Re: [PATCH v3 2/2] riscv: timer: Add support for an early timer
From: Pragnesh Patel [mailto:pragnesh.patel@sifive.com] Sent: Sunday, January 10, 2021 8:43 PM To: u-boot@lists.denx.de Cc: atish.patra@wdc.com; palmerdabbelt@google.com; bmeng.cn@gmail.com; paul.walmsley@sifive.com; anup.patel@wdc.com; sagar.kadam@sifive.com; Rick Jian-Zhi Chen(陳建志); Pragnesh Patel; Palmer Dabbelt; Sean Anderson; Simon Glass Subject: [PATCH v3 2/2] riscv: timer: Add support for an early timer
Added support for timer_early_get_count() and timer_early_get_rate() This is mostly useful in tracing.
Signed-off-by: Pragnesh Patel pragnesh.patel@sifive.com
Changes in v3:
- Add IS_ENABLED(CONFIG_TIMER_EARLY) for timer_early_get_rate() and timer_early_get_count() functions.
Reviewed-by: Rick Chen rick@andestech.com
Hi Pragnesh
Changes in v3:
I am trying to merge to mainline, but it conflict with master. Please rebase again,
Applying: trace: select TIMER_EARLY to avoid infinite recursion Applying: riscv: timer: Add support for an early timer error: patch failed: drivers/timer/andes_plmt_timer.c:17 error: drivers/timer/andes_plmt_timer.c: patch does not apply error: patch failed: drivers/timer/sifive_clint_timer.c:14 error: drivers/timer/sifive_clint_timer.c: patch does not apply Patch failed at 0002 riscv: timer: Add support for an early timer The copy of the patch that failed is found in: .git/rebase-apply/patch When you have resolved this problem, run "git am --continue". If you prefer to skip this patch, run "git am --skip" instead. To restore the original branch and stop patching, run "git am --abort".
Thanks, Rick
Hi Rick
On Tue, Jan 12, 2021 at 7:30 AM Rick Chen rickchen36@gmail.com wrote:
Hi Pragnesh
Changes in v3:
Will rebase and send again.
Thanks, Rick
Pragnesh Patel
Rick Chen
