[U-Boot-Users] PCI video display in MPC8270
Hi All,
We currently just enabled the PCI bus on our MPC8270 custom board. We intend to put a video chip in the PCI bus (XGI Volari Z7). For testing, we got the Z7 PCI demo board. We are using u-boot and Linux kernel 2.4.25 in our system. I had a pre-conception that the Linux kernel will be able to handle the VGA console by itself without any BIOS help (or in this case U-boot). After configuring the kernel to support VGA console, the PCI video card did not give any display (probably no sync at all). AFAIK, the PCI bus is working correctly. I did test a Netgear PCI network card to verify it (and it passed).
The Z7 demo card works ok on a regular Linux PC with a standard BIOS on it.
1. Does our system require a VGA BIOS (aside from U-boot) to display console (and later on to display a GUI, i.e. X Windows, Tiny X)?
2. Is it possible to configure the Kernel to do the PCI video card initialization without involving U-boot so that it will at least display a VGA console 80x25?
3. Do I actually need to write a driver for the Z7 in U-boot (similar to CT9000, SMI 710/712/810) to configure the video chip correctly before Linux takes over?
4. I still like to send U-boot console messages to the MPC8270 (SCC) serial port and just start the VGA console once Linux takes over. Is this possible?
I greatly appreciate any insights about this issue.
thanks in advance, Maynard
Hello,
in message 38948EB93E24844E9911E0E932C0466470B1CC@plum.raritan.com you wrote:
- Does our system require a VGA BIOS (aside from U-boot) to display
Probably yes; alternatively you can try an enable the x86 emulation code in U-Boot and use this to run the card BIOS init code.
- Is it possible to configure the Kernel to do the PCI video card
Everthing is possible, if you spend enough effort on it. In this case you will probably need some form of x86 emulation in Linux.
- Do I actually need to write a driver for the Z7 in U-boot (similar to
YOu probably don't need a graphics driver but somce code to initialize the card, either in U-Boot or in Linux. Given the fact that you will most probably have to run the card's BIOS code yuou need an x86 emulation. This is easier in the U-Boot context than in Linux.
- I still like to send U-boot console messages to the MPC8270 (SCC)
Yes, of course.
Content-Type: text/html; charset=iso-8859-1" Content-Transfer-Encoding: quoted-printable
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN"><HTML
And please NEVER post HTML to this list!
Maynard Cabiente
