[U-Boot] [PATCH 0/3] RFC: Patches to reduce TPL code size
With the rockchip 'rock' board some build and code size problems have come to light with TPL. This series provides a few ideas to improve things.
Simon Glass (3): Makefile: Correct dependency race condition with TPL string: Provide a slimmed-down memset() Makefile: Provide an option to select SPL or TPL
Makefile | 3 ++- lib/Kconfig | 9 +++++++++ lib/string.c | 6 ++++-- scripts/Kbuild.include | 6 ++++++ scripts/Makefile.spl | 6 ++++++ 5 files changed, 27 insertions(+), 3 deletions(-)
At present we sometimes see the following build error when building on a machine with multiple cores.
+make[2]: *** No rule to make target 'dts/dt.dtb', needed by 'tpl/u-boot-tpl.dtb'. Stop.
Add a dependency to correct this.
Makefile | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/Makefile b/Makefile index 1001bc5a7b..5e82b78ade 100644 --- a/Makefile +++ b/Makefile @@ -1351,7 +1351,8 @@ spl/u-boot-spl.sfp: spl/u-boot-spl spl/boot.bin: spl/u-boot-spl @:
-tpl/u-boot-tpl.bin: tools prepare +tpl/u-boot-tpl.bin: tools prepare \ + $(if $(CONFIG_OF_SEPARATE)$(CONFIG_SPL_OF_PLATDATA),dts/dt.dtb) $(Q)$(MAKE) obj=tpl -f $(srctree)/scripts/Makefile.spl all
TAG_SUBDIRS := $(patsubst %,$(srctree)/%,$(u-boot-dirs) include)
Am Sonntag, 26. März 2017, 17:38:15 CEST schrieb Simon Glass:
Fixes the build of rk3188-rock board using buildman for me with more than one job, which failed very reliable before, so
Tested-by: Heiko Stuebner heiko@sntech.de
$(Q)$(MAKE) obj=tpl -f $(srctree)/scripts/Makefile.spl all$(if $(CONFIG_OF_SEPARATE)$(CONFIG_SPL_OF_PLATDATA),dts/dt.dtb)
Applied to u-boot-rockchip.
Most of the time the optimised memset() is what we want. For extreme situations such as TPL it may be too large. For example on the 'rock' board, using a simple loop saves a useful 48 bytes. With gcc 4.9 and the rodata bug, this patch is enough to reduce the TPL image below the limit.
lib/Kconfig | 9 +++++++++ lib/string.c | 6 ++++-- 2 files changed, 13 insertions(+), 2 deletions(-)
diff --git a/lib/Kconfig b/lib/Kconfig index 65c01573e1..5bf512d8c0 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -52,6 +52,15 @@ config LIB_RAND help This library provides pseudo-random number generator functions.
+config FAST_MEMSET + bool "Use an optimised memset()" + default y + help + The faster memset() is the arch-specific one (if available) enabled + by CONFIG_USE_ARCH_MEMSET. If that is not enabled, we can still get + better performance by write a word at a time. Disable this option + to reduce code size slightly at the cost of some speed. + source lib/dhry/Kconfig
source lib/rsa/Kconfig diff --git a/lib/string.c b/lib/string.c index 67d5f6a421..159493ed17 100644 --- a/lib/string.c +++ b/lib/string.c @@ -437,8 +437,10 @@ char *strswab(const char *s) void * memset(void * s,int c,size_t count) { unsigned long *sl = (unsigned long *) s; - unsigned long cl = 0; char *s8; + +#ifdef CONFIG_FAST_MEMSET + unsigned long cl = 0; int i;
/* do it one word at a time (32 bits or 64 bits) while possible */ @@ -452,7 +454,7 @@ void * memset(void * s,int c,size_t count) count -= sizeof(*sl); } } - /* fill 8 bits at a time */ +#endif /* fill 8 bits at a time */ s8 = (char *)sl; while (count--) *s8++ = c;
+config FAST_MEMSET
- bool "Use an optimised memset()"
- default y
- help
The comment sounds slightly confused - it took me a few times of reading it until I grasped what it was trying to tell me :).
So while this is all neat, a few ideas:
1) Would having memset in a header improve things even more? After all, each external function call clobbers registers that you need to save/restore...
2) How much would GOLD save you? Have you tried? U-Boot is small enough of a code base that global optimizations should be able to give significant size savings.
Alex
Am Montag, 27. März 2017, 09:14:47 CEST schrieb Alexander Graf:
+config FAST_MEMSET
- default y
- help
- Would having memset in a header improve things even more? After all,
I'd guess it really depends on the size constraints. The regular libgeneric memset compiles on my rk3188 tpl to a total of 64bytes on both gcc-4.9 and gcc-6.3 while Simon's fast-memset comes down to 14bytes on my rk3188.
On the rk3188 the only memset user is board_init_f, so here memset is called only once without needing to save registers and I'd guess if an implementation really is that size-constrained to worry about 50bytes this one caller will probably always be the only one?
- How much would GOLD save you? Have you tried? U-Boot is small enough
I think the issue that this is trying to solve is to allow more toolchains to be used and thus make rebuilds on changes work on a lot of boards at the same time with random toolchains.
gcc-6.3 already produces way smaller results (well within the size constraints the rk3188 has) than for example the gcc-4.9 used by buildman as baseline toolchain.
+config FAST_MEMSET
- default y
- help
I'm not sure I follow. If you put it into a header, the compiler has a better chance of evicting untaken code paths and optimize register usage over object linked variants (unless you use GOLD). I was mostly wondering whether that would already give you the savings without introducing a complicated #ifdef that is going to bitrot over time :).
I'm just slightly worried about the massive number of preprocessor excludes that happen in U-Boot in general. It seems like something that's really hard to ever have full testing coverage on.
Ah, I see. So 4.9 does not have -lto? There's a good chance my gut feeling that GOLD actually saves anything is wrong - I don't know. Has anyone done the numbers? Then we would have something to actually base gut feeling on.
Size is always a serious constraint in U-Boot, especially in SPL environments. If we can include one more tool in our portfolio to optimize size across the board, I'm all for it. This patch just feels slightly short-term - but I'm definitely not nack'ing it :).
Alex
Am Montag, 27. März 2017, 23:16:45 CEST schrieb Alexander Graf:
+config FAST_MEMSET
- default y
- help
On rk3188-tpl that small non-fast memset gets compiled to (bfd linker): 100809aa <board_init_f_init_reserve>: 100809aa: b510 push {r4, lr} 100809ac: 22c0 movs r2, #192 ; 0xc0 100809ae: 2100 movs r1, #0 100809b0: 4604 mov r4, r0 100809b2: f000 f804 bl 100809be <memset> 100809b6: 34c0 adds r4, #192 ; 0xc0 100809b8: f8c9 4090 str.w r4, [r9, #144] ; 0x90 100809bc: bd10 pop {r4, pc}
100809be <memset>: 100809be: 4402 add r2, r0 100809c0: 4603 mov r3, r0 100809c2: 4293 cmp r3, r2 100809c4: d100 bne.n 100809c8 <memset+0xa> 100809c6: 4770 bx lr 100809c8: f803 1b01 strb.w r1, [r3], #1 100809cc: e7f9 b.n 100809c2 <memset+0x4>
not saving any outside registers, as it's used only once at all and what I was trying to say was that in cases where we worry about having the tiniest memset possible, I guess that will most likely stay the only call.
But I may have been dug into the rk3188 tpl-specifics to long, to see other possible cases right now :-) .
That's essentially what I was worried about as well, seeing that memset can be provided by different sources it seems. There is the libgeneric memset we're having here and also the arch- specific memset (way faster but also again way bigger) and without using either, one could also provide some completely separate implementation at the moment.
So having one version in a header would probably also incur some sort of ifdef voodoo?
It looks like the u-boot Makefile makes explicitly sure to use GNU ld. So I didn't try to dig deeper into this :-) .
Heiko
Am Sonntag, 26. März 2017, 17:38:16 CEST schrieb Simon Glass:
This brings down the rk3188-rock tpl from 1020 to 972 bytes (with a 1020 byte size limit for the tpl) even with gcc-4.9 and down to 748 bytes on gcc-6.3.
I was using the original memset in all tests before, so am quite sure it should work without issues, but cannot test it on actual hardware this week.
Heiko
+config FAST_MEMSET
- default y
- help
Signed-off-by: Simon Glass sjg@chromium.org Signed-off-by: Heiko Stuebner heiko@sntech.de --- Hi Simon,
a bit bikesheddy, but might it make more sense to structure the options like below? That way it matches USE_ARCH_MEMSET and might make the intent visible better, as you get USE_ARCH_MEMSET=y = biggest but also fastest (nothing) = default from libgeneric USE_TINY_MEMSET=y = optimize for size over speed
Also might make reading defconfigs easier as you would have CONFIG_USE_TINY_MEMSET=y instead of # CONFIG_FAST_MEMSET is not set when needing that option.
Anyway, I've tested both variants on a live rk3188-rock now and everything of course still works, even when build with gcc-4.9, so both variants also Tested-by: Heiko Stuebner heiko@sntech.de
Heiko
lib/Kconfig | 20 ++++++++++++++++++++ lib/string.c | 5 ++++- 2 files changed, 24 insertions(+), 1 deletion(-)
diff --git a/lib/Kconfig b/lib/Kconfig index 65c01573e1..ab42413839 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -52,6 +52,26 @@ config LIB_RAND help This library provides pseudo-random number generator functions.
+config USE_TINY_MEMSET + bool "Use a size-optimized memset()" + help + This makes memset prefer code size over speed optimizations. + The fastest memset() is the arch-specific one (if available) enabled + by CONFIG_USE_ARCH_MEMSET. If that is not enabled, we can still get + better performance by writing a word at a time at the cost of + slightly bigger memset code, but in some special cases size might + be more important than speed. + +config SPL_USE_TINY_MEMSET + bool "Use a size-optimized memset()" + help + This makes memset prefer code size over speed optimizations. + The fastest memset() is the arch-specific one (if available) enabled + by CONFIG_USE_ARCH_MEMSET. If that is not enabled, we can still get + better performance by writing a word at a time at the cost of + slightly bigger memset code, but in some special cases size might + be more important than speed. + source lib/dhry/Kconfig
source lib/rsa/Kconfig diff --git a/lib/string.c b/lib/string.c index 67d5f6a421..edae997fa6 100644 --- a/lib/string.c +++ b/lib/string.c @@ -437,8 +437,10 @@ char *strswab(const char *s) void * memset(void * s,int c,size_t count) { unsigned long *sl = (unsigned long *) s; - unsigned long cl = 0; char *s8; + +#if !CONFIG_IS_ENABLED(USE_TINY_MEMSET) + unsigned long cl = 0; int i;
/* do it one word at a time (32 bits or 64 bits) while possible */ @@ -452,6 +454,7 @@ void * memset(void * s,int c,size_t count) count -= sizeof(*sl); } } +#endif /* fill 8 bits at a time */ s8 = (char *)sl; while (count--)
At present we have SPL_ which can be used in Makefiles to select between normal and SPL CONFIGs like this:
obj-$(CONFIG_$(SPL_)DM) += core/
When TPL is being built, SPL_ has the value 'SPL' which is generally a good idea since they tend to follow each other. But in extreme situations we may want to distinugish between SPL and TPL. For example we may not want to enable CONFIG_DM with TPL.
Add a new SPL_TPL_ variable which is set to either empty (for U-Boot proper), 'SPL' or 'TPL'. This may prove useful with TPL-specific options.
scripts/Kbuild.include | 6 ++++++ scripts/Makefile.spl | 6 ++++++ 2 files changed, 12 insertions(+)
diff --git a/scripts/Kbuild.include b/scripts/Kbuild.include index 1b62aedb00..a3a5c59d0d 100644 --- a/scripts/Kbuild.include +++ b/scripts/Kbuild.include @@ -321,6 +321,12 @@ endif
ifdef CONFIG_SPL_BUILD SPL_ := SPL_ +ifeq ($(CONFIG_TPL_BUILD),y) +SPL_TPL_ := TPL_ +else +SPL_TPL_ := SPL_ +endif else SPL_ := +SPL_TPL_ := endif diff --git a/scripts/Makefile.spl b/scripts/Makefile.spl index 5370648e85..4485ea8812 100644 --- a/scripts/Makefile.spl +++ b/scripts/Makefile.spl @@ -37,8 +37,14 @@ endif
include $(srctree)/config.mk
Alexander Graf
Heiko Stuebner
