[PATCH v6 0/8] efi: capsule: Capsule Update fixes and enhancements
This series is cleaning up the usage of the image GUIDs that are used in capsule update and the EFI System Resource Table(ESRT). There are some other enhancements being made to the capsule update code to make it more robust.
Firstly, an overview of the fixes being made.
Currently, there are two instances of the Firmware Management Protocol(FMP), one defined for updating the FIT images, and the other for updating raw images. The FMP code defines two GUID values, one for all FIT images, and one for raw images. Depending on the FMP instance used on a platform, the platform needs to use the corresponding image GUID value for all images on the platform, and also across platforms.
A few issues are being fixed through the patch series. One, that an image for a different platform can be flashed on another platform if both the platforms are using the same FMP instance. So, for e.g. a capsule generated for the Socionext DeveloperBox platform can be flashed on the ZynqMP platform, since both the platforms use the CONFIG_EFI_CAPSULE_FIRMWARE_RAW instance of the FMP. This can be corrected if each firmware image that can be updated through the capsule update mechanism has it's own unique image GUID.
The second issue that this patch series fixes is the value of FwClass in the ESRT. With the current logic, all firmware image entries in the ESRT display the same GUID value -- either the FIT GUID or the raw GUID. This is not in compliance with the UEFI specification, as the specification requires all entries to have unique GUID values.
The third issue being fixed is the population of the EFI_FIRMWARE_IMAGE_DESCRIPTOR array. The current code uses the dfu framework for populating the image descriptor array. However, there might be other images that are not to be updated through the capsule update mechanism also registered with the dfu framework. As a result of this, the ESRT will show up entries of images that are not to be targeted by the capsule update mechanism.
These issues are being fixed by defining a structure, efi_fw_images. A platform can then define image related information like the image GUID and image name. Every platform that uses capsule update mechanism needs to define fw_images array. This array will then be used to populate the image descriptor array, and also in determining if a particular capsule's payload can be used for updating an image on the platform.
The other part of the patches are some enhancements being made to the capsule update code to make it more robust.
The first enhancement being made is to have a check for the image index being passed through the capsule header. The capsule update code uses the image index value as the dfu alt number, which points to the partition to which the update must be made. The platform is supposed to define the image index value for the updatable firmare images as part of the fw_images array. This value must correspond to the dfu alt num for the corresponding image, and can be obtained by checking the output of the 'dfu list' u-boot command. At the time of update, the image index being passed through the capsule is checked against the image index value obtained from the platform.
The second enhancement made is the retrieval of the dfu_alt_info variable from the set_dfu_alt_info function instead of using the value defined in the environment. The dfu framework checks for the existence of this function, and if the function is not defined, gets the value from the environment. This can cause in an incorrect update if the environment variable value is incorrect. A weak function is defined for populating dfu_alt_info from the information obtained from the platform. This function gets invoked on all platforms which enabled capsule update feature.
The first patch adds the structure efi_capsule_update_info and initialises the structure on all platforms which enable capsule update feature
The second patch populates the image descriptor array in the GetImageInfo function with the values from the fw_images array defined in the board file
The third patch adds a check for the image index value from the capsule header against the value obtained from the fw_images array for the corresponding image
The fourth patch defines a weak function set_dfu_alt_info which is used to populate dfu_alt_info to be used for capsule updates.
The fifth patch splits the capsule update test script into two, one for FMP for raw images, and one for FMP for FIT images. The test for FIT images is being enabled on the sandbox_flattree variant.
The sixth patch removes the now unused FIT and raw image GUID values from the FMP module.
The seventh patch removes the --raw and --fit command line parameters in the mkeficapsule utility.
The eighth patch makes corresponding changes in the capsule update related documentation.
Changes since V5: ----------------- * Create a separate entry in fw_images array per config for boards with multiple configs as suggested by Heinrich. * Removed CONFIG_IS_ENABLED(EFI_HAVE_CAPSULE_SUPPORT) check in the board config headers, as suggested by Heinrich. * Add a check in the set_dfu_alt_info functions for the xilinx and qemu platforms to get the board defined value of dfu_alt_info when capsule update feature is enabled. * Simplify the set_dfu_alt_info function definition to set the variable directly from dfu_string, as suggested by Heinrich. * Restart the platform before starting the tests. This is done to clear out any stale state from a previously run test.
Changes since V4: -----------------
* Define a structure efi_capsule_update_info which includes the string for populating dfu_alt_info * Initialise the string for dfu_alt_info in the board file * Drop the image_count variable as was suggested by Ilias * Drop another unused variable names_len * Define a weak function set_dfu_alt_info for setting the variable in a non board specific file as suggested by Ilias * Drop the definitions of set_dfu_alt_info that were being added in the board files * Change the description of the platform data based on the changes made in earlier patches
Changes since V3: -----------------
* Do not remove the existing dfu_alt_info definitions made by platforms in the config files, as discussed with Masami. * Squash the selection of the SET_DFU_ALT_INFO config symbol for capsule update feature as part of this patch. * Rephrase the commit message to indicate that the doc changes are not just limited to adding the GUID values, but other info as well. * Elaborate with an example on the relation between the dfu alt number and the image index
Changes since V2: -----------------
* Add a new member image_index to the struct efi_fw_images to allow the platforms to define the values for images. * Address review comments from Michal Simek for the xilinx boards. * Fix double inclusion of efi_loader.h as was pointed out by Heiko Thiery. * Use the image index values defined in the platform's fw_images array for the image descriptors * Add a description for adding image index value and definition of set_dfu_alt_info function for the capsule updates.
Changes since V1: -----------------
* Make changes for the xilinx boards as suggested by Michal Simek. * Add a GUID for the sandbox FIT image. * Split the capsule update test cases into two scripts, one for raw images and one for FIT images. * Add the capsule update test case for FIT images on sandbox64 and sandbox_flattree variants. * Add capsule update support on sandbox_flattree variant for enabling FIT capsule update testing as part of the python tests
Sughosh Ganu (8): capsule: board: Add information needed for capsule updates capsule: FMP: Populate the image descriptor array from platform data capsule: Put a check for image index before the update efi: Define set_dfu_alt_info() for boards with UEFI capsule update enabled test: capsule: Modify the capsule tests to use GUID values for sandbox FMP: Remove GUIDs for FIT and raw images mkeficapsule: Remove raw and FIT GUID types doc: uefi: Update the capsule update related documentation
.../imx8mp_rsb3720a1/imx8mp_rsb3720a1.c | 29 +++ .../imx8mm-cl-iot-gate/imx8mm-cl-iot-gate.c | 28 +++ board/emulation/common/qemu_dfu.c | 3 +- board/emulation/qemu-arm/qemu-arm.c | 28 +++ board/kontron/pitx_imx8m/pitx_imx8m.c | 21 +- board/kontron/sl-mx8mm/sl-mx8mm.c | 20 ++ board/kontron/sl28/sl28.c | 21 ++ board/sandbox/sandbox.c | 34 ++++ board/socionext/developerbox/developerbox.c | 33 +++ board/xilinx/common/board.c | 28 +++ board/xilinx/zynq/board.c | 3 +- board/xilinx/zynqmp/zynqmp.c | 3 +- configs/sandbox64_defconfig | 1 - configs/sandbox_defconfig | 1 - configs/sandbox_flattree_defconfig | 5 + doc/develop/uefi/uefi.rst | 51 ++++- include/configs/imx8mm-cl-iot-gate.h | 9 + include/configs/imx8mp_rsb3720.h | 9 + include/configs/kontron-sl-mx8mm.h | 5 + include/configs/kontron_pitx_imx8m.h | 5 + include/configs/kontron_sl28.h | 5 + include/configs/qemu-arm.h | 9 + include/configs/sandbox.h | 13 ++ include/configs/synquacer.h | 13 ++ include/configs/xilinx_versal.h | 5 + include/configs/xilinx_zynqmp.h | 9 + include/configs/zynq-common.h | 9 + include/efi_api.h | 8 - include/efi_loader.h | 36 ++++ lib/efi_loader/Kconfig | 2 + lib/efi_loader/efi_capsule.c | 8 +- lib/efi_loader/efi_firmware.c | 104 +++------- test/py/tests/test_efi_capsule/conftest.py | 21 +- .../test_capsule_firmware_fit.py | 191 ++++++++++++++++++ ...rmware.py => test_capsule_firmware_raw.py} | 167 ++++++--------- tools/eficapsule.h | 8 - tools/mkeficapsule.c | 26 +-- 37 files changed, 734 insertions(+), 237 deletions(-) create mode 100644 test/py/tests/test_efi_capsule/test_capsule_firmware_fit.py rename test/py/tests/test_efi_capsule/{test_capsule_firmware.py => test_capsule_firmware_raw.py} (75%)
Add a structure which defines the information that is needed for executing capsule updates on a platform. Some information in the structure like the dfu string is used for making the update process more robust while some information like the per platform image GUIDs is used for fixing issues. Initialise this structure in the board file, and use the information for the capsule updates.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org ---
Changes since V5:
.../imx8mp_rsb3720a1/imx8mp_rsb3720a1.c | 29 +++++++++++++++ .../imx8mm-cl-iot-gate/imx8mm-cl-iot-gate.c | 28 +++++++++++++++ board/emulation/common/qemu_dfu.c | 3 +- board/emulation/qemu-arm/qemu-arm.c | 28 +++++++++++++++ board/kontron/pitx_imx8m/pitx_imx8m.c | 21 ++++++++++- board/kontron/sl-mx8mm/sl-mx8mm.c | 20 +++++++++++ board/kontron/sl28/sl28.c | 21 +++++++++++ board/sandbox/sandbox.c | 34 ++++++++++++++++++ board/socionext/developerbox/developerbox.c | 33 +++++++++++++++++ board/xilinx/common/board.c | 28 +++++++++++++++ board/xilinx/zynq/board.c | 3 +- board/xilinx/zynqmp/zynqmp.c | 3 +- include/configs/imx8mm-cl-iot-gate.h | 9 +++++ include/configs/imx8mp_rsb3720.h | 9 +++++ include/configs/kontron-sl-mx8mm.h | 5 +++ include/configs/kontron_pitx_imx8m.h | 5 +++ include/configs/kontron_sl28.h | 5 +++ include/configs/qemu-arm.h | 9 +++++ include/configs/sandbox.h | 13 +++++++ include/configs/synquacer.h | 13 +++++++ include/configs/xilinx_versal.h | 5 +++ include/configs/xilinx_zynqmp.h | 9 +++++ include/configs/zynq-common.h | 9 +++++ include/efi_loader.h | 36 +++++++++++++++++++ 24 files changed, 374 insertions(+), 4 deletions(-)
diff --git a/board/advantech/imx8mp_rsb3720a1/imx8mp_rsb3720a1.c b/board/advantech/imx8mp_rsb3720a1/imx8mp_rsb3720a1.c index 16566092bd..c85a99f650 100644 --- a/board/advantech/imx8mp_rsb3720a1/imx8mp_rsb3720a1.c +++ b/board/advantech/imx8mp_rsb3720a1/imx8mp_rsb3720a1.c @@ -6,6 +6,8 @@
#include <common.h> #include <dwc3-uboot.h> +#include <efi.h> +#include <efi_loader.h> #include <errno.h> #include <miiphy.h> #include <netdev.h> @@ -21,6 +23,7 @@ #include <asm/arch/clock.h> #include <asm/mach-imx/dma.h> #include <linux/delay.h> +#include <linux/kernel.h> #include <power/pmic.h>
DECLARE_GLOBAL_DATA_PTR; @@ -44,6 +47,32 @@ static void setup_gpmi_nand(void) } #endif
+#if CONFIG_IS_ENABLED(EFI_HAVE_CAPSULE_SUPPORT) +struct efi_fw_images fw_images[] = { +#if defined(CONFIG_TARGET_IMX8MP_RSB3720A1_4G) + { + .image_type_id = IMX8MP_RSB3720A1_4G_FIT_IMAGE_GUID, + .fw_name = u"IMX8MP-RSB3720-FIT", + .image_index = 1, + }, +#elif defined(CONFIG_TARGET_IMX8MP_RSB3720A1_6G) + { + .image_type_id = IMX8MP_RSB3720A1_6G_FIT_IMAGE_GUID, + .fw_name = u"IMX8MP-RSB3720-FIT", + .image_index = 1, + }, +#endif +}; + +struct efi_capsule_update_info update_info = { + .dfu_string = "mmc 2=flash-bin raw 0 0x1B00 mmcpart 1", + .images = fw_images, +}; + +u8 num_image_type_guids = ARRAY_SIZE(fw_images); +#endif /* EFI_HAVE_CAPSULE_SUPPORT */ + + int board_early_init_f(void) { struct wdog_regs *wdog = (struct wdog_regs *)WDOG1_BASE_ADDR; diff --git a/board/compulab/imx8mm-cl-iot-gate/imx8mm-cl-iot-gate.c b/board/compulab/imx8mm-cl-iot-gate/imx8mm-cl-iot-gate.c index 7e2d88f449..a82a001e2a 100644 --- a/board/compulab/imx8mm-cl-iot-gate/imx8mm-cl-iot-gate.c +++ b/board/compulab/imx8mm-cl-iot-gate/imx8mm-cl-iot-gate.c @@ -5,6 +5,8 @@ */
#include <common.h> +#include <efi.h> +#include <efi_loader.h> #include <env.h> #include <extension_board.h> #include <hang.h> @@ -21,11 +23,37 @@ #include <asm/mach-imx/gpio.h> #include <asm/mach-imx/mxc_i2c.h> #include <asm/sections.h> +#include <linux/kernel.h>
#include "ddr/ddr.h"
+#if CONFIG_IS_ENABLED(EFI_HAVE_CAPSULE_SUPPORT) +struct efi_fw_images fw_images[] = { +#if defined(CONFIG_TARGET_IMX8MM_CL_IOT_GATE) + { + .image_type_id = IMX8MM_CL_IOT_GATE_FIT_IMAGE_GUID, + .fw_name = u"IMX8MM-CL-IOT-GATE-FIT", + .image_index = 1, + }, +#elif defined(CONFIG_TARGET_IMX8MM_CL_IOT_GATE_OPTEE) + { + .image_type_id = IMX8MM_CL_IOT_GATE_OPTEE_FIT_IMAGE_GUID, + .fw_name = u"IMX8MM-CL-IOT-GATE-FIT", + .image_index = 1, + }, +#endif +}; + +struct efi_capsule_update_info update_info = { + .dfu_string = "mmc 2=flash-bin raw 0x42 0x1D00 mmcpart 1", + .images = fw_images, +}; + +u8 num_image_type_guids = ARRAY_SIZE(fw_images); +#endif /* EFI_HAVE_CAPSULE_SUPPORT */ + int board_phys_sdram_size(phys_size_t *size) { struct lpddr4_tcm_desc *lpddr4_tcm_desc = diff --git a/board/emulation/common/qemu_dfu.c b/board/emulation/common/qemu_dfu.c index 62234a7647..c1aeaf10d9 100644 --- a/board/emulation/common/qemu_dfu.c +++ b/board/emulation/common/qemu_dfu.c @@ -44,7 +44,8 @@ void set_dfu_alt_info(char *interface, char *devstr)
ALLOC_CACHE_ALIGN_BUFFER(char, buf, DFU_ALT_BUF_LEN);
- if (env_get("dfu_alt_info")) + if (!CONFIG_IS_ENABLED(EFI_HAVE_CAPSULE_SUPPORT) && + env_get("dfu_alt_info")) return;
memset(buf, 0, sizeof(buf)); diff --git a/board/emulation/qemu-arm/qemu-arm.c b/board/emulation/qemu-arm/qemu-arm.c index c9e886e44a..ff5499264b 100644 --- a/board/emulation/qemu-arm/qemu-arm.c +++ b/board/emulation/qemu-arm/qemu-arm.c @@ -6,15 +6,43 @@ #include <common.h> #include <cpu_func.h> #include <dm.h> +#include <efi.h> +#include <efi_loader.h> #include <fdtdec.h> #include <init.h> #include <log.h> #include <virtio_types.h> #include <virtio.h>
+#include <linux/kernel.h> + #ifdef CONFIG_ARM64 #include <asm/armv8/mmu.h>
+#if CONFIG_IS_ENABLED(EFI_HAVE_CAPSULE_SUPPORT) +struct efi_fw_images fw_images[] = { +#if defined(CONFIG_TARGET_QEMU_ARM_32BIT) + { + .image_type_id = QEMU_ARM_UBOOT_IMAGE_GUID, + .fw_name = u"Qemu-Arm-UBOOT", + .image_index = 1, + }, +#elif defined(CONFIG_TARGET_QEMU_ARM_64BIT) + { + .image_type_id = QEMU_ARM64_UBOOT_IMAGE_GUID, + .fw_name = u"Qemu-Arm-UBOOT", + .image_index = 1, + }, +#endif +}; + +struct efi_capsule_update_info update_info = { + .images = fw_images, +}; + +u8 num_image_type_guids = ARRAY_SIZE(fw_images); +#endif /* EFI_HAVE_CAPSULE_SUPPORT */ + static struct mm_region qemu_arm64_mem_map[] = { { /* Flash */ diff --git a/board/kontron/pitx_imx8m/pitx_imx8m.c b/board/kontron/pitx_imx8m/pitx_imx8m.c index d655fe099b..a9329460f6 100644 --- a/board/kontron/pitx_imx8m/pitx_imx8m.c +++ b/board/kontron/pitx_imx8m/pitx_imx8m.c @@ -2,6 +2,8 @@
#include "pitx_misc.h" #include <common.h> +#include <efi.h> +#include <efi_loader.h> #include <init.h> #include <mmc.h> #include <miiphy.h> @@ -12,7 +14,7 @@ #include <asm/mach-imx/gpio.h> #include <asm/mach-imx/iomux-v3.h> #include <linux/delay.h> - +#include <linux/kernel.h>
@@ -30,6 +32,23 @@ static iomux_v3_cfg_t const uart_pads[] = { IMX8MQ_PAD_ECSPI1_MISO__UART3_CTS_B | MUX_PAD_CTRL(UART_PAD_CTRL), };
+#if CONFIG_IS_ENABLED(EFI_HAVE_CAPSULE_SUPPORT) +struct efi_fw_images fw_images[] = { + { + .image_type_id = KONTRON_PITX_IMX8M_FIT_IMAGE_GUID, + .fw_name = u"KONTRON-PITX-IMX8M-UBOOT", + .image_index = 1, + }, +}; + +struct efi_capsule_update_info update_info = { + .dfu_string = "mmc 0=flash-bin raw 0x42 0x1000 mmcpart 1", + .images = fw_images, +}; + +u8 num_image_type_guids = ARRAY_SIZE(fw_images); +#endif /* EFI_HAVE_CAPSULE_SUPPORT */ + int board_early_init_f(void) { struct wdog_regs *wdog = (struct wdog_regs *)WDOG1_BASE_ADDR; diff --git a/board/kontron/sl-mx8mm/sl-mx8mm.c b/board/kontron/sl-mx8mm/sl-mx8mm.c index 48376cb826..287c572eeb 100644 --- a/board/kontron/sl-mx8mm/sl-mx8mm.c +++ b/board/kontron/sl-mx8mm/sl-mx8mm.c @@ -6,12 +6,32 @@ #include <asm/arch/imx-regs.h> #include <asm/global_data.h> #include <asm/io.h> +#include <efi.h> +#include <efi_loader.h> #include <fdt_support.h> #include <linux/errno.h> +#include <linux/kernel.h> #include <net.h>
+#if CONFIG_IS_ENABLED(EFI_HAVE_CAPSULE_SUPPORT) +struct efi_fw_images fw_images[] = { + { + .image_type_id = KONTRON_SL_MX8MM_FIT_IMAGE_GUID, + .fw_name = u"KONTROL-SL-MX8MM-UBOOT", + .image_index = 1, + }, +}; + +struct efi_capsule_update_info update_info = { + .dfu_string = "sf 0:0=flash-bin raw 0x400 0x1f0000", + .images = fw_images, +}; + +u8 num_image_type_guids = ARRAY_SIZE(fw_images); +#endif /* EFI_HAVE_CAPSULE_SUPPORT */ + int board_phys_sdram_size(phys_size_t *size) { u32 ddr_size = readl(M4_BOOTROM_BASE_ADDR); diff --git a/board/kontron/sl28/sl28.c b/board/kontron/sl28/sl28.c index 3c48a9141d..0ffa351288 100644 --- a/board/kontron/sl28/sl28.c +++ b/board/kontron/sl28/sl28.c @@ -3,11 +3,14 @@ #include <common.h> #include <dm.h> #include <malloc.h> +#include <efi.h> +#include <efi_loader.h> #include <errno.h> #include <fsl_ddr.h> #include <fdt_support.h> #include <asm/global_data.h> #include <linux/libfdt.h> +#include <linux/kernel.h> #include <env_internal.h> #include <asm/arch-fsl-layerscape/soc.h> #include <asm/arch-fsl-layerscape/fsl_icid.h> @@ -23,6 +26,24 @@
+#if CONFIG_IS_ENABLED(EFI_HAVE_CAPSULE_SUPPORT) +struct efi_fw_images fw_images[] = { + { + .image_type_id = KONTRON_SL28_FIT_IMAGE_GUID, + .fw_name = u"KONTRON-SL28-FIT", + .image_index = 1, + }, +}; + +struct efi_capsule_update_info update_info = { + .dfu_string = "sf 0:0=u-boot-bin raw 0x210000 0x1d0000;" + "u-boot-env raw 0x3e0000 0x20000", + .images = fw_images, +}; + +u8 num_image_type_guids = ARRAY_SIZE(fw_images); +#endif /* EFI_HAVE_CAPSULE_SUPPORT */ + int board_early_init_f(void) { fsl_lsch3_early_init_f(); diff --git a/board/sandbox/sandbox.c b/board/sandbox/sandbox.c index 5d9a945d64..d93aaa6a20 100644 --- a/board/sandbox/sandbox.c +++ b/board/sandbox/sandbox.c @@ -7,6 +7,8 @@ #include <cpu_func.h> #include <cros_ec.h> #include <dm.h> +#include <efi.h> +#include <efi_loader.h> #include <env_internal.h> #include <init.h> #include <led.h> @@ -14,6 +16,7 @@ #include <asm/global_data.h> #include <asm/test.h> #include <asm/u-boot-sandbox.h> +#include <linux/kernel.h> #include <malloc.h>
#include <extension_board.h> @@ -25,6 +28,37 @@ */ gd_t *gd;
+#if CONFIG_IS_ENABLED(EFI_HAVE_CAPSULE_SUPPORT) +struct efi_fw_images fw_images[] = { +#if defined(CONFIG_EFI_CAPSULE_FIRMWARE_RAW) + { + .image_type_id = SANDBOX_UBOOT_IMAGE_GUID, + .fw_name = u"SANDBOX-UBOOT", + .image_index = 1, + }, + { + .image_type_id = SANDBOX_UBOOT_ENV_IMAGE_GUID, + .fw_name = u"SANDBOX-UBOOT-ENV", + .image_index = 2, + }, +#elif defined(CONFIG_EFI_CAPSULE_FIRMWARE_FIT) + { + .image_type_id = SANDBOX_FIT_IMAGE_GUID, + .fw_name = u"SANDBOX-FIT", + .image_index = 1, + }, +#endif +}; + +struct efi_capsule_update_info update_info = { + .dfu_string = "sf 0:0=u-boot-bin raw 0x100000 0x50000;" + "u-boot-env raw 0x150000 0x200000", + .images = fw_images, +}; + +u8 num_image_type_guids = ARRAY_SIZE(fw_images); +#endif /* EFI_HAVE_CAPSULE_SUPPORT */ + #if !CONFIG_IS_ENABLED(OF_PLATDATA) /* * Add a simple GPIO device (don't use with of-platdata as it interferes with diff --git a/board/socionext/developerbox/developerbox.c b/board/socionext/developerbox/developerbox.c index 9552bfcdc3..7820b7e68a 100644 --- a/board/socionext/developerbox/developerbox.c +++ b/board/socionext/developerbox/developerbox.c @@ -10,10 +10,43 @@ #include <asm/global_data.h> #include <asm/io.h> #include <common.h> +#include <efi.h> +#include <efi_loader.h> #include <env_internal.h> #include <fdt_support.h> #include <log.h>
+#include <linux/kernel.h> + +#if CONFIG_IS_ENABLED(EFI_HAVE_CAPSULE_SUPPORT) +struct efi_fw_images fw_images[] = { + { + .image_type_id = DEVELOPERBOX_UBOOT_IMAGE_GUID, + .fw_name = u"DEVELOPERBOX-UBOOT", + .image_index = 1, + }, + { + .image_type_id = DEVELOPERBOX_FIP_IMAGE_GUID, + .fw_name = u"DEVELOPERBOX-FIP", + .image_index = 2, + }, + { + .image_type_id = DEVELOPERBOX_OPTEE_IMAGE_GUID, + .fw_name = u"DEVELOPERBOX-OPTEE", + .image_index = 3, + }, +}; + +struct efi_capsule_update_info update_info = { + .dfu_string = "mtd nor1=u-boot.bin raw 200000 100000;" + "fip.bin raw 180000 78000;" + "optee.bin raw 500000 100000", + .images = fw_images, +}; + +u8 num_image_type_guids = ARRAY_SIZE(fw_images); +#endif /* EFI_HAVE_CAPSULE_SUPPORT */ + static struct mm_region sc2a11_mem_map[] = { { .virt = 0x0UL, diff --git a/board/xilinx/common/board.c b/board/xilinx/common/board.c index 0769189dcf..42a0031ebf 100644 --- a/board/xilinx/common/board.c +++ b/board/xilinx/common/board.c @@ -5,6 +5,8 @@ */
#include <common.h> +#include <efi.h> +#include <efi_loader.h> #include <env.h> #include <log.h> #include <asm/global_data.h> @@ -20,9 +22,35 @@ #include <generated/dt.h> #include <soc.h> #include <linux/ctype.h> +#include <linux/kernel.h>
#include "fru.h"
+#if CONFIG_IS_ENABLED(EFI_HAVE_CAPSULE_SUPPORT) +struct efi_fw_images fw_images[] = { +#if defined(XILINX_BOOT_IMAGE_GUID) + { + .image_type_id = XILINX_BOOT_IMAGE_GUID, + .fw_name = u"XILINX-BOOT", + .image_index = 1, + }, +#endif +#if defined(XILINX_UBOOT_IMAGE_GUID) + { + .image_type_id = XILINX_UBOOT_IMAGE_GUID, + .fw_name = u"XILINX-UBOOT", + .image_index = 2, + }, +#endif +}; + +struct efi_capsule_update_info update_info = { + .images = fw_images, +}; + +u8 num_image_type_guids = ARRAY_SIZE(fw_images); +#endif /* EFI_HAVE_CAPSULE_SUPPORT */ + #if defined(CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET) int zynq_board_read_rom_ethaddr(unsigned char *ethaddr) { diff --git a/board/xilinx/zynq/board.c b/board/xilinx/zynq/board.c index 26ef048835..63aff0474b 100644 --- a/board/xilinx/zynq/board.c +++ b/board/xilinx/zynq/board.c @@ -168,7 +168,8 @@ void set_dfu_alt_info(char *interface, char *devstr) { ALLOC_CACHE_ALIGN_BUFFER(char, buf, DFU_ALT_BUF_LEN);
memset(buf, 0, sizeof(buf)); diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index e7e8e91d2c..41ecc9559c 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -889,7 +889,8 @@ void set_dfu_alt_info(char *interface, char *devstr)
memset(buf, 0, sizeof(buf)); diff --git a/include/configs/imx8mm-cl-iot-gate.h b/include/configs/imx8mm-cl-iot-gate.h index cd1eafdd5c..079e8a9491 100644 --- a/include/configs/imx8mm-cl-iot-gate.h +++ b/include/configs/imx8mm-cl-iot-gate.h @@ -31,6 +31,15 @@
#endif
+/* GUIDs for capsule updatable firmware images */ +#define IMX8MM_CL_IOT_GATE_FIT_IMAGE_GUID \ + EFI_GUID(0x7a32a939, 0xab92, 0x467b, 0x91, 0x52, \ + 0x74, 0x77, 0x1b, 0x95, 0xe6, 0x46) + +#define IMX8MM_CL_IOT_GATE_OPTEE_FIT_IMAGE_GUID \ + EFI_GUID(0x0bf1165c, 0x1831, 0x4864, 0x94, 0x5e, \ + 0xac, 0x3d, 0x38, 0x48, 0xf4, 0x99) + #if CONFIG_IS_ENABLED(CMD_MMC) # define BOOT_TARGET_MMC(func) \ func(MMC, mmc, 2) \ diff --git a/include/configs/imx8mp_rsb3720.h b/include/configs/imx8mp_rsb3720.h index 62e06d2303..2553f0dfb5 100644 --- a/include/configs/imx8mp_rsb3720.h +++ b/include/configs/imx8mp_rsb3720.h @@ -18,6 +18,15 @@ #define CONFIG_SYS_MONITOR_LEN (512 * 1024) #define CONFIG_SYS_UBOOT_BASE (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512)
+/* GUIDs for capsule updatable firmware images */ +#define IMX8MP_RSB3720A1_4G_FIT_IMAGE_GUID \ + EFI_GUID(0xb1251e89, 0x384a, 0x4635, 0xa8, 0x06, \ + 0x3a, 0xa0, 0xb0, 0xe9, 0xf9, 0x65) + +#define IMX8MP_RSB3720A1_6G_FIT_IMAGE_GUID \ + EFI_GUID(0xb5fb6f08, 0xe142, 0x4db1, 0x97, 0xea, \ + 0x5f, 0xd3, 0x6b, 0x9b, 0xe5, 0xb9) + #ifdef CONFIG_SPL_BUILD #define CONFIG_SPL_STACK 0x960000 #define CONFIG_SPL_BSS_START_ADDR 0x0098FC00 diff --git a/include/configs/kontron-sl-mx8mm.h b/include/configs/kontron-sl-mx8mm.h index 788ae77cd3..1b429f7dbe 100644 --- a/include/configs/kontron-sl-mx8mm.h +++ b/include/configs/kontron-sl-mx8mm.h @@ -38,6 +38,11 @@ #define CONFIG_USB_MAX_CONTROLLER_COUNT 2 #endif
+/* GUID for capsule updatable firmware image */ +#define KONTRON_SL_MX8MM_FIT_IMAGE_GUID \ + EFI_GUID(0xd488e45a, 0x4929, 0x4b55, 0x8c, 0x14, \ + 0x86, 0xce, 0xa2, 0xcd, 0x66, 0x29) + #ifndef CONFIG_SPL_BUILD #define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 1) \ diff --git a/include/configs/kontron_pitx_imx8m.h b/include/configs/kontron_pitx_imx8m.h index 2c0ad96e0d..ea0b573ca1 100644 --- a/include/configs/kontron_pitx_imx8m.h +++ b/include/configs/kontron_pitx_imx8m.h @@ -12,6 +12,11 @@ #define CONFIG_SPL_MAX_SIZE (124 * SZ_1K) #define CONFIG_SYS_MONITOR_LEN (512 * SZ_1K)
+/* GUID for capsule updatable firmware image */ +#define KONTRON_PITX_IMX8M_FIT_IMAGE_GUID \ + EFI_GUID(0xc898e959, 0x5b1f, 0x4e6d, 0x88, 0xe0, \ + 0x40, 0xd4, 0x5c, 0xca, 0x13, 0x99) + #ifdef CONFIG_SPL_BUILD #define CONFIG_SPL_STACK 0x187FF0 #define CONFIG_SPL_BSS_START_ADDR 0x00180000 diff --git a/include/configs/kontron_sl28.h b/include/configs/kontron_sl28.h index 97286b6180..c3ab049535 100644 --- a/include/configs/kontron_sl28.h +++ b/include/configs/kontron_sl28.h @@ -52,6 +52,11 @@ #define CONFIG_SYS_SPL_MALLOC_START 0x80200000 #define CONFIG_SYS_MONITOR_LEN (1024 * 1024)
+/* GUID for capsule updatable firmware image */ +#define KONTRON_SL28_FIT_IMAGE_GUID \ + EFI_GUID(0x86ebd44f, 0xfeb8, 0x466f, 0x8b, 0xb8, \ + 0x89, 0x06, 0x18, 0x45, 0x6d, 0x8b) + /* environment */ /* see include/configs/ti_armv7_common.h */ #define ENV_MEM_LAYOUT_SETTINGS \ diff --git a/include/configs/qemu-arm.h b/include/configs/qemu-arm.h index 3ad1cf3232..550e26f3f1 100644 --- a/include/configs/qemu-arm.h +++ b/include/configs/qemu-arm.h @@ -17,6 +17,15 @@
#define CONFIG_SYS_BOOTM_LEN SZ_64M
+/* GUIDs for capsule updatable firmware images */ +#define QEMU_ARM_UBOOT_IMAGE_GUID \ + EFI_GUID(0xf885b085, 0x99f8, 0x45af, 0x84, 0x7d, \ + 0xd5, 0x14, 0x10, 0x7a, 0x4a, 0x2c) + +#define QEMU_ARM64_UBOOT_IMAGE_GUID \ + EFI_GUID(0x058b7d83, 0x50d5, 0x4c47, 0xa1, 0x95, \ + 0x60, 0xd8, 0x6a, 0xd3, 0x41, 0xc4) + /* For timer, QEMU emulates an ARMv7/ARMv8 architected timer */
/* Environment options */ diff --git a/include/configs/sandbox.h b/include/configs/sandbox.h index 71b47996da..7b6db46ee1 100644 --- a/include/configs/sandbox.h +++ b/include/configs/sandbox.h @@ -14,6 +14,19 @@
#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */
+/* GUIDs for capsule updatable firmware images */ +#define SANDBOX_UBOOT_IMAGE_GUID \ + EFI_GUID(0x09d7cf52, 0x0720, 0x4710, 0x91, 0xd1, \ + 0x08, 0x46, 0x9b, 0x7f, 0xe9, 0xc8) + +#define SANDBOX_UBOOT_ENV_IMAGE_GUID \ + EFI_GUID(0x5a7021f5, 0xfef2, 0x48b4, 0xaa, 0xba, \ + 0x83, 0x2e, 0x77, 0x74, 0x18, 0xc0) + +#define SANDBOX_FIT_IMAGE_GUID \ + EFI_GUID(0x3673b45d, 0x6a7c, 0x46f3, 0x9e, 0x60, \ + 0xad, 0xab, 0xb0, 0x3f, 0x79, 0x37) + /* Size of our emulated memory */ #define SB_CONCAT(x, y) x ## y #define SB_TO_UL(s) SB_CONCAT(s, UL) diff --git a/include/configs/synquacer.h b/include/configs/synquacer.h index 8dd092fc59..5686a5b910 100644 --- a/include/configs/synquacer.h +++ b/include/configs/synquacer.h @@ -51,6 +51,19 @@ "fip.bin raw 180000 78000;" \ "optee.bin raw 500000 100000\0"
+/* GUIDs for capsule updatable firmware images */ +#define DEVELOPERBOX_UBOOT_IMAGE_GUID \ + EFI_GUID(0x53a92e83, 0x4ef4, 0x473a, 0x8b, 0x0d, \ + 0xb5, 0xd8, 0xc7, 0xb2, 0xd6, 0x00) + +#define DEVELOPERBOX_FIP_IMAGE_GUID \ + EFI_GUID(0x880866e9, 0x84ba, 0x4793, 0xa9, 0x08, \ + 0x33, 0xe0, 0xb9, 0x16, 0xf3, 0x98) + +#define DEVELOPERBOX_OPTEE_IMAGE_GUID \ + EFI_GUID(0xc1b629f1, 0xce0e, 0x4894, 0x82, 0xbf, \ + 0xf0, 0xa3, 0x83, 0x87, 0xe6, 0x30) + /* Distro boot settings */ #ifndef CONFIG_SPL_BUILD #ifdef CONFIG_CMD_USB diff --git a/include/configs/xilinx_versal.h b/include/configs/xilinx_versal.h index 80e94113f0..b025d2638d 100644 --- a/include/configs/xilinx_versal.h +++ b/include/configs/xilinx_versal.h @@ -25,6 +25,11 @@ #define CONFIG_SYS_BAUDRATE_TABLE \ { 4800, 9600, 19200, 38400, 57600, 115200 }
+/* GUID for capsule updatable firmware image */ +#define XILINX_BOOT_IMAGE_GUID \ + EFI_GUID(0x20c5fba5, 0x0171, 0x457f, 0xb9, 0xcd, \ + 0xf5, 0x12, 0x9c, 0xd0, 0x72, 0x28) + /* Miscellaneous configurable options */
/* Monitor Command Prompt */ diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index 1985a09325..e5e700d804 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -25,6 +25,15 @@ #define CONFIG_SYS_BAUDRATE_TABLE \ { 4800, 9600, 19200, 38400, 57600, 115200 }
+/* GUIDs for capsule updatable firmware images */ +#define XILINX_BOOT_IMAGE_GUID \ + EFI_GUID(0xde6066e8, 0x0256, 0x4fad, 0x82, 0x38, \ + 0xe4, 0x06, 0xe2, 0x74, 0xc4, 0xcf) + +#define XILINX_UBOOT_IMAGE_GUID \ + EFI_GUID(0xcf9ecfd4, 0x938b, 0x41c5, 0x85, 0x51, \ + 0x1f, 0x88, 0x3a, 0xb7, 0xdc, 0x18) + #ifdef CONFIG_NAND_ARASAN # define CONFIG_SYS_MAX_NAND_DEVICE 1 #endif diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index c92f796f8d..bd88b59f24 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -20,6 +20,15 @@ #define CONFIG_SYS_TIMER_COUNTS_DOWN #define CONFIG_SYS_TIMER_COUNTER (CONFIG_SYS_TIMERBASE + 0x4)
+/* GUIDs for capsule updatable firmware images */ +#define XILINX_BOOT_IMAGE_GUID \ + EFI_GUID(0x1ba29a15, 0x9969, 0x40aa, 0xb4, 0x24, \ + 0xe8, 0x61, 0x21, 0x61, 0x86, 0x64) + +#define XILINX_UBOOT_IMAGE_GUID \ + EFI_GUID(0x1a5178f0, 0x87d3, 0x4f36, 0xac, 0x63, \ + 0x3b, 0x31, 0xa2, 0x3b, 0xe3, 0x05) + /* Serial drivers */ /* The following table includes the supported baudrates */ #define CONFIG_SYS_BAUDRATE_TABLE \ diff --git a/include/efi_loader.h b/include/efi_loader.h index af36639ec6..a064a2c4ec 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -979,6 +979,42 @@ efi_status_t efi_capsule_authenticate(const void *capsule,
#define EFI_CAPSULE_DIR u"\EFI\UpdateCapsule\"
+/** + * struct efi_fw_images - List of firmware images updatable through capsule + * update + * + * This structure gives information about the firmware images on the platform + * which can be updated through the capsule update mechanism + * + * @image_type_id: Image GUID. Same value is to be used in the capsule + * @fw_name: Name of the firmware image + * @image_index: Image Index, same as value passed to SetImage FMP + * function + */ +struct efi_fw_images { + efi_guid_t image_type_id; + u16 *fw_name; + u8 image_index; +}; + +/** + * struct efi_capsule_update_info - Information needed for capsule updates + * + * This structure provides information needed for performing firmware + * updates. The structure needs to be initialised per platform, for all + * platforms which enable capsule updates + * + * @dfu_string: String used to populate dfu_alt_info + * @images: Pointer to an array of updatable images + */ +struct efi_capsule_update_info { + const char *dfu_string; + struct efi_fw_images *images; +}; + +extern struct efi_capsule_update_info update_info; +extern u8 num_image_type_guids; + /** * Install the ESRT system table. *
Currently, the image descriptor array that has been passed to the GetImageInfo function of the Firmware Management Protocol(FMP) gets populated through the data stored with the dfu framework. The dfu data is not restricted to contain information only of the images updatable through the capsule update mechanism, but it also contains information on other images. The image descriptor array is also parsed by the ESRT generation code, and thus the ESRT table contains entries for other images that are not being handled by the FMP for the capsule updates. Fix this by populating the image descriptor array from the structure initialised in the board file.
The other issue fixed is assignment of a separate GUID for all images in the image descriptor array. The UEFI specification mandates that all entries in the ESRT table should have a unique GUID value as part of the FwClass member of the EFI_SYSTEM_RESOURCE_ENTRY. Currently, all images are assigned a single GUID value, either an FIT GUID or a raw image GUID. This is fixed by obtaining the GUID values from the efi_fw_images array defined per platform.
Changes since V5: None
lib/efi_loader/efi_firmware.c | 95 +++++++++++------------------------ 1 file changed, 28 insertions(+), 67 deletions(-)
diff --git a/lib/efi_loader/efi_firmware.c b/lib/efi_loader/efi_firmware.c index a5ff32f121..e9fc4b9c1e 100644 --- a/lib/efi_loader/efi_firmware.c +++ b/lib/efi_loader/efi_firmware.c @@ -97,91 +97,58 @@ efi_status_t EFIAPI efi_firmware_set_package_info_unsupported( }
/** - * efi_get_dfu_info - return information about the current firmware image + * efi_fill_image_desc_array - populate image descriptor array * @this: Protocol instance * @image_info_size: Size of @image_info * @image_info: Image information * @descriptor_version: Pointer to version number - * @descriptor_count: Pointer to number of descriptors + * @descriptor_count: Image count * @descriptor_size: Pointer to descriptor size - * package_version: Package version - * package_version_name: Package version's name - * image_type: Image type GUID + * @package_version: Package version + * @package_version_name: Package version's name * * Return information bout the current firmware image in @image_info. * @image_info will consist of a number of descriptors. - * Each descriptor will be created based on "dfu_alt_info" variable. + * Each descriptor will be created based on "efi_fw_images" variable. * * Return status code */ -static efi_status_t efi_get_dfu_info( +static efi_status_t efi_fill_image_desc_array( efi_uintn_t *image_info_size, struct efi_firmware_image_descriptor *image_info, u32 *descriptor_version, u8 *descriptor_count, efi_uintn_t *descriptor_size, u32 *package_version, - u16 **package_version_name, - const efi_guid_t *image_type) + u16 **package_version_name) { - struct dfu_entity *dfu; - size_t names_len, total_size; - int dfu_num, i; - u16 *name, *next; - int ret; - - ret = dfu_init_env_entities(NULL, NULL); - if (ret) - return EFI_SUCCESS; - - names_len = 0; - dfu_num = 0; - list_for_each_entry(dfu, &dfu_list, list) { - names_len += (utf8_utf16_strlen(dfu->name) + 1) * 2; - dfu_num++; - } - if (!dfu_num) { - log_warning("No entities in dfu_alt_info\n"); - *image_info_size = 0; - dfu_free_entities(); + size_t total_size; + struct efi_fw_images *fw_array; + int i;
- return EFI_SUCCESS; - } + fw_array = update_info.images; + *descriptor_count = num_image_type_guids; + + total_size = sizeof(*image_info) * num_image_type_guids;
- total_size = sizeof(*image_info) * dfu_num + names_len; - /* - * we will assume that sizeof(*image_info) * dfu_name - * is, at least, a multiple of 2. So the start address for - * image_id_name would be aligned with 2 bytes. - */ if (*image_info_size < total_size) { *image_info_size = total_size; - dfu_free_entities();
return EFI_BUFFER_TOO_SMALL; } *image_info_size = total_size;
*descriptor_version = EFI_FIRMWARE_IMAGE_DESCRIPTOR_VERSION; - *descriptor_count = dfu_num; *descriptor_size = sizeof(*image_info); *package_version = 0xffffffff; /* not supported */ *package_version_name = NULL; /* not supported */
- /* DFU alt number should correspond to image_index */ - i = 0; - /* Name area starts just after descriptors */ - name = (u16 *)((u8 *)image_info + sizeof(*image_info) * dfu_num); - next = name; - list_for_each_entry(dfu, &dfu_list, list) { - image_info[i].image_index = dfu->alt + 1; - image_info[i].image_type_id = *image_type; - image_info[i].image_id = dfu->alt; - - /* copy the DFU entity name */ - utf8_utf16_strcpy(&next, dfu->name); - image_info[i].image_id_name = name; - name = ++next; + for (i = 0; i < num_image_type_guids; i++) { + image_info[i].image_index = fw_array[i].image_index; + image_info[i].image_type_id = fw_array[i].image_type_id; + image_info[i].image_id = fw_array[i].image_index; + + image_info[i].image_id_name = fw_array[i].fw_name;
image_info[i].version = 0; /* not supported */ image_info[i].version_name = NULL; /* not supported */ @@ -202,12 +169,8 @@ static efi_status_t efi_get_dfu_info( image_info[i].last_attempt_status = LAST_ATTEMPT_STATUS_SUCCESS; image_info[i].hardware_instance = 1; image_info[i].dependencies = NULL; - - i++; }
- dfu_free_entities(); - return EFI_SUCCESS; }
@@ -267,11 +230,10 @@ efi_status_t EFIAPI efi_firmware_fit_get_image_info( !descriptor_size || !package_version || !package_version_name)) return EFI_EXIT(EFI_INVALID_PARAMETER);
- ret = efi_get_dfu_info(image_info_size, image_info, - descriptor_version, descriptor_count, - descriptor_size, - package_version, package_version_name, - &efi_firmware_image_type_uboot_fit); + ret = efi_fill_image_desc_array(image_info_size, image_info, + descriptor_version, descriptor_count, + descriptor_size, package_version, + package_version_name);
return EFI_EXIT(ret); } @@ -376,11 +338,10 @@ efi_status_t EFIAPI efi_firmware_raw_get_image_info( !descriptor_size || !package_version || !package_version_name)) return EFI_EXIT(EFI_INVALID_PARAMETER);
- ret = efi_get_dfu_info(image_info_size, image_info, - descriptor_version, descriptor_count, - descriptor_size, - package_version, package_version_name, - &efi_firmware_image_type_uboot_raw); + ret = efi_fill_image_desc_array(image_info_size, image_info, + descriptor_version, descriptor_count, + descriptor_size, package_version, + package_version_name);
The current capsule update code compares the image GUID value in the capsule header with the image GUID value obtained from the GetImageInfo function of the Firmware Management Protocol(FMP). This comparison is done to ascertain if the FMP's SetImage function can be called for the update. Make this checking more robust by comparing the image_index value passed through the capsule with that returned by the FMP's GetImageInfo function. This protects against the scenario of the firmware being updated in a wrong partition/location on the storage device if an incorrect value has been passed through the capsule, since the image_index is used to determine the location of the update on the storage device.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org Reviewed-by: Masami Hiramatsu masami.hiramatsu@linaro.org Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org ---
lib/efi_loader/efi_capsule.c | 8 +++++--- 1 file changed, 5 insertions(+), 3 deletions(-)
diff --git a/lib/efi_loader/efi_capsule.c b/lib/efi_loader/efi_capsule.c index a107f285dd..c76a5f3570 100644 --- a/lib/efi_loader/efi_capsule.c +++ b/lib/efi_loader/efi_capsule.c @@ -129,6 +129,7 @@ void set_capsule_result(int index, struct efi_capsule_header *capsule, /** * efi_fmp_find - search for Firmware Management Protocol drivers * @image_type: Image type guid + * @image_index: Image Index * @instance: Instance number * @handles: Handles of FMP drivers * @no_handles: Number of handles @@ -142,8 +143,8 @@ void set_capsule_result(int index, struct efi_capsule_header *capsule, * * NULL - on failure */ static struct efi_firmware_management_protocol * -efi_fmp_find(efi_guid_t *image_type, u64 instance, efi_handle_t *handles, - efi_uintn_t no_handles) +efi_fmp_find(efi_guid_t *image_type, u8 image_index, u64 instance, + efi_handle_t *handles, efi_uintn_t no_handles) { efi_handle_t *handle; struct efi_firmware_management_protocol *fmp; @@ -204,6 +205,7 @@ efi_fmp_find(efi_guid_t *image_type, u64 instance, efi_handle_t *handles, log_debug("+++ desc[%d] index: %d, name: %ls\n", j, desc->image_index, desc->image_id_name); if (!guidcmp(&desc->image_type_id, image_type) && + (desc->image_index == image_index) && (!instance || !desc->hardware_instance || desc->hardware_instance == instance)) @@ -450,8 +452,8 @@ static efi_status_t efi_capsule_update_firmware( }
/* find a device for update firmware */ - /* TODO: should we pass index as well, or nothing but type? */ fmp = efi_fmp_find(&image->update_image_type_id, + image->update_image_index, image->update_hardware_instance, handles, no_handles); if (!fmp) {
Currently, there are a bunch of boards which enable the UEFI capsule update feature. The actual update of the firmware images is done through the dfu framework which uses the dfu_alt_info environment variable for getting information on the update, like device, partition number/address etc. The dfu framework allows the variable to be set through the set_dfu_alt_info function defined by the platform, or if the function is not defined, it gets the variable from the environment. Using the value set in the environment is not very robust, since the variable can be modified from the u-boot command line and this can cause an incorrect update.
To prevent this from happening, define the set_dfu_alt_info function when the capsule update feature is enabled. A weak function is defined which sets the dfu_alt_info environment variable by getting the string for the variable from the platform.
Changes since V5: * Simplify the set_dfu_alt_info function definition to set the variable directly from dfu_string, as suggested by Heinrich.
lib/efi_loader/Kconfig | 2 ++ lib/efi_loader/efi_firmware.c | 5 +++++ 2 files changed, 7 insertions(+)
diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index 559b95a599..d50cd2563d 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -181,6 +181,7 @@ config EFI_CAPSULE_FIRMWARE_FIT depends on EFI_CAPSULE_FIRMWARE_MANAGEMENT select UPDATE_FIT select DFU + select SET_DFU_ALT_INFO select EFI_CAPSULE_FIRMWARE help Select this option if you want to enable firmware management protocol @@ -192,6 +193,7 @@ config EFI_CAPSULE_FIRMWARE_RAW depends on SANDBOX || (!SANDBOX && !EFI_CAPSULE_FIRMWARE_FIT) select DFU_WRITE_ALT select DFU + select SET_DFU_ALT_INFO select EFI_CAPSULE_FIRMWARE help Select this option if you want to enable firmware management protocol diff --git a/lib/efi_loader/efi_firmware.c b/lib/efi_loader/efi_firmware.c index e9fc4b9c1e..c2fe660cdd 100644 --- a/lib/efi_loader/efi_firmware.c +++ b/lib/efi_loader/efi_firmware.c @@ -35,6 +35,11 @@ struct fmp_payload_header { u32 lowest_supported_version; };
+__weak void set_dfu_alt_info(char *interface, char *devstr) +{ + env_set("dfu_alt_info", update_info.dfu_string); +} + /* Place holder; not supported */ static efi_status_t EFIAPI efi_firmware_get_image_unsupported(
The current UEFI capsule updation code uses two GUID values, one for FIT images, and one for raw images across platforms. This logic is being changed to have GUID values per image, per platform. Change the tests for the capsule update code to reflect this change. The GUID values now used are the ones specific to the sandbox platform -- one for the u-boot image, and another for the u-boot environment image.
Install the FMP instance for raw images on the sandbox variant for testing the capsule update code. Install the FMP instance for the FIT images on the sandbox64 and sandbox_flattree variant for testing capsule update for FIT images. This is being done by splitting the capsule update script for FIT and raw images.
Changes since V5: * Restart the platform before starting the tests. This is done to clear out any stale state from a previously run test.
configs/sandbox64_defconfig | 1 - configs/sandbox_defconfig | 1 - configs/sandbox_flattree_defconfig | 5 + test/py/tests/test_efi_capsule/conftest.py | 21 +- .../test_capsule_firmware_fit.py | 191 ++++++++++++++++++ ...rmware.py => test_capsule_firmware_raw.py} | 167 ++++++--------- 6 files changed, 270 insertions(+), 116 deletions(-) create mode 100644 test/py/tests/test_efi_capsule/test_capsule_firmware_fit.py rename test/py/tests/test_efi_capsule/{test_capsule_firmware.py => test_capsule_firmware_raw.py} (75%)
diff --git a/configs/sandbox64_defconfig b/configs/sandbox64_defconfig index 88f9ecbb7f..db748bbed3 100644 --- a/configs/sandbox64_defconfig +++ b/configs/sandbox64_defconfig @@ -246,7 +246,6 @@ CONFIG_ERRNO_STR=y CONFIG_EFI_RUNTIME_UPDATE_CAPSULE=y CONFIG_EFI_CAPSULE_ON_DISK=y CONFIG_EFI_CAPSULE_FIRMWARE_FIT=y -CONFIG_EFI_CAPSULE_FIRMWARE_RAW=y CONFIG_EFI_SECURE_BOOT=y CONFIG_TEST_FDTDEC=y CONFIG_UNIT_TEST=y diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index cb8d590eb6..0dfc2d863d 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -319,7 +319,6 @@ CONFIG_SHA384=y CONFIG_ERRNO_STR=y CONFIG_EFI_RUNTIME_UPDATE_CAPSULE=y CONFIG_EFI_CAPSULE_ON_DISK=y -CONFIG_EFI_CAPSULE_FIRMWARE_FIT=y CONFIG_EFI_CAPSULE_FIRMWARE_RAW=y CONFIG_EFI_SECURE_BOOT=y CONFIG_TEST_FDTDEC=y diff --git a/configs/sandbox_flattree_defconfig b/configs/sandbox_flattree_defconfig index 24b272068a..27dd38a0c0 100644 --- a/configs/sandbox_flattree_defconfig +++ b/configs/sandbox_flattree_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_BOOTEFI_HELLO=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y CONFIG_CMD_ERASEENV=y +CONFIG_CMD_NVEDIT_EFI=y CONFIG_CMD_NVEDIT_INFO=y CONFIG_CMD_NVEDIT_LOAD=y CONFIG_CMD_NVEDIT_SELECT=y @@ -209,3 +210,7 @@ CONFIG_HEXDUMP=y CONFIG_UNIT_TEST=y CONFIG_UT_TIME=y CONFIG_UT_DM=y +CONFIG_EFI_RUNTIME_UPDATE_CAPSULE=y +CONFIG_EFI_CAPSULE_ON_DISK=y +CONFIG_EFI_CAPSULE_FIRMWARE_FIT=y +CONFIG_DFU_SF=y diff --git a/test/py/tests/test_efi_capsule/conftest.py b/test/py/tests/test_efi_capsule/conftest.py index 9076087a12..d757415c88 100644 --- a/test/py/tests/test_efi_capsule/conftest.py +++ b/test/py/tests/test_efi_capsule/conftest.py @@ -72,7 +72,7 @@ def efi_capsule_data(request, u_boot_config):
# Create capsule files # two regions: one for u-boot.bin and the other for u-boot.env - check_call('cd %s; echo -n u-boot:Old > u-boot.bin.old; echo -n u-boot:New > u-boot.bin.new; echo -n u-boot-env:Old -> u-boot.env.old; echo -n u-boot-env:New > u-boot.env.new' % data_dir, + check_call('cd %s; echo -n u-boot:Old > u-boot.bin.old; echo -n u-boot:New > u-boot.bin.new; echo -n u-boot-env:Old > u-boot.env.old; echo -n u-boot-env:New > u-boot.env.new' % data_dir, shell=True) check_call('sed -e "s?BINFILE1?u-boot.bin.new?" -e "s?BINFILE2?u-boot.env.new?" %s/test/py/tests/test_efi_capsule/uboot_bin_env.its > %s/uboot_bin_env.its' % (u_boot_config.source_dir, data_dir), @@ -80,21 +80,29 @@ def efi_capsule_data(request, u_boot_config): check_call('cd %s; %s/tools/mkimage -f uboot_bin_env.its uboot_bin_env.itb' % (data_dir, u_boot_config.build_dir), shell=True) - check_call('cd %s; %s/tools/mkeficapsule --index 1 --fit uboot_bin_env.itb Test01' % + check_call('cd %s; %s/tools/mkeficapsule --index 1 --guid 09D7CF52-0720-4710-91D1-08469B7FE9C8 u-boot.bin.new Test01' % (data_dir, u_boot_config.build_dir), shell=True) - check_call('cd %s; %s/tools/mkeficapsule --index 1 --raw u-boot.bin.new Test02' % + check_call('cd %s; %s/tools/mkeficapsule --index 2 --guid 5A7021F5-FEF2-48B4-AABA-832E777418C0 u-boot.env.new Test02' % (data_dir, u_boot_config.build_dir), shell=True) - check_call('cd %s; %s/tools/mkeficapsule --index 1 --guid E2BB9C06-70E9-4B14-97A3-5A7913176E3F u-boot.bin.new Test03' % + check_call('cd %s; %s/tools/mkeficapsule --index 1 --guid 058B7D83-50D5-4C47-A195-60D86AD341C4 u-boot.bin.new Test03' % (data_dir, u_boot_config.build_dir), shell=True) + check_call('cd %s; %s/tools/mkeficapsule --index 1 --guid 3673B45D-6A7C-46F3-9E60-ADABB03F7937 uboot_bin_env.itb Test04' % + (data_dir, u_boot_config.build_dir), + shell=True) + check_call('cd %s; %s/tools/mkeficapsule --index 1 --guid 058B7D83-50D5-4C47-A195-60D86AD341C4 uboot_bin_env.itb Test05' % + (data_dir, u_boot_config.build_dir), + shell=True) + if capsule_auth_enabled: # firmware signed with proper key check_call('cd %s; ' '%s/tools/mkeficapsule --index 1 --monotonic-count 1 ' '--private-key SIGNER.key --certificate SIGNER.crt ' - '--raw u-boot.bin.new Test11' + '--guid 09D7DF52-0720-4710-91D1-08469B7FE9C8 ' + 'u-boot.bin.new Test11' % (data_dir, u_boot_config.build_dir), shell=True) # firmware signed with *mal* key @@ -102,7 +110,8 @@ def efi_capsule_data(request, u_boot_config): '%s/tools/mkeficapsule --index 1 --monotonic-count 1 ' '--private-key SIGNER2.key ' '--certificate SIGNER2.crt ' - '--raw u-boot.bin.new Test12' + '--guid 09D7DF52-0720-4710-91D1-08469B7FE9C8 ' + 'u-boot.bin.new Test12' % (data_dir, u_boot_config.build_dir), shell=True)
diff --git a/test/py/tests/test_efi_capsule/test_capsule_firmware_fit.py b/test/py/tests/test_efi_capsule/test_capsule_firmware_fit.py new file mode 100644 index 0000000000..5bef84958b --- /dev/null +++ b/test/py/tests/test_efi_capsule/test_capsule_firmware_fit.py @@ -0,0 +1,191 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (c) 2020, Linaro Limited +# Author: AKASHI Takahiro takahiro.akashi@linaro.org +# +# U-Boot UEFI: Firmware Update Test + +""" +This test verifies capsule-on-disk firmware update for FIT images +""" + +from subprocess import check_call, check_output, CalledProcessError +import pytest +from capsule_defs import * + + +@pytest.mark.boardspec('sandbox64') +@pytest.mark.boardspec('sandbox_flattree') +@pytest.mark.buildconfigspec('efi_capsule_firmware_fit') +@pytest.mark.buildconfigspec('efi_capsule_on_disk') +@pytest.mark.buildconfigspec('dfu') +@pytest.mark.buildconfigspec('dfu_sf') +@pytest.mark.buildconfigspec('cmd_efidebug') +@pytest.mark.buildconfigspec('cmd_fat') +@pytest.mark.buildconfigspec('cmd_memory') +@pytest.mark.buildconfigspec('cmd_nvedit_efi') +@pytest.mark.buildconfigspec('cmd_sf') +@pytest.mark.slow +class TestEfiCapsuleFirmwareFit(object): + def test_efi_capsule_fw1( + self, u_boot_config, u_boot_console, efi_capsule_data): + """ + Test Case 1 - Update U-Boot and U-Boot environment on SPI Flash + but with an incorrect GUID value in the capsule + No update should happen + 0x100000-0x150000: U-Boot binary (but dummy) + 0x150000-0x200000: U-Boot environment (but dummy) + """ + # other tests might have run and the + # system might not be in a clean state. + # Restart before starting the tests. + u_boot_console.restart_uboot() + + disk_img = efi_capsule_data + with u_boot_console.log.section('Test Case 1-a, before reboot'): + output = u_boot_console.run_command_list([ + 'host bind 0 %s' % disk_img, + 'efidebug boot add -b 1 TEST host 0:1 /helloworld.efi -s ""', + 'efidebug boot order 1', + 'env set -e -nv -bs -rt OsIndications =0x0000000000000004', + 'env set dfu_alt_info "sf 0:0=u-boot-bin raw 0x100000 0x50000;u-boot-env raw 0x150000 0x200000"', + 'env save']) + + # initialize contents + output = u_boot_console.run_command_list([ + 'sf probe 0:0', + 'fatload host 0:1 4000000 %s/u-boot.bin.old' % CAPSULE_DATA_DIR, + 'sf write 4000000 100000 10', + 'sf read 5000000 100000 10', + 'md.b 5000000 10']) + assert 'Old' in ''.join(output) + output = u_boot_console.run_command_list([ + 'sf probe 0:0', + 'fatload host 0:1 4000000 %s/u-boot.env.old' % CAPSULE_DATA_DIR, + 'sf write 4000000 150000 10', + 'sf read 5000000 150000 10', + 'md.b 5000000 10']) + assert 'Old' in ''.join(output) + + # place a capsule file + output = u_boot_console.run_command_list([ + 'fatload host 0:1 4000000 %s/Test05' % CAPSULE_DATA_DIR, + 'fatwrite host 0:1 4000000 %s/Test05 $filesize' % CAPSULE_INSTALL_DIR, + 'fatls host 0:1 %s' % CAPSULE_INSTALL_DIR]) + assert 'Test05' in ''.join(output) + + capsule_early = u_boot_config.buildconfig.get( + 'config_efi_capsule_on_disk_early') + capsule_auth = u_boot_config.buildconfig.get( + 'config_efi_capsule_authenticate') + + # reboot + u_boot_console.restart_uboot(expect_reset = capsule_early) + + with u_boot_console.log.section('Test Case 1-b, after reboot'): + if not capsule_early: + # make sure that dfu_alt_info exists even persistent variables + # are not available. + output = u_boot_console.run_command_list([ + 'env set dfu_alt_info "sf 0:0=u-boot-bin raw 0x100000 0x50000;u-boot-env raw 0x150000 0x200000"', + 'host bind 0 %s' % disk_img, + 'fatls host 0:1 %s' % CAPSULE_INSTALL_DIR]) + assert 'Test05' in ''.join(output) + + # need to run uefi command to initiate capsule handling + output = u_boot_console.run_command( + 'env print -e Capsule0000', wait_for_reboot = True) + + output = u_boot_console.run_command_list([ + 'sf probe 0:0', + 'sf read 4000000 100000 10', + 'md.b 4000000 10']) + assert 'u-boot:Old' in ''.join(output) + + output = u_boot_console.run_command_list([ + 'sf read 4000000 150000 10', + 'md.b 4000000 10']) + assert 'u-boot-env:Old' in ''.join(output) + + def test_efi_capsule_fw2( + self, u_boot_config, u_boot_console, efi_capsule_data): + """ + Test Case 2 - Update U-Boot and U-Boot environment on SPI Flash + 0x100000-0x150000: U-Boot binary (but dummy) + 0x150000-0x200000: U-Boot environment (but dummy) + """ + disk_img = efi_capsule_data + with u_boot_console.log.section('Test Case 2-a, before reboot'): + output = u_boot_console.run_command_list([ + 'host bind 0 %s' % disk_img, + 'efidebug boot add -b 1 TEST host 0:1 /helloworld.efi -s ""', + 'efidebug boot order 1', + 'env set -e -nv -bs -rt OsIndications =0x0000000000000004', + 'env set dfu_alt_info "sf 0:0=u-boot-bin raw 0x100000 0x50000;u-boot-env raw 0x150000 0x200000"', + 'env save']) + + # initialize contents + output = u_boot_console.run_command_list([ + 'sf probe 0:0', + 'fatload host 0:1 4000000 %s/u-boot.bin.old' % CAPSULE_DATA_DIR, + 'sf write 4000000 100000 10', + 'sf read 5000000 100000 10', + 'md.b 5000000 10']) + assert 'Old' in ''.join(output) + output = u_boot_console.run_command_list([ + 'sf probe 0:0', + 'fatload host 0:1 4000000 %s/u-boot.env.old' % CAPSULE_DATA_DIR, + 'sf write 4000000 150000 10', + 'sf read 5000000 150000 10', + 'md.b 5000000 10']) + assert 'Old' in ''.join(output) + + # place a capsule file + output = u_boot_console.run_command_list([ + 'fatload host 0:1 4000000 %s/Test04' % CAPSULE_DATA_DIR, + 'fatwrite host 0:1 4000000 %s/Test04 $filesize' % CAPSULE_INSTALL_DIR, + 'fatls host 0:1 %s' % CAPSULE_INSTALL_DIR]) + assert 'Test04' in ''.join(output) + + capsule_early = u_boot_config.buildconfig.get( + 'config_efi_capsule_on_disk_early') + capsule_auth = u_boot_config.buildconfig.get( + 'config_efi_capsule_authenticate') + + # reboot + u_boot_console.restart_uboot(expect_reset = capsule_early) + + with u_boot_console.log.section('Test Case 2-b, after reboot'): + if not capsule_early: + # make sure that dfu_alt_info exists even persistent variables + # are not available. + output = u_boot_console.run_command_list([ + 'env set dfu_alt_info "sf 0:0=u-boot-bin raw 0x100000 0x50000;u-boot-env raw 0x150000 0x200000"', + 'host bind 0 %s' % disk_img, + 'fatls host 0:1 %s' % CAPSULE_INSTALL_DIR]) + assert 'Test04' in ''.join(output) + + # need to run uefi command to initiate capsule handling + output = u_boot_console.run_command( + 'env print -e Capsule0000', wait_for_reboot = True) + + output = u_boot_console.run_command_list([ + 'host bind 0 %s' % disk_img, + 'fatls host 0:1 %s' % CAPSULE_INSTALL_DIR]) + assert 'Test04' not in ''.join(output) + + output = u_boot_console.run_command_list([ + 'sf probe 0:0', + 'sf read 4000000 100000 10', + 'md.b 4000000 10']) + if capsule_auth: + assert 'u-boot:Old' in ''.join(output) + else: + assert 'u-boot:New' in ''.join(output) + + output = u_boot_console.run_command_list([ + 'sf read 4000000 150000 10', + 'md.b 4000000 10']) + if capsule_auth: + assert 'u-boot-env:Old' in ''.join(output) + else: + assert 'u-boot-env:New' in ''.join(output) diff --git a/test/py/tests/test_efi_capsule/test_capsule_firmware.py b/test/py/tests/test_efi_capsule/test_capsule_firmware_raw.py similarity index 75% rename from test/py/tests/test_efi_capsule/test_capsule_firmware.py rename to test/py/tests/test_efi_capsule/test_capsule_firmware_raw.py index 1dcf1c70f4..ae99f080ff 100644 --- a/test/py/tests/test_efi_capsule/test_capsule_firmware.py +++ b/test/py/tests/test_efi_capsule/test_capsule_firmware_raw.py @@ -5,7 +5,7 @@ # U-Boot UEFI: Firmware Update Test
""" -This test verifies capsule-on-disk firmware update +This test verifies capsule-on-disk firmware update for raw images """
from subprocess import check_call, check_output, CalledProcessError @@ -14,7 +14,6 @@ from capsule_defs import *
@pytest.mark.boardspec('sandbox') -@pytest.mark.buildconfigspec('efi_capsule_firmware_fit') @pytest.mark.buildconfigspec('efi_capsule_firmware_raw') @pytest.mark.buildconfigspec('efi_capsule_on_disk') @pytest.mark.buildconfigspec('dfu') @@ -25,23 +24,29 @@ from capsule_defs import * @pytest.mark.buildconfigspec('cmd_nvedit_efi') @pytest.mark.buildconfigspec('cmd_sf') @pytest.mark.slow -class TestEfiCapsuleFirmwareFit(object): +class TestEfiCapsuleFirmwareRaw(object): def test_efi_capsule_fw1( self, u_boot_config, u_boot_console, efi_capsule_data): """ Test Case 1 - Update U-Boot and U-Boot environment on SPI Flash - but with OsIndications unset + but with an incorrect GUID value in the capsule No update should happen 0x100000-0x150000: U-Boot binary (but dummy) 0x150000-0x200000: U-Boot environment (but dummy) """ + + # other tests might have run and the + # system might not be in a clean state. + # Restart before starting the tests. + u_boot_console.restart_uboot() + disk_img = efi_capsule_data with u_boot_console.log.section('Test Case 1-a, before reboot'): output = u_boot_console.run_command_list([ 'host bind 0 %s' % disk_img, 'efidebug boot add -b 1 TEST host 0:1 /helloworld.efi -s ""', 'efidebug boot order 1', - 'env set -e OsIndications', + 'env set -e -nv -bs -rt OsIndications =0x0000000000000004', 'env set dfu_alt_info "sf 0:0=u-boot-bin raw 0x100000 0x50000;u-boot-env raw 0x150000 0x200000"', 'env save'])
@@ -63,16 +68,17 @@ class TestEfiCapsuleFirmwareFit(object):
# place a capsule file output = u_boot_console.run_command_list([ - 'fatload host 0:1 4000000 %s/Test01' % CAPSULE_DATA_DIR, - 'fatwrite host 0:1 4000000 %s/Test01 $filesize' % CAPSULE_INSTALL_DIR, + 'fatload host 0:1 4000000 %s/Test03' % CAPSULE_DATA_DIR, + 'fatwrite host 0:1 4000000 %s/Test03 $filesize' % CAPSULE_INSTALL_DIR, 'fatls host 0:1 %s' % CAPSULE_INSTALL_DIR]) - assert 'Test01' in ''.join(output) + assert 'Test03' in ''.join(output)
# reboot u_boot_console.restart_uboot()
capsule_early = u_boot_config.buildconfig.get( 'config_efi_capsule_on_disk_early') + with u_boot_console.log.section('Test Case 1-b, after reboot'): if not capsule_early: # make sure that dfu_alt_info exists even persistent variables @@ -81,16 +87,11 @@ class TestEfiCapsuleFirmwareFit(object): 'env set dfu_alt_info "sf 0:0=u-boot-bin raw 0x100000 0x50000;u-boot-env raw 0x150000 0x200000"', 'host bind 0 %s' % disk_img, 'fatls host 0:1 %s' % CAPSULE_INSTALL_DIR]) - assert 'Test01' in ''.join(output) + assert 'Test03' in ''.join(output)
# need to run uefi command to initiate capsule handling output = u_boot_console.run_command( - 'env print -e Capsule0000') - - output = u_boot_console.run_command_list([ - 'host bind 0 %s' % disk_img, - 'fatls host 0:1 %s' % CAPSULE_INSTALL_DIR]) - assert 'Test01' in ''.join(output) + 'env print -e Capsule0000', wait_for_reboot = True)
output = u_boot_console.run_command_list([ 'sf probe 0:0', @@ -107,6 +108,8 @@ class TestEfiCapsuleFirmwareFit(object): self, u_boot_config, u_boot_console, efi_capsule_data): """ Test Case 2 - Update U-Boot and U-Boot environment on SPI Flash + but with OsIndications unset + No update should happen 0x100000-0x150000: U-Boot binary (but dummy) 0x150000-0x200000: U-Boot environment (but dummy) """ @@ -116,7 +119,7 @@ class TestEfiCapsuleFirmwareFit(object): 'host bind 0 %s' % disk_img, 'efidebug boot add -b 1 TEST host 0:1 /helloworld.efi -s ""', 'efidebug boot order 1', - 'env set -e -nv -bs -rt OsIndications =0x0000000000000004', + 'env set -e OsIndications', 'env set dfu_alt_info "sf 0:0=u-boot-bin raw 0x100000 0x50000;u-boot-env raw 0x150000 0x200000"', 'env save'])
@@ -136,21 +139,24 @@ class TestEfiCapsuleFirmwareFit(object): 'md.b 5000000 10']) assert 'Old' in ''.join(output)
- # place a capsule file + # place the capsule files output = u_boot_console.run_command_list([ 'fatload host 0:1 4000000 %s/Test01' % CAPSULE_DATA_DIR, 'fatwrite host 0:1 4000000 %s/Test01 $filesize' % CAPSULE_INSTALL_DIR, 'fatls host 0:1 %s' % CAPSULE_INSTALL_DIR]) assert 'Test01' in ''.join(output)
- capsule_early = u_boot_config.buildconfig.get( - 'config_efi_capsule_on_disk_early') - capsule_auth = u_boot_config.buildconfig.get( - 'config_efi_capsule_authenticate') + output = u_boot_console.run_command_list([ + 'fatload host 0:1 4000000 %s/Test02' % CAPSULE_DATA_DIR, + 'fatwrite host 0:1 4000000 %s/Test02 $filesize' % CAPSULE_INSTALL_DIR, + 'fatls host 0:1 %s' % CAPSULE_INSTALL_DIR]) + assert 'Test02' in ''.join(output)
# reboot - u_boot_console.restart_uboot(expect_reset = capsule_early) + u_boot_console.restart_uboot()
+ capsule_early = u_boot_config.buildconfig.get( + 'config_efi_capsule_on_disk_early') with u_boot_console.log.section('Test Case 2-b, after reboot'): if not capsule_early: # make sure that dfu_alt_info exists even persistent variables @@ -160,32 +166,28 @@ class TestEfiCapsuleFirmwareFit(object): 'host bind 0 %s' % disk_img, 'fatls host 0:1 %s' % CAPSULE_INSTALL_DIR]) assert 'Test01' in ''.join(output) + assert 'Test02' in ''.join(output)
# need to run uefi command to initiate capsule handling output = u_boot_console.run_command( - 'env print -e Capsule0000', wait_for_reboot = True) + 'env print -e Capsule0000')
output = u_boot_console.run_command_list([ 'host bind 0 %s' % disk_img, 'fatls host 0:1 %s' % CAPSULE_INSTALL_DIR]) - assert 'Test01' not in ''.join(output) + assert 'Test01' in ''.join(output) + assert 'Test02' in ''.join(output)
output = u_boot_console.run_command_list([ 'sf probe 0:0', 'sf read 4000000 100000 10', 'md.b 4000000 10']) - if capsule_auth: - assert 'u-boot:Old' in ''.join(output) - else: - assert 'u-boot:New' in ''.join(output) + assert 'u-boot:Old' in ''.join(output)
output = u_boot_console.run_command_list([ 'sf read 4000000 150000 10', 'md.b 4000000 10']) - if capsule_auth: - assert 'u-boot-env:Old' in ''.join(output) - else: - assert 'u-boot-env:New' in ''.join(output) + assert 'u-boot-env:Old' in ''.join(output)
def test_efi_capsule_fw3( self, u_boot_config, u_boot_console, efi_capsule_data): @@ -203,7 +205,7 @@ class TestEfiCapsuleFirmwareFit(object): 'env set dfu_alt_info "sf 0:0=u-boot-bin raw 0x100000 0x50000;u-boot-env raw 0x150000 0x200000"', 'env save'])
- # initialize content + # initialize contents output = u_boot_console.run_command_list([ 'sf probe 0:0', 'fatload host 0:1 4000000 %s/u-boot.bin.old' % CAPSULE_DATA_DIR, @@ -212,7 +214,21 @@ class TestEfiCapsuleFirmwareFit(object): 'md.b 5000000 10']) assert 'Old' in ''.join(output)
- # place a capsule file + output = u_boot_console.run_command_list([ + 'sf probe 0:0', + 'fatload host 0:1 4000000 %s/u-boot.env.old' % CAPSULE_DATA_DIR, + 'sf write 4000000 150000 10', + 'sf read 5000000 100000 10', + 'md.b 5000000 10']) + assert 'Old' in ''.join(output) + + # place the capsule files + output = u_boot_console.run_command_list([ + 'fatload host 0:1 4000000 %s/Test01' % CAPSULE_DATA_DIR, + 'fatwrite host 0:1 4000000 %s/Test01 $filesize' % CAPSULE_INSTALL_DIR, + 'fatls host 0:1 %s' % CAPSULE_INSTALL_DIR]) + assert 'Test01' in ''.join(output) + output = u_boot_console.run_command_list([ 'fatload host 0:1 4000000 %s/Test02' % CAPSULE_DATA_DIR, 'fatwrite host 0:1 4000000 %s/Test02 $filesize' % CAPSULE_INSTALL_DIR, @@ -235,6 +251,7 @@ class TestEfiCapsuleFirmwareFit(object): 'env set dfu_alt_info "sf 0:0=u-boot-bin raw 0x100000 0x50000;u-boot-env raw 0x150000 0x200000"', 'host bind 0 %s' % disk_img, 'fatls host 0:1 %s' % CAPSULE_INSTALL_DIR]) + assert 'Test01' in ''.join(output) assert 'Test02' in ''.join(output)
# need to run uefi command to initiate capsule handling @@ -246,15 +263,16 @@ class TestEfiCapsuleFirmwareFit(object): 'env set dfu_alt_info "sf 0:0=u-boot-bin raw 0x100000 0x50000;u-boot-env raw 0x150000 0x200000"', 'efidebug capsule esrt'])
- # ensure that EFI_FIRMWARE_IMAGE_TYPE_UBOOT_FIT_GUID is in the ESRT. - assert 'AE13FF2D-9AD4-4E25-9AC8-6D80B3B22147' in ''.join(output) + # ensure that SANDBOX_UBOOT_ENV_IMAGE_GUID is in the ESRT. + assert '5A7021F5-FEF2-48B4-AABA-832E777418C0' in ''.join(output)
- # ensure that EFI_FIRMWARE_IMAGE_TYPE_UBOOT_RAW_GUID is in the ESRT. - assert 'E2BB9C06-70E9-4B14-97A3-5A7913176E3F' in ''.join(output) + # ensure that SANDBOX_UBOOT_IMAGE_GUID is in the ESRT. + assert '09D7CF52-0720-4710-91D1-08469B7FE9C8' in ''.join(output)
output = u_boot_console.run_command_list([ 'host bind 0 %s' % disk_img, 'fatls host 0:1 %s' % CAPSULE_INSTALL_DIR]) + assert 'Test01' not in ''.join(output) assert 'Test02' not in ''.join(output)
output = u_boot_console.run_command_list([ @@ -266,78 +284,11 @@ class TestEfiCapsuleFirmwareFit(object): else: assert 'u-boot:New' in ''.join(output)
- def test_efi_capsule_fw4( - self, u_boot_config, u_boot_console, efi_capsule_data): - """ - Test Case 4 - Test "--guid" option of mkeficapsule - The test scenario is the same as Case 3. - """ - disk_img = efi_capsule_data - with u_boot_console.log.section('Test Case 4-a, before reboot'): - output = u_boot_console.run_command_list([ - 'host bind 0 %s' % disk_img, - 'efidebug boot add -b 1 TEST host 0:1 /helloworld.efi -s ""', - 'efidebug boot order 1', - 'env set -e -nv -bs -rt OsIndications =0x0000000000000004', - 'env set dfu_alt_info "sf 0:0=u-boot-bin raw 0x100000 0x50000;u-boot-env raw 0x150000 0x200000"', - 'env save']) - - # initialize content output = u_boot_console.run_command_list([ 'sf probe 0:0', - 'fatload host 0:1 4000000 %s/u-boot.bin.old' % CAPSULE_DATA_DIR, - 'sf write 4000000 100000 10', - 'sf read 5000000 100000 10', - 'md.b 5000000 10']) - assert 'Old' in ''.join(output) - - # place a capsule file - output = u_boot_console.run_command_list([ - 'fatload host 0:1 4000000 %s/Test03' % CAPSULE_DATA_DIR, - 'fatwrite host 0:1 4000000 %s/Test03 $filesize' % CAPSULE_INSTALL_DIR, - 'fatls host 0:1 %s' % CAPSULE_INSTALL_DIR]) - assert 'Test03' in ''.join(output) - - capsule_early = u_boot_config.buildconfig.get( - 'config_efi_capsule_on_disk_early') - capsule_auth = u_boot_config.buildconfig.get( - 'config_efi_capsule_authenticate') - - # reboot - u_boot_console.restart_uboot(expect_reset = capsule_early) - - with u_boot_console.log.section('Test Case 4-b, after reboot'): - if not capsule_early: - # make sure that dfu_alt_info exists even persistent variables - # are not available. - output = u_boot_console.run_command_list([ - 'env set dfu_alt_info "sf 0:0=u-boot-bin raw 0x100000 0x50000;u-boot-env raw 0x150000 0x200000"', - 'host bind 0 %s' % disk_img, - 'fatls host 0:1 %s' % CAPSULE_INSTALL_DIR]) - assert 'Test03' in ''.join(output) - - # need to run uefi command to initiate capsule handling - output = u_boot_console.run_command( - 'env print -e Capsule0000', wait_for_reboot = True) - - # make sure the dfu_alt_info exists because it is required for making ESRT. - output = u_boot_console.run_command_list([ - 'env set dfu_alt_info "sf 0:0=u-boot-bin raw 0x100000 0x50000;u-boot-env raw 0x150000 0x200000"', - 'efidebug capsule esrt']) - - # ensure that EFI_FIRMWARE_IMAGE_TYPE_UBOOT_RAW_GUID is in the ESRT. - assert 'E2BB9C06-70E9-4B14-97A3-5A7913176E3F' in ''.join(output) - - output = u_boot_console.run_command_list([ - 'host bind 0 %s' % disk_img, - 'fatls host 0:1 %s' % CAPSULE_INSTALL_DIR]) - assert 'Test03' not in ''.join(output) - - output = u_boot_console.run_command_list([ - 'sf probe 0:0', - 'sf read 4000000 100000 10', + 'sf read 4000000 150000 10', 'md.b 4000000 10']) if capsule_auth: - assert 'u-boot:Old' in ''.join(output) + assert 'u-boot-env:Old' in ''.join(output) else: - assert 'u-boot:New' in ''.join(output) + assert 'u-boot-env:New' in ''.join(output)
Why do we have to have different configs to test FIT and RAW capsules?
Changes since V5:
- Restart the platform before starting the tests. This is done to clear out any stale state from a previously run test.
check_call('cd %s; echo -n u-boot:Old > u-boot.bin.old; echo -n u-boot:New > u-boot.bin.new; echo -n u-boot-env:Old > u-boot.env.old; echo -n u-boot-env:New > u-boot.env.new' % data_dir, shell=True) check_call('sed -e \"s?BINFILE1?u-boot.bin.new?\" -e \"s?BINFILE2?u-boot.env.new?\" %s/test/py/tests/test_efi_capsule/uboot_bin_env.its > %s/uboot_bin_env.its' % (u_boot_config.source_dir, data_dir),
shell=True)
shell=True)
If possible, can you manage the git history so that test/py/tests/test_efi_capsule/test_capsule_firmware_fit.py is the original and test/py/tests/test_efi_capsule/test_capsule_firmware_raw.py is a new test? I think that will reflect the correct history of development/changes.
-Takahiro Akashi
- def test_efi_capsule_fw1(
'env save'])
'sf probe 0:0',
'md.b 5000000 10'])
'sf probe 0:0',
'md.b 5000000 10'])
# reboot
'sf probe 0:0',
'md.b 4000000 10'])
'md.b 4000000 10'])
- def test_efi_capsule_fw2(
'env save'])
'sf probe 0:0',
'md.b 5000000 10'])
'sf probe 0:0',
'md.b 5000000 10'])
# reboot
'sf probe 0:0',
'md.b 4000000 10'])
if capsule_auth:
else:
'md.b 4000000 10'])
if capsule_auth:
else:
assert 'Test03' in ''.join(output) # reboot u_boot_console.restart_uboot() capsule_early = u_boot_config.buildconfig.get( 'config_efi_capsule_on_disk_early')
assert 'Test03' in ''.join(output) # need to run uefi command to initiate capsule handling output = u_boot_console.run_command(
'env print -e Capsule0000', wait_for_reboot = True) output = u_boot_console.run_command_list([ 'sf probe 0:0',
assert 'Test02' in ''.join(output) # reboot
assert 'Test02' in ''.join(output) # need to run uefi command to initiate capsule handling output = u_boot_console.run_command(
'env print -e Capsule0000') output = u_boot_console.run_command_list([ 'host bind 0 %s' % disk_img, 'fatls host 0:1 %s' % CAPSULE_INSTALL_DIR])
assert 'Test02' in ''.join(output) output = u_boot_console.run_command_list([ 'sf probe 0:0', 'sf read 4000000 100000 10', 'md.b 4000000 10'])
if capsule_auth:
else:
assert 'u-boot:Old' in ''.join(output) output = u_boot_console.run_command_list([ 'sf read 4000000 150000 10', 'md.b 4000000 10'])
if capsule_auth:
else:
'sf probe 0:0',
'md.b 5000000 10'])
assert 'Test01' in ''.join(output) assert 'Test02' in ''.join(output) # need to run uefi command to initiate capsule handling
assert '09D7CF52-0720-4710-91D1-08469B7FE9C8' in ''.join(output) output = u_boot_console.run_command_list([ 'host bind 0 %s' % disk_img, 'fatls host 0:1 %s' % CAPSULE_INSTALL_DIR])
assert 'Test01' not in ''.join(output) assert 'Test02' not in ''.join(output) output = u_boot_console.run_command_list([
'env save'])
'md.b 5000000 10'])
# reboot
'sf probe 0:0',
-- 2.25.1
On Wed, 13 Apr 2022 at 12:05, AKASHI Takahiro takahiro.akashi@linaro.org wrote:
With the current design, we have an FMP instance per platform. But the struct efi_fw_images can be extended to have a fmp member, so every image would have an FMP instance associated with it. With that, a platform can define multiple FMP instances. Would you prefer that?
Changes since V5:
shell=True)
shell=True)
Okay. Let me see if/how that can be done. If you know a way to do so, please let me know.
-sughosh
-Takahiro Akashi
'env save'])
'sf probe 0:0',
'md.b 5000000 10'])
'sf probe 0:0',
'md.b 5000000 10'])
# reboot
'sf probe 0:0',
'md.b 4000000 10'])
'md.b 4000000 10'])
'env save'])
'sf probe 0:0',
'md.b 5000000 10'])
'sf probe 0:0',
'md.b 5000000 10'])
# reboot
'sf probe 0:0',
'md.b 4000000 10'])
if capsule_auth:
else:
'md.b 4000000 10'])
if capsule_auth:
else:
if capsule_auth:
else:
if capsule_auth:
else:
'sf probe 0:0',
'md.b 5000000 10'])
'env save'])
'md.b 5000000 10'])
# reboot
'sf probe 0:0',
-- 2.25.1
The capsule update code has been modified for getting the image GUID values from the platform code. With this, each image now has a unique GUID value. With this change, there is no longer a need for defining GUIDs for FIT and raw images. Remove these GUID values.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org ---
include/efi_api.h | 8 -------- lib/efi_loader/efi_firmware.c | 4 ---- 2 files changed, 12 deletions(-)
diff --git a/include/efi_api.h b/include/efi_api.h index 982c200172..c7f7873b5d 100644 --- a/include/efi_api.h +++ b/include/efi_api.h @@ -1967,14 +1967,6 @@ struct efi_signature_list { EFI_GUID(0x86c77a67, 0x0b97, 0x4633, 0xa1, 0x87, \ 0x49, 0x10, 0x4d, 0x06, 0x85, 0xc7)
-#define EFI_FIRMWARE_IMAGE_TYPE_UBOOT_FIT_GUID \ - EFI_GUID(0xae13ff2d, 0x9ad4, 0x4e25, 0x9a, 0xc8, \ - 0x6d, 0x80, 0xb3, 0xb2, 0x21, 0x47) - -#define EFI_FIRMWARE_IMAGE_TYPE_UBOOT_RAW_GUID \ - EFI_GUID(0xe2bb9c06, 0x70e9, 0x4b14, 0x97, 0xa3, \ - 0x5a, 0x79, 0x13, 0x17, 0x6e, 0x3f) - #define IMAGE_ATTRIBUTE_IMAGE_UPDATABLE 0x0000000000000001 #define IMAGE_ATTRIBUTE_RESET_REQUIRED 0x0000000000000002 #define IMAGE_ATTRIBUTE_AUTHENTICATION_REQUIRED 0x0000000000000004 diff --git a/lib/efi_loader/efi_firmware.c b/lib/efi_loader/efi_firmware.c index c2fe660cdd..bd9ed1e524 100644 --- a/lib/efi_loader/efi_firmware.c +++ b/lib/efi_loader/efi_firmware.c @@ -188,8 +188,6 @@ static efi_status_t efi_fill_image_desc_array( * - versioning of firmware image * - package information */ -const efi_guid_t efi_firmware_image_type_uboot_fit = - EFI_FIRMWARE_IMAGE_TYPE_UBOOT_FIT_GUID;
/** * efi_firmware_fit_get_image_info - return information about the current @@ -296,8 +294,6 @@ const struct efi_firmware_management_protocol efi_fmp_fit = { * This FIRMWARE_MANAGEMENT_PROTOCOL driver provides a firmware update * method with raw data. */ -const efi_guid_t efi_firmware_image_type_uboot_raw = - EFI_FIRMWARE_IMAGE_TYPE_UBOOT_RAW_GUID;
/** * efi_firmware_raw_get_image_info - return information about the current
While building a capsule, the GUID value of that specific image is to be passed through the --guid command option to the mkeficapsule tool. This renders the EFI_FIRMWARE_IMAGE_TYPE_UBOOT_FIT_GUID and EFI_FIRMWARE_IMAGE_TYPE_UBOOT_RAW_GUID values superfluous. Remove the --raw and --fit command line options as well.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org Acked-by: Ilias Apalodimas ilias.apalodimas@linaro.org ---
tools/eficapsule.h | 8 -------- tools/mkeficapsule.c | 26 +------------------------- 2 files changed, 1 insertion(+), 33 deletions(-)
diff --git a/tools/eficapsule.h b/tools/eficapsule.h index 69c9c58c2f..d63b831443 100644 --- a/tools/eficapsule.h +++ b/tools/eficapsule.h @@ -37,14 +37,6 @@ typedef struct { EFI_GUID(0x6dcbd5ed, 0xe82d, 0x4c44, 0xbd, 0xa1, \ 0x71, 0x94, 0x19, 0x9a, 0xd9, 0x2a)
-#define EFI_FIRMWARE_IMAGE_TYPE_UBOOT_FIT_GUID \ - EFI_GUID(0xae13ff2d, 0x9ad4, 0x4e25, 0x9a, 0xc8, \ - 0x6d, 0x80, 0xb3, 0xb2, 0x21, 0x47) - -#define EFI_FIRMWARE_IMAGE_TYPE_UBOOT_RAW_GUID \ - EFI_GUID(0xe2bb9c06, 0x70e9, 0x4b14, 0x97, 0xa3, \ - 0x5a, 0x79, 0x13, 0x17, 0x6e, 0x3f) - #define EFI_CERT_TYPE_PKCS7_GUID \ EFI_GUID(0x4aafd29d, 0x68df, 0x49ee, 0x8a, 0xa9, \ 0x34, 0x7d, 0x37, 0x56, 0x65, 0xa7) diff --git a/tools/mkeficapsule.c b/tools/mkeficapsule.c index c118335b93..5f74d23b9e 100644 --- a/tools/mkeficapsule.c +++ b/tools/mkeficapsule.c @@ -27,17 +27,11 @@ static const char *tool_name = "mkeficapsule";
efi_guid_t efi_guid_fm_capsule = EFI_FIRMWARE_MANAGEMENT_CAPSULE_ID_GUID; -efi_guid_t efi_guid_image_type_uboot_fit = - EFI_FIRMWARE_IMAGE_TYPE_UBOOT_FIT_GUID; -efi_guid_t efi_guid_image_type_uboot_raw = - EFI_FIRMWARE_IMAGE_TYPE_UBOOT_RAW_GUID; efi_guid_t efi_guid_cert_type_pkcs7 = EFI_CERT_TYPE_PKCS7_GUID;
-static const char *opts_short = "frg:i:I:v:p:c:m:dh"; +static const char *opts_short = "g:i:I:v:p:c:m:dh";
static struct option options[] = { - {"fit", no_argument, NULL, 'f'}, - {"raw", no_argument, NULL, 'r'}, {"guid", required_argument, NULL, 'g'}, {"index", required_argument, NULL, 'i'}, {"instance", required_argument, NULL, 'I'}, @@ -54,8 +48,6 @@ static void print_usage(void) fprintf(stderr, "Usage: %s [options] <image blob> <output file>\n" "Options:\n"
- "\t-f, --fit FIT image type\n" - "\t-r, --raw raw image type\n" "\t-g, --guid <guid string> guid for image blob type\n" "\t-i, --index <index> update image index\n" "\t-I, --instance <instance> update hardware instance\n" @@ -606,22 +598,6 @@ int main(int argc, char **argv) break;
switch (c) { - case 'f': - if (guid) { - fprintf(stderr, - "Image type already specified\n"); - exit(EXIT_FAILURE); - } - guid = &efi_guid_image_type_uboot_fit; - break; - case 'r': - if (guid) { - fprintf(stderr, - "Image type already specified\n"); - exit(EXIT_FAILURE); - } - guid = &efi_guid_image_type_uboot_raw; - break; case 'g': if (guid) { fprintf(stderr,
superfluous? I don't think it is the reason for removing guids for FIT/RAW.
Please update doc/mkeficapsule.1 as well.
-Takahiro Akashi
"\t-g, --guid <guid string> guid for image blob type\n" "\t-i, --index <index> update image index\n" "\t-I, --instance <instance> update hardware instance\n""\t-r, --raw raw image type\n"
switch (c) {
case 'f':
if (guid) {
fprintf(stderr,
exit(EXIT_FAILURE);
break;
case 'r':
if (guid) {
fprintf(stderr,
exit(EXIT_FAILURE);
case 'g': if (guid) { fprintf(stderr,break;
-- 2.25.1
On Wed, 13 Apr 2022 at 11:35, AKASHI Takahiro takahiro.akashi@linaro.org wrote:
The reason for using that word is that these GUID values would not be used any longer. Do you prefer some other phrasing of the sentence?
Will do.
-sughosh
-Takahiro Akashi
switch (c) {
case 'f':
if (guid) {
fprintf(stderr,
exit(EXIT_FAILURE);
break;
case 'r':
if (guid) {
fprintf(stderr,
exit(EXIT_FAILURE);
-- 2.25.1
They are not used not because we have "--guid" option, which I added later than "--fit" or "--raw" in order to handle extra cases, but because you changed the semantics of FIT/RAW drivers.
-Takahiro Akashi
Will do.
-sughosh
-Takahiro Akashi
switch (c) {
case 'f':
if (guid) {
fprintf(stderr,
exit(EXIT_FAILURE);
break;
case 'r':
if (guid) {
fprintf(stderr,
exit(EXIT_FAILURE);
-- 2.25.1
On Wed, 13 Apr 2022 at 11:53, AKASHI Takahiro takahiro.akashi@linaro.org wrote:
That is what I have mentioned above. With the passing of the GUID value through the --guid option, the raw and FIT GUIDs are no longer needed.
-sughosh
-Takahiro Akashi
Will do.
-sughosh
-Takahiro Akashi
switch (c) {
case 'f':
if (guid) {
fprintf(stderr,
exit(EXIT_FAILURE);
break;
case 'r':
if (guid) {
fprintf(stderr,
exit(EXIT_FAILURE);
-- 2.25.1
"--guid" could also be used as an alternative of "--fit" or "--raw" even without your patch applied. The point is that you have "changed the semantics". "This renders" doesn't explain it.
-Takahiro Akashi
-sughosh
-Takahiro Akashi
Will do.
-sughosh
-Takahiro Akashi
switch (c) {
case 'f':
if (guid) {
fprintf(stderr,
exit(EXIT_FAILURE);
break;
case 'r':
if (guid) {
fprintf(stderr,
exit(EXIT_FAILURE);
-- 2.25.1
Update the capsule update functionality related documentation to refect the additional definitions that need to be made per platform for supporting the capsule update feature.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org ---
doc/develop/uefi/uefi.rst | 51 +++++++++++++++++++++++++++++++++++++-- 1 file changed, 49 insertions(+), 2 deletions(-)
diff --git a/doc/develop/uefi/uefi.rst b/doc/develop/uefi/uefi.rst index fe337c88bd..b766aecf67 100644 --- a/doc/develop/uefi/uefi.rst +++ b/doc/develop/uefi/uefi.rst @@ -312,8 +312,8 @@ Run the following command .. code-block:: console
$ mkeficapsule \ - --index 1 --instance 0 \ - [--fit <FIT image> | --raw <raw image>] \ + --index <index> --instance 0 \ + --guid <image GUID> \ <capsule_file_name>
Performing the update @@ -333,6 +333,53 @@ won't be taken over across the reboot. If this is the case, you can skip this feature check with the Kconfig option (CONFIG_EFI_IGNORE_OSINDICATIONS) set.
+A few values need to be defined in the board file for performing the +capsule update. These values are defined in the board file by +initialisation of a structure which provides information needed for +capsule updates. The following structures have been defined for +containing the image related information + +.. code-block:: c + + struct efi_fw_images { + efi_guid_t image_type_id; + u16 *fw_name; + u8 image_index; + }; + + struct efi_capsule_update_info { + const char *dfu_string; + struct efi_fw_images *images; + }; + + +A string is defined which is to be used for populating the +dfu_alt_info variable. This string is used by the function +set_dfu_alt_info. Instead of taking the variable from the environment, +the capsule update feature requires that the variable be set through +the function, since that is more robust. Allowing the user to change +the location of the firmware updates is not a very secure +practice. Getting this information from the firmware itself is more +secure, assuming the firmware has been verified by a previous stage +boot loader. + +The firmware images structure defines the GUID values, image index +values and the name of the images that are to be updated through +the capsule update feature. These values are to be defined as part of +an array. These GUID values would be used by the Firmware Management +Protocol(FMP) to populate the image descriptor array and also +displayed as part of the ESRT table. The image index values defined in +the array should be one greater than the dfu alt number that +corresponds to the firmware image. So, if the dfu alt number for an +image is 2, the value of image index in the fw_images array for that +image should be 3. The dfu alt number can be obtained by running the +following command:: + + dfu list + +When using the FMP for FIT images, the image index value needs to be +set to 1. + Finally, the capsule update can be initiated by rebooting the board.
Enabling Capsule Authentication
$ mkeficapsule \
+.. code-block:: c
- struct efi_fw_images {
Why "images" (in the plural)?
u16 *fw_name;
u8 image_index;
Why not add "version" and "last_attempt_version" which is expected to be easily implemented in this structure.
- struct efi_capsule_update_info {
- dfu list
The explanation would be correct, but it's not quite easy to understand, in particular, index in case of raw. You should add some examples here.
-Takahiro Akashi
2.25.1
On Wed, 13 Apr 2022 at 11:48, AKASHI Takahiro takahiro.akashi@linaro.org wrote:
$ mkeficapsule \
+.. code-block:: c
Hmm, since this is to be an array of firmware images which should be handled by the capsule update code, I used a plural form. Do you prefer efi_fw_image instead?
u16 *fw_name;
u8 image_index;
It can be added to this structure, yes. But we will also need to add code in the capsule driver to update these fields accordingly. I can take this up as a follow up task once the FWU series upstreaming is done.
- dfu list
I have added an example above for the raw images, as to how the image index corresponds with the dfu alt number. Does it not suffice?
-sughosh
-Takahiro Akashi
2.25.1
$ mkeficapsule \
+.. code-block:: c
This structure (not a variable like struct efi_fw_image foo_images[]) can only hold/represent one firmware image, right? If so, efi_fw_image looks better.
u16 *fw_name;
u8 image_index;
- dfu list
I hope that it will cover not only index, but example arrays of struct efi_fw_image and struct efi_capsule_update_info as well as an example "dfu_alto_info".
-Takahiro Akashi
-sughosh
-Takahiro Akashi
2.25.1
Hi
2022年4月13日(水) 16:33 AKASHI Takahiro takahiro.akashi@linaro.org:
$ mkeficapsule \
+.. code-block:: c
u16 *fw_name;
u8 image_index;
- dfu list
+1. If there is an example of "dfu_alt_info", the platform setting of image-type and index list, and how to make a capsule file in that case, people can easily understand the relationship of them. Can we use Qemu case for example?
Thank you,
-Takahiro Akashi
-sughosh
-Takahiro Akashi
2.25.1
AKASHI Takahiro
Masami Hiramatsu
Sughosh Ganu
