0072 */ + u16 reserved_5[70]; /* 0x0074 */ + struct ihs_osd osd; /* 0x0100 */ + u16 reserved_6[889]; /* 0x010e */ + u16 videomem[31736]; /* 0x0800 */ +}; +#endif + #ifdef CONFIG_DLVISION_10G struct ihs_fpga { u16 reflection_low; /* 0x0000 */
The strider platform moved some generic code into ioep-fpga.c. Make use of that on hrcon platform.
board/gdsys/common/Makefile | 2 +- board/gdsys/common/ioep-fpga.c | 5 + board/gdsys/mpc8308/hrcon.c | 241 +---------------------------------------- 3 files changed, 9 insertions(+), 239 deletions(-)
diff --git a/board/gdsys/common/Makefile b/board/gdsys/common/Makefile index ba48e8b..0aa1849 100644 --- a/board/gdsys/common/Makefile +++ b/board/gdsys/common/Makefile @@ -12,6 +12,6 @@ obj-$(CONFIG_IO64) += miiphybb.o obj-$(CONFIG_IOCON) += osd.o mclink.o dp501.o phy.o ch7301.o obj-$(CONFIG_DLVISION_10G) += osd.o dp501.o obj-$(CONFIG_CONTROLCENTERD) += dp501.o -obj-$(CONFIG_HRCON) += osd.o mclink.o dp501.o phy.o +obj-$(CONFIG_HRCON) += osd.o mclink.o dp501.o phy.o ioep-fpga.o obj-$(CONFIG_STRIDER) += mclink.o dp501.o phy.o ioep-fpga.o adv7611.o ch7301.o obj-$(CONFIG_STRIDER_CON) += osd.o diff --git a/board/gdsys/common/ioep-fpga.c b/board/gdsys/common/ioep-fpga.c index 18d37dc..96f02d6 100644 --- a/board/gdsys/common/ioep-fpga.c +++ b/board/gdsys/common/ioep-fpga.c @@ -43,6 +43,7 @@ enum { enum { RAM_DDR2_32 = 0, RAM_DDR3_32 = 1, + RAM_DDR3_48 = 2, };
enum { @@ -215,6 +216,10 @@ void ioep_fpga_print_info(unsigned int fpga) printf(", RAM 32 bit DDR3"); break;
+ case RAM_DDR3_48: + printf(", RAM 48 bit DDR3"); + break; + default: printf(", RAM %d(not supported)", feature_ramconfig); break; diff --git a/board/gdsys/mpc8308/hrcon.c b/board/gdsys/mpc8308/hrcon.c index e4434b3..29c85c8 100644 --- a/board/gdsys/mpc8308/hrcon.c +++ b/board/gdsys/mpc8308/hrcon.c @@ -22,6 +22,7 @@
+#include "../common/ioep-fpga.h" #include "../common/osd.h" #include "../common/mclink.h" #include "../common/phy.h" @@ -36,57 +37,6 @@ DECLARE_GLOBAL_DATA_PTR; #define MAX_MUX_CHANNELS 2
enum { - UNITTYPE_MAIN_SERVER = 0, - UNITTYPE_MAIN_USER = 1, - UNITTYPE_VIDEO_SERVER = 2, - UNITTYPE_VIDEO_USER = 3, -}; - -enum { - UNITTYPEPCB_DVI = 0, - UNITTYPEPCB_DP_165 = 1, - UNITTYPEPCB_DP_300 = 2, - UNITTYPEPCB_HDMI = 3, -}; - -enum { - HWVER_100 = 0, - HWVER_110 = 1, -}; - -enum { - FPGA_HWVER_200 = 0, - FPGA_HWVER_210 = 1, -}; - -enum { - COMPRESSION_NONE = 0, - COMPRESSION_TYPE1_DELTA = 1, - COMPRESSION_TYPE1_TYPE2_DELTA = 3, -}; - -enum { - AUDIO_NONE = 0, - AUDIO_TX = 1, - AUDIO_RX = 2, - AUDIO_RXTX = 3, -}; - -enum { - SYSCLK_147456 = 0, -}; - -enum { - RAM_DDR2_32 = 0, - RAM_DDR3_32 = 1, -}; - -enum { - CARRIER_SPEED_1G = 0, - CARRIER_SPEED_2_5G = 1, -}; - -enum { MCFPGA_DONE = 1 << 0, MCFPGA_INIT_N = 1 << 1, MCFPGA_PROGRAM_N = 1 << 2, @@ -164,191 +114,6 @@ int checkboard(void) return 0; }
-static void print_fpga_info(unsigned int fpga, bool rgmii2_present) -{ - u16 versions; - u16 fpga_version; - u16 fpga_features; - unsigned unit_type; - unsigned unit_type_pcb_video; - unsigned hardware_version; - unsigned feature_compression; - unsigned feature_osd; - unsigned feature_audio; - unsigned feature_sysclock; - unsigned feature_ramconfig; - unsigned feature_carrier_speed; - unsigned feature_carriers; - unsigned feature_video_channels; - - FPGA_GET_REG(fpga, versions, &versions); - FPGA_GET_REG(fpga, fpga_version, &fpga_version); - FPGA_GET_REG(fpga, fpga_features, &fpga_features); - - unit_type = (versions & 0xf000) >> 12; - unit_type_pcb_video = (versions & 0x01c0) >> 6; - feature_compression = (fpga_features & 0xe000) >> 13; - feature_osd = fpga_features & (1<<11); - feature_audio = (fpga_features & 0x0600) >> 9; - feature_sysclock = (fpga_features & 0x0180) >> 7; - feature_ramconfig = (fpga_features & 0x0060) >> 5; - feature_carrier_speed = fpga_features & (1<<4); - feature_carriers = (fpga_features & 0x000c) >> 2; - feature_video_channels = fpga_features & 0x0003; - - switch (unit_type) { - case UNITTYPE_MAIN_USER: - printf("Mainchannel"); - break; - - case UNITTYPE_VIDEO_USER: - printf("Videochannel"); - break; - - default: - printf("UnitType %d(not supported)", unit_type); - break; - } - - if (unit_type == UNITTYPE_MAIN_USER) { - hardware_version = - (!!pca9698_get_value(0x20, 24) << 0) - | (!!pca9698_get_value(0x20, 25) << 1) - | (!!pca9698_get_value(0x20, 26) << 2) - | (!!pca9698_get_value(0x20, 27) << 3) - | (!!pca9698_get_value(0x20, 28) << 4); - switch (hardware_version) { - case HWVER_100: - printf(" HW-Ver 1.00,"); - break; - - case HWVER_110: - printf(" HW-Ver 1.10,"); - break; - - default: - printf(" HW-Ver %d(not supported),", - hardware_version); - break; - } - if (rgmii2_present) - printf(" RGMII2,"); - } - - if (unit_type == UNITTYPE_VIDEO_USER) { - hardware_version = versions & 0x000f; - switch (hardware_version) { - case FPGA_HWVER_200: - printf(" HW-Ver 2.00,"); - break; - - case FPGA_HWVER_210: - printf(" HW-Ver 2.10,"); - break; - - default: - printf(" HW-Ver %d(not supported),", - hardware_version); - break; - } - } - - switch (unit_type_pcb_video) { - case UNITTYPEPCB_DVI: - printf(" DVI,"); - break; - - case UNITTYPEPCB_DP_165: - printf(" DP 165MPix/s,"); - break; - - case UNITTYPEPCB_DP_300: - printf(" DP 300MPix/s,"); - break; - - case UNITTYPEPCB_HDMI: - printf(" HDMI,"); - break; - } - - printf(" FPGA V %d.%02d\n features:", - fpga_version / 100, fpga_version % 100); - - - switch (feature_compression) { - case COMPRESSION_NONE: - printf(" no compression"); - break; - - case COMPRESSION_TYPE1_DELTA: - printf(" type1-deltacompression"); - break; - - case COMPRESSION_TYPE1_TYPE2_DELTA: - printf(" type1-deltacompression, type2-inlinecompression"); - break; - - default: - printf(" compression %d(not supported)", feature_compression); - break; - } - - printf(", %sosd", feature_osd ? "" : "no "); - - switch (feature_audio) { - case AUDIO_NONE: - printf(", no audio"); - break; - - case AUDIO_TX: - printf(", audio tx"); - break; - - case AUDIO_RX: - printf(", audio rx"); - break; - - case AUDIO_RXTX: - printf(", audio rx+tx"); - break; - - default: - printf(", audio %d(not supported)", feature_audio); - break; - } - - puts(",\n "); - - switch (feature_sysclock) { - case SYSCLK_147456: - printf("clock 147.456 MHz"); - break; - - default: - printf("clock %d(not supported)", feature_sysclock); - break; - } - - switch (feature_ramconfig) { - case RAM_DDR2_32: - printf(", RAM 32 bit DDR2"); - break; - - case RAM_DDR3_32: - printf(", RAM 32 bit DDR3"); - break; - - default: - printf(", RAM %d(not supported)", feature_ramconfig); - break; - } - - printf(", %d carrier(s) %s", feature_carriers, - feature_carrier_speed ? "2.5Gbit/s" : "1Gbit/s"); - - printf(", %d video channel(s)\n", feature_video_channels); -} - int last_stage_init(void) { int slaves; @@ -401,7 +166,7 @@ int last_stage_init(void) slaves = mclink_probe(); mclink_fpgacount = 0;
- print_fpga_info(0, ch0_rgmii2_present); + ioep_fpga_print_info(0); osd_probe(0);
if (slaves <= 0) @@ -412,7 +177,7 @@ int last_stage_init(void) for (k = 1; k <= slaves; ++k) { FPGA_GET_REG(k, fpga_features, &fpga_features);
- print_fpga_info(k, false); + ioep_fpga_print_info(k); osd_probe(k); if (hw_type_cat) { miiphy_register(bb_miiphy_buses[k].name,
Signed-off-by: Dirk Eibach dirk.eibach@gdsys.cc
- i2c addresses for the videoboard port expanders were wrong. - the fpga reset signal was not initialized.
Signed-off-by: Dirk Eibach dirk.eibach@gdsys.cc ---
board/gdsys/mpc8308/hrcon.c | 10 ++++++++-- 1 file changed, 8 insertions(+), 2 deletions(-)
diff --git a/board/gdsys/mpc8308/hrcon.c b/board/gdsys/mpc8308/hrcon.c index 29c85c8..5492718 100644 --- a/board/gdsys/mpc8308/hrcon.c +++ b/board/gdsys/mpc8308/hrcon.c @@ -119,7 +119,7 @@ int last_stage_init(void) int slaves; unsigned int k; unsigned int mux_ch; - unsigned char mclink_controllers[] = { 0x24, 0x25, 0x26 }; + unsigned char mclink_controllers[] = { 0x3c, 0x3d, 0x3e }; u16 fpga_features; bool hw_type_cat = pca9698_get_value(0x20, 20); bool ch0_rgmii2_present = false; @@ -131,7 +131,7 @@ int last_stage_init(void)
ch0_rgmii2_present = !pca9698_get_value(0x20, 30);
- /* wait for FPGA done */ + /* wait for FPGA done, then reset FPGA */ for (k = 0; k < ARRAY_SIZE(mclink_controllers); ++k) { unsigned int ctr = 0;
@@ -146,6 +146,12 @@ int last_stage_init(void) break; } } + + pca953x_set_dir(mclink_controllers[k], MCFPGA_RESET_N, 0); + pca953x_set_val(mclink_controllers[k], MCFPGA_RESET_N, 0); + udelay(10); + pca953x_set_val(mclink_controllers[k], MCFPGA_RESET_N, + MCFPGA_RESET_N); }
if (hw_type_cat) {
hrcon DH(dual head) has two video outputs per FPGA.
board/gdsys/common/osd.c | 111 +++++++++++++++++++++++++++++++--------- board/gdsys/mpc8308/MAINTAINERS | 1 + board/gdsys/mpc8308/hrcon.c | 31 +++++++++-- configs/hrcon_dh_defconfig | 5 ++ drivers/i2c/soft_i2c.c | 28 ++++++++++ include/configs/hrcon.h | 56 ++++++++++++++++++++ include/gdsys_fpga.h | 30 +++++++---- 7 files changed, 225 insertions(+), 37 deletions(-) create mode 100644 configs/hrcon_dh_defconfig
diff --git a/board/gdsys/common/osd.c b/board/gdsys/common/osd.c index f11e26f..b288df8 100644 --- a/board/gdsys/common/osd.c +++ b/board/gdsys/common/osd.c @@ -28,12 +28,45 @@
+#ifdef CONFIG_SYS_OSD_DH +#define MAX_OSD_SCREEN 8 +#define OSD_DH_BASE 4 +#else +#define MAX_OSD_SCREEN 4 +#endif + +#ifdef CONFIG_SYS_OSD_DH +#define OSD_SET_REG(screen, fld, val) \ + do { \ + if (screen >= OSD_DH_BASE) \ + FPGA_SET_REG(screen - OSD_DH_BASE, osd1.fld, val); \ + else \ + FPGA_SET_REG(screen, osd0.fld, val); \ + } while (0) +#else +#define OSD_SET_REG(screen, fld, val) \ + FPGA_SET_REG(screen, osd0.fld, val) +#endif + +#ifdef CONFIG_SYS_OSD_DH +#define OSD_GET_REG(screen, fld, val) \ + do { \ + if (screen >= OSD_DH_BASE) \ + FPGA_GET_REG(screen - OSD_DH_BASE, osd1.fld, val); \ + else \ + FPGA_GET_REG(screen, osd0.fld, val); \ + } while (0) +#else +#define OSD_GET_REG(screen, fld, val) \ + FPGA_GET_REG(screen, osd0.fld, val) +#endif + unsigned int base_width; unsigned int base_height; size_t bufsize; u16 *buf;
-unsigned int max_osd_screen = CONFIG_SYS_OSD_SCREENS - 1; +unsigned int osd_screen_mask = 0;
#ifdef CONFIG_SYS_ICS8N3QV01_I2C int ics8n3qv01_i2c[] = CONFIG_SYS_ICS8N3QV01_I2C; @@ -47,6 +80,9 @@ int sil1178_i2c[] = CONFIG_SYS_SIL1178_I2C; int dp501_i2c[] = CONFIG_SYS_DP501_I2C; #endif
+#ifdef CONFIG_SYS_DP501_BASE +int dp501_base[] = CONFIG_SYS_DP501_BASE; +#endif
#ifdef CONFIG_SYS_MPC92469AC static void mpc92469ac_calc_parameters(unsigned int fout, @@ -216,7 +252,15 @@ static int osd_write_videomem(unsigned screen, unsigned offset, for (k = 0; k < charcount; ++k) { if (offset + k >= bufsize) return -1; - FPGA_SET_REG(screen, videomem[offset + k], data[k]); +#ifdef CONFIG_SYS_OSD_DH + if (screen >= OSD_DH_BASE) + FPGA_SET_REG(screen - OSD_DH_BASE, + videomem1[offset + k], data[k]); + else + FPGA_SET_REG(screen, videomem0[offset + k], data[k]); +#else + FPGA_SET_REG(screen, videomem0[offset + k], data[k]); +#endif }
return charcount; @@ -226,7 +270,12 @@ static int osd_print(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { unsigned screen;
- for (screen = 0; screen <= max_osd_screen; ++screen) { + if (argc < 5) { + cmd_usage(cmdtp); + return 1; + } + + for (screen = 0; screen < MAX_OSD_SCREEN; ++screen) { unsigned x; unsigned y; unsigned charcount; @@ -236,10 +285,8 @@ static int osd_print(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) char *text; int res;
- if (argc < 5) { - cmd_usage(cmdtp); - return 1; - } + if (!(osd_screen_mask & (1 << screen))) + continue;
x = simple_strtoul(argv[1], NULL, 16); y = simple_strtoul(argv[2], NULL, 16); @@ -266,9 +313,16 @@ int osd_probe(unsigned screen) int old_bus = i2c_get_bus_num(); bool pixclock_present = false; bool output_driver_present = false; +#ifdef CONFIG_SYS_DP501_I2C +#ifdef CONFIG_SYS_DP501_BASE + uint8_t dp501_addr = dp501_base[screen]; +#else + uint8_t dp501_addr = DP501_I2C_ADDR; +#endif +#endif
- FPGA_GET_REG(0, osd.version, &version); - FPGA_GET_REG(0, osd.features, &features); + OSD_GET_REG(0, version, &version); + OSD_GET_REG(0, features, &features);
base_width = ((features & 0x3f00) >> 8) + 1; base_height = (features & 0x001f) + 1; @@ -277,9 +331,15 @@ int osd_probe(unsigned screen) if (!buf) return -1;
+#ifdef CONFIG_SYS_OSD_DH + printf("OSD%d-%d: Digital-OSD version %01d.%02d, %d" "x%d characters\n", + (screen >= OSD_DH_BASE) ? (screen - OSD_DH_BASE) : screen, + (screen > 3) ? 1 : 0, version/100, version%100, base_width, + base_height); +#else printf("OSD%d: Digital-OSD version %01d.%02d, %d" "x%d characters\n", - screen, version/100, version%100, base_width, base_height); - + screen, version/100, version%100, base_width, base_height); +#endif /* setup pixclock */
#ifdef CONFIG_SYS_MPC92469AC @@ -330,8 +390,8 @@ int osd_probe(unsigned screen)
#ifdef CONFIG_SYS_DP501_I2C i2c_set_bus_num(dp501_i2c[screen]); - if (!i2c_probe(DP501_I2C_ADDR)) { - dp501_powerup(DP501_I2C_ADDR); + if (!i2c_probe(dp501_addr)) { + dp501_powerup(dp501_addr); output_driver_present = true; } #endif @@ -339,14 +399,14 @@ int osd_probe(unsigned screen) if (!output_driver_present) printf(" no output driver found\n");
- FPGA_SET_REG(screen, osd.control, 0x0049); + OSD_SET_REG(screen, control, 0x0049);
- FPGA_SET_REG(screen, osd.xy_size, ((32 - 1) << 8) | (16 - 1)); - FPGA_SET_REG(screen, osd.x_pos, 0x007f); - FPGA_SET_REG(screen, osd.y_pos, 0x005f); + OSD_SET_REG(screen, xy_size, ((32 - 1) << 8) | (16 - 1)); + OSD_SET_REG(screen, x_pos, 0x007f); + OSD_SET_REG(screen, y_pos, 0x005f);
- if (screen > max_osd_screen) - max_osd_screen = screen; + if (pixclock_present && output_driver_present) + osd_screen_mask |= 1 << screen;
@@ -357,7 +417,12 @@ int osd_write(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { unsigned screen;
- for (screen = 0; screen <= max_osd_screen; ++screen) { + if ((argc < 4) || (strlen(argv[3]) % 4)) { + cmd_usage(cmdtp); + return 1; + } + + for (screen = 0; screen < MAX_OSD_SCREEN; ++screen) { unsigned x; unsigned y; unsigned k; @@ -367,10 +432,8 @@ int osd_write(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) unsigned count = (argc > 4) ? simple_strtoul(argv[4], NULL, 16) : 1;
- if ((argc < 4) || (strlen(argv[3]) % 4)) { - cmd_usage(cmdtp); - return 1; - } + if (!(osd_screen_mask & (1 << screen))) + continue;
x = simple_strtoul(argv[1], NULL, 16); y = simple_strtoul(argv[2], NULL, 16); diff --git a/board/gdsys/mpc8308/MAINTAINERS b/board/gdsys/mpc8308/MAINTAINERS index 35704bc..3895b01 100644 --- a/board/gdsys/mpc8308/MAINTAINERS +++ b/board/gdsys/mpc8308/MAINTAINERS @@ -4,6 +4,7 @@ S: Maintained F: board/gdsys/mpc8308/ F: include/configs/hrcon.h F: configs/hrcon_defconfig +F: configs/hrcon_dh_defconfig F: include/configs/strider.h F: configs/strider_cpu_defconfig F: configs/strider_con_defconfig diff --git a/board/gdsys/mpc8308/hrcon.c b/board/gdsys/mpc8308/hrcon.c index 5492718..3cc03cb 100644 --- a/board/gdsys/mpc8308/hrcon.c +++ b/board/gdsys/mpc8308/hrcon.c @@ -128,6 +128,7 @@ int last_stage_init(void)
/* Turn on Parade DP501 */ pca9698_direction_output(0x20, 10, 1); + pca9698_direction_output(0x20, 11, 1);
@@ -174,6 +175,9 @@ int last_stage_init(void)
ioep_fpga_print_info(0); osd_probe(0); +#ifdef CONFIG_SYS_OSD_DH + osd_probe(4); +#endif
if (slaves <= 0) return 0; @@ -185,6 +189,9 @@ int last_stage_init(void)
ioep_fpga_print_info(k); osd_probe(k); +#ifdef CONFIG_SYS_OSD_DH + osd_probe(k + 4); +#endif if (hw_type_cat) { miiphy_register(bb_miiphy_buses[k].name, bb_miiphy_read, bb_miiphy_write); @@ -196,28 +203,44 @@ int last_stage_init(void) }
/* - * provide access to fpga gpios (for I2C bitbang) + * provide access to fpga gpios and controls (for I2C bitbang) * (these may look all too simple but make iocon.h much more readable) */ void fpga_gpio_set(unsigned int bus, int pin) { - FPGA_SET_REG(bus, gpio.set, pin); + FPGA_SET_REG(bus >= 4 ? (bus - 4) : bus, gpio.set, pin); }
void fpga_gpio_clear(unsigned int bus, int pin) { - FPGA_SET_REG(bus, gpio.clear, pin); + FPGA_SET_REG(bus >= 4 ? (bus - 4) : bus, gpio.clear, pin); }
int fpga_gpio_get(unsigned int bus, int pin) { u16 val;
- FPGA_GET_REG(bus, gpio.read, &val); + FPGA_GET_REG(bus >= 4 ? (bus - 4) : bus, gpio.read, &val);
return val & pin; }
+void fpga_control_set(unsigned int bus, int pin) +{ + u16 val; + + FPGA_GET_REG(bus >= 4 ? (bus - 4) : bus, control, &val); + FPGA_SET_REG(bus >= 4 ? (bus - 4) : bus, control, val | pin); +} + +void fpga_control_clear(unsigned int bus, int pin) +{ + u16 val; + + FPGA_GET_REG(bus >= 4 ? (bus - 4) : bus, control, &val); + FPGA_SET_REG(bus >= 4 ? (bus - 4) : bus, control, val & ~pin); +} + void mpc8308_init(void) { pca9698_direction_output(0x20, 4, 1); diff --git a/configs/hrcon_dh_defconfig b/configs/hrcon_dh_defconfig new file mode 100644 index 0000000..a059dd9 --- /dev/null +++ b/configs/hrcon_dh_defconfig @@ -0,0 +1,5 @@ +CONFIG_SYS_EXTRA_OPTIONS="HRCON_DH" + +CONFIG_PPC=y +CONFIG_MPC83xx=y +CONFIG_TARGET_HRCON=y diff --git a/drivers/i2c/soft_i2c.c b/drivers/i2c/soft_i2c.c index db9b402..b000a0e 100644 --- a/drivers/i2c/soft_i2c.c +++ b/drivers/i2c/soft_i2c.c @@ -473,3 +473,31 @@ U_BOOT_I2C_ADAP_COMPLETE(soft3, soft_i2c_init, soft_i2c_probe, CONFIG_SYS_I2C_SOFT_SLAVE_4, 3) #endif +#if defined(I2C_SOFT_DECLARATIONS5) +U_BOOT_I2C_ADAP_COMPLETE(soft4, soft_i2c_init, soft_i2c_probe, + soft_i2c_read, soft_i2c_write, NULL, + CONFIG_SYS_I2C_SOFT_SPEED_5, + CONFIG_SYS_I2C_SOFT_SLAVE_5, + 4) +#endif +#if defined(I2C_SOFT_DECLARATIONS6) +U_BOOT_I2C_ADAP_COMPLETE(soft5, soft_i2c_init, soft_i2c_probe, + soft_i2c_read, soft_i2c_write, NULL, + CONFIG_SYS_I2C_SOFT_SPEED_6, + CONFIG_SYS_I2C_SOFT_SLAVE_6, + 5) +#endif +#if defined(I2C_SOFT_DECLARATIONS7) +U_BOOT_I2C_ADAP_COMPLETE(soft6, soft_i2c_init, soft_i2c_probe, + soft_i2c_read, soft_i2c_write, NULL, + CONFIG_SYS_I2C_SOFT_SPEED_7, + CONFIG_SYS_I2C_SOFT_SLAVE_7, + 6) +#endif +#if defined(I2C_SOFT_DECLARATIONS8) +U_BOOT_I2C_ADAP_COMPLETE(soft7, soft_i2c_init, soft_i2c_probe, + soft_i2c_read, soft_i2c_write, NULL, + CONFIG_SYS_I2C_SOFT_SPEED_8, + CONFIG_SYS_I2C_SOFT_SLAVE_8, + 7) +#endif diff --git a/include/configs/hrcon.h b/include/configs/hrcon.h index f1a69a3..bdc56ef 100644 --- a/include/configs/hrcon.h +++ b/include/configs/hrcon.h @@ -20,7 +20,11 @@
+#ifdef CONFIG_HRCON_DH +#define CONFIG_IDENT_STRING " hrcon dh 0.01" +#else #define CONFIG_IDENT_STRING " hrcon 0.01" +#endif
@@ -344,6 +348,22 @@ #define CONFIG_SYS_I2C_IHS_SPEED_3 50000 #define CONFIG_SYS_I2C_IHS_SLAVE_3 0x7F
+#ifdef CONFIG_HRCON_DH +#define CONFIG_SYS_I2C_IHS_DUAL +#define CONFIG_SYS_I2C_IHS_CH0_1 +#define CONFIG_SYS_I2C_IHS_SPEED_0_1 50000 +#define CONFIG_SYS_I2C_IHS_SLAVE_0_1 0x7F +#define CONFIG_SYS_I2C_IHS_CH1_1 +#define CONFIG_SYS_I2C_IHS_SPEED_1_1 50000 +#define CONFIG_SYS_I2C_IHS_SLAVE_1_1 0x7F +#define CONFIG_SYS_I2C_IHS_CH2_1 +#define CONFIG_SYS_I2C_IHS_SPEED_2_1 50000 +#define CONFIG_SYS_I2C_IHS_SLAVE_2_1 0x7F +#define CONFIG_SYS_I2C_IHS_CH3_1 +#define CONFIG_SYS_I2C_IHS_SPEED_3_1 50000 +#define CONFIG_SYS_I2C_IHS_SLAVE_3_1 0x7F +#endif + /* * Software (bit-bang) I2C driver configuration */ @@ -360,16 +380,48 @@ #define CONFIG_SYS_I2C_SOFT_SPEED_4 50000 #define CONFIG_SYS_I2C_SOFT_SLAVE_4 0x7F
+#ifdef CONFIG_HRCON_DH +#define I2C_SOFT_DECLARATIONS5 +#define CONFIG_SYS_I2C_SOFT_SPEED_5 50000 +#define CONFIG_SYS_I2C_SOFT_SLAVE_5 0x7F +#define I2C_SOFT_DECLARATIONS6 +#define CONFIG_SYS_I2C_SOFT_SPEED_6 50000 +#define CONFIG_SYS_I2C_SOFT_SLAVE_6 0x7F +#define I2C_SOFT_DECLARATIONS7 +#define CONFIG_SYS_I2C_SOFT_SPEED_7 50000 +#define CONFIG_SYS_I2C_SOFT_SLAVE_7 0x7F +#define I2C_SOFT_DECLARATIONS8 +#define CONFIG_SYS_I2C_SOFT_SPEED_8 50000 +#define CONFIG_SYS_I2C_SOFT_SLAVE_8 0x7F +#endif + +#ifdef CONFIG_HRCON_DH +#define CONFIG_SYS_ICS8N3QV01_I2C {9, 10, 11, 12, 13, 14, 15, 16} +#define CONFIG_SYS_DP501_I2C {1, 3, 5, 7, 2, 4, 6, 8} +#else #define CONFIG_SYS_ICS8N3QV01_I2C {5, 6, 7, 8} #define CONFIG_SYS_DP501_I2C {1, 2, 3, 4} +#endif
#ifndef __ASSEMBLY__ void fpga_gpio_set(unsigned int bus, int pin); void fpga_gpio_clear(unsigned int bus, int pin); int fpga_gpio_get(unsigned int bus, int pin); +void fpga_control_set(unsigned int bus, int pin); +void fpga_control_clear(unsigned int bus, int pin); #endif
+#ifdef CONFIG_HRCON_DH +#define I2C_ACTIVE \ + do { \ + if (I2C_ADAP_HWNR > 3) \ + fpga_control_set(I2C_ADAP_HWNR, 0x0004); \ + else \ + fpga_control_clear(I2C_ADAP_HWNR, 0x0004); \ + } while (0) +#else #define I2C_ACTIVE { } +#endif #define I2C_TRISTATE { } #define I2C_READ \ (fpga_gpio_get(I2C_ADAP_HWNR, 0x0040) ? 1 : 0) @@ -402,6 +454,10 @@ int fpga_gpio_get(unsigned int bus, int pin); #define CONFIG_SYS_DP501_DIFFERENTIAL #define CONFIG_SYS_DP501_VCAPCTRL0 0x01 /* DDR mode 0, DE for H/VSYNC */
+#ifdef CONFIG_HRCON_DH +#define CONFIG_SYS_OSD_DH +#endif + /* * General PCI * Addresses are mapped 1-1. diff --git a/include/gdsys_fpga.h b/include/gdsys_fpga.h index 69d248f..3b8762d 100644 --- a/include/gdsys_fpga.h +++ b/include/gdsys_fpga.h @@ -157,9 +157,9 @@ struct ihs_fpga { u16 mc_rx_data; /* 0x0072 */ u16 reserved_5[69]; /* 0x0074 */ u16 reflection_high; /* 0x00fe */ - struct ihs_osd osd; /* 0x0100 */ + struct ihs_osd osd0; /* 0x0100 */ u16 reserved_6[889]; /* 0x010e */ - u16 videomem[31736]; /* 0x0800 */ + u16 videomem0[2048]; /* 0x0800 */ }; #endif
@@ -171,7 +171,9 @@ struct ihs_fpga { u16 fpga_features; /* 0x0006 */ u16 reserved_0[1]; /* 0x0008 */ u16 top_interrupt; /* 0x000a */ - u16 reserved_1[4]; /* 0x000c */ + u16 reserved_1[2]; /* 0x000c */ + u16 control; /* 0x0010 */ + u16 extended_control; /* 0x0012 */ struct ihs_gpio gpio; /* 0x0014 */ u16 mpc3w_control; /* 0x001a */ u16 reserved_2[2]; /* 0x001c */ @@ -191,9 +193,19 @@ struct ihs_fpga { u16 mc_rx_data; /* 0x0072 */ u16 reserved_5[69]; /* 0x0074 */ u16 reflection_high; /* 0x00fe */ - struct ihs_osd osd; /* 0x0100 */ + struct ihs_osd osd0; /* 0x0100 */ +#ifdef CONFIG_SYS_OSD_DH + u16 reserved_6[57]; /* 0x010e */ + struct ihs_osd osd1; /* 0x0180 */ + u16 reserved_7[9]; /* 0x018e */ + struct ihs_i2c i2c1; /* 0x01a0 */ + u16 reserved_8[1834]; /* 0x01ac */ + u16 videomem0[2048]; /* 0x1000 */ + u16 videomem1[2048]; /* 0x2000 */ +#else u16 reserved_6[889]; /* 0x010e */ - u16 videomem[31736]; /* 0x0800 */ + u16 videomem0[2048]; /* 0x0800 */ +#endif }; #endif
@@ -254,9 +266,9 @@ struct ihs_fpga { u16 mc_rx_cmd_status; /* 0x0070 */ u16 mc_rx_data; /* 0x0072 */ u16 reserved_5[70]; /* 0x0074 */ - struct ihs_osd osd; /* 0x0100 */ + struct ihs_osd osd0; /* 0x0100 */ u16 reserved_6[889]; /* 0x010e */ - u16 videomem[31736]; /* 0x0800 */ + u16 videomem0[2048]; /* 0x0800 */ }; #endif
@@ -275,9 +287,9 @@ struct ihs_fpga { u16 reserved_3[2]; /* 0x006c */ struct ihs_i2c i2c1; /* 0x0070 */ u16 reserved_4[194]; /* 0x007c */ - struct ihs_osd osd; /* 0x0200 */ + struct ihs_osd osd0; /* 0x0200 */ u16 reserved_5[761]; /* 0x020e */ - u16 videomem[31736]; /* 0x0800 */ + u16 videomem0[2048]; /* 0x0800 */ }; #endif
board/gdsys/common/Makefile | 3 ++- board/gdsys/common/fanctrl.c | 32 +++++++++++++++++++++++++++++++ board/gdsys/common/fanctrl.h | 13 +++++++++++++ board/gdsys/mpc8308/hrcon.c | 11 +++++++++++ board/gdsys/mpc8308/strider.c | 24 +---------------------- drivers/i2c/soft_i2c.c | 28 +++++++++++++++++++++++++++ include/configs/hrcon.h | 44 +++++++++++++++++++++++++++++++------------ 7 files changed, 119 insertions(+), 36 deletions(-) create mode 100644 board/gdsys/common/fanctrl.c create mode 100644 board/gdsys/common/fanctrl.h
diff --git a/board/gdsys/common/Makefile b/board/gdsys/common/Makefile index 0aa1849..ce23045 100644 --- a/board/gdsys/common/Makefile +++ b/board/gdsys/common/Makefile @@ -12,6 +12,7 @@ obj-$(CONFIG_IO64) += miiphybb.o obj-$(CONFIG_IOCON) += osd.o mclink.o dp501.o phy.o ch7301.o obj-$(CONFIG_DLVISION_10G) += osd.o dp501.o obj-$(CONFIG_CONTROLCENTERD) += dp501.o -obj-$(CONFIG_HRCON) += osd.o mclink.o dp501.o phy.o ioep-fpga.o +obj-$(CONFIG_HRCON) += osd.o mclink.o dp501.o phy.o ioep-fpga.o fanctrl.o obj-$(CONFIG_STRIDER) += mclink.o dp501.o phy.o ioep-fpga.o adv7611.o ch7301.o +obj-$(CONFIG_STRIDER) += fanctrl.o obj-$(CONFIG_STRIDER_CON) += osd.o diff --git a/board/gdsys/common/fanctrl.c b/board/gdsys/common/fanctrl.c new file mode 100644 index 0000000..44569bb --- /dev/null +++ b/board/gdsys/common/fanctrl.c @@ -0,0 +1,32 @@ +/* + * (C) Copyright 2015 + * Dirk Eibach, Guntermann & Drunck GmbH, eibach@gdsys.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <i2c.h> + +enum { + FAN_CONFIG = 0x03, + FAN_TACHLIM_LSB = 0x48, + FAN_TACHLIM_MSB = 0x49, + FAN_PWM_FREQ = 0x4D, +}; + +void init_fan_controller(u8 addr) +{ + int val; + + /* set PWM Frequency to 2.5% resolution */ + i2c_reg_write(addr, FAN_PWM_FREQ, 20); + + /* set Tachometer Limit */ + i2c_reg_write(addr, FAN_TACHLIM_LSB, 0x10); + i2c_reg_write(addr, FAN_TACHLIM_MSB, 0x0a); + + /* enable Tach input */ + val = i2c_reg_read(addr, FAN_CONFIG) | 0x04; + i2c_reg_write(addr, FAN_CONFIG, val); +} diff --git a/board/gdsys/common/fanctrl.h b/board/gdsys/common/fanctrl.h new file mode 100644 index 0000000..12bc850 --- /dev/null +++ b/board/gdsys/common/fanctrl.h @@ -0,0 +1,13 @@ +/* + * (C) Copyright 2015 + * Dirk Eibach, Guntermann & Drunck GmbH, dirk.eibach@gdsys.cc + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _FANCTRL_H_ +#define _FANCTRL_H_ + +void init_fan_controller(u8 addr); + +#endif diff --git a/board/gdsys/mpc8308/hrcon.c b/board/gdsys/mpc8308/hrcon.c index 3cc03cb..880b638 100644 --- a/board/gdsys/mpc8308/hrcon.c +++ b/board/gdsys/mpc8308/hrcon.c @@ -26,6 +26,7 @@ #include "../common/osd.h" #include "../common/mclink.h" #include "../common/phy.h" +#include "../common/fanctrl.h"
#include <pca953x.h> #include <pca9698.h> @@ -52,6 +53,11 @@ enum { unsigned int mclink_fpgacount; struct ihs_fpga *fpga_ptr[] = CONFIG_SYS_FPGA_PTR;
+struct { + u8 bus; + u8 addr; +} hrcon_fans[] = CONFIG_HRCON_FANS; + int fpga_set_reg(u32 fpga, u16 *reg, off_t regoff, u16 data) { int res; @@ -199,6 +205,11 @@ int last_stage_init(void) } }
+ for (k = 0; k < ARRAY_SIZE(hrcon_fans); ++k) { + i2c_set_bus_num(hrcon_fans[k].bus); + init_fan_controller(hrcon_fans[k].addr); + } + return 0; }
diff --git a/board/gdsys/mpc8308/strider.c b/board/gdsys/mpc8308/strider.c index 8e5d5de..ef5b6c0 100644 --- a/board/gdsys/mpc8308/strider.c +++ b/board/gdsys/mpc8308/strider.c @@ -28,6 +28,7 @@ #include "../common/mclink.h" #include "../common/osd.h" #include "../common/phy.h" +#include "../common/fanctrl.h"
#include <pca953x.h> #include <pca9698.h> @@ -51,13 +52,6 @@ enum { GPIO_MDIO = 1 << 15, };
-enum { - FAN_CONFIG = 0x03, - FAN_TACHLIM_LSB = 0x48, - FAN_TACHLIM_MSB = 0x49, - FAN_PWM_FREQ = 0x4D, -}; - unsigned int mclink_fpgacount; struct ihs_fpga *fpga_ptr[] = CONFIG_SYS_FPGA_PTR;
@@ -128,22 +122,6 @@ int checkboard(void) return 0; }
-static void init_fan_controller(u8 addr) -{ - int val; - - /* set PWM Frequency to 2.5% resolution */ - i2c_reg_write(addr, FAN_PWM_FREQ, 20); - - /* set Tachometer Limit */ - i2c_reg_write(addr, FAN_TACHLIM_LSB, 0x10); - i2c_reg_write(addr, FAN_TACHLIM_MSB, 0x0a); - - /* enable Tach input */ - val = i2c_reg_read(addr, FAN_CONFIG) | 0x04; - i2c_reg_write(addr, FAN_CONFIG, val); -} - int last_stage_init(void) { int slaves; diff --git a/drivers/i2c/soft_i2c.c b/drivers/i2c/soft_i2c.c index b000a0e..5ffc974 100644 --- a/drivers/i2c/soft_i2c.c +++ b/drivers/i2c/soft_i2c.c @@ -501,3 +501,31 @@ U_BOOT_I2C_ADAP_COMPLETE(soft7, soft_i2c_init, soft_i2c_probe, CONFIG_SYS_I2C_SOFT_SLAVE_8, 7) #endif +#if defined(I2C_SOFT_DECLARATIONS9) +U_BOOT_I2C_ADAP_COMPLETE(soft8, soft_i2c_init, soft_i2c_probe, + soft_i2c_read, soft_i2c_write, NULL, + CONFIG_SYS_I2C_SOFT_SPEED_9, + CONFIG_SYS_I2C_SOFT_SLAVE_9, + 8) +#endif +#if defined(I2C_SOFT_DECLARATIONS10) +U_BOOT_I2C_ADAP_COMPLETE(soft9, soft_i2c_init, soft_i2c_probe, + soft_i2c_read, soft_i2c_write, NULL, + CONFIG_SYS_I2C_SOFT_SPEED_10, + CONFIG_SYS_I2C_SOFT_SLAVE_10, + 9) +#endif +#if defined(I2C_SOFT_DECLARATIONS11) +U_BOOT_I2C_ADAP_COMPLETE(soft10, soft_i2c_init, soft_i2c_probe, + soft_i2c_read, soft_i2c_write, NULL, + CONFIG_SYS_I2C_SOFT_SPEED_11, + CONFIG_SYS_I2C_SOFT_SLAVE_11, + 10) +#endif +#if defined(I2C_SOFT_DECLARATIONS12) +U_BOOT_I2C_ADAP_COMPLETE(soft11, soft_i2c_init, soft_i2c_probe, + soft_i2c_read, soft_i2c_write, NULL, + CONFIG_SYS_I2C_SOFT_SPEED_12, + CONFIG_SYS_I2C_SOFT_SLAVE_12, + 11) +#endif diff --git a/include/configs/hrcon.h b/include/configs/hrcon.h index bdc56ef..93db49b 100644 --- a/include/configs/hrcon.h +++ b/include/configs/hrcon.h @@ -379,8 +379,6 @@ #define I2C_SOFT_DECLARATIONS4 #define CONFIG_SYS_I2C_SOFT_SPEED_4 50000 #define CONFIG_SYS_I2C_SOFT_SLAVE_4 0x7F - -#ifdef CONFIG_HRCON_DH #define I2C_SOFT_DECLARATIONS5 #define CONFIG_SYS_I2C_SOFT_SPEED_5 50000 #define CONFIG_SYS_I2C_SOFT_SLAVE_5 0x7F @@ -393,14 +391,32 @@ #define I2C_SOFT_DECLARATIONS8 #define CONFIG_SYS_I2C_SOFT_SPEED_8 50000 #define CONFIG_SYS_I2C_SOFT_SLAVE_8 0x7F + +#ifdef CONFIG_HRCON_DH +#define I2C_SOFT_DECLARATIONS9 +#define CONFIG_SYS_I2C_SOFT_SPEED_9 50000 +#define CONFIG_SYS_I2C_SOFT_SLAVE_9 0x7F +#define I2C_SOFT_DECLARATIONS10 +#define CONFIG_SYS_I2C_SOFT_SPEED_10 50000 +#define CONFIG_SYS_I2C_SOFT_SLAVE_10 0x7F +#define I2C_SOFT_DECLARATIONS11 +#define CONFIG_SYS_I2C_SOFT_SPEED_11 50000 +#define CONFIG_SYS_I2C_SOFT_SLAVE_11 0x7F +#define I2C_SOFT_DECLARATIONS12 +#define CONFIG_SYS_I2C_SOFT_SPEED_12 50000 +#define CONFIG_SYS_I2C_SOFT_SLAVE_12 0x7F #endif
#ifdef CONFIG_HRCON_DH -#define CONFIG_SYS_ICS8N3QV01_I2C {9, 10, 11, 12, 13, 14, 15, 16} +#define CONFIG_SYS_ICS8N3QV01_I2C {13, 14, 15, 16, 17, 18, 19, 20} #define CONFIG_SYS_DP501_I2C {1, 3, 5, 7, 2, 4, 6, 8} +#define CONFIG_HRCON_FANS { {10, 0x4c}, {11, 0x4c}, \ + {12, 0x4c} } #else -#define CONFIG_SYS_ICS8N3QV01_I2C {5, 6, 7, 8} +#define CONFIG_SYS_ICS8N3QV01_I2C {9, 10, 11, 12} #define CONFIG_SYS_DP501_I2C {1, 2, 3, 4} +#define CONFIG_HRCON_FANS { {6, 0x4c}, {7, 0x4c}, \ + {8, 0x4c} } #endif
#ifndef __ASSEMBLY__ @@ -411,33 +427,37 @@ void fpga_control_set(unsigned int bus, int pin); void fpga_control_clear(unsigned int bus, int pin); #endif
+#define I2C_SDA_GPIO ((I2C_ADAP_HWNR > 3) ? 0x0040 : 0x0200) +#define I2C_SCL_GPIO ((I2C_ADAP_HWNR > 3) ? 0x0020 : 0x0100) +#define I2C_FPGA_IDX (I2C_ADAP_HWNR % 4) + #ifdef CONFIG_HRCON_DH #define I2C_ACTIVE \ do { \ - if (I2C_ADAP_HWNR > 3) \ - fpga_control_set(I2C_ADAP_HWNR, 0x0004); \ + if (I2C_ADAP_HWNR > 7) \ + fpga_control_set(I2C_FPGA_IDX, 0x0004); \ else \ - fpga_control_clear(I2C_ADAP_HWNR, 0x0004); \ + fpga_control_clear(I2C_FPGA_IDX, 0x0004); \ } while (0) #else #define I2C_ACTIVE { } #endif #define I2C_TRISTATE { } #define I2C_READ \ - (fpga_gpio_get(I2C_ADAP_HWNR, 0x0040) ? 1 : 0) + (fpga_gpio_get(I2C_FPGA_IDX, I2C_SDA_GPIO) ? 1 : 0) #define I2C_SDA(bit) \ do { \ if (bit) \ - fpga_gpio_set(I2C_ADAP_HWNR, 0x0040); \ + fpga_gpio_set(I2C_FPGA_IDX, I2C_SDA_GPIO); \ else \ - fpga_gpio_clear(I2C_ADAP_HWNR, 0x0040); \ + fpga_gpio_clear(I2C_FPGA_IDX, I2C_SDA_GPIO); \ } while (0) #define I2C_SCL(bit) \ do { \ if (bit) \ - fpga_gpio_set(I2C_ADAP_HWNR, 0x0020); \ + fpga_gpio_set(I2C_FPGA_IDX, I2C_SCL_GPIO); \ else \ - fpga_gpio_clear(I2C_ADAP_HWNR, 0x0020); \ + fpga_gpio_clear(I2C_FPGA_IDX, I2C_SCL_GPIO); \ } while (0) #define I2C_DELAY udelay(25) /* 1/4 I2C clock duration */
osdsize adjusts the gdsys IHS osd dimensions in characters.
board/gdsys/common/osd.c | 38 ++++++++++++++++++++++++++++++++++++++ 1 file changed, 38 insertions(+)
diff --git a/board/gdsys/common/osd.c b/board/gdsys/common/osd.c index b288df8..a774bec 100644 --- a/board/gdsys/common/osd.c +++ b/board/gdsys/common/osd.c @@ -27,6 +27,8 @@ #define DP501_I2C_ADDR 0x08
#define PIXCLK_640_480_60 25180000 +#define MAX_X_CHARS 53 +#define MAX_Y_CHARS 26
#ifdef CONFIG_SYS_OSD_DH #define MAX_OSD_SCREEN 8 @@ -464,6 +466,35 @@ int osd_write(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return 0; }
+int osd_size(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + unsigned screen; + unsigned x; + unsigned y; + + if (argc < 3) { + cmd_usage(cmdtp); + return 1; + } + + x = simple_strtoul(argv[1], NULL, 16); + y = simple_strtoul(argv[2], NULL, 16); + + if (!x || (x > 64) || (x > MAX_X_CHARS) || + !y || (y > 32) || (y > MAX_Y_CHARS)) { + cmd_usage(cmdtp); + return 1; + } + + for (screen = 0; screen < MAX_OSD_SCREEN; ++screen) { + OSD_SET_REG(screen, xy_size, ((x - 1) << 8) | (y - 1)); + OSD_SET_REG(screen, x_pos, 32767 * (640 - 12 * x) / 65535); + OSD_SET_REG(screen, y_pos, 32767 * (480 - 18 * y) / 65535); + } + + return 0; +} + U_BOOT_CMD( osdw, 5, 0, osd_write, "write 16-bit hex encoded buffer to osd memory", @@ -475,3 +506,10 @@ U_BOOT_CMD( "write ASCII buffer to osd memory", "pos_x pos_y color text\n" ); + +U_BOOT_CMD( + osdsize, 3, 0, osd_size, + "set OSD XY size in characters", + "size_x(max. " __stringify(MAX_X_CHARS) + ") size_y(max. " __stringify(MAX_Y_CHARS) ")\n" +);
board/gdsys/common/osd.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/board/gdsys/common/osd.c b/board/gdsys/common/osd.c index a774bec..7444bee 100644 --- a/board/gdsys/common/osd.c +++ b/board/gdsys/common/osd.c @@ -303,6 +303,8 @@ static int osd_print(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) res = osd_write_videomem(screen, y * base_width + x, buf, len); if (res < 0) return res; + + OSD_SET_REG(screen, control, 0x0049); }
return 0; @@ -401,8 +403,6 @@ int osd_probe(unsigned screen) if (!output_driver_present) printf(" no output driver found\n");
- OSD_SET_REG(screen, control, 0x0049); - OSD_SET_REG(screen, xy_size, ((32 - 1) << 8) | (16 - 1)); OSD_SET_REG(screen, x_pos, 0x007f); OSD_SET_REG(screen, y_pos, 0x005f); @@ -461,6 +461,8 @@ int osd_write(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) osd_write_videomem(screen, offset, buffer, wp - buffer); } + + OSD_SET_REG(screen, control, 0x0049); }
Since busses are sorted in alphabetical order, introducing more than nine busses led to unexpected behaviour.
drivers/i2c/soft_i2c.c | 20 ++++++++++---------- 1 file changed, 10 insertions(+), 10 deletions(-)
diff --git a/drivers/i2c/soft_i2c.c b/drivers/i2c/soft_i2c.c index 5ffc974..05bf4d4 100644 --- a/drivers/i2c/soft_i2c.c +++ b/drivers/i2c/soft_i2c.c @@ -448,68 +448,68 @@ static int soft_i2c_write(struct i2c_adapter *adap, uchar chip, uint addr, /* * Register soft i2c adapters */ -U_BOOT_I2C_ADAP_COMPLETE(soft0, soft_i2c_init, soft_i2c_probe, +U_BOOT_I2C_ADAP_COMPLETE(soft00, soft_i2c_init, soft_i2c_probe, soft_i2c_read, soft_i2c_write, NULL, CONFIG_SYS_I2C_SOFT_SPEED, CONFIG_SYS_I2C_SOFT_SLAVE, 0) #if defined(I2C_SOFT_DECLARATIONS2) -U_BOOT_I2C_ADAP_COMPLETE(soft1, soft_i2c_init, soft_i2c_probe, +U_BOOT_I2C_ADAP_COMPLETE(soft01, soft_i2c_init, soft_i2c_probe, soft_i2c_read, soft_i2c_write, NULL, CONFIG_SYS_I2C_SOFT_SPEED_2, CONFIG_SYS_I2C_SOFT_SLAVE_2, 1) #endif #if defined(I2C_SOFT_DECLARATIONS3) -U_BOOT_I2C_ADAP_COMPLETE(soft2, soft_i2c_init, soft_i2c_probe, +U_BOOT_I2C_ADAP_COMPLETE(soft02, soft_i2c_init, soft_i2c_probe, soft_i2c_read, soft_i2c_write, NULL, CONFIG_SYS_I2C_SOFT_SPEED_3, CONFIG_SYS_I2C_SOFT_SLAVE_3, 2) #endif #if defined(I2C_SOFT_DECLARATIONS4) -U_BOOT_I2C_ADAP_COMPLETE(soft3, soft_i2c_init, soft_i2c_probe, +U_BOOT_I2C_ADAP_COMPLETE(soft03, soft_i2c_init, soft_i2c_probe, soft_i2c_read, soft_i2c_write, NULL, CONFIG_SYS_I2C_SOFT_SPEED_4, CONFIG_SYS_I2C_SOFT_SLAVE_4, 3) #endif #if defined(I2C_SOFT_DECLARATIONS5) -U_BOOT_I2C_ADAP_COMPLETE(soft4, soft_i2c_init, soft_i2c_probe, +U_BOOT_I2C_ADAP_COMPLETE(soft04, soft_i2c_init, soft_i2c_probe, soft_i2c_read, soft_i2c_write, NULL, CONFIG_SYS_I2C_SOFT_SPEED_5, CONFIG_SYS_I2C_SOFT_SLAVE_5, 4) #endif #if defined(I2C_SOFT_DECLARATIONS6) -U_BOOT_I2C_ADAP_COMPLETE(soft5, soft_i2c_init, soft_i2c_probe, +U_BOOT_I2C_ADAP_COMPLETE(soft05, soft_i2c_init, soft_i2c_probe, soft_i2c_read, soft_i2c_write, NULL, CONFIG_SYS_I2C_SOFT_SPEED_6, CONFIG_SYS_I2C_SOFT_SLAVE_6, 5) #endif #if defined(I2C_SOFT_DECLARATIONS7) -U_BOOT_I2C_ADAP_COMPLETE(soft6, soft_i2c_init, soft_i2c_probe, +U_BOOT_I2C_ADAP_COMPLETE(soft06, soft_i2c_init, soft_i2c_probe, soft_i2c_read, soft_i2c_write, NULL, CONFIG_SYS_I2C_SOFT_SPEED_7, CONFIG_SYS_I2C_SOFT_SLAVE_7, 6) #endif #if defined(I2C_SOFT_DECLARATIONS8) -U_BOOT_I2C_ADAP_COMPLETE(soft7, soft_i2c_init, soft_i2c_probe, +U_BOOT_I2C_ADAP_COMPLETE(soft07, soft_i2c_init, soft_i2c_probe, soft_i2c_read, soft_i2c_write, NULL, CONFIG_SYS_I2C_SOFT_SPEED_8, CONFIG_SYS_I2C_SOFT_SLAVE_8, 7) #endif #if defined(I2C_SOFT_DECLARATIONS9) -U_BOOT_I2C_ADAP_COMPLETE(soft8, soft_i2c_init, soft_i2c_probe, +U_BOOT_I2C_ADAP_COMPLETE(soft08, soft_i2c_init, soft_i2c_probe, soft_i2c_read, soft_i2c_write, NULL, CONFIG_SYS_I2C_SOFT_SPEED_9, CONFIG_SYS_I2C_SOFT_SLAVE_9, 8) #endif #if defined(I2C_SOFT_DECLARATIONS10) -U_BOOT_I2C_ADAP_COMPLETE(soft9, soft_i2c_init, soft_i2c_probe, +U_BOOT_I2C_ADAP_COMPLETE(soft09, soft_i2c_init, soft_i2c_probe, soft_i2c_read, soft_i2c_write, NULL, CONFIG_SYS_I2C_SOFT_SPEED_10, CONFIG_SYS_I2C_SOFT_SLAVE_10,
Hi Dirk,
On 28 October 2015 at 04:46, dirk.eibach@gdsys.cc wrote:
Dirk Eibach (17): i2c: ihs_i2c: Dual channel support i2c: ihs_i2c: Use macro bestpractices i2c: ihs_i2c: Fix hold_bus control board: gdsys: Configure DP501 SPDIF input board: gdsys: Increase DP501 I2C retry interval board: gdsys: Consider DP501 limits on link training dlvision-10g: Support displayport controlcenterd: Disable sideband clocks hrcon: Remove CH7301 configuration mpc83xx: Add strider board hrcon: Use generic ioep-fpga support hrcon: Fix videoboard i2c setup hrcon: Add support for the DH variant hrcon: Add fan controllers board: gdsys: Add osdsize command board: gdsys: Enable osd on output only i2c: soft_i2c: Fix bus indizes
Reinhard Pfau (1): iocon: reset FPGAs in last_stage_init()
Would this be a good opportunity to convert these boards over to driver model for I2C?
Hi Simon,
2015-10-28 14:42 GMT+01:00 Simon Glass sjg@chromium.org:
I'd love to, devicetrees are already there. But I am still working on a concept to deploy this on *all* our boards and not only for I2C. So please remain patient, I think this will be for the next merge window.
Cheers Dirk
Hello Dirk,
Am 28.10.2015 um 15:01 schrieb Dirk Eibach:
Hi Simon,
Sounds great!
bye, Heiko
Cheers Dirk
participants (5)
Dirk Eibach
Heiko Schocher
