[U-Boot] [PATCH] sf: set the Uniform Sector to CR3NV instead of CR3V
Set the flash to Uniform Sector Architecture in the non-volatile register. After the power cycle, it's also Uniform Sector Architecture.
Signed-off-by: Mingkai Hu mingkai.hu@nxp.com Signed-off-by: Gong Qianyu Qianyu.Gong@nxp.com
diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index 64d4e0f..366c362 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -975,7 +975,7 @@ int spi_flash_decode_fdt(const void *blob, struct spi_flash *flash) static int spansion_s25fss_disable_4KB_erase(struct spi_slave *spi) { u8 cmd[4]; - u32 offset = 0x800004; /* CR3V register offset */ + u32 offset = 0x4; /* CR3NV register offset */ u8 cr3v; int ret;
Hi
spi_flash *flash)
I have already tested it and I have in my tree. I don't think that should be mandatory in general
Michael
-- 2.1.0.27.g96db324
From: Michael Trimarchi [mailto:michael@amarulasolutions.com] Sent: Thursday, June 30, 2016 2:50 PM To: Qianyu Gong Cc: Mingkai Hu; u-boot@lists.denx.de; Yunhui Cui; jteki@openedev.com Subject: Re: [U-Boot] [PATCH] sf: set the Uniform Sector to CR3NV instead of CR3V
Hi
On Jun 30, 2016 08:47, "Gong Qianyu" <Qianyu.Gong@nxp.commailto:Qianyu.Gong@nxp.com> wrote:
From: Mingkai Hu <mingkai.hu@nxp.commailto:mingkai.hu@nxp.com>
Signed-off-by: Mingkai Hu <mingkai.hu@nxp.commailto:mingkai.hu@nxp.com> Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.commailto:Qianyu.Gong@nxp.com>
What does this mean?
The general code doesn’t handle different sector operation, so need to set it as uniform sector architecture.
Michael
U-Boot mailing list U-Boot@lists.denx.demailto:U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Hi
Hi
And what about board that does not use the flash in uboot but manage in some other way. I'm not saying that is wrong but I don't know if this setting must be no-volatile. Is it something connected from booting on QSPI?
Michael
Michael
-----Original Message----- From: Michael Trimarchi [mailto:michael@amarulasolutions.com] Sent: Thursday, June 30, 2016 3:33 PM To: Mingkai Hu Cc: Qianyu Gong; u-boot@lists.denx.de; Yunhui Cui; jteki@openedev.com Subject: Re: [U-Boot] [PATCH] sf: set the Uniform Sector to CR3NV instead of CR3V
Hi
Hi
If it was not used as uniform sector architecture, the spansion_s25fss_disable_4KB_erase should not be called, correct?
Thanks, Mingkai
-- | Michael Nazzareno Trimarchi Amarula Solutions BV | | COO - Founder Cruquiuskade 47 | | +31(0)851119172 Amsterdam 1018 AM NL | | [`as] http://www.amarulasolutions.com |
Hi
Hi
Hi
Ok, understand what you mean. You should just probe one time during development and if you probe means that you want it configured.
Anyway as I said I have it in my tree. So I was just asking about permanent setting
Michael
Thanks, Mingkai
-----Original Message----- From: Michael Trimarchi [mailto:michael@amarulasolutions.com] Sent: Thursday, June 30, 2016 3:47 PM To: Mingkai Hu Cc: Qianyu Gong; u-boot@lists.denx.de; Yunhui Cui; jteki@openedev.com Subject: Re: [U-Boot] [PATCH] sf: set the Uniform Sector to CR3NV instead of CR3V
Hi
Hi
Hi
QSPI?
Yes, and if probed but not using the uniform sector, need to add the code to handle different sectors operation and do not call the function on_s25fss_disable_4KB_erase.
Michael
Thanks, Mingkai
Gong Qianyu
Michael Trimarchi
Mingkai Hu
