[PATCH] board: stmp32mp1: split board and SOC STM32MP15 configuration
Add a configuration file "stm32mp15_st_common.h" to handle the STMicroelectronics boards configuration and rename stm32mp1.h to "stm32mp15_common.h" to handle the generic STM32MP15x series configuration.
The configuration file "dh_stm32mp1.h" is also renamed to "stm32mp15_dh_dhcom" for the configuration of board based on the dhelectronics STM32MP15x SOM.
In the STMicroelectronics board configuration the default bootcmd "bootcmd_stm32mp" is updated to only select the extlinux file found on SD-Card on STM32MP15x EV1 for boot from NOR device.
Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com ---
board/dhelectronics/dh_stm32mp1/Kconfig | 2 +- board/dhelectronics/dh_stm32mp1/MAINTAINERS | 2 +- board/engicam/stm32mp1/Kconfig | 2 +- board/st/stm32mp1/Kconfig | 2 +- board/st/stm32mp1/MAINTAINERS | 3 +- .../{stm32mp1.h => stm32mp15_common.h} | 51 ++++++++++++------- .../{dh_stm32mp1.h => stm32mp15_dh_dhsom.h} | 6 +-- include/configs/stm32mp15_st_common.h | 46 +++++++++++++++++ 8 files changed, 87 insertions(+), 27 deletions(-) rename include/configs/{stm32mp1.h => stm32mp15_common.h} (78%) rename include/configs/{dh_stm32mp1.h => stm32mp15_dh_dhsom.h} (65%) create mode 100644 include/configs/stm32mp15_st_common.h
diff --git a/board/dhelectronics/dh_stm32mp1/Kconfig b/board/dhelectronics/dh_stm32mp1/Kconfig index 1fc792c9d1..dc707c2753 100644 --- a/board/dhelectronics/dh_stm32mp1/Kconfig +++ b/board/dhelectronics/dh_stm32mp1/Kconfig @@ -7,7 +7,7 @@ config SYS_VENDOR default "dhelectronics"
config SYS_CONFIG_NAME - default "dh_stm32mp1" + default "stm32mp15_dh_dhsom"
config ENV_SECT_SIZE default 0x10000 if ENV_IS_IN_SPI_FLASH diff --git a/board/dhelectronics/dh_stm32mp1/MAINTAINERS b/board/dhelectronics/dh_stm32mp1/MAINTAINERS index 9ce21c3ab2..865588f5b8 100644 --- a/board/dhelectronics/dh_stm32mp1/MAINTAINERS +++ b/board/dhelectronics/dh_stm32mp1/MAINTAINERS @@ -6,4 +6,4 @@ F: arch/arm/dts/stm32mp15xx-dhcom* F: board/dhelectronics/dh_stm32mp1/ F: configs/stm32mp15_dhcom_basic_defconfig F: configs/stm32mp15_dhcor_basic_defconfig -F: include/configs/stm32mp1.h +F: include/configs/stm32mp15_dh_dhsom.h diff --git a/board/engicam/stm32mp1/Kconfig b/board/engicam/stm32mp1/Kconfig index c800fd4e60..3802d44cef 100644 --- a/board/engicam/stm32mp1/Kconfig +++ b/board/engicam/stm32mp1/Kconfig @@ -7,6 +7,6 @@ config SYS_VENDOR default "engicam"
config SYS_CONFIG_NAME - default "stm32mp1" + default "stm32mp15_common"
endif diff --git a/board/st/stm32mp1/Kconfig b/board/st/stm32mp1/Kconfig index c5ab7553d4..89e97aec2b 100644 --- a/board/st/stm32mp1/Kconfig +++ b/board/st/stm32mp1/Kconfig @@ -7,7 +7,7 @@ config SYS_VENDOR default "st"
config SYS_CONFIG_NAME - default "stm32mp1" + default "stm32mp15_st_common"
source "board/st/common/Kconfig" endif diff --git a/board/st/stm32mp1/MAINTAINERS b/board/st/stm32mp1/MAINTAINERS index 0e6d80fb45..6451195269 100644 --- a/board/st/stm32mp1/MAINTAINERS +++ b/board/st/stm32mp1/MAINTAINERS @@ -8,4 +8,5 @@ F: board/st/stm32mp1/ F: configs/stm32mp15_defconfig F: configs/stm32mp15_basic_defconfig F: configs/stm32mp15_trusted_defconfig -F: include/configs/stm32mp1.h +F: include/configs/stm32mp15_common.h +F: include/configs/stm32mp15_st_common.h diff --git a/include/configs/stm32mp1.h b/include/configs/stm32mp15_common.h similarity index 78% rename from include/configs/stm32mp1.h rename to include/configs/stm32mp15_common.h index 30d4e8ff1f..46a92a06e5 100644 --- a/include/configs/stm32mp1.h +++ b/include/configs/stm32mp15_common.h @@ -5,8 +5,8 @@ * Configuration settings for the STM32MP15x CPU */
-#ifndef __CONFIG_H -#define __CONFIG_H +#ifndef __CONFIG_STM32MP15_COMMMON_H +#define __CONFIG_STM32MP15_COMMMON_H #include <linux/sizes.h> #include <asm/arch/stm32.h>
@@ -104,11 +104,11 @@ BOOT_TARGET_PXE(func)
/* - * bootcmd for stm32mp1: + * default bootcmd for stm32mp1: * for serial/usb: execute the stm32prog command - * for mmc boot (eMMC, SD card), boot only on the same device - * for nand or spi-nand boot, boot with on ubifs partition on UBI partition - * for nor boot, use the default order + * for mmc boot (eMMC, SD card), distro boot on the same mmc device + * for nand or spi-nand boot, distro boot with ubifs on UBI partition + * for nor boot, use the default distro order in ${boot_targets} */ #define STM32MP_BOOTCMD "bootcmd_stm32mp=" \ "echo "Boot over ${boot_device}${boot_instance}!";" \ @@ -126,7 +126,7 @@
#ifdef CONFIG_FASTBOOT_CMD_OEM_FORMAT /* eMMC default partitions for fastboot command: oem format */ -#define PARTS_DEFAULT \ +#define STM32MP_PARTS_DEFAULT \ "partitions=" \ "name=ssbl,size=2M;" \ "name=bootfs,size=64MB,bootable;" \ @@ -134,9 +134,14 @@ "name=rootfs,size=746M;" \ "name=userfs,size=-\0" #else -#define PARTS_DEFAULT +#define STM32MP_PARTS_DEFAULT #endif
+#define STM32MP_EXTRA \ + "altbootcmd=run bootcmd\0" \ + "env_check=if env info -p -d -q; then env save; fi\0" \ + "boot_net_usb_start=true\0" + #include <config_distro_bootcmd.h>
/* @@ -144,21 +149,29 @@ * 1M fdt, 1M script, 1M pxe and 1M for overlay * and the ramdisk at the end. */ +#define __KERNEL_ADDR_R __stringify(0xc2000000) +#define __FDT_ADDR_R __stringify(0xc4000000) +#define __SCRIPT_ADDR_R __stringify(0xc4100000) +#define __PXEFILE_ADDR_R __stringify(0xc4200000) +#define __FDTOVERLAY_ADDR_R __stringify(0xc4300000) +#define __RAMDISK_ADDR_R __stringify(0xc4400000) + +#define STM32MP_MEM_LAYOUT \ + "kernel_addr_r=" __KERNEL_ADDR_R "\0" \ + "fdt_addr_r=" __FDT_ADDR_R "\0" \ + "scriptaddr=" __SCRIPT_ADDR_R "\0" \ + "pxefile_addr_r=" __PXEFILE_ADDR_R "\0" \ + "fdtoverlay_addr_r=" __FDTOVERLAY_ADDR_R "\0" \ + "ramdisk_addr_r=" __RAMDISK_ADDR_R "\0" + #define CONFIG_EXTRA_ENV_SETTINGS \ - "kernel_addr_r=0xc2000000\0" \ - "fdt_addr_r=0xc4000000\0" \ - "scriptaddr=0xc4100000\0" \ - "pxefile_addr_r=0xc4200000\0" \ - "fdtoverlay_addr_r=0xc4300000\0" \ - "ramdisk_addr_r=0xc4400000\0" \ - "altbootcmd=run bootcmd\0" \ - "env_check=if env info -p -d -q; then env save; fi\0" \ + STM32MP_MEM_LAYOUT \ STM32MP_BOOTCMD \ - PARTS_DEFAULT \ + STM32MP_PARTS_DEFAULT \ BOOTENV \ - "boot_net_usb_start=true\0" + STM32MP_EXTRA
#endif /* ifndef CONFIG_SPL_BUILD */ #endif /* ifdef CONFIG_DISTRO_DEFAULTS*/
-#endif /* __CONFIG_H */ +#endif /* __CONFIG_STM32MP15_COMMMON_H */ diff --git a/include/configs/dh_stm32mp1.h b/include/configs/stm32mp15_dh_dhsom.h similarity index 65% rename from include/configs/dh_stm32mp1.h rename to include/configs/stm32mp15_dh_dhsom.h index 89d317ba2b..c559cd72da 100644 --- a/include/configs/dh_stm32mp1.h +++ b/include/configs/stm32mp15_dh_dhsom.h @@ -5,10 +5,10 @@ * Configuration settings for the DH STM32MP15x SoMs */
-#ifndef __CONFIG_DH_STM32MP1_H__ -#define __CONFIG_DH_STM32MP1_H__ +#ifndef __CONFIG_STM32MP15_DH_DHSOM_H__ +#define __CONFIG_STM32MP15_DH_DHSOM_H__
-#include <configs/stm32mp1.h> +#include <configs/stm32mp15_common.h>
#define CONFIG_SPL_TARGET "u-boot.itb"
diff --git a/include/configs/stm32mp15_st_common.h b/include/configs/stm32mp15_st_common.h new file mode 100644 index 0000000000..10248bffc1 --- /dev/null +++ b/include/configs/stm32mp15_st_common.h @@ -0,0 +1,46 @@ +/* SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause */ +/* + * Copyright (C) 2021, STMicroelectronics - All Rights Reserved + * + * Configuration settings for the STMicroelectonics STM32MP15x boards + */ + +#ifndef __CONFIG_STM32MP15_ST_COMMON_H__ +#define __CONFIG_STM32MP15_ST_COMMON_H__ + +#include <configs/stm32mp15_common.h> + +#ifdef CONFIG_EXTRA_ENV_SETTINGS +/* + * default bootcmd for stm32mp1 STMicroelectronics boards: + * for serial/usb: execute the stm32prog command + * for mmc boot (eMMC, SD card), distro boot on the same mmc device + * for nand or spi-nand boot, distro boot with ubifs on UBI partition + * for nor boot, distro boot on SD card = mmc0 ONLY ! + */ +#define ST_STM32MP1_BOOTCMD "bootcmd_stm32mp=" \ + "echo "Boot over ${boot_device}${boot_instance}!";" \ + "if test ${boot_device} = serial || test ${boot_device} = usb;" \ + "then stm32prog ${boot_device} ${boot_instance}; " \ + "else " \ + "run env_check;" \ + "if test ${boot_device} = mmc;" \ + "then env set boot_targets "mmc${boot_instance}"; fi;" \ + "if test ${boot_device} = nand ||" \ + " test ${boot_device} = spi-nand ;" \ + "then env set boot_targets ubifs0; fi;" \ + "if test ${boot_device} = nor;" \ + "then env set boot_targets mmc0; fi;" \ + "run distro_bootcmd;" \ + "fi;\0" + +#undef CONFIG_EXTRA_ENV_SETTINGS +#define CONFIG_EXTRA_ENV_SETTINGS \ + STM32MP_MEM_LAYOUT \ + ST_STM32MP1_BOOTCMD \ + STM32MP_PARTS_DEFAULT \ + BOOTENV \ + STM32MP_EXTRA + +#endif +#endif
Hi Patrick
- default "stm32mp15_dh_dhsom"
- default "stm32mp15_common"
- default "stm32mp15_st_common"
- Configuration settings for the STM32MP15x CPU
- bootcmd for stm32mp1:
- default bootcmd for stm32mp1:
- for serial/usb: execute the stm32prog command
- for mmc boot (eMMC, SD card), boot only on the same device
- for nand or spi-nand boot, boot with on ubifs partition on UBI partition
- for nor boot, use the default order
- for mmc boot (eMMC, SD card), distro boot on the same mmc device
- for nand or spi-nand boot, distro boot with ubifs on UBI partition
- for nor boot, use the default distro order in ${boot_targets}
- 1M fdt, 1M script, 1M pxe and 1M for overlay
- and the ramdisk at the end.
- "kernel_addr_r=" __KERNEL_ADDR_R "\0" \
- "fdt_addr_r=" __FDT_ADDR_R "\0" \
- "scriptaddr=" __SCRIPT_ADDR_R "\0" \
- "pxefile_addr_r=" __PXEFILE_ADDR_R "\0" \
- "fdtoverlay_addr_r=" __FDTOVERLAY_ADDR_R "\0" \
- "ramdisk_addr_r=" __RAMDISK_ADDR_R "\0"
- STM32MP_MEM_LAYOUT \ STM32MP_BOOTCMD \
- PARTS_DEFAULT \
- STM32MP_PARTS_DEFAULT \ BOOTENV \
- STM32MP_EXTRA
- Configuration settings for the DH STM32MP15x SoMs
- Copyright (C) 2021, STMicroelectronics - All Rights Reserved
- Configuration settings for the STMicroelectonics STM32MP15x boards
- default bootcmd for stm32mp1 STMicroelectronics boards:
- for nor boot, distro boot on SD card = mmc0 ONLY !
- "echo "Boot over ${boot_device}${boot_instance}!";" \
- "if test ${boot_device} = serial || test ${boot_device} = usb;" \
- "then stm32prog ${boot_device} ${boot_instance}; " \
- "else " \
"run env_check;" \
"then env set boot_targets \"mmc${boot_instance}\"; fi;" \
- "fi;\0"
- ST_STM32MP1_BOOTCMD \
- BOOTENV \
- STM32MP_EXTRA
+#endif +#endif
Reviewed-by: Patrice Chotard patrice.chotard@foss.st.com Thanks Patrice
Hi Patrick
On 10/25/21 9:06 AM, Patrice CHOTARD wrote:
Hi Patrick
- PARTS_DEFAULT \
- STM32MP_EXTRA
- "else " \
"run env_check;" \
- "fi;\0"
- BOOTENV \
- STM32MP_EXTRA
+#endif +#endif
Reviewed-by: Patrice Chotard patrice.chotard@foss.st.com Thanks Patrice _______________________________________________ Uboot-stm32 mailing list Uboot-stm32@st-md-mailman.stormreply.com https://st-md-mailman.stormreply.com/mailman/listinfo/uboot-stm32
Applied on u-boot-stm/master Thanks
Patrice CHOTARD
Patrick Delaunay
