[PATCH 01/11] net: dc2114x: Clean up init code
Clean up the driver init code to bring it up to standards with U-Boot coding style, no functional change.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Joe Hershberger joe.hershberger@ni.com --- drivers/net/dc2114x.c | 66 +++++++++++++++++++++---------------------- 1 file changed, 32 insertions(+), 34 deletions(-)
diff --git a/drivers/net/dc2114x.c b/drivers/net/dc2114x.c index 40bfc5281b..d302d0362a 100644 --- a/drivers/net/dc2114x.c +++ b/drivers/net/dc2114x.c @@ -167,33 +167,30 @@ static struct pci_device_id supported[] = {
int dc21x4x_initialize(bd_t *bis) { - int idx=0; - int card_number = 0; - unsigned int cfrv; - unsigned char timer; - pci_dev_t devbusfn; - unsigned int iobase; - unsigned short status; - struct eth_device* dev; - - while(1) { - devbusfn = pci_find_devices(supported, idx++); - if (devbusfn == -1) { + struct eth_device *dev; + unsigned short status; + unsigned char timer; + unsigned int iobase; + int card_number = 0; + pci_dev_t devbusfn; + unsigned int cfrv; + int idx = 0; + + while (1) { + devbusfn = pci_find_devices(supported, idx++); + if (devbusfn == -1) break; - }
/* Get the chip configuration revision register. */ pci_read_config_dword(devbusfn, PCI_REVISION_ID, &cfrv);
- if ((cfrv & CFRV_RN) < DC2114x_BRK ) { + if ((cfrv & CFRV_RN) < DC2114x_BRK) { printf("Error: The chip is not DC21143.\n"); continue; }
pci_read_config_word(devbusfn, PCI_COMMAND, &status); - status |= - PCI_COMMAND_MEMORY | - PCI_COMMAND_MASTER; + status |= PCI_COMMAND_MEMORY | PCI_COMMAND_MASTER; pci_write_config_word(devbusfn, PCI_COMMAND, status);
pci_read_config_word(devbusfn, PCI_COMMAND, &status); @@ -211,30 +208,31 @@ int dc21x4x_initialize(bd_t *bis) pci_read_config_byte(devbusfn, PCI_LATENCY_TIMER, &timer);
if (timer < 0x60) { - pci_write_config_byte(devbusfn, PCI_LATENCY_TIMER, 0x60); + pci_write_config_byte(devbusfn, PCI_LATENCY_TIMER, + 0x60); }
/* read BAR for memory space access */ pci_read_config_dword(devbusfn, PCI_BASE_ADDRESS_1, &iobase); iobase &= PCI_BASE_ADDRESS_MEM_MASK; - debug ("dc21x4x: DEC 21142 PCI Device @0x%x\n", iobase); - - dev = (struct eth_device*) malloc(sizeof *dev); + debug("dc21x4x: DEC 21142 PCI Device @0x%x\n", iobase);
+ dev = (struct eth_device *)malloc(sizeof(*dev)); if (!dev) { printf("Can not allocalte memory of dc21x4x\n"); break; } + memset(dev, 0, sizeof(*dev));
sprintf(dev->name, "dc21x4x#%d", card_number);
dev->iobase = pci_mem_to_phys(devbusfn, iobase); - dev->priv = (void*) devbusfn; - dev->init = dc21x4x_init; - dev->halt = dc21x4x_halt; - dev->send = dc21x4x_send; - dev->recv = dc21x4x_recv; + dev->priv = (void *)devbusfn; + dev->init = dc21x4x_init; + dev->halt = dc21x4x_halt; + dev->send = dc21x4x_send; + dev->recv = dc21x4x_recv;
/* Ensure we're not sleeping. */ pci_write_config_byte(devbusfn, PCI_CFDA_PSM, WAKEUP); @@ -251,10 +249,10 @@ int dc21x4x_initialize(bd_t *bis) return card_number; }
-static int dc21x4x_init(struct eth_device* dev, bd_t* bis) +static int dc21x4x_init(struct eth_device *dev, bd_t *bis) { - int i; - int devbusfn = (int) dev->priv; + int i; + int devbusfn = (int)dev->priv;
/* Ensure we're not sleeping. */ pci_write_config_byte(devbusfn, PCI_CFDA_PSM, WAKEUP); @@ -271,12 +269,12 @@ static int dc21x4x_init(struct eth_device* dev, bd_t* bis) for (i = 0; i < NUM_RX_DESC; i++) { rx_ring[i].status = cpu_to_le32(R_OWN); rx_ring[i].des1 = cpu_to_le32(RX_BUFF_SZ); - rx_ring[i].buf = cpu_to_le32( - phys_to_bus((u32)net_rx_packets[i])); + rx_ring[i].buf = + cpu_to_le32(phys_to_bus((u32)net_rx_packets[i])); rx_ring[i].next = 0; }
- for (i=0; i < NUM_TX_DESC; i++) { + for (i = 0; i < NUM_TX_DESC; i++) { tx_ring[i].status = 0; tx_ring[i].des1 = 0; tx_ring[i].buf = 0; @@ -291,8 +289,8 @@ static int dc21x4x_init(struct eth_device* dev, bd_t* bis) tx_ring[txRingSize - 1].des1 |= cpu_to_le32(TD_TER);
/* Tell the adapter where the TX/RX rings are located. */ - OUTL(dev, phys_to_bus((u32) &rx_ring), DE4X5_RRBA); - OUTL(dev, phys_to_bus((u32) &tx_ring), DE4X5_TRBA); + OUTL(dev, phys_to_bus((u32)&rx_ring), DE4X5_RRBA); + OUTL(dev, phys_to_bus((u32)&tx_ring), DE4X5_TRBA);
START_DE4X5(dev);
Clean up the driver send code to bring it up to standards with U-Boot coding style, invert the loops where applicable to cut down the level of indent. No functional change.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Joe Hershberger joe.hershberger@ni.com --- drivers/net/dc2114x.c | 42 ++++++++++++++++++++---------------------- 1 file changed, 20 insertions(+), 22 deletions(-)
diff --git a/drivers/net/dc2114x.c b/drivers/net/dc2114x.c index d302d0362a..11ebea9c1a 100644 --- a/drivers/net/dc2114x.c +++ b/drivers/net/dc2114x.c @@ -304,47 +304,45 @@ static int dc21x4x_init(struct eth_device *dev, bd_t *bis)
static int dc21x4x_send(struct eth_device *dev, void *packet, int length) { - int status = -1; - int i; + int status = -1; + int i;
if (length <= 0) { printf("%s: bad packet size: %d\n", dev->name, length); - goto Done; + goto done; }
- for(i = 0; tx_ring[tx_new].status & cpu_to_le32(T_OWN); i++) { - if (i >= TOUT_LOOP) { - printf("%s: tx error buffer not ready\n", dev->name); - goto Done; - } + for (i = 0; tx_ring[tx_new].status & cpu_to_le32(T_OWN); i++) { + if (i < TOUT_LOOP) + continue; + + printf("%s: tx error buffer not ready\n", dev->name); + goto done; }
- tx_ring[tx_new].buf = cpu_to_le32(phys_to_bus((u32) packet)); - tx_ring[tx_new].des1 = cpu_to_le32(TD_TER | TD_LS | TD_FS | length); + tx_ring[tx_new].buf = cpu_to_le32(phys_to_bus((u32)packet)); + tx_ring[tx_new].des1 = cpu_to_le32(TD_TER | TD_LS | TD_FS | length); tx_ring[tx_new].status = cpu_to_le32(T_OWN);
OUTL(dev, POLL_DEMAND, DE4X5_TPD);
- for(i = 0; tx_ring[tx_new].status & cpu_to_le32(T_OWN); i++) { - if (i >= TOUT_LOOP) { - printf(".%s: tx buffer not ready\n", dev->name); - goto Done; - } + for (i = 0; tx_ring[tx_new].status & cpu_to_le32(T_OWN); i++) { + if (i < TOUT_LOOP) + continue; + + printf(".%s: tx buffer not ready\n", dev->name); + goto done; }
if (le32_to_cpu(tx_ring[tx_new].status) & TD_ES) { -#if 0 /* test-only */ - printf("TX error status = 0x%08X\n", - le32_to_cpu(tx_ring[tx_new].status)); -#endif tx_ring[tx_new].status = 0x0; - goto Done; + goto done; }
status = length;
- Done: - tx_new = (tx_new+1) % NUM_TX_DESC; +done: + tx_new = (tx_new + 1) % NUM_TX_DESC; return status; }
Clean up the driver recv code to bring it up to standards with U-Boot coding style. No functional change.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Joe Hershberger joe.hershberger@ni.com --- drivers/net/dc2114x.c | 44 +++++++++++++++++++------------------------ 1 file changed, 19 insertions(+), 25 deletions(-)
diff --git a/drivers/net/dc2114x.c b/drivers/net/dc2114x.c index 11ebea9c1a..4d2e11672e 100644 --- a/drivers/net/dc2114x.c +++ b/drivers/net/dc2114x.c @@ -346,46 +346,40 @@ done: return status; }
-static int dc21x4x_recv(struct eth_device* dev) +static int dc21x4x_recv(struct eth_device *dev) { - s32 status; - int length = 0; + int length = 0; + u32 status;
- for ( ; ; ) { - status = (s32)le32_to_cpu(rx_ring[rx_new].status); + while (true) { + status = le32_to_cpu(rx_ring[rx_new].status);
- if (status & R_OWN) { + if (status & R_OWN) break; - }
if (status & RD_LS) { - /* Valid frame status. - */ + /* Valid frame status. */ if (status & RD_ES) { - - /* There was an error. - */ + /* There was an error. */ printf("RX error status = 0x%08X\n", status); } else { - /* A valid frame received. - */ - length = (le32_to_cpu(rx_ring[rx_new].status) >> 16); - - /* Pass the packet up to the protocol - * layers. - */ - net_process_received_packet( - net_rx_packets[rx_new], length - 4); + /* A valid frame received. */ + length = (le32_to_cpu(rx_ring[rx_new].status) + >> 16); + + /* Pass the packet up to the protocol layers */ + net_process_received_packet + (net_rx_packets[rx_new], length - 4); }
- /* Change buffer ownership for this frame, back - * to the adapter. + /* + * Change buffer ownership for this frame, + * back to the adapter. */ rx_ring[rx_new].status = cpu_to_le32(R_OWN); }
- /* Update entry information. - */ + /* Update entry information. */ rx_new = (rx_new + 1) % rxRingSize; }
Clean up the driver halt code to bring it up to standards with U-Boot coding style. No functional change.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Joe Hershberger joe.hershberger@ni.com --- drivers/net/dc2114x.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/net/dc2114x.c b/drivers/net/dc2114x.c index 4d2e11672e..6fe05113ca 100644 --- a/drivers/net/dc2114x.c +++ b/drivers/net/dc2114x.c @@ -386,9 +386,9 @@ static int dc21x4x_recv(struct eth_device *dev) return length; }
-static void dc21x4x_halt(struct eth_device* dev) +static void dc21x4x_halt(struct eth_device *dev) { - int devbusfn = (int) dev->priv; + int devbusfn = (int)dev->priv;
STOP_DE4X5(dev); OUTL(dev, 0, DE4X5_SICR);
Clean up the send_setup_frame() to bring it up to standards with U-Boot coding style, invert the loops where applicable to cut down the level of indent. No functional change.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Joe Hershberger joe.hershberger@ni.com --- drivers/net/dc2114x.c | 44 +++++++++++++++++++++---------------------- 1 file changed, 22 insertions(+), 22 deletions(-)
diff --git a/drivers/net/dc2114x.c b/drivers/net/dc2114x.c index 6fe05113ca..bd64c75af4 100644 --- a/drivers/net/dc2114x.c +++ b/drivers/net/dc2114x.c @@ -396,48 +396,48 @@ static void dc21x4x_halt(struct eth_device *dev) pci_write_config_byte(devbusfn, PCI_CFDA_PSM, SLEEP); }
-static void send_setup_frame(struct eth_device* dev, bd_t *bis) +static void send_setup_frame(struct eth_device *dev, bd_t *bis) { - int i; - char setup_frame[SETUP_FRAME_LEN]; - char *pa = &setup_frame[0]; + char setup_frame[SETUP_FRAME_LEN]; + char *pa = &setup_frame[0]; + int i;
memset(pa, 0xff, SETUP_FRAME_LEN);
for (i = 0; i < ETH_ALEN; i++) { *(pa + (i & 1)) = dev->enetaddr[i]; - if (i & 0x01) { + if (i & 0x01) pa += 4; - } }
- for(i = 0; tx_ring[tx_new].status & cpu_to_le32(T_OWN); i++) { - if (i >= TOUT_LOOP) { - printf("%s: tx error buffer not ready\n", dev->name); - goto Done; - } + for (i = 0; tx_ring[tx_new].status & cpu_to_le32(T_OWN); i++) { + if (i < TOUT_LOOP) + continue; + + printf("%s: tx error buffer not ready\n", dev->name); + return; }
- tx_ring[tx_new].buf = cpu_to_le32(phys_to_bus((u32) &setup_frame[0])); - tx_ring[tx_new].des1 = cpu_to_le32(TD_TER | TD_SET| SETUP_FRAME_LEN); + tx_ring[tx_new].buf = cpu_to_le32(phys_to_bus((u32)&setup_frame[0])); + tx_ring[tx_new].des1 = cpu_to_le32(TD_TER | TD_SET | SETUP_FRAME_LEN); tx_ring[tx_new].status = cpu_to_le32(T_OWN);
- for(i = 0; tx_ring[tx_new].status & cpu_to_le32(T_OWN); i++) { - if (i >= TOUT_LOOP) { - printf("%s: tx buffer not ready\n", dev->name); - goto Done; - } + for (i = 0; tx_ring[tx_new].status & cpu_to_le32(T_OWN); i++) { + if (i < TOUT_LOOP) + continue; + + printf("%s: tx buffer not ready\n", dev->name); + return; }
if (le32_to_cpu(tx_ring[tx_new].status) != 0x7FFFFFFF) { - printf("TX error status2 = 0x%08X\n", le32_to_cpu(tx_ring[tx_new].status)); + printf("TX error status2 = 0x%08X\n", + le32_to_cpu(tx_ring[tx_new].status)); } - tx_new = (tx_new+1) % NUM_TX_DESC;
-Done: - return; + tx_new = (tx_new + 1) % NUM_TX_DESC; }
/* SROM Read and write routines. */
Clean up the SROM accessors to bring them up to standards with U-Boot coding style. Sort variable into reverse xmas tree. No functional change.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Joe Hershberger joe.hershberger@ni.com --- drivers/net/dc2114x.c | 117 +++++++++++++++++++++++------------------- 1 file changed, 63 insertions(+), 54 deletions(-)
diff --git a/drivers/net/dc2114x.c b/drivers/net/dc2114x.c index bd64c75af4..b375906e27 100644 --- a/drivers/net/dc2114x.c +++ b/drivers/net/dc2114x.c @@ -441,30 +441,27 @@ static void send_setup_frame(struct eth_device *dev, bd_t *bis) }
/* SROM Read and write routines. */ -static void -sendto_srom(struct eth_device* dev, u_int command, u_long addr) +static void sendto_srom(struct eth_device *dev, u_int command, u_long addr) { OUTL(dev, command, addr); udelay(1); }
-static int -getfrom_srom(struct eth_device* dev, u_long addr) +static int getfrom_srom(struct eth_device *dev, u_long addr) { - s32 tmp; + s32 tmp = INL(dev, addr);
- tmp = INL(dev, addr); udelay(1); - return tmp; }
/* Note: this routine returns extra data bits for size detection. */ -static int do_read_eeprom(struct eth_device *dev, u_long ioaddr, int location, int addr_len) +static int do_read_eeprom(struct eth_device *dev, u_long ioaddr, int location, + int addr_len) { - int i; - unsigned retval = 0; int read_cmd = location | (SROM_READ_CMD << addr_len); + unsigned int retval = 0; + int i;
sendto_srom(dev, SROM_RD | SROM_SR, ioaddr); sendto_srom(dev, SROM_RD | SROM_SR | DT_CS, ioaddr); @@ -476,14 +473,18 @@ static int do_read_eeprom(struct eth_device *dev, u_long ioaddr, int location, i /* Shift the read command bits out. */ for (i = 4 + addr_len; i >= 0; i--) { short dataval = (read_cmd & (1 << i)) ? EE_DATA_WRITE : 0; - sendto_srom(dev, SROM_RD | SROM_SR | DT_CS | dataval, ioaddr); + + sendto_srom(dev, SROM_RD | SROM_SR | DT_CS | dataval, + ioaddr); udelay(10); - sendto_srom(dev, SROM_RD | SROM_SR | DT_CS | dataval | DT_CLK, ioaddr); + sendto_srom(dev, SROM_RD | SROM_SR | DT_CS | dataval | DT_CLK, + ioaddr); udelay(10); #ifdef DEBUG_SROM2 printf("%X", getfrom_srom(dev, ioaddr) & 15); #endif - retval = (retval << 1) | ((getfrom_srom(dev, ioaddr) & EE_DATA_READ) ? 1 : 0); + retval = (retval << 1) | + !!(getfrom_srom(dev, ioaddr) & EE_DATA_READ); }
sendto_srom(dev, SROM_RD | SROM_SR | DT_CS, ioaddr); @@ -498,7 +499,8 @@ static int do_read_eeprom(struct eth_device *dev, u_long ioaddr, int location, i #ifdef DEBUG_SROM2 printf("%X", getfrom_srom(dev, ioaddr) & 15); #endif - retval = (retval << 1) | ((getfrom_srom(dev, ioaddr) & EE_DATA_READ) ? 1 : 0); + retval = (retval << 1) | + !!(getfrom_srom(dev, ioaddr) & EE_DATA_READ); sendto_srom(dev, SROM_RD | SROM_SR | DT_CS, ioaddr); udelay(10); } @@ -518,34 +520,38 @@ static int do_read_eeprom(struct eth_device *dev, u_long ioaddr, int location, i * enable. It returns the data output from the EEPROM, and thus may * also be used for reads. */ -static int do_eeprom_cmd(struct eth_device *dev, u_long ioaddr, int cmd, int cmd_len) +static int do_eeprom_cmd(struct eth_device *dev, u_long ioaddr, int cmd, + int cmd_len) { - unsigned retval = 0; + unsigned int retval = 0;
#ifdef DEBUG_SROM printf(" EEPROM op 0x%x: ", cmd); #endif
- sendto_srom(dev,SROM_RD | SROM_SR | DT_CS | DT_CLK, ioaddr); + sendto_srom(dev, SROM_RD | SROM_SR | DT_CS | DT_CLK, ioaddr);
/* Shift the command bits out. */ do { - short dataval = (cmd & (1 << cmd_len)) ? EE_WRITE_1 : EE_WRITE_0; - sendto_srom(dev,dataval, ioaddr); + short dataval = (cmd & BIT(cmd_len)) ? EE_WRITE_1 : EE_WRITE_0; + + sendto_srom(dev, dataval, ioaddr); udelay(10);
#ifdef DEBUG_SROM2 - printf("%X", getfrom_srom(dev,ioaddr) & 15); + printf("%X", getfrom_srom(dev, ioaddr) & 15); #endif
- sendto_srom(dev,dataval | DT_CLK, ioaddr); + sendto_srom(dev, dataval | DT_CLK, ioaddr); udelay(10); - retval = (retval << 1) | ((getfrom_srom(dev,ioaddr) & EE_DATA_READ) ? 1 : 0); + retval = (retval << 1) | + !!(getfrom_srom(dev, ioaddr) & EE_DATA_READ); } while (--cmd_len >= 0); - sendto_srom(dev,SROM_RD | SROM_SR | DT_CS, ioaddr); + + sendto_srom(dev, SROM_RD | SROM_SR | DT_CS, ioaddr);
/* Terminate the EEPROM access. */ - sendto_srom(dev,SROM_RD | SROM_SR, ioaddr); + sendto_srom(dev, SROM_RD | SROM_SR, ioaddr);
#ifdef DEBUG_SROM printf(" EEPROM result is 0x%5.5x.\n", retval); @@ -556,21 +562,26 @@ static int do_eeprom_cmd(struct eth_device *dev, u_long ioaddr, int cmd, int cmd
static int read_srom(struct eth_device *dev, u_long ioaddr, int index) { - int ee_addr_size = do_read_eeprom(dev, ioaddr, 0xff, 8) & 0x40000 ? 8 : 6; + int ee_addr_size;
- return do_eeprom_cmd(dev, ioaddr, - (((SROM_READ_CMD << ee_addr_size) | index) << 16) - | 0xffff, 3 + ee_addr_size + 16); + ee_addr_size = (do_read_eeprom(dev, ioaddr, 0xff, 8) & BIT(18)) ? 8 : 6; + + return do_eeprom_cmd(dev, ioaddr, 0xffff | + (((SROM_READ_CMD << ee_addr_size) | index) << 16), + 3 + ee_addr_size + 16); }
#ifdef UPDATE_SROM -static int write_srom(struct eth_device *dev, u_long ioaddr, int index, int new_value) +static int write_srom(struct eth_device *dev, u_long ioaddr, int index, + int new_value) { - int ee_addr_size = do_read_eeprom(dev, ioaddr, 0xff, 8) & 0x40000 ? 8 : 6; - int i; unsigned short newval; + int ee_addr_size; + int i;
- udelay(10*1000); /* test-only */ + ee_addr_size = (do_read_eeprom(dev, ioaddr, 0xff, 8) & BIT(18)) ? 8 : 6; + + udelay(10 * 1000); /* test-only */
#ifdef DEBUG_SROM printf("ee_addr_size=%d.\n", ee_addr_size); @@ -578,33 +589,37 @@ static int write_srom(struct eth_device *dev, u_long ioaddr, int index, int new_ #endif
/* Enable programming modes. */ - do_eeprom_cmd(dev, ioaddr, (0x4f << (ee_addr_size-4)), 3+ee_addr_size); + do_eeprom_cmd(dev, ioaddr, 0x4f << (ee_addr_size - 4), + 3 + ee_addr_size);
/* Do the actual write. */ - do_eeprom_cmd(dev, ioaddr, - (((SROM_WRITE_CMD<<ee_addr_size)|index) << 16) | new_value, + do_eeprom_cmd(dev, ioaddr, new_value | + (((SROM_WRITE_CMD << ee_addr_size) | index) << 16), 3 + ee_addr_size + 16);
/* Poll for write finished. */ sendto_srom(dev, SROM_RD | SROM_SR | DT_CS, ioaddr); - for (i = 0; i < 10000; i++) /* Typical 2000 ticks */ + for (i = 0; i < 10000; i++) { /* Typical 2000 ticks */ if (getfrom_srom(dev, ioaddr) & EE_DATA_READ) break; + }
#ifdef DEBUG_SROM printf(" Write finished after %d ticks.\n", i); #endif
/* Disable programming. */ - do_eeprom_cmd(dev, ioaddr, (0x40 << (ee_addr_size-4)), 3 + ee_addr_size); + do_eeprom_cmd(dev, ioaddr, (0x40 << (ee_addr_size - 4)), + 3 + ee_addr_size);
/* And read the result. */ newval = do_eeprom_cmd(dev, ioaddr, - (((SROM_READ_CMD<<ee_addr_size)|index) << 16) + (((SROM_READ_CMD << ee_addr_size) | index) << 16) | 0xffff, 3 + ee_addr_size + 16); #ifdef DEBUG_SROM printf(" New value at offset %d is %4.4x.\n", index, newval); #endif + return 1; } #endif @@ -615,30 +630,23 @@ static void read_hw_addr(struct eth_device *dev, bd_t *bis) int i, j = 0;
for (i = 0; i < (ETH_ALEN >> 1); i++) { - tmp = read_srom(dev, DE4X5_APROM, ((SROM_HWADD >> 1) + i)); + tmp = read_srom(dev, DE4X5_APROM, (SROM_HWADD >> 1) + i); *p = le16_to_cpu(tmp); j += *p++; }
- if ((j == 0) || (j == 0x2fffd)) { - memset (dev->enetaddr, 0, ETH_ALEN); - debug ("Warning: can't read HW address from SROM.\n"); - goto Done; - } - - return; - -Done: + if (!j || j == 0x2fffd) { + memset(dev->enetaddr, 0, ETH_ALEN); + debug("Warning: can't read HW address from SROM.\n"); #ifdef UPDATE_SROM - update_srom(dev, bis); + update_srom(dev, bis); #endif - return; + } }
#ifdef UPDATE_SROM static void update_srom(struct eth_device *dev, bd_t *bis) { - int i; static unsigned short eeprom[0x40] = { 0x140b, 0x6610, 0x0000, 0x0000, /* 00 */ 0x0000, 0x0000, 0x0000, 0x0000, /* 04 */ @@ -658,16 +666,17 @@ static void update_srom(struct eth_device *dev, bd_t *bis) 0x0000, 0x0000, 0x0000, 0x4e07, /* 3c */ }; uchar enetaddr[6]; + int i;
/* Ethernet Addr... */ if (!eth_env_get_enetaddr("ethaddr", enetaddr)) return; + eeprom[0x0a] = (enetaddr[1] << 8) | enetaddr[0]; eeprom[0x0b] = (enetaddr[3] << 8) | enetaddr[2]; eeprom[0x0c] = (enetaddr[5] << 8) | enetaddr[4];
- for (i=0; i<0x40; i++) { + for (i = 0; i < 0x40; i++) write_srom(dev, DE4X5_APROM, i, eeprom[i]); - } } -#endif /* UPDATE_SROM */ +#endif /* UPDATE_SROM */
Clean up the remaining driver code, macro space alignment, function declaration indent, replace __attribute__((aligned(32))) with plain __aligned(32). No functional change.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Joe Hershberger joe.hershberger@ni.com --- drivers/net/dc2114x.c | 86 +++++++++++++++++++++---------------------- 1 file changed, 43 insertions(+), 43 deletions(-)
diff --git a/drivers/net/dc2114x.c b/drivers/net/dc2114x.c index b375906e27..007e4cecb6 100644 --- a/drivers/net/dc2114x.c +++ b/drivers/net/dc2114x.c @@ -12,19 +12,17 @@
#undef UPDATE_SROM
-/* PCI Registers. - */ -#define PCI_CFDA_PSM 0x43 +/* PCI Registers. */ +#define PCI_CFDA_PSM 0x43
#define CFRV_RN 0x000000f0 /* Revision Number */
#define WAKEUP 0x00 /* Power Saving Wakeup */ #define SLEEP 0x80 /* Power Saving Sleep Mode */
-#define DC2114x_BRK 0x0020 /* CFRV break between DC21142 & DC21143 */ +#define DC2114x_BRK 0x0020 /* CFRV break between DC21142 & DC21143 */
-/* Ethernet chip registers. - */ +/* Ethernet chip registers. */ #define DE4X5_BMR 0x000 /* Bus Mode Register */ #define DE4X5_TPD 0x008 /* Transmit Poll Demand Reg */ #define DE4X5_RRBA 0x018 /* RX Ring Base Address Reg */ @@ -34,8 +32,7 @@ #define DE4X5_SICR 0x068 /* SIA Connectivity Register */ #define DE4X5_APROM 0x048 /* Ethernet Address PROM */
-/* Register bits. - */ +/* Register bits. */ #define BMR_SWR 0x00000001 /* Software Reset */ #define STS_TS 0x00700000 /* Transmit Process State */ #define STS_RS 0x000e0000 /* Receive Process State */ @@ -45,8 +42,7 @@ #define OMR_SDP 0x02000000 /* SD Polarity - MUST BE ASSERTED */ #define OMR_PM 0x00000080 /* Pass All Multicast */
-/* Descriptor bits. - */ +/* Descriptor bits. */ #define R_OWN 0x80000000 /* Own Bit */ #define RD_RER 0x02000000 /* Receive End Of Ring */ #define RD_LS 0x00000100 /* Last Descriptor */ @@ -63,12 +59,12 @@ #define SROM_READ_CMD 6 #define SROM_ERASE_CMD 7
-#define SROM_HWADD 0x0014 /* Hardware Address offset in SROM */ +#define SROM_HWADD 0x0014 /* Hardware Address offset in SROM */ #define SROM_RD 0x00004000 /* Read from Boot ROM */ -#define EE_DATA_WRITE 0x04 /* EEPROM chip data in. */ -#define EE_WRITE_0 0x4801 -#define EE_WRITE_1 0x4805 -#define EE_DATA_READ 0x08 /* EEPROM chip data out. */ +#define EE_DATA_WRITE 0x04 /* EEPROM chip data in. */ +#define EE_WRITE_0 0x4801 +#define EE_WRITE_1 0x4805 +#define EE_DATA_READ 0x08 /* EEPROM chip data out. */ #define SROM_SR 0x00000800 /* Select Serial ROM when set */
#define DT_IN 0x00000004 /* Serial Data In */ @@ -79,13 +75,13 @@
#define RESET_DE4X5(dev) {\ int i;\ - i=INL(dev, DE4X5_BMR);\ + i = INL(dev, DE4X5_BMR);\ udelay(1000);\ OUTL(dev, i | BMR_SWR, DE4X5_BMR);\ udelay(1000);\ OUTL(dev, i, DE4X5_BMR);\ udelay(1000);\ - for (i=0;i<5;i++) {INL(dev, DE4X5_BMR); udelay(10000);}\ + for (i = 0; i < 5; i++) {INL(dev, DE4X5_BMR); udelay(10000); } \ udelay(1000);\ }
@@ -99,7 +95,7 @@ #define STOP_DE4X5(dev) {\ s32 omr; \ omr = INL(dev, DE4X5_OMR);\ - omr &= ~(OMR_ST|OMR_SR);\ + omr &= ~(OMR_ST | OMR_SR);\ OUTL(dev, omr, DE4X5_OMR); /* Disable the TX and/or RX */ \ }
@@ -118,30 +114,34 @@ struct de4x5_desc { u32 next; };
-static struct de4x5_desc rx_ring[NUM_RX_DESC] __attribute__ ((aligned(32))); /* RX descriptor ring */ -static struct de4x5_desc tx_ring[NUM_TX_DESC] __attribute__ ((aligned(32))); /* TX descriptor ring */ -static int rx_new; /* RX descriptor ring pointer */ -static int tx_new; /* TX descriptor ring pointer */ - -static char rxRingSize; -static char txRingSize; - -static void sendto_srom(struct eth_device* dev, u_int command, u_long addr); -static int getfrom_srom(struct eth_device* dev, u_long addr); -static int do_eeprom_cmd(struct eth_device *dev, u_long ioaddr,int cmd,int cmd_len); -static int do_read_eeprom(struct eth_device *dev,u_long ioaddr,int location,int addr_len); +/* RX and TX descriptor ring */ +static struct de4x5_desc rx_ring[NUM_RX_DESC] __aligned(32); +static struct de4x5_desc tx_ring[NUM_TX_DESC] __aligned(32); +static int rx_new; /* RX descriptor ring pointer */ +static int tx_new; /* TX descriptor ring pointer */ + +static char rx_ring_size; +static char tx_ring_size; + +static void sendto_srom(struct eth_device *dev, u_int command, u_long addr); +static int getfrom_srom(struct eth_device *dev, u_long addr); +static int do_eeprom_cmd(struct eth_device *dev, u_long ioaddr, + int cmd, int cmd_len); +static int do_read_eeprom(struct eth_device *dev, u_long ioaddr, + int location, int addr_len); #ifdef UPDATE_SROM -static int write_srom(struct eth_device *dev, u_long ioaddr, int index, int new_value); +static int write_srom(struct eth_device *dev, u_long ioaddr, + int index, int new_value); static void update_srom(struct eth_device *dev, bd_t *bis); #endif static int read_srom(struct eth_device *dev, u_long ioaddr, int index); -static void read_hw_addr(struct eth_device* dev, bd_t * bis); -static void send_setup_frame(struct eth_device* dev, bd_t * bis); +static void read_hw_addr(struct eth_device *dev, bd_t *bis); +static void send_setup_frame(struct eth_device *dev, bd_t *bis);
-static int dc21x4x_init(struct eth_device* dev, bd_t* bis); +static int dc21x4x_init(struct eth_device *dev, bd_t *bis); static int dc21x4x_send(struct eth_device *dev, void *packet, int length); -static int dc21x4x_recv(struct eth_device* dev); -static void dc21x4x_halt(struct eth_device* dev); +static int dc21x4x_recv(struct eth_device *dev); +static void dc21x4x_halt(struct eth_device *dev);
#if defined(CONFIG_E500) #define phys_to_bus(a) (a) @@ -149,12 +149,12 @@ static void dc21x4x_halt(struct eth_device* dev); #define phys_to_bus(a) pci_phys_to_mem((pci_dev_t)dev->priv, a) #endif
-static int INL(struct eth_device* dev, u_long addr) +static int INL(struct eth_device *dev, u_long addr) { return le32_to_cpu(*(volatile u_long *)(addr + dev->iobase)); }
-static void OUTL(struct eth_device* dev, int command, u_long addr) +static void OUTL(struct eth_device *dev, int command, u_long addr) { *(volatile u_long *)(addr + dev->iobase) = cpu_to_le32(command); } @@ -281,12 +281,12 @@ static int dc21x4x_init(struct eth_device *dev, bd_t *bis) tx_ring[i].next = 0; }
- rxRingSize = NUM_RX_DESC; - txRingSize = NUM_TX_DESC; + rx_ring_size = NUM_RX_DESC; + tx_ring_size = NUM_TX_DESC;
/* Write the end of list marker to the descriptor lists. */ - rx_ring[rxRingSize - 1].des1 |= cpu_to_le32(RD_RER); - tx_ring[txRingSize - 1].des1 |= cpu_to_le32(TD_TER); + rx_ring[rx_ring_size - 1].des1 |= cpu_to_le32(RD_RER); + tx_ring[tx_ring_size - 1].des1 |= cpu_to_le32(TD_TER);
/* Tell the adapter where the TX/RX rings are located. */ OUTL(dev, phys_to_bus((u32)&rx_ring), DE4X5_RRBA); @@ -380,7 +380,7 @@ static int dc21x4x_recv(struct eth_device *dev) }
/* Update entry information. */ - rx_new = (rx_new + 1) % rxRingSize; + rx_new = (rx_new + 1) % rx_ring_size; }
return length;
Replace these macros with static functions to permit the compiler to do type checking on the functions. The INL()/OUTL() functions have to be moved in this patch as well, as those DE4X5 macros are using them. No functional change.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Joe Hershberger joe.hershberger@ni.com --- drivers/net/dc2114x.c | 89 ++++++++++++++++++++++++------------------- 1 file changed, 50 insertions(+), 39 deletions(-)
diff --git a/drivers/net/dc2114x.c b/drivers/net/dc2114x.c index 007e4cecb6..a85fb76d53 100644 --- a/drivers/net/dc2114x.c +++ b/drivers/net/dc2114x.c @@ -73,30 +73,57 @@
#define POLL_DEMAND 1
-#define RESET_DE4X5(dev) {\ - int i;\ - i = INL(dev, DE4X5_BMR);\ - udelay(1000);\ - OUTL(dev, i | BMR_SWR, DE4X5_BMR);\ - udelay(1000);\ - OUTL(dev, i, DE4X5_BMR);\ - udelay(1000);\ - for (i = 0; i < 5; i++) {INL(dev, DE4X5_BMR); udelay(10000); } \ - udelay(1000);\ +#if defined(CONFIG_E500) +#define phys_to_bus(a) (a) +#else +#define phys_to_bus(a) pci_phys_to_mem((pci_dev_t)dev->priv, a) +#endif + +static int INL(struct eth_device *dev, u_long addr) +{ + return le32_to_cpu(*(volatile u_long *)(addr + dev->iobase)); +} + +static void OUTL(struct eth_device *dev, int command, u_long addr) +{ + *(volatile u_long *)(addr + dev->iobase) = cpu_to_le32(command); +} + +static void reset_de4x5(struct eth_device *dev) +{ + int i; + + i = INL(dev, DE4X5_BMR); + mdelay(1); + OUTL(dev, i | BMR_SWR, DE4X5_BMR); + mdelay(1); + OUTL(dev, i, DE4X5_BMR); + mdelay(1); + + for (i = 0; i < 5; i++) { + INL(dev, DE4X5_BMR); + mdelay(10); + } + + mdelay(1); }
-#define START_DE4X5(dev) {\ - s32 omr; \ - omr = INL(dev, DE4X5_OMR);\ - omr |= OMR_ST | OMR_SR;\ - OUTL(dev, omr, DE4X5_OMR); /* Enable the TX and/or RX */\ +static void start_de4x5(struct eth_device *dev) +{ + s32 omr; + + omr = INL(dev, DE4X5_OMR); + omr |= OMR_ST | OMR_SR; + OUTL(dev, omr, DE4X5_OMR); /* Enable the TX and/or RX */ }
-#define STOP_DE4X5(dev) {\ - s32 omr; \ - omr = INL(dev, DE4X5_OMR);\ - omr &= ~(OMR_ST | OMR_SR);\ - OUTL(dev, omr, DE4X5_OMR); /* Disable the TX and/or RX */ \ +static void stop_de4x5(struct eth_device *dev) +{ + s32 omr; + + omr = INL(dev, DE4X5_OMR); + omr &= ~(OMR_ST | OMR_SR); + OUTL(dev, omr, DE4X5_OMR); /* Disable the TX and/or RX */ }
#define NUM_RX_DESC PKTBUFSRX @@ -143,22 +170,6 @@ static int dc21x4x_send(struct eth_device *dev, void *packet, int length); static int dc21x4x_recv(struct eth_device *dev); static void dc21x4x_halt(struct eth_device *dev);
-#if defined(CONFIG_E500) -#define phys_to_bus(a) (a) -#else -#define phys_to_bus(a) pci_phys_to_mem((pci_dev_t)dev->priv, a) -#endif - -static int INL(struct eth_device *dev, u_long addr) -{ - return le32_to_cpu(*(volatile u_long *)(addr + dev->iobase)); -} - -static void OUTL(struct eth_device *dev, int command, u_long addr) -{ - *(volatile u_long *)(addr + dev->iobase) = cpu_to_le32(command); -} - static struct pci_device_id supported[] = { { PCI_VENDOR_ID_DEC, PCI_DEVICE_ID_DEC_TULIP_FAST }, { PCI_VENDOR_ID_DEC, PCI_DEVICE_ID_DEC_21142 }, @@ -257,7 +268,7 @@ static int dc21x4x_init(struct eth_device *dev, bd_t *bis) /* Ensure we're not sleeping. */ pci_write_config_byte(devbusfn, PCI_CFDA_PSM, WAKEUP);
- RESET_DE4X5(dev); + reset_de4x5(dev);
if ((INL(dev, DE4X5_STS) & (STS_TS | STS_RS)) != 0) { printf("Error: Cannot reset ethernet controller.\n"); @@ -292,7 +303,7 @@ static int dc21x4x_init(struct eth_device *dev, bd_t *bis) OUTL(dev, phys_to_bus((u32)&rx_ring), DE4X5_RRBA); OUTL(dev, phys_to_bus((u32)&tx_ring), DE4X5_TRBA);
- START_DE4X5(dev); + start_de4x5(dev);
tx_new = 0; rx_new = 0; @@ -390,7 +401,7 @@ static void dc21x4x_halt(struct eth_device *dev) { int devbusfn = (int)dev->priv;
- STOP_DE4X5(dev); + stop_de4x5(dev); OUTL(dev, 0, DE4X5_SICR);
Rename these functions to dc2114x_{inl,outl}(), use u32 values in them instead of plain signed integers as all those values are in fact register values and the driver code does bitwise operations on them. No functional change intended.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Joe Hershberger joe.hershberger@ni.com --- drivers/net/dc2114x.c | 48 +++++++++++++++++++++---------------------- 1 file changed, 24 insertions(+), 24 deletions(-)
diff --git a/drivers/net/dc2114x.c b/drivers/net/dc2114x.c index a85fb76d53..2bbe4e5d60 100644 --- a/drivers/net/dc2114x.c +++ b/drivers/net/dc2114x.c @@ -79,29 +79,29 @@ #define phys_to_bus(a) pci_phys_to_mem((pci_dev_t)dev->priv, a) #endif
-static int INL(struct eth_device *dev, u_long addr) +static u32 dc2114x_inl(struct eth_device *dev, u32 addr) { - return le32_to_cpu(*(volatile u_long *)(addr + dev->iobase)); + return le32_to_cpu(*(volatile u32 *)(addr + dev->iobase)); }
-static void OUTL(struct eth_device *dev, int command, u_long addr) +static void dc2114x_outl(struct eth_device *dev, u32 command, u32 addr) { - *(volatile u_long *)(addr + dev->iobase) = cpu_to_le32(command); + *(volatile u32 *)(addr + dev->iobase) = cpu_to_le32(command); }
static void reset_de4x5(struct eth_device *dev) { - int i; + u32 i;
- i = INL(dev, DE4X5_BMR); + i = dc2114x_inl(dev, DE4X5_BMR); mdelay(1); - OUTL(dev, i | BMR_SWR, DE4X5_BMR); + dc2114x_outl(dev, i | BMR_SWR, DE4X5_BMR); mdelay(1); - OUTL(dev, i, DE4X5_BMR); + dc2114x_outl(dev, i, DE4X5_BMR); mdelay(1);
for (i = 0; i < 5; i++) { - INL(dev, DE4X5_BMR); + dc2114x_inl(dev, DE4X5_BMR); mdelay(10); }
@@ -110,20 +110,20 @@ static void reset_de4x5(struct eth_device *dev)
static void start_de4x5(struct eth_device *dev) { - s32 omr; + u32 omr;
- omr = INL(dev, DE4X5_OMR); + omr = dc2114x_inl(dev, DE4X5_OMR); omr |= OMR_ST | OMR_SR; - OUTL(dev, omr, DE4X5_OMR); /* Enable the TX and/or RX */ + dc2114x_outl(dev, omr, DE4X5_OMR); /* Enable the TX and/or RX */ }
static void stop_de4x5(struct eth_device *dev) { - s32 omr; + u32 omr;
- omr = INL(dev, DE4X5_OMR); + omr = dc2114x_inl(dev, DE4X5_OMR); omr &= ~(OMR_ST | OMR_SR); - OUTL(dev, omr, DE4X5_OMR); /* Disable the TX and/or RX */ + dc2114x_outl(dev, omr, DE4X5_OMR); /* Disable the TX and/or RX */ }
#define NUM_RX_DESC PKTBUFSRX @@ -270,12 +270,12 @@ static int dc21x4x_init(struct eth_device *dev, bd_t *bis)
reset_de4x5(dev);
- if ((INL(dev, DE4X5_STS) & (STS_TS | STS_RS)) != 0) { + if (dc2114x_inl(dev, DE4X5_STS) & (STS_TS | STS_RS)) { printf("Error: Cannot reset ethernet controller.\n"); return -1; }
- OUTL(dev, OMR_SDP | OMR_PS | OMR_PM, DE4X5_OMR); + dc2114x_outl(dev, OMR_SDP | OMR_PS | OMR_PM, DE4X5_OMR);
for (i = 0; i < NUM_RX_DESC; i++) { rx_ring[i].status = cpu_to_le32(R_OWN); @@ -300,8 +300,8 @@ static int dc21x4x_init(struct eth_device *dev, bd_t *bis) tx_ring[tx_ring_size - 1].des1 |= cpu_to_le32(TD_TER);
/* Tell the adapter where the TX/RX rings are located. */ - OUTL(dev, phys_to_bus((u32)&rx_ring), DE4X5_RRBA); - OUTL(dev, phys_to_bus((u32)&tx_ring), DE4X5_TRBA); + dc2114x_outl(dev, phys_to_bus((u32)&rx_ring), DE4X5_RRBA); + dc2114x_outl(dev, phys_to_bus((u32)&tx_ring), DE4X5_TRBA);
start_de4x5(dev);
@@ -335,7 +335,7 @@ static int dc21x4x_send(struct eth_device *dev, void *packet, int length) tx_ring[tx_new].des1 = cpu_to_le32(TD_TER | TD_LS | TD_FS | length); tx_ring[tx_new].status = cpu_to_le32(T_OWN);
- OUTL(dev, POLL_DEMAND, DE4X5_TPD); + dc2114x_outl(dev, POLL_DEMAND, DE4X5_TPD);
for (i = 0; tx_ring[tx_new].status & cpu_to_le32(T_OWN); i++) { if (i < TOUT_LOOP) @@ -402,7 +402,7 @@ static void dc21x4x_halt(struct eth_device *dev) int devbusfn = (int)dev->priv;
stop_de4x5(dev); - OUTL(dev, 0, DE4X5_SICR); + dc2114x_outl(dev, 0, DE4X5_SICR);
pci_write_config_byte(devbusfn, PCI_CFDA_PSM, SLEEP); } @@ -433,7 +433,7 @@ static void send_setup_frame(struct eth_device *dev, bd_t *bis) tx_ring[tx_new].des1 = cpu_to_le32(TD_TER | TD_SET | SETUP_FRAME_LEN); tx_ring[tx_new].status = cpu_to_le32(T_OWN);
for (i = 0; tx_ring[tx_new].status & cpu_to_le32(T_OWN); i++) { if (i < TOUT_LOOP) @@ -454,13 +454,13 @@ static void send_setup_frame(struct eth_device *dev, bd_t *bis) /* SROM Read and write routines. */ static void sendto_srom(struct eth_device *dev, u_int command, u_long addr) { - OUTL(dev, command, addr); + dc2114x_outl(dev, command, addr); udelay(1); }
static int getfrom_srom(struct eth_device *dev, u_long addr) { - s32 tmp = INL(dev, addr); + u32 tmp = dc2114x_inl(dev, addr);
udelay(1); return tmp;
Move the functions in the driver around to better fit future DM conversion, drop function forward declarations. No functional change.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Joe Hershberger joe.hershberger@ni.com --- drivers/net/dc2114x.c | 736 ++++++++++++++++++++---------------------- 1 file changed, 357 insertions(+), 379 deletions(-)
diff --git a/drivers/net/dc2114x.c b/drivers/net/dc2114x.c index 2bbe4e5d60..9de9634cd5 100644 --- a/drivers/net/dc2114x.c +++ b/drivers/net/dc2114x.c @@ -79,6 +79,30 @@ #define phys_to_bus(a) pci_phys_to_mem((pci_dev_t)dev->priv, a) #endif
+#define NUM_RX_DESC PKTBUFSRX +#define NUM_TX_DESC 1 /* Number of TX descriptors */ +#define RX_BUFF_SZ PKTSIZE_ALIGN + +#define TOUT_LOOP 1000000 + +#define SETUP_FRAME_LEN 192 + +struct de4x5_desc { + volatile s32 status; + u32 des1; + u32 buf; + u32 next; +}; + +/* RX and TX descriptor ring */ +static struct de4x5_desc rx_ring[NUM_RX_DESC] __aligned(32); +static struct de4x5_desc tx_ring[NUM_TX_DESC] __aligned(32); +static int rx_new; /* RX descriptor ring pointer */ +static int tx_new; /* TX descriptor ring pointer */ + +static char rx_ring_size; +static char tx_ring_size; + static u32 dc2114x_inl(struct eth_device *dev, u32 addr) { return le32_to_cpu(*(volatile u32 *)(addr + dev->iobase)); @@ -126,191 +150,267 @@ static void stop_de4x5(struct eth_device *dev) dc2114x_outl(dev, omr, DE4X5_OMR); /* Disable the TX and/or RX */ }
-#define NUM_RX_DESC PKTBUFSRX -#define NUM_TX_DESC 1 /* Number of TX descriptors */ -#define RX_BUFF_SZ PKTSIZE_ALIGN - -#define TOUT_LOOP 1000000 +/* SROM Read and write routines. */ +static void sendto_srom(struct eth_device *dev, u_int command, u_long addr) +{ + dc2114x_outl(dev, command, addr); + udelay(1); +}
-#define SETUP_FRAME_LEN 192 +static int getfrom_srom(struct eth_device *dev, u_long addr) +{ + u32 tmp = dc2114x_inl(dev, addr);
-struct de4x5_desc { - volatile s32 status; - u32 des1; - u32 buf; - u32 next; -}; + udelay(1); + return tmp; +}
-/* RX and TX descriptor ring */ -static struct de4x5_desc rx_ring[NUM_RX_DESC] __aligned(32); -static struct de4x5_desc tx_ring[NUM_TX_DESC] __aligned(32); -static int rx_new; /* RX descriptor ring pointer */ -static int tx_new; /* TX descriptor ring pointer */ +/* Note: this routine returns extra data bits for size detection. */ +static int do_read_eeprom(struct eth_device *dev, u_long ioaddr, int location, + int addr_len) +{ + int read_cmd = location | (SROM_READ_CMD << addr_len); + unsigned int retval = 0; + int i;
-static char rx_ring_size; -static char tx_ring_size; + sendto_srom(dev, SROM_RD | SROM_SR, ioaddr); + sendto_srom(dev, SROM_RD | SROM_SR | DT_CS, ioaddr);
-static void sendto_srom(struct eth_device *dev, u_int command, u_long addr); -static int getfrom_srom(struct eth_device *dev, u_long addr); -static int do_eeprom_cmd(struct eth_device *dev, u_long ioaddr, - int cmd, int cmd_len); -static int do_read_eeprom(struct eth_device *dev, u_long ioaddr, - int location, int addr_len); -#ifdef UPDATE_SROM -static int write_srom(struct eth_device *dev, u_long ioaddr, - int index, int new_value); -static void update_srom(struct eth_device *dev, bd_t *bis); +#ifdef DEBUG_SROM + printf(" EEPROM read at %d ", location); #endif -static int read_srom(struct eth_device *dev, u_long ioaddr, int index); -static void read_hw_addr(struct eth_device *dev, bd_t *bis); -static void send_setup_frame(struct eth_device *dev, bd_t *bis);
-static int dc21x4x_init(struct eth_device *dev, bd_t *bis); -static int dc21x4x_send(struct eth_device *dev, void *packet, int length); -static int dc21x4x_recv(struct eth_device *dev); -static void dc21x4x_halt(struct eth_device *dev); + /* Shift the read command bits out. */ + for (i = 4 + addr_len; i >= 0; i--) { + short dataval = (read_cmd & (1 << i)) ? EE_DATA_WRITE : 0;
-static struct pci_device_id supported[] = { - { PCI_VENDOR_ID_DEC, PCI_DEVICE_ID_DEC_TULIP_FAST }, - { PCI_VENDOR_ID_DEC, PCI_DEVICE_ID_DEC_21142 }, - { } -}; + sendto_srom(dev, SROM_RD | SROM_SR | DT_CS | dataval, + ioaddr); + udelay(10); + sendto_srom(dev, SROM_RD | SROM_SR | DT_CS | dataval | DT_CLK, + ioaddr); + udelay(10); +#ifdef DEBUG_SROM2 + printf("%X", getfrom_srom(dev, ioaddr) & 15); +#endif + retval = (retval << 1) | + !!(getfrom_srom(dev, ioaddr) & EE_DATA_READ); + }
-int dc21x4x_initialize(bd_t *bis) -{ - struct eth_device *dev; - unsigned short status; - unsigned char timer; - unsigned int iobase; - int card_number = 0; - pci_dev_t devbusfn; - unsigned int cfrv; - int idx = 0; + sendto_srom(dev, SROM_RD | SROM_SR | DT_CS, ioaddr);
- while (1) { - devbusfn = pci_find_devices(supported, idx++); - if (devbusfn == -1) - break; +#ifdef DEBUG_SROM2 + printf(" :%X:", getfrom_srom(dev, ioaddr) & 15); +#endif
- /* Get the chip configuration revision register. */ - pci_read_config_dword(devbusfn, PCI_REVISION_ID, &cfrv); + for (i = 16; i > 0; i--) { + sendto_srom(dev, SROM_RD | SROM_SR | DT_CS | DT_CLK, ioaddr); + udelay(10); +#ifdef DEBUG_SROM2 + printf("%X", getfrom_srom(dev, ioaddr) & 15); +#endif + retval = (retval << 1) | + !!(getfrom_srom(dev, ioaddr) & EE_DATA_READ); + sendto_srom(dev, SROM_RD | SROM_SR | DT_CS, ioaddr); + udelay(10); + }
- if ((cfrv & CFRV_RN) < DC2114x_BRK) { - printf("Error: The chip is not DC21143.\n"); - continue; - } + /* Terminate the EEPROM access. */ + sendto_srom(dev, SROM_RD | SROM_SR, ioaddr);
- pci_read_config_word(devbusfn, PCI_COMMAND, &status); - status |= PCI_COMMAND_MEMORY | PCI_COMMAND_MASTER; - pci_write_config_word(devbusfn, PCI_COMMAND, status); +#ifdef DEBUG_SROM2 + printf(" EEPROM value at %d is %5.5x.\n", location, retval); +#endif
- pci_read_config_word(devbusfn, PCI_COMMAND, &status); - if (!(status & PCI_COMMAND_MEMORY)) { - printf("Error: Can not enable MEMORY access.\n"); - continue; - } + return retval; +}
- if (!(status & PCI_COMMAND_MASTER)) { - printf("Error: Can not enable Bus Mastering.\n"); - continue; - } +/* + * This executes a generic EEPROM command, typically a write or write + * enable. It returns the data output from the EEPROM, and thus may + * also be used for reads. + */ +static int do_eeprom_cmd(struct eth_device *dev, u_long ioaddr, int cmd, + int cmd_len) +{ + unsigned int retval = 0;
- /* Check the latency timer for values >= 0x60. */ - pci_read_config_byte(devbusfn, PCI_LATENCY_TIMER, &timer); +#ifdef DEBUG_SROM + printf(" EEPROM op 0x%x: ", cmd); +#endif
- if (timer < 0x60) { - pci_write_config_byte(devbusfn, PCI_LATENCY_TIMER, - 0x60); - } + sendto_srom(dev, SROM_RD | SROM_SR | DT_CS | DT_CLK, ioaddr);
- /* read BAR for memory space access */ - pci_read_config_dword(devbusfn, PCI_BASE_ADDRESS_1, &iobase); - iobase &= PCI_BASE_ADDRESS_MEM_MASK; - debug("dc21x4x: DEC 21142 PCI Device @0x%x\n", iobase); + /* Shift the command bits out. */ + do { + short dataval = (cmd & BIT(cmd_len)) ? EE_WRITE_1 : EE_WRITE_0;
- dev = (struct eth_device *)malloc(sizeof(*dev)); - if (!dev) { - printf("Can not allocalte memory of dc21x4x\n"); - break; - } + sendto_srom(dev, dataval, ioaddr); + udelay(10);
- memset(dev, 0, sizeof(*dev)); +#ifdef DEBUG_SROM2 + printf("%X", getfrom_srom(dev, ioaddr) & 15); +#endif
- sprintf(dev->name, "dc21x4x#%d", card_number); + sendto_srom(dev, dataval | DT_CLK, ioaddr); + udelay(10); + retval = (retval << 1) | + !!(getfrom_srom(dev, ioaddr) & EE_DATA_READ); + } while (--cmd_len >= 0);
- dev->iobase = pci_mem_to_phys(devbusfn, iobase); - dev->priv = (void *)devbusfn; - dev->init = dc21x4x_init; - dev->halt = dc21x4x_halt; - dev->send = dc21x4x_send; - dev->recv = dc21x4x_recv; + sendto_srom(dev, SROM_RD | SROM_SR | DT_CS, ioaddr);
- /* Ensure we're not sleeping. */ - pci_write_config_byte(devbusfn, PCI_CFDA_PSM, WAKEUP); + /* Terminate the EEPROM access. */ + sendto_srom(dev, SROM_RD | SROM_SR, ioaddr);
- udelay(10 * 1000); +#ifdef DEBUG_SROM + printf(" EEPROM result is 0x%5.5x.\n", retval); +#endif
- read_hw_addr(dev, bis); + return retval; +}
- eth_register(dev); +static int read_srom(struct eth_device *dev, u_long ioaddr, int index) +{ + int ee_addr_size;
- card_number++; - } + ee_addr_size = (do_read_eeprom(dev, ioaddr, 0xff, 8) & BIT(18)) ? 8 : 6;
- return card_number; + return do_eeprom_cmd(dev, ioaddr, 0xffff | + (((SROM_READ_CMD << ee_addr_size) | index) << 16), + 3 + ee_addr_size + 16); }
-static int dc21x4x_init(struct eth_device *dev, bd_t *bis) +#ifdef UPDATE_SROM +static int write_srom(struct eth_device *dev, u_long ioaddr, int index, + int new_value) { + unsigned short newval; + int ee_addr_size; int i; - int devbusfn = (int)dev->priv;
- /* Ensure we're not sleeping. */ - pci_write_config_byte(devbusfn, PCI_CFDA_PSM, WAKEUP); + ee_addr_size = (do_read_eeprom(dev, ioaddr, 0xff, 8) & BIT(18)) ? 8 : 6;
- reset_de4x5(dev); + udelay(10 * 1000); /* test-only */
- if (dc2114x_inl(dev, DE4X5_STS) & (STS_TS | STS_RS)) { - printf("Error: Cannot reset ethernet controller.\n"); - return -1; - } +#ifdef DEBUG_SROM + printf("ee_addr_size=%d.\n", ee_addr_size); + printf("Writing new entry 0x%4.4x to offset %d.\n", new_value, index); +#endif
- dc2114x_outl(dev, OMR_SDP | OMR_PS | OMR_PM, DE4X5_OMR); + /* Enable programming modes. */ + do_eeprom_cmd(dev, ioaddr, 0x4f << (ee_addr_size - 4), + 3 + ee_addr_size);
- for (i = 0; i < NUM_RX_DESC; i++) { - rx_ring[i].status = cpu_to_le32(R_OWN); - rx_ring[i].des1 = cpu_to_le32(RX_BUFF_SZ); - rx_ring[i].buf = - cpu_to_le32(phys_to_bus((u32)net_rx_packets[i])); - rx_ring[i].next = 0; + /* Do the actual write. */ + do_eeprom_cmd(dev, ioaddr, new_value | + (((SROM_WRITE_CMD << ee_addr_size) | index) << 16), + 3 + ee_addr_size + 16); + + /* Poll for write finished. */ + sendto_srom(dev, SROM_RD | SROM_SR | DT_CS, ioaddr); + for (i = 0; i < 10000; i++) { /* Typical 2000 ticks */ + if (getfrom_srom(dev, ioaddr) & EE_DATA_READ) + break; }
- for (i = 0; i < NUM_TX_DESC; i++) { - tx_ring[i].status = 0; - tx_ring[i].des1 = 0; - tx_ring[i].buf = 0; - tx_ring[i].next = 0; +#ifdef DEBUG_SROM + printf(" Write finished after %d ticks.\n", i); +#endif + + /* Disable programming. */ + do_eeprom_cmd(dev, ioaddr, (0x40 << (ee_addr_size - 4)), + 3 + ee_addr_size); + + /* And read the result. */ + newval = do_eeprom_cmd(dev, ioaddr, + (((SROM_READ_CMD << ee_addr_size) | index) << 16) + | 0xffff, 3 + ee_addr_size + 16); +#ifdef DEBUG_SROM + printf(" New value at offset %d is %4.4x.\n", index, newval); +#endif + + return 1; +} + +static void update_srom(struct eth_device *dev, bd_t *bis) +{ + static unsigned short eeprom[0x40] = { + 0x140b, 0x6610, 0x0000, 0x0000, /* 00 */ + 0x0000, 0x0000, 0x0000, 0x0000, /* 04 */ + 0x00a3, 0x0103, 0x0000, 0x0000, /* 08 */ + 0x0000, 0x1f00, 0x0000, 0x0000, /* 0c */ + 0x0108, 0x038d, 0x0000, 0x0000, /* 10 */ + 0xe078, 0x0001, 0x0040, 0x0018, /* 14 */ + 0x0000, 0x0000, 0x0000, 0x0000, /* 18 */ + 0x0000, 0x0000, 0x0000, 0x0000, /* 1c */ + 0x0000, 0x0000, 0x0000, 0x0000, /* 20 */ + 0x0000, 0x0000, 0x0000, 0x0000, /* 24 */ + 0x0000, 0x0000, 0x0000, 0x0000, /* 28 */ + 0x0000, 0x0000, 0x0000, 0x0000, /* 2c */ + 0x0000, 0x0000, 0x0000, 0x0000, /* 30 */ + 0x0000, 0x0000, 0x0000, 0x0000, /* 34 */ + 0x0000, 0x0000, 0x0000, 0x0000, /* 38 */ + 0x0000, 0x0000, 0x0000, 0x4e07, /* 3c */ + }; + uchar enetaddr[6]; + int i; + + /* Ethernet Addr... */ + if (!eth_env_get_enetaddr("ethaddr", enetaddr)) + return; + + eeprom[0x0a] = (enetaddr[1] << 8) | enetaddr[0]; + eeprom[0x0b] = (enetaddr[3] << 8) | enetaddr[2]; + eeprom[0x0c] = (enetaddr[5] << 8) | enetaddr[4]; + + for (i = 0; i < 0x40; i++) + write_srom(dev, DE4X5_APROM, i, eeprom[i]); +} +#endif /* UPDATE_SROM */ + +static void send_setup_frame(struct eth_device *dev, bd_t *bis) +{ + char setup_frame[SETUP_FRAME_LEN]; + char *pa = &setup_frame[0]; + int i; + + memset(pa, 0xff, SETUP_FRAME_LEN); + + for (i = 0; i < ETH_ALEN; i++) { + *(pa + (i & 1)) = dev->enetaddr[i]; + if (i & 0x01) + pa += 4; }
- rx_ring_size = NUM_RX_DESC; - tx_ring_size = NUM_TX_DESC; + for (i = 0; tx_ring[tx_new].status & cpu_to_le32(T_OWN); i++) { + if (i < TOUT_LOOP) + continue;
- /* Write the end of list marker to the descriptor lists. */ - rx_ring[rx_ring_size - 1].des1 |= cpu_to_le32(RD_RER); - tx_ring[tx_ring_size - 1].des1 |= cpu_to_le32(TD_TER); + printf("%s: tx error buffer not ready\n", dev->name); + return; + }
- /* Tell the adapter where the TX/RX rings are located. */ - dc2114x_outl(dev, phys_to_bus((u32)&rx_ring), DE4X5_RRBA); - dc2114x_outl(dev, phys_to_bus((u32)&tx_ring), DE4X5_TRBA); + tx_ring[tx_new].buf = cpu_to_le32(phys_to_bus((u32)&setup_frame[0])); + tx_ring[tx_new].des1 = cpu_to_le32(TD_TER | TD_SET | SETUP_FRAME_LEN); + tx_ring[tx_new].status = cpu_to_le32(T_OWN);
- start_de4x5(dev); + dc2114x_outl(dev, POLL_DEMAND, DE4X5_TPD);
- tx_new = 0; - rx_new = 0; + for (i = 0; tx_ring[tx_new].status & cpu_to_le32(T_OWN); i++) { + if (i < TOUT_LOOP) + continue;
- send_setup_frame(dev, bis); + printf("%s: tx buffer not ready\n", dev->name); + return; + }
- return 0; + if (le32_to_cpu(tx_ring[tx_new].status) != 0x7FFFFFFF) { + printf("TX error status2 = 0x%08X\n", + le32_to_cpu(tx_ring[tx_new].status)); + } + + tx_new = (tx_new + 1) % NUM_TX_DESC; }
static int dc21x4x_send(struct eth_device *dev, void *packet, int length) @@ -397,297 +497,175 @@ static int dc21x4x_recv(struct eth_device *dev) return length; }
-static void dc21x4x_halt(struct eth_device *dev) +static int dc21x4x_init(struct eth_device *dev, bd_t *bis) { + int i; int devbusfn = (int)dev->priv;
- stop_de4x5(dev); - dc2114x_outl(dev, 0, DE4X5_SICR); + /* Ensure we're not sleeping. */ + pci_write_config_byte(devbusfn, PCI_CFDA_PSM, WAKEUP);
- pci_write_config_byte(devbusfn, PCI_CFDA_PSM, SLEEP); -} + reset_de4x5(dev);
-static void send_setup_frame(struct eth_device *dev, bd_t *bis) -{ - char setup_frame[SETUP_FRAME_LEN]; - char *pa = &setup_frame[0]; - int i; + if (dc2114x_inl(dev, DE4X5_STS) & (STS_TS | STS_RS)) { + printf("Error: Cannot reset ethernet controller.\n"); + return -1; + }
- memset(pa, 0xff, SETUP_FRAME_LEN); + dc2114x_outl(dev, OMR_SDP | OMR_PS | OMR_PM, DE4X5_OMR);
- for (i = 0; i < ETH_ALEN; i++) { - *(pa + (i & 1)) = dev->enetaddr[i]; - if (i & 0x01) - pa += 4; + for (i = 0; i < NUM_RX_DESC; i++) { + rx_ring[i].status = cpu_to_le32(R_OWN); + rx_ring[i].des1 = cpu_to_le32(RX_BUFF_SZ); + rx_ring[i].buf = + cpu_to_le32(phys_to_bus((u32)net_rx_packets[i])); + rx_ring[i].next = 0; }
- for (i = 0; tx_ring[tx_new].status & cpu_to_le32(T_OWN); i++) { - if (i < TOUT_LOOP) - continue; - - printf("%s: tx error buffer not ready\n", dev->name); - return; + for (i = 0; i < NUM_TX_DESC; i++) { + tx_ring[i].status = 0; + tx_ring[i].des1 = 0; + tx_ring[i].buf = 0; + tx_ring[i].next = 0; }
- tx_ring[tx_new].buf = cpu_to_le32(phys_to_bus((u32)&setup_frame[0])); - tx_ring[tx_new].des1 = cpu_to_le32(TD_TER | TD_SET | SETUP_FRAME_LEN); - tx_ring[tx_new].status = cpu_to_le32(T_OWN); + rx_ring_size = NUM_RX_DESC; + tx_ring_size = NUM_TX_DESC;
- dc2114x_outl(dev, POLL_DEMAND, DE4X5_TPD); + /* Write the end of list marker to the descriptor lists. */ + rx_ring[rx_ring_size - 1].des1 |= cpu_to_le32(RD_RER); + tx_ring[tx_ring_size - 1].des1 |= cpu_to_le32(TD_TER);
- for (i = 0; tx_ring[tx_new].status & cpu_to_le32(T_OWN); i++) { - if (i < TOUT_LOOP) - continue; + /* Tell the adapter where the TX/RX rings are located. */ + dc2114x_outl(dev, phys_to_bus((u32)&rx_ring), DE4X5_RRBA); + dc2114x_outl(dev, phys_to_bus((u32)&tx_ring), DE4X5_TRBA);
- printf("%s: tx buffer not ready\n", dev->name); - return; - } + start_de4x5(dev);
- if (le32_to_cpu(tx_ring[tx_new].status) != 0x7FFFFFFF) { - printf("TX error status2 = 0x%08X\n", - le32_to_cpu(tx_ring[tx_new].status)); - } + tx_new = 0; + rx_new = 0;
- tx_new = (tx_new + 1) % NUM_TX_DESC; -} + send_setup_frame(dev, bis);
-/* SROM Read and write routines. */ -static void sendto_srom(struct eth_device *dev, u_int command, u_long addr) -{ - dc2114x_outl(dev, command, addr); - udelay(1); + return 0; }
-static int getfrom_srom(struct eth_device *dev, u_long addr) +static void dc21x4x_halt(struct eth_device *dev) { - u32 tmp = dc2114x_inl(dev, addr); + int devbusfn = (int)dev->priv;
- udelay(1); - return tmp; + stop_de4x5(dev); + dc2114x_outl(dev, 0, DE4X5_SICR); + + pci_write_config_byte(devbusfn, PCI_CFDA_PSM, SLEEP); }
-/* Note: this routine returns extra data bits for size detection. */ -static int do_read_eeprom(struct eth_device *dev, u_long ioaddr, int location, - int addr_len) +static void read_hw_addr(struct eth_device *dev, bd_t *bis) { - int read_cmd = location | (SROM_READ_CMD << addr_len); - unsigned int retval = 0; - int i; - - sendto_srom(dev, SROM_RD | SROM_SR, ioaddr); - sendto_srom(dev, SROM_RD | SROM_SR | DT_CS, ioaddr); - -#ifdef DEBUG_SROM - printf(" EEPROM read at %d ", location); -#endif - - /* Shift the read command bits out. */ - for (i = 4 + addr_len; i >= 0; i--) { - short dataval = (read_cmd & (1 << i)) ? EE_DATA_WRITE : 0; + u_short tmp, *p = (u_short *)(&dev->enetaddr[0]); + int i, j = 0;
- sendto_srom(dev, SROM_RD | SROM_SR | DT_CS | dataval, - ioaddr); - udelay(10); - sendto_srom(dev, SROM_RD | SROM_SR | DT_CS | dataval | DT_CLK, - ioaddr); - udelay(10); -#ifdef DEBUG_SROM2 - printf("%X", getfrom_srom(dev, ioaddr) & 15); -#endif - retval = (retval << 1) | - !!(getfrom_srom(dev, ioaddr) & EE_DATA_READ); + for (i = 0; i < (ETH_ALEN >> 1); i++) { + tmp = read_srom(dev, DE4X5_APROM, (SROM_HWADD >> 1) + i); + *p = le16_to_cpu(tmp); + j += *p++; }
- sendto_srom(dev, SROM_RD | SROM_SR | DT_CS, ioaddr); - -#ifdef DEBUG_SROM2 - printf(" :%X:", getfrom_srom(dev, ioaddr) & 15); -#endif - - for (i = 16; i > 0; i--) { - sendto_srom(dev, SROM_RD | SROM_SR | DT_CS | DT_CLK, ioaddr); - udelay(10); -#ifdef DEBUG_SROM2 - printf("%X", getfrom_srom(dev, ioaddr) & 15); + if (!j || j == 0x2fffd) { + memset(dev->enetaddr, 0, ETH_ALEN); + debug("Warning: can't read HW address from SROM.\n"); +#ifdef UPDATE_SROM + update_srom(dev, bis); #endif - retval = (retval << 1) | - !!(getfrom_srom(dev, ioaddr) & EE_DATA_READ); - sendto_srom(dev, SROM_RD | SROM_SR | DT_CS, ioaddr); - udelay(10); } - - /* Terminate the EEPROM access. */ - sendto_srom(dev, SROM_RD | SROM_SR, ioaddr); - -#ifdef DEBUG_SROM2 - printf(" EEPROM value at %d is %5.5x.\n", location, retval); -#endif - - return retval; }
-/* - * This executes a generic EEPROM command, typically a write or write - * enable. It returns the data output from the EEPROM, and thus may - * also be used for reads. - */ -static int do_eeprom_cmd(struct eth_device *dev, u_long ioaddr, int cmd, - int cmd_len) -{ - unsigned int retval = 0; - -#ifdef DEBUG_SROM - printf(" EEPROM op 0x%x: ", cmd); -#endif - - sendto_srom(dev, SROM_RD | SROM_SR | DT_CS | DT_CLK, ioaddr); - - /* Shift the command bits out. */ - do { - short dataval = (cmd & BIT(cmd_len)) ? EE_WRITE_1 : EE_WRITE_0; - - sendto_srom(dev, dataval, ioaddr); - udelay(10); - -#ifdef DEBUG_SROM2 - printf("%X", getfrom_srom(dev, ioaddr) & 15); -#endif - - sendto_srom(dev, dataval | DT_CLK, ioaddr); - udelay(10); - retval = (retval << 1) | - !!(getfrom_srom(dev, ioaddr) & EE_DATA_READ); - } while (--cmd_len >= 0); - - sendto_srom(dev, SROM_RD | SROM_SR | DT_CS, ioaddr); - - /* Terminate the EEPROM access. */ - sendto_srom(dev, SROM_RD | SROM_SR, ioaddr); - -#ifdef DEBUG_SROM - printf(" EEPROM result is 0x%5.5x.\n", retval); -#endif - - return retval; -} +static struct pci_device_id supported[] = { + { PCI_VENDOR_ID_DEC, PCI_DEVICE_ID_DEC_TULIP_FAST }, + { PCI_VENDOR_ID_DEC, PCI_DEVICE_ID_DEC_21142 }, + { } +};
-static int read_srom(struct eth_device *dev, u_long ioaddr, int index) +int dc21x4x_initialize(bd_t *bis) { - int ee_addr_size; - - ee_addr_size = (do_read_eeprom(dev, ioaddr, 0xff, 8) & BIT(18)) ? 8 : 6; + struct eth_device *dev; + unsigned short status; + unsigned char timer; + unsigned int iobase; + int card_number = 0; + pci_dev_t devbusfn; + unsigned int cfrv; + int idx = 0;
- return do_eeprom_cmd(dev, ioaddr, 0xffff | - (((SROM_READ_CMD << ee_addr_size) | index) << 16), - 3 + ee_addr_size + 16); -} + while (1) { + devbusfn = pci_find_devices(supported, idx++); + if (devbusfn == -1) + break;
-#ifdef UPDATE_SROM -static int write_srom(struct eth_device *dev, u_long ioaddr, int index, - int new_value) -{ - unsigned short newval; - int ee_addr_size; - int i; + /* Get the chip configuration revision register. */ + pci_read_config_dword(devbusfn, PCI_REVISION_ID, &cfrv);
- ee_addr_size = (do_read_eeprom(dev, ioaddr, 0xff, 8) & BIT(18)) ? 8 : 6; + if ((cfrv & CFRV_RN) < DC2114x_BRK) { + printf("Error: The chip is not DC21143.\n"); + continue; + }
- udelay(10 * 1000); /* test-only */ + pci_read_config_word(devbusfn, PCI_COMMAND, &status); + status |= PCI_COMMAND_MEMORY | PCI_COMMAND_MASTER; + pci_write_config_word(devbusfn, PCI_COMMAND, status);
-#ifdef DEBUG_SROM - printf("ee_addr_size=%d.\n", ee_addr_size); - printf("Writing new entry 0x%4.4x to offset %d.\n", new_value, index); -#endif + pci_read_config_word(devbusfn, PCI_COMMAND, &status); + if (!(status & PCI_COMMAND_MEMORY)) { + printf("Error: Can not enable MEMORY access.\n"); + continue; + }
- /* Enable programming modes. */ - do_eeprom_cmd(dev, ioaddr, 0x4f << (ee_addr_size - 4), - 3 + ee_addr_size); + if (!(status & PCI_COMMAND_MASTER)) { + printf("Error: Can not enable Bus Mastering.\n"); + continue; + }
- /* Do the actual write. */ - do_eeprom_cmd(dev, ioaddr, new_value | - (((SROM_WRITE_CMD << ee_addr_size) | index) << 16), - 3 + ee_addr_size + 16); + /* Check the latency timer for values >= 0x60. */ + pci_read_config_byte(devbusfn, PCI_LATENCY_TIMER, &timer);
- /* Poll for write finished. */ - sendto_srom(dev, SROM_RD | SROM_SR | DT_CS, ioaddr); - for (i = 0; i < 10000; i++) { /* Typical 2000 ticks */ - if (getfrom_srom(dev, ioaddr) & EE_DATA_READ) - break; - } + if (timer < 0x60) { + pci_write_config_byte(devbusfn, PCI_LATENCY_TIMER, + 0x60); + }
-#ifdef DEBUG_SROM - printf(" Write finished after %d ticks.\n", i); -#endif + /* read BAR for memory space access */ + pci_read_config_dword(devbusfn, PCI_BASE_ADDRESS_1, &iobase); + iobase &= PCI_BASE_ADDRESS_MEM_MASK; + debug("dc21x4x: DEC 21142 PCI Device @0x%x\n", iobase);
- /* Disable programming. */ - do_eeprom_cmd(dev, ioaddr, (0x40 << (ee_addr_size - 4)), - 3 + ee_addr_size); + dev = (struct eth_device *)malloc(sizeof(*dev)); + if (!dev) { + printf("Can not allocalte memory of dc21x4x\n"); + break; + }
- /* And read the result. */ - newval = do_eeprom_cmd(dev, ioaddr, - (((SROM_READ_CMD << ee_addr_size) | index) << 16) - | 0xffff, 3 + ee_addr_size + 16); -#ifdef DEBUG_SROM - printf(" New value at offset %d is %4.4x.\n", index, newval); -#endif + memset(dev, 0, sizeof(*dev));
- return 1; -} -#endif + sprintf(dev->name, "dc21x4x#%d", card_number);
-static void read_hw_addr(struct eth_device *dev, bd_t *bis) -{ - u_short tmp, *p = (u_short *)(&dev->enetaddr[0]); - int i, j = 0; + dev->iobase = pci_mem_to_phys(devbusfn, iobase); + dev->priv = (void *)devbusfn; + dev->init = dc21x4x_init; + dev->halt = dc21x4x_halt; + dev->send = dc21x4x_send; + dev->recv = dc21x4x_recv;
- for (i = 0; i < (ETH_ALEN >> 1); i++) { - tmp = read_srom(dev, DE4X5_APROM, (SROM_HWADD >> 1) + i); - *p = le16_to_cpu(tmp); - j += *p++; - } + /* Ensure we're not sleeping. */ + pci_write_config_byte(devbusfn, PCI_CFDA_PSM, WAKEUP);
- if (!j || j == 0x2fffd) { - memset(dev->enetaddr, 0, ETH_ALEN); - debug("Warning: can't read HW address from SROM.\n"); -#ifdef UPDATE_SROM - update_srom(dev, bis); -#endif - } -} + udelay(10 * 1000);
-#ifdef UPDATE_SROM -static void update_srom(struct eth_device *dev, bd_t *bis) -{ - static unsigned short eeprom[0x40] = { - 0x140b, 0x6610, 0x0000, 0x0000, /* 00 */ - 0x0000, 0x0000, 0x0000, 0x0000, /* 04 */ - 0x00a3, 0x0103, 0x0000, 0x0000, /* 08 */ - 0x0000, 0x1f00, 0x0000, 0x0000, /* 0c */ - 0x0108, 0x038d, 0x0000, 0x0000, /* 10 */ - 0xe078, 0x0001, 0x0040, 0x0018, /* 14 */ - 0x0000, 0x0000, 0x0000, 0x0000, /* 18 */ - 0x0000, 0x0000, 0x0000, 0x0000, /* 1c */ - 0x0000, 0x0000, 0x0000, 0x0000, /* 20 */ - 0x0000, 0x0000, 0x0000, 0x0000, /* 24 */ - 0x0000, 0x0000, 0x0000, 0x0000, /* 28 */ - 0x0000, 0x0000, 0x0000, 0x0000, /* 2c */ - 0x0000, 0x0000, 0x0000, 0x0000, /* 30 */ - 0x0000, 0x0000, 0x0000, 0x0000, /* 34 */ - 0x0000, 0x0000, 0x0000, 0x0000, /* 38 */ - 0x0000, 0x0000, 0x0000, 0x4e07, /* 3c */ - }; - uchar enetaddr[6]; - int i; + read_hw_addr(dev, bis);
- /* Ethernet Addr... */ - if (!eth_env_get_enetaddr("ethaddr", enetaddr)) - return; + eth_register(dev);
- eeprom[0x0a] = (enetaddr[1] << 8) | enetaddr[0]; - eeprom[0x0b] = (enetaddr[3] << 8) | enetaddr[2]; - eeprom[0x0c] = (enetaddr[5] << 8) | enetaddr[4]; + card_number++; + }
- for (i = 0; i < 0x40; i++) - write_srom(dev, DE4X5_APROM, i, eeprom[i]); + return card_number; } -#endif /* UPDATE_SROM */
Replace the adhoc debugging ifdeffery with debug_cond() and an internal SROM_DEBUG macro to select the debug level.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Joe Hershberger joe.hershberger@ni.com --- drivers/net/dc2114x.c | 57 ++++++++++++++++--------------------------- 1 file changed, 21 insertions(+), 36 deletions(-)
diff --git a/drivers/net/dc2114x.c b/drivers/net/dc2114x.c index 9de9634cd5..d008696b0f 100644 --- a/drivers/net/dc2114x.c +++ b/drivers/net/dc2114x.c @@ -7,8 +7,7 @@ #include <netdev.h> #include <pci.h>
-#undef DEBUG_SROM -#undef DEBUG_SROM2 +#define SROM_DLEVEL 0
#undef UPDATE_SROM
@@ -176,9 +175,7 @@ static int do_read_eeprom(struct eth_device *dev, u_long ioaddr, int location, sendto_srom(dev, SROM_RD | SROM_SR, ioaddr); sendto_srom(dev, SROM_RD | SROM_SR | DT_CS, ioaddr);
-#ifdef DEBUG_SROM - printf(" EEPROM read at %d ", location); -#endif + debug_cond(SROM_DLEVEL >= 1, " EEPROM read at %d ", location);
/* Shift the read command bits out. */ for (i = 4 + addr_len; i >= 0; i--) { @@ -190,25 +187,21 @@ static int do_read_eeprom(struct eth_device *dev, u_long ioaddr, int location, sendto_srom(dev, SROM_RD | SROM_SR | DT_CS | dataval | DT_CLK, ioaddr); udelay(10); -#ifdef DEBUG_SROM2 - printf("%X", getfrom_srom(dev, ioaddr) & 15); -#endif + debug_cond(SROM_DLEVEL >= 2, "%X", + getfrom_srom(dev, ioaddr) & 15); retval = (retval << 1) | !!(getfrom_srom(dev, ioaddr) & EE_DATA_READ); }
-#ifdef DEBUG_SROM2 - printf(" :%X:", getfrom_srom(dev, ioaddr) & 15); -#endif + debug_cond(SROM_DLEVEL >= 2, " :%X:", getfrom_srom(dev, ioaddr) & 15);
for (i = 16; i > 0; i--) { sendto_srom(dev, SROM_RD | SROM_SR | DT_CS | DT_CLK, ioaddr); udelay(10); -#ifdef DEBUG_SROM2 - printf("%X", getfrom_srom(dev, ioaddr) & 15); -#endif + debug_cond(SROM_DLEVEL >= 2, "%X", + getfrom_srom(dev, ioaddr) & 15); retval = (retval << 1) | !!(getfrom_srom(dev, ioaddr) & EE_DATA_READ); sendto_srom(dev, SROM_RD | SROM_SR | DT_CS, ioaddr); @@ -218,9 +211,8 @@ static int do_read_eeprom(struct eth_device *dev, u_long ioaddr, int location, /* Terminate the EEPROM access. */ sendto_srom(dev, SROM_RD | SROM_SR, ioaddr);
-#ifdef DEBUG_SROM2 - printf(" EEPROM value at %d is %5.5x.\n", location, retval); -#endif + debug_cond(SROM_DLEVEL >= 2, " EEPROM value at %d is %5.5x.\n", + location, retval);
return retval; } @@ -235,9 +227,7 @@ static int do_eeprom_cmd(struct eth_device *dev, u_long ioaddr, int cmd, { unsigned int retval = 0;
-#ifdef DEBUG_SROM - printf(" EEPROM op 0x%x: ", cmd); -#endif + debug_cond(SROM_DLEVEL >= 1, " EEPROM op 0x%x: ", cmd);
@@ -248,9 +238,8 @@ static int do_eeprom_cmd(struct eth_device *dev, u_long ioaddr, int cmd, sendto_srom(dev, dataval, ioaddr); udelay(10);
sendto_srom(dev, dataval | DT_CLK, ioaddr); udelay(10); @@ -263,9 +252,7 @@ static int do_eeprom_cmd(struct eth_device *dev, u_long ioaddr, int cmd, /* Terminate the EEPROM access. */ sendto_srom(dev, SROM_RD | SROM_SR, ioaddr);
-#ifdef DEBUG_SROM - printf(" EEPROM result is 0x%5.5x.\n", retval); -#endif + debug_cond(SROM_DLEVEL >= 1, " EEPROM result is 0x%5.5x.\n", retval);
return retval; } @@ -293,10 +280,10 @@ static int write_srom(struct eth_device *dev, u_long ioaddr, int index,
-#ifdef DEBUG_SROM - printf("ee_addr_size=%d.\n", ee_addr_size); - printf("Writing new entry 0x%4.4x to offset %d.\n", new_value, index); -#endif + debug_cond(SROM_DLEVEL >= 1, "ee_addr_size=%d.\n", ee_addr_size); + debug_cond(SROM_DLEVEL >= 1, + "Writing new entry 0x%4.4x to offset %d.\n", + new_value, index);
/* Enable programming modes. */ do_eeprom_cmd(dev, ioaddr, 0x4f << (ee_addr_size - 4), @@ -314,9 +301,7 @@ static int write_srom(struct eth_device *dev, u_long ioaddr, int index, break; }
-#ifdef DEBUG_SROM - printf(" Write finished after %d ticks.\n", i); -#endif + debug_cond(SROM_DLEVEL >= 1, " Write finished after %d ticks.\n", i);
/* Disable programming. */ do_eeprom_cmd(dev, ioaddr, (0x40 << (ee_addr_size - 4)), @@ -326,9 +311,9 @@ static int write_srom(struct eth_device *dev, u_long ioaddr, int index, newval = do_eeprom_cmd(dev, ioaddr, (((SROM_READ_CMD << ee_addr_size) | index) << 16) | 0xffff, 3 + ee_addr_size + 16); -#ifdef DEBUG_SROM - printf(" New value at offset %d is %4.4x.\n", index, newval); -#endif + + debug_cond(SROM_DLEVEL >= 1, " New value at offset %d is %4.4x.\n", + index, newval);
return 1; }
