[U-Boot] [PATCH v3] i.MX6: nand: extend nandbcb command for imx6UL(L)
Firmware Configuration Block(FCB) for imx6ul(l) needs to be BCH encoded.
Signed-off-by: Parthiban Nallathambi pn@denx.de Acked-by: Shyam Saini shyam.saini@amarulasolutions.com Acked-by: Peng Fan peng.fan@nxp.com ---
Notes: Notes: Changes in v3: - Conditionally include BCH both in Kconfig and source Changes in v2: - use kfree instead of free
arch/arm/mach-imx/Kconfig | 1 + arch/arm/mach-imx/cmd_nandbcb.c | 69 +++++++++++++++++++++++++++++++++ 2 files changed, 70 insertions(+)
diff --git a/arch/arm/mach-imx/Kconfig b/arch/arm/mach-imx/Kconfig index b0b9d2c070..4a2f39b110 100644 --- a/arch/arm/mach-imx/Kconfig +++ b/arch/arm/mach-imx/Kconfig @@ -81,6 +81,7 @@ config CMD_HDMIDETECT config CMD_NANDBCB bool "i.MX6 NAND Boot Control Block(BCB) command" depends on NAND && CMD_MTDPARTS + select BCH if MX6UL || MX6ULL default y if ARCH_MX6 && NAND_MXS help Unlike normal 'nand write/erase' commands, this command update diff --git a/arch/arm/mach-imx/cmd_nandbcb.c b/arch/arm/mach-imx/cmd_nandbcb.c index 7811c61d22..1a2e017aaf 100644 --- a/arch/arm/mach-imx/cmd_nandbcb.c +++ b/arch/arm/mach-imx/cmd_nandbcb.c @@ -14,6 +14,7 @@
#include <asm/io.h> #include <jffs2/jffs2.h> +#include <linux/bch.h> #include <linux/mtd/mtd.h>
#include <asm/mach-imx/imx-nandbcb.h> @@ -25,6 +26,68 @@ #define BF_VAL(v, bf) (((v) & bf##_MASK) >> bf##_OFFSET) #define GETBIT(v, n) (((v) >> (n)) & 0x1)
+#if defined(CONFIG_MX6UL) || defined(CONFIG_MX6ULL) +static uint8_t reverse_bit(uint8_t b) +{ + b = (b & 0xf0) >> 4 | (b & 0x0f) << 4; + b = (b & 0xcc) >> 2 | (b & 0x33) << 2; + b = (b & 0xaa) >> 1 | (b & 0x55) << 1; + + return b; +} + +static void encode_bch_ecc(void *buf, struct fcb_block *fcb, int eccbits) +{ + int i, j, m = 13; + int blocksize = 128; + int numblocks = 8; + int ecc_buf_size = (m * eccbits + 7) / 8; + struct bch_control *bch = init_bch(m, eccbits, 0); + u8 *ecc_buf = kzalloc(ecc_buf_size, GFP_KERNEL); + u8 *tmp_buf = kzalloc(blocksize * numblocks, GFP_KERNEL); + u8 *psrc, *pdst; + + /* + * The blocks here are bit aligned. If eccbits is a multiple of 8, + * we just can copy bytes. Otherwiese we must move the blocks to + * the next free bit position. + */ + WARN_ON(eccbits % 8); + + memcpy(tmp_buf, fcb, sizeof(*fcb)); + + for (i = 0; i < numblocks; i++) { + memset(ecc_buf, 0, ecc_buf_size); + psrc = tmp_buf + i * blocksize; + pdst = buf + i * (blocksize + ecc_buf_size); + + /* copy data byte aligned to destination buf */ + memcpy(pdst, psrc, blocksize); + + /* + * imx-kobs use a modified encode_bch which reverse the + * bit order of the data before calculating bch. + * Do this in the buffer and use the bch lib here. + */ + for (j = 0; j < blocksize; j++) + psrc[j] = reverse_bit(psrc[j]); + + encode_bch(bch, psrc, blocksize, ecc_buf); + + /* reverse ecc bit */ + for (j = 0; j < ecc_buf_size; j++) + ecc_buf[j] = reverse_bit(ecc_buf[j]); + + /* Here eccbuf is byte aligned and we can just copy it */ + memcpy(pdst + blocksize, ecc_buf, ecc_buf_size); + } + + kfree(ecc_buf); + kfree(tmp_buf); + free_bch(bch); +} +#else + static u8 calculate_parity_13_8(u8 d) { u8 p = 0; @@ -50,6 +113,7 @@ static void encode_hamming_13_8(void *_src, void *_ecc, size_t size) for (i = 0; i < size; i++) ecc[i] = calculate_parity_13_8(src[i]); } +#endif
static u32 calc_chksum(void *buf, size_t size) { @@ -231,8 +295,13 @@ static int nandbcb_update(struct mtd_info *mtd, loff_t off, size_t size, goto dbbt_data_page_err; }
+#if defined(CONFIG_MX6UL) || defined(CONFIG_MX6ULL) + /* 40 bit BCH, for i.MX6UL(L) */ + encode_bch_ecc(fcb_raw_page + 32, fcb, 40); +#else memcpy(fcb_raw_page + 12, fcb, sizeof(struct fcb_block)); encode_hamming_13_8(fcb_raw_page + 12, fcb_raw_page + 12 + 512, 512); +#endif /* * Set the first and second byte of OOB data to 0xFF, not 0x00. These * bytes are used as the Manufacturers Bad Block Marker (MBBM). Since
Firmware Configuration Block(FCB) for imx6ul(l) needs to be BCH encoded. Signed-off-by: Parthiban Nallathambi pn@denx.de Acked-by: Shyam Saini shyam.saini@amarulasolutions.com Acked-by: Peng Fan peng.fan@nxp.com
Best regards, Stefano Babic
sbabic@denx.de
