[U-Boot-Users] [PATCH] Add .gitignore files
Add various .gitignore files for all of the generated targets. This prevents these files from being accidentally committed and showing up in git-status.
Signed-off-by: Timur Tabi timur@freescale.com --- .gitignore | 5 +++++ examples/.gitignore | 4 ++++ include/.gitignore | 5 +++++ include/asm-arm/.gitignore | 1 + include/asm-avr32/.gitignore | 1 + include/asm-blackfin/.gitignore | 1 + include/asm-i386/.gitignore | 1 + include/asm-m68k/.gitignore | 1 + include/asm-microblaze/.gitignore | 1 + include/asm-mips/.gitignore | 1 + include/asm-nios/.gitignore | 1 + include/asm-nios2/.gitignore | 1 + include/asm-ppc/.gitignore | 1 + tools/.gitignore | 7 +++++++ 14 files changed, 31 insertions(+), 0 deletions(-) create mode 100644 .gitignore create mode 100644 examples/.gitignore create mode 100644 include/.gitignore create mode 100644 include/asm-arm/.gitignore create mode 100644 include/asm-avr32/.gitignore create mode 100644 include/asm-blackfin/.gitignore create mode 100644 include/asm-i386/.gitignore create mode 100644 include/asm-m68k/.gitignore create mode 100644 include/asm-microblaze/.gitignore create mode 100644 include/asm-mips/.gitignore create mode 100644 include/asm-nios/.gitignore create mode 100644 include/asm-nios2/.gitignore create mode 100644 include/asm-ppc/.gitignore create mode 100644 tools/.gitignore
diff --git a/.gitignore b/.gitignore new file mode 100644 index 0000000..5883e45 --- /dev/null +++ b/.gitignore @@ -0,0 +1,5 @@ +.* +*.o +*.a +System.map +u-boot* diff --git a/examples/.gitignore b/examples/.gitignore new file mode 100644 index 0000000..f715e1b --- /dev/null +++ b/examples/.gitignore @@ -0,0 +1,4 @@ +*.bin +*.srec +hello_world +sched diff --git a/include/.gitignore b/include/.gitignore new file mode 100644 index 0000000..8d2fb78 --- /dev/null +++ b/include/.gitignore @@ -0,0 +1,5 @@ +bmp_logo.h +config.h +config.mk +version_autogenerated.h +asm diff --git a/include/asm-arm/.gitignore b/include/asm-arm/.gitignore new file mode 100644 index 0000000..1689398 --- /dev/null +++ b/include/asm-arm/.gitignore @@ -0,0 +1 @@ +arch diff --git a/include/asm-avr32/.gitignore b/include/asm-avr32/.gitignore new file mode 100644 index 0000000..1689398 --- /dev/null +++ b/include/asm-avr32/.gitignore @@ -0,0 +1 @@ +arch diff --git a/include/asm-blackfin/.gitignore b/include/asm-blackfin/.gitignore new file mode 100644 index 0000000..1689398 --- /dev/null +++ b/include/asm-blackfin/.gitignore @@ -0,0 +1 @@ +arch diff --git a/include/asm-i386/.gitignore b/include/asm-i386/.gitignore new file mode 100644 index 0000000..1689398 --- /dev/null +++ b/include/asm-i386/.gitignore @@ -0,0 +1 @@ +arch diff --git a/include/asm-m68k/.gitignore b/include/asm-m68k/.gitignore new file mode 100644 index 0000000..1689398 --- /dev/null +++ b/include/asm-m68k/.gitignore @@ -0,0 +1 @@ +arch diff --git a/include/asm-microblaze/.gitignore b/include/asm-microblaze/.gitignore new file mode 100644 index 0000000..1689398 --- /dev/null +++ b/include/asm-microblaze/.gitignore @@ -0,0 +1 @@ +arch diff --git a/include/asm-mips/.gitignore b/include/asm-mips/.gitignore new file mode 100644 index 0000000..1689398 --- /dev/null +++ b/include/asm-mips/.gitignore @@ -0,0 +1 @@ +arch diff --git a/include/asm-nios/.gitignore b/include/asm-nios/.gitignore new file mode 100644 index 0000000..1689398 --- /dev/null +++ b/include/asm-nios/.gitignore @@ -0,0 +1 @@ +arch diff --git a/include/asm-nios2/.gitignore b/include/asm-nios2/.gitignore new file mode 100644 index 0000000..1689398 --- /dev/null +++ b/include/asm-nios2/.gitignore @@ -0,0 +1 @@ +arch diff --git a/include/asm-ppc/.gitignore b/include/asm-ppc/.gitignore new file mode 100644 index 0000000..1689398 --- /dev/null +++ b/include/asm-ppc/.gitignore @@ -0,0 +1 @@ +arch diff --git a/tools/.gitignore b/tools/.gitignore new file mode 100644 index 0000000..6ef414a --- /dev/null +++ b/tools/.gitignore @@ -0,0 +1,7 @@ +bmp_logo +crc32.c +envcrc +environment.c +gen_eth_addr +img2srec +mkimage
Acked-by: Grant Likely grant.likely@secretlab.ca
Wolfgang, I know you're not fond of .gitignore files because you use git-status to get a list of all non-committed files. However, for many of us having a nice set of .gitignore files is pretty much a necessity. I personally have a .gitignore patch that I need to apply everytime I fetch the latest mainline.
If an alternative command can be used to do the same thing, would you consider accepting this patch? Have you tried: 'git-ls-files --others'?
Thanks, g.
In message 528646bc0702201547o28480db3g8973c63764fd58ce@mail.gmail.com you wrote:
No, it's not about non-committed files. It's about files that get forgotten to be cleaned up because of errors / omissions / dead code in the Makefiles.
I never felt the need for a .gitignore file; mayby you can explain what you need it for?
It doesn't do what I want. For example:
-> cg-status ... ? LOG/ ? board/amcc/yellowstone/ -> git-ls-files --others LOG/cam5200.ERR LOG/cam5200.MAKELOG ->
The first command shows me that there is a stale (empty) directory left, the second doesn't.
To keep the output of git-status clean. I need to do a "make clean" in order for git-status to give me meaningful results.
Another reason for .gitignore is to avoid accidentally including target files in a patch.
Hmmm... git-status doesn't show the LOG directory either.
If git-ls-files were updated to include empty directories, would you be willing to have .gitignore files?
That's what I do, too. What's the problem with that?
Also, you could get used to using the O= option and put the builkd tree in a separate directory, so you don't even have to run "make clean".
And as mentioned before, I see the benefit of the current situation that it clearly shows if "make clean" fails to clean up any files it should.
Willing...
To be honest: no. My regular working mode is to use "cg-status" to see what was changed / added etc. before I commit a change. For me it is very convenient when I see any stray files at the same time without need to run any other command.
But I'm willing to listen to arguments. At the moment it's that either I have to run an additional command I didn't need to use before, or you have to run "make clean" or use "O=". I don't see any significant difference of added inconvenience between these two. So I tend to shift the inconvenience to you :-)
However, if you have a *good* reason for using .gitignore files, I will reconsider.
I think that's a very good summary of the current situation.
However, I would like to point out that, at least according to the current discussion, you are the only person who opposes .gitignore files. Everyone else wants this patch applied. So it's not really just me who is inconvenienced by the status quo - it's everyone but you who is inconvenienced.
I think I have already come up with arguments to use .gitignore files, and these are just the normal reasons for using .gitignore files. I don't have anything else to add to this discussion.
Well, everyone that spoke up spoke up for the patch, but most of the developers on the list did not speak up. Personally, I don't feel inconvenienced by Wolfgang's choice and am OK with status quo (inertia is the most powerful force in the universe). <http://thinkexist.com/quotation/the_most_powerful_force_in_the_universe_is/1... although that is apparently an urban legend: http://en.wikipedia.org/wiki/Einstein#Popularity_and_cultural_impact
I suspect that, for most developers, it's not an itch so they aren't scratching it.
Best regards, gvb
It forces the assumption that you must 'make clean' before you commit.
There is a strongly established workflow convention use by other git-using projects. The workflow for committing is this: $ git-status # to show what has changed/added/removed $ git-update-index # as needed to update the index $ git-commit # make it real; It should be noted that 'make clean' is not a required step for the commit workflow.
Alternately, the same thing is done with cogito: $ cg-status $ cg-commit
In this work flow, the user is interested primarily in what changes will be made to the repo. As such, git-status is optimized to that specific task. .gitignore files are a feature designed to support that optimization. They are used to omit uninteresting files, where uninteresting is defined as files you don't care about when performing the task of commit.
It is absolutely true that git-status can be used in the manor that Wolfgang is using it. It is also absolutely true that absence of .gitfiles does not technically prevent using the established workflow conventions. All the information is still there. However, no .gitignore files means that the output of git-status is unfiltered. Unfiltered output is harder to parse and therefore requires more work to commit changes. I'd even argue that the unfiltered output is verbose enough to be useless. This is not the established workflow used in other projects.
There is another command specifically designed for the task of seeing *all* files not included in the repo.
The next question that must be asked is "why does it matter?" If u-boot has it's own convention and the commands all work, then what's the problem? The problem is that it erects an artificial barrier between the developing for u-boot and for other projects, *while adding no significant benefit*. The last part is important. If significant benefit can be shown to differing from the conventions used by other project, then I strongly support such a difference.
Note: There absolutely are convention differences between u-boot and other projects. It would be silly to go down the path of trying to unify all conventions; it's a waste of time and it wouldn't work anyway. Implicit choices to diverge happen all the time. It's part of engineering. We don't even think about those sorts of things. However, if an explicit choice is made to diverge from conventions used by another project (like choosing to not use .gitignore files), then there better be a good reason for doing so. (assuming non-trivial differences).
Is the convenience of one developer worth breaking the established convention at the inconvenience of other developers.
I second the argument that's already been made the number of people inconvenienced by .gitignore absence is greater than the number inconvenienced by their presence. :-P
g.
I had a wordy email which boiled down to the above argument, so I'll just agree. Arguing that we should just go with the flow (rather than overcome inertia) by leaving out .gitignore files is assuming that U-Boot is a closed system. :)
There's a *lot* of momentum behind *using* them, and I know every single developer I've talked with (with the notable exception of Wolfgang) has complained on multiple occasions about the uselessness of git status output in U-Boot.
Agreed. Our inertia is greater than yours! Join us! ;)
Andy
In message 528646bc0702261635y51e80d76sd27c4b113eb09820@mail.gmail.com you wrote:
Well, I don't have to do that.
Maybe my confusion / ignorance comes from the fact that I tend to use cogito rather that raw git commands.
I can do this fine even with uncleanded files. cg-commit will not anny files that have not been added with cg-add.
Is this different with above sequence of git commands?
I always assumed that you have to use "git-add" to explicitely add new files to the idex. Is this assumption wrong?
If not, what do a few extra files hurt when running a commit?
I lost you here. Why do you need the output of git-status to commit changes?
You are really persuasive.
Will you nevertheless help me and explain what I'm missing? Why is all this needed?
So much ado about this ...
You leave me no sane way out but to give in, but at least I want to understand why all this is needed. I don't get it yet.
You don't *have* to use git-status first. If, for instance, you know all the names of the files which need to be committed. But this is typically done to see what files have changed, and to see what files aren't yet tracked by git. However, when there are a few hundred object files also in that list, git-status is useless for seeing the new files.
It's also a bit inconvenient for checking the status, because people who are used to Linux are used to just typing git-status, and seeing the handful of lines of output. In U-Boot, you only get a handful of lines if you've done make clean.
In other words, the forgetful developer like me has this process in U-Boot:
git-status # swear git-status | less # wonder if I added any new files git-status | less # swear. Give up on finding new files make clean git-status # Ah, I forgot about that one git-add # Add/update all files, including the new ones git-commit #commit the changes
I work in an office environment--all that swearing endangers my job! ;)
No, that's right.
It's not a few extra files. It's several hundred. And it makes it harder to find the handful of files which are actually relevant.
Just to identify them. It feeds the information to the developer, so we can tell git which files need to be committed.
Andy
Actually, I think you've hit on something here that I wasn't thinking about. By default,cg-commit records all changes in the working set. git-commit requires you to explicitly mark the files for commit (using one of git-update-index, git-commit <filelist>, or git-commit -a). So while the resulting tree is compatible (praise God!), it does encourage a different usage model.
With cg-commit, you don't really need cg-status. When you do a cg-commit, it brings up an editor window and tells you exactly what it intends to commit, and even gives you the option to change the commit list before finishing. cg-status is redundant for this activity.
With git-commit, it's different. git-status is used multiple times to determine what state the index is in. Calls to git-update-index, git-add and git-rm are used to manipulate the index before finally calling git-commit. hollisb would puke on this UI, but some of us actually like it. :)
Not having a nice set of .gitignore files doesn't really impact cg-commit usage, but it severely impacts those of us using git-commit. Every time we do a git-status there are a load of uninteresting .o files interleaved with a (usually) small number interesting changes. Plus, if you're like me and make many commits 'on the fly', then it becomes invasive to do a 'make clean' before the output git-status becomes parseable by mere mortals.
No it's not different. Your right. New files must always be explicitly added. I was also wrong when I wrote the cogito workflow above; cg-status is redundant.
A few extra files (under 10): wouldn't hurt a bit The 400 .o files that git-status currently reports: Pretty much cripples git-status for the purpose of preparing the index for a commit.
As discussed above, git-commit needs to be explicitly told which files to commit. By default, it commits nothing. (as opposed to the cg-commit default, which is to commit everything).
Thanks! :-)
Hehehe, I probably owe you like 10 beers to offset some of the debates I've instigated lately. Are you going to be able to make it to OLS this year?
Cheers, g.
If I understand it correctly, then the main usage difference between you (core git users) and Wolfgang (and me by the way) cogito users, is the handling of new files. With git-update-index all new files are added to the index automatically (without parameters), right? Using cg-add you have to either name the files explicitly you want to add, or use the "-a" option.
Even as cogito user (and I'm thinking again about switching to using the core git commands more and more), I vote for adding this .gitignore file, since it really seems to be needed in this workflow. And we want to make it as easy for most of the people to work on this project.
Could be that I will make it this year. Perhaps I can act here as Wolfgangs "substitute"? ;-)
Best regards, Stefan
===================================================================== DENX Software Engineering GmbH, HRB 165235 Munich, CEO: Wolfgang Denk Office: Kirchenstr. 5, D-82194 Groebenzell, Germany =====================================================================
Actually, no. I probably didn't explain well.
Cogito and core git handle new files in exactly the same way: they must be added explicitly (with cg-add, git-update-index --add, or git-add). It's *changed* files that are handled differently.
By default, cg-commit assumes that you want to commit *all* file changes, and gives you the option to cull the list.
By default, git-commit assumes that you want to commit *no* file changes, and gives you the tools to add files to the commit list (with 'git-update-index', or 'git-commit <filelist>'). Hence git-status gets called a really large number of times.
You'll have to fight him for it; but I probably owe you a beer or three also. :)
Just for the record:
git-add without parameters will automatically add all non-ignored files to the index. That seems to be the workflow at least Andy is using.
Yup; I was wrong on this point.
g.
On Feb 27, 2007, at 8:56 AM, Timur Tabi wrote:
No. You have to manually specify all file names with git-update- index. Fortunately, there's a shortcut:
git-update-index `git-diff-index --name-only -p HEAD`
I think git-add in 1.5 is suppose to clean all this up and be the single front end to get items into the index (either new files or existing).
- k
On 2/27/07, Timur Tabi timur@freescale.com wrote:
No. You have to manually specify all file names with git-update-index. Fortunately, there's a shortcut:
An even easier shortcut is "git commit -a", which will update the index for all files before committing.
Haavard
Try "git ls-files --others --directory". And for cleaning absolutely everything, "git clean -x -d".
-Scott
I don't want to have .gitignore files; see the archive for explanations.
participants (9)
Andy Fleming
Grant Likely
Haavard Skinnemoen
Jerry Van Baren
Kumar Gala
Scott Wood
Stefan Roese
Timur Tabi
