[U-Boot] [RFC PATCH 0/5] Port of MUSB gadget driver from Linux
Current MUSB driver in U-Boot uses old UDC API while new gagdet client drivers need new gadget API. Also current MUSB driver has some significant limitations (like inability to handle tx for endpoints other than ep0). So I think port of new Linux driver is desirable.
This is initial port, performed mostly by putting DM, host and OTG code under #ifndef __UBOOT__ clauses. My intention was to be as close as possible to the original to ease of possible resyncs. Some warnings are suppressed via CFLAGS. There are some style problems but I'm not touching them for now for the above mentioned reason. There is obviously some room for optimisation, some structure fields are unused as well as (probably) some code.
This is not a replacement for existing MUSB driver (at least for now), cause host mode is not supported and there are still consumers of the old interface.
Host mode, OTG and DMA are not supported. The only ported driver is for TI AM33xx, but others should be easy to port too.
Tested it on AM335x EVM and BeagleBone with CDC Ethernet gadget.
Ilya Yanok (5): linux/usb/ch9.h: update with the version from Linux tree musb-new: port of Linux musb gadget driver musb-new: dsps backend driver am33xx: init OTG hardware and new musb gadget driver am335x_evm: enable musb gadget on port 0
Makefile | 1 + arch/arm/cpu/armv7/am33xx/board.c | 81 +- arch/arm/cpu/armv7/am33xx/clock.c | 8 + arch/arm/include/asm/arch-am33xx/cpu.h | 11 +- arch/arm/include/asm/arch-am33xx/hardware.h | 4 + arch/arm/include/asm/omap_musb.h | 25 + drivers/usb/gadget/config.c | 1 - drivers/usb/gadget/epautoconf.c | 1 - drivers/usb/gadget/ether.c | 1 - drivers/usb/gadget/gadget_chips.h | 2 + drivers/usb/gadget/s3c_udc_otg.c | 1 - drivers/usb/gadget/usbstring.c | 1 - drivers/usb/musb-new/Makefile | 36 + drivers/usb/musb-new/musb_core.c | 2489 +++++++++++++++++++++++++++ drivers/usb/musb-new/musb_core.h | 611 +++++++ drivers/usb/musb-new/musb_debug.h | 58 + drivers/usb/musb-new/musb_dma.h | 186 ++ drivers/usb/musb-new/musb_dsps.c | 769 +++++++++ drivers/usb/musb-new/musb_gadget.c | 2319 +++++++++++++++++++++++++ drivers/usb/musb-new/musb_gadget.h | 127 ++ drivers/usb/musb-new/musb_gadget_ep0.c | 1089 ++++++++++++ drivers/usb/musb-new/musb_gadget_uboot.c | 72 + drivers/usb/musb-new/musb_io.h | 146 ++ drivers/usb/musb-new/musb_regs.h | 645 +++++++ include/configs/am335x_evm.h | 19 + include/linux/usb/ch9.h | 514 +++++- include/linux/usb/musb.h | 162 ++ include/usb/s3c_udc.h | 1 - 28 files changed, 9355 insertions(+), 25 deletions(-) create mode 100644 arch/arm/include/asm/omap_musb.h create mode 100644 drivers/usb/musb-new/Makefile create mode 100644 drivers/usb/musb-new/musb_core.c create mode 100644 drivers/usb/musb-new/musb_core.h create mode 100644 drivers/usb/musb-new/musb_debug.h create mode 100644 drivers/usb/musb-new/musb_dma.h create mode 100644 drivers/usb/musb-new/musb_dsps.c create mode 100644 drivers/usb/musb-new/musb_gadget.c create mode 100644 drivers/usb/musb-new/musb_gadget.h create mode 100644 drivers/usb/musb-new/musb_gadget_ep0.c create mode 100644 drivers/usb/musb-new/musb_gadget_uboot.c create mode 100644 drivers/usb/musb-new/musb_io.h create mode 100644 drivers/usb/musb-new/musb_regs.h create mode 100644 include/linux/usb/musb.h
Signed-off-by: Ilya Yanok ilya.yanok@cogentembedded.com --- drivers/usb/gadget/config.c | 1 - drivers/usb/gadget/epautoconf.c | 1 - drivers/usb/gadget/ether.c | 1 - drivers/usb/gadget/s3c_udc_otg.c | 1 - drivers/usb/gadget/usbstring.c | 1 - include/linux/usb/ch9.h | 514 ++++++++++++++++++++++++++++++++++++-- include/usb/s3c_udc.h | 1 - 7 files changed, 499 insertions(+), 21 deletions(-)
diff --git a/drivers/usb/gadget/config.c b/drivers/usb/gadget/config.c index f88d0c1..f9163a8 100644 --- a/drivers/usb/gadget/config.c +++ b/drivers/usb/gadget/config.c @@ -27,7 +27,6 @@ #include <linux/string.h>
#include <linux/usb/ch9.h> -#include <usbdescriptors.h> #include <linux/usb/gadget.h>
diff --git a/drivers/usb/gadget/epautoconf.c b/drivers/usb/gadget/epautoconf.c index b656c8b..5b8776e 100644 --- a/drivers/usb/gadget/epautoconf.c +++ b/drivers/usb/gadget/epautoconf.c @@ -23,7 +23,6 @@
#include <common.h> #include <linux/usb/ch9.h> -#include <usbdescriptors.h> #include <asm/errno.h> #include <linux/usb/gadget.h> #include <asm/unaligned.h> diff --git a/drivers/usb/gadget/ether.c b/drivers/usb/gadget/ether.c index d975fb6..6f7e4cd 100644 --- a/drivers/usb/gadget/ether.c +++ b/drivers/usb/gadget/ether.c @@ -24,7 +24,6 @@ #include <asm/errno.h> #include <linux/netdevice.h> #include <linux/usb/ch9.h> -#include <usbdescriptors.h> #include <linux/usb/cdc.h> #include <linux/usb/gadget.h> #include <net.h> diff --git a/drivers/usb/gadget/s3c_udc_otg.c b/drivers/usb/gadget/s3c_udc_otg.c index 3fdfdf7..f9d24e3 100644 --- a/drivers/usb/gadget/s3c_udc_otg.c +++ b/drivers/usb/gadget/s3c_udc_otg.c @@ -37,7 +37,6 @@ #include <malloc.h>
#include <asm/byteorder.h> diff --git a/drivers/usb/gadget/usbstring.c b/drivers/usb/gadget/usbstring.c index 4dbe060..95555cf 100644 --- a/drivers/usb/gadget/usbstring.c +++ b/drivers/usb/gadget/usbstring.c @@ -13,7 +13,6 @@ #include <common.h> #include <asm/errno.h> #include <linux/usb/ch9.h> -#include <usbdescriptors.h> #include <linux/usb/gadget.h>
#include <asm/unaligned.h> diff --git a/include/linux/usb/ch9.h b/include/linux/usb/ch9.h index ce1d1e1..d1d732c 100644 --- a/include/linux/usb/ch9.h +++ b/include/linux/usb/ch9.h @@ -28,15 +28,13 @@ * [c] for consistency, removing all doubt even when it appears to * someone that the two other points are non-issues for that * particular descriptor type. - * - * Ported to U-boot by: Thomas Smits ts.smits@gmail.com and - * Remy Bohmer linux@bohmer.net */
#ifndef __LINUX_USB_CH9_H #define __LINUX_USB_CH9_H
#include <linux/types.h> /* __u8 etc */ +#include <asm/byteorder.h> /* le16_to_cpu */
@@ -70,7 +68,7 @@ #define USB_RECIP_OTHER 0x03 /* From Wireless USB 1.0 */ #define USB_RECIP_PORT 0x04 -#define USB_RECIP_RPIPE 0x05 +#define USB_RECIP_RPIPE 0x05
/* * Standard requests, for the bRequest field of a SETUP packet. @@ -90,6 +88,8 @@ #define USB_REQ_GET_INTERFACE 0x0A #define USB_REQ_SET_INTERFACE 0x0B #define USB_REQ_SYNCH_FRAME 0x0C +#define USB_REQ_SET_SEL 0x30 +#define USB_REQ_SET_ISOCH_DELAY 0x31
#define USB_REQ_SET_ENCRYPTION 0x0D /* Wireless USB */ #define USB_REQ_GET_ENCRYPTION 0x0E @@ -105,10 +105,16 @@ #define USB_REQ_LOOPBACK_DATA_READ 0x16 #define USB_REQ_SET_INTERFACE_DS 0x17
+/* The Link Power Management (LPM) ECN defines USB_REQ_TEST_AND_SET command, + * used by hubs to put ports into a new L1 suspend state, except that it + * forgot to define its number ... + */ + /* * USB feature flags are written using USB_REQ_{CLEAR,SET}_FEATURE, and * are read as a bit array returned by USB_REQ_GET_STATUS. (So there - * are at most sixteen features of each type.) + * are at most sixteen features of each type.) Hubs may also support a + * new USB_REQ_TEST_AND_SET_FEATURE to put ports into L1 suspend. */ #define USB_DEVICE_SELF_POWERED 0 /* (read only) */ #define USB_DEVICE_REMOTE_WAKEUP 1 /* dev may initiate wakeup */ @@ -120,8 +126,38 @@ #define USB_DEVICE_A_ALT_HNP_SUPPORT 5 /* (otg) other RH port does */ #define USB_DEVICE_DEBUG_MODE 6 /* (special devices only) */
+/* + * Test Mode Selectors + * See USB 2.0 spec Table 9-7 + */ +#define TEST_J 1 +#define TEST_K 2 +#define TEST_SE0_NAK 3 +#define TEST_PACKET 4 +#define TEST_FORCE_EN 5 + +/* + * New Feature Selectors as added by USB 3.0 + * See USB 3.0 spec Table 9-6 + */ +#define USB_DEVICE_U1_ENABLE 48 /* dev may initiate U1 transition */ +#define USB_DEVICE_U2_ENABLE 49 /* dev may initiate U2 transition */ +#define USB_DEVICE_LTM_ENABLE 50 /* dev may send LTM */ +#define USB_INTRF_FUNC_SUSPEND 0 /* function suspend */ + +#define USB_INTR_FUNC_SUSPEND_OPT_MASK 0xFF00 +/* + * Suspend Options, Table 9-7 USB 3.0 spec + */ +#define USB_INTRF_FUNC_SUSPEND_LP (1 << (8 + 0)) +#define USB_INTRF_FUNC_SUSPEND_RW (1 << (8 + 1)) + #define USB_ENDPOINT_HALT 0 /* IN/OUT will STALL */
+/* Bit array elements as returned by the USB_REQ_GET_STATUS request. */ +#define USB_DEV_STAT_U1_ENABLED 2 /* transition into U1 state */ +#define USB_DEV_STAT_U2_ENABLED 3 /* transition into U2 state */ +#define USB_DEV_STAT_LTM_ENABLED 4 /* Latency tolerance messages */
/** * struct usb_ctrlrequest - SETUP data for a USB device control request @@ -140,10 +176,6 @@ * For most devices, interfaces don't coordinate with each other, so * such requests may be made at any time. */ -#if defined(__BIG_ENDIAN) || defined(__ARMEB__) -#error (functionality not verified for big endian targets, todo...) -#endif - struct usb_ctrlrequest { __u8 bRequestType; __u8 bRequest; @@ -159,8 +191,12 @@ struct usb_ctrlrequest { * (rarely) accepted by SET_DESCRIPTOR. * * Note that all multi-byte values here are encoded in little endian - * byte order "on the wire". But when exposed through Linux-USB APIs, - * they've been converted to cpu byte order. + * byte order "on the wire". Within the kernel and when exposed + * through the Linux-USB APIs, they are not converted to cpu byte + * order; it is the responsibility of the client code to do this. + * The single exception is when device and configuration descriptors (but + * not other descriptors) are read from usbfs (i.e. /proc/bus/usb/BBB/DDD); + * in this case the fields are converted to host endianness by the kernel. */
/* @@ -187,6 +223,11 @@ struct usb_ctrlrequest { #define USB_DT_WIRELESS_ENDPOINT_COMP 0x11 #define USB_DT_WIRE_ADAPTER 0x21 #define USB_DT_RPIPE 0x22 +#define USB_DT_CS_RADIO_CONTROL 0x23 +/* From the T10 UAS specification */ +#define USB_DT_PIPE_USAGE 0x24 +/* From the USB 3.0 spec */ +#define USB_DT_SS_ENDPOINT_COMP 0x30
/* Conventional codes for class-specific descriptors. The convention is * defined in the USB "Common Class" Spec (3.11). Individual class specs @@ -204,6 +245,28 @@ struct usb_descriptor_header { __u8 bDescriptorType; } __attribute__ ((packed));
+ +/*-------------------------------------------------------------------------*/ + +/* USB_DT_DEVICE: Device descriptor */ +struct usb_device_descriptor { + __u8 bLength; + __u8 bDescriptorType; + + __le16 bcdUSB; + __u8 bDeviceClass; + __u8 bDeviceSubClass; + __u8 bDeviceProtocol; + __u8 bMaxPacketSize0; + __le16 idVendor; + __le16 idProduct; + __le16 bcdDevice; + __u8 iManufacturer; + __u8 iProduct; + __u8 iSerialNumber; + __u8 bNumConfigurations; +} __attribute__ ((packed)); + #define USB_DT_DEVICE_SIZE 18
@@ -230,6 +293,8 @@ struct usb_descriptor_header { #define USB_CLASS_APP_SPEC 0xfe #define USB_CLASS_VENDOR_SPEC 0xff
+#define USB_SUBCLASS_VENDOR_SPEC 0xff + /*-------------------------------------------------------------------------*/
/* USB_DT_CONFIG: Configuration descriptor information. @@ -260,11 +325,56 @@ struct usb_config_descriptor { #define USB_CONFIG_ATT_WAKEUP (1 << 5) /* can wakeup */ #define USB_CONFIG_ATT_BATTERY (1 << 4) /* battery powered */
+/*-------------------------------------------------------------------------*/ + +/* USB_DT_STRING: String descriptor */ +struct usb_string_descriptor { + __u8 bLength; + __u8 bDescriptorType; + + __le16 wData[1]; /* UTF-16LE encoded */ +} __attribute__ ((packed)); + /* note that "string" zero is special, it holds language codes that * the device supports, not Unicode characters. */
+/*-------------------------------------------------------------------------*/ + +/* USB_DT_INTERFACE: Interface descriptor */ +struct usb_interface_descriptor { + __u8 bLength; + __u8 bDescriptorType; + + __u8 bInterfaceNumber; + __u8 bAlternateSetting; + __u8 bNumEndpoints; + __u8 bInterfaceClass; + __u8 bInterfaceSubClass; + __u8 bInterfaceProtocol; + __u8 iInterface; +} __attribute__ ((packed)); + #define USB_DT_INTERFACE_SIZE 9 + +/*-------------------------------------------------------------------------*/ + +/* USB_DT_ENDPOINT: Endpoint descriptor */ +struct usb_endpoint_descriptor { + __u8 bLength; + __u8 bDescriptorType; + + __u8 bEndpointAddress; + __u8 bmAttributes; + __le16 wMaxPacketSize; + __u8 bInterval; + + /* NOTE: these two are _only_ in audio endpoints. */ + /* use USB_DT_ENDPOINT*_SIZE in bLength, not sizeof. */ + __u8 bRefresh; + __u8 bSynchAddress; +} __attribute__ ((packed)); + #define USB_DT_ENDPOINT_SIZE 7 #define USB_DT_ENDPOINT_AUDIO_SIZE 9 /* Audio extension */
@@ -282,6 +392,254 @@ struct usb_config_descriptor { #define USB_ENDPOINT_XFER_INT 3 #define USB_ENDPOINT_MAX_ADJUSTABLE 0x80
+/* The USB 3.0 spec redefines bits 5:4 of bmAttributes as interrupt ep type. */ +#define USB_ENDPOINT_INTRTYPE 0x30 +#define USB_ENDPOINT_INTR_PERIODIC (0 << 4) +#define USB_ENDPOINT_INTR_NOTIFICATION (1 << 4) + +#define USB_ENDPOINT_SYNCTYPE 0x0c +#define USB_ENDPOINT_SYNC_NONE (0 << 2) +#define USB_ENDPOINT_SYNC_ASYNC (1 << 2) +#define USB_ENDPOINT_SYNC_ADAPTIVE (2 << 2) +#define USB_ENDPOINT_SYNC_SYNC (3 << 2) + +#define USB_ENDPOINT_USAGE_MASK 0x30 +#define USB_ENDPOINT_USAGE_DATA 0x00 +#define USB_ENDPOINT_USAGE_FEEDBACK 0x10 +#define USB_ENDPOINT_USAGE_IMPLICIT_FB 0x20 /* Implicit feedback Data endpoint */ + +/*-------------------------------------------------------------------------*/ + +/** + * usb_endpoint_num - get the endpoint's number + * @epd: endpoint to be checked + * + * Returns @epd's number: 0 to 15. + */ +static inline int usb_endpoint_num(const struct usb_endpoint_descriptor *epd) +{ + return epd->bEndpointAddress & USB_ENDPOINT_NUMBER_MASK; +} + +/** + * usb_endpoint_type - get the endpoint's transfer type + * @epd: endpoint to be checked + * + * Returns one of USB_ENDPOINT_XFER_{CONTROL, ISOC, BULK, INT} according + * to @epd's transfer type. + */ +static inline int usb_endpoint_type(const struct usb_endpoint_descriptor *epd) +{ + return epd->bmAttributes & USB_ENDPOINT_XFERTYPE_MASK; +} + +/** + * usb_endpoint_dir_in - check if the endpoint has IN direction + * @epd: endpoint to be checked + * + * Returns true if the endpoint is of type IN, otherwise it returns false. + */ +static inline int usb_endpoint_dir_in(const struct usb_endpoint_descriptor *epd) +{ + return ((epd->bEndpointAddress & USB_ENDPOINT_DIR_MASK) == USB_DIR_IN); +} + +/** + * usb_endpoint_dir_out - check if the endpoint has OUT direction + * @epd: endpoint to be checked + * + * Returns true if the endpoint is of type OUT, otherwise it returns false. + */ +static inline int usb_endpoint_dir_out( + const struct usb_endpoint_descriptor *epd) +{ + return ((epd->bEndpointAddress & USB_ENDPOINT_DIR_MASK) == USB_DIR_OUT); +} + +/** + * usb_endpoint_xfer_bulk - check if the endpoint has bulk transfer type + * @epd: endpoint to be checked + * + * Returns true if the endpoint is of type bulk, otherwise it returns false. + */ +static inline int usb_endpoint_xfer_bulk( + const struct usb_endpoint_descriptor *epd) +{ + return ((epd->bmAttributes & USB_ENDPOINT_XFERTYPE_MASK) == + USB_ENDPOINT_XFER_BULK); +} + +/** + * usb_endpoint_xfer_control - check if the endpoint has control transfer type + * @epd: endpoint to be checked + * + * Returns true if the endpoint is of type control, otherwise it returns false. + */ +static inline int usb_endpoint_xfer_control( + const struct usb_endpoint_descriptor *epd) +{ + return ((epd->bmAttributes & USB_ENDPOINT_XFERTYPE_MASK) == + USB_ENDPOINT_XFER_CONTROL); +} + +/** + * usb_endpoint_xfer_int - check if the endpoint has interrupt transfer type + * @epd: endpoint to be checked + * + * Returns true if the endpoint is of type interrupt, otherwise it returns + * false. + */ +static inline int usb_endpoint_xfer_int( + const struct usb_endpoint_descriptor *epd) +{ + return ((epd->bmAttributes & USB_ENDPOINT_XFERTYPE_MASK) == + USB_ENDPOINT_XFER_INT); +} + +/** + * usb_endpoint_xfer_isoc - check if the endpoint has isochronous transfer type + * @epd: endpoint to be checked + * + * Returns true if the endpoint is of type isochronous, otherwise it returns + * false. + */ +static inline int usb_endpoint_xfer_isoc( + const struct usb_endpoint_descriptor *epd) +{ + return ((epd->bmAttributes & USB_ENDPOINT_XFERTYPE_MASK) == + USB_ENDPOINT_XFER_ISOC); +} + +/** + * usb_endpoint_is_bulk_in - check if the endpoint is bulk IN + * @epd: endpoint to be checked + * + * Returns true if the endpoint has bulk transfer type and IN direction, + * otherwise it returns false. + */ +static inline int usb_endpoint_is_bulk_in( + const struct usb_endpoint_descriptor *epd) +{ + return usb_endpoint_xfer_bulk(epd) && usb_endpoint_dir_in(epd); +} + +/** + * usb_endpoint_is_bulk_out - check if the endpoint is bulk OUT + * @epd: endpoint to be checked + * + * Returns true if the endpoint has bulk transfer type and OUT direction, + * otherwise it returns false. + */ +static inline int usb_endpoint_is_bulk_out( + const struct usb_endpoint_descriptor *epd) +{ + return usb_endpoint_xfer_bulk(epd) && usb_endpoint_dir_out(epd); +} + +/** + * usb_endpoint_is_int_in - check if the endpoint is interrupt IN + * @epd: endpoint to be checked + * + * Returns true if the endpoint has interrupt transfer type and IN direction, + * otherwise it returns false. + */ +static inline int usb_endpoint_is_int_in( + const struct usb_endpoint_descriptor *epd) +{ + return usb_endpoint_xfer_int(epd) && usb_endpoint_dir_in(epd); +} + +/** + * usb_endpoint_is_int_out - check if the endpoint is interrupt OUT + * @epd: endpoint to be checked + * + * Returns true if the endpoint has interrupt transfer type and OUT direction, + * otherwise it returns false. + */ +static inline int usb_endpoint_is_int_out( + const struct usb_endpoint_descriptor *epd) +{ + return usb_endpoint_xfer_int(epd) && usb_endpoint_dir_out(epd); +} + +/** + * usb_endpoint_is_isoc_in - check if the endpoint is isochronous IN + * @epd: endpoint to be checked + * + * Returns true if the endpoint has isochronous transfer type and IN direction, + * otherwise it returns false. + */ +static inline int usb_endpoint_is_isoc_in( + const struct usb_endpoint_descriptor *epd) +{ + return usb_endpoint_xfer_isoc(epd) && usb_endpoint_dir_in(epd); +} + +/** + * usb_endpoint_is_isoc_out - check if the endpoint is isochronous OUT + * @epd: endpoint to be checked + * + * Returns true if the endpoint has isochronous transfer type and OUT direction, + * otherwise it returns false. + */ +static inline int usb_endpoint_is_isoc_out( + const struct usb_endpoint_descriptor *epd) +{ + return usb_endpoint_xfer_isoc(epd) && usb_endpoint_dir_out(epd); +} + +/** + * usb_endpoint_maxp - get endpoint's max packet size + * @epd: endpoint to be checked + * + * Returns @epd's max packet + */ +static inline int usb_endpoint_maxp(const struct usb_endpoint_descriptor *epd) +{ + return __le16_to_cpu(epd->wMaxPacketSize); +} + +static inline int usb_endpoint_interrupt_type( + const struct usb_endpoint_descriptor *epd) +{ + return epd->bmAttributes & USB_ENDPOINT_INTRTYPE; +} + +/*-------------------------------------------------------------------------*/ + +/* USB_DT_SS_ENDPOINT_COMP: SuperSpeed Endpoint Companion descriptor */ +struct usb_ss_ep_comp_descriptor { + __u8 bLength; + __u8 bDescriptorType; + + __u8 bMaxBurst; + __u8 bmAttributes; + __le16 wBytesPerInterval; +} __attribute__ ((packed)); + +#define USB_DT_SS_EP_COMP_SIZE 6 + +/* Bits 4:0 of bmAttributes if this is a bulk endpoint */ +static inline int +usb_ss_max_streams(const struct usb_ss_ep_comp_descriptor *comp) +{ + int max_streams; + + if (!comp) + return 0; + + max_streams = comp->bmAttributes & 0x1f; + + if (!max_streams) + return 0; + + max_streams = 1 << max_streams; + + return max_streams; +} + +/* Bits 1:0 of bmAttributes if this is an isoc endpoint */ +#define USB_SS_MULT(p) (1 + ((p) & 0x3))
@@ -388,7 +746,7 @@ struct usb_encryption_descriptor {
-/* USB_DT_BOS: group of wireless capabilities */ +/* USB_DT_BOS: group of device-level capabilities */ struct usb_bos_descriptor { __u8 bLength; __u8 bDescriptorType; @@ -397,6 +755,7 @@ struct usb_bos_descriptor { __u8 bNumDeviceCaps; } __attribute__((packed));
+#define USB_DT_BOS_SIZE 5 /*-------------------------------------------------------------------------*/
/* USB_DT_DEVICE_CAPABILITY: grouped with BOS */ @@ -434,6 +793,61 @@ struct usb_wireless_cap_descriptor { /* Ultra Wide Band */ __u8 bReserved; } __attribute__((packed));
+/* USB 2.0 Extension descriptor */ +#define USB_CAP_TYPE_EXT 2 + +struct usb_ext_cap_descriptor { /* Link Power Management */ + __u8 bLength; + __u8 bDescriptorType; + __u8 bDevCapabilityType; + __le32 bmAttributes; +#define USB_LPM_SUPPORT (1 << 1) /* supports LPM */ +#define USB_BESL_SUPPORT (1 << 2) /* supports BESL */ +#define USB_BESL_BASELINE_VALID (1 << 3) /* Baseline BESL valid*/ +#define USB_BESL_DEEP_VALID (1 << 4) /* Deep BESL valid */ +#define USB_GET_BESL_BASELINE(p) (((p) & (0xf << 8)) >> 8) +#define USB_GET_BESL_DEEP(p) (((p) & (0xf << 12)) >> 12) +} __attribute__((packed)); + +#define USB_DT_USB_EXT_CAP_SIZE 7 + +/* + * SuperSpeed USB Capability descriptor: Defines the set of SuperSpeed USB + * specific device level capabilities + */ +#define USB_SS_CAP_TYPE 3 +struct usb_ss_cap_descriptor { /* Link Power Management */ + __u8 bLength; + __u8 bDescriptorType; + __u8 bDevCapabilityType; + __u8 bmAttributes; +#define USB_LTM_SUPPORT (1 << 1) /* supports LTM */ + __le16 wSpeedSupported; +#define USB_LOW_SPEED_OPERATION (1) /* Low speed operation */ +#define USB_FULL_SPEED_OPERATION (1 << 1) /* Full speed operation */ +#define USB_HIGH_SPEED_OPERATION (1 << 2) /* High speed operation */ +#define USB_5GBPS_OPERATION (1 << 3) /* Operation at 5Gbps */ + __u8 bFunctionalitySupport; + __u8 bU1devExitLat; + __le16 bU2DevExitLat; +} __attribute__((packed)); + +#define USB_DT_USB_SS_CAP_SIZE 10 + +/* + * Container ID Capability descriptor: Defines the instance unique ID used to + * identify the instance across all operating modes + */ +#define CONTAINER_ID_TYPE 4 +struct usb_ss_container_id_descriptor { + __u8 bLength; + __u8 bDescriptorType; + __u8 bDevCapabilityType; + __u8 bReserved; + __u8 ContainerID[16]; /* 128-bit number */ +} __attribute__((packed)); + +#define USB_DT_USB_SS_CONTN_ID_SIZE 20 /*-------------------------------------------------------------------------*/
/* USB_DT_WIRELESS_ENDPOINT_COMP: companion descriptor associated with @@ -491,9 +905,22 @@ enum usb_device_speed { USB_SPEED_UNKNOWN = 0, /* enumerating */ USB_SPEED_LOW, USB_SPEED_FULL, /* usb 1.1 */ USB_SPEED_HIGH, /* usb 2.0 */ - USB_SPEED_VARIABLE, /* wireless (usb 2.5) */ + USB_SPEED_WIRELESS, /* wireless (usb 2.5) */ + USB_SPEED_SUPER, /* usb 3.0 */ };
+#ifdef __KERNEL__ + +/** + * usb_speed_string() - Returns human readable-name of the speed. + * @speed: The speed to return human-readable name for. If it's not + * any of the speeds defined in usb_device_speed enum, string for + * USB_SPEED_UNKNOWN will be returned. + */ +extern const char *usb_speed_string(enum usb_device_speed speed); + +#endif + enum usb_device_state { /* NOTATTACHED isn't in the USB spec, and this state acts * the same as ATTACHED ... but it's clearer this way. @@ -503,8 +930,8 @@ enum usb_device_state { /* chapter 9 and authentication (wireless) device states */ USB_STATE_ATTACHED, USB_STATE_POWERED, /* wired */ - USB_STATE_UNAUTHENTICATED, /* auth */ USB_STATE_RECONNECTING, /* auth */ + USB_STATE_UNAUTHENTICATED, /* auth */ USB_STATE_DEFAULT, /* limited function */ USB_STATE_ADDRESS, USB_STATE_CONFIGURED, /* most functions */ @@ -514,7 +941,64 @@ enum usb_device_state { /* NOTE: there are actually four different SUSPENDED * states, returning to POWERED, DEFAULT, ADDRESS, or * CONFIGURED respectively when SOF tokens flow again. + * At this level there's no difference between L1 and L2 + * suspend states. (L2 being original USB 1.1 suspend.) */ };
-#endif /* __LINUX_USB_CH9_H */ +enum usb3_link_state { + USB3_LPM_U0 = 0, + USB3_LPM_U1, + USB3_LPM_U2, + USB3_LPM_U3 +}; + +/* + * A U1 timeout of 0x0 means the parent hub will reject any transitions to U1. + * 0xff means the parent hub will accept transitions to U1, but will not + * initiate a transition. + * + * A U1 timeout of 0x1 to 0x7F also causes the hub to initiate a transition to + * U1 after that many microseconds. Timeouts of 0x80 to 0xFE are reserved + * values. + * + * A U2 timeout of 0x0 means the parent hub will reject any transitions to U2. + * 0xff means the parent hub will accept transitions to U2, but will not + * initiate a transition. + * + * A U2 timeout of 0x1 to 0xFE also causes the hub to initiate a transition to + * U2 after N*256 microseconds. Therefore a U2 timeout value of 0x1 means a U2 + * idle timer of 256 microseconds, 0x2 means 512 microseconds, 0xFE means + * 65.024ms. + */ +#define USB3_LPM_DISABLED 0x0 +#define USB3_LPM_U1_MAX_TIMEOUT 0x7F +#define USB3_LPM_U2_MAX_TIMEOUT 0xFE +#define USB3_LPM_DEVICE_INITIATED 0xFF + +struct usb_set_sel_req { + __u8 u1_sel; + __u8 u1_pel; + __le16 u2_sel; + __le16 u2_pel; +} __attribute__ ((packed)); + +/* + * The Set System Exit Latency control transfer provides one byte each for + * U1 SEL and U1 PEL, so the max exit latency is 0xFF. U2 SEL and U2 PEL each + * are two bytes long. + */ +#define USB3_LPM_MAX_U1_SEL_PEL 0xFF +#define USB3_LPM_MAX_U2_SEL_PEL 0xFFFF + +/*-------------------------------------------------------------------------*/ + +/* + * As per USB compliance update, a device that is actively drawing + * more than 100mA from USB must report itself as bus-powered in + * the GetStatus(DEVICE) call. + * http://compliance.usb.org/index.asp?UpdateFile=Electrical&Format=Standar... + */ +#define USB_SELF_POWER_VBUS_MAX_DRAW 100 + +#endif /* __LINUX_USB_CH9_H */ diff --git a/include/usb/s3c_udc.h b/include/usb/s3c_udc.h index 6a8fd44..7114dae 100644 --- a/include/usb/s3c_udc.h +++ b/include/usb/s3c_udc.h @@ -24,7 +24,6 @@
#include <asm/errno.h> #include <linux/usb/ch9.h> -#include <usbdescriptors.h> #include <linux/usb/gadget.h> #include <linux/list.h> #include <usb/lin_gadget_compat.h>
Existing U-Boot musb driver has no support for the new gadget framework and also seems to have other limitations. As gadget framework is ported from Linux it seems pretty natural to port musb gadget driver as well.
This is not a replacement for current musb driver (at least now) as host mode is not supported and there are still some consumers of the old UDC interface.
No DMA operation support included, CONFIG_MUSB_PIO_ONLY should be defined.
Signed-off-by: Ilya Yanok ilya.yanok@cogentembedded.com --- Makefile | 1 + drivers/usb/gadget/gadget_chips.h | 2 + drivers/usb/musb-new/Makefile | 35 + drivers/usb/musb-new/musb_core.c | 2489 ++++++++++++++++++++++++++++++ drivers/usb/musb-new/musb_core.h | 611 ++++++++ drivers/usb/musb-new/musb_debug.h | 58 + drivers/usb/musb-new/musb_dma.h | 186 +++ drivers/usb/musb-new/musb_gadget.c | 2319 ++++++++++++++++++++++++++++ drivers/usb/musb-new/musb_gadget.h | 127 ++ drivers/usb/musb-new/musb_gadget_ep0.c | 1089 +++++++++++++ drivers/usb/musb-new/musb_gadget_uboot.c | 72 + drivers/usb/musb-new/musb_io.h | 146 ++ drivers/usb/musb-new/musb_regs.h | 645 ++++++++ include/linux/usb/musb.h | 162 ++ 14 files changed, 7942 insertions(+) create mode 100644 drivers/usb/musb-new/Makefile create mode 100644 drivers/usb/musb-new/musb_core.c create mode 100644 drivers/usb/musb-new/musb_core.h create mode 100644 drivers/usb/musb-new/musb_debug.h create mode 100644 drivers/usb/musb-new/musb_dma.h create mode 100644 drivers/usb/musb-new/musb_gadget.c create mode 100644 drivers/usb/musb-new/musb_gadget.h create mode 100644 drivers/usb/musb-new/musb_gadget_ep0.c create mode 100644 drivers/usb/musb-new/musb_gadget_uboot.c create mode 100644 drivers/usb/musb-new/musb_io.h create mode 100644 drivers/usb/musb-new/musb_regs.h create mode 100644 include/linux/usb/musb.h
diff --git a/Makefile b/Makefile index 8b555fb..2e82429 100644 --- a/Makefile +++ b/Makefile @@ -296,6 +296,7 @@ LIBS += drivers/usb/eth/libusb_eth.o LIBS += drivers/usb/gadget/libusb_gadget.o LIBS += drivers/usb/host/libusb_host.o LIBS += drivers/usb/musb/libusb_musb.o +LIBS += drivers/usb/musb-new/libusb_musb-new.o LIBS += drivers/usb/phy/libusb_phy.o LIBS += drivers/usb/ulpi/libusb_ulpi.o LIBS += drivers/video/libvideo.o diff --git a/drivers/usb/gadget/gadget_chips.h b/drivers/usb/gadget/gadget_chips.h index 5d7b638..3b1db2e 100644 --- a/drivers/usb/gadget/gadget_chips.h +++ b/drivers/usb/gadget/gadget_chips.h @@ -133,6 +133,8 @@ /* Mentor high speed "dual role" controller, in peripheral role */ #ifdef CONFIG_USB_GADGET_MUSB_HDRC #define gadget_is_musbhdrc(g) (!strcmp("musb_hdrc", (g)->name)) +#elif defined(CONFIG_MUSB_GADGET) +#define gadget_is_musbhdrc(g) (!strcmp("musb-hdrc", (g)->name)) #else #define gadget_is_musbhdrc(g) 0 #endif diff --git a/drivers/usb/musb-new/Makefile b/drivers/usb/musb-new/Makefile new file mode 100644 index 0000000..a518dcd --- /dev/null +++ b/drivers/usb/musb-new/Makefile @@ -0,0 +1,35 @@ +# +# for USB OTG silicon based on Mentor Graphics INVENTRA designs +# + +include $(TOPDIR)/config.mk + +LIB := $(obj)libusb_musb-new.o + +COBJS-$(CONFIG_MUSB_GADGET) += musb_gadget.o musb_gadget_ep0.o musb_core.o +COBJS-$(CONFIG_MUSB_GADGET) += musb_gadget_uboot.o + +CFLAGS_NO_WARN := $(call cc-option,-Wno-unused-variable) \ + $(call cc-option,-Wno-unused-but-set-variable) \ + $(call cc-option,-Wno-unused-label) +CFLAGS += $(CFLAGS_NO_WARN) + +COBJS := $(COBJS-y) +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +all: $(LIB) + +#$(LIB): $(OBJS) +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### + diff --git a/drivers/usb/musb-new/musb_core.c b/drivers/usb/musb-new/musb_core.c new file mode 100644 index 0000000..063dc8d --- /dev/null +++ b/drivers/usb/musb-new/musb_core.c @@ -0,0 +1,2489 @@ +/* + * MUSB OTG driver core code + * + * Copyright 2005 Mentor Graphics Corporation + * Copyright (C) 2005-2006 by Texas Instruments + * Copyright (C) 2006-2007 Nokia Corporation + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, but + * WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU + * General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA + * 02110-1301 USA + * + * THIS SOFTWARE IS PROVIDED "AS IS" AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN + * NO EVENT SHALL THE AUTHORS BE LIABLE FOR ANY DIRECT, INDIRECT, + * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT + * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF + * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON + * ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT + * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF + * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. + * + */ + +/* + * Inventra (Multipoint) Dual-Role Controller Driver for Linux. + * + * This consists of a Host Controller Driver (HCD) and a peripheral + * controller driver implementing the "Gadget" API; OTG support is + * in the works. These are normal Linux-USB controller drivers which + * use IRQs and have no dedicated thread. + * + * This version of the driver has only been used with products from + * Texas Instruments. Those products integrate the Inventra logic + * with other DMA, IRQ, and bus modules, as well as other logic that + * needs to be reflected in this driver. + * + * + * NOTE: the original Mentor code here was pretty much a collection + * of mechanisms that don't seem to have been fully integrated/working + * for *any* Linux kernel version. This version aims at Linux 2.6.now, + * Key open issues include: + * + * - Lack of host-side transaction scheduling, for all transfer types. + * The hardware doesn't do it; instead, software must. + * + * This is not an issue for OTG devices that don't support external + * hubs, but for more "normal" USB hosts it's a user issue that the + * "multipoint" support doesn't scale in the expected ways. That + * includes DaVinci EVM in a common non-OTG mode. + * + * * Control and bulk use dedicated endpoints, and there's as + * yet no mechanism to either (a) reclaim the hardware when + * peripherals are NAKing, which gets complicated with bulk + * endpoints, or (b) use more than a single bulk endpoint in + * each direction. + * + * RESULT: one device may be perceived as blocking another one. + * + * * Interrupt and isochronous will dynamically allocate endpoint + * hardware, but (a) there's no record keeping for bandwidth; + * (b) in the common case that few endpoints are available, there + * is no mechanism to reuse endpoints to talk to multiple devices. + * + * RESULT: At one extreme, bandwidth can be overcommitted in + * some hardware configurations, no faults will be reported. + * At the other extreme, the bandwidth capabilities which do + * exist tend to be severely undercommitted. You can't yet hook + * up both a keyboard and a mouse to an external USB hub. + */ + +/* + * This gets many kinds of configuration information: + * - Kconfig for everything user-configurable + * - platform_device for addressing, irq, and platform_data + * - platform_data is mostly for board-specific informarion + * (plus recentrly, SOC or family details) + * + * Most of the conditional compilation will (someday) vanish. + */ + +#define __UBOOT__ +#ifndef __UBOOT__ +#include <linux/module.h> +#include <linux/kernel.h> +#include <linux/sched.h> +#include <linux/slab.h> +#include <linux/init.h> +#include <linux/list.h> +#include <linux/kobject.h> +#include <linux/prefetch.h> +#include <linux/platform_device.h> +#include <linux/io.h> +#else +#include <common.h> +#include <asm/errno.h> +#include <linux/usb/ch9.h> +#include <linux/usb/gadget.h> +#include <linux/usb/musb.h> +#include <asm/io.h> +#include "linux-compat.h" +#endif + +#include "musb_core.h" + +#define TA_WAIT_BCON(m) max_t(int, (m)->a_wait_bcon, OTG_TIME_A_WAIT_BCON) + + +#define DRIVER_AUTHOR "Mentor Graphics, Texas Instruments, Nokia" +#define DRIVER_DESC "Inventra Dual-Role USB Controller Driver" + +#define MUSB_VERSION "6.0" + +#define DRIVER_INFO DRIVER_DESC ", v" MUSB_VERSION + +#define MUSB_DRIVER_NAME "musb-hdrc" +const char musb_driver_name[] = MUSB_DRIVER_NAME; + +MODULE_DESCRIPTION(DRIVER_INFO); +MODULE_AUTHOR(DRIVER_AUTHOR); +MODULE_LICENSE("GPL"); +MODULE_ALIAS("platform:" MUSB_DRIVER_NAME); + + +#ifndef __UBOOT__ +/*-------------------------------------------------------------------------*/ + +static inline struct musb *dev_to_musb(struct device *dev) +{ + return dev_get_drvdata(dev); +} +#endif + +/*-------------------------------------------------------------------------*/ + +#ifndef __UBOOT__ +#ifndef CONFIG_BLACKFIN +static int musb_ulpi_read(struct usb_phy *phy, u32 offset) +{ + void __iomem *addr = phy->io_priv; + int i = 0; + u8 r; + u8 power; + int ret; + + pm_runtime_get_sync(phy->io_dev); + + /* Make sure the transceiver is not in low power mode */ + power = musb_readb(addr, MUSB_POWER); + power &= ~MUSB_POWER_SUSPENDM; + musb_writeb(addr, MUSB_POWER, power); + + /* REVISIT: musbhdrc_ulpi_an.pdf recommends setting the + * ULPICarKitControlDisableUTMI after clearing POWER_SUSPENDM. + */ + + musb_writeb(addr, MUSB_ULPI_REG_ADDR, (u8)offset); + musb_writeb(addr, MUSB_ULPI_REG_CONTROL, + MUSB_ULPI_REG_REQ | MUSB_ULPI_RDN_WR); + + while (!(musb_readb(addr, MUSB_ULPI_REG_CONTROL) + & MUSB_ULPI_REG_CMPLT)) { + i++; + if (i == 10000) { + ret = -ETIMEDOUT; + goto out; + } + + } + r = musb_readb(addr, MUSB_ULPI_REG_CONTROL); + r &= ~MUSB_ULPI_REG_CMPLT; + musb_writeb(addr, MUSB_ULPI_REG_CONTROL, r); + + ret = musb_readb(addr, MUSB_ULPI_REG_DATA); + +out: + pm_runtime_put(phy->io_dev); + + return ret; +} + +static int musb_ulpi_write(struct usb_phy *phy, u32 offset, u32 data) +{ + void __iomem *addr = phy->io_priv; + int i = 0; + u8 r = 0; + u8 power; + int ret = 0; + + pm_runtime_get_sync(phy->io_dev); + + /* Make sure the transceiver is not in low power mode */ + power = musb_readb(addr, MUSB_POWER); + power &= ~MUSB_POWER_SUSPENDM; + musb_writeb(addr, MUSB_POWER, power); + + musb_writeb(addr, MUSB_ULPI_REG_ADDR, (u8)offset); + musb_writeb(addr, MUSB_ULPI_REG_DATA, (u8)data); + musb_writeb(addr, MUSB_ULPI_REG_CONTROL, MUSB_ULPI_REG_REQ); + + while (!(musb_readb(addr, MUSB_ULPI_REG_CONTROL) + & MUSB_ULPI_REG_CMPLT)) { + i++; + if (i == 10000) { + ret = -ETIMEDOUT; + goto out; + } + } + + r = musb_readb(addr, MUSB_ULPI_REG_CONTROL); + r &= ~MUSB_ULPI_REG_CMPLT; + musb_writeb(addr, MUSB_ULPI_REG_CONTROL, r); + +out: + pm_runtime_put(phy->io_dev); + + return ret; +} +#else +#define musb_ulpi_read NULL +#define musb_ulpi_write NULL +#endif + +static struct usb_phy_io_ops musb_ulpi_access = { + .read = musb_ulpi_read, + .write = musb_ulpi_write, +}; +#endif + +/*-------------------------------------------------------------------------*/ + +#if !defined(CONFIG_USB_MUSB_TUSB6010) && !defined(CONFIG_USB_MUSB_BLACKFIN) + +/* + * Load an endpoint's FIFO + */ +void musb_write_fifo(struct musb_hw_ep *hw_ep, u16 len, const u8 *src) +{ + struct musb *musb = hw_ep->musb; + void __iomem *fifo = hw_ep->fifo; + + prefetch((u8 *)src); + + dev_dbg(musb->controller, "%cX ep%d fifo %p count %d buf %p\n", + 'T', hw_ep->epnum, fifo, len, src); + + /* we can't assume unaligned reads work */ + if (likely((0x01 & (unsigned long) src) == 0)) { + u16 index = 0; + + /* best case is 32bit-aligned source address */ + if ((0x02 & (unsigned long) src) == 0) { + if (len >= 4) { + writesl(fifo, src + index, len >> 2); + index += len & ~0x03; + } + if (len & 0x02) { + musb_writew(fifo, 0, *(u16 *)&src[index]); + index += 2; + } + } else { + if (len >= 2) { + writesw(fifo, src + index, len >> 1); + index += len & ~0x01; + } + } + if (len & 0x01) + musb_writeb(fifo, 0, src[index]); + } else { + /* byte aligned */ + writesb(fifo, src, len); + } +} + +#if !defined(CONFIG_USB_MUSB_AM35X) +/* + * Unload an endpoint's FIFO + */ +void musb_read_fifo(struct musb_hw_ep *hw_ep, u16 len, u8 *dst) +{ + struct musb *musb = hw_ep->musb; + void __iomem *fifo = hw_ep->fifo; + + dev_dbg(musb->controller, "%cX ep%d fifo %p count %d buf %p\n", + 'R', hw_ep->epnum, fifo, len, dst); + + /* we can't assume unaligned writes work */ + if (likely((0x01 & (unsigned long) dst) == 0)) { + u16 index = 0; + + /* best case is 32bit-aligned destination address */ + if ((0x02 & (unsigned long) dst) == 0) { + if (len >= 4) { + readsl(fifo, dst, len >> 2); + index = len & ~0x03; + } + if (len & 0x02) { + *(u16 *)&dst[index] = musb_readw(fifo, 0); + index += 2; + } + } else { + if (len >= 2) { + readsw(fifo, dst, len >> 1); + index = len & ~0x01; + } + } + if (len & 0x01) + dst[index] = musb_readb(fifo, 0); + } else { + /* byte aligned */ + readsb(fifo, dst, len); + } +} +#endif + +#endif /* normal PIO */ + + +/*-------------------------------------------------------------------------*/ + +/* for high speed test mode; see USB 2.0 spec 7.1.20 */ +static const u8 musb_test_packet[53] = { + /* implicit SYNC then DATA0 to start */ + + /* JKJKJKJK x9 */ + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + /* JJKKJJKK x8 */ + 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, + /* JJJJKKKK x8 */ + 0xee, 0xee, 0xee, 0xee, 0xee, 0xee, 0xee, 0xee, + /* JJJJJJJKKKKKKK x8 */ + 0xfe, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + /* JJJJJJJK x8 */ + 0x7f, 0xbf, 0xdf, 0xef, 0xf7, 0xfb, 0xfd, + /* JKKKKKKK x10, JK */ + 0xfc, 0x7e, 0xbf, 0xdf, 0xef, 0xf7, 0xfb, 0xfd, 0x7e + + /* implicit CRC16 then EOP to end */ +}; + +void musb_load_testpacket(struct musb *musb) +{ + void __iomem *regs = musb->endpoints[0].regs; + + musb_ep_select(musb->mregs, 0); + musb_write_fifo(musb->control_ep, + sizeof(musb_test_packet), musb_test_packet); + musb_writew(regs, MUSB_CSR0, MUSB_CSR0_TXPKTRDY); +} + +#ifndef __UBOOT__ +/*-------------------------------------------------------------------------*/ + +/* + * Handles OTG hnp timeouts, such as b_ase0_brst + */ +void musb_otg_timer_func(unsigned long data) +{ + struct musb *musb = (struct musb *)data; + unsigned long flags; + + spin_lock_irqsave(&musb->lock, flags); + switch (musb->xceiv->state) { + case OTG_STATE_B_WAIT_ACON: + dev_dbg(musb->controller, "HNP: b_wait_acon timeout; back to b_peripheral\n"); + musb_g_disconnect(musb); + musb->xceiv->state = OTG_STATE_B_PERIPHERAL; + musb->is_active = 0; + break; + case OTG_STATE_A_SUSPEND: + case OTG_STATE_A_WAIT_BCON: + dev_dbg(musb->controller, "HNP: %s timeout\n", + otg_state_string(musb->xceiv->state)); + musb_platform_set_vbus(musb, 0); + musb->xceiv->state = OTG_STATE_A_WAIT_VFALL; + break; + default: + dev_dbg(musb->controller, "HNP: Unhandled mode %s\n", + otg_state_string(musb->xceiv->state)); + } + musb->ignore_disconnect = 0; + spin_unlock_irqrestore(&musb->lock, flags); +} + +/* + * Stops the HNP transition. Caller must take care of locking. + */ +void musb_hnp_stop(struct musb *musb) +{ + struct usb_hcd *hcd = musb_to_hcd(musb); + void __iomem *mbase = musb->mregs; + u8 reg; + + dev_dbg(musb->controller, "HNP: stop from %s\n", otg_state_string(musb->xceiv->state)); + + switch (musb->xceiv->state) { + case OTG_STATE_A_PERIPHERAL: + musb_g_disconnect(musb); + dev_dbg(musb->controller, "HNP: back to %s\n", + otg_state_string(musb->xceiv->state)); + break; + case OTG_STATE_B_HOST: + dev_dbg(musb->controller, "HNP: Disabling HR\n"); + hcd->self.is_b_host = 0; + musb->xceiv->state = OTG_STATE_B_PERIPHERAL; + MUSB_DEV_MODE(musb); + reg = musb_readb(mbase, MUSB_POWER); + reg |= MUSB_POWER_SUSPENDM; + musb_writeb(mbase, MUSB_POWER, reg); + /* REVISIT: Start SESSION_REQUEST here? */ + break; + default: + dev_dbg(musb->controller, "HNP: Stopping in unknown state %s\n", + otg_state_string(musb->xceiv->state)); + } + + /* + * When returning to A state after HNP, avoid hub_port_rebounce(), + * which cause occasional OPT A "Did not receive reset after connect" + * errors. + */ + musb->port1_status &= ~(USB_PORT_STAT_C_CONNECTION << 16); +} + +/* + * Interrupt Service Routine to record USB "global" interrupts. + * Since these do not happen often and signify things of + * paramount importance, it seems OK to check them individually; + * the order of the tests is specified in the manual + * + * @param musb instance pointer + * @param int_usb register contents + * @param devctl + * @param power + */ + +static irqreturn_t musb_stage0_irq(struct musb *musb, u8 int_usb, + u8 devctl, u8 power) +{ + struct usb_otg *otg = musb->xceiv->otg; + irqreturn_t handled = IRQ_NONE; + + dev_dbg(musb->controller, "<== Power=%02x, DevCtl=%02x, int_usb=0x%x\n", power, devctl, + int_usb); + + /* in host mode, the peripheral may issue remote wakeup. + * in peripheral mode, the host may resume the link. + * spurious RESUME irqs happen too, paired with SUSPEND. + */ + if (int_usb & MUSB_INTR_RESUME) { + handled = IRQ_HANDLED; + dev_dbg(musb->controller, "RESUME (%s)\n", otg_state_string(musb->xceiv->state)); + + if (devctl & MUSB_DEVCTL_HM) { + void __iomem *mbase = musb->mregs; + + switch (musb->xceiv->state) { + case OTG_STATE_A_SUSPEND: + /* remote wakeup? later, GetPortStatus + * will stop RESUME signaling + */ + + if (power & MUSB_POWER_SUSPENDM) { + /* spurious */ + musb->int_usb &= ~MUSB_INTR_SUSPEND; + dev_dbg(musb->controller, "Spurious SUSPENDM\n"); + break; + } + + power &= ~MUSB_POWER_SUSPENDM; + musb_writeb(mbase, MUSB_POWER, + power | MUSB_POWER_RESUME); + + musb->port1_status |= + (USB_PORT_STAT_C_SUSPEND << 16) + | MUSB_PORT_STAT_RESUME; + musb->rh_timer = jiffies + + msecs_to_jiffies(20); + + musb->xceiv->state = OTG_STATE_A_HOST; + musb->is_active = 1; + usb_hcd_resume_root_hub(musb_to_hcd(musb)); + break; + case OTG_STATE_B_WAIT_ACON: + musb->xceiv->state = OTG_STATE_B_PERIPHERAL; + musb->is_active = 1; + MUSB_DEV_MODE(musb); + break; + default: + WARNING("bogus %s RESUME (%s)\n", + "host", + otg_state_string(musb->xceiv->state)); + } + } else { + switch (musb->xceiv->state) { + case OTG_STATE_A_SUSPEND: + /* possibly DISCONNECT is upcoming */ + musb->xceiv->state = OTG_STATE_A_HOST; + usb_hcd_resume_root_hub(musb_to_hcd(musb)); + break; + case OTG_STATE_B_WAIT_ACON: + case OTG_STATE_B_PERIPHERAL: + /* disconnect while suspended? we may + * not get a disconnect irq... + */ + if ((devctl & MUSB_DEVCTL_VBUS) + != (3 << MUSB_DEVCTL_VBUS_SHIFT) + ) { + musb->int_usb |= MUSB_INTR_DISCONNECT; + musb->int_usb &= ~MUSB_INTR_SUSPEND; + break; + } + musb_g_resume(musb); + break; + case OTG_STATE_B_IDLE: + musb->int_usb &= ~MUSB_INTR_SUSPEND; + break; + default: + WARNING("bogus %s RESUME (%s)\n", + "peripheral", + otg_state_string(musb->xceiv->state)); + } + } + } + + /* see manual for the order of the tests */ + if (int_usb & MUSB_INTR_SESSREQ) { + void __iomem *mbase = musb->mregs; + + if ((devctl & MUSB_DEVCTL_VBUS) == MUSB_DEVCTL_VBUS + && (devctl & MUSB_DEVCTL_BDEVICE)) { + dev_dbg(musb->controller, "SessReq while on B state\n"); + return IRQ_HANDLED; + } + + dev_dbg(musb->controller, "SESSION_REQUEST (%s)\n", + otg_state_string(musb->xceiv->state)); + + /* IRQ arrives from ID pin sense or (later, if VBUS power + * is removed) SRP. responses are time critical: + * - turn on VBUS (with silicon-specific mechanism) + * - go through A_WAIT_VRISE + * - ... to A_WAIT_BCON. + * a_wait_vrise_tmout triggers VBUS_ERROR transitions + */ + musb_writeb(mbase, MUSB_DEVCTL, MUSB_DEVCTL_SESSION); + musb->ep0_stage = MUSB_EP0_START; + musb->xceiv->state = OTG_STATE_A_IDLE; + MUSB_HST_MODE(musb); + musb_platform_set_vbus(musb, 1); + + handled = IRQ_HANDLED; + } + + if (int_usb & MUSB_INTR_VBUSERROR) { + int ignore = 0; + + /* During connection as an A-Device, we may see a short + * current spikes causing voltage drop, because of cable + * and peripheral capacitance combined with vbus draw. + * (So: less common with truly self-powered devices, where + * vbus doesn't act like a power supply.) + * + * Such spikes are short; usually less than ~500 usec, max + * of ~2 msec. That is, they're not sustained overcurrent + * errors, though they're reported using VBUSERROR irqs. + * + * Workarounds: (a) hardware: use self powered devices. + * (b) software: ignore non-repeated VBUS errors. + * + * REVISIT: do delays from lots of DEBUG_KERNEL checks + * make trouble here, keeping VBUS < 4.4V ? + */ + switch (musb->xceiv->state) { + case OTG_STATE_A_HOST: + /* recovery is dicey once we've gotten past the + * initial stages of enumeration, but if VBUS + * stayed ok at the other end of the link, and + * another reset is due (at least for high speed, + * to redo the chirp etc), it might work OK... + */ + case OTG_STATE_A_WAIT_BCON: + case OTG_STATE_A_WAIT_VRISE: + if (musb->vbuserr_retry) { + void __iomem *mbase = musb->mregs; + + musb->vbuserr_retry--; + ignore = 1; + devctl |= MUSB_DEVCTL_SESSION; + musb_writeb(mbase, MUSB_DEVCTL, devctl); + } else { + musb->port1_status |= + USB_PORT_STAT_OVERCURRENT + | (USB_PORT_STAT_C_OVERCURRENT << 16); + } + break; + default: + break; + } + + dev_dbg(musb->controller, "VBUS_ERROR in %s (%02x, %s), retry #%d, port1 %08x\n", + otg_state_string(musb->xceiv->state), + devctl, + ({ char *s; + switch (devctl & MUSB_DEVCTL_VBUS) { + case 0 << MUSB_DEVCTL_VBUS_SHIFT: + s = "<SessEnd"; break; + case 1 << MUSB_DEVCTL_VBUS_SHIFT: + s = "<AValid"; break; + case 2 << MUSB_DEVCTL_VBUS_SHIFT: + s = "<VBusValid"; break; + /* case 3 << MUSB_DEVCTL_VBUS_SHIFT: */ + default: + s = "VALID"; break; + }; s; }), + VBUSERR_RETRY_COUNT - musb->vbuserr_retry, + musb->port1_status); + + /* go through A_WAIT_VFALL then start a new session */ + if (!ignore) + musb_platform_set_vbus(musb, 0); + handled = IRQ_HANDLED; + } + + if (int_usb & MUSB_INTR_SUSPEND) { + dev_dbg(musb->controller, "SUSPEND (%s) devctl %02x power %02x\n", + otg_state_string(musb->xceiv->state), devctl, power); + handled = IRQ_HANDLED; + + switch (musb->xceiv->state) { + case OTG_STATE_A_PERIPHERAL: + /* We also come here if the cable is removed, since + * this silicon doesn't report ID-no-longer-grounded. + * + * We depend on T(a_wait_bcon) to shut us down, and + * hope users don't do anything dicey during this + * undesired detour through A_WAIT_BCON. + */ + musb_hnp_stop(musb); + usb_hcd_resume_root_hub(musb_to_hcd(musb)); + musb_root_disconnect(musb); + musb_platform_try_idle(musb, jiffies + + msecs_to_jiffies(musb->a_wait_bcon + ? : OTG_TIME_A_WAIT_BCON)); + + break; + case OTG_STATE_B_IDLE: + if (!musb->is_active) + break; + case OTG_STATE_B_PERIPHERAL: + musb_g_suspend(musb); + musb->is_active = is_otg_enabled(musb) + && otg->gadget->b_hnp_enable; + if (musb->is_active) { + musb->xceiv->state = OTG_STATE_B_WAIT_ACON; + dev_dbg(musb->controller, "HNP: Setting timer for b_ase0_brst\n"); + mod_timer(&musb->otg_timer, jiffies + + msecs_to_jiffies( + OTG_TIME_B_ASE0_BRST)); + } + break; + case OTG_STATE_A_WAIT_BCON: + if (musb->a_wait_bcon != 0) + musb_platform_try_idle(musb, jiffies + + msecs_to_jiffies(musb->a_wait_bcon)); + break; + case OTG_STATE_A_HOST: + musb->xceiv->state = OTG_STATE_A_SUSPEND; + musb->is_active = is_otg_enabled(musb) + && otg->host->b_hnp_enable; + break; + case OTG_STATE_B_HOST: + /* Transition to B_PERIPHERAL, see 6.8.2.6 p 44 */ + dev_dbg(musb->controller, "REVISIT: SUSPEND as B_HOST\n"); + break; + default: + /* "should not happen" */ + musb->is_active = 0; + break; + } + } + + if (int_usb & MUSB_INTR_CONNECT) { + struct usb_hcd *hcd = musb_to_hcd(musb); + + handled = IRQ_HANDLED; + musb->is_active = 1; + + musb->ep0_stage = MUSB_EP0_START; + + /* flush endpoints when transitioning from Device Mode */ + if (is_peripheral_active(musb)) { + /* REVISIT HNP; just force disconnect */ + } + musb_writew(musb->mregs, MUSB_INTRTXE, musb->epmask); + musb_writew(musb->mregs, MUSB_INTRRXE, musb->epmask & 0xfffe); + musb_writeb(musb->mregs, MUSB_INTRUSBE, 0xf7); + musb->port1_status &= ~(USB_PORT_STAT_LOW_SPEED + |USB_PORT_STAT_HIGH_SPEED + |USB_PORT_STAT_ENABLE + ); + musb->port1_status |= USB_PORT_STAT_CONNECTION + |(USB_PORT_STAT_C_CONNECTION << 16); + + /* high vs full speed is just a guess until after reset */ + if (devctl & MUSB_DEVCTL_LSDEV) + musb->port1_status |= USB_PORT_STAT_LOW_SPEED; + + /* indicate new connection to OTG machine */ + switch (musb->xceiv->state) { + case OTG_STATE_B_PERIPHERAL: + if (int_usb & MUSB_INTR_SUSPEND) { + dev_dbg(musb->controller, "HNP: SUSPEND+CONNECT, now b_host\n"); + int_usb &= ~MUSB_INTR_SUSPEND; + goto b_host; + } else + dev_dbg(musb->controller, "CONNECT as b_peripheral???\n"); + break; + case OTG_STATE_B_WAIT_ACON: + dev_dbg(musb->controller, "HNP: CONNECT, now b_host\n"); +b_host: + musb->xceiv->state = OTG_STATE_B_HOST; + hcd->self.is_b_host = 1; + musb->ignore_disconnect = 0; + del_timer(&musb->otg_timer); + break; + default: + if ((devctl & MUSB_DEVCTL_VBUS) + == (3 << MUSB_DEVCTL_VBUS_SHIFT)) { + musb->xceiv->state = OTG_STATE_A_HOST; + hcd->self.is_b_host = 0; + } + break; + } + + /* poke the root hub */ + MUSB_HST_MODE(musb); + if (hcd->status_urb) + usb_hcd_poll_rh_status(hcd); + else + usb_hcd_resume_root_hub(hcd); + + dev_dbg(musb->controller, "CONNECT (%s) devctl %02x\n", + otg_state_string(musb->xceiv->state), devctl); + } + + if ((int_usb & MUSB_INTR_DISCONNECT) && !musb->ignore_disconnect) { + dev_dbg(musb->controller, "DISCONNECT (%s) as %s, devctl %02x\n", + otg_state_string(musb->xceiv->state), + MUSB_MODE(musb), devctl); + handled = IRQ_HANDLED; + + switch (musb->xceiv->state) { + case OTG_STATE_A_HOST: + case OTG_STATE_A_SUSPEND: + usb_hcd_resume_root_hub(musb_to_hcd(musb)); + musb_root_disconnect(musb); + if (musb->a_wait_bcon != 0 && is_otg_enabled(musb)) + musb_platform_try_idle(musb, jiffies + + msecs_to_jiffies(musb->a_wait_bcon)); + break; + case OTG_STATE_B_HOST: + /* REVISIT this behaves for "real disconnect" + * cases; make sure the other transitions from + * from B_HOST act right too. The B_HOST code + * in hnp_stop() is currently not used... + */ + musb_root_disconnect(musb); + musb_to_hcd(musb)->self.is_b_host = 0; + musb->xceiv->state = OTG_STATE_B_PERIPHERAL; + MUSB_DEV_MODE(musb); + musb_g_disconnect(musb); + break; + case OTG_STATE_A_PERIPHERAL: + musb_hnp_stop(musb); + musb_root_disconnect(musb); + /* FALLTHROUGH */ + case OTG_STATE_B_WAIT_ACON: + /* FALLTHROUGH */ + case OTG_STATE_B_PERIPHERAL: + case OTG_STATE_B_IDLE: + musb_g_disconnect(musb); + break; + default: + WARNING("unhandled DISCONNECT transition (%s)\n", + otg_state_string(musb->xceiv->state)); + break; + } + } + + /* mentor saves a bit: bus reset and babble share the same irq. + * only host sees babble; only peripheral sees bus reset. + */ + if (int_usb & MUSB_INTR_RESET) { + handled = IRQ_HANDLED; + if (is_host_capable() && (devctl & MUSB_DEVCTL_HM) != 0) { + /* + * Looks like non-HS BABBLE can be ignored, but + * HS BABBLE is an error condition. For HS the solution + * is to avoid babble in the first place and fix what + * caused BABBLE. When HS BABBLE happens we can only + * stop the session. + */ + if (devctl & (MUSB_DEVCTL_FSDEV | MUSB_DEVCTL_LSDEV)) + dev_dbg(musb->controller, "BABBLE devctl: %02x\n", devctl); + else { + ERR("Stopping host session -- babble\n"); + musb_writeb(musb->mregs, MUSB_DEVCTL, 0); + } + } else if (is_peripheral_capable()) { + dev_dbg(musb->controller, "BUS RESET as %s\n", + otg_state_string(musb->xceiv->state)); + switch (musb->xceiv->state) { + case OTG_STATE_A_SUSPEND: + /* We need to ignore disconnect on suspend + * otherwise tusb 2.0 won't reconnect after a + * power cycle, which breaks otg compliance. + */ + musb->ignore_disconnect = 1; + musb_g_reset(musb); + /* FALLTHROUGH */ + case OTG_STATE_A_WAIT_BCON: /* OPT TD.4.7-900ms */ + /* never use invalid T(a_wait_bcon) */ + dev_dbg(musb->controller, "HNP: in %s, %d msec timeout\n", + otg_state_string(musb->xceiv->state), + TA_WAIT_BCON(musb)); + mod_timer(&musb->otg_timer, jiffies + + msecs_to_jiffies(TA_WAIT_BCON(musb))); + break; + case OTG_STATE_A_PERIPHERAL: + musb->ignore_disconnect = 0; + del_timer(&musb->otg_timer); + musb_g_reset(musb); + break; + case OTG_STATE_B_WAIT_ACON: + dev_dbg(musb->controller, "HNP: RESET (%s), to b_peripheral\n", + otg_state_string(musb->xceiv->state)); + musb->xceiv->state = OTG_STATE_B_PERIPHERAL; + musb_g_reset(musb); + break; + case OTG_STATE_B_IDLE: + musb->xceiv->state = OTG_STATE_B_PERIPHERAL; + /* FALLTHROUGH */ + case OTG_STATE_B_PERIPHERAL: + musb_g_reset(musb); + break; + default: + dev_dbg(musb->controller, "Unhandled BUS RESET as %s\n", + otg_state_string(musb->xceiv->state)); + } + } + } + +#if 0 +/* REVISIT ... this would be for multiplexing periodic endpoints, or + * supporting transfer phasing to prevent exceeding ISO bandwidth + * limits of a given frame or microframe. + * + * It's not needed for peripheral side, which dedicates endpoints; + * though it _might_ use SOF irqs for other purposes. + * + * And it's not currently needed for host side, which also dedicates + * endpoints, relies on TX/RX interval registers, and isn't claimed + * to support ISO transfers yet. + */ + if (int_usb & MUSB_INTR_SOF) { + void __iomem *mbase = musb->mregs; + struct musb_hw_ep *ep; + u8 epnum; + u16 frame; + + dev_dbg(musb->controller, "START_OF_FRAME\n"); + handled = IRQ_HANDLED; + + /* start any periodic Tx transfers waiting for current frame */ + frame = musb_readw(mbase, MUSB_FRAME); + ep = musb->endpoints; + for (epnum = 1; (epnum < musb->nr_endpoints) + && (musb->epmask >= (1 << epnum)); + epnum++, ep++) { + /* + * FIXME handle framecounter wraps (12 bits) + * eliminate duplicated StartUrb logic + */ + if (ep->dwWaitFrame >= frame) { + ep->dwWaitFrame = 0; + pr_debug("SOF --> periodic TX%s on %d\n", + ep->tx_channel ? " DMA" : "", + epnum); + if (!ep->tx_channel) + musb_h_tx_start(musb, epnum); + else + cppi_hostdma_start(musb, epnum); + } + } /* end of for loop */ + } +#endif + + schedule_work(&musb->irq_work); + + return handled; +} +#endif + +/*-------------------------------------------------------------------------*/ + +/* +* Program the HDRC to start (enable interrupts, dma, etc.). +*/ +void musb_start(struct musb *musb) +{ + void __iomem *regs = musb->mregs; + u8 devctl = musb_readb(regs, MUSB_DEVCTL); + + dev_dbg(musb->controller, "<== devctl %02x\n", devctl); + + /* Set INT enable registers, enable interrupts */ + musb_writew(regs, MUSB_INTRTXE, musb->epmask); + musb_writew(regs, MUSB_INTRRXE, musb->epmask & 0xfffe); + musb_writeb(regs, MUSB_INTRUSBE, 0xf7); + + musb_writeb(regs, MUSB_TESTMODE, 0); + + /* put into basic highspeed mode and start session */ + musb_writeb(regs, MUSB_POWER, MUSB_POWER_ISOUPDATE + | MUSB_POWER_HSENAB + /* ENSUSPEND wedges tusb */ + /* | MUSB_POWER_ENSUSPEND */ + ); + + musb->is_active = 0; + devctl = musb_readb(regs, MUSB_DEVCTL); + devctl &= ~MUSB_DEVCTL_SESSION; + +#ifndef __UBOOT__ + if (is_otg_enabled(musb)) { + /* session started after: + * (a) ID-grounded irq, host mode; + * (b) vbus present/connect IRQ, peripheral mode; + * (c) peripheral initiates, using SRP + */ + if ((devctl & MUSB_DEVCTL_VBUS) == MUSB_DEVCTL_VBUS) + musb->is_active = 1; + else + devctl |= MUSB_DEVCTL_SESSION; + + } else if (is_host_enabled(musb)) { + /* assume ID pin is hard-wired to ground */ + devctl |= MUSB_DEVCTL_SESSION; + + } else /* peripheral is enabled */ { +#endif + if ((devctl & MUSB_DEVCTL_VBUS) == MUSB_DEVCTL_VBUS) + musb->is_active = 1; +#ifndef __UBOOT__ + } +#endif + musb_platform_enable(musb); + musb_writeb(regs, MUSB_DEVCTL, devctl); +} + + +static void musb_generic_disable(struct musb *musb) +{ + void __iomem *mbase = musb->mregs; + u16 temp; + + /* disable interrupts */ + musb_writeb(mbase, MUSB_INTRUSBE, 0); + musb_writew(mbase, MUSB_INTRTXE, 0); + musb_writew(mbase, MUSB_INTRRXE, 0); + + /* off */ + musb_writeb(mbase, MUSB_DEVCTL, 0); + + /* flush pending interrupts */ + temp = musb_readb(mbase, MUSB_INTRUSB); + temp = musb_readw(mbase, MUSB_INTRTX); + temp = musb_readw(mbase, MUSB_INTRRX); + +} + +/* + * Make the HDRC stop (disable interrupts, etc.); + * reversible by musb_start + * called on gadget driver unregister + * with controller locked, irqs blocked + * acts as a NOP unless some role activated the hardware + */ +void musb_stop(struct musb *musb) +{ + /* stop IRQs, timers, ... */ + musb_platform_disable(musb); + musb_generic_disable(musb); + dev_dbg(musb->controller, "HDRC disabled\n"); + + /* FIXME + * - mark host and/or peripheral drivers unusable/inactive + * - disable DMA (and enable it in HdrcStart) + * - make sure we can musb_start() after musb_stop(); with + * OTG mode, gadget driver module rmmod/modprobe cycles that + * - ... + */ + musb_platform_try_idle(musb, 0); +} + +#ifndef __UBOOT__ +static void musb_shutdown(struct platform_device *pdev) +{ + struct musb *musb = dev_to_musb(&pdev->dev); + unsigned long flags; + + pm_runtime_get_sync(musb->controller); + + musb_gadget_cleanup(musb); + + spin_lock_irqsave(&musb->lock, flags); + musb_platform_disable(musb); + musb_generic_disable(musb); + spin_unlock_irqrestore(&musb->lock, flags); + + if (!is_otg_enabled(musb) && is_host_enabled(musb)) + usb_remove_hcd(musb_to_hcd(musb)); + musb_writeb(musb->mregs, MUSB_DEVCTL, 0); + musb_platform_exit(musb); + + pm_runtime_put(musb->controller); + /* FIXME power down */ +} +#endif + + +/*-------------------------------------------------------------------------*/ + +/* + * The silicon either has hard-wired endpoint configurations, or else + * "dynamic fifo" sizing. The driver has support for both, though at this + * writing only the dynamic sizing is very well tested. Since we switched + * away from compile-time hardware parameters, we can no longer rely on + * dead code elimination to leave only the relevant one in the object file. + * + * We don't currently use dynamic fifo setup capability to do anything + * more than selecting one of a bunch of predefined configurations. + */ +#if defined(CONFIG_USB_MUSB_TUSB6010) \ + || defined(CONFIG_USB_MUSB_TUSB6010_MODULE) \ + || defined(CONFIG_USB_MUSB_OMAP2PLUS) \ + || defined(CONFIG_USB_MUSB_OMAP2PLUS_MODULE) \ + || defined(CONFIG_USB_MUSB_AM35X) \ + || defined(CONFIG_USB_MUSB_AM35X_MODULE) \ + || defined(CONFIG_USB_MUSB_DSPS) \ + || defined(CONFIG_USB_MUSB_DSPS_MODULE) +static ushort __devinitdata fifo_mode = 4; +#elif defined(CONFIG_USB_MUSB_UX500) \ + || defined(CONFIG_USB_MUSB_UX500_MODULE) +static ushort __devinitdata fifo_mode = 5; +#else +static ushort __devinitdata fifo_mode = 2; +#endif + +/* "modprobe ... fifo_mode=1" etc */ +module_param(fifo_mode, ushort, 0); +MODULE_PARM_DESC(fifo_mode, "initial endpoint configuration"); + +/* + * tables defining fifo_mode values. define more if you like. + * for host side, make sure both halves of ep1 are set up. + */ + +/* mode 0 - fits in 2KB */ +static struct musb_fifo_cfg __devinitdata mode_0_cfg[] = { +{ .hw_ep_num = 1, .style = FIFO_TX, .maxpacket = 512, }, +{ .hw_ep_num = 1, .style = FIFO_RX, .maxpacket = 512, }, +{ .hw_ep_num = 2, .style = FIFO_RXTX, .maxpacket = 512, }, +{ .hw_ep_num = 3, .style = FIFO_RXTX, .maxpacket = 256, }, +{ .hw_ep_num = 4, .style = FIFO_RXTX, .maxpacket = 256, }, +}; + +/* mode 1 - fits in 4KB */ +static struct musb_fifo_cfg __devinitdata mode_1_cfg[] = { +{ .hw_ep_num = 1, .style = FIFO_TX, .maxpacket = 512, .mode = BUF_DOUBLE, }, +{ .hw_ep_num = 1, .style = FIFO_RX, .maxpacket = 512, .mode = BUF_DOUBLE, }, +{ .hw_ep_num = 2, .style = FIFO_RXTX, .maxpacket = 512, .mode = BUF_DOUBLE, }, +{ .hw_ep_num = 3, .style = FIFO_RXTX, .maxpacket = 256, }, +{ .hw_ep_num = 4, .style = FIFO_RXTX, .maxpacket = 256, }, +}; + +/* mode 2 - fits in 4KB */ +static struct musb_fifo_cfg __devinitdata mode_2_cfg[] = { +{ .hw_ep_num = 1, .style = FIFO_TX, .maxpacket = 512, }, +{ .hw_ep_num = 1, .style = FIFO_RX, .maxpacket = 512, }, +{ .hw_ep_num = 2, .style = FIFO_TX, .maxpacket = 512, }, +{ .hw_ep_num = 2, .style = FIFO_RX, .maxpacket = 512, }, +{ .hw_ep_num = 3, .style = FIFO_RXTX, .maxpacket = 256, }, +{ .hw_ep_num = 4, .style = FIFO_RXTX, .maxpacket = 256, }, +}; + +/* mode 3 - fits in 4KB */ +static struct musb_fifo_cfg __devinitdata mode_3_cfg[] = { +{ .hw_ep_num = 1, .style = FIFO_TX, .maxpacket = 512, .mode = BUF_DOUBLE, }, +{ .hw_ep_num = 1, .style = FIFO_RX, .maxpacket = 512, .mode = BUF_DOUBLE, }, +{ .hw_ep_num = 2, .style = FIFO_TX, .maxpacket = 512, }, +{ .hw_ep_num = 2, .style = FIFO_RX, .maxpacket = 512, }, +{ .hw_ep_num = 3, .style = FIFO_RXTX, .maxpacket = 256, }, +{ .hw_ep_num = 4, .style = FIFO_RXTX, .maxpacket = 256, }, +}; + +/* mode 4 - fits in 16KB */ +static struct musb_fifo_cfg __devinitdata mode_4_cfg[] = { +{ .hw_ep_num = 1, .style = FIFO_TX, .maxpacket = 512, }, +{ .hw_ep_num = 1, .style = FIFO_RX, .maxpacket = 512, }, +{ .hw_ep_num = 2, .style = FIFO_TX, .maxpacket = 512, }, +{ .hw_ep_num = 2, .style = FIFO_RX, .maxpacket = 512, }, +{ .hw_ep_num = 3, .style = FIFO_TX, .maxpacket = 512, }, +{ .hw_ep_num = 3, .style = FIFO_RX, .maxpacket = 512, }, +{ .hw_ep_num = 4, .style = FIFO_TX, .maxpacket = 512, }, +{ .hw_ep_num = 4, .style = FIFO_RX, .maxpacket = 512, }, +{ .hw_ep_num = 5, .style = FIFO_TX, .maxpacket = 512, }, +{ .hw_ep_num = 5, .style = FIFO_RX, .maxpacket = 512, }, +{ .hw_ep_num = 6, .style = FIFO_TX, .maxpacket = 512, }, +{ .hw_ep_num = 6, .style = FIFO_RX, .maxpacket = 512, }, +{ .hw_ep_num = 7, .style = FIFO_TX, .maxpacket = 512, }, +{ .hw_ep_num = 7, .style = FIFO_RX, .maxpacket = 512, }, +{ .hw_ep_num = 8, .style = FIFO_TX, .maxpacket = 512, }, +{ .hw_ep_num = 8, .style = FIFO_RX, .maxpacket = 512, }, +{ .hw_ep_num = 9, .style = FIFO_TX, .maxpacket = 512, }, +{ .hw_ep_num = 9, .style = FIFO_RX, .maxpacket = 512, }, +{ .hw_ep_num = 10, .style = FIFO_TX, .maxpacket = 256, }, +{ .hw_ep_num = 10, .style = FIFO_RX, .maxpacket = 64, }, +{ .hw_ep_num = 11, .style = FIFO_TX, .maxpacket = 256, }, +{ .hw_ep_num = 11, .style = FIFO_RX, .maxpacket = 64, }, +{ .hw_ep_num = 12, .style = FIFO_TX, .maxpacket = 256, }, +{ .hw_ep_num = 12, .style = FIFO_RX, .maxpacket = 64, }, +{ .hw_ep_num = 13, .style = FIFO_RXTX, .maxpacket = 4096, }, +{ .hw_ep_num = 14, .style = FIFO_RXTX, .maxpacket = 1024, }, +{ .hw_ep_num = 15, .style = FIFO_RXTX, .maxpacket = 1024, }, +}; + +/* mode 5 - fits in 8KB */ +static struct musb_fifo_cfg __devinitdata mode_5_cfg[] = { +{ .hw_ep_num = 1, .style = FIFO_TX, .maxpacket = 512, }, +{ .hw_ep_num = 1, .style = FIFO_RX, .maxpacket = 512, }, +{ .hw_ep_num = 2, .style = FIFO_TX, .maxpacket = 512, }, +{ .hw_ep_num = 2, .style = FIFO_RX, .maxpacket = 512, }, +{ .hw_ep_num = 3, .style = FIFO_TX, .maxpacket = 512, }, +{ .hw_ep_num = 3, .style = FIFO_RX, .maxpacket = 512, }, +{ .hw_ep_num = 4, .style = FIFO_TX, .maxpacket = 512, }, +{ .hw_ep_num = 4, .style = FIFO_RX, .maxpacket = 512, }, +{ .hw_ep_num = 5, .style = FIFO_TX, .maxpacket = 512, }, +{ .hw_ep_num = 5, .style = FIFO_RX, .maxpacket = 512, }, +{ .hw_ep_num = 6, .style = FIFO_TX, .maxpacket = 32, }, +{ .hw_ep_num = 6, .style = FIFO_RX, .maxpacket = 32, }, +{ .hw_ep_num = 7, .style = FIFO_TX, .maxpacket = 32, }, +{ .hw_ep_num = 7, .style = FIFO_RX, .maxpacket = 32, }, +{ .hw_ep_num = 8, .style = FIFO_TX, .maxpacket = 32, }, +{ .hw_ep_num = 8, .style = FIFO_RX, .maxpacket = 32, }, +{ .hw_ep_num = 9, .style = FIFO_TX, .maxpacket = 32, }, +{ .hw_ep_num = 9, .style = FIFO_RX, .maxpacket = 32, }, +{ .hw_ep_num = 10, .style = FIFO_TX, .maxpacket = 32, }, +{ .hw_ep_num = 10, .style = FIFO_RX, .maxpacket = 32, }, +{ .hw_ep_num = 11, .style = FIFO_TX, .maxpacket = 32, }, +{ .hw_ep_num = 11, .style = FIFO_RX, .maxpacket = 32, }, +{ .hw_ep_num = 12, .style = FIFO_TX, .maxpacket = 32, }, +{ .hw_ep_num = 12, .style = FIFO_RX, .maxpacket = 32, }, +{ .hw_ep_num = 13, .style = FIFO_RXTX, .maxpacket = 512, }, +{ .hw_ep_num = 14, .style = FIFO_RXTX, .maxpacket = 1024, }, +{ .hw_ep_num = 15, .style = FIFO_RXTX, .maxpacket = 1024, }, +}; + +/* + * configure a fifo; for non-shared endpoints, this may be called + * once for a tx fifo and once for an rx fifo. + * + * returns negative errno or offset for next fifo. + */ +static int __devinit +fifo_setup(struct musb *musb, struct musb_hw_ep *hw_ep, + const struct musb_fifo_cfg *cfg, u16 offset) +{ + void __iomem *mbase = musb->mregs; + int size = 0; + u16 maxpacket = cfg->maxpacket; + u16 c_off = offset >> 3; + u8 c_size; + + /* expect hw_ep has already been zero-initialized */ + + size = ffs(max(maxpacket, (u16) 8)) - 1; + maxpacket = 1 << size; + + c_size = size - 3; + if (cfg->mode == BUF_DOUBLE) { + if ((offset + (maxpacket << 1)) > + (1 << (musb->config->ram_bits + 2))) + return -EMSGSIZE; + c_size |= MUSB_FIFOSZ_DPB; + } else { + if ((offset + maxpacket) > (1 << (musb->config->ram_bits + 2))) + return -EMSGSIZE; + } + + /* configure the FIFO */ + musb_writeb(mbase, MUSB_INDEX, hw_ep->epnum); + + /* EP0 reserved endpoint for control, bidirectional; + * EP1 reserved for bulk, two unidirection halves. + */ + if (hw_ep->epnum == 1) + musb->bulk_ep = hw_ep; + /* REVISIT error check: be sure ep0 can both rx and tx ... */ + switch (cfg->style) { + case FIFO_TX: + musb_write_txfifosz(mbase, c_size); + musb_write_txfifoadd(mbase, c_off); + hw_ep->tx_double_buffered = !!(c_size & MUSB_FIFOSZ_DPB); + hw_ep->max_packet_sz_tx = maxpacket; + break; + case FIFO_RX: + musb_write_rxfifosz(mbase, c_size); + musb_write_rxfifoadd(mbase, c_off); + hw_ep->rx_double_buffered = !!(c_size & MUSB_FIFOSZ_DPB); + hw_ep->max_packet_sz_rx = maxpacket; + break; + case FIFO_RXTX: + musb_write_txfifosz(mbase, c_size); + musb_write_txfifoadd(mbase, c_off); + hw_ep->rx_double_buffered = !!(c_size & MUSB_FIFOSZ_DPB); + hw_ep->max_packet_sz_rx = maxpacket; + + musb_write_rxfifosz(mbase, c_size); + musb_write_rxfifoadd(mbase, c_off); + hw_ep->tx_double_buffered = hw_ep->rx_double_buffered; + hw_ep->max_packet_sz_tx = maxpacket; + + hw_ep->is_shared_fifo = true; + break; + } + + /* NOTE rx and tx endpoint irqs aren't managed separately, + * which happens to be ok + */ + musb->epmask |= (1 << hw_ep->epnum); + + return offset + (maxpacket << ((c_size & MUSB_FIFOSZ_DPB) ? 1 : 0)); +} + +static struct musb_fifo_cfg __devinitdata ep0_cfg = { + .style = FIFO_RXTX, .maxpacket = 64, +}; + +static int __devinit ep_config_from_table(struct musb *musb) +{ + const struct musb_fifo_cfg *cfg; + unsigned i, n; + int offset; + struct musb_hw_ep *hw_ep = musb->endpoints; + + if (musb->config->fifo_cfg) { + cfg = musb->config->fifo_cfg; + n = musb->config->fifo_cfg_size; + goto done; + } + + switch (fifo_mode) { + default: + fifo_mode = 0; + /* FALLTHROUGH */ + case 0: + cfg = mode_0_cfg; + n = ARRAY_SIZE(mode_0_cfg); + break; + case 1: + cfg = mode_1_cfg; + n = ARRAY_SIZE(mode_1_cfg); + break; + case 2: + cfg = mode_2_cfg; + n = ARRAY_SIZE(mode_2_cfg); + break; + case 3: + cfg = mode_3_cfg; + n = ARRAY_SIZE(mode_3_cfg); + break; + case 4: + cfg = mode_4_cfg; + n = ARRAY_SIZE(mode_4_cfg); + break; + case 5: + cfg = mode_5_cfg; + n = ARRAY_SIZE(mode_5_cfg); + break; + } + + printk(KERN_DEBUG "%s: setup fifo_mode %d\n", + musb_driver_name, fifo_mode); + + +done: + offset = fifo_setup(musb, hw_ep, &ep0_cfg, 0); + /* assert(offset > 0) */ + + /* NOTE: for RTL versions >= 1.400 EPINFO and RAMINFO would + * be better than static musb->config->num_eps and DYN_FIFO_SIZE... + */ + + for (i = 0; i < n; i++) { + u8 epn = cfg->hw_ep_num; + + if (epn >= musb->config->num_eps) { + pr_debug("%s: invalid ep %d\n", + musb_driver_name, epn); + return -EINVAL; + } + offset = fifo_setup(musb, hw_ep + epn, cfg++, offset); + if (offset < 0) { + pr_debug("%s: mem overrun, ep %d\n", + musb_driver_name, epn); + return -EINVAL; + } + epn++; + musb->nr_endpoints = max(epn, musb->nr_endpoints); + } + + printk(KERN_DEBUG "%s: %d/%d max ep, %d/%d memory\n", + musb_driver_name, + n + 1, musb->config->num_eps * 2 - 1, + offset, (1 << (musb->config->ram_bits + 2))); + + if (!musb->bulk_ep) { + pr_debug("%s: missing bulk\n", musb_driver_name); + return -EINVAL; + } + + return 0; +} + + +/* + * ep_config_from_hw - when MUSB_C_DYNFIFO_DEF is false + * @param musb the controller + */ +static int __devinit ep_config_from_hw(struct musb *musb) +{ + u8 epnum = 0; + struct musb_hw_ep *hw_ep; + void *mbase = musb->mregs; + int ret = 0; + + dev_dbg(musb->controller, "<== static silicon ep config\n"); + + /* FIXME pick up ep0 maxpacket size */ + + for (epnum = 1; epnum < musb->config->num_eps; epnum++) { + musb_ep_select(mbase, epnum); + hw_ep = musb->endpoints + epnum; + + ret = musb_read_fifosize(musb, hw_ep, epnum); + if (ret < 0) + break; + + /* FIXME set up hw_ep->{rx,tx}_double_buffered */ + + /* pick an RX/TX endpoint for bulk */ + if (hw_ep->max_packet_sz_tx < 512 + || hw_ep->max_packet_sz_rx < 512) + continue; + + /* REVISIT: this algorithm is lazy, we should at least + * try to pick a double buffered endpoint. + */ + if (musb->bulk_ep) + continue; + musb->bulk_ep = hw_ep; + } + + if (!musb->bulk_ep) { + pr_debug("%s: missing bulk\n", musb_driver_name); + return -EINVAL; + } + + return 0; +} + +enum { MUSB_CONTROLLER_MHDRC, MUSB_CONTROLLER_HDRC, }; + +/* Initialize MUSB (M)HDRC part of the USB hardware subsystem; + * configure endpoints, or take their config from silicon + */ +static int __devinit musb_core_init(u16 musb_type, struct musb *musb) +{ + u8 reg; + char *type; + char aInfo[90], aRevision[32], aDate[12]; + void __iomem *mbase = musb->mregs; + int status = 0; + int i; + + /* log core options (read using indexed model) */ + reg = musb_read_configdata(mbase); + + strcpy(aInfo, (reg & MUSB_CONFIGDATA_UTMIDW) ? "UTMI-16" : "UTMI-8"); + if (reg & MUSB_CONFIGDATA_DYNFIFO) { + strcat(aInfo, ", dyn FIFOs"); + musb->dyn_fifo = true; + } + if (reg & MUSB_CONFIGDATA_MPRXE) { + strcat(aInfo, ", bulk combine"); + musb->bulk_combine = true; + } + if (reg & MUSB_CONFIGDATA_MPTXE) { + strcat(aInfo, ", bulk split"); + musb->bulk_split = true; + } + if (reg & MUSB_CONFIGDATA_HBRXE) { + strcat(aInfo, ", HB-ISO Rx"); + musb->hb_iso_rx = true; + } + if (reg & MUSB_CONFIGDATA_HBTXE) { + strcat(aInfo, ", HB-ISO Tx"); + musb->hb_iso_tx = true; + } + if (reg & MUSB_CONFIGDATA_SOFTCONE) + strcat(aInfo, ", SoftConn"); + + printk(KERN_DEBUG "%s: ConfigData=0x%02x (%s)\n", + musb_driver_name, reg, aInfo); + + aDate[0] = 0; + if (MUSB_CONTROLLER_MHDRC == musb_type) { + musb->is_multipoint = 1; + type = "M"; + } else { + musb->is_multipoint = 0; + type = ""; +#ifndef CONFIG_USB_OTG_BLACKLIST_HUB + printk(KERN_ERR + "%s: kernel must blacklist external hubs\n", + musb_driver_name); +#endif + } + + /* log release info */ + musb->hwvers = musb_read_hwvers(mbase); + snprintf(aRevision, 32, "%d.%d%s", MUSB_HWVERS_MAJOR(musb->hwvers), + MUSB_HWVERS_MINOR(musb->hwvers), + (musb->hwvers & MUSB_HWVERS_RC) ? "RC" : ""); + printk(KERN_DEBUG "%s: %sHDRC RTL version %s %s\n", + musb_driver_name, type, aRevision, aDate); + + /* configure ep0 */ + musb_configure_ep0(musb); + + /* discover endpoint configuration */ + musb->nr_endpoints = 1; + musb->epmask = 1; + + if (musb->dyn_fifo) + status = ep_config_from_table(musb); + else + status = ep_config_from_hw(musb); + + if (status < 0) + return status; + + /* finish init, and print endpoint config */ + for (i = 0; i < musb->nr_endpoints; i++) { + struct musb_hw_ep *hw_ep = musb->endpoints + i; + + hw_ep->fifo = MUSB_FIFO_OFFSET(i) + mbase; +#if defined(CONFIG_USB_MUSB_TUSB6010) || defined (CONFIG_USB_MUSB_TUSB6010_MODULE) + hw_ep->fifo_async = musb->async + 0x400 + MUSB_FIFO_OFFSET(i); + hw_ep->fifo_sync = musb->sync + 0x400 + MUSB_FIFO_OFFSET(i); + hw_ep->fifo_sync_va = + musb->sync_va + 0x400 + MUSB_FIFO_OFFSET(i); + + if (i == 0) + hw_ep->conf = mbase - 0x400 + TUSB_EP0_CONF; + else + hw_ep->conf = mbase + 0x400 + (((i - 1) & 0xf) << 2); +#endif + + hw_ep->regs = MUSB_EP_OFFSET(i, 0) + mbase; + hw_ep->target_regs = musb_read_target_reg_base(i, mbase); + hw_ep->rx_reinit = 1; + hw_ep->tx_reinit = 1; + + if (hw_ep->max_packet_sz_tx) { + dev_dbg(musb->controller, + "%s: hw_ep %d%s, %smax %d\n", + musb_driver_name, i, + hw_ep->is_shared_fifo ? "shared" : "tx", + hw_ep->tx_double_buffered + ? "doublebuffer, " : "", + hw_ep->max_packet_sz_tx); + } + if (hw_ep->max_packet_sz_rx && !hw_ep->is_shared_fifo) { + dev_dbg(musb->controller, + "%s: hw_ep %d%s, %smax %d\n", + musb_driver_name, i, + "rx", + hw_ep->rx_double_buffered + ? "doublebuffer, " : "", + hw_ep->max_packet_sz_rx); + } + if (!(hw_ep->max_packet_sz_tx || hw_ep->max_packet_sz_rx)) + dev_dbg(musb->controller, "hw_ep %d not configured\n", i); + } + + return 0; +} + +/*-------------------------------------------------------------------------*/ + +#if defined(CONFIG_SOC_OMAP2430) || defined(CONFIG_SOC_OMAP3430) || \ + defined(CONFIG_ARCH_OMAP4) || defined(CONFIG_ARCH_U8500) + +static irqreturn_t generic_interrupt(int irq, void *__hci) +{ + unsigned long flags; + irqreturn_t retval = IRQ_NONE; + struct musb *musb = __hci; + + spin_lock_irqsave(&musb->lock, flags); + + musb->int_usb = musb_readb(musb->mregs, MUSB_INTRUSB); + musb->int_tx = musb_readw(musb->mregs, MUSB_INTRTX); + musb->int_rx = musb_readw(musb->mregs, MUSB_INTRRX); + + if (musb->int_usb || musb->int_tx || musb->int_rx) + retval = musb_interrupt(musb); + + spin_unlock_irqrestore(&musb->lock, flags); + + return retval; +} + +#else +#define generic_interrupt NULL +#endif + +/* + * handle all the irqs defined by the HDRC core. for now we expect: other + * irq sources (phy, dma, etc) will be handled first, musb->int_* values + * will be assigned, and the irq will already have been acked. + * + * called in irq context with spinlock held, irqs blocked + */ +irqreturn_t musb_interrupt(struct musb *musb) +{ + irqreturn_t retval = IRQ_NONE; + u8 devctl, power; + int ep_num; + u32 reg; + + devctl = musb_readb(musb->mregs, MUSB_DEVCTL); + power = musb_readb(musb->mregs, MUSB_POWER); + + dev_dbg(musb->controller, "** IRQ %s usb%04x tx%04x rx%04x\n", + (devctl & MUSB_DEVCTL_HM) ? "host" : "peripheral", + musb->int_usb, musb->int_tx, musb->int_rx); + +#ifndef __UBOOT__ + /* the core can interrupt us for multiple reasons; docs have + * a generic interrupt flowchart to follow + */ + if (musb->int_usb) + retval |= musb_stage0_irq(musb, musb->int_usb, + devctl, power); +#endif + + /* "stage 1" is handling endpoint irqs */ + + /* handle endpoint 0 first */ + if (musb->int_tx & 1) { +#ifndef __UBOOT__ + if (devctl & MUSB_DEVCTL_HM) + retval |= musb_h_ep0_irq(musb); + else +#endif + retval |= musb_g_ep0_irq(musb); + } + + /* RX on endpoints 1-15 */ + reg = musb->int_rx >> 1; + ep_num = 1; + while (reg) { + if (reg & 1) { + /* musb_ep_select(musb->mregs, ep_num); */ + /* REVISIT just retval = ep->rx_irq(...) */ + retval = IRQ_HANDLED; + if (devctl & MUSB_DEVCTL_HM) { +#ifndef __UBOOT__ + if (is_host_capable()) + musb_host_rx(musb, ep_num); +#endif + } else { + if (is_peripheral_capable()) + musb_g_rx(musb, ep_num); + } + } + + reg >>= 1; + ep_num++; + } + + /* TX on endpoints 1-15 */ + reg = musb->int_tx >> 1; + ep_num = 1; + while (reg) { + if (reg & 1) { + /* musb_ep_select(musb->mregs, ep_num); */ + /* REVISIT just retval |= ep->tx_irq(...) */ + retval = IRQ_HANDLED; + if (devctl & MUSB_DEVCTL_HM) { +#ifndef __UBOOT__ + if (is_host_capable()) + musb_host_tx(musb, ep_num); +#endif + } else { + if (is_peripheral_capable()) + musb_g_tx(musb, ep_num); + } + } + reg >>= 1; + ep_num++; + } + + return retval; +} +EXPORT_SYMBOL_GPL(musb_interrupt); + +#ifndef CONFIG_MUSB_PIO_ONLY +static bool __devinitdata use_dma = 1; + +/* "modprobe ... use_dma=0" etc */ +module_param(use_dma, bool, 0); +MODULE_PARM_DESC(use_dma, "enable/disable use of DMA"); + +void musb_dma_completion(struct musb *musb, u8 epnum, u8 transmit) +{ + u8 devctl = musb_readb(musb->mregs, MUSB_DEVCTL); + + /* called with controller lock already held */ + + if (!epnum) { +#ifndef CONFIG_USB_TUSB_OMAP_DMA + if (!is_cppi_enabled()) { + /* endpoint 0 */ + if (devctl & MUSB_DEVCTL_HM) + musb_h_ep0_irq(musb); + else + musb_g_ep0_irq(musb); + } +#endif + } else { + /* endpoints 1..15 */ + if (transmit) { + if (devctl & MUSB_DEVCTL_HM) { + if (is_host_capable()) + musb_host_tx(musb, epnum); + } else { + if (is_peripheral_capable()) + musb_g_tx(musb, epnum); + } + } else { + /* receive */ + if (devctl & MUSB_DEVCTL_HM) { + if (is_host_capable()) + musb_host_rx(musb, epnum); + } else { + if (is_peripheral_capable()) + musb_g_rx(musb, epnum); + } + } + } +} +EXPORT_SYMBOL_GPL(musb_dma_completion); + +#else +#define use_dma 0 +#endif + +/*-------------------------------------------------------------------------*/ + +#ifdef CONFIG_SYSFS + +static ssize_t +musb_mode_show(struct device *dev, struct device_attribute *attr, char *buf) +{ + struct musb *musb = dev_to_musb(dev); + unsigned long flags; + int ret = -EINVAL; + + spin_lock_irqsave(&musb->lock, flags); + ret = sprintf(buf, "%s\n", otg_state_string(musb->xceiv->state)); + spin_unlock_irqrestore(&musb->lock, flags); + + return ret; +} + +static ssize_t +musb_mode_store(struct device *dev, struct device_attribute *attr, + const char *buf, size_t n) +{ + struct musb *musb = dev_to_musb(dev); + unsigned long flags; + int status; + + spin_lock_irqsave(&musb->lock, flags); + if (sysfs_streq(buf, "host")) + status = musb_platform_set_mode(musb, MUSB_HOST); + else if (sysfs_streq(buf, "peripheral")) + status = musb_platform_set_mode(musb, MUSB_PERIPHERAL); + else if (sysfs_streq(buf, "otg")) + status = musb_platform_set_mode(musb, MUSB_OTG); + else + status = -EINVAL; + spin_unlock_irqrestore(&musb->lock, flags); + + return (status == 0) ? n : status; +} +static DEVICE_ATTR(mode, 0644, musb_mode_show, musb_mode_store); + +static ssize_t +musb_vbus_store(struct device *dev, struct device_attribute *attr, + const char *buf, size_t n) +{ + struct musb *musb = dev_to_musb(dev); + unsigned long flags; + unsigned long val; + + if (sscanf(buf, "%lu", &val) < 1) { + dev_err(dev, "Invalid VBUS timeout ms value\n"); + return -EINVAL; + } + + spin_lock_irqsave(&musb->lock, flags); + /* force T(a_wait_bcon) to be zero/unlimited *OR* valid */ + musb->a_wait_bcon = val ? max_t(int, val, OTG_TIME_A_WAIT_BCON) : 0 ; + if (musb->xceiv->state == OTG_STATE_A_WAIT_BCON) + musb->is_active = 0; + musb_platform_try_idle(musb, jiffies + msecs_to_jiffies(val)); + spin_unlock_irqrestore(&musb->lock, flags); + + return n; +} + +static ssize_t +musb_vbus_show(struct device *dev, struct device_attribute *attr, char *buf) +{ + struct musb *musb = dev_to_musb(dev); + unsigned long flags; + unsigned long val; + int vbus; + + spin_lock_irqsave(&musb->lock, flags); + val = musb->a_wait_bcon; + /* FIXME get_vbus_status() is normally #defined as false... + * and is effectively TUSB-specific. + */ + vbus = musb_platform_get_vbus_status(musb); + spin_unlock_irqrestore(&musb->lock, flags); + + return sprintf(buf, "Vbus %s, timeout %lu msec\n", + vbus ? "on" : "off", val); +} +static DEVICE_ATTR(vbus, 0644, musb_vbus_show, musb_vbus_store); + +/* Gadget drivers can't know that a host is connected so they might want + * to start SRP, but users can. This allows userspace to trigger SRP. + */ +static ssize_t +musb_srp_store(struct device *dev, struct device_attribute *attr, + const char *buf, size_t n) +{ + struct musb *musb = dev_to_musb(dev); + unsigned short srp; + + if (sscanf(buf, "%hu", &srp) != 1 + || (srp != 1)) { + dev_err(dev, "SRP: Value must be 1\n"); + return -EINVAL; + } + + if (srp == 1) + musb_g_wakeup(musb); + + return n; +} +static DEVICE_ATTR(srp, 0644, NULL, musb_srp_store); + +static struct attribute *musb_attributes[] = { + &dev_attr_mode.attr, + &dev_attr_vbus.attr, + &dev_attr_srp.attr, + NULL +}; + +static const struct attribute_group musb_attr_group = { + .attrs = musb_attributes, +}; + +#endif /* sysfs */ + +#ifndef __UBOOT__ +/* Only used to provide driver mode change events */ +static void musb_irq_work(struct work_struct *data) +{ + struct musb *musb = container_of(data, struct musb, irq_work); + static int old_state; + + if (musb->xceiv->state != old_state) { + old_state = musb->xceiv->state; + sysfs_notify(&musb->controller->kobj, NULL, "mode"); + } +} +#endif + +/* -------------------------------------------------------------------------- + * Init support + */ + +static struct musb *__devinit +allocate_instance(struct device *dev, + struct musb_hdrc_config *config, void __iomem *mbase) +{ + struct musb *musb; + struct musb_hw_ep *ep; + int epnum; +#ifndef __UBOOT__ + struct usb_hcd *hcd; + + hcd = usb_create_hcd(&musb_hc_driver, dev, dev_name(dev)); + if (!hcd) + return NULL; + /* usbcore sets dev->driver_data to hcd, and sometimes uses that... */ + + musb = hcd_to_musb(hcd); +#else + musb = malloc(sizeof(*musb)); +#endif + INIT_LIST_HEAD(&musb->control); + INIT_LIST_HEAD(&musb->in_bulk); + INIT_LIST_HEAD(&musb->out_bulk); + +#ifndef __UBOOT__ + hcd->uses_new_polling = 1; + hcd->has_tt = 1; +#endif + + musb->vbuserr_retry = VBUSERR_RETRY_COUNT; + musb->a_wait_bcon = OTG_TIME_A_WAIT_BCON; + dev_set_drvdata(dev, musb); + musb->mregs = mbase; + musb->ctrl_base = mbase; + musb->nIrq = -ENODEV; + musb->config = config; + BUG_ON(musb->config->num_eps > MUSB_C_NUM_EPS); + for (epnum = 0, ep = musb->endpoints; + epnum < musb->config->num_eps; + epnum++, ep++) { + ep->musb = musb; + ep->epnum = epnum; + } + + musb->controller = dev; + + return musb; +} + +static void musb_free(struct musb *musb) +{ + /* this has multiple entry modes. it handles fault cleanup after + * probe(), where things may be partially set up, as well as rmmod + * cleanup after everything's been de-activated. + */ + +#ifdef CONFIG_SYSFS + sysfs_remove_group(&musb->controller->kobj, &musb_attr_group); +#endif + + if (musb->nIrq >= 0) { + if (musb->irq_wake) + disable_irq_wake(musb->nIrq); + free_irq(musb->nIrq, musb); + } + if (is_dma_capable() && musb->dma_controller) { + struct dma_controller *c = musb->dma_controller; + + (void) c->stop(c); + dma_controller_destroy(c); + } + + kfree(musb); +} + +/* + * Perform generic per-controller initialization. + * + * @pDevice: the controller (already clocked, etc) + * @nIrq: irq + * @mregs: virtual address of controller registers, + * not yet corrected for platform-specific offsets + */ +#ifndef __UBOOT__ +static int __devinit +musb_init_controller(struct device *dev, int nIrq, void __iomem *ctrl) +#else +struct musb * +musb_init_controller(struct musb_hdrc_platform_data *plat, struct device *dev, + void *ctrl) +#endif +{ + int status; + struct musb *musb; +#ifndef __UBOOT__ + struct musb_hdrc_platform_data *plat = dev->platform_data; +#else + int nIrq = 0; +#endif + + /* The driver might handle more features than the board; OK. + * Fail when the board needs a feature that's not enabled. + */ + if (!plat) { + dev_dbg(dev, "no platform_data?\n"); + status = -ENODEV; + goto fail0; + } + + /* allocate */ + musb = allocate_instance(dev, plat->config, ctrl); + if (!musb) { + status = -ENOMEM; + goto fail0; + } + + pm_runtime_use_autosuspend(musb->controller); + pm_runtime_set_autosuspend_delay(musb->controller, 200); + pm_runtime_enable(musb->controller); + + spin_lock_init(&musb->lock); + musb->board_mode = plat->mode; + musb->board_set_power = plat->set_power; + musb->min_power = plat->min_power; + musb->ops = plat->platform_ops; + + /* The musb_platform_init() call: + * - adjusts musb->mregs and musb->isr if needed, + * - may initialize an integrated tranceiver + * - initializes musb->xceiv, usually by otg_get_transceiver() + * - stops powering VBUS + * + * There are various transceiver configurations. Blackfin, + * DaVinci, TUSB60x0, and others integrate them. OMAP3 uses + * external/discrete ones in various flavors (twl4030 family, + * isp1504, non-OTG, etc) mostly hooking up through ULPI. + */ + musb->isr = generic_interrupt; + status = musb_platform_init(musb); + if (status < 0) + goto fail1; + + if (!musb->isr) { + status = -ENODEV; + goto fail2; + } + +#ifndef __UBOOT__ + if (!musb->xceiv->io_ops) { + musb->xceiv->io_dev = musb->controller; + musb->xceiv->io_priv = musb->mregs; + musb->xceiv->io_ops = &musb_ulpi_access; + } +#endif + + pm_runtime_get_sync(musb->controller); + +#ifndef CONFIG_MUSB_PIO_ONLY + if (use_dma && dev->dma_mask) { + struct dma_controller *c; + + c = dma_controller_create(musb, musb->mregs); + musb->dma_controller = c; + if (c) + (void) c->start(c); + } +#endif +#ifndef __UBOOT__ + /* ideally this would be abstracted in platform setup */ + if (!is_dma_capable() || !musb->dma_controller) + dev->dma_mask = NULL; +#endif + + /* be sure interrupts are disabled before connecting ISR */ + musb_platform_disable(musb); + musb_generic_disable(musb); + + /* setup musb parts of the core (especially endpoints) */ + status = musb_core_init(plat->config->multipoint + ? MUSB_CONTROLLER_MHDRC + : MUSB_CONTROLLER_HDRC, musb); + if (status < 0) + goto fail3; + + setup_timer(&musb->otg_timer, musb_otg_timer_func, (unsigned long) musb); + + /* Init IRQ workqueue before request_irq */ + INIT_WORK(&musb->irq_work, musb_irq_work); + + /* attach to the IRQ */ + if (request_irq(nIrq, musb->isr, 0, dev_name(dev), musb)) { + dev_err(dev, "request_irq %d failed!\n", nIrq); + status = -ENODEV; + goto fail3; + } + musb->nIrq = nIrq; +/* FIXME this handles wakeup irqs wrong */ + if (enable_irq_wake(nIrq) == 0) { + musb->irq_wake = 1; + device_init_wakeup(dev, 1); + } else { + musb->irq_wake = 0; + } + +#ifndef __UBOOT__ + /* host side needs more setup */ + if (is_host_enabled(musb)) { + struct usb_hcd *hcd = musb_to_hcd(musb); + + otg_set_host(musb->xceiv->otg, &hcd->self); + + if (is_otg_enabled(musb)) + hcd->self.otg_port = 1; + musb->xceiv->otg->host = &hcd->self; + hcd->power_budget = 2 * (plat->power ? : 250); + + /* program PHY to use external vBus if required */ + if (plat->extvbus) { + u8 busctl = musb_read_ulpi_buscontrol(musb->mregs); + busctl |= MUSB_ULPI_USE_EXTVBUS; + musb_write_ulpi_buscontrol(musb->mregs, busctl); + } + } + + /* For the host-only role, we can activate right away. + * (We expect the ID pin to be forcibly grounded!!) + * Otherwise, wait till the gadget driver hooks up. + */ + if (!is_otg_enabled(musb) && is_host_enabled(musb)) { + struct usb_hcd *hcd = musb_to_hcd(musb); + + MUSB_HST_MODE(musb); + musb->xceiv->otg->default_a = 1; + musb->xceiv->state = OTG_STATE_A_IDLE; + + status = usb_add_hcd(musb_to_hcd(musb), 0, 0); + + hcd->self.uses_pio_for_control = 1; + dev_dbg(musb->controller, "%s mode, status %d, devctl %02x %c\n", + "HOST", status, + musb_readb(musb->mregs, MUSB_DEVCTL), + (musb_readb(musb->mregs, MUSB_DEVCTL) + & MUSB_DEVCTL_BDEVICE + ? 'B' : 'A')); + + } else /* peripheral is enabled */ { +#endif + MUSB_DEV_MODE(musb); +#ifndef __UBOOT__ + musb->xceiv->otg->default_a = 0; + musb->xceiv->state = OTG_STATE_B_IDLE; +#endif + + status = musb_gadget_setup(musb); + +#ifndef __UBOOT__ + dev_dbg(musb->controller, "%s mode, status %d, dev%02x\n", + is_otg_enabled(musb) ? "OTG" : "PERIPHERAL", + status, + musb_readb(musb->mregs, MUSB_DEVCTL)); + + } +#endif + if (status < 0) + goto fail3; + + status = musb_init_debugfs(musb); + if (status < 0) + goto fail4; + +#ifdef CONFIG_SYSFS + status = sysfs_create_group(&musb->controller->kobj, &musb_attr_group); + if (status) + goto fail5; +#endif + + pm_runtime_put(musb->controller); + + dev_info(dev, "USB %s mode controller at %p using %s, IRQ %d\n", + ({char *s; + switch (musb->board_mode) { + case MUSB_HOST: s = "Host"; break; + case MUSB_PERIPHERAL: s = "Peripheral"; break; + default: s = "OTG"; break; + }; s; }), + ctrl, + (is_dma_capable() && musb->dma_controller) + ? "DMA" : "PIO", + musb->nIrq); + +#ifndef __UBOOT__ + return 0; +#else + return status == 0 ? musb : NULL; +#endif + +fail5: + musb_exit_debugfs(musb); + +fail4: +#ifndef __UBOOT__ + if (!is_otg_enabled(musb) && is_host_enabled(musb)) + usb_remove_hcd(musb_to_hcd(musb)); + else +#endif + musb_gadget_cleanup(musb); + +fail3: + pm_runtime_put_sync(musb->controller); + +fail2: + if (musb->irq_wake) + device_init_wakeup(dev, 0); + musb_platform_exit(musb); + +fail1: + dev_err(musb->controller, + "musb_init_controller failed with status %d\n", status); + + musb_free(musb); + +fail0: + +#ifndef __UBOOT__ + return status; +#else + return status == 0 ? musb : NULL; +#endif + +} + +/*-------------------------------------------------------------------------*/ + +/* all implementations (PCI bridge to FPGA, VLYNQ, etc) should just + * bridge to a platform device; this driver then suffices. + */ + +#ifndef CONFIG_MUSB_PIO_ONLY +static u64 *orig_dma_mask; +#endif + +#ifndef __UBOOT__ +static int __devinit musb_probe(struct platform_device *pdev) +{ + struct device *dev = &pdev->dev; + int irq = platform_get_irq_byname(pdev, "mc"); + int status; + struct resource *iomem; + void __iomem *base; + + iomem = platform_get_resource(pdev, IORESOURCE_MEM, 0); + if (!iomem || irq <= 0) + return -ENODEV; + + base = ioremap(iomem->start, resource_size(iomem)); + if (!base) { + dev_err(dev, "ioremap failed\n"); + return -ENOMEM; + } + +#ifndef CONFIG_MUSB_PIO_ONLY + /* clobbered by use_dma=n */ + orig_dma_mask = dev->dma_mask; +#endif + status = musb_init_controller(dev, irq, base); + if (status < 0) + iounmap(base); + + return status; +} + +static int __devexit musb_remove(struct platform_device *pdev) +{ + struct musb *musb = dev_to_musb(&pdev->dev); + void __iomem *ctrl_base = musb->ctrl_base; + + /* this gets called on rmmod. + * - Host mode: host may still be active + * - Peripheral mode: peripheral is deactivated (or never-activated) + * - OTG mode: both roles are deactivated (or never-activated) + */ + musb_exit_debugfs(musb); + musb_shutdown(pdev); + + musb_free(musb); + iounmap(ctrl_base); + device_init_wakeup(&pdev->dev, 0); +#ifndef CONFIG_MUSB_PIO_ONLY + pdev->dev.dma_mask = orig_dma_mask; +#endif + return 0; +} + +#ifdef CONFIG_PM + +static void musb_save_context(struct musb *musb) +{ + int i; + void __iomem *musb_base = musb->mregs; + void __iomem *epio; + + if (is_host_enabled(musb)) { + musb->context.frame = musb_readw(musb_base, MUSB_FRAME); + musb->context.testmode = musb_readb(musb_base, MUSB_TESTMODE); + musb->context.busctl = musb_read_ulpi_buscontrol(musb->mregs); + } + musb->context.power = musb_readb(musb_base, MUSB_POWER); + musb->context.intrtxe = musb_readw(musb_base, MUSB_INTRTXE); + musb->context.intrrxe = musb_readw(musb_base, MUSB_INTRRXE); + musb->context.intrusbe = musb_readb(musb_base, MUSB_INTRUSBE); + musb->context.index = musb_readb(musb_base, MUSB_INDEX); + musb->context.devctl = musb_readb(musb_base, MUSB_DEVCTL); + + for (i = 0; i < musb->config->num_eps; ++i) { + struct musb_hw_ep *hw_ep; + + hw_ep = &musb->endpoints[i]; + if (!hw_ep) + continue; + + epio = hw_ep->regs; + if (!epio) + continue; + + musb_writeb(musb_base, MUSB_INDEX, i); + musb->context.index_regs[i].txmaxp = + musb_readw(epio, MUSB_TXMAXP); + musb->context.index_regs[i].txcsr = + musb_readw(epio, MUSB_TXCSR); + musb->context.index_regs[i].rxmaxp = + musb_readw(epio, MUSB_RXMAXP); + musb->context.index_regs[i].rxcsr = + musb_readw(epio, MUSB_RXCSR); + + if (musb->dyn_fifo) { + musb->context.index_regs[i].txfifoadd = + musb_read_txfifoadd(musb_base); + musb->context.index_regs[i].rxfifoadd = + musb_read_rxfifoadd(musb_base); + musb->context.index_regs[i].txfifosz = + musb_read_txfifosz(musb_base); + musb->context.index_regs[i].rxfifosz = + musb_read_rxfifosz(musb_base); + } + if (is_host_enabled(musb)) { + musb->context.index_regs[i].txtype = + musb_readb(epio, MUSB_TXTYPE); + musb->context.index_regs[i].txinterval = + musb_readb(epio, MUSB_TXINTERVAL); + musb->context.index_regs[i].rxtype = + musb_readb(epio, MUSB_RXTYPE); + musb->context.index_regs[i].rxinterval = + musb_readb(epio, MUSB_RXINTERVAL); + + musb->context.index_regs[i].txfunaddr = + musb_read_txfunaddr(musb_base, i); + musb->context.index_regs[i].txhubaddr = + musb_read_txhubaddr(musb_base, i); + musb->context.index_regs[i].txhubport = + musb_read_txhubport(musb_base, i); + + musb->context.index_regs[i].rxfunaddr = + musb_read_rxfunaddr(musb_base, i); + musb->context.index_regs[i].rxhubaddr = + musb_read_rxhubaddr(musb_base, i); + musb->context.index_regs[i].rxhubport = + musb_read_rxhubport(musb_base, i); + } + } +} + +static void musb_restore_context(struct musb *musb) +{ + int i; + void __iomem *musb_base = musb->mregs; + void __iomem *ep_target_regs; + void __iomem *epio; + + if (is_host_enabled(musb)) { + musb_writew(musb_base, MUSB_FRAME, musb->context.frame); + musb_writeb(musb_base, MUSB_TESTMODE, musb->context.testmode); + musb_write_ulpi_buscontrol(musb->mregs, musb->context.busctl); + } + musb_writeb(musb_base, MUSB_POWER, musb->context.power); + musb_writew(musb_base, MUSB_INTRTXE, musb->context.intrtxe); + musb_writew(musb_base, MUSB_INTRRXE, musb->context.intrrxe); + musb_writeb(musb_base, MUSB_INTRUSBE, musb->context.intrusbe); + musb_writeb(musb_base, MUSB_DEVCTL, musb->context.devctl); + + for (i = 0; i < musb->config->num_eps; ++i) { + struct musb_hw_ep *hw_ep; + + hw_ep = &musb->endpoints[i]; + if (!hw_ep) + continue; + + epio = hw_ep->regs; + if (!epio) + continue; + + musb_writeb(musb_base, MUSB_INDEX, i); + musb_writew(epio, MUSB_TXMAXP, + musb->context.index_regs[i].txmaxp); + musb_writew(epio, MUSB_TXCSR, + musb->context.index_regs[i].txcsr); + musb_writew(epio, MUSB_RXMAXP, + musb->context.index_regs[i].rxmaxp); + musb_writew(epio, MUSB_RXCSR, + musb->context.index_regs[i].rxcsr); + + if (musb->dyn_fifo) { + musb_write_txfifosz(musb_base, + musb->context.index_regs[i].txfifosz); + musb_write_rxfifosz(musb_base, + musb->context.index_regs[i].rxfifosz); + musb_write_txfifoadd(musb_base, + musb->context.index_regs[i].txfifoadd); + musb_write_rxfifoadd(musb_base, + musb->context.index_regs[i].rxfifoadd); + } + + if (is_host_enabled(musb)) { + musb_writeb(epio, MUSB_TXTYPE, + musb->context.index_regs[i].txtype); + musb_writeb(epio, MUSB_TXINTERVAL, + musb->context.index_regs[i].txinterval); + musb_writeb(epio, MUSB_RXTYPE, + musb->context.index_regs[i].rxtype); + musb_writeb(epio, MUSB_RXINTERVAL, + + musb->context.index_regs[i].rxinterval); + musb_write_txfunaddr(musb_base, i, + musb->context.index_regs[i].txfunaddr); + musb_write_txhubaddr(musb_base, i, + musb->context.index_regs[i].txhubaddr); + musb_write_txhubport(musb_base, i, + musb->context.index_regs[i].txhubport); + + ep_target_regs = + musb_read_target_reg_base(i, musb_base); + + musb_write_rxfunaddr(ep_target_regs, + musb->context.index_regs[i].rxfunaddr); + musb_write_rxhubaddr(ep_target_regs, + musb->context.index_regs[i].rxhubaddr); + musb_write_rxhubport(ep_target_regs, + musb->context.index_regs[i].rxhubport); + } + } + musb_writeb(musb_base, MUSB_INDEX, musb->context.index); +} + +static int musb_suspend(struct device *dev) +{ + struct musb *musb = dev_to_musb(dev); + unsigned long flags; + + spin_lock_irqsave(&musb->lock, flags); + + if (is_peripheral_active(musb)) { + /* FIXME force disconnect unless we know USB will wake + * the system up quickly enough to respond ... + */ + } else if (is_host_active(musb)) { + /* we know all the children are suspended; sometimes + * they will even be wakeup-enabled. + */ + } + + spin_unlock_irqrestore(&musb->lock, flags); + return 0; +} + +static int musb_resume_noirq(struct device *dev) +{ + /* for static cmos like DaVinci, register values were preserved + * unless for some reason the whole soc powered down or the USB + * module got reset through the PSC (vs just being disabled). + */ + return 0; +} + +static int musb_runtime_suspend(struct device *dev) +{ + struct musb *musb = dev_to_musb(dev); + + musb_save_context(musb); + + return 0; +} + +static int musb_runtime_resume(struct device *dev) +{ + struct musb *musb = dev_to_musb(dev); + static int first = 1; + + /* + * When pm_runtime_get_sync called for the first time in driver + * init, some of the structure is still not initialized which is + * used in restore function. But clock needs to be + * enabled before any register access, so + * pm_runtime_get_sync has to be called. + * Also context restore without save does not make + * any sense + */ + if (!first) + musb_restore_context(musb); + first = 0; + + return 0; +} + +static const struct dev_pm_ops musb_dev_pm_ops = { + .suspend = musb_suspend, + .resume_noirq = musb_resume_noirq, + .runtime_suspend = musb_runtime_suspend, + .runtime_resume = musb_runtime_resume, +}; + +#define MUSB_DEV_PM_OPS (&musb_dev_pm_ops) +#else +#define MUSB_DEV_PM_OPS NULL +#endif + +static struct platform_driver musb_driver = { + .driver = { + .name = (char *)musb_driver_name, + .bus = &platform_bus_type, + .owner = THIS_MODULE, + .pm = MUSB_DEV_PM_OPS, + }, + .probe = musb_probe, + .remove = __devexit_p(musb_remove), + .shutdown = musb_shutdown, +}; + +/*-------------------------------------------------------------------------*/ + +static int __init musb_init(void) +{ + if (usb_disabled()) + return 0; + + pr_info("%s: version " MUSB_VERSION ", " + "?dma?" + ", " + "otg (peripheral+host)", + musb_driver_name); + return platform_driver_register(&musb_driver); +} +module_init(musb_init); + +static void __exit musb_cleanup(void) +{ + platform_driver_unregister(&musb_driver); +} +module_exit(musb_cleanup); +#endif diff --git a/drivers/usb/musb-new/musb_core.h b/drivers/usb/musb-new/musb_core.h new file mode 100644 index 0000000..27f45b4 --- /dev/null +++ b/drivers/usb/musb-new/musb_core.h @@ -0,0 +1,611 @@ +/* + * MUSB OTG driver defines + * + * Copyright 2005 Mentor Graphics Corporation + * Copyright (C) 2005-2006 by Texas Instruments + * Copyright (C) 2006-2007 Nokia Corporation + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, but + * WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU + * General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA + * 02110-1301 USA + * + * THIS SOFTWARE IS PROVIDED "AS IS" AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN + * NO EVENT SHALL THE AUTHORS BE LIABLE FOR ANY DIRECT, INDIRECT, + * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT + * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF + * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON + * ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT + * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF + * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. + * + */ + +#ifndef __MUSB_CORE_H__ +#define __MUSB_CORE_H__ + +#ifndef __UBOOT__ +#include <linux/slab.h> +#include <linux/list.h> +#include <linux/interrupt.h> +#include <linux/errno.h> +#include <linux/timer.h> +#include <linux/device.h> +#include <linux/usb.h> +#include <linux/usb/otg.h> +#else +#include <asm/errno.h> +#endif +#include <linux/usb/ch9.h> +#include <linux/usb/gadget.h> +#include <linux/usb/musb.h> +struct musb; +struct musb_hw_ep; +struct musb_ep; + +/* Helper defines for struct musb->hwvers */ +#define MUSB_HWVERS_MAJOR(x) ((x >> 10) & 0x1f) +#define MUSB_HWVERS_MINOR(x) (x & 0x3ff) +#define MUSB_HWVERS_RC 0x8000 +#define MUSB_HWVERS_1300 0x52C +#define MUSB_HWVERS_1400 0x590 +#define MUSB_HWVERS_1800 0x720 +#define MUSB_HWVERS_1900 0x784 +#define MUSB_HWVERS_2000 0x800 + +#include "musb_debug.h" +#include "musb_dma.h" + +#include "musb_io.h" +#include "musb_regs.h" + +#include "musb_gadget.h" +#ifndef __UBOOT__ +#include <linux/usb/hcd.h> +#include "musb_host.h" +#endif + +#define is_peripheral_enabled(musb) ((musb)->board_mode != MUSB_HOST) +#define is_host_enabled(musb) ((musb)->board_mode != MUSB_PERIPHERAL) +#define is_otg_enabled(musb) ((musb)->board_mode == MUSB_OTG) + +/* NOTE: otg and peripheral-only state machines start at B_IDLE. + * OTG or host-only go to A_IDLE when ID is sensed. + */ +#define is_peripheral_active(m) (!(m)->is_host) +#define is_host_active(m) ((m)->is_host) + +#ifndef CONFIG_HAVE_CLK +/* Dummy stub for clk framework */ +#define clk_get(dev, id) NULL +#define clk_put(clock) do {} while (0) +#define clk_enable(clock) do {} while (0) +#define clk_disable(clock) do {} while (0) +#endif + +#ifdef CONFIG_PROC_FS +#include <linux/fs.h> +#define MUSB_CONFIG_PROC_FS +#endif + +/****************************** PERIPHERAL ROLE *****************************/ + +#define is_peripheral_capable() (1) + +extern irqreturn_t musb_g_ep0_irq(struct musb *); +extern void musb_g_tx(struct musb *, u8); +extern void musb_g_rx(struct musb *, u8); +extern void musb_g_reset(struct musb *); +extern void musb_g_suspend(struct musb *); +extern void musb_g_resume(struct musb *); +extern void musb_g_wakeup(struct musb *); +extern void musb_g_disconnect(struct musb *); + +/****************************** HOST ROLE ***********************************/ + +#define is_host_capable() (1) + +extern irqreturn_t musb_h_ep0_irq(struct musb *); +extern void musb_host_tx(struct musb *, u8); +extern void musb_host_rx(struct musb *, u8); + +/****************************** CONSTANTS ********************************/ + +#ifndef MUSB_C_NUM_EPS +#define MUSB_C_NUM_EPS ((u8)16) +#endif + +#ifndef MUSB_MAX_END0_PACKET +#define MUSB_MAX_END0_PACKET ((u16)MUSB_EP0_FIFOSIZE) +#endif + +/* host side ep0 states */ +enum musb_h_ep0_state { + MUSB_EP0_IDLE, + MUSB_EP0_START, /* expect ack of setup */ + MUSB_EP0_IN, /* expect IN DATA */ + MUSB_EP0_OUT, /* expect ack of OUT DATA */ + MUSB_EP0_STATUS, /* expect ack of STATUS */ +} __attribute__ ((packed)); + +/* peripheral side ep0 states */ +enum musb_g_ep0_state { + MUSB_EP0_STAGE_IDLE, /* idle, waiting for SETUP */ + MUSB_EP0_STAGE_SETUP, /* received SETUP */ + MUSB_EP0_STAGE_TX, /* IN data */ + MUSB_EP0_STAGE_RX, /* OUT data */ + MUSB_EP0_STAGE_STATUSIN, /* (after OUT data) */ + MUSB_EP0_STAGE_STATUSOUT, /* (after IN data) */ + MUSB_EP0_STAGE_ACKWAIT, /* after zlp, before statusin */ +} __attribute__ ((packed)); + +/* + * OTG protocol constants. See USB OTG 1.3 spec, + * sections 5.5 "Device Timings" and 6.6.5 "Timers". + */ +#define OTG_TIME_A_WAIT_VRISE 100 /* msec (max) */ +#define OTG_TIME_A_WAIT_BCON 1100 /* min 1 second */ +#define OTG_TIME_A_AIDL_BDIS 200 /* min 200 msec */ +#define OTG_TIME_B_ASE0_BRST 100 /* min 3.125 ms */ + + +/*************************** REGISTER ACCESS ********************************/ + +/* Endpoint registers (other than dynfifo setup) can be accessed either + * directly with the "flat" model, or after setting up an index register. + */ + +#if defined(CONFIG_ARCH_DAVINCI) || defined(CONFIG_SOC_OMAP2430) \ + || defined(CONFIG_SOC_OMAP3430) || defined(CONFIG_BLACKFIN) \ + || defined(CONFIG_ARCH_OMAP4) +/* REVISIT indexed access seemed to + * misbehave (on DaVinci) for at least peripheral IN ... + */ +#define MUSB_FLAT_REG +#endif + +/* TUSB mapping: "flat" plus ep0 special cases */ +#if defined(CONFIG_USB_MUSB_TUSB6010) || \ + defined(CONFIG_USB_MUSB_TUSB6010_MODULE) +#define musb_ep_select(_mbase, _epnum) \ + musb_writeb((_mbase), MUSB_INDEX, (_epnum)) +#define MUSB_EP_OFFSET MUSB_TUSB_OFFSET + +/* "flat" mapping: each endpoint has its own i/o address */ +#elif defined(MUSB_FLAT_REG) +#define musb_ep_select(_mbase, _epnum) (((void)(_mbase)), ((void)(_epnum))) +#define MUSB_EP_OFFSET MUSB_FLAT_OFFSET + +/* "indexed" mapping: INDEX register controls register bank select */ +#else +#define musb_ep_select(_mbase, _epnum) \ + musb_writeb((_mbase), MUSB_INDEX, (_epnum)) +#define MUSB_EP_OFFSET MUSB_INDEXED_OFFSET +#endif + +/****************************** FUNCTIONS ********************************/ + +#define MUSB_HST_MODE(_musb)\ + { (_musb)->is_host = true; } +#define MUSB_DEV_MODE(_musb) \ + { (_musb)->is_host = false; } + +#define test_devctl_hst_mode(_x) \ + (musb_readb((_x)->mregs, MUSB_DEVCTL)&MUSB_DEVCTL_HM) + +#define MUSB_MODE(musb) ((musb)->is_host ? "Host" : "Peripheral") + +/******************************** TYPES *************************************/ + +/** + * struct musb_platform_ops - Operations passed to musb_core by HW glue layer + * @init: turns on clocks, sets up platform-specific registers, etc + * @exit: undoes @init + * @set_mode: forcefully changes operating mode + * @try_ilde: tries to idle the IP + * @vbus_status: returns vbus status if possible + * @set_vbus: forces vbus status + * @adjust_channel_params: pre check for standard dma channel_program func + */ +struct musb_platform_ops { + int (*init)(struct musb *musb); + int (*exit)(struct musb *musb); + + void (*enable)(struct musb *musb); + void (*disable)(struct musb *musb); + + int (*set_mode)(struct musb *musb, u8 mode); + void (*try_idle)(struct musb *musb, unsigned long timeout); + + int (*vbus_status)(struct musb *musb); + void (*set_vbus)(struct musb *musb, int on); + + int (*adjust_channel_params)(struct dma_channel *channel, + u16 packet_sz, u8 *mode, + dma_addr_t *dma_addr, u32 *len); +}; + +/* + * struct musb_hw_ep - endpoint hardware (bidirectional) + * + * Ordered slightly for better cacheline locality. + */ +struct musb_hw_ep { + struct musb *musb; + void __iomem *fifo; + void __iomem *regs; + +#if defined(CONFIG_USB_MUSB_TUSB6010) || \ + defined(CONFIG_USB_MUSB_TUSB6010_MODULE) + void __iomem *conf; +#endif + + /* index in musb->endpoints[] */ + u8 epnum; + + /* hardware configuration, possibly dynamic */ + bool is_shared_fifo; + bool tx_double_buffered; + bool rx_double_buffered; + u16 max_packet_sz_tx; + u16 max_packet_sz_rx; + + struct dma_channel *tx_channel; + struct dma_channel *rx_channel; + +#if defined(CONFIG_USB_MUSB_TUSB6010) || \ + defined(CONFIG_USB_MUSB_TUSB6010_MODULE) + /* TUSB has "asynchronous" and "synchronous" dma modes */ + dma_addr_t fifo_async; + dma_addr_t fifo_sync; + void __iomem *fifo_sync_va; +#endif + + void __iomem *target_regs; + + /* currently scheduled peripheral endpoint */ + struct musb_qh *in_qh; + struct musb_qh *out_qh; + + u8 rx_reinit; + u8 tx_reinit; + + /* peripheral side */ + struct musb_ep ep_in; /* TX */ + struct musb_ep ep_out; /* RX */ +}; + +static inline struct musb_request *next_in_request(struct musb_hw_ep *hw_ep) +{ + return next_request(&hw_ep->ep_in); +} + +static inline struct musb_request *next_out_request(struct musb_hw_ep *hw_ep) +{ + return next_request(&hw_ep->ep_out); +} + +struct musb_csr_regs { + /* FIFO registers */ + u16 txmaxp, txcsr, rxmaxp, rxcsr; + u16 rxfifoadd, txfifoadd; + u8 txtype, txinterval, rxtype, rxinterval; + u8 rxfifosz, txfifosz; + u8 txfunaddr, txhubaddr, txhubport; + u8 rxfunaddr, rxhubaddr, rxhubport; +}; + +struct musb_context_registers { + + u8 power; + u16 intrtxe, intrrxe; + u8 intrusbe; + u16 frame; + u8 index, testmode; + + u8 devctl, busctl, misc; + u32 otg_interfsel; + + struct musb_csr_regs index_regs[MUSB_C_NUM_EPS]; +}; + +/* + * struct musb - Driver instance data. + */ +struct musb { + /* device lock */ + spinlock_t lock; + + const struct musb_platform_ops *ops; + struct musb_context_registers context; + + irqreturn_t (*isr)(int, void *); + struct work_struct irq_work; + struct work_struct otg_notifier_work; + u16 hwvers; + +/* this hub status bit is reserved by USB 2.0 and not seen by usbcore */ +#define MUSB_PORT_STAT_RESUME (1 << 31) + + u32 port1_status; + + unsigned long rh_timer; + + enum musb_h_ep0_state ep0_stage; + + /* bulk traffic normally dedicates endpoint hardware, and each + * direction has its own ring of host side endpoints. + * we try to progress the transfer at the head of each endpoint's + * queue until it completes or NAKs too much; then we try the next + * endpoint. + */ + struct musb_hw_ep *bulk_ep; + + struct list_head control; /* of musb_qh */ + struct list_head in_bulk; /* of musb_qh */ + struct list_head out_bulk; /* of musb_qh */ + + struct timer_list otg_timer; + struct notifier_block nb; + + struct dma_controller *dma_controller; + + struct device *controller; + void __iomem *ctrl_base; + void __iomem *mregs; + +#if defined(CONFIG_USB_MUSB_TUSB6010) || \ + defined(CONFIG_USB_MUSB_TUSB6010_MODULE) + dma_addr_t async; + dma_addr_t sync; + void __iomem *sync_va; +#endif + + /* passed down from chip/board specific irq handlers */ + u8 int_usb; + u16 int_rx; + u16 int_tx; + + struct usb_phy *xceiv; + u8 xceiv_event; + + int nIrq; + unsigned irq_wake:1; + + struct musb_hw_ep endpoints[MUSB_C_NUM_EPS]; +#define control_ep endpoints + +#define VBUSERR_RETRY_COUNT 3 + u16 vbuserr_retry; + u16 epmask; + u8 nr_endpoints; + + u8 board_mode; /* enum musb_mode */ + int (*board_set_power)(int state); + + u8 min_power; /* vbus for periph, in mA/2 */ + + bool is_host; + + int a_wait_bcon; /* VBUS timeout in msecs */ + unsigned long idle_timeout; /* Next timeout in jiffies */ + + /* active means connected and not suspended */ + unsigned is_active:1; + + unsigned is_multipoint:1; + unsigned ignore_disconnect:1; /* during bus resets */ + + unsigned hb_iso_rx:1; /* high bandwidth iso rx? */ + unsigned hb_iso_tx:1; /* high bandwidth iso tx? */ + unsigned dyn_fifo:1; /* dynamic FIFO supported? */ + + unsigned bulk_split:1; +#define can_bulk_split(musb,type) \ + (((type) == USB_ENDPOINT_XFER_BULK) && (musb)->bulk_split) + + unsigned bulk_combine:1; +#define can_bulk_combine(musb,type) \ + (((type) == USB_ENDPOINT_XFER_BULK) && (musb)->bulk_combine) + + /* is_suspended means USB B_PERIPHERAL suspend */ + unsigned is_suspended:1; + + /* may_wakeup means remote wakeup is enabled */ + unsigned may_wakeup:1; + + /* is_self_powered is reported in device status and the + * config descriptor. is_bus_powered means B_PERIPHERAL + * draws some VBUS current; both can be true. + */ + unsigned is_self_powered:1; + unsigned is_bus_powered:1; + + unsigned set_address:1; + unsigned test_mode:1; + unsigned softconnect:1; + + u8 address; + u8 test_mode_nr; + u16 ackpend; /* ep0 */ + enum musb_g_ep0_state ep0_state; + struct usb_gadget g; /* the gadget */ + struct usb_gadget_driver *gadget_driver; /* its driver */ + + /* + * FIXME: Remove this flag. + * + * This is only added to allow Blackfin to work + * with current driver. For some unknown reason + * Blackfin doesn't work with double buffering + * and that's enabled by default. + * + * We added this flag to forcefully disable double + * buffering until we get it working. + */ + unsigned double_buffer_not_ok:1; + + struct musb_hdrc_config *config; + +#ifdef MUSB_CONFIG_PROC_FS + struct proc_dir_entry *proc_entry; +#endif +}; + +static inline struct musb *gadget_to_musb(struct usb_gadget *g) +{ + return container_of(g, struct musb, g); +} + +#ifdef CONFIG_BLACKFIN +static inline int musb_read_fifosize(struct musb *musb, + struct musb_hw_ep *hw_ep, u8 epnum) +{ + musb->nr_endpoints++; + musb->epmask |= (1 << epnum); + + if (epnum < 5) { + hw_ep->max_packet_sz_tx = 128; + hw_ep->max_packet_sz_rx = 128; + } else { + hw_ep->max_packet_sz_tx = 1024; + hw_ep->max_packet_sz_rx = 1024; + } + hw_ep->is_shared_fifo = false; + + return 0; +} + +static inline void musb_configure_ep0(struct musb *musb) +{ + musb->endpoints[0].max_packet_sz_tx = MUSB_EP0_FIFOSIZE; + musb->endpoints[0].max_packet_sz_rx = MUSB_EP0_FIFOSIZE; + musb->endpoints[0].is_shared_fifo = true; +} + +#else + +static inline int musb_read_fifosize(struct musb *musb, + struct musb_hw_ep *hw_ep, u8 epnum) +{ + void *mbase = musb->mregs; + u8 reg = 0; + + /* read from core using indexed model */ + reg = musb_readb(mbase, MUSB_EP_OFFSET(epnum, MUSB_FIFOSIZE)); + /* 0's returned when no more endpoints */ + if (!reg) + return -ENODEV; + + musb->nr_endpoints++; + musb->epmask |= (1 << epnum); + + hw_ep->max_packet_sz_tx = 1 << (reg & 0x0f); + + /* shared TX/RX FIFO? */ + if ((reg & 0xf0) == 0xf0) { + hw_ep->max_packet_sz_rx = hw_ep->max_packet_sz_tx; + hw_ep->is_shared_fifo = true; + return 0; + } else { + hw_ep->max_packet_sz_rx = 1 << ((reg & 0xf0) >> 4); + hw_ep->is_shared_fifo = false; + } + + return 0; +} + +static inline void musb_configure_ep0(struct musb *musb) +{ + musb->endpoints[0].max_packet_sz_tx = MUSB_EP0_FIFOSIZE; + musb->endpoints[0].max_packet_sz_rx = MUSB_EP0_FIFOSIZE; + musb->endpoints[0].is_shared_fifo = true; +} +#endif /* CONFIG_BLACKFIN */ + + +/***************************** Glue it together *****************************/ + +extern const char musb_driver_name[]; + +extern void musb_start(struct musb *musb); +extern void musb_stop(struct musb *musb); + +extern void musb_write_fifo(struct musb_hw_ep *ep, u16 len, const u8 *src); +extern void musb_read_fifo(struct musb_hw_ep *ep, u16 len, u8 *dst); + +extern void musb_load_testpacket(struct musb *); + +extern irqreturn_t musb_interrupt(struct musb *); + +extern void musb_hnp_stop(struct musb *musb); + +static inline void musb_platform_set_vbus(struct musb *musb, int is_on) +{ + if (musb->ops->set_vbus) + musb->ops->set_vbus(musb, is_on); +} + +static inline void musb_platform_enable(struct musb *musb) +{ + if (musb->ops->enable) + musb->ops->enable(musb); +} + +static inline void musb_platform_disable(struct musb *musb) +{ + if (musb->ops->disable) + musb->ops->disable(musb); +} + +static inline int musb_platform_set_mode(struct musb *musb, u8 mode) +{ + if (!musb->ops->set_mode) + return 0; + + return musb->ops->set_mode(musb, mode); +} + +static inline void musb_platform_try_idle(struct musb *musb, + unsigned long timeout) +{ + if (musb->ops->try_idle) + musb->ops->try_idle(musb, timeout); +} + +static inline int musb_platform_get_vbus_status(struct musb *musb) +{ + if (!musb->ops->vbus_status) + return 0; + + return musb->ops->vbus_status(musb); +} + +static inline int musb_platform_init(struct musb *musb) +{ + if (!musb->ops->init) + return -EINVAL; + + return musb->ops->init(musb); +} + +static inline int musb_platform_exit(struct musb *musb) +{ + if (!musb->ops->exit) + return -EINVAL; + + return musb->ops->exit(musb); +} + +#endif /* __MUSB_CORE_H__ */ diff --git a/drivers/usb/musb-new/musb_debug.h b/drivers/usb/musb-new/musb_debug.h new file mode 100644 index 0000000..27ba8f7 --- /dev/null +++ b/drivers/usb/musb-new/musb_debug.h @@ -0,0 +1,58 @@ +/* + * MUSB OTG driver debug defines + * + * Copyright 2005 Mentor Graphics Corporation + * Copyright (C) 2005-2006 by Texas Instruments + * Copyright (C) 2006-2007 Nokia Corporation + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, but + * WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU + * General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA + * 02110-1301 USA + * + * THIS SOFTWARE IS PROVIDED "AS IS" AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN + * NO EVENT SHALL THE AUTHORS BE LIABLE FOR ANY DIRECT, INDIRECT, + * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT + * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF + * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON + * ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT + * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF + * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. + * + */ + +#ifndef __MUSB_LINUX_DEBUG_H__ +#define __MUSB_LINUX_DEBUG_H__ + +#define yprintk(facility, format, args...) \ + do { printk(facility "%s %d: " format , \ + __func__, __LINE__ , ## args); } while (0) +#define WARNING(fmt, args...) yprintk(KERN_WARNING, fmt, ## args) +#define INFO(fmt, args...) yprintk(KERN_INFO, fmt, ## args) +#define ERR(fmt, args...) yprintk(KERN_ERR, fmt, ## args) + +#ifdef CONFIG_DEBUG_FS +int musb_init_debugfs(struct musb *musb); +void musb_exit_debugfs(struct musb *musb); +#else +static inline int musb_init_debugfs(struct musb *musb) +{ + return 0; +} +static inline void musb_exit_debugfs(struct musb *musb) +{ +} +#endif + +#endif /* __MUSB_LINUX_DEBUG_H__ */ diff --git a/drivers/usb/musb-new/musb_dma.h b/drivers/usb/musb-new/musb_dma.h new file mode 100644 index 0000000..3a97c4e --- /dev/null +++ b/drivers/usb/musb-new/musb_dma.h @@ -0,0 +1,186 @@ +/* + * MUSB OTG driver DMA controller abstraction + * + * Copyright 2005 Mentor Graphics Corporation + * Copyright (C) 2005-2006 by Texas Instruments + * Copyright (C) 2006-2007 Nokia Corporation + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, but + * WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU + * General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA + * 02110-1301 USA + * + * THIS SOFTWARE IS PROVIDED "AS IS" AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN + * NO EVENT SHALL THE AUTHORS BE LIABLE FOR ANY DIRECT, INDIRECT, + * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT + * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF + * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON + * ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT + * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF + * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. + * + */ + +#ifndef __MUSB_DMA_H__ +#define __MUSB_DMA_H__ + +struct musb_hw_ep; + +/* + * DMA Controller Abstraction + * + * DMA Controllers are abstracted to allow use of a variety of different + * implementations of DMA, as allowed by the Inventra USB cores. On the + * host side, usbcore sets up the DMA mappings and flushes caches; on the + * peripheral side, the gadget controller driver does. Responsibilities + * of a DMA controller driver include: + * + * - Handling the details of moving multiple USB packets + * in cooperation with the Inventra USB core, including especially + * the correct RX side treatment of short packets and buffer-full + * states (both of which terminate transfers). + * + * - Knowing the correlation between dma channels and the + * Inventra core's local endpoint resources and data direction. + * + * - Maintaining a list of allocated/available channels. + * + * - Updating channel status on interrupts, + * whether shared with the Inventra core or separate. + */ + +#define DMA_ADDR_INVALID (~(dma_addr_t)0) + +#ifndef CONFIG_MUSB_PIO_ONLY +#define is_dma_capable() (1) +#else +#define is_dma_capable() (0) +#endif + +#ifdef CONFIG_USB_TI_CPPI_DMA +#define is_cppi_enabled() 1 +#else +#define is_cppi_enabled() 0 +#endif + +#ifdef CONFIG_USB_TUSB_OMAP_DMA +#define tusb_dma_omap() 1 +#else +#define tusb_dma_omap() 0 +#endif + +/* Anomaly 05000456 - USB Receive Interrupt Is Not Generated in DMA Mode 1 + * Only allow DMA mode 1 to be used when the USB will actually generate the + * interrupts we expect. + */ +#ifdef CONFIG_BLACKFIN +# undef USE_MODE1 +# if !ANOMALY_05000456 +# define USE_MODE1 +# endif +#endif + +/* + * DMA channel status ... updated by the dma controller driver whenever that + * status changes, and protected by the overall controller spinlock. + */ +enum dma_channel_status { + /* unallocated */ + MUSB_DMA_STATUS_UNKNOWN, + /* allocated ... but not busy, no errors */ + MUSB_DMA_STATUS_FREE, + /* busy ... transactions are active */ + MUSB_DMA_STATUS_BUSY, + /* transaction(s) aborted due to ... dma or memory bus error */ + MUSB_DMA_STATUS_BUS_ABORT, + /* transaction(s) aborted due to ... core error or USB fault */ + MUSB_DMA_STATUS_CORE_ABORT +}; + +struct dma_controller; + +/** + * struct dma_channel - A DMA channel. + * @private_data: channel-private data + * @max_len: the maximum number of bytes the channel can move in one + * transaction (typically representing many USB maximum-sized packets) + * @actual_len: how many bytes have been transferred + * @status: current channel status (updated e.g. on interrupt) + * @desired_mode: true if mode 1 is desired; false if mode 0 is desired + * + * channels are associated with an endpoint for the duration of at least + * one usb transfer. + */ +struct dma_channel { + void *private_data; + /* FIXME not void* private_data, but a dma_controller * */ + size_t max_len; + size_t actual_len; + enum dma_channel_status status; + bool desired_mode; +}; + +/* + * dma_channel_status - return status of dma channel + * @c: the channel + * + * Returns the software's view of the channel status. If that status is BUSY + * then it's possible that the hardware has completed (or aborted) a transfer, + * so the driver needs to update that status. + */ +static inline enum dma_channel_status +dma_channel_status(struct dma_channel *c) +{ + return (is_dma_capable() && c) ? c->status : MUSB_DMA_STATUS_UNKNOWN; +} + +/** + * struct dma_controller - A DMA Controller. + * @start: call this to start a DMA controller; + * return 0 on success, else negative errno + * @stop: call this to stop a DMA controller + * return 0 on success, else negative errno + * @channel_alloc: call this to allocate a DMA channel + * @channel_release: call this to release a DMA channel + * @channel_abort: call this to abort a pending DMA transaction, + * returning it to FREE (but allocated) state + * + * Controllers manage dma channels. + */ +struct dma_controller { + int (*start)(struct dma_controller *); + int (*stop)(struct dma_controller *); + struct dma_channel *(*channel_alloc)(struct dma_controller *, + struct musb_hw_ep *, u8 is_tx); + void (*channel_release)(struct dma_channel *); + int (*channel_program)(struct dma_channel *channel, + u16 maxpacket, u8 mode, + dma_addr_t dma_addr, + u32 length); + int (*channel_abort)(struct dma_channel *); + int (*is_compatible)(struct dma_channel *channel, + u16 maxpacket, + void *buf, u32 length); +}; + +/* called after channel_program(), may indicate a fault */ +extern void musb_dma_completion(struct musb *musb, u8 epnum, u8 transmit); + + +extern struct dma_controller *__init +dma_controller_create(struct musb *, void __iomem *); + +extern void dma_controller_destroy(struct dma_controller *); + +#endif /* __MUSB_DMA_H__ */ diff --git a/drivers/usb/musb-new/musb_gadget.c b/drivers/usb/musb-new/musb_gadget.c new file mode 100644 index 0000000..4f3e84f --- /dev/null +++ b/drivers/usb/musb-new/musb_gadget.c @@ -0,0 +1,2319 @@ +/* + * MUSB OTG driver peripheral support + * + * Copyright 2005 Mentor Graphics Corporation + * Copyright (C) 2005-2006 by Texas Instruments + * Copyright (C) 2006-2007 Nokia Corporation + * Copyright (C) 2009 MontaVista Software, Inc. source@mvista.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, but + * WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU + * General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA + * 02110-1301 USA + * + * THIS SOFTWARE IS PROVIDED "AS IS" AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN + * NO EVENT SHALL THE AUTHORS BE LIABLE FOR ANY DIRECT, INDIRECT, + * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT + * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF + * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON + * ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT + * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF + * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. + * + */ + +#define __UBOOT__ +#ifndef __UBOOT__ +#include <linux/kernel.h> +#include <linux/list.h> +#include <linux/timer.h> +#include <linux/module.h> +#include <linux/smp.h> +#include <linux/spinlock.h> +#include <linux/delay.h> +#include <linux/dma-mapping.h> +#include <linux/slab.h> +#else +#include <common.h> +#include <linux/usb/ch9.h> +#include "linux-compat.h" +#endif + +#include "musb_core.h" + + +/* MUSB PERIPHERAL status 3-mar-2006: + * + * - EP0 seems solid. It passes both USBCV and usbtest control cases. + * Minor glitches: + * + * + remote wakeup to Linux hosts work, but saw USBCV failures; + * in one test run (operator error?) + * + endpoint halt tests -- in both usbtest and usbcv -- seem + * to break when dma is enabled ... is something wrongly + * clearing SENDSTALL? + * + * - Mass storage behaved ok when last tested. Network traffic patterns + * (with lots of short transfers etc) need retesting; they turn up the + * worst cases of the DMA, since short packets are typical but are not + * required. + * + * - TX/IN + * + both pio and dma behave in with network and g_zero tests + * + no cppi throughput issues other than no-hw-queueing + * + failed with FLAT_REG (DaVinci) + * + seems to behave with double buffering, PIO -and- CPPI + * + with gadgetfs + AIO, requests got lost? + * + * - RX/OUT + * + both pio and dma behave in with network and g_zero tests + * + dma is slow in typical case (short_not_ok is clear) + * + double buffering ok with PIO + * + double buffering *FAILS* with CPPI, wrong data bytes sometimes + * + request lossage observed with gadgetfs + * + * - ISO not tested ... might work, but only weakly isochronous + * + * - Gadget driver disabling of softconnect during bind() is ignored; so + * drivers can't hold off host requests until userspace is ready. + * (Workaround: they can turn it off later.) + * + * - PORTABILITY (assumes PIO works): + * + DaVinci, basically works with cppi dma + * + OMAP 2430, ditto with mentor dma + * + TUSB 6010, platform-specific dma in the works + */ + +/* ----------------------------------------------------------------------- */ + +#define is_buffer_mapped(req) (is_dma_capable() && \ + (req->map_state != UN_MAPPED)) + +#ifndef CONFIG_MUSB_PIO_ONLY +/* Maps the buffer to dma */ + +static inline void map_dma_buffer(struct musb_request *request, + struct musb *musb, struct musb_ep *musb_ep) +{ + int compatible = true; + struct dma_controller *dma = musb->dma_controller; + + request->map_state = UN_MAPPED; + + if (!is_dma_capable() || !musb_ep->dma) + return; + + /* Check if DMA engine can handle this request. + * DMA code must reject the USB request explicitly. + * Default behaviour is to map the request. + */ + if (dma->is_compatible) + compatible = dma->is_compatible(musb_ep->dma, + musb_ep->packet_sz, request->request.buf, + request->request.length); + if (!compatible) + return; + + if (request->request.dma == DMA_ADDR_INVALID) { + request->request.dma = dma_map_single( + musb->controller, + request->request.buf, + request->request.length, + request->tx + ? DMA_TO_DEVICE + : DMA_FROM_DEVICE); + request->map_state = MUSB_MAPPED; + } else { + dma_sync_single_for_device(musb->controller, + request->request.dma, + request->request.length, + request->tx + ? DMA_TO_DEVICE + : DMA_FROM_DEVICE); + request->map_state = PRE_MAPPED; + } +} + +/* Unmap the buffer from dma and maps it back to cpu */ +static inline void unmap_dma_buffer(struct musb_request *request, + struct musb *musb) +{ + if (!is_buffer_mapped(request)) + return; + + if (request->request.dma == DMA_ADDR_INVALID) { + dev_vdbg(musb->controller, + "not unmapping a never mapped buffer\n"); + return; + } + if (request->map_state == MUSB_MAPPED) { + dma_unmap_single(musb->controller, + request->request.dma, + request->request.length, + request->tx + ? DMA_TO_DEVICE + : DMA_FROM_DEVICE); + request->request.dma = DMA_ADDR_INVALID; + } else { /* PRE_MAPPED */ + dma_sync_single_for_cpu(musb->controller, + request->request.dma, + request->request.length, + request->tx + ? DMA_TO_DEVICE + : DMA_FROM_DEVICE); + } + request->map_state = UN_MAPPED; +} +#else +static inline void map_dma_buffer(struct musb_request *request, + struct musb *musb, struct musb_ep *musb_ep) +{ +} + +static inline void unmap_dma_buffer(struct musb_request *request, + struct musb *musb) +{ +} +#endif + +/* + * Immediately complete a request. + * + * @param request the request to complete + * @param status the status to complete the request with + * Context: controller locked, IRQs blocked. + */ +void musb_g_giveback( + struct musb_ep *ep, + struct usb_request *request, + int status) +__releases(ep->musb->lock) +__acquires(ep->musb->lock) +{ + struct musb_request *req; + struct musb *musb; + int busy = ep->busy; + + req = to_musb_request(request); + + list_del(&req->list); + if (req->request.status == -EINPROGRESS) + req->request.status = status; + musb = req->musb; + + ep->busy = 1; + spin_unlock(&musb->lock); + unmap_dma_buffer(req, musb); + if (request->status == 0) + dev_dbg(musb->controller, "%s done request %p, %d/%d\n", + ep->end_point.name, request, + req->request.actual, req->request.length); + else + dev_dbg(musb->controller, "%s request %p, %d/%d fault %d\n", + ep->end_point.name, request, + req->request.actual, req->request.length, + request->status); + req->request.complete(&req->ep->end_point, &req->request); + spin_lock(&musb->lock); + ep->busy = busy; +} + +/* ----------------------------------------------------------------------- */ + +/* + * Abort requests queued to an endpoint using the status. Synchronous. + * caller locked controller and blocked irqs, and selected this ep. + */ +static void nuke(struct musb_ep *ep, const int status) +{ + struct musb *musb = ep->musb; + struct musb_request *req = NULL; + void __iomem *epio = ep->musb->endpoints[ep->current_epnum].regs; + + ep->busy = 1; + + if (is_dma_capable() && ep->dma) { + struct dma_controller *c = ep->musb->dma_controller; + int value; + + if (ep->is_in) { + /* + * The programming guide says that we must not clear + * the DMAMODE bit before DMAENAB, so we only + * clear it in the second write... + */ + musb_writew(epio, MUSB_TXCSR, + MUSB_TXCSR_DMAMODE | MUSB_TXCSR_FLUSHFIFO); + musb_writew(epio, MUSB_TXCSR, + 0 | MUSB_TXCSR_FLUSHFIFO); + } else { + musb_writew(epio, MUSB_RXCSR, + 0 | MUSB_RXCSR_FLUSHFIFO); + musb_writew(epio, MUSB_RXCSR, + 0 | MUSB_RXCSR_FLUSHFIFO); + } + + value = c->channel_abort(ep->dma); + dev_dbg(musb->controller, "%s: abort DMA --> %d\n", + ep->name, value); + c->channel_release(ep->dma); + ep->dma = NULL; + } + + while (!list_empty(&ep->req_list)) { + req = list_first_entry(&ep->req_list, struct musb_request, list); + musb_g_giveback(ep, &req->request, status); + } +} + +/* ----------------------------------------------------------------------- */ + +/* Data transfers - pure PIO, pure DMA, or mixed mode */ + +/* + * This assumes the separate CPPI engine is responding to DMA requests + * from the usb core ... sequenced a bit differently from mentor dma. + */ + +static inline int max_ep_writesize(struct musb *musb, struct musb_ep *ep) +{ + if (can_bulk_split(musb, ep->type)) + return ep->hw_ep->max_packet_sz_tx; + else + return ep->packet_sz; +} + + +#ifdef CONFIG_USB_INVENTRA_DMA + +/* Peripheral tx (IN) using Mentor DMA works as follows: + Only mode 0 is used for transfers <= wPktSize, + mode 1 is used for larger transfers, + + One of the following happens: + - Host sends IN token which causes an endpoint interrupt + -> TxAvail + -> if DMA is currently busy, exit. + -> if queue is non-empty, txstate(). + + - Request is queued by the gadget driver. + -> if queue was previously empty, txstate() + + txstate() + -> start + /\ -> setup DMA + | (data is transferred to the FIFO, then sent out when + | IN token(s) are recd from Host. + | -> DMA interrupt on completion + | calls TxAvail. + | -> stop DMA, ~DMAENAB, + | -> set TxPktRdy for last short pkt or zlp + | -> Complete Request + | -> Continue next request (call txstate) + |___________________________________| + + * Non-Mentor DMA engines can of course work differently, such as by + * upleveling from irq-per-packet to irq-per-buffer. + */ + +#endif + +/* + * An endpoint is transmitting data. This can be called either from + * the IRQ routine or from ep.queue() to kickstart a request on an + * endpoint. + * + * Context: controller locked, IRQs blocked, endpoint selected + */ +static void txstate(struct musb *musb, struct musb_request *req) +{ + u8 epnum = req->epnum; + struct musb_ep *musb_ep; + void __iomem *epio = musb->endpoints[epnum].regs; + struct usb_request *request; + u16 fifo_count = 0, csr; + int use_dma = 0; + + musb_ep = req->ep; + + /* we shouldn't get here while DMA is active ... but we do ... */ + if (dma_channel_status(musb_ep->dma) == MUSB_DMA_STATUS_BUSY) { + dev_dbg(musb->controller, "dma pending...\n"); + return; + } + + /* read TXCSR before */ + csr = musb_readw(epio, MUSB_TXCSR); + + request = &req->request; + fifo_count = min(max_ep_writesize(musb, musb_ep), + (int)(request->length - request->actual)); + + if (csr & MUSB_TXCSR_TXPKTRDY) { + dev_dbg(musb->controller, "%s old packet still ready , txcsr %03x\n", + musb_ep->end_point.name, csr); + return; + } + + if (csr & MUSB_TXCSR_P_SENDSTALL) { + dev_dbg(musb->controller, "%s stalling, txcsr %03x\n", + musb_ep->end_point.name, csr); + return; + } + + dev_dbg(musb->controller, "hw_ep%d, maxpacket %d, fifo count %d, txcsr %03x\n", + epnum, musb_ep->packet_sz, fifo_count, + csr); + +#ifndef CONFIG_MUSB_PIO_ONLY + if (is_buffer_mapped(req)) { + struct dma_controller *c = musb->dma_controller; + size_t request_size; + + /* setup DMA, then program endpoint CSR */ + request_size = min_t(size_t, request->length - request->actual, + musb_ep->dma->max_len); + + use_dma = (request->dma != DMA_ADDR_INVALID); + + /* MUSB_TXCSR_P_ISO is still set correctly */ + +#if defined(CONFIG_USB_INVENTRA_DMA) || defined(CONFIG_USB_UX500_DMA) + { + if (request_size < musb_ep->packet_sz) + musb_ep->dma->desired_mode = 0; + else + musb_ep->dma->desired_mode = 1; + + use_dma = use_dma && c->channel_program( + musb_ep->dma, musb_ep->packet_sz, + musb_ep->dma->desired_mode, + request->dma + request->actual, request_size); + if (use_dma) { + if (musb_ep->dma->desired_mode == 0) { + /* + * We must not clear the DMAMODE bit + * before the DMAENAB bit -- and the + * latter doesn't always get cleared + * before we get here... + */ + csr &= ~(MUSB_TXCSR_AUTOSET + | MUSB_TXCSR_DMAENAB); + musb_writew(epio, MUSB_TXCSR, csr + | MUSB_TXCSR_P_WZC_BITS); + csr &= ~MUSB_TXCSR_DMAMODE; + csr |= (MUSB_TXCSR_DMAENAB | + MUSB_TXCSR_MODE); + /* against programming guide */ + } else { + csr |= (MUSB_TXCSR_DMAENAB + | MUSB_TXCSR_DMAMODE + | MUSB_TXCSR_MODE); + if (!musb_ep->hb_mult) + csr |= MUSB_TXCSR_AUTOSET; + } + csr &= ~MUSB_TXCSR_P_UNDERRUN; + + musb_writew(epio, MUSB_TXCSR, csr); + } + } + +#elif defined(CONFIG_USB_TI_CPPI_DMA) + /* program endpoint CSR first, then setup DMA */ + csr &= ~(MUSB_TXCSR_P_UNDERRUN | MUSB_TXCSR_TXPKTRDY); + csr |= MUSB_TXCSR_DMAENAB | MUSB_TXCSR_DMAMODE | + MUSB_TXCSR_MODE; + musb_writew(epio, MUSB_TXCSR, + (MUSB_TXCSR_P_WZC_BITS & ~MUSB_TXCSR_P_UNDERRUN) + | csr); + + /* ensure writebuffer is empty */ + csr = musb_readw(epio, MUSB_TXCSR); + + /* NOTE host side sets DMAENAB later than this; both are + * OK since the transfer dma glue (between CPPI and Mentor + * fifos) just tells CPPI it could start. Data only moves + * to the USB TX fifo when both fifos are ready. + */ + + /* "mode" is irrelevant here; handle terminating ZLPs like + * PIO does, since the hardware RNDIS mode seems unreliable + * except for the last-packet-is-already-short case. + */ + use_dma = use_dma && c->channel_program( + musb_ep->dma, musb_ep->packet_sz, + 0, + request->dma + request->actual, + request_size); + if (!use_dma) { + c->channel_release(musb_ep->dma); + musb_ep->dma = NULL; + csr &= ~MUSB_TXCSR_DMAENAB; + musb_writew(epio, MUSB_TXCSR, csr); + /* invariant: prequest->buf is non-null */ + } +#elif defined(CONFIG_USB_TUSB_OMAP_DMA) + use_dma = use_dma && c->channel_program( + musb_ep->dma, musb_ep->packet_sz, + request->zero, + request->dma + request->actual, + request_size); +#endif + } +#endif + + if (!use_dma) { + /* + * Unmap the dma buffer back to cpu if dma channel + * programming fails + */ + unmap_dma_buffer(req, musb); + + musb_write_fifo(musb_ep->hw_ep, fifo_count, + (u8 *) (request->buf + request->actual)); + request->actual += fifo_count; + csr |= MUSB_TXCSR_TXPKTRDY; + csr &= ~MUSB_TXCSR_P_UNDERRUN; + musb_writew(epio, MUSB_TXCSR, csr); + } + + /* host may already have the data when this message shows... */ + dev_dbg(musb->controller, "%s TX/IN %s len %d/%d, txcsr %04x, fifo %d/%d\n", + musb_ep->end_point.name, use_dma ? "dma" : "pio", + request->actual, request->length, + musb_readw(epio, MUSB_TXCSR), + fifo_count, + musb_readw(epio, MUSB_TXMAXP)); +} + +/* + * FIFO state update (e.g. data ready). + * Called from IRQ, with controller locked. + */ +void musb_g_tx(struct musb *musb, u8 epnum) +{ + u16 csr; + struct musb_request *req; + struct usb_request *request; + u8 __iomem *mbase = musb->mregs; + struct musb_ep *musb_ep = &musb->endpoints[epnum].ep_in; + void __iomem *epio = musb->endpoints[epnum].regs; + struct dma_channel *dma; + + musb_ep_select(mbase, epnum); + req = next_request(musb_ep); + request = &req->request; + + csr = musb_readw(epio, MUSB_TXCSR); + dev_dbg(musb->controller, "<== %s, txcsr %04x\n", musb_ep->end_point.name, csr); + + dma = is_dma_capable() ? musb_ep->dma : NULL; + + /* + * REVISIT: for high bandwidth, MUSB_TXCSR_P_INCOMPTX + * probably rates reporting as a host error. + */ + if (csr & MUSB_TXCSR_P_SENTSTALL) { + csr |= MUSB_TXCSR_P_WZC_BITS; + csr &= ~MUSB_TXCSR_P_SENTSTALL; + musb_writew(epio, MUSB_TXCSR, csr); + return; + } + + if (csr & MUSB_TXCSR_P_UNDERRUN) { + /* We NAKed, no big deal... little reason to care. */ + csr |= MUSB_TXCSR_P_WZC_BITS; + csr &= ~(MUSB_TXCSR_P_UNDERRUN | MUSB_TXCSR_TXPKTRDY); + musb_writew(epio, MUSB_TXCSR, csr); + dev_vdbg(musb->controller, "underrun on ep%d, req %p\n", + epnum, request); + } + + if (dma_channel_status(dma) == MUSB_DMA_STATUS_BUSY) { + /* + * SHOULD NOT HAPPEN... has with CPPI though, after + * changing SENDSTALL (and other cases); harmless? + */ + dev_dbg(musb->controller, "%s dma still busy?\n", musb_ep->end_point.name); + return; + } + + if (request) { + u8 is_dma = 0; + + if (dma && (csr & MUSB_TXCSR_DMAENAB)) { + is_dma = 1; + csr |= MUSB_TXCSR_P_WZC_BITS; + csr &= ~(MUSB_TXCSR_DMAENAB | MUSB_TXCSR_P_UNDERRUN | + MUSB_TXCSR_TXPKTRDY | MUSB_TXCSR_AUTOSET); + musb_writew(epio, MUSB_TXCSR, csr); + /* Ensure writebuffer is empty. */ + csr = musb_readw(epio, MUSB_TXCSR); + request->actual += musb_ep->dma->actual_len; + dev_dbg(musb->controller, "TXCSR%d %04x, DMA off, len %zu, req %p\n", + epnum, csr, musb_ep->dma->actual_len, request); + } + + /* + * First, maybe a terminating short packet. Some DMA + * engines might handle this by themselves. + */ + if ((request->zero && request->length + && (request->length % musb_ep->packet_sz == 0) + && (request->actual == request->length)) +#if defined(CONFIG_USB_INVENTRA_DMA) || defined(CONFIG_USB_UX500_DMA) + || (is_dma && (!dma->desired_mode || + (request->actual & + (musb_ep->packet_sz - 1)))) +#endif + ) { + /* + * On DMA completion, FIFO may not be + * available yet... + */ + if (csr & MUSB_TXCSR_TXPKTRDY) + return; + + dev_dbg(musb->controller, "sending zero pkt\n"); + musb_writew(epio, MUSB_TXCSR, MUSB_TXCSR_MODE + | MUSB_TXCSR_TXPKTRDY); + request->zero = 0; + } + + if (request->actual == request->length) { + musb_g_giveback(musb_ep, request, 0); + /* + * In the giveback function the MUSB lock is + * released and acquired after sometime. During + * this time period the INDEX register could get + * changed by the gadget_queue function especially + * on SMP systems. Reselect the INDEX to be sure + * we are reading/modifying the right registers + */ + musb_ep_select(mbase, epnum); + req = musb_ep->desc ? next_request(musb_ep) : NULL; + if (!req) { + dev_dbg(musb->controller, "%s idle now\n", + musb_ep->end_point.name); + return; + } + } + + txstate(musb, req); + } +} + +/* ------------------------------------------------------------ */ + +#ifdef CONFIG_USB_INVENTRA_DMA + +/* Peripheral rx (OUT) using Mentor DMA works as follows: + - Only mode 0 is used. + + - Request is queued by the gadget class driver. + -> if queue was previously empty, rxstate() + + - Host sends OUT token which causes an endpoint interrupt + /\ -> RxReady + | -> if request queued, call rxstate + | /\ -> setup DMA + | | -> DMA interrupt on completion + | | -> RxReady + | | -> stop DMA + | | -> ack the read + | | -> if data recd = max expected + | | by the request, or host + | | sent a short packet, + | | complete the request, + | | and start the next one. + | |_____________________________________| + | else just wait for the host + | to send the next OUT token. + |__________________________________________________| + + * Non-Mentor DMA engines can of course work differently. + */ + +#endif + +/* + * Context: controller locked, IRQs blocked, endpoint selected + */ +static void rxstate(struct musb *musb, struct musb_request *req) +{ + const u8 epnum = req->epnum; + struct usb_request *request = &req->request; + struct musb_ep *musb_ep; + void __iomem *epio = musb->endpoints[epnum].regs; + unsigned fifo_count = 0; + u16 len; + u16 csr = musb_readw(epio, MUSB_RXCSR); + struct musb_hw_ep *hw_ep = &musb->endpoints[epnum]; + u8 use_mode_1; + + if (hw_ep->is_shared_fifo) + musb_ep = &hw_ep->ep_in; + else + musb_ep = &hw_ep->ep_out; + + len = musb_ep->packet_sz; + + /* We shouldn't get here while DMA is active, but we do... */ + if (dma_channel_status(musb_ep->dma) == MUSB_DMA_STATUS_BUSY) { + dev_dbg(musb->controller, "DMA pending...\n"); + return; + } + + if (csr & MUSB_RXCSR_P_SENDSTALL) { + dev_dbg(musb->controller, "%s stalling, RXCSR %04x\n", + musb_ep->end_point.name, csr); + return; + } + + if (is_cppi_enabled() && is_buffer_mapped(req)) { + struct dma_controller *c = musb->dma_controller; + struct dma_channel *channel = musb_ep->dma; + + /* NOTE: CPPI won't actually stop advancing the DMA + * queue after short packet transfers, so this is almost + * always going to run as IRQ-per-packet DMA so that + * faults will be handled correctly. + */ + if (c->channel_program(channel, + musb_ep->packet_sz, + !request->short_not_ok, + request->dma + request->actual, + request->length - request->actual)) { + + /* make sure that if an rxpkt arrived after the irq, + * the cppi engine will be ready to take it as soon + * as DMA is enabled + */ + csr &= ~(MUSB_RXCSR_AUTOCLEAR + | MUSB_RXCSR_DMAMODE); + csr |= MUSB_RXCSR_DMAENAB | MUSB_RXCSR_P_WZC_BITS; + musb_writew(epio, MUSB_RXCSR, csr); + return; + } + } + + if (csr & MUSB_RXCSR_RXPKTRDY) { + len = musb_readw(epio, MUSB_RXCOUNT); + + /* + * Enable Mode 1 on RX transfers only when short_not_ok flag + * is set. Currently short_not_ok flag is set only from + * file_storage and f_mass_storage drivers + */ + + if (request->short_not_ok && len == musb_ep->packet_sz) + use_mode_1 = 1; + else + use_mode_1 = 0; + + if (request->actual < request->length) { +#ifdef CONFIG_USB_INVENTRA_DMA + if (is_buffer_mapped(req)) { + struct dma_controller *c; + struct dma_channel *channel; + int use_dma = 0; + + c = musb->dma_controller; + channel = musb_ep->dma; + + /* We use DMA Req mode 0 in rx_csr, and DMA controller operates in + * mode 0 only. So we do not get endpoint interrupts due to DMA + * completion. We only get interrupts from DMA controller. + * + * We could operate in DMA mode 1 if we knew the size of the tranfer + * in advance. For mass storage class, request->length = what the host + * sends, so that'd work. But for pretty much everything else, + * request->length is routinely more than what the host sends. For + * most these gadgets, end of is signified either by a short packet, + * or filling the last byte of the buffer. (Sending extra data in + * that last pckate should trigger an overflow fault.) But in mode 1, + * we don't get DMA completion interrupt for short packets. + * + * Theoretically, we could enable DMAReq irq (MUSB_RXCSR_DMAMODE = 1), + * to get endpoint interrupt on every DMA req, but that didn't seem + * to work reliably. + * + * REVISIT an updated g_file_storage can set req->short_not_ok, which + * then becomes usable as a runtime "use mode 1" hint... + */ + + /* Experimental: Mode1 works with mass storage use cases */ + if (use_mode_1) { + csr |= MUSB_RXCSR_AUTOCLEAR; + musb_writew(epio, MUSB_RXCSR, csr); + csr |= MUSB_RXCSR_DMAENAB; + musb_writew(epio, MUSB_RXCSR, csr); + + /* + * this special sequence (enabling and then + * disabling MUSB_RXCSR_DMAMODE) is required + * to get DMAReq to activate + */ + musb_writew(epio, MUSB_RXCSR, + csr | MUSB_RXCSR_DMAMODE); + musb_writew(epio, MUSB_RXCSR, csr); + + } else { + if (!musb_ep->hb_mult && + musb_ep->hw_ep->rx_double_buffered) + csr |= MUSB_RXCSR_AUTOCLEAR; + csr |= MUSB_RXCSR_DMAENAB; + musb_writew(epio, MUSB_RXCSR, csr); + } + + if (request->actual < request->length) { + int transfer_size = 0; + if (use_mode_1) { + transfer_size = min(request->length - request->actual, + channel->max_len); + musb_ep->dma->desired_mode = 1; + } else { + transfer_size = min(request->length - request->actual, + (unsigned)len); + musb_ep->dma->desired_mode = 0; + } + + use_dma = c->channel_program( + channel, + musb_ep->packet_sz, + channel->desired_mode, + request->dma + + request->actual, + transfer_size); + } + + if (use_dma) + return; + } +#elif defined(CONFIG_USB_UX500_DMA) + if ((is_buffer_mapped(req)) && + (request->actual < request->length)) { + + struct dma_controller *c; + struct dma_channel *channel; + int transfer_size = 0; + + c = musb->dma_controller; + channel = musb_ep->dma; + + /* In case first packet is short */ + if (len < musb_ep->packet_sz) + transfer_size = len; + else if (request->short_not_ok) + transfer_size = min(request->length - + request->actual, + channel->max_len); + else + transfer_size = min(request->length - + request->actual, + (unsigned)len); + + csr &= ~MUSB_RXCSR_DMAMODE; + csr |= (MUSB_RXCSR_DMAENAB | + MUSB_RXCSR_AUTOCLEAR); + + musb_writew(epio, MUSB_RXCSR, csr); + + if (transfer_size <= musb_ep->packet_sz) { + musb_ep->dma->desired_mode = 0; + } else { + musb_ep->dma->desired_mode = 1; + /* Mode must be set after DMAENAB */ + csr |= MUSB_RXCSR_DMAMODE; + musb_writew(epio, MUSB_RXCSR, csr); + } + + if (c->channel_program(channel, + musb_ep->packet_sz, + channel->desired_mode, + request->dma + + request->actual, + transfer_size)) + + return; + } +#endif /* Mentor's DMA */ + + fifo_count = request->length - request->actual; + dev_dbg(musb->controller, "%s OUT/RX pio fifo %d/%d, maxpacket %d\n", + musb_ep->end_point.name, + len, fifo_count, + musb_ep->packet_sz); + + fifo_count = min_t(unsigned, len, fifo_count); + +#ifdef CONFIG_USB_TUSB_OMAP_DMA + if (tusb_dma_omap() && is_buffer_mapped(req)) { + struct dma_controller *c = musb->dma_controller; + struct dma_channel *channel = musb_ep->dma; + u32 dma_addr = request->dma + request->actual; + int ret; + + ret = c->channel_program(channel, + musb_ep->packet_sz, + channel->desired_mode, + dma_addr, + fifo_count); + if (ret) + return; + } +#endif + /* + * Unmap the dma buffer back to cpu if dma channel + * programming fails. This buffer is mapped if the + * channel allocation is successful + */ + if (is_buffer_mapped(req)) { + unmap_dma_buffer(req, musb); + + /* + * Clear DMAENAB and AUTOCLEAR for the + * PIO mode transfer + */ + csr &= ~(MUSB_RXCSR_DMAENAB | MUSB_RXCSR_AUTOCLEAR); + musb_writew(epio, MUSB_RXCSR, csr); + } + + musb_read_fifo(musb_ep->hw_ep, fifo_count, (u8 *) + (request->buf + request->actual)); + request->actual += fifo_count; + + /* REVISIT if we left anything in the fifo, flush + * it and report -EOVERFLOW + */ + + /* ack the read! */ + csr |= MUSB_RXCSR_P_WZC_BITS; + csr &= ~MUSB_RXCSR_RXPKTRDY; + musb_writew(epio, MUSB_RXCSR, csr); + } + } + + /* reach the end or short packet detected */ + if (request->actual == request->length || len < musb_ep->packet_sz) + musb_g_giveback(musb_ep, request, 0); +} + +/* + * Data ready for a request; called from IRQ + */ +void musb_g_rx(struct musb *musb, u8 epnum) +{ + u16 csr; + struct musb_request *req; + struct usb_request *request; + void __iomem *mbase = musb->mregs; + struct musb_ep *musb_ep; + void __iomem *epio = musb->endpoints[epnum].regs; + struct dma_channel *dma; + struct musb_hw_ep *hw_ep = &musb->endpoints[epnum]; + + if (hw_ep->is_shared_fifo) + musb_ep = &hw_ep->ep_in; + else + musb_ep = &hw_ep->ep_out; + + musb_ep_select(mbase, epnum); + + req = next_request(musb_ep); + if (!req) + return; + + request = &req->request; + + csr = musb_readw(epio, MUSB_RXCSR); + dma = is_dma_capable() ? musb_ep->dma : NULL; + + dev_dbg(musb->controller, "<== %s, rxcsr %04x%s %p\n", musb_ep->end_point.name, + csr, dma ? " (dma)" : "", request); + + if (csr & MUSB_RXCSR_P_SENTSTALL) { + csr |= MUSB_RXCSR_P_WZC_BITS; + csr &= ~MUSB_RXCSR_P_SENTSTALL; + musb_writew(epio, MUSB_RXCSR, csr); + return; + } + + if (csr & MUSB_RXCSR_P_OVERRUN) { + /* csr |= MUSB_RXCSR_P_WZC_BITS; */ + csr &= ~MUSB_RXCSR_P_OVERRUN; + musb_writew(epio, MUSB_RXCSR, csr); + + dev_dbg(musb->controller, "%s iso overrun on %p\n", musb_ep->name, request); + if (request->status == -EINPROGRESS) + request->status = -EOVERFLOW; + } + if (csr & MUSB_RXCSR_INCOMPRX) { + /* REVISIT not necessarily an error */ + dev_dbg(musb->controller, "%s, incomprx\n", musb_ep->end_point.name); + } + + if (dma_channel_status(dma) == MUSB_DMA_STATUS_BUSY) { + /* "should not happen"; likely RXPKTRDY pending for DMA */ + dev_dbg(musb->controller, "%s busy, csr %04x\n", + musb_ep->end_point.name, csr); + return; + } + + if (dma && (csr & MUSB_RXCSR_DMAENAB)) { + csr &= ~(MUSB_RXCSR_AUTOCLEAR + | MUSB_RXCSR_DMAENAB + | MUSB_RXCSR_DMAMODE); + musb_writew(epio, MUSB_RXCSR, + MUSB_RXCSR_P_WZC_BITS | csr); + + request->actual += musb_ep->dma->actual_len; + + dev_dbg(musb->controller, "RXCSR%d %04x, dma off, %04x, len %zu, req %p\n", + epnum, csr, + musb_readw(epio, MUSB_RXCSR), + musb_ep->dma->actual_len, request); + +#if defined(CONFIG_USB_INVENTRA_DMA) || defined(CONFIG_USB_TUSB_OMAP_DMA) || \ + defined(CONFIG_USB_UX500_DMA) + /* Autoclear doesn't clear RxPktRdy for short packets */ + if ((dma->desired_mode == 0 && !hw_ep->rx_double_buffered) + || (dma->actual_len + & (musb_ep->packet_sz - 1))) { + /* ack the read! */ + csr &= ~MUSB_RXCSR_RXPKTRDY; + musb_writew(epio, MUSB_RXCSR, csr); + } + + /* incomplete, and not short? wait for next IN packet */ + if ((request->actual < request->length) + && (musb_ep->dma->actual_len + == musb_ep->packet_sz)) { + /* In double buffer case, continue to unload fifo if + * there is Rx packet in FIFO. + **/ + csr = musb_readw(epio, MUSB_RXCSR); + if ((csr & MUSB_RXCSR_RXPKTRDY) && + hw_ep->rx_double_buffered) + goto exit; + return; + } +#endif + musb_g_giveback(musb_ep, request, 0); + /* + * In the giveback function the MUSB lock is + * released and acquired after sometime. During + * this time period the INDEX register could get + * changed by the gadget_queue function especially + * on SMP systems. Reselect the INDEX to be sure + * we are reading/modifying the right registers + */ + musb_ep_select(mbase, epnum); + + req = next_request(musb_ep); + if (!req) + return; + } +#if defined(CONFIG_USB_INVENTRA_DMA) || defined(CONFIG_USB_TUSB_OMAP_DMA) || \ + defined(CONFIG_USB_UX500_DMA) +exit: +#endif + /* Analyze request */ + rxstate(musb, req); +} + +/* ------------------------------------------------------------ */ + +static int musb_gadget_enable(struct usb_ep *ep, + const struct usb_endpoint_descriptor *desc) +{ + unsigned long flags; + struct musb_ep *musb_ep; + struct musb_hw_ep *hw_ep; + void __iomem *regs; + struct musb *musb; + void __iomem *mbase; + u8 epnum; + u16 csr; + unsigned tmp; + int status = -EINVAL; + + if (!ep || !desc) + return -EINVAL; + + musb_ep = to_musb_ep(ep); + hw_ep = musb_ep->hw_ep; + regs = hw_ep->regs; + musb = musb_ep->musb; + mbase = musb->mregs; + epnum = musb_ep->current_epnum; + + spin_lock_irqsave(&musb->lock, flags); + + if (musb_ep->desc) { + status = -EBUSY; + goto fail; + } + musb_ep->type = usb_endpoint_type(desc); + + /* check direction and (later) maxpacket size against endpoint */ + if (usb_endpoint_num(desc) != epnum) + goto fail; + + /* REVISIT this rules out high bandwidth periodic transfers */ + tmp = usb_endpoint_maxp(desc); + if (tmp & ~0x07ff) { + int ok; + + if (usb_endpoint_dir_in(desc)) + ok = musb->hb_iso_tx; + else + ok = musb->hb_iso_rx; + + if (!ok) { + dev_dbg(musb->controller, "no support for high bandwidth ISO\n"); + goto fail; + } + musb_ep->hb_mult = (tmp >> 11) & 3; + } else { + musb_ep->hb_mult = 0; + } + + musb_ep->packet_sz = tmp & 0x7ff; + tmp = musb_ep->packet_sz * (musb_ep->hb_mult + 1); + + /* enable the interrupts for the endpoint, set the endpoint + * packet size (or fail), set the mode, clear the fifo + */ + musb_ep_select(mbase, epnum); + if (usb_endpoint_dir_in(desc)) { + u16 int_txe = musb_readw(mbase, MUSB_INTRTXE); + + if (hw_ep->is_shared_fifo) + musb_ep->is_in = 1; + if (!musb_ep->is_in) + goto fail; + + if (tmp > hw_ep->max_packet_sz_tx) { + dev_dbg(musb->controller, "packet size beyond hardware FIFO size\n"); + goto fail; + } + + int_txe |= (1 << epnum); + musb_writew(mbase, MUSB_INTRTXE, int_txe); + + /* REVISIT if can_bulk_split(), use by updating "tmp"; + * likewise high bandwidth periodic tx + */ + /* Set TXMAXP with the FIFO size of the endpoint + * to disable double buffering mode. + */ + if (musb->double_buffer_not_ok) + musb_writew(regs, MUSB_TXMAXP, hw_ep->max_packet_sz_tx); + else + musb_writew(regs, MUSB_TXMAXP, musb_ep->packet_sz + | (musb_ep->hb_mult << 11)); + + csr = MUSB_TXCSR_MODE | MUSB_TXCSR_CLRDATATOG; + if (musb_readw(regs, MUSB_TXCSR) + & MUSB_TXCSR_FIFONOTEMPTY) + csr |= MUSB_TXCSR_FLUSHFIFO; + if (musb_ep->type == USB_ENDPOINT_XFER_ISOC) + csr |= MUSB_TXCSR_P_ISO; + + /* set twice in case of double buffering */ + musb_writew(regs, MUSB_TXCSR, csr); + /* REVISIT may be inappropriate w/o FIFONOTEMPTY ... */ + musb_writew(regs, MUSB_TXCSR, csr); + + } else { + u16 int_rxe = musb_readw(mbase, MUSB_INTRRXE); + + if (hw_ep->is_shared_fifo) + musb_ep->is_in = 0; + if (musb_ep->is_in) + goto fail; + + if (tmp > hw_ep->max_packet_sz_rx) { + dev_dbg(musb->controller, "packet size beyond hardware FIFO size\n"); + goto fail; + } + + int_rxe |= (1 << epnum); + musb_writew(mbase, MUSB_INTRRXE, int_rxe); + + /* REVISIT if can_bulk_combine() use by updating "tmp" + * likewise high bandwidth periodic rx + */ + /* Set RXMAXP with the FIFO size of the endpoint + * to disable double buffering mode. + */ + if (musb->double_buffer_not_ok) + musb_writew(regs, MUSB_RXMAXP, hw_ep->max_packet_sz_tx); + else + musb_writew(regs, MUSB_RXMAXP, musb_ep->packet_sz + | (musb_ep->hb_mult << 11)); + + /* force shared fifo to OUT-only mode */ + if (hw_ep->is_shared_fifo) { + csr = musb_readw(regs, MUSB_TXCSR); + csr &= ~(MUSB_TXCSR_MODE | MUSB_TXCSR_TXPKTRDY); + musb_writew(regs, MUSB_TXCSR, csr); + } + + csr = MUSB_RXCSR_FLUSHFIFO | MUSB_RXCSR_CLRDATATOG; + if (musb_ep->type == USB_ENDPOINT_XFER_ISOC) + csr |= MUSB_RXCSR_P_ISO; + else if (musb_ep->type == USB_ENDPOINT_XFER_INT) + csr |= MUSB_RXCSR_DISNYET; + + /* set twice in case of double buffering */ + musb_writew(regs, MUSB_RXCSR, csr); + musb_writew(regs, MUSB_RXCSR, csr); + } + + /* NOTE: all the I/O code _should_ work fine without DMA, in case + * for some reason you run out of channels here. + */ + if (is_dma_capable() && musb->dma_controller) { + struct dma_controller *c = musb->dma_controller; + + musb_ep->dma = c->channel_alloc(c, hw_ep, + (desc->bEndpointAddress & USB_DIR_IN)); + } else + musb_ep->dma = NULL; + + musb_ep->desc = desc; + musb_ep->busy = 0; + musb_ep->wedged = 0; + status = 0; + + pr_debug("%s periph: enabled %s for %s %s, %smaxpacket %d\n", + musb_driver_name, musb_ep->end_point.name, + ({ char *s; switch (musb_ep->type) { + case USB_ENDPOINT_XFER_BULK: s = "bulk"; break; + case USB_ENDPOINT_XFER_INT: s = "int"; break; + default: s = "iso"; break; + }; s; }), + musb_ep->is_in ? "IN" : "OUT", + musb_ep->dma ? "dma, " : "", + musb_ep->packet_sz); + + schedule_work(&musb->irq_work); + +fail: + spin_unlock_irqrestore(&musb->lock, flags); + return status; +} + +/* + * Disable an endpoint flushing all requests queued. + */ +static int musb_gadget_disable(struct usb_ep *ep) +{ + unsigned long flags; + struct musb *musb; + u8 epnum; + struct musb_ep *musb_ep; + void __iomem *epio; + int status = 0; + + musb_ep = to_musb_ep(ep); + musb = musb_ep->musb; + epnum = musb_ep->current_epnum; + epio = musb->endpoints[epnum].regs; + + spin_lock_irqsave(&musb->lock, flags); + musb_ep_select(musb->mregs, epnum); + + /* zero the endpoint sizes */ + if (musb_ep->is_in) { + u16 int_txe = musb_readw(musb->mregs, MUSB_INTRTXE); + int_txe &= ~(1 << epnum); + musb_writew(musb->mregs, MUSB_INTRTXE, int_txe); + musb_writew(epio, MUSB_TXMAXP, 0); + } else { + u16 int_rxe = musb_readw(musb->mregs, MUSB_INTRRXE); + int_rxe &= ~(1 << epnum); + musb_writew(musb->mregs, MUSB_INTRRXE, int_rxe); + musb_writew(epio, MUSB_RXMAXP, 0); + } + + musb_ep->desc = NULL; +#ifndef __UBOOT__ + musb_ep->end_point.desc = NULL; +#endif + + /* abort all pending DMA and requests */ + nuke(musb_ep, -ESHUTDOWN); + + schedule_work(&musb->irq_work); + + spin_unlock_irqrestore(&(musb->lock), flags); + + dev_dbg(musb->controller, "%s\n", musb_ep->end_point.name); + + return status; +} + +/* + * Allocate a request for an endpoint. + * Reused by ep0 code. + */ +struct usb_request *musb_alloc_request(struct usb_ep *ep, gfp_t gfp_flags) +{ + struct musb_ep *musb_ep = to_musb_ep(ep); + struct musb *musb = musb_ep->musb; + struct musb_request *request = NULL; + + request = kzalloc(sizeof *request, gfp_flags); + if (!request) { + dev_dbg(musb->controller, "not enough memory\n"); + return NULL; + } + + request->request.dma = DMA_ADDR_INVALID; + request->epnum = musb_ep->current_epnum; + request->ep = musb_ep; + + return &request->request; +} + +/* + * Free a request + * Reused by ep0 code. + */ +void musb_free_request(struct usb_ep *ep, struct usb_request *req) +{ + kfree(to_musb_request(req)); +} + +static LIST_HEAD(buffers); + +struct free_record { + struct list_head list; + struct device *dev; + unsigned bytes; + dma_addr_t dma; +}; + +/* + * Context: controller locked, IRQs blocked. + */ +void musb_ep_restart(struct musb *musb, struct musb_request *req) +{ + dev_dbg(musb->controller, "<== %s request %p len %u on hw_ep%d\n", + req->tx ? "TX/IN" : "RX/OUT", + &req->request, req->request.length, req->epnum); + + musb_ep_select(musb->mregs, req->epnum); + if (req->tx) + txstate(musb, req); + else + rxstate(musb, req); +} + +static int musb_gadget_queue(struct usb_ep *ep, struct usb_request *req, + gfp_t gfp_flags) +{ + struct musb_ep *musb_ep; + struct musb_request *request; + struct musb *musb; + int status = 0; + unsigned long lockflags; + + if (!ep || !req) + return -EINVAL; + if (!req->buf) + return -ENODATA; + + musb_ep = to_musb_ep(ep); + musb = musb_ep->musb; + + request = to_musb_request(req); + request->musb = musb; + + if (request->ep != musb_ep) + return -EINVAL; + + dev_dbg(musb->controller, "<== to %s request=%p\n", ep->name, req); + + /* request is mine now... */ + request->request.actual = 0; + request->request.status = -EINPROGRESS; + request->epnum = musb_ep->current_epnum; + request->tx = musb_ep->is_in; + + map_dma_buffer(request, musb, musb_ep); + + spin_lock_irqsave(&musb->lock, lockflags); + + /* don't queue if the ep is down */ + if (!musb_ep->desc) { + dev_dbg(musb->controller, "req %p queued to %s while ep %s\n", + req, ep->name, "disabled"); + status = -ESHUTDOWN; + goto cleanup; + } + + /* add request to the list */ + list_add_tail(&request->list, &musb_ep->req_list); + + /* it this is the head of the queue, start i/o ... */ + if (!musb_ep->busy && &request->list == musb_ep->req_list.next) + musb_ep_restart(musb, request); + +cleanup: + spin_unlock_irqrestore(&musb->lock, lockflags); + return status; +} + +static int musb_gadget_dequeue(struct usb_ep *ep, struct usb_request *request) +{ + struct musb_ep *musb_ep = to_musb_ep(ep); + struct musb_request *req = to_musb_request(request); + struct musb_request *r; + unsigned long flags; + int status = 0; + struct musb *musb = musb_ep->musb; + + if (!ep || !request || to_musb_request(request)->ep != musb_ep) + return -EINVAL; + + spin_lock_irqsave(&musb->lock, flags); + + list_for_each_entry(r, &musb_ep->req_list, list) { + if (r == req) + break; + } + if (r != req) { + dev_dbg(musb->controller, "request %p not queued to %s\n", request, ep->name); + status = -EINVAL; + goto done; + } + + /* if the hardware doesn't have the request, easy ... */ + if (musb_ep->req_list.next != &req->list || musb_ep->busy) + musb_g_giveback(musb_ep, request, -ECONNRESET); + + /* ... else abort the dma transfer ... */ + else if (is_dma_capable() && musb_ep->dma) { + struct dma_controller *c = musb->dma_controller; + + musb_ep_select(musb->mregs, musb_ep->current_epnum); + if (c->channel_abort) + status = c->channel_abort(musb_ep->dma); + else + status = -EBUSY; + if (status == 0) + musb_g_giveback(musb_ep, request, -ECONNRESET); + } else { + /* NOTE: by sticking to easily tested hardware/driver states, + * we leave counting of in-flight packets imprecise. + */ + musb_g_giveback(musb_ep, request, -ECONNRESET); + } + +done: + spin_unlock_irqrestore(&musb->lock, flags); + return status; +} + +/* + * Set or clear the halt bit of an endpoint. A halted enpoint won't tx/rx any + * data but will queue requests. + * + * exported to ep0 code + */ +static int musb_gadget_set_halt(struct usb_ep *ep, int value) +{ + struct musb_ep *musb_ep = to_musb_ep(ep); + u8 epnum = musb_ep->current_epnum; + struct musb *musb = musb_ep->musb; + void __iomem *epio = musb->endpoints[epnum].regs; + void __iomem *mbase; + unsigned long flags; + u16 csr; + struct musb_request *request; + int status = 0; + + if (!ep) + return -EINVAL; + mbase = musb->mregs; + + spin_lock_irqsave(&musb->lock, flags); + + if ((USB_ENDPOINT_XFER_ISOC == musb_ep->type)) { + status = -EINVAL; + goto done; + } + + musb_ep_select(mbase, epnum); + + request = next_request(musb_ep); + if (value) { + if (request) { + dev_dbg(musb->controller, "request in progress, cannot halt %s\n", + ep->name); + status = -EAGAIN; + goto done; + } + /* Cannot portably stall with non-empty FIFO */ + if (musb_ep->is_in) { + csr = musb_readw(epio, MUSB_TXCSR); + if (csr & MUSB_TXCSR_FIFONOTEMPTY) { + dev_dbg(musb->controller, "FIFO busy, cannot halt %s\n", ep->name); + status = -EAGAIN; + goto done; + } + } + } else + musb_ep->wedged = 0; + + /* set/clear the stall and toggle bits */ + dev_dbg(musb->controller, "%s: %s stall\n", ep->name, value ? "set" : "clear"); + if (musb_ep->is_in) { + csr = musb_readw(epio, MUSB_TXCSR); + csr |= MUSB_TXCSR_P_WZC_BITS + | MUSB_TXCSR_CLRDATATOG; + if (value) + csr |= MUSB_TXCSR_P_SENDSTALL; + else + csr &= ~(MUSB_TXCSR_P_SENDSTALL + | MUSB_TXCSR_P_SENTSTALL); + csr &= ~MUSB_TXCSR_TXPKTRDY; + musb_writew(epio, MUSB_TXCSR, csr); + } else { + csr = musb_readw(epio, MUSB_RXCSR); + csr |= MUSB_RXCSR_P_WZC_BITS + | MUSB_RXCSR_FLUSHFIFO + | MUSB_RXCSR_CLRDATATOG; + if (value) + csr |= MUSB_RXCSR_P_SENDSTALL; + else + csr &= ~(MUSB_RXCSR_P_SENDSTALL + | MUSB_RXCSR_P_SENTSTALL); + musb_writew(epio, MUSB_RXCSR, csr); + } + + /* maybe start the first request in the queue */ + if (!musb_ep->busy && !value && request) { + dev_dbg(musb->controller, "restarting the request\n"); + musb_ep_restart(musb, request); + } + +done: + spin_unlock_irqrestore(&musb->lock, flags); + return status; +} + +#ifndef __UBOOT__ +/* + * Sets the halt feature with the clear requests ignored + */ +static int musb_gadget_set_wedge(struct usb_ep *ep) +{ + struct musb_ep *musb_ep = to_musb_ep(ep); + + if (!ep) + return -EINVAL; + + musb_ep->wedged = 1; + + return usb_ep_set_halt(ep); +} +#endif + +static int musb_gadget_fifo_status(struct usb_ep *ep) +{ + struct musb_ep *musb_ep = to_musb_ep(ep); + void __iomem *epio = musb_ep->hw_ep->regs; + int retval = -EINVAL; + + if (musb_ep->desc && !musb_ep->is_in) { + struct musb *musb = musb_ep->musb; + int epnum = musb_ep->current_epnum; + void __iomem *mbase = musb->mregs; + unsigned long flags; + + spin_lock_irqsave(&musb->lock, flags); + + musb_ep_select(mbase, epnum); + /* FIXME return zero unless RXPKTRDY is set */ + retval = musb_readw(epio, MUSB_RXCOUNT); + + spin_unlock_irqrestore(&musb->lock, flags); + } + return retval; +} + +static void musb_gadget_fifo_flush(struct usb_ep *ep) +{ + struct musb_ep *musb_ep = to_musb_ep(ep); + struct musb *musb = musb_ep->musb; + u8 epnum = musb_ep->current_epnum; + void __iomem *epio = musb->endpoints[epnum].regs; + void __iomem *mbase; + unsigned long flags; + u16 csr, int_txe; + + mbase = musb->mregs; + + spin_lock_irqsave(&musb->lock, flags); + musb_ep_select(mbase, (u8) epnum); + + /* disable interrupts */ + int_txe = musb_readw(mbase, MUSB_INTRTXE); + musb_writew(mbase, MUSB_INTRTXE, int_txe & ~(1 << epnum)); + + if (musb_ep->is_in) { + csr = musb_readw(epio, MUSB_TXCSR); + if (csr & MUSB_TXCSR_FIFONOTEMPTY) { + csr |= MUSB_TXCSR_FLUSHFIFO | MUSB_TXCSR_P_WZC_BITS; + /* + * Setting both TXPKTRDY and FLUSHFIFO makes controller + * to interrupt current FIFO loading, but not flushing + * the already loaded ones. + */ + csr &= ~MUSB_TXCSR_TXPKTRDY; + musb_writew(epio, MUSB_TXCSR, csr); + /* REVISIT may be inappropriate w/o FIFONOTEMPTY ... */ + musb_writew(epio, MUSB_TXCSR, csr); + } + } else { + csr = musb_readw(epio, MUSB_RXCSR); + csr |= MUSB_RXCSR_FLUSHFIFO | MUSB_RXCSR_P_WZC_BITS; + musb_writew(epio, MUSB_RXCSR, csr); + musb_writew(epio, MUSB_RXCSR, csr); + } + + /* re-enable interrupt */ + musb_writew(mbase, MUSB_INTRTXE, int_txe); + spin_unlock_irqrestore(&musb->lock, flags); +} + +static const struct usb_ep_ops musb_ep_ops = { + .enable = musb_gadget_enable, + .disable = musb_gadget_disable, + .alloc_request = musb_alloc_request, + .free_request = musb_free_request, + .queue = musb_gadget_queue, + .dequeue = musb_gadget_dequeue, + .set_halt = musb_gadget_set_halt, +#ifndef __UBOOT__ + .set_wedge = musb_gadget_set_wedge, +#endif + .fifo_status = musb_gadget_fifo_status, + .fifo_flush = musb_gadget_fifo_flush +}; + +/* ----------------------------------------------------------------------- */ + +static int musb_gadget_get_frame(struct usb_gadget *gadget) +{ + struct musb *musb = gadget_to_musb(gadget); + + return (int)musb_readw(musb->mregs, MUSB_FRAME); +} + +static int musb_gadget_wakeup(struct usb_gadget *gadget) +{ +#ifndef __UBOOT__ + struct musb *musb = gadget_to_musb(gadget); + void __iomem *mregs = musb->mregs; + unsigned long flags; + int status = -EINVAL; + u8 power, devctl; + int retries; + + spin_lock_irqsave(&musb->lock, flags); + + switch (musb->xceiv->state) { + case OTG_STATE_B_PERIPHERAL: + /* NOTE: OTG state machine doesn't include B_SUSPENDED; + * that's part of the standard usb 1.1 state machine, and + * doesn't affect OTG transitions. + */ + if (musb->may_wakeup && musb->is_suspended) + break; + goto done; + case OTG_STATE_B_IDLE: + /* Start SRP ... OTG not required. */ + devctl = musb_readb(mregs, MUSB_DEVCTL); + dev_dbg(musb->controller, "Sending SRP: devctl: %02x\n", devctl); + devctl |= MUSB_DEVCTL_SESSION; + musb_writeb(mregs, MUSB_DEVCTL, devctl); + devctl = musb_readb(mregs, MUSB_DEVCTL); + retries = 100; + while (!(devctl & MUSB_DEVCTL_SESSION)) { + devctl = musb_readb(mregs, MUSB_DEVCTL); + if (retries-- < 1) + break; + } + retries = 10000; + while (devctl & MUSB_DEVCTL_SESSION) { + devctl = musb_readb(mregs, MUSB_DEVCTL); + if (retries-- < 1) + break; + } + + spin_unlock_irqrestore(&musb->lock, flags); + otg_start_srp(musb->xceiv->otg); + spin_lock_irqsave(&musb->lock, flags); + + /* Block idling for at least 1s */ + musb_platform_try_idle(musb, + jiffies + msecs_to_jiffies(1 * HZ)); + + status = 0; + goto done; + default: + dev_dbg(musb->controller, "Unhandled wake: %s\n", + otg_state_string(musb->xceiv->state)); + goto done; + } + + status = 0; + + power = musb_readb(mregs, MUSB_POWER); + power |= MUSB_POWER_RESUME; + musb_writeb(mregs, MUSB_POWER, power); + dev_dbg(musb->controller, "issue wakeup\n"); + + /* FIXME do this next chunk in a timer callback, no udelay */ + mdelay(2); + + power = musb_readb(mregs, MUSB_POWER); + power &= ~MUSB_POWER_RESUME; + musb_writeb(mregs, MUSB_POWER, power); +done: + spin_unlock_irqrestore(&musb->lock, flags); + return status; +#else + return 0; +#endif +} + +static int +musb_gadget_set_self_powered(struct usb_gadget *gadget, int is_selfpowered) +{ + struct musb *musb = gadget_to_musb(gadget); + + musb->is_self_powered = !!is_selfpowered; + return 0; +} + +static void musb_pullup(struct musb *musb, int is_on) +{ + u8 power; + + power = musb_readb(musb->mregs, MUSB_POWER); + if (is_on) + power |= MUSB_POWER_SOFTCONN; + else + power &= ~MUSB_POWER_SOFTCONN; + + /* FIXME if on, HdrcStart; if off, HdrcStop */ + + dev_dbg(musb->controller, "gadget D+ pullup %s\n", + is_on ? "on" : "off"); + musb_writeb(musb->mregs, MUSB_POWER, power); +} + +#if 0 +static int musb_gadget_vbus_session(struct usb_gadget *gadget, int is_active) +{ + dev_dbg(musb->controller, "<= %s =>\n", __func__); + + /* + * FIXME iff driver's softconnect flag is set (as it is during probe, + * though that can clear it), just musb_pullup(). + */ + + return -EINVAL; +} +#endif + +static int musb_gadget_vbus_draw(struct usb_gadget *gadget, unsigned mA) +{ +#ifndef __UBOOT__ + struct musb *musb = gadget_to_musb(gadget); + + if (!musb->xceiv->set_power) + return -EOPNOTSUPP; + return usb_phy_set_power(musb->xceiv, mA); +#else + return 0; +#endif +} + +static int musb_gadget_pullup(struct usb_gadget *gadget, int is_on) +{ + struct musb *musb = gadget_to_musb(gadget); + unsigned long flags; + + is_on = !!is_on; + + pm_runtime_get_sync(musb->controller); + + /* NOTE: this assumes we are sensing vbus; we'd rather + * not pullup unless the B-session is active. + */ + spin_lock_irqsave(&musb->lock, flags); + if (is_on != musb->softconnect) { + musb->softconnect = is_on; + musb_pullup(musb, is_on); + } + spin_unlock_irqrestore(&musb->lock, flags); + + pm_runtime_put(musb->controller); + + return 0; +} + +#ifndef __UBOOT__ +static int musb_gadget_start(struct usb_gadget *g, + struct usb_gadget_driver *driver); +static int musb_gadget_stop(struct usb_gadget *g, + struct usb_gadget_driver *driver); +#endif + +static const struct usb_gadget_ops musb_gadget_operations = { + .get_frame = musb_gadget_get_frame, + .wakeup = musb_gadget_wakeup, + .set_selfpowered = musb_gadget_set_self_powered, + /* .vbus_session = musb_gadget_vbus_session, */ + .vbus_draw = musb_gadget_vbus_draw, + .pullup = musb_gadget_pullup, +#ifndef __UBOOT__ + .udc_start = musb_gadget_start, + .udc_stop = musb_gadget_stop, +#endif +}; + +/* ----------------------------------------------------------------------- */ + +/* Registration */ + +/* Only this registration code "knows" the rule (from USB standards) + * about there being only one external upstream port. It assumes + * all peripheral ports are external... + */ + +#ifndef __UBOOT__ +static void musb_gadget_release(struct device *dev) +{ + /* kref_put(WHAT) */ + dev_dbg(dev, "%s\n", __func__); +} +#endif + + +static void __devinit +init_peripheral_ep(struct musb *musb, struct musb_ep *ep, u8 epnum, int is_in) +{ + struct musb_hw_ep *hw_ep = musb->endpoints + epnum; + + memset(ep, 0, sizeof *ep); + + ep->current_epnum = epnum; + ep->musb = musb; + ep->hw_ep = hw_ep; + ep->is_in = is_in; + + INIT_LIST_HEAD(&ep->req_list); + + sprintf(ep->name, "ep%d%s", epnum, + (!epnum || hw_ep->is_shared_fifo) ? "" : ( + is_in ? "in" : "out")); + ep->end_point.name = ep->name; + INIT_LIST_HEAD(&ep->end_point.ep_list); + if (!epnum) { + ep->end_point.maxpacket = 64; + ep->end_point.ops = &musb_g_ep0_ops; + musb->g.ep0 = &ep->end_point; + } else { + if (is_in) + ep->end_point.maxpacket = hw_ep->max_packet_sz_tx; + else + ep->end_point.maxpacket = hw_ep->max_packet_sz_rx; + ep->end_point.ops = &musb_ep_ops; + list_add_tail(&ep->end_point.ep_list, &musb->g.ep_list); + } +} + +/* + * Initialize the endpoints exposed to peripheral drivers, with backlinks + * to the rest of the driver state. + */ +static inline void __devinit musb_g_init_endpoints(struct musb *musb) +{ + u8 epnum; + struct musb_hw_ep *hw_ep; + unsigned count = 0; + + /* initialize endpoint list just once */ + INIT_LIST_HEAD(&(musb->g.ep_list)); + + for (epnum = 0, hw_ep = musb->endpoints; + epnum < musb->nr_endpoints; + epnum++, hw_ep++) { + if (hw_ep->is_shared_fifo /* || !epnum */) { + init_peripheral_ep(musb, &hw_ep->ep_in, epnum, 0); + count++; + } else { + if (hw_ep->max_packet_sz_tx) { + init_peripheral_ep(musb, &hw_ep->ep_in, + epnum, 1); + count++; + } + if (hw_ep->max_packet_sz_rx) { + init_peripheral_ep(musb, &hw_ep->ep_out, + epnum, 0); + count++; + } + } + } +} + +/* called once during driver setup to initialize and link into + * the driver model; memory is zeroed. + */ +int __devinit musb_gadget_setup(struct musb *musb) +{ + int status; + + /* REVISIT minor race: if (erroneously) setting up two + * musb peripherals at the same time, only the bus lock + * is probably held. + */ + + musb->g.ops = &musb_gadget_operations; +#ifndef __UBOOT__ + musb->g.max_speed = USB_SPEED_HIGH; +#endif + musb->g.speed = USB_SPEED_UNKNOWN; + +#ifndef __UBOOT__ + /* this "gadget" abstracts/virtualizes the controller */ + dev_set_name(&musb->g.dev, "gadget"); + musb->g.dev.parent = musb->controller; + musb->g.dev.dma_mask = musb->controller->dma_mask; + musb->g.dev.release = musb_gadget_release; +#endif + musb->g.name = musb_driver_name; + +#ifndef __UBOOT__ + if (is_otg_enabled(musb)) + musb->g.is_otg = 1; +#endif + + musb_g_init_endpoints(musb); + + musb->is_active = 0; + musb_platform_try_idle(musb, 0); + +#ifndef __UBOOT__ + status = device_register(&musb->g.dev); + if (status != 0) { + put_device(&musb->g.dev); + return status; + } + status = usb_add_gadget_udc(musb->controller, &musb->g); + if (status) + goto err; +#endif + + return 0; +#ifndef __UBOOT__ +err: + musb->g.dev.parent = NULL; + device_unregister(&musb->g.dev); + return status; +#endif +} + +void musb_gadget_cleanup(struct musb *musb) +{ +#ifndef __UBOOT__ + usb_del_gadget_udc(&musb->g); + if (musb->g.dev.parent) + device_unregister(&musb->g.dev); +#endif +} + +/* + * Register the gadget driver. Used by gadget drivers when + * registering themselves with the controller. + * + * -EINVAL something went wrong (not driver) + * -EBUSY another gadget is already using the controller + * -ENOMEM no memory to perform the operation + * + * @param driver the gadget driver + * @return <0 if error, 0 if everything is fine + */ +#ifndef __UBOOT__ +static int musb_gadget_start(struct usb_gadget *g, + struct usb_gadget_driver *driver) +#else +int musb_gadget_start(struct usb_gadget *g, + struct usb_gadget_driver *driver) +#endif +{ + struct musb *musb = gadget_to_musb(g); +#ifndef __UBOOT__ + struct usb_otg *otg = musb->xceiv->otg; +#endif + unsigned long flags; + int retval = -EINVAL; + +#ifndef __UBOOT__ + if (driver->max_speed < USB_SPEED_HIGH) + goto err0; +#endif + + pm_runtime_get_sync(musb->controller); + +#ifndef __UBOOT__ + dev_dbg(musb->controller, "registering driver %s\n", driver->function); +#endif + + musb->softconnect = 0; + musb->gadget_driver = driver; + + spin_lock_irqsave(&musb->lock, flags); + musb->is_active = 1; + +#ifndef __UBOOT__ + otg_set_peripheral(otg, &musb->g); + musb->xceiv->state = OTG_STATE_B_IDLE; + + /* + * FIXME this ignores the softconnect flag. Drivers are + * allowed hold the peripheral inactive until for example + * userspace hooks up printer hardware or DSP codecs, so + * hosts only see fully functional devices. + */ + + if (!is_otg_enabled(musb)) +#endif + musb_start(musb); + + spin_unlock_irqrestore(&musb->lock, flags); + +#ifndef __UBOOT__ + if (is_otg_enabled(musb)) { + struct usb_hcd *hcd = musb_to_hcd(musb); + + dev_dbg(musb->controller, "OTG startup...\n"); + + /* REVISIT: funcall to other code, which also + * handles power budgeting ... this way also + * ensures HdrcStart is indirectly called. + */ + retval = usb_add_hcd(musb_to_hcd(musb), 0, 0); + if (retval < 0) { + dev_dbg(musb->controller, "add_hcd failed, %d\n", retval); + goto err2; + } + + if ((musb->xceiv->last_event == USB_EVENT_ID) + && otg->set_vbus) + otg_set_vbus(otg, 1); + + hcd->self.uses_pio_for_control = 1; + } + if (musb->xceiv->last_event == USB_EVENT_NONE) + pm_runtime_put(musb->controller); +#endif + + return 0; + +#ifndef __UBOOT__ +err2: + if (!is_otg_enabled(musb)) + musb_stop(musb); +err0: + return retval; +#endif +} + +#ifndef __UBOOT__ +static void stop_activity(struct musb *musb, struct usb_gadget_driver *driver) +{ + int i; + struct musb_hw_ep *hw_ep; + + /* don't disconnect if it's not connected */ + if (musb->g.speed == USB_SPEED_UNKNOWN) + driver = NULL; + else + musb->g.speed = USB_SPEED_UNKNOWN; + + /* deactivate the hardware */ + if (musb->softconnect) { + musb->softconnect = 0; + musb_pullup(musb, 0); + } + musb_stop(musb); + + /* killing any outstanding requests will quiesce the driver; + * then report disconnect + */ + if (driver) { + for (i = 0, hw_ep = musb->endpoints; + i < musb->nr_endpoints; + i++, hw_ep++) { + musb_ep_select(musb->mregs, i); + if (hw_ep->is_shared_fifo /* || !epnum */) { + nuke(&hw_ep->ep_in, -ESHUTDOWN); + } else { + if (hw_ep->max_packet_sz_tx) + nuke(&hw_ep->ep_in, -ESHUTDOWN); + if (hw_ep->max_packet_sz_rx) + nuke(&hw_ep->ep_out, -ESHUTDOWN); + } + } + } +} + +/* + * Unregister the gadget driver. Used by gadget drivers when + * unregistering themselves from the controller. + * + * @param driver the gadget driver to unregister + */ +static int musb_gadget_stop(struct usb_gadget *g, + struct usb_gadget_driver *driver) +{ + struct musb *musb = gadget_to_musb(g); + unsigned long flags; + + if (musb->xceiv->last_event == USB_EVENT_NONE) + pm_runtime_get_sync(musb->controller); + + /* + * REVISIT always use otg_set_peripheral() here too; + * this needs to shut down the OTG engine. + */ + + spin_lock_irqsave(&musb->lock, flags); + + musb_hnp_stop(musb); + + (void) musb_gadget_vbus_draw(&musb->g, 0); + + musb->xceiv->state = OTG_STATE_UNDEFINED; + stop_activity(musb, driver); + otg_set_peripheral(musb->xceiv->otg, NULL); + + dev_dbg(musb->controller, "unregistering driver %s\n", driver->function); + + musb->is_active = 0; + musb_platform_try_idle(musb, 0); + spin_unlock_irqrestore(&musb->lock, flags); + + if (is_otg_enabled(musb)) { + usb_remove_hcd(musb_to_hcd(musb)); + /* FIXME we need to be able to register another + * gadget driver here and have everything work; + * that currently misbehaves. + */ + } + + if (!is_otg_enabled(musb)) + musb_stop(musb); + + pm_runtime_put(musb->controller); + + return 0; +} +#endif + +/* ----------------------------------------------------------------------- */ + +/* lifecycle operations called through plat_uds.c */ + +void musb_g_resume(struct musb *musb) +{ +#ifndef __UBOOT__ + musb->is_suspended = 0; + switch (musb->xceiv->state) { + case OTG_STATE_B_IDLE: + break; + case OTG_STATE_B_WAIT_ACON: + case OTG_STATE_B_PERIPHERAL: + musb->is_active = 1; + if (musb->gadget_driver && musb->gadget_driver->resume) { + spin_unlock(&musb->lock); + musb->gadget_driver->resume(&musb->g); + spin_lock(&musb->lock); + } + break; + default: + WARNING("unhandled RESUME transition (%s)\n", + otg_state_string(musb->xceiv->state)); + } +#endif +} + +/* called when SOF packets stop for 3+ msec */ +void musb_g_suspend(struct musb *musb) +{ +#ifndef __UBOOT__ + u8 devctl; + + devctl = musb_readb(musb->mregs, MUSB_DEVCTL); + dev_dbg(musb->controller, "devctl %02x\n", devctl); + + switch (musb->xceiv->state) { + case OTG_STATE_B_IDLE: + if ((devctl & MUSB_DEVCTL_VBUS) == MUSB_DEVCTL_VBUS) + musb->xceiv->state = OTG_STATE_B_PERIPHERAL; + break; + case OTG_STATE_B_PERIPHERAL: + musb->is_suspended = 1; + if (musb->gadget_driver && musb->gadget_driver->suspend) { + spin_unlock(&musb->lock); + musb->gadget_driver->suspend(&musb->g); + spin_lock(&musb->lock); + } + break; + default: + /* REVISIT if B_HOST, clear DEVCTL.HOSTREQ; + * A_PERIPHERAL may need care too + */ + WARNING("unhandled SUSPEND transition (%s)\n", + otg_state_string(musb->xceiv->state)); + } +#endif +} + +/* Called during SRP */ +void musb_g_wakeup(struct musb *musb) +{ + musb_gadget_wakeup(&musb->g); +} + +/* called when VBUS drops below session threshold, and in other cases */ +void musb_g_disconnect(struct musb *musb) +{ + void __iomem *mregs = musb->mregs; + u8 devctl = musb_readb(mregs, MUSB_DEVCTL); + + dev_dbg(musb->controller, "devctl %02x\n", devctl); + + /* clear HR */ + musb_writeb(mregs, MUSB_DEVCTL, devctl & MUSB_DEVCTL_SESSION); + + /* don't draw vbus until new b-default session */ + (void) musb_gadget_vbus_draw(&musb->g, 0); + + musb->g.speed = USB_SPEED_UNKNOWN; + if (musb->gadget_driver && musb->gadget_driver->disconnect) { + spin_unlock(&musb->lock); + musb->gadget_driver->disconnect(&musb->g); + spin_lock(&musb->lock); + } + +#ifndef __UBOOT__ + switch (musb->xceiv->state) { + default: + dev_dbg(musb->controller, "Unhandled disconnect %s, setting a_idle\n", + otg_state_string(musb->xceiv->state)); + musb->xceiv->state = OTG_STATE_A_IDLE; + MUSB_HST_MODE(musb); + break; + case OTG_STATE_A_PERIPHERAL: + musb->xceiv->state = OTG_STATE_A_WAIT_BCON; + MUSB_HST_MODE(musb); + break; + case OTG_STATE_B_WAIT_ACON: + case OTG_STATE_B_HOST: + case OTG_STATE_B_PERIPHERAL: + case OTG_STATE_B_IDLE: + musb->xceiv->state = OTG_STATE_B_IDLE; + break; + case OTG_STATE_B_SRP_INIT: + break; + } +#endif + + musb->is_active = 0; +} + +void musb_g_reset(struct musb *musb) +__releases(musb->lock) +__acquires(musb->lock) +{ + void __iomem *mbase = musb->mregs; + u8 devctl = musb_readb(mbase, MUSB_DEVCTL); + u8 power; + +#ifndef __UBOOT__ + dev_dbg(musb->controller, "<== %s addr=%x driver '%s'\n", + (devctl & MUSB_DEVCTL_BDEVICE) + ? "B-Device" : "A-Device", + musb_readb(mbase, MUSB_FADDR), + musb->gadget_driver + ? musb->gadget_driver->driver.name + : NULL + ); +#endif + + /* report disconnect, if we didn't already (flushing EP state) */ + if (musb->g.speed != USB_SPEED_UNKNOWN) + musb_g_disconnect(musb); + + /* clear HR */ + else if (devctl & MUSB_DEVCTL_HR) + musb_writeb(mbase, MUSB_DEVCTL, MUSB_DEVCTL_SESSION); + + + /* what speed did we negotiate? */ + power = musb_readb(mbase, MUSB_POWER); + musb->g.speed = (power & MUSB_POWER_HSMODE) + ? USB_SPEED_HIGH : USB_SPEED_FULL; + + /* start in USB_STATE_DEFAULT */ + musb->is_active = 1; + musb->is_suspended = 0; + MUSB_DEV_MODE(musb); + musb->address = 0; + musb->ep0_state = MUSB_EP0_STAGE_SETUP; + + musb->may_wakeup = 0; + musb->g.b_hnp_enable = 0; + musb->g.a_alt_hnp_support = 0; + musb->g.a_hnp_support = 0; + +#ifndef __UBOOT__ + /* Normal reset, as B-Device; + * or else after HNP, as A-Device + */ + if (devctl & MUSB_DEVCTL_BDEVICE) { + musb->xceiv->state = OTG_STATE_B_PERIPHERAL; + musb->g.is_a_peripheral = 0; + } else if (is_otg_enabled(musb)) { + musb->xceiv->state = OTG_STATE_A_PERIPHERAL; + musb->g.is_a_peripheral = 1; + } else + WARN_ON(1); + + /* start with default limits on VBUS power draw */ + (void) musb_gadget_vbus_draw(&musb->g, + is_otg_enabled(musb) ? 8 : 100); +#endif +} diff --git a/drivers/usb/musb-new/musb_gadget.h b/drivers/usb/musb-new/musb_gadget.h new file mode 100644 index 0000000..85584d4 --- /dev/null +++ b/drivers/usb/musb-new/musb_gadget.h @@ -0,0 +1,127 @@ +/* + * MUSB OTG driver peripheral defines + * + * Copyright 2005 Mentor Graphics Corporation + * Copyright (C) 2005-2006 by Texas Instruments + * Copyright (C) 2006-2007 Nokia Corporation + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, but + * WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU + * General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA + * 02110-1301 USA + * + * THIS SOFTWARE IS PROVIDED "AS IS" AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN + * NO EVENT SHALL THE AUTHORS BE LIABLE FOR ANY DIRECT, INDIRECT, + * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT + * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF + * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON + * ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT + * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF + * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. + * + */ + +#ifndef __MUSB_GADGET_H +#define __MUSB_GADGET_H + +#include <linux/list.h> +#ifdef __UBOOT__ +#include <asm/byteorder.h> +#include <asm/errno.h> +#include <linux/usb/ch9.h> +#include <linux/usb/gadget.h> +#endif + +enum buffer_map_state { + UN_MAPPED = 0, + PRE_MAPPED, + MUSB_MAPPED +}; + +struct musb_request { + struct usb_request request; + struct list_head list; + struct musb_ep *ep; + struct musb *musb; + u8 tx; /* endpoint direction */ + u8 epnum; + enum buffer_map_state map_state; +}; + +static inline struct musb_request *to_musb_request(struct usb_request *req) +{ + return req ? container_of(req, struct musb_request, request) : NULL; +} + +extern struct usb_request * +musb_alloc_request(struct usb_ep *ep, gfp_t gfp_flags); +extern void musb_free_request(struct usb_ep *ep, struct usb_request *req); + + +/* + * struct musb_ep - peripheral side view of endpoint rx or tx side + */ +struct musb_ep { + /* stuff towards the head is basically write-once. */ + struct usb_ep end_point; + char name[12]; + struct musb_hw_ep *hw_ep; + struct musb *musb; + u8 current_epnum; + + /* ... when enabled/disabled ... */ + u8 type; + u8 is_in; + u16 packet_sz; + const struct usb_endpoint_descriptor *desc; + struct dma_channel *dma; + + /* later things are modified based on usage */ + struct list_head req_list; + + u8 wedged; + + /* true if lock must be dropped but req_list may not be advanced */ + u8 busy; + + u8 hb_mult; +}; + +static inline struct musb_ep *to_musb_ep(struct usb_ep *ep) +{ + return ep ? container_of(ep, struct musb_ep, end_point) : NULL; +} + +static inline struct musb_request *next_request(struct musb_ep *ep) +{ + struct list_head *queue = &ep->req_list; + + if (list_empty(queue)) + return NULL; + return container_of(queue->next, struct musb_request, list); +} + +extern void musb_g_tx(struct musb *musb, u8 epnum); +extern void musb_g_rx(struct musb *musb, u8 epnum); + +extern const struct usb_ep_ops musb_g_ep0_ops; + +extern int musb_gadget_setup(struct musb *); +extern void musb_gadget_cleanup(struct musb *); + +extern void musb_g_giveback(struct musb_ep *, struct usb_request *, int); + +extern void musb_ep_restart(struct musb *, struct musb_request *); + +#endif /* __MUSB_GADGET_H */ diff --git a/drivers/usb/musb-new/musb_gadget_ep0.c b/drivers/usb/musb-new/musb_gadget_ep0.c new file mode 100644 index 0000000..6599d38 --- /dev/null +++ b/drivers/usb/musb-new/musb_gadget_ep0.c @@ -0,0 +1,1089 @@ +/* + * MUSB OTG peripheral driver ep0 handling + * + * Copyright 2005 Mentor Graphics Corporation + * Copyright (C) 2005-2006 by Texas Instruments + * Copyright (C) 2006-2007 Nokia Corporation + * Copyright (C) 2008-2009 MontaVista Software, Inc. source@mvista.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, but + * WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU + * General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA + * 02110-1301 USA + * + * THIS SOFTWARE IS PROVIDED "AS IS" AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN + * NO EVENT SHALL THE AUTHORS BE LIABLE FOR ANY DIRECT, INDIRECT, + * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT + * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF + * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON + * ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT + * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF + * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. + * + */ + +#define __UBOOT__ +#ifndef __UBOOT__ +#include <linux/kernel.h> +#include <linux/list.h> +#include <linux/timer.h> +#include <linux/spinlock.h> +#include <linux/device.h> +#include <linux/interrupt.h> +#else +#include <common.h> +#include "linux-compat.h" +#endif + +#include "musb_core.h" + +/* ep0 is always musb->endpoints[0].ep_in */ +#define next_ep0_request(musb) next_in_request(&(musb)->endpoints[0]) + +/* + * locking note: we use only the controller lock, for simpler correctness. + * It's always held with IRQs blocked. + * + * It protects the ep0 request queue as well as ep0_state, not just the + * controller and indexed registers. And that lock stays held unless it + * needs to be dropped to allow reentering this driver ... like upcalls to + * the gadget driver, or adjusting endpoint halt status. + */ + +static char *decode_ep0stage(u8 stage) +{ + switch (stage) { + case MUSB_EP0_STAGE_IDLE: return "idle"; + case MUSB_EP0_STAGE_SETUP: return "setup"; + case MUSB_EP0_STAGE_TX: return "in"; + case MUSB_EP0_STAGE_RX: return "out"; + case MUSB_EP0_STAGE_ACKWAIT: return "wait"; + case MUSB_EP0_STAGE_STATUSIN: return "in/status"; + case MUSB_EP0_STAGE_STATUSOUT: return "out/status"; + default: return "?"; + } +} + +/* handle a standard GET_STATUS request + * Context: caller holds controller lock + */ +static int service_tx_status_request( + struct musb *musb, + const struct usb_ctrlrequest *ctrlrequest) +{ + void __iomem *mbase = musb->mregs; + int handled = 1; + u8 result[2], epnum = 0; + const u8 recip = ctrlrequest->bRequestType & USB_RECIP_MASK; + + result[1] = 0; + + switch (recip) { + case USB_RECIP_DEVICE: + result[0] = musb->is_self_powered << USB_DEVICE_SELF_POWERED; + result[0] |= musb->may_wakeup << USB_DEVICE_REMOTE_WAKEUP; + if (musb->g.is_otg) { + result[0] |= musb->g.b_hnp_enable + << USB_DEVICE_B_HNP_ENABLE; + result[0] |= musb->g.a_alt_hnp_support + << USB_DEVICE_A_ALT_HNP_SUPPORT; + result[0] |= musb->g.a_hnp_support + << USB_DEVICE_A_HNP_SUPPORT; + } + break; + + case USB_RECIP_INTERFACE: + result[0] = 0; + break; + + case USB_RECIP_ENDPOINT: { + int is_in; + struct musb_ep *ep; + u16 tmp; + void __iomem *regs; + + epnum = (u8) ctrlrequest->wIndex; + if (!epnum) { + result[0] = 0; + break; + } + + is_in = epnum & USB_DIR_IN; + if (is_in) { + epnum &= 0x0f; + ep = &musb->endpoints[epnum].ep_in; + } else { + ep = &musb->endpoints[epnum].ep_out; + } + regs = musb->endpoints[epnum].regs; + + if (epnum >= MUSB_C_NUM_EPS || !ep->desc) { + handled = -EINVAL; + break; + } + + musb_ep_select(mbase, epnum); + if (is_in) + tmp = musb_readw(regs, MUSB_TXCSR) + & MUSB_TXCSR_P_SENDSTALL; + else + tmp = musb_readw(regs, MUSB_RXCSR) + & MUSB_RXCSR_P_SENDSTALL; + musb_ep_select(mbase, 0); + + result[0] = tmp ? 1 : 0; + } break; + + default: + /* class, vendor, etc ... delegate */ + handled = 0; + break; + } + + /* fill up the fifo; caller updates csr0 */ + if (handled > 0) { + u16 len = le16_to_cpu(ctrlrequest->wLength); + + if (len > 2) + len = 2; + musb_write_fifo(&musb->endpoints[0], len, result); + } + + return handled; +} + +/* + * handle a control-IN request, the end0 buffer contains the current request + * that is supposed to be a standard control request. Assumes the fifo to + * be at least 2 bytes long. + * + * @return 0 if the request was NOT HANDLED, + * < 0 when error + * > 0 when the request is processed + * + * Context: caller holds controller lock + */ +static int +service_in_request(struct musb *musb, const struct usb_ctrlrequest *ctrlrequest) +{ + int handled = 0; /* not handled */ + + if ((ctrlrequest->bRequestType & USB_TYPE_MASK) + == USB_TYPE_STANDARD) { + switch (ctrlrequest->bRequest) { + case USB_REQ_GET_STATUS: + handled = service_tx_status_request(musb, + ctrlrequest); + break; + + /* case USB_REQ_SYNC_FRAME: */ + + default: + break; + } + } + return handled; +} + +/* + * Context: caller holds controller lock + */ +static void musb_g_ep0_giveback(struct musb *musb, struct usb_request *req) +{ + musb_g_giveback(&musb->endpoints[0].ep_in, req, 0); +} + +/* + * Tries to start B-device HNP negotiation if enabled via sysfs + */ +static inline void musb_try_b_hnp_enable(struct musb *musb) +{ + void __iomem *mbase = musb->mregs; + u8 devctl; + + dev_dbg(musb->controller, "HNP: Setting HR\n"); + devctl = musb_readb(mbase, MUSB_DEVCTL); + musb_writeb(mbase, MUSB_DEVCTL, devctl | MUSB_DEVCTL_HR); +} + +/* + * Handle all control requests with no DATA stage, including standard + * requests such as: + * USB_REQ_SET_CONFIGURATION, USB_REQ_SET_INTERFACE, unrecognized + * always delegated to the gadget driver + * USB_REQ_SET_ADDRESS, USB_REQ_CLEAR_FEATURE, USB_REQ_SET_FEATURE + * always handled here, except for class/vendor/... features + * + * Context: caller holds controller lock + */ +static int +service_zero_data_request(struct musb *musb, + struct usb_ctrlrequest *ctrlrequest) +__releases(musb->lock) +__acquires(musb->lock) +{ + int handled = -EINVAL; + void __iomem *mbase = musb->mregs; + const u8 recip = ctrlrequest->bRequestType & USB_RECIP_MASK; + + /* the gadget driver handles everything except what we MUST handle */ + if ((ctrlrequest->bRequestType & USB_TYPE_MASK) + == USB_TYPE_STANDARD) { + switch (ctrlrequest->bRequest) { + case USB_REQ_SET_ADDRESS: + /* change it after the status stage */ + musb->set_address = true; + musb->address = (u8) (ctrlrequest->wValue & 0x7f); + handled = 1; + break; + + case USB_REQ_CLEAR_FEATURE: + switch (recip) { + case USB_RECIP_DEVICE: + if (ctrlrequest->wValue + != USB_DEVICE_REMOTE_WAKEUP) + break; + musb->may_wakeup = 0; + handled = 1; + break; + case USB_RECIP_INTERFACE: + break; + case USB_RECIP_ENDPOINT:{ + const u8 epnum = + ctrlrequest->wIndex & 0x0f; + struct musb_ep *musb_ep; + struct musb_hw_ep *ep; + struct musb_request *request; + void __iomem *regs; + int is_in; + u16 csr; + + if (epnum == 0 || epnum >= MUSB_C_NUM_EPS || + ctrlrequest->wValue != USB_ENDPOINT_HALT) + break; + + ep = musb->endpoints + epnum; + regs = ep->regs; + is_in = ctrlrequest->wIndex & USB_DIR_IN; + if (is_in) + musb_ep = &ep->ep_in; + else + musb_ep = &ep->ep_out; + if (!musb_ep->desc) + break; + + handled = 1; + /* Ignore request if endpoint is wedged */ + if (musb_ep->wedged) + break; + + musb_ep_select(mbase, epnum); + if (is_in) { + csr = musb_readw(regs, MUSB_TXCSR); + csr |= MUSB_TXCSR_CLRDATATOG | + MUSB_TXCSR_P_WZC_BITS; + csr &= ~(MUSB_TXCSR_P_SENDSTALL | + MUSB_TXCSR_P_SENTSTALL | + MUSB_TXCSR_TXPKTRDY); + musb_writew(regs, MUSB_TXCSR, csr); + } else { + csr = musb_readw(regs, MUSB_RXCSR); + csr |= MUSB_RXCSR_CLRDATATOG | + MUSB_RXCSR_P_WZC_BITS; + csr &= ~(MUSB_RXCSR_P_SENDSTALL | + MUSB_RXCSR_P_SENTSTALL); + musb_writew(regs, MUSB_RXCSR, csr); + } + + /* Maybe start the first request in the queue */ + request = next_request(musb_ep); + if (!musb_ep->busy && request) { + dev_dbg(musb->controller, "restarting the request\n"); + musb_ep_restart(musb, request); + } + + /* select ep0 again */ + musb_ep_select(mbase, 0); + } break; + default: + /* class, vendor, etc ... delegate */ + handled = 0; + break; + } + break; + + case USB_REQ_SET_FEATURE: + switch (recip) { + case USB_RECIP_DEVICE: + handled = 1; + switch (ctrlrequest->wValue) { + case USB_DEVICE_REMOTE_WAKEUP: + musb->may_wakeup = 1; + break; + case USB_DEVICE_TEST_MODE: + if (musb->g.speed != USB_SPEED_HIGH) + goto stall; + if (ctrlrequest->wIndex & 0xff) + goto stall; + + switch (ctrlrequest->wIndex >> 8) { + case 1: + pr_debug("TEST_J\n"); + /* TEST_J */ + musb->test_mode_nr = + MUSB_TEST_J; + break; + case 2: + /* TEST_K */ + pr_debug("TEST_K\n"); + musb->test_mode_nr = + MUSB_TEST_K; + break; + case 3: + /* TEST_SE0_NAK */ + pr_debug("TEST_SE0_NAK\n"); + musb->test_mode_nr = + MUSB_TEST_SE0_NAK; + break; + case 4: + /* TEST_PACKET */ + pr_debug("TEST_PACKET\n"); + musb->test_mode_nr = + MUSB_TEST_PACKET; + break; + + case 0xc0: + /* TEST_FORCE_HS */ + pr_debug("TEST_FORCE_HS\n"); + musb->test_mode_nr = + MUSB_TEST_FORCE_HS; + break; + case 0xc1: + /* TEST_FORCE_FS */ + pr_debug("TEST_FORCE_FS\n"); + musb->test_mode_nr = + MUSB_TEST_FORCE_FS; + break; + case 0xc2: + /* TEST_FIFO_ACCESS */ + pr_debug("TEST_FIFO_ACCESS\n"); + musb->test_mode_nr = + MUSB_TEST_FIFO_ACCESS; + break; + case 0xc3: + /* TEST_FORCE_HOST */ + pr_debug("TEST_FORCE_HOST\n"); + musb->test_mode_nr = + MUSB_TEST_FORCE_HOST; + break; + default: + goto stall; + } + + /* enter test mode after irq */ + if (handled > 0) + musb->test_mode = true; + break; + case USB_DEVICE_B_HNP_ENABLE: + if (!musb->g.is_otg) + goto stall; + musb->g.b_hnp_enable = 1; + musb_try_b_hnp_enable(musb); + break; + case USB_DEVICE_A_HNP_SUPPORT: + if (!musb->g.is_otg) + goto stall; + musb->g.a_hnp_support = 1; + break; + case USB_DEVICE_A_ALT_HNP_SUPPORT: + if (!musb->g.is_otg) + goto stall; + musb->g.a_alt_hnp_support = 1; + break; + case USB_DEVICE_DEBUG_MODE: + handled = 0; + break; +stall: + default: + handled = -EINVAL; + break; + } + break; + + case USB_RECIP_INTERFACE: + break; + + case USB_RECIP_ENDPOINT:{ + const u8 epnum = + ctrlrequest->wIndex & 0x0f; + struct musb_ep *musb_ep; + struct musb_hw_ep *ep; + void __iomem *regs; + int is_in; + u16 csr; + + if (epnum == 0 || epnum >= MUSB_C_NUM_EPS || + ctrlrequest->wValue != USB_ENDPOINT_HALT) + break; + + ep = musb->endpoints + epnum; + regs = ep->regs; + is_in = ctrlrequest->wIndex & USB_DIR_IN; + if (is_in) + musb_ep = &ep->ep_in; + else + musb_ep = &ep->ep_out; + if (!musb_ep->desc) + break; + + musb_ep_select(mbase, epnum); + if (is_in) { + csr = musb_readw(regs, MUSB_TXCSR); + if (csr & MUSB_TXCSR_FIFONOTEMPTY) + csr |= MUSB_TXCSR_FLUSHFIFO; + csr |= MUSB_TXCSR_P_SENDSTALL + | MUSB_TXCSR_CLRDATATOG + | MUSB_TXCSR_P_WZC_BITS; + musb_writew(regs, MUSB_TXCSR, csr); + } else { + csr = musb_readw(regs, MUSB_RXCSR); + csr |= MUSB_RXCSR_P_SENDSTALL + | MUSB_RXCSR_FLUSHFIFO + | MUSB_RXCSR_CLRDATATOG + | MUSB_RXCSR_P_WZC_BITS; + musb_writew(regs, MUSB_RXCSR, csr); + } + + /* select ep0 again */ + musb_ep_select(mbase, 0); + handled = 1; + } break; + + default: + /* class, vendor, etc ... delegate */ + handled = 0; + break; + } + break; + default: + /* delegate SET_CONFIGURATION, etc */ + handled = 0; + } + } else + handled = 0; + return handled; +} + +/* we have an ep0out data packet + * Context: caller holds controller lock + */ +static void ep0_rxstate(struct musb *musb) +{ + void __iomem *regs = musb->control_ep->regs; + struct musb_request *request; + struct usb_request *req; + u16 count, csr; + + request = next_ep0_request(musb); + req = &request->request; + + /* read packet and ack; or stall because of gadget driver bug: + * should have provided the rx buffer before setup() returned. + */ + if (req) { + void *buf = req->buf + req->actual; + unsigned len = req->length - req->actual; + + /* read the buffer */ + count = musb_readb(regs, MUSB_COUNT0); + if (count > len) { + req->status = -EOVERFLOW; + count = len; + } + musb_read_fifo(&musb->endpoints[0], count, buf); + req->actual += count; + csr = MUSB_CSR0_P_SVDRXPKTRDY; + if (count < 64 || req->actual == req->length) { + musb->ep0_state = MUSB_EP0_STAGE_STATUSIN; + csr |= MUSB_CSR0_P_DATAEND; + } else + req = NULL; + } else + csr = MUSB_CSR0_P_SVDRXPKTRDY | MUSB_CSR0_P_SENDSTALL; + + + /* Completion handler may choose to stall, e.g. because the + * message just received holds invalid data. + */ + if (req) { + musb->ackpend = csr; + musb_g_ep0_giveback(musb, req); + if (!musb->ackpend) + return; + musb->ackpend = 0; + } + musb_ep_select(musb->mregs, 0); + musb_writew(regs, MUSB_CSR0, csr); +} + +/* + * transmitting to the host (IN), this code might be called from IRQ + * and from kernel thread. + * + * Context: caller holds controller lock + */ +static void ep0_txstate(struct musb *musb) +{ + void __iomem *regs = musb->control_ep->regs; + struct musb_request *req = next_ep0_request(musb); + struct usb_request *request; + u16 csr = MUSB_CSR0_TXPKTRDY; + u8 *fifo_src; + u8 fifo_count; + + if (!req) { + /* WARN_ON(1); */ + dev_dbg(musb->controller, "odd; csr0 %04x\n", musb_readw(regs, MUSB_CSR0)); + return; + } + + request = &req->request; + + /* load the data */ + fifo_src = (u8 *) request->buf + request->actual; + fifo_count = min((unsigned) MUSB_EP0_FIFOSIZE, + request->length - request->actual); + musb_write_fifo(&musb->endpoints[0], fifo_count, fifo_src); + request->actual += fifo_count; + + /* update the flags */ + if (fifo_count < MUSB_MAX_END0_PACKET + || (request->actual == request->length + && !request->zero)) { + musb->ep0_state = MUSB_EP0_STAGE_STATUSOUT; + csr |= MUSB_CSR0_P_DATAEND; + } else + request = NULL; + + /* report completions as soon as the fifo's loaded; there's no + * win in waiting till this last packet gets acked. (other than + * very precise fault reporting, needed by USB TMC; possible with + * this hardware, but not usable from portable gadget drivers.) + */ + if (request) { + musb->ackpend = csr; + musb_g_ep0_giveback(musb, request); + if (!musb->ackpend) + return; + musb->ackpend = 0; + } + + /* send it out, triggering a "txpktrdy cleared" irq */ + musb_ep_select(musb->mregs, 0); + musb_writew(regs, MUSB_CSR0, csr); +} + +/* + * Read a SETUP packet (struct usb_ctrlrequest) from the hardware. + * Fields are left in USB byte-order. + * + * Context: caller holds controller lock. + */ +static void +musb_read_setup(struct musb *musb, struct usb_ctrlrequest *req) +{ + struct musb_request *r; + void __iomem *regs = musb->control_ep->regs; + + musb_read_fifo(&musb->endpoints[0], sizeof *req, (u8 *)req); + + /* NOTE: earlier 2.6 versions changed setup packets to host + * order, but now USB packets always stay in USB byte order. + */ + dev_dbg(musb->controller, "SETUP req%02x.%02x v%04x i%04x l%d\n", + req->bRequestType, + req->bRequest, + le16_to_cpu(req->wValue), + le16_to_cpu(req->wIndex), + le16_to_cpu(req->wLength)); + + /* clean up any leftover transfers */ + r = next_ep0_request(musb); + if (r) + musb_g_ep0_giveback(musb, &r->request); + + /* For zero-data requests we want to delay the STATUS stage to + * avoid SETUPEND errors. If we read data (OUT), delay accepting + * packets until there's a buffer to store them in. + * + * If we write data, the controller acts happier if we enable + * the TX FIFO right away, and give the controller a moment + * to switch modes... + */ + musb->set_address = false; + musb->ackpend = MUSB_CSR0_P_SVDRXPKTRDY; + if (req->wLength == 0) { + if (req->bRequestType & USB_DIR_IN) + musb->ackpend |= MUSB_CSR0_TXPKTRDY; + musb->ep0_state = MUSB_EP0_STAGE_ACKWAIT; + } else if (req->bRequestType & USB_DIR_IN) { + musb->ep0_state = MUSB_EP0_STAGE_TX; + musb_writew(regs, MUSB_CSR0, MUSB_CSR0_P_SVDRXPKTRDY); + while ((musb_readw(regs, MUSB_CSR0) + & MUSB_CSR0_RXPKTRDY) != 0) + cpu_relax(); + musb->ackpend = 0; + } else + musb->ep0_state = MUSB_EP0_STAGE_RX; +} + +static int +forward_to_driver(struct musb *musb, const struct usb_ctrlrequest *ctrlrequest) +__releases(musb->lock) +__acquires(musb->lock) +{ + int retval; + if (!musb->gadget_driver) + return -EOPNOTSUPP; + spin_unlock(&musb->lock); + retval = musb->gadget_driver->setup(&musb->g, ctrlrequest); + spin_lock(&musb->lock); + return retval; +} + +/* + * Handle peripheral ep0 interrupt + * + * Context: irq handler; we won't re-enter the driver that way. + */ +irqreturn_t musb_g_ep0_irq(struct musb *musb) +{ + u16 csr; + u16 len; + void __iomem *mbase = musb->mregs; + void __iomem *regs = musb->endpoints[0].regs; + irqreturn_t retval = IRQ_NONE; + + musb_ep_select(mbase, 0); /* select ep0 */ + csr = musb_readw(regs, MUSB_CSR0); + len = musb_readb(regs, MUSB_COUNT0); + + dev_dbg(musb->controller, "csr %04x, count %d, myaddr %d, ep0stage %s\n", + csr, len, + musb_readb(mbase, MUSB_FADDR), + decode_ep0stage(musb->ep0_state)); + + if (csr & MUSB_CSR0_P_DATAEND) { + /* + * If DATAEND is set we should not call the callback, + * hence the status stage is not complete. + */ + return IRQ_HANDLED; + } + + /* I sent a stall.. need to acknowledge it now.. */ + if (csr & MUSB_CSR0_P_SENTSTALL) { + musb_writew(regs, MUSB_CSR0, + csr & ~MUSB_CSR0_P_SENTSTALL); + retval = IRQ_HANDLED; + musb->ep0_state = MUSB_EP0_STAGE_IDLE; + csr = musb_readw(regs, MUSB_CSR0); + } + + /* request ended "early" */ + if (csr & MUSB_CSR0_P_SETUPEND) { + musb_writew(regs, MUSB_CSR0, MUSB_CSR0_P_SVDSETUPEND); + retval = IRQ_HANDLED; + /* Transition into the early status phase */ + switch (musb->ep0_state) { + case MUSB_EP0_STAGE_TX: + musb->ep0_state = MUSB_EP0_STAGE_STATUSOUT; + break; + case MUSB_EP0_STAGE_RX: + musb->ep0_state = MUSB_EP0_STAGE_STATUSIN; + break; + default: + ERR("SetupEnd came in a wrong ep0stage %s\n", + decode_ep0stage(musb->ep0_state)); + } + csr = musb_readw(regs, MUSB_CSR0); + /* NOTE: request may need completion */ + } + + /* docs from Mentor only describe tx, rx, and idle/setup states. + * we need to handle nuances around status stages, and also the + * case where status and setup stages come back-to-back ... + */ + switch (musb->ep0_state) { + + case MUSB_EP0_STAGE_TX: + /* irq on clearing txpktrdy */ + if ((csr & MUSB_CSR0_TXPKTRDY) == 0) { + ep0_txstate(musb); + retval = IRQ_HANDLED; + } + break; + + case MUSB_EP0_STAGE_RX: + /* irq on set rxpktrdy */ + if (csr & MUSB_CSR0_RXPKTRDY) { + ep0_rxstate(musb); + retval = IRQ_HANDLED; + } + break; + + case MUSB_EP0_STAGE_STATUSIN: + /* end of sequence #2 (OUT/RX state) or #3 (no data) */ + + /* update address (if needed) only @ the end of the + * status phase per usb spec, which also guarantees + * we get 10 msec to receive this irq... until this + * is done we won't see the next packet. + */ + if (musb->set_address) { + musb->set_address = false; + musb_writeb(mbase, MUSB_FADDR, musb->address); + } + + /* enter test mode if needed (exit by reset) */ + else if (musb->test_mode) { + dev_dbg(musb->controller, "entering TESTMODE\n"); + + if (MUSB_TEST_PACKET == musb->test_mode_nr) + musb_load_testpacket(musb); + + musb_writeb(mbase, MUSB_TESTMODE, + musb->test_mode_nr); + } + /* FALLTHROUGH */ + + case MUSB_EP0_STAGE_STATUSOUT: + /* end of sequence #1: write to host (TX state) */ + { + struct musb_request *req; + + req = next_ep0_request(musb); + if (req) + musb_g_ep0_giveback(musb, &req->request); + } + + /* + * In case when several interrupts can get coalesced, + * check to see if we've already received a SETUP packet... + */ + if (csr & MUSB_CSR0_RXPKTRDY) + goto setup; + + retval = IRQ_HANDLED; + musb->ep0_state = MUSB_EP0_STAGE_IDLE; + break; + + case MUSB_EP0_STAGE_IDLE: + /* + * This state is typically (but not always) indiscernible + * from the status states since the corresponding interrupts + * tend to happen within too little period of time (with only + * a zero-length packet in between) and so get coalesced... + */ + retval = IRQ_HANDLED; + musb->ep0_state = MUSB_EP0_STAGE_SETUP; + /* FALLTHROUGH */ + + case MUSB_EP0_STAGE_SETUP: +setup: + if (csr & MUSB_CSR0_RXPKTRDY) { + struct usb_ctrlrequest setup; + int handled = 0; + + if (len != 8) { + ERR("SETUP packet len %d != 8 ?\n", len); + break; + } + musb_read_setup(musb, &setup); + retval = IRQ_HANDLED; + + /* sometimes the RESET won't be reported */ + if (unlikely(musb->g.speed == USB_SPEED_UNKNOWN)) { + u8 power; + + printk(KERN_NOTICE "%s: peripheral reset " + "irq lost!\n", + musb_driver_name); + power = musb_readb(mbase, MUSB_POWER); + musb->g.speed = (power & MUSB_POWER_HSMODE) + ? USB_SPEED_HIGH : USB_SPEED_FULL; + + } + + switch (musb->ep0_state) { + + /* sequence #3 (no data stage), includes requests + * we can't forward (notably SET_ADDRESS and the + * device/endpoint feature set/clear operations) + * plus SET_CONFIGURATION and others we must + */ + case MUSB_EP0_STAGE_ACKWAIT: + handled = service_zero_data_request( + musb, &setup); + + /* + * We're expecting no data in any case, so + * always set the DATAEND bit -- doing this + * here helps avoid SetupEnd interrupt coming + * in the idle stage when we're stalling... + */ + musb->ackpend |= MUSB_CSR0_P_DATAEND; + + /* status stage might be immediate */ + if (handled > 0) + musb->ep0_state = + MUSB_EP0_STAGE_STATUSIN; + break; + + /* sequence #1 (IN to host), includes GET_STATUS + * requests that we can't forward, GET_DESCRIPTOR + * and others that we must + */ + case MUSB_EP0_STAGE_TX: + handled = service_in_request(musb, &setup); + if (handled > 0) { + musb->ackpend = MUSB_CSR0_TXPKTRDY + | MUSB_CSR0_P_DATAEND; + musb->ep0_state = + MUSB_EP0_STAGE_STATUSOUT; + } + break; + + /* sequence #2 (OUT from host), always forward */ + default: /* MUSB_EP0_STAGE_RX */ + break; + } + + dev_dbg(musb->controller, "handled %d, csr %04x, ep0stage %s\n", + handled, csr, + decode_ep0stage(musb->ep0_state)); + + /* unless we need to delegate this to the gadget + * driver, we know how to wrap this up: csr0 has + * not yet been written. + */ + if (handled < 0) + goto stall; + else if (handled > 0) + goto finish; + + handled = forward_to_driver(musb, &setup); + if (handled < 0) { + musb_ep_select(mbase, 0); +stall: + dev_dbg(musb->controller, "stall (%d)\n", handled); + musb->ackpend |= MUSB_CSR0_P_SENDSTALL; + musb->ep0_state = MUSB_EP0_STAGE_IDLE; +finish: + musb_writew(regs, MUSB_CSR0, + musb->ackpend); + musb->ackpend = 0; + } + } + break; + + case MUSB_EP0_STAGE_ACKWAIT: + /* This should not happen. But happens with tusb6010 with + * g_file_storage and high speed. Do nothing. + */ + retval = IRQ_HANDLED; + break; + + default: + /* "can't happen" */ + WARN_ON(1); + musb_writew(regs, MUSB_CSR0, MUSB_CSR0_P_SENDSTALL); + musb->ep0_state = MUSB_EP0_STAGE_IDLE; + break; + } + + return retval; +} + + +static int +musb_g_ep0_enable(struct usb_ep *ep, const struct usb_endpoint_descriptor *desc) +{ + /* always enabled */ + return -EINVAL; +} + +static int musb_g_ep0_disable(struct usb_ep *e) +{ + /* always enabled */ + return -EINVAL; +} + +static int +musb_g_ep0_queue(struct usb_ep *e, struct usb_request *r, gfp_t gfp_flags) +{ + struct musb_ep *ep; + struct musb_request *req; + struct musb *musb; + int status; + unsigned long lockflags; + void __iomem *regs; + + if (!e || !r) + return -EINVAL; + + ep = to_musb_ep(e); + musb = ep->musb; + regs = musb->control_ep->regs; + + req = to_musb_request(r); + req->musb = musb; + req->request.actual = 0; + req->request.status = -EINPROGRESS; + req->tx = ep->is_in; + + spin_lock_irqsave(&musb->lock, lockflags); + + if (!list_empty(&ep->req_list)) { + status = -EBUSY; + goto cleanup; + } + + switch (musb->ep0_state) { + case MUSB_EP0_STAGE_RX: /* control-OUT data */ + case MUSB_EP0_STAGE_TX: /* control-IN data */ + case MUSB_EP0_STAGE_ACKWAIT: /* zero-length data */ + status = 0; + break; + default: + dev_dbg(musb->controller, "ep0 request queued in state %d\n", + musb->ep0_state); + status = -EINVAL; + goto cleanup; + } + + /* add request to the list */ + list_add_tail(&req->list, &ep->req_list); + + dev_dbg(musb->controller, "queue to %s (%s), length=%d\n", + ep->name, ep->is_in ? "IN/TX" : "OUT/RX", + req->request.length); + + musb_ep_select(musb->mregs, 0); + + /* sequence #1, IN ... start writing the data */ + if (musb->ep0_state == MUSB_EP0_STAGE_TX) + ep0_txstate(musb); + + /* sequence #3, no-data ... issue IN status */ + else if (musb->ep0_state == MUSB_EP0_STAGE_ACKWAIT) { + if (req->request.length) + status = -EINVAL; + else { + musb->ep0_state = MUSB_EP0_STAGE_STATUSIN; + musb_writew(regs, MUSB_CSR0, + musb->ackpend | MUSB_CSR0_P_DATAEND); + musb->ackpend = 0; + musb_g_ep0_giveback(ep->musb, r); + } + + /* else for sequence #2 (OUT), caller provides a buffer + * before the next packet arrives. deferred responses + * (after SETUP is acked) are racey. + */ + } else if (musb->ackpend) { + musb_writew(regs, MUSB_CSR0, musb->ackpend); + musb->ackpend = 0; + } + +cleanup: + spin_unlock_irqrestore(&musb->lock, lockflags); + return status; +} + +static int musb_g_ep0_dequeue(struct usb_ep *ep, struct usb_request *req) +{ + /* we just won't support this */ + return -EINVAL; +} + +static int musb_g_ep0_halt(struct usb_ep *e, int value) +{ + struct musb_ep *ep; + struct musb *musb; + void __iomem *base, *regs; + unsigned long flags; + int status; + u16 csr; + + if (!e || !value) + return -EINVAL; + + ep = to_musb_ep(e); + musb = ep->musb; + base = musb->mregs; + regs = musb->control_ep->regs; + status = 0; + + spin_lock_irqsave(&musb->lock, flags); + + if (!list_empty(&ep->req_list)) { + status = -EBUSY; + goto cleanup; + } + + musb_ep_select(base, 0); + csr = musb->ackpend; + + switch (musb->ep0_state) { + + /* Stalls are usually issued after parsing SETUP packet, either + * directly in irq context from setup() or else later. + */ + case MUSB_EP0_STAGE_TX: /* control-IN data */ + case MUSB_EP0_STAGE_ACKWAIT: /* STALL for zero-length data */ + case MUSB_EP0_STAGE_RX: /* control-OUT data */ + csr = musb_readw(regs, MUSB_CSR0); + /* FALLTHROUGH */ + + /* It's also OK to issue stalls during callbacks when a non-empty + * DATA stage buffer has been read (or even written). + */ + case MUSB_EP0_STAGE_STATUSIN: /* control-OUT status */ + case MUSB_EP0_STAGE_STATUSOUT: /* control-IN status */ + + csr |= MUSB_CSR0_P_SENDSTALL; + musb_writew(regs, MUSB_CSR0, csr); + musb->ep0_state = MUSB_EP0_STAGE_IDLE; + musb->ackpend = 0; + break; + default: + dev_dbg(musb->controller, "ep0 can't halt in state %d\n", musb->ep0_state); + status = -EINVAL; + } + +cleanup: + spin_unlock_irqrestore(&musb->lock, flags); + return status; +} + +const struct usb_ep_ops musb_g_ep0_ops = { + .enable = musb_g_ep0_enable, + .disable = musb_g_ep0_disable, + .alloc_request = musb_alloc_request, + .free_request = musb_free_request, + .queue = musb_g_ep0_queue, + .dequeue = musb_g_ep0_dequeue, + .set_halt = musb_g_ep0_halt, +}; diff --git a/drivers/usb/musb-new/musb_gadget_uboot.c b/drivers/usb/musb-new/musb_gadget_uboot.c new file mode 100644 index 0000000..59b6d65 --- /dev/null +++ b/drivers/usb/musb-new/musb_gadget_uboot.c @@ -0,0 +1,72 @@ +#include <common.h> +#include <asm/errno.h> +#include <linux/usb/ch9.h> +#include <linux/usb/gadget.h> + +#define __UBOOT__ +#include "linux-compat.h" +#include "musb_core.h" +#include "musb_gadget.h" + +struct musb * +musb_init_controller(struct musb_hdrc_platform_data *plat, struct device *dev, + void *ctrl); +int musb_gadget_start(struct usb_gadget *g, struct usb_gadget_driver *driver); + +struct musb *musb; + +int usb_gadget_handle_interrupts(void) +{ + if (!musb || !musb->isr) + return -EINVAL; + + return musb->isr(0, musb); +} + +int musb_register(struct musb_hdrc_platform_data *plat, void *bdata, + void *ctl_regs) +{ + musb = musb_init_controller(plat, (struct device *)bdata, ctl_regs); + if (!musb) { + printf("Failed to init the controller\n"); + return -EIO; + } + + return 0; +} + +int usb_gadget_register_driver(struct usb_gadget_driver *driver) +{ + int ret; + + if (!driver || driver->speed < USB_SPEED_HIGH || !driver->bind || + !driver->setup) { + printf("bad parameter.\n"); + return -EINVAL; + } + + if (!musb) { + printf("Controller uninitialized\n"); + return -ENXIO; + } + + ret = musb_gadget_start(&musb->g, driver); + if (ret < 0) { + printf("gadget_start failed with %d\n", ret); + return ret; + } + + ret = driver->bind(&musb->g); + if (ret < 0) { + printf("bind failed with %d\n", ret); + return ret; + } + + return 0; +} + +int usb_gadget_unregister_driver(struct usb_gadget_driver *driver) +{ + /* TODO: implement me */ + return 0; +} diff --git a/drivers/usb/musb-new/musb_io.h b/drivers/usb/musb-new/musb_io.h new file mode 100644 index 0000000..51730ae --- /dev/null +++ b/drivers/usb/musb-new/musb_io.h @@ -0,0 +1,146 @@ +/* + * MUSB OTG driver register I/O + * + * Copyright 2005 Mentor Graphics Corporation + * Copyright (C) 2005-2006 by Texas Instruments + * Copyright (C) 2006-2007 Nokia Corporation + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, but + * WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU + * General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA + * 02110-1301 USA + * + * THIS SOFTWARE IS PROVIDED "AS IS" AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN + * NO EVENT SHALL THE AUTHORS BE LIABLE FOR ANY DIRECT, INDIRECT, + * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT + * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF + * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON + * ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT + * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF + * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. + * + */ + +#ifndef __MUSB_LINUX_PLATFORM_ARCH_H__ +#define __MUSB_LINUX_PLATFORM_ARCH_H__ + +#ifndef __UBOOT__ +#include <linux/io.h> +#else +#include <asm/io.h> +#endif + +#if !defined(CONFIG_ARM) && !defined(CONFIG_SUPERH) \ + && !defined(CONFIG_AVR32) && !defined(CONFIG_PPC32) \ + && !defined(CONFIG_PPC64) && !defined(CONFIG_BLACKFIN) \ + && !defined(CONFIG_MIPS) && !defined(CONFIG_M68K) +static inline void readsl(const void __iomem *addr, void *buf, int len) + { insl((unsigned long)addr, buf, len); } +static inline void readsw(const void __iomem *addr, void *buf, int len) + { insw((unsigned long)addr, buf, len); } +static inline void readsb(const void __iomem *addr, void *buf, int len) + { insb((unsigned long)addr, buf, len); } + +static inline void writesl(const void __iomem *addr, const void *buf, int len) + { outsl((unsigned long)addr, buf, len); } +static inline void writesw(const void __iomem *addr, const void *buf, int len) + { outsw((unsigned long)addr, buf, len); } +static inline void writesb(const void __iomem *addr, const void *buf, int len) + { outsb((unsigned long)addr, buf, len); } + +#endif + +#ifndef CONFIG_BLACKFIN + +/* NOTE: these offsets are all in bytes */ + +static inline u16 musb_readw(const void __iomem *addr, unsigned offset) + { return __raw_readw(addr + offset); } + +static inline u32 musb_readl(const void __iomem *addr, unsigned offset) + { return __raw_readl(addr + offset); } + + +static inline void musb_writew(void __iomem *addr, unsigned offset, u16 data) + { __raw_writew(data, addr + offset); } + +static inline void musb_writel(void __iomem *addr, unsigned offset, u32 data) + { __raw_writel(data, addr + offset); } + + +#if defined(CONFIG_USB_MUSB_TUSB6010) || defined (CONFIG_USB_MUSB_TUSB6010_MODULE) + +/* + * TUSB6010 doesn't allow 8-bit access; 16-bit access is the minimum. + */ +static inline u8 musb_readb(const void __iomem *addr, unsigned offset) +{ + u16 tmp; + u8 val; + + tmp = __raw_readw(addr + (offset & ~1)); + if (offset & 1) + val = (tmp >> 8); + else + val = tmp & 0xff; + + return val; +} + +static inline void musb_writeb(void __iomem *addr, unsigned offset, u8 data) +{ + u16 tmp; + + tmp = __raw_readw(addr + (offset & ~1)); + if (offset & 1) + tmp = (data << 8) | (tmp & 0xff); + else + tmp = (tmp & 0xff00) | data; + + __raw_writew(tmp, addr + (offset & ~1)); +} + +#else + +static inline u8 musb_readb(const void __iomem *addr, unsigned offset) + { return __raw_readb(addr + offset); } + +static inline void musb_writeb(void __iomem *addr, unsigned offset, u8 data) + { __raw_writeb(data, addr + offset); } + +#endif /* CONFIG_USB_MUSB_TUSB6010 */ + +#else + +static inline u8 musb_readb(const void __iomem *addr, unsigned offset) + { return (u8) (bfin_read16(addr + offset)); } + +static inline u16 musb_readw(const void __iomem *addr, unsigned offset) + { return bfin_read16(addr + offset); } + +static inline u32 musb_readl(const void __iomem *addr, unsigned offset) + { return (u32) (bfin_read16(addr + offset)); } + +static inline void musb_writeb(void __iomem *addr, unsigned offset, u8 data) + { bfin_write16(addr + offset, (u16) data); } + +static inline void musb_writew(void __iomem *addr, unsigned offset, u16 data) + { bfin_write16(addr + offset, data); } + +static inline void musb_writel(void __iomem *addr, unsigned offset, u32 data) + { bfin_write16(addr + offset, (u16) data); } + +#endif /* CONFIG_BLACKFIN */ + +#endif diff --git a/drivers/usb/musb-new/musb_regs.h b/drivers/usb/musb-new/musb_regs.h new file mode 100644 index 0000000..03f2655 --- /dev/null +++ b/drivers/usb/musb-new/musb_regs.h @@ -0,0 +1,645 @@ +/* + * MUSB OTG driver register defines + * + * Copyright 2005 Mentor Graphics Corporation + * Copyright (C) 2005-2006 by Texas Instruments + * Copyright (C) 2006-2007 Nokia Corporation + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, but + * WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU + * General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA + * 02110-1301 USA + * + * THIS SOFTWARE IS PROVIDED "AS IS" AND ANY EXPRESS OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN + * NO EVENT SHALL THE AUTHORS BE LIABLE FOR ANY DIRECT, INDIRECT, + * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT + * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF + * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON + * ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT + * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF + * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. + * + */ + +#ifndef __MUSB_REGS_H__ +#define __MUSB_REGS_H__ + +#define MUSB_EP0_FIFOSIZE 64 /* This is non-configurable */ + +/* + * MUSB Register bits + */ + +/* POWER */ +#define MUSB_POWER_ISOUPDATE 0x80 +#define MUSB_POWER_SOFTCONN 0x40 +#define MUSB_POWER_HSENAB 0x20 +#define MUSB_POWER_HSMODE 0x10 +#define MUSB_POWER_RESET 0x08 +#define MUSB_POWER_RESUME 0x04 +#define MUSB_POWER_SUSPENDM 0x02 +#define MUSB_POWER_ENSUSPEND 0x01 + +/* INTRUSB */ +#define MUSB_INTR_SUSPEND 0x01 +#define MUSB_INTR_RESUME 0x02 +#define MUSB_INTR_RESET 0x04 +#define MUSB_INTR_BABBLE 0x04 +#define MUSB_INTR_SOF 0x08 +#define MUSB_INTR_CONNECT 0x10 +#define MUSB_INTR_DISCONNECT 0x20 +#define MUSB_INTR_SESSREQ 0x40 +#define MUSB_INTR_VBUSERROR 0x80 /* For SESSION end */ + +/* DEVCTL */ +#define MUSB_DEVCTL_BDEVICE 0x80 +#define MUSB_DEVCTL_FSDEV 0x40 +#define MUSB_DEVCTL_LSDEV 0x20 +#define MUSB_DEVCTL_VBUS 0x18 +#define MUSB_DEVCTL_VBUS_SHIFT 3 +#define MUSB_DEVCTL_HM 0x04 +#define MUSB_DEVCTL_HR 0x02 +#define MUSB_DEVCTL_SESSION 0x01 + +/* MUSB ULPI VBUSCONTROL */ +#define MUSB_ULPI_USE_EXTVBUS 0x01 +#define MUSB_ULPI_USE_EXTVBUSIND 0x02 +/* ULPI_REG_CONTROL */ +#define MUSB_ULPI_REG_REQ (1 << 0) +#define MUSB_ULPI_REG_CMPLT (1 << 1) +#define MUSB_ULPI_RDN_WR (1 << 2) + +/* TESTMODE */ +#define MUSB_TEST_FORCE_HOST 0x80 +#define MUSB_TEST_FIFO_ACCESS 0x40 +#define MUSB_TEST_FORCE_FS 0x20 +#define MUSB_TEST_FORCE_HS 0x10 +#define MUSB_TEST_PACKET 0x08 +#define MUSB_TEST_K 0x04 +#define MUSB_TEST_J 0x02 +#define MUSB_TEST_SE0_NAK 0x01 + +/* Allocate for double-packet buffering (effectively doubles assigned _SIZE) */ +#define MUSB_FIFOSZ_DPB 0x10 +/* Allocation size (8, 16, 32, ... 4096) */ +#define MUSB_FIFOSZ_SIZE 0x0f + +/* CSR0 */ +#define MUSB_CSR0_FLUSHFIFO 0x0100 +#define MUSB_CSR0_TXPKTRDY 0x0002 +#define MUSB_CSR0_RXPKTRDY 0x0001 + +/* CSR0 in Peripheral mode */ +#define MUSB_CSR0_P_SVDSETUPEND 0x0080 +#define MUSB_CSR0_P_SVDRXPKTRDY 0x0040 +#define MUSB_CSR0_P_SENDSTALL 0x0020 +#define MUSB_CSR0_P_SETUPEND 0x0010 +#define MUSB_CSR0_P_DATAEND 0x0008 +#define MUSB_CSR0_P_SENTSTALL 0x0004 + +/* CSR0 in Host mode */ +#define MUSB_CSR0_H_DIS_PING 0x0800 +#define MUSB_CSR0_H_WR_DATATOGGLE 0x0400 /* Set to allow setting: */ +#define MUSB_CSR0_H_DATATOGGLE 0x0200 /* Data toggle control */ +#define MUSB_CSR0_H_NAKTIMEOUT 0x0080 +#define MUSB_CSR0_H_STATUSPKT 0x0040 +#define MUSB_CSR0_H_REQPKT 0x0020 +#define MUSB_CSR0_H_ERROR 0x0010 +#define MUSB_CSR0_H_SETUPPKT 0x0008 +#define MUSB_CSR0_H_RXSTALL 0x0004 + +/* CSR0 bits to avoid zeroing (write zero clears, write 1 ignored) */ +#define MUSB_CSR0_P_WZC_BITS \ + (MUSB_CSR0_P_SENTSTALL) +#define MUSB_CSR0_H_WZC_BITS \ + (MUSB_CSR0_H_NAKTIMEOUT | MUSB_CSR0_H_RXSTALL \ + | MUSB_CSR0_RXPKTRDY) + +/* TxType/RxType */ +#define MUSB_TYPE_SPEED 0xc0 +#define MUSB_TYPE_SPEED_SHIFT 6 +#define MUSB_TYPE_PROTO 0x30 /* Implicitly zero for ep0 */ +#define MUSB_TYPE_PROTO_SHIFT 4 +#define MUSB_TYPE_REMOTE_END 0xf /* Implicitly zero for ep0 */ + +/* CONFIGDATA */ +#define MUSB_CONFIGDATA_MPRXE 0x80 /* Auto bulk pkt combining */ +#define MUSB_CONFIGDATA_MPTXE 0x40 /* Auto bulk pkt splitting */ +#define MUSB_CONFIGDATA_BIGENDIAN 0x20 +#define MUSB_CONFIGDATA_HBRXE 0x10 /* HB-ISO for RX */ +#define MUSB_CONFIGDATA_HBTXE 0x08 /* HB-ISO for TX */ +#define MUSB_CONFIGDATA_DYNFIFO 0x04 /* Dynamic FIFO sizing */ +#define MUSB_CONFIGDATA_SOFTCONE 0x02 /* SoftConnect */ +#define MUSB_CONFIGDATA_UTMIDW 0x01 /* Data width 0/1 => 8/16bits */ + +/* TXCSR in Peripheral and Host mode */ +#define MUSB_TXCSR_AUTOSET 0x8000 +#define MUSB_TXCSR_DMAENAB 0x1000 +#define MUSB_TXCSR_FRCDATATOG 0x0800 +#define MUSB_TXCSR_DMAMODE 0x0400 +#define MUSB_TXCSR_CLRDATATOG 0x0040 +#define MUSB_TXCSR_FLUSHFIFO 0x0008 +#define MUSB_TXCSR_FIFONOTEMPTY 0x0002 +#define MUSB_TXCSR_TXPKTRDY 0x0001 + +/* TXCSR in Peripheral mode */ +#define MUSB_TXCSR_P_ISO 0x4000 +#define MUSB_TXCSR_P_INCOMPTX 0x0080 +#define MUSB_TXCSR_P_SENTSTALL 0x0020 +#define MUSB_TXCSR_P_SENDSTALL 0x0010 +#define MUSB_TXCSR_P_UNDERRUN 0x0004 + +/* TXCSR in Host mode */ +#define MUSB_TXCSR_H_WR_DATATOGGLE 0x0200 +#define MUSB_TXCSR_H_DATATOGGLE 0x0100 +#define MUSB_TXCSR_H_NAKTIMEOUT 0x0080 +#define MUSB_TXCSR_H_RXSTALL 0x0020 +#define MUSB_TXCSR_H_ERROR 0x0004 + +/* TXCSR bits to avoid zeroing (write zero clears, write 1 ignored) */ +#define MUSB_TXCSR_P_WZC_BITS \ + (MUSB_TXCSR_P_INCOMPTX | MUSB_TXCSR_P_SENTSTALL \ + | MUSB_TXCSR_P_UNDERRUN | MUSB_TXCSR_FIFONOTEMPTY) +#define MUSB_TXCSR_H_WZC_BITS \ + (MUSB_TXCSR_H_NAKTIMEOUT | MUSB_TXCSR_H_RXSTALL \ + | MUSB_TXCSR_H_ERROR | MUSB_TXCSR_FIFONOTEMPTY) + +/* RXCSR in Peripheral and Host mode */ +#define MUSB_RXCSR_AUTOCLEAR 0x8000 +#define MUSB_RXCSR_DMAENAB 0x2000 +#define MUSB_RXCSR_DISNYET 0x1000 +#define MUSB_RXCSR_PID_ERR 0x1000 +#define MUSB_RXCSR_DMAMODE 0x0800 +#define MUSB_RXCSR_INCOMPRX 0x0100 +#define MUSB_RXCSR_CLRDATATOG 0x0080 +#define MUSB_RXCSR_FLUSHFIFO 0x0010 +#define MUSB_RXCSR_DATAERROR 0x0008 +#define MUSB_RXCSR_FIFOFULL 0x0002 +#define MUSB_RXCSR_RXPKTRDY 0x0001 + +/* RXCSR in Peripheral mode */ +#define MUSB_RXCSR_P_ISO 0x4000 +#define MUSB_RXCSR_P_SENTSTALL 0x0040 +#define MUSB_RXCSR_P_SENDSTALL 0x0020 +#define MUSB_RXCSR_P_OVERRUN 0x0004 + +/* RXCSR in Host mode */ +#define MUSB_RXCSR_H_AUTOREQ 0x4000 +#define MUSB_RXCSR_H_WR_DATATOGGLE 0x0400 +#define MUSB_RXCSR_H_DATATOGGLE 0x0200 +#define MUSB_RXCSR_H_RXSTALL 0x0040 +#define MUSB_RXCSR_H_REQPKT 0x0020 +#define MUSB_RXCSR_H_ERROR 0x0004 + +/* RXCSR bits to avoid zeroing (write zero clears, write 1 ignored) */ +#define MUSB_RXCSR_P_WZC_BITS \ + (MUSB_RXCSR_P_SENTSTALL | MUSB_RXCSR_P_OVERRUN \ + | MUSB_RXCSR_RXPKTRDY) +#define MUSB_RXCSR_H_WZC_BITS \ + (MUSB_RXCSR_H_RXSTALL | MUSB_RXCSR_H_ERROR \ + | MUSB_RXCSR_DATAERROR | MUSB_RXCSR_RXPKTRDY) + +/* HUBADDR */ +#define MUSB_HUBADDR_MULTI_TT 0x80 + + +#ifndef CONFIG_BLACKFIN + +/* + * Common USB registers + */ + +#define MUSB_FADDR 0x00 /* 8-bit */ +#define MUSB_POWER 0x01 /* 8-bit */ + +#define MUSB_INTRTX 0x02 /* 16-bit */ +#define MUSB_INTRRX 0x04 +#define MUSB_INTRTXE 0x06 +#define MUSB_INTRRXE 0x08 +#define MUSB_INTRUSB 0x0A /* 8 bit */ +#define MUSB_INTRUSBE 0x0B /* 8 bit */ +#define MUSB_FRAME 0x0C +#define MUSB_INDEX 0x0E /* 8 bit */ +#define MUSB_TESTMODE 0x0F /* 8 bit */ + +/* Get offset for a given FIFO from musb->mregs */ +#if defined(CONFIG_USB_MUSB_TUSB6010) || \ + defined(CONFIG_USB_MUSB_TUSB6010_MODULE) +#define MUSB_FIFO_OFFSET(epnum) (0x200 + ((epnum) * 0x20)) +#else +#define MUSB_FIFO_OFFSET(epnum) (0x20 + ((epnum) * 4)) +#endif + +/* + * Additional Control Registers + */ + +#define MUSB_DEVCTL 0x60 /* 8 bit */ + +/* These are always controlled through the INDEX register */ +#define MUSB_TXFIFOSZ 0x62 /* 8-bit (see masks) */ +#define MUSB_RXFIFOSZ 0x63 /* 8-bit (see masks) */ +#define MUSB_TXFIFOADD 0x64 /* 16-bit offset shifted right 3 */ +#define MUSB_RXFIFOADD 0x66 /* 16-bit offset shifted right 3 */ + +/* REVISIT: vctrl/vstatus: optional vendor utmi+phy register at 0x68 */ +#define MUSB_HWVERS 0x6C /* 8 bit */ +#define MUSB_ULPI_BUSCONTROL 0x70 /* 8 bit */ +#define MUSB_ULPI_INT_MASK 0x72 /* 8 bit */ +#define MUSB_ULPI_INT_SRC 0x73 /* 8 bit */ +#define MUSB_ULPI_REG_DATA 0x74 /* 8 bit */ +#define MUSB_ULPI_REG_ADDR 0x75 /* 8 bit */ +#define MUSB_ULPI_REG_CONTROL 0x76 /* 8 bit */ +#define MUSB_ULPI_RAW_DATA 0x77 /* 8 bit */ + +#define MUSB_EPINFO 0x78 /* 8 bit */ +#define MUSB_RAMINFO 0x79 /* 8 bit */ +#define MUSB_LINKINFO 0x7a /* 8 bit */ +#define MUSB_VPLEN 0x7b /* 8 bit */ +#define MUSB_HS_EOF1 0x7c /* 8 bit */ +#define MUSB_FS_EOF1 0x7d /* 8 bit */ +#define MUSB_LS_EOF1 0x7e /* 8 bit */ + +/* Offsets to endpoint registers */ +#define MUSB_TXMAXP 0x00 +#define MUSB_TXCSR 0x02 +#define MUSB_CSR0 MUSB_TXCSR /* Re-used for EP0 */ +#define MUSB_RXMAXP 0x04 +#define MUSB_RXCSR 0x06 +#define MUSB_RXCOUNT 0x08 +#define MUSB_COUNT0 MUSB_RXCOUNT /* Re-used for EP0 */ +#define MUSB_TXTYPE 0x0A +#define MUSB_TYPE0 MUSB_TXTYPE /* Re-used for EP0 */ +#define MUSB_TXINTERVAL 0x0B +#define MUSB_NAKLIMIT0 MUSB_TXINTERVAL /* Re-used for EP0 */ +#define MUSB_RXTYPE 0x0C +#define MUSB_RXINTERVAL 0x0D +#define MUSB_FIFOSIZE 0x0F +#define MUSB_CONFIGDATA MUSB_FIFOSIZE /* Re-used for EP0 */ + +/* Offsets to endpoint registers in indexed model (using INDEX register) */ +#define MUSB_INDEXED_OFFSET(_epnum, _offset) \ + (0x10 + (_offset)) + +/* Offsets to endpoint registers in flat models */ +#define MUSB_FLAT_OFFSET(_epnum, _offset) \ + (0x100 + (0x10*(_epnum)) + (_offset)) + +#if defined(CONFIG_USB_MUSB_TUSB6010) || \ + defined(CONFIG_USB_MUSB_TUSB6010_MODULE) +/* TUSB6010 EP0 configuration register is special */ +#define MUSB_TUSB_OFFSET(_epnum, _offset) \ + (0x10 + _offset) +#include "tusb6010.h" /* Needed "only" for TUSB_EP0_CONF */ +#endif + +#define MUSB_TXCSR_MODE 0x2000 + +/* "bus control"/target registers, for host side multipoint (external hubs) */ +#define MUSB_TXFUNCADDR 0x00 +#define MUSB_TXHUBADDR 0x02 +#define MUSB_TXHUBPORT 0x03 + +#define MUSB_RXFUNCADDR 0x04 +#define MUSB_RXHUBADDR 0x06 +#define MUSB_RXHUBPORT 0x07 + +#define MUSB_BUSCTL_OFFSET(_epnum, _offset) \ + (0x80 + (8*(_epnum)) + (_offset)) + +static inline void musb_write_txfifosz(void __iomem *mbase, u8 c_size) +{ + musb_writeb(mbase, MUSB_TXFIFOSZ, c_size); +} + +static inline void musb_write_txfifoadd(void __iomem *mbase, u16 c_off) +{ + musb_writew(mbase, MUSB_TXFIFOADD, c_off); +} + +static inline void musb_write_rxfifosz(void __iomem *mbase, u8 c_size) +{ + musb_writeb(mbase, MUSB_RXFIFOSZ, c_size); +} + +static inline void musb_write_rxfifoadd(void __iomem *mbase, u16 c_off) +{ + musb_writew(mbase, MUSB_RXFIFOADD, c_off); +} + +static inline void musb_write_ulpi_buscontrol(void __iomem *mbase, u8 val) +{ + musb_writeb(mbase, MUSB_ULPI_BUSCONTROL, val); +} + +static inline u8 musb_read_txfifosz(void __iomem *mbase) +{ + return musb_readb(mbase, MUSB_TXFIFOSZ); +} + +static inline u16 musb_read_txfifoadd(void __iomem *mbase) +{ + return musb_readw(mbase, MUSB_TXFIFOADD); +} + +static inline u8 musb_read_rxfifosz(void __iomem *mbase) +{ + return musb_readb(mbase, MUSB_RXFIFOSZ); +} + +static inline u16 musb_read_rxfifoadd(void __iomem *mbase) +{ + return musb_readw(mbase, MUSB_RXFIFOADD); +} + +static inline u8 musb_read_ulpi_buscontrol(void __iomem *mbase) +{ + return musb_readb(mbase, MUSB_ULPI_BUSCONTROL); +} + +static inline u8 musb_read_configdata(void __iomem *mbase) +{ + musb_writeb(mbase, MUSB_INDEX, 0); + return musb_readb(mbase, 0x10 + MUSB_CONFIGDATA); +} + +static inline u16 musb_read_hwvers(void __iomem *mbase) +{ + return musb_readw(mbase, MUSB_HWVERS); +} + +static inline void __iomem *musb_read_target_reg_base(u8 i, void __iomem *mbase) +{ + return (MUSB_BUSCTL_OFFSET(i, 0) + mbase); +} + +static inline void musb_write_rxfunaddr(void __iomem *ep_target_regs, + u8 qh_addr_reg) +{ + musb_writeb(ep_target_regs, MUSB_RXFUNCADDR, qh_addr_reg); +} + +static inline void musb_write_rxhubaddr(void __iomem *ep_target_regs, + u8 qh_h_addr_reg) +{ + musb_writeb(ep_target_regs, MUSB_RXHUBADDR, qh_h_addr_reg); +} + +static inline void musb_write_rxhubport(void __iomem *ep_target_regs, + u8 qh_h_port_reg) +{ + musb_writeb(ep_target_regs, MUSB_RXHUBPORT, qh_h_port_reg); +} + +static inline void musb_write_txfunaddr(void __iomem *mbase, u8 epnum, + u8 qh_addr_reg) +{ + musb_writeb(mbase, MUSB_BUSCTL_OFFSET(epnum, MUSB_TXFUNCADDR), + qh_addr_reg); +} + +static inline void musb_write_txhubaddr(void __iomem *mbase, u8 epnum, + u8 qh_addr_reg) +{ + musb_writeb(mbase, MUSB_BUSCTL_OFFSET(epnum, MUSB_TXHUBADDR), + qh_addr_reg); +} + +static inline void musb_write_txhubport(void __iomem *mbase, u8 epnum, + u8 qh_h_port_reg) +{ + musb_writeb(mbase, MUSB_BUSCTL_OFFSET(epnum, MUSB_TXHUBPORT), + qh_h_port_reg); +} + +static inline u8 musb_read_rxfunaddr(void __iomem *mbase, u8 epnum) +{ + return musb_readb(mbase, MUSB_BUSCTL_OFFSET(epnum, MUSB_RXFUNCADDR)); +} + +static inline u8 musb_read_rxhubaddr(void __iomem *mbase, u8 epnum) +{ + return musb_readb(mbase, MUSB_BUSCTL_OFFSET(epnum, MUSB_RXHUBADDR)); +} + +static inline u8 musb_read_rxhubport(void __iomem *mbase, u8 epnum) +{ + return musb_readb(mbase, MUSB_BUSCTL_OFFSET(epnum, MUSB_RXHUBPORT)); +} + +static inline u8 musb_read_txfunaddr(void __iomem *mbase, u8 epnum) +{ + return musb_readb(mbase, MUSB_BUSCTL_OFFSET(epnum, MUSB_TXFUNCADDR)); +} + +static inline u8 musb_read_txhubaddr(void __iomem *mbase, u8 epnum) +{ + return musb_readb(mbase, MUSB_BUSCTL_OFFSET(epnum, MUSB_TXHUBADDR)); +} + +static inline u8 musb_read_txhubport(void __iomem *mbase, u8 epnum) +{ + return musb_readb(mbase, MUSB_BUSCTL_OFFSET(epnum, MUSB_TXHUBPORT)); +} + +#else /* CONFIG_BLACKFIN */ + +#define USB_BASE USB_FADDR +#define USB_OFFSET(reg) (reg - USB_BASE) + +/* + * Common USB registers + */ +#define MUSB_FADDR USB_OFFSET(USB_FADDR) /* 8-bit */ +#define MUSB_POWER USB_OFFSET(USB_POWER) /* 8-bit */ +#define MUSB_INTRTX USB_OFFSET(USB_INTRTX) /* 16-bit */ +#define MUSB_INTRRX USB_OFFSET(USB_INTRRX) +#define MUSB_INTRTXE USB_OFFSET(USB_INTRTXE) +#define MUSB_INTRRXE USB_OFFSET(USB_INTRRXE) +#define MUSB_INTRUSB USB_OFFSET(USB_INTRUSB) /* 8 bit */ +#define MUSB_INTRUSBE USB_OFFSET(USB_INTRUSBE)/* 8 bit */ +#define MUSB_FRAME USB_OFFSET(USB_FRAME) +#define MUSB_INDEX USB_OFFSET(USB_INDEX) /* 8 bit */ +#define MUSB_TESTMODE USB_OFFSET(USB_TESTMODE)/* 8 bit */ + +/* Get offset for a given FIFO from musb->mregs */ +#define MUSB_FIFO_OFFSET(epnum) \ + (USB_OFFSET(USB_EP0_FIFO) + ((epnum) * 8)) + +/* + * Additional Control Registers + */ + +#define MUSB_DEVCTL USB_OFFSET(USB_OTG_DEV_CTL) /* 8 bit */ + +#define MUSB_LINKINFO USB_OFFSET(USB_LINKINFO)/* 8 bit */ +#define MUSB_VPLEN USB_OFFSET(USB_VPLEN) /* 8 bit */ +#define MUSB_HS_EOF1 USB_OFFSET(USB_HS_EOF1) /* 8 bit */ +#define MUSB_FS_EOF1 USB_OFFSET(USB_FS_EOF1) /* 8 bit */ +#define MUSB_LS_EOF1 USB_OFFSET(USB_LS_EOF1) /* 8 bit */ + +/* Offsets to endpoint registers */ +#define MUSB_TXMAXP 0x00 +#define MUSB_TXCSR 0x04 +#define MUSB_CSR0 MUSB_TXCSR /* Re-used for EP0 */ +#define MUSB_RXMAXP 0x08 +#define MUSB_RXCSR 0x0C +#define MUSB_RXCOUNT 0x10 +#define MUSB_COUNT0 MUSB_RXCOUNT /* Re-used for EP0 */ +#define MUSB_TXTYPE 0x14 +#define MUSB_TYPE0 MUSB_TXTYPE /* Re-used for EP0 */ +#define MUSB_TXINTERVAL 0x18 +#define MUSB_NAKLIMIT0 MUSB_TXINTERVAL /* Re-used for EP0 */ +#define MUSB_RXTYPE 0x1C +#define MUSB_RXINTERVAL 0x20 +#define MUSB_TXCOUNT 0x28 + +/* Offsets to endpoint registers in indexed model (using INDEX register) */ +#define MUSB_INDEXED_OFFSET(_epnum, _offset) \ + (0x40 + (_offset)) + +/* Offsets to endpoint registers in flat models */ +#define MUSB_FLAT_OFFSET(_epnum, _offset) \ + (USB_OFFSET(USB_EP_NI0_TXMAXP) + (0x40 * (_epnum)) + (_offset)) + +/* Not implemented - HW has separate Tx/Rx FIFO */ +#define MUSB_TXCSR_MODE 0x0000 + +static inline void musb_write_txfifosz(void __iomem *mbase, u8 c_size) +{ +} + +static inline void musb_write_txfifoadd(void __iomem *mbase, u16 c_off) +{ +} + +static inline void musb_write_rxfifosz(void __iomem *mbase, u8 c_size) +{ +} + +static inline void musb_write_rxfifoadd(void __iomem *mbase, u16 c_off) +{ +} + +static inline void musb_write_ulpi_buscontrol(void __iomem *mbase, u8 val) +{ +} + +static inline u8 musb_read_txfifosz(void __iomem *mbase) +{ + return 0; +} + +static inline u16 musb_read_txfifoadd(void __iomem *mbase) +{ + return 0; +} + +static inline u8 musb_read_rxfifosz(void __iomem *mbase) +{ + return 0; +} + +static inline u16 musb_read_rxfifoadd(void __iomem *mbase) +{ + return 0; +} + +static inline u8 musb_read_ulpi_buscontrol(void __iomem *mbase) +{ + return 0; +} + +static inline u8 musb_read_configdata(void __iomem *mbase) +{ + return 0; +} + +static inline u16 musb_read_hwvers(void __iomem *mbase) +{ + /* + * This register is invisible on Blackfin, actually the MUSB + * RTL version of Blackfin is 1.9, so just harcode its value. + */ + return MUSB_HWVERS_1900; +} + +static inline void __iomem *musb_read_target_reg_base(u8 i, void __iomem *mbase) +{ + return NULL; +} + +static inline void musb_write_rxfunaddr(void __iomem *ep_target_regs, + u8 qh_addr_req) +{ +} + +static inline void musb_write_rxhubaddr(void __iomem *ep_target_regs, + u8 qh_h_addr_reg) +{ +} + +static inline void musb_write_rxhubport(void __iomem *ep_target_regs, + u8 qh_h_port_reg) +{ +} + +static inline void musb_write_txfunaddr(void __iomem *mbase, u8 epnum, + u8 qh_addr_reg) +{ +} + +static inline void musb_write_txhubaddr(void __iomem *mbase, u8 epnum, + u8 qh_addr_reg) +{ +} + +static inline void musb_write_txhubport(void __iomem *mbase, u8 epnum, + u8 qh_h_port_reg) +{ +} + +static inline u8 musb_read_rxfunaddr(void __iomem *mbase, u8 epnum) +{ + return 0; +} + +static inline u8 musb_read_rxhubaddr(void __iomem *mbase, u8 epnum) +{ + return 0; +} + +static inline u8 musb_read_rxhubport(void __iomem *mbase, u8 epnum) +{ + return 0; +} + +static inline u8 musb_read_txfunaddr(void __iomem *mbase, u8 epnum) +{ + return 0; +} + +static inline u8 musb_read_txhubaddr(void __iomem *mbase, u8 epnum) +{ + return 0; +} + +static inline u8 musb_read_txhubport(void __iomem *mbase, u8 epnum) +{ + return 0; +} + +#endif /* CONFIG_BLACKFIN */ + +#endif /* __MUSB_REGS_H__ */ diff --git a/include/linux/usb/musb.h b/include/linux/usb/musb.h new file mode 100644 index 0000000..9f65ef9 --- /dev/null +++ b/include/linux/usb/musb.h @@ -0,0 +1,162 @@ +/* + * This is used to for host and peripheral modes of the driver for + * Inventra (Multidrop) Highspeed Dual-Role Controllers: (M)HDRC. + * + * Board initialization should put one of these into dev->platform_data, + * probably on some platform_device named "musb-hdrc". It encapsulates + * key configuration differences between boards. + */ + +#ifndef __LINUX_USB_MUSB_H +#define __LINUX_USB_MUSB_H + +#ifndef __deprecated +#define __deprecated +#endif + +/* The USB role is defined by the connector used on the board, so long as + * standards are being followed. (Developer boards sometimes won't.) + */ +enum musb_mode { + MUSB_UNDEFINED = 0, + MUSB_HOST, /* A or Mini-A connector */ + MUSB_PERIPHERAL, /* B or Mini-B connector */ + MUSB_OTG /* Mini-AB connector */ +}; + +struct clk; + +enum musb_fifo_style { + FIFO_RXTX, + FIFO_TX, + FIFO_RX +} __attribute__ ((packed)); + +enum musb_buf_mode { + BUF_SINGLE, + BUF_DOUBLE +} __attribute__ ((packed)); + +struct musb_fifo_cfg { + u8 hw_ep_num; + enum musb_fifo_style style; + enum musb_buf_mode mode; + u16 maxpacket; +}; + +#define MUSB_EP_FIFO(ep, st, m, pkt) \ +{ \ + .hw_ep_num = ep, \ + .style = st, \ + .mode = m, \ + .maxpacket = pkt, \ +} + +#define MUSB_EP_FIFO_SINGLE(ep, st, pkt) \ + MUSB_EP_FIFO(ep, st, BUF_SINGLE, pkt) + +#define MUSB_EP_FIFO_DOUBLE(ep, st, pkt) \ + MUSB_EP_FIFO(ep, st, BUF_DOUBLE, pkt) + +struct musb_hdrc_eps_bits { + const char name[16]; + u8 bits; +}; + +struct musb_hdrc_config { + struct musb_fifo_cfg *fifo_cfg; /* board fifo configuration */ + unsigned fifo_cfg_size; /* size of the fifo configuration */ + + /* MUSB configuration-specific details */ + unsigned multipoint:1; /* multipoint device */ + unsigned dyn_fifo:1 __deprecated; /* supports dynamic fifo sizing */ + unsigned soft_con:1 __deprecated; /* soft connect required */ + unsigned utm_16:1 __deprecated; /* utm data witdh is 16 bits */ + unsigned big_endian:1; /* true if CPU uses big-endian */ + unsigned mult_bulk_tx:1; /* Tx ep required for multbulk pkts */ + unsigned mult_bulk_rx:1; /* Rx ep required for multbulk pkts */ + unsigned high_iso_tx:1; /* Tx ep required for HB iso */ + unsigned high_iso_rx:1; /* Rx ep required for HD iso */ + unsigned dma:1 __deprecated; /* supports DMA */ + unsigned vendor_req:1 __deprecated; /* vendor registers required */ + + u8 num_eps; /* number of endpoints _with_ ep0 */ + u8 dma_channels __deprecated; /* number of dma channels */ + u8 dyn_fifo_size; /* dynamic size in bytes */ + u8 vendor_ctrl __deprecated; /* vendor control reg width */ + u8 vendor_stat __deprecated; /* vendor status reg witdh */ + u8 dma_req_chan __deprecated; /* bitmask for required dma channels */ + u8 ram_bits; /* ram address size */ + + struct musb_hdrc_eps_bits *eps_bits __deprecated; +#ifdef CONFIG_BLACKFIN + /* A GPIO controlling VRSEL in Blackfin */ + unsigned int gpio_vrsel; + unsigned int gpio_vrsel_active; + /* musb CLKIN in Blackfin in MHZ */ + unsigned char clkin; +#endif + +}; + +struct musb_hdrc_platform_data { + /* MUSB_HOST, MUSB_PERIPHERAL, or MUSB_OTG */ + u8 mode; + + /* for clk_get() */ + const char *clock; + + /* (HOST or OTG) switch VBUS on/off */ + int (*set_vbus)(struct device *dev, int is_on); + + /* (HOST or OTG) mA/2 power supplied on (default = 8mA) */ + u8 power; + + /* (PERIPHERAL) mA/2 max power consumed (default = 100mA) */ + u8 min_power; + + /* (HOST or OTG) msec/2 after VBUS on till power good */ + u8 potpgt; + + /* (HOST or OTG) program PHY for external Vbus */ + unsigned extvbus:1; + + /* Power the device on or off */ + int (*set_power)(int state); + + /* MUSB configuration-specific details */ + struct musb_hdrc_config *config; + + /* Architecture specific board data */ + void *board_data; + + /* Platform specific struct musb_ops pointer */ + const void *platform_ops; +}; + + +/* TUSB 6010 support */ + +#define TUSB6010_OSCCLK_60 16667 /* psec/clk @ 60.0 MHz */ +#define TUSB6010_REFCLK_24 41667 /* psec/clk @ 24.0 MHz XI */ +#define TUSB6010_REFCLK_19 52083 /* psec/clk @ 19.2 MHz CLKIN */ + +#ifdef CONFIG_ARCH_OMAP2 + +extern int __init tusb6010_setup_interface( + struct musb_hdrc_platform_data *data, + unsigned ps_refclk, unsigned waitpin, + unsigned async_cs, unsigned sync_cs, + unsigned irq, unsigned dmachan); + +extern int tusb6010_platform_retime(unsigned is_refclk); + +#endif /* OMAP2 */ + +/* + * U-Boot specfic stuff + */ +int musb_register(struct musb_hdrc_platform_data *plat, void *bdata, + void *ctl_regs); + +#endif /* __LINUX_USB_MUSB_H */
Backend driver for MUSB OTG controllers found on TI AM33xx and TI81xx SoCs (tested with AM33xx only).
Signed-off-by: Ilya Yanok ilya.yanok@cogentembedded.com --- arch/arm/include/asm/omap_musb.h | 25 ++ drivers/usb/musb-new/Makefile | 1 + drivers/usb/musb-new/musb_dsps.c | 769 ++++++++++++++++++++++++++++++++++++++ 3 files changed, 795 insertions(+) create mode 100644 arch/arm/include/asm/omap_musb.h create mode 100644 drivers/usb/musb-new/musb_dsps.c
diff --git a/arch/arm/include/asm/omap_musb.h b/arch/arm/include/asm/omap_musb.h new file mode 100644 index 0000000..0081a68 --- /dev/null +++ b/arch/arm/include/asm/omap_musb.h @@ -0,0 +1,25 @@ +/* + * Board data structure for musb gadget on OMAPs + * + * Copyright (C) 2012, Ilya Yanok ilya.yanok@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR /PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef __ASM_ARM_OMAP_MUSB_H +#define __ASM_ARM_OMAP_MUSB_H + +extern struct musb_platform_ops musb_dsps_ops; + +struct omap_musb_board_data { + void (*set_phy_power)(u8 on); +}; +#endif /* __ASM_ARM_OMAP_MUSB_H */ diff --git a/drivers/usb/musb-new/Makefile b/drivers/usb/musb-new/Makefile index a518dcd..e0c9263 100644 --- a/drivers/usb/musb-new/Makefile +++ b/drivers/usb/musb-new/Makefile @@ -8,6 +8,7 @@ LIB := $(obj)libusb_musb-new.o
COBJS-$(CONFIG_MUSB_GADGET) += musb_gadget.o musb_gadget_ep0.o musb_core.o COBJS-$(CONFIG_MUSB_GADGET) += musb_gadget_uboot.o +COBJS-$(CONFIG_USB_AM335X) += musb_dsps.o
CFLAGS_NO_WARN := $(call cc-option,-Wno-unused-variable) \ $(call cc-option,-Wno-unused-but-set-variable) \ diff --git a/drivers/usb/musb-new/musb_dsps.c b/drivers/usb/musb-new/musb_dsps.c new file mode 100644 index 0000000..fbd66f8 --- /dev/null +++ b/drivers/usb/musb-new/musb_dsps.c @@ -0,0 +1,769 @@ +/* + * Texas Instruments DSPS platforms "glue layer" + * + * Copyright (C) 2012, by Texas Instruments + * + * Based on the am35x "glue layer" code. + * + * This file is part of the Inventra Controller Driver for Linux. + * + * The Inventra Controller Driver for Linux is free software; you + * can redistribute it and/or modify it under the terms of the GNU + * General Public License version 2 as published by the Free Software + * Foundation. + * + * The Inventra Controller Driver for Linux is distributed in + * the hope that it will be useful, but WITHOUT ANY WARRANTY; + * without even the implied warranty of MERCHANTABILITY or + * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public + * License for more details. + * + * You should have received a copy of the GNU General Public License + * along with The Inventra Controller Driver for Linux ; if not, + * write to the Free Software Foundation, Inc., 59 Temple Place, + * Suite 330, Boston, MA 02111-1307 USA + * + * musb_dsps.c will be a common file for all the TI DSPS platforms + * such as dm64x, dm36x, dm35x, da8x, am35x and ti81x. + * For now only ti81x is using this and in future davinci.c, am35x.c + * da8xx.c would be merged to this file after testing. + */ + +#define __UBOOT__ +#ifndef __UBOOT__ +#include <linux/init.h> +#include <linux/io.h> +#include <linux/platform_device.h> +#include <linux/dma-mapping.h> +#include <linux/pm_runtime.h> +#include <linux/module.h> + +#include <linux/of.h> +#include <linux/of_device.h> +#include <linux/of_address.h> + +#include <plat/usb.h> +#else +#include <common.h> +#include <asm/omap_musb.h> +#include "linux-compat.h" +#endif + +#include "musb_core.h" + +/** + * avoid using musb_readx()/musb_writex() as glue layer should not be + * dependent on musb core layer symbols. + */ +static inline u8 dsps_readb(const void __iomem *addr, unsigned offset) + { return __raw_readb(addr + offset); } + +static inline u32 dsps_readl(const void __iomem *addr, unsigned offset) + { return __raw_readl(addr + offset); } + +static inline void dsps_writeb(void __iomem *addr, unsigned offset, u8 data) + { __raw_writeb(data, addr + offset); } + +static inline void dsps_writel(void __iomem *addr, unsigned offset, u32 data) + { __raw_writel(data, addr + offset); } + +/** + * DSPS musb wrapper register offset. + * FIXME: This should be expanded to have all the wrapper registers from TI DSPS + * musb ips. + */ +struct dsps_musb_wrapper { + u16 revision; + u16 control; + u16 status; + u16 eoi; + u16 epintr_set; + u16 epintr_clear; + u16 epintr_status; + u16 coreintr_set; + u16 coreintr_clear; + u16 coreintr_status; + u16 phy_utmi; + u16 mode; + + /* bit positions for control */ + unsigned reset:5; + + /* bit positions for interrupt */ + unsigned usb_shift:5; + u32 usb_mask; + u32 usb_bitmap; + unsigned drvvbus:5; + + unsigned txep_shift:5; + u32 txep_mask; + u32 txep_bitmap; + + unsigned rxep_shift:5; + u32 rxep_mask; + u32 rxep_bitmap; + + /* bit positions for phy_utmi */ + unsigned otg_disable:5; + + /* bit positions for mode */ + unsigned iddig:5; + /* miscellaneous stuff */ + u32 musb_core_offset; + u8 poll_seconds; +}; + +static const struct dsps_musb_wrapper ti81xx_driver_data __devinitconst = { + .revision = 0x00, + .control = 0x14, + .status = 0x18, + .eoi = 0x24, + .epintr_set = 0x38, + .epintr_clear = 0x40, + .epintr_status = 0x30, + .coreintr_set = 0x3c, + .coreintr_clear = 0x44, + .coreintr_status = 0x34, + .phy_utmi = 0xe0, + .mode = 0xe8, + .reset = 0, + .otg_disable = 21, + .iddig = 8, + .usb_shift = 0, + .usb_mask = 0x1ff, + .usb_bitmap = (0x1ff << 0), + .drvvbus = 8, + .txep_shift = 0, + .txep_mask = 0xffff, + .txep_bitmap = (0xffff << 0), + .rxep_shift = 16, + .rxep_mask = 0xfffe, + .rxep_bitmap = (0xfffe << 16), + .musb_core_offset = 0x400, + .poll_seconds = 2, +}; + +/** + * DSPS glue structure. + */ +struct dsps_glue { + struct device *dev; + struct platform_device *musb; /* child musb pdev */ + const struct dsps_musb_wrapper *wrp; /* wrapper register offsets */ + struct timer_list timer; /* otg_workaround timer */ +}; + +/** + * dsps_musb_enable - enable interrupts + */ +static void dsps_musb_enable(struct musb *musb) +{ +#ifndef __UBOOT__ + struct device *dev = musb->controller; + struct platform_device *pdev = to_platform_device(dev->parent); + struct dsps_glue *glue = platform_get_drvdata(pdev); + const struct dsps_musb_wrapper *wrp = glue->wrp; +#else + const struct dsps_musb_wrapper *wrp = &ti81xx_driver_data; +#endif + void __iomem *reg_base = musb->ctrl_base; + u32 epmask, coremask; + + /* Workaround: setup IRQs through both register sets. */ + epmask = ((musb->epmask & wrp->txep_mask) << wrp->txep_shift) | + ((musb->epmask & wrp->rxep_mask) << wrp->rxep_shift); + coremask = (wrp->usb_bitmap & ~MUSB_INTR_SOF); + + dsps_writel(reg_base, wrp->epintr_set, epmask); + dsps_writel(reg_base, wrp->coreintr_set, coremask); + /* Force the DRVVBUS IRQ so we can start polling for ID change. */ +#ifndef __UBOOT__ + if (is_otg_enabled(musb)) + dsps_writel(reg_base, wrp->coreintr_set, + (1 << wrp->drvvbus) << wrp->usb_shift); +#endif +} + +/** + * dsps_musb_disable - disable HDRC and flush interrupts + */ +static void dsps_musb_disable(struct musb *musb) +{ +#ifndef __UBOOT__ + struct device *dev = musb->controller; + struct platform_device *pdev = to_platform_device(dev->parent); + struct dsps_glue *glue = platform_get_drvdata(pdev); + const struct dsps_musb_wrapper *wrp = glue->wrp; + void __iomem *reg_base = musb->ctrl_base; + + dsps_writel(reg_base, wrp->coreintr_clear, wrp->usb_bitmap); + dsps_writel(reg_base, wrp->epintr_clear, + wrp->txep_bitmap | wrp->rxep_bitmap); + dsps_writeb(musb->mregs, MUSB_DEVCTL, 0); + dsps_writel(reg_base, wrp->eoi, 0); +#endif +} + +#ifndef __UBOOT__ +static void otg_timer(unsigned long _musb) +{ + struct musb *musb = (void *)_musb; + void __iomem *mregs = musb->mregs; + struct device *dev = musb->controller; + struct platform_device *pdev = to_platform_device(dev->parent); + struct dsps_glue *glue = platform_get_drvdata(pdev); + const struct dsps_musb_wrapper *wrp = glue->wrp; + u8 devctl; + unsigned long flags; + + /* + * We poll because DSPS IP's won't expose several OTG-critical + * status change events (from the transceiver) otherwise. + */ + devctl = dsps_readb(mregs, MUSB_DEVCTL); + dev_dbg(musb->controller, "Poll devctl %02x (%s)\n", devctl, + otg_state_string(musb->xceiv->state)); + + spin_lock_irqsave(&musb->lock, flags); + switch (musb->xceiv->state) { + case OTG_STATE_A_WAIT_BCON: + devctl &= ~MUSB_DEVCTL_SESSION; + dsps_writeb(musb->mregs, MUSB_DEVCTL, devctl); + + devctl = dsps_readb(musb->mregs, MUSB_DEVCTL); + if (devctl & MUSB_DEVCTL_BDEVICE) { + musb->xceiv->state = OTG_STATE_B_IDLE; + MUSB_DEV_MODE(musb); + } else { + musb->xceiv->state = OTG_STATE_A_IDLE; + MUSB_HST_MODE(musb); + } + break; + case OTG_STATE_A_WAIT_VFALL: + musb->xceiv->state = OTG_STATE_A_WAIT_VRISE; + dsps_writel(musb->ctrl_base, wrp->coreintr_set, + MUSB_INTR_VBUSERROR << wrp->usb_shift); + break; + case OTG_STATE_B_IDLE: + if (!is_peripheral_enabled(musb)) + break; + + devctl = dsps_readb(mregs, MUSB_DEVCTL); + if (devctl & MUSB_DEVCTL_BDEVICE) + mod_timer(&glue->timer, + jiffies + wrp->poll_seconds * HZ); + else + musb->xceiv->state = OTG_STATE_A_IDLE; + break; + default: + break; + } + spin_unlock_irqrestore(&musb->lock, flags); +} + +static void dsps_musb_try_idle(struct musb *musb, unsigned long timeout) +{ + struct device *dev = musb->controller; + struct platform_device *pdev = to_platform_device(dev->parent); + struct dsps_glue *glue = platform_get_drvdata(pdev); + static unsigned long last_timer; + + if (!is_otg_enabled(musb)) + return; + + if (timeout == 0) + timeout = jiffies + msecs_to_jiffies(3); + + /* Never idle if active, or when VBUS timeout is not set as host */ + if (musb->is_active || (musb->a_wait_bcon == 0 && + musb->xceiv->state == OTG_STATE_A_WAIT_BCON)) { + dev_dbg(musb->controller, "%s active, deleting timer\n", + otg_state_string(musb->xceiv->state)); + del_timer(&glue->timer); + last_timer = jiffies; + return; + } + + if (time_after(last_timer, timeout) && timer_pending(&glue->timer)) { + dev_dbg(musb->controller, + "Longer idle timer already pending, ignoring...\n"); + return; + } + last_timer = timeout; + + dev_dbg(musb->controller, "%s inactive, starting idle timer for %u ms\n", + otg_state_string(musb->xceiv->state), + jiffies_to_msecs(timeout - jiffies)); + mod_timer(&glue->timer, timeout); +} +#endif + +static irqreturn_t dsps_interrupt(int irq, void *hci) +{ + struct musb *musb = hci; + void __iomem *reg_base = musb->ctrl_base; +#ifndef __UBOOT__ + struct device *dev = musb->controller; + struct platform_device *pdev = to_platform_device(dev->parent); + struct dsps_glue *glue = platform_get_drvdata(pdev); + const struct dsps_musb_wrapper *wrp = glue->wrp; +#else + const struct dsps_musb_wrapper *wrp = &ti81xx_driver_data; +#endif + unsigned long flags; + irqreturn_t ret = IRQ_NONE; + u32 epintr, usbintr; + + spin_lock_irqsave(&musb->lock, flags); + + /* Get endpoint interrupts */ + epintr = dsps_readl(reg_base, wrp->epintr_status); + musb->int_rx = (epintr & wrp->rxep_bitmap) >> wrp->rxep_shift; + musb->int_tx = (epintr & wrp->txep_bitmap) >> wrp->txep_shift; + + if (epintr) + dsps_writel(reg_base, wrp->epintr_status, epintr); + + /* Get usb core interrupts */ + usbintr = dsps_readl(reg_base, wrp->coreintr_status); + if (!usbintr && !epintr) + goto eoi; + + musb->int_usb = (usbintr & wrp->usb_bitmap) >> wrp->usb_shift; + if (usbintr) + dsps_writel(reg_base, wrp->coreintr_status, usbintr); + + dev_dbg(musb->controller, "usbintr (%x) epintr(%x)\n", + usbintr, epintr); +#ifndef __UBOOT__ + /* + * DRVVBUS IRQs are the only proxy we have (a very poor one!) for + * DSPS IP's missing ID change IRQ. We need an ID change IRQ to + * switch appropriately between halves of the OTG state machine. + * Managing DEVCTL.SESSION per Mentor docs requires that we know its + * value but DEVCTL.BDEVICE is invalid without DEVCTL.SESSION set. + * Also, DRVVBUS pulses for SRP (but not at 5V) ... + */ + if ((usbintr & MUSB_INTR_BABBLE) && is_host_enabled(musb)) + pr_info("CAUTION: musb: Babble Interrupt Occured\n"); + + if (usbintr & ((1 << wrp->drvvbus) << wrp->usb_shift)) { + int drvvbus = dsps_readl(reg_base, wrp->status); + void __iomem *mregs = musb->mregs; + u8 devctl = dsps_readb(mregs, MUSB_DEVCTL); + int err; + + err = is_host_enabled(musb) && (musb->int_usb & + MUSB_INTR_VBUSERROR); + if (err) { + /* + * The Mentor core doesn't debounce VBUS as needed + * to cope with device connect current spikes. This + * means it's not uncommon for bus-powered devices + * to get VBUS errors during enumeration. + * + * This is a workaround, but newer RTL from Mentor + * seems to allow a better one: "re"-starting sessions + * without waiting for VBUS to stop registering in + * devctl. + */ + musb->int_usb &= ~MUSB_INTR_VBUSERROR; + musb->xceiv->state = OTG_STATE_A_WAIT_VFALL; + mod_timer(&glue->timer, + jiffies + wrp->poll_seconds * HZ); + WARNING("VBUS error workaround (delay coming)\n"); + } else if (is_host_enabled(musb) && drvvbus) { + musb->is_active = 1; + MUSB_HST_MODE(musb); + musb->xceiv->otg->default_a = 1; + musb->xceiv->state = OTG_STATE_A_WAIT_VRISE; + del_timer(&glue->timer); + } else { + musb->is_active = 0; + MUSB_DEV_MODE(musb); + musb->xceiv->otg->default_a = 0; + musb->xceiv->state = OTG_STATE_B_IDLE; + } + + /* NOTE: this must complete power-on within 100 ms. */ + dev_dbg(musb->controller, "VBUS %s (%s)%s, devctl %02x\n", + drvvbus ? "on" : "off", + otg_state_string(musb->xceiv->state), + err ? " ERROR" : "", + devctl); + ret = IRQ_HANDLED; + } +#endif + + if (musb->int_tx || musb->int_rx || musb->int_usb) + ret |= musb_interrupt(musb); + + eoi: + /* EOI needs to be written for the IRQ to be re-asserted. */ + if (ret == IRQ_HANDLED || epintr || usbintr) + dsps_writel(reg_base, wrp->eoi, 1); + +#ifndef __UBOOT__ + /* Poll for ID change */ + if (is_otg_enabled(musb) && musb->xceiv->state == OTG_STATE_B_IDLE) + mod_timer(&glue->timer, jiffies + wrp->poll_seconds * HZ); +#endif + + spin_unlock_irqrestore(&musb->lock, flags); + + return ret; +} + +static int dsps_musb_init(struct musb *musb) +{ +#ifndef __UBOOT__ + struct device *dev = musb->controller; + struct musb_hdrc_platform_data *plat = dev->platform_data; + struct platform_device *pdev = to_platform_device(dev->parent); + struct dsps_glue *glue = platform_get_drvdata(pdev); + const struct dsps_musb_wrapper *wrp = glue->wrp; + struct omap_musb_board_data *data = plat->board_data; +#else + struct omap_musb_board_data *data = + (struct omap_musb_board_data *)musb->controller; + const struct dsps_musb_wrapper *wrp = &ti81xx_driver_data; +#endif + void __iomem *reg_base = musb->ctrl_base; + u32 rev, val; + int status; + + /* mentor core register starts at offset of 0x400 from musb base */ + musb->mregs += wrp->musb_core_offset; + +#ifndef __UBOOT__ + /* NOP driver needs change if supporting dual instance */ + usb_nop_xceiv_register(); + musb->xceiv = usb_get_transceiver(); + if (!musb->xceiv) + return -ENODEV; +#endif + + /* Returns zero if e.g. not clocked */ + rev = dsps_readl(reg_base, wrp->revision); + if (!rev) { + status = -ENODEV; + goto err0; + } + +#ifndef __UBOOT__ + if (is_host_enabled(musb)) + setup_timer(&glue->timer, otg_timer, (unsigned long) musb); +#endif + + /* Reset the musb */ + dsps_writel(reg_base, wrp->control, (1 << wrp->reset)); + + /* Start the on-chip PHY and its PLL. */ + if (data->set_phy_power) + data->set_phy_power(1); + + musb->isr = dsps_interrupt; + + /* reset the otgdisable bit, needed for host mode to work */ + val = dsps_readl(reg_base, wrp->phy_utmi); + val &= ~(1 << wrp->otg_disable); + dsps_writel(musb->ctrl_base, wrp->phy_utmi, val); + + /* clear level interrupt */ + dsps_writel(reg_base, wrp->eoi, 0); + + return 0; +err0: +#ifndef __UBOOT__ + usb_put_transceiver(musb->xceiv); + usb_nop_xceiv_unregister(); +#endif + return status; +} + +static int dsps_musb_exit(struct musb *musb) +{ +#ifndef __UBOOT__ + struct device *dev = musb->controller; + struct musb_hdrc_platform_data *plat = dev->platform_data; + struct omap_musb_board_data *data = plat->board_data; + struct platform_device *pdev = to_platform_device(dev->parent); + struct dsps_glue *glue = platform_get_drvdata(pdev); +#else + struct omap_musb_board_data *data = + (struct omap_musb_board_data *)musb->controller; +#endif + +#ifndef __UBOOT__ + if (is_host_enabled(musb)) + del_timer_sync(&glue->timer); +#endif + + /* Shutdown the on-chip PHY and its PLL. */ + if (data->set_phy_power) + data->set_phy_power(0); + +#ifndef __UBOOT__ + /* NOP driver needs change if supporting dual instance */ + usb_put_transceiver(musb->xceiv); + usb_nop_xceiv_unregister(); +#endif + + return 0; +} + +#ifndef __UBOOT__ +static struct musb_platform_ops dsps_ops = { +#else +struct musb_platform_ops musb_dsps_ops = { +#endif + .init = dsps_musb_init, + .exit = dsps_musb_exit, + + .enable = dsps_musb_enable, + .disable = dsps_musb_disable, + +#ifndef __UBOOT__ + .try_idle = dsps_musb_try_idle, +#endif +}; + +#ifndef __UBOOT__ +static u64 musb_dmamask = DMA_BIT_MASK(32); +#endif + +#ifndef __UBOOT__ +static int __devinit dsps_create_musb_pdev(struct dsps_glue *glue, u8 id) +{ + struct device *dev = glue->dev; + struct platform_device *pdev = to_platform_device(dev); + struct musb_hdrc_platform_data *pdata = dev->platform_data; + struct platform_device *musb; + struct resource *res; + struct resource resources[2]; + char res_name[10]; + int ret; + + /* get memory resource */ + sprintf(res_name, "musb%d", id); + res = platform_get_resource_byname(pdev, IORESOURCE_MEM, res_name); + if (!res) { + dev_err(dev, "%s get mem resource failed\n", res_name); + ret = -ENODEV; + goto err0; + } + res->parent = NULL; + resources[0] = *res; + + /* get irq resource */ + sprintf(res_name, "musb%d-irq", id); + res = platform_get_resource_byname(pdev, IORESOURCE_IRQ, res_name); + if (!res) { + dev_err(dev, "%s get irq resource failed\n", res_name); + ret = -ENODEV; + goto err0; + } + strcpy((u8 *)res->name, "mc"); + res->parent = NULL; + resources[1] = *res; + + /* allocate the child platform device */ + musb = platform_device_alloc("musb-hdrc", -1); + if (!musb) { + dev_err(dev, "failed to allocate musb device\n"); + ret = -ENOMEM; + goto err0; + } + + musb->dev.parent = dev; + musb->dev.dma_mask = &musb_dmamask; + musb->dev.coherent_dma_mask = musb_dmamask; + + glue->musb = musb; + + pdata->platform_ops = &dsps_ops; + + ret = platform_device_add_resources(musb, resources, 2); + if (ret) { + dev_err(dev, "failed to add resources\n"); + goto err1; + } + + ret = platform_device_add_data(musb, pdata, sizeof(*pdata)); + if (ret) { + dev_err(dev, "failed to add platform_data\n"); + goto err1; + } + + ret = platform_device_add(musb); + if (ret) { + dev_err(dev, "failed to register musb device\n"); + goto err1; + } + + return 0; + +err1: + platform_device_put(musb); +err0: + return ret; +} + +static void __devexit dsps_delete_musb_pdev(struct dsps_glue *glue) +{ + platform_device_del(glue->musb); + platform_device_put(glue->musb); +} + +static int __devinit dsps_probe(struct platform_device *pdev) +{ + const struct platform_device_id *id = platform_get_device_id(pdev); + const struct dsps_musb_wrapper *wrp = + (struct dsps_musb_wrapper *)id->driver_data; + struct dsps_glue *glue; + struct resource *iomem; + int ret; + + /* allocate glue */ + glue = kzalloc(sizeof(*glue), GFP_KERNEL); + if (!glue) { + dev_err(&pdev->dev, "unable to allocate glue memory\n"); + ret = -ENOMEM; + goto err0; + } + + /* get memory resource */ + iomem = platform_get_resource(pdev, IORESOURCE_MEM, 0); + if (!iomem) { + dev_err(&pdev->dev, "failed to get usbss mem resourse\n"); + ret = -ENODEV; + goto err1; + } + + glue->dev = &pdev->dev; + + glue->wrp = kmemdup(wrp, sizeof(*wrp), GFP_KERNEL); + if (!glue->wrp) { + dev_err(&pdev->dev, "failed to duplicate wrapper struct memory\n"); + ret = -ENOMEM; + goto err1; + } + platform_set_drvdata(pdev, glue); + + /* create the child platform device for first instances of musb */ + ret = dsps_create_musb_pdev(glue, 0); + if (ret != 0) { + dev_err(&pdev->dev, "failed to create child pdev\n"); + goto err2; + } + + /* enable the usbss clocks */ + pm_runtime_enable(&pdev->dev); + + ret = pm_runtime_get_sync(&pdev->dev); + if (ret < 0) { + dev_err(&pdev->dev, "pm_runtime_get_sync FAILED"); + goto err3; + } + + return 0; + +err3: + pm_runtime_disable(&pdev->dev); +err2: + kfree(glue->wrp); +err1: + kfree(glue); +err0: + return ret; +} +static int __devexit dsps_remove(struct platform_device *pdev) +{ + struct dsps_glue *glue = platform_get_drvdata(pdev); + + /* delete the child platform device */ + dsps_delete_musb_pdev(glue); + + /* disable usbss clocks */ + pm_runtime_put(&pdev->dev); + pm_runtime_disable(&pdev->dev); + kfree(glue->wrp); + kfree(glue); + return 0; +} + +#ifdef CONFIG_PM_SLEEP +static int dsps_suspend(struct device *dev) +{ + struct musb_hdrc_platform_data *plat = dev->platform_data; + struct omap_musb_board_data *data = plat->board_data; + + /* Shutdown the on-chip PHY and its PLL. */ + if (data->set_phy_power) + data->set_phy_power(0); + + return 0; +} + +static int dsps_resume(struct device *dev) +{ + struct musb_hdrc_platform_data *plat = dev->platform_data; + struct omap_musb_board_data *data = plat->board_data; + + /* Start the on-chip PHY and its PLL. */ + if (data->set_phy_power) + data->set_phy_power(1); + + return 0; +} +#endif + +static SIMPLE_DEV_PM_OPS(dsps_pm_ops, dsps_suspend, dsps_resume); +#endif + +#ifndef __UBOOT__ +static const struct platform_device_id musb_dsps_id_table[] __devinitconst = { + { + .name = "musb-ti81xx", + .driver_data = (kernel_ulong_t) &ti81xx_driver_data, + }, + { }, /* Terminating Entry */ +}; +MODULE_DEVICE_TABLE(platform, musb_dsps_id_table); + +static const struct of_device_id musb_dsps_of_match[] __devinitconst = { + { .compatible = "musb-ti81xx", }, + { .compatible = "ti,ti81xx-musb", }, + { .compatible = "ti,am335x-musb", }, + { }, +}; +MODULE_DEVICE_TABLE(of, musb_dsps_of_match); + +static struct platform_driver dsps_usbss_driver = { + .probe = dsps_probe, + .remove = __devexit_p(dsps_remove), + .driver = { + .name = "musb-dsps", + .pm = &dsps_pm_ops, + .of_match_table = musb_dsps_of_match, + }, + .id_table = musb_dsps_id_table, +}; + +MODULE_DESCRIPTION("TI DSPS MUSB Glue Layer"); +MODULE_AUTHOR("Ravi B ravibabu@ti.com"); +MODULE_AUTHOR("Ajay Kumar Gupta ajay.gupta@ti.com"); +MODULE_LICENSE("GPL v2"); + +static int __init dsps_init(void) +{ + return platform_driver_register(&dsps_usbss_driver); +} +subsys_initcall(dsps_init); + +static void __exit dsps_exit(void) +{ + platform_driver_unregister(&dsps_usbss_driver); +} +module_exit(dsps_exit); +#endif
AM33xx has support for dual port MUSB OTG controller. This patch adds initialization for the controller using new MUSB gadget driver and ether gadget.
Signed-off-by: Ilya Yanok ilya.yanok@cogentembedded.com --- arch/arm/cpu/armv7/am33xx/board.c | 81 ++++++++++++++++++++++++++- arch/arm/cpu/armv7/am33xx/clock.c | 8 +++ arch/arm/include/asm/arch-am33xx/cpu.h | 11 +++- arch/arm/include/asm/arch-am33xx/hardware.h | 4 ++ 4 files changed, 100 insertions(+), 4 deletions(-)
diff --git a/arch/arm/cpu/armv7/am33xx/board.c b/arch/arm/cpu/armv7/am33xx/board.c index 2ca4ca7..dafc264 100644 --- a/arch/arm/cpu/armv7/am33xx/board.c +++ b/arch/arm/cpu/armv7/am33xx/board.c @@ -33,6 +33,11 @@ #include <i2c.h> #include <miiphy.h> #include <cpsw.h> +#include <asm/errno.h> +#include <linux/usb/ch9.h> +#include <linux/usb/gadget.h> +#include <linux/usb/musb.h> +#include <asm/omap_musb.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -273,9 +278,65 @@ static struct cpsw_platform_data cpsw_data = { .host_port_num = 0, .version = CPSW_CTRL_VERSION_2, }; +#endif + +#ifdef CONFIG_MUSB_GADGET +#ifdef CONFIG_MUSB_GADGET_PORT0 +#define USB_CTRL_REG &cdev->usb_ctrl0 +#define OTG_REGS_BASE ((void *)AM335X_USB0_OTG_BASE) +#elif defined(CONFIG_MUSB_GADGET_PORT1) +#define USB_CTRL_REG &cdev->usb_ctrl1 +#define OTG_REGS_BASE ((void *)AM335X_USB1_OTG_BASE) +#else +#error "Please define CONFIG_MUSB_GADGET_PORT0 or CONFIG_MUSB_GADGET_PORT1" +#endif + +/* USB 2.0 PHY Control */ +#define CM_PHY_PWRDN (1 << 0) +#define CM_PHY_OTG_PWRDN (1 << 1) +#define OTGVDET_EN (1 << 19) +#define OTGSESSENDEN (1 << 20) + +static void am33xx_usb_set_phy_power(u8 on) +{ + u32 usb_ctrl_reg; + + usb_ctrl_reg = readl(USB_CTRL_REG); + if (on) { + usb_ctrl_reg &= ~(CM_PHY_PWRDN | CM_PHY_OTG_PWRDN); + usb_ctrl_reg |= (OTGVDET_EN | OTGSESSENDEN); + } else { + usb_ctrl_reg |= (CM_PHY_PWRDN | CM_PHY_OTG_PWRDN); + } + writel(usb_ctrl_reg, USB_CTRL_REG); +} + +static struct musb_hdrc_config musb_config = { + .multipoint = 1, + .dyn_fifo = 1, + .num_eps = 16, + .ram_bits = 12, +};
+struct omap_musb_board_data musb_board_data = { + .set_phy_power = am33xx_usb_set_phy_power, +}; + +static struct musb_hdrc_platform_data musb_plat = { + .mode = MUSB_PERIPHERAL, + .config = &musb_config, + .power = 50, + .platform_ops = &musb_dsps_ops, + .board_data = &musb_board_data, +}; +#endif + +#if defined(CONFIG_DRIVER_TI_CPSW) || \ + (defined(CONFIG_USB_ETHER) && defined(CONFIG_MUSB_GADGET)) int board_eth_init(bd_t *bis) { + int rv, n = 0; +#ifdef CONFIG_DRIVER_TI_CPSW uint8_t mac_addr[6]; uint32_t mac_hi, mac_lo;
@@ -307,6 +368,24 @@ int board_eth_init(bd_t *bis) PHY_INTERFACE_MODE_RGMII; }
- return cpsw_register(&cpsw_data); + rv = cpsw_register(&cpsw_data); + if (rv < 0) + printf("Error %d registering CPSW switch\n", rv); + else + n += rv; +#endif +#ifdef CONFIG_USB_ETHER + rv = musb_register(&musb_plat, &musb_board_data, OTG_REGS_BASE); + if (rv < 0) { + printf("Error %d registering MUSB device\n", rv); + } else { + rv = usb_eth_initialize(bis); + if (rv < 0) + printf("Error %d registering USB_ETHER\n", rv); + else + n += rv; + } +#endif + return n; } #endif diff --git a/arch/arm/cpu/armv7/am33xx/clock.c b/arch/arm/cpu/armv7/am33xx/clock.c index 1071f92..5ad84ce 100644 --- a/arch/arm/cpu/armv7/am33xx/clock.c +++ b/arch/arm/cpu/armv7/am33xx/clock.c @@ -40,6 +40,7 @@ #define CLK_MODE_MASK 0xfffffff8 #define CLK_DIV_SEL 0xFFFFFFE0 #define CPGMAC0_IDLE 0x30000 +#define DPLL_CLKDCOLDO_GATE_CTRL 0x300
const struct cm_perpll *cmper = (struct cm_perpll *)CM_PER; const struct cm_wkuppll *cmwkup = (struct cm_wkuppll *)CM_WKUP; @@ -148,6 +149,11 @@ static void enable_per_clocks(void) writel(PRCM_MOD_EN, &cmper->cpgmac0clkctrl); while ((readl(&cmper->cpgmac0clkctrl) & CPGMAC0_IDLE) != PRCM_FUNCTL) ; + + /* MUSB */ + writel(PRCM_MOD_EN, &cmper->usb0clkctrl); + while (readl(&cmper->usb0clkctrl) != PRCM_MOD_EN) + ; }
static void mpu_pll_config(void) @@ -244,6 +250,8 @@ static void per_pll_config(void)
while (readl(&cmwkup->idlestdpllper) != ST_DPLL_CLK) ; + + writel(DPLL_CLKDCOLDO_GATE_CTRL, &cmwkup->clkdcoldodpllper); }
void ddr_pll_config(unsigned int ddrpll_m) diff --git a/arch/arm/include/asm/arch-am33xx/cpu.h b/arch/arm/include/asm/arch-am33xx/cpu.h index de9ee91..a98ffa2 100644 --- a/arch/arm/include/asm/arch-am33xx/cpu.h +++ b/arch/arm/include/asm/arch-am33xx/cpu.h @@ -82,7 +82,8 @@ struct cm_wkuppll { unsigned int clkseldpllcore; /* offset 0x68 */ unsigned int resv9[1]; unsigned int idlestdpllper; /* offset 0x70 */ - unsigned int resv10[3]; + unsigned int resv10[2]; + unsigned int clkdcoldodpllper; /* offset 0x7c */ unsigned int divm4dpllcore; /* offset 0x80 */ unsigned int divm5dpllcore; /* offset 0x84 */ unsigned int clkmoddpllmpu; /* offset 0x88 */ @@ -258,12 +259,16 @@ struct ctrl_stat { /* Control Device Register */ struct ctrl_dev { unsigned int deviceid; /* offset 0x00 */ - unsigned int resv1[11]; + unsigned int resv1[7]; + unsigned int usb_ctrl0; /* offset 0x20 */ + unsigned int resv2; + unsigned int usb_ctrl1; /* offset 0x28 */ + unsigned int resv3; unsigned int macid0l; /* offset 0x30 */ unsigned int macid0h; /* offset 0x34 */ unsigned int macid1l; /* offset 0x38 */ unsigned int macid1h; /* offset 0x3c */ - unsigned int resv2[4]; + unsigned int resv4[4]; unsigned int miisel; /* offset 0x50 */ }; #endif /* __ASSEMBLY__ */ diff --git a/arch/arm/include/asm/arch-am33xx/hardware.h b/arch/arm/include/asm/arch-am33xx/hardware.h index c617331..f98f497 100644 --- a/arch/arm/include/asm/arch-am33xx/hardware.h +++ b/arch/arm/include/asm/arch-am33xx/hardware.h @@ -82,4 +82,8 @@ #define AM335X_CPSW_BASE 0x4A100000 #define AM335X_CPSW_MDIO_BASE 0x4A101000
+/* OTG */ +#define AM335X_USB0_OTG_BASE 0x47401000 +#define AM335X_USB1_OTG_BASE 0x47401800 + #endif /* __AM33XX_HARDWARE_H */
Enable musb gadget in Ethernet mode on port 0.
Signed-off-by: Ilya Yanok ilya.yanok@cogentembedded.com --- include/configs/am335x_evm.h | 19 +++++++++++++++++++ 1 file changed, 19 insertions(+)
diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index c827ebf..e0f0656 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -224,6 +224,25 @@ #define CONFIG_SKIP_LOWLEVEL_INIT #endif
+ +/* + * USB configuration + */ + +#define CONFIG_USB_AM335X +#define CONFIG_MUSB_GADGET +#define CONFIG_MUSB_GADGET_PORT0 +#define CONFIG_MUSB_PIO_ONLY +#define CONFIG_USB_GADGET_DUALSPEED + +#ifdef CONFIG_MUSB_GADGET +#define CONFIG_USB_ETHER +#define CONFIG_USB_ETH_RNDIS +#define CONFIG_CMD_NET +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_TFTP +#endif /* CONFIG_MUSB_GADGET */ + /* Unsupported features */ #undef CONFIG_USE_IRQ
Dear Ilya Yanok,
Current MUSB driver in U-Boot uses old UDC API while new gagdet client drivers need new gadget API. Also current MUSB driver has some significant limitations (like inability to handle tx for endpoints other than ep0). So I think port of new Linux driver is desirable.
This is initial port, performed mostly by putting DM, host and OTG code under #ifndef __UBOOT__ clauses. My intention was to be as close as possible to the original to ease of possible resyncs. Some warnings are suppressed via CFLAGS. There are some style problems but I'm not touching them for now for the above mentioned reason. There is obviously some room for optimisation, some structure fields are unused as well as (probably) some code.
This is not a replacement for existing MUSB driver (at least for now), cause host mode is not supported and there are still consumers of the old interface.
Host mode, OTG and DMA are not supported. The only ported driver is for TI AM33xx, but others should be easy to port too.
Tested it on AM335x EVM and BeagleBone with CDC Ethernet gadget.
I hate to say it ... but given that this will cause duplication of code, I'm somehow inclined to push you to do a complete replacement of the old musb code, remove it and add this.
Tom, what do you think?
Ilya Yanok (5): linux/usb/ch9.h: update with the version from Linux tree musb-new: port of Linux musb gadget driver musb-new: dsps backend driver am33xx: init OTG hardware and new musb gadget driver am335x_evm: enable musb gadget on port 0
Best regards, Marek Vasut
Dear Marek Vasut,
Agreed, we should avoid such duplication.
Dear Marek, Wolfgang,
I'm
musb code,
I agree with you generally. But I fear I won't have enough time now to port the host part too. Also please note that usbtty works only with the old API now.
Regards, Ilya.
Marek, Wolfgang,
On Fri, Aug 10, 2012 at 9:56 PM, Ilya Yanok ilya.yanok@cogentembedded.comwrote:
code, I'm
musb code,
Also current MUSB code supports a number of systems, I could add support for all these to the new code (I just don't have the hardware). So I think it's better to allow the two versions coexist for some time.
Regards, Ilya.
Ilya Yanok
