[U-Boot] [PATCH 0/3] Introduce asm-offsets and fix CONFIG_SYS_GBL_DATA_SIZE problems
The following patch series starts some clean up of for the handling f initial data; the most important change is the replacement of a manually configured (and thus often wrong) CONFIG_SYS_GBL_DATA_SIZE by an automatically generated value.
More similar clean-ups can and will be done, but this is stuff for the next merge window (or the "next" branch); here we focus on a fix for the CONFIG_SYS_GBL_DATA_SIZE problems.
The changes are mostly simple and straightforward, but they are huge as they affect a lots of files.
[PATCH 1/3] Rename CONFIG_SYS_INIT_RAM_END into CONFIG_SYS_INIT_RAM_SIZE
CONFIG_SYS_INIT_RAM_END was a misnomer as it suggests this might be some end address; to make the meaning more clear we rename it into CONFIG_SYS_INIT_RAM_SIZE
No other code changes are performed in this patch, only minor editing of white space (due to the changed length) and the comments was done, where noticed.
Note that the code for the PATI and cmi_mpc5xx board configurations looks seriously broken. Last known maintainers on Cc:
Signed-off-by: Wolfgang Denk wd@denx.de Cc: Denis Peter d.peter@mpl.ch Cc: Martin Winistoerfer martinwinistoerfer@gmx.ch --- README | 2 +- arch/m68k/lib/board.c | 2 +- arch/powerpc/cpu/74xx_7xx/start.S | 4 ++-- arch/powerpc/cpu/mpc83xx/start.S | 4 ++-- arch/powerpc/cpu/mpc86xx/start.S | 4 ++-- arch/powerpc/cpu/ppc4xx/start.S | 22 +++++++++++----------- board/fads/fads.h | 4 ++-- include/configs/A3000.h | 4 ++-- include/configs/ADCIOP.h | 4 ++-- include/configs/AMX860.h | 4 ++-- include/configs/AP1000.h | 4 ++-- include/configs/APC405.h | 4 ++-- include/configs/AR405.h | 4 ++-- include/configs/ASH405.h | 4 ++-- include/configs/ATUM8548.h | 4 ++-- include/configs/Adder.h | 4 ++-- include/configs/Alaska8220.h | 4 ++-- include/configs/BAB7xx.h | 4 ++-- include/configs/BC3450.h | 6 +++--- include/configs/BMW.h | 4 ++-- include/configs/CANBT.h | 4 ++-- include/configs/CATcenter.h | 4 ++-- include/configs/CMS700.h | 4 ++-- include/configs/CPC45.h | 4 ++-- include/configs/CPCI2DP.h | 4 ++-- include/configs/CPCI405.h | 4 ++-- include/configs/CPCI4052.h | 4 ++-- include/configs/CPCI405AB.h | 4 ++-- include/configs/CPCI405DT.h | 4 ++-- include/configs/CPCI750.h | 4 ++-- include/configs/CPCIISER4.h | 4 ++-- include/configs/CPU86.h | 4 ++-- include/configs/CPU87.h | 4 ++-- include/configs/CRAYL1.h | 8 ++++---- include/configs/CU824.h | 4 ++-- include/configs/DASA_SIM.h | 4 ++-- include/configs/DB64360.h | 4 ++-- include/configs/DB64460.h | 4 ++-- include/configs/DP405.h | 4 ++-- include/configs/DU405.h | 4 ++-- include/configs/DU440.h | 4 ++-- include/configs/EB+MCF-EV123.h | 8 ++++---- include/configs/ELPPC.h | 4 ++-- include/configs/ELPT860.h | 4 ++-- include/configs/EP88x.h | 4 ++-- include/configs/ERIC.h | 4 ++-- include/configs/ESTEEM192E.h | 4 ++-- include/configs/ETX094.h | 4 ++-- include/configs/EVB64260.h | 4 ++-- include/configs/EXBITGEN.h | 4 ++-- include/configs/FADS823.h | 4 ++-- include/configs/FADS850SAR.h | 4 ++-- include/configs/FLAGADM.h | 4 ++-- include/configs/FPS850L.h | 4 ++-- include/configs/FPS860L.h | 4 ++-- include/configs/G2000.h | 4 ++-- include/configs/GEN860T.h | 4 ++-- include/configs/GENIETV.h | 4 ++-- include/configs/HH405.h | 4 ++-- include/configs/HIDDEN_DRAGON.h | 8 ++++---- include/configs/HUB405.h | 4 ++-- include/configs/IAD210.h | 4 ++-- include/configs/ICU862.h | 4 ++-- include/configs/IDS8247.h | 4 ++-- include/configs/IP860.h | 4 ++-- include/configs/IPHASE4539.h | 4 ++-- include/configs/ISPAN.h | 4 ++-- include/configs/IVML24.h | 8 ++++---- include/configs/IVMS8.h | 8 ++++---- include/configs/IceCube.h | 4 ++-- include/configs/JSE.h | 4 ++-- include/configs/KAREF.h | 4 ++-- include/configs/KUP4K.h | 4 ++-- include/configs/KUP4X.h | 4 ++-- include/configs/LANTEC.h | 4 ++-- include/configs/M5208EVBE.h | 8 ++++---- include/configs/M52277EVB.h | 10 +++++----- include/configs/M5235EVB.h | 8 ++++---- include/configs/M5249EVB.h | 8 ++++---- include/configs/M5253DEMO.h | 8 ++++---- include/configs/M5253EVBE.h | 8 ++++---- include/configs/M5271EVB.h | 8 ++++---- include/configs/M5272C3.h | 8 ++++---- include/configs/M5275EVB.h | 8 ++++---- include/configs/M5282EVB.h | 8 ++++---- include/configs/M53017EVB.h | 8 ++++---- include/configs/M5329EVB.h | 8 ++++---- include/configs/M5373EVB.h | 8 ++++---- include/configs/M54451EVB.h | 10 +++++----- include/configs/M54455EVB.h | 10 +++++----- include/configs/M5475EVB.h | 10 +++++----- include/configs/M5485EVB.h | 10 +++++----- include/configs/MBX.h | 4 ++-- include/configs/MBX860T.h | 4 ++-- include/configs/METROBOX.h | 4 ++-- include/configs/MHPC.h | 4 ++-- include/configs/MIP405.h | 4 ++-- include/configs/ML2.h | 4 ++-- include/configs/MOUSSE.h | 4 ++-- include/configs/MPC8260ADS.h | 4 ++-- include/configs/MPC8266ADS.h | 4 ++-- include/configs/MPC8308RDB.h | 4 ++-- include/configs/MPC8313ERDB.h | 4 ++-- include/configs/MPC8315ERDB.h | 4 ++-- include/configs/MPC8323ERDB.h | 4 ++-- include/configs/MPC832XEMDS.h | 4 ++-- include/configs/MPC8349EMDS.h | 4 ++-- include/configs/MPC8349ITX.h | 4 ++-- include/configs/MPC8360EMDS.h | 4 ++-- include/configs/MPC8360ERDK.h | 4 ++-- include/configs/MPC837XEMDS.h | 4 ++-- include/configs/MPC837XERDB.h | 4 ++-- include/configs/MPC8536DS.h | 4 ++-- include/configs/MPC8540ADS.h | 4 ++-- include/configs/MPC8540EVAL.h | 4 ++-- include/configs/MPC8541CDS.h | 4 ++-- include/configs/MPC8544DS.h | 4 ++-- include/configs/MPC8548CDS.h | 4 ++-- include/configs/MPC8555CDS.h | 4 ++-- include/configs/MPC8560ADS.h | 4 ++-- include/configs/MPC8568MDS.h | 4 ++-- include/configs/MPC8569MDS.h | 4 ++-- include/configs/MPC8572DS.h | 4 ++-- include/configs/MPC8610HPCD.h | 4 ++-- include/configs/MPC8641HPCN.h | 4 ++-- include/configs/MUSENKI.h | 4 ++-- include/configs/MVBC_P.h | 4 ++-- include/configs/MVBLM7.h | 4 ++-- include/configs/MVBLUE.h | 4 ++-- include/configs/MVS1.h | 4 ++-- include/configs/MVSMR.h | 4 ++-- include/configs/NETPHONE.h | 4 ++-- include/configs/NETTA.h | 4 ++-- include/configs/NETTA2.h | 4 ++-- include/configs/NETVIA.h | 4 ++-- include/configs/NSCU.h | 4 ++-- include/configs/NX823.h | 4 ++-- include/configs/OCRTC.h | 4 ++-- include/configs/ORSG.h | 4 ++-- include/configs/OXC.h | 4 ++-- include/configs/P1022DS.h | 4 ++-- include/configs/P1_P2_RDB.h | 4 ++-- include/configs/P2020DS.h | 4 ++-- include/configs/P3G4.h | 4 ++-- include/configs/PATI.h | 4 ++-- include/configs/PCI405.h | 4 ++-- include/configs/PCIPPC2.h | 4 ++-- include/configs/PCIPPC6.h | 4 ++-- include/configs/PIP405.h | 4 ++-- include/configs/PLU405.h | 4 ++-- include/configs/PM520.h | 4 ++-- include/configs/PM826.h | 4 ++-- include/configs/PM828.h | 4 ++-- include/configs/PM854.h | 4 ++-- include/configs/PM856.h | 4 ++-- include/configs/PMC405.h | 4 ++-- include/configs/PMC405DE.h | 4 ++-- include/configs/PMC440.h | 4 ++-- include/configs/PN62.h | 4 ++-- include/configs/PPChameleonEVB.h | 4 ++-- include/configs/QS823.h | 4 ++-- include/configs/QS850.h | 4 ++-- include/configs/QS860T.h | 4 ++-- include/configs/R360MPI.h | 4 ++-- include/configs/RBC823.h | 4 ++-- include/configs/RPXClassic.h | 4 ++-- include/configs/RPXlite.h | 4 ++-- include/configs/RPXlite_DW.h | 4 ++-- include/configs/RPXsuper.h | 4 ++-- include/configs/RRvision.h | 4 ++-- include/configs/Rattler.h | 4 ++-- include/configs/SBC8540.h | 4 ++-- include/configs/SCM.h | 4 ++-- include/configs/SIMPC8313.h | 4 ++-- include/configs/SM850.h | 4 ++-- include/configs/SPD823TS.h | 4 ++-- include/configs/SXNI855T.h | 4 ++-- include/configs/Sandpoint8240.h | 8 ++++---- include/configs/Sandpoint8245.h | 8 ++++---- include/configs/TASREG.h | 8 ++++---- include/configs/TB5200.h | 6 +++--- include/configs/TK885D.h | 4 ++-- include/configs/TOP5200.h | 4 ++-- include/configs/TOP860.h | 4 ++-- include/configs/TQM5200.h | 6 +++--- include/configs/TQM823L.h | 4 ++-- include/configs/TQM823M.h | 4 ++-- include/configs/TQM8260.h | 4 ++-- include/configs/TQM8272.h | 4 ++-- include/configs/TQM834x.h | 4 ++-- include/configs/TQM850L.h | 4 ++-- include/configs/TQM850M.h | 4 ++-- include/configs/TQM855L.h | 4 ++-- include/configs/TQM855M.h | 4 ++-- include/configs/TQM85xx.h | 4 ++-- include/configs/TQM860L.h | 4 ++-- include/configs/TQM860M.h | 4 ++-- include/configs/TQM862L.h | 4 ++-- include/configs/TQM862M.h | 4 ++-- include/configs/TQM866M.h | 4 ++-- include/configs/TQM885D.h | 4 ++-- include/configs/Total5200.h | 4 ++-- include/configs/VOH405.h | 4 ++-- include/configs/VOM405.h | 4 ++-- include/configs/VoVPN-GW.h | 4 ++-- include/configs/W7OLMC.h | 4 ++-- include/configs/W7OLMG.h | 4 ++-- include/configs/WUH405.h | 4 ++-- include/configs/Yukon8220.h | 4 ++-- include/configs/ZPC1900.h | 4 ++-- include/configs/ZUMA.h | 4 ++-- include/configs/a4m072.h | 4 ++-- include/configs/acadia.h | 4 ++-- include/configs/aev.h | 6 +++--- include/configs/alpr.h | 4 ++-- include/configs/aria.h | 4 ++-- include/configs/astro_mcf5373l.h | 8 ++++---- include/configs/atc.h | 4 ++-- include/configs/bamboo.h | 4 ++-- include/configs/barco.h | 8 ++++---- include/configs/bluestone.h | 4 ++-- include/configs/bubinga.h | 4 ++-- include/configs/c2mon.h | 4 ++-- include/configs/ca9x4_ct_vxp.h | 4 ++-- include/configs/canmb.h | 4 ++-- include/configs/canyonlands.h | 4 ++-- include/configs/cm5200.h | 6 +++--- include/configs/cmi_mpc5xx.h | 4 ++-- include/configs/cobra5272.h | 8 ++++---- include/configs/cogent_mpc8260.h | 4 ++-- include/configs/cogent_mpc8xx.h | 4 ++-- include/configs/corenet_ds.h | 4 ++-- include/configs/cpci5200.h | 4 ++-- include/configs/csb272.h | 4 ++-- include/configs/csb472.h | 4 ++-- include/configs/debris.h | 8 ++++---- include/configs/digsy_mtc.h | 4 ++-- include/configs/dlvision.h | 4 ++-- include/configs/eXalion.h | 6 +++--- include/configs/ebony.h | 4 ++-- include/configs/ep8248.h | 4 ++-- include/configs/ep8260.h | 4 ++-- include/configs/ep82xxm.h | 4 ++-- include/configs/galaxy5200.h | 4 ++-- include/configs/gdppc440etx.h | 4 ++-- include/configs/gw8260.h | 4 ++-- include/configs/hcu4.h | 4 ++-- include/configs/hcu5.h | 4 ++-- include/configs/hermes.h | 4 ++-- include/configs/hmi1001.h | 6 +++--- include/configs/hymod.h | 4 ++-- include/configs/icon.h | 4 ++-- include/configs/idmr.h | 8 ++++---- include/configs/imx31_litekit.h | 4 ++-- include/configs/inka4x0.h | 6 +++--- include/configs/intip.h | 4 ++-- include/configs/ipek01.h | 4 ++-- include/configs/jupiter.h | 4 ++-- include/configs/katmai.h | 4 ++-- include/configs/kilauea.h | 4 ++-- include/configs/km8xx.h | 4 ++-- include/configs/kmeter1.h | 4 ++-- include/configs/korat.h | 4 ++-- include/configs/kvme080.h | 4 ++-- include/configs/linkstation.h | 4 ++-- include/configs/luan.h | 4 ++-- include/configs/lwmon.h | 4 ++-- include/configs/lwmon5.h | 4 ++-- include/configs/makalu.h | 4 ++-- include/configs/manroland/mpc5200-common.h | 6 +++--- include/configs/mcc200.h | 4 ++-- include/configs/mcu25.h | 4 ++-- include/configs/mecp5123.h | 4 ++-- include/configs/mecp5200.h | 4 ++-- include/configs/mgcoge.h | 4 ++-- include/configs/motionpro.h | 4 ++-- include/configs/mpc5121-common.h | 4 ++-- include/configs/mpc5121ads.h | 4 ++-- include/configs/mpc7448hpc2.h | 4 ++-- include/configs/mpc8308_p1m.h | 4 ++-- include/configs/muas3001.h | 4 ++-- include/configs/munices.h | 4 ++-- include/configs/neo.h | 4 ++-- include/configs/o2dnt.h | 4 ++-- include/configs/ocotea.h | 4 ++-- include/configs/p3mx.h | 4 ++-- include/configs/p3p440.h | 4 ++-- include/configs/pcm030.h | 4 ++-- include/configs/pcs440ep.h | 4 ++-- include/configs/pf5200.h | 4 ++-- include/configs/ppmc7xx.h | 6 +++--- include/configs/ppmc8260.h | 4 ++-- include/configs/qong.h | 4 ++-- include/configs/quad100hd.h | 4 ++-- include/configs/quantum.h | 4 ++-- include/configs/redwood.h | 4 ++-- include/configs/rmu.h | 4 ++-- include/configs/rsdproto.h | 4 ++-- include/configs/sacsng.h | 4 ++-- include/configs/sbc405.h | 4 ++-- include/configs/sbc8240.h | 4 ++-- include/configs/sbc8260.h | 4 ++-- include/configs/sbc8349.h | 4 ++-- include/configs/sbc8548.h | 4 ++-- include/configs/sbc8560.h | 4 ++-- include/configs/sbc8641d.h | 4 ++-- include/configs/sc3.h | 6 +++--- include/configs/sequoia.h | 4 ++-- include/configs/socrates.h | 4 ++-- include/configs/sorcery.h | 4 ++-- include/configs/spc1920.h | 4 ++-- include/configs/spieval.h | 6 +++--- include/configs/stxgp3.h | 4 ++-- include/configs/stxssa.h | 4 ++-- include/configs/stxxtc.h | 4 ++-- include/configs/svm_sc8xx.h | 4 ++-- include/configs/t3corp.h | 4 ++-- include/configs/taihu.h | 4 ++-- include/configs/taishan.h | 4 ++-- include/configs/uc100.h | 4 ++-- include/configs/utx8245.h | 6 +++--- include/configs/v37.h | 4 ++-- include/configs/v38b.h | 4 ++-- include/configs/ve8313.h | 4 ++-- include/configs/virtlab2.h | 4 ++-- include/configs/vision2.h | 4 ++-- include/configs/vme8349.h | 4 ++-- include/configs/walnut.h | 4 ++-- include/configs/xilinx-ppc.h | 4 ++-- include/configs/xpedite1000.h | 4 ++-- include/configs/xpedite517x.h | 4 ++-- include/configs/xpedite520x.h | 4 ++-- include/configs/xpedite537x.h | 4 ++-- include/configs/xpedite550x.h | 4 ++-- include/configs/yosemite.h | 4 ++-- include/configs/yucca.h | 4 ++-- include/configs/zeus.h | 4 ++-- 337 files changed, 759 insertions(+), 759 deletions(-)
[PATCH 2/3] include/asm-offsets.h: automatically generate assembler constants
A recurrent issue is that certain C level constructs like sizeof() or offsetof() cannot be used in assembler files, which is inconvenient when such constructs are used in the definition of macro names etc.
To avoid duplication of such definitions (and thus another cause of problems), we adapt the Linux way to automatically generate the respective definitions from the respective C header files.
In Linux, this is implemented in include/linux/kbuild.h, Kbuild, and arch/*/kernel/asm-offsets.c; we adapt the code from the Linux v2.6.36 kernel tree.
We also copy the concept of the include/generated/ directory which can be used to hold other automatically generated files as well.
We start with an architecture-independent lib/asm-offsets.c which generates include/generated/generic-asm-offsets.h (included by include/asm-offsets.h, which is what will be referred to in the actual source code). Later this may be extended by architecture-specific arch/*/lib/asm-offsets.c files that will generate a include/generated/asm-offsets.h. --- .gitignore | 3 +++ Makefile | 23 ++++++++++++++++++++--- include/asm-offsets.h | 2 ++ include/linux/kbuild.h | 20 ++++++++++++++++++++ lib/asm-offsets.c | 25 +++++++++++++++++++++++++ tools/scripts/make-asm-offsets | 27 +++++++++++++++++++++++++++ 6 files changed, 97 insertions(+), 3 deletions(-) create mode 100644 include/asm-offsets.h create mode 100644 include/linux/kbuild.h create mode 100644 lib/asm-offsets.c create mode 100755 tools/scripts/make-asm-offsets
[PATCH 3/3] Replace CONFIG_SYS_GBL_DATA_SIZE by auto-generated value
CONFIG_SYS_GBL_DATA_SIZE has always been just a bad workarond for not being able to use "sizeof(struct global_data)" in assembler files. Recent experience has shown that manual synchronization is not reliable enough. This patch renames CONFIG_SYS_GBL_DATA_SIZE into GENERATED_GBL_DATA_SIZE which gets automatically generated by the asm-offsets tool. In the result, all definitions of this value can be deleted from the board config files. We have to make sure that all files that reference such data include the new <asm-offsets.h> file.
No other changes have been done yet, but it is obvious that similar changes / simplifications can be done for other, related macro definitions as well.
Signed-off-by: Wolfgang Denk wd@denx.de --- arch/arm/cpu/arm1136/start.S | 9 +++++---- arch/arm/cpu/arm1176/start.S | 9 +++++---- arch/arm/cpu/arm720t/start.S | 8 ++++---- arch/arm/cpu/arm920t/start.S | 7 ++++--- arch/arm/cpu/arm925t/start.S | 8 ++++---- arch/arm/cpu/arm926ejs/start.S | 8 ++++---- arch/arm/cpu/arm946es/start.S | 8 ++++---- arch/arm/cpu/arm_intcm/start.S | 8 ++++---- arch/arm/cpu/armv7/start.S | 9 +++++---- arch/arm/cpu/ixp/start.S | 7 ++++--- arch/arm/cpu/lh7a40x/start.S | 9 ++++----- arch/arm/cpu/pxa/start.S | 5 +++-- arch/arm/cpu/s3c44b0/start.S | 5 ++--- arch/arm/cpu/sa1100/start.S | 9 ++++----- arch/arm/include/asm/global_data.h | 2 +- arch/arm/lib/interrupts.c | 2 +- arch/avr32/cpu/start.S | 1 + arch/avr32/include/asm/global_data.h | 2 +- arch/blackfin/include/asm/config.h | 5 ++--- arch/blackfin/include/asm/global_data.h | 2 +- arch/blackfin/lib/board.c | 4 ++-- arch/i386/include/asm/global_data.h | 2 +- arch/m68k/cpu/mcf5227x/start.S | 1 + arch/m68k/cpu/mcf523x/start.S | 1 + arch/m68k/cpu/mcf52x2/start.S | 1 + arch/m68k/cpu/mcf532x/start.S | 1 + arch/m68k/cpu/mcf5445x/start.S | 1 + arch/m68k/cpu/mcf547x_8x/start.S | 1 + arch/m68k/include/asm/global_data.h | 2 +- arch/microblaze/cpu/start.S | 1 + arch/microblaze/include/asm/global_data.h | 2 +- arch/microblaze/lib/board.c | 2 +- arch/mips/cpu/cache.S | 1 + arch/mips/cpu/start.S | 1 + arch/mips/include/asm/global_data.h | 2 +- arch/nios2/cpu/start.S | 2 +- arch/nios2/lib/board.c | 2 +- arch/powerpc/cpu/74xx_7xx/start.S | 1 + arch/powerpc/cpu/mpc512x/start.S | 1 + arch/powerpc/cpu/mpc5xx/start.S | 1 + arch/powerpc/cpu/mpc5xxx/start.S | 1 + arch/powerpc/cpu/mpc8220/start.S | 1 + arch/powerpc/cpu/mpc824x/start.S | 1 + arch/powerpc/cpu/mpc8260/start.S | 1 + arch/powerpc/cpu/mpc83xx/start.S | 1 + arch/powerpc/cpu/mpc85xx/release.S | 1 + arch/powerpc/cpu/mpc85xx/start.S | 1 + arch/powerpc/cpu/mpc86xx/start.S | 1 + arch/powerpc/cpu/mpc8xx/start.S | 1 + arch/powerpc/cpu/ppc4xx/start.S | 3 ++- arch/powerpc/include/asm/global_data.h | 2 +- arch/sh/cpu/sh2/start.S | 5 +++-- arch/sh/cpu/sh3/start.S | 5 +++-- arch/sh/cpu/sh4/start.S | 5 +++-- arch/sh/lib/board.c | 4 ++-- arch/sparc/cpu/leon2/start.S | 1 + arch/sparc/cpu/leon3/start.S | 1 + arch/sparc/include/asm/global_data.h | 2 +- arch/sparc/lib/board.c | 2 +- board/amcc/bamboo/init.S | 1 + board/amcc/bluestone/init.S | 1 + board/amcc/canyonlands/init.S | 1 + board/amcc/sequoia/init.S | 1 + board/amcc/yosemite/init.S | 1 + board/barco/early_init.S | 1 + board/esd/du440/init.S | 1 + board/esd/pmc440/init.S | 1 + board/fads/fads.h | 3 +-- board/gdsys/gdppc440etx/init.S | 1 + board/gdsys/intip/init.S | 1 + board/hidden_dragon/early_init.S | 1 + board/korat/init.S | 1 + board/lwmon5/init.S | 1 + board/pcs440ep/init.S | 1 + board/prodrive/alpr/init.S | 1 + board/sandpoint/early_init.S | 1 + board/t3corp/init.S | 1 + common/cmd_bdinfo.c | 2 +- include/asm-offsets.h | 4 ++++ include/common.h | 1 + include/configs/A3000.h | 4 +--- include/configs/ADCIOP.h | 3 +-- include/configs/AMX860.h | 3 +-- include/configs/AP1000.h | 3 +-- include/configs/APC405.h | 3 +-- include/configs/AR405.h | 3 +-- include/configs/ASH405.h | 3 +-- include/configs/ATUM8548.h | 3 +-- include/configs/Adder.h | 3 +-- include/configs/Alaska8220.h | 3 +-- include/configs/B2.h | 1 - include/configs/BAB7xx.h | 3 +-- include/configs/BC3450.h | 3 +-- include/configs/BMW.h | 3 +-- include/configs/CANBT.h | 3 +-- include/configs/CATcenter.h | 3 +-- include/configs/CMS700.h | 3 +-- include/configs/CPC45.h | 3 +-- include/configs/CPCI2DP.h | 3 +-- include/configs/CPCI405.h | 3 +-- include/configs/CPCI4052.h | 3 +-- include/configs/CPCI405AB.h | 3 +-- include/configs/CPCI405DT.h | 3 +-- include/configs/CPCI750.h | 3 +-- include/configs/CPCIISER4.h | 3 +-- include/configs/CPU86.h | 3 +-- include/configs/CPU87.h | 3 +-- include/configs/CRAYL1.h | 6 ++---- include/configs/CU824.h | 3 +-- include/configs/DASA_SIM.h | 3 +-- include/configs/DB64360.h | 3 +-- include/configs/DB64460.h | 3 +-- include/configs/DP405.h | 3 +-- include/configs/DU405.h | 3 +-- include/configs/DU440.h | 3 +-- include/configs/EB+MCF-EV123.h | 3 +-- include/configs/ELPPC.h | 3 +-- include/configs/ELPT860.h | 3 +-- include/configs/EP88x.h | 3 +-- include/configs/ERIC.h | 3 +-- include/configs/ESTEEM192E.h | 3 +-- include/configs/ETX094.h | 3 +-- include/configs/EVB64260.h | 3 +-- include/configs/EXBITGEN.h | 3 +-- include/configs/FADS823.h | 3 +-- include/configs/FADS850SAR.h | 3 +-- include/configs/FLAGADM.h | 3 +-- include/configs/FPS850L.h | 3 +-- include/configs/FPS860L.h | 3 +-- include/configs/G2000.h | 3 +-- include/configs/GENIETV.h | 3 +-- include/configs/HH405.h | 3 +-- include/configs/HIDDEN_DRAGON.h | 6 ++---- include/configs/HUB405.h | 3 +-- include/configs/IAD210.h | 3 +-- include/configs/ICU862.h | 3 +-- include/configs/IDS8247.h | 3 +-- include/configs/IP860.h | 3 +-- include/configs/IPHASE4539.h | 3 +-- include/configs/ISPAN.h | 3 +-- include/configs/IVML24.h | 3 +-- include/configs/IVMS8.h | 3 +-- include/configs/IceCube.h | 3 +-- include/configs/JSE.h | 3 +-- include/configs/KAREF.h | 3 +-- include/configs/KUP4K.h | 3 +-- include/configs/KUP4X.h | 3 +-- include/configs/LANTEC.h | 3 +-- include/configs/M5208EVBE.h | 3 +-- include/configs/M52277EVB.h | 3 +-- include/configs/M5235EVB.h | 3 +-- include/configs/M5249EVB.h | 3 +-- include/configs/M5253DEMO.h | 3 +-- include/configs/M5253EVBE.h | 3 +-- include/configs/M5271EVB.h | 3 +-- include/configs/M5272C3.h | 3 +-- include/configs/M5275EVB.h | 3 +-- include/configs/M5282EVB.h | 3 +-- include/configs/M53017EVB.h | 3 +-- include/configs/M5329EVB.h | 3 +-- include/configs/M5373EVB.h | 3 +-- include/configs/M54451EVB.h | 3 +-- include/configs/M54455EVB.h | 3 +-- include/configs/M5475EVB.h | 3 +-- include/configs/M5485EVB.h | 3 +-- include/configs/MBX.h | 3 +-- include/configs/MBX860T.h | 3 +-- include/configs/METROBOX.h | 3 +-- include/configs/MHPC.h | 3 +-- include/configs/MIP405.h | 3 +-- include/configs/ML2.h | 3 +-- include/configs/MOUSSE.h | 3 +-- include/configs/MPC8260ADS.h | 3 +-- include/configs/MPC8266ADS.h | 3 +-- include/configs/MPC8308RDB.h | 3 +-- include/configs/MPC8313ERDB.h | 3 +-- include/configs/MPC8315ERDB.h | 3 +-- include/configs/MPC8323ERDB.h | 3 +-- include/configs/MPC832XEMDS.h | 3 +-- include/configs/MPC8349EMDS.h | 3 +-- include/configs/MPC8349ITX.h | 3 +-- include/configs/MPC8360EMDS.h | 3 +-- include/configs/MPC8360ERDK.h | 3 +-- include/configs/MPC837XEMDS.h | 3 +-- include/configs/MPC837XERDB.h | 3 +-- include/configs/MPC8536DS.h | 3 +-- include/configs/MPC8540ADS.h | 3 +-- include/configs/MPC8540EVAL.h | 3 +-- include/configs/MPC8541CDS.h | 3 +-- include/configs/MPC8544DS.h | 3 +-- include/configs/MPC8548CDS.h | 3 +-- include/configs/MPC8555CDS.h | 3 +-- include/configs/MPC8560ADS.h | 3 +-- include/configs/MPC8568MDS.h | 3 +-- include/configs/MPC8569MDS.h | 3 +-- include/configs/MPC8572DS.h | 3 +-- include/configs/MPC8610HPCD.h | 3 +-- include/configs/MPC8641HPCN.h | 3 +-- include/configs/MUSENKI.h | 4 +--- include/configs/MVBC_P.h | 3 +-- include/configs/MVBLM7.h | 3 +-- include/configs/MVBLUE.h | 3 +-- include/configs/MVS1.h | 3 +-- include/configs/MVSMR.h | 3 +-- include/configs/MigoR.h | 1 - include/configs/NETPHONE.h | 3 +-- include/configs/NETTA.h | 3 +-- include/configs/NETTA2.h | 3 +-- include/configs/NETVIA.h | 3 +-- include/configs/NSCU.h | 3 +-- include/configs/NX823.h | 3 +-- include/configs/OCRTC.h | 3 +-- include/configs/ORSG.h | 3 +-- include/configs/OXC.h | 3 +-- include/configs/P1022DS.h | 3 +-- include/configs/P1_P2_RDB.h | 3 +-- include/configs/P2020DS.h | 3 +-- include/configs/P3G4.h | 3 +-- include/configs/PATI.h | 3 +-- include/configs/PCI405.h | 3 +-- include/configs/PCI5441.h | 3 +-- include/configs/PCIPPC2.h | 3 +-- include/configs/PCIPPC6.h | 3 +-- include/configs/PIP405.h | 3 +-- include/configs/PK1C20.h | 3 +-- include/configs/PLU405.h | 3 +-- include/configs/PM520.h | 3 +-- include/configs/PM826.h | 3 +-- include/configs/PM828.h | 3 +-- include/configs/PM854.h | 3 +-- include/configs/PM856.h | 3 +-- include/configs/PMC405.h | 3 +-- include/configs/PMC405DE.h | 3 +-- include/configs/PMC440.h | 3 +-- include/configs/PN62.h | 4 +--- include/configs/PPChameleonEVB.h | 3 +-- include/configs/QS823.h | 3 +-- include/configs/QS850.h | 3 +-- include/configs/QS860T.h | 3 +-- include/configs/R360MPI.h | 3 +-- include/configs/RBC823.h | 3 +-- include/configs/RPXClassic.h | 3 +-- include/configs/RPXlite.h | 3 +-- include/configs/RPXlite_DW.h | 3 +-- include/configs/RPXsuper.h | 3 +-- include/configs/RRvision.h | 3 +-- include/configs/Rattler.h | 3 +-- include/configs/SBC8540.h | 3 +-- include/configs/SCM.h | 3 +-- include/configs/SIMPC8313.h | 3 +-- include/configs/SM850.h | 3 +-- include/configs/SMN42.h | 1 - include/configs/SPD823TS.h | 3 +-- include/configs/SX1.h | 1 - include/configs/SXNI855T.h | 3 +-- include/configs/Sandpoint8240.h | 7 ++----- include/configs/Sandpoint8245.h | 7 ++----- include/configs/TASREG.h | 3 +-- include/configs/TB5200.h | 3 +-- include/configs/TK885D.h | 3 +-- include/configs/TOP5200.h | 3 +-- include/configs/TOP860.h | 3 +-- include/configs/TQM5200.h | 3 +-- include/configs/TQM823L.h | 3 +-- include/configs/TQM823M.h | 3 +-- include/configs/TQM8260.h | 3 +-- include/configs/TQM8272.h | 3 +-- include/configs/TQM834x.h | 3 +-- include/configs/TQM850L.h | 3 +-- include/configs/TQM850M.h | 3 +-- include/configs/TQM855L.h | 3 +-- include/configs/TQM855M.h | 3 +-- include/configs/TQM85xx.h | 3 +-- include/configs/TQM860L.h | 3 +-- include/configs/TQM860M.h | 3 +-- include/configs/TQM862L.h | 3 +-- include/configs/TQM862M.h | 3 +-- include/configs/TQM866M.h | 3 +-- include/configs/TQM885D.h | 3 +-- include/configs/Total5200.h | 3 +-- include/configs/VCMA9.h | 1 - include/configs/VOH405.h | 3 +-- include/configs/VOM405.h | 3 +-- include/configs/VoVPN-GW.h | 3 +-- include/configs/W7OLMC.h | 3 +-- include/configs/W7OLMG.h | 3 +-- include/configs/WUH405.h | 3 +-- include/configs/Yukon8220.h | 3 +-- include/configs/ZPC1900.h | 3 +-- include/configs/ZUMA.h | 3 +-- include/configs/a320evb.h | 1 - include/configs/a4m072.h | 3 +-- include/configs/acadia.h | 3 +-- include/configs/actux1.h | 1 - include/configs/actux2.h | 1 - include/configs/actux3.h | 1 - include/configs/actux4.h | 1 - include/configs/aev.h | 3 +-- include/configs/afeb9260.h | 1 - include/configs/alpr.h | 3 +-- include/configs/am3517_evm.h | 1 - include/configs/ap325rxa.h | 1 - include/configs/apollon.h | 1 - include/configs/aria.h | 3 +-- include/configs/armadillo.h | 1 - include/configs/assabet.h | 1 - include/configs/astro_mcf5373l.h | 3 +-- include/configs/at91cap9adk.h | 1 - include/configs/at91rm9200dk.h | 1 - include/configs/at91rm9200ek.h | 3 +-- include/configs/at91sam9260ek.h | 1 - include/configs/at91sam9261ek.h | 1 - include/configs/at91sam9263ek.h | 1 - include/configs/at91sam9m10g45ek.h | 1 - include/configs/at91sam9rlek.h | 1 - include/configs/atc.h | 3 +-- include/configs/balloon3.h | 3 +-- include/configs/bamboo.h | 3 +-- include/configs/barco.h | 6 ++---- include/configs/bluestone.h | 3 +-- include/configs/bubinga.h | 3 +-- include/configs/c2mon.h | 3 +-- include/configs/ca9x4_ct_vxp.h | 3 +-- include/configs/canmb.h | 3 +-- include/configs/canyonlands.h | 3 +-- include/configs/cerf250.h | 3 +-- include/configs/cm4008.h | 1 - include/configs/cm41xx.h | 1 - include/configs/cm5200.h | 3 +-- include/configs/cmc_pu2.h | 1 - include/configs/cmi_mpc5xx.h | 3 +-- include/configs/cobra5272.h | 3 +-- include/configs/cogent_mpc8260.h | 3 +-- include/configs/cogent_mpc8xx.h | 3 +-- include/configs/colibri_pxa270.h | 3 +-- include/configs/corenet_ds.h | 3 +-- include/configs/cpci5200.h | 3 +-- include/configs/cpu9260.h | 1 - include/configs/cpuat91.h | 1 - include/configs/cradle.h | 3 +-- include/configs/csb226.h | 3 +-- include/configs/csb272.h | 3 +-- include/configs/csb472.h | 3 +-- include/configs/csb637.h | 1 - include/configs/da830evm.h | 1 - include/configs/da850evm.h | 3 +-- include/configs/davinci_dm355evm.h | 1 - include/configs/davinci_dm355leopard.h | 1 - include/configs/davinci_dm365evm.h | 1 - include/configs/davinci_dm6467evm.h | 1 - include/configs/davinci_dvevm.h | 1 - include/configs/davinci_schmoogie.h | 1 - include/configs/davinci_sffsdr.h | 1 - include/configs/davinci_sonata.h | 1 - include/configs/debris.h | 7 ++----- include/configs/devkit8000.h | 1 - include/configs/digsy_mtc.h | 3 +-- include/configs/dlvision.h | 3 +-- include/configs/dnp1110.h | 1 - include/configs/eXalion.h | 3 +-- include/configs/eb_cpux9k2.h | 1 - include/configs/ebony.h | 3 +-- include/configs/edb93xx.h | 1 - include/configs/edminiv2.h | 3 +-- include/configs/ep7312.h | 1 - include/configs/ep8248.h | 3 +-- include/configs/ep8260.h | 3 +-- include/configs/ep82xxm.h | 3 +-- include/configs/espt.h | 1 - include/configs/evb4510.h | 1 - include/configs/galaxy5200.h | 3 +-- include/configs/gcplus.h | 1 - include/configs/gdppc440etx.h | 3 +-- include/configs/gr_cpci_ax2000.h | 5 ++--- include/configs/gr_ep2s60.h | 5 ++--- include/configs/gr_xc3s_1500.h | 5 ++--- include/configs/grsim.h | 5 ++--- include/configs/grsim_leon2.h | 5 ++--- include/configs/gw8260.h | 3 +-- include/configs/hcu4.h | 3 +-- include/configs/hcu5.h | 3 +-- include/configs/hermes.h | 3 +-- include/configs/hmi1001.h | 3 +-- include/configs/hymod.h | 3 +-- include/configs/icon.h | 3 +-- include/configs/idmr.h | 3 +-- include/configs/igep0020.h | 3 +-- include/configs/igep0030.h | 3 +-- include/configs/impa7.h | 1 - include/configs/imx27lite-common.h | 3 +-- include/configs/imx31_litekit.h | 3 +-- include/configs/imx31_phycore.h | 1 - include/configs/inka4x0.h | 3 +-- include/configs/innokom.h | 3 +-- include/configs/integratorap.h | 1 - include/configs/integratorcp.h | 1 - include/configs/intip.h | 3 +-- include/configs/ipek01.h | 3 +-- include/configs/ixdp425.h | 1 - include/configs/ixdpg425.h | 1 - include/configs/jadecpu.h | 1 - include/configs/jornada.h | 1 - include/configs/jupiter.h | 3 +-- include/configs/katmai.h | 3 +-- include/configs/kb9202.h | 1 - include/configs/kilauea.h | 3 +-- include/configs/km8xx.h | 3 +-- include/configs/km_arm.h | 3 +-- include/configs/kmeter1.h | 3 +-- include/configs/korat.h | 3 +-- include/configs/kvme080.h | 3 +-- include/configs/lart.h | 1 - include/configs/linkstation.h | 3 +-- include/configs/lpc2292sodimm.h | 1 - include/configs/lpd7a400.h | 1 - include/configs/lpd7a404.h | 1 - include/configs/luan.h | 3 +-- include/configs/lubbock.h | 3 +-- include/configs/lwmon.h | 3 +-- include/configs/lwmon5.h | 3 +-- include/configs/m501sk.h | 1 - include/configs/makalu.h | 3 +-- include/configs/manroland/mpc5200-common.h | 3 +-- include/configs/mcc200.h | 3 +-- include/configs/mcu25.h | 3 +-- include/configs/mecp5123.h | 3 +-- include/configs/mecp5200.h | 3 +-- include/configs/meesc.h | 1 - include/configs/mgcoge.h | 3 +-- include/configs/microblaze-generic.h | 5 ++--- include/configs/modnet50.h | 1 - include/configs/motionpro.h | 3 +-- include/configs/mp2usb.h | 1 - include/configs/mpc5121-common.h | 3 +-- include/configs/mpc5121ads.h | 3 +-- include/configs/mpc7448hpc2.h | 3 +-- include/configs/mpc8308_p1m.h | 3 +-- include/configs/mpr2.h | 1 - include/configs/ms7720se.h | 1 - include/configs/ms7722se.h | 1 - include/configs/ms7750se.h | 1 - include/configs/muas3001.h | 3 +-- include/configs/munices.h | 3 +-- include/configs/mv-common.h | 1 - include/configs/mx1ads.h | 1 - include/configs/mx1fs2.h | 1 - include/configs/mx31ads.h | 1 - include/configs/mx31pdk.h | 1 - include/configs/mx51evk.h | 1 - include/configs/neo.h | 3 +-- include/configs/netstar.h | 1 - include/configs/nhk8815.h | 1 - include/configs/nios2-generic.h | 3 +-- include/configs/ns9750dev.h | 1 - include/configs/o2dnt.h | 3 +-- include/configs/ocotea.h | 3 +-- include/configs/omap1510inn.h | 1 - include/configs/omap1610h2.h | 1 - include/configs/omap1610inn.h | 1 - include/configs/omap2420h4.h | 1 - include/configs/omap3_beagle.h | 3 +-- include/configs/omap3_evm.h | 1 - include/configs/omap3_overo.h | 3 +-- include/configs/omap3_pandora.h | 1 - include/configs/omap3_sdp3430.h | 1 - include/configs/omap3_zoom1.h | 1 - include/configs/omap3_zoom2.h | 1 - include/configs/omap4_panda.h | 3 +-- include/configs/omap4_sdp4430.h | 3 +-- include/configs/omap5912osk.h | 1 - include/configs/omap730p2.h | 1 - include/configs/otc570.h | 1 - include/configs/p3mx.h | 3 +-- include/configs/p3p440.h | 3 +-- include/configs/palmld.h | 3 +-- include/configs/palmtc.h | 3 +-- include/configs/pcm030.h | 3 +-- include/configs/pcs440ep.h | 3 +-- include/configs/pdnb3.h | 1 - include/configs/pf5200.h | 3 +-- include/configs/pleb2.h | 3 +-- include/configs/pm9261.h | 1 - include/configs/pm9263.h | 1 - include/configs/pm9g45.h | 1 - include/configs/ppmc7xx.h | 5 ++--- include/configs/ppmc8260.h | 3 +-- include/configs/pxa255_idp.h | 3 +-- include/configs/qong.h | 3 +-- include/configs/quad100hd.h | 3 +-- include/configs/quantum.h | 3 +-- include/configs/r2dplus.h | 1 - include/configs/r7780mp.h | 1 - include/configs/redwood.h | 3 +-- include/configs/rmu.h | 3 +-- include/configs/rsdproto.h | 3 +-- include/configs/rsk7203.h | 1 - include/configs/s5p_goni.h | 1 - include/configs/sacsng.h | 3 +-- include/configs/sbc2410x.h | 1 - include/configs/sbc35_a9g20.h | 1 - include/configs/sbc405.h | 3 +-- include/configs/sbc8240.h | 3 +-- include/configs/sbc8260.h | 3 +-- include/configs/sbc8349.h | 3 +-- include/configs/sbc8548.h | 3 +-- include/configs/sbc8560.h | 3 +-- include/configs/sbc8641d.h | 3 +-- include/configs/sc3.h | 3 +-- include/configs/scb9328.h | 1 - include/configs/sequoia.h | 3 +-- include/configs/sh7763rdp.h | 1 - include/configs/sh7785lcr.h | 1 - include/configs/shannon.h | 1 - include/configs/smdk2400.h | 1 - include/configs/smdk2410.h | 1 - include/configs/smdk6400.h | 1 - include/configs/smdkc100.h | 1 - include/configs/socrates.h | 3 +-- include/configs/sorcery.h | 3 +-- include/configs/spc1920.h | 3 +-- include/configs/spear-common.h | 1 - include/configs/spieval.h | 3 +-- include/configs/stxgp3.h | 3 +-- include/configs/stxssa.h | 3 +-- include/configs/stxxtc.h | 3 +-- include/configs/svm_sc8xx.h | 3 +-- include/configs/t3corp.h | 3 +-- include/configs/taihu.h | 3 +-- include/configs/taishan.h | 3 +-- include/configs/tnetv107x_evm.h | 1 - include/configs/tny_a9260.h | 1 - include/configs/trab.h | 1 - include/configs/trizepsiv.h | 3 +-- include/configs/tx25.h | 3 +-- include/configs/uc100.h | 3 +-- include/configs/utx8245.h | 3 +-- include/configs/v37.h | 3 +-- include/configs/v38b.h | 3 +-- include/configs/ve8313.h | 3 +-- include/configs/versatile.h | 1 - include/configs/virtlab2.h | 3 +-- include/configs/vision2.h | 3 +-- include/configs/vme8349.h | 3 +-- include/configs/voiceblue.h | 1 - include/configs/vpac270.h | 3 +-- include/configs/walnut.h | 3 +-- include/configs/xaeniax.h | 3 +-- include/configs/xilinx-ppc.h | 3 +-- include/configs/xm250.h | 3 +-- include/configs/xpedite1000.h | 3 +-- include/configs/xpedite517x.h | 3 +-- include/configs/xpedite520x.h | 3 +-- include/configs/xpedite537x.h | 3 +-- include/configs/xpedite550x.h | 3 +-- include/configs/yosemite.h | 3 +-- include/configs/yucca.h | 3 +-- include/configs/zeus.h | 3 +-- include/configs/zipitz2.h | 3 +-- include/configs/zylonite.h | 3 +-- lib/asm-offsets.c | 2 ++ 560 files changed, 517 insertions(+), 955 deletions(-)
diff --git a/README b/README index a507a1f..3d87423 100644 --- a/README +++ b/README @@ -2686,7 +2686,7 @@ Low Level (hardware related) configuration options: area defined by CONFIG_SYS_INIT_RAM_ADDR. Usually CONFIG_SYS_GBL_DATA_OFFSET is chosen such that the initial data is located at the end of the available space - (sometimes written as (CONFIG_SYS_INIT_RAM_END - + (sometimes written as (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_INIT_DATA_SIZE), and the initial stack is just below that area (growing from (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_GBL_DATA_OFFSET) downward. diff --git a/arch/m68k/lib/board.c b/arch/m68k/lib/board.c index 4541e24..976d5bf 100644 --- a/arch/m68k/lib/board.c +++ b/arch/m68k/lib/board.c @@ -341,7 +341,7 @@ board_init_f (ulong bootflag) bd->bi_memsize = gd->ram_size; /* size of DRAM memory in bytes */ #ifdef CONFIG_SYS_INIT_RAM_ADDR bd->bi_sramstart = CONFIG_SYS_INIT_RAM_ADDR; /* start of SRAM memory */ - bd->bi_sramsize = CONFIG_SYS_INIT_RAM_END; /* size of SRAM memory */ + bd->bi_sramsize = CONFIG_SYS_INIT_RAM_SIZE; /* size of SRAM memory */ #endif bd->bi_mbar_base = CONFIG_SYS_MBAR; /* base of internal registers */
diff --git a/arch/powerpc/cpu/74xx_7xx/start.S b/arch/powerpc/cpu/74xx_7xx/start.S index 573e6d0..b4121df 100644 --- a/arch/powerpc/cpu/74xx_7xx/start.S +++ b/arch/powerpc/cpu/74xx_7xx/start.S @@ -819,7 +819,7 @@ lock_ram_in_cache: */ lis r3, (CONFIG_SYS_INIT_RAM_ADDR & ~31)@h ori r3, r3, (CONFIG_SYS_INIT_RAM_ADDR & ~31)@l - li r4, ((CONFIG_SYS_INIT_RAM_END & ~31) + \ + li r4, ((CONFIG_SYS_INIT_RAM_SIZE & ~31) + \ (CONFIG_SYS_INIT_RAM_ADDR & 31) + 31) / 32 mtctr r4 1: @@ -840,7 +840,7 @@ unlock_ram_in_cache: /* invalidate the INIT_RAM section */ lis r3, (CONFIG_SYS_INIT_RAM_ADDR & ~31)@h ori r3, r3, (CONFIG_SYS_INIT_RAM_ADDR & ~31)@l - li r4, ((CONFIG_SYS_INIT_RAM_END & ~31) + \ + li r4, ((CONFIG_SYS_INIT_RAM_SIZE & ~31) + \ (CONFIG_SYS_INIT_RAM_ADDR & 31) + 31) / 32 mtctr r4 1: icbi r0, r3 diff --git a/arch/powerpc/cpu/mpc83xx/start.S b/arch/powerpc/cpu/mpc83xx/start.S index 536604f..403fda4 100644 --- a/arch/powerpc/cpu/mpc83xx/start.S +++ b/arch/powerpc/cpu/mpc83xx/start.S @@ -1072,7 +1072,7 @@ lock_ram_in_cache: */ lis r3, (CONFIG_SYS_INIT_RAM_ADDR & ~31)@h ori r3, r3, (CONFIG_SYS_INIT_RAM_ADDR & ~31)@l - li r4, ((CONFIG_SYS_INIT_RAM_END & ~31) + \ + li r4, ((CONFIG_SYS_INIT_RAM_SIZE & ~31) + \ (CONFIG_SYS_INIT_RAM_ADDR & 31) + 31) / 32 mtctr r4 1: @@ -1094,7 +1094,7 @@ unlock_ram_in_cache: /* invalidate the INIT_RAM section */ lis r3, (CONFIG_SYS_INIT_RAM_ADDR & ~31)@h ori r3, r3, (CONFIG_SYS_INIT_RAM_ADDR & ~31)@l - li r4, ((CONFIG_SYS_INIT_RAM_END & ~31) + \ + li r4, ((CONFIG_SYS_INIT_RAM_SIZE & ~31) + \ (CONFIG_SYS_INIT_RAM_ADDR & 31) + 31) / 32 mtctr r4 1: icbi r0, r3 diff --git a/arch/powerpc/cpu/mpc86xx/start.S b/arch/powerpc/cpu/mpc86xx/start.S index 3817f19..36004b7 100644 --- a/arch/powerpc/cpu/mpc86xx/start.S +++ b/arch/powerpc/cpu/mpc86xx/start.S @@ -870,7 +870,7 @@ lock_ram_in_cache: */ lis r3, (CONFIG_SYS_INIT_RAM_ADDR & ~31)@h ori r3, r3, (CONFIG_SYS_INIT_RAM_ADDR & ~31)@l - li r4, ((CONFIG_SYS_INIT_RAM_END & ~31) + \ + li r4, ((CONFIG_SYS_INIT_RAM_SIZE & ~31) + \ (CONFIG_SYS_INIT_RAM_ADDR & 31) + 31) / 32 mtctr r4 1: @@ -905,7 +905,7 @@ unlock_ram_in_cache: /* invalidate the INIT_RAM section */ lis r3, (CONFIG_SYS_INIT_RAM_ADDR & ~31)@h ori r3, r3, (CONFIG_SYS_INIT_RAM_ADDR & ~31)@l - li r4, ((CONFIG_SYS_INIT_RAM_END & ~31) + \ + li r4, ((CONFIG_SYS_INIT_RAM_SIZE & ~31) + \ (CONFIG_SYS_INIT_RAM_ADDR & 31) + 31) / 32 mtctr r4 1: icbi r0, r3 diff --git a/arch/powerpc/cpu/ppc4xx/start.S b/arch/powerpc/cpu/ppc4xx/start.S index 87caea1..140bfc9 100644 --- a/arch/powerpc/cpu/ppc4xx/start.S +++ b/arch/powerpc/cpu/ppc4xx/start.S @@ -182,8 +182,8 @@ # endif #endif /* CONFIG_SYS_INIT_DCACHE_CS */
-#if (defined(CONFIG_SYS_INIT_RAM_DCACHE) && (CONFIG_SYS_INIT_RAM_END > (4 << 10))) -#error Only 4k of init-ram is supported - please adjust CONFIG_SYS_INIT_RAM_END! +#if (defined(CONFIG_SYS_INIT_RAM_DCACHE) && (CONFIG_SYS_INIT_RAM_SIZE > (4 << 10))) +#error Only 4k of init-ram is supported - please adjust CONFIG_SYS_INIT_RAM_SIZE! #endif
/* @@ -656,8 +656,8 @@ _start: /* Clear Dcache to use as RAM */ addis r3,r0,CONFIG_SYS_INIT_RAM_ADDR@h ori r3,r3,CONFIG_SYS_INIT_RAM_ADDR@l - addis r4,r0,CONFIG_SYS_INIT_RAM_END@h - ori r4,r4,CONFIG_SYS_INIT_RAM_END@l + addis r4,r0,CONFIG_SYS_INIT_RAM_SIZE@h + ori r4,r4,CONFIG_SYS_INIT_RAM_SIZE@l rlwinm. r5,r4,0,27,31 rlwinm r5,r4,27,5,31 beq ..d_ran @@ -1091,8 +1091,8 @@ _start: lis r3, CONFIG_SYS_INIT_RAM_ADDR@h ori r3, r3, CONFIG_SYS_INIT_RAM_ADDR@l
- lis r4, CONFIG_SYS_INIT_RAM_END@h - ori r4, r4, CONFIG_SYS_INIT_RAM_END@l + lis r4, CONFIG_SYS_INIT_RAM_SIZE@h + ori r4, r4, CONFIG_SYS_INIT_RAM_SIZE@l
/* * Convert the size, in bytes, to the number of cache lines/blocks @@ -1119,12 +1119,12 @@ _start: lis r1, CONFIG_SYS_INIT_RAM_ADDR@h ori r1, r1, CONFIG_SYS_INIT_SP_OFFSET@l
- lis r4, (CONFIG_SYS_INIT_RAM_END >> 2)@h - ori r4, r4, (CONFIG_SYS_INIT_RAM_END >> 2)@l + lis r4, (CONFIG_SYS_INIT_RAM_SIZE >> 2)@h + ori r4, r4, (CONFIG_SYS_INIT_RAM_SIZE >> 2)@l mtctr r4
lis r2, CONFIG_SYS_INIT_RAM_ADDR@h - ori r2, r2, CONFIG_SYS_INIT_RAM_END@l + ori r2, r2, CONFIG_SYS_INIT_RAM_SIZE@l
lis r4, CONFIG_SYS_INIT_RAM_PATTERN@h ori r4, r4, CONFIG_SYS_INIT_RAM_PATTERN@l @@ -1414,8 +1414,8 @@ relocate_code: lis r3, CONFIG_SYS_INIT_RAM_ADDR@h ori r3, r3, CONFIG_SYS_INIT_RAM_ADDR@l
- lis r4, CONFIG_SYS_INIT_RAM_END@h - ori r4, r4, CONFIG_SYS_INIT_RAM_END@l + lis r4, CONFIG_SYS_INIT_RAM_SIZE@h + ori r4, r4, CONFIG_SYS_INIT_RAM_SIZE@l add r4, r4, r3
bl invalidate_dcache_range diff --git a/board/fads/fads.h b/board/fads/fads.h index 38abc70..08d4b79 100644 --- a/board/fads/fads.h +++ b/board/fads/fads.h @@ -164,9 +164,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/A3000.h b/include/configs/A3000.h index 26d4d8a..648aa03 100644 --- a/include/configs/A3000.h +++ b/include/configs/A3000.h @@ -175,8 +175,8 @@ /*#define CONFIG_SYS_GBL_DATA_SIZE 256*/ #define CONFIG_SYS_GBL_DATA_SIZE 128 #define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 -#define CONFIG_SYS_INIT_RAM_END 0x1000 -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE)
/* diff --git a/include/configs/ADCIOP.h b/include/configs/ADCIOP.h index 5610914..c4bc151 100644 --- a/include/configs/ADCIOP.h +++ b/include/configs/ADCIOP.h @@ -114,9 +114,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR 0x00df0000 /* inside of SDRAM */ -#define CONFIG_SYS_INIT_RAM_END 0x0f00 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x0f00 /* Size of used area in RAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/AMX860.h b/include/configs/AMX860.h index aa35cbc..f5fa648 100644 --- a/include/configs/AMX860.h +++ b/include/configs/AMX860.h @@ -138,9 +138,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/AP1000.h b/include/configs/AP1000.h index f1ae16c..31df89c 100644 --- a/include/configs/AP1000.h +++ b/include/configs/AP1000.h @@ -209,9 +209,9 @@ */
#define CONFIG_SYS_INIT_RAM_ADDR 0x400000 /* inside of SDRAM */ -#define CONFIG_SYS_INIT_RAM_END 0x2000 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in RAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/APC405.h b/include/configs/APC405.h index b846afc..af3223b 100644 --- a/include/configs/APC405.h +++ b/include/configs/APC405.h @@ -420,9 +420,9 @@ #define CONFIG_SYS_OCM_DATA_SIZE 0x1000
#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* reserved bytes for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) /* reserve some memory for BOOT limit info */ #define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_GBL_DATA_OFFSET - 16)
diff --git a/include/configs/AR405.h b/include/configs/AR405.h index b4ff718..1f7e79e 100644 --- a/include/configs/AR405.h +++ b/include/configs/AR405.h @@ -266,9 +266,9 @@ #define CONFIG_SYS_INIT_DCACHE_CS 7 /* use cs # 7 for data cache memory */
#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 /* use data cache */ -#define CONFIG_SYS_INIT_RAM_END 0x2000 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in RAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#endif /* __CONFIG_H */ diff --git a/include/configs/ASH405.h b/include/configs/ASH405.h index 480051b..a818070 100644 --- a/include/configs/ASH405.h +++ b/include/configs/ASH405.h @@ -324,10 +324,10 @@ #define CONFIG_SYS_OCM_DATA_ADDR 0xF8000000 #define CONFIG_SYS_OCM_DATA_SIZE 0x1000 #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */
/*----------------------------------------------------------------------- diff --git a/include/configs/ATUM8548.h b/include/configs/ATUM8548.h index dda6baa..261aff1 100644 --- a/include/configs/ATUM8548.h +++ b/include/configs/ATUM8548.h @@ -191,12 +191,12 @@ /* Memory */ #define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xe4010000 /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_END 0x4000 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in RAM */
#define CONFIG_SYS_INIT_L2_ADDR 0xf8f80000 /* relocate boot L2SRAM */
#define CONFIG_SYS_GBL_DATA_SIZE 128 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ diff --git a/include/configs/Adder.h b/include/configs/Adder.h index a1c530b..71e36c6 100644 --- a/include/configs/Adder.h +++ b/include/configs/Adder.h @@ -170,9 +170,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* Size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/Alaska8220.h b/include/configs/Alaska8220.h index b5c9049..7ede318 100644 --- a/include/configs/Alaska8220.h +++ b/include/configs/Alaska8220.h @@ -246,10 +246,10 @@
/* Use SRAM until RAM will be available */ #define CONFIG_SYS_INIT_RAM_ADDR (CONFIG_SYS_MBAR + 0x20000) -#define CONFIG_SYS_INIT_RAM_END 0x8000 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x8000 /* Size of used area in DPRAM */
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/BAB7xx.h b/include/configs/BAB7xx.h index 9250ef3..c557197 100644 --- a/include/configs/BAB7xx.h +++ b/include/configs/BAB7xx.h @@ -199,9 +199,9 @@ * Definitions for initial stack pointer and data area */ #define CONFIG_SYS_INIT_RAM_ADDR 0x00fd0000 /* above the memtest region */ -#define CONFIG_SYS_INIT_RAM_END 0x4000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for init data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* diff --git a/include/configs/BC3450.h b/include/configs/BC3450.h index d051704..563da68 100644 --- a/include/configs/BC3450.h +++ b/include/configs/BC3450.h @@ -384,13 +384,13 @@ #define CONFIG_SYS_INIT_RAM_ADDR MPC5XXX_SRAM #ifdef CONFIG_POST /* preserve space for the post_word at end of on-chip SRAM */ -# define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_POST_SIZE +# define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_POST_SIZE #else -# define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_SIZE +# define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE #endif /*CONFIG_POST*/
#define CONFIG_SYS_GBL_DATA_SIZE 128 /* Bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/BMW.h b/include/configs/BMW.h index 7d928eb..234cc20 100644 --- a/include/configs/BMW.h +++ b/include/configs/BMW.h @@ -150,9 +150,9 @@ * Definitions for initial stack pointer and data area */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_SDRAM_BASE + CONFIG_SYS_MONITOR_LEN -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* diff --git a/include/configs/CANBT.h b/include/configs/CANBT.h index 9c55805..d67b659 100644 --- a/include/configs/CANBT.h +++ b/include/configs/CANBT.h @@ -223,9 +223,9 @@ * Definitions for initial stack pointer and data area (in RAM) */ #define CONFIG_SYS_INIT_RAM_ADDR 0x00ef0000 /* inside of SDRAM */ -#define CONFIG_SYS_INIT_RAM_END 0x0f00 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x0f00 /* Size of used area in RAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#endif /* __CONFIG_H */ diff --git a/include/configs/CATcenter.h b/include/configs/CATcenter.h index ad36a14..7442e3c 100644 --- a/include/configs/CATcenter.h +++ b/include/configs/CATcenter.h @@ -514,10 +514,10 @@ #define CONFIG_SYS_OCM_DATA_ADDR 0xF8000000 #define CONFIG_SYS_OCM_DATA_SIZE 0x1000 #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */
/*----------------------------------------------------------------------- diff --git a/include/configs/CMS700.h b/include/configs/CMS700.h index 3e973f2..34478bb 100644 --- a/include/configs/CMS700.h +++ b/include/configs/CMS700.h @@ -286,10 +286,10 @@ #define CONFIG_SYS_OCM_DATA_ADDR 0xF8000000 #define CONFIG_SYS_OCM_DATA_SIZE 0x1000 #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */
/*----------------------------------------------------------------------- diff --git a/include/configs/CPC45.h b/include/configs/CPC45.h index 486a4e0..8502542 100644 --- a/include/configs/CPC45.h +++ b/include/configs/CPC45.h @@ -156,8 +156,8 @@ #define CONFIG_SYS_GBL_DATA_SIZE 128
/* * NS16550 Configuration diff --git a/include/configs/CPCI2DP.h b/include/configs/CPCI2DP.h index e4d8f9c..b5edc03 100644 --- a/include/configs/CPCI2DP.h +++ b/include/configs/CPCI2DP.h @@ -259,9 +259,9 @@ #define CONFIG_SYS_INIT_DCACHE_CS 7 /* use cs # 7 for data cache memory */
/*----------------------------------------------------------------------- diff --git a/include/configs/CPCI405.h b/include/configs/CPCI405.h index 6b2986d..df45b12 100644 --- a/include/configs/CPCI405.h +++ b/include/configs/CPCI405.h @@ -335,9 +335,9 @@ #else #define CONFIG_SYS_INIT_RAM_ADDR 0x00df0000 /* inside of SDRAM */ #endif -#define CONFIG_SYS_INIT_RAM_END 0x2000 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in RAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#endif /* __CONFIG_H */ diff --git a/include/configs/CPCI4052.h b/include/configs/CPCI4052.h index 908b872..9a4e5f8 100644 --- a/include/configs/CPCI4052.h +++ b/include/configs/CPCI4052.h @@ -396,9 +396,9 @@ #define CONFIG_SYS_INIT_DCACHE_CS 7 /* use cs # 7 for data cache memory */
#endif /* __CONFIG_H */ diff --git a/include/configs/CPCI405AB.h b/include/configs/CPCI405AB.h index a2b8d72..fb14cd3 100644 --- a/include/configs/CPCI405AB.h +++ b/include/configs/CPCI405AB.h @@ -388,9 +388,9 @@ #define CONFIG_SYS_INIT_DCACHE_CS 7 /* use cs # 7 for data cache memory */
#endif /* __CONFIG_H */ diff --git a/include/configs/CPCI405DT.h b/include/configs/CPCI405DT.h index 7fea5e3..70af2da 100644 --- a/include/configs/CPCI405DT.h +++ b/include/configs/CPCI405DT.h @@ -391,9 +391,9 @@ #define CONFIG_SYS_INIT_DCACHE_CS 7 /* use cs # 7 for data cache memory */
#endif /* __CONFIG_H */ diff --git a/include/configs/CPCI750.h b/include/configs/CPCI750.h index 37341cb..76172eb 100644 --- a/include/configs/CPCI750.h +++ b/include/configs/CPCI750.h @@ -266,9 +266,9 @@ /* #define CONFIG_SYS_INIT_RAM_ADDR 0x40000000*/ /* unused memory region */ /* #define CONFIG_SYS_INIT_RAM_ADDR 0xfba00000*/ /* unused memory region */ #define CONFIG_SYS_INIT_RAM_ADDR 0xf1080000 /* unused memory region */ -#define CONFIG_SYS_INIT_RAM_END 0x1000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for init data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE)
#define RELOCATE_INTERNAL_RAM_ADDR #ifdef RELOCATE_INTERNAL_RAM_ADDR diff --git a/include/configs/CPCIISER4.h b/include/configs/CPCIISER4.h index 5aff74c..f9badc0 100644 --- a/include/configs/CPCIISER4.h +++ b/include/configs/CPCIISER4.h @@ -249,9 +249,9 @@ */ #define CONFIG_SYS_INIT_DCACHE_CS 7 /* use cs # 7 for data cache memory */ #define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 /* use data cache */ -#define CONFIG_SYS_INIT_RAM_END 0x2000 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in RAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#endif /* __CONFIG_H */ diff --git a/include/configs/CPU86.h b/include/configs/CPU86.h index 233d36b..7662b52 100644 --- a/include/configs/CPU86.h +++ b/include/configs/CPU86.h @@ -296,9 +296,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x4000 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data*/ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/CPU87.h b/include/configs/CPU87.h index 560e449..18fdb90 100644 --- a/include/configs/CPU87.h +++ b/include/configs/CPU87.h @@ -311,9 +311,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x4000 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data*/ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/CRAYL1.h b/include/configs/CRAYL1.h index 6ababa1..146540a 100644 --- a/include/configs/CRAYL1.h +++ b/include/configs/CRAYL1.h @@ -228,17 +228,17 @@ #define CONFIG_SYS_OCM_DATA_SIZE 0x1000
#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */ #define CONFIG_SYS_GBL_DATA_SIZE 256 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET #else #define CONFIG_SYS_OCM_DATA_ADDR 0xF0000000 #define CONFIG_SYS_OCM_DATA_SIZE 0x1000 #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of On Chip SRAM */ -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE /* End of On Chip SRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of On Chip SRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET #endif
diff --git a/include/configs/CU824.h b/include/configs/CU824.h index 8e19aeb..14970e0 100644 --- a/include/configs/CU824.h +++ b/include/configs/CU824.h @@ -144,8 +144,8 @@ #define CONFIG_SYS_GBL_DATA_SIZE 128
/* * NS16550 Configuration diff --git a/include/configs/DASA_SIM.h b/include/configs/DASA_SIM.h index fc2727e..3d6b95a 100644 --- a/include/configs/DASA_SIM.h +++ b/include/configs/DASA_SIM.h @@ -115,9 +115,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR 0x00df0000 /* inside of SDRAM */ -#define CONFIG_SYS_INIT_RAM_END 0x0f00 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x0f00 /* Size of used area in RAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/DB64360.h b/include/configs/DB64360.h index 26bb649..ba5adda 100644 --- a/include/configs/DB64360.h +++ b/include/configs/DB64360.h @@ -352,9 +352,9 @@ ip=${ipaddr}:${serverip}${bootargs_end}; bootm 0x400000;\0" */ #define CONFIG_SYS_INIT_RAM_LOCK #define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 /* unused memory region */ -#define CONFIG_SYS_INIT_RAM_END 0x1000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for init data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE)
#define RELOCATE_INTERNAL_RAM_ADDR #ifdef RELOCATE_INTERNAL_RAM_ADDR diff --git a/include/configs/DB64460.h b/include/configs/DB64460.h index 74312cd..6586f23 100644 --- a/include/configs/DB64460.h +++ b/include/configs/DB64460.h @@ -290,9 +290,9 @@ ip=${ipaddr}:${serverip}${bootargs_end}; bootm 0x400000;\0" */ #define CONFIG_SYS_INIT_RAM_LOCK #define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 /* unused memory region */ -#define CONFIG_SYS_INIT_RAM_END 0x1000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for init data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE)
#define RELOCATE_INTERNAL_RAM_ADDR #ifdef RELOCATE_INTERNAL_RAM_ADDR diff --git a/include/configs/DP405.h b/include/configs/DP405.h index cb110e3..2bf0799 100644 --- a/include/configs/DP405.h +++ b/include/configs/DP405.h @@ -228,10 +228,10 @@ #define CONFIG_SYS_OCM_DATA_ADDR 0xF8000000 #define CONFIG_SYS_OCM_DATA_SIZE 0x1000 #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */
/*----------------------------------------------------------------------- diff --git a/include/configs/DU405.h b/include/configs/DU405.h index d99b840..bb03f23 100644 --- a/include/configs/DU405.h +++ b/include/configs/DU405.h @@ -286,9 +286,9 @@ #define CONFIG_SYS_OCM_DATA_SIZE 0x1000
#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#endif /* __CONFIG_H */ diff --git a/include/configs/DU440.h b/include/configs/DU440.h index e6e2b30..9146ad2 100644 --- a/include/configs/DU440.h +++ b/include/configs/DU440.h @@ -79,9 +79,9 @@ #define CONFIG_SYS_INIT_RAM_OCM 1 /* OCM as init ram */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_BASE /* OCM */
-#define CONFIG_SYS_INIT_RAM_END (4 << 10) +#define CONFIG_SYS_INIT_RAM_SIZE (4 << 10) #define CONFIG_SYS_GBL_DATA_SIZE 256 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* diff --git a/include/configs/EB+MCF-EV123.h b/include/configs/EB+MCF-EV123.h index af57fb9..d722ae6 100644 --- a/include/configs/EB+MCF-EV123.h +++ b/include/configs/EB+MCF-EV123.h @@ -153,10 +153,10 @@ *-----------------------------------------------------------------------*/
#define CONFIG_SYS_INIT_RAM_ADDR 0x20000000 -#define CONFIG_SYS_INIT_RAM_END 0x10000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x10000 #define CONFIG_SYS_GBL_DATA_SIZE 64 #define CONFIG_SYS_GBL_DATA_OFFSET \ - (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) + (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- @@ -209,9 +209,9 @@ #define CONFIG_SYS_CACHELINE_SIZE 16
#define ICACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_END - 8) + CONFIG_SYS_INIT_RAM_SIZE - 8) #define DCACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_END - 4) + CONFIG_SYS_INIT_RAM_SIZE - 4) #define CONFIG_SYS_ICACHE_INV (CF_CACR_CINV + CF_CACR_DCM) #define CONFIG_SYS_CACHE_ACR0 (CONFIG_SYS_SDRAM_BASE | \ CF_ADDRMASK(CONFIG_SYS_SDRAM_SIZE) | \ diff --git a/include/configs/ELPPC.h b/include/configs/ELPPC.h index 7e940b8..ae9bfc5 100644 --- a/include/configs/ELPPC.h +++ b/include/configs/ELPPC.h @@ -176,9 +176,9 @@ * Definitions for initial stack pointer and data area */ #define CONFIG_SYS_INIT_RAM_ADDR 0x00fd0000 /* above the memtest region */ -#define CONFIG_SYS_INIT_RAM_END 0x4000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for init data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* diff --git a/include/configs/ELPT860.h b/include/configs/ELPT860.h index f38160a..28e396e 100644 --- a/include/configs/ELPT860.h +++ b/include/configs/ELPT860.h @@ -169,9 +169,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/EP88x.h b/include/configs/EP88x.h index ec1cc4eb..fbc3f25 100644 --- a/include/configs/EP88x.h +++ b/include/configs/EP88x.h @@ -171,9 +171,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* Size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/ERIC.h b/include/configs/ERIC.h index 42465da..4e05e8f 100644 --- a/include/configs/ERIC.h +++ b/include/configs/ERIC.h @@ -352,9 +352,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR 0x00df0000 /* inside of SDRAM */ -#define CONFIG_SYS_INIT_RAM_END 0x0f00 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x0f00 /* Size of used area in RAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/ESTEEM192E.h b/include/configs/ESTEEM192E.h index d5a3cd3..21d995f 100644 --- a/include/configs/ESTEEM192E.h +++ b/include/configs/ESTEEM192E.h @@ -120,9 +120,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
diff --git a/include/configs/ETX094.h b/include/configs/ETX094.h index e890a97..a9e7fa0 100644 --- a/include/configs/ETX094.h +++ b/include/configs/ETX094.h @@ -138,9 +138,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/EVB64260.h b/include/configs/EVB64260.h index d312811..94ab1c9 100644 --- a/include/configs/EVB64260.h +++ b/include/configs/EVB64260.h @@ -162,9 +162,9 @@ * Definitions for initial stack pointer and data area */ #define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 -#define CONFIG_SYS_INIT_RAM_END 0x1000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for init data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_RAM_LOCK
diff --git a/include/configs/EXBITGEN.h b/include/configs/EXBITGEN.h index 1489d30..286c38c 100644 --- a/include/configs/EXBITGEN.h +++ b/include/configs/EXBITGEN.h @@ -200,9 +200,9 @@
/* Global info and initial stack */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of on-chip SRAM */ -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#if defined(CONFIG_CMD_KGDB) diff --git a/include/configs/FADS823.h b/include/configs/FADS823.h index 9795834..dcffac2 100644 --- a/include/configs/FADS823.h +++ b/include/configs/FADS823.h @@ -170,9 +170,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/FADS850SAR.h b/include/configs/FADS850SAR.h index 9e2b1a4..e94474d 100644 --- a/include/configs/FADS850SAR.h +++ b/include/configs/FADS850SAR.h @@ -117,9 +117,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/FLAGADM.h b/include/configs/FLAGADM.h index 12144cd..0471f8f 100644 --- a/include/configs/FLAGADM.h +++ b/include/configs/FLAGADM.h @@ -128,9 +128,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/FPS850L.h b/include/configs/FPS850L.h index 1a3d2f8..06b78ee 100644 --- a/include/configs/FPS850L.h +++ b/include/configs/FPS850L.h @@ -167,9 +167,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/FPS860L.h b/include/configs/FPS860L.h index 20e618f..90d5b46 100644 --- a/include/configs/FPS860L.h +++ b/include/configs/FPS860L.h @@ -167,9 +167,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/G2000.h b/include/configs/G2000.h index 00f27cc..6723c96 100644 --- a/include/configs/G2000.h +++ b/include/configs/G2000.h @@ -354,10 +354,10 @@ #define CONFIG_SYS_OCM_DATA_ADDR 0xF8000000 #define CONFIG_SYS_OCM_DATA_SIZE 0x1000 #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */
/*----------------------------------------------------------------------- diff --git a/include/configs/GEN860T.h b/include/configs/GEN860T.h index 915aff3..68a0cfd 100644 --- a/include/configs/GEN860T.h +++ b/include/configs/GEN860T.h @@ -382,9 +382,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_INIT_DATA_SIZE 64 /* # bytes reserved for initial data*/ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_INIT_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_INIT_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* diff --git a/include/configs/GENIETV.h b/include/configs/GENIETV.h index dc925af..929b56e 100644 --- a/include/configs/GENIETV.h +++ b/include/configs/GENIETV.h @@ -161,9 +161,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/HH405.h b/include/configs/HH405.h index 8a31324..4244a04 100644 --- a/include/configs/HH405.h +++ b/include/configs/HH405.h @@ -450,10 +450,10 @@ #define CONFIG_SYS_OCM_DATA_ADDR 0xF8000000 #define CONFIG_SYS_OCM_DATA_SIZE 0x1000 #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */
/*----------------------------------------------------------------------- diff --git a/include/configs/HIDDEN_DRAGON.h b/include/configs/HIDDEN_DRAGON.h index 6cb19c5..592f4d2 100644 --- a/include/configs/HIDDEN_DRAGON.h +++ b/include/configs/HIDDEN_DRAGON.h @@ -126,9 +126,9 @@ #define CONFIG_SYS_MONITOR_BASE 0x00090000 #define CONFIG_SYS_RAMBOOT 1 #define CONFIG_SYS_INIT_RAM_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) -#define CONFIG_SYS_INIT_RAM_END 0x10000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x10000 #define CONFIG_SYS_GBL_DATA_SIZE 256 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET #else #undef CONFIG_SYS_RAMBOOT @@ -138,8 +138,8 @@ #define CONFIG_SYS_GBL_DATA_SIZE 128
#endif
diff --git a/include/configs/HUB405.h b/include/configs/HUB405.h index 863204e..cc5a9b7 100644 --- a/include/configs/HUB405.h +++ b/include/configs/HUB405.h @@ -323,10 +323,10 @@ #define CONFIG_SYS_OCM_DATA_ADDR 0xF8000000 #define CONFIG_SYS_OCM_DATA_SIZE 0x1000 #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */
/*----------------------------------------------------------------------- diff --git a/include/configs/IAD210.h b/include/configs/IAD210.h index 5633177..75e152c 100644 --- a/include/configs/IAD210.h +++ b/include/configs/IAD210.h @@ -183,9 +183,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/ICU862.h b/include/configs/ICU862.h index 3fa6130..3528d5d 100644 --- a/include/configs/ICU862.h +++ b/include/configs/ICU862.h @@ -187,9 +187,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/IDS8247.h b/include/configs/IDS8247.h index 1b90a6b..d0f6952 100644 --- a/include/configs/IDS8247.h +++ b/include/configs/IDS8247.h @@ -293,9 +293,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2000 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data*/ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/IP860.h b/include/configs/IP860.h index df7ea9a..cbece32 100644 --- a/include/configs/IP860.h +++ b/include/configs/IP860.h @@ -151,9 +151,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/IPHASE4539.h b/include/configs/IPHASE4539.h index 281d0bd..e19a3df 100644 --- a/include/configs/IPHASE4539.h +++ b/include/configs/IPHASE4539.h @@ -246,9 +246,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x4000 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/ISPAN.h b/include/configs/ISPAN.h index e651658..e78ff06 100644 --- a/include/configs/ISPAN.h +++ b/include/configs/ISPAN.h @@ -231,9 +231,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x4000 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* Size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/IVML24.h b/include/configs/IVML24.h index 6444bd1..28a8ace 100644 --- a/include/configs/IVML24.h +++ b/include/configs/IVML24.h @@ -147,15 +147,15 @@ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR
#if defined (CONFIG_IVML24_16M) -# define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +# define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #elif defined (CONFIG_IVML24_32M) -# define CONFIG_SYS_INIT_RAM_END 0x3000 /* End of used area in DPRAM */ +# define CONFIG_SYS_INIT_RAM_SIZE 0x3000 /* Size of used area in DPRAM */ #elif defined (CONFIG_IVML24_64M) -# define CONFIG_SYS_INIT_RAM_END 0x3000 /* End of used area in DPRAM */ +# define CONFIG_SYS_INIT_RAM_SIZE 0x3000 /* Size of used area in DPRAM */ #endif
/*----------------------------------------------------------------------- diff --git a/include/configs/IVMS8.h b/include/configs/IVMS8.h index 1ebbc45..16628ea 100644 --- a/include/configs/IVMS8.h +++ b/include/configs/IVMS8.h @@ -143,15 +143,15 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #if defined (CONFIG_IVMS8_16M) -# define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +# define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #elif defined (CONFIG_IVMS8_32M) -# define CONFIG_SYS_INIT_RAM_END 0x3000 /* End of used area in DPRAM */ +# define CONFIG_SYS_INIT_RAM_SIZE 0x3000 /* Size of used area in DPRAM */ #elif defined (CONFIG_IVMS8_64M) -# define CONFIG_SYS_INIT_RAM_END 0x3000 /* End of used area in DPRAM */ +# define CONFIG_SYS_INIT_RAM_SIZE 0x3000 /* Size of used area in DPRAM */ #endif
/*----------------------------------------------------------------------- diff --git a/include/configs/IceCube.h b/include/configs/IceCube.h index f54a393..8584b34 100644 --- a/include/configs/IceCube.h +++ b/include/configs/IceCube.h @@ -275,11 +275,11 @@
/* Use SRAM until RAM will be available */ #define CONFIG_SYS_INIT_RAM_ADDR MPC5XXX_SRAM -#define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_SIZE /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE /* Size of used area in DPRAM */
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/JSE.h b/include/configs/JSE.h index 2a1cc58..fb35ee6 100644 --- a/include/configs/JSE.h +++ b/include/configs/JSE.h @@ -59,10 +59,10 @@ /* ... place INIT RAM in the OCM address */ # define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* ... give it the whole init ram */ -# define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE +# define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* ... Shave a bit off the end for global data */ # define CONFIG_SYS_GBL_DATA_SIZE 128 -# define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +# define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) /* ... and place the stack pointer at the top of what's left. */ # define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
diff --git a/include/configs/KAREF.h b/include/configs/KAREF.h index 46b9175..82b79c9 100644 --- a/include/configs/KAREF.h +++ b/include/configs/KAREF.h @@ -80,10 +80,10 @@ #define CONFIG_SYS_TEMP_STACK_OCM 1 #define CONFIG_SYS_OCM_DATA_ADDR CONFIG_SYS_ISRAM_BASE #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_ISRAM_BASE /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_END 0x2000 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in RAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* num bytes initial data */
-#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_GBL_DATA_OFFSET - 0x4)
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Rsrv 256kB for Mon */ diff --git a/include/configs/KUP4K.h b/include/configs/KUP4K.h index c8e0ff2..1bcf581 100644 --- a/include/configs/KUP4K.h +++ b/include/configs/KUP4K.h @@ -211,9 +211,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/KUP4X.h b/include/configs/KUP4X.h index ce731e3..b220991 100644 --- a/include/configs/KUP4X.h +++ b/include/configs/KUP4X.h @@ -227,9 +227,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/LANTEC.h b/include/configs/LANTEC.h index 7c58f68..4357062 100644 --- a/include/configs/LANTEC.h +++ b/include/configs/LANTEC.h @@ -155,9 +155,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/M5208EVBE.h b/include/configs/M5208EVBE.h index e6632ac..d251625 100644 --- a/include/configs/M5208EVBE.h +++ b/include/configs/M5208EVBE.h @@ -146,10 +146,10 @@ */ /* Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR 0x80000000 -#define CONFIG_SYS_INIT_RAM_END 0x4000 /* End of used area in internal SRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in internal SRAM */ #define CONFIG_SYS_INIT_RAM_CTRL 0x221 #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) - 0x10) +#define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) - 0x10) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* @@ -208,9 +208,9 @@ #define CONFIG_SYS_CACHELINE_SIZE 16
#define ICACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_END - 8) + CONFIG_SYS_INIT_RAM_SIZE - 8) #define DCACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_END - 4) + CONFIG_SYS_INIT_RAM_SIZE - 4) #define CONFIG_SYS_ICACHE_INV (CF_CACR_CINV | CF_CACR_INVI) #define CONFIG_SYS_CACHE_ACR0 (CONFIG_SYS_SDRAM_BASE | \ CF_ADDRMASK(CONFIG_SYS_SDRAM_SIZE) | \ diff --git a/include/configs/M52277EVB.h b/include/configs/M52277EVB.h index 887bd63..a4420eb 100644 --- a/include/configs/M52277EVB.h +++ b/include/configs/M52277EVB.h @@ -207,12 +207,12 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR 0x80000000 -#define CONFIG_SYS_INIT_RAM_END 0x8000 /* End of used area in internal SRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x8000 /* Size of used area in internal SRAM */ #define CONFIG_SYS_INIT_RAM_CTRL 0x221 #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) - 32) +#define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) - 32) #define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_GBL_DATA_OFFSET - 32) -#define CONFIG_SYS_SBFHDR_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - 32) +#define CONFIG_SYS_SBFHDR_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - 32)
/* * Start addresses for the final memory configuration @@ -303,9 +303,9 @@ #define CONFIG_SYS_CACHELINE_SIZE 16
#define ICACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_END - 8) + CONFIG_SYS_INIT_RAM_SIZE - 8) #define DCACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_END - 4) + CONFIG_SYS_INIT_RAM_SIZE - 4) #define CONFIG_SYS_ICACHE_INV (CF_CACR_CINV | CF_CACR_INVI) #define CONFIG_SYS_CACHE_ACR0 (CONFIG_SYS_SDRAM_BASE | \ CF_ADDRMASK(CONFIG_SYS_SDRAM_SIZE) | \ diff --git a/include/configs/M5235EVB.h b/include/configs/M5235EVB.h index 5c0dc84..6d624dc 100644 --- a/include/configs/M5235EVB.h +++ b/include/configs/M5235EVB.h @@ -167,10 +167,10 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR 0x20000000 -#define CONFIG_SYS_INIT_RAM_END 0x10000 /* End of used area in internal SRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x10000 /* Size of used area in internal SRAM */ #define CONFIG_SYS_INIT_RAM_CTRL 0x21 #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE - 0x10) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE - 0x10) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- @@ -238,9 +238,9 @@ #define CONFIG_SYS_CACHELINE_SIZE 16
#define ICACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_END - 8) + CONFIG_SYS_INIT_RAM_SIZE - 8) #define DCACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_END - 4) + CONFIG_SYS_INIT_RAM_SIZE - 4) #define CONFIG_SYS_ICACHE_INV (CF_CACR_CINV) #define CONFIG_SYS_CACHE_ACR0 (CONFIG_SYS_SDRAM_BASE | \ CF_ADDRMASK(CONFIG_SYS_SDRAM_SIZE) | \ diff --git a/include/configs/M5249EVB.h b/include/configs/M5249EVB.h index 33ac285..9aae2c6 100644 --- a/include/configs/M5249EVB.h +++ b/include/configs/M5249EVB.h @@ -109,9 +109,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR 0x20000000 -#define CONFIG_SYS_INIT_RAM_END 0x1000 /* End of used area in internal SRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in internal SRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#define CONFIG_ENV_IS_IN_FLASH 1 @@ -167,9 +167,9 @@ #define CONFIG_SYS_CACHELINE_SIZE 16
#define ICACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_END - 8) + CONFIG_SYS_INIT_RAM_SIZE - 8) #define DCACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_END - 4) + CONFIG_SYS_INIT_RAM_SIZE - 4) #define CONFIG_SYS_ICACHE_INV (CF_CACR_DCM) #define CONFIG_SYS_CACHE_ACR0 (CONFIG_SYS_FLASH_BASE | \ CF_ADDRMASK(2) | \ diff --git a/include/configs/M5253DEMO.h b/include/configs/M5253DEMO.h index b5af493..64b0b69 100644 --- a/include/configs/M5253DEMO.h +++ b/include/configs/M5253DEMO.h @@ -167,9 +167,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR 0x20000000 -#define CONFIG_SYS_INIT_RAM_END 0x10000 /* End of used area in internal SRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x10000 /* Size of used area in internal SRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* @@ -228,9 +228,9 @@ #define CONFIG_SYS_CACHELINE_SIZE 16
#define ICACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_END - 8) + CONFIG_SYS_INIT_RAM_SIZE - 8) #define DCACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_END - 4) + CONFIG_SYS_INIT_RAM_SIZE - 4) #define CONFIG_SYS_ICACHE_INV (CF_CACR_DCM) #define CONFIG_SYS_CACHE_ACR0 (CONFIG_SYS_FLASH_BASE | \ CF_ADDRMASK(8) | \ diff --git a/include/configs/M5253EVBE.h b/include/configs/M5253EVBE.h index 206d115..1dee3ef 100644 --- a/include/configs/M5253EVBE.h +++ b/include/configs/M5253EVBE.h @@ -135,9 +135,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR 0x20000000 -#define CONFIG_SYS_INIT_RAM_END 0x10000 /* End of used area in internal SRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x10000 /* Size of used area in internal SRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* @@ -181,9 +181,9 @@ #define CONFIG_SYS_CACHELINE_SIZE 16
#define ICACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_END - 8) + CONFIG_SYS_INIT_RAM_SIZE - 8) #define DCACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_END - 4) + CONFIG_SYS_INIT_RAM_SIZE - 4) #define CONFIG_SYS_ICACHE_INV (CF_CACR_DCM) #define CONFIG_SYS_CACHE_ACR0 (CONFIG_SYS_FLASH_BASE | \ CF_ADDRMASK(2) | \ diff --git a/include/configs/M5271EVB.h b/include/configs/M5271EVB.h index 798949c..41b1314 100644 --- a/include/configs/M5271EVB.h +++ b/include/configs/M5271EVB.h @@ -187,9 +187,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR 0x20000000 -#define CONFIG_SYS_INIT_RAM_END 0x1000 /* End of used area in internal SRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in internal SRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* @@ -231,9 +231,9 @@ #define CONFIG_SYS_CACHELINE_SIZE 16
#define ICACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_END - 8) + CONFIG_SYS_INIT_RAM_SIZE - 8) #define DCACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_END - 4) + CONFIG_SYS_INIT_RAM_SIZE - 4) #define CONFIG_SYS_ICACHE_INV (CF_CACR_CINV | CF_CACR_INVI) #define CONFIG_SYS_CACHE_ACR0 (CONFIG_SYS_SDRAM_BASE | \ CF_ADDRMASK(CONFIG_SYS_SDRAM_SIZE) | \ diff --git a/include/configs/M5272C3.h b/include/configs/M5272C3.h index f704bb3..dd5ca08 100644 --- a/include/configs/M5272C3.h +++ b/include/configs/M5272C3.h @@ -163,9 +163,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR 0x20000000 -#define CONFIG_SYS_INIT_RAM_END 0x1000 /* End of used area in internal SRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in internal SRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- @@ -213,9 +213,9 @@ #define CONFIG_SYS_CACHELINE_SIZE 16
#define ICACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_END - 8) + CONFIG_SYS_INIT_RAM_SIZE - 8) #define DCACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_END - 4) + CONFIG_SYS_INIT_RAM_SIZE - 4) #define CONFIG_SYS_ICACHE_INV (CF_CACR_CINV | CF_CACR_INVI) #define CONFIG_SYS_CACHE_ACR0 (CONFIG_SYS_SDRAM_BASE | \ CF_ADDRMASK(CONFIG_SYS_SDRAM_SIZE) | \ diff --git a/include/configs/M5275EVB.h b/include/configs/M5275EVB.h index 981670a..f879042 100644 --- a/include/configs/M5275EVB.h +++ b/include/configs/M5275EVB.h @@ -173,9 +173,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR 0x20000000 -#define CONFIG_SYS_INIT_RAM_END 0x10000 /* End of used area in internal SRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x10000 /* Size of used area in internal SRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 1000 /* bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- @@ -222,9 +222,9 @@ #define CONFIG_SYS_CACHELINE_SIZE 16
#define ICACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_END - 8) + CONFIG_SYS_INIT_RAM_SIZE - 8) #define DCACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_END - 4) + CONFIG_SYS_INIT_RAM_SIZE - 4) #define CONFIG_SYS_ICACHE_INV (CF_CACR_CINV | CF_CACR_INVI) #define CONFIG_SYS_CACHE_ACR0 (CONFIG_SYS_SDRAM_BASE | \ CF_ADDRMASK(CONFIG_SYS_SDRAM_SIZE) | \ diff --git a/include/configs/M5282EVB.h b/include/configs/M5282EVB.h index 46f60bf..9aecd12 100644 --- a/include/configs/M5282EVB.h +++ b/include/configs/M5282EVB.h @@ -154,9 +154,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR 0x20000000 -#define CONFIG_SYS_INIT_RAM_END 0x10000 /* End of used area in internal SRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x10000 /* Size of used area in internal SRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- @@ -211,9 +211,9 @@ #define CONFIG_SYS_CACHELINE_SIZE 16
#define ICACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_END - 8) + CONFIG_SYS_INIT_RAM_SIZE - 8) #define DCACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_END - 4) + CONFIG_SYS_INIT_RAM_SIZE - 4) #define CONFIG_SYS_ICACHE_INV (CF_CACR_CINV + CF_CACR_DCM) #define CONFIG_SYS_CACHE_ACR0 (CONFIG_SYS_SDRAM_BASE | \ CF_ADDRMASK(CONFIG_SYS_SDRAM_SIZE) | \ diff --git a/include/configs/M53017EVB.h b/include/configs/M53017EVB.h index d983a8f..17efb63 100644 --- a/include/configs/M53017EVB.h +++ b/include/configs/M53017EVB.h @@ -167,10 +167,10 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR 0x80000000 -#define CONFIG_SYS_INIT_RAM_END 0x20000 /* End of used area in internal SRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x20000 /* Size of used area in internal SRAM */ #define CONFIG_SYS_INIT_RAM_CTRL 0x221 #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) - 0x10) +#define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) - 0x10) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* @@ -234,9 +234,9 @@ #define CONFIG_SYS_CACHELINE_SIZE 16
#define ICACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_END - 8) + CONFIG_SYS_INIT_RAM_SIZE - 8) #define DCACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_END - 4) + CONFIG_SYS_INIT_RAM_SIZE - 4) #define CONFIG_SYS_ICACHE_INV (CF_CACR_CINVA) #define CONFIG_SYS_CACHE_ACR0 (CONFIG_SYS_SDRAM_BASE | \ CF_ADDRMASK(CONFIG_SYS_SDRAM_SIZE) | \ diff --git a/include/configs/M5329EVB.h b/include/configs/M5329EVB.h index 159b178..6717ef3 100644 --- a/include/configs/M5329EVB.h +++ b/include/configs/M5329EVB.h @@ -162,10 +162,10 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR 0x80000000 -#define CONFIG_SYS_INIT_RAM_END 0x8000 /* End of used area in internal SRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x8000 /* Size of used area in internal SRAM */ #define CONFIG_SYS_INIT_RAM_CTRL 0x221 #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) - 0x10) +#define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) - 0x10) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#define ICACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_END - 8) + CONFIG_SYS_INIT_RAM_SIZE - 8) #define DCACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_END - 4) + CONFIG_SYS_INIT_RAM_SIZE - 4) #define CONFIG_SYS_ICACHE_INV (CF_CACR_CINVA) #define CONFIG_SYS_CACHE_ACR0 (CONFIG_SYS_SDRAM_BASE | \ CF_ADDRMASK(CONFIG_SYS_SDRAM_SIZE) | \ diff --git a/include/configs/M5373EVB.h b/include/configs/M5373EVB.h index af1988c..441496b 100644 --- a/include/configs/M5373EVB.h +++ b/include/configs/M5373EVB.h @@ -162,10 +162,10 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR 0x80000000 -#define CONFIG_SYS_INIT_RAM_END 0x8000 /* End of used area in internal SRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x8000 /* Size of used area in internal SRAM */ #define CONFIG_SYS_INIT_RAM_CTRL 0x221 #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) - 0x10) +#define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) - 0x10) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#define ICACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_END - 8) + CONFIG_SYS_INIT_RAM_SIZE - 8) #define DCACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_END - 4) + CONFIG_SYS_INIT_RAM_SIZE - 4) #define CONFIG_SYS_ICACHE_INV (CF_CACR_CINVA) #define CONFIG_SYS_CACHE_ACR0 (CONFIG_SYS_SDRAM_BASE | \ CF_ADDRMASK(CONFIG_SYS_SDRAM_SIZE) | \ diff --git a/include/configs/M54451EVB.h b/include/configs/M54451EVB.h index 1ff80ee..4c45517 100644 --- a/include/configs/M54451EVB.h +++ b/include/configs/M54451EVB.h @@ -220,12 +220,12 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR 0x80000000 -#define CONFIG_SYS_INIT_RAM_END 0x8000 /* End of used area in internal SRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x8000 /* Size of used area in internal SRAM */ #define CONFIG_SYS_INIT_RAM_CTRL 0x221 #define CONFIG_SYS_GBL_DATA_SIZE 256 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) - 32) +#define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) - 32) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET -#define CONFIG_SYS_SBFHDR_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - 32) +#define CONFIG_SYS_SBFHDR_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - 32)
/*----------------------------------------------------------------------- * Start addresses for the final memory configuration @@ -310,9 +310,9 @@ #define CONFIG_SYS_CACHELINE_SIZE 16
#define ICACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_END - 8) + CONFIG_SYS_INIT_RAM_SIZE - 8) #define DCACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_END - 4) + CONFIG_SYS_INIT_RAM_SIZE - 4) #define CONFIG_SYS_ICACHE_INV (CF_CACR_BCINVA + CF_CACR_ICINVA) #define CONFIG_SYS_DCACHE_INV (CF_CACR_DCINVA) #define CONFIG_SYS_CACHE_ACR2 (CONFIG_SYS_SDRAM_BASE | \ diff --git a/include/configs/M54455EVB.h b/include/configs/M54455EVB.h index 1cdc373..6a7c92c 100644 --- a/include/configs/M54455EVB.h +++ b/include/configs/M54455EVB.h @@ -279,12 +279,12 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR 0x80000000 -#define CONFIG_SYS_INIT_RAM_END 0x8000 /* End of used area in internal SRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x8000 /* Size of used area in internal SRAM */ #define CONFIG_SYS_INIT_RAM_CTRL 0x221 #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) - 32) +#define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) - 32) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET -#define CONFIG_SYS_SBFHDR_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - 32) +#define CONFIG_SYS_SBFHDR_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - 32)
/*----------------------------------------------------------------------- * Start addresses for the final memory configuration @@ -409,9 +409,9 @@ #define CONFIG_SYS_CACHELINE_SIZE 16
#define ICACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_END - 8) + CONFIG_SYS_INIT_RAM_SIZE - 8) #define DCACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_END - 4) + CONFIG_SYS_INIT_RAM_SIZE - 4) #define CONFIG_SYS_ICACHE_INV (CF_CACR_BCINVA + CF_CACR_ICINVA) #define CONFIG_SYS_DCACHE_INV (CF_CACR_DCINVA) #define CONFIG_SYS_CACHE_ACR2 (CONFIG_SYS_SDRAM_BASE | \ diff --git a/include/configs/M5475EVB.h b/include/configs/M5475EVB.h index d007766..ec2b075 100644 --- a/include/configs/M5475EVB.h +++ b/include/configs/M5475EVB.h @@ -210,13 +210,13 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR 0xF2000000 -#define CONFIG_SYS_INIT_RAM_END 0x1000 /* End of used area in internal SRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in internal SRAM */ #define CONFIG_SYS_INIT_RAM_CTRL 0x21 -#define CONFIG_SYS_INIT_RAM1_ADDR (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_RAM_END) +#define CONFIG_SYS_INIT_RAM1_ADDR (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_RAM_SIZE) #define CONFIG_SYS_INIT_RAM1_END 0x1000 /* End of used area in internal SRAM */ #define CONFIG_SYS_INIT_RAM1_CTRL 0x21 #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) - 0x10) +#define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) - 0x10) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- @@ -287,9 +287,9 @@ #define CONFIG_SYS_CACHELINE_SIZE 16
#define ICACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_END - 8) + CONFIG_SYS_INIT_RAM_SIZE - 8) #define DCACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_END - 4) + CONFIG_SYS_INIT_RAM_SIZE - 4) #define CONFIG_SYS_ICACHE_INV (CF_CACR_BCINVA + CF_CACR_ICINVA + \ CF_CACR_IDCM) #define CONFIG_SYS_DCACHE_INV (CF_CACR_DCINVA) diff --git a/include/configs/M5485EVB.h b/include/configs/M5485EVB.h index f23b8b0..92fe316 100644 --- a/include/configs/M5485EVB.h +++ b/include/configs/M5485EVB.h @@ -196,13 +196,13 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR 0xF2000000 -#define CONFIG_SYS_INIT_RAM_END 0x1000 /* End of used area in internal SRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in internal SRAM */ #define CONFIG_SYS_INIT_RAM_CTRL 0x21 -#define CONFIG_SYS_INIT_RAM1_ADDR (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_RAM_END) +#define CONFIG_SYS_INIT_RAM1_ADDR (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_RAM_SIZE) #define CONFIG_SYS_INIT_RAM1_END 0x1000 /* End of used area in internal SRAM */ #define CONFIG_SYS_INIT_RAM1_CTRL 0x21 #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) - 0x10) +#define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) - 0x10) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- @@ -273,9 +273,9 @@ #define CONFIG_SYS_CACHELINE_SIZE 16
#define ICACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_END - 8) + CONFIG_SYS_INIT_RAM_SIZE - 8) #define DCACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_END - 4) + CONFIG_SYS_INIT_RAM_SIZE - 4) #define CONFIG_SYS_ICACHE_INV (CF_CACR_BCINVA + CF_CACR_ICINVA + \ CF_CACR_IDCM) #define CONFIG_SYS_DCACHE_INV (CF_CACR_DCINVA) diff --git a/include/configs/MBX.h b/include/configs/MBX.h index 3b4d60c..647e9dd 100644 --- a/include/configs/MBX.h +++ b/include/configs/MBX.h @@ -144,9 +144,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2f00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2f00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_VPD_SIZE 256 /* size in bytes reserved for vpd buffer */ #define CONFIG_SYS_INIT_VPD_OFFSET (CONFIG_SYS_GBL_DATA_OFFSET - CONFIG_SYS_INIT_VPD_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_INIT_VPD_OFFSET-8) diff --git a/include/configs/MBX860T.h b/include/configs/MBX860T.h index 6964bec..26d1b22 100644 --- a/include/configs/MBX860T.h +++ b/include/configs/MBX860T.h @@ -98,9 +98,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2f00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2f00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_VPD_SIZE 256 /* size in bytes reserved for vpd buffer */ #define CONFIG_SYS_INIT_VPD_OFFSET (CONFIG_SYS_GBL_DATA_OFFSET - CONFIG_SYS_INIT_VPD_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_INIT_VPD_OFFSET-8) diff --git a/include/configs/METROBOX.h b/include/configs/METROBOX.h index d79b702..abc7ad2 100644 --- a/include/configs/METROBOX.h +++ b/include/configs/METROBOX.h @@ -142,10 +142,10 @@ #define CONFIG_SYS_TEMP_STACK_OCM 1 #define CONFIG_SYS_OCM_DATA_ADDR CONFIG_SYS_ISRAM_BASE #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_ISRAM_BASE /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_END 0x2000 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in RAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* num bytes initial data */
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Rsrv 256kB for Mon */ diff --git a/include/configs/MHPC.h b/include/configs/MHPC.h index 6ad0658..a4a5269 100644 --- a/include/configs/MHPC.h +++ b/include/configs/MHPC.h @@ -179,9 +179,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/MIP405.h b/include/configs/MIP405.h index 58764d0..a8d297e 100644 --- a/include/configs/MIP405.h +++ b/include/configs/MIP405.h @@ -308,9 +308,9 @@ #define CONFIG_SYS_OCM_DATA_ADDR 0xF0000000 #define CONFIG_SYS_OCM_DATA_SIZE 0x1000 #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of On Chip SRAM */ -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE /* End of On Chip SRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of On Chip SRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) /* reserve some memory for POST and BOOT limit info */ #define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_GBL_DATA_OFFSET - 32)
diff --git a/include/configs/ML2.h b/include/configs/ML2.h index 8579f96..c22824f 100644 --- a/include/configs/ML2.h +++ b/include/configs/ML2.h @@ -211,9 +211,9 @@ */
#define CONFIG_SYS_INIT_RAM_ADDR 0x800000 /* inside of SDRAM */ -#define CONFIG_SYS_INIT_RAM_END 0x2000 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in RAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/MOUSSE.h b/include/configs/MOUSSE.h index 69c0cab..4a407b1 100644 --- a/include/configs/MOUSSE.h +++ b/include/configs/MOUSSE.h @@ -157,9 +157,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_SDRAM_BASE + CONFIG_SYS_MONITOR_LEN -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* diff --git a/include/configs/MPC8260ADS.h b/include/configs/MPC8260ADS.h index 05caf21..c3ab8a7 100644 --- a/include/configs/MPC8260ADS.h +++ b/include/configs/MPC8260ADS.h @@ -348,9 +348,9 @@ #define BCSR_PCI_MODE 0x01000000
#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2000 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#ifdef CONFIG_SYS_LOWBOOT diff --git a/include/configs/MPC8266ADS.h b/include/configs/MPC8266ADS.h index 97202df..456f008 100644 --- a/include/configs/MPC8266ADS.h +++ b/include/configs/MPC8266ADS.h @@ -382,9 +382,9 @@ #define FETH_RST 0x04000004
/* Use this HRCW for booting from address 0xfe00000 (JP3 in setting 1-2) */ diff --git a/include/configs/MPC8308RDB.h b/include/configs/MPC8308RDB.h index 2eab1c4..b111015 100644 --- a/include/configs/MPC8308RDB.h +++ b/include/configs/MPC8308RDB.h @@ -212,10 +212,10 @@ */ #define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xE6000000 /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_END 0x1000 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM */ #define CONFIG_SYS_GBL_DATA_SIZE 0x100 /* num bytes initial data */ #define CONFIG_SYS_GBL_DATA_OFFSET \ - (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) + (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE)
/* * Local Bus Configuration & Clock Setup diff --git a/include/configs/MPC8313ERDB.h b/include/configs/MPC8313ERDB.h index 1b2bebb..b141fdf 100644 --- a/include/configs/MPC8313ERDB.h +++ b/include/configs/MPC8313ERDB.h @@ -208,10 +208,10 @@
#define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xFD000000 /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_END 0x1000 /* End of used area in RAM*/ +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM*/
#define CONFIG_SYS_GBL_DATA_SIZE 0x100 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* CONFIG_SYS_MONITOR_LEN must be a multiple of CONFIG_ENV_SECT_SIZE */ diff --git a/include/configs/MPC8315ERDB.h b/include/configs/MPC8315ERDB.h index 17ce3bc..48167c4 100644 --- a/include/configs/MPC8315ERDB.h +++ b/include/configs/MPC8315ERDB.h @@ -191,9 +191,9 @@ */ #define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xE6000000 /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_END 0x1000 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM */ #define CONFIG_SYS_GBL_DATA_SIZE 0x100 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE)
/* * Local Bus Configuration & Clock Setup diff --git a/include/configs/MPC8323ERDB.h b/include/configs/MPC8323ERDB.h index abbb92a..857181a 100644 --- a/include/configs/MPC8323ERDB.h +++ b/include/configs/MPC8323ERDB.h @@ -165,9 +165,9 @@ */ #define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xE6000000 /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_END 0x1000 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM */ #define CONFIG_SYS_GBL_DATA_SIZE 0x100 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE)
/* * Local Bus Configuration & Clock Setup diff --git a/include/configs/MPC832XEMDS.h b/include/configs/MPC832XEMDS.h index 6009d44..ade5b6d 100644 --- a/include/configs/MPC832XEMDS.h +++ b/include/configs/MPC832XEMDS.h @@ -152,9 +152,9 @@ */ #define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xE6000000 /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_END 0x1000 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM */ #define CONFIG_SYS_GBL_DATA_SIZE 0x100 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE)
/* * Local Bus Configuration & Clock Setup diff --git a/include/configs/MPC8349EMDS.h b/include/configs/MPC8349EMDS.h index 5682787..5ac20f2 100644 --- a/include/configs/MPC8349EMDS.h +++ b/include/configs/MPC8349EMDS.h @@ -193,10 +193,10 @@
#define CONFIG_SYS_MONITOR_LEN (384 * 1024) /* Reserve 384 kB for Mon */ diff --git a/include/configs/MPC8349ITX.h b/include/configs/MPC8349ITX.h index 5d10a5e..26e9b82 100644 --- a/include/configs/MPC8349ITX.h +++ b/include/configs/MPC8349ITX.h @@ -306,10 +306,10 @@ boards, we say we have two, but don't display a message if we find only one. */
#define CONFIG_SYS_INIT_RAM_LOCK #define CONFIG_SYS_INIT_RAM_ADDR 0xFD000000 /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_END 0x1000 /* End of used area in RAM*/ +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM*/
/* CONFIG_SYS_MONITOR_LEN must be a multiple of CONFIG_ENV_SECT_SIZE */ diff --git a/include/configs/MPC8360EMDS.h b/include/configs/MPC8360EMDS.h index bc644ba..29e1d31 100644 --- a/include/configs/MPC8360EMDS.h +++ b/include/configs/MPC8360EMDS.h @@ -181,9 +181,9 @@ */ #define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xE6000000 /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_END 0x1000 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM */ #define CONFIG_SYS_GBL_DATA_SIZE 0x100 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE)
/* * Local Bus Configuration & Clock Setup diff --git a/include/configs/MPC8360ERDK.h b/include/configs/MPC8360ERDK.h index e9a6400..b830a0f 100644 --- a/include/configs/MPC8360ERDK.h +++ b/include/configs/MPC8360ERDK.h @@ -172,9 +172,9 @@ */ #define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xE6000000 /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_END 0x1000 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM */ #define CONFIG_SYS_GBL_DATA_SIZE 0x100 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE)
/* * Local Bus Configuration & Clock Setup diff --git a/include/configs/MPC837XEMDS.h b/include/configs/MPC837XEMDS.h index fa0da48..e482646 100644 --- a/include/configs/MPC837XEMDS.h +++ b/include/configs/MPC837XEMDS.h @@ -215,9 +215,9 @@ */ #define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xE6000000 /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_END 0x1000 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM */ #define CONFIG_SYS_GBL_DATA_SIZE 0x100 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE)
/* * Local Bus Configuration & Clock Setup diff --git a/include/configs/MPC837XERDB.h b/include/configs/MPC837XERDB.h index 9d99a93..b5c05fe 100644 --- a/include/configs/MPC837XERDB.h +++ b/include/configs/MPC837XERDB.h @@ -238,9 +238,9 @@ */ #define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xE6000000 /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_END 0x1000 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM */ #define CONFIG_SYS_GBL_DATA_SIZE 0x100 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE)
/* * Local Bus Configuration & Clock Setup diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index 8b8f467..6f4c1bf 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -303,11 +303,11 @@
#define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xffd00000 /* Initial L1 address */ -#define CONFIG_SYS_INIT_RAM_END 0x00004000 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x00004000 /* Size of used area in RAM */
#define CONFIG_SYS_GBL_DATA_SIZE 128 /* num bytes initial data */ #define CONFIG_SYS_GBL_DATA_OFFSET \ - (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) + (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ diff --git a/include/configs/MPC8540ADS.h b/include/configs/MPC8540ADS.h index b1ee07b..2d9e788 100644 --- a/include/configs/MPC8540ADS.h +++ b/include/configs/MPC8540ADS.h @@ -232,10 +232,10 @@
#define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xe4010000 /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_END 0x4000 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in RAM */
#define CONFIG_SYS_GBL_DATA_SIZE 128 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ diff --git a/include/configs/MPC8540EVAL.h b/include/configs/MPC8540EVAL.h index cc52a67..dcb1127 100644 --- a/include/configs/MPC8540EVAL.h +++ b/include/configs/MPC8540EVAL.h @@ -164,10 +164,10 @@
#define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_END 0x4000 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in RAM */
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ diff --git a/include/configs/MPC8541CDS.h b/include/configs/MPC8541CDS.h index 037aae7..ffaa8d3 100644 --- a/include/configs/MPC8541CDS.h +++ b/include/configs/MPC8541CDS.h @@ -254,10 +254,10 @@ extern unsigned long get_clock_freq(void);
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ diff --git a/include/configs/MPC8544DS.h b/include/configs/MPC8544DS.h index 0b69885..cd5f181 100644 --- a/include/configs/MPC8544DS.h +++ b/include/configs/MPC8544DS.h @@ -203,11 +203,11 @@ extern unsigned long get_board_sys_clk(unsigned long dummy);
#define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xf4010000 /* Initial L1 address */ -#define CONFIG_SYS_INIT_RAM_END 0x00004000 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x00004000 /* Size of used area in RAM */
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ diff --git a/include/configs/MPC8548CDS.h b/include/configs/MPC8548CDS.h index 5d21d11..031e130 100644 --- a/include/configs/MPC8548CDS.h +++ b/include/configs/MPC8548CDS.h @@ -273,12 +273,12 @@ extern unsigned long get_clock_freq(void);
#define CONFIG_SYS_INIT_L2_ADDR 0xf8f80000 /* relocate boot L2SRAM */
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ diff --git a/include/configs/MPC8555CDS.h b/include/configs/MPC8555CDS.h index 0068684..13df407 100644 --- a/include/configs/MPC8555CDS.h +++ b/include/configs/MPC8555CDS.h @@ -252,10 +252,10 @@ extern unsigned long get_clock_freq(void);
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ diff --git a/include/configs/MPC8560ADS.h b/include/configs/MPC8560ADS.h index 96f7383..b2d7892 100644 --- a/include/configs/MPC8560ADS.h +++ b/include/configs/MPC8560ADS.h @@ -229,10 +229,10 @@
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ diff --git a/include/configs/MPC8568MDS.h b/include/configs/MPC8568MDS.h index d6171b4..6e0ff7e 100644 --- a/include/configs/MPC8568MDS.h +++ b/include/configs/MPC8568MDS.h @@ -235,10 +235,10 @@ extern unsigned long get_clock_freq(void);
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ diff --git a/include/configs/MPC8569MDS.h b/include/configs/MPC8569MDS.h index e3a997e..6ef30c5 100644 --- a/include/configs/MPC8569MDS.h +++ b/include/configs/MPC8569MDS.h @@ -268,11 +268,11 @@ extern unsigned long get_clock_freq(void);
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index e8206ea..9685df8 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -268,10 +268,10 @@
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ diff --git a/include/configs/MPC8610HPCD.h b/include/configs/MPC8610HPCD.h index c876e98..b023f81 100644 --- a/include/configs/MPC8610HPCD.h +++ b/include/configs/MPC8610HPCD.h @@ -213,10 +213,10 @@ #else #define CONFIG_SYS_INIT_RAM_ADDR 0xe4000000 /* Initial RAM address */ #endif -#define CONFIG_SYS_INIT_RAM_END 0x4000 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in RAM */
#define CONFIG_SYS_MONITOR_LEN (512 * 1024) /* Reserve 512 KB for Mon */ diff --git a/include/configs/MPC8641HPCN.h b/include/configs/MPC8641HPCN.h index 9009e3c..9c6f840 100644 --- a/include/configs/MPC8641HPCN.h +++ b/include/configs/MPC8641HPCN.h @@ -271,10 +271,10 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #else #define CONFIG_SYS_INIT_RAM_ADDR 0xf8400000 /* Initial RAM address */ #endif -#define CONFIG_SYS_INIT_RAM_END 0x4000 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in RAM */
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ diff --git a/include/configs/MUSENKI.h b/include/configs/MUSENKI.h index e0bfd08..79bd608 100644 --- a/include/configs/MUSENKI.h +++ b/include/configs/MUSENKI.h @@ -158,8 +158,8 @@ /*#define CONFIG_SYS_GBL_DATA_SIZE 256*/ #define CONFIG_SYS_GBL_DATA_SIZE 128 #define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 -#define CONFIG_SYS_INIT_RAM_END 0x1000 -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE)
/* diff --git a/include/configs/MVBC_P.h b/include/configs/MVBC_P.h index acc7187..88bfc81 100644 --- a/include/configs/MVBC_P.h +++ b/include/configs/MVBC_P.h @@ -235,10 +235,10 @@ #define CONFIG_SYS_DEFAULT_MBAR 0x80000000
#define CONFIG_SYS_INIT_RAM_ADDR MPC5XXX_SRAM -#define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_SIZE +#define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE
#define CONFIG_SYS_GBL_DATA_SIZE 128 -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/MVBLM7.h b/include/configs/MVBLM7.h index 44d45e3..c2fe620 100644 --- a/include/configs/MVBLM7.h +++ b/include/configs/MVBLM7.h @@ -123,10 +123,10 @@
/* CONFIG_SYS_MONITOR_LEN must be a multiple of CONFIG_ENV_SECT_SIZE */ diff --git a/include/configs/MVBLUE.h b/include/configs/MVBLUE.h index dd392d0..cd1bc80 100644 --- a/include/configs/MVBLUE.h +++ b/include/configs/MVBLUE.h @@ -214,9 +214,9 @@ * Definitions for initial stack pointer and data area */ #define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 -#define CONFIG_SYS_INIT_RAM_END 0x1000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 #define CONFIG_SYS_GBL_DATA_SIZE 128 -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE)
/* * Low Level Configuration Settings diff --git a/include/configs/MVS1.h b/include/configs/MVS1.h index 9bf7fcb..1e4e6d9 100644 --- a/include/configs/MVS1.h +++ b/include/configs/MVS1.h @@ -140,9 +140,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/MVSMR.h b/include/configs/MVSMR.h index c125157..7582735 100644 --- a/include/configs/MVSMR.h +++ b/include/configs/MVSMR.h @@ -204,10 +204,10 @@ #define CONFIG_SYS_DEFAULT_MBAR 0x80000000
#define CONFIG_SYS_GBL_DATA_SIZE 128 -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - \ +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
diff --git a/include/configs/NETPHONE.h b/include/configs/NETPHONE.h index 62eef46..fd6ab59 100644 --- a/include/configs/NETPHONE.h +++ b/include/configs/NETPHONE.h @@ -172,9 +172,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x3000 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x3000 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/NETTA.h b/include/configs/NETTA.h index db22ba3..2d38a1b 100644 --- a/include/configs/NETTA.h +++ b/include/configs/NETTA.h @@ -185,9 +185,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x3000 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x3000 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/NETTA2.h b/include/configs/NETTA2.h index 87000e6..5415b5c 100644 --- a/include/configs/NETTA2.h +++ b/include/configs/NETTA2.h @@ -173,9 +173,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x3000 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x3000 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/NETVIA.h b/include/configs/NETVIA.h index b7119fd..ea838ae 100644 --- a/include/configs/NETVIA.h +++ b/include/configs/NETVIA.h @@ -153,9 +153,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x3000 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x3000 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/NSCU.h b/include/configs/NSCU.h index 4f76ca1..743b6dd 100644 --- a/include/configs/NSCU.h +++ b/include/configs/NSCU.h @@ -175,9 +175,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/NX823.h b/include/configs/NX823.h index e588ea3..23a30f7 100644 --- a/include/configs/NX823.h +++ b/include/configs/NX823.h @@ -117,9 +117,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/OCRTC.h b/include/configs/OCRTC.h index 0343043..6c6828a 100644 --- a/include/configs/OCRTC.h +++ b/include/configs/OCRTC.h @@ -297,9 +297,9 @@ #define CONFIG_SYS_OCM_DATA_SIZE 0x1000
#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#endif /* __CONFIG_H */ diff --git a/include/configs/ORSG.h b/include/configs/ORSG.h index cef1117..5ab9942 100644 --- a/include/configs/ORSG.h +++ b/include/configs/ORSG.h @@ -293,9 +293,9 @@ #define CONFIG_SYS_OCM_DATA_SIZE 0x1000
#endif /* __CONFIG_H */ diff --git a/include/configs/OXC.h b/include/configs/OXC.h index 9a0c558..0f362f1 100644 --- a/include/configs/OXC.h +++ b/include/configs/OXC.h @@ -148,10 +148,10 @@ #endif
#define CONFIG_SYS_MALLOC_LEN (512 << 10) /* Reserve 512 kB for malloc() */ diff --git a/include/configs/P1022DS.h b/include/configs/P1022DS.h index 1a4632f..bc5b73e 100644 --- a/include/configs/P1022DS.h +++ b/include/configs/P1022DS.h @@ -153,11 +153,11 @@
#define CONFIG_SYS_INIT_RAM_LOCK #define CONFIG_SYS_INIT_RAM_ADDR 0xffd00000 /* Initial L1 address */ -#define CONFIG_SYS_INIT_RAM_END 0x00004000 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x00004000 /* Size of used area in RAM */
#define CONFIG_SYS_MONITOR_LEN (512 * 1024) diff --git a/include/configs/P1_P2_RDB.h b/include/configs/P1_P2_RDB.h index cff0ed34..7f05618 100644 --- a/include/configs/P1_P2_RDB.h +++ b/include/configs/P1_P2_RDB.h @@ -211,10 +211,10 @@ extern unsigned long get_board_sys_clk(unsigned long dummy);
#define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xffd00000 /* stack in RAM */ -#define CONFIG_SYS_INIT_RAM_END 0x00004000 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x00004000 /* Size of used area in RAM */
#define CONFIG_SYS_GBL_DATA_SIZE 128 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END \ +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE \ - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
diff --git a/include/configs/P2020DS.h b/include/configs/P2020DS.h index 8c7d528..6e26f7a 100644 --- a/include/configs/P2020DS.h +++ b/include/configs/P2020DS.h @@ -272,10 +272,10 @@ #define CONFIG_SYS_INIT_RAM_ADDR_PHYS_HIGH 0 #define CONFIG_SYS_INIT_RAM_ADDR_PHYS_LOW CONFIG_SYS_INIT_RAM_ADDR_PHYS #endif -#define CONFIG_SYS_INIT_RAM_END 0x00004000 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x00004000 /* Size of used area in RAM */
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ diff --git a/include/configs/P3G4.h b/include/configs/P3G4.h index 47b7558..54212f1 100644 --- a/include/configs/P3G4.h +++ b/include/configs/P3G4.h @@ -185,9 +185,9 @@ * Definitions for initial stack pointer and data area */ #define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 -#define CONFIG_SYS_INIT_RAM_END 0x1000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for init data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_RAM_LOCK
diff --git a/include/configs/PATI.h b/include/configs/PATI.h index b07cac1..8887f97 100644 --- a/include/configs/PATI.h +++ b/include/configs/PATI.h @@ -132,9 +132,9 @@ * Definitions for initial stack pointer and data area */ #define CONFIG_SYS_INIT_RAM_ADDR (CONFIG_SYS_IMMR + 0x003f9800) /* Physical start adress of internal MPC555 writable RAM */ -#define CONFIG_SYS_INIT_RAM_END (CONFIG_SYS_IMMR + 0x003fffff) /* Physical end adress of internal MPC555 used RAM area */ +#define CONFIG_SYS_INIT_RAM_SIZE (CONFIG_SYS_IMMR + 0x003fffff) /* Physical end adress of internal MPC555 used RAM area */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* Size in bytes reserved for initial global data */ -#define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_INIT_RAM_ADDR) - CONFIG_SYS_GBL_DATA_SIZE) /* Offset from the beginning of ram */ +#define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_INIT_RAM_ADDR) - CONFIG_SYS_GBL_DATA_SIZE) /* Offset from the beginning of ram */ #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_IMMR + 0x03fa000) /* Physical start adress of inital stack */ /* * Start addresses for the final memory configuration diff --git a/include/configs/PCI405.h b/include/configs/PCI405.h index 28769b3..91c8f53 100644 --- a/include/configs/PCI405.h +++ b/include/configs/PCI405.h @@ -307,10 +307,10 @@ #define CONFIG_SYS_OCM_DATA_ADDR 0xF8000000 #define CONFIG_SYS_OCM_DATA_SIZE 0x1000 #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */
#endif /* __CONFIG_H */ diff --git a/include/configs/PCIPPC2.h b/include/configs/PCIPPC2.h index d0ce924..ea02311 100644 --- a/include/configs/PCIPPC2.h +++ b/include/configs/PCIPPC2.h @@ -143,8 +143,8 @@ #define CONFIG_SYS_GBL_DATA_SIZE 128
#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 -#define CONFIG_SYS_INIT_RAM_END 0x8000 -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_RAM_SIZE 0x8000 +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#define CONFIG_SYS_INIT_RAM_LOCK diff --git a/include/configs/PCIPPC6.h b/include/configs/PCIPPC6.h index 8f7ec02..4cf45d3 100644 --- a/include/configs/PCIPPC6.h +++ b/include/configs/PCIPPC6.h @@ -145,8 +145,8 @@ #define CONFIG_SYS_GBL_DATA_SIZE 128
#define CONFIG_SYS_INIT_RAM_LOCK diff --git a/include/configs/PIP405.h b/include/configs/PIP405.h index e3cf943..04062b0 100644 --- a/include/configs/PIP405.h +++ b/include/configs/PIP405.h @@ -258,9 +258,9 @@ #define CONFIG_SYS_OCM_DATA_ADDR 0xF0000000 #define CONFIG_SYS_OCM_DATA_SIZE 0x1000 #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of On Chip SRAM */ -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE /* End of On Chip SRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of On Chip SRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*********************************************************************** diff --git a/include/configs/PLU405.h b/include/configs/PLU405.h index 3844e48..421f26a 100644 --- a/include/configs/PLU405.h +++ b/include/configs/PLU405.h @@ -368,10 +368,10 @@ #define CONFIG_SYS_OCM_DATA_ADDR 0xF8000000 #define CONFIG_SYS_OCM_DATA_SIZE 0x1000 #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */
/* diff --git a/include/configs/PM520.h b/include/configs/PM520.h index 5832307..f039e5a 100644 --- a/include/configs/PM520.h +++ b/include/configs/PM520.h @@ -233,11 +233,11 @@
/* Use SRAM until RAM will be available */ #define CONFIG_SYS_INIT_RAM_ADDR MPC5XXX_SRAM -#define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_SIZE /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE /* Size of used area in DPRAM */
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/PM826.h b/include/configs/PM826.h index d26254f..7ac29f2 100644 --- a/include/configs/PM826.h +++ b/include/configs/PM826.h @@ -293,9 +293,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x4000 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data*/ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/PM828.h b/include/configs/PM828.h index 3053ad4..565a5d8 100644 --- a/include/configs/PM828.h +++ b/include/configs/PM828.h @@ -287,9 +287,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x4000 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data*/ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/PM854.h b/include/configs/PM854.h index 5963334..6c3f7c2 100644 --- a/include/configs/PM854.h +++ b/include/configs/PM854.h @@ -165,10 +165,10 @@
#define CONFIG_SYS_MONITOR_LEN (512 * 1024) /* Reserve 512 kB for Mon */ diff --git a/include/configs/PM856.h b/include/configs/PM856.h index 1559fd6..f5aa77a 100644 --- a/include/configs/PM856.h +++ b/include/configs/PM856.h @@ -168,10 +168,10 @@
#define CONFIG_SYS_MONITOR_LEN (512 * 1024) /* Reserve 512 kB for Mon */ diff --git a/include/configs/PMC405.h b/include/configs/PMC405.h index b1d0ea5..d5794e4 100644 --- a/include/configs/PMC405.h +++ b/include/configs/PMC405.h @@ -328,11 +328,11 @@ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR
/* End of used area in RAM */ -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE
/* size in bytes reserved for initial data */ #define CONFIG_SYS_GBL_DATA_SIZE 128 -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - \ +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
diff --git a/include/configs/PMC405DE.h b/include/configs/PMC405DE.h index 74b656c..201a9c4 100644 --- a/include/configs/PMC405DE.h +++ b/include/configs/PMC405DE.h @@ -270,10 +270,10 @@ /* inside SDRAM */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* End of used area in RAM */ -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE
#define CONFIG_SYS_GBL_DATA_SIZE 128 /* bytes res. for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - \ +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
diff --git a/include/configs/PMC440.h b/include/configs/PMC440.h index 7585e6e..1568912 100644 --- a/include/configs/PMC440.h +++ b/include/configs/PMC440.h @@ -88,9 +88,9 @@ *----------------------------------------------------------------------*/ /* 440EPx/440GRx have 16KB of internal SRAM, so no need for D-Cache */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_BASE /* OCM */ -#define CONFIG_SYS_INIT_RAM_END (4 << 10) +#define CONFIG_SYS_INIT_RAM_SIZE (4 << 10) #define CONFIG_SYS_GBL_DATA_SIZE 256 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_GBL_DATA_OFFSET - 0x4)
/*----------------------------------------------------------------------- diff --git a/include/configs/PN62.h b/include/configs/PN62.h index 01878ab..29ebd09 100644 --- a/include/configs/PN62.h +++ b/include/configs/PN62.h @@ -156,8 +156,8 @@ #define CONFIG_SYS_GBL_DATA_SIZE 128
#define CONFIG_SYS_NO_FLASH 1 /* There is no FLASH memory */ diff --git a/include/configs/PPChameleonEVB.h b/include/configs/PPChameleonEVB.h index 3bc3d70..b2de868 100644 --- a/include/configs/PPChameleonEVB.h +++ b/include/configs/PPChameleonEVB.h @@ -531,10 +531,10 @@ #define CONFIG_SYS_OCM_DATA_ADDR 0xF8000000 #define CONFIG_SYS_OCM_DATA_SIZE 0x1000 #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */
/*----------------------------------------------------------------------- diff --git a/include/configs/QS823.h b/include/configs/QS823.h index ec2e0c9..0df1084 100644 --- a/include/configs/QS823.h +++ b/include/configs/QS823.h @@ -272,9 +272,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/QS850.h b/include/configs/QS850.h index 3d455c4..338ca2e 100644 --- a/include/configs/QS850.h +++ b/include/configs/QS850.h @@ -272,9 +272,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/QS860T.h b/include/configs/QS860T.h index 99ccf08..6574986 100644 --- a/include/configs/QS860T.h +++ b/include/configs/QS860T.h @@ -181,9 +181,9 @@ CONFIG_SPI * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/R360MPI.h b/include/configs/R360MPI.h index a0355f1..000a27d 100644 --- a/include/configs/R360MPI.h +++ b/include/configs/R360MPI.h @@ -195,9 +195,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/RBC823.h b/include/configs/RBC823.h index 5a23e56..91e3b77 100644 --- a/include/configs/RBC823.h +++ b/include/configs/RBC823.h @@ -167,9 +167,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/RPXClassic.h b/include/configs/RPXClassic.h index e8e8a5d..757b7f9 100644 --- a/include/configs/RPXClassic.h +++ b/include/configs/RPXClassic.h @@ -183,9 +183,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x3000 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x3000 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/RPXlite.h b/include/configs/RPXlite.h index a7609ca..3fa5a9a 100644 --- a/include/configs/RPXlite.h +++ b/include/configs/RPXlite.h @@ -119,9 +119,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/RPXlite_DW.h b/include/configs/RPXlite_DW.h index b895f05..ebc652d 100644 --- a/include/configs/RPXlite_DW.h +++ b/include/configs/RPXlite_DW.h @@ -194,9 +194,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/RPXsuper.h b/include/configs/RPXsuper.h index 2ac764d..3a30b4a 100644 --- a/include/configs/RPXsuper.h +++ b/include/configs/RPXsuper.h @@ -265,9 +265,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x4000 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/RRvision.h b/include/configs/RRvision.h index 9530381..58813d7 100644 --- a/include/configs/RRvision.h +++ b/include/configs/RRvision.h @@ -196,9 +196,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/Rattler.h b/include/configs/Rattler.h index cdfce6a..ae71e37 100644 --- a/include/configs/Rattler.h +++ b/include/configs/Rattler.h @@ -241,9 +241,9 @@ #define CONFIG_SYS_IMMR 0xF0000000
#define CONFIG_SYS_SDRAM_BASE 0x00000000 diff --git a/include/configs/SBC8540.h b/include/configs/SBC8540.h index b91dc4b..081c59b 100644 --- a/include/configs/SBC8540.h +++ b/include/configs/SBC8540.h @@ -193,10 +193,10 @@
#define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0x70000000 /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_END 0x4000 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in RAM */
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ diff --git a/include/configs/SCM.h b/include/configs/SCM.h index edad459..55efe53 100644 --- a/include/configs/SCM.h +++ b/include/configs/SCM.h @@ -325,9 +325,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x4000 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data*/ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/SIMPC8313.h b/include/configs/SIMPC8313.h index 15d99f9..0348297 100644 --- a/include/configs/SIMPC8313.h +++ b/include/configs/SIMPC8313.h @@ -103,10 +103,10 @@
/* CONFIG_SYS_MONITOR_LEN must be a multiple of CONFIG_ENV_SECT_SIZE */ diff --git a/include/configs/SM850.h b/include/configs/SM850.h index 259f8ab..13d556d 100644 --- a/include/configs/SM850.h +++ b/include/configs/SM850.h @@ -125,9 +125,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/SPD823TS.h b/include/configs/SPD823TS.h index b132a78..a1cd670 100644 --- a/include/configs/SPD823TS.h +++ b/include/configs/SPD823TS.h @@ -137,9 +137,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/SXNI855T.h b/include/configs/SXNI855T.h index 7c3f874..52e8e16 100644 --- a/include/configs/SXNI855T.h +++ b/include/configs/SXNI855T.h @@ -205,9 +205,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/Sandpoint8240.h b/include/configs/Sandpoint8240.h index f6107ce..e2d45b1 100644 --- a/include/configs/Sandpoint8240.h +++ b/include/configs/Sandpoint8240.h @@ -154,9 +154,9 @@ #define CONFIG_SYS_MONITOR_BASE 0x00090000 #define CONFIG_SYS_RAMBOOT 1 #define CONFIG_SYS_INIT_RAM_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) -#define CONFIG_SYS_INIT_RAM_END 0x10000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x10000 #define CONFIG_SYS_GBL_DATA_SIZE 256 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET #else #undef CONFIG_SYS_RAMBOOT @@ -167,8 +167,8 @@ #define CONFIG_SYS_GBL_DATA_SIZE 128
#endif
diff --git a/include/configs/Sandpoint8245.h b/include/configs/Sandpoint8245.h index 66a98c1..1eaad5a 100644 --- a/include/configs/Sandpoint8245.h +++ b/include/configs/Sandpoint8245.h @@ -124,9 +124,9 @@ #define CONFIG_SYS_MONITOR_BASE 0x00090000 #define CONFIG_SYS_RAMBOOT 1 #define CONFIG_SYS_INIT_RAM_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) -#define CONFIG_SYS_INIT_RAM_END 0x10000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x10000 #define CONFIG_SYS_GBL_DATA_SIZE 256 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET #else #undef CONFIG_SYS_RAMBOOT @@ -137,8 +137,8 @@ #define CONFIG_SYS_GBL_DATA_SIZE 128
#endif
diff --git a/include/configs/TASREG.h b/include/configs/TASREG.h index b69f015..6be20be 100644 --- a/include/configs/TASREG.h +++ b/include/configs/TASREG.h @@ -189,9 +189,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR 0x20000000 -#define CONFIG_SYS_INIT_RAM_END 0x1000 /* End of used area in internal SRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in internal SRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#define CONFIG_ENV_IS_IN_FLASH 1 @@ -253,9 +253,9 @@ #define CONFIG_SYS_CACHELINE_SIZE 16
#define ICACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_END - 8) + CONFIG_SYS_INIT_RAM_SIZE - 8) #define DCACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_END - 4) + CONFIG_SYS_INIT_RAM_SIZE - 4) #define CONFIG_SYS_ICACHE_INV (CF_CACR_DCM) #define CONFIG_SYS_CACHE_ACR1 (CONFIG_SYS_SDRAM_BASE | \ CF_ADDRMASK(CONFIG_SYS_SDRAM_SIZE) | \ diff --git a/include/configs/TB5200.h b/include/configs/TB5200.h index f336e8d..1bcb9d0 100644 --- a/include/configs/TB5200.h +++ b/include/configs/TB5200.h @@ -327,14 +327,14 @@ #define CONFIG_SYS_INIT_RAM_ADDR MPC5XXX_SRAM #ifdef CONFIG_POST /* preserve space for the post_word at end of on-chip SRAM */ -#define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_POST_SIZE +#define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_POST_SIZE #else -#define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_SIZE +#define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE #endif
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/TK885D.h b/include/configs/TK885D.h index d849dbc..f24b86e 100644 --- a/include/configs/TK885D.h +++ b/include/configs/TK885D.h @@ -221,9 +221,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/TOP5200.h b/include/configs/TOP5200.h index ab1773c..ba1fcf1 100644 --- a/include/configs/TOP5200.h +++ b/include/configs/TOP5200.h @@ -297,11 +297,11 @@
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/TOP860.h b/include/configs/TOP860.h index a9d9bed..0901013 100644 --- a/include/configs/TOP860.h +++ b/include/configs/TOP860.h @@ -230,9 +230,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2f00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2f00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_VPD_SIZE 256 /* size in bytes reserved for vpd buffer */ #define CONFIG_SYS_INIT_VPD_OFFSET (CONFIG_SYS_GBL_DATA_OFFSET - CONFIG_SYS_INIT_VPD_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_INIT_VPD_OFFSET-8) diff --git a/include/configs/TQM5200.h b/include/configs/TQM5200.h index 794e11b..86ebaa4 100644 --- a/include/configs/TQM5200.h +++ b/include/configs/TQM5200.h @@ -487,14 +487,14 @@ #define CONFIG_SYS_INIT_RAM_ADDR MPC5XXX_SRAM #ifdef CONFIG_POST /* preserve space for the post_word at end of on-chip SRAM */ -#define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_POST_SIZE +#define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_POST_SIZE #else -#define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_SIZE +#define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE #endif
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/TQM823L.h b/include/configs/TQM823L.h index b68d7a7..681185d 100644 --- a/include/configs/TQM823L.h +++ b/include/configs/TQM823L.h @@ -182,9 +182,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/TQM823M.h b/include/configs/TQM823M.h index 374300b..5d32b41 100644 --- a/include/configs/TQM823M.h +++ b/include/configs/TQM823M.h @@ -177,9 +177,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/TQM8260.h b/include/configs/TQM8260.h index 2104e03..7214c85 100644 --- a/include/configs/TQM8260.h +++ b/include/configs/TQM8260.h @@ -362,9 +362,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x4000 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data*/ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/TQM8272.h b/include/configs/TQM8272.h index 063ca23..1771824 100644 --- a/include/configs/TQM8272.h +++ b/include/configs/TQM8272.h @@ -488,9 +488,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2000 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data*/ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/TQM834x.h b/include/configs/TQM834x.h index 36399ca..abaae73 100644 --- a/include/configs/TQM834x.h +++ b/include/configs/TQM834x.h @@ -151,10 +151,10 @@
#define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0x20000000 /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_END 0x1000 /* End of used area in RAM*/ +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM*/
#define CONFIG_SYS_MONITOR_LEN (384 * 1024) /* Reserve 384 kB = 3 sect. for Mon */ diff --git a/include/configs/TQM850L.h b/include/configs/TQM850L.h index c97bf66..a4efe11 100644 --- a/include/configs/TQM850L.h +++ b/include/configs/TQM850L.h @@ -167,9 +167,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/TQM850M.h b/include/configs/TQM850M.h index 3e13f61..0300586 100644 --- a/include/configs/TQM850M.h +++ b/include/configs/TQM850M.h @@ -166,9 +166,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/TQM855L.h b/include/configs/TQM855L.h index 1bc2861..e9c69dc 100644 --- a/include/configs/TQM855L.h +++ b/include/configs/TQM855L.h @@ -171,9 +171,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/TQM855M.h b/include/configs/TQM855M.h index 197ffde..e0481f1 100644 --- a/include/configs/TQM855M.h +++ b/include/configs/TQM855M.h @@ -205,9 +205,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/TQM85xx.h b/include/configs/TQM85xx.h index d5c116f..5836976 100644 --- a/include/configs/TQM85xx.h +++ b/include/configs/TQM85xx.h @@ -243,10 +243,10 @@ #define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR (CONFIG_SYS_CCSRBAR \ + 0x04010000) /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_END 0x4000 /* End used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size used area in RAM */
#define CONFIG_SYS_MONITOR_LEN (~CONFIG_SYS_TEXT_BASE + 1)/* Reserved for Monitor */ diff --git a/include/configs/TQM860L.h b/include/configs/TQM860L.h index d3d0db4..da8a664 100644 --- a/include/configs/TQM860L.h +++ b/include/configs/TQM860L.h @@ -170,9 +170,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/TQM860M.h b/include/configs/TQM860M.h index 0854d95..13425b1 100644 --- a/include/configs/TQM860M.h +++ b/include/configs/TQM860M.h @@ -171,9 +171,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/TQM862L.h b/include/configs/TQM862L.h index c247737..3f879ec 100644 --- a/include/configs/TQM862L.h +++ b/include/configs/TQM862L.h @@ -174,9 +174,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/TQM862M.h b/include/configs/TQM862M.h index 1b6d9cb..1206b7a 100644 --- a/include/configs/TQM862M.h +++ b/include/configs/TQM862M.h @@ -174,9 +174,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/TQM866M.h b/include/configs/TQM866M.h index a5018d5..c3f3e87 100644 --- a/include/configs/TQM866M.h +++ b/include/configs/TQM866M.h @@ -217,9 +217,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/TQM885D.h b/include/configs/TQM885D.h index 507fb2f..a30e82d 100644 --- a/include/configs/TQM885D.h +++ b/include/configs/TQM885D.h @@ -219,9 +219,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/Total5200.h b/include/configs/Total5200.h index c518d6e..3bb975c 100644 --- a/include/configs/Total5200.h +++ b/include/configs/Total5200.h @@ -246,10 +246,10 @@
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/VOH405.h b/include/configs/VOH405.h index 026d2a4..4827748 100644 --- a/include/configs/VOH405.h +++ b/include/configs/VOH405.h @@ -377,10 +377,10 @@ #define CONFIG_SYS_OCM_DATA_ADDR 0xF8000000 #define CONFIG_SYS_OCM_DATA_SIZE 0x1000 #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */
/*----------------------------------------------------------------------- diff --git a/include/configs/VOM405.h b/include/configs/VOM405.h index fddefb2..f1e4407 100644 --- a/include/configs/VOM405.h +++ b/include/configs/VOM405.h @@ -258,10 +258,10 @@ #define CONFIG_SYS_OCM_DATA_ADDR 0xF8000000 #define CONFIG_SYS_OCM_DATA_SIZE 0x1000 #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */
/* diff --git a/include/configs/VoVPN-GW.h b/include/configs/VoVPN-GW.h index 6243afe..4db8356 100644 --- a/include/configs/VoVPN-GW.h +++ b/include/configs/VoVPN-GW.h @@ -298,9 +298,9 @@
/* definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x2000 #define CONFIG_SYS_GBL_DATA_SIZE 128 -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* diff --git a/include/configs/W7OLMC.h b/include/configs/W7OLMC.h index 9eacd82..1e71d09 100644 --- a/include/configs/W7OLMC.h +++ b/include/configs/W7OLMC.h @@ -313,9 +313,9 @@ * Definitions for initial stack pointer and data area (in RAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#if defined(CONFIG_CMD_KGDB) diff --git a/include/configs/W7OLMG.h b/include/configs/W7OLMG.h index 6591d02..0ff84d5 100644 --- a/include/configs/W7OLMG.h +++ b/include/configs/W7OLMG.h @@ -316,9 +316,9 @@ * Definitions for initial stack pointer and data area (in RAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#if defined(CONFIG_CMD_KGDB) diff --git a/include/configs/WUH405.h b/include/configs/WUH405.h index e23ad41..a67dab2 100644 --- a/include/configs/WUH405.h +++ b/include/configs/WUH405.h @@ -321,10 +321,10 @@ #define CONFIG_SYS_OCM_DATA_ADDR 0xF8000000 #define CONFIG_SYS_OCM_DATA_SIZE 0x1000 #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */
/*----------------------------------------------------------------------- diff --git a/include/configs/Yukon8220.h b/include/configs/Yukon8220.h index a0fca03..2d52864 100644 --- a/include/configs/Yukon8220.h +++ b/include/configs/Yukon8220.h @@ -257,10 +257,10 @@
/* Use SRAM until RAM will be available */ #define CONFIG_SYS_INIT_RAM_ADDR (CONFIG_SYS_MBAR + 0x20000) -#define CONFIG_SYS_INIT_RAM_END 0x8000 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x8000 /* Size of used area in DPRAM */
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/ZPC1900.h b/include/configs/ZPC1900.h index 0eabf37..1d103f2 100644 --- a/include/configs/ZPC1900.h +++ b/include/configs/ZPC1900.h @@ -195,9 +195,9 @@ #define BCSR_PCI_MODE 0x01
#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x4000 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* Hard reset configuration word */ diff --git a/include/configs/ZUMA.h b/include/configs/ZUMA.h index 17ada0d..69e28d5 100644 --- a/include/configs/ZUMA.h +++ b/include/configs/ZUMA.h @@ -180,9 +180,9 @@ * Definitions for initial stack pointer and data area */ #define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 -#define CONFIG_SYS_INIT_RAM_END 0x1000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for init data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_RAM_LOCK
diff --git a/include/configs/a4m072.h b/include/configs/a4m072.h index f18bc45..aa0238b 100644 --- a/include/configs/a4m072.h +++ b/include/configs/a4m072.h @@ -250,11 +250,11 @@
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/acadia.h b/include/configs/acadia.h index c1bd4be..0b10569 100644 --- a/include/configs/acadia.h +++ b/include/configs/acadia.h @@ -84,10 +84,10 @@ #define CONFIG_SYS_OCM_DATA_ADDR 0xf8000000 #define CONFIG_SYS_OCM_DATA_SIZE 0x4000 /* 16K of onchip SRAM */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SRAM */ -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */
#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/aev.h b/include/configs/aev.h index 10ffb2e..122ebab 100644 --- a/include/configs/aev.h +++ b/include/configs/aev.h @@ -271,14 +271,14 @@ #define CONFIG_SYS_INIT_RAM_ADDR MPC5XXX_SRAM #ifdef CONFIG_POST /* preserve space for the post_word at end of on-chip SRAM */ -#define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_POST_SIZE +#define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_POST_SIZE #else -#define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_SIZE +#define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE #endif
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/alpr.h b/include/configs/alpr.h index dfe7802..ee13d1b 100644 --- a/include/configs/alpr.h +++ b/include/configs/alpr.h @@ -64,10 +64,10 @@ #define CONFIG_SYS_TEMP_STACK_OCM 1 #define CONFIG_SYS_OCM_DATA_ADDR CONFIG_SYS_ISRAM_BASE #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_ISRAM_BASE /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_END 0x2000 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in RAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* num bytes initial data */
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ diff --git a/include/configs/aria.h b/include/configs/aria.h index a63c453..37592fc 100644 --- a/include/configs/aria.h +++ b/include/configs/aria.h @@ -300,10 +300,10 @@
/* Use SRAM for initial stack */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_SRAM_BASE -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_SRAM_SIZE +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_SRAM_SIZE
#define CONFIG_SYS_GBL_DATA_SIZE 0x100 -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - \ +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
diff --git a/include/configs/astro_mcf5373l.h b/include/configs/astro_mcf5373l.h index f2bc26a..dae31b1 100644 --- a/include/configs/astro_mcf5373l.h +++ b/include/configs/astro_mcf5373l.h @@ -300,10 +300,10 @@ * Definitions for initial stack pointer and data area (in internal SRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR 0x80000000 -#define CONFIG_SYS_INIT_RAM_END 0x8000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x8000 #define CONFIG_SYS_INIT_RAM_CTRL 0x221 #define CONFIG_SYS_GBL_DATA_SIZE 128 -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - \ +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
@@ -387,9 +387,9 @@ #define CONFIG_SYS_CACHELINE_SIZE 16
#define ICACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_END - 8) + CONFIG_SYS_INIT_RAM_SIZE - 8) #define DCACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_END - 4) + CONFIG_SYS_INIT_RAM_SIZE - 4) #define CONFIG_SYS_ICACHE_INV (CF_CACR_CINVA) #define CONFIG_SYS_CACHE_ACR0 (CONFIG_SYS_SDRAM_BASE | \ CF_ADDRMASK(CONFIG_SYS_SDRAM_SIZE) | \ diff --git a/include/configs/atc.h b/include/configs/atc.h index 62e38e1..472e73c 100644 --- a/include/configs/atc.h +++ b/include/configs/atc.h @@ -244,9 +244,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data*/ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/bamboo.h b/include/configs/bamboo.h index 1bdfd9d..b985dc1 100644 --- a/include/configs/bamboo.h +++ b/include/configs/bamboo.h @@ -80,9 +80,9 @@ *----------------------------------------------------------------------*/ #define CONFIG_SYS_INIT_RAM_DCACHE 1 /* d-cache as init ram */ #define CONFIG_SYS_INIT_RAM_ADDR 0x70000000 /* DCache */ -#define CONFIG_SYS_INIT_RAM_END (4 << 10) +#define CONFIG_SYS_INIT_RAM_SIZE (4 << 10) #define CONFIG_SYS_GBL_DATA_SIZE 256 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/barco.h b/include/configs/barco.h index b656c01..6ff5c55 100644 --- a/include/configs/barco.h +++ b/include/configs/barco.h @@ -151,9 +151,9 @@ #define CONFIG_SYS_MONITOR_BASE 0x00090000 #define CONFIG_SYS_RAMBOOT 1 #define CONFIG_SYS_INIT_RAM_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) -#define CONFIG_SYS_INIT_RAM_END 0x10000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x10000 #define CONFIG_SYS_GBL_DATA_SIZE 256 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET #else #undef CONFIG_SYS_RAMBOOT @@ -163,8 +163,8 @@ #define CONFIG_SYS_GBL_DATA_SIZE 128
#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 -#define CONFIG_SYS_INIT_RAM_END 0x1000 -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE)
#endif
diff --git a/include/configs/bluestone.h b/include/configs/bluestone.h index 0bb97d9..c689763 100644 --- a/include/configs/bluestone.h +++ b/include/configs/bluestone.h @@ -66,10 +66,10 @@ * Initial RAM & stack pointer (placed in OCM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_BASE /* OCM */ -#define CONFIG_SYS_INIT_RAM_END (4 << 10) +#define CONFIG_SYS_INIT_RAM_SIZE (4 << 10) #define CONFIG_SYS_GBL_DATA_SIZE 256 /* num bytes initial data */ #define CONFIG_SYS_GBL_DATA_OFFSET \ - (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) + (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* diff --git a/include/configs/bubinga.h b/include/configs/bubinga.h index 7262b3e..7171032 100644 --- a/include/configs/bubinga.h +++ b/include/configs/bubinga.h @@ -238,10 +238,10 @@ #define CONFIG_SYS_OCM_DATA_ADDR 0xF8000000 #define CONFIG_SYS_OCM_DATA_SIZE 0x1000 #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */
/*----------------------------------------------------------------------- diff --git a/include/configs/c2mon.h b/include/configs/c2mon.h index 1351f29..8852f74 100644 --- a/include/configs/c2mon.h +++ b/include/configs/c2mon.h @@ -143,9 +143,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/ca9x4_ct_vxp.h b/include/configs/ca9x4_ct_vxp.h index 5547d55..2ab5579 100644 --- a/include/configs/ca9x4_ct_vxp.h +++ b/include/configs/ca9x4_ct_vxp.h @@ -116,9 +116,9 @@
/* additions for new relocation code */ #define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 -#define CONFIG_SYS_INIT_RAM_END 0x1000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 #define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_SDRAM_BASE + \ - CONFIG_SYS_INIT_RAM_END - \ + CONFIG_SYS_INIT_RAM_SIZE - \ CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_ADDR CONFIG_SYS_GBL_DATA_OFFSET
diff --git a/include/configs/canmb.h b/include/configs/canmb.h index e1ee158..7666ee7 100644 --- a/include/configs/canmb.h +++ b/include/configs/canmb.h @@ -157,11 +157,11 @@
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/canyonlands.h b/include/configs/canyonlands.h index fcc7d0e..fc039f8 100644 --- a/include/configs/canyonlands.h +++ b/include/configs/canyonlands.h @@ -124,9 +124,9 @@ * Initial RAM & stack pointer (placed in OCM) *----------------------------------------------------------------------*/ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_BASE /* OCM */ -#define CONFIG_SYS_INIT_RAM_END (4 << 10) +#define CONFIG_SYS_INIT_RAM_SIZE (4 << 10) #define CONFIG_SYS_GBL_DATA_SIZE 256 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/cm5200.h b/include/configs/cm5200.h index af6769b..488c0f2 100644 --- a/include/configs/cm5200.h +++ b/include/configs/cm5200.h @@ -162,13 +162,13 @@ #define CONFIG_SYS_INIT_RAM_ADDR MPC5XXX_SRAM #ifdef CONFIG_POST /* preserve space for the post_word at end of on-chip SRAM */ -#define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_POST_SIZE +#define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_POST_SIZE #else -#define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_SIZE +#define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE #endif
#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_BOARD_TYPES 1 /* we use board_type */
#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET diff --git a/include/configs/cmi_mpc5xx.h b/include/configs/cmi_mpc5xx.h index 88a45c3..e03bf31 100644 --- a/include/configs/cmi_mpc5xx.h +++ b/include/configs/cmi_mpc5xx.h @@ -129,9 +129,9 @@ * Definitions for initial stack pointer and data area */ #define CONFIG_SYS_INIT_RAM_ADDR (CONFIG_SYS_IMMR + 0x003f9800) /* Physical start adress of internal MPC555 writable RAM */ -#define CONFIG_SYS_INIT_RAM_END (CONFIG_SYS_IMMR + 0x003fffff) /* Physical end adress of internal MPC555 used RAM area */ +#define CONFIG_SYS_INIT_RAM_SIZE (CONFIG_SYS_IMMR + 0x003fffff) /* Physical end adress of internal MPC555 used RAM area */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* Size in bytes reserved for initial global data */ -#define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_INIT_RAM_ADDR) - CONFIG_SYS_GBL_DATA_SIZE) /* Offset from the beginning of ram */ +#define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_INIT_RAM_ADDR) - CONFIG_SYS_GBL_DATA_SIZE) /* Offset from the beginning of ram */ #define CONFIG_SYS_INIT_SP_ADDR 0x013fa000 /* Physical start adress of inital stack */
/* diff --git a/include/configs/cobra5272.h b/include/configs/cobra5272.h index 18710fb..0b36eb5 100644 --- a/include/configs/cobra5272.h +++ b/include/configs/cobra5272.h @@ -276,9 +276,9 @@ from which user programs will be started */ * Definitions for initial stack pointer and data area (in internal SRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR 0x20000000 -#define CONFIG_SYS_INIT_RAM_END 0x1000 /* End of used area in internal SRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in internal SRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- @@ -332,9 +332,9 @@ from which user programs will be started */ #define CONFIG_SYS_CACHELINE_SIZE 16
#define ICACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_END - 8) + CONFIG_SYS_INIT_RAM_SIZE - 8) #define DCACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_END - 4) + CONFIG_SYS_INIT_RAM_SIZE - 4) #define CONFIG_SYS_ICACHE_INV (CF_CACR_CINV | CF_CACR_INVI) #define CONFIG_SYS_CACHE_ACR0 (CONFIG_SYS_SDRAM_BASE | \ CF_ADDRMASK(CONFIG_SYS_SDRAM_SIZE) | \ diff --git a/include/configs/cogent_mpc8260.h b/include/configs/cogent_mpc8260.h index 8bfd702..b10e217 100644 --- a/include/configs/cogent_mpc8260.h +++ b/include/configs/cogent_mpc8260.h @@ -224,9 +224,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x4000 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/cogent_mpc8xx.h b/include/configs/cogent_mpc8xx.h index 3cc95b4..4d4a81c 100644 --- a/include/configs/cogent_mpc8xx.h +++ b/include/configs/cogent_mpc8xx.h @@ -171,9 +171,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index 2733fb2..065e89f 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -211,10 +211,10 @@ #define CONFIG_SYS_INIT_RAM_ADDR_PHYS_HIGH 0 #define CONFIG_SYS_INIT_RAM_ADDR_PHYS_LOW CONFIG_SYS_INIT_RAM_ADDR_PHYS #endif -#define CONFIG_SYS_INIT_RAM_END 0x00004000 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x00004000 /* Size of used area in RAM */
#define CONFIG_SYS_MONITOR_LEN (512 * 1024) diff --git a/include/configs/cpci5200.h b/include/configs/cpci5200.h index a865296..78df31f 100644 --- a/include/configs/cpci5200.h +++ b/include/configs/cpci5200.h @@ -235,10 +235,10 @@
/* Use SRAM until RAM will be available */ #define CONFIG_SYS_INIT_RAM_ADDR MPC5XXX_SRAM -#define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_SIZE /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE /* Size of used area in DPRAM */
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/csb272.h b/include/configs/csb272.h index acd9c93..071e967 100644 --- a/include/configs/csb272.h +++ b/include/configs/csb272.h @@ -293,9 +293,9 @@ * */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of on-chip SRAM */ -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* byte size reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* diff --git a/include/configs/csb472.h b/include/configs/csb472.h index 69abb16..8f5b3d4 100644 --- a/include/configs/csb472.h +++ b/include/configs/csb472.h @@ -292,9 +292,9 @@ * */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of on-chip SRAM */ -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* byte size reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* diff --git a/include/configs/debris.h b/include/configs/debris.h index 188061e..978b143 100644 --- a/include/configs/debris.h +++ b/include/configs/debris.h @@ -199,9 +199,9 @@ #define CONFIG_SYS_MONITOR_BASE 0x00090000 #define CONFIG_SYS_RAMBOOT 1 #define CONFIG_SYS_INIT_RAM_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) -#define CONFIG_SYS_INIT_RAM_END 0x10000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x10000 #define CONFIG_SYS_GBL_DATA_SIZE 256 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET #else #undef CONFIG_SYS_RAMBOOT @@ -212,8 +212,8 @@ #define CONFIG_SYS_GBL_DATA_SIZE 128
#endif
diff --git a/include/configs/digsy_mtc.h b/include/configs/digsy_mtc.h index 2e9a13f..0ede4ec 100644 --- a/include/configs/digsy_mtc.h +++ b/include/configs/digsy_mtc.h @@ -308,11 +308,11 @@ * Use SRAM until RAM will be available */ #define CONFIG_SYS_INIT_RAM_ADDR MPC5XXX_SRAM -#define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_SIZE +#define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE
#define CONFIG_SYS_GBL_DATA_SIZE 4096 #define CONFIG_SYS_GBL_DATA_OFFSET \ - (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) + (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/dlvision.h b/include/configs/dlvision.h index 0d44eda..c9bd261 100644 --- a/include/configs/dlvision.h +++ b/include/configs/dlvision.h @@ -191,11 +191,11 @@ #define CONFIG_SYS_OCM_DATA_ADDR 0xF8000000 #define CONFIG_SYS_OCM_DATA_SIZE 0x1000 #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* in SDRAM */ -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE /* End of used area */ +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area */
#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size/bytes res'd for init data*/ #define CONFIG_SYS_GBL_DATA_OFFSET \ - (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) + (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* diff --git a/include/configs/eXalion.h b/include/configs/eXalion.h index 637cc55..11cfe70 100644 --- a/include/configs/eXalion.h +++ b/include/configs/eXalion.h @@ -119,11 +119,11 @@ #define CONFIG_SYS_INIT_DATA_SIZE 128
#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 -#define CONFIG_SYS_INIT_RAM_END 0x1000 -#define CONFIG_SYS_INIT_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_INIT_DATA_SIZE) +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 +#define CONFIG_SYS_INIT_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_INIT_DATA_SIZE)
diff --git a/include/configs/ebony.h b/include/configs/ebony.h index a0d3869..46988c1 100644 --- a/include/configs/ebony.h +++ b/include/configs/ebony.h @@ -73,10 +73,10 @@ * Initial RAM & stack pointer (placed in internal SRAM) *----------------------------------------------------------------------*/ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_ISRAM_BASE /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_END 0x2000 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in RAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* num bytes initial data */
/*----------------------------------------------------------------------- diff --git a/include/configs/ep8248.h b/include/configs/ep8248.h index 5f083bd..a21dbf7 100644 --- a/include/configs/ep8248.h +++ b/include/configs/ep8248.h @@ -218,9 +218,9 @@ #define CONFIG_SYS_IMMR 0xF0000000
#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2000 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* Hard reset configuration word */ diff --git a/include/configs/ep8260.h b/include/configs/ep8260.h index cbf55db..277bd8d 100644 --- a/include/configs/ep8260.h +++ b/include/configs/ep8260.h @@ -429,9 +429,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x4000 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/ep82xxm.h b/include/configs/ep82xxm.h index 48985a0..114af7a 100644 --- a/include/configs/ep82xxm.h +++ b/include/configs/ep82xxm.h @@ -346,9 +346,9 @@ #define CONFIG_SYS_IMMR 0xF0000000
diff --git a/include/configs/galaxy5200.h b/include/configs/galaxy5200.h index d95144d..cb521a1 100644 --- a/include/configs/galaxy5200.h +++ b/include/configs/galaxy5200.h @@ -207,12 +207,12 @@ #define CONFIG_SYS_INIT_RAM_ADDR MPC5XXX_SRAM
/* End of used area in SPRAM */ -#define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_SIZE +#define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE
/* Size in bytes reserved for initial data */ #define CONFIG_SYS_GBL_DATA_SIZE 128
diff --git a/include/configs/gdppc440etx.h b/include/configs/gdppc440etx.h index 282afbc..32e3cd6 100644 --- a/include/configs/gdppc440etx.h +++ b/include/configs/gdppc440etx.h @@ -72,9 +72,9 @@ */ #define CONFIG_SYS_INIT_RAM_DCACHE 1 /* d-cache as init ram*/ #define CONFIG_SYS_INIT_RAM_ADDR 0x70000000 /* DCache */ -#define CONFIG_SYS_INIT_RAM_END (4 << 10) +#define CONFIG_SYS_INIT_RAM_SIZE (4 << 10) #define CONFIG_SYS_GBL_DATA_SIZE 256 /* num bytes init data*/ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END \ +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE \ - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
diff --git a/include/configs/gw8260.h b/include/configs/gw8260.h index 6c1ddac..13bb822 100644 --- a/include/configs/gw8260.h +++ b/include/configs/gw8260.h @@ -438,9 +438,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x4000 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/hcu4.h b/include/configs/hcu4.h index dd5e5a2..d4168eb 100644 --- a/include/configs/hcu4.h +++ b/include/configs/hcu4.h @@ -71,9 +71,9 @@ #define CONFIG_SYS_TEMP_STACK_OCM 1
#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* OCM */ -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE #define CONFIG_SYS_GBL_DATA_SIZE 256 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_GBL_DATA_OFFSET - 0x4)
/*----------------------------------------------------------------------- diff --git a/include/configs/hcu5.h b/include/configs/hcu5.h index a2edf51..7ff51a7 100644 --- a/include/configs/hcu5.h +++ b/include/configs/hcu5.h @@ -82,9 +82,9 @@ /* 440EPx/440GRx have 16KB of internal SRAM, so no need for D-Cache */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_BASE /* OCM */
-#define CONFIG_SYS_INIT_RAM_END (4 << 10) +#define CONFIG_SYS_INIT_RAM_SIZE (4 << 10) #define CONFIG_SYS_GBL_DATA_SIZE 256 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_GBL_DATA_OFFSET - 0x4)
/*----------------------------------------------------------------------- diff --git a/include/configs/hermes.h b/include/configs/hermes.h index 58fc4ce..089f1da 100644 --- a/include/configs/hermes.h +++ b/include/configs/hermes.h @@ -122,9 +122,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/hmi1001.h b/include/configs/hmi1001.h index 60e5c2b..aebb5e5 100644 --- a/include/configs/hmi1001.h +++ b/include/configs/hmi1001.h @@ -196,13 +196,13 @@ #define MPC5XXX_SRAM_POST_SIZE (MPC5XXX_SRAM_SIZE - 4)
#ifdef CONFIG_POST -#define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_POST_SIZE +#define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_POST_SIZE #else -#define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_SIZE +#define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE #endif
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/hymod.h b/include/configs/hymod.h index ccfc3df..5a4488b 100644 --- a/include/configs/hymod.h +++ b/include/configs/hymod.h @@ -377,9 +377,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x4000 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/icon.h b/include/configs/icon.h index 8d98d57..4742429 100644 --- a/include/configs/icon.h +++ b/include/configs/icon.h @@ -97,10 +97,10 @@ #define CONFIG_SYS_TEMP_STACK_OCM 1 #define CONFIG_SYS_OCM_DATA_ADDR CONFIG_SYS_ISRAM_BASE #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_ISRAM_BASE /* Init RAM */ -#define CONFIG_SYS_INIT_RAM_END 0x2000 /* end used area */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* size of used area */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* sizeof init data */
-#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - \ +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_GBL_DATA_OFFSET - 0x4)
diff --git a/include/configs/idmr.h b/include/configs/idmr.h index 8105876..259d070 100644 --- a/include/configs/idmr.h +++ b/include/configs/idmr.h @@ -180,9 +180,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR 0x20000000 -#define CONFIG_SYS_INIT_RAM_END 0x1000 /* End of used area in internal SRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in internal SRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* @@ -225,9 +225,9 @@ #define CONFIG_SYS_CACHELINE_SIZE 16
#define ICACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_END - 8) + CONFIG_SYS_INIT_RAM_SIZE - 8) #define DCACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_END - 4) + CONFIG_SYS_INIT_RAM_SIZE - 4) #define CONFIG_SYS_ICACHE_INV (CF_CACR_CINV | CF_CACR_INVI) #define CONFIG_SYS_CACHE_ACR0 (CONFIG_SYS_SDRAM_BASE | \ CF_ADDRMASK(CONFIG_SYS_SDRAM_SIZE) | \ diff --git a/include/configs/imx31_litekit.h b/include/configs/imx31_litekit.h index 9425237..09dc876 100644 --- a/include/configs/imx31_litekit.h +++ b/include/configs/imx31_litekit.h @@ -150,8 +150,8 @@ #undef CONFIG_SYS_ARM_WITHOUT_RELOC #define CONFIG_SYS_SDRAM_BASE CSD0_BASE #define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR -#define CONFIG_SYS_INIT_RAM_END IRAM_SIZE -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_GBL_DATA_OFFSET)
/*----------------------------------------------------------------------- diff --git a/include/configs/inka4x0.h b/include/configs/inka4x0.h index 3636d12..e381d0d 100644 --- a/include/configs/inka4x0.h +++ b/include/configs/inka4x0.h @@ -211,13 +211,13 @@ #define MPC5XXX_SRAM_POST_SIZE (MPC5XXX_SRAM_SIZE - 4)
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/intip.h b/include/configs/intip.h index 56d2be2..4e490ee 100644 --- a/include/configs/intip.h +++ b/include/configs/intip.h @@ -106,10 +106,10 @@ * Initial RAM & stack pointer (placed in OCM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_BASE /* OCM */ -#define CONFIG_SYS_INIT_RAM_END (4 << 10) +#define CONFIG_SYS_INIT_RAM_SIZE (4 << 10) #define CONFIG_SYS_GBL_DATA_SIZE 256 /* num bytes initial data */ #define CONFIG_SYS_GBL_DATA_OFFSET \ - (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) + (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* diff --git a/include/configs/ipek01.h b/include/configs/ipek01.h index c37b83b..e7edf61 100644 --- a/include/configs/ipek01.h +++ b/include/configs/ipek01.h @@ -264,12 +264,12 @@ /* Use SRAM until RAM will be available */ #define CONFIG_SYS_INIT_RAM_ADDR MPC5XXX_SRAM /* End of used area in DPRAM */ -#define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_SIZE +#define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE
/* size in bytes reserved for initial data */ #define CONFIG_SYS_GBL_DATA_SIZE 128
diff --git a/include/configs/jupiter.h b/include/configs/jupiter.h index 6f5ac94..70d67e7 100644 --- a/include/configs/jupiter.h +++ b/include/configs/jupiter.h @@ -225,11 +225,11 @@
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/katmai.h b/include/configs/katmai.h index 135a4c2..df92576 100644 --- a/include/configs/katmai.h +++ b/include/configs/katmai.h @@ -96,10 +96,10 @@ #define CONFIG_SYS_TEMP_STACK_OCM 1 #define CONFIG_SYS_OCM_DATA_ADDR CONFIG_SYS_ISRAM_BASE #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_ISRAM_BASE /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_END 0x2000 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in RAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* num bytes initial data */
/*----------------------------------------------------------------------- diff --git a/include/configs/kilauea.h b/include/configs/kilauea.h index e153b31..6dff260 100644 --- a/include/configs/kilauea.h +++ b/include/configs/kilauea.h @@ -92,9 +92,9 @@ #define CONFIG_SYS_INIT_RAM_ADDR (CONFIG_SYS_SDRAM_BASE + (32 << 20)) /* 32 MiB */ #endif /* defined(CONFIG_SYS_INIT_DCACHE_CS) */
-#define CONFIG_SYS_INIT_RAM_END (4 << 10) /* 4 KiB */ +#define CONFIG_SYS_INIT_RAM_SIZE (4 << 10) /* 4 KiB */ #define CONFIG_SYS_GBL_DATA_SIZE 256 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE)
/* * If the data cache is being used for the primordial stack and global diff --git a/include/configs/km8xx.h b/include/configs/km8xx.h index 2a42e99..5c2a7ad 100644 --- a/include/configs/km8xx.h +++ b/include/configs/km8xx.h @@ -107,9 +107,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/kmeter1.h b/include/configs/kmeter1.h index 03d3aac..81536a0 100644 --- a/include/configs/kmeter1.h +++ b/include/configs/kmeter1.h @@ -179,9 +179,9 @@ */ #define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xE6000000 /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_END 0x1000 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM */ #define CONFIG_SYS_GBL_DATA_SIZE 0x100 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE)
/* * Local Bus Configuration & Clock Setup diff --git a/include/configs/korat.h b/include/configs/korat.h index 3a0531b..55485c2 100644 --- a/include/configs/korat.h +++ b/include/configs/korat.h @@ -88,9 +88,9 @@ /* 440EPx has 16KB of internal SRAM, so no need for D-Cache */ #undef CONFIG_SYS_INIT_RAM_DCACHE #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_BASE /* OCM */ -#define CONFIG_SYS_INIT_RAM_END (4 << 10) +#define CONFIG_SYS_INIT_RAM_SIZE (4 << 10) #define CONFIG_SYS_GBL_DATA_SIZE 256 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_GBL_DATA_OFFSET - 0x4)
/* diff --git a/include/configs/kvme080.h b/include/configs/kvme080.h index fa87625..c597204 100644 --- a/include/configs/kvme080.h +++ b/include/configs/kvme080.h @@ -117,9 +117,9 @@ #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 }
#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 -#define CONFIG_SYS_INIT_RAM_END 0x1000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 #define CONFIG_SYS_GBL_DATA_SIZE 128 -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE)
#define CONFIG_SYS_SDRAM_BASE 0x00000000 #define CONFIG_SYS_FLASH_BASE 0x7C000000 diff --git a/include/configs/linkstation.h b/include/configs/linkstation.h index aaf663a..7a2a8c3 100644 --- a/include/configs/linkstation.h +++ b/include/configs/linkstation.h @@ -275,9 +275,9 @@ #else #define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 #endif -#define CONFIG_SYS_INIT_RAM_END 0x1000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 #define CONFIG_SYS_GBL_DATA_SIZE 128 -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE)
/*---------------------------------------------------------------------- * Serial configuration diff --git a/include/configs/luan.h b/include/configs/luan.h index d801404..60ebafb 100644 --- a/include/configs/luan.h +++ b/include/configs/luan.h @@ -80,9 +80,9 @@ * Initial RAM & stack pointer (placed in SDRAM) *----------------------------------------------------------------------*/ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_ISRAM_BASE -#define CONFIG_SYS_INIT_RAM_END (8 << 10) +#define CONFIG_SYS_INIT_RAM_SIZE (8 << 10) #define CONFIG_SYS_GBL_DATA_SIZE 256 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/lwmon.h b/include/configs/lwmon.h index 9e48857..cf9a2ca 100644 --- a/include/configs/lwmon.h +++ b/include/configs/lwmon.h @@ -275,9 +275,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 68 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/lwmon5.h b/include/configs/lwmon5.h index 63e22d4..0f637c7 100644 --- a/include/configs/lwmon5.h +++ b/include/configs/lwmon5.h @@ -87,9 +87,9 @@ */ #define CONFIG_SYS_INIT_RAM_DCACHE 1 /* d-cache as init ram */ #define CONFIG_SYS_INIT_RAM_ADDR 0x70000000 /* DCache */ -#define CONFIG_SYS_INIT_RAM_END (4 << 10) +#define CONFIG_SYS_INIT_RAM_SIZE (4 << 10) #define CONFIG_SYS_GBL_DATA_SIZE 256 /* num bytes initial data*/ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - \ +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET /* unused GPT0 COMP reg */ diff --git a/include/configs/makalu.h b/include/configs/makalu.h index c4853ab..ae07dc7 100644 --- a/include/configs/makalu.h +++ b/include/configs/makalu.h @@ -88,9 +88,9 @@ #define CONFIG_SYS_INIT_RAM_ADDR (CONFIG_SYS_SDRAM_BASE + (32 << 20)) /* 32 MiB */ #endif /* defined(CONFIG_SYS_INIT_DCACHE_CS) */
/* * If the data cache is being used for the primordial stack and global diff --git a/include/configs/manroland/mpc5200-common.h b/include/configs/manroland/mpc5200-common.h index 7be1354..62398a8 100644 --- a/include/configs/manroland/mpc5200-common.h +++ b/include/configs/manroland/mpc5200-common.h @@ -114,7 +114,7 @@ #define CONFIG_SYS_DEFAULT_MBAR 0x80000000
#define CONFIG_SYS_GBL_DATA_SIZE 128 -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END -\ +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE -\ CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
@@ -135,9 +135,9 @@ #define CONFIG_SYS_INIT_RAM_ADDR MPC5XXX_SRAM #ifdef CONFIG_POST /* preserve space for the post_word at end of on-chip SRAM */ -#define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_POST_SIZE +#define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_POST_SIZE #else -#define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_SIZE +#define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE #endif
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/mcc200.h b/include/configs/mcc200.h index 4d946ab..e127504 100644 --- a/include/configs/mcc200.h +++ b/include/configs/mcc200.h @@ -259,11 +259,11 @@
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/mcu25.h b/include/configs/mcu25.h index 4aef6fc..336871d 100644 --- a/include/configs/mcu25.h +++ b/include/configs/mcu25.h @@ -71,9 +71,9 @@ #define CONFIG_SYS_TEMP_STACK_OCM 1
/*----------------------------------------------------------------------- diff --git a/include/configs/mecp5123.h b/include/configs/mecp5123.h index 1e82bc5..501e78c 100644 --- a/include/configs/mecp5123.h +++ b/include/configs/mecp5123.h @@ -206,10 +206,10 @@
/* Use SRAM for initial stack */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_SRAM_BASE /* Init RAM addr */ -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_SRAM_SIZE +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_SRAM_SIZE
#define CONFIG_SYS_GBL_DATA_SIZE 0x100 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* Start of monitor */ diff --git a/include/configs/mecp5200.h b/include/configs/mecp5200.h index 036b790..d577f1d 100644 --- a/include/configs/mecp5200.h +++ b/include/configs/mecp5200.h @@ -215,11 +215,11 @@
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/mgcoge.h b/include/configs/mgcoge.h index 4dcd679..bdc98a6 100644 --- a/include/configs/mgcoge.h +++ b/include/configs/mgcoge.h @@ -178,9 +178,9 @@ #define CONFIG_SYS_IMMR 0xF0000000
/* Hard reset configuration word */ diff --git a/include/configs/motionpro.h b/include/configs/motionpro.h index f7493f5..6c13e3f 100644 --- a/include/configs/motionpro.h +++ b/include/configs/motionpro.h @@ -200,10 +200,10 @@
/* Use SRAM until RAM will be available */ #define CONFIG_SYS_INIT_RAM_ADDR MPC5XXX_SRAM -#define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_SIZE +#define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE
#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/mpc5121-common.h b/include/configs/mpc5121-common.h index afae1ab..399e43f 100644 --- a/include/configs/mpc5121-common.h +++ b/include/configs/mpc5121-common.h @@ -25,10 +25,10 @@
/* Use SRAM for initial stack */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_SRAM_BASE /* Init RAM base */ -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_SRAM_SIZE /* End of area */ +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_SRAM_SIZE /* Size of area */
#define CONFIG_SYS_GBL_DATA_SIZE 0x100 /* num bytes of initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - \ +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_GBL_DATA_OFFSET - 0x4)
diff --git a/include/configs/mpc5121ads.h b/include/configs/mpc5121ads.h index fbcc839..cbfcb70 100644 --- a/include/configs/mpc5121ads.h +++ b/include/configs/mpc5121ads.h @@ -270,10 +270,10 @@
/* Use SRAM for initial stack */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_SRAM_BASE /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_SRAM_SIZE /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_SRAM_SIZE /* Size of used area in RAM */
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* Start of monitor */ diff --git a/include/configs/mpc7448hpc2.h b/include/configs/mpc7448hpc2.h index 94a8c93..1ab58ad 100644 --- a/include/configs/mpc7448hpc2.h +++ b/include/configs/mpc7448hpc2.h @@ -221,10 +221,10 @@ */ #undef CONFIG_SYS_INIT_RAM_LOCK #define CONFIG_SYS_INIT_RAM_ADDR 0x07d00000 /* unused memory region */ -#define CONFIG_SYS_INIT_RAM_END 0x4000/* larger space - we have SDRAM initialized */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x4000/* larger space - we have SDRAM initialized */
#define CONFIG_SYS_GBL_DATA_SIZE 128/* size in bytes reserved for init data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE)
/*----------------------------------------------------------------------- * Start addresses for the final memory configuration diff --git a/include/configs/mpc8308_p1m.h b/include/configs/mpc8308_p1m.h index 14f663f..1d0e1f2 100644 --- a/include/configs/mpc8308_p1m.h +++ b/include/configs/mpc8308_p1m.h @@ -220,10 +220,10 @@ */ #define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xE6000000 /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_END 0x1000 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM */ #define CONFIG_SYS_GBL_DATA_SIZE 0x100 /* num bytes initial data */ #define CONFIG_SYS_GBL_DATA_OFFSET \ - (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) + (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE)
/* * Local Bus Configuration & Clock Setup diff --git a/include/configs/muas3001.h b/include/configs/muas3001.h index 345bdd1..e35f923 100644 --- a/include/configs/muas3001.h +++ b/include/configs/muas3001.h @@ -260,9 +260,9 @@ #define CONFIG_SYS_DEFAULT_IMMR 0x0F010000
/* Hard reset configuration word */ diff --git a/include/configs/munices.h b/include/configs/munices.h index 97330d5..db3cc35 100644 --- a/include/configs/munices.h +++ b/include/configs/munices.h @@ -117,9 +117,9 @@ #define CONFIG_SYS_SDRAM_BASE 0x00000000 /* Use SRAM until RAM will be available */ #define CONFIG_SYS_INIT_RAM_ADDR MPC5XXX_SRAM -#define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_SIZE /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/neo.h b/include/configs/neo.h index 1063d12..5ee6c7f 100644 --- a/include/configs/neo.h +++ b/include/configs/neo.h @@ -208,10 +208,10 @@ #define CONFIG_SYS_OCM_DATA_ADDR 0xF8000000 #define CONFIG_SYS_OCM_DATA_SIZE 0x1000 #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */
/* diff --git a/include/configs/o2dnt.h b/include/configs/o2dnt.h index c9c69bb..b5878b4 100644 --- a/include/configs/o2dnt.h +++ b/include/configs/o2dnt.h @@ -214,11 +214,11 @@
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/ocotea.h b/include/configs/ocotea.h index f33f0ff..fe6f579 100644 --- a/include/configs/ocotea.h +++ b/include/configs/ocotea.h @@ -72,10 +72,10 @@ #define CONFIG_SYS_TEMP_STACK_OCM 1 #define CONFIG_SYS_OCM_DATA_ADDR CONFIG_SYS_ISRAM_BASE #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_ISRAM_BASE /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_END 0x2000 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in RAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* num bytes initial data */
/*----------------------------------------------------------------------- diff --git a/include/configs/p3mx.h b/include/configs/p3mx.h index 8b5ef8f..97703d6 100644 --- a/include/configs/p3mx.h +++ b/include/configs/p3mx.h @@ -98,9 +98,9 @@ */ #undef CONFIG_SYS_INIT_RAM_LOCK #define CONFIG_SYS_INIT_RAM_ADDR 0x42000000 -#define CONFIG_SYS_INIT_RAM_END 0x1000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for init data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE)
/*----------------------------------------------------------------------- diff --git a/include/configs/p3p440.h b/include/configs/p3p440.h index 71529a2..20a0755 100644 --- a/include/configs/p3p440.h +++ b/include/configs/p3p440.h @@ -61,10 +61,10 @@ * Initial RAM & stack pointer (placed in internal SRAM) *----------------------------------------------------------------------*/ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_ISRAM_BASE /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_END 0x2000 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in RAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* num bytes initial data */
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon*/ diff --git a/include/configs/pcm030.h b/include/configs/pcm030.h index 5898b4e..1249b0d 100644 --- a/include/configs/pcm030.h +++ b/include/configs/pcm030.h @@ -223,11 +223,11 @@ RTC configuration #define CONFIG_SYS_DEFAULT_MBAR 0x80000000 /* Use SRAM until RAM will be available */ #define CONFIG_SYS_INIT_RAM_ADDR MPC5XXX_SRAM -#define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_SIZE /* End of used */ +#define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE /* Size of used */ /* area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes */ /* reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - \ +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
diff --git a/include/configs/pcs440ep.h b/include/configs/pcs440ep.h index afdd69c..bf89ddc 100644 --- a/include/configs/pcs440ep.h +++ b/include/configs/pcs440ep.h @@ -74,9 +74,9 @@ *----------------------------------------------------------------------*/ #define CONFIG_SYS_INIT_RAM_DCACHE 1 /* d-cache as init ram */ #define CONFIG_SYS_INIT_RAM_ADDR 0x70000000 /* DCache */ -#define CONFIG_SYS_INIT_RAM_END (4 << 10) +#define CONFIG_SYS_INIT_RAM_SIZE (4 << 10) #define CONFIG_SYS_GBL_DATA_SIZE 256 /* num bytes initial data*/ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/pf5200.h b/include/configs/pf5200.h index 28dfe3b..3f66a98 100644 --- a/include/configs/pf5200.h +++ b/include/configs/pf5200.h @@ -221,10 +221,10 @@
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/ppmc7xx.h b/include/configs/ppmc7xx.h index e7584c3..831097e 100644 --- a/include/configs/ppmc7xx.h +++ b/include/configs/ppmc7xx.h @@ -297,15 +297,15 @@ * copied to top of RAM by the init code. * * CONFIG_SYS_INIT_RAM_ADDR - Address of Init RAM, above exception vect - * CONFIG_SYS_INIT_RAM_END - Size of Init RAM + * CONFIG_SYS_INIT_RAM_SIZE - Size of Init RAM * CONFIG_SYS_GBL_DATA_SIZE - Ammount of RAM to reserve for global data * CONFIG_SYS_GBL_DATA_OFFSET - Start of global data, top of stack */
#define CONFIG_SYS_INIT_RAM_ADDR (CONFIG_SYS_SDRAM_BASE + 0x4000) -#define CONFIG_SYS_INIT_RAM_END 0x4000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 #define CONFIG_SYS_GBL_DATA_SIZE 128 -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE)
/* diff --git a/include/configs/ppmc8260.h b/include/configs/ppmc8260.h index 7018a8c..d37d588 100644 --- a/include/configs/ppmc8260.h +++ b/include/configs/ppmc8260.h @@ -422,9 +422,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x4000 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/qong.h b/include/configs/qong.h index 426d90d..900c279 100644 --- a/include/configs/qong.h +++ b/include/configs/qong.h @@ -300,8 +300,8 @@ extern int qong_nand_rdy(void *chip); /* additions for new relocation code, must be added to all boards */ #define CONFIG_SYS_SDRAM_BASE 0x80000000 #define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR -#define CONFIG_SYS_INIT_RAM_END IRAM_SIZE -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_GBL_DATA_OFFSET)
#define CONFIG_BOARD_EARLY_INIT_F 1 diff --git a/include/configs/quad100hd.h b/include/configs/quad100hd.h index f847f9c..e3929bb 100644 --- a/include/configs/quad100hd.h +++ b/include/configs/quad100hd.h @@ -247,10 +247,10 @@ #define CONFIG_SYS_OCM_DATA_ADDR 0xF8000000 #define CONFIG_SYS_OCM_DATA_SIZE 0x1000 #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of OCM */ -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */
/*----------------------------------------------------------------------- diff --git a/include/configs/quantum.h b/include/configs/quantum.h index 2440eee..54a8886 100644 --- a/include/configs/quantum.h +++ b/include/configs/quantum.h @@ -158,9 +158,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/redwood.h b/include/configs/redwood.h index a7d5dac..53f817c 100644 --- a/include/configs/redwood.h +++ b/include/configs/redwood.h @@ -89,10 +89,10 @@ #define CONFIG_SYS_TEMP_STACK_OCM 1 #define CONFIG_SYS_OCM_DATA_ADDR CONFIG_SYS_ISRAM_BASE #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_ISRAM_BASE /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_END 0x2000 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in RAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* num bytes initial data */
/*----------------------------------------------------------------------- diff --git a/include/configs/rmu.h b/include/configs/rmu.h index 5e6bc27..8e6a0a3 100644 --- a/include/configs/rmu.h +++ b/include/configs/rmu.h @@ -154,9 +154,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/rsdproto.h b/include/configs/rsdproto.h index b82ff37..9e705de 100644 --- a/include/configs/rsdproto.h +++ b/include/configs/rsdproto.h @@ -253,9 +253,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x4000 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/sacsng.h b/include/configs/sacsng.h index d741716..118e80d 100644 --- a/include/configs/sacsng.h +++ b/include/configs/sacsng.h @@ -673,9 +673,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x4000 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/sbc405.h b/include/configs/sbc405.h index 3de2a9e..a308085 100644 --- a/include/configs/sbc405.h +++ b/include/configs/sbc405.h @@ -264,9 +264,9 @@ #define CONFIG_SYS_OCM_DATA_SIZE 0x1000
#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/sbc8240.h b/include/configs/sbc8240.h index 0934a00..f6a32d7 100644 --- a/include/configs/sbc8240.h +++ b/include/configs/sbc8240.h @@ -204,8 +204,8 @@ typedef unsigned int led_id_t; #define CONFIG_SYS_GBL_DATA_SIZE 128
/* * NS16550 Configuration diff --git a/include/configs/sbc8260.h b/include/configs/sbc8260.h index 54a1a36..48a1c56 100644 --- a/include/configs/sbc8260.h +++ b/include/configs/sbc8260.h @@ -572,9 +572,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x4000 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/sbc8349.h b/include/configs/sbc8349.h index ee2292c..e07513a 100644 --- a/include/configs/sbc8349.h +++ b/include/configs/sbc8349.h @@ -169,10 +169,10 @@
#define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xFD000000 /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_END 0x1000 /* End of used area in RAM*/ +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM*/
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ diff --git a/include/configs/sbc8548.h b/include/configs/sbc8548.h index 0ddd20d..ff0a7db 100644 --- a/include/configs/sbc8548.h +++ b/include/configs/sbc8548.h @@ -321,12 +321,12 @@
#define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xe4010000 /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_END 0x4000 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in RAM */
#define CONFIG_SYS_INIT_L2_ADDR 0xf8f80000 /* relocate boot L2SRAM */
#define CONFIG_SYS_GBL_DATA_SIZE 128 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* diff --git a/include/configs/sbc8560.h b/include/configs/sbc8560.h index cd9652c..4526944 100644 --- a/include/configs/sbc8560.h +++ b/include/configs/sbc8560.h @@ -191,10 +191,10 @@
#define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0x70000000 /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_END 0x4000 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in RAM */
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ diff --git a/include/configs/sbc8641d.h b/include/configs/sbc8641d.h index 9e2aef4..dfeb798 100644 --- a/include/configs/sbc8641d.h +++ b/include/configs/sbc8641d.h @@ -249,10 +249,10 @@ #else #define CONFIG_SYS_INIT_RAM_ADDR 0xf8400000 /* Initial RAM address */ #endif -#define CONFIG_SYS_INIT_RAM_END 0x4000 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in RAM */
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ diff --git a/include/configs/sc3.h b/include/configs/sc3.h index 3e6abf3..2a166bc 100644 --- a/include/configs/sc3.h +++ b/include/configs/sc3.h @@ -463,7 +463,7 @@ /* Where the internal SRAM starts */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* Where the internal SRAM ends (only offset) */ -#define CONFIG_SYS_INIT_RAM_END 0x0F00 +#define CONFIG_SYS_INIT_RAM_SIZE 0x0F00
@@ -476,13 +476,13 @@ | | | 64 Bytes | | | - CONFIG_SYS_INIT_RAM_END ------> ------------ higher address + CONFIG_SYS_INIT_RAM_SIZE ------> ------------ higher address (offset only)
*/ /* size in bytes reserved for initial data */ #define CONFIG_SYS_GBL_DATA_SIZE 64 -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) /* Initial value of the stack pointern in internal SRAM */ #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
diff --git a/include/configs/sequoia.h b/include/configs/sequoia.h index 412deea..b8581de 100644 --- a/include/configs/sequoia.h +++ b/include/configs/sequoia.h @@ -98,9 +98,9 @@ */ /* 440EPx/440GRx have 16KB of internal SRAM, so no need for D-Cache */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_BASE /* OCM */ -#define CONFIG_SYS_INIT_RAM_END (4 << 10) +#define CONFIG_SYS_INIT_RAM_SIZE (4 << 10) #define CONFIG_SYS_GBL_DATA_SIZE 256 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_GBL_DATA_OFFSET - 0x4)
/* diff --git a/include/configs/socrates.h b/include/configs/socrates.h index 0bbad16..81f607d 100644 --- a/include/configs/socrates.h +++ b/include/configs/socrates.h @@ -170,10 +170,10 @@
#define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xe4010000 /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_END 0x4000 /* End used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size used area in RAM*/
#define CONFIG_SYS_GBL_DATA_SIZE 128 /* num bytes initial data*/ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#define CONFIG_SYS_MONITOR_LEN (384 * 1024) /* Reserve 384KiB for Mon */ diff --git a/include/configs/sorcery.h b/include/configs/sorcery.h index 75b8e60..c956e0d 100644 --- a/include/configs/sorcery.h +++ b/include/configs/sorcery.h @@ -227,10 +227,10 @@
/* Use SRAM until RAM will be available */ #define CONFIG_SYS_INIT_RAM_ADDR (CONFIG_SYS_MBAR + 0x20000) -#define CONFIG_SYS_INIT_RAM_END 0x8000 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x8000 /* Size of used area in DPRAM */
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/spc1920.h b/include/configs/spc1920.h index 4d18747..91a6840 100644 --- a/include/configs/spc1920.h +++ b/include/configs/spc1920.h @@ -143,9 +143,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/spieval.h b/include/configs/spieval.h index 880c8a3..cf86735 100644 --- a/include/configs/spieval.h +++ b/include/configs/spieval.h @@ -322,14 +322,14 @@ #define CONFIG_SYS_INIT_RAM_ADDR MPC5XXX_SRAM #ifdef CONFIG_POST /* preserve space for the post_word at end of on-chip SRAM */ -#define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_POST_SIZE +#define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_POST_SIZE #else -#define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_SIZE +#define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE #endif
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/stxgp3.h b/include/configs/stxgp3.h index 479fbab..8fc3d40 100644 --- a/include/configs/stxgp3.h +++ b/include/configs/stxgp3.h @@ -155,10 +155,10 @@
#define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0x60000000 /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_END 0x4000 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in RAM */
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ diff --git a/include/configs/stxssa.h b/include/configs/stxssa.h index 6ea5807..42188dd 100644 --- a/include/configs/stxssa.h +++ b/include/configs/stxssa.h @@ -167,10 +167,10 @@
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ diff --git a/include/configs/stxxtc.h b/include/configs/stxxtc.h index b9739ff..cb8abea 100644 --- a/include/configs/stxxtc.h +++ b/include/configs/stxxtc.h @@ -168,9 +168,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x3000 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x3000 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/svm_sc8xx.h b/include/configs/svm_sc8xx.h index 219b85b..9f12e73 100644 --- a/include/configs/svm_sc8xx.h +++ b/include/configs/svm_sc8xx.h @@ -193,9 +193,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/t3corp.h b/include/configs/t3corp.h index d00e64e..a31e3b6 100644 --- a/include/configs/t3corp.h +++ b/include/configs/t3corp.h @@ -97,10 +97,10 @@ * Initial RAM & stack pointer (placed in OCM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_BASE /* OCM */ -#define CONFIG_SYS_INIT_RAM_END (4 << 10) +#define CONFIG_SYS_INIT_RAM_SIZE (4 << 10) #define CONFIG_SYS_GBL_DATA_SIZE 256 /* num bytes initial data */ #define CONFIG_SYS_GBL_DATA_OFFSET \ - (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) + (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* diff --git a/include/configs/taihu.h b/include/configs/taihu.h index 6e9dbc5..493e3e0 100644 --- a/include/configs/taihu.h +++ b/include/configs/taihu.h @@ -288,10 +288,10 @@ unsigned char spi_read(void); #define CONFIG_SYS_OCM_DATA_ADDR 0xF8000000 #define CONFIG_SYS_OCM_DATA_SIZE 0x1000 #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */
/*----------------------------------------------------------------------- diff --git a/include/configs/taishan.h b/include/configs/taishan.h index 12f35ae..29b60a1 100644 --- a/include/configs/taishan.h +++ b/include/configs/taishan.h @@ -68,10 +68,10 @@ #define CONFIG_SYS_TEMP_STACK_OCM 1 #define CONFIG_SYS_OCM_DATA_ADDR CONFIG_SYS_ISRAM_BASE #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_ISRAM_BASE /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_END 0x2000 /* End of used area in RAM*/ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in RAM*/ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* num bytes initial data*/
/*----------------------------------------------------------------------- diff --git a/include/configs/uc100.h b/include/configs/uc100.h index 5392fb5..5d55279 100644 --- a/include/configs/uc100.h +++ b/include/configs/uc100.h @@ -200,9 +200,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/utx8245.h b/include/configs/utx8245.h index c027f46..b962c49 100644 --- a/include/configs/utx8245.h +++ b/include/configs/utx8245.h @@ -196,10 +196,10 @@ protect on ${u-boot_startaddr} ${u-boot_endaddr}" #define CONFIG_SYS_INIT_DATA_SIZE 128 /* Size in bytes reserved for */ /* initial data */ #define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 -#define CONFIG_SYS_INIT_RAM_END 0x1000 -#define CONFIG_SYS_INIT_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_INIT_DATA_SIZE) +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 +#define CONFIG_SYS_INIT_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_INIT_DATA_SIZE) #define CONFIG_SYS_GBL_DATA_SIZE 128 -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE)
/*-------------------------------------------------------------------- * NS16550 Configuration diff --git a/include/configs/v37.h b/include/configs/v37.h index c34b6e8..0d9a249 100644 --- a/include/configs/v37.h +++ b/include/configs/v37.h @@ -158,9 +158,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/v38b.h b/include/configs/v38b.h index 96ffc6a..4a97cac 100644 --- a/include/configs/v38b.h +++ b/include/configs/v38b.h @@ -227,10 +227,10 @@
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/ve8313.h b/include/configs/ve8313.h index 283b92c..11b9cfc 100644 --- a/include/configs/ve8313.h +++ b/include/configs/ve8313.h @@ -171,10 +171,10 @@
#define CONFIG_SYS_GBL_DATA_SIZE 0x100 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - \ +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
diff --git a/include/configs/virtlab2.h b/include/configs/virtlab2.h index 56fb5f7..d98fc20 100644 --- a/include/configs/virtlab2.h +++ b/include/configs/virtlab2.h @@ -176,9 +176,9 @@ * Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ #define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/vision2.h b/include/configs/vision2.h index d2d9565..7bc6318 100644 --- a/include/configs/vision2.h +++ b/include/configs/vision2.h @@ -192,8 +192,8 @@ #define CONFIG_SYS_INIT_RAM_ADDR 0x1FFE8000
#ifndef CONFIG_SYS_ARM_WITHOUT_RELOC -#define CONFIG_SYS_INIT_RAM_END (64 * 1024) -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - \ +#define CONFIG_SYS_INIT_RAM_SIZE (64 * 1024) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INIT_RAM_ADDR + \ CONFIG_SYS_GBL_DATA_OFFSET) diff --git a/include/configs/vme8349.h b/include/configs/vme8349.h index 2c95c12..81c7489 100644 --- a/include/configs/vme8349.h +++ b/include/configs/vme8349.h @@ -161,10 +161,10 @@
#define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xF7000000 /* Initial RAM addr */ -#define CONFIG_SYS_INIT_RAM_END 0x1000 /* size */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* size */
#define CONFIG_SYS_GBL_DATA_SIZE 0x100 /* size init data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - \ +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
diff --git a/include/configs/walnut.h b/include/configs/walnut.h index 72ac4e3..6e063f5 100644 --- a/include/configs/walnut.h +++ b/include/configs/walnut.h @@ -217,9 +217,9 @@ #define CONFIG_SYS_INIT_DCACHE_CS 4 /* use cs # 4 for data cache memory */
#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 /* inside of SDRAM */ -#define CONFIG_SYS_INIT_RAM_END 0x2000 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in RAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/xilinx-ppc.h b/include/configs/xilinx-ppc.h index b4a9675..d377848 100644 --- a/include/configs/xilinx-ppc.h +++ b/include/configs/xilinx-ppc.h @@ -91,9 +91,9 @@
/*Stack*/ #define CONFIG_SYS_INIT_RAM_ADDR 0x800000/* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_END 0x2000 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in RAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END \ +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE \ - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET /*Speed*/ diff --git a/include/configs/xpedite1000.h b/include/configs/xpedite1000.h index d0f9363..9103b6a 100644 --- a/include/configs/xpedite1000.h +++ b/include/configs/xpedite1000.h @@ -102,9 +102,9 @@ extern void out32(unsigned int, unsigned long); #define CONFIG_SYS_TEMP_STACK_OCM 1 #define CONFIG_SYS_OCM_DATA_ADDR CONFIG_SYS_ISRAM_BASE #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_ISRAM_BASE /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_END 0x2000 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in RAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_GBL_DATA_OFFSET - 0x4)
#define CONFIG_SYS_MONITOR_LEN (512 * 1024) /* Reserve 512 KB for Mon */ diff --git a/include/configs/xpedite517x.h b/include/configs/xpedite517x.h index 8df9edd..a4e485c 100644 --- a/include/configs/xpedite517x.h +++ b/include/configs/xpedite517x.h @@ -218,10 +218,10 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); */ #define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xe0000000 -#define CONFIG_SYS_INIT_RAM_END 0x00004000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x00004000
#define CONFIG_SYS_MONITOR_LEN (512 * 1024) /* Reserve 512 KB for Mon */ diff --git a/include/configs/xpedite520x.h b/include/configs/xpedite520x.h index 2f31337..eb73fa8 100644 --- a/include/configs/xpedite520x.h +++ b/include/configs/xpedite520x.h @@ -186,10 +186,10 @@ */ #define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xe0000000 -#define CONFIG_SYS_INIT_RAM_END 0x4000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x4000
#define CONFIG_SYS_MONITOR_LEN (512 * 1024) /* Reserve 512 KB for Mon */ diff --git a/include/configs/xpedite537x.h b/include/configs/xpedite537x.h index e7de13a..dd8d226 100644 --- a/include/configs/xpedite537x.h +++ b/include/configs/xpedite537x.h @@ -224,10 +224,10 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); */ #define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xe0000000 -#define CONFIG_SYS_INIT_RAM_END 0x00004000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x00004000
#define CONFIG_SYS_MONITOR_LEN (512 * 1024) /* Reserve 512 KB for Mon */ diff --git a/include/configs/xpedite550x.h b/include/configs/xpedite550x.h index a849cf9..3c6bf5c 100644 --- a/include/configs/xpedite550x.h +++ b/include/configs/xpedite550x.h @@ -214,10 +214,10 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); */ #define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xe0000000 -#define CONFIG_SYS_INIT_RAM_END 0x00004000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x00004000
#define CONFIG_SYS_MONITOR_LEN (512 * 1024) /* Reserve 512 KB for Mon */ diff --git a/include/configs/yosemite.h b/include/configs/yosemite.h index 0d450f5..85b88c8 100644 --- a/include/configs/yosemite.h +++ b/include/configs/yosemite.h @@ -77,9 +77,9 @@ *----------------------------------------------------------------------*/ #define CONFIG_SYS_INIT_RAM_DCACHE 1 /* d-cache as init ram */ #define CONFIG_SYS_INIT_RAM_ADDR 0x70000000 /* DCache */ -#define CONFIG_SYS_INIT_RAM_END (4 << 10) +#define CONFIG_SYS_INIT_RAM_SIZE (4 << 10) #define CONFIG_SYS_GBL_DATA_SIZE 256 /* num bytes initial data*/ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/yucca.h b/include/configs/yucca.h index 8d5d45f..55a364c 100644 --- a/include/configs/yucca.h +++ b/include/configs/yucca.h @@ -97,10 +97,10 @@ #define CONFIG_SYS_TEMP_STACK_OCM 1 #define CONFIG_SYS_OCM_DATA_ADDR CONFIG_SYS_ISRAM_BASE #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_ISRAM_BASE /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_END 0x2000 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in RAM */ #define CONFIG_SYS_GBL_DATA_SIZE 128 /* num bytes initial data */
/*----------------------------------------------------------------------- diff --git a/include/configs/zeus.h b/include/configs/zeus.h index 5ddec84..d24ea0b 100644 --- a/include/configs/zeus.h +++ b/include/configs/zeus.h @@ -253,10 +253,10 @@ #define CONFIG_SYS_OCM_DATA_ADDR 0xF8000000 #define CONFIG_SYS_OCM_DATA_SIZE 0x1000 #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of OCM */ -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */
#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) /* reserve some memory for POST and BOOT limit info */ #define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_GBL_DATA_OFFSET - 16)
In message 1288101601-24871-2-git-send-email-wd@denx.de you wrote:
CONFIG_SYS_INIT_RAM_END was a misnomer as it suggests this might be some end address; to make the meaning more clear we rename it into CONFIG_SYS_INIT_RAM_SIZE
No other code changes are performed in this patch, only minor editing of white space (due to the changed length) and the comments was done, where noticed.
Note that the code for the PATI and cmi_mpc5xx board configurations looks seriously broken. Last known maintainers on Cc:
Signed-off-by: Wolfgang Denk wd@denx.de Cc: Denis Peter d.peter@mpl.ch Cc: Martin Winistoerfer martinwinistoerfer@gmx.ch
Applied.
A recurrent issue is that certain C level constructs like sizeof() or offsetof() cannot be used in assembler files, which is inconvenient when such constructs are used in the definition of macro names etc.
To avoid duplication of such definitions (and thus another cause of problems), we adapt the Linux way to automatically generate the respective definitions from the respective C header files.
In Linux, this is implemented in include/linux/kbuild.h, Kbuild, and arch/*/kernel/asm-offsets.c; we adapt the code from the Linux v2.6.36 kernel tree.
We also copy the concept of the include/generated/ directory which can be used to hold other automatically generated files as well.
We start with an architecture-independent lib/asm-offsets.c which generates include/generated/generic-asm-offsets.h (included by include/asm-offsets.h, which is what will be referred to in the actual source code). Later this may be extended by architecture-specific arch/*/lib/asm-offsets.c files that will generate a include/generated/asm-offsets.h. --- .gitignore | 3 +++ Makefile | 23 ++++++++++++++++++++--- include/asm-offsets.h | 2 ++ include/linux/kbuild.h | 20 ++++++++++++++++++++ lib/asm-offsets.c | 25 +++++++++++++++++++++++++ tools/scripts/make-asm-offsets | 27 +++++++++++++++++++++++++++ 6 files changed, 97 insertions(+), 3 deletions(-) create mode 100644 include/asm-offsets.h create mode 100644 include/linux/kbuild.h create mode 100644 lib/asm-offsets.c create mode 100755 tools/scripts/make-asm-offsets
diff --git a/.gitignore b/.gitignore index 67d2cd6..e71f6ac 100644 --- a/.gitignore +++ b/.gitignore @@ -40,6 +40,9 @@ /errlog /reloc_off
+/include/generated/ +/lib/asm-offsets.s + # stgit generated dirs patches-* .stgit-edit.txt diff --git a/Makefile b/Makefile index f8e13d7..737eb11 100644 --- a/Makefile +++ b/Makefile @@ -372,7 +372,8 @@ GEN_UBOOT = \ cd $(LNDIR) && $(LD) $(LDFLAGS) $$UNDEF_SYM $(__OBJS) \ --start-group $(__LIBS) --end-group $(PLATFORM_LIBS) \ -Map u-boot.map -o u-boot -$(obj)u-boot: depend $(SUBDIRS) $(OBJS) $(LIBBOARD) $(LIBS) $(LDSCRIPT) $(obj)u-boot.lds +$(obj)u-boot: depend \ + $(SUBDIRS) $(OBJS) $(LIBBOARD) $(LIBS) $(LDSCRIPT) $(obj)u-boot.lds $(GEN_UBOOT) ifeq ($(CONFIG_KALLSYMS),y) smap=`$(call SYSTEM_MAP,u-boot) | \ @@ -426,7 +427,9 @@ updater:
# Explicitly make _depend in subdirs containing multiple targets to prevent # parallel sub-makes creating .depend files simultaneously. -depend dep: $(TIMESTAMP_FILE) $(VERSION_FILE) $(obj)include/autoconf.mk +depend dep: $(TIMESTAMP_FILE) $(VERSION_FILE) \ + $(obj)include/autoconf.mk \ + $(obj)include/generated/generic-asm-offsets.h for dir in $(SUBDIRS) $(CPUDIR) $(dir $(LDSCRIPT)) ; do \ $(MAKE) -C $$dir _depend ; done
@@ -453,7 +456,7 @@ $(obj)System.map: $(obj)u-boot @$(call SYSTEM_MAP,$<) > $(obj)System.map
# -# Auto-generate the autoconf.mk file (which is included by all makefiles) +# Auto-generate the autoconi.mk file (which is included by all makefiles) # # This target actually generates 2 files; autoconf.mk and autoconf.mk.dep. # the dep file is only include in this top level makefile to determine when @@ -473,6 +476,18 @@ $(obj)include/autoconf.mk: $(obj)include/config.h sed -n -f tools/scripts/define2mk.sed > $@.tmp && \ mv $@.tmp $@
+$(obj)include/generated/generic-asm-offsets.h: $(obj)include/autoconf.mk.dep \ + $(obj)lib/asm-offsets.s + @$(XECHO) Generating $@ + tools/scripts/make-asm-offsets $(obj)lib/asm-offsets.s $@ + +$(obj)lib/asm-offsets.s: $(obj)include/autoconf.mk.dep \ + $(src)lib/asm-offsets.c + @mkdir -p $(obj)lib + $(CC) -DDO_DEPS_ONLY \ + $(CFLAGS) $(CFLAGS_$(BCURDIR)/$(@F)) $(CFLAGS_$(BCURDIR)) \ + -o $@ $(src)lib/asm-offsets.c -c -S + ######################################################################### else # !config.mk all $(obj)u-boot.hex $(obj)u-boot.srec $(obj)u-boot.bin \ @@ -1214,6 +1229,7 @@ clean: $(obj)u-boot.lds \ $(obj)arch/blackfin/cpu/bootrom-asm-offsets.[chs] @rm -f $(obj)include/bmp_logo.h + @rm -f $(obj)lib/asm-offsets.s @rm -f $(obj)nand_spl/{u-boot.lds,u-boot-spl,u-boot-spl.map,System.map} @rm -f $(obj)onenand_ipl/onenand-{ipl,ipl.bin,ipl.map} @rm -f $(ONENAND_BIN) @@ -1237,6 +1253,7 @@ clobber: clean @rm -f $(obj)tools/{env/crc32.c,inca-swap-bytes} @rm -f $(obj)arch/powerpc/cpu/mpc824x/bedbug_603e.c @rm -f $(obj)include/asm/proc $(obj)include/asm/arch $(obj)include/asm + @rm -fr $(obj)include/generated @[ ! -d $(obj)nand_spl ] || find $(obj)nand_spl -name "*" -type l -print | xargs rm -f @[ ! -d $(obj)onenand_ipl ] || find $(obj)onenand_ipl -name "*" -type l -print | xargs rm -f
diff --git a/include/asm-offsets.h b/include/asm-offsets.h new file mode 100644 index 0000000..ab28184 --- /dev/null +++ b/include/asm-offsets.h @@ -0,0 +1,2 @@ +#include <generated/generic-asm-offsets.h> +/* #include <generated/asm-offsets.h> */ diff --git a/include/linux/kbuild.h b/include/linux/kbuild.h new file mode 100644 index 0000000..be76384 --- /dev/null +++ b/include/linux/kbuild.h @@ -0,0 +1,20 @@ +/* + * Copied from Linux: + * commit 37487a56523d402e25650da16c337acf4cecd13d + * Author: Christoph Lameter clameter@sgi.com + */ +#ifndef __LINUX_KBUILD_H +#define __LINUX_KBUILD_H + +#define DEFINE(sym, val) \ + asm volatile("\n->" #sym " %0 " #val : : "i" (val)) + +#define BLANK() asm volatile("\n->" : : ) + +#define OFFSET(sym, str, mem) \ + DEFINE(sym, offsetof(struct str, mem)) + +#define COMMENT(x) \ + asm volatile("\n->#" x) + +#endif diff --git a/lib/asm-offsets.c b/lib/asm-offsets.c new file mode 100644 index 0000000..4eb6174 --- /dev/null +++ b/lib/asm-offsets.c @@ -0,0 +1,25 @@ +/* + * Adapted from Linux v2.6.36 kernel: arch/powerpc/kernel/asm-offsets.c + * + * This program is used to generate definitions needed by + * assembly language modules. + * + * We use the technique used in the OSF Mach kernel code: + * generate asm statements containing #defines, + * compile this file to assembler, and then extract the + * #defines from the assembly-language output. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * as published by the Free Software Foundation; either version + * 2 of the License, or (at your option) any later version. + */ + +#include <common.h> + +#include <linux/kbuild.h> + +int main(void) +{ + return 0; +} diff --git a/tools/scripts/make-asm-offsets b/tools/scripts/make-asm-offsets new file mode 100755 index 0000000..61c095f --- /dev/null +++ b/tools/scripts/make-asm-offsets @@ -0,0 +1,27 @@ +#!/bin/sh + +# Adapted from Linux kernel's "Kbuild": +# commit 1cdf25d704f7951d02a04064c97db547d6021872 +# Author: Christoph Lameter clameter@sgi.com + +mkdir -p $(dirname $2) + +# Default sed regexp - multiline due to syntax constraints +SED_CMD="/^->/{s:->#(.*):/* \1 */:; \ + s:^->([^ ]*) [$$#]*([-0-9]*) (.*):#define \1 (\2) /* \3 */:; \ + s:^->([^ ]*) [$$#]*([^ ]*) (.*):#define \1 \2 /* \3 */:; \ + s:->::; p;}" + +(set -e + echo "#ifndef __ASM_OFFSETS_H__" + echo "#define __ASM_OFFSETS_H__" + echo "/*" + echo " * DO NOT MODIFY." + echo " *" + echo " * This file was generated by $(basename $0)" + echo " *" + echo " */" + echo "" + sed -ne "${SED_CMD}" $1 + echo "" + echo "#endif" ) > $2
I think thats a typo.
Alexander
Dear Alexander Stein,
In message 201010261611.59856.alexander.stein@systec-electronic.com you wrote:
oops. thanks, will fix that!
Signed-off-by: Wolfgang Denk wd@denx.de --- v2: fix typo add SoB line
.gitignore | 3 +++ Makefile | 21 +++++++++++++++++++-- include/asm-offsets.h | 2 ++ include/linux/kbuild.h | 20 ++++++++++++++++++++ lib/asm-offsets.c | 25 +++++++++++++++++++++++++ tools/scripts/make-asm-offsets | 27 +++++++++++++++++++++++++++ 6 files changed, 96 insertions(+), 2 deletions(-) create mode 100644 include/asm-offsets.h create mode 100644 include/linux/kbuild.h create mode 100644 lib/asm-offsets.c create mode 100755 tools/scripts/make-asm-offsets
+/include/generated/ +/lib/asm-offsets.s + # stgit generated dirs patches-* .stgit-edit.txt diff --git a/Makefile b/Makefile index f8e13d7..6e146d4 100644 --- a/Makefile +++ b/Makefile @@ -372,7 +372,8 @@ GEN_UBOOT = \ cd $(LNDIR) && $(LD) $(LDFLAGS) $$UNDEF_SYM $(__OBJS) \ --start-group $(__LIBS) --end-group $(PLATFORM_LIBS) \ -Map u-boot.map -o u-boot -$(obj)u-boot: depend $(SUBDIRS) $(OBJS) $(LIBBOARD) $(LIBS) $(LDSCRIPT) $(obj)u-boot.lds +$(obj)u-boot: depend \ + $(SUBDIRS) $(OBJS) $(LIBBOARD) $(LIBS) $(LDSCRIPT) $(obj)u-boot.lds $(GEN_UBOOT) ifeq ($(CONFIG_KALLSYMS),y) smap=`$(call SYSTEM_MAP,u-boot) | \ @@ -426,7 +427,9 @@ updater:
Aplied.
CONFIG_SYS_GBL_DATA_SIZE has always been just a bad workarond for not being able to use "sizeof(struct global_data)" in assembler files. Recent experience has shown that manual synchronization is not reliable enough. This patch renames CONFIG_SYS_GBL_DATA_SIZE into GENERATED_GBL_DATA_SIZE which gets automatically generated by the asm-offsets tool. In the result, all definitions of this value can be deleted from the board config files. We have to make sure that all files that reference such data include the new <asm-offsets.h> file.
No other changes have been done yet, but it is obvious that similar changes / simplifications can be done for other, related macro definitions as well.
Signed-off-by: Wolfgang Denk wd@denx.de --- arch/arm/cpu/arm1136/start.S | 9 +++++---- arch/arm/cpu/arm1176/start.S | 9 +++++---- arch/arm/cpu/arm720t/start.S | 8 ++++---- arch/arm/cpu/arm920t/start.S | 7 ++++--- arch/arm/cpu/arm925t/start.S | 8 ++++---- arch/arm/cpu/arm926ejs/start.S | 8 ++++---- arch/arm/cpu/arm946es/start.S | 8 ++++---- arch/arm/cpu/arm_intcm/start.S | 8 ++++---- arch/arm/cpu/armv7/start.S | 9 +++++---- arch/arm/cpu/ixp/start.S | 7 ++++--- arch/arm/cpu/lh7a40x/start.S | 9 ++++----- arch/arm/cpu/pxa/start.S | 5 +++-- arch/arm/cpu/s3c44b0/start.S | 5 ++--- arch/arm/cpu/sa1100/start.S | 9 ++++----- arch/arm/include/asm/global_data.h | 2 +- arch/arm/lib/interrupts.c | 2 +- arch/avr32/cpu/start.S | 1 + arch/avr32/include/asm/global_data.h | 2 +- arch/blackfin/include/asm/config.h | 5 ++--- arch/blackfin/include/asm/global_data.h | 2 +- arch/blackfin/lib/board.c | 4 ++-- arch/i386/include/asm/global_data.h | 2 +- arch/m68k/cpu/mcf5227x/start.S | 1 + arch/m68k/cpu/mcf523x/start.S | 1 + arch/m68k/cpu/mcf52x2/start.S | 1 + arch/m68k/cpu/mcf532x/start.S | 1 + arch/m68k/cpu/mcf5445x/start.S | 1 + arch/m68k/cpu/mcf547x_8x/start.S | 1 + arch/m68k/include/asm/global_data.h | 2 +- arch/microblaze/cpu/start.S | 1 + arch/microblaze/include/asm/global_data.h | 2 +- arch/microblaze/lib/board.c | 2 +- arch/mips/cpu/cache.S | 1 + arch/mips/cpu/start.S | 1 + arch/mips/include/asm/global_data.h | 2 +- arch/nios2/cpu/start.S | 2 +- arch/nios2/lib/board.c | 2 +- arch/powerpc/cpu/74xx_7xx/start.S | 1 + arch/powerpc/cpu/mpc512x/start.S | 1 + arch/powerpc/cpu/mpc5xx/start.S | 1 + arch/powerpc/cpu/mpc5xxx/start.S | 1 + arch/powerpc/cpu/mpc8220/start.S | 1 + arch/powerpc/cpu/mpc824x/start.S | 1 + arch/powerpc/cpu/mpc8260/start.S | 1 + arch/powerpc/cpu/mpc83xx/start.S | 1 + arch/powerpc/cpu/mpc85xx/release.S | 1 + arch/powerpc/cpu/mpc85xx/start.S | 1 + arch/powerpc/cpu/mpc86xx/start.S | 1 + arch/powerpc/cpu/mpc8xx/start.S | 1 + arch/powerpc/cpu/ppc4xx/start.S | 3 ++- arch/powerpc/include/asm/global_data.h | 2 +- arch/sh/cpu/sh2/start.S | 5 +++-- arch/sh/cpu/sh3/start.S | 5 +++-- arch/sh/cpu/sh4/start.S | 5 +++-- arch/sh/lib/board.c | 4 ++-- arch/sparc/cpu/leon2/start.S | 1 + arch/sparc/cpu/leon3/start.S | 1 + arch/sparc/include/asm/global_data.h | 2 +- arch/sparc/lib/board.c | 2 +- board/amcc/bamboo/init.S | 1 + board/amcc/bluestone/init.S | 1 + board/amcc/canyonlands/init.S | 1 + board/amcc/sequoia/init.S | 1 + board/amcc/yosemite/init.S | 1 + board/barco/early_init.S | 1 + board/esd/du440/init.S | 1 + board/esd/pmc440/init.S | 1 + board/fads/fads.h | 3 +-- board/gdsys/gdppc440etx/init.S | 1 + board/gdsys/intip/init.S | 1 + board/hidden_dragon/early_init.S | 1 + board/korat/init.S | 1 + board/lwmon5/init.S | 1 + board/pcs440ep/init.S | 1 + board/prodrive/alpr/init.S | 1 + board/sandpoint/early_init.S | 1 + board/t3corp/init.S | 1 + common/cmd_bdinfo.c | 2 +- include/asm-offsets.h | 4 ++++ include/common.h | 1 + include/configs/A3000.h | 4 +--- include/configs/ADCIOP.h | 3 +-- include/configs/AMX860.h | 3 +-- include/configs/AP1000.h | 3 +-- include/configs/APC405.h | 3 +-- include/configs/AR405.h | 3 +-- include/configs/ASH405.h | 3 +-- include/configs/ATUM8548.h | 3 +-- include/configs/Adder.h | 3 +-- include/configs/Alaska8220.h | 3 +-- include/configs/B2.h | 1 - include/configs/BAB7xx.h | 3 +-- include/configs/BC3450.h | 3 +-- include/configs/BMW.h | 3 +-- include/configs/CANBT.h | 3 +-- include/configs/CATcenter.h | 3 +-- include/configs/CMS700.h | 3 +-- include/configs/CPC45.h | 3 +-- include/configs/CPCI2DP.h | 3 +-- include/configs/CPCI405.h | 3 +-- include/configs/CPCI4052.h | 3 +-- include/configs/CPCI405AB.h | 3 +-- include/configs/CPCI405DT.h | 3 +-- include/configs/CPCI750.h | 3 +-- include/configs/CPCIISER4.h | 3 +-- include/configs/CPU86.h | 3 +-- include/configs/CPU87.h | 3 +-- include/configs/CRAYL1.h | 6 ++---- include/configs/CU824.h | 3 +-- include/configs/DASA_SIM.h | 3 +-- include/configs/DB64360.h | 3 +-- include/configs/DB64460.h | 3 +-- include/configs/DP405.h | 3 +-- include/configs/DU405.h | 3 +-- include/configs/DU440.h | 3 +-- include/configs/EB+MCF-EV123.h | 3 +-- include/configs/ELPPC.h | 3 +-- include/configs/ELPT860.h | 3 +-- include/configs/EP88x.h | 3 +-- include/configs/ERIC.h | 3 +-- include/configs/ESTEEM192E.h | 3 +-- include/configs/ETX094.h | 3 +-- include/configs/EVB64260.h | 3 +-- include/configs/EXBITGEN.h | 3 +-- include/configs/FADS823.h | 3 +-- include/configs/FADS850SAR.h | 3 +-- include/configs/FLAGADM.h | 3 +-- include/configs/FPS850L.h | 3 +-- include/configs/FPS860L.h | 3 +-- include/configs/G2000.h | 3 +-- include/configs/GENIETV.h | 3 +-- include/configs/HH405.h | 3 +-- include/configs/HIDDEN_DRAGON.h | 6 ++---- include/configs/HUB405.h | 3 +-- include/configs/IAD210.h | 3 +-- include/configs/ICU862.h | 3 +-- include/configs/IDS8247.h | 3 +-- include/configs/IP860.h | 3 +-- include/configs/IPHASE4539.h | 3 +-- include/configs/ISPAN.h | 3 +-- include/configs/IVML24.h | 3 +-- include/configs/IVMS8.h | 3 +-- include/configs/IceCube.h | 3 +-- include/configs/JSE.h | 3 +-- include/configs/KAREF.h | 3 +-- include/configs/KUP4K.h | 3 +-- include/configs/KUP4X.h | 3 +-- include/configs/LANTEC.h | 3 +-- include/configs/M5208EVBE.h | 3 +-- include/configs/M52277EVB.h | 3 +-- include/configs/M5235EVB.h | 3 +-- include/configs/M5249EVB.h | 3 +-- include/configs/M5253DEMO.h | 3 +-- include/configs/M5253EVBE.h | 3 +-- include/configs/M5271EVB.h | 3 +-- include/configs/M5272C3.h | 3 +-- include/configs/M5275EVB.h | 3 +-- include/configs/M5282EVB.h | 3 +-- include/configs/M53017EVB.h | 3 +-- include/configs/M5329EVB.h | 3 +-- include/configs/M5373EVB.h | 3 +-- include/configs/M54451EVB.h | 3 +-- include/configs/M54455EVB.h | 3 +-- include/configs/M5475EVB.h | 3 +-- include/configs/M5485EVB.h | 3 +-- include/configs/MBX.h | 3 +-- include/configs/MBX860T.h | 3 +-- include/configs/METROBOX.h | 3 +-- include/configs/MHPC.h | 3 +-- include/configs/MIP405.h | 3 +-- include/configs/ML2.h | 3 +-- include/configs/MOUSSE.h | 3 +-- include/configs/MPC8260ADS.h | 3 +-- include/configs/MPC8266ADS.h | 3 +-- include/configs/MPC8308RDB.h | 3 +-- include/configs/MPC8313ERDB.h | 3 +-- include/configs/MPC8315ERDB.h | 3 +-- include/configs/MPC8323ERDB.h | 3 +-- include/configs/MPC832XEMDS.h | 3 +-- include/configs/MPC8349EMDS.h | 3 +-- include/configs/MPC8349ITX.h | 3 +-- include/configs/MPC8360EMDS.h | 3 +-- include/configs/MPC8360ERDK.h | 3 +-- include/configs/MPC837XEMDS.h | 3 +-- include/configs/MPC837XERDB.h | 3 +-- include/configs/MPC8536DS.h | 3 +-- include/configs/MPC8540ADS.h | 3 +-- include/configs/MPC8540EVAL.h | 3 +-- include/configs/MPC8541CDS.h | 3 +-- include/configs/MPC8544DS.h | 3 +-- include/configs/MPC8548CDS.h | 3 +-- include/configs/MPC8555CDS.h | 3 +-- include/configs/MPC8560ADS.h | 3 +-- include/configs/MPC8568MDS.h | 3 +-- include/configs/MPC8569MDS.h | 3 +-- include/configs/MPC8572DS.h | 3 +-- include/configs/MPC8610HPCD.h | 3 +-- include/configs/MPC8641HPCN.h | 3 +-- include/configs/MUSENKI.h | 4 +--- include/configs/MVBC_P.h | 3 +-- include/configs/MVBLM7.h | 3 +-- include/configs/MVBLUE.h | 3 +-- include/configs/MVS1.h | 3 +-- include/configs/MVSMR.h | 3 +-- include/configs/MigoR.h | 1 - include/configs/NETPHONE.h | 3 +-- include/configs/NETTA.h | 3 +-- include/configs/NETTA2.h | 3 +-- include/configs/NETVIA.h | 3 +-- include/configs/NSCU.h | 3 +-- include/configs/NX823.h | 3 +-- include/configs/OCRTC.h | 3 +-- include/configs/ORSG.h | 3 +-- include/configs/OXC.h | 3 +-- include/configs/P1022DS.h | 3 +-- include/configs/P1_P2_RDB.h | 3 +-- include/configs/P2020DS.h | 3 +-- include/configs/P3G4.h | 3 +-- include/configs/PATI.h | 3 +-- include/configs/PCI405.h | 3 +-- include/configs/PCI5441.h | 3 +-- include/configs/PCIPPC2.h | 3 +-- include/configs/PCIPPC6.h | 3 +-- include/configs/PIP405.h | 3 +-- include/configs/PK1C20.h | 3 +-- include/configs/PLU405.h | 3 +-- include/configs/PM520.h | 3 +-- include/configs/PM826.h | 3 +-- include/configs/PM828.h | 3 +-- include/configs/PM854.h | 3 +-- include/configs/PM856.h | 3 +-- include/configs/PMC405.h | 3 +-- include/configs/PMC405DE.h | 3 +-- include/configs/PMC440.h | 3 +-- include/configs/PN62.h | 4 +--- include/configs/PPChameleonEVB.h | 3 +-- include/configs/QS823.h | 3 +-- include/configs/QS850.h | 3 +-- include/configs/QS860T.h | 3 +-- include/configs/R360MPI.h | 3 +-- include/configs/RBC823.h | 3 +-- include/configs/RPXClassic.h | 3 +-- include/configs/RPXlite.h | 3 +-- include/configs/RPXlite_DW.h | 3 +-- include/configs/RPXsuper.h | 3 +-- include/configs/RRvision.h | 3 +-- include/configs/Rattler.h | 3 +-- include/configs/SBC8540.h | 3 +-- include/configs/SCM.h | 3 +-- include/configs/SIMPC8313.h | 3 +-- include/configs/SM850.h | 3 +-- include/configs/SMN42.h | 1 - include/configs/SPD823TS.h | 3 +-- include/configs/SX1.h | 1 - include/configs/SXNI855T.h | 3 +-- include/configs/Sandpoint8240.h | 7 ++----- include/configs/Sandpoint8245.h | 7 ++----- include/configs/TASREG.h | 3 +-- include/configs/TB5200.h | 3 +-- include/configs/TK885D.h | 3 +-- include/configs/TOP5200.h | 3 +-- include/configs/TOP860.h | 3 +-- include/configs/TQM5200.h | 3 +-- include/configs/TQM823L.h | 3 +-- include/configs/TQM823M.h | 3 +-- include/configs/TQM8260.h | 3 +-- include/configs/TQM8272.h | 3 +-- include/configs/TQM834x.h | 3 +-- include/configs/TQM850L.h | 3 +-- include/configs/TQM850M.h | 3 +-- include/configs/TQM855L.h | 3 +-- include/configs/TQM855M.h | 3 +-- include/configs/TQM85xx.h | 3 +-- include/configs/TQM860L.h | 3 +-- include/configs/TQM860M.h | 3 +-- include/configs/TQM862L.h | 3 +-- include/configs/TQM862M.h | 3 +-- include/configs/TQM866M.h | 3 +-- include/configs/TQM885D.h | 3 +-- include/configs/Total5200.h | 3 +-- include/configs/VCMA9.h | 1 - include/configs/VOH405.h | 3 +-- include/configs/VOM405.h | 3 +-- include/configs/VoVPN-GW.h | 3 +-- include/configs/W7OLMC.h | 3 +-- include/configs/W7OLMG.h | 3 +-- include/configs/WUH405.h | 3 +-- include/configs/Yukon8220.h | 3 +-- include/configs/ZPC1900.h | 3 +-- include/configs/ZUMA.h | 3 +-- include/configs/a320evb.h | 1 - include/configs/a4m072.h | 3 +-- include/configs/acadia.h | 3 +-- include/configs/actux1.h | 1 - include/configs/actux2.h | 1 - include/configs/actux3.h | 1 - include/configs/actux4.h | 1 - include/configs/aev.h | 3 +-- include/configs/afeb9260.h | 1 - include/configs/alpr.h | 3 +-- include/configs/am3517_evm.h | 1 - include/configs/ap325rxa.h | 1 - include/configs/apollon.h | 1 - include/configs/aria.h | 3 +-- include/configs/armadillo.h | 1 - include/configs/assabet.h | 1 - include/configs/astro_mcf5373l.h | 3 +-- include/configs/at91cap9adk.h | 1 - include/configs/at91rm9200dk.h | 1 - include/configs/at91rm9200ek.h | 3 +-- include/configs/at91sam9260ek.h | 1 - include/configs/at91sam9261ek.h | 1 - include/configs/at91sam9263ek.h | 1 - include/configs/at91sam9m10g45ek.h | 1 - include/configs/at91sam9rlek.h | 1 - include/configs/atc.h | 3 +-- include/configs/balloon3.h | 3 +-- include/configs/bamboo.h | 3 +-- include/configs/barco.h | 6 ++---- include/configs/bluestone.h | 3 +-- include/configs/bubinga.h | 3 +-- include/configs/c2mon.h | 3 +-- include/configs/ca9x4_ct_vxp.h | 3 +-- include/configs/canmb.h | 3 +-- include/configs/canyonlands.h | 3 +-- include/configs/cerf250.h | 3 +-- include/configs/cm4008.h | 1 - include/configs/cm41xx.h | 1 - include/configs/cm5200.h | 3 +-- include/configs/cmc_pu2.h | 1 - include/configs/cmi_mpc5xx.h | 3 +-- include/configs/cobra5272.h | 3 +-- include/configs/cogent_mpc8260.h | 3 +-- include/configs/cogent_mpc8xx.h | 3 +-- include/configs/colibri_pxa270.h | 3 +-- include/configs/corenet_ds.h | 3 +-- include/configs/cpci5200.h | 3 +-- include/configs/cpu9260.h | 1 - include/configs/cpuat91.h | 1 - include/configs/cradle.h | 3 +-- include/configs/csb226.h | 3 +-- include/configs/csb272.h | 3 +-- include/configs/csb472.h | 3 +-- include/configs/csb637.h | 1 - include/configs/da830evm.h | 1 - include/configs/da850evm.h | 3 +-- include/configs/davinci_dm355evm.h | 1 - include/configs/davinci_dm355leopard.h | 1 - include/configs/davinci_dm365evm.h | 1 - include/configs/davinci_dm6467evm.h | 1 - include/configs/davinci_dvevm.h | 1 - include/configs/davinci_schmoogie.h | 1 - include/configs/davinci_sffsdr.h | 1 - include/configs/davinci_sonata.h | 1 - include/configs/debris.h | 7 ++----- include/configs/devkit8000.h | 1 - include/configs/digsy_mtc.h | 3 +-- include/configs/dlvision.h | 3 +-- include/configs/dnp1110.h | 1 - include/configs/eXalion.h | 3 +-- include/configs/eb_cpux9k2.h | 1 - include/configs/ebony.h | 3 +-- include/configs/edb93xx.h | 1 - include/configs/edminiv2.h | 3 +-- include/configs/ep7312.h | 1 - include/configs/ep8248.h | 3 +-- include/configs/ep8260.h | 3 +-- include/configs/ep82xxm.h | 3 +-- include/configs/espt.h | 1 - include/configs/evb4510.h | 1 - include/configs/galaxy5200.h | 3 +-- include/configs/gcplus.h | 1 - include/configs/gdppc440etx.h | 3 +-- include/configs/gr_cpci_ax2000.h | 5 ++--- include/configs/gr_ep2s60.h | 5 ++--- include/configs/gr_xc3s_1500.h | 5 ++--- include/configs/grsim.h | 5 ++--- include/configs/grsim_leon2.h | 5 ++--- include/configs/gw8260.h | 3 +-- include/configs/hcu4.h | 3 +-- include/configs/hcu5.h | 3 +-- include/configs/hermes.h | 3 +-- include/configs/hmi1001.h | 3 +-- include/configs/hymod.h | 3 +-- include/configs/icon.h | 3 +-- include/configs/idmr.h | 3 +-- include/configs/igep0020.h | 3 +-- include/configs/igep0030.h | 3 +-- include/configs/impa7.h | 1 - include/configs/imx27lite-common.h | 3 +-- include/configs/imx31_litekit.h | 3 +-- include/configs/imx31_phycore.h | 1 - include/configs/inka4x0.h | 3 +-- include/configs/innokom.h | 3 +-- include/configs/integratorap.h | 1 - include/configs/integratorcp.h | 1 - include/configs/intip.h | 3 +-- include/configs/ipek01.h | 3 +-- include/configs/ixdp425.h | 1 - include/configs/ixdpg425.h | 1 - include/configs/jadecpu.h | 1 - include/configs/jornada.h | 1 - include/configs/jupiter.h | 3 +-- include/configs/katmai.h | 3 +-- include/configs/kb9202.h | 1 - include/configs/kilauea.h | 3 +-- include/configs/km8xx.h | 3 +-- include/configs/km_arm.h | 3 +-- include/configs/kmeter1.h | 3 +-- include/configs/korat.h | 3 +-- include/configs/kvme080.h | 3 +-- include/configs/lart.h | 1 - include/configs/linkstation.h | 3 +-- include/configs/lpc2292sodimm.h | 1 - include/configs/lpd7a400.h | 1 - include/configs/lpd7a404.h | 1 - include/configs/luan.h | 3 +-- include/configs/lubbock.h | 3 +-- include/configs/lwmon.h | 3 +-- include/configs/lwmon5.h | 3 +-- include/configs/m501sk.h | 1 - include/configs/makalu.h | 3 +-- include/configs/manroland/mpc5200-common.h | 3 +-- include/configs/mcc200.h | 3 +-- include/configs/mcu25.h | 3 +-- include/configs/mecp5123.h | 3 +-- include/configs/mecp5200.h | 3 +-- include/configs/meesc.h | 1 - include/configs/mgcoge.h | 3 +-- include/configs/microblaze-generic.h | 5 ++--- include/configs/modnet50.h | 1 - include/configs/motionpro.h | 3 +-- include/configs/mp2usb.h | 1 - include/configs/mpc5121-common.h | 3 +-- include/configs/mpc5121ads.h | 3 +-- include/configs/mpc7448hpc2.h | 3 +-- include/configs/mpc8308_p1m.h | 3 +-- include/configs/mpr2.h | 1 - include/configs/ms7720se.h | 1 - include/configs/ms7722se.h | 1 - include/configs/ms7750se.h | 1 - include/configs/muas3001.h | 3 +-- include/configs/munices.h | 3 +-- include/configs/mv-common.h | 1 - include/configs/mx1ads.h | 1 - include/configs/mx1fs2.h | 1 - include/configs/mx31ads.h | 1 - include/configs/mx31pdk.h | 1 - include/configs/mx51evk.h | 1 - include/configs/neo.h | 3 +-- include/configs/netstar.h | 1 - include/configs/nhk8815.h | 1 - include/configs/nios2-generic.h | 3 +-- include/configs/ns9750dev.h | 1 - include/configs/o2dnt.h | 3 +-- include/configs/ocotea.h | 3 +-- include/configs/omap1510inn.h | 1 - include/configs/omap1610h2.h | 1 - include/configs/omap1610inn.h | 1 - include/configs/omap2420h4.h | 1 - include/configs/omap3_beagle.h | 3 +-- include/configs/omap3_evm.h | 1 - include/configs/omap3_overo.h | 3 +-- include/configs/omap3_pandora.h | 1 - include/configs/omap3_sdp3430.h | 1 - include/configs/omap3_zoom1.h | 1 - include/configs/omap3_zoom2.h | 1 - include/configs/omap4_panda.h | 3 +-- include/configs/omap4_sdp4430.h | 3 +-- include/configs/omap5912osk.h | 1 - include/configs/omap730p2.h | 1 - include/configs/otc570.h | 1 - include/configs/p3mx.h | 3 +-- include/configs/p3p440.h | 3 +-- include/configs/palmld.h | 3 +-- include/configs/palmtc.h | 3 +-- include/configs/pcm030.h | 3 +-- include/configs/pcs440ep.h | 3 +-- include/configs/pdnb3.h | 1 - include/configs/pf5200.h | 3 +-- include/configs/pleb2.h | 3 +-- include/configs/pm9261.h | 1 - include/configs/pm9263.h | 1 - include/configs/pm9g45.h | 1 - include/configs/ppmc7xx.h | 5 ++--- include/configs/ppmc8260.h | 3 +-- include/configs/pxa255_idp.h | 3 +-- include/configs/qong.h | 3 +-- include/configs/quad100hd.h | 3 +-- include/configs/quantum.h | 3 +-- include/configs/r2dplus.h | 1 - include/configs/r7780mp.h | 1 - include/configs/redwood.h | 3 +-- include/configs/rmu.h | 3 +-- include/configs/rsdproto.h | 3 +-- include/configs/rsk7203.h | 1 - include/configs/s5p_goni.h | 1 - include/configs/sacsng.h | 3 +-- include/configs/sbc2410x.h | 1 - include/configs/sbc35_a9g20.h | 1 - include/configs/sbc405.h | 3 +-- include/configs/sbc8240.h | 3 +-- include/configs/sbc8260.h | 3 +-- include/configs/sbc8349.h | 3 +-- include/configs/sbc8548.h | 3 +-- include/configs/sbc8560.h | 3 +-- include/configs/sbc8641d.h | 3 +-- include/configs/sc3.h | 3 +-- include/configs/scb9328.h | 1 - include/configs/sequoia.h | 3 +-- include/configs/sh7763rdp.h | 1 - include/configs/sh7785lcr.h | 1 - include/configs/shannon.h | 1 - include/configs/smdk2400.h | 1 - include/configs/smdk2410.h | 1 - include/configs/smdk6400.h | 1 - include/configs/smdkc100.h | 1 - include/configs/socrates.h | 3 +-- include/configs/sorcery.h | 3 +-- include/configs/spc1920.h | 3 +-- include/configs/spear-common.h | 1 - include/configs/spieval.h | 3 +-- include/configs/stxgp3.h | 3 +-- include/configs/stxssa.h | 3 +-- include/configs/stxxtc.h | 3 +-- include/configs/svm_sc8xx.h | 3 +-- include/configs/t3corp.h | 3 +-- include/configs/taihu.h | 3 +-- include/configs/taishan.h | 3 +-- include/configs/tnetv107x_evm.h | 1 - include/configs/tny_a9260.h | 1 - include/configs/trab.h | 1 - include/configs/trizepsiv.h | 3 +-- include/configs/tx25.h | 3 +-- include/configs/uc100.h | 3 +-- include/configs/utx8245.h | 3 +-- include/configs/v37.h | 3 +-- include/configs/v38b.h | 3 +-- include/configs/ve8313.h | 3 +-- include/configs/versatile.h | 1 - include/configs/virtlab2.h | 3 +-- include/configs/vision2.h | 3 +-- include/configs/vme8349.h | 3 +-- include/configs/voiceblue.h | 1 - include/configs/vpac270.h | 3 +-- include/configs/walnut.h | 3 +-- include/configs/xaeniax.h | 3 +-- include/configs/xilinx-ppc.h | 3 +-- include/configs/xm250.h | 3 +-- include/configs/xpedite1000.h | 3 +-- include/configs/xpedite517x.h | 3 +-- include/configs/xpedite520x.h | 3 +-- include/configs/xpedite537x.h | 3 +-- include/configs/xpedite550x.h | 3 +-- include/configs/yosemite.h | 3 +-- include/configs/yucca.h | 3 +-- include/configs/zeus.h | 3 +-- include/configs/zipitz2.h | 3 +-- include/configs/zylonite.h | 3 +-- lib/asm-offsets.c | 2 ++ 560 files changed, 517 insertions(+), 955 deletions(-)
diff --git a/arch/arm/cpu/arm1136/start.S b/arch/arm/cpu/arm1136/start.S index 29ed065..845433a 100644 --- a/arch/arm/cpu/arm1136/start.S +++ b/arch/arm/cpu/arm1136/start.S @@ -28,6 +28,7 @@ * MA 02111-1307 USA */
+#include <asm-offsets.h> #include <config.h> #include <version.h> .globl _start @@ -380,7 +381,7 @@ stack_setup: sub sp, r0, #128 /* leave 32 words for abort-stack */ #else sub r0, r0, #CONFIG_SYS_MALLOC_LEN /* malloc area */ - sub r0, r0, #CONFIG_SYS_GBL_DATA_SIZE /* bdinfo */ + sub r0, r0, #GENERATED_GBL_DATA_SIZE /* bdinfo */ #ifdef CONFIG_USE_IRQ sub r0, r0, #(CONFIG_STACKSIZE_IRQ+CONFIG_STACKSIZE_FIQ) #endif @@ -510,7 +511,7 @@ cpu_init_crit: #else adr r2, _start sub r2, r2, #(CONFIG_SYS_MALLOC_LEN) - sub r2, r2, #(CONFIG_SYS_GBL_DATA_SIZE+8) @ set base 2 words into abort stack + sub r2, r2, #(GENERATED_GBL_DATA_SIZE+8) @ set base 2 words into abort stack #endif ldmia r2, {r2 - r3} @ get values for "aborted" pc and cpsr (into parm regs) add r0, sp, #S_FRAME_SIZE @ grab pointer to old stack @@ -547,7 +548,7 @@ cpu_init_crit: #else adr r13, _start @ setup our mode stack (enter in banked mode) sub r13, r13, #(CONFIG_STACKSIZE+CONFIG_SYS_MALLOC_LEN) @ move past malloc pool - sub r13, r13, #(CONFIG_SYS_GBL_DATA_SIZE+8) @ move to reserved a couple spots for abort stack + sub r13, r13, #(GENERATED_GBL_DATA_SIZE+8) @ move to reserved a couple spots for abort stack #endif
str lr, [r13] @ save caller lr in position 0 of saved stack @@ -569,7 +570,7 @@ cpu_init_crit: #else ldr r0, _armboot_start @ get data regions start sub r0, r0, #(CONFIG_SYS_MALLOC_LEN) @ move past malloc pool - sub r0, r0, #(CONFIG_SYS_GBL_DATA_SIZE+8) @ move past gbl and a couple spots for abort stack + sub r0, r0, #(GENERATED_GBL_DATA_SIZE+8) @ move past gbl and a couple spots for abort stack #endif str lr, [r0] @ save caller lr in position 0 of saved stack mrs r0, spsr @ get the spsr diff --git a/arch/arm/cpu/arm1176/start.S b/arch/arm/cpu/arm1176/start.S index 24e5bf4..c13cceb 100644 --- a/arch/arm/cpu/arm1176/start.S +++ b/arch/arm/cpu/arm1176/start.S @@ -30,6 +30,7 @@ * Base codes by scsuh (sc.suh) */
+#include <asm-offsets.h> #include <config.h> #include <version.h> #ifdef CONFIG_ENABLE_MMU @@ -546,7 +547,7 @@ skip_hw_init: stack_setup: ldr r0, =CONFIG_SYS_UBOOT_BASE /* base of copy in DRAM */ sub r0, r0, #CONFIG_SYS_MALLOC_LEN /* malloc area */ - sub r0, r0, #CONFIG_SYS_GBL_DATA_SIZE /* bdinfo */ + sub r0, r0, #GENERATED_GBL_DATA_SIZE /* bdinfo */ sub sp, r0, #12 /* leave 3 words for abort-stack */ bic sp, sp, #7 /* 8-byte alignment for ABI compliance */
@@ -663,7 +664,7 @@ phy_last_jump: ldr r2, _armboot_start sub r2, r2, #(CONFIG_SYS_MALLOC_LEN) /* set base 2 words into abort stack */ - sub r2, r2, #(CONFIG_SYS_GBL_DATA_SIZE+8) + sub r2, r2, #(GENERATED_GBL_DATA_SIZE+8) #else ldr r2, IRQ_STACK_START_IN #endif @@ -687,7 +688,7 @@ phy_last_jump: /* move past malloc pool */ sub r13, r13, #(CONFIG_SYS_MALLOC_LEN) /* move to reserved a couple spots for abort stack */ - sub r13, r13, #(CONFIG_SYS_GBL_DATA_SIZE + 8) + sub r13, r13, #(GENERATED_GBL_DATA_SIZE + 8) #else ldr r13, IRQ_STACK_START_IN @ setup our mode stack #endif @@ -721,7 +722,7 @@ phy_last_jump: /* move past malloc pool */ sub r0, r0, #(CONFIG_SYS_MALLOC_LEN) /* move past gbl and a couple spots for abort stack */ - sub r0, r0, #(CONFIG_SYS_GBL_DATA_SIZE + 8) + sub r0, r0, #(GENERATED_GBL_DATA_SIZE + 8) #else ldr r13, IRQ_STACK_START_IN @ setup our mode stack #endif diff --git a/arch/arm/cpu/arm720t/start.S b/arch/arm/cpu/arm720t/start.S index d93911f..06aa3a2 100644 --- a/arch/arm/cpu/arm720t/start.S +++ b/arch/arm/cpu/arm720t/start.S @@ -23,7 +23,7 @@ * MA 02111-1307 USA */
- +#include <asm-offsets.h> #include <config.h> #include <version.h> #include <asm/hardware.h> @@ -327,7 +327,7 @@ copy_loop: stack_setup: ldr r0, _TEXT_BASE /* upper 128 KiB: relocated uboot */ sub r0, r0, #CONFIG_SYS_MALLOC_LEN /* malloc area */ - sub r0, r0, #CONFIG_SYS_GBL_DATA_SIZE /* bdinfo */ + sub r0, r0, #GENERATED_GBL_DATA_SIZE /* bdinfo */ #ifdef CONFIG_USE_IRQ sub r0, r0, #(CONFIG_STACKSIZE_IRQ+CONFIG_STACKSIZE_FIQ) #endif @@ -609,7 +609,7 @@ lock_loop: #if defined(CONFIG_SYS_ARM_WITHOUT_RELOC) ldr r2, _armboot_start sub r2, r2, #(CONFIG_STACKSIZE+CONFIG_SYS_MALLOC_LEN) - sub r2, r2, #(CONFIG_SYS_GBL_DATA_SIZE+8) @ set base 2 words into abort stack + sub r2, r2, #(GENERATED_GBL_DATA_SIZE+8) @ set base 2 words into abort stack #else ldr r2, IRQ_STACK_START_IN #endif @@ -646,7 +646,7 @@ lock_loop: #if defined(CONFIG_SYS_ARM_WITHOUT_RELOC) ldr r13, _armboot_start @ setup our mode stack sub r13, r13, #(CONFIG_STACKSIZE+CONFIG_SYS_MALLOC_LEN) - sub r13, r13, #(CONFIG_SYS_GBL_DATA_SIZE+8) @ reserved a couple spots in abort stack + sub r13, r13, #(GENERATED_GBL_DATA_SIZE+8) @ reserved a couple spots in abort stack #else ldr r13, IRQ_STACK_START_IN @ setup our mode stack #endif diff --git a/arch/arm/cpu/arm920t/start.S b/arch/arm/cpu/arm920t/start.S index 343a760..84f7546 100644 --- a/arch/arm/cpu/arm920t/start.S +++ b/arch/arm/cpu/arm920t/start.S @@ -24,6 +24,7 @@ * MA 02111-1307 USA */
+#include <asm-offsets.h> #include <common.h> #include <config.h>
@@ -414,7 +415,7 @@ copy_loop: stack_setup: ldr r0, _TEXT_BASE /* upper 128 KiB: relocated uboot */ sub r0, r0, #CONFIG_SYS_MALLOC_LEN /* malloc area */ - sub r0, r0, #CONFIG_SYS_GBL_DATA_SIZE /* bdinfo */ + sub r0, r0, #GENERATED_GBL_DATA_SIZE /* bdinfo */ #ifdef CONFIG_USE_IRQ sub r0, r0, #(CONFIG_STACKSIZE_IRQ+CONFIG_STACKSIZE_FIQ) #endif @@ -529,7 +530,7 @@ cpu_init_crit: sub r2, r2, #(CONFIG_STACKSIZE) sub r2, r2, #(CONFIG_SYS_MALLOC_LEN) /* set base 2 words into abort stack */ - sub r2, r2, #(CONFIG_SYS_GBL_DATA_SIZE+8) + sub r2, r2, #(GENERATED_GBL_DATA_SIZE+8) #else ldr r2, IRQ_STACK_START_IN #endif @@ -569,7 +570,7 @@ cpu_init_crit: sub r13, r13, #(CONFIG_STACKSIZE) sub r13, r13, #(CONFIG_SYS_MALLOC_LEN) /* reserve a couple spots in abort stack */ - sub r13, r13, #(CONFIG_SYS_GBL_DATA_SIZE+8) + sub r13, r13, #(GENERATED_GBL_DATA_SIZE+8) #else ldr r13, IRQ_STACK_START_IN @ setup our mode stack #endif diff --git a/arch/arm/cpu/arm925t/start.S b/arch/arm/cpu/arm925t/start.S index cf18a01..f45ad89 100644 --- a/arch/arm/cpu/arm925t/start.S +++ b/arch/arm/cpu/arm925t/start.S @@ -30,7 +30,7 @@ * MA 02111-1307 USA */
@@ -385,7 +385,7 @@ copy_loop: stack_setup: ldr r0, _TEXT_BASE /* upper 128 KiB: relocated uboot */ sub r0, r0, #CONFIG_SYS_MALLOC_LEN /* malloc area */ - sub r0, r0, #CONFIG_SYS_GBL_DATA_SIZE /* bdinfo */ + sub r0, r0, #GENERATED_GBL_DATA_SIZE /* bdinfo */ #ifdef CONFIG_USE_IRQ sub r0, r0, #(CONFIG_STACKSIZE_IRQ+CONFIG_STACKSIZE_FIQ) #endif @@ -492,7 +492,7 @@ cpu_init_crit: #if defined(CONFIG_SYS_ARM_WITHOUT_RELOC) ldr r2, _armboot_start sub r2, r2, #(CONFIG_STACKSIZE+CONFIG_SYS_MALLOC_LEN) - sub r2, r2, #(CONFIG_SYS_GBL_DATA_SIZE+8) @ set base 2 words into abort stack + sub r2, r2, #(GENERATED_GBL_DATA_SIZE+8) @ set base 2 words into abort stack #else ldr r2, IRQ_STACK_START_IN #endif @@ -529,7 +529,7 @@ cpu_init_crit: #if defined(CONFIG_SYS_ARM_WITHOUT_RELOC) ldr r13, _armboot_start @ setup our mode stack sub r13, r13, #(CONFIG_STACKSIZE+CONFIG_SYS_MALLOC_LEN) - sub r13, r13, #(CONFIG_SYS_GBL_DATA_SIZE+8) @ reserved a couple spots in abort stack + sub r13, r13, #(GENERATED_GBL_DATA_SIZE+8) @ reserved a couple spots in abort stack #else ldr r13, IRQ_STACK_START_IN #endif diff --git a/arch/arm/cpu/arm926ejs/start.S b/arch/arm/cpu/arm926ejs/start.S index 863de3b..8449d25 100644 --- a/arch/arm/cpu/arm926ejs/start.S +++ b/arch/arm/cpu/arm926ejs/start.S @@ -31,7 +31,7 @@ * MA 02111-1307 USA */
- +#include <asm-offsets.h> #include <config.h> #include <common.h> #include <version.h> @@ -349,7 +349,7 @@ stack_setup: sub sp, r0, #128 /* leave 32 words for abort-stack */ #ifndef CONFIG_PRELOADER sub r0, r0, #CONFIG_SYS_MALLOC_LEN /* malloc area */ - sub r0, r0, #CONFIG_SYS_GBL_DATA_SIZE /* bdinfo */ + sub r0, r0, #GENERATED_GBL_DATA_SIZE /* bdinfo */ #ifdef CONFIG_USE_IRQ sub r0, r0, #(CONFIG_STACKSIZE_IRQ+CONFIG_STACKSIZE_FIQ) #endif @@ -475,7 +475,7 @@ cpu_init_crit: #if defined(CONFIG_SYS_ARM_WITHOUT_RELOC) adr r2, _start sub r2, r2, #(CONFIG_STACKSIZE+CONFIG_SYS_MALLOC_LEN) - sub r2, r2, #(CONFIG_SYS_GBL_DATA_SIZE+8) @ set base 2 words into abort stack + sub r2, r2, #(GENERATED_GBL_DATA_SIZE+8) @ set base 2 words into abort stack #else ldr r2, IRQ_STACK_START_IN #endif @@ -513,7 +513,7 @@ cpu_init_crit: #if defined(CONFIG_SYS_ARM_WITHOUT_RELOC) adr r13, _start @ setup our mode stack sub r13, r13, #(CONFIG_STACKSIZE+CONFIG_SYS_MALLOC_LEN) - sub r13, r13, #(CONFIG_SYS_GBL_DATA_SIZE+8) @ reserved a couple spots in abort stack + sub r13, r13, #(GENERATED_GBL_DATA_SIZE+8) @ reserved a couple spots in abort stack #else ldr r13, IRQ_STACK_START_IN @ setup our mode stack #endif diff --git a/arch/arm/cpu/arm946es/start.S b/arch/arm/cpu/arm946es/start.S index 077886f..25b573b 100644 --- a/arch/arm/cpu/arm946es/start.S +++ b/arch/arm/cpu/arm946es/start.S @@ -30,7 +30,7 @@ * MA 02111-1307 USA */
@@ -316,7 +316,7 @@ copy_loop: stack_setup: ldr r0, _TEXT_BASE /* upper 128 KiB: relocated uboot */ sub r0, r0, #CONFIG_SYS_MALLOC_LEN /* malloc area */ - sub r0, r0, #CONFIG_SYS_GBL_DATA_SIZE /* bdinfo */ + sub r0, r0, #GENERATED_GBL_DATA_SIZE /* bdinfo */ #ifdef CONFIG_USE_IRQ sub r0, r0, #(CONFIG_STACKSIZE_IRQ+CONFIG_STACKSIZE_FIQ) #endif @@ -427,7 +427,7 @@ cpu_init_crit: #if defined(CONFIG_SYS_ARM_WITHOUT_RELOC) ldr r2, _armboot_start sub r2, r2, #(CONFIG_STACKSIZE+CONFIG_SYS_MALLOC_LEN) - sub r2, r2, #(CONFIG_SYS_GBL_DATA_SIZE+8) @ set base 2 words into abort stack + sub r2, r2, #(GENERATED_GBL_DATA_SIZE+8) @ set base 2 words into abort stack #else ldr r2, IRQ_STACK_START_IN #endif @@ -465,7 +465,7 @@ cpu_init_crit: #if defined(CONFIG_SYS_ARM_WITHOUT_RELOC) ldr r13, _armboot_start @ setup our mode stack sub r13, r13, #(CONFIG_STACKSIZE+CONFIG_SYS_MALLOC_LEN) - sub r13, r13, #(CONFIG_SYS_GBL_DATA_SIZE+8) @ reserved a couple spots in abort stack + sub r13, r13, #(GENERATED_GBL_DATA_SIZE+8) @ reserved a couple spots in abort stack #else ldr r13, IRQ_STACK_START_IN @ setup our mode stack #endif diff --git a/arch/arm/cpu/arm_intcm/start.S b/arch/arm/cpu/arm_intcm/start.S index 07356cb..3e9d5e8 100644 --- a/arch/arm/cpu/arm_intcm/start.S +++ b/arch/arm/cpu/arm_intcm/start.S @@ -30,7 +30,7 @@ * MA 02111-1307 USA */
@@ -312,7 +312,7 @@ copy_loop: stack_setup: ldr r0, _TEXT_BASE /* upper 128 KiB: relocated uboot */ sub r0, r0, #CONFIG_SYS_MALLOC_LEN /* malloc area */ - sub r0, r0, #CONFIG_SYS_GBL_DATA_SIZE /* bdinfo */ + sub r0, r0, #GENERATED_GBL_DATA_SIZE /* bdinfo */ #ifdef CONFIG_USE_IRQ sub r0, r0, #(CONFIG_STACKSIZE_IRQ+CONFIG_STACKSIZE_FIQ) #endif @@ -403,7 +403,7 @@ cpu_init_crit: #if defined(CONFIG_SYS_ARM_WITHOUT_RELOC) ldr r2, _armboot_start sub r2, r2, #(CONFIG_STACKSIZE+CONFIG_SYS_MALLOC_LEN) - sub r2, r2, #(CONFIG_SYS_GBL_DATA_SIZE+8) @ set base 2 words into abort stack + sub r2, r2, #(GENERATED_GBL_DATA_SIZE+8) @ set base 2 words into abort stack #else ldr r2, IRQ_STACK_START_IN #endif @@ -441,7 +441,7 @@ cpu_init_crit: #if defined(CONFIG_SYS_ARM_WITHOUT_RELOC) ldr r13, _armboot_start @ setup our mode stack sub r13, r13, #(CONFIG_STACKSIZE+CONFIG_SYS_MALLOC_LEN) - sub r13, r13, #(CONFIG_SYS_GBL_DATA_SIZE+8) @ reserved a couple spots in abort stack + sub r13, r13, #(GENERATED_GBL_DATA_SIZE+8) @ reserved a couple spots in abort stack #else ldr r13, IRQ_STACK_START_IN @ setup our mode stack #endif diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index 64c86e9..b6896a8 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -29,6 +29,7 @@ * MA 02111-1307 USA */
@@ -357,7 +358,7 @@ copy_loop: @ copy 32 bytes at a time stack_setup: ldr r0, _TEXT_BASE @ upper 128 KiB: relocated uboot sub r0, r0, #CONFIG_SYS_MALLOC_LEN @ malloc area - sub r0, r0, #CONFIG_SYS_GBL_DATA_SIZE @ bdinfo + sub r0, r0, #GENERATED_GBL_DATA_SIZE @ bdinfo #ifdef CONFIG_USE_IRQ sub r0, r0, #(CONFIG_STACKSIZE_IRQ + CONFIG_STACKSIZE_FIQ) #endif @@ -464,7 +465,7 @@ cpu_init_crit: #if defined(CONFIG_SYS_ARM_WITHOUT_RELOC) ldr r2, _armboot_start sub r2, r2, #(CONFIG_SYS_MALLOC_LEN) - sub r2, r2, #(CONFIG_SYS_GBL_DATA_SIZE + 8) @ set base 2 words into abort + sub r2, r2, #(GENERATED_GBL_DATA_SIZE + 8) @ set base 2 words into abort #else ldr r2, IRQ_STACK_START_IN @ set base 2 words into abort @ stack @@ -507,7 +508,7 @@ cpu_init_crit: #if defined(CONFIG_SYS_ARM_WITHOUT_RELOC) ldr r13, _armboot_start @ setup our mode stack (enter sub r13, r13, #(CONFIG_SYS_MALLOC_LEN) @ move past malloc pool - sub r13, r13, #(CONFIG_SYS_GBL_DATA_SIZE + 8) @ move to reserved a couple + sub r13, r13, #(GENERATED_GBL_DATA_SIZE + 8) @ move to reserved a couple #else ldr r13, IRQ_STACK_START_IN @ setup our mode stack (enter @ in banked mode) @@ -535,7 +536,7 @@ cpu_init_crit: #if defined(CONFIG_SYS_ARM_WITHOUT_RELOC) ldr r0, _armboot_start @ get data regions start sub r0, r0, #(CONFIG_SYS_MALLOC_LEN) @ move past malloc pool - sub r0, r0, #(CONFIG_SYS_GBL_DATA_SIZE + 8) @ move past gbl and a couple + sub r0, r0, #(GENERATED_GBL_DATA_SIZE + 8) @ move past gbl and a couple #else ldr r0, IRQ_STACK_START_IN @ get data regions start @ spots for abort stack diff --git a/arch/arm/cpu/ixp/start.S b/arch/arm/cpu/ixp/start.S index 836c33b..2931ccd 100644 --- a/arch/arm/cpu/ixp/start.S +++ b/arch/arm/cpu/ixp/start.S @@ -27,6 +27,7 @@ * MA 02111-1307 USA */
+#include <asm-offsets.h> #include <config.h> #include <version.h> #include <asm/arch/ixp425.h> @@ -555,7 +556,7 @@ copy_loop: stack_setup: ldr r0, _TEXT_BASE /* upper 128 KiB: relocated uboot */ sub r0, r0, #CONFIG_SYS_MALLOC_LEN /* malloc area */ - sub r0, r0, #CONFIG_SYS_GBL_DATA_SIZE /* bdinfo */ + sub r0, r0, #GENERATED_GBL_DATA_SIZE /* bdinfo */ #ifdef CONFIG_USE_IRQ sub r0, r0, #(CONFIG_STACKSIZE_IRQ+CONFIG_STACKSIZE_FIQ) #endif @@ -620,7 +621,7 @@ _start_armboot: .word start_armboot #if defined(CONFIG_SYS_ARM_WITHOUT_RELOC) ldr r2, _armboot_start sub r2, r2, #(CONFIG_STACKSIZE+CONFIG_SYS_MALLOC_LEN) - sub r2, r2, #(CONFIG_SYS_GBL_DATA_SIZE+8) @ set base 2 words into abort stack + sub r2, r2, #(GENERATED_GBL_DATA_SIZE+8) @ set base 2 words into abort stack #else ldr r2, IRQ_STACK_START_IN #endif @@ -661,7 +662,7 @@ _start_armboot: .word start_armboot #if defined(CONFIG_SYS_ARM_WITHOUT_RELOC) ldr r13, _armboot_start @ setup our mode stack sub r13, r13, #(CONFIG_STACKSIZE+CONFIG_SYS_MALLOC_LEN) - sub r13, r13, #(CONFIG_SYS_GBL_DATA_SIZE+8) @ reserved a couple spots in abort stack + sub r13, r13, #(GENERATED_GBL_DATA_SIZE+8) @ reserved a couple spots in abort stack #else ldr r13, IRQ_STACK_START_IN @ setup our mode stack #endif diff --git a/arch/arm/cpu/lh7a40x/start.S b/arch/arm/cpu/lh7a40x/start.S index d944860..703baf8 100644 --- a/arch/arm/cpu/lh7a40x/start.S +++ b/arch/arm/cpu/lh7a40x/start.S @@ -24,11 +24,10 @@ * MA 02111-1307 USA */
- /* ************************************************************************* * @@ -349,7 +348,7 @@ copy_loop: stack_setup: ldr r0, _TEXT_BASE /* upper 128 KiB: relocated uboot */ sub r0, r0, #CONFIG_SYS_MALLOC_LEN /* malloc area */ - sub r0, r0, #CONFIG_SYS_GBL_DATA_SIZE /* bdinfo */ + sub r0, r0, #GENERATED_GBL_DATA_SIZE /* bdinfo */ #ifdef CONFIG_USE_IRQ sub r0, r0, #(CONFIG_STACKSIZE_IRQ+CONFIG_STACKSIZE_FIQ) #endif @@ -464,7 +463,7 @@ cpu_init_crit: #if defined(CONFIG_SYS_ARM_WITHOUT_RELOC) ldr r2, _armboot_start sub r2, r2, #(CONFIG_STACKSIZE+CONFIG_SYS_MALLOC_LEN) - sub r2, r2, #(CONFIG_SYS_GBL_DATA_SIZE+8) @ set base 2 words into abort stack + sub r2, r2, #(GENERATED_GBL_DATA_SIZE+8) @ set base 2 words into abort stack #else ldr r2, IRQ_STACK_START_IN #endif @@ -501,7 +500,7 @@ cpu_init_crit: #if defined(CONFIG_SYS_ARM_WITHOUT_RELOC) ldr r13, _armboot_start @ setup our mode stack sub r13, r13, #(CONFIG_STACKSIZE+CONFIG_SYS_MALLOC_LEN) - sub r13, r13, #(CONFIG_SYS_GBL_DATA_SIZE+8) @ reserved a couple spots in abort stack + sub r13, r13, #(GENERATED_GBL_DATA_SIZE+8) @ reserved a couple spots in abort stack #else ldr r13, IRQ_STACK_START_IN @ setup our mode stack #endif diff --git a/arch/arm/cpu/pxa/start.S b/arch/arm/cpu/pxa/start.S index 3c5bd84..b8065b7 100644 --- a/arch/arm/cpu/pxa/start.S +++ b/arch/arm/cpu/pxa/start.S @@ -29,6 +29,7 @@ * MA 02111-1307 USA */
+#include <asm-offsets.h> #include <config.h> #include <version.h> #include <asm/arch/pxa-regs.h> @@ -419,7 +420,7 @@ reset: #if defined(CONFIG_SYS_ARM_WITHOUT_RELOC) ldr r2, _armboot_start sub r2, r2, #(CONFIG_STACKSIZE+CONFIG_SYS_MALLOC_LEN) - sub r2, r2, #(CONFIG_SYS_GBL_DATA_SIZE+8) @ set base 2 words into abort stack + sub r2, r2, #(GENERATED_GBL_DATA_SIZE+8) @ set base 2 words into abort stack #else ldr r2, IRQ_STACK_START_IN #endif @@ -460,7 +461,7 @@ reset: #if defined(CONFIG_SYS_ARM_WITHOUT_RELOC) ldr r13, _armboot_start @ setup our mode stack sub r13, r13, #(CONFIG_STACKSIZE+CONFIG_SYS_MALLOC_LEN) - sub r13, r13, #(CONFIG_SYS_GBL_DATA_SIZE+8) @ reserved a couple spots in abort stack + sub r13, r13, #(GENERATED_GBL_DATA_SIZE+8) @ reserved a couple spots in abort stack #else ldr r13, IRQ_STACK_START_IN @ setup our mode stack #endif diff --git a/arch/arm/cpu/s3c44b0/start.S b/arch/arm/cpu/s3c44b0/start.S index 20091b2..77f3735 100644 --- a/arch/arm/cpu/s3c44b0/start.S +++ b/arch/arm/cpu/s3c44b0/start.S @@ -27,11 +27,10 @@ * MA 02111-1307 USA */
- /* * Jump vector table */ @@ -331,7 +330,7 @@ vector_copy_loop: stack_setup: ldr r0, _TEXT_BASE /* upper 128 KiB: relocated uboot */ sub r0, r0, #CONFIG_SYS_MALLOC_LEN /* malloc area */ - sub r0, r0, #CONFIG_SYS_GBL_DATA_SIZE /* bdinfo */ + sub r0, r0, #GENERATED_GBL_DATA_SIZE /* bdinfo */ #ifdef CONFIG_USE_IRQ sub r0, r0, #(CONFIG_STACKSIZE_IRQ+CONFIG_STACKSIZE_FIQ) #endif diff --git a/arch/arm/cpu/sa1100/start.S b/arch/arm/cpu/sa1100/start.S index 8eabb66..5635e0a 100644 --- a/arch/arm/cpu/sa1100/start.S +++ b/arch/arm/cpu/sa1100/start.S @@ -25,11 +25,10 @@ * MA 02111-1307 USA */
- /* ************************************************************************* * @@ -301,7 +300,7 @@ copy_loop: stack_setup: ldr r0, _TEXT_BASE /* upper 128 KiB: relocated uboot */ sub r0, r0, #CONFIG_SYS_MALLOC_LEN /* malloc area */ - sub r0, r0, #CONFIG_SYS_GBL_DATA_SIZE /* bdinfo */ + sub r0, r0, #GENERATED_GBL_DATA_SIZE /* bdinfo */ #ifdef CONFIG_USE_IRQ sub r0, r0, #(CONFIG_STACKSIZE_IRQ+CONFIG_STACKSIZE_FIQ) #endif @@ -445,7 +444,7 @@ cpu_init_crit: #if defined(CONFIG_SYS_ARM_WITHOUT_RELOC) ldr r2, _armboot_start sub r2, r2, #(CONFIG_STACKSIZE+CONFIG_SYS_MALLOC_LEN) - sub r2, r2, #(CONFIG_SYS_GBL_DATA_SIZE+8) @ set base 2 words into abort stack + sub r2, r2, #(GENERATED_GBL_DATA_SIZE+8) @ set base 2 words into abort stack #else ldr r2, IRQ_STACK_START_IN #endif @@ -482,7 +481,7 @@ cpu_init_crit: #if defined(CONFIG_SYS_ARM_WITHOUT_RELOC) ldr r13, _armboot_start @ setup our mode stack sub r13, r13, #(CONFIG_STACKSIZE+CONFIG_SYS_MALLOC_LEN) - sub r13, r13, #(CONFIG_SYS_GBL_DATA_SIZE+8) @ reserved a couple spots in abort stack + sub r13, r13, #(GENERATED_GBL_DATA_SIZE+8) @ reserved a couple spots in abort stack #else ldr r13, IRQ_STACK_START_IN @ setup our mode stack #endif diff --git a/arch/arm/include/asm/global_data.h b/arch/arm/include/asm/global_data.h index 6dae432..5438ebc 100644 --- a/arch/arm/include/asm/global_data.h +++ b/arch/arm/include/asm/global_data.h @@ -30,7 +30,7 @@ * global variables during system initialization (until we have set * up the memory controller so that we can use RAM). * - * Keep it *SMALL* and remember to set CONFIG_SYS_GBL_DATA_SIZE > sizeof(gd_t) + * Keep it *SMALL* and remember to set GENERATED_GBL_DATA_SIZE > sizeof(gd_t) */
typedef struct global_data { diff --git a/arch/arm/lib/interrupts.c b/arch/arm/lib/interrupts.c index 9a21e7b..90aa04b 100644 --- a/arch/arm/lib/interrupts.c +++ b/arch/arm/lib/interrupts.c @@ -50,7 +50,7 @@ int interrupt_init (void) IRQ_STACK_START = gd->irq_sp - 4; IRQ_STACK_START_IN = gd->irq_sp + 8; #else - IRQ_STACK_START = _armboot_start - CONFIG_SYS_MALLOC_LEN - CONFIG_SYS_GBL_DATA_SIZE - 4; + IRQ_STACK_START = _armboot_start - CONFIG_SYS_MALLOC_LEN - GENERATED_GBL_DATA_SIZE - 4; #endif FIQ_STACK_START = IRQ_STACK_START - CONFIG_STACKSIZE_IRQ;
diff --git a/arch/avr32/cpu/start.S b/arch/avr32/cpu/start.S index 06bf4c6..97140e9 100644 --- a/arch/avr32/cpu/start.S +++ b/arch/avr32/cpu/start.S @@ -19,6 +19,7 @@ * Foundation, Inc., 59 Temple Place, Suite 330, Boston, * MA 02111-1307 USA */ +#include <asm-offsets.h> #include <config.h> #include <asm/ptrace.h> #include <asm/sysreg.h> diff --git a/arch/avr32/include/asm/global_data.h b/arch/avr32/include/asm/global_data.h index 5a7aed9..4ef8fc5 100644 --- a/arch/avr32/include/asm/global_data.h +++ b/arch/avr32/include/asm/global_data.h @@ -29,7 +29,7 @@ * global variables during system initialization (until we have set * up the memory controller so that we can use RAM). * - * Keep it *SMALL* and remember to set CONFIG_SYS_GBL_DATA_SIZE > sizeof(gd_t) + * Keep it *SMALL* and remember to set GENERATED_GBL_DATA_SIZE > sizeof(gd_t) */
typedef struct global_data { diff --git a/arch/blackfin/include/asm/config.h b/arch/blackfin/include/asm/config.h index 215e0f2..877aa97 100644 --- a/arch/blackfin/include/asm/config.h +++ b/arch/blackfin/include/asm/config.h @@ -101,11 +101,10 @@ #ifndef CONFIG_SYS_MALLOC_BASE # define CONFIG_SYS_MALLOC_BASE (CONFIG_SYS_MONITOR_BASE - CONFIG_SYS_MALLOC_LEN) #endif -#ifndef CONFIG_SYS_GBL_DATA_SIZE -# define CONFIG_SYS_GBL_DATA_SIZE (128) +#ifndef GENERATED_GBL_DATA_SIZE #endif #ifndef CONFIG_SYS_GBL_DATA_ADDR -# define CONFIG_SYS_GBL_DATA_ADDR (CONFIG_SYS_MALLOC_BASE - CONFIG_SYS_GBL_DATA_SIZE) +# define CONFIG_SYS_GBL_DATA_ADDR (CONFIG_SYS_MALLOC_BASE - GENERATED_GBL_DATA_SIZE) #endif #ifndef CONFIG_STACKBASE # define CONFIG_STACKBASE (CONFIG_SYS_GBL_DATA_ADDR - 4) diff --git a/arch/blackfin/include/asm/global_data.h b/arch/blackfin/include/asm/global_data.h index d5514b0..eba5e93 100644 --- a/arch/blackfin/include/asm/global_data.h +++ b/arch/blackfin/include/asm/global_data.h @@ -37,7 +37,7 @@ * global variables during system initialization (until we have set * up the memory controller so that we can use RAM). * - * Keep it *SMALL* and remember to set CONFIG_SYS_GBL_DATA_SIZE > sizeof(gd_t) + * Keep it *SMALL* and remember to set GENERATED_GBL_DATA_SIZE > sizeof(gd_t) */ typedef struct global_data { bd_t *bd; diff --git a/arch/blackfin/lib/board.c b/arch/blackfin/lib/board.c index fcfd174..8eca7d6 100644 --- a/arch/blackfin/lib/board.c +++ b/arch/blackfin/lib/board.c @@ -237,12 +237,12 @@ void board_init_f(ulong bootflag) #endif
#ifdef DEBUG - if (CONFIG_SYS_GBL_DATA_SIZE < sizeof(*gd)) + if (GENERATED_GBL_DATA_SIZE < sizeof(*gd)) hang(); #endif serial_early_puts("Init global data\n"); gd = (gd_t *) (CONFIG_SYS_GBL_DATA_ADDR); - memset((void *)gd, 0, CONFIG_SYS_GBL_DATA_SIZE); + memset((void *)gd, 0, GENERATED_GBL_DATA_SIZE);
/* Board data initialization */ addr = (CONFIG_SYS_GBL_DATA_ADDR + sizeof(gd_t)); diff --git a/arch/i386/include/asm/global_data.h b/arch/i386/include/asm/global_data.h index 5971123..e3f8a25 100644 --- a/arch/i386/include/asm/global_data.h +++ b/arch/i386/include/asm/global_data.h @@ -30,7 +30,7 @@ * global variables during system initialization (until we have set * up the memory controller so that we can use RAM). * - * Keep it *SMALL* and remember to set CONFIG_SYS_GBL_DATA_SIZE > sizeof(gd_t) + * Keep it *SMALL* and remember to set GENERATED_GBL_DATA_SIZE > sizeof(gd_t) */
#ifndef __ASSEMBLY__ diff --git a/arch/m68k/cpu/mcf5227x/start.S b/arch/m68k/cpu/mcf5227x/start.S index ac71096..d09d492 100644 --- a/arch/m68k/cpu/mcf5227x/start.S +++ b/arch/m68k/cpu/mcf5227x/start.S @@ -21,6 +21,7 @@ * MA 02111-1307 USA */
+#include <asm-offsets.h> #include <config.h> #include <timestamp.h> #include "version.h" diff --git a/arch/m68k/cpu/mcf523x/start.S b/arch/m68k/cpu/mcf523x/start.S index 20b50e7..a726b59 100644 --- a/arch/m68k/cpu/mcf523x/start.S +++ b/arch/m68k/cpu/mcf523x/start.S @@ -21,6 +21,7 @@ * MA 02111-1307 USA */
+#include <asm-offsets.h> #include <config.h> #include <timestamp.h> #include "version.h" diff --git a/arch/m68k/cpu/mcf52x2/start.S b/arch/m68k/cpu/mcf52x2/start.S index d1f3d83..f0cfa6f 100644 --- a/arch/m68k/cpu/mcf52x2/start.S +++ b/arch/m68k/cpu/mcf52x2/start.S @@ -21,6 +21,7 @@ * MA 02111-1307 USA */
+#include <asm-offsets.h> #include <config.h> #include <timestamp.h> #include "version.h" diff --git a/arch/m68k/cpu/mcf532x/start.S b/arch/m68k/cpu/mcf532x/start.S index a80b0a9..53ac471 100644 --- a/arch/m68k/cpu/mcf532x/start.S +++ b/arch/m68k/cpu/mcf532x/start.S @@ -24,6 +24,7 @@ * MA 02111-1307 USA */
+#include <asm-offsets.h> #include <config.h> #include <timestamp.h> #include "version.h" diff --git a/arch/m68k/cpu/mcf5445x/start.S b/arch/m68k/cpu/mcf5445x/start.S index 8b69d1f..5255f37 100644 --- a/arch/m68k/cpu/mcf5445x/start.S +++ b/arch/m68k/cpu/mcf5445x/start.S @@ -21,6 +21,7 @@ * MA 02111-1307 USA */
+#include <asm-offsets.h> #include <config.h> #include <timestamp.h> #include "version.h" diff --git a/arch/m68k/cpu/mcf547x_8x/start.S b/arch/m68k/cpu/mcf547x_8x/start.S index 8411862..e30923f 100644 --- a/arch/m68k/cpu/mcf547x_8x/start.S +++ b/arch/m68k/cpu/mcf547x_8x/start.S @@ -21,6 +21,7 @@ * MA 02111-1307 USA */
+#include <asm-offsets.h> #include <config.h> #include <timestamp.h> #include "version.h" diff --git a/arch/m68k/include/asm/global_data.h b/arch/m68k/include/asm/global_data.h index 3a36f82..fc486fd 100644 --- a/arch/m68k/include/asm/global_data.h +++ b/arch/m68k/include/asm/global_data.h @@ -30,7 +30,7 @@ * global variables during system initialization (until we have set * up the memory controller so that we can use RAM). * - * Keep it *SMALL* and remember to set CONFIG_SYS_GBL_DATA_SIZE > sizeof(gd_t) + * Keep it *SMALL* and remember to set GENERATED_GBL_DATA_SIZE > sizeof(gd_t) */
typedef struct global_data { diff --git a/arch/microblaze/cpu/start.S b/arch/microblaze/cpu/start.S index 98c248f..d44903b 100644 --- a/arch/microblaze/cpu/start.S +++ b/arch/microblaze/cpu/start.S @@ -24,6 +24,7 @@ * MA 02111-1307 USA */
.text diff --git a/arch/microblaze/include/asm/global_data.h b/arch/microblaze/include/asm/global_data.h index 03444ef..557ad27 100644 --- a/arch/microblaze/include/asm/global_data.h +++ b/arch/microblaze/include/asm/global_data.h @@ -31,7 +31,7 @@ * global variables during system initialization (until we have set * up the memory controller so that we can use RAM). * - * Keep it *SMALL* and remember to set CONFIG_SYS_GBL_DATA_SIZE > sizeof(gd_t) + * Keep it *SMALL* and remember to set GENERATED_GBL_DATA_SIZE > sizeof(gd_t) */
typedef struct global_data { diff --git a/arch/microblaze/lib/board.c b/arch/microblaze/lib/board.c index 84267cd..eeef579 100644 --- a/arch/microblaze/lib/board.c +++ b/arch/microblaze/lib/board.c @@ -96,7 +96,7 @@ void board_init (void) ulong flash_size = 0; #endif asm ("nop"); /* FIXME gd is not initialize - wait */ - memset ((void *)gd, 0, CONFIG_SYS_GBL_DATA_SIZE); + memset ((void *)gd, 0, GENERATED_GBL_DATA_SIZE); gd->bd = (bd_t *) (gd + 1); /* At end of global data */ gd->baudrate = CONFIG_BAUDRATE; bd = gd->bd; diff --git a/arch/mips/cpu/cache.S b/arch/mips/cpu/cache.S index ff4f11c..4b30c89 100644 --- a/arch/mips/cpu/cache.S +++ b/arch/mips/cpu/cache.S @@ -22,6 +22,7 @@ * MA 02111-1307 USA */
+#include <asm-offsets.h> #include <config.h> #include <asm/asm.h> #include <asm/regdef.h> diff --git a/arch/mips/cpu/start.S b/arch/mips/cpu/start.S index 57db589..d6bcef6 100644 --- a/arch/mips/cpu/start.S +++ b/arch/mips/cpu/start.S @@ -22,6 +22,7 @@ * MA 02111-1307 USA */
+#include <asm-offsets.h> #include <config.h> #include <asm/regdef.h> #include <asm/mipsregs.h> diff --git a/arch/mips/include/asm/global_data.h b/arch/mips/include/asm/global_data.h index bf1bfc3..271a290 100644 --- a/arch/mips/include/asm/global_data.h +++ b/arch/mips/include/asm/global_data.h @@ -33,7 +33,7 @@ * global variables during system initialization (until we have set * up the memory controller so that we can use RAM). * - * Keep it *SMALL* and remember to set CONFIG_SYS_GBL_DATA_SIZE > sizeof(gd_t) + * Keep it *SMALL* and remember to set GENERATED_GBL_DATA_SIZE > sizeof(gd_t) */
typedef struct global_data { diff --git a/arch/nios2/cpu/start.S b/arch/nios2/cpu/start.S index 76d3b52..9b0f52d 100644 --- a/arch/nios2/cpu/start.S +++ b/arch/nios2/cpu/start.S @@ -21,7 +21,7 @@ * MA 02111-1307 USA */
- +#include <asm-offsets.h> #include <config.h> #include <timestamp.h> #include <version.h> diff --git a/arch/nios2/lib/board.c b/arch/nios2/lib/board.c index f83e691..f6c6bc1 100644 --- a/arch/nios2/lib/board.c +++ b/arch/nios2/lib/board.c @@ -95,7 +95,7 @@ void board_init (void) /* compiler optimization barrier needed for GCC >= 3.4 */ __asm__ __volatile__("": : :"memory");
- memset( gd, 0, CONFIG_SYS_GBL_DATA_SIZE ); + memset( gd, 0, GENERATED_GBL_DATA_SIZE );
gd->bd = (bd_t *)(gd+1); /* At end of global data */ gd->baudrate = CONFIG_BAUDRATE; diff --git a/arch/powerpc/cpu/74xx_7xx/start.S b/arch/powerpc/cpu/74xx_7xx/start.S index b4121df..280781e 100644 --- a/arch/powerpc/cpu/74xx_7xx/start.S +++ b/arch/powerpc/cpu/74xx_7xx/start.S @@ -32,6 +32,7 @@ * board_init lies at a quite high address and when the cpu has * jumped there, everything is ok. */ +#include <asm-offsets.h> #include <config.h> #include <74xx_7xx.h> #include <timestamp.h> diff --git a/arch/powerpc/cpu/mpc512x/start.S b/arch/powerpc/cpu/mpc512x/start.S index 2265c8c..fe35190 100644 --- a/arch/powerpc/cpu/mpc512x/start.S +++ b/arch/powerpc/cpu/mpc512x/start.S @@ -29,6 +29,7 @@ * U-Boot - Startup Code for MPC512x based Embedded Boards */
+#include <asm-offsets.h> #include <config.h> #include <timestamp.h> #include <version.h> diff --git a/arch/powerpc/cpu/mpc5xx/start.S b/arch/powerpc/cpu/mpc5xx/start.S index da42557..63449c3 100644 --- a/arch/powerpc/cpu/mpc5xx/start.S +++ b/arch/powerpc/cpu/mpc5xx/start.S @@ -30,6 +30,7 @@ * */
+#include <asm-offsets.h> #include <config.h> #include <mpc5xx.h> #include <timestamp.h> diff --git a/arch/powerpc/cpu/mpc5xxx/start.S b/arch/powerpc/cpu/mpc5xxx/start.S index 92858fc..ad54677 100644 --- a/arch/powerpc/cpu/mpc5xxx/start.S +++ b/arch/powerpc/cpu/mpc5xxx/start.S @@ -25,6 +25,7 @@ /* * U-Boot - Startup Code for MPC5xxx CPUs */ +#include <asm-offsets.h> #include <config.h> #include <mpc5xxx.h> #include <timestamp.h> diff --git a/arch/powerpc/cpu/mpc8220/start.S b/arch/powerpc/cpu/mpc8220/start.S index b5c160b..b029e84 100644 --- a/arch/powerpc/cpu/mpc8220/start.S +++ b/arch/powerpc/cpu/mpc8220/start.S @@ -25,6 +25,7 @@ /* * U-Boot - Startup Code for MPC8220 CPUs */ +#include <asm-offsets.h> #include <config.h> #include <mpc8220.h> #include <timestamp.h> diff --git a/arch/powerpc/cpu/mpc824x/start.S b/arch/powerpc/cpu/mpc824x/start.S index d10231e..616de58 100644 --- a/arch/powerpc/cpu/mpc824x/start.S +++ b/arch/powerpc/cpu/mpc824x/start.S @@ -37,6 +37,7 @@ * board_init will change CS0 to be positioned at the correct * address and (s)dram will be positioned at address 0 */ +#include <asm-offsets.h> #include <config.h> #include <mpc824x.h> #include <timestamp.h> diff --git a/arch/powerpc/cpu/mpc8260/start.S b/arch/powerpc/cpu/mpc8260/start.S index 55c64ea..521a639 100644 --- a/arch/powerpc/cpu/mpc8260/start.S +++ b/arch/powerpc/cpu/mpc8260/start.S @@ -25,6 +25,7 @@ /* * U-Boot - Startup Code for MPC8260 PowerPC based Embedded Boards */ +#include <asm-offsets.h> #include <config.h> #include <mpc8260.h> #include <timestamp.h> diff --git a/arch/powerpc/cpu/mpc83xx/start.S b/arch/powerpc/cpu/mpc83xx/start.S index 403fda4..a35697d 100644 --- a/arch/powerpc/cpu/mpc83xx/start.S +++ b/arch/powerpc/cpu/mpc83xx/start.S @@ -27,6 +27,7 @@ * U-Boot - Startup Code for MPC83xx PowerPC based Embedded Boards */
+#include <asm-offsets.h> #include <config.h> #include <mpc83xx.h> #include <timestamp.h> diff --git a/arch/powerpc/cpu/mpc85xx/release.S b/arch/powerpc/cpu/mpc85xx/release.S index 53cefaf..56a853e 100644 --- a/arch/powerpc/cpu/mpc85xx/release.S +++ b/arch/powerpc/cpu/mpc85xx/release.S @@ -21,6 +21,7 @@ * MA 02111-1307 USA */
+#include <asm-offsets.h> #include <config.h> #include <mpc85xx.h> #include <version.h> diff --git a/arch/powerpc/cpu/mpc85xx/start.S b/arch/powerpc/cpu/mpc85xx/start.S index 7e5e6b1..291557d 100644 --- a/arch/powerpc/cpu/mpc85xx/start.S +++ b/arch/powerpc/cpu/mpc85xx/start.S @@ -28,6 +28,7 @@ * */
+#include <asm-offsets.h> #include <config.h> #include <mpc85xx.h> #include <timestamp.h> diff --git a/arch/powerpc/cpu/mpc86xx/start.S b/arch/powerpc/cpu/mpc86xx/start.S index 36004b7..6127115 100644 --- a/arch/powerpc/cpu/mpc86xx/start.S +++ b/arch/powerpc/cpu/mpc86xx/start.S @@ -30,6 +30,7 @@ * board_init lies at a quite high address and when the cpu has * jumped there, everything is ok. */ +#include <asm-offsets.h> #include <config.h> #include <mpc86xx.h> #include <timestamp.h> diff --git a/arch/powerpc/cpu/mpc8xx/start.S b/arch/powerpc/cpu/mpc8xx/start.S index 4a8c5d9..9d022bf 100644 --- a/arch/powerpc/cpu/mpc8xx/start.S +++ b/arch/powerpc/cpu/mpc8xx/start.S @@ -37,6 +37,7 @@ * board_init will change CS0 to be positioned at the correct * address and (s)dram will be positioned at address 0 */ +#include <asm-offsets.h> #include <config.h> #include <mpc8xx.h> #include <timestamp.h> diff --git a/arch/powerpc/cpu/ppc4xx/start.S b/arch/powerpc/cpu/ppc4xx/start.S index 140bfc9..363becc 100644 --- a/arch/powerpc/cpu/ppc4xx/start.S +++ b/arch/powerpc/cpu/ppc4xx/start.S @@ -63,6 +63,7 @@ * board_init will change CS0 to be positioned at the correct * address and (s)dram will be positioned at address 0 */ +#include <asm-offsets.h> #include <config.h> #include <asm/ppc4xx.h> #include <timestamp.h> @@ -1399,7 +1400,7 @@ relocate_code:
/* Flush initial global data range */ mr r3, r4 - addi r4, r4, CONFIG_SYS_GBL_DATA_SIZE@l + addi r4, r4, GENERATED_GBL_DATA_SIZE@l bl flush_dcache_range
#if defined(CONFIG_SYS_INIT_DCACHE_CS) diff --git a/arch/powerpc/include/asm/global_data.h b/arch/powerpc/include/asm/global_data.h index 2a323e1..2e218de 100644 --- a/arch/powerpc/include/asm/global_data.h +++ b/arch/powerpc/include/asm/global_data.h @@ -34,7 +34,7 @@ * global variables during system initialization (until we have set * up the memory controller so that we can use RAM). * - * Keep it *SMALL* and remember to set CONFIG_SYS_GBL_DATA_SIZE > sizeof(gd_t) + * Keep it *SMALL* and remember to set GENERATED_GBL_DATA_SIZE > sizeof(gd_t) */
typedef struct global_data { diff --git a/arch/sh/cpu/sh2/start.S b/arch/sh/cpu/sh2/start.S index 0ab867d..77043f6 100644 --- a/arch/sh/cpu/sh2/start.S +++ b/arch/sh/cpu/sh2/start.S @@ -18,6 +18,7 @@ * MA 02111-1307 USA */
@@ -73,6 +74,6 @@ loop: ._reloc_dst_end: .long reloc_dst_end ._bss_start: .long bss_start ._bss_end: .long bss_end -._gd_init: .long (_start - CONFIG_SYS_GBL_DATA_SIZE) -._stack_init: .long (_start - CONFIG_SYS_GBL_DATA_SIZE - CONFIG_SYS_MALLOC_LEN - 16) +._gd_init: .long (_start - GENERATED_GBL_DATA_SIZE) +._stack_init: .long (_start - GENERATED_GBL_DATA_SIZE - CONFIG_SYS_MALLOC_LEN - 16) ._sh_generic_init: .long sh_generic_init diff --git a/arch/sh/cpu/sh3/start.S b/arch/sh/cpu/sh3/start.S index c0f8326..9dd2303 100644 --- a/arch/sh/cpu/sh3/start.S +++ b/arch/sh/cpu/sh3/start.S @@ -21,6 +21,7 @@ * MA 02111-1307 USA */
@@ -72,6 +73,6 @@ loop: ._reloc_dst_end: .long reloc_dst_end ._bss_start: .long bss_start ._bss_end: .long bss_end -._gd_init: .long (_start - CONFIG_SYS_GBL_DATA_SIZE) -._stack_init: .long (_start - CONFIG_SYS_GBL_DATA_SIZE - CONFIG_SYS_MALLOC_LEN - 16) +._gd_init: .long (_start - GENERATED_GBL_DATA_SIZE) +._stack_init: .long (_start - GENERATED_GBL_DATA_SIZE - CONFIG_SYS_MALLOC_LEN - 16) ._sh_generic_init: .long sh_generic_init diff --git a/arch/sh/cpu/sh4/start.S b/arch/sh/cpu/sh4/start.S index 711ae66..4b5f606 100644 --- a/arch/sh/cpu/sh4/start.S +++ b/arch/sh/cpu/sh4/start.S @@ -18,6 +18,7 @@ * MA 02111-1307 USA */
@@ -69,6 +70,6 @@ loop: ._reloc_dst_end: .long reloc_dst_end ._bss_start: .long bss_start ._bss_end: .long bss_end -._gd_init: .long (_start - CONFIG_SYS_GBL_DATA_SIZE) -._stack_init: .long (_start - CONFIG_SYS_GBL_DATA_SIZE - CONFIG_SYS_MALLOC_LEN - 16) +._gd_init: .long (_start - GENERATED_GBL_DATA_SIZE) +._stack_init: .long (_start - GENERATED_GBL_DATA_SIZE - CONFIG_SYS_MALLOC_LEN - 16) ._sh_generic_init: .long sh_generic_init diff --git a/arch/sh/lib/board.c b/arch/sh/lib/board.c index a302fc2..fe53ab4 100644 --- a/arch/sh/lib/board.c +++ b/arch/sh/lib/board.c @@ -89,7 +89,7 @@ static int sh_pci_init(void)
static int sh_mem_env_init(void) { - mem_malloc_init(CONFIG_SYS_TEXT_BASE - CONFIG_SYS_GBL_DATA_SIZE - + mem_malloc_init(CONFIG_SYS_TEXT_BASE - GENERATED_GBL_DATA_SIZE - CONFIG_SYS_MALLOC_LEN, CONFIG_SYS_MALLOC_LEN - 16); env_relocate(); jumptable_init(); @@ -144,7 +144,7 @@ void sh_generic_init(void) bd_t *bd; init_fnc_t **init_fnc_ptr;
- memset(gd, 0, CONFIG_SYS_GBL_DATA_SIZE); + memset(gd, 0, GENERATED_GBL_DATA_SIZE);
gd->flags |= GD_FLG_RELOC; /* tell others: relocation done */
diff --git a/arch/sparc/cpu/leon2/start.S b/arch/sparc/cpu/leon2/start.S index dd58262..f22fb7e 100644 --- a/arch/sparc/cpu/leon2/start.S +++ b/arch/sparc/cpu/leon2/start.S @@ -21,6 +21,7 @@ * MA 02111-1307 USA */
+#include <asm-offsets.h> #include <config.h> #include <asm/asmmacro.h> #include <asm/winmacro.h> diff --git a/arch/sparc/cpu/leon3/start.S b/arch/sparc/cpu/leon3/start.S index 5c0808a..56ae88d 100644 --- a/arch/sparc/cpu/leon3/start.S +++ b/arch/sparc/cpu/leon3/start.S @@ -21,6 +21,7 @@ * MA 02111-1307 USA */
+#include <asm-offsets.h> #include <config.h> #include <asm/asmmacro.h> #include <asm/winmacro.h> diff --git a/arch/sparc/include/asm/global_data.h b/arch/sparc/include/asm/global_data.h index 7c1ac0d..9b14674 100644 --- a/arch/sparc/include/asm/global_data.h +++ b/arch/sparc/include/asm/global_data.h @@ -36,7 +36,7 @@ * global variables during system initialization (until we have set * up the memory controller so that we can use RAM). * - * Keep it *SMALL* and remember to set CONFIG_SYS_GBL_DATA_SIZE > sizeof(gd_t) + * Keep it *SMALL* and remember to set GENERATED_GBL_DATA_SIZE > sizeof(gd_t) */
typedef struct global_data { diff --git a/arch/sparc/lib/board.c b/arch/sparc/lib/board.c index 09bcdb0..4a6041f 100644 --- a/arch/sparc/lib/board.c +++ b/arch/sparc/lib/board.c @@ -244,7 +244,7 @@ void board_init_f(ulong bootflag) printf("CONFIG_SYS_PROM_OFFSET: 0x%lx (%d)\n", CONFIG_SYS_PROM_OFFSET, CONFIG_SYS_PROM_SIZE); printf("CONFIG_SYS_GBL_DATA_OFFSET: 0x%lx (%d)\n", CONFIG_SYS_GBL_DATA_OFFSET, - CONFIG_SYS_GBL_DATA_SIZE); + GENERATED_GBL_DATA_SIZE); #endif
#ifdef CONFIG_POST diff --git a/board/amcc/bamboo/init.S b/board/amcc/bamboo/init.S index 6925921..3d9989d 100644 --- a/board/amcc/bamboo/init.S +++ b/board/amcc/bamboo/init.S @@ -23,6 +23,7 @@ * MA 02111-1307 USA */
+#include <asm-offsets.h> #include <ppc_asm.tmpl> #include <config.h> #include <asm/mmu.h> diff --git a/board/amcc/bluestone/init.S b/board/amcc/bluestone/init.S index e969fcf..4b90c8d 100644 --- a/board/amcc/bluestone/init.S +++ b/board/amcc/bluestone/init.S @@ -21,6 +21,7 @@ * MA 02111-1307 USA */
+#include <asm-offsets.h> #include <ppc_asm.tmpl> #include <config.h> #include <asm/mmu.h> diff --git a/board/amcc/canyonlands/init.S b/board/amcc/canyonlands/init.S index 64d5d42..680feaa 100644 --- a/board/amcc/canyonlands/init.S +++ b/board/amcc/canyonlands/init.S @@ -21,6 +21,7 @@ * MA 02111-1307 USA */
+#include <asm-offsets.h> #include <ppc_asm.tmpl> #include <config.h> #include <asm/mmu.h> diff --git a/board/amcc/sequoia/init.S b/board/amcc/sequoia/init.S index 7139aae..419ef4f 100644 --- a/board/amcc/sequoia/init.S +++ b/board/amcc/sequoia/init.S @@ -21,6 +21,7 @@ * MA 02111-1307 USA */
+#include <asm-offsets.h> #include <ppc_asm.tmpl> #include <asm/mmu.h> #include <config.h> diff --git a/board/amcc/yosemite/init.S b/board/amcc/yosemite/init.S index ed3741c..d23cdc7 100644 --- a/board/amcc/yosemite/init.S +++ b/board/amcc/yosemite/init.S @@ -19,6 +19,7 @@ * MA 02111-1307 USA */
+#include <asm-offsets.h> #include <ppc_asm.tmpl> #include <asm/mmu.h> #include <config.h> diff --git a/board/barco/early_init.S b/board/barco/early_init.S index 531dcdf..61b4b55 100644 --- a/board/barco/early_init.S +++ b/board/barco/early_init.S @@ -25,6 +25,7 @@ #define __ASSEMBLY__ 1 #endif
+#include <asm-offsets.h> #include <config.h> #include <asm/processor.h> #include <mpc824x.h> diff --git a/board/esd/du440/init.S b/board/esd/du440/init.S index 351095a..88565d9 100644 --- a/board/esd/du440/init.S +++ b/board/esd/du440/init.S @@ -21,6 +21,7 @@ * MA 02111-1307 USA */
+#include <asm-offsets.h> #include <ppc_asm.tmpl> #include <asm/mmu.h> #include <config.h> diff --git a/board/esd/pmc440/init.S b/board/esd/pmc440/init.S index 96f7206..b99a8e9 100644 --- a/board/esd/pmc440/init.S +++ b/board/esd/pmc440/init.S @@ -19,6 +19,7 @@ * MA 02111-1307 USA */
+#include <asm-offsets.h> #include <ppc_asm.tmpl> #include <asm/mmu.h> #include <config.h> diff --git a/board/fads/fads.h b/board/fads/fads.h index 08d4b79..3dc5358 100644 --- a/board/fads/fads.h +++ b/board/fads/fads.h @@ -165,8 +165,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/board/gdsys/gdppc440etx/init.S b/board/gdsys/gdppc440etx/init.S index ba750cb..4a40e4b 100644 --- a/board/gdsys/gdppc440etx/init.S +++ b/board/gdsys/gdppc440etx/init.S @@ -24,6 +24,7 @@ * MA 02111-1307 USA */
diff --git a/board/gdsys/intip/init.S b/board/gdsys/intip/init.S index 5a819c2..7513f1d 100644 --- a/board/gdsys/intip/init.S +++ b/board/gdsys/intip/init.S @@ -25,6 +25,7 @@ * MA 02111-1307 USA */
+#include <asm-offsets.h> #include <ppc_asm.tmpl> #include <config.h> #include <asm/mmu.h> diff --git a/board/hidden_dragon/early_init.S b/board/hidden_dragon/early_init.S index 531dcdf..61b4b55 100644 --- a/board/hidden_dragon/early_init.S +++ b/board/hidden_dragon/early_init.S @@ -25,6 +25,7 @@ #define __ASSEMBLY__ 1 #endif
+#include <asm-offsets.h> #include <config.h> #include <asm/processor.h> #include <mpc824x.h> diff --git a/board/korat/init.S b/board/korat/init.S index bfc6bc1..3741277 100644 --- a/board/korat/init.S +++ b/board/korat/init.S @@ -19,6 +19,7 @@ * MA 02111-1307 USA */
+#include <asm-offsets.h> #include <ppc_asm.tmpl> #include <asm/mmu.h> #include <config.h> diff --git a/board/lwmon5/init.S b/board/lwmon5/init.S index 8efc8a1..2014cd7 100644 --- a/board/lwmon5/init.S +++ b/board/lwmon5/init.S @@ -23,6 +23,7 @@ * MA 02111-1307 USA */
+#include <asm-offsets.h> #include <ppc_asm.tmpl> #include <config.h> #include <asm/mmu.h> diff --git a/board/pcs440ep/init.S b/board/pcs440ep/init.S index 9745c14..6bd8852 100644 --- a/board/pcs440ep/init.S +++ b/board/pcs440ep/init.S @@ -21,6 +21,7 @@ * MA 02111-1307 USA */
+#include <asm-offsets.h> #include <ppc_asm.tmpl> #include <asm/mmu.h> #include <config.h> diff --git a/board/prodrive/alpr/init.S b/board/prodrive/alpr/init.S index 119bc53..d9961dd 100644 --- a/board/prodrive/alpr/init.S +++ b/board/prodrive/alpr/init.S @@ -21,6 +21,7 @@ * MA 02111-1307 USA */
+#include <asm-offsets.h> #include <ppc_asm.tmpl> #include <asm/mmu.h> #include <config.h> diff --git a/board/sandpoint/early_init.S b/board/sandpoint/early_init.S index 531dcdf..61b4b55 100644 --- a/board/sandpoint/early_init.S +++ b/board/sandpoint/early_init.S @@ -25,6 +25,7 @@ #define __ASSEMBLY__ 1 #endif
+#include <asm-offsets.h> #include <config.h> #include <asm/processor.h> #include <mpc824x.h> diff --git a/board/t3corp/init.S b/board/t3corp/init.S index ecd35ff..a24d6f3 100644 --- a/board/t3corp/init.S +++ b/board/t3corp/init.S @@ -21,6 +21,7 @@ * MA 02111-1307 USA */
+#include <asm-offsets.h> #include <ppc_asm.tmpl> #include <config.h> #include <asm/mmu.h> diff --git a/common/cmd_bdinfo.c b/common/cmd_bdinfo.c index 1326c8f..51b75ff 100644 --- a/common/cmd_bdinfo.c +++ b/common/cmd_bdinfo.c @@ -192,7 +192,7 @@ int do_bdinfo(cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[]) printf("CONFIG_SYS_PROM_OFFSET = 0x%lx (%d)\n", CONFIG_SYS_PROM_OFFSET, CONFIG_SYS_PROM_SIZE); printf("CONFIG_SYS_GBL_DATA_OFFSET = 0x%lx (%d)\n", CONFIG_SYS_GBL_DATA_OFFSET, - CONFIG_SYS_GBL_DATA_SIZE); + GENERATED_GBL_DATA_SIZE);
#if defined(CONFIG_CMD_NET) print_eth(0); diff --git a/include/asm-offsets.h b/include/asm-offsets.h index ab28184..ad3bf1f 100644 --- a/include/asm-offsets.h +++ b/include/asm-offsets.h @@ -1,2 +1,6 @@ +#ifndef DO_DEPS_ONLY + #include <generated/generic-asm-offsets.h> /* #include <generated/asm-offsets.h> */ + +#endif diff --git a/include/common.h b/include/common.h index 0686a17..189ad81 100644 --- a/include/common.h +++ b/include/common.h @@ -35,6 +35,7 @@ typedef volatile unsigned short vu_short; typedef volatile unsigned char vu_char;
#include <config.h> +#include <asm-offsets.h> #include <linux/bitops.h> #include <linux/types.h> #include <linux/string.h> diff --git a/include/configs/A3000.h b/include/configs/A3000.h index 648aa03..3d60141 100644 --- a/include/configs/A3000.h +++ b/include/configs/A3000.h @@ -172,11 +172,9 @@ */
/* #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE */ -/*#define CONFIG_SYS_GBL_DATA_SIZE 256*/ -#define CONFIG_SYS_GBL_DATA_SIZE 128 #define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
/* diff --git a/include/configs/ADCIOP.h b/include/configs/ADCIOP.h index c4bc151..6f12c8d 100644 --- a/include/configs/ADCIOP.h +++ b/include/configs/ADCIOP.h @@ -115,8 +115,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR 0x00df0000 /* inside of SDRAM */ #define CONFIG_SYS_INIT_RAM_SIZE 0x0f00 /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/AMX860.h b/include/configs/AMX860.h index f5fa648..e7c6f96 100644 --- a/include/configs/AMX860.h +++ b/include/configs/AMX860.h @@ -139,8 +139,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/AP1000.h b/include/configs/AP1000.h index 31df89c..9e5490d 100644 --- a/include/configs/AP1000.h +++ b/include/configs/AP1000.h @@ -210,8 +210,7 @@
#define CONFIG_SYS_INIT_RAM_ADDR 0x400000 /* inside of SDRAM */ #define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/APC405.h b/include/configs/APC405.h index af3223b..0adf3ed 100644 --- a/include/configs/APC405.h +++ b/include/configs/APC405.h @@ -421,8 +421,7 @@
#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ #define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* reserved bytes for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) /* reserve some memory for BOOT limit info */ #define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_GBL_DATA_OFFSET - 16)
diff --git a/include/configs/AR405.h b/include/configs/AR405.h index 1f7e79e..4963e9f 100644 --- a/include/configs/AR405.h +++ b/include/configs/AR405.h @@ -267,8 +267,7 @@
#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 /* use data cache */ #define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#endif /* __CONFIG_H */ diff --git a/include/configs/ASH405.h b/include/configs/ASH405.h index a818070..ee80d9d 100644 --- a/include/configs/ASH405.h +++ b/include/configs/ASH405.h @@ -326,8 +326,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ #define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */
/*----------------------------------------------------------------------- diff --git a/include/configs/ATUM8548.h b/include/configs/ATUM8548.h index 261aff1..78757ec 100644 --- a/include/configs/ATUM8548.h +++ b/include/configs/ATUM8548.h @@ -195,8 +195,7 @@
#define CONFIG_SYS_INIT_L2_ADDR 0xf8f80000 /* relocate boot L2SRAM */
-#define CONFIG_SYS_GBL_DATA_SIZE 128 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ diff --git a/include/configs/Adder.h b/include/configs/Adder.h index 71e36c6..48e6df5 100644 --- a/include/configs/Adder.h +++ b/include/configs/Adder.h @@ -171,8 +171,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* Size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/Alaska8220.h b/include/configs/Alaska8220.h index 7ede318..e050992 100644 --- a/include/configs/Alaska8220.h +++ b/include/configs/Alaska8220.h @@ -248,8 +248,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR (CONFIG_SYS_MBAR + 0x20000) #define CONFIG_SYS_INIT_RAM_SIZE 0x8000 /* Size of used area in DPRAM */
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/B2.h b/include/configs/B2.h index ca7350d..7846a92 100644 --- a/include/configs/B2.h +++ b/include/configs/B2.h @@ -53,7 +53,6 @@ #define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Monitor */ #define CONFIG_ENV_SIZE 1024 /* 1024 bytes may be used for env vars*/ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024 ) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
/* * Hardware drivers diff --git a/include/configs/BAB7xx.h b/include/configs/BAB7xx.h index c557197..1497cae 100644 --- a/include/configs/BAB7xx.h +++ b/include/configs/BAB7xx.h @@ -200,8 +200,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR 0x00fd0000 /* above the memtest region */ #define CONFIG_SYS_INIT_RAM_SIZE 0x4000 -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for init data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* diff --git a/include/configs/BC3450.h b/include/configs/BC3450.h index 563da68..a833893 100644 --- a/include/configs/BC3450.h +++ b/include/configs/BC3450.h @@ -389,8 +389,7 @@ # define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE #endif /*CONFIG_POST*/
-#define CONFIG_SYS_GBL_DATA_SIZE 128 /* Bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/BMW.h b/include/configs/BMW.h index 234cc20..8398b29 100644 --- a/include/configs/BMW.h +++ b/include/configs/BMW.h @@ -151,8 +151,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_SDRAM_BASE + CONFIG_SYS_MONITOR_LEN #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* diff --git a/include/configs/CANBT.h b/include/configs/CANBT.h index d67b659..b27ef64 100644 --- a/include/configs/CANBT.h +++ b/include/configs/CANBT.h @@ -224,8 +224,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR 0x00ef0000 /* inside of SDRAM */ #define CONFIG_SYS_INIT_RAM_SIZE 0x0f00 /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#endif /* __CONFIG_H */ diff --git a/include/configs/CATcenter.h b/include/configs/CATcenter.h index 7442e3c..ac70d15 100644 --- a/include/configs/CATcenter.h +++ b/include/configs/CATcenter.h @@ -516,8 +516,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ #define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */
/*----------------------------------------------------------------------- diff --git a/include/configs/CMS700.h b/include/configs/CMS700.h index 34478bb..daaf624 100644 --- a/include/configs/CMS700.h +++ b/include/configs/CMS700.h @@ -288,8 +288,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ #define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */
/*----------------------------------------------------------------------- diff --git a/include/configs/CPC45.h b/include/configs/CPC45.h index 8502542..6a88d26 100644 --- a/include/configs/CPC45.h +++ b/include/configs/CPC45.h @@ -153,11 +153,10 @@
/* Size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_SIZE 128
/* * NS16550 Configuration diff --git a/include/configs/CPCI2DP.h b/include/configs/CPCI2DP.h index b5edc03..99ace67 100644 --- a/include/configs/CPCI2DP.h +++ b/include/configs/CPCI2DP.h @@ -260,8 +260,7 @@
/*----------------------------------------------------------------------- diff --git a/include/configs/CPCI405.h b/include/configs/CPCI405.h index df45b12..426fc57 100644 --- a/include/configs/CPCI405.h +++ b/include/configs/CPCI405.h @@ -336,8 +336,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR 0x00df0000 /* inside of SDRAM */ #endif #define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#endif /* __CONFIG_H */ diff --git a/include/configs/CPCI4052.h b/include/configs/CPCI4052.h index 9a4e5f8..8f48ded 100644 --- a/include/configs/CPCI4052.h +++ b/include/configs/CPCI4052.h @@ -397,8 +397,7 @@
#endif /* __CONFIG_H */ diff --git a/include/configs/CPCI405AB.h b/include/configs/CPCI405AB.h index fb14cd3..a042abf 100644 --- a/include/configs/CPCI405AB.h +++ b/include/configs/CPCI405AB.h @@ -389,8 +389,7 @@
#endif /* __CONFIG_H */ diff --git a/include/configs/CPCI405DT.h b/include/configs/CPCI405DT.h index 70af2da..9b99ba8 100644 --- a/include/configs/CPCI405DT.h +++ b/include/configs/CPCI405DT.h @@ -392,8 +392,7 @@
#endif /* __CONFIG_H */ diff --git a/include/configs/CPCI750.h b/include/configs/CPCI750.h index 76172eb..92ffaaa 100644 --- a/include/configs/CPCI750.h +++ b/include/configs/CPCI750.h @@ -267,8 +267,7 @@ /* #define CONFIG_SYS_INIT_RAM_ADDR 0xfba00000*/ /* unused memory region */ #define CONFIG_SYS_INIT_RAM_ADDR 0xf1080000 /* unused memory region */ #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for init data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
#define RELOCATE_INTERNAL_RAM_ADDR #ifdef RELOCATE_INTERNAL_RAM_ADDR diff --git a/include/configs/CPCIISER4.h b/include/configs/CPCIISER4.h index f9badc0..b2ee873 100644 --- a/include/configs/CPCIISER4.h +++ b/include/configs/CPCIISER4.h @@ -250,8 +250,7 @@ #define CONFIG_SYS_INIT_DCACHE_CS 7 /* use cs # 7 for data cache memory */ #define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 /* use data cache */ #define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#endif /* __CONFIG_H */ diff --git a/include/configs/CPU86.h b/include/configs/CPU86.h index 7662b52..ab64ada 100644 --- a/include/configs/CPU86.h +++ b/include/configs/CPU86.h @@ -297,8 +297,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data*/ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/CPU87.h b/include/configs/CPU87.h index 18fdb90..2b1716a 100644 --- a/include/configs/CPU87.h +++ b/include/configs/CPU87.h @@ -312,8 +312,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data*/ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/CRAYL1.h b/include/configs/CRAYL1.h index 146540a..885d42b 100644 --- a/include/configs/CRAYL1.h +++ b/include/configs/CRAYL1.h @@ -229,16 +229,14 @@
#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ #define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 256 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET #else #define CONFIG_SYS_OCM_DATA_ADDR 0xF0000000 #define CONFIG_SYS_OCM_DATA_SIZE 0x1000 #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of On Chip SRAM */ #define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of On Chip SRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET #endif
diff --git a/include/configs/CU824.h b/include/configs/CU824.h index 14970e0..a5c2ce5 100644 --- a/include/configs/CU824.h +++ b/include/configs/CU824.h @@ -141,11 +141,10 @@
/* * NS16550 Configuration diff --git a/include/configs/DASA_SIM.h b/include/configs/DASA_SIM.h index 3d6b95a..3706071 100644 --- a/include/configs/DASA_SIM.h +++ b/include/configs/DASA_SIM.h @@ -116,8 +116,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR 0x00df0000 /* inside of SDRAM */ #define CONFIG_SYS_INIT_RAM_SIZE 0x0f00 /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/DB64360.h b/include/configs/DB64360.h index ba5adda..dbd224c 100644 --- a/include/configs/DB64360.h +++ b/include/configs/DB64360.h @@ -353,8 +353,7 @@ ip=${ipaddr}:${serverip}${bootargs_end}; bootm 0x400000;\0" #define CONFIG_SYS_INIT_RAM_LOCK #define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 /* unused memory region */ #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for init data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
#define RELOCATE_INTERNAL_RAM_ADDR #ifdef RELOCATE_INTERNAL_RAM_ADDR diff --git a/include/configs/DB64460.h b/include/configs/DB64460.h index 6586f23..321692b 100644 --- a/include/configs/DB64460.h +++ b/include/configs/DB64460.h @@ -291,8 +291,7 @@ ip=${ipaddr}:${serverip}${bootargs_end}; bootm 0x400000;\0" #define CONFIG_SYS_INIT_RAM_LOCK #define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 /* unused memory region */ #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for init data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
#define RELOCATE_INTERNAL_RAM_ADDR #ifdef RELOCATE_INTERNAL_RAM_ADDR diff --git a/include/configs/DP405.h b/include/configs/DP405.h index 2bf0799..ecdf93f 100644 --- a/include/configs/DP405.h +++ b/include/configs/DP405.h @@ -230,8 +230,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ #define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */
/*----------------------------------------------------------------------- diff --git a/include/configs/DU405.h b/include/configs/DU405.h index bb03f23..1493f75 100644 --- a/include/configs/DU405.h +++ b/include/configs/DU405.h @@ -287,8 +287,7 @@
#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ #define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#endif /* __CONFIG_H */ diff --git a/include/configs/DU440.h b/include/configs/DU440.h index 9146ad2..ceab604 100644 --- a/include/configs/DU440.h +++ b/include/configs/DU440.h @@ -80,8 +80,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_BASE /* OCM */
#define CONFIG_SYS_INIT_RAM_SIZE (4 << 10) -#define CONFIG_SYS_GBL_DATA_SIZE 256 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* diff --git a/include/configs/EB+MCF-EV123.h b/include/configs/EB+MCF-EV123.h index d722ae6..0333925 100644 --- a/include/configs/EB+MCF-EV123.h +++ b/include/configs/EB+MCF-EV123.h @@ -154,9 +154,8 @@
#define CONFIG_SYS_INIT_RAM_ADDR 0x20000000 #define CONFIG_SYS_INIT_RAM_SIZE 0x10000 -#define CONFIG_SYS_GBL_DATA_SIZE 64 #define CONFIG_SYS_GBL_DATA_OFFSET \ - (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/ELPPC.h b/include/configs/ELPPC.h index ae9bfc5..8cce70c 100644 --- a/include/configs/ELPPC.h +++ b/include/configs/ELPPC.h @@ -177,8 +177,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR 0x00fd0000 /* above the memtest region */ #define CONFIG_SYS_INIT_RAM_SIZE 0x4000 -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for init data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* diff --git a/include/configs/ELPT860.h b/include/configs/ELPT860.h index 28e396e..c6a17b0 100644 --- a/include/configs/ELPT860.h +++ b/include/configs/ELPT860.h @@ -170,8 +170,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/EP88x.h b/include/configs/EP88x.h index fbc3f25..a0acfd2 100644 --- a/include/configs/EP88x.h +++ b/include/configs/EP88x.h @@ -172,8 +172,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* Size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/ERIC.h b/include/configs/ERIC.h index 4e05e8f..8a0f850 100644 --- a/include/configs/ERIC.h +++ b/include/configs/ERIC.h @@ -353,8 +353,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR 0x00df0000 /* inside of SDRAM */ #define CONFIG_SYS_INIT_RAM_SIZE 0x0f00 /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/ESTEEM192E.h b/include/configs/ESTEEM192E.h index 21d995f..841bf11 100644 --- a/include/configs/ESTEEM192E.h +++ b/include/configs/ESTEEM192E.h @@ -121,8 +121,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
diff --git a/include/configs/ETX094.h b/include/configs/ETX094.h index a9e7fa0..c427093 100644 --- a/include/configs/ETX094.h +++ b/include/configs/ETX094.h @@ -139,8 +139,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/EVB64260.h b/include/configs/EVB64260.h index 94ab1c9..3fda551 100644 --- a/include/configs/EVB64260.h +++ b/include/configs/EVB64260.h @@ -163,8 +163,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for init data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_RAM_LOCK
diff --git a/include/configs/EXBITGEN.h b/include/configs/EXBITGEN.h index 286c38c..f7b5bc9 100644 --- a/include/configs/EXBITGEN.h +++ b/include/configs/EXBITGEN.h @@ -201,8 +201,7 @@ /* Global info and initial stack */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of on-chip SRAM */ #define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#if defined(CONFIG_CMD_KGDB) diff --git a/include/configs/FADS823.h b/include/configs/FADS823.h index dcffac2..57336f9 100644 --- a/include/configs/FADS823.h +++ b/include/configs/FADS823.h @@ -171,8 +171,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/FADS850SAR.h b/include/configs/FADS850SAR.h index e94474d..438d19e 100644 --- a/include/configs/FADS850SAR.h +++ b/include/configs/FADS850SAR.h @@ -118,8 +118,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/FLAGADM.h b/include/configs/FLAGADM.h index 0471f8f..339bb59 100644 --- a/include/configs/FLAGADM.h +++ b/include/configs/FLAGADM.h @@ -129,8 +129,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/FPS850L.h b/include/configs/FPS850L.h index 06b78ee..38d905a 100644 --- a/include/configs/FPS850L.h +++ b/include/configs/FPS850L.h @@ -168,8 +168,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/FPS860L.h b/include/configs/FPS860L.h index 90d5b46..ca0b1cc 100644 --- a/include/configs/FPS860L.h +++ b/include/configs/FPS860L.h @@ -168,8 +168,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/G2000.h b/include/configs/G2000.h index 6723c96..af602ff 100644 --- a/include/configs/G2000.h +++ b/include/configs/G2000.h @@ -356,8 +356,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ #define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */
/*----------------------------------------------------------------------- diff --git a/include/configs/GENIETV.h b/include/configs/GENIETV.h index 929b56e..c5ca279 100644 --- a/include/configs/GENIETV.h +++ b/include/configs/GENIETV.h @@ -162,8 +162,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/HH405.h b/include/configs/HH405.h index 4244a04..a15e686 100644 --- a/include/configs/HH405.h +++ b/include/configs/HH405.h @@ -452,8 +452,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ #define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */
/*----------------------------------------------------------------------- diff --git a/include/configs/HIDDEN_DRAGON.h b/include/configs/HIDDEN_DRAGON.h index 592f4d2..c684cb8 100644 --- a/include/configs/HIDDEN_DRAGON.h +++ b/include/configs/HIDDEN_DRAGON.h @@ -127,19 +127,17 @@ #define CONFIG_SYS_RAMBOOT 1 #define CONFIG_SYS_INIT_RAM_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) #define CONFIG_SYS_INIT_RAM_SIZE 0x10000 -#define CONFIG_SYS_GBL_DATA_SIZE 256 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET #else #undef CONFIG_SYS_RAMBOOT #define CONFIG_SYS_MONITOR_LEN 0x00030000 #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE
#endif
diff --git a/include/configs/HUB405.h b/include/configs/HUB405.h index cc5a9b7..827ecf2 100644 --- a/include/configs/HUB405.h +++ b/include/configs/HUB405.h @@ -325,8 +325,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ #define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */
/*----------------------------------------------------------------------- diff --git a/include/configs/IAD210.h b/include/configs/IAD210.h index 75e152c..27bd146 100644 --- a/include/configs/IAD210.h +++ b/include/configs/IAD210.h @@ -184,8 +184,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/ICU862.h b/include/configs/ICU862.h index 3528d5d..b011d50 100644 --- a/include/configs/ICU862.h +++ b/include/configs/ICU862.h @@ -188,8 +188,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/IDS8247.h b/include/configs/IDS8247.h index d0f6952..8552250 100644 --- a/include/configs/IDS8247.h +++ b/include/configs/IDS8247.h @@ -294,8 +294,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data*/ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/IP860.h b/include/configs/IP860.h index cbece32..ba8d633 100644 --- a/include/configs/IP860.h +++ b/include/configs/IP860.h @@ -152,8 +152,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/IPHASE4539.h b/include/configs/IPHASE4539.h index e19a3df..0af43b6 100644 --- a/include/configs/IPHASE4539.h +++ b/include/configs/IPHASE4539.h @@ -247,8 +247,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/ISPAN.h b/include/configs/ISPAN.h index e78ff06..49c6510 100644 --- a/include/configs/ISPAN.h +++ b/include/configs/ISPAN.h @@ -232,8 +232,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* Size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/IVML24.h b/include/configs/IVML24.h index 28a8ace..b827954 100644 --- a/include/configs/IVML24.h +++ b/include/configs/IVML24.h @@ -154,8 +154,7 @@ # define CONFIG_SYS_INIT_RAM_SIZE 0x3000 /* Size of used area in DPRAM */ #endif
/*----------------------------------------------------------------------- diff --git a/include/configs/IVMS8.h b/include/configs/IVMS8.h index 16628ea..9b0c32a 100644 --- a/include/configs/IVMS8.h +++ b/include/configs/IVMS8.h @@ -150,8 +150,7 @@ # define CONFIG_SYS_INIT_RAM_SIZE 0x3000 /* Size of used area in DPRAM */ #endif
/*----------------------------------------------------------------------- diff --git a/include/configs/IceCube.h b/include/configs/IceCube.h index 8584b34..bc5d761 100644 --- a/include/configs/IceCube.h +++ b/include/configs/IceCube.h @@ -278,8 +278,7 @@ #define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE /* Size of used area in DPRAM */
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/JSE.h b/include/configs/JSE.h index fb35ee6..c38e0d2 100644 --- a/include/configs/JSE.h +++ b/include/configs/JSE.h @@ -61,8 +61,7 @@ /* ... give it the whole init ram */ # define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* ... Shave a bit off the end for global data */ -# define CONFIG_SYS_GBL_DATA_SIZE 128 -# define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +# define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) /* ... and place the stack pointer at the top of what's left. */ # define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
diff --git a/include/configs/KAREF.h b/include/configs/KAREF.h index 82b79c9..fcf66b7 100644 --- a/include/configs/KAREF.h +++ b/include/configs/KAREF.h @@ -81,9 +81,8 @@ #define CONFIG_SYS_OCM_DATA_ADDR CONFIG_SYS_ISRAM_BASE #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_ISRAM_BASE /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* num bytes initial data */
-#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_GBL_DATA_OFFSET - 0x4)
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Rsrv 256kB for Mon */ diff --git a/include/configs/KUP4K.h b/include/configs/KUP4K.h index 1bcf581..c0035e6 100644 --- a/include/configs/KUP4K.h +++ b/include/configs/KUP4K.h @@ -212,8 +212,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/KUP4X.h b/include/configs/KUP4X.h index b220991..5084ccc 100644 --- a/include/configs/KUP4X.h +++ b/include/configs/KUP4X.h @@ -228,8 +228,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/LANTEC.h b/include/configs/LANTEC.h index 4357062..0f4ea41 100644 --- a/include/configs/LANTEC.h +++ b/include/configs/LANTEC.h @@ -156,8 +156,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/M5208EVBE.h b/include/configs/M5208EVBE.h index d251625..a45cdc1 100644 --- a/include/configs/M5208EVBE.h +++ b/include/configs/M5208EVBE.h @@ -148,8 +148,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR 0x80000000 #define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in internal SRAM */ #define CONFIG_SYS_INIT_RAM_CTRL 0x221 -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) - 0x10) +#define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) - 0x10) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* diff --git a/include/configs/M52277EVB.h b/include/configs/M52277EVB.h index a4420eb..bb3b474 100644 --- a/include/configs/M52277EVB.h +++ b/include/configs/M52277EVB.h @@ -209,8 +209,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR 0x80000000 #define CONFIG_SYS_INIT_RAM_SIZE 0x8000 /* Size of used area in internal SRAM */ #define CONFIG_SYS_INIT_RAM_CTRL 0x221 -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) - 32) +#define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) - 32) #define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_GBL_DATA_OFFSET - 32) #define CONFIG_SYS_SBFHDR_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - 32)
diff --git a/include/configs/M5235EVB.h b/include/configs/M5235EVB.h index 6d624dc..cd12d2b 100644 --- a/include/configs/M5235EVB.h +++ b/include/configs/M5235EVB.h @@ -169,8 +169,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR 0x20000000 #define CONFIG_SYS_INIT_RAM_SIZE 0x10000 /* Size of used area in internal SRAM */ #define CONFIG_SYS_INIT_RAM_CTRL 0x21 -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE - 0x10) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE - 0x10) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/M5249EVB.h b/include/configs/M5249EVB.h index 9aae2c6..104fcde 100644 --- a/include/configs/M5249EVB.h +++ b/include/configs/M5249EVB.h @@ -110,8 +110,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR 0x20000000 #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in internal SRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#define CONFIG_ENV_IS_IN_FLASH 1 diff --git a/include/configs/M5253DEMO.h b/include/configs/M5253DEMO.h index 64b0b69..f2f3159 100644 --- a/include/configs/M5253DEMO.h +++ b/include/configs/M5253DEMO.h @@ -168,8 +168,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR 0x20000000 #define CONFIG_SYS_INIT_RAM_SIZE 0x10000 /* Size of used area in internal SRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* diff --git a/include/configs/M5253EVBE.h b/include/configs/M5253EVBE.h index 1dee3ef..dd8a560 100644 --- a/include/configs/M5253EVBE.h +++ b/include/configs/M5253EVBE.h @@ -136,8 +136,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR 0x20000000 #define CONFIG_SYS_INIT_RAM_SIZE 0x10000 /* Size of used area in internal SRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* diff --git a/include/configs/M5271EVB.h b/include/configs/M5271EVB.h index 41b1314..992d738 100644 --- a/include/configs/M5271EVB.h +++ b/include/configs/M5271EVB.h @@ -188,8 +188,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR 0x20000000 #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in internal SRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* diff --git a/include/configs/M5272C3.h b/include/configs/M5272C3.h index dd5ca08..b3c774f 100644 --- a/include/configs/M5272C3.h +++ b/include/configs/M5272C3.h @@ -164,8 +164,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR 0x20000000 #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in internal SRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/M5275EVB.h b/include/configs/M5275EVB.h index f879042..56a760f 100644 --- a/include/configs/M5275EVB.h +++ b/include/configs/M5275EVB.h @@ -174,8 +174,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR 0x20000000 #define CONFIG_SYS_INIT_RAM_SIZE 0x10000 /* Size of used area in internal SRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 1000 /* bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/M5282EVB.h b/include/configs/M5282EVB.h index 9aecd12..0c10480 100644 --- a/include/configs/M5282EVB.h +++ b/include/configs/M5282EVB.h @@ -155,8 +155,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR 0x20000000 #define CONFIG_SYS_INIT_RAM_SIZE 0x10000 /* Size of used area in internal SRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/M53017EVB.h b/include/configs/M53017EVB.h index 17efb63..d205e7c 100644 --- a/include/configs/M53017EVB.h +++ b/include/configs/M53017EVB.h @@ -169,8 +169,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR 0x80000000 #define CONFIG_SYS_INIT_RAM_SIZE 0x20000 /* Size of used area in internal SRAM */ #define CONFIG_SYS_INIT_RAM_CTRL 0x221 -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) - 0x10) +#define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) - 0x10) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* diff --git a/include/configs/M5329EVB.h b/include/configs/M5329EVB.h index 6717ef3..7ae0fad 100644 --- a/include/configs/M5329EVB.h +++ b/include/configs/M5329EVB.h @@ -164,8 +164,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR 0x80000000 #define CONFIG_SYS_INIT_RAM_SIZE 0x8000 /* Size of used area in internal SRAM */ #define CONFIG_SYS_INIT_RAM_CTRL 0x221 -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) - 0x10) +#define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) - 0x10) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/M5373EVB.h b/include/configs/M5373EVB.h index 441496b..7086a1b 100644 --- a/include/configs/M5373EVB.h +++ b/include/configs/M5373EVB.h @@ -164,8 +164,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR 0x80000000 #define CONFIG_SYS_INIT_RAM_SIZE 0x8000 /* Size of used area in internal SRAM */ #define CONFIG_SYS_INIT_RAM_CTRL 0x221 -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) - 0x10) +#define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) - 0x10) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/M54451EVB.h b/include/configs/M54451EVB.h index 4c45517..37715c5 100644 --- a/include/configs/M54451EVB.h +++ b/include/configs/M54451EVB.h @@ -222,8 +222,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR 0x80000000 #define CONFIG_SYS_INIT_RAM_SIZE 0x8000 /* Size of used area in internal SRAM */ #define CONFIG_SYS_INIT_RAM_CTRL 0x221 -#define CONFIG_SYS_GBL_DATA_SIZE 256 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) - 32) +#define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) - 32) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET #define CONFIG_SYS_SBFHDR_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - 32)
diff --git a/include/configs/M54455EVB.h b/include/configs/M54455EVB.h index 6a7c92c..86faa3d 100644 --- a/include/configs/M54455EVB.h +++ b/include/configs/M54455EVB.h @@ -281,8 +281,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR 0x80000000 #define CONFIG_SYS_INIT_RAM_SIZE 0x8000 /* Size of used area in internal SRAM */ #define CONFIG_SYS_INIT_RAM_CTRL 0x221 -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) - 32) +#define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) - 32) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET #define CONFIG_SYS_SBFHDR_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - 32)
diff --git a/include/configs/M5475EVB.h b/include/configs/M5475EVB.h index ec2b075..5f6eb55 100644 --- a/include/configs/M5475EVB.h +++ b/include/configs/M5475EVB.h @@ -215,8 +215,7 @@ #define CONFIG_SYS_INIT_RAM1_ADDR (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_RAM_SIZE) #define CONFIG_SYS_INIT_RAM1_END 0x1000 /* End of used area in internal SRAM */ #define CONFIG_SYS_INIT_RAM1_CTRL 0x21 -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) - 0x10) +#define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) - 0x10) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/M5485EVB.h b/include/configs/M5485EVB.h index 92fe316..e178e35 100644 --- a/include/configs/M5485EVB.h +++ b/include/configs/M5485EVB.h @@ -201,8 +201,7 @@ #define CONFIG_SYS_INIT_RAM1_ADDR (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_RAM_SIZE) #define CONFIG_SYS_INIT_RAM1_END 0x1000 /* End of used area in internal SRAM */ #define CONFIG_SYS_INIT_RAM1_CTRL 0x21 -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) - 0x10) +#define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) - 0x10) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/MBX.h b/include/configs/MBX.h index 647e9dd..cb5b023 100644 --- a/include/configs/MBX.h +++ b/include/configs/MBX.h @@ -145,8 +145,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2f00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_VPD_SIZE 256 /* size in bytes reserved for vpd buffer */ #define CONFIG_SYS_INIT_VPD_OFFSET (CONFIG_SYS_GBL_DATA_OFFSET - CONFIG_SYS_INIT_VPD_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_INIT_VPD_OFFSET-8) diff --git a/include/configs/MBX860T.h b/include/configs/MBX860T.h index 26d1b22..969ba7e 100644 --- a/include/configs/MBX860T.h +++ b/include/configs/MBX860T.h @@ -99,8 +99,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2f00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_VPD_SIZE 256 /* size in bytes reserved for vpd buffer */ #define CONFIG_SYS_INIT_VPD_OFFSET (CONFIG_SYS_GBL_DATA_OFFSET - CONFIG_SYS_INIT_VPD_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_INIT_VPD_OFFSET-8) diff --git a/include/configs/METROBOX.h b/include/configs/METROBOX.h index abc7ad2..9b83e21 100644 --- a/include/configs/METROBOX.h +++ b/include/configs/METROBOX.h @@ -143,9 +143,8 @@ #define CONFIG_SYS_OCM_DATA_ADDR CONFIG_SYS_ISRAM_BASE #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_ISRAM_BASE /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* num bytes initial data */
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Rsrv 256kB for Mon */ diff --git a/include/configs/MHPC.h b/include/configs/MHPC.h index a4a5269..b9c1638 100644 --- a/include/configs/MHPC.h +++ b/include/configs/MHPC.h @@ -180,8 +180,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/MIP405.h b/include/configs/MIP405.h index a8d297e..ce9273b 100644 --- a/include/configs/MIP405.h +++ b/include/configs/MIP405.h @@ -309,8 +309,7 @@ #define CONFIG_SYS_OCM_DATA_SIZE 0x1000 #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of On Chip SRAM */ #define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of On Chip SRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) /* reserve some memory for POST and BOOT limit info */ #define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_GBL_DATA_OFFSET - 32)
diff --git a/include/configs/ML2.h b/include/configs/ML2.h index c22824f..ed78387 100644 --- a/include/configs/ML2.h +++ b/include/configs/ML2.h @@ -212,8 +212,7 @@
#define CONFIG_SYS_INIT_RAM_ADDR 0x800000 /* inside of SDRAM */ #define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/MOUSSE.h b/include/configs/MOUSSE.h index 4a407b1..9529c87 100644 --- a/include/configs/MOUSSE.h +++ b/include/configs/MOUSSE.h @@ -158,8 +158,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_SDRAM_BASE + CONFIG_SYS_MONITOR_LEN #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* diff --git a/include/configs/MPC8260ADS.h b/include/configs/MPC8260ADS.h index c3ab8a7..2225b46 100644 --- a/include/configs/MPC8260ADS.h +++ b/include/configs/MPC8260ADS.h @@ -349,8 +349,7 @@
#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#ifdef CONFIG_SYS_LOWBOOT diff --git a/include/configs/MPC8266ADS.h b/include/configs/MPC8266ADS.h index 456f008..5794473 100644 --- a/include/configs/MPC8266ADS.h +++ b/include/configs/MPC8266ADS.h @@ -383,8 +383,7 @@
/* Use this HRCW for booting from address 0xfe00000 (JP3 in setting 1-2) */ diff --git a/include/configs/MPC8308RDB.h b/include/configs/MPC8308RDB.h index b111015..3ff175c 100644 --- a/include/configs/MPC8308RDB.h +++ b/include/configs/MPC8308RDB.h @@ -213,9 +213,8 @@ #define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xE6000000 /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 0x100 /* num bytes initial data */ #define CONFIG_SYS_GBL_DATA_OFFSET \ - (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
/* * Local Bus Configuration & Clock Setup diff --git a/include/configs/MPC8313ERDB.h b/include/configs/MPC8313ERDB.h index b141fdf..1201133 100644 --- a/include/configs/MPC8313ERDB.h +++ b/include/configs/MPC8313ERDB.h @@ -210,8 +210,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR 0xFD000000 /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM*/
-#define CONFIG_SYS_GBL_DATA_SIZE 0x100 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* CONFIG_SYS_MONITOR_LEN must be a multiple of CONFIG_ENV_SECT_SIZE */ diff --git a/include/configs/MPC8315ERDB.h b/include/configs/MPC8315ERDB.h index 48167c4..6476c4c 100644 --- a/include/configs/MPC8315ERDB.h +++ b/include/configs/MPC8315ERDB.h @@ -192,8 +192,7 @@ #define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xE6000000 /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 0x100 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
/* * Local Bus Configuration & Clock Setup diff --git a/include/configs/MPC8323ERDB.h b/include/configs/MPC8323ERDB.h index 857181a..1191eea 100644 --- a/include/configs/MPC8323ERDB.h +++ b/include/configs/MPC8323ERDB.h @@ -166,8 +166,7 @@ #define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xE6000000 /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 0x100 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
/* * Local Bus Configuration & Clock Setup diff --git a/include/configs/MPC832XEMDS.h b/include/configs/MPC832XEMDS.h index ade5b6d..affa3a9 100644 --- a/include/configs/MPC832XEMDS.h +++ b/include/configs/MPC832XEMDS.h @@ -153,8 +153,7 @@ #define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xE6000000 /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 0x100 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
/* * Local Bus Configuration & Clock Setup diff --git a/include/configs/MPC8349EMDS.h b/include/configs/MPC8349EMDS.h index 5ac20f2..45b6b5f 100644 --- a/include/configs/MPC8349EMDS.h +++ b/include/configs/MPC8349EMDS.h @@ -195,8 +195,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR 0xFD000000 /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM*/
#define CONFIG_SYS_MONITOR_LEN (384 * 1024) /* Reserve 384 kB for Mon */ diff --git a/include/configs/MPC8349ITX.h b/include/configs/MPC8349ITX.h index 26e9b82..de233ff 100644 --- a/include/configs/MPC8349ITX.h +++ b/include/configs/MPC8349ITX.h @@ -308,8 +308,7 @@ boards, we say we have two, but don't display a message if we find only one. */ #define CONFIG_SYS_INIT_RAM_ADDR 0xFD000000 /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM*/
/* CONFIG_SYS_MONITOR_LEN must be a multiple of CONFIG_ENV_SECT_SIZE */ diff --git a/include/configs/MPC8360EMDS.h b/include/configs/MPC8360EMDS.h index 29e1d31..7b82c43 100644 --- a/include/configs/MPC8360EMDS.h +++ b/include/configs/MPC8360EMDS.h @@ -182,8 +182,7 @@ #define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xE6000000 /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 0x100 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
/* * Local Bus Configuration & Clock Setup diff --git a/include/configs/MPC8360ERDK.h b/include/configs/MPC8360ERDK.h index b830a0f..b0cdc02 100644 --- a/include/configs/MPC8360ERDK.h +++ b/include/configs/MPC8360ERDK.h @@ -173,8 +173,7 @@ #define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xE6000000 /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 0x100 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
/* * Local Bus Configuration & Clock Setup diff --git a/include/configs/MPC837XEMDS.h b/include/configs/MPC837XEMDS.h index e482646..c237991 100644 --- a/include/configs/MPC837XEMDS.h +++ b/include/configs/MPC837XEMDS.h @@ -216,8 +216,7 @@ #define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xE6000000 /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 0x100 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
/* * Local Bus Configuration & Clock Setup diff --git a/include/configs/MPC837XERDB.h b/include/configs/MPC837XERDB.h index b5c05fe..385c7c3 100644 --- a/include/configs/MPC837XERDB.h +++ b/include/configs/MPC837XERDB.h @@ -239,8 +239,7 @@ #define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xE6000000 /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 0x100 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
/* * Local Bus Configuration & Clock Setup diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index 6f4c1bf..8410bb7 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -305,9 +305,8 @@ #define CONFIG_SYS_INIT_RAM_ADDR 0xffd00000 /* Initial L1 address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x00004000 /* Size of used area in RAM */
-#define CONFIG_SYS_GBL_DATA_SIZE 128 /* num bytes initial data */ #define CONFIG_SYS_GBL_DATA_OFFSET \ - (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ diff --git a/include/configs/MPC8540ADS.h b/include/configs/MPC8540ADS.h index 2d9e788..9386f64 100644 --- a/include/configs/MPC8540ADS.h +++ b/include/configs/MPC8540ADS.h @@ -234,8 +234,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR 0xe4010000 /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in RAM */
-#define CONFIG_SYS_GBL_DATA_SIZE 128 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ diff --git a/include/configs/MPC8540EVAL.h b/include/configs/MPC8540EVAL.h index dcb1127..a968949 100644 --- a/include/configs/MPC8540EVAL.h +++ b/include/configs/MPC8540EVAL.h @@ -166,8 +166,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in RAM */
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ diff --git a/include/configs/MPC8541CDS.h b/include/configs/MPC8541CDS.h index ffaa8d3..12ce6f7 100644 --- a/include/configs/MPC8541CDS.h +++ b/include/configs/MPC8541CDS.h @@ -256,8 +256,7 @@ extern unsigned long get_clock_freq(void); #define CONFIG_SYS_INIT_RAM_ADDR 0xe4010000 /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in RAM */
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ diff --git a/include/configs/MPC8544DS.h b/include/configs/MPC8544DS.h index cd5f181..e94822e 100644 --- a/include/configs/MPC8544DS.h +++ b/include/configs/MPC8544DS.h @@ -206,8 +206,7 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_SYS_INIT_RAM_SIZE 0x00004000 /* Size of used area in RAM */
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ diff --git a/include/configs/MPC8548CDS.h b/include/configs/MPC8548CDS.h index 031e130..b221a5c 100644 --- a/include/configs/MPC8548CDS.h +++ b/include/configs/MPC8548CDS.h @@ -277,8 +277,7 @@ extern unsigned long get_clock_freq(void);
#define CONFIG_SYS_INIT_L2_ADDR 0xf8f80000 /* relocate boot L2SRAM */
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ diff --git a/include/configs/MPC8555CDS.h b/include/configs/MPC8555CDS.h index 13df407..334a410 100644 --- a/include/configs/MPC8555CDS.h +++ b/include/configs/MPC8555CDS.h @@ -254,8 +254,7 @@ extern unsigned long get_clock_freq(void); #define CONFIG_SYS_INIT_RAM_ADDR 0xe4010000 /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in RAM */
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ diff --git a/include/configs/MPC8560ADS.h b/include/configs/MPC8560ADS.h index b2d7892..744e4a3 100644 --- a/include/configs/MPC8560ADS.h +++ b/include/configs/MPC8560ADS.h @@ -231,8 +231,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR 0xe4010000 /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in RAM */
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ diff --git a/include/configs/MPC8568MDS.h b/include/configs/MPC8568MDS.h index 6e0ff7e..281918b 100644 --- a/include/configs/MPC8568MDS.h +++ b/include/configs/MPC8568MDS.h @@ -237,8 +237,7 @@ extern unsigned long get_clock_freq(void); #define CONFIG_SYS_INIT_RAM_ADDR 0xe4010000 /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in RAM */
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ diff --git a/include/configs/MPC8569MDS.h b/include/configs/MPC8569MDS.h index 6ef30c5..6a15da5 100644 --- a/include/configs/MPC8569MDS.h +++ b/include/configs/MPC8569MDS.h @@ -270,9 +270,8 @@ extern unsigned long get_clock_freq(void); #define CONFIG_SYS_INIT_RAM_ADDR 0xe4010000 /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in RAM */
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index 9685df8..f949cc2 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -270,8 +270,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR 0xffd00000 /* Initial L1 address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x00004000 /* Size of used area in RAM */
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ diff --git a/include/configs/MPC8610HPCD.h b/include/configs/MPC8610HPCD.h index b023f81..17dac6c 100644 --- a/include/configs/MPC8610HPCD.h +++ b/include/configs/MPC8610HPCD.h @@ -215,8 +215,7 @@ #endif #define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in RAM */
#define CONFIG_SYS_MONITOR_LEN (512 * 1024) /* Reserve 512 KB for Mon */ diff --git a/include/configs/MPC8641HPCN.h b/include/configs/MPC8641HPCN.h index 9c6f840..ab3ae5b 100644 --- a/include/configs/MPC8641HPCN.h +++ b/include/configs/MPC8641HPCN.h @@ -273,8 +273,7 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #endif #define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in RAM */
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ diff --git a/include/configs/MUSENKI.h b/include/configs/MUSENKI.h index 79bd608..27ebceb 100644 --- a/include/configs/MUSENKI.h +++ b/include/configs/MUSENKI.h @@ -155,11 +155,9 @@ */
/* #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE */ -/*#define CONFIG_SYS_GBL_DATA_SIZE 256*/ -#define CONFIG_SYS_GBL_DATA_SIZE 128 #define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
/* diff --git a/include/configs/MVBC_P.h b/include/configs/MVBC_P.h index 88bfc81..6f4d187 100644 --- a/include/configs/MVBC_P.h +++ b/include/configs/MVBC_P.h @@ -237,8 +237,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR MPC5XXX_SRAM #define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE
-#define CONFIG_SYS_GBL_DATA_SIZE 128 -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/MVBLM7.h b/include/configs/MVBLM7.h index c2fe620..c201310 100644 --- a/include/configs/MVBLM7.h +++ b/include/configs/MVBLM7.h @@ -125,8 +125,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR 0xFD000000 /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM*/
/* CONFIG_SYS_MONITOR_LEN must be a multiple of CONFIG_ENV_SECT_SIZE */ diff --git a/include/configs/MVBLUE.h b/include/configs/MVBLUE.h index cd1bc80..3aed447 100644 --- a/include/configs/MVBLUE.h +++ b/include/configs/MVBLUE.h @@ -215,8 +215,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 -#define CONFIG_SYS_GBL_DATA_SIZE 128 -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
/* * Low Level Configuration Settings diff --git a/include/configs/MVS1.h b/include/configs/MVS1.h index 1e4e6d9..46151da 100644 --- a/include/configs/MVS1.h +++ b/include/configs/MVS1.h @@ -141,8 +141,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/MVSMR.h b/include/configs/MVSMR.h index 7582735..f7fd9b2 100644 --- a/include/configs/MVSMR.h +++ b/include/configs/MVSMR.h @@ -206,9 +206,8 @@ #define CONFIG_SYS_INIT_RAM_ADDR MPC5XXX_SRAM #define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE
-#define CONFIG_SYS_GBL_DATA_SIZE 128 #define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ - CONFIG_SYS_GBL_DATA_SIZE) + GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/MigoR.h b/include/configs/MigoR.h index 6083892..8a6b8d0 100644 --- a/include/configs/MigoR.h +++ b/include/configs/MigoR.h @@ -99,7 +99,6 @@ /* Size of DRAM reserved for malloc() use */ #define CONFIG_SYS_MALLOC_LEN (256 * 1024) /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_SIZE (256) #define CONFIG_SYS_BOOTMAPSZ (8 * 1024 * 1024)
/* FLASH */ diff --git a/include/configs/NETPHONE.h b/include/configs/NETPHONE.h index fd6ab59..04f0f0b 100644 --- a/include/configs/NETPHONE.h +++ b/include/configs/NETPHONE.h @@ -173,8 +173,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x3000 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/NETTA.h b/include/configs/NETTA.h index 2d38a1b..795c0f6 100644 --- a/include/configs/NETTA.h +++ b/include/configs/NETTA.h @@ -186,8 +186,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x3000 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/NETTA2.h b/include/configs/NETTA2.h index 5415b5c..d02dca9 100644 --- a/include/configs/NETTA2.h +++ b/include/configs/NETTA2.h @@ -174,8 +174,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x3000 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/NETVIA.h b/include/configs/NETVIA.h index ea838ae..a92e3a6 100644 --- a/include/configs/NETVIA.h +++ b/include/configs/NETVIA.h @@ -154,8 +154,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x3000 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/NSCU.h b/include/configs/NSCU.h index 743b6dd..7e3ba2a 100644 --- a/include/configs/NSCU.h +++ b/include/configs/NSCU.h @@ -176,8 +176,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/NX823.h b/include/configs/NX823.h index 23a30f7..bb0d3a3 100644 --- a/include/configs/NX823.h +++ b/include/configs/NX823.h @@ -118,8 +118,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/OCRTC.h b/include/configs/OCRTC.h index 6c6828a..65a366a 100644 --- a/include/configs/OCRTC.h +++ b/include/configs/OCRTC.h @@ -298,8 +298,7 @@
#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ #define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#endif /* __CONFIG_H */ diff --git a/include/configs/ORSG.h b/include/configs/ORSG.h index 5ab9942..c2e3b2b 100644 --- a/include/configs/ORSG.h +++ b/include/configs/ORSG.h @@ -294,8 +294,7 @@
#endif /* __CONFIG_H */ diff --git a/include/configs/OXC.h b/include/configs/OXC.h index 0f362f1..bc8e718 100644 --- a/include/configs/OXC.h +++ b/include/configs/OXC.h @@ -150,8 +150,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 #define CONFIG_SYS_INIT_RAM_SIZE 0x1000
#define CONFIG_SYS_MALLOC_LEN (512 << 10) /* Reserve 512 kB for malloc() */ diff --git a/include/configs/P1022DS.h b/include/configs/P1022DS.h index bc5b73e..6c8579f 100644 --- a/include/configs/P1022DS.h +++ b/include/configs/P1022DS.h @@ -155,9 +155,8 @@ #define CONFIG_SYS_INIT_RAM_ADDR 0xffd00000 /* Initial L1 address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x00004000 /* Size of used area in RAM */
#define CONFIG_SYS_MONITOR_LEN (512 * 1024) diff --git a/include/configs/P1_P2_RDB.h b/include/configs/P1_P2_RDB.h index 7f05618..b99f383 100644 --- a/include/configs/P1_P2_RDB.h +++ b/include/configs/P1_P2_RDB.h @@ -213,9 +213,8 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_SYS_INIT_RAM_ADDR 0xffd00000 /* stack in RAM */ #define CONFIG_SYS_INIT_RAM_SIZE 0x00004000 /* Size of used area in RAM */
-#define CONFIG_SYS_GBL_DATA_SIZE 128 /* num bytes initial data */ #define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE \ - - CONFIG_SYS_GBL_DATA_SIZE) + - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon*/ diff --git a/include/configs/P2020DS.h b/include/configs/P2020DS.h index 6e26f7a..0af2152 100644 --- a/include/configs/P2020DS.h +++ b/include/configs/P2020DS.h @@ -274,8 +274,7 @@ #endif #define CONFIG_SYS_INIT_RAM_SIZE 0x00004000 /* Size of used area in RAM */
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ diff --git a/include/configs/P3G4.h b/include/configs/P3G4.h index 54212f1..eb641f5 100644 --- a/include/configs/P3G4.h +++ b/include/configs/P3G4.h @@ -186,8 +186,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for init data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_RAM_LOCK
diff --git a/include/configs/PATI.h b/include/configs/PATI.h index 8887f97..da2d602 100644 --- a/include/configs/PATI.h +++ b/include/configs/PATI.h @@ -133,8 +133,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR (CONFIG_SYS_IMMR + 0x003f9800) /* Physical start adress of internal MPC555 writable RAM */ #define CONFIG_SYS_INIT_RAM_SIZE (CONFIG_SYS_IMMR + 0x003fffff) /* Physical end adress of internal MPC555 used RAM area */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* Size in bytes reserved for initial global data */ -#define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_INIT_RAM_ADDR) - CONFIG_SYS_GBL_DATA_SIZE) /* Offset from the beginning of ram */ +#define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_INIT_RAM_ADDR) - GENERATED_GBL_DATA_SIZE) /* Offset from the beginning of ram */ #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_IMMR + 0x03fa000) /* Physical start adress of inital stack */ /* * Start addresses for the final memory configuration diff --git a/include/configs/PCI405.h b/include/configs/PCI405.h index 91c8f53..6be5c25 100644 --- a/include/configs/PCI405.h +++ b/include/configs/PCI405.h @@ -309,8 +309,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ #define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */
#endif /* __CONFIG_H */ diff --git a/include/configs/PCI5441.h b/include/configs/PCI5441.h index 3e7e74b..70775e7 100644 --- a/include/configs/PCI5441.h +++ b/include/configs/PCI5441.h @@ -60,12 +60,11 @@ * -The stack is placed below global data (&grows down). *----------------------------------------------------------------------*/ #define CONFIG_SYS_MONITOR_LEN (128 * 1024) /* Reserve 128k */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* Global data size rsvd*/ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024)
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_MALLOC_BASE (CONFIG_SYS_MONITOR_BASE - CONFIG_SYS_MALLOC_LEN) -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_MALLOC_BASE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_MALLOC_BASE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP CONFIG_SYS_GBL_DATA_OFFSET
/*------------------------------------------------------------------------ diff --git a/include/configs/PCIPPC2.h b/include/configs/PCIPPC2.h index ea02311..e778c59 100644 --- a/include/configs/PCIPPC2.h +++ b/include/configs/PCIPPC2.h @@ -140,11 +140,10 @@
/* Size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_SIZE 128
#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 #define CONFIG_SYS_INIT_RAM_SIZE 0x8000 -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#define CONFIG_SYS_INIT_RAM_LOCK diff --git a/include/configs/PCIPPC6.h b/include/configs/PCIPPC6.h index 4cf45d3..48911b7 100644 --- a/include/configs/PCIPPC6.h +++ b/include/configs/PCIPPC6.h @@ -142,11 +142,10 @@
#define CONFIG_SYS_INIT_RAM_LOCK diff --git a/include/configs/PIP405.h b/include/configs/PIP405.h index 04062b0..2dc6057 100644 --- a/include/configs/PIP405.h +++ b/include/configs/PIP405.h @@ -259,8 +259,7 @@ #define CONFIG_SYS_OCM_DATA_SIZE 0x1000 #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of On Chip SRAM */ #define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of On Chip SRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*********************************************************************** diff --git a/include/configs/PK1C20.h b/include/configs/PK1C20.h index 8e8c049..b466c4b 100644 --- a/include/configs/PK1C20.h +++ b/include/configs/PK1C20.h @@ -62,12 +62,11 @@ * -The stack is placed below global data (&grows down). *----------------------------------------------------------------------*/ #define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 128k */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* Global data size rsvd*/ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024)
/*------------------------------------------------------------------------ diff --git a/include/configs/PLU405.h b/include/configs/PLU405.h index 421f26a..dcf6293 100644 --- a/include/configs/PLU405.h +++ b/include/configs/PLU405.h @@ -370,8 +370,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ #define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */
/* diff --git a/include/configs/PM520.h b/include/configs/PM520.h index f039e5a..8354e70 100644 --- a/include/configs/PM520.h +++ b/include/configs/PM520.h @@ -236,8 +236,7 @@ #define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE /* Size of used area in DPRAM */
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/PM826.h b/include/configs/PM826.h index 7ac29f2..501f691 100644 --- a/include/configs/PM826.h +++ b/include/configs/PM826.h @@ -294,8 +294,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data*/ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/PM828.h b/include/configs/PM828.h index 565a5d8..1af043d 100644 --- a/include/configs/PM828.h +++ b/include/configs/PM828.h @@ -288,8 +288,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data*/ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/PM854.h b/include/configs/PM854.h index 6c3f7c2..1e2089f 100644 --- a/include/configs/PM854.h +++ b/include/configs/PM854.h @@ -167,8 +167,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR 0xe4010000 /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in RAM */
#define CONFIG_SYS_MONITOR_LEN (512 * 1024) /* Reserve 512 kB for Mon */ diff --git a/include/configs/PM856.h b/include/configs/PM856.h index f5aa77a..d3e8f41 100644 --- a/include/configs/PM856.h +++ b/include/configs/PM856.h @@ -170,8 +170,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR 0xe4010000 /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in RAM */
#define CONFIG_SYS_MONITOR_LEN (512 * 1024) /* Reserve 512 kB for Mon */ diff --git a/include/configs/PMC405.h b/include/configs/PMC405.h index d5794e4..c2db5ea 100644 --- a/include/configs/PMC405.h +++ b/include/configs/PMC405.h @@ -331,9 +331,8 @@ #define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE
/* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 #define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ - CONFIG_SYS_GBL_DATA_SIZE) + GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#define CONFIG_OF_LIBFDT diff --git a/include/configs/PMC405DE.h b/include/configs/PMC405DE.h index 201a9c4..83cee96 100644 --- a/include/configs/PMC405DE.h +++ b/include/configs/PMC405DE.h @@ -272,9 +272,8 @@ /* End of used area in RAM */ #define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE
-#define CONFIG_SYS_GBL_DATA_SIZE 128 /* bytes res. for initial data */ #define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ - CONFIG_SYS_GBL_DATA_SIZE) + GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* diff --git a/include/configs/PMC440.h b/include/configs/PMC440.h index 1568912..4eb0735 100644 --- a/include/configs/PMC440.h +++ b/include/configs/PMC440.h @@ -89,8 +89,7 @@ /* 440EPx/440GRx have 16KB of internal SRAM, so no need for D-Cache */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_BASE /* OCM */ #define CONFIG_SYS_INIT_RAM_SIZE (4 << 10) -#define CONFIG_SYS_GBL_DATA_SIZE 256 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_GBL_DATA_OFFSET - 0x4)
/*----------------------------------------------------------------------- diff --git a/include/configs/PN62.h b/include/configs/PN62.h index 29ebd09..7f2f113 100644 --- a/include/configs/PN62.h +++ b/include/configs/PN62.h @@ -152,12 +152,10 @@ #define CONFIG_SYS_MONITOR_LEN 0x00030000 #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE
#define CONFIG_SYS_NO_FLASH 1 /* There is no FLASH memory */ diff --git a/include/configs/PPChameleonEVB.h b/include/configs/PPChameleonEVB.h index b2de868..a14bd0e 100644 --- a/include/configs/PPChameleonEVB.h +++ b/include/configs/PPChameleonEVB.h @@ -533,8 +533,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ #define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */
/*----------------------------------------------------------------------- diff --git a/include/configs/QS823.h b/include/configs/QS823.h index 0df1084..36efbf2 100644 --- a/include/configs/QS823.h +++ b/include/configs/QS823.h @@ -273,8 +273,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/QS850.h b/include/configs/QS850.h index 338ca2e..5c6ed07 100644 --- a/include/configs/QS850.h +++ b/include/configs/QS850.h @@ -273,8 +273,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/QS860T.h b/include/configs/QS860T.h index 6574986..b0bee82 100644 --- a/include/configs/QS860T.h +++ b/include/configs/QS860T.h @@ -182,8 +182,7 @@ CONFIG_SPI */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/R360MPI.h b/include/configs/R360MPI.h index 000a27d..a8e9a4a 100644 --- a/include/configs/R360MPI.h +++ b/include/configs/R360MPI.h @@ -196,8 +196,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/RBC823.h b/include/configs/RBC823.h index 91e3b77..40980fe 100644 --- a/include/configs/RBC823.h +++ b/include/configs/RBC823.h @@ -168,8 +168,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/RPXClassic.h b/include/configs/RPXClassic.h index 757b7f9..267ece1 100644 --- a/include/configs/RPXClassic.h +++ b/include/configs/RPXClassic.h @@ -184,8 +184,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x3000 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/RPXlite.h b/include/configs/RPXlite.h index 3fa5a9a..74926d8 100644 --- a/include/configs/RPXlite.h +++ b/include/configs/RPXlite.h @@ -120,8 +120,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/RPXlite_DW.h b/include/configs/RPXlite_DW.h index ebc652d..7b561cb 100644 --- a/include/configs/RPXlite_DW.h +++ b/include/configs/RPXlite_DW.h @@ -195,8 +195,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/RPXsuper.h b/include/configs/RPXsuper.h index 3a30b4a..5c19bd3 100644 --- a/include/configs/RPXsuper.h +++ b/include/configs/RPXsuper.h @@ -266,8 +266,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/RRvision.h b/include/configs/RRvision.h index 58813d7..7dcc14c 100644 --- a/include/configs/RRvision.h +++ b/include/configs/RRvision.h @@ -197,8 +197,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/Rattler.h b/include/configs/Rattler.h index ae71e37..4844fba 100644 --- a/include/configs/Rattler.h +++ b/include/configs/Rattler.h @@ -242,8 +242,7 @@
#define CONFIG_SYS_SDRAM_BASE 0x00000000 diff --git a/include/configs/SBC8540.h b/include/configs/SBC8540.h index 081c59b..fd9bacc 100644 --- a/include/configs/SBC8540.h +++ b/include/configs/SBC8540.h @@ -195,8 +195,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR 0x70000000 /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in RAM */
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ diff --git a/include/configs/SCM.h b/include/configs/SCM.h index 55efe53..ec26290 100644 --- a/include/configs/SCM.h +++ b/include/configs/SCM.h @@ -326,8 +326,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data*/ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/SIMPC8313.h b/include/configs/SIMPC8313.h index 0348297..30a8e41 100644 --- a/include/configs/SIMPC8313.h +++ b/include/configs/SIMPC8313.h @@ -105,8 +105,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR 0xFD000000 /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM*/
/* CONFIG_SYS_MONITOR_LEN must be a multiple of CONFIG_ENV_SECT_SIZE */ diff --git a/include/configs/SM850.h b/include/configs/SM850.h index 13d556d..833b18a 100644 --- a/include/configs/SM850.h +++ b/include/configs/SM850.h @@ -126,8 +126,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/SMN42.h b/include/configs/SMN42.h index ba3ada1..6d8780a 100644 --- a/include/configs/SMN42.h +++ b/include/configs/SMN42.h @@ -48,7 +48,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
/* * Hardware drivers diff --git a/include/configs/SPD823TS.h b/include/configs/SPD823TS.h index a1cd670..fba5b5e 100644 --- a/include/configs/SPD823TS.h +++ b/include/configs/SPD823TS.h @@ -138,8 +138,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/SX1.h b/include/configs/SX1.h index 6149276..01c2b3d 100644 --- a/include/configs/SX1.h +++ b/include/configs/SX1.h @@ -47,7 +47,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
/* * Hardware drivers diff --git a/include/configs/SXNI855T.h b/include/configs/SXNI855T.h index 52e8e16..774c98f 100644 --- a/include/configs/SXNI855T.h +++ b/include/configs/SXNI855T.h @@ -206,8 +206,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/Sandpoint8240.h b/include/configs/Sandpoint8240.h index e2d45b1..f984141 100644 --- a/include/configs/Sandpoint8240.h +++ b/include/configs/Sandpoint8240.h @@ -155,20 +155,17 @@ #define CONFIG_SYS_RAMBOOT 1 #define CONFIG_SYS_INIT_RAM_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) #define CONFIG_SYS_INIT_RAM_SIZE 0x10000 -#define CONFIG_SYS_GBL_DATA_SIZE 256 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET #else #undef CONFIG_SYS_RAMBOOT #define CONFIG_SYS_MONITOR_LEN 0x00030000 #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE
#endif
diff --git a/include/configs/Sandpoint8245.h b/include/configs/Sandpoint8245.h index 1eaad5a..b47adcc 100644 --- a/include/configs/Sandpoint8245.h +++ b/include/configs/Sandpoint8245.h @@ -125,20 +125,17 @@ #define CONFIG_SYS_RAMBOOT 1 #define CONFIG_SYS_INIT_RAM_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) #define CONFIG_SYS_INIT_RAM_SIZE 0x10000 -#define CONFIG_SYS_GBL_DATA_SIZE 256 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET #else #undef CONFIG_SYS_RAMBOOT #define CONFIG_SYS_MONITOR_LEN 0x00030000 #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE
#endif
diff --git a/include/configs/TASREG.h b/include/configs/TASREG.h index 6be20be..c93b12e 100644 --- a/include/configs/TASREG.h +++ b/include/configs/TASREG.h @@ -190,8 +190,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR 0x20000000 #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in internal SRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#define CONFIG_ENV_IS_IN_FLASH 1 diff --git a/include/configs/TB5200.h b/include/configs/TB5200.h index 1bcb9d0..feaadf3 100644 --- a/include/configs/TB5200.h +++ b/include/configs/TB5200.h @@ -333,8 +333,7 @@ #endif
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/TK885D.h b/include/configs/TK885D.h index f24b86e..72c6523 100644 --- a/include/configs/TK885D.h +++ b/include/configs/TK885D.h @@ -222,8 +222,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/TOP5200.h b/include/configs/TOP5200.h index ba1fcf1..2267d59 100644 --- a/include/configs/TOP5200.h +++ b/include/configs/TOP5200.h @@ -300,8 +300,7 @@ #define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE /* Size of used area in DPRAM */
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/TOP860.h b/include/configs/TOP860.h index 0901013..d6ea22d 100644 --- a/include/configs/TOP860.h +++ b/include/configs/TOP860.h @@ -231,8 +231,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2f00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_VPD_SIZE 256 /* size in bytes reserved for vpd buffer */ #define CONFIG_SYS_INIT_VPD_OFFSET (CONFIG_SYS_GBL_DATA_OFFSET - CONFIG_SYS_INIT_VPD_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_INIT_VPD_OFFSET-8) diff --git a/include/configs/TQM5200.h b/include/configs/TQM5200.h index 86ebaa4..c11fe8a 100644 --- a/include/configs/TQM5200.h +++ b/include/configs/TQM5200.h @@ -493,8 +493,7 @@ #endif
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/TQM823L.h b/include/configs/TQM823L.h index 681185d..f2a2e33 100644 --- a/include/configs/TQM823L.h +++ b/include/configs/TQM823L.h @@ -183,8 +183,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/TQM823M.h b/include/configs/TQM823M.h index 5d32b41..f6b856c 100644 --- a/include/configs/TQM823M.h +++ b/include/configs/TQM823M.h @@ -178,8 +178,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/TQM8260.h b/include/configs/TQM8260.h index 7214c85..36ecbd8 100644 --- a/include/configs/TQM8260.h +++ b/include/configs/TQM8260.h @@ -363,8 +363,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data*/ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/TQM8272.h b/include/configs/TQM8272.h index 1771824..d1d9e8e 100644 --- a/include/configs/TQM8272.h +++ b/include/configs/TQM8272.h @@ -489,8 +489,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data*/ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/TQM834x.h b/include/configs/TQM834x.h index abaae73..7c9dd79 100644 --- a/include/configs/TQM834x.h +++ b/include/configs/TQM834x.h @@ -153,8 +153,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR 0x20000000 /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM*/
#define CONFIG_SYS_MONITOR_LEN (384 * 1024) /* Reserve 384 kB = 3 sect. for Mon */ diff --git a/include/configs/TQM850L.h b/include/configs/TQM850L.h index a4efe11..6114bb0 100644 --- a/include/configs/TQM850L.h +++ b/include/configs/TQM850L.h @@ -168,8 +168,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/TQM850M.h b/include/configs/TQM850M.h index 0300586..3b52025 100644 --- a/include/configs/TQM850M.h +++ b/include/configs/TQM850M.h @@ -167,8 +167,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/TQM855L.h b/include/configs/TQM855L.h index e9c69dc..fd90501 100644 --- a/include/configs/TQM855L.h +++ b/include/configs/TQM855L.h @@ -172,8 +172,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/TQM855M.h b/include/configs/TQM855M.h index e0481f1..3e3f6de 100644 --- a/include/configs/TQM855M.h +++ b/include/configs/TQM855M.h @@ -206,8 +206,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/TQM85xx.h b/include/configs/TQM85xx.h index 5836976..890d6d9 100644 --- a/include/configs/TQM85xx.h +++ b/include/configs/TQM85xx.h @@ -245,8 +245,7 @@ + 0x04010000) /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size used area in RAM */
#define CONFIG_SYS_MONITOR_LEN (~CONFIG_SYS_TEXT_BASE + 1)/* Reserved for Monitor */ diff --git a/include/configs/TQM860L.h b/include/configs/TQM860L.h index da8a664..cdf4885 100644 --- a/include/configs/TQM860L.h +++ b/include/configs/TQM860L.h @@ -171,8 +171,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/TQM860M.h b/include/configs/TQM860M.h index 13425b1..7ccc614 100644 --- a/include/configs/TQM860M.h +++ b/include/configs/TQM860M.h @@ -172,8 +172,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/TQM862L.h b/include/configs/TQM862L.h index 3f879ec..0082e71 100644 --- a/include/configs/TQM862L.h +++ b/include/configs/TQM862L.h @@ -175,8 +175,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/TQM862M.h b/include/configs/TQM862M.h index 1206b7a..6e891e7 100644 --- a/include/configs/TQM862M.h +++ b/include/configs/TQM862M.h @@ -175,8 +175,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/TQM866M.h b/include/configs/TQM866M.h index c3f3e87..8636ff4 100644 --- a/include/configs/TQM866M.h +++ b/include/configs/TQM866M.h @@ -218,8 +218,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/TQM885D.h b/include/configs/TQM885D.h index a30e82d..5204771 100644 --- a/include/configs/TQM885D.h +++ b/include/configs/TQM885D.h @@ -220,8 +220,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/Total5200.h b/include/configs/Total5200.h index 3bb975c..717b5cd 100644 --- a/include/configs/Total5200.h +++ b/include/configs/Total5200.h @@ -248,8 +248,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR MPC5XXX_SRAM #define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE /* Size of used area in DPRAM */
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/VCMA9.h b/include/configs/VCMA9.h index ebc81c4..ebe9e42 100644 --- a/include/configs/VCMA9.h +++ b/include/configs/VCMA9.h @@ -101,7 +101,6 @@ * Size of malloc() pool */ /*#define CONFIG_MALLOC_SIZE (CONFIG_ENV_SIZE + 128*1024)*/ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) #define CONFIG_SYS_MALLOC_LEN (1024 * 1024) /* BUNZIP2 needs a lot of RAM */ diff --git a/include/configs/VOH405.h b/include/configs/VOH405.h index 4827748..f0c0bd9 100644 --- a/include/configs/VOH405.h +++ b/include/configs/VOH405.h @@ -379,8 +379,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ #define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */
/*----------------------------------------------------------------------- diff --git a/include/configs/VOM405.h b/include/configs/VOM405.h index f1e4407..fec9df0 100644 --- a/include/configs/VOM405.h +++ b/include/configs/VOM405.h @@ -260,8 +260,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ #define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */
/* diff --git a/include/configs/VoVPN-GW.h b/include/configs/VoVPN-GW.h index 4db8356..c06909f 100644 --- a/include/configs/VoVPN-GW.h +++ b/include/configs/VoVPN-GW.h @@ -299,8 +299,7 @@ /* definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2000 -#define CONFIG_SYS_GBL_DATA_SIZE 128 -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* diff --git a/include/configs/W7OLMC.h b/include/configs/W7OLMC.h index 1e71d09..5d1c188 100644 --- a/include/configs/W7OLMC.h +++ b/include/configs/W7OLMC.h @@ -314,8 +314,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ #define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#if defined(CONFIG_CMD_KGDB) diff --git a/include/configs/W7OLMG.h b/include/configs/W7OLMG.h index 0ff84d5..422a781 100644 --- a/include/configs/W7OLMG.h +++ b/include/configs/W7OLMG.h @@ -317,8 +317,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ #define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#if defined(CONFIG_CMD_KGDB) diff --git a/include/configs/WUH405.h b/include/configs/WUH405.h index a67dab2..027a904 100644 --- a/include/configs/WUH405.h +++ b/include/configs/WUH405.h @@ -323,8 +323,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ #define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */
/*----------------------------------------------------------------------- diff --git a/include/configs/Yukon8220.h b/include/configs/Yukon8220.h index 2d52864..0e340e8 100644 --- a/include/configs/Yukon8220.h +++ b/include/configs/Yukon8220.h @@ -259,8 +259,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR (CONFIG_SYS_MBAR + 0x20000) #define CONFIG_SYS_INIT_RAM_SIZE 0x8000 /* Size of used area in DPRAM */
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/ZPC1900.h b/include/configs/ZPC1900.h index 1d103f2..265b111 100644 --- a/include/configs/ZPC1900.h +++ b/include/configs/ZPC1900.h @@ -196,8 +196,7 @@
#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* Hard reset configuration word */ diff --git a/include/configs/ZUMA.h b/include/configs/ZUMA.h index 69e28d5..5489bd8 100644 --- a/include/configs/ZUMA.h +++ b/include/configs/ZUMA.h @@ -181,8 +181,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for init data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_RAM_LOCK
diff --git a/include/configs/a320evb.h b/include/configs/a320evb.h index fcc5563..f67cf06 100644 --- a/include/configs/a320evb.h +++ b/include/configs/a320evb.h @@ -110,7 +110,6 @@ /*----------------------------------------------------------------------- * size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_SIZE 128
/*----------------------------------------------------------------------- * SDRAM controller configuration diff --git a/include/configs/a4m072.h b/include/configs/a4m072.h index aa0238b..20c119a 100644 --- a/include/configs/a4m072.h +++ b/include/configs/a4m072.h @@ -253,8 +253,7 @@ #define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE /* Size of used area in DPRAM */
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/acadia.h b/include/configs/acadia.h index 0b10569..5573dc7 100644 --- a/include/configs/acadia.h +++ b/include/configs/acadia.h @@ -86,8 +86,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SRAM */ #define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */
-#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/actux1.h b/include/configs/actux1.h index 91f6ff0..8886eff 100644 --- a/include/configs/actux1.h +++ b/include/configs/actux1.h @@ -55,7 +55,6 @@ */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_SIZE 128
/* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE diff --git a/include/configs/actux2.h b/include/configs/actux2.h index b936938..756279e 100644 --- a/include/configs/actux2.h +++ b/include/configs/actux2.h @@ -46,7 +46,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_SIZE 128
/* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE diff --git a/include/configs/actux3.h b/include/configs/actux3.h index f5ee899..ad9173f 100644 --- a/include/configs/actux3.h +++ b/include/configs/actux3.h @@ -46,7 +46,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_SIZE 128
/* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE diff --git a/include/configs/actux4.h b/include/configs/actux4.h index 8d70a26..04145c3 100644 --- a/include/configs/actux4.h +++ b/include/configs/actux4.h @@ -46,7 +46,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_SIZE 128
/* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE diff --git a/include/configs/aev.h b/include/configs/aev.h index 122ebab..fb958fd 100644 --- a/include/configs/aev.h +++ b/include/configs/aev.h @@ -277,8 +277,7 @@ #endif
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/afeb9260.h b/include/configs/afeb9260.h index 24484fd..9cd0bc6 100644 --- a/include/configs/afeb9260.h +++ b/include/configs/afeb9260.h @@ -167,7 +167,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN ROUND(3 * CONFIG_ENV_SIZE + 128*1024, 0x1000) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* 128 bytes for initial data */
#define CONFIG_STACKSIZE (32 * 1024) /* regular stack */
diff --git a/include/configs/alpr.h b/include/configs/alpr.h index ee13d1b..d93e505 100644 --- a/include/configs/alpr.h +++ b/include/configs/alpr.h @@ -65,9 +65,8 @@ #define CONFIG_SYS_OCM_DATA_ADDR CONFIG_SYS_ISRAM_BASE #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_ISRAM_BASE /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* num bytes initial data */
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ diff --git a/include/configs/am3517_evm.h b/include/configs/am3517_evm.h index a9045d8..9a9ba88 100644 --- a/include/configs/am3517_evm.h +++ b/include/configs/am3517_evm.h @@ -61,7 +61,6 @@ */ #define CONFIG_ENV_SIZE (128 << 10) /* 128 KiB sector */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (128 << 10)) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* bytes reserved for */ /* initial data */ /* * DDR related diff --git a/include/configs/ap325rxa.h b/include/configs/ap325rxa.h index 80a5797..e7f37f5 100644 --- a/include/configs/ap325rxa.h +++ b/include/configs/ap325rxa.h @@ -112,7 +112,6 @@ /* Size of DRAM reserved for malloc() use */ #define CONFIG_SYS_MALLOC_LEN (256 * 1024) /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_SIZE (256) #define CONFIG_SYS_BOOTMAPSZ (8 * 1024 * 1024)
/* FLASH */ diff --git a/include/configs/apollon.h b/include/configs/apollon.h index c1295de..aa74462 100644 --- a/include/configs/apollon.h +++ b/include/configs/apollon.h @@ -79,7 +79,6 @@ #define CONFIG_ENV_SIZE_FLEX SZ_256K #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + SZ_1M) /* bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_SIZE 128
/* * Hardware drivers diff --git a/include/configs/aria.h b/include/configs/aria.h index 37592fc..b3ca8d2 100644 --- a/include/configs/aria.h +++ b/include/configs/aria.h @@ -302,9 +302,8 @@ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_SRAM_BASE #define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_SRAM_SIZE
-#define CONFIG_SYS_GBL_DATA_SIZE 0x100 #define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ - CONFIG_SYS_GBL_DATA_SIZE) + GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/armadillo.h b/include/configs/armadillo.h index 49ea3a1..d0d0998 100644 --- a/include/configs/armadillo.h +++ b/include/configs/armadillo.h @@ -51,7 +51,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
/* * Hardware drivers diff --git a/include/configs/assabet.h b/include/configs/assabet.h index 58cdbd5..5cd1836 100644 --- a/include/configs/assabet.h +++ b/include/configs/assabet.h @@ -48,7 +48,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size rsrvd for initial data */
/* * Hardware drivers diff --git a/include/configs/astro_mcf5373l.h b/include/configs/astro_mcf5373l.h index dae31b1..d468e49 100644 --- a/include/configs/astro_mcf5373l.h +++ b/include/configs/astro_mcf5373l.h @@ -302,9 +302,8 @@ #define CONFIG_SYS_INIT_RAM_ADDR 0x80000000 #define CONFIG_SYS_INIT_RAM_SIZE 0x8000 #define CONFIG_SYS_INIT_RAM_CTRL 0x221 -#define CONFIG_SYS_GBL_DATA_SIZE 128 #define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ - CONFIG_SYS_GBL_DATA_SIZE) + GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* diff --git a/include/configs/at91cap9adk.h b/include/configs/at91cap9adk.h index 44c2870..cde5aed 100644 --- a/include/configs/at91cap9adk.h +++ b/include/configs/at91cap9adk.h @@ -209,7 +209,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN ROUND(CONFIG_ENV_SIZE + 128*1024, 0x1000) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* 128 bytes for initial data */
#define CONFIG_STACKSIZE (32*1024) /* regular stack */
diff --git a/include/configs/at91rm9200dk.h b/include/configs/at91rm9200dk.h index d39e8f2..fb9d0a5 100644 --- a/include/configs/at91rm9200dk.h +++ b/include/configs/at91rm9200dk.h @@ -76,7 +76,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
#define CONFIG_BAUDRATE 115200
diff --git a/include/configs/at91rm9200ek.h b/include/configs/at91rm9200ek.h index b386057..14559f5 100644 --- a/include/configs/at91rm9200ek.h +++ b/include/configs/at91rm9200ek.h @@ -205,10 +205,9 @@ #define CONFIG_SYS_MALLOC_LEN ROUND(3 * CONFIG_ENV_SIZE + SZ_128K, \ SZ_4K) /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_SIZE 128
#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + SZ_4K \ - - CONFIG_SYS_GBL_DATA_SIZE) + - GENERATED_GBL_DATA_SIZE)
#define CONFIG_STACKSIZE SZ_32K /* regular stack */ #define CONFIG_STACKSIZE_IRQ SZ_4K /* Unsure if to big or to small*/ diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index b89242b..02401b8 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -213,7 +213,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN ROUND(3 * CONFIG_ENV_SIZE + 128*1024, 0x1000) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* 128 bytes for initial data */
diff --git a/include/configs/at91sam9261ek.h b/include/configs/at91sam9261ek.h index df8181b..05e12dd 100644 --- a/include/configs/at91sam9261ek.h +++ b/include/configs/at91sam9261ek.h @@ -231,7 +231,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN ROUND(3 * CONFIG_ENV_SIZE + 128*1024, 0x1000) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* 128 bytes for initial data */
diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h index 5cafa1e..0905638 100644 --- a/include/configs/at91sam9263ek.h +++ b/include/configs/at91sam9263ek.h @@ -341,7 +341,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN ROUND(3 * CONFIG_ENV_SIZE + 128*1024, 0x1000) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* 128 bytes for initial data */
diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index 44c5496..67288d0 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -217,7 +217,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN ROUND(3 * CONFIG_ENV_SIZE + 128*1024, 0x1000) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* 128 bytes for initial data */
diff --git a/include/configs/at91sam9rlek.h b/include/configs/at91sam9rlek.h index e8fcd66..22054cf 100644 --- a/include/configs/at91sam9rlek.h +++ b/include/configs/at91sam9rlek.h @@ -176,7 +176,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN ROUND(3 * CONFIG_ENV_SIZE + 128*1024, 0x1000) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* 128 bytes for initial data */
diff --git a/include/configs/atc.h b/include/configs/atc.h index 472e73c..53da0f7 100644 --- a/include/configs/atc.h +++ b/include/configs/atc.h @@ -245,8 +245,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data*/ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/balloon3.h b/include/configs/balloon3.h index ae60f2e..63e6d6e 100644 --- a/include/configs/balloon3.h +++ b/include/configs/balloon3.h @@ -33,7 +33,6 @@ */ #define CONFIG_ENV_OVERWRITE #define CONFIG_SYS_MALLOC_LEN (128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 #define CONFIG_ARCH_CPU_INIT #define CONFIG_BOOTCOMMAND \ "fpga load 0x0 0x50000 0x62638; " \ @@ -133,7 +132,7 @@
#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 #define CONFIG_SYS_INIT_SP_ADDR \ - (PHYS_SDRAM_1 + CONFIG_SYS_GBL_DATA_SIZE + 2048) + (PHYS_SDRAM_1 + GENERATED_GBL_DATA_SIZE + 2048)
/* * NOR FLASH diff --git a/include/configs/bamboo.h b/include/configs/bamboo.h index b985dc1..7b66fc0 100644 --- a/include/configs/bamboo.h +++ b/include/configs/bamboo.h @@ -81,8 +81,7 @@ #define CONFIG_SYS_INIT_RAM_DCACHE 1 /* d-cache as init ram */ #define CONFIG_SYS_INIT_RAM_ADDR 0x70000000 /* DCache */ #define CONFIG_SYS_INIT_RAM_SIZE (4 << 10) -#define CONFIG_SYS_GBL_DATA_SIZE 256 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/barco.h b/include/configs/barco.h index 6ff5c55..dcba0cb 100644 --- a/include/configs/barco.h +++ b/include/configs/barco.h @@ -152,19 +152,17 @@ #define CONFIG_SYS_RAMBOOT 1 #define CONFIG_SYS_INIT_RAM_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) #define CONFIG_SYS_INIT_RAM_SIZE 0x10000 -#define CONFIG_SYS_GBL_DATA_SIZE 256 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET #else #undef CONFIG_SYS_RAMBOOT #define CONFIG_SYS_MONITOR_LEN 0x00030000 #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE
#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
#endif
diff --git a/include/configs/bluestone.h b/include/configs/bluestone.h index c689763..3e691fd 100644 --- a/include/configs/bluestone.h +++ b/include/configs/bluestone.h @@ -67,9 +67,8 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_BASE /* OCM */ #define CONFIG_SYS_INIT_RAM_SIZE (4 << 10) -#define CONFIG_SYS_GBL_DATA_SIZE 256 /* num bytes initial data */ #define CONFIG_SYS_GBL_DATA_OFFSET \ - (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* diff --git a/include/configs/bubinga.h b/include/configs/bubinga.h index 7171032..da67ae3 100644 --- a/include/configs/bubinga.h +++ b/include/configs/bubinga.h @@ -240,8 +240,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ #define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */
/*----------------------------------------------------------------------- diff --git a/include/configs/c2mon.h b/include/configs/c2mon.h index 8852f74..f325d2b 100644 --- a/include/configs/c2mon.h +++ b/include/configs/c2mon.h @@ -144,8 +144,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/ca9x4_ct_vxp.h b/include/configs/ca9x4_ct_vxp.h index 2ab5579..63f003d 100644 --- a/include/configs/ca9x4_ct_vxp.h +++ b/include/configs/ca9x4_ct_vxp.h @@ -45,7 +45,6 @@
/* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128 * 1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128
#define SCTL_BASE 0x10001000 #define VEXPRESS_FLASHPROG_FLVPPEN (1 << 0) @@ -119,7 +118,7 @@ #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 #define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_SDRAM_BASE + \ CONFIG_SYS_INIT_RAM_SIZE - \ - CONFIG_SYS_GBL_DATA_SIZE) + GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_ADDR CONFIG_SYS_GBL_DATA_OFFSET
/* Basic environment settings */ diff --git a/include/configs/canmb.h b/include/configs/canmb.h index 7666ee7..d4c5bbd 100644 --- a/include/configs/canmb.h +++ b/include/configs/canmb.h @@ -160,8 +160,7 @@ #define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE /* Size of used area in DPRAM */
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/canyonlands.h b/include/configs/canyonlands.h index fc039f8..8c03582 100644 --- a/include/configs/canyonlands.h +++ b/include/configs/canyonlands.h @@ -125,8 +125,7 @@ *----------------------------------------------------------------------*/ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_BASE /* OCM */ #define CONFIG_SYS_INIT_RAM_SIZE (4 << 10) -#define CONFIG_SYS_GBL_DATA_SIZE 256 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/cerf250.h b/include/configs/cerf250.h index a0726a9..9696487 100644 --- a/include/configs/cerf250.h +++ b/include/configs/cerf250.h @@ -49,7 +49,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
/* * Hardware drivers @@ -157,7 +156,7 @@ #define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1
#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 -#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_GBL_DATA_SIZE + PHYS_SDRAM_1) +#define CONFIG_SYS_INIT_SP_ADDR (GENERATED_GBL_DATA_SIZE + PHYS_SDRAM_1)
/* * GPIO settings diff --git a/include/configs/cm4008.h b/include/configs/cm4008.h index 7ea1a46..6e4a3b4 100644 --- a/include/configs/cm4008.h +++ b/include/configs/cm4008.h @@ -43,7 +43,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
/* * Hardware drivers diff --git a/include/configs/cm41xx.h b/include/configs/cm41xx.h index ea374da..dca7d54 100644 --- a/include/configs/cm41xx.h +++ b/include/configs/cm41xx.h @@ -43,7 +43,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
/* * Hardware drivers diff --git a/include/configs/cm5200.h b/include/configs/cm5200.h index 488c0f2..0abe090 100644 --- a/include/configs/cm5200.h +++ b/include/configs/cm5200.h @@ -167,8 +167,7 @@ #define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE #endif
-#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_BOARD_TYPES 1 /* we use board_type */
#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET diff --git a/include/configs/cmc_pu2.h b/include/configs/cmc_pu2.h index ffe83f0..ff4f306 100644 --- a/include/configs/cmc_pu2.h +++ b/include/configs/cmc_pu2.h @@ -76,7 +76,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
#define CONFIG_BAUDRATE 9600
diff --git a/include/configs/cmi_mpc5xx.h b/include/configs/cmi_mpc5xx.h index e03bf31..198f342 100644 --- a/include/configs/cmi_mpc5xx.h +++ b/include/configs/cmi_mpc5xx.h @@ -130,8 +130,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR (CONFIG_SYS_IMMR + 0x003f9800) /* Physical start adress of internal MPC555 writable RAM */ #define CONFIG_SYS_INIT_RAM_SIZE (CONFIG_SYS_IMMR + 0x003fffff) /* Physical end adress of internal MPC555 used RAM area */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* Size in bytes reserved for initial global data */ -#define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_INIT_RAM_ADDR) - CONFIG_SYS_GBL_DATA_SIZE) /* Offset from the beginning of ram */ +#define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_INIT_RAM_ADDR) - GENERATED_GBL_DATA_SIZE) /* Offset from the beginning of ram */ #define CONFIG_SYS_INIT_SP_ADDR 0x013fa000 /* Physical start adress of inital stack */
/* diff --git a/include/configs/cobra5272.h b/include/configs/cobra5272.h index 0b36eb5..5348ad1 100644 --- a/include/configs/cobra5272.h +++ b/include/configs/cobra5272.h @@ -277,8 +277,7 @@ from which user programs will be started */ */ #define CONFIG_SYS_INIT_RAM_ADDR 0x20000000 #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in internal SRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/cogent_mpc8260.h b/include/configs/cogent_mpc8260.h index b10e217..d77af0d 100644 --- a/include/configs/cogent_mpc8260.h +++ b/include/configs/cogent_mpc8260.h @@ -225,8 +225,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/cogent_mpc8xx.h b/include/configs/cogent_mpc8xx.h index 4d4a81c..3ee4a40 100644 --- a/include/configs/cogent_mpc8xx.h +++ b/include/configs/cogent_mpc8xx.h @@ -172,8 +172,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/colibri_pxa270.h b/include/configs/colibri_pxa270.h index afc1537..a523189 100644 --- a/include/configs/colibri_pxa270.h +++ b/include/configs/colibri_pxa270.h @@ -38,7 +38,6 @@ */ #define CONFIG_ENV_SIZE 0x4000 #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 #define CONFIG_SYS_TEXT_BASE 0x0 #define CONFIG_ENV_OVERWRITE /* override default environment */
@@ -170,7 +169,7 @@ #define CONFIG_SYS_LOAD_ADDR (0xa1000000)
/* * NOR FLASH diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index 065e89f..2ac59e5 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -213,8 +213,7 @@ #endif #define CONFIG_SYS_INIT_RAM_SIZE 0x00004000 /* Size of used area in RAM */
#define CONFIG_SYS_MONITOR_LEN (512 * 1024) diff --git a/include/configs/cpci5200.h b/include/configs/cpci5200.h index 78df31f..c1742c1 100644 --- a/include/configs/cpci5200.h +++ b/include/configs/cpci5200.h @@ -237,8 +237,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR MPC5XXX_SRAM #define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE /* Size of used area in DPRAM */
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/cpu9260.h b/include/configs/cpu9260.h index fb6f79a..d239423 100644 --- a/include/configs/cpu9260.h +++ b/include/configs/cpu9260.h @@ -445,7 +445,6 @@ */ #define CONFIG_SYS_MALLOC_LEN \ ROUND(3 * CONFIG_ENV_SIZE + 128 * 1024, 0x1000) -#define CONFIG_SYS_GBL_DATA_SIZE 128
diff --git a/include/configs/cpuat91.h b/include/configs/cpuat91.h index 9ef4523..5f40908 100644 --- a/include/configs/cpuat91.h +++ b/include/configs/cpuat91.h @@ -200,7 +200,6 @@ #define CONFIG_SYS_HZ_CLOCK (AT91C_MASTER_CLOCK / 2)
#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128 * 1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 #define CONFIG_STACKSIZE (32 * 1024)
#if defined(CONFIG_USE_IRQ) diff --git a/include/configs/cradle.h b/include/configs/cradle.h index 3da3562..c21af38 100644 --- a/include/configs/cradle.h +++ b/include/configs/cradle.h @@ -44,7 +44,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
/* * Hardware drivers @@ -140,7 +139,7 @@ #define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1
/* * FLASH and environment organization diff --git a/include/configs/csb226.h b/include/configs/csb226.h index 72e47ce..505740c 100644 --- a/include/configs/csb226.h +++ b/include/configs/csb226.h @@ -117,7 +117,6 @@ * */ #define CONFIG_SYS_MALLOC_LEN (128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
#define CONFIG_SYS_LONGHELP /* undef to save memory */ #define CONFIG_SYS_PROMPT "uboot> " /* Monitor Command Prompt */ @@ -182,7 +181,7 @@ #define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1
# if 0 /* FIXME: switch to _documented_ registers */ diff --git a/include/configs/csb272.h b/include/configs/csb272.h index 071e967..0ea34b8 100644 --- a/include/configs/csb272.h +++ b/include/configs/csb272.h @@ -294,8 +294,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of on-chip SRAM */ #define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* byte size reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* diff --git a/include/configs/csb472.h b/include/configs/csb472.h index 8f5b3d4..2373167 100644 --- a/include/configs/csb472.h +++ b/include/configs/csb472.h @@ -293,8 +293,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of on-chip SRAM */ #define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* byte size reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* diff --git a/include/configs/csb637.h b/include/configs/csb637.h index efa2780..f92f3c7 100644 --- a/include/configs/csb637.h +++ b/include/configs/csb637.h @@ -76,7 +76,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
diff --git a/include/configs/da830evm.h b/include/configs/da830evm.h index 160ece2..d8f1e9f 100644 --- a/include/configs/da830evm.h +++ b/include/configs/da830evm.h @@ -47,7 +47,6 @@ * Memory Info */ #define CONFIG_SYS_MALLOC_LEN (0x10000 + 1*1024*1024) /* malloc() len */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* reserved for initial data */ #define PHYS_SDRAM_1 DAVINCI_DDR_EMIF_DATA_BASE /* DDR Start */ #define PHYS_SDRAM_1_SIZE (64 << 20) /* SDRAM size 64MB */ #define CONFIG_SYS_MEMTEST_START PHYS_SDRAM_1 /* memtest start addr */ diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index 7bf6336..11f2869 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -45,7 +45,6 @@ * Memory Info */ #define CONFIG_SYS_MALLOC_LEN (0x10000 + 1*1024*1024) /* malloc() len */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* reserved for initial data */ #define PHYS_SDRAM_1 DAVINCI_DDR_EMIF_DATA_BASE /* DDR Start */ #define PHYS_SDRAM_1_SIZE (64 << 20) /* SDRAM size 64MB */ #define CONFIG_MAX_RAM_BANK_SIZE (512 << 20) /* max size from SPRS586*/ @@ -192,5 +191,5 @@ /* additions for new relocation code, must added to all boards */ #define CONFIG_SYS_SDRAM_BASE 0xc0000000 #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + 0x1000 - /* Fix this */ \ - CONFIG_SYS_GBL_DATA_SIZE) + GENERATED_GBL_DATA_SIZE) #endif /* __CONFIG_H */ diff --git a/include/configs/davinci_dm355evm.h b/include/configs/davinci_dm355evm.h index 37011c0..d4c3697 100644 --- a/include/configs/davinci_dm355evm.h +++ b/include/configs/davinci_dm355evm.h @@ -151,7 +151,6 @@ /* U-Boot memory configuration */ #define CONFIG_STACKSIZE (256 << 10) /* 256 KiB */ #define CONFIG_SYS_MALLOC_LEN (1 << 20) /* 1 MiB */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* for initial data */ #define CONFIG_SYS_MEMTEST_START 0x87000000 /* physical address */ #define CONFIG_SYS_MEMTEST_END 0x88000000 /* test 16MB RAM */
diff --git a/include/configs/davinci_dm355leopard.h b/include/configs/davinci_dm355leopard.h index e09fb75..4b1f029 100644 --- a/include/configs/davinci_dm355leopard.h +++ b/include/configs/davinci_dm355leopard.h @@ -134,7 +134,6 @@ /* U-Boot memory configuration */ #define CONFIG_STACKSIZE (256 << 10) /* 256 KiB */ #define CONFIG_SYS_MALLOC_LEN (1 << 20) /* 1 MiB */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* for initial data */ #define CONFIG_SYS_MEMTEST_START 0x87000000 /* physical address */ #define CONFIG_SYS_MEMTEST_END 0x88000000 /* test 16MB RAM */
diff --git a/include/configs/davinci_dm365evm.h b/include/configs/davinci_dm365evm.h index 2c3d88d..04b6044 100644 --- a/include/configs/davinci_dm365evm.h +++ b/include/configs/davinci_dm365evm.h @@ -183,7 +183,6 @@ /* U-Boot memory configuration */ #define CONFIG_STACKSIZE (256 << 10) /* 256 KiB */ #define CONFIG_SYS_MALLOC_LEN (1 << 20) /* 1 MiB */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* for initial data */ #define CONFIG_SYS_MEMTEST_START 0x87000000 /* physical address */ #define CONFIG_SYS_MEMTEST_END 0x88000000 /* test 16MB RAM */
diff --git a/include/configs/davinci_dm6467evm.h b/include/configs/davinci_dm6467evm.h index ddc5990..6b5d865 100644 --- a/include/configs/davinci_dm6467evm.h +++ b/include/configs/davinci_dm6467evm.h @@ -41,7 +41,6 @@
/* Memory Info */ #define CONFIG_SYS_MALLOC_LEN (1 << 20) /* 1 MiB */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* initial data */ #define CONFIG_SYS_MEMTEST_START 0x80000000 #define CONFIG_SYS_MEMTEST_END 0x81000000 /* 16MB RAM test */ #define CONFIG_NR_DRAM_BANKS 1 diff --git a/include/configs/davinci_dvevm.h b/include/configs/davinci_dvevm.h index aab2afa..ec05aba 100644 --- a/include/configs/davinci_dvevm.h +++ b/include/configs/davinci_dvevm.h @@ -72,7 +72,6 @@ /* Memory Info */ /*=============*/ #define CONFIG_SYS_MALLOC_LEN (0x10000 + 128*1024) /* malloc() len */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* reserved for initial data */ #define CONFIG_SYS_MEMTEST_START 0x80000000 /* memtest start address */ #define CONFIG_SYS_MEMTEST_END 0x81000000 /* 16MB RAM test */ #define CONFIG_NR_DRAM_BANKS 1 /* we have 1 bank of DRAM */ diff --git a/include/configs/davinci_schmoogie.h b/include/configs/davinci_schmoogie.h index 04cdc21..409c5a4 100644 --- a/include/configs/davinci_schmoogie.h +++ b/include/configs/davinci_schmoogie.h @@ -39,7 +39,6 @@ /* Memory Info */ /*=============*/ #define CONFIG_SYS_MALLOC_LEN (0x10000 + 256*1024) /* malloc() len */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* reserved for initial data */ #define CONFIG_SYS_MEMTEST_START 0x80000000 /* memtest start address */ #define CONFIG_SYS_MEMTEST_END 0x81000000 /* 16MB RAM test */ #define CONFIG_NR_DRAM_BANKS 1 /* we have 1 bank of DRAM */ diff --git a/include/configs/davinci_sffsdr.h b/include/configs/davinci_sffsdr.h index f4e17f8..c7e0e56 100644 --- a/include/configs/davinci_sffsdr.h +++ b/include/configs/davinci_sffsdr.h @@ -42,7 +42,6 @@ #define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 20 /* Memory Info */ #define CONFIG_SYS_MALLOC_LEN (0x10000 + 256*1024) /* malloc() len */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* reserved for initial data */ #define CONFIG_SYS_MEMTEST_START 0x80000000 /* memtest start address */ #define CONFIG_SYS_MEMTEST_END 0x81000000 /* 16MB RAM test */ #define CONFIG_NR_DRAM_BANKS 1 /* we have 1 bank of DRAM */ diff --git a/include/configs/davinci_sonata.h b/include/configs/davinci_sonata.h index 1746495..3035f79 100644 --- a/include/configs/davinci_sonata.h +++ b/include/configs/davinci_sonata.h @@ -72,7 +72,6 @@ /* Memory Info */ /*=============*/ #define CONFIG_SYS_MALLOC_LEN (0x10000 + 128*1024) /* malloc() len */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* reserved for initial data */ #define CONFIG_SYS_MEMTEST_START 0x80000000 /* memtest start address */ #define CONFIG_SYS_MEMTEST_END 0x81000000 /* 16MB RAM test */ #define CONFIG_NR_DRAM_BANKS 1 /* we have 1 bank of DRAM */ diff --git a/include/configs/debris.h b/include/configs/debris.h index 978b143..7ad36a1 100644 --- a/include/configs/debris.h +++ b/include/configs/debris.h @@ -200,20 +200,17 @@ #define CONFIG_SYS_RAMBOOT 1 #define CONFIG_SYS_INIT_RAM_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) #define CONFIG_SYS_INIT_RAM_SIZE 0x10000 -#define CONFIG_SYS_GBL_DATA_SIZE 256 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET #else #undef CONFIG_SYS_RAMBOOT #define CONFIG_SYS_MONITOR_LEN 0x00040000 #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE
-/*#define CONFIG_SYS_GBL_DATA_SIZE 256*/ -#define CONFIG_SYS_GBL_DATA_SIZE 128
#endif
diff --git a/include/configs/devkit8000.h b/include/configs/devkit8000.h index 2815771..fb81c64 100644 --- a/include/configs/devkit8000.h +++ b/include/configs/devkit8000.h @@ -63,7 +63,6 @@ #define CONFIG_ENV_SIZE (128 << 10) /* 128 KiB */ /* Sector */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (128 << 10)) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* bytes reserved for */ /* initial data */
/* Hardware drivers */ diff --git a/include/configs/digsy_mtc.h b/include/configs/digsy_mtc.h index 0ede4ec..d541160 100644 --- a/include/configs/digsy_mtc.h +++ b/include/configs/digsy_mtc.h @@ -310,9 +310,8 @@ #define CONFIG_SYS_INIT_RAM_ADDR MPC5XXX_SRAM #define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE
-#define CONFIG_SYS_GBL_DATA_SIZE 4096 #define CONFIG_SYS_GBL_DATA_OFFSET \ - (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/dlvision.h b/include/configs/dlvision.h index c9bd261..c490ff6 100644 --- a/include/configs/dlvision.h +++ b/include/configs/dlvision.h @@ -193,9 +193,8 @@ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* in SDRAM */ #define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area */
-#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size/bytes res'd for init data*/ #define CONFIG_SYS_GBL_DATA_OFFSET \ - (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* diff --git a/include/configs/dnp1110.h b/include/configs/dnp1110.h index e48e20f..5c05e4d 100644 --- a/include/configs/dnp1110.h +++ b/include/configs/dnp1110.h @@ -49,7 +49,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
/* * Hardware drivers diff --git a/include/configs/eXalion.h b/include/configs/eXalion.h index 11cfe70..61f34dd 100644 --- a/include/configs/eXalion.h +++ b/include/configs/eXalion.h @@ -122,8 +122,7 @@ #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 #define CONFIG_SYS_INIT_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_INIT_DATA_SIZE)
diff --git a/include/configs/eb_cpux9k2.h b/include/configs/eb_cpux9k2.h index 8d8af93..754fc8b 100644 --- a/include/configs/eb_cpux9k2.h +++ b/include/configs/eb_cpux9k2.h @@ -91,7 +91,6 @@ */
#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 520*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128
/* * sdram diff --git a/include/configs/ebony.h b/include/configs/ebony.h index 46988c1..d6b6551 100644 --- a/include/configs/ebony.h +++ b/include/configs/ebony.h @@ -74,9 +74,8 @@ *----------------------------------------------------------------------*/ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_ISRAM_BASE /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* num bytes initial data */
/*----------------------------------------------------------------------- diff --git a/include/configs/edb93xx.h b/include/configs/edb93xx.h index ff25ee2..19b7632 100644 --- a/include/configs/edb93xx.h +++ b/include/configs/edb93xx.h @@ -218,7 +218,6 @@ #define LINUX_BOOT_PARAM_ADDR (PHYS_SDRAM_1 + 0x100)
/* Run-time memory allocatons */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 #define CONFIG_STACKSIZE (128 * 1024)
#if defined(CONFIG_USE_IRQ) diff --git a/include/configs/edminiv2.h b/include/configs/edminiv2.h index 43e5e87..a75f06a 100644 --- a/include/configs/edminiv2.h +++ b/include/configs/edminiv2.h @@ -205,7 +205,6 @@ */ #define CONFIG_SYS_MALLOC_LEN (1024 * 128) /* 128kB for malloc() */ /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_SIZE 128
/* * Other required minimal configurations @@ -226,6 +225,6 @@ /* additions for new relocation code, must be added to all boards */ #define CONFIG_SYS_SDRAM_BASE 0 #define CONFIG_SYS_INIT_SP_ADDR \ - (CONFIG_SYS_SDRAM_BASE + 0x1000 - CONFIG_SYS_GBL_DATA_SIZE) + (CONFIG_SYS_SDRAM_BASE + 0x1000 - GENERATED_GBL_DATA_SIZE)
#endif /* _CONFIG_EDMINIV2_H */ diff --git a/include/configs/ep7312.h b/include/configs/ep7312.h index e151faa..fdb98b5 100644 --- a/include/configs/ep7312.h +++ b/include/configs/ep7312.h @@ -42,7 +42,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
/* * Hardware drivers diff --git a/include/configs/ep8248.h b/include/configs/ep8248.h index a21dbf7..bb87d36 100644 --- a/include/configs/ep8248.h +++ b/include/configs/ep8248.h @@ -219,8 +219,7 @@
#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* Hard reset configuration word */ diff --git a/include/configs/ep8260.h b/include/configs/ep8260.h index 277bd8d..b15659d 100644 --- a/include/configs/ep8260.h +++ b/include/configs/ep8260.h @@ -430,8 +430,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/ep82xxm.h b/include/configs/ep82xxm.h index 114af7a..692f0ec 100644 --- a/include/configs/ep82xxm.h +++ b/include/configs/ep82xxm.h @@ -347,8 +347,7 @@
diff --git a/include/configs/espt.h b/include/configs/espt.h index 2ec907c..26389ed 100644 --- a/include/configs/espt.h +++ b/include/configs/espt.h @@ -85,7 +85,6 @@ /* Size of DRAM reserved for malloc() use */ #define CONFIG_SYS_MALLOC_LEN (1024 * 1024) /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_SIZE (256) #define CONFIG_SYS_BOOTMAPSZ (8 * 1024 * 1024)
#define CONFIG_SYS_FLASH_CFI diff --git a/include/configs/evb4510.h b/include/configs/evb4510.h index 0f415d9..fb05727 100644 --- a/include/configs/evb4510.h +++ b/include/configs/evb4510.h @@ -53,7 +53,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128
/* * Hardware drivers diff --git a/include/configs/galaxy5200.h b/include/configs/galaxy5200.h index cb521a1..9535eb9 100644 --- a/include/configs/galaxy5200.h +++ b/include/configs/galaxy5200.h @@ -210,10 +210,9 @@ #define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE
/* Size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_SIZE 128
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/gcplus.h b/include/configs/gcplus.h index 41294b9..82e70f7 100644 --- a/include/configs/gcplus.h +++ b/include/configs/gcplus.h @@ -60,7 +60,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size rsrvd for initial data */
/* diff --git a/include/configs/gdppc440etx.h b/include/configs/gdppc440etx.h index 32e3cd6..3c59ff4 100644 --- a/include/configs/gdppc440etx.h +++ b/include/configs/gdppc440etx.h @@ -73,9 +73,8 @@ #define CONFIG_SYS_INIT_RAM_DCACHE 1 /* d-cache as init ram*/ #define CONFIG_SYS_INIT_RAM_ADDR 0x70000000 /* DCache */ #define CONFIG_SYS_INIT_RAM_SIZE (4 << 10) -#define CONFIG_SYS_GBL_DATA_SIZE 256 /* num bytes init data*/ #define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE \ - - CONFIG_SYS_GBL_DATA_SIZE) + - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* diff --git a/include/configs/gr_cpci_ax2000.h b/include/configs/gr_cpci_ax2000.h index bb4ea79..dc62ea3 100644 --- a/include/configs/gr_cpci_ax2000.h +++ b/include/configs/gr_cpci_ax2000.h @@ -261,10 +261,9 @@ #define CONFIG_SYS_RAM_END CONFIG_SYS_SDRAM_END #endif
-#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_RAM_END - GENERATED_GBL_DATA_SIZE)
-#define CONFIG_SYS_PROM_SIZE (8192-CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_PROM_SIZE (8192-GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_PROM_OFFSET (CONFIG_SYS_GBL_DATA_OFFSET-CONFIG_SYS_PROM_SIZE)
#define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_PROM_OFFSET-32) diff --git a/include/configs/gr_ep2s60.h b/include/configs/gr_ep2s60.h index 35c4a08..5efe676 100644 --- a/include/configs/gr_ep2s60.h +++ b/include/configs/gr_ep2s60.h @@ -229,10 +229,9 @@ #define CONFIG_SYS_RAM_SIZE CONFIG_SYS_SDRAM_SIZE #define CONFIG_SYS_RAM_END CONFIG_SYS_SDRAM_END
-#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_SDRAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_SDRAM_END - GENERATED_GBL_DATA_SIZE)
#define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_PROM_OFFSET-32) diff --git a/include/configs/gr_xc3s_1500.h b/include/configs/gr_xc3s_1500.h index 92fbbbb..505db10 100644 --- a/include/configs/gr_xc3s_1500.h +++ b/include/configs/gr_xc3s_1500.h @@ -206,10 +206,9 @@ #define CONFIG_SYS_RAM_SIZE CONFIG_SYS_SDRAM_SIZE #define CONFIG_SYS_RAM_END CONFIG_SYS_SDRAM_END
#define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_PROM_OFFSET-32) diff --git a/include/configs/grsim.h b/include/configs/grsim.h index 5dfdf51..bbd2f91 100644 --- a/include/configs/grsim.h +++ b/include/configs/grsim.h @@ -231,10 +231,9 @@ #define CONFIG_SYS_RAM_SIZE CONFIG_SYS_SDRAM_SIZE #define CONFIG_SYS_RAM_END CONFIG_SYS_SDRAM_END
#define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_PROM_OFFSET-32) diff --git a/include/configs/grsim_leon2.h b/include/configs/grsim_leon2.h index 39af8fe..294d6c4 100644 --- a/include/configs/grsim_leon2.h +++ b/include/configs/grsim_leon2.h @@ -229,10 +229,9 @@ #define CONFIG_SYS_RAM_SIZE CONFIG_SYS_SDRAM_SIZE #define CONFIG_SYS_RAM_END CONFIG_SYS_SDRAM_END
#define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_PROM_OFFSET-32) diff --git a/include/configs/gw8260.h b/include/configs/gw8260.h index 13bb822..35e6944 100644 --- a/include/configs/gw8260.h +++ b/include/configs/gw8260.h @@ -439,8 +439,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/hcu4.h b/include/configs/hcu4.h index d4168eb..c56efde 100644 --- a/include/configs/hcu4.h +++ b/include/configs/hcu4.h @@ -72,8 +72,7 @@
#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* OCM */ #define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE -#define CONFIG_SYS_GBL_DATA_SIZE 256 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_GBL_DATA_OFFSET - 0x4)
/*----------------------------------------------------------------------- diff --git a/include/configs/hcu5.h b/include/configs/hcu5.h index 7ff51a7..0c8fdf5 100644 --- a/include/configs/hcu5.h +++ b/include/configs/hcu5.h @@ -83,8 +83,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_BASE /* OCM */
#define CONFIG_SYS_INIT_RAM_SIZE (4 << 10) -#define CONFIG_SYS_GBL_DATA_SIZE 256 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_GBL_DATA_OFFSET - 0x4)
/*----------------------------------------------------------------------- diff --git a/include/configs/hermes.h b/include/configs/hermes.h index 089f1da..d849b5c 100644 --- a/include/configs/hermes.h +++ b/include/configs/hermes.h @@ -123,8 +123,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/hmi1001.h b/include/configs/hmi1001.h index aebb5e5..354072a 100644 --- a/include/configs/hmi1001.h +++ b/include/configs/hmi1001.h @@ -201,8 +201,7 @@ #define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE #endif
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/hymod.h b/include/configs/hymod.h index 5a4488b..7c4c2ba 100644 --- a/include/configs/hymod.h +++ b/include/configs/hymod.h @@ -378,8 +378,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/icon.h b/include/configs/icon.h index 4742429..2fac0ef 100644 --- a/include/configs/icon.h +++ b/include/configs/icon.h @@ -98,10 +98,9 @@ #define CONFIG_SYS_OCM_DATA_ADDR CONFIG_SYS_ISRAM_BASE #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_ISRAM_BASE /* Init RAM */ #define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* size of used area */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* sizeof init data */
#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ - CONFIG_SYS_GBL_DATA_SIZE) + GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_GBL_DATA_OFFSET - 0x4)
/* diff --git a/include/configs/idmr.h b/include/configs/idmr.h index 259d070..fc046d6 100644 --- a/include/configs/idmr.h +++ b/include/configs/idmr.h @@ -181,8 +181,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR 0x20000000 #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in internal SRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* diff --git a/include/configs/igep0020.h b/include/configs/igep0020.h index 34e8a57..16d9279 100644 --- a/include/configs/igep0020.h +++ b/include/configs/igep0020.h @@ -210,7 +210,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (128 << 10)) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* bytes for initial data */
/* * SMSC911x Ethernet @@ -223,6 +222,6 @@ #endif /* (CONFIG_CMD_NET) */
#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 -#define CONFIG_SYS_INIT_SP_ADDR (LOW_LEVEL_SRAM_STACK - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR (LOW_LEVEL_SRAM_STACK - GENERATED_GBL_DATA_SIZE)
#endif /* __CONFIG_H */ diff --git a/include/configs/igep0030.h b/include/configs/igep0030.h index 5e2e0ed..d6fbec7 100644 --- a/include/configs/igep0030.h +++ b/include/configs/igep0030.h @@ -207,9 +207,8 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (128 << 10)) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* bytes for initial data */
#endif /* __CONFIG_H */ diff --git a/include/configs/impa7.h b/include/configs/impa7.h index fdfa022..3328e63 100644 --- a/include/configs/impa7.h +++ b/include/configs/impa7.h @@ -42,7 +42,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
/* * Hardware drivers diff --git a/include/configs/imx27lite-common.h b/include/configs/imx27lite-common.h index 88e8d3d..b8dc5aa 100644 --- a/include/configs/imx27lite-common.h +++ b/include/configs/imx27lite-common.h @@ -89,7 +89,6 @@ /* malloc() len */ #define CONFIG_SYS_MALLOC_LEN (0x10000 + 512 * 1024) /* reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* memtest start address */ #define CONFIG_SYS_MEMTEST_START 0xA0000000 #define CONFIG_SYS_MEMTEST_END 0xA1000000 /* 16MB RAM test */ @@ -238,5 +237,5 @@ /* additions for new relocation code, must be added to all boards */ #define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + 0x1000 - /* Fix this */ \ - CONFIG_SYS_GBL_DATA_SIZE) + GENERATED_GBL_DATA_SIZE) #endif /* __IMX27LITE_COMMON_CONFIG_H */ diff --git a/include/configs/imx31_litekit.h b/include/configs/imx31_litekit.h index 09dc876..db4ec3d 100644 --- a/include/configs/imx31_litekit.h +++ b/include/configs/imx31_litekit.h @@ -54,7 +54,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128 * 1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
/* * Hardware drivers @@ -151,7 +150,7 @@ #define CONFIG_SYS_SDRAM_BASE CSD0_BASE #define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR #define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_GBL_DATA_OFFSET)
/*----------------------------------------------------------------------- diff --git a/include/configs/imx31_phycore.h b/include/configs/imx31_phycore.h index 62944a9..4d11f97 100644 --- a/include/configs/imx31_phycore.h +++ b/include/configs/imx31_phycore.h @@ -52,7 +52,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128 * 1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
/* * Hardware drivers diff --git a/include/configs/inka4x0.h b/include/configs/inka4x0.h index e381d0d..9b116e6 100644 --- a/include/configs/inka4x0.h +++ b/include/configs/inka4x0.h @@ -216,8 +216,7 @@ #define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE #endif
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/innokom.h b/include/configs/innokom.h index 01522cd..d8fcbdb 100644 --- a/include/configs/innokom.h +++ b/include/configs/innokom.h @@ -110,7 +110,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (256*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
#define CONFIG_SYS_LONGHELP /* undef to save memory */ #define CONFIG_SYS_PROMPT "uboot> " /* Monitor Command Prompt */ @@ -195,7 +194,7 @@ #define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1
/* * JFFS2 partitions diff --git a/include/configs/integratorap.h b/include/configs/integratorap.h index e0e8258..32ff193 100644 --- a/include/configs/integratorap.h +++ b/include/configs/integratorap.h @@ -53,7 +53,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
/* * PL010 Configuration diff --git a/include/configs/integratorcp.h b/include/configs/integratorcp.h index caafc93..2c8ca2d 100644 --- a/include/configs/integratorcp.h +++ b/include/configs/integratorcp.h @@ -48,7 +48,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
/* * Hardware drivers diff --git a/include/configs/intip.h b/include/configs/intip.h index 4e490ee..3ff4a86 100644 --- a/include/configs/intip.h +++ b/include/configs/intip.h @@ -107,9 +107,8 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_BASE /* OCM */ #define CONFIG_SYS_INIT_RAM_SIZE (4 << 10) -#define CONFIG_SYS_GBL_DATA_SIZE 256 /* num bytes initial data */ #define CONFIG_SYS_GBL_DATA_OFFSET \ - (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* diff --git a/include/configs/ipek01.h b/include/configs/ipek01.h index e7edf61..d382138 100644 --- a/include/configs/ipek01.h +++ b/include/configs/ipek01.h @@ -267,10 +267,9 @@ #define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/ixdp425.h b/include/configs/ixdp425.h index 768e836..28d41e2 100644 --- a/include/configs/ixdp425.h +++ b/include/configs/ixdp425.h @@ -46,7 +46,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
/* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE diff --git a/include/configs/ixdpg425.h b/include/configs/ixdpg425.h index 0c09234..637fd7d 100644 --- a/include/configs/ixdpg425.h +++ b/include/configs/ixdpg425.h @@ -68,7 +68,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (256 << 10) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
/* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE diff --git a/include/configs/jadecpu.h b/include/configs/jadecpu.h index a5d8764..c119392 100644 --- a/include/configs/jadecpu.h +++ b/include/configs/jadecpu.h @@ -197,7 +197,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (0x400000 - 0x8000) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* 128 bytes for initial data */
diff --git a/include/configs/jornada.h b/include/configs/jornada.h index 69a045c..4cbbf24 100644 --- a/include/configs/jornada.h +++ b/include/configs/jornada.h @@ -46,7 +46,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size for initial data */
/* * select serial console configuration diff --git a/include/configs/jupiter.h b/include/configs/jupiter.h index 70d67e7..8d27c0b 100644 --- a/include/configs/jupiter.h +++ b/include/configs/jupiter.h @@ -228,8 +228,7 @@ #define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE /* Size of used area in DPRAM */
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/katmai.h b/include/configs/katmai.h index df92576..3ed8dc7 100644 --- a/include/configs/katmai.h +++ b/include/configs/katmai.h @@ -97,9 +97,8 @@ #define CONFIG_SYS_OCM_DATA_ADDR CONFIG_SYS_ISRAM_BASE #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_ISRAM_BASE /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* num bytes initial data */
/*----------------------------------------------------------------------- diff --git a/include/configs/kb9202.h b/include/configs/kb9202.h index 41ec1d5..a2edaf9 100644 --- a/include/configs/kb9202.h +++ b/include/configs/kb9202.h @@ -65,7 +65,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (roundup(CONFIG_ENV_SIZE,4096) + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
diff --git a/include/configs/kilauea.h b/include/configs/kilauea.h index 6dff260..031f8fb 100644 --- a/include/configs/kilauea.h +++ b/include/configs/kilauea.h @@ -93,8 +93,7 @@ #endif /* defined(CONFIG_SYS_INIT_DCACHE_CS) */
#define CONFIG_SYS_INIT_RAM_SIZE (4 << 10) /* 4 KiB */ -#define CONFIG_SYS_GBL_DATA_SIZE 256 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
/* * If the data cache is being used for the primordial stack and global diff --git a/include/configs/km8xx.h b/include/configs/km8xx.h index 5c2a7ad..7683fe5 100644 --- a/include/configs/km8xx.h +++ b/include/configs/km8xx.h @@ -108,8 +108,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/km_arm.h b/include/configs/km_arm.h index faa0f50..986c46e 100644 --- a/include/configs/km_arm.h +++ b/include/configs/km_arm.h @@ -108,7 +108,6 @@ #define CONFIG_KM_CONSOLE_TTY "ttyS0"
/* * Other required minimal configurations @@ -183,5 +182,5 @@ int get_scl (void); /* additions for new relocation code, must be added to all boards */ #define CONFIG_SYS_SDRAM_BASE 0x00000000 #define CONFIG_SYS_INIT_SP_ADDR (0x00000000 + 0x1000 - /* Fix this */ \ - CONFIG_SYS_GBL_DATA_SIZE) + GENERATED_GBL_DATA_SIZE) #endif /* _CONFIG_KM_ARM_H */ diff --git a/include/configs/kmeter1.h b/include/configs/kmeter1.h index 81536a0..8fcadfe 100644 --- a/include/configs/kmeter1.h +++ b/include/configs/kmeter1.h @@ -180,8 +180,7 @@ #define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xE6000000 /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 0x100 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
/* * Local Bus Configuration & Clock Setup diff --git a/include/configs/korat.h b/include/configs/korat.h index 55485c2..66cb533 100644 --- a/include/configs/korat.h +++ b/include/configs/korat.h @@ -89,8 +89,7 @@ #undef CONFIG_SYS_INIT_RAM_DCACHE #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_BASE /* OCM */ #define CONFIG_SYS_INIT_RAM_SIZE (4 << 10) -#define CONFIG_SYS_GBL_DATA_SIZE 256 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_GBL_DATA_OFFSET - 0x4)
/* diff --git a/include/configs/kvme080.h b/include/configs/kvme080.h index c597204..95fc243 100644 --- a/include/configs/kvme080.h +++ b/include/configs/kvme080.h @@ -118,8 +118,7 @@
#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 -#define CONFIG_SYS_GBL_DATA_SIZE 128 -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
#define CONFIG_SYS_SDRAM_BASE 0x00000000 #define CONFIG_SYS_FLASH_BASE 0x7C000000 diff --git a/include/configs/lart.h b/include/configs/lart.h index 2d3b369..795cf34 100644 --- a/include/configs/lart.h +++ b/include/configs/lart.h @@ -42,7 +42,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
/* * Hardware drivers diff --git a/include/configs/linkstation.h b/include/configs/linkstation.h index 7a2a8c3..b00647b 100644 --- a/include/configs/linkstation.h +++ b/include/configs/linkstation.h @@ -276,8 +276,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 #endif #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 -#define CONFIG_SYS_GBL_DATA_SIZE 128 -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
/*---------------------------------------------------------------------- * Serial configuration diff --git a/include/configs/lpc2292sodimm.h b/include/configs/lpc2292sodimm.h index 65276a2..a0fe32e 100644 --- a/include/configs/lpc2292sodimm.h +++ b/include/configs/lpc2292sodimm.h @@ -48,7 +48,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
/* * Hardware drivers diff --git a/include/configs/lpd7a400.h b/include/configs/lpd7a400.h index bf4a57d..06f3d7e 100644 --- a/include/configs/lpd7a400.h +++ b/include/configs/lpd7a400.h @@ -38,7 +38,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
/* * select serial console configuration diff --git a/include/configs/lpd7a404.h b/include/configs/lpd7a404.h index 557f389..7535f62 100644 --- a/include/configs/lpd7a404.h +++ b/include/configs/lpd7a404.h @@ -38,7 +38,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
/* * select serial console configuration diff --git a/include/configs/luan.h b/include/configs/luan.h index 60ebafb..3b4761b 100644 --- a/include/configs/luan.h +++ b/include/configs/luan.h @@ -81,8 +81,7 @@ *----------------------------------------------------------------------*/ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_ISRAM_BASE #define CONFIG_SYS_INIT_RAM_SIZE (8 << 10) -#define CONFIG_SYS_GBL_DATA_SIZE 256 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/lubbock.h b/include/configs/lubbock.h index 62f9691..b7d53b6 100644 --- a/include/configs/lubbock.h +++ b/include/configs/lubbock.h @@ -53,7 +53,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
/* * Hardware drivers @@ -177,7 +176,7 @@ #define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1
#define FPGA_REGS_BASE_PHYSICAL 0x08000000
diff --git a/include/configs/lwmon.h b/include/configs/lwmon.h index cf9a2ca..e23b0a1 100644 --- a/include/configs/lwmon.h +++ b/include/configs/lwmon.h @@ -276,8 +276,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 68 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/lwmon5.h b/include/configs/lwmon5.h index 0f637c7..4c9744c 100644 --- a/include/configs/lwmon5.h +++ b/include/configs/lwmon5.h @@ -88,9 +88,8 @@ #define CONFIG_SYS_INIT_RAM_DCACHE 1 /* d-cache as init ram */ #define CONFIG_SYS_INIT_RAM_ADDR 0x70000000 /* DCache */ #define CONFIG_SYS_INIT_RAM_SIZE (4 << 10) -#define CONFIG_SYS_GBL_DATA_SIZE 256 /* num bytes initial data*/ #define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ - CONFIG_SYS_GBL_DATA_SIZE) + GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET /* unused GPT0 COMP reg */ #define CONFIG_SYS_POST_WORD_ADDR (CONFIG_SYS_PERIPHERAL_BASE + GPT0_COMP6) diff --git a/include/configs/m501sk.h b/include/configs/m501sk.h index 26c2bcb..68f0415 100644 --- a/include/configs/m501sk.h +++ b/include/configs/m501sk.h @@ -77,7 +77,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* Bytes reserved for initial data */
diff --git a/include/configs/makalu.h b/include/configs/makalu.h index ae07dc7..fcc789d 100644 --- a/include/configs/makalu.h +++ b/include/configs/makalu.h @@ -89,8 +89,7 @@ #endif /* defined(CONFIG_SYS_INIT_DCACHE_CS) */
/* * If the data cache is being used for the primordial stack and global diff --git a/include/configs/manroland/mpc5200-common.h b/include/configs/manroland/mpc5200-common.h index 62398a8..3e4131e 100644 --- a/include/configs/manroland/mpc5200-common.h +++ b/include/configs/manroland/mpc5200-common.h @@ -113,9 +113,8 @@ #define CONFIG_SYS_MBAR 0xF0000000 #define CONFIG_SYS_DEFAULT_MBAR 0x80000000
-#define CONFIG_SYS_GBL_DATA_SIZE 128 #define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE -\ - CONFIG_SYS_GBL_DATA_SIZE) + GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#define CONFIG_SYS_SDRAM_BASE 0x00000000 diff --git a/include/configs/mcc200.h b/include/configs/mcc200.h index e127504..f1cdc40 100644 --- a/include/configs/mcc200.h +++ b/include/configs/mcc200.h @@ -262,8 +262,7 @@ #define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE /* Size of used area in DPRAM */
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/mcu25.h b/include/configs/mcu25.h index 336871d..a162291 100644 --- a/include/configs/mcu25.h +++ b/include/configs/mcu25.h @@ -72,8 +72,7 @@
/*----------------------------------------------------------------------- diff --git a/include/configs/mecp5123.h b/include/configs/mecp5123.h index 501e78c..b9cf1dc 100644 --- a/include/configs/mecp5123.h +++ b/include/configs/mecp5123.h @@ -208,8 +208,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_SRAM_BASE /* Init RAM addr */ #define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_SRAM_SIZE
-#define CONFIG_SYS_GBL_DATA_SIZE 0x100 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* Start of monitor */ diff --git a/include/configs/mecp5200.h b/include/configs/mecp5200.h index d577f1d..9961f12 100644 --- a/include/configs/mecp5200.h +++ b/include/configs/mecp5200.h @@ -218,8 +218,7 @@ #define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE /* Size of used area in DPRAM */
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/meesc.h b/include/configs/meesc.h index dbb2531..41a953e 100644 --- a/include/configs/meesc.h +++ b/include/configs/meesc.h @@ -182,7 +182,6 @@ */ #define CONFIG_SYS_MALLOC_LEN ROUND(3 * CONFIG_ENV_SIZE + \ 128*1024, 0x1000) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* 128 bytes for initial data */
#define CONFIG_STACKSIZE (32 * 1024) /* regular stack */
diff --git a/include/configs/mgcoge.h b/include/configs/mgcoge.h index bdc98a6..6dec0ee 100644 --- a/include/configs/mgcoge.h +++ b/include/configs/mgcoge.h @@ -179,8 +179,7 @@
/* Hard reset configuration word */ diff --git a/include/configs/microblaze-generic.h b/include/configs/microblaze-generic.h index bcdd86e..75e4e07 100644 --- a/include/configs/microblaze-generic.h +++ b/include/configs/microblaze-generic.h @@ -135,15 +135,14 @@ #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x1000)
/* global pointer */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size of global data */ /* start of global data */ #define CONFIG_SYS_GBL_DATA_OFFSET \ (CONFIG_SYS_SDRAM_BASE + CONFIG_SYS_SDRAM_SIZE \ - - CONFIG_SYS_GBL_DATA_SIZE) + - GENERATED_GBL_DATA_SIZE)
/* monitor code */ #define SIZE 0x40000 -#define CONFIG_SYS_MONITOR_LEN (SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_MONITOR_LEN (SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_MONITOR_BASE \ (CONFIG_SYS_GBL_DATA_OFFSET - CONFIG_SYS_MONITOR_LEN) #define CONFIG_SYS_MONITOR_END \ diff --git a/include/configs/modnet50.h b/include/configs/modnet50.h index 74bab5f..57707f3 100644 --- a/include/configs/modnet50.h +++ b/include/configs/modnet50.h @@ -46,7 +46,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128
/* * Hardware drivers diff --git a/include/configs/motionpro.h b/include/configs/motionpro.h index 6c13e3f..bdcae59 100644 --- a/include/configs/motionpro.h +++ b/include/configs/motionpro.h @@ -202,8 +202,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR MPC5XXX_SRAM #define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE
-#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/mp2usb.h b/include/configs/mp2usb.h index 3138b49..956603a 100644 --- a/include/configs/mp2usb.h +++ b/include/configs/mp2usb.h @@ -81,7 +81,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
#define CONFIG_BAUDRATE 115200
diff --git a/include/configs/mpc5121-common.h b/include/configs/mpc5121-common.h index 399e43f..a5e77c5 100644 --- a/include/configs/mpc5121-common.h +++ b/include/configs/mpc5121-common.h @@ -27,9 +27,8 @@ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_SRAM_BASE /* Init RAM base */ #define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_SRAM_SIZE /* Size of area */
-#define CONFIG_SYS_GBL_DATA_SIZE 0x100 /* num bytes of initial data */ #define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ - CONFIG_SYS_GBL_DATA_SIZE) + GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_GBL_DATA_OFFSET - 0x4)
#define CONFIG_SYS_MEMTEST_START 0x00200000 /* memtest region */ diff --git a/include/configs/mpc5121ads.h b/include/configs/mpc5121ads.h index cbfcb70..f966325 100644 --- a/include/configs/mpc5121ads.h +++ b/include/configs/mpc5121ads.h @@ -272,8 +272,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_SRAM_BASE /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_SRAM_SIZE /* Size of used area in RAM */
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* Start of monitor */ diff --git a/include/configs/mpc7448hpc2.h b/include/configs/mpc7448hpc2.h index 1ab58ad..9274464 100644 --- a/include/configs/mpc7448hpc2.h +++ b/include/configs/mpc7448hpc2.h @@ -223,8 +223,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR 0x07d00000 /* unused memory region */ #define CONFIG_SYS_INIT_RAM_SIZE 0x4000/* larger space - we have SDRAM initialized */
-#define CONFIG_SYS_GBL_DATA_SIZE 128/* size in bytes reserved for init data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
/*----------------------------------------------------------------------- * Start addresses for the final memory configuration diff --git a/include/configs/mpc8308_p1m.h b/include/configs/mpc8308_p1m.h index 1d0e1f2..d7a3a96 100644 --- a/include/configs/mpc8308_p1m.h +++ b/include/configs/mpc8308_p1m.h @@ -221,9 +221,8 @@ #define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xE6000000 /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 0x100 /* num bytes initial data */ #define CONFIG_SYS_GBL_DATA_OFFSET \ - (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
/* * Local Bus Configuration & Clock Setup diff --git a/include/configs/mpr2.h b/include/configs/mpr2.h index 0a472a6..311f524 100644 --- a/include/configs/mpr2.h +++ b/include/configs/mpr2.h @@ -57,7 +57,6 @@ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE #define CONFIG_SYS_MONITOR_LEN (128 * 1024) #define CONFIG_SYS_MALLOC_LEN (256 * 1024) -#define CONFIG_SYS_GBL_DATA_SIZE 256
/* Memory */ #define CONFIG_SYS_SDRAM_BASE 0x8C000000 diff --git a/include/configs/ms7720se.h b/include/configs/ms7720se.h index 0ea3527..5304237 100644 --- a/include/configs/ms7720se.h +++ b/include/configs/ms7720se.h @@ -76,7 +76,6 @@ #define CONFIG_SYS_MONITOR_BASE MS7720SE_FLASH_BASE_1 #define CONFIG_SYS_MONITOR_LEN (128 * 1024) #define CONFIG_SYS_MALLOC_LEN (256 * 1024) -#define CONFIG_SYS_GBL_DATA_SIZE 256 #define CONFIG_SYS_BOOTMAPSZ (8 * 1024 * 1024)
diff --git a/include/configs/ms7722se.h b/include/configs/ms7722se.h index 0251428..1ddadf6 100644 --- a/include/configs/ms7722se.h +++ b/include/configs/ms7722se.h @@ -89,7 +89,6 @@ in Flash (NOT run time address in SDRAM) ?!? */ #define CONFIG_SYS_MONITOR_LEN (128 * 1024) /* */ #define CONFIG_SYS_MALLOC_LEN (256 * 1024) /* Size of DRAM reserved for malloc() use */ -#define CONFIG_SYS_GBL_DATA_SIZE (256) /* size in bytes reserved for initial data */ #define CONFIG_SYS_BOOTMAPSZ (8 * 1024 * 1024)
/* FLASH */ diff --git a/include/configs/ms7750se.h b/include/configs/ms7750se.h index 02090f2..9b43acb 100644 --- a/include/configs/ms7750se.h +++ b/include/configs/ms7750se.h @@ -81,7 +81,6 @@ #define CONFIG_SYS_MONITOR_LEN (128 * 1024) #define CONFIG_SYS_MALLOC_LEN (256 * 1024) /* Size of DRAM reserved for malloc() use */
-#define CONFIG_SYS_GBL_DATA_SIZE (256) /* size in bytes reserved for initial data */ #define CONFIG_SYS_BOOTMAPSZ (8 * 1024 * 1024) #define CONFIG_SYS_RX_ETH_BUFFER (8)
diff --git a/include/configs/muas3001.h b/include/configs/muas3001.h index e35f923..8b3022b 100644 --- a/include/configs/muas3001.h +++ b/include/configs/muas3001.h @@ -261,8 +261,7 @@
/* Hard reset configuration word */ diff --git a/include/configs/munices.h b/include/configs/munices.h index db3cc35..425a1d8 100644 --- a/include/configs/munices.h +++ b/include/configs/munices.h @@ -118,8 +118,7 @@ /* Use SRAM until RAM will be available */ #define CONFIG_SYS_INIT_RAM_ADDR MPC5XXX_SRAM #define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/mv-common.h b/include/configs/mv-common.h index bdcebd3..bc81f2d 100644 --- a/include/configs/mv-common.h +++ b/include/configs/mv-common.h @@ -131,7 +131,6 @@ */ #define CONFIG_SYS_MALLOC_LEN (1024 * 1024) /* 1MiB for malloc() */ /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_SIZE 128
/* * Other required minimal configurations diff --git a/include/configs/mx1ads.h b/include/configs/mx1ads.h index b2ffd3e..21b7ec7 100644 --- a/include/configs/mx1ads.h +++ b/include/configs/mx1ads.h @@ -61,7 +61,6 @@ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024)
/* * CS8900 Ethernet drivers diff --git a/include/configs/mx1fs2.h b/include/configs/mx1fs2.h index 90a8d84..0641bef 100644 --- a/include/configs/mx1fs2.h +++ b/include/configs/mx1fs2.h @@ -99,7 +99,6 @@ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (128<<10) )
#define CONFIG_STACKSIZE (120<<10) /* stack size */
diff --git a/include/configs/mx31ads.h b/include/configs/mx31ads.h index 57955df..d2798e97 100644 --- a/include/configs/mx31ads.h +++ b/include/configs/mx31ads.h @@ -51,7 +51,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128 * 1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
/* * Hardware drivers diff --git a/include/configs/mx31pdk.h b/include/configs/mx31pdk.h index 4b4fb1a..47e7c86 100644 --- a/include/configs/mx31pdk.h +++ b/include/configs/mx31pdk.h @@ -55,7 +55,6 @@ */ #define CONFIG_SYS_MALLOC_LEN (2*CONFIG_ENV_SIZE + 2 * 128 * 1024) /* Bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_SIZE 128
/* * Hardware drivers diff --git a/include/configs/mx51evk.h b/include/configs/mx51evk.h index 6165473..f31fc4e 100644 --- a/include/configs/mx51evk.h +++ b/include/configs/mx51evk.h @@ -52,7 +52,6 @@ */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 2 * 1024 * 1024) /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_SIZE 128
#define BOARD_LATE_INIT
diff --git a/include/configs/neo.h b/include/configs/neo.h index 5ee6c7f..8de5aaf 100644 --- a/include/configs/neo.h +++ b/include/configs/neo.h @@ -210,8 +210,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ #define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */
/* diff --git a/include/configs/netstar.h b/include/configs/netstar.h index c63c846..ee5a995 100644 --- a/include/configs/netstar.h +++ b/include/configs/netstar.h @@ -72,7 +72,6 @@ /* * Size of malloc() pool */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 #define CONFIG_SYS_MALLOC_LEN (4 * 1024 * 1024)
/* diff --git a/include/configs/nhk8815.h b/include/configs/nhk8815.h index 2b640dc..49a16ab 100644 --- a/include/configs/nhk8815.h +++ b/include/configs/nhk8815.h @@ -90,7 +90,6 @@ #define CONFIG_SYS_MEMTEST_START 0x00000000 #define CONFIG_SYS_MEMTEST_END 0x0FFFFFFF #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 256 * 1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* for initial data */
#define BOARD_LATE_INIT /* call board_late_init during start up */
diff --git a/include/configs/nios2-generic.h b/include/configs/nios2-generic.h index e4bf57b..53f2084 100644 --- a/include/configs/nios2-generic.h +++ b/include/configs/nios2-generic.h @@ -123,12 +123,11 @@ #define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_SDRAM_BASE + \ CONFIG_SYS_SDRAM_SIZE - \ CONFIG_SYS_MONITOR_LEN) -#define CONFIG_SYS_GBL_DATA_SIZE 256 /* Global data size rsvd */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 0x20000) #define CONFIG_SYS_MALLOC_BASE (CONFIG_SYS_MONITOR_BASE - \ CONFIG_SYS_MALLOC_LEN) #define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_MALLOC_BASE - \ - CONFIG_SYS_GBL_DATA_SIZE) + GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP CONFIG_SYS_GBL_DATA_OFFSET
/* diff --git a/include/configs/ns9750dev.h b/include/configs/ns9750dev.h index 79dcd64..e6b774f 100644 --- a/include/configs/ns9750dev.h +++ b/include/configs/ns9750dev.h @@ -50,7 +50,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial * data */
/* diff --git a/include/configs/o2dnt.h b/include/configs/o2dnt.h index b5878b4..9f5a0b8 100644 --- a/include/configs/o2dnt.h +++ b/include/configs/o2dnt.h @@ -217,8 +217,7 @@ #define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE /* Size of used area in DPRAM */
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/ocotea.h b/include/configs/ocotea.h index fe6f579..d0fe9da 100644 --- a/include/configs/ocotea.h +++ b/include/configs/ocotea.h @@ -73,9 +73,8 @@ #define CONFIG_SYS_OCM_DATA_ADDR CONFIG_SYS_ISRAM_BASE #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_ISRAM_BASE /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* num bytes initial data */
/*----------------------------------------------------------------------- diff --git a/include/configs/omap1510inn.h b/include/configs/omap1510inn.h index b0ebafd..9ff4f84 100644 --- a/include/configs/omap1510inn.h +++ b/include/configs/omap1510inn.h @@ -50,7 +50,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
/* * Hardware drivers diff --git a/include/configs/omap1610h2.h b/include/configs/omap1610h2.h index 0bbb5b3..2936dcc 100644 --- a/include/configs/omap1610h2.h +++ b/include/configs/omap1610h2.h @@ -52,7 +52,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
/* * Hardware drivers diff --git a/include/configs/omap1610inn.h b/include/configs/omap1610inn.h index 832dd42..0b41c46 100644 --- a/include/configs/omap1610inn.h +++ b/include/configs/omap1610inn.h @@ -51,7 +51,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
/* * Hardware drivers diff --git a/include/configs/omap2420h4.h b/include/configs/omap2420h4.h index 47437b0..7161ab1 100644 --- a/include/configs/omap2420h4.h +++ b/include/configs/omap2420h4.h @@ -72,7 +72,6 @@ */ #define CONFIG_ENV_SIZE SZ_128K /* Total Size of Environment Sector */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + SZ_128K) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
/* * Hardware drivers diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index 900dbd3..1c9a007 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -75,7 +75,6 @@ #define CONFIG_ENV_SIZE (128 << 10) /* 128 KiB */ /* Sector */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (128 << 10)) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* bytes reserved for */ /* initial data */
/* @@ -348,6 +347,6 @@ extern unsigned int boot_flash_type;
/* additions for new relocation code, must be added to all boards */ #define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 -#define CONFIG_SYS_INIT_SP_ADDR (LOW_LEVEL_SRAM_STACK - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR (LOW_LEVEL_SRAM_STACK - GENERATED_GBL_DATA_SIZE)
#endif /* __CONFIG_H */ diff --git a/include/configs/omap3_evm.h b/include/configs/omap3_evm.h index c4aa220..e925f3b 100644 --- a/include/configs/omap3_evm.h +++ b/include/configs/omap3_evm.h @@ -71,7 +71,6 @@ #define CONFIG_ENV_SIZE (128 << 10) /* 128 KiB */ /* Sector */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (128 << 10)) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* bytes reserved for */ /* initial data */ /* * Hardware drivers diff --git a/include/configs/omap3_overo.h b/include/configs/omap3_overo.h index 69f9126..0292078 100644 --- a/include/configs/omap3_overo.h +++ b/include/configs/omap3_overo.h @@ -58,7 +58,6 @@ #define CONFIG_ENV_SIZE (128 << 10) /* 128 KiB */ /* Sector */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (128 << 10)) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* bytes reserved for */ /* initial data */
/* @@ -325,6 +324,6 @@ extern unsigned int boot_flash_type; #endif /* (CONFIG_CMD_NET) */
#endif /* __CONFIG_H */ diff --git a/include/configs/omap3_pandora.h b/include/configs/omap3_pandora.h index 3308ace..b78aacf 100644 --- a/include/configs/omap3_pandora.h +++ b/include/configs/omap3_pandora.h @@ -61,7 +61,6 @@ #define CONFIG_ENV_SIZE (128 << 10) /* 128 KiB */ /* Sector */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (128 << 10)) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* bytes reserved for */ /* initial data */
/* diff --git a/include/configs/omap3_sdp3430.h b/include/configs/omap3_sdp3430.h index 5439aa3..fab263d 100644 --- a/include/configs/omap3_sdp3430.h +++ b/include/configs/omap3_sdp3430.h @@ -78,7 +78,6 @@ */ #define CONFIG_ENV_SIZE (256 << 10) #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (256 << 10)) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* bytes reserved for */ /* initial data */
/*--------------------------------------------------------------------------*/ diff --git a/include/configs/omap3_zoom1.h b/include/configs/omap3_zoom1.h index f612e0f..10b248a 100644 --- a/include/configs/omap3_zoom1.h +++ b/include/configs/omap3_zoom1.h @@ -67,7 +67,6 @@ #define CONFIG_ENV_SIZE (128 << 10) /* 128 KiB */ /* Sector */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (128 << 10)) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* bytes reserved for */ /* initial data */
/* diff --git a/include/configs/omap3_zoom2.h b/include/configs/omap3_zoom2.h index aaf929e..b7c301f 100644 --- a/include/configs/omap3_zoom2.h +++ b/include/configs/omap3_zoom2.h @@ -68,7 +68,6 @@ #define CONFIG_ENV_SIZE (128 << 10) /* 128 KiB */ /* Sector */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (128 << 10)) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* bytes reserved for */ /* initial data */ /* * Hardware drivers diff --git a/include/configs/omap4_panda.h b/include/configs/omap4_panda.h index b52ca19..74defab 100644 --- a/include/configs/omap4_panda.h +++ b/include/configs/omap4_panda.h @@ -67,7 +67,6 @@ */ #define CONFIG_ENV_SIZE (256 << 10) #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (256 << 10)) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* bytes reserved for */ /* initial data */ /* Vector Base */ #define CONFIG_SYS_CA9_VECTOR_BASE SRAM_ROM_VECT_BASE @@ -228,6 +227,6 @@ #define CONFIG_NR_DRAM_BANKS 1
#define CONFIG_SYS_SDRAM_BASE 0x80000000 -#define CONFIG_SYS_INIT_SP_ADDR (LOW_LEVEL_SRAM_STACK - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR (LOW_LEVEL_SRAM_STACK - GENERATED_GBL_DATA_SIZE)
#endif /* __CONFIG_H */ diff --git a/include/configs/omap4_sdp4430.h b/include/configs/omap4_sdp4430.h index 174d73f..26c380d 100644 --- a/include/configs/omap4_sdp4430.h +++ b/include/configs/omap4_sdp4430.h @@ -68,7 +68,6 @@ */ #define CONFIG_ENV_SIZE (128 << 10) #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (256 << 10)) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* bytes reserved for */ /* initial data */ /* Vector Base */ #define CONFIG_SYS_CA9_VECTOR_BASE SRAM_ROM_VECT_BASE @@ -233,6 +232,6 @@ #define CONFIG_NR_DRAM_BANKS 1
#endif /* __CONFIG_H */ diff --git a/include/configs/omap5912osk.h b/include/configs/omap5912osk.h index bc660e3..b875464 100644 --- a/include/configs/omap5912osk.h +++ b/include/configs/omap5912osk.h @@ -54,7 +54,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
/* * Hardware drivers diff --git a/include/configs/omap730p2.h b/include/configs/omap730p2.h index a6a8a02..fa3681e 100644 --- a/include/configs/omap730p2.h +++ b/include/configs/omap730p2.h @@ -59,7 +59,6 @@ */
/* * Hardware drivers diff --git a/include/configs/otc570.h b/include/configs/otc570.h index 4a1cede..af0202c 100644 --- a/include/configs/otc570.h +++ b/include/configs/otc570.h @@ -235,7 +235,6 @@ */ #define CONFIG_SYS_MALLOC_LEN ROUND(3 * CONFIG_ENV_SIZE + \ 128*1024, 0x1000) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* 128 bytes for initial data */
diff --git a/include/configs/p3mx.h b/include/configs/p3mx.h index 97703d6..71eb784 100644 --- a/include/configs/p3mx.h +++ b/include/configs/p3mx.h @@ -99,8 +99,7 @@ #undef CONFIG_SYS_INIT_RAM_LOCK #define CONFIG_SYS_INIT_RAM_ADDR 0x42000000 #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for init data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
/*----------------------------------------------------------------------- diff --git a/include/configs/p3p440.h b/include/configs/p3p440.h index 20a0755..719a12a 100644 --- a/include/configs/p3p440.h +++ b/include/configs/p3p440.h @@ -62,9 +62,8 @@ *----------------------------------------------------------------------*/ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_ISRAM_BASE /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* num bytes initial data */
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon*/ diff --git a/include/configs/palmld.h b/include/configs/palmld.h index a2310a9..65f1306 100644 --- a/include/configs/palmld.h +++ b/include/configs/palmld.h @@ -33,7 +33,6 @@ */ #define CONFIG_ENV_OVERWRITE #define CONFIG_SYS_MALLOC_LEN (128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 #define CONFIG_SYS_TEXT_BASE 0x0
#define CONFIG_BOOTCOMMAND \ @@ -156,7 +155,7 @@ #define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_DRAM_BASE
#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 -#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_GBL_DATA_SIZE + PHYS_SDRAM_1) +#define CONFIG_SYS_INIT_SP_ADDR (GENERATED_GBL_DATA_SIZE + PHYS_SDRAM_1)
/* * NOR FLASH diff --git a/include/configs/palmtc.h b/include/configs/palmtc.h index 40ab0bf..3f6c2f1 100644 --- a/include/configs/palmtc.h +++ b/include/configs/palmtc.h @@ -35,7 +35,6 @@ */ #define CONFIG_ENV_OVERWRITE #define CONFIG_SYS_MALLOC_LEN (128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 #define CONFIG_SYS_TEXT_BASE 0x0
#define CONFIG_BOOTCOMMAND \ @@ -157,7 +156,7 @@ #define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_DRAM_BASE
/* * NOR FLASH diff --git a/include/configs/pcm030.h b/include/configs/pcm030.h index 1249b0d..676f40c 100644 --- a/include/configs/pcm030.h +++ b/include/configs/pcm030.h @@ -225,10 +225,9 @@ RTC configuration #define CONFIG_SYS_INIT_RAM_ADDR MPC5XXX_SRAM #define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE /* Size of used */ /* area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes */ /* reserved for initial data */ #define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ - CONFIG_SYS_GBL_DATA_SIZE) + GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/pcs440ep.h b/include/configs/pcs440ep.h index bf89ddc..deb5b33 100644 --- a/include/configs/pcs440ep.h +++ b/include/configs/pcs440ep.h @@ -75,8 +75,7 @@ #define CONFIG_SYS_INIT_RAM_DCACHE 1 /* d-cache as init ram */ #define CONFIG_SYS_INIT_RAM_ADDR 0x70000000 /* DCache */ #define CONFIG_SYS_INIT_RAM_SIZE (4 << 10) -#define CONFIG_SYS_GBL_DATA_SIZE 256 /* num bytes initial data*/ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/pdnb3.h b/include/configs/pdnb3.h index 220f686..33fa6ee 100644 --- a/include/configs/pdnb3.h +++ b/include/configs/pdnb3.h @@ -64,7 +64,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (1 << 20) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
/* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE diff --git a/include/configs/pf5200.h b/include/configs/pf5200.h index 3f66a98..5830345 100644 --- a/include/configs/pf5200.h +++ b/include/configs/pf5200.h @@ -223,8 +223,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR MPC5XXX_SRAM #define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE /* Size of used area in DPRAM */
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/pleb2.h b/include/configs/pleb2.h index b366f38..64654f8 100644 --- a/include/configs/pleb2.h +++ b/include/configs/pleb2.h @@ -50,7 +50,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
/* * Hardware drivers @@ -175,7 +174,7 @@ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE
/* * GPIO settings diff --git a/include/configs/pm9261.h b/include/configs/pm9261.h index a0b00e9..aee842f 100644 --- a/include/configs/pm9261.h +++ b/include/configs/pm9261.h @@ -370,7 +370,6 @@ */ #define CONFIG_SYS_MALLOC_LEN \ ROUND(3 * CONFIG_ENV_SIZE + 128 * 1024, 0x1000) -#define CONFIG_SYS_GBL_DATA_SIZE 128
diff --git a/include/configs/pm9263.h b/include/configs/pm9263.h index 9735e6a..42ec855 100644 --- a/include/configs/pm9263.h +++ b/include/configs/pm9263.h @@ -401,7 +401,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN ROUND(3 * CONFIG_ENV_SIZE + 128 * 1024, 0x1000) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* 128 bytes for initial data */
diff --git a/include/configs/pm9g45.h b/include/configs/pm9g45.h index 690f119..2fbe5c6 100644 --- a/include/configs/pm9g45.h +++ b/include/configs/pm9g45.h @@ -175,7 +175,6 @@ */ #define CONFIG_SYS_MALLOC_LEN ROUND(3 * CONFIG_ENV_SIZE + 128*1024,\ 0x1000) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* 128 bytes for initial data */
#define CONFIG_STACKSIZE (32*1024) /* regular stack */
diff --git a/include/configs/ppmc7xx.h b/include/configs/ppmc7xx.h index 831097e..652b85e 100644 --- a/include/configs/ppmc7xx.h +++ b/include/configs/ppmc7xx.h @@ -298,14 +298,13 @@ * * CONFIG_SYS_INIT_RAM_ADDR - Address of Init RAM, above exception vect * CONFIG_SYS_INIT_RAM_SIZE - Size of Init RAM - * CONFIG_SYS_GBL_DATA_SIZE - Ammount of RAM to reserve for global data + * GENERATED_GBL_DATA_SIZE - Ammount of RAM to reserve for global data * CONFIG_SYS_GBL_DATA_OFFSET - Start of global data, top of stack */
#define CONFIG_SYS_INIT_RAM_ADDR (CONFIG_SYS_SDRAM_BASE + 0x4000) #define CONFIG_SYS_INIT_RAM_SIZE 0x4000 -#define CONFIG_SYS_GBL_DATA_SIZE 128 -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
/* diff --git a/include/configs/ppmc8260.h b/include/configs/ppmc8260.h index d37d588..68c6277 100644 --- a/include/configs/ppmc8260.h +++ b/include/configs/ppmc8260.h @@ -423,8 +423,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/pxa255_idp.h b/include/configs/pxa255_idp.h index b4327c6..1ff35e3 100644 --- a/include/configs/pxa255_idp.h +++ b/include/configs/pxa255_idp.h @@ -76,7 +76,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
/* * PXA250 IDP memory map information @@ -294,7 +293,7 @@ #define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1
/* * GPIO settings diff --git a/include/configs/qong.h b/include/configs/qong.h index 900c279..e2f7a5e 100644 --- a/include/configs/qong.h +++ b/include/configs/qong.h @@ -43,7 +43,6 @@ */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 1024 * 1024) /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_SIZE 128
/* * Hardware drivers @@ -301,7 +300,7 @@ extern int qong_nand_rdy(void *chip); #define CONFIG_SYS_SDRAM_BASE 0x80000000 #define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR #define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_GBL_DATA_OFFSET)
#define CONFIG_BOARD_EARLY_INIT_F 1 diff --git a/include/configs/quad100hd.h b/include/configs/quad100hd.h index e3929bb..5fd7838 100644 --- a/include/configs/quad100hd.h +++ b/include/configs/quad100hd.h @@ -249,8 +249,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of OCM */ #define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */
/*----------------------------------------------------------------------- diff --git a/include/configs/quantum.h b/include/configs/quantum.h index 54a8886..0ebb094 100644 --- a/include/configs/quantum.h +++ b/include/configs/quantum.h @@ -159,8 +159,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/r2dplus.h b/include/configs/r2dplus.h index bc518db..ade6f7c 100644 --- a/include/configs/r2dplus.h +++ b/include/configs/r2dplus.h @@ -58,7 +58,6 @@ /* Size of DRAM reserved for malloc() use */ #define CONFIG_SYS_MALLOC_LEN (1024 * 1024) /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_SIZE (256) #define CONFIG_SYS_BOOTMAPSZ (8 * 1024 * 1024)
/* diff --git a/include/configs/r7780mp.h b/include/configs/r7780mp.h index 41376da..3416cb8 100644 --- a/include/configs/r7780mp.h +++ b/include/configs/r7780mp.h @@ -101,7 +101,6 @@ #define CONFIG_SYS_MALLOC_LEN (1204 * 1024)
/* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_SIZE (256) #define CONFIG_SYS_BOOTMAPSZ (8 * 1024 * 1024) #define CONFIG_SYS_RX_ETH_BUFFER (8)
diff --git a/include/configs/redwood.h b/include/configs/redwood.h index 53f817c..f75ab67 100644 --- a/include/configs/redwood.h +++ b/include/configs/redwood.h @@ -90,9 +90,8 @@ #define CONFIG_SYS_OCM_DATA_ADDR CONFIG_SYS_ISRAM_BASE #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_ISRAM_BASE /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* num bytes initial data */
/*----------------------------------------------------------------------- diff --git a/include/configs/rmu.h b/include/configs/rmu.h index 8e6a0a3..064716f 100644 --- a/include/configs/rmu.h +++ b/include/configs/rmu.h @@ -155,8 +155,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/rsdproto.h b/include/configs/rsdproto.h index 9e705de..5761f20 100644 --- a/include/configs/rsdproto.h +++ b/include/configs/rsdproto.h @@ -254,8 +254,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/rsk7203.h b/include/configs/rsk7203.h index 9aa71b4..b3feaa8 100644 --- a/include/configs/rsk7203.h +++ b/include/configs/rsk7203.h @@ -78,7 +78,6 @@ #define CONFIG_SYS_MONITOR_BASE RSK7203_FLASH_BASE_1 #define CONFIG_SYS_MONITOR_LEN (128 * 1024) #define CONFIG_SYS_MALLOC_LEN (256 * 1024) -#define CONFIG_SYS_GBL_DATA_SIZE 256 #define CONFIG_SYS_BOOTMAPSZ (8 * 1024 * 1024)
/* FLASH */ diff --git a/include/configs/s5p_goni.h b/include/configs/s5p_goni.h index dc01ceb..47b8a55 100644 --- a/include/configs/s5p_goni.h +++ b/include/configs/s5p_goni.h @@ -58,7 +58,6 @@ * 1MB = 0x100000, 0x100000 = 1024 * 1024 */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (1 << 20)) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes for */ /* initial data */ /* * select serial console configuration diff --git a/include/configs/sacsng.h b/include/configs/sacsng.h index 118e80d..32e0444 100644 --- a/include/configs/sacsng.h +++ b/include/configs/sacsng.h @@ -674,8 +674,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/sbc2410x.h b/include/configs/sbc2410x.h index 025ad09..f0f19b2 100644 --- a/include/configs/sbc2410x.h +++ b/include/configs/sbc2410x.h @@ -59,7 +59,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
/* * Hardware drivers diff --git a/include/configs/sbc35_a9g20.h b/include/configs/sbc35_a9g20.h index b9f27cc..cdbe710 100644 --- a/include/configs/sbc35_a9g20.h +++ b/include/configs/sbc35_a9g20.h @@ -187,7 +187,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN ROUND(3 * CONFIG_ENV_SIZE + 128 * 1024, 0x1000) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* 128 bytes for initial data */ #define CONFIG_STACKSIZE (32 * 1024) /* regular stack */
#ifdef CONFIG_USE_IRQ diff --git a/include/configs/sbc405.h b/include/configs/sbc405.h index a308085..6f0d728 100644 --- a/include/configs/sbc405.h +++ b/include/configs/sbc405.h @@ -265,8 +265,7 @@
#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ #define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/sbc8240.h b/include/configs/sbc8240.h index f6a32d7..5993be6 100644 --- a/include/configs/sbc8240.h +++ b/include/configs/sbc8240.h @@ -201,11 +201,10 @@ typedef unsigned int led_id_t;
/* Size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_SIZE 128
#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
/* * NS16550 Configuration diff --git a/include/configs/sbc8260.h b/include/configs/sbc8260.h index 48a1c56..0d83337 100644 --- a/include/configs/sbc8260.h +++ b/include/configs/sbc8260.h @@ -573,8 +573,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/sbc8349.h b/include/configs/sbc8349.h index e07513a..b418cf2 100644 --- a/include/configs/sbc8349.h +++ b/include/configs/sbc8349.h @@ -171,8 +171,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR 0xFD000000 /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM*/
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ diff --git a/include/configs/sbc8548.h b/include/configs/sbc8548.h index ff0a7db..7bf9fc7 100644 --- a/include/configs/sbc8548.h +++ b/include/configs/sbc8548.h @@ -325,8 +325,7 @@
#define CONFIG_SYS_INIT_L2_ADDR 0xf8f80000 /* relocate boot L2SRAM */
-#define CONFIG_SYS_GBL_DATA_SIZE 128 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* diff --git a/include/configs/sbc8560.h b/include/configs/sbc8560.h index 4526944..101c5d9 100644 --- a/include/configs/sbc8560.h +++ b/include/configs/sbc8560.h @@ -193,8 +193,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR 0x70000000 /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in RAM */
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ diff --git a/include/configs/sbc8641d.h b/include/configs/sbc8641d.h index dfeb798..90d84eb 100644 --- a/include/configs/sbc8641d.h +++ b/include/configs/sbc8641d.h @@ -251,8 +251,7 @@ #endif #define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in RAM */
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ diff --git a/include/configs/sc3.h b/include/configs/sc3.h index 2a166bc..0451105 100644 --- a/include/configs/sc3.h +++ b/include/configs/sc3.h @@ -481,8 +481,7 @@
*/ /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) /* Initial value of the stack pointern in internal SRAM */ #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
diff --git a/include/configs/scb9328.h b/include/configs/scb9328.h index 5556714..c0ae2d9 100644 --- a/include/configs/scb9328.h +++ b/include/configs/scb9328.h @@ -107,7 +107,6 @@ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (128<<10) )
diff --git a/include/configs/sequoia.h b/include/configs/sequoia.h index b8581de..a406ca0 100644 --- a/include/configs/sequoia.h +++ b/include/configs/sequoia.h @@ -99,8 +99,7 @@ /* 440EPx/440GRx have 16KB of internal SRAM, so no need for D-Cache */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_BASE /* OCM */ #define CONFIG_SYS_INIT_RAM_SIZE (4 << 10) -#define CONFIG_SYS_GBL_DATA_SIZE 256 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_GBL_DATA_OFFSET - 0x4)
/* diff --git a/include/configs/sh7763rdp.h b/include/configs/sh7763rdp.h index c8c62ad..209cb88 100644 --- a/include/configs/sh7763rdp.h +++ b/include/configs/sh7763rdp.h @@ -85,7 +85,6 @@ /* Size of DRAM reserved for malloc() use */ #define CONFIG_SYS_MALLOC_LEN (1024 * 1024) /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_SIZE (256) #define CONFIG_SYS_BOOTMAPSZ (8 * 1024 * 1024)
#define CONFIG_SYS_FLASH_CFI diff --git a/include/configs/sh7785lcr.h b/include/configs/sh7785lcr.h index 6627f99..591fb5c 100644 --- a/include/configs/sh7785lcr.h +++ b/include/configs/sh7785lcr.h @@ -110,7 +110,6 @@ #define CONFIG_SYS_MONITOR_BASE (SH7785LCR_FLASH_BASE_1) #define CONFIG_SYS_MONITOR_LEN (512 * 1024) #define CONFIG_SYS_MALLOC_LEN (512 * 1024) -#define CONFIG_SYS_GBL_DATA_SIZE (256) #define CONFIG_SYS_BOOTMAPSZ (8 * 1024 * 1024)
/* FLASH */ diff --git a/include/configs/shannon.h b/include/configs/shannon.h index d848915..e02d5e7 100644 --- a/include/configs/shannon.h +++ b/include/configs/shannon.h @@ -51,7 +51,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
/* * Hardware drivers diff --git a/include/configs/smdk2400.h b/include/configs/smdk2400.h index fd51219..064749e 100644 --- a/include/configs/smdk2400.h +++ b/include/configs/smdk2400.h @@ -52,7 +52,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
/* * Hardware drivers diff --git a/include/configs/smdk2410.h b/include/configs/smdk2410.h index f9d1e55..62fe97e 100644 --- a/include/configs/smdk2410.h +++ b/include/configs/smdk2410.h @@ -49,7 +49,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
/* * Hardware drivers diff --git a/include/configs/smdk6400.h b/include/configs/smdk6400.h index 451b534..f89fc3e 100644 --- a/include/configs/smdk6400.h +++ b/include/configs/smdk6400.h @@ -71,7 +71,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 1024 * 1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes for initial data */
/* * Hardware drivers diff --git a/include/configs/smdkc100.h b/include/configs/smdkc100.h index bfd09a0..6bea5b2 100644 --- a/include/configs/smdkc100.h +++ b/include/configs/smdkc100.h @@ -63,7 +63,6 @@ * 1MB = 0x100000, 0x100000 = 1024 * 1024 */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (1 << 20)) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes for */ /* initial data */ /* * select serial console configuration diff --git a/include/configs/socrates.h b/include/configs/socrates.h index 81f607d..5f2fb1e 100644 --- a/include/configs/socrates.h +++ b/include/configs/socrates.h @@ -172,8 +172,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR 0xe4010000 /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size used area in RAM*/
-#define CONFIG_SYS_GBL_DATA_SIZE 128 /* num bytes initial data*/ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#define CONFIG_SYS_MONITOR_LEN (384 * 1024) /* Reserve 384KiB for Mon */ diff --git a/include/configs/sorcery.h b/include/configs/sorcery.h index c956e0d..f1cbe95 100644 --- a/include/configs/sorcery.h +++ b/include/configs/sorcery.h @@ -229,8 +229,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR (CONFIG_SYS_MBAR + 0x20000) #define CONFIG_SYS_INIT_RAM_SIZE 0x8000 /* Size of used area in DPRAM */
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/spc1920.h b/include/configs/spc1920.h index 91a6840..e39d3bd 100644 --- a/include/configs/spc1920.h +++ b/include/configs/spc1920.h @@ -144,8 +144,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/spear-common.h b/include/configs/spear-common.h index cc52e39..4e5bdea 100644 --- a/include/configs/spear-common.h +++ b/include/configs/spear-common.h @@ -181,7 +181,6 @@ #define CONFIG_SYS_MEMTEST_START 0x00800000 #define CONFIG_SYS_MEMTEST_END 0x04000000 #define CONFIG_SYS_MALLOC_LEN (1024*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 #define CONFIG_IDENT_STRING "-SPEAr" #define CONFIG_SYS_LONGHELP #define CONFIG_SYS_PROMPT "u-boot> " diff --git a/include/configs/spieval.h b/include/configs/spieval.h index cf86735..d6195b1 100644 --- a/include/configs/spieval.h +++ b/include/configs/spieval.h @@ -328,8 +328,7 @@ #endif
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/stxgp3.h b/include/configs/stxgp3.h index 8fc3d40..c2497ad 100644 --- a/include/configs/stxgp3.h +++ b/include/configs/stxgp3.h @@ -157,8 +157,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR 0x60000000 /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in RAM */
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ diff --git a/include/configs/stxssa.h b/include/configs/stxssa.h index 42188dd..996120a 100644 --- a/include/configs/stxssa.h +++ b/include/configs/stxssa.h @@ -169,8 +169,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR 0x60000000 /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in RAM */
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ diff --git a/include/configs/stxxtc.h b/include/configs/stxxtc.h index cb8abea..890186e 100644 --- a/include/configs/stxxtc.h +++ b/include/configs/stxxtc.h @@ -169,8 +169,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x3000 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/svm_sc8xx.h b/include/configs/svm_sc8xx.h index 9f12e73..2248680 100644 --- a/include/configs/svm_sc8xx.h +++ b/include/configs/svm_sc8xx.h @@ -194,8 +194,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/t3corp.h b/include/configs/t3corp.h index a31e3b6..6115a5f 100644 --- a/include/configs/t3corp.h +++ b/include/configs/t3corp.h @@ -98,9 +98,8 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_BASE /* OCM */ #define CONFIG_SYS_INIT_RAM_SIZE (4 << 10) -#define CONFIG_SYS_GBL_DATA_SIZE 256 /* num bytes initial data */ #define CONFIG_SYS_GBL_DATA_OFFSET \ - (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* diff --git a/include/configs/taihu.h b/include/configs/taihu.h index 493e3e0..a3738b7 100644 --- a/include/configs/taihu.h +++ b/include/configs/taihu.h @@ -290,8 +290,7 @@ unsigned char spi_read(void); #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ #define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */
/*----------------------------------------------------------------------- diff --git a/include/configs/taishan.h b/include/configs/taishan.h index 29b60a1..3046081 100644 --- a/include/configs/taishan.h +++ b/include/configs/taishan.h @@ -69,9 +69,8 @@ #define CONFIG_SYS_OCM_DATA_ADDR CONFIG_SYS_ISRAM_BASE #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_ISRAM_BASE /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in RAM*/ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* num bytes initial data*/
/*----------------------------------------------------------------------- diff --git a/include/configs/tnetv107x_evm.h b/include/configs/tnetv107x_evm.h index f423a0e..68290ef 100644 --- a/include/configs/tnetv107x_evm.h +++ b/include/configs/tnetv107x_evm.h @@ -50,7 +50,6 @@
/* Memory Info */ #define CONFIG_SYS_MALLOC_LEN (0x10000 + 1*1024*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 #define PHYS_SDRAM_1 TNETV107X_DDR_EMIF_DATA_BASE #define PHYS_SDRAM_1_SIZE 0x04000000 #define CONFIG_SYS_MEMTEST_START PHYS_SDRAM_1 diff --git a/include/configs/tny_a9260.h b/include/configs/tny_a9260.h index 5af2af3..31a0bdf 100644 --- a/include/configs/tny_a9260.h +++ b/include/configs/tny_a9260.h @@ -164,7 +164,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN ROUND(3 * CONFIG_ENV_SIZE + 128 * 1024, 0x1000) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* 128 bytes for initial data */
diff --git a/include/configs/trab.h b/include/configs/trab.h index 9827195..d5736a2 100644 --- a/include/configs/trab.h +++ b/include/configs/trab.h @@ -95,7 +95,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
/* * Hardware drivers diff --git a/include/configs/trizepsiv.h b/include/configs/trizepsiv.h index ac3566c..2512f93 100644 --- a/include/configs/trizepsiv.h +++ b/include/configs/trizepsiv.h @@ -57,7 +57,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
/* * Hardware drivers @@ -214,7 +213,7 @@ #define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1
/* * GPIO settings diff --git a/include/configs/tx25.h b/include/configs/tx25.h index 996afa3..8f8a1a3 100644 --- a/include/configs/tx25.h +++ b/include/configs/tx25.h @@ -66,7 +66,6 @@ /* malloc() len */ #define CONFIG_SYS_MALLOC_LEN (1 << 20) /* 1 MiB */ /* reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* * Board has 2 32MB banks of DRAM but there is a bug when using * both so only the first is configured @@ -179,6 +178,6 @@ /* additions for new relocation code, must be added to all boards */ #define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + 0x1000 - /* Fix this */ \ - CONFIG_SYS_GBL_DATA_SIZE) + GENERATED_GBL_DATA_SIZE)
#endif /* __CONFIG_H */ diff --git a/include/configs/uc100.h b/include/configs/uc100.h index 5d55279..9da318d 100644 --- a/include/configs/uc100.h +++ b/include/configs/uc100.h @@ -201,8 +201,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/utx8245.h b/include/configs/utx8245.h index b962c49..bb9f606 100644 --- a/include/configs/utx8245.h +++ b/include/configs/utx8245.h @@ -198,8 +198,7 @@ protect on ${u-boot_startaddr} ${u-boot_endaddr}" #define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 #define CONFIG_SYS_INIT_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_INIT_DATA_SIZE) -#define CONFIG_SYS_GBL_DATA_SIZE 128 -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
/*-------------------------------------------------------------------- * NS16550 Configuration diff --git a/include/configs/v37.h b/include/configs/v37.h index 0d9a249..a3fdc38 100644 --- a/include/configs/v37.h +++ b/include/configs/v37.h @@ -159,8 +159,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/v38b.h b/include/configs/v38b.h index 4a97cac..47bb846 100644 --- a/include/configs/v38b.h +++ b/include/configs/v38b.h @@ -229,8 +229,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR MPC5XXX_SRAM #define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE /* Size of used area in DPRAM */
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/ve8313.h b/include/configs/ve8313.h index 11b9cfc..abb57fe 100644 --- a/include/configs/ve8313.h +++ b/include/configs/ve8313.h @@ -173,9 +173,8 @@ #define CONFIG_SYS_INIT_RAM_ADDR 0xFD000000 /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM*/
-#define CONFIG_SYS_GBL_DATA_SIZE 0x100 /* num bytes initial data */ #define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ - CONFIG_SYS_GBL_DATA_SIZE) + GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* CONFIG_SYS_MONITOR_LEN must be a multiple of CONFIG_ENV_SECT_SIZE */ diff --git a/include/configs/versatile.h b/include/configs/versatile.h index 4273b84..45d8434 100644 --- a/include/configs/versatile.h +++ b/include/configs/versatile.h @@ -76,7 +76,6 @@ */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128 * 1024) /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_SIZE 128
/* * Hardware drivers diff --git a/include/configs/virtlab2.h b/include/configs/virtlab2.h index d98fc20..466d930 100644 --- a/include/configs/virtlab2.h +++ b/include/configs/virtlab2.h @@ -177,8 +177,7 @@ */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR #define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/vision2.h b/include/configs/vision2.h index 7bc6318..1d97193 100644 --- a/include/configs/vision2.h +++ b/include/configs/vision2.h @@ -46,7 +46,6 @@ #define CONFIG_SYS_MALLOC_LEN (2048 * 1024)
/* * Hardware drivers @@ -194,7 +193,7 @@ #ifndef CONFIG_SYS_ARM_WITHOUT_RELOC #define CONFIG_SYS_INIT_RAM_SIZE (64 * 1024) #define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ - CONFIG_SYS_GBL_DATA_SIZE) + GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INIT_RAM_ADDR + \ CONFIG_SYS_GBL_DATA_OFFSET) #undef CONFIG_SKIP_RELOCATE_UBOOT diff --git a/include/configs/vme8349.h b/include/configs/vme8349.h index 81c7489..d153762 100644 --- a/include/configs/vme8349.h +++ b/include/configs/vme8349.h @@ -163,9 +163,8 @@ #define CONFIG_SYS_INIT_RAM_ADDR 0xF7000000 /* Initial RAM addr */ #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* size */
-#define CONFIG_SYS_GBL_DATA_SIZE 0x100 /* size init data */ #define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ - CONFIG_SYS_GBL_DATA_SIZE) + GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB */ diff --git a/include/configs/voiceblue.h b/include/configs/voiceblue.h index d46717c..c258030 100644 --- a/include/configs/voiceblue.h +++ b/include/configs/voiceblue.h @@ -71,7 +71,6 @@ /* * Size of malloc() pool and stack */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 #define CONFIG_SYS_MALLOC_LEN (4 * 1024 * 1024) #define CONFIG_STACKSIZE (1 * 1024 * 1024)
diff --git a/include/configs/vpac270.h b/include/configs/vpac270.h index 3107014..35afcd3 100644 --- a/include/configs/vpac270.h +++ b/include/configs/vpac270.h @@ -34,7 +34,6 @@ */ #define CONFIG_ENV_OVERWRITE #define CONFIG_SYS_MALLOC_LEN (128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 #define CONFIG_ARCH_CPU_INIT #define CONFIG_BOOTCOMMAND \ "if mmc init && fatload mmc 0 0xa4000000 uImage; then " \ @@ -185,7 +184,7 @@ #define CONFIG_SYS_IPL_LOAD_ADDR (0x5c000000) #define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 #define CONFIG_SYS_INIT_SP_ADDR \ - (PHYS_SDRAM_1 + CONFIG_SYS_GBL_DATA_SIZE + 2048) + (PHYS_SDRAM_1 + GENERATED_GBL_DATA_SIZE + 2048)
/* * NOR FLASH diff --git a/include/configs/walnut.h b/include/configs/walnut.h index 6e063f5..d10f748 100644 --- a/include/configs/walnut.h +++ b/include/configs/walnut.h @@ -218,8 +218,7 @@
#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 /* inside of SDRAM */ #define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/xaeniax.h b/include/configs/xaeniax.h index 18b68fa..a75c426 100644 --- a/include/configs/xaeniax.h +++ b/include/configs/xaeniax.h @@ -115,7 +115,6 @@ * used for the RAM copy of the uboot code */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
/* * Miscellaneous configurable options @@ -169,7 +168,7 @@ #define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1
/* * FLASH and environment organization diff --git a/include/configs/xilinx-ppc.h b/include/configs/xilinx-ppc.h index d377848..2422c0b 100644 --- a/include/configs/xilinx-ppc.h +++ b/include/configs/xilinx-ppc.h @@ -92,9 +92,8 @@ /*Stack*/ #define CONFIG_SYS_INIT_RAM_ADDR 0x800000/* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* num bytes initial data */ #define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE \ - - CONFIG_SYS_GBL_DATA_SIZE) + - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET /*Speed*/ #define CONFIG_SYS_CLK_FREQ XPAR_CORE_CLOCK_FREQ_HZ diff --git a/include/configs/xm250.h b/include/configs/xm250.h index ea52454..497cb91 100644 --- a/include/configs/xm250.h +++ b/include/configs/xm250.h @@ -46,7 +46,6 @@ * */ #define CONFIG_SYS_MALLOC_LEN (256*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
/* * Hardware drivers @@ -176,7 +175,7 @@ #define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1
/* * FLASH and environment organization diff --git a/include/configs/xpedite1000.h b/include/configs/xpedite1000.h index 9103b6a..cd7148d 100644 --- a/include/configs/xpedite1000.h +++ b/include/configs/xpedite1000.h @@ -103,8 +103,7 @@ extern void out32(unsigned int, unsigned long); #define CONFIG_SYS_OCM_DATA_ADDR CONFIG_SYS_ISRAM_BASE #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_ISRAM_BASE /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* num bytes initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_GBL_DATA_OFFSET - 0x4)
#define CONFIG_SYS_MONITOR_LEN (512 * 1024) /* Reserve 512 KB for Mon */ diff --git a/include/configs/xpedite517x.h b/include/configs/xpedite517x.h index a4e485c..cb83a64 100644 --- a/include/configs/xpedite517x.h +++ b/include/configs/xpedite517x.h @@ -220,8 +220,7 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_SYS_INIT_RAM_ADDR 0xe0000000 #define CONFIG_SYS_INIT_RAM_SIZE 0x00004000
#define CONFIG_SYS_MONITOR_LEN (512 * 1024) /* Reserve 512 KB for Mon */ diff --git a/include/configs/xpedite520x.h b/include/configs/xpedite520x.h index eb73fa8..b6b391f 100644 --- a/include/configs/xpedite520x.h +++ b/include/configs/xpedite520x.h @@ -188,8 +188,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR 0xe0000000 #define CONFIG_SYS_INIT_RAM_SIZE 0x4000
#define CONFIG_SYS_MONITOR_LEN (512 * 1024) /* Reserve 512 KB for Mon */ diff --git a/include/configs/xpedite537x.h b/include/configs/xpedite537x.h index dd8d226..e0a1fa4 100644 --- a/include/configs/xpedite537x.h +++ b/include/configs/xpedite537x.h @@ -226,8 +226,7 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); #define CONFIG_SYS_INIT_RAM_ADDR 0xe0000000 #define CONFIG_SYS_INIT_RAM_SIZE 0x00004000
#define CONFIG_SYS_MONITOR_LEN (512 * 1024) /* Reserve 512 KB for Mon */ diff --git a/include/configs/xpedite550x.h b/include/configs/xpedite550x.h index 3c6bf5c..42d1f69 100644 --- a/include/configs/xpedite550x.h +++ b/include/configs/xpedite550x.h @@ -216,8 +216,7 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); #define CONFIG_SYS_INIT_RAM_ADDR 0xe0000000 #define CONFIG_SYS_INIT_RAM_SIZE 0x00004000
#define CONFIG_SYS_MONITOR_LEN (512 * 1024) /* Reserve 512 KB for Mon */ diff --git a/include/configs/yosemite.h b/include/configs/yosemite.h index 85b88c8..0cbef6f 100644 --- a/include/configs/yosemite.h +++ b/include/configs/yosemite.h @@ -78,8 +78,7 @@ #define CONFIG_SYS_INIT_RAM_DCACHE 1 /* d-cache as init ram */ #define CONFIG_SYS_INIT_RAM_ADDR 0x70000000 /* DCache */ #define CONFIG_SYS_INIT_RAM_SIZE (4 << 10) -#define CONFIG_SYS_GBL_DATA_SIZE 256 /* num bytes initial data*/ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/*----------------------------------------------------------------------- diff --git a/include/configs/yucca.h b/include/configs/yucca.h index 55a364c..fb684b5 100644 --- a/include/configs/yucca.h +++ b/include/configs/yucca.h @@ -98,9 +98,8 @@ #define CONFIG_SYS_OCM_DATA_ADDR CONFIG_SYS_ISRAM_BASE #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_ISRAM_BASE /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x2000 /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* num bytes initial data */
/*----------------------------------------------------------------------- diff --git a/include/configs/zeus.h b/include/configs/zeus.h index d24ea0b..f9a6b93 100644 --- a/include/configs/zeus.h +++ b/include/configs/zeus.h @@ -255,8 +255,7 @@ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of OCM */ #define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */
-#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) /* reserve some memory for POST and BOOT limit info */ #define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_GBL_DATA_OFFSET - 16)
diff --git a/include/configs/zipitz2.h b/include/configs/zipitz2.h index 48537e3..a8b88da 100644 --- a/include/configs/zipitz2.h +++ b/include/configs/zipitz2.h @@ -43,7 +43,6 @@ #define CONFIG_ENV_SIZE 0x20000
#define CONFIG_SYS_MALLOC_LEN (128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 512 #define CONFIG_ARCH_CPU_INIT
#define CONFIG_BOOTCOMMAND \ @@ -178,7 +177,7 @@ unsigned char zipitz2_spi_read(void); #define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_DRAM_BASE
#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 -#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_GBL_DATA_SIZE + PHYS_SDRAM_1 + 2048) +#define CONFIG_SYS_INIT_SP_ADDR (GENERATED_GBL_DATA_SIZE + PHYS_SDRAM_1 + 2048)
/* * NOR FLASH diff --git a/include/configs/zylonite.h b/include/configs/zylonite.h index c33ca2d..4ecef94 100644 --- a/include/configs/zylonite.h +++ b/include/configs/zylonite.h @@ -55,7 +55,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
/* * Hardware drivers @@ -191,7 +190,7 @@ #undef CONFIG_SYS_SKIP_DRAM_SCRUB
/* * NAND Flash diff --git a/lib/asm-offsets.c b/lib/asm-offsets.c index 4eb6174..f379e6b 100644 --- a/lib/asm-offsets.c +++ b/lib/asm-offsets.c @@ -21,5 +21,7 @@
int main(void) { + DEFINE(GENERATED_GBL_DATA_SIZE, sizeof(struct global_data)); + return 0; }
Hi Wolfgang,
On Tuesday 26 October 2010 16:00:01 Wolfgang Denk wrote:
CONFIG_SYS_GBL_DATA_SIZE has always been just a bad workarond for not being able to use "sizeof(struct global_data)" in assembler files. Recent experience has shown that manual synchronization is not reliable enough. This patch renames CONFIG_SYS_GBL_DATA_SIZE into GENERATED_GBL_DATA_SIZE which gets automatically generated by the asm-offsets tool. In the result, all definitions of this value can be deleted from the board config files. We have to make sure that all files that reference such data include the new <asm-offsets.h> file.
No other changes have been done yet, but it is obvious that similar changes / simplifications can be done for other, related macro definitions as well.
Nice. Thanks all for this work.
One thing that comes to my mind while looking into this patchset is, if we need to make sure that the replacement for CONFIG_SYS_GBL_DATA_SIZE is (still) aligned. Till now CONFIG_SYS_GBL_DATA_SIZE has been defined mostly to something like 64/128/256. Now with using sizeof(struct global_data) this is may not the case any more. Perhaps I'm missing something (didn't look through the patchset too closely), but shouldn't we make sure that the new values used for the memory-reservation is at least 4-byte aligned?
Thanks.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
On Oct 26, 2010, at 9:22 AM, Stefan Roese wrote:
Hi Wolfgang,
I was wondering about this too, and since most of these are used to define CONFIG_SYS_INIT_SP_OFFSET, we probably need stack level alignment.
- k
Dear Stefan Roese,
You are right, especially as the resulting start address of the global data is usually also used as the top of the internal stack. Guess we should align it on 16 bytes, to be sure.
BTW - this uncovers a number of other problems.
commit 800eb096 "POST cleanup." inserts a single data word between global data and initial stack, thus also breaking stack alignment.
I think this approach is wrong, the POST word should be made part of the global_data instead.
[This was one of the reasons I did not replace CONFIG_SYS_GBL_DATA_OFFSET yet, which usually is always "(CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)", nor CONFIG_SYS_INIT_SP_OFFSET, which usually is the same as CONFIG_SYS_GBL_DATA_OFFSET.]
Patch v3 following.
Hi Wolfgang,
Yes, we already had this 8-byte stack align problem on ARM, IIRC.
Good idea.
Cheers, Stefan
Signed-off-by: Wolfgang Denk wd@denx.de --- v2: round global data size up to a multiple of 16 to guarantee sufficient alignment of the initial stack.
... [other files unchanged, suppressed to reduce size] ... lib/asm-offsets.c | 4 ++++ 560 files changed, 519 insertions(+), 955 deletions(-)
diff --git a/lib/asm-offsets.c b/lib/asm-offsets.c index 4eb6174..0bc70ab 100644 --- a/lib/asm-offsets.c +++ b/lib/asm-offsets.c @@ -21,5 +21,9 @@
int main(void) { + /* Round up to make sure size gives nice stack alignment */ + DEFINE(GENERATED_GBL_DATA_SIZE, + (sizeof(struct global_data)+15) & ~15); + return 0; }
Applied, thanks.
- /* Round up to make sure size gives nice stack alignment */
- DEFINE(GENERATED_GBL_DATA_SIZE,
This has already been applied, sooner than usual. Isn't it cleaner to force alignment on the structure itself? This way different architectures may use different values, if the need arises.
This shows it.
struct a { int i; } __attribute__((aligned(16)));
struct b { int i; };
int main() { printf("%i %i\n", sizeof(struct a), sizeof(struct b)); }
It prints "16 4" as expected.
/alessandro
Dear Alessandro Rubini,
It would be better, but how to implement that? Please keep in mind that the pointers are set up in aseembler code, where we don't have such things as "struct" etc. We're dealing with raw addresses here, which is the reason we have to go through all this effort with asm-offsets and such.
Instead of:
DEFINE(GENERATED_GBL_DATA_SIZE, (sizeof(struct global_data)+15) & ~15);
I'd use:
DEFINE(GENERATED_GBL_DATA_SIZE, (sizeof(struct global_data)),
leaving the alignment requirement in the structure itself (include/asm/global_data.h for each architecture).
/alessandro
In message 20101026205756.GA2139@morgana.i.gnudd.com you wrote:
Instead of:
I'd use:
Is it guaranteed (I mean by the C standard) that the alignment of a struct (which affects only the possible start address) also has effect on the sizeof() for that struct, in the sense that sizeof() is guaranteed to be a multiple of that alignment requirement?
Yes. Because if you make an array, all of them must be aligned, and the size of an array is a multiple of sizeof(array_item). While alignment is not in the standard, the sizeof/array relationship is.
It's in C99 draft (http://busybox.net/~landley/c99-draft.html)
6.5.3.4 The sizeof operator
#6
EXAMPLE 2 Another use of the sizeof operator is to compute the number of elements in an array: sizeof array / sizeof array[0]
/alessandro
I am not convinced, as we don't have an array context here.
6.5.3.4 The sizeof operator #6 EXAMPLE 2 Another use of the sizeof operator is to compute the number of elements in an array: sizeof array / sizeof array[0]
I don't see that with
struct foo x; struct foo y[N];
we have a guarantee that sizeof(x) == sizeof(y[0]).
Maybe I'm just paranoid...
But sizeof(struct x) doesn't depend on how struct x is used. You can declare a pointer and then allocate for an array.
Yes, I see this requirement. But maybe we're already bikeshedding: I won't get offended if you keep the global +15 & ~15.
regards /alessandro
Please let me get -rc1 out, and all the urgent problems fixed first. I will try to keep this in mind and re-check when there is a little more time. Thanks!
On Tuesday, October 26, 2010 10:00:01 Wolfgang Denk wrote:
--- a/arch/blackfin/include/asm/config.h +++ b/arch/blackfin/include/asm/config.h -#ifndef CONFIG_SYS_GBL_DATA_SIZE -# define CONFIG_SYS_GBL_DATA_SIZE (128) +#ifndef GENERATED_GBL_DATA_SIZE #endif
might as well delete this whole construct
otherwise, the rest of the Blackfin stuff looks sane to me -mike
Dear Mike Frysinger,
OK, will do on check-in.
Thanks.
On Oct 26, 2010, at 8:59 AM, Wolfgang Denk wrote:
The following patch series starts some clean up of for the handling f initial data; the most important change is the replacement of a manually configured (and thus often wrong) CONFIG_SYS_GBL_DATA_SIZE by an automatically generated value.
More similar clean-ups can and will be done, but this is stuff for the next merge window (or the "next" branch); here we focus on a fix for the CONFIG_SYS_GBL_DATA_SIZE problems.
The changes are mostly simple and straightforward, but they are huge as they affect a lots of files.
[PATCH 1/3] Rename CONFIG_SYS_INIT_RAM_END into CONFIG_SYS_INIT_RAM_SIZE
CONFIG_SYS_INIT_RAM_END was a misnomer as it suggests this might be some end address; to make the meaning more clear we rename it into CONFIG_SYS_INIT_RAM_SIZE
No other code changes are performed in this patch, only minor editing of white space (due to the changed length) and the comments was done, where noticed.
Note that the code for the PATI and cmi_mpc5xx board configurations looks seriously broken. Last known maintainers on Cc:
Signed-off-by: Wolfgang Denk wd@denx.de Cc: Denis Peter d.peter@mpl.ch Cc: Martin Winistoerfer martinwinistoerfer@gmx.ch
Acked-by: Kumar Gala galak@kernel.crashing.org
looks good to me (beyond the typo ;)
- k
participants (6)
Alessandro Rubini
Alexander Stein
Kumar Gala
Mike Frysinger
Stefan Roese
