[U-Boot] [PATCH v3 0/6] rockchip: kylin: Boot with android boot image
We are porting android to kylin board now. This series could let it boot up with android's boot image.
Changes in v3: Use rockchip's legacy reboot mode definitions.
Changes in v2: Add comments.
Jeffy Chen (6): common/image-fdt.c: Make boot_get_fdt() perform a check for Android images ARM: bootm: Try to use relocated ramdisk rockchip: rk3036: Bind GPIO banks rockchip: kylin: Add default gpt partition table rockchip: kylin: Enable boot with android boot image rockchip: kylin: Check fastboot request
arch/arm/lib/bootm.c | 12 ++++++- board/kylin/kylin_rk3036/kylin_rk3036.c | 46 ++++++++++++++++++++++++++ common/image-fdt.c | 4 +++ drivers/pinctrl/rockchip/pinctrl_rk3036.c | 8 +++++ include/configs/kylin_rk3036.h | 55 +++++++++++++++++++++++++++++++ 5 files changed, 124 insertions(+), 1 deletion(-)
Android images don't have a fdt.
Signed-off-by: Jeffy Chen jeffy.chen@rock-chips.com Acked-by: Simon Glass sjg@chromium.org ---
common/image-fdt.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/common/image-fdt.c b/common/image-fdt.c index 5e4e5bd..41aaa0d 100644 --- a/common/image-fdt.c +++ b/common/image-fdt.c @@ -379,6 +379,10 @@ int boot_get_fdt(int flag, int argc, char * const argv[], uint8_t arch, (long)fdt_addr); } break; +#ifdef CONFIG_ANDROID_BOOT_IMAGE + case IMAGE_FORMAT_ANDROID: + goto no_fdt; +#endif default: puts("ERROR: Did not find a cmdline Flattened Device Tree\n"); goto no_fdt;
After boot_ramdisk_high(), ramdisk would be relocated to initrd_start & initrd_end, so use them instead of rd_start & rd_end.
Changes in v3: None Changes in v2: Add comments.
arch/arm/lib/bootm.c | 12 +++++++++++- 1 file changed, 11 insertions(+), 1 deletion(-)
diff --git a/arch/arm/lib/bootm.c b/arch/arm/lib/bootm.c index a477cae..0838d89 100644 --- a/arch/arm/lib/bootm.c +++ b/arch/arm/lib/bootm.c @@ -225,7 +225,17 @@ static void boot_prep_linux(bootm_headers_t *images) if (BOOTM_ENABLE_MEMORY_TAGS) setup_memory_tags(gd->bd); if (BOOTM_ENABLE_INITRD_TAG) { - if (images->rd_start && images->rd_end) { + /* + * In boot_ramdisk_high(), it may relocate ramdisk to + * a specified location. And set images->initrd_start & + * images->initrd_end to relocated ramdisk's start/end + * addresses. So use them instead of images->rd_start & + * images->rd_end when possible. + */ + if (images->initrd_start && images->initrd_end) { + setup_initrd_tag(gd->bd, images->initrd_start, + images->initrd_end); + } else if (images->rd_start && images->rd_end) { setup_initrd_tag(gd->bd, images->rd_start, images->rd_end); }
Call dm_scan_fdt_node() in rk3036 pinctrl uclass binding.
drivers/pinctrl/rockchip/pinctrl_rk3036.c | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/drivers/pinctrl/rockchip/pinctrl_rk3036.c b/drivers/pinctrl/rockchip/pinctrl_rk3036.c index 581b096..1f78bf8 100644 --- a/drivers/pinctrl/rockchip/pinctrl_rk3036.c +++ b/drivers/pinctrl/rockchip/pinctrl_rk3036.c @@ -15,6 +15,7 @@ #include <asm/arch/hardware.h> #include <asm/arch/periph.h> #include <dm/pinctrl.h> +#include <dm/root.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -252,6 +253,12 @@ static struct pinctrl_ops rk3036_pinctrl_ops = { .get_periph_id = rk3036_pinctrl_get_periph_id, };
+static int rk3036_pinctrl_bind(struct udevice *dev) +{ + /* scan child GPIO banks */ + return dm_scan_fdt_node(dev, gd->fdt_blob, dev->of_offset, false); +} + static int rk3036_pinctrl_probe(struct udevice *dev) { struct rk3036_pinctrl_priv *priv = dev_get_priv(dev); @@ -272,5 +279,6 @@ U_BOOT_DRIVER(pinctrl_rk3036) = { .of_match = rk3036_pinctrl_ids, .priv_auto_alloc_size = sizeof(struct rk3036_pinctrl_priv), .ops = &rk3036_pinctrl_ops, + .bind = rk3036_pinctrl_bind, .probe = rk3036_pinctrl_probe, };
Add default android gpt partition table for kylin board.
Use "gpt write mmc 0 $partitions" to apply.
include/configs/kylin_rk3036.h | 29 +++++++++++++++++++++++++++++ 1 file changed, 29 insertions(+)
diff --git a/include/configs/kylin_rk3036.h b/include/configs/kylin_rk3036.h index aa07889..b750b26 100644 --- a/include/configs/kylin_rk3036.h +++ b/include/configs/kylin_rk3036.h @@ -9,4 +9,33 @@
#include <configs/rk3036_common.h>
+#ifndef CONFIG_SPL_BUILD + +/* Enable gpt partition table */ +#define CONFIG_CMD_GPT +#define CONFIG_RANDOM_UUID +#define CONFIG_EFI_PARTITION +#define PARTS_DEFAULT \ + "uuid_disk=${uuid_gpt_disk};" \ + "name=loader,start=32K,size=4000K,uuid=${uuid_gpt_loader};" \ + "name=reserved,size=64K,uuid=${uuid_gpt_reserved};" \ + "name=misc,size=4M,uuid=${uuid_gpt_misc};" \ + "name=recovery,size=32M,uuid=${uuid_gpt_recovery};" \ + "name=boot_a,size=32M,uuid=${uuid_gpt_boot_a};" \ + "name=boot_b,size=32M,uuid=${uuid_gpt_boot_b};" \ + "name=system_a,size=818M,uuid=${uuid_gpt_system_a};" \ + "name=system_b,size=818M,uuid=${uuid_gpt_system_b};" \ + "name=vendor_a,size=50M,uuid=${uuid_gpt_vendor_a};" \ + "name=vendor_b,size=50M,uuid=${uuid_gpt_vendor_b};" \ + "name=cache,size=100M,uuid=${uuid_gpt_cache};" \ + "name=metadata,size=16M,uuid=${uuid_gpt_metadata};" \ + "name=persist,size=4M,uuid=${uuid_gpt_persist};" \ + "name=userdata,size=-,uuid=${uuid_gpt_userdata};\0" \ + +#undef CONFIG_EXTRA_ENV_SETTINGS +#define CONFIG_EXTRA_ENV_SETTINGS \ + "partitions=" PARTS_DEFAULT \ + +#endif + #endif
The android kernel is using appended dtb by default, and store ramdisk right after kernel & dtb. So we needs to relocate ramdisk, and use atags to pass params.
include/configs/kylin_rk3036.h | 23 +++++++++++++++++++++++ 1 file changed, 23 insertions(+)
diff --git a/include/configs/kylin_rk3036.h b/include/configs/kylin_rk3036.h index b750b26..49997ec 100644 --- a/include/configs/kylin_rk3036.h +++ b/include/configs/kylin_rk3036.h @@ -35,6 +35,29 @@ #undef CONFIG_EXTRA_ENV_SETTINGS #define CONFIG_EXTRA_ENV_SETTINGS \ "partitions=" PARTS_DEFAULT \ + "mmcdev=0\0" \ + "mmcpart=5\0" \ + "loadaddr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ + +#define CONFIG_ANDROID_BOOT_IMAGE +#define CONFIG_SYS_BOOT_RAMDISK_HIGH +#define CONFIG_SYS_HUSH_PARSER + +#undef CONFIG_BOOTCOMMAND +#define CONFIG_BOOTCOMMAND \ + "mmc dev ${mmcdev}; if mmc rescan; then " \ + "part start mmc ${mmcdev} ${mmcpart} boot_start;" \ + "part size mmc ${mmcdev} ${mmcpart} boot_size;" \ + "mmc read ${loadaddr} ${boot_start} ${boot_size};" \ + "bootm start ${loadaddr}; bootm ramdisk;" \ + "bootm prep; bootm go;" \ + "fi;" \ + +/* Enable atags */ +#define CONFIG_SYS_BOOTPARAMS_LEN (64*1024) +#define CONFIG_INITRD_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_CMDLINE_TAG
#endif
We will save boot mode flag in grf's os_reg[0], if fastboot requested or fastboot key pressed, try to enter fastboot mode at preboot stage.
Changes in v2: None
board/kylin/kylin_rk3036/kylin_rk3036.c | 46 +++++++++++++++++++++++++++++++++ include/configs/kylin_rk3036.h | 3 +++ 2 files changed, 49 insertions(+)
diff --git a/board/kylin/kylin_rk3036/kylin_rk3036.c b/board/kylin/kylin_rk3036/kylin_rk3036.c index 40d6b52..4fc31b1 100644 --- a/board/kylin/kylin_rk3036/kylin_rk3036.c +++ b/board/kylin/kylin_rk3036/kylin_rk3036.c @@ -8,10 +8,15 @@ #include <dm.h> #include <asm/io.h> #include <asm/arch/uart.h> +#include <asm/arch-rockchip/grf_rk3036.h> #include <asm/arch/sdram_rk3036.h> +#include <asm/gpio.h>
+#define GRF_BASE 0x20008000 +static struct rk3036_grf * const grf = (void *)GRF_BASE; + void get_ddr_config(struct rk3036_ddr_config *config) { /* K4B4G1646Q config */ @@ -28,6 +33,47 @@ void get_ddr_config(struct rk3036_ddr_config *config) config->bw = 1; }
+#define FASTBOOT_KEY_GPIO 93 + +int fastboot_key_pressed(void) +{ + gpio_request(FASTBOOT_KEY_GPIO, "fastboot_key"); + gpio_direction_input(FASTBOOT_KEY_GPIO); + return !gpio_get_value(FASTBOOT_KEY_GPIO); +} + +enum rockchip_boot_mode { + ROCKCHIP_BOOT_MODE_NORMAL = 0x5242C300, + ROCKCHIP_BOOT_MODE_LOADER, + ROCKCHIP_BOOT_MODE_MASKROM, + ROCKCHIP_BOOT_MODE_RECOVER, + ROCKCHIP_BOOT_MODE_NORECOVER, + ROCKCHIP_BOOT_MODE_SECONDOS, + ROCKCHIP_BOOT_MODE_WIPEDATA, + ROCKCHIP_BOOT_MODE_WIPEALL, + ROCKCHIP_BOOT_MODE_CHECKIMG, + ROCKCHIP_BOOT_MODE_FASTBOOT, + ROCKCHIP_BOOT_MODE_SECUREBOOT_DISABLE, + ROCKCHIP_BOOT_MODE_CHARGING, + ROCKCHIP_BOOT_MODE_MAX, +}; + +int board_late_init(void) +{ + int boot_mode = readl(&grf->os_reg[4]); + + /* Clear boot mode */ + writel(0, &grf->os_reg[4]); + + if (boot_mode == ROCKCHIP_BOOT_MODE_FASTBOOT || + fastboot_key_pressed()) { + printf("enter fastboot!\n"); + setenv("preboot", "setenv preboot; fastboot usb0"); + } + + return 0; +} + int board_init(void) { return 0; diff --git a/include/configs/kylin_rk3036.h b/include/configs/kylin_rk3036.h index 49997ec..424e81b 100644 --- a/include/configs/kylin_rk3036.h +++ b/include/configs/kylin_rk3036.h @@ -39,6 +39,9 @@ "mmcpart=5\0" \ "loadaddr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \
+#define CONFIG_BOARD_LATE_INIT +#define CONFIG_PREBOOT + #define CONFIG_ANDROID_BOOT_IMAGE #define CONFIG_SYS_BOOT_RAMDISK_HIGH #define CONFIG_SYS_HUSH_PARSER
Hi Jeffy,
Changes in v2: None
Can you make this a local var in board_late_init()? I does not seem to need to be static.
2.1.4
Jeffy Chen
