[PATCH 0/3] qcom: switch to OF_UPSTREAM
This series does the initial switch to OF_UPSTREAM for Qualcomm platforms. The DT files we have in U-Boot are outdated by now, so drop them and move to upstream.
Patch 2 drops all the Qualcomm dts files that are now provided in dts/upstream. As some of the files exceed the 100k size limit by themselves I thought it would be easier to just lump them together rather than trying to split them up.
The associated qcom headers will be cleaned up in future patches.
--- Caleb Connolly (3): mach-snapdragon: use OF_UPSTREAM arm: dts: drop qcom dts files qcom_defconfig: set SYS_INIT_SP_BSS_OFFSET
MAINTAINERS | 4 - arch/arm/Kconfig | 1 + arch/arm/dts/apq8016-sbc.dts | 729 ---- arch/arm/dts/apq8096-db820c.dts | 1137 ------ arch/arm/dts/msm8916-pm8916.dtsi | 157 - arch/arm/dts/msm8916.dtsi | 2702 ------------- arch/arm/dts/msm8996.dtsi | 3884 ------------------ arch/arm/dts/pm8916.dtsi | 178 - arch/arm/dts/pm8994.dtsi | 152 - arch/arm/dts/pm8998.dtsi | 130 - arch/arm/dts/pmi8994.dtsi | 65 - arch/arm/dts/pmi8998.dtsi | 98 - arch/arm/dts/pms405.dtsi | 149 - arch/arm/dts/qcs404-evb-4000.dts | 96 - arch/arm/dts/qcs404-evb.dtsi | 389 -- arch/arm/dts/qcs404.dtsi | 1829 --------- arch/arm/dts/sdm845-db845c.dts | 1190 ------ arch/arm/dts/sdm845-samsung-starqltechn.dts | 460 --- arch/arm/dts/sdm845-wcd9340.dtsi | 86 - arch/arm/dts/sdm845.dtsi | 5752 --------------------------- configs/dragonboard410c_defconfig | 2 +- configs/dragonboard820c_defconfig | 2 +- configs/qcom_defconfig | 3 +- 23 files changed, 5 insertions(+), 19190 deletions(-) --- base-commit: d5460b082cd6afd0e07c0ec0e5a82d1af8dc09f7
// Caleb (they/them)
Switch to using upstream DT from dts/upstream.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- MAINTAINERS | 4 ---- arch/arm/Kconfig | 1 + configs/dragonboard410c_defconfig | 2 +- configs/dragonboard820c_defconfig | 2 +- configs/qcom_defconfig | 2 +- 5 files changed, 4 insertions(+), 7 deletions(-)
diff --git a/MAINTAINERS b/MAINTAINERS index c0d2b5138fca..d0a4a28b401d 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -605,12 +605,8 @@ M: Neil Armstrong neil.armstrong@linaro.org R: Sumit Garg sumit.garg@linaro.org L: u-boot-qcom@groups.io S: Maintained T: git https://source.denx.de/u-boot/custodians/u-boot-snapdragon.git -F: arch/arm/dts/msm8*.dtsi -F: arch/arm/dts/pm8???.dtsi -F: arch/arm/dts/pms405.dtsi -F: arch/arm/dts/sdm845.dtsi F: drivers/*/*/pm8???-* F: drivers/gpio/msm_gpio.c F: drivers/mmc/msm_sdhci.c F: drivers/phy/msm8916-usbh-phy.c diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 23ee25269a24..2931c82eb11f 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1088,8 +1088,9 @@ config ARCH_SNAPDRAGON select BOARD_LATE_INIT select OF_BOARD select SAVE_PREV_BL_FDT_ADDR select LINUX_KERNEL_IMAGE_HEADER + imply OF_UPSTREAM imply CMD_DM
config ARCH_SOCFPGA bool "Altera SOCFPGA family" diff --git a/configs/dragonboard410c_defconfig b/configs/dragonboard410c_defconfig index 260a8349d3b2..9ef04fd45546 100644 --- a/configs/dragonboard410c_defconfig +++ b/configs/dragonboard410c_defconfig @@ -8,9 +8,9 @@ CONFIG_SYS_MALLOC_LEN=0x802000 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x8007fff0 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x0 -CONFIG_DEFAULT_DEVICE_TREE="apq8016-sbc" +CONFIG_DEFAULT_DEVICE_TREE="qcom/apq8016-sbc" CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_IDENT_STRING="\nQualcomm-DragonBoard 410C" CONFIG_SYS_LOAD_ADDR=0x80080000 CONFIG_REMAKE_ELF=y diff --git a/configs/dragonboard820c_defconfig b/configs/dragonboard820c_defconfig index ebc80eb2a464..f6b2cb09ba31 100644 --- a/configs/dragonboard820c_defconfig +++ b/configs/dragonboard820c_defconfig @@ -6,9 +6,9 @@ CONFIG_TEXT_BASE=0x80080000 CONFIG_SYS_MALLOC_LEN=0x804000 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x8007fff0 CONFIG_ENV_SIZE=0x4000 -CONFIG_DEFAULT_DEVICE_TREE="apq8096-db820c" +CONFIG_DEFAULT_DEVICE_TREE="qcom/apq8096-db820c" CONFIG_IDENT_STRING="\nQualcomm-DragonBoard 820C" CONFIG_SYS_LOAD_ADDR=0x80080000 CONFIG_DISTRO_DEFAULTS=y CONFIG_USE_BOOTARGS=y diff --git a/configs/qcom_defconfig b/configs/qcom_defconfig index ee3ed89cbc8a..218a9a769682 100644 --- a/configs/qcom_defconfig +++ b/configs/qcom_defconfig @@ -1,9 +1,9 @@ CONFIG_ARM=y CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_POSITION_INDEPENDENT=y CONFIG_ARCH_SNAPDRAGON=y -CONFIG_DEFAULT_DEVICE_TREE="sdm845-db845c" +CONFIG_DEFAULT_DEVICE_TREE="qcom/sdm845-db845c" CONFIG_SYS_LOAD_ADDR=0x0 CONFIG_BUTTON_CMD=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y
Reviewed-by: Neil Armstrong neil.armstrong@linaro.org
These files are all identical (or older) than those in dts/upstream. Drop them as we now use upstream DTS files with OF_UPSTREAM.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- arch/arm/dts/apq8016-sbc.dts | 729 ---- arch/arm/dts/apq8096-db820c.dts | 1137 ------ arch/arm/dts/msm8916-pm8916.dtsi | 157 - arch/arm/dts/msm8916.dtsi | 2702 ------------- arch/arm/dts/msm8996.dtsi | 3884 ------------------ arch/arm/dts/pm8916.dtsi | 178 - arch/arm/dts/pm8994.dtsi | 152 - arch/arm/dts/pm8998.dtsi | 130 - arch/arm/dts/pmi8994.dtsi | 65 - arch/arm/dts/pmi8998.dtsi | 98 - arch/arm/dts/pms405.dtsi | 149 - arch/arm/dts/qcs404-evb-4000.dts | 96 - arch/arm/dts/qcs404-evb.dtsi | 389 -- arch/arm/dts/qcs404.dtsi | 1829 --------- arch/arm/dts/sdm845-db845c.dts | 1190 ------ arch/arm/dts/sdm845-samsung-starqltechn.dts | 460 --- arch/arm/dts/sdm845-wcd9340.dtsi | 86 - arch/arm/dts/sdm845.dtsi | 5752 --------------------------- 18 files changed, 19183 deletions(-)
diff --git a/arch/arm/dts/apq8016-sbc.dts b/arch/arm/dts/apq8016-sbc.dts deleted file mode 100644 index 9ffad7d1f2b6..000000000000 --- a/arch/arm/dts/apq8016-sbc.dts +++ /dev/null @@ -1,729 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-only -/* - * Copyright (c) 2015, The Linux Foundation. All rights reserved. - */ - -/dts-v1/; - -#include "msm8916-pm8916.dtsi" -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/input/input.h> -#include <dt-bindings/leds/common.h> -#include <dt-bindings/pinctrl/qcom,pmic-gpio.h> -#include <dt-bindings/pinctrl/qcom,pmic-mpp.h> -#include <dt-bindings/sound/apq8016-lpass.h> - -/ { - model = "Qualcomm Technologies, Inc. APQ 8016 SBC"; - compatible = "qcom,apq8016-sbc", "qcom,apq8016"; - - aliases { - mmc0 = &sdhc_1; /* eMMC */ - mmc1 = &sdhc_2; /* SD card */ - serial0 = &blsp_uart2; - serial1 = &blsp_uart1; - usid0 = &pm8916_0; - i2c0 = &blsp_i2c2; - i2c1 = &blsp_i2c6; - i2c3 = &blsp_i2c4; - spi0 = &blsp_spi5; - spi1 = &blsp_spi3; - }; - - chosen { - stdout-path = "serial0"; - }; - - reserved-memory { - ramoops@bff00000 { - compatible = "ramoops"; - reg = <0x0 0xbff00000 0x0 0x100000>; - - record-size = <0x20000>; - console-size = <0x20000>; - ftrace-size = <0x20000>; - }; - }; - - usb2513 { - compatible = "smsc,usb3503"; - reset-gpios = <&pm8916_gpios 3 GPIO_ACTIVE_LOW>; - initial-mode = <1>; - }; - - usb_id: usb-id { - compatible = "linux,extcon-usb-gpio"; - id-gpios = <&tlmm 121 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&usb_id_default>; - }; - - hdmi-out { - compatible = "hdmi-connector"; - type = "a"; - - port { - hdmi_con: endpoint { - remote-endpoint = <&adv7533_out>; - }; - }; - }; - - gpio-keys { - compatible = "gpio-keys"; - autorepeat; - - pinctrl-names = "default"; - pinctrl-0 = <&msm_key_volp_n_default>; - - button { - label = "Volume Up"; - linux,code = <KEY_VOLUMEUP>; - gpios = <&tlmm 107 GPIO_ACTIVE_LOW>; - }; - }; - - leds { - pinctrl-names = "default"; - pinctrl-0 = <&tlmm_leds>, - <&pm8916_gpios_leds>, - <&pm8916_mpps_leds>; - - compatible = "gpio-leds"; - - led@1 { - label = "apq8016-sbc:green:user1"; - function = LED_FUNCTION_HEARTBEAT; - color = <LED_COLOR_ID_GREEN>; - gpios = <&tlmm 21 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "heartbeat"; - default-state = "off"; - }; - - led@2 { - label = "apq8016-sbc:green:user2"; - function = LED_FUNCTION_DISK_ACTIVITY; - color = <LED_COLOR_ID_GREEN>; - gpios = <&tlmm 120 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "mmc0"; - default-state = "off"; - }; - - led@3 { - label = "apq8016-sbc:green:user3"; - function = LED_FUNCTION_DISK_ACTIVITY; - color = <LED_COLOR_ID_GREEN>; - gpios = <&pm8916_gpios 1 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "mmc1"; - default-state = "off"; - }; - - led@4 { - label = "apq8016-sbc:green:user4"; - color = <LED_COLOR_ID_GREEN>; - gpios = <&pm8916_gpios 2 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "none"; - panic-indicator; - default-state = "off"; - }; - - led@5 { - label = "apq8016-sbc:yellow:wlan"; - function = LED_FUNCTION_WLAN; - color = <LED_COLOR_ID_YELLOW>; - gpios = <&pm8916_mpps 2 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "phy0tx"; - default-state = "off"; - }; - - led@6 { - label = "apq8016-sbc:blue:bt"; - function = LED_FUNCTION_BLUETOOTH; - color = <LED_COLOR_ID_BLUE>; - gpios = <&pm8916_mpps 3 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "bluetooth-power"; - default-state = "off"; - }; - }; -}; - -&blsp_i2c2 { - /* On Low speed expansion: LS-I2C0 */ - status = "okay"; -}; - -&blsp_i2c4 { - /* On High speed expansion: HS-I2C2 */ - status = "okay"; - - adv_bridge: bridge@39 { - status = "okay"; - - compatible = "adi,adv7533"; - reg = <0x39>; - - interrupt-parent = <&tlmm>; - interrupts = <31 IRQ_TYPE_EDGE_FALLING>; - - adi,dsi-lanes = <4>; - clocks = <&rpmcc RPM_SMD_BB_CLK2>; - clock-names = "cec"; - - pd-gpios = <&tlmm 32 GPIO_ACTIVE_HIGH>; - - avdd-supply = <&pm8916_l6>; - a2vdd-supply = <&pm8916_l6>; - dvdd-supply = <&pm8916_l6>; - pvdd-supply = <&pm8916_l6>; - v1p2-supply = <&pm8916_l6>; - v3p3-supply = <&pm8916_l17>; - - pinctrl-names = "default","sleep"; - pinctrl-0 = <&adv7533_int_active &adv7533_switch_active>; - pinctrl-1 = <&adv7533_int_suspend &adv7533_switch_suspend>; - #sound-dai-cells = <1>; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - adv7533_in: endpoint { - remote-endpoint = <&mdss_dsi0_out>; - }; - }; - - port@1 { - reg = <1>; - adv7533_out: endpoint { - remote-endpoint = <&hdmi_con>; - }; - }; - }; - }; -}; - -&blsp_i2c6 { - /* On Low speed expansion: LS-I2C1 */ - status = "okay"; -}; - -&blsp_spi3 { - /* On High speed expansion: HS-SPI1 */ - status = "okay"; -}; - -&blsp_spi5 { - /* On Low speed expansion: LS-SPI0 */ - status = "okay"; -}; - -&blsp_uart1 { - status = "okay"; - label = "LS-UART0"; -}; - -&blsp_uart2 { - status = "okay"; - label = "LS-UART1"; -}; - -&camss { - status = "okay"; -}; - -&gpu { - status = "okay"; -}; - -&lpass { - status = "okay"; -}; - -&lpass_codec { - status = "okay"; -}; - -&mba_mem { - status = "okay"; -}; - -&mdss { - status = "okay"; -}; - -&mdss_dsi0_out { - data-lanes = <0 1 2 3>; - remote-endpoint = <&adv7533_in>; -}; - -&mpss { - status = "okay"; - - firmware-name = "qcom/apq8016/mba.mbn", "qcom/apq8016/modem.mbn"; -}; - -&mpss_mem { - status = "okay"; - reg = <0x0 0x86800000 0x0 0x2b00000>; -}; - -&pm8916_codec { - status = "okay"; - qcom,mbhc-vthreshold-low = <75 150 237 450 500>; - qcom,mbhc-vthreshold-high = <75 150 237 450 500>; -}; - -&pm8916_resin { - status = "okay"; - linux,code = <KEY_VOLUMEDOWN>; -}; - -&pm8916_rpm_regulators { - /* - * The 96Boards specification expects a 1.8V power rail on the low-speed - * expansion connector that is able to provide at least 0.18W / 100 mA. - * L15/L16 are connected in parallel to provide 55 mA each. A minimum load - * must be specified to ensure the regulators are not put in LPM where they - * would only provide 5 mA. - */ - pm8916_l15: l15 { - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-system-load = <50000>; - regulator-allow-set-load; - regulator-always-on; - }; - pm8916_l16: l16 { - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-system-load = <50000>; - regulator-allow-set-load; - regulator-always-on; - }; - - pm8916_l17: l17 { - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; -}; - -&sdhc_1 { - status = "okay"; -}; - -&sdhc_2 { - status = "okay"; - - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&sdc2_default &sdc2_cd_default>; - pinctrl-1 = <&sdc2_sleep &sdc2_cd_default>; - - cd-gpios = <&tlmm 38 GPIO_ACTIVE_LOW>; -}; - -&sound { - status = "okay"; - - pinctrl-0 = <&cdc_pdm_default &sec_mi2s_default>; - pinctrl-1 = <&cdc_pdm_sleep &sec_mi2s_sleep>; - pinctrl-names = "default", "sleep"; - model = "DB410c"; - audio-routing = - "AMIC2", "MIC BIAS Internal2", - "AMIC3", "MIC BIAS External1"; - - quaternary-dai-link { - link-name = "ADV7533"; - cpu { - sound-dai = <&lpass MI2S_QUATERNARY>; - }; - codec { - sound-dai = <&adv_bridge 0>; - }; - }; - - primary-dai-link { - link-name = "WCD"; - cpu { - sound-dai = <&lpass MI2S_PRIMARY>; - }; - codec { - sound-dai = <&lpass_codec 0>, <&pm8916_codec 0>; - }; - }; - - tertiary-dai-link { - link-name = "WCD-Capture"; - cpu { - sound-dai = <&lpass MI2S_TERTIARY>; - }; - codec { - sound-dai = <&lpass_codec 1>, <&pm8916_codec 1>; - }; - }; -}; - -&usb { - status = "okay"; - extcon = <&usb_id>, <&usb_id>; - - pinctrl-names = "default", "device"; - pinctrl-0 = <&usb_sw_sel_pm &usb_hub_reset_pm>; - pinctrl-1 = <&usb_sw_sel_pm_device &usb_hub_reset_pm_device>; -}; - -&usb_hs_phy { - extcon = <&usb_id>; -}; - -&venus { - status = "okay"; -}; - -&venus_mem { - status = "okay"; -}; - -&wcnss { - status = "okay"; - firmware-name = "qcom/apq8016/wcnss.mbn"; -}; - -&wcnss_ctrl { - firmware-name = "qcom/apq8016/WCNSS_qcom_wlan_nv_sbc.bin"; -}; - -&wcnss_iris { - compatible = "qcom,wcn3620"; -}; - -&wcnss_mem { - status = "okay"; -}; - -/* Enable CoreSight */ -&cti0 { status = "okay"; }; -&cti1 { status = "okay"; }; -&cti12 { status = "okay"; }; -&cti13 { status = "okay"; }; -&cti14 { status = "okay"; }; -&cti15 { status = "okay"; }; -&debug0 { status = "okay"; }; -&debug1 { status = "okay"; }; -&debug2 { status = "okay"; }; -&debug3 { status = "okay"; }; -&etf { status = "okay"; }; -&etm0 { status = "okay"; }; -&etm1 { status = "okay"; }; -&etm2 { status = "okay"; }; -&etm3 { status = "okay"; }; -&etr { status = "okay"; }; -&funnel0 { status = "okay"; }; -&funnel1 { status = "okay"; }; -&replicator { status = "okay"; }; -&stm { status = "okay"; }; -&tpiu { status = "okay"; }; - -/* - * 2mA drive strength is not enough when connecting multiple - * I2C devices with different pull up resistors. - */ -&blsp_i2c2_default { - drive-strength = <16>; -}; - -&blsp_i2c4_default { - drive-strength = <16>; -}; - -&blsp_i2c6_default { - drive-strength = <16>; -}; - -/* - * GPIO name legend: proper name = the GPIO line is used as GPIO - * NC = not connected (pin out but not routed from the chip to - * anything the board) - * "[PER]" = pin is muxed for [peripheral] (not GPIO) - * LSEC = Low Speed External Connector - * HSEC = High Speed External Connector - * - * Line names are taken from the schematic "DragonBoard410c" - * dated monday, august 31, 2015. Page 5 in particular. - * - * For the lines routed to the external connectors the - * lines are named after the 96Boards CE Specification 1.0, - * Appendix "Expansion Connector Signal Description". - * - * When the 96Board naming of a line and the schematic name of - * the same line are in conflict, the 96Board specification - * takes precedence, which means that the external UART on the - * LSEC is named UART0 while the schematic and SoC names this - * UART3. This is only for the informational lines i.e. "[FOO]", - * the GPIO named lines "GPIO-A" thru "GPIO-L" are the only - * ones actually used for GPIO. - */ - -&tlmm { - gpio-line-names = - "[UART0_TX]", /* GPIO_0, LSEC pin 5 */ - "[UART0_RX]", /* GPIO_1, LSEC pin 7 */ - "[UART0_CTS_N]", /* GPIO_2, LSEC pin 3 */ - "[UART0_RTS_N]", /* GPIO_3, LSEC pin 9 */ - "[UART1_TX]", /* GPIO_4, LSEC pin 11 */ - "[UART1_RX]", /* GPIO_5, LSEC pin 13 */ - "[I2C0_SDA]", /* GPIO_8, LSEC pin 17 */ - "[I2C0_SCL]", /* GPIO_7, LSEC pin 15 */ - "[SPI1_DOUT]", /* SPI1_MOSI, HSEC pin 1 */ - "[SPI1_DIN]", /* SPI1_MISO, HSEC pin 11 */ - "[SPI1_CS]", /* SPI1_CS_N, HSEC pin 7 */ - "[SPI1_SCLK]", /* SPI1_CLK, HSEC pin 9 */ - "GPIO-B", /* LS_EXP_GPIO_B, LSEC pin 24 */ - "GPIO-C", /* LS_EXP_GPIO_C, LSEC pin 25 */ - "[I2C3_SDA]", /* HSEC pin 38 */ - "[I2C3_SCL]", /* HSEC pin 36 */ - "[SPI0_MOSI]", /* LSEC pin 14 */ - "[SPI0_MISO]", /* LSEC pin 10 */ - "[SPI0_CS_N]", /* LSEC pin 12 */ - "[SPI0_CLK]", /* LSEC pin 8 */ - "HDMI_HPD_N", /* GPIO 20 */ - "USR_LED_1_CTRL", - "[I2C1_SDA]", /* GPIO_22, LSEC pin 21 */ - "[I2C1_SCL]", /* GPIO_23, LSEC pin 19 */ - "GPIO-G", /* LS_EXP_GPIO_G, LSEC pin 29 */ - "GPIO-H", /* LS_EXP_GPIO_H, LSEC pin 30 */ - "[CSI0_MCLK]", /* HSEC pin 15 */ - "[CSI1_MCLK]", /* HSEC pin 17 */ - "GPIO-K", /* LS_EXP_GPIO_K, LSEC pin 33 */ - "[I2C2_SDA]", /* HSEC pin 34 */ - "[I2C2_SCL]", /* HSEC pin 32 */ - "DSI2HDMI_INT_N", - "DSI_SW_SEL_APQ", - "GPIO-L", /* LS_EXP_GPIO_L, LSEC pin 34 */ - "GPIO-J", /* LS_EXP_GPIO_J, LSEC pin 32 */ - "GPIO-I", /* LS_EXP_GPIO_I, LSEC pin 31 */ - "GPIO-A", /* LS_EXP_GPIO_A, LSEC pin 23 */ - "FORCED_USB_BOOT", - "SD_CARD_DET_N", - "[WCSS_BT_SSBI]", - "[WCSS_WLAN_DATA_2]", /* GPIO 40 */ - "[WCSS_WLAN_DATA_1]", - "[WCSS_WLAN_DATA_0]", - "[WCSS_WLAN_SET]", - "[WCSS_WLAN_CLK]", - "[WCSS_FM_SSBI]", - "[WCSS_FM_SDI]", - "[WCSS_BT_DAT_CTL]", - "[WCSS_BT_DAT_STB]", - "NC", - "NC", /* GPIO 50 */ - "NC", - "NC", - "NC", - "NC", - "NC", - "NC", - "NC", - "NC", - "NC", - "NC", /* GPIO 60 */ - "NC", - "NC", - "[CDC_PDM0_CLK]", - "[CDC_PDM0_SYNC]", - "[CDC_PDM0_TX0]", - "[CDC_PDM0_RX0]", - "[CDC_PDM0_RX1]", - "[CDC_PDM0_RX2]", - "GPIO-D", /* LS_EXP_GPIO_D, LSEC pin 26 */ - "NC", /* GPIO 70 */ - "NC", - "NC", - "NC", - "NC", /* GPIO 74 */ - "NC", - "NC", - "NC", - "NC", - "NC", - "BOOT_CONFIG_0", /* GPIO 80 */ - "BOOT_CONFIG_1", - "BOOT_CONFIG_2", - "BOOT_CONFIG_3", - "NC", - "NC", - "BOOT_CONFIG_5", - "NC", - "NC", - "NC", - "NC", /* GPIO 90 */ - "NC", - "NC", - "NC", - "NC", - "NC", - "NC", - "NC", - "NC", - "NC", - "NC", /* GPIO 100 */ - "NC", - "NC", - "NC", - "SSBI_GPS", - "NC", - "NC", - "KEY_VOLP_N", - "NC", - "NC", - "[LS_EXP_MI2S_WS]", /* GPIO 110 */ - "NC", - "NC", - "[LS_EXP_MI2S_SCK]", - "[LS_EXP_MI2S_DATA0]", - "GPIO-E", /* LS_EXP_GPIO_E, LSEC pin 27 */ - "NC", - "[DSI2HDMI_MI2S_WS]", - "[DSI2HDMI_MI2S_SCK]", - "[DSI2HDMI_MI2S_DATA0]", - "USR_LED_2_CTRL", /* GPIO 120 */ - "SB_HS_ID"; - - sdc2_cd_default: sdc2-cd-default-state { - pins = "gpio38"; - function = "gpio"; - drive-strength = <2>; - bias-disable; - }; - - tlmm_leds: tlmm-leds-state { - pins = "gpio21", "gpio120"; - function = "gpio"; - - output-low; - }; - - usb_id_default: usb-id-default-state { - pins = "gpio121"; - function = "gpio"; - - drive-strength = <8>; - bias-pull-up; - }; - - adv7533_int_active: adv533-int-active-state { - pins = "gpio31"; - function = "gpio"; - - drive-strength = <16>; - bias-disable; - }; - - adv7533_int_suspend: adv7533-int-suspend-state { - pins = "gpio31"; - function = "gpio"; - - drive-strength = <2>; - bias-disable; - }; - - adv7533_switch_active: adv7533-switch-active-state { - pins = "gpio32"; - function = "gpio"; - - drive-strength = <16>; - bias-disable; - }; - - adv7533_switch_suspend: adv7533-switch-suspend-state { - pins = "gpio32"; - function = "gpio"; - - drive-strength = <2>; - bias-disable; - }; - - msm_key_volp_n_default: msm-key-volp-n-default-state { - pins = "gpio107"; - function = "gpio"; - - drive-strength = <8>; - bias-pull-up; - }; -}; - -&pm8916_gpios { - gpio-line-names = - "USR_LED_3_CTRL", - "USR_LED_4_CTRL", - "USB_HUB_RESET_N_PM", - "USB_SW_SEL_PM"; - - usb_hub_reset_pm: usb-hub-reset-pm-state { - pins = "gpio3"; - function = PMIC_GPIO_FUNC_NORMAL; - - input-disable; - output-high; - }; - - usb_hub_reset_pm_device: usb-hub-reset-pm-device-state { - pins = "gpio3"; - function = PMIC_GPIO_FUNC_NORMAL; - - output-low; - }; - - usb_sw_sel_pm: usb-sw-sel-pm-state { - pins = "gpio4"; - function = PMIC_GPIO_FUNC_NORMAL; - - power-source = <PM8916_GPIO_VPH>; - input-disable; - output-high; - }; - - usb_sw_sel_pm_device: usb-sw-sel-pm-device-state { - pins = "gpio4"; - function = PMIC_GPIO_FUNC_NORMAL; - - power-source = <PM8916_GPIO_VPH>; - input-disable; - output-low; - }; - - pm8916_gpios_leds: pm8916-gpios-leds-state { - pins = "gpio1", "gpio2"; - function = PMIC_GPIO_FUNC_NORMAL; - - output-low; - }; -}; - -&pm8916_mpps { - gpio-line-names = - "VDD_PX_BIAS", - "WLAN_LED_CTRL", - "BT_LED_CTRL", - "GPIO-F"; /* LS_EXP_GPIO_F, LSEC pin 28 */ - - pinctrl-names = "default"; - pinctrl-0 = <&ls_exp_gpio_f>; - - ls_exp_gpio_f: pm8916-mpp4-state { - pins = "mpp4"; - function = "digital"; - - output-low; - power-source = <PM8916_MPP_L5>; /* 1.8V */ - }; - - pm8916_mpps_leds: pm8916-mpps-state { - pins = "mpp2", "mpp3"; - function = "digital"; - - output-low; - }; -}; diff --git a/arch/arm/dts/apq8096-db820c.dts b/arch/arm/dts/apq8096-db820c.dts deleted file mode 100644 index e8148b3d6c50..000000000000 --- a/arch/arm/dts/apq8096-db820c.dts +++ /dev/null @@ -1,1137 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-only -/* - * Copyright (c) 2014-2016, The Linux Foundation. All rights reserved. - */ - -/dts-v1/; - -#include "msm8996.dtsi" -#include "pm8994.dtsi" -#include "pmi8994.dtsi" -#include <dt-bindings/input/input.h> -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/leds/common.h> -#include <dt-bindings/pinctrl/qcom,pmic-gpio.h> -#include <dt-bindings/sound/qcom,q6afe.h> -#include <dt-bindings/sound/qcom,q6asm.h> -#include <dt-bindings/sound/qcom,wcd9335.h> - -/* - * GPIO name legend: proper name = the GPIO line is used as GPIO - * NC = not connected (pin out but not routed from the chip to - * anything the board) - * "[PER]" = pin is muxed for [peripheral] (not GPIO) - * LSEC = Low Speed External Connector - * P HSEC = Primary High Speed External Connector - * S HSEC = Secondary High Speed External Connector - * J14 = Camera Connector - * TP = Test Points - * - * Line names are taken from the schematic "DragonBoard 820c", - * drawing no: LM25-P2751-1 - * - * For the lines routed to the external connectors the - * lines are named after the 96Boards CE Specification 1.0, - * Appendix "Expansion Connector Signal Description". - * - * When the 96Board naming of a line and the schematic name of - * the same line are in conflict, the 96Board specification - * takes precedence, which means that the external UART on the - * LSEC is named UART0 while the schematic and SoC names this - * UART3. This is only for the informational lines i.e. "[FOO]", - * the GPIO named lines "GPIO-A" thru "GPIO-L" are the only - * ones actually used for GPIO. - */ - -/ { - model = "Qualcomm Technologies, Inc. DB820c"; - compatible = "arrow,apq8096-db820c", "qcom,apq8096-sbc", "qcom,apq8096"; - - aliases { - serial0 = &blsp2_uart2; - serial1 = &blsp2_uart3; - serial2 = &blsp1_uart2; - i2c0 = &blsp1_i2c3; - i2c1 = &blsp2_i2c1; - i2c2 = &blsp2_i2c1; - spi0 = &blsp1_spi1; - spi1 = &blsp2_spi6; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - div1_mclk: divclk1 { - compatible = "gpio-gate-clock"; - pinctrl-0 = <&audio_mclk>; - pinctrl-names = "default"; - clocks = <&rpmcc RPM_SMD_DIV_CLK1>; - #clock-cells = <0>; - enable-gpios = <&pm8994_gpios 15 0>; - }; - - divclk4: divclk4 { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <32768>; - clock-output-names = "divclk4"; - - pinctrl-names = "default"; - pinctrl-0 = <&divclk4_pin_a>; - }; - - gpio-keys { - compatible = "gpio-keys"; - autorepeat; - - pinctrl-names = "default"; - pinctrl-0 = <&volume_up_gpio>; - - button { - label = "Volume Up"; - linux,code = <KEY_VOLUMEUP>; - gpios = <&pm8994_gpios 2 GPIO_ACTIVE_LOW>; - }; - }; - - usb2_id: usb2-id { - compatible = "linux,extcon-usb-gpio"; - id-gpios = <&pmi8994_gpios 6 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&usb2_vbus_det_gpio>; - }; - - usb3_id: usb3-id { - compatible = "linux,extcon-usb-gpio"; - id-gpios = <&pm8994_gpios 22 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&usb3_vbus_det_gpio>; - }; - - vph_pwr: vph-pwr-regulator { - compatible = "regulator-fixed"; - regulator-name = "vph_pwr"; - regulator-always-on; - regulator-boot-on; - - regulator-min-microvolt = <3700000>; - regulator-max-microvolt = <3700000>; - }; - - wlan_en: wlan-en-1-8v { - pinctrl-names = "default"; - pinctrl-0 = <&wlan_en_gpios>; - compatible = "regulator-fixed"; - regulator-name = "wlan-en-regulator"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - gpio = <&pm8994_gpios 8 0>; - - /* WLAN card specific delay */ - startup-delay-us = <70000>; - enable-active-high; - }; -}; - -&blsp1_i2c3 { - /* On Low speed expansion: LS-I2C0 */ - status = "okay"; -}; - -&blsp1_spi1 { - /* On Low speed expansion */ - status = "okay"; -}; - -&blsp1_uart2 { - label = "BT-UART"; - status = "okay"; - - bluetooth { - compatible = "qcom,qca6174-bt"; - - /* bt_disable_n gpio */ - enable-gpios = <&pm8994_gpios 19 GPIO_ACTIVE_HIGH>; - - clocks = <&divclk4>; - }; -}; - -&adsp_pil { - status = "okay"; - firmware-name = "qcom/apq8096/adsp.mbn"; -}; - -&blsp2_i2c1 { - /* On High speed expansion: HS-I2C2 */ - status = "okay"; -}; - -&blsp2_i2c1 { - /* On Low speed expansion: LS-I2C1 */ - status = "okay"; -}; - -&blsp2_spi6 { - /* On High speed expansion */ - status = "okay"; -}; - -&blsp2_uart2 { - label = "LS-UART1"; - status = "okay"; - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&blsp2_uart2_2pins_default>; - pinctrl-1 = <&blsp2_uart2_2pins_sleep>; -}; - -&blsp2_uart3 { - label = "LS-UART0"; - status = "disabled"; - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&blsp2_uart3_4pins_default>; - pinctrl-1 = <&blsp2_uart3_4pins_sleep>; -}; - -&camss { - vdda-supply = <&vreg_l2a_1p25>; -}; - -&gpu { - status = "okay"; -}; - -&hsusb_phy1 { - status = "okay"; - - vdd-supply = <&vreg_l28a_0p925>; - vdda-pll-supply = <&vreg_l12a_1p8>; - vdda-phy-dpdm-supply = <&vreg_l24a_3p075>; -}; - -&hsusb_phy2 { - status = "okay"; - - vdd-supply = <&vreg_l28a_0p925>; - vdda-pll-supply = <&vreg_l12a_1p8>; - vdda-phy-dpdm-supply = <&vreg_l24a_3p075>; -}; - -&mdp { - status = "okay"; -}; - -&mdss { - status = "okay"; -}; - -&mdss_hdmi { - status = "okay"; - - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&hdmi_hpd_active &hdmi_ddc_active>; - pinctrl-1 = <&hdmi_hpd_suspend &hdmi_ddc_suspend>; - - core-vdda-supply = <&vreg_l12a_1p8>; - core-vcc-supply = <&vreg_s4a_1p8>; -}; - -&mdss_hdmi_phy { - status = "okay"; - - vddio-supply = <&vreg_l12a_1p8>; - vcca-supply = <&vreg_l28a_0p925>; - #phy-cells = <0>; -}; - -&mmcc { - vdd-gfx-supply = <&vdd_gfx>; -}; - -&mss_pil { - status = "okay"; - pll-supply = <&vreg_l12a_1p8>; - firmware-name = "qcom/apq8096/mba.mbn", "qcom/apq8096/modem.mbn"; -}; - -&pm8994_resin { - status = "okay"; - linux,code = <KEY_VOLUMEDOWN>; -}; - -&tlmm { - gpio-line-names = - "[SPI0_DOUT]", /* GPIO_0, BLSP1_SPI_MOSI, LSEC pin 14 */ - "[SPI0_DIN]", /* GPIO_1, BLSP1_SPI_MISO, LSEC pin 10 */ - "[SPI0_CS]", /* GPIO_2, BLSP1_SPI_CS_N, LSEC pin 12 */ - "[SPI0_SCLK]", /* GPIO_3, BLSP1_SPI_CLK, LSEC pin 8 */ - "[UART1_TxD]", /* GPIO_4, BLSP8_UART_TX, LSEC pin 11 */ - "[UART1_RxD]", /* GPIO_5, BLSP8_UART_RX, LSEC pin 13 */ - "[I2C1_SDA]", /* GPIO_6, BLSP8_I2C_SDA, LSEC pin 21 */ - "[I2C1_SCL]", /* GPIO_7, BLSP8_I2C_SCL, LSEC pin 19 */ - "GPIO-H", /* GPIO_8, LCD0_RESET_N, LSEC pin 30 */ - "TP93", /* GPIO_9 */ - "GPIO-G", /* GPIO_10, MDP_VSYNC_P, LSEC pin 29 */ - "[MDP_VSYNC_S]", /* GPIO_11, S HSEC pin 55 */ - "NC", /* GPIO_12 */ - "[CSI0_MCLK]", /* GPIO_13, CAM_MCLK0, P HSEC pin 15 */ - "[CAM_MCLK1]", /* GPIO_14, J14 pin 11 */ - "[CSI1_MCLK]", /* GPIO_15, CAM_MCLK2, P HSEC pin 17 */ - "TP99", /* GPIO_16 */ - "[I2C2_SDA]", /* GPIO_17, CCI_I2C_SDA0, P HSEC pin 34 */ - "[I2C2_SCL]", /* GPIO_18, CCI_I2C_SCL0, P HSEC pin 32 */ - "[CCI_I2C_SDA1]", /* GPIO_19, S HSEC pin 38 */ - "[CCI_I2C_SCL1]", /* GPIO_20, S HSEC pin 36 */ - "FLASH_STROBE_EN", /* GPIO_21, S HSEC pin 5 */ - "FLASH_STROBE_TRIG", /* GPIO_22, S HSEC pin 1 */ - "GPIO-K", /* GPIO_23, CAM2_RST_N, LSEC pin 33 */ - "GPIO-D", /* GPIO_24, LSEC pin 26 */ - "GPIO-I", /* GPIO_25, CAM0_RST_N, LSEC pin 31 */ - "GPIO-J", /* GPIO_26, CAM0_STANDBY_N, LSEC pin 32 */ - "BLSP6_I2C_SDA", /* GPIO_27 */ - "BLSP6_I2C_SCL", /* GPIO_28 */ - "GPIO-B", /* GPIO_29, TS0_RESET_N, LSEC pin 24 */ - "GPIO30", /* GPIO_30, S HSEC pin 4 */ - "HDMI_CEC", /* GPIO_31 */ - "HDMI_DDC_CLOCK", /* GPIO_32 */ - "HDMI_DDC_DATA", /* GPIO_33 */ - "HDMI_HOT_PLUG_DETECT", /* GPIO_34 */ - "PCIE0_RST_N", /* GPIO_35 */ - "PCIE0_CLKREQ_N", /* GPIO_36 */ - "PCIE0_WAKE", /* GPIO_37 */ - "SD_CARD_DET_N", /* GPIO_38 */ - "TSIF1_SYNC", /* GPIO_39, S HSEC pin 48 */ - "W_DISABLE_N", /* GPIO_40 */ - "[BLSP9_UART_TX]", /* GPIO_41 */ - "[BLSP9_UART_RX]", /* GPIO_42 */ - "[BLSP2_UART_CTS_N]", /* GPIO_43 */ - "[BLSP2_UART_RFR_N]", /* GPIO_44 */ - "[BLSP3_UART_TX]", /* GPIO_45 */ - "[BLSP3_UART_RX]", /* GPIO_46 */ - "[I2C0_SDA]", /* GPIO_47, LS_I2C0_SDA, LSEC pin 17 */ - "[I2C0_SCL]", /* GPIO_48, LS_I2C0_SCL, LSEC pin 15 */ - "[UART0_TxD]", /* GPIO_49, BLSP9_UART_TX, LSEC pin 5 */ - "[UART0_RxD]", /* GPIO_50, BLSP9_UART_RX, LSEC pin 7 */ - "[UART0_CTS]", /* GPIO_51, BLSP9_UART_CTS_N, LSEC pin 3 */ - "[UART0_RTS]", /* GPIO_52, BLSP9_UART_RFR_N, LSEC pin 9 */ - "[CODEC_INT1_N]", /* GPIO_53 */ - "[CODEC_INT2_N]", /* GPIO_54 */ - "[BLSP7_I2C_SDA]", /* GPIO_55 */ - "[BLSP7_I2C_SCL]", /* GPIO_56 */ - "MI2S_MCLK", /* GPIO_57, S HSEC pin 3 */ - "[PCM_CLK]", /* GPIO_58, QUA_MI2S_SCK, LSEC pin 18 */ - "[PCM_FS]", /* GPIO_59, QUA_MI2S_WS, LSEC pin 16 */ - "[PCM_DO]", /* GPIO_60, QUA_MI2S_DATA0, LSEC pin 20 */ - "[PCM_DI]", /* GPIO_61, QUA_MI2S_DATA1, LSEC pin 22 */ - "GPIO-E", /* GPIO_62, LSEC pin 27 */ - "TP87", /* GPIO_63 */ - "[CODEC_RST_N]", /* GPIO_64 */ - "[PCM1_CLK]", /* GPIO_65 */ - "[PCM1_SYNC]", /* GPIO_66 */ - "[PCM1_DIN]", /* GPIO_67 */ - "[PCM1_DOUT]", /* GPIO_68 */ - "AUDIO_REF_CLK", /* GPIO_69 */ - "SLIMBUS_CLK", /* GPIO_70 */ - "SLIMBUS_DATA0", /* GPIO_71 */ - "SLIMBUS_DATA1", /* GPIO_72 */ - "NC", /* GPIO_73 */ - "NC", /* GPIO_74 */ - "NC", /* GPIO_75 */ - "NC", /* GPIO_76 */ - "TP94", /* GPIO_77 */ - "NC", /* GPIO_78 */ - "TP95", /* GPIO_79 */ - "GPIO-A", /* GPIO_80, MEMS_RESET_N, LSEC pin 23 */ - "TP88", /* GPIO_81 */ - "TP89", /* GPIO_82 */ - "TP90", /* GPIO_83 */ - "TP91", /* GPIO_84 */ - "[SD_DAT0]", /* GPIO_85, BLSP12_SPI_MOSI, P HSEC pin 1 */ - "[SD_CMD]", /* GPIO_86, BLSP12_SPI_MISO, P HSEC pin 11 */ - "[SD_DAT3]", /* GPIO_87, BLSP12_SPI_CS_N, P HSEC pin 7 */ - "[SD_SCLK]", /* GPIO_88, BLSP12_SPI_CLK, P HSEC pin 9 */ - "TSIF1_CLK", /* GPIO_89, S HSEC pin 42 */ - "TSIF1_EN", /* GPIO_90, S HSEC pin 46 */ - "TSIF1_DATA", /* GPIO_91, S HSEC pin 44 */ - "NC", /* GPIO_92 */ - "TSIF2_CLK", /* GPIO_93, S HSEC pin 52 */ - "TSIF2_EN", /* GPIO_94, S HSEC pin 56 */ - "TSIF2_DATA", /* GPIO_95, S HSEC pin 54 */ - "TSIF2_SYNC", /* GPIO_96, S HSEC pin 58 */ - "NC", /* GPIO_97 */ - "CAM1_STANDBY_N", /* GPIO_98 */ - "NC", /* GPIO_99 */ - "NC", /* GPIO_100 */ - "[LCD1_RESET_N]", /* GPIO_101, S HSEC pin 51 */ - "BOOT_CONFIG1", /* GPIO_102 */ - "USB_HUB_RESET", /* GPIO_103 */ - "CAM1_RST_N", /* GPIO_104 */ - "NC", /* GPIO_105 */ - "NC", /* GPIO_106 */ - "NC", /* GPIO_107 */ - "NC", /* GPIO_108 */ - "NC", /* GPIO_109 */ - "NC", /* GPIO_110 */ - "NC", /* GPIO_111 */ - "NC", /* GPIO_112 */ - "PMI8994_BUA", /* GPIO_113 */ - "PCIE2_RST_N", /* GPIO_114 */ - "PCIE2_CLKREQ_N", /* GPIO_115 */ - "PCIE2_WAKE", /* GPIO_116 */ - "SSC_IRQ_0", /* GPIO_117 */ - "SSC_IRQ_1", /* GPIO_118 */ - "SSC_IRQ_2", /* GPIO_119 */ - "NC", /* GPIO_120 */ - "GPIO121", /* GPIO_121, S HSEC pin 2 */ - "NC", /* GPIO_122 */ - "SSC_IRQ_6", /* GPIO_123 */ - "SSC_IRQ_7", /* GPIO_124 */ - "GPIO-C", /* GPIO_125, TS_INT0, LSEC pin 25 */ - "BOOT_CONFIG5", /* GPIO_126 */ - "NC", /* GPIO_127 */ - "NC", /* GPIO_128 */ - "BOOT_CONFIG7", /* GPIO_129 */ - "PCIE1_RST_N", /* GPIO_130 */ - "PCIE1_CLKREQ_N", /* GPIO_131 */ - "PCIE1_WAKE", /* GPIO_132 */ - "GPIO-L", /* GPIO_133, CAM2_STANDBY_N, LSEC pin 34 */ - "NC", /* GPIO_134 */ - "NC", /* GPIO_135 */ - "BOOT_CONFIG8", /* GPIO_136 */ - "NC", /* GPIO_137 */ - "NC", /* GPIO_138 */ - "GPS_SSBI2", /* GPIO_139 */ - "GPS_SSBI1", /* GPIO_140 */ - "NC", /* GPIO_141 */ - "NC", /* GPIO_142 */ - "NC", /* GPIO_143 */ - "BOOT_CONFIG6", /* GPIO_144 */ - "NC", /* GPIO_145 */ - "NC", /* GPIO_146 */ - "NC", /* GPIO_147 */ - "NC", /* GPIO_148 */ - "NC"; /* GPIO_149 */ - - sdc2_cd_on: sdc2-cd-on-state { - pins = "gpio38"; - function = "gpio"; - bias-pull-up; - drive-strength = <16>; - }; - - sdc2_cd_off: sdc2-cd-off-state { - pins = "gpio38"; - function = "gpio"; - bias-pull-up; - drive-strength = <2>; - }; - - hdmi_hpd_active: hdmi-hpd-active-state { - pins = "gpio34"; - function = "hdmi_hot"; - bias-pull-down; - drive-strength = <16>; - }; - - hdmi_hpd_suspend: hdmi-hpd-suspend-state { - pins = "gpio34"; - function = "hdmi_hot"; - bias-pull-down; - drive-strength = <2>; - }; - - hdmi_ddc_active: hdmi-ddc-active-state { - pins = "gpio32", "gpio33"; - function = "hdmi_ddc"; - drive-strength = <2>; - bias-pull-up; - }; - - hdmi_ddc_suspend: hdmi-ddc-suspend-state { - pins = "gpio32", "gpio33"; - function = "hdmi_ddc"; - drive-strength = <2>; - bias-pull-down; - }; -}; - -&pcie0 { - status = "okay"; - perst-gpios = <&tlmm 35 GPIO_ACTIVE_LOW>; - vddpe-3v3-supply = <&wlan_en>; - vdda-supply = <&vreg_l28a_0p925>; -}; - -&pcie1 { - status = "okay"; - perst-gpios = <&tlmm 130 GPIO_ACTIVE_LOW>; - vdda-supply = <&vreg_l28a_0p925>; -}; - -&pcie2 { - status = "okay"; - perst-gpios = <&tlmm 114 GPIO_ACTIVE_LOW>; - vdda-supply = <&vreg_l28a_0p925>; -}; - -&pcie_phy { - status = "okay"; - - vdda-phy-supply = <&vreg_l28a_0p925>; - vdda-pll-supply = <&vreg_l12a_1p8>; -}; - -&pm8994_gpios { - gpio-line-names = - "NC", - "KEY_VOLP_N", - "NC", - "BL1_PWM", - "GPIO-F", /* BL0_PWM, LSEC pin 28 */ - "BL1_EN", - "NC", - "WLAN_EN", - "NC", - "NC", - "NC", - "NC", - "NC", - "NC", - "DIVCLK1", - "DIVCLK2", - "DIVCLK3", - "DIVCLK4", - "BT_EN", - "PMIC_SLB", - "PMIC_BUA", - "USB_VBUS_DET"; - - pinctrl-names = "default"; - pinctrl-0 = <&ls_exp_gpio_f &bt_en_gpios>; - - ls_exp_gpio_f: pm8994-gpio5-state { - pinconf { - pins = "gpio5"; - function = PMIC_GPIO_FUNC_NORMAL; - output-low; - power-source = <PM8994_GPIO_S4>; /* 1.8V */ - }; - }; - - bt_en_gpios: bt-en-pios-state { - pinconf { - pins = "gpio19"; - function = PMIC_GPIO_FUNC_NORMAL; - output-low; - power-source = <PM8994_GPIO_S4>; /* 1.8V */ - qcom,drive-strength = <PMIC_GPIO_STRENGTH_LOW>; - bias-pull-down; - }; - }; - - wlan_en_gpios: wlan-en-gpios-state { - pinconf { - pins = "gpio8"; - function = PMIC_GPIO_FUNC_NORMAL; - output-low; - power-source = <PM8994_GPIO_S4>; /* 1.8V */ - qcom,drive-strength = <PMIC_GPIO_STRENGTH_LOW>; - bias-pull-down; - }; - }; - - audio_mclk: clk-div1-state { - pinconf { - pins = "gpio15"; - function = "func1"; - power-source = <PM8994_GPIO_S4>; /* 1.8V */ - }; - }; - - volume_up_gpio: pm8996-gpio2-state { - pinconf { - pins = "gpio2"; - function = "normal"; - input-enable; - drive-push-pull; - bias-pull-up; - qcom,drive-strength = <PMIC_GPIO_STRENGTH_NO>; - power-source = <PM8994_GPIO_S4>; /* 1.8V */ - }; - }; - - divclk4_pin_a: divclk4-state { - pinconf { - pins = "gpio18"; - function = PMIC_GPIO_FUNC_FUNC2; - - bias-disable; - power-source = <PM8994_GPIO_S4>; - }; - }; - - usb3_vbus_det_gpio: pm8996-gpio22-state { - pinconf { - pins = "gpio22"; - function = PMIC_GPIO_FUNC_NORMAL; - input-enable; - bias-pull-down; - qcom,drive-strength = <PMIC_GPIO_STRENGTH_NO>; - power-source = <PM8994_GPIO_S4>; /* 1.8V */ - }; - }; -}; - -&pm8994_mpps { - gpio-line-names = - "VDDPX_BIAS", - "WIFI_LED", - "NC", - "BT_LED", - "PM_MPP05", - "PM_MPP06", - "PM_MPP07", - "NC"; -}; - -&pm8994_spmi_regulators { - qcom,saw-reg = <&saw3>; - vdd_s11-supply = <&vph_pwr>; - - s9 { - qcom,saw-slave; - }; - s10 { - qcom,saw-slave; - }; - s11 { - qcom,saw-leader; - regulator-name = "VDD_APCC"; - regulator-always-on; - regulator-min-microvolt = <980000>; - regulator-max-microvolt = <980000>; - }; -}; - -&pmi8994_gpios { - gpio-line-names = - "NC", - "SPKR_AMP_EN1", - "SPKR_AMP_EN2", - "TP61", - "NC", - "USB2_VBUS_DET", - "NC", - "NC", - "NC", - "NC"; - - usb2_vbus_det_gpio: pmi8996-gpio6-state { - pinconf { - pins = "gpio6"; - function = PMIC_GPIO_FUNC_NORMAL; - input-enable; - bias-pull-down; - qcom,drive-strength = <PMIC_GPIO_STRENGTH_NO>; - power-source = <PM8994_GPIO_S4>; /* 1.8V */ - }; - }; -}; - -&pmi8994_lpg { - qcom,power-source = <1>; - - pinctrl-names = "default"; - pinctrl-0 = <&pmi8994_mpp2_userled4>; - - qcom,dtest = <0 0>, - <0 0>, - <0 0>, - <4 1>; - - status = "okay"; - - led@1 { - reg = <1>; - color = <LED_COLOR_ID_GREEN>; - function = LED_FUNCTION_HEARTBEAT; - function-enumerator = <1>; - - linux,default-trigger = "heartbeat"; - default-state = "on"; - }; - - led@2 { - reg = <2>; - color = <LED_COLOR_ID_GREEN>; - function = LED_FUNCTION_HEARTBEAT; - function-enumerator = <0>; - }; - - led@3 { - reg = <3>; - color = <LED_COLOR_ID_GREEN>; - function = LED_FUNCTION_HEARTBEAT; - function-enumerator = <2>; - }; - - led@4 { - reg = <4>; - color = <LED_COLOR_ID_GREEN>; - function = LED_FUNCTION_HEARTBEAT; - function-enumerator = <3>; - }; -}; - -&pmi8994_mpps { - pmi8994_mpp2_userled4: mpp2-userled4-state { - pins = "mpp2"; - function = "sink"; - - output-low; - qcom,dtest = <4>; - }; -}; - -&pmi8994_spmi_regulators { - vdd_s2-supply = <&vph_pwr>; - - vdd_gfx: s2 { - regulator-name = "VDD_GFX"; - regulator-min-microvolt = <980000>; - regulator-max-microvolt = <980000>; - }; -}; - -&rpm_requests { - regulators-0 { - compatible = "qcom,rpm-pm8994-regulators"; - - vdd_s1-supply = <&vph_pwr>; - vdd_s2-supply = <&vph_pwr>; - vdd_s3-supply = <&vph_pwr>; - vdd_s4-supply = <&vph_pwr>; - vdd_s5-supply = <&vph_pwr>; - vdd_s6-supply = <&vph_pwr>; - vdd_s7-supply = <&vph_pwr>; - vdd_s8-supply = <&vph_pwr>; - vdd_s9-supply = <&vph_pwr>; - vdd_s10-supply = <&vph_pwr>; - vdd_s11-supply = <&vph_pwr>; - vdd_s12-supply = <&vph_pwr>; - vdd_l1-supply = <&vreg_s1b_1p025>; - vdd_l2_l26_l28-supply = <&vreg_s3a_1p3>; - vdd_l3_l11-supply = <&vreg_s3a_1p3>; - vdd_l4_l27_l31-supply = <&vreg_s3a_1p3>; - vdd_l5_l7-supply = <&vreg_s5a_2p15>; - vdd_l6_l12_l32-supply = <&vreg_s5a_2p15>; - vdd_l8_l16_l30-supply = <&vph_pwr>; - vdd_l9_l10_l18_l22-supply = <&vph_pwr_bbyp>; - vdd_l13_l19_l23_l24-supply = <&vph_pwr_bbyp>; - vdd_l14_l15-supply = <&vreg_s5a_2p15>; - vdd_l17_l29-supply = <&vph_pwr_bbyp>; - vdd_l20_l21-supply = <&vph_pwr_bbyp>; - vdd_l25-supply = <&vreg_s3a_1p3>; - vdd_lvs1_2-supply = <&vreg_s4a_1p8>; - - vreg_s3a_1p3: s3 { - regulator-name = "vreg_s3a_1p3"; - regulator-min-microvolt = <1300000>; - regulator-max-microvolt = <1300000>; - }; - - /** - * 1.8v required on LS expansion - * for mezzanine boards - */ - vreg_s4a_1p8: s4 { - regulator-name = "vreg_s4a_1p8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - }; - vreg_s5a_2p15: s5 { - regulator-name = "vreg_s5a_2p15"; - regulator-min-microvolt = <2150000>; - regulator-max-microvolt = <2150000>; - }; - vreg_s7a_1p0: s7 { - regulator-name = "vreg_s7a_1p0"; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <800000>; - }; - - vreg_l1a_1p0: l1 { - regulator-name = "vreg_l1a_1p0"; - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - }; - vreg_l2a_1p25: l2 { - regulator-name = "vreg_l2a_1p25"; - regulator-min-microvolt = <1250000>; - regulator-max-microvolt = <1250000>; - }; - vreg_l3a_0p875: l3 { - regulator-name = "vreg_l3a_0p875"; - regulator-min-microvolt = <850000>; - regulator-max-microvolt = <850000>; - }; - vreg_l4a_1p225: l4 { - regulator-name = "vreg_l4a_1p225"; - regulator-min-microvolt = <1225000>; - regulator-max-microvolt = <1225000>; - }; - vreg_l6a_1p2: l6 { - regulator-name = "vreg_l6a_1p2"; - regulator-min-microvolt = <1200000>; - regulator-max-microvolt = <1200000>; - }; - vreg_l8a_1p8: l8 { - regulator-name = "vreg_l8a_1p8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - }; - vreg_l9a_1p8: l9 { - regulator-name = "vreg_l9a_1p8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - }; - vreg_l10a_1p8: l10 { - regulator-name = "vreg_l10a_1p8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - }; - vreg_l11a_1p15: l11 { - regulator-name = "vreg_l11a_1p15"; - regulator-min-microvolt = <1150000>; - regulator-max-microvolt = <1150000>; - }; - vreg_l12a_1p8: l12 { - regulator-name = "vreg_l12a_1p8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - }; - vreg_l13a_2p95: l13 { - regulator-name = "vreg_l13a_2p95"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <2950000>; - }; - vreg_l14a_1p8: l14 { - regulator-name = "vreg_l14a_1p8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - }; - vreg_l15a_1p8: l15 { - regulator-name = "vreg_l15a_1p8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - }; - vreg_l16a_2p7: l16 { - regulator-name = "vreg_l16a_2p7"; - regulator-min-microvolt = <2700000>; - regulator-max-microvolt = <2700000>; - }; - vreg_l17a_2p8: l17 { - regulator-name = "vreg_l17a_2p8"; - regulator-min-microvolt = <2500000>; - regulator-max-microvolt = <2500000>; - }; - vreg_l18a_2p85: l18 { - regulator-name = "vreg_l18a_2p85"; - regulator-min-microvolt = <2700000>; - regulator-max-microvolt = <2900000>; - }; - vreg_l19a_2p8: l19 { - regulator-name = "vreg_l19a_2p8"; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - }; - vreg_l20a_2p95: l20 { - regulator-name = "vreg_l20a_2p95"; - regulator-min-microvolt = <2950000>; - regulator-max-microvolt = <2950000>; - regulator-allow-set-load; - }; - vreg_l21a_2p95: l21 { - regulator-name = "vreg_l21a_2p95"; - regulator-min-microvolt = <2950000>; - regulator-max-microvolt = <2950000>; - regulator-allow-set-load; - regulator-system-load = <200000>; - }; - vreg_l22a_3p0: l22 { - regulator-name = "vreg_l22a_3p0"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; - vreg_l23a_2p8: l23 { - regulator-name = "vreg_l23a_2p8"; - regulator-min-microvolt = <2800000>; - regulator-max-microvolt = <2800000>; - }; - vreg_l24a_3p075: l24 { - regulator-name = "vreg_l24a_3p075"; - regulator-min-microvolt = <3075000>; - regulator-max-microvolt = <3075000>; - }; - vreg_l25a_1p2: l25 { - regulator-name = "vreg_l25a_1p2"; - regulator-min-microvolt = <1200000>; - regulator-max-microvolt = <1200000>; - regulator-allow-set-load; - }; - vreg_l26a_0p8: l27 { - regulator-name = "vreg_l26a_0p8"; - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - }; - vreg_l28a_0p925: l28 { - regulator-name = "vreg_l28a_0p925"; - regulator-min-microvolt = <925000>; - regulator-max-microvolt = <925000>; - regulator-allow-set-load; - }; - vreg_l29a_2p8: l29 { - regulator-name = "vreg_l29a_2p8"; - regulator-min-microvolt = <2800000>; - regulator-max-microvolt = <2800000>; - }; - vreg_l30a_1p8: l30 { - regulator-name = "vreg_l30a_1p8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - }; - vreg_l32a_1p8: l32 { - regulator-name = "vreg_l32a_1p8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - }; - - vreg_lvs1a_1p8: lvs1 { - regulator-name = "vreg_lvs1a_1p8"; - }; - - vreg_lvs2a_1p8: lvs2 { - regulator-name = "vreg_lvs2a_1p8"; - }; - }; - - regulators-1 { - compatible = "qcom,rpm-pmi8994-regulators"; - - vdd_s1-supply = <&vph_pwr>; - vdd_s2-supply = <&vph_pwr>; - vdd_s3-supply = <&vph_pwr>; - vdd_bst_byp-supply = <&vph_pwr>; - - vph_pwr_bbyp: boost-bypass { - regulator-name = "vph_pwr_bbyp"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; - - vreg_s1b_1p025: s1 { - regulator-name = "vreg_s1b_1p025"; - regulator-min-microvolt = <1025000>; - regulator-max-microvolt = <1025000>; - }; - }; -}; - -&sdhc2 { - /* External SD card */ - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&sdc2_state_on &sdc2_cd_on>; - pinctrl-1 = <&sdc2_state_off &sdc2_cd_off>; - cd-gpios = <&tlmm 38 GPIO_ACTIVE_LOW>; - vmmc-supply = <&vreg_l21a_2p95>; - vqmmc-supply = <&vreg_l13a_2p95>; - status = "okay"; -}; - -&q6asmdai { - dai@0 { - reg = <0>; - }; - - dai@1 { - reg = <1>; - }; - - dai@2 { - reg = <2>; - }; -}; - -&slim_msm { - status = "okay"; - - slim@1 { - reg = <1>; - #address-cells = <2>; - #size-cells = <0>; - - tasha_ifd: tas-ifd@0,0 { - compatible = "slim217,1a0"; - reg = <0 0>; - }; - - wcd9335: codec@1,0 { - compatible = "slim217,1a0"; - reg = <1 0>; - - clock-names = "mclk", "slimbus"; - clocks = <&div1_mclk>, - <&rpmcc RPM_SMD_BB_CLK1>; - interrupt-parent = <&tlmm>; - interrupts = <54 IRQ_TYPE_LEVEL_HIGH>, - <53 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "intr1", "intr2"; - interrupt-controller; - #interrupt-cells = <1>; - - pinctrl-0 = <&cdc_reset_active &wcd_intr_default>; - pinctrl-names = "default"; - - reset-gpios = <&tlmm 64 GPIO_ACTIVE_LOW>; - slim-ifc-dev = <&tasha_ifd>; - - #sound-dai-cells = <1>; - - vdd-buck-supply = <&vreg_s4a_1p8>; - vdd-buck-sido-supply = <&vreg_s4a_1p8>; - vdd-tx-supply = <&vreg_s4a_1p8>; - vdd-rx-supply = <&vreg_s4a_1p8>; - vdd-io-supply = <&vreg_s4a_1p8>; - }; - }; -}; - -&sound { - compatible = "qcom,apq8096-sndcard"; - model = "DB820c"; - audio-routing = "RX_BIAS", "MCLK", - "MM_DL1", "MultiMedia1 Playback", - "MM_DL2", "MultiMedia2 Playback", - "MultiMedia3 Capture", "MM_UL3"; - - mm1-dai-link { - link-name = "MultiMedia1"; - cpu { - sound-dai = <&q6asmdai MSM_FRONTEND_DAI_MULTIMEDIA1>; - }; - }; - - mm2-dai-link { - link-name = "MultiMedia2"; - cpu { - sound-dai = <&q6asmdai MSM_FRONTEND_DAI_MULTIMEDIA2>; - }; - }; - - mm3-dai-link { - link-name = "MultiMedia3"; - cpu { - sound-dai = <&q6asmdai MSM_FRONTEND_DAI_MULTIMEDIA3>; - }; - }; - - hdmi-dai-link { - link-name = "HDMI"; - cpu { - sound-dai = <&q6afedai HDMI_RX>; - }; - - platform { - sound-dai = <&q6routing>; - }; - - codec { - sound-dai = <&mdss_hdmi 0>; - }; - }; - - slim-dai-link { - link-name = "SLIM Playback"; - cpu { - sound-dai = <&q6afedai SLIMBUS_6_RX>; - }; - - platform { - sound-dai = <&q6routing>; - }; - - codec { - sound-dai = <&wcd9335 AIF4_PB>; - }; - }; - - slimcap-dai-link { - link-name = "SLIM Capture"; - cpu { - sound-dai = <&q6afedai SLIMBUS_0_TX>; - }; - - platform { - sound-dai = <&q6routing>; - }; - - codec { - sound-dai = <&wcd9335 AIF1_CAP>; - }; - }; -}; - -&ufsphy { - status = "okay"; - - vdda-phy-supply = <&vreg_l28a_0p925>; - vdda-pll-supply = <&vreg_l12a_1p8>; -}; - -&ufshc { - status = "okay"; - - vcc-supply = <&vreg_l20a_2p95>; - vccq-supply = <&vreg_l25a_1p2>; - vccq2-supply = <&vreg_s4a_1p8>; - vdd-hba-supply = <&vreg_l25a_1p2>; - - vcc-max-microamp = <600000>; - vccq-max-microamp = <450000>; - vccq2-max-microamp = <450000>; -}; - -&usb2 { - status = "okay"; - extcon = <&usb2_id>; -}; - -&usb2_dwc3 { - extcon = <&usb2_id>; - dr_mode = "otg"; - maximum-speed = "high-speed"; -}; - -&usb3 { - status = "okay"; - extcon = <&usb3_id>; -}; - -&usb3_dwc3 { - extcon = <&usb3_id>; - dr_mode = "otg"; -}; - -&usb3phy { - status = "okay"; - - vdda-phy-supply = <&vreg_l28a_0p925>; - vdda-pll-supply = <&vreg_l12a_1p8>; -}; - -&venus { - status = "okay"; -}; diff --git a/arch/arm/dts/msm8916-pm8916.dtsi b/arch/arm/dts/msm8916-pm8916.dtsi deleted file mode 100644 index b1a7eafbee31..000000000000 --- a/arch/arm/dts/msm8916-pm8916.dtsi +++ /dev/null @@ -1,157 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-only -/* - * msm8916-pm8916.dtsi describes common properties (e.g. regulator connections) - * that apply to most devices that make use of the MSM8916 SoC and PM8916 PMIC. - * Many regulators have a fixed purpose in the original reference design and - * were rarely re-used for different purposes. Devices that deviate from the - * typical reference design should not make use of this include and instead add - * the necessary properties in the board-specific device tree. - */ - -#include "msm8916.dtsi" -#include "pm8916.dtsi" - -&camss { - vdda-supply = <&pm8916_l2>; -}; - -&mdss_dsi0 { - vdda-supply = <&pm8916_l2>; - vddio-supply = <&pm8916_l6>; -}; - -&mdss_dsi0_phy { - vddio-supply = <&pm8916_l6>; -}; - -&mpss { - pll-supply = <&pm8916_l7>; -}; - -&pm8916_codec { - vdd-cdc-io-supply = <&pm8916_l5>; - vdd-cdc-tx-rx-cx-supply = <&pm8916_l5>; - vdd-micbias-supply = <&pm8916_l13>; -}; - -&sdhc_1 { - vmmc-supply = <&pm8916_l8>; - vqmmc-supply = <&pm8916_l5>; -}; - -&sdhc_2 { - vmmc-supply = <&pm8916_l11>; - vqmmc-supply = <&pm8916_l12>; -}; - -&usb_hs_phy { - v1p8-supply = <&pm8916_l7>; - v3p3-supply = <&pm8916_l13>; -}; - -&wcnss { - vddpx-supply = <&pm8916_l7>; -}; - -&wcnss_iris { - vddxo-supply = <&pm8916_l7>; - vddrfa-supply = <&pm8916_s3>; - vddpa-supply = <&pm8916_l9>; - vdddig-supply = <&pm8916_l5>; -}; - -&rpm_requests { - pm8916_rpm_regulators: regulators { - compatible = "qcom,rpm-pm8916-regulators"; - vdd_l1_l2_l3-supply = <&pm8916_s3>; - vdd_l4_l5_l6-supply = <&pm8916_s4>; - vdd_l7-supply = <&pm8916_s4>; - - /* pm8916_s1 is managed by rpmpd (MSM8916_VDDCX) */ - - pm8916_s3: s3 { - regulator-min-microvolt = <1250000>; - regulator-max-microvolt = <1350000>; - regulator-always-on; /* Needed for L2 */ - }; - - pm8916_s4: s4 { - regulator-min-microvolt = <1850000>; - regulator-max-microvolt = <2150000>; - regulator-always-on; /* Needed for L5/L7 */ - }; - - /* - * Some of the regulators are unused or managed by another - * processor (e.g. the modem). We should still define nodes for - * them to ensure the vote from the application processor can be - * dropped in case the regulators are already on during boot. - * - * The labels for these nodes are omitted on purpose because - * boards should configure a proper voltage before using them. - */ - l1 {}; - - pm8916_l2: l2 { - regulator-min-microvolt = <1200000>; - regulator-max-microvolt = <1200000>; - regulator-always-on; /* Needed for LPDDR RAM */ - }; - - /* pm8916_l3 is managed by rpmpd (MSM8916_VDDMX) */ - - l4 {}; - - pm8916_l5: l5 { - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; /* Needed for most digital I/O */ - }; - - pm8916_l6: l6 { - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - }; - - pm8916_l7: l7 { - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; /* Needed for CPU PLL */ - }; - - pm8916_l8: l8 { - regulator-min-microvolt = <2900000>; - regulator-max-microvolt = <2900000>; - }; - - pm8916_l9: l9 { - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; - - l10 {}; - - pm8916_l11: l11 { - regulator-min-microvolt = <2950000>; - regulator-max-microvolt = <2950000>; - regulator-allow-set-load; - regulator-system-load = <200000>; - }; - - pm8916_l12: l12 { - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <2950000>; - }; - - pm8916_l13: l13 { - regulator-min-microvolt = <3075000>; - regulator-max-microvolt = <3075000>; - }; - - l14 {}; - l15 {}; - l16 {}; - l17 {}; - l18 {}; - }; -}; diff --git a/arch/arm/dts/msm8916.dtsi b/arch/arm/dts/msm8916.dtsi deleted file mode 100644 index 4f799b536a92..000000000000 --- a/arch/arm/dts/msm8916.dtsi +++ /dev/null @@ -1,2702 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-only -/* - * Copyright (c) 2013-2015, The Linux Foundation. All rights reserved. - */ - -#include <dt-bindings/arm/coresight-cti-dt.h> -#include <dt-bindings/clock/qcom,gcc-msm8916.h> -#include <dt-bindings/clock/qcom,rpmcc.h> -#include <dt-bindings/interconnect/qcom,msm8916.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/power/qcom-rpmpd.h> -#include <dt-bindings/reset/qcom,gcc-msm8916.h> -#include <dt-bindings/thermal/thermal.h> - -/ { - interrupt-parent = <&intc>; - - #address-cells = <2>; - #size-cells = <2>; - - chosen { }; - - memory@80000000 { - device_type = "memory"; - /* We expect the bootloader to fill in the reg */ - reg = <0 0x80000000 0 0>; - }; - - reserved-memory { - #address-cells = <2>; - #size-cells = <2>; - ranges; - - tz-apps@86000000 { - reg = <0x0 0x86000000 0x0 0x300000>; - no-map; - }; - - smem@86300000 { - compatible = "qcom,smem"; - reg = <0x0 0x86300000 0x0 0x100000>; - no-map; - - hwlocks = <&tcsr_mutex 3>; - qcom,rpm-msg-ram = <&rpm_msg_ram>; - }; - - hypervisor@86400000 { - reg = <0x0 0x86400000 0x0 0x100000>; - no-map; - }; - - tz@86500000 { - reg = <0x0 0x86500000 0x0 0x180000>; - no-map; - }; - - reserved@86680000 { - reg = <0x0 0x86680000 0x0 0x80000>; - no-map; - }; - - rmtfs@86700000 { - compatible = "qcom,rmtfs-mem"; - reg = <0x0 0x86700000 0x0 0xe0000>; - no-map; - - qcom,client-id = <1>; - }; - - rfsa@867e0000 { - reg = <0x0 0x867e0000 0x0 0x20000>; - no-map; - }; - - mpss_mem: mpss@86800000 { - /* - * The memory region for the mpss firmware is generally - * relocatable and could be allocated dynamically. - * However, many firmware versions tend to fail when - * loaded to some special addresses, so it is hard to - * define reliable alloc-ranges. - * - * alignment = <0x0 0x400000>; - * alloc-ranges = <0x0 0x86800000 0x0 0x8000000>; - */ - reg = <0x0 0x86800000 0x0 0>; /* size is device-specific */ - no-map; - status = "disabled"; - }; - - wcnss_mem: wcnss { - size = <0x0 0x600000>; - alignment = <0x0 0x100000>; - alloc-ranges = <0x0 0x86800000 0x0 0x8000000>; - no-map; - status = "disabled"; - }; - - venus_mem: venus { - size = <0x0 0x500000>; - alignment = <0x0 0x100000>; - alloc-ranges = <0x0 0x86800000 0x0 0x8000000>; - no-map; - status = "disabled"; - }; - - mba_mem: mba { - size = <0x0 0x100000>; - alignment = <0x0 0x100000>; - alloc-ranges = <0x0 0x86800000 0x0 0x8000000>; - no-map; - status = "disabled"; - }; - }; - - clocks { - xo_board: xo-board { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <19200000>; - }; - - sleep_clk: sleep-clk { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <32768>; - }; - }; - - cpus { - #address-cells = <1>; - #size-cells = <0>; - - CPU0: cpu@0 { - device_type = "cpu"; - compatible = "arm,cortex-a53"; - reg = <0x0>; - next-level-cache = <&L2_0>; - enable-method = "psci"; - clocks = <&apcs>; - operating-points-v2 = <&cpu_opp_table>; - #cooling-cells = <2>; - power-domains = <&CPU_PD0>; - power-domain-names = "psci"; - qcom,acc = <&cpu0_acc>; - qcom,saw = <&cpu0_saw>; - }; - - CPU1: cpu@1 { - device_type = "cpu"; - compatible = "arm,cortex-a53"; - reg = <0x1>; - next-level-cache = <&L2_0>; - enable-method = "psci"; - clocks = <&apcs>; - operating-points-v2 = <&cpu_opp_table>; - #cooling-cells = <2>; - power-domains = <&CPU_PD1>; - power-domain-names = "psci"; - qcom,acc = <&cpu1_acc>; - qcom,saw = <&cpu1_saw>; - }; - - CPU2: cpu@2 { - device_type = "cpu"; - compatible = "arm,cortex-a53"; - reg = <0x2>; - next-level-cache = <&L2_0>; - enable-method = "psci"; - clocks = <&apcs>; - operating-points-v2 = <&cpu_opp_table>; - #cooling-cells = <2>; - power-domains = <&CPU_PD2>; - power-domain-names = "psci"; - qcom,acc = <&cpu2_acc>; - qcom,saw = <&cpu2_saw>; - }; - - CPU3: cpu@3 { - device_type = "cpu"; - compatible = "arm,cortex-a53"; - reg = <0x3>; - next-level-cache = <&L2_0>; - enable-method = "psci"; - clocks = <&apcs>; - operating-points-v2 = <&cpu_opp_table>; - #cooling-cells = <2>; - power-domains = <&CPU_PD3>; - power-domain-names = "psci"; - qcom,acc = <&cpu3_acc>; - qcom,saw = <&cpu3_saw>; - }; - - L2_0: l2-cache { - compatible = "cache"; - cache-level = <2>; - cache-unified; - }; - - idle-states { - entry-method = "psci"; - - CPU_SLEEP_0: cpu-sleep-0 { - compatible = "arm,idle-state"; - idle-state-name = "standalone-power-collapse"; - arm,psci-suspend-param = <0x40000002>; - entry-latency-us = <130>; - exit-latency-us = <150>; - min-residency-us = <2000>; - local-timer-stop; - }; - }; - - domain-idle-states { - - CLUSTER_RET: cluster-retention { - compatible = "domain-idle-state"; - arm,psci-suspend-param = <0x41000012>; - entry-latency-us = <500>; - exit-latency-us = <500>; - min-residency-us = <2000>; - }; - - CLUSTER_PWRDN: cluster-gdhs { - compatible = "domain-idle-state"; - arm,psci-suspend-param = <0x41000032>; - entry-latency-us = <2000>; - exit-latency-us = <2000>; - min-residency-us = <6000>; - }; - }; - }; - - cpu_opp_table: opp-table-cpu { - compatible = "operating-points-v2"; - opp-shared; - - opp-200000000 { - opp-hz = /bits/ 64 <200000000>; - }; - opp-400000000 { - opp-hz = /bits/ 64 <400000000>; - }; - opp-800000000 { - opp-hz = /bits/ 64 <800000000>; - }; - opp-998400000 { - opp-hz = /bits/ 64 <998400000>; - }; - }; - - firmware { - scm: scm { - compatible = "qcom,scm-msm8916", "qcom,scm"; - clocks = <&gcc GCC_CRYPTO_CLK>, - <&gcc GCC_CRYPTO_AXI_CLK>, - <&gcc GCC_CRYPTO_AHB_CLK>; - clock-names = "core", "bus", "iface"; - #reset-cells = <1>; - - qcom,dload-mode = <&tcsr 0x6100>; - }; - }; - - pmu { - compatible = "arm,cortex-a53-pmu"; - interrupts = <GIC_PPI 7 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; - }; - - psci { - compatible = "arm,psci-1.0"; - method = "smc"; - - CPU_PD0: power-domain-cpu0 { - #power-domain-cells = <0>; - power-domains = <&CLUSTER_PD>; - domain-idle-states = <&CPU_SLEEP_0>; - }; - - CPU_PD1: power-domain-cpu1 { - #power-domain-cells = <0>; - power-domains = <&CLUSTER_PD>; - domain-idle-states = <&CPU_SLEEP_0>; - }; - - CPU_PD2: power-domain-cpu2 { - #power-domain-cells = <0>; - power-domains = <&CLUSTER_PD>; - domain-idle-states = <&CPU_SLEEP_0>; - }; - - CPU_PD3: power-domain-cpu3 { - #power-domain-cells = <0>; - power-domains = <&CLUSTER_PD>; - domain-idle-states = <&CPU_SLEEP_0>; - }; - - CLUSTER_PD: power-domain-cluster { - #power-domain-cells = <0>; - domain-idle-states = <&CLUSTER_RET>, <&CLUSTER_PWRDN>; - }; - }; - - rpm: remoteproc { - compatible = "qcom,msm8916-rpm-proc", "qcom,rpm-proc"; - - smd-edge { - interrupts = <GIC_SPI 168 IRQ_TYPE_EDGE_RISING>; - qcom,ipc = <&apcs 8 0>; - qcom,smd-edge = <15>; - - rpm_requests: rpm-requests { - compatible = "qcom,rpm-msm8916"; - qcom,smd-channels = "rpm_requests"; - - rpmcc: clock-controller { - compatible = "qcom,rpmcc-msm8916", "qcom,rpmcc"; - #clock-cells = <1>; - clocks = <&xo_board>; - clock-names = "xo"; - }; - - rpmpd: power-controller { - compatible = "qcom,msm8916-rpmpd"; - #power-domain-cells = <1>; - operating-points-v2 = <&rpmpd_opp_table>; - - rpmpd_opp_table: opp-table { - compatible = "operating-points-v2"; - - rpmpd_opp_ret: opp1 { - opp-level = <1>; - }; - rpmpd_opp_svs_krait: opp2 { - opp-level = <2>; - }; - rpmpd_opp_svs_soc: opp3 { - opp-level = <3>; - }; - rpmpd_opp_nom: opp4 { - opp-level = <4>; - }; - rpmpd_opp_turbo: opp5 { - opp-level = <5>; - }; - rpmpd_opp_super_turbo: opp6 { - opp-level = <6>; - }; - }; - }; - }; - }; - }; - - smp2p-hexagon { - compatible = "qcom,smp2p"; - qcom,smem = <435>, <428>; - - interrupts = <GIC_SPI 27 IRQ_TYPE_EDGE_RISING>; - - qcom,ipc = <&apcs 8 14>; - - qcom,local-pid = <0>; - qcom,remote-pid = <1>; - - hexagon_smp2p_out: master-kernel { - qcom,entry-name = "master-kernel"; - - #qcom,smem-state-cells = <1>; - }; - - hexagon_smp2p_in: slave-kernel { - qcom,entry-name = "slave-kernel"; - - interrupt-controller; - #interrupt-cells = <2>; - }; - }; - - smp2p-wcnss { - compatible = "qcom,smp2p"; - qcom,smem = <451>, <431>; - - interrupts = <GIC_SPI 143 IRQ_TYPE_EDGE_RISING>; - - qcom,ipc = <&apcs 8 18>; - - qcom,local-pid = <0>; - qcom,remote-pid = <4>; - - wcnss_smp2p_out: master-kernel { - qcom,entry-name = "master-kernel"; - - #qcom,smem-state-cells = <1>; - }; - - wcnss_smp2p_in: slave-kernel { - qcom,entry-name = "slave-kernel"; - - interrupt-controller; - #interrupt-cells = <2>; - }; - }; - - smsm { - compatible = "qcom,smsm"; - - #address-cells = <1>; - #size-cells = <0>; - - qcom,ipc-1 = <&apcs 8 13>; - qcom,ipc-3 = <&apcs 8 19>; - - apps_smsm: apps@0 { - reg = <0>; - - #qcom,smem-state-cells = <1>; - }; - - hexagon_smsm: hexagon@1 { - reg = <1>; - interrupts = <GIC_SPI 26 IRQ_TYPE_EDGE_RISING>; - - interrupt-controller; - #interrupt-cells = <2>; - }; - - wcnss_smsm: wcnss@6 { - reg = <6>; - interrupts = <GIC_SPI 144 IRQ_TYPE_EDGE_RISING>; - - interrupt-controller; - #interrupt-cells = <2>; - }; - }; - - soc: soc@0 { - #address-cells = <1>; - #size-cells = <1>; - ranges = <0 0 0 0xffffffff>; - compatible = "simple-bus"; - - rng@22000 { - compatible = "qcom,prng"; - reg = <0x00022000 0x200>; - clocks = <&gcc GCC_PRNG_AHB_CLK>; - clock-names = "core"; - }; - - restart@4ab000 { - compatible = "qcom,pshold"; - reg = <0x004ab000 0x4>; - }; - - qfprom: qfprom@5c000 { - compatible = "qcom,msm8916-qfprom", "qcom,qfprom"; - reg = <0x0005c000 0x1000>; - #address-cells = <1>; - #size-cells = <1>; - - tsens_base1: base1@d0 { - reg = <0xd0 0x1>; - bits = <0 7>; - }; - - tsens_s0_p1: s0-p1@d0 { - reg = <0xd0 0x2>; - bits = <7 5>; - }; - - tsens_s0_p2: s0-p2@d1 { - reg = <0xd1 0x2>; - bits = <4 5>; - }; - - tsens_s1_p1: s1-p1@d2 { - reg = <0xd2 0x1>; - bits = <1 5>; - }; - tsens_s1_p2: s1-p2@d2 { - reg = <0xd2 0x2>; - bits = <6 5>; - }; - tsens_s2_p1: s2-p1@d3 { - reg = <0xd3 0x1>; - bits = <3 5>; - }; - - tsens_s2_p2: s2-p2@d4 { - reg = <0xd4 0x1>; - bits = <0 5>; - }; - - // no tsens with hw_id 3 - - tsens_s4_p1: s4-p1@d4 { - reg = <0xd4 0x2>; - bits = <5 5>; - }; - - tsens_s4_p2: s4-p2@d5 { - reg = <0xd5 0x1>; - bits = <2 5>; - }; - - tsens_s5_p1: s5-p1@d5 { - reg = <0xd5 0x2>; - bits = <7 5>; - }; - - tsens_s5_p2: s5-p2@d6 { - reg = <0xd6 0x2>; - bits = <4 5>; - }; - - tsens_base2: base2@d7 { - reg = <0xd7 0x1>; - bits = <1 7>; - }; - - tsens_mode: mode@ef { - reg = <0xef 0x1>; - bits = <5 3>; - }; - }; - - rpm_msg_ram: sram@60000 { - compatible = "qcom,rpm-msg-ram"; - reg = <0x00060000 0x8000>; - }; - - sram@290000 { - compatible = "qcom,msm8916-rpm-stats"; - reg = <0x00290000 0x10000>; - }; - - bimc: interconnect@400000 { - compatible = "qcom,msm8916-bimc"; - reg = <0x00400000 0x62000>; - #interconnect-cells = <1>; - clock-names = "bus", "bus_a"; - clocks = <&rpmcc RPM_SMD_BIMC_CLK>, - <&rpmcc RPM_SMD_BIMC_A_CLK>; - }; - - tsens: thermal-sensor@4a9000 { - compatible = "qcom,msm8916-tsens", "qcom,tsens-v0_1"; - reg = <0x004a9000 0x1000>, /* TM */ - <0x004a8000 0x1000>; /* SROT */ - - // no hw_id 3 - nvmem-cells = <&tsens_mode>, - <&tsens_base1>, <&tsens_base2>, - <&tsens_s0_p1>, <&tsens_s0_p2>, - <&tsens_s1_p1>, <&tsens_s1_p2>, - <&tsens_s2_p1>, <&tsens_s2_p2>, - <&tsens_s4_p1>, <&tsens_s4_p2>, - <&tsens_s5_p1>, <&tsens_s5_p2>; - nvmem-cell-names = "mode", - "base1", "base2", - "s0_p1", "s0_p2", - "s1_p1", "s1_p2", - "s2_p1", "s2_p2", - "s4_p1", "s4_p2", - "s5_p1", "s5_p2"; - #qcom,sensors = <5>; - interrupts = <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "uplow"; - #thermal-sensor-cells = <1>; - }; - - pcnoc: interconnect@500000 { - compatible = "qcom,msm8916-pcnoc"; - reg = <0x00500000 0x11000>; - #interconnect-cells = <1>; - clock-names = "bus", "bus_a"; - clocks = <&rpmcc RPM_SMD_PCNOC_CLK>, - <&rpmcc RPM_SMD_PCNOC_A_CLK>; - }; - - snoc: interconnect@580000 { - compatible = "qcom,msm8916-snoc"; - reg = <0x00580000 0x14000>; - #interconnect-cells = <1>; - clock-names = "bus", "bus_a"; - clocks = <&rpmcc RPM_SMD_SNOC_CLK>, - <&rpmcc RPM_SMD_SNOC_A_CLK>; - }; - - stm: stm@802000 { - compatible = "arm,coresight-stm", "arm,primecell"; - reg = <0x00802000 0x1000>, - <0x09280000 0x180000>; - reg-names = "stm-base", "stm-stimulus-base"; - - clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; - clock-names = "apb_pclk", "atclk"; - - status = "disabled"; - - out-ports { - port { - stm_out: endpoint { - remote-endpoint = <&funnel0_in7>; - }; - }; - }; - }; - - /* System CTIs */ - /* CTI 0 - TMC connections */ - cti0: cti@810000 { - compatible = "arm,coresight-cti", "arm,primecell"; - reg = <0x00810000 0x1000>; - - clocks = <&rpmcc RPM_QDSS_CLK>; - clock-names = "apb_pclk"; - - status = "disabled"; - }; - - /* CTI 1 - TPIU connections */ - cti1: cti@811000 { - compatible = "arm,coresight-cti", "arm,primecell"; - reg = <0x00811000 0x1000>; - - clocks = <&rpmcc RPM_QDSS_CLK>; - clock-names = "apb_pclk"; - - status = "disabled"; - }; - - /* CTIs 2-11 - no information - not instantiated */ - - tpiu: tpiu@820000 { - compatible = "arm,coresight-tpiu", "arm,primecell"; - reg = <0x00820000 0x1000>; - - clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; - clock-names = "apb_pclk", "atclk"; - - status = "disabled"; - - in-ports { - port { - tpiu_in: endpoint { - remote-endpoint = <&replicator_out1>; - }; - }; - }; - }; - - funnel0: funnel@821000 { - compatible = "arm,coresight-dynamic-funnel", "arm,primecell"; - reg = <0x00821000 0x1000>; - - clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; - clock-names = "apb_pclk", "atclk"; - - status = "disabled"; - - in-ports { - #address-cells = <1>; - #size-cells = <0>; - - /* - * Not described input ports: - * 0 - connected to Resource and Power Manger CPU ETM - * 1 - not-connected - * 2 - connected to Modem CPU ETM - * 3 - not-connected - * 5 - not-connected - * 6 - connected trought funnel to Wireless CPU ETM - * 7 - connected to STM component - */ - - port@4 { - reg = <4>; - funnel0_in4: endpoint { - remote-endpoint = <&funnel1_out>; - }; - }; - - port@7 { - reg = <7>; - funnel0_in7: endpoint { - remote-endpoint = <&stm_out>; - }; - }; - }; - - out-ports { - port { - funnel0_out: endpoint { - remote-endpoint = <&etf_in>; - }; - }; - }; - }; - - replicator: replicator@824000 { - compatible = "arm,coresight-dynamic-replicator", "arm,primecell"; - reg = <0x00824000 0x1000>; - - clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; - clock-names = "apb_pclk", "atclk"; - - status = "disabled"; - - out-ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - replicator_out0: endpoint { - remote-endpoint = <&etr_in>; - }; - }; - port@1 { - reg = <1>; - replicator_out1: endpoint { - remote-endpoint = <&tpiu_in>; - }; - }; - }; - - in-ports { - port { - replicator_in: endpoint { - remote-endpoint = <&etf_out>; - }; - }; - }; - }; - - etf: etf@825000 { - compatible = "arm,coresight-tmc", "arm,primecell"; - reg = <0x00825000 0x1000>; - - clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; - clock-names = "apb_pclk", "atclk"; - - status = "disabled"; - - in-ports { - port { - etf_in: endpoint { - remote-endpoint = <&funnel0_out>; - }; - }; - }; - - out-ports { - port { - etf_out: endpoint { - remote-endpoint = <&replicator_in>; - }; - }; - }; - }; - - etr: etr@826000 { - compatible = "arm,coresight-tmc", "arm,primecell"; - reg = <0x00826000 0x1000>; - - clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; - clock-names = "apb_pclk", "atclk"; - - status = "disabled"; - - in-ports { - port { - etr_in: endpoint { - remote-endpoint = <&replicator_out0>; - }; - }; - }; - }; - - funnel1: funnel@841000 { /* APSS funnel only 4 inputs are used */ - compatible = "arm,coresight-dynamic-funnel", "arm,primecell"; - reg = <0x00841000 0x1000>; - - clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; - clock-names = "apb_pclk", "atclk"; - - status = "disabled"; - - in-ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - funnel1_in0: endpoint { - remote-endpoint = <&etm0_out>; - }; - }; - port@1 { - reg = <1>; - funnel1_in1: endpoint { - remote-endpoint = <&etm1_out>; - }; - }; - port@2 { - reg = <2>; - funnel1_in2: endpoint { - remote-endpoint = <&etm2_out>; - }; - }; - port@3 { - reg = <3>; - funnel1_in3: endpoint { - remote-endpoint = <&etm3_out>; - }; - }; - }; - - out-ports { - port { - funnel1_out: endpoint { - remote-endpoint = <&funnel0_in4>; - }; - }; - }; - }; - - debug0: debug@850000 { - compatible = "arm,coresight-cpu-debug", "arm,primecell"; - reg = <0x00850000 0x1000>; - clocks = <&rpmcc RPM_QDSS_CLK>; - clock-names = "apb_pclk"; - cpu = <&CPU0>; - status = "disabled"; - }; - - debug1: debug@852000 { - compatible = "arm,coresight-cpu-debug", "arm,primecell"; - reg = <0x00852000 0x1000>; - clocks = <&rpmcc RPM_QDSS_CLK>; - clock-names = "apb_pclk"; - cpu = <&CPU1>; - status = "disabled"; - }; - - debug2: debug@854000 { - compatible = "arm,coresight-cpu-debug", "arm,primecell"; - reg = <0x00854000 0x1000>; - clocks = <&rpmcc RPM_QDSS_CLK>; - clock-names = "apb_pclk"; - cpu = <&CPU2>; - status = "disabled"; - }; - - debug3: debug@856000 { - compatible = "arm,coresight-cpu-debug", "arm,primecell"; - reg = <0x00856000 0x1000>; - clocks = <&rpmcc RPM_QDSS_CLK>; - clock-names = "apb_pclk"; - cpu = <&CPU3>; - status = "disabled"; - }; - - /* Core CTIs; CTIs 12-15 */ - /* CTI - CPU-0 */ - cti12: cti@858000 { - compatible = "arm,coresight-cti-v8-arch", "arm,coresight-cti", - "arm,primecell"; - reg = <0x00858000 0x1000>; - - clocks = <&rpmcc RPM_QDSS_CLK>; - clock-names = "apb_pclk"; - - cpu = <&CPU0>; - arm,cs-dev-assoc = <&etm0>; - - status = "disabled"; - }; - - /* CTI - CPU-1 */ - cti13: cti@859000 { - compatible = "arm,coresight-cti-v8-arch", "arm,coresight-cti", - "arm,primecell"; - reg = <0x00859000 0x1000>; - - clocks = <&rpmcc RPM_QDSS_CLK>; - clock-names = "apb_pclk"; - - cpu = <&CPU1>; - arm,cs-dev-assoc = <&etm1>; - - status = "disabled"; - }; - - /* CTI - CPU-2 */ - cti14: cti@85a000 { - compatible = "arm,coresight-cti-v8-arch", "arm,coresight-cti", - "arm,primecell"; - reg = <0x0085a000 0x1000>; - - clocks = <&rpmcc RPM_QDSS_CLK>; - clock-names = "apb_pclk"; - - cpu = <&CPU2>; - arm,cs-dev-assoc = <&etm2>; - - status = "disabled"; - }; - - /* CTI - CPU-3 */ - cti15: cti@85b000 { - compatible = "arm,coresight-cti-v8-arch", "arm,coresight-cti", - "arm,primecell"; - reg = <0x0085b000 0x1000>; - - clocks = <&rpmcc RPM_QDSS_CLK>; - clock-names = "apb_pclk"; - - cpu = <&CPU3>; - arm,cs-dev-assoc = <&etm3>; - - status = "disabled"; - }; - - etm0: etm@85c000 { - compatible = "arm,coresight-etm4x", "arm,primecell"; - reg = <0x0085c000 0x1000>; - - clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; - clock-names = "apb_pclk", "atclk"; - arm,coresight-loses-context-with-cpu; - - cpu = <&CPU0>; - - status = "disabled"; - - out-ports { - port { - etm0_out: endpoint { - remote-endpoint = <&funnel1_in0>; - }; - }; - }; - }; - - etm1: etm@85d000 { - compatible = "arm,coresight-etm4x", "arm,primecell"; - reg = <0x0085d000 0x1000>; - - clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; - clock-names = "apb_pclk", "atclk"; - arm,coresight-loses-context-with-cpu; - - cpu = <&CPU1>; - - status = "disabled"; - - out-ports { - port { - etm1_out: endpoint { - remote-endpoint = <&funnel1_in1>; - }; - }; - }; - }; - - etm2: etm@85e000 { - compatible = "arm,coresight-etm4x", "arm,primecell"; - reg = <0x0085e000 0x1000>; - - clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; - clock-names = "apb_pclk", "atclk"; - arm,coresight-loses-context-with-cpu; - - cpu = <&CPU2>; - - status = "disabled"; - - out-ports { - port { - etm2_out: endpoint { - remote-endpoint = <&funnel1_in2>; - }; - }; - }; - }; - - etm3: etm@85f000 { - compatible = "arm,coresight-etm4x", "arm,primecell"; - reg = <0x0085f000 0x1000>; - - clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; - clock-names = "apb_pclk", "atclk"; - arm,coresight-loses-context-with-cpu; - - cpu = <&CPU3>; - - status = "disabled"; - - out-ports { - port { - etm3_out: endpoint { - remote-endpoint = <&funnel1_in3>; - }; - }; - }; - }; - - tlmm: pinctrl@1000000 { - compatible = "qcom,msm8916-pinctrl"; - reg = <0x01000000 0x300000>; - interrupts = <GIC_SPI 208 IRQ_TYPE_LEVEL_HIGH>; - gpio-controller; - gpio-ranges = <&tlmm 0 0 122>; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - - blsp_i2c1_default: blsp-i2c1-default-state { - pins = "gpio2", "gpio3"; - function = "blsp_i2c1"; - drive-strength = <2>; - bias-disable; - }; - - blsp_i2c1_sleep: blsp-i2c1-sleep-state { - pins = "gpio2", "gpio3"; - function = "gpio"; - drive-strength = <2>; - bias-disable; - }; - - blsp_i2c2_default: blsp-i2c2-default-state { - pins = "gpio6", "gpio7"; - function = "blsp_i2c2"; - drive-strength = <2>; - bias-disable; - }; - - blsp_i2c2_sleep: blsp-i2c2-sleep-state { - pins = "gpio6", "gpio7"; - function = "gpio"; - drive-strength = <2>; - bias-disable; - }; - - blsp_i2c3_default: blsp-i2c3-default-state { - pins = "gpio10", "gpio11"; - function = "blsp_i2c3"; - drive-strength = <2>; - bias-disable; - }; - - blsp_i2c3_sleep: blsp-i2c3-sleep-state { - pins = "gpio10", "gpio11"; - function = "gpio"; - drive-strength = <2>; - bias-disable; - }; - - blsp_i2c4_default: blsp-i2c4-default-state { - pins = "gpio14", "gpio15"; - function = "blsp_i2c4"; - drive-strength = <2>; - bias-disable; - }; - - blsp_i2c4_sleep: blsp-i2c4-sleep-state { - pins = "gpio14", "gpio15"; - function = "gpio"; - drive-strength = <2>; - bias-disable; - }; - - blsp_i2c5_default: blsp-i2c5-default-state { - pins = "gpio18", "gpio19"; - function = "blsp_i2c5"; - drive-strength = <2>; - bias-disable; - }; - - blsp_i2c5_sleep: blsp-i2c5-sleep-state { - pins = "gpio18", "gpio19"; - function = "gpio"; - drive-strength = <2>; - bias-disable; - }; - - blsp_i2c6_default: blsp-i2c6-default-state { - pins = "gpio22", "gpio23"; - function = "blsp_i2c6"; - drive-strength = <2>; - bias-disable; - }; - - blsp_i2c6_sleep: blsp-i2c6-sleep-state { - pins = "gpio22", "gpio23"; - function = "gpio"; - drive-strength = <2>; - bias-disable; - }; - - blsp_spi1_default: blsp-spi1-default-state { - spi-pins { - pins = "gpio0", "gpio1", "gpio3"; - function = "blsp_spi1"; - drive-strength = <12>; - bias-disable; - }; - cs-pins { - pins = "gpio2"; - function = "gpio"; - drive-strength = <16>; - bias-disable; - output-high; - }; - }; - - blsp_spi1_sleep: blsp-spi1-sleep-state { - pins = "gpio0", "gpio1", "gpio2", "gpio3"; - function = "gpio"; - drive-strength = <2>; - bias-pull-down; - }; - - blsp_spi2_default: blsp-spi2-default-state { - spi-pins { - pins = "gpio4", "gpio5", "gpio7"; - function = "blsp_spi2"; - drive-strength = <12>; - bias-disable; - }; - cs-pins { - pins = "gpio6"; - function = "gpio"; - drive-strength = <16>; - bias-disable; - output-high; - }; - }; - - blsp_spi2_sleep: blsp-spi2-sleep-state { - pins = "gpio4", "gpio5", "gpio6", "gpio7"; - function = "gpio"; - drive-strength = <2>; - bias-pull-down; - }; - - blsp_spi3_default: blsp-spi3-default-state { - spi-pins { - pins = "gpio8", "gpio9", "gpio11"; - function = "blsp_spi3"; - drive-strength = <12>; - bias-disable; - }; - cs-pins { - pins = "gpio10"; - function = "gpio"; - drive-strength = <16>; - bias-disable; - output-high; - }; - }; - - blsp_spi3_sleep: blsp-spi3-sleep-state { - pins = "gpio8", "gpio9", "gpio10", "gpio11"; - function = "gpio"; - drive-strength = <2>; - bias-pull-down; - }; - - blsp_spi4_default: blsp-spi4-default-state { - spi-pins { - pins = "gpio12", "gpio13", "gpio15"; - function = "blsp_spi4"; - drive-strength = <12>; - bias-disable; - }; - cs-pins { - pins = "gpio14"; - function = "gpio"; - drive-strength = <16>; - bias-disable; - output-high; - }; - }; - - blsp_spi4_sleep: blsp-spi4-sleep-state { - pins = "gpio12", "gpio13", "gpio14", "gpio15"; - function = "gpio"; - drive-strength = <2>; - bias-pull-down; - }; - - blsp_spi5_default: blsp-spi5-default-state { - spi-pins { - pins = "gpio16", "gpio17", "gpio19"; - function = "blsp_spi5"; - drive-strength = <12>; - bias-disable; - }; - cs-pins { - pins = "gpio18"; - function = "gpio"; - drive-strength = <16>; - bias-disable; - output-high; - }; - }; - - blsp_spi5_sleep: blsp-spi5-sleep-state { - pins = "gpio16", "gpio17", "gpio18", "gpio19"; - function = "gpio"; - drive-strength = <2>; - bias-pull-down; - }; - - blsp_spi6_default: blsp-spi6-default-state { - spi-pins { - pins = "gpio20", "gpio21", "gpio23"; - function = "blsp_spi6"; - drive-strength = <12>; - bias-disable; - }; - cs-pins { - pins = "gpio22"; - function = "gpio"; - drive-strength = <16>; - bias-disable; - output-high; - }; - }; - - blsp_spi6_sleep: blsp-spi6-sleep-state { - pins = "gpio20", "gpio21", "gpio22", "gpio23"; - function = "gpio"; - drive-strength = <2>; - bias-pull-down; - }; - - blsp_uart1_default: blsp-uart1-default-state { - /* TX, RX, CTS_N, RTS_N */ - pins = "gpio0", "gpio1", "gpio2", "gpio3"; - function = "blsp_uart1"; - drive-strength = <16>; - bias-disable; - }; - - blsp_uart1_sleep: blsp-uart1-sleep-state { - pins = "gpio0", "gpio1", "gpio2", "gpio3"; - function = "gpio"; - drive-strength = <2>; - bias-pull-down; - }; - - blsp_uart2_default: blsp-uart2-default-state { - pins = "gpio4", "gpio5"; - function = "blsp_uart2"; - drive-strength = <16>; - bias-disable; - }; - - blsp_uart2_sleep: blsp-uart2-sleep-state { - pins = "gpio4", "gpio5"; - function = "gpio"; - drive-strength = <2>; - bias-pull-down; - }; - - camera_front_default: camera-front-default-state { - pwdn-pins { - pins = "gpio33"; - function = "gpio"; - drive-strength = <16>; - bias-disable; - }; - rst-pins { - pins = "gpio28"; - function = "gpio"; - drive-strength = <16>; - bias-disable; - }; - mclk1-pins { - pins = "gpio27"; - function = "cam_mclk1"; - drive-strength = <16>; - bias-disable; - }; - }; - - camera_rear_default: camera-rear-default-state { - pwdn-pins { - pins = "gpio34"; - function = "gpio"; - drive-strength = <16>; - bias-disable; - }; - rst-pins { - pins = "gpio35"; - function = "gpio"; - drive-strength = <16>; - bias-disable; - }; - mclk0-pins { - pins = "gpio26"; - function = "cam_mclk0"; - drive-strength = <16>; - bias-disable; - }; - }; - - cci0_default: cci0-default-state { - pins = "gpio29", "gpio30"; - function = "cci_i2c"; - drive-strength = <16>; - bias-disable; - }; - - cdc_dmic_default: cdc-dmic-default-state { - clk-pins { - pins = "gpio0"; - function = "dmic0_clk"; - drive-strength = <8>; - }; - data-pins { - pins = "gpio1"; - function = "dmic0_data"; - drive-strength = <8>; - }; - }; - - cdc_dmic_sleep: cdc-dmic-sleep-state { - clk-pins { - pins = "gpio0"; - function = "dmic0_clk"; - drive-strength = <2>; - bias-disable; - }; - data-pins { - pins = "gpio1"; - function = "dmic0_data"; - drive-strength = <2>; - bias-disable; - }; - }; - - cdc_pdm_default: cdc-pdm-default-state { - pins = "gpio63", "gpio64", "gpio65", "gpio66", - "gpio67", "gpio68"; - function = "cdc_pdm0"; - drive-strength = <8>; - bias-disable; - }; - - cdc_pdm_sleep: cdc-pdm-sleep-state { - pins = "gpio63", "gpio64", "gpio65", "gpio66", - "gpio67", "gpio68"; - function = "cdc_pdm0"; - drive-strength = <2>; - bias-pull-down; - }; - - pri_mi2s_default: mi2s-pri-default-state { - pins = "gpio113", "gpio114", "gpio115", "gpio116"; - function = "pri_mi2s"; - drive-strength = <8>; - bias-disable; - }; - - pri_mi2s_sleep: mi2s-pri-sleep-state { - pins = "gpio113", "gpio114", "gpio115", "gpio116"; - function = "pri_mi2s"; - drive-strength = <2>; - bias-disable; - }; - - pri_mi2s_mclk_default: mi2s-pri-mclk-default-state { - pins = "gpio116"; - function = "pri_mi2s"; - drive-strength = <8>; - bias-disable; - }; - - pri_mi2s_mclk_sleep: mi2s-pri-mclk-sleep-state { - pins = "gpio116"; - function = "pri_mi2s"; - drive-strength = <2>; - bias-disable; - }; - - pri_mi2s_ws_default: mi2s-pri-ws-default-state { - pins = "gpio110"; - function = "pri_mi2s_ws"; - drive-strength = <8>; - bias-disable; - }; - - pri_mi2s_ws_sleep: mi2s-pri-ws-sleep-state { - pins = "gpio110"; - function = "pri_mi2s_ws"; - drive-strength = <2>; - bias-disable; - }; - - sec_mi2s_default: mi2s-sec-default-state { - pins = "gpio112", "gpio117", "gpio118", "gpio119"; - function = "sec_mi2s"; - drive-strength = <8>; - bias-disable; - }; - - sec_mi2s_sleep: mi2s-sec-sleep-state { - pins = "gpio112", "gpio117", "gpio118", "gpio119"; - function = "sec_mi2s"; - drive-strength = <2>; - bias-disable; - }; - - sdc1_default: sdc1-default-state { - clk-pins { - pins = "sdc1_clk"; - bias-disable; - drive-strength = <16>; - }; - cmd-pins { - pins = "sdc1_cmd"; - bias-pull-up; - drive-strength = <10>; - }; - data-pins { - pins = "sdc1_data"; - bias-pull-up; - drive-strength = <10>; - }; - }; - - sdc1_sleep: sdc1-sleep-state { - clk-pins { - pins = "sdc1_clk"; - bias-disable; - drive-strength = <2>; - }; - cmd-pins { - pins = "sdc1_cmd"; - bias-pull-up; - drive-strength = <2>; - }; - data-pins { - pins = "sdc1_data"; - bias-pull-up; - drive-strength = <2>; - }; - }; - - sdc2_default: sdc2-default-state { - clk-pins { - pins = "sdc2_clk"; - bias-disable; - drive-strength = <16>; - }; - cmd-pins { - pins = "sdc2_cmd"; - bias-pull-up; - drive-strength = <10>; - }; - data-pins { - pins = "sdc2_data"; - bias-pull-up; - drive-strength = <10>; - }; - }; - - sdc2_sleep: sdc2-sleep-state { - clk-pins { - pins = "sdc2_clk"; - bias-disable; - drive-strength = <2>; - }; - cmd-pins { - pins = "sdc2_cmd"; - bias-pull-up; - drive-strength = <2>; - }; - data-pins { - pins = "sdc2_data"; - bias-pull-up; - drive-strength = <2>; - }; - }; - - wcss_wlan_default: wcss-wlan-default-state { - pins = "gpio40", "gpio41", "gpio42", "gpio43", "gpio44"; - function = "wcss_wlan"; - drive-strength = <6>; - bias-pull-up; - }; - }; - - gcc: clock-controller@1800000 { - compatible = "qcom,gcc-msm8916"; - #clock-cells = <1>; - #reset-cells = <1>; - #power-domain-cells = <1>; - reg = <0x01800000 0x80000>; - clocks = <&xo_board>, - <&sleep_clk>, - <&mdss_dsi0_phy 1>, - <&mdss_dsi0_phy 0>, - <0>, - <0>, - <0>; - clock-names = "xo", - "sleep_clk", - "dsi0pll", - "dsi0pllbyte", - "ext_mclk", - "ext_pri_i2s", - "ext_sec_i2s"; - }; - - tcsr_mutex: hwlock@1905000 { - compatible = "qcom,tcsr-mutex"; - reg = <0x01905000 0x20000>; - #hwlock-cells = <1>; - }; - - tcsr: syscon@1937000 { - compatible = "qcom,tcsr-msm8916", "syscon"; - reg = <0x01937000 0x30000>; - }; - - mdss: display-subsystem@1a00000 { - status = "disabled"; - compatible = "qcom,mdss"; - reg = <0x01a00000 0x1000>, - <0x01ac8000 0x3000>; - reg-names = "mdss_phys", "vbif_phys"; - - power-domains = <&gcc MDSS_GDSC>; - - clocks = <&gcc GCC_MDSS_AHB_CLK>, - <&gcc GCC_MDSS_AXI_CLK>, - <&gcc GCC_MDSS_VSYNC_CLK>; - clock-names = "iface", - "bus", - "vsync"; - - interrupts = <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>; - - interrupt-controller; - #interrupt-cells = <1>; - - #address-cells = <1>; - #size-cells = <1>; - ranges; - - mdss_mdp: display-controller@1a01000 { - compatible = "qcom,msm8916-mdp5", "qcom,mdp5"; - reg = <0x01a01000 0x89000>; - reg-names = "mdp_phys"; - - interrupt-parent = <&mdss>; - interrupts = <0>; - - clocks = <&gcc GCC_MDSS_AHB_CLK>, - <&gcc GCC_MDSS_AXI_CLK>, - <&gcc GCC_MDSS_MDP_CLK>, - <&gcc GCC_MDSS_VSYNC_CLK>; - clock-names = "iface", - "bus", - "core", - "vsync"; - - iommus = <&apps_iommu 4>; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - mdss_mdp_intf1_out: endpoint { - remote-endpoint = <&mdss_dsi0_in>; - }; - }; - }; - }; - - mdss_dsi0: dsi@1a98000 { - compatible = "qcom,msm8916-dsi-ctrl", - "qcom,mdss-dsi-ctrl"; - reg = <0x01a98000 0x25c>; - reg-names = "dsi_ctrl"; - - interrupt-parent = <&mdss>; - interrupts = <4>; - - assigned-clocks = <&gcc BYTE0_CLK_SRC>, - <&gcc PCLK0_CLK_SRC>; - assigned-clock-parents = <&mdss_dsi0_phy 0>, - <&mdss_dsi0_phy 1>; - - clocks = <&gcc GCC_MDSS_MDP_CLK>, - <&gcc GCC_MDSS_AHB_CLK>, - <&gcc GCC_MDSS_AXI_CLK>, - <&gcc GCC_MDSS_BYTE0_CLK>, - <&gcc GCC_MDSS_PCLK0_CLK>, - <&gcc GCC_MDSS_ESC0_CLK>; - clock-names = "mdp_core", - "iface", - "bus", - "byte", - "pixel", - "core"; - phys = <&mdss_dsi0_phy>; - - #address-cells = <1>; - #size-cells = <0>; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - mdss_dsi0_in: endpoint { - remote-endpoint = <&mdss_mdp_intf1_out>; - }; - }; - - port@1 { - reg = <1>; - mdss_dsi0_out: endpoint { - }; - }; - }; - }; - - mdss_dsi0_phy: phy@1a98300 { - compatible = "qcom,dsi-phy-28nm-lp"; - reg = <0x01a98300 0xd4>, - <0x01a98500 0x280>, - <0x01a98780 0x30>; - reg-names = "dsi_pll", - "dsi_phy", - "dsi_phy_regulator"; - - #clock-cells = <1>; - #phy-cells = <0>; - - clocks = <&gcc GCC_MDSS_AHB_CLK>, - <&xo_board>; - clock-names = "iface", "ref"; - }; - }; - - camss: camss@1b0ac00 { - compatible = "qcom,msm8916-camss"; - reg = <0x01b0ac00 0x200>, - <0x01b00030 0x4>, - <0x01b0b000 0x200>, - <0x01b00038 0x4>, - <0x01b08000 0x100>, - <0x01b08400 0x100>, - <0x01b0a000 0x500>, - <0x01b00020 0x10>, - <0x01b10000 0x1000>; - reg-names = "csiphy0", - "csiphy0_clk_mux", - "csiphy1", - "csiphy1_clk_mux", - "csid0", - "csid1", - "ispif", - "csi_clk_mux", - "vfe0"; - interrupts = <GIC_SPI 78 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 79 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 51 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 52 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 55 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 57 IRQ_TYPE_EDGE_RISING>; - interrupt-names = "csiphy0", - "csiphy1", - "csid0", - "csid1", - "ispif", - "vfe0"; - power-domains = <&gcc VFE_GDSC>; - clocks = <&gcc GCC_CAMSS_TOP_AHB_CLK>, - <&gcc GCC_CAMSS_ISPIF_AHB_CLK>, - <&gcc GCC_CAMSS_CSI0PHYTIMER_CLK>, - <&gcc GCC_CAMSS_CSI1PHYTIMER_CLK>, - <&gcc GCC_CAMSS_CSI0_AHB_CLK>, - <&gcc GCC_CAMSS_CSI0_CLK>, - <&gcc GCC_CAMSS_CSI0PHY_CLK>, - <&gcc GCC_CAMSS_CSI0PIX_CLK>, - <&gcc GCC_CAMSS_CSI0RDI_CLK>, - <&gcc GCC_CAMSS_CSI1_AHB_CLK>, - <&gcc GCC_CAMSS_CSI1_CLK>, - <&gcc GCC_CAMSS_CSI1PHY_CLK>, - <&gcc GCC_CAMSS_CSI1PIX_CLK>, - <&gcc GCC_CAMSS_CSI1RDI_CLK>, - <&gcc GCC_CAMSS_AHB_CLK>, - <&gcc GCC_CAMSS_VFE0_CLK>, - <&gcc GCC_CAMSS_CSI_VFE0_CLK>, - <&gcc GCC_CAMSS_VFE_AHB_CLK>, - <&gcc GCC_CAMSS_VFE_AXI_CLK>; - clock-names = "top_ahb", - "ispif_ahb", - "csiphy0_timer", - "csiphy1_timer", - "csi0_ahb", - "csi0", - "csi0_phy", - "csi0_pix", - "csi0_rdi", - "csi1_ahb", - "csi1", - "csi1_phy", - "csi1_pix", - "csi1_rdi", - "ahb", - "vfe0", - "csi_vfe0", - "vfe_ahb", - "vfe_axi"; - iommus = <&apps_iommu 3>; - status = "disabled"; - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - }; - - port@1 { - reg = <1>; - }; - }; - }; - - cci: cci@1b0c000 { - compatible = "qcom,msm8916-cci", "qcom,msm8226-cci"; - #address-cells = <1>; - #size-cells = <0>; - reg = <0x01b0c000 0x1000>; - interrupts = <GIC_SPI 50 IRQ_TYPE_EDGE_RISING>; - clocks = <&gcc GCC_CAMSS_TOP_AHB_CLK>, - <&gcc GCC_CAMSS_CCI_AHB_CLK>, - <&gcc GCC_CAMSS_CCI_CLK>, - <&gcc GCC_CAMSS_AHB_CLK>; - clock-names = "camss_top_ahb", "cci_ahb", - "cci", "camss_ahb"; - assigned-clocks = <&gcc GCC_CAMSS_CCI_AHB_CLK>, - <&gcc GCC_CAMSS_CCI_CLK>; - assigned-clock-rates = <80000000>, <19200000>; - pinctrl-names = "default"; - pinctrl-0 = <&cci0_default>; - status = "disabled"; - - cci_i2c0: i2c-bus@0 { - reg = <0>; - clock-frequency = <400000>; - #address-cells = <1>; - #size-cells = <0>; - }; - }; - - gpu: gpu@1c00000 { - compatible = "qcom,adreno-306.0", "qcom,adreno"; - reg = <0x01c00000 0x20000>; - reg-names = "kgsl_3d0_reg_memory"; - interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "kgsl_3d0_irq"; - clock-names = - "core", - "iface", - "mem", - "mem_iface", - "alt_mem_iface", - "gfx3d"; - clocks = - <&gcc GCC_OXILI_GFX3D_CLK>, - <&gcc GCC_OXILI_AHB_CLK>, - <&gcc GCC_OXILI_GMEM_CLK>, - <&gcc GCC_BIMC_GFX_CLK>, - <&gcc GCC_BIMC_GPU_CLK>, - <&gcc GFX3D_CLK_SRC>; - power-domains = <&gcc OXILI_GDSC>; - operating-points-v2 = <&gpu_opp_table>; - iommus = <&gpu_iommu 1>, <&gpu_iommu 2>; - status = "disabled"; - - gpu_opp_table: opp-table { - compatible = "operating-points-v2"; - - opp-400000000 { - opp-hz = /bits/ 64 <400000000>; - }; - opp-19200000 { - opp-hz = /bits/ 64 <19200000>; - }; - }; - }; - - venus: video-codec@1d00000 { - compatible = "qcom,msm8916-venus"; - reg = <0x01d00000 0xff000>; - interrupts = <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&gcc VENUS_GDSC>; - clocks = <&gcc GCC_VENUS0_VCODEC0_CLK>, - <&gcc GCC_VENUS0_AHB_CLK>, - <&gcc GCC_VENUS0_AXI_CLK>; - clock-names = "core", "iface", "bus"; - iommus = <&apps_iommu 5>; - memory-region = <&venus_mem>; - status = "disabled"; - - video-decoder { - compatible = "venus-decoder"; - }; - - video-encoder { - compatible = "venus-encoder"; - }; - }; - - apps_iommu: iommu@1ef0000 { - #address-cells = <1>; - #size-cells = <1>; - #iommu-cells = <1>; - compatible = "qcom,msm8916-iommu", "qcom,msm-iommu-v1"; - ranges = <0 0x01e20000 0x20000>; - reg = <0x01ef0000 0x3000>; - clocks = <&gcc GCC_SMMU_CFG_CLK>, - <&gcc GCC_APSS_TCU_CLK>; - clock-names = "iface", "bus"; - qcom,iommu-secure-id = <17>; - - /* VFE */ - iommu-ctx@3000 { - compatible = "qcom,msm-iommu-v1-sec"; - reg = <0x3000 0x1000>; - interrupts = <GIC_SPI 70 IRQ_TYPE_LEVEL_HIGH>; - }; - - /* MDP_0 */ - iommu-ctx@4000 { - compatible = "qcom,msm-iommu-v1-ns"; - reg = <0x4000 0x1000>; - interrupts = <GIC_SPI 70 IRQ_TYPE_LEVEL_HIGH>; - }; - - /* VENUS_NS */ - iommu-ctx@5000 { - compatible = "qcom,msm-iommu-v1-sec"; - reg = <0x5000 0x1000>; - interrupts = <GIC_SPI 70 IRQ_TYPE_LEVEL_HIGH>; - }; - }; - - gpu_iommu: iommu@1f08000 { - #address-cells = <1>; - #size-cells = <1>; - #iommu-cells = <1>; - compatible = "qcom,msm8916-iommu", "qcom,msm-iommu-v1"; - ranges = <0 0x01f08000 0x10000>; - clocks = <&gcc GCC_SMMU_CFG_CLK>, - <&gcc GCC_GFX_TCU_CLK>; - clock-names = "iface", "bus"; - qcom,iommu-secure-id = <18>; - - /* GFX3D_USER */ - iommu-ctx@1000 { - compatible = "qcom,msm-iommu-v1-ns"; - reg = <0x1000 0x1000>; - interrupts = <GIC_SPI 241 IRQ_TYPE_LEVEL_HIGH>; - }; - - /* GFX3D_PRIV */ - iommu-ctx@2000 { - compatible = "qcom,msm-iommu-v1-ns"; - reg = <0x2000 0x1000>; - interrupts = <GIC_SPI 242 IRQ_TYPE_LEVEL_HIGH>; - }; - }; - - spmi_bus: spmi@200f000 { - compatible = "qcom,spmi-pmic-arb"; - reg = <0x0200f000 0x001000>, - <0x02400000 0x400000>, - <0x02c00000 0x400000>, - <0x03800000 0x200000>, - <0x0200a000 0x002100>; - reg-names = "core", "chnls", "obsrvr", "intr", "cnfg"; - interrupt-names = "periph_irq"; - interrupts = <GIC_SPI 190 IRQ_TYPE_LEVEL_HIGH>; - qcom,ee = <0>; - qcom,channel = <0>; - #address-cells = <2>; - #size-cells = <0>; - interrupt-controller; - #interrupt-cells = <4>; - }; - - bam_dmux_dma: dma-controller@4044000 { - compatible = "qcom,bam-v1.7.0"; - reg = <0x04044000 0x19000>; - interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>; - #dma-cells = <1>; - qcom,ee = <0>; - - num-channels = <6>; - qcom,num-ees = <1>; - qcom,powered-remotely; - - status = "disabled"; - }; - - mpss: remoteproc@4080000 { - compatible = "qcom,msm8916-mss-pil"; - reg = <0x04080000 0x100>, - <0x04020000 0x040>; - - reg-names = "qdsp6", "rmb"; - - interrupts-extended = <&intc GIC_SPI 24 IRQ_TYPE_EDGE_RISING>, - <&hexagon_smp2p_in 0 IRQ_TYPE_EDGE_RISING>, - <&hexagon_smp2p_in 1 IRQ_TYPE_EDGE_RISING>, - <&hexagon_smp2p_in 2 IRQ_TYPE_EDGE_RISING>, - <&hexagon_smp2p_in 3 IRQ_TYPE_EDGE_RISING>; - interrupt-names = "wdog", "fatal", "ready", - "handover", "stop-ack"; - - power-domains = <&rpmpd MSM8916_VDDCX>, - <&rpmpd MSM8916_VDDMX>; - power-domain-names = "cx", "mx"; - - clocks = <&gcc GCC_MSS_CFG_AHB_CLK>, - <&gcc GCC_MSS_Q6_BIMC_AXI_CLK>, - <&gcc GCC_BOOT_ROM_AHB_CLK>, - <&xo_board>; - clock-names = "iface", "bus", "mem", "xo"; - - qcom,smem-states = <&hexagon_smp2p_out 0>; - qcom,smem-state-names = "stop"; - - resets = <&scm 0>; - reset-names = "mss_restart"; - - qcom,halt-regs = <&tcsr 0x18000 0x19000 0x1a000>; - - status = "disabled"; - - mba { - memory-region = <&mba_mem>; - }; - - mpss { - memory-region = <&mpss_mem>; - }; - - bam_dmux: bam-dmux { - compatible = "qcom,bam-dmux"; - - interrupt-parent = <&hexagon_smsm>; - interrupts = <1 IRQ_TYPE_EDGE_BOTH>, <11 IRQ_TYPE_EDGE_BOTH>; - interrupt-names = "pc", "pc-ack"; - - qcom,smem-states = <&apps_smsm 1>, <&apps_smsm 11>; - qcom,smem-state-names = "pc", "pc-ack"; - - dmas = <&bam_dmux_dma 4>, <&bam_dmux_dma 5>; - dma-names = "tx", "rx"; - - status = "disabled"; - }; - - smd-edge { - interrupts = <GIC_SPI 25 IRQ_TYPE_EDGE_RISING>; - - qcom,smd-edge = <0>; - qcom,ipc = <&apcs 8 12>; - qcom,remote-pid = <1>; - - label = "hexagon"; - - fastrpc { - compatible = "qcom,fastrpc"; - qcom,smd-channels = "fastrpcsmd-apps-dsp"; - label = "adsp"; - qcom,non-secure-domain; - - #address-cells = <1>; - #size-cells = <0>; - - cb@1 { - compatible = "qcom,fastrpc-compute-cb"; - reg = <1>; - }; - }; - }; - }; - - sound: sound@7702000 { - status = "disabled"; - compatible = "qcom,apq8016-sbc-sndcard"; - reg = <0x07702000 0x4>, <0x07702004 0x4>; - reg-names = "mic-iomux", "spkr-iomux"; - }; - - lpass: audio-controller@7708000 { - status = "disabled"; - compatible = "qcom,apq8016-lpass-cpu"; - - /* - * Note: Unlike the name would suggest, the SEC_I2S_CLK - * is actually only used by Tertiary MI2S while - * Primary/Secondary MI2S both use the PRI_I2S_CLK. - */ - clocks = <&gcc GCC_ULTAUDIO_AHBFABRIC_IXFABRIC_CLK>, - <&gcc GCC_ULTAUDIO_LPAIF_PRI_I2S_CLK>, - <&gcc GCC_ULTAUDIO_LPAIF_PRI_I2S_CLK>, - <&gcc GCC_ULTAUDIO_LPAIF_SEC_I2S_CLK>, - <&gcc GCC_ULTAUDIO_LPAIF_AUX_I2S_CLK>, - <&gcc GCC_ULTAUDIO_PCNOC_MPORT_CLK>, - <&gcc GCC_ULTAUDIO_PCNOC_SWAY_CLK>; - - clock-names = "ahbix-clk", - "mi2s-bit-clk0", - "mi2s-bit-clk1", - "mi2s-bit-clk2", - "mi2s-bit-clk3", - "pcnoc-mport-clk", - "pcnoc-sway-clk"; - #sound-dai-cells = <1>; - - interrupts = <GIC_SPI 160 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "lpass-irq-lpaif"; - reg = <0x07708000 0x10000>; - reg-names = "lpass-lpaif"; - - #address-cells = <1>; - #size-cells = <0>; - }; - - lpass_codec: audio-codec@771c000 { - compatible = "qcom,msm8916-wcd-digital-codec"; - reg = <0x0771c000 0x400>; - clocks = <&gcc GCC_ULTAUDIO_AHBFABRIC_IXFABRIC_CLK>, - <&gcc GCC_CODEC_DIGCODEC_CLK>; - clock-names = "ahbix-clk", "mclk"; - #sound-dai-cells = <1>; - status = "disabled"; - }; - - sdhc_1: mmc@7824900 { - compatible = "qcom,msm8916-sdhci", "qcom,sdhci-msm-v4"; - reg = <0x07824900 0x11c>, <0x07824000 0x800>; - reg-names = "hc", "core"; - - interrupts = <GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 138 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "hc_irq", "pwr_irq"; - clocks = <&gcc GCC_SDCC1_AHB_CLK>, - <&gcc GCC_SDCC1_APPS_CLK>, - <&xo_board>; - clock-names = "iface", "core", "xo"; - pinctrl-0 = <&sdc1_default>; - pinctrl-1 = <&sdc1_sleep>; - pinctrl-names = "default", "sleep"; - mmc-ddr-1_8v; - bus-width = <8>; - non-removable; - status = "disabled"; - }; - - sdhc_2: mmc@7864900 { - compatible = "qcom,msm8916-sdhci", "qcom,sdhci-msm-v4"; - reg = <0x07864900 0x11c>, <0x07864000 0x800>; - reg-names = "hc", "core"; - - interrupts = <GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 221 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "hc_irq", "pwr_irq"; - clocks = <&gcc GCC_SDCC2_AHB_CLK>, - <&gcc GCC_SDCC2_APPS_CLK>, - <&xo_board>; - clock-names = "iface", "core", "xo"; - pinctrl-0 = <&sdc2_default>; - pinctrl-1 = <&sdc2_sleep>; - pinctrl-names = "default", "sleep"; - bus-width = <4>; - status = "disabled"; - }; - - blsp_dma: dma-controller@7884000 { - compatible = "qcom,bam-v1.7.0"; - reg = <0x07884000 0x23000>; - interrupts = <GIC_SPI 238 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP1_AHB_CLK>; - clock-names = "bam_clk"; - #dma-cells = <1>; - qcom,ee = <0>; - }; - - blsp_uart1: serial@78af000 { - compatible = "qcom,msm-uartdm-v1.4", "qcom,msm-uartdm"; - reg = <0x078af000 0x200>; - interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP1_UART1_APPS_CLK>, <&gcc GCC_BLSP1_AHB_CLK>; - clock-names = "core", "iface"; - dmas = <&blsp_dma 0>, <&blsp_dma 1>; - dma-names = "tx", "rx"; - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&blsp_uart1_default>; - pinctrl-1 = <&blsp_uart1_sleep>; - status = "disabled"; - }; - - blsp_uart2: serial@78b0000 { - compatible = "qcom,msm-uartdm-v1.4", "qcom,msm-uartdm"; - reg = <0x078b0000 0x200>; - interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP1_UART2_APPS_CLK>, <&gcc GCC_BLSP1_AHB_CLK>; - clock-names = "core", "iface"; - dmas = <&blsp_dma 2>, <&blsp_dma 3>; - dma-names = "tx", "rx"; - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&blsp_uart2_default>; - pinctrl-1 = <&blsp_uart2_sleep>; - status = "disabled"; - }; - - blsp_i2c1: i2c@78b5000 { - compatible = "qcom,i2c-qup-v2.2.1"; - reg = <0x078b5000 0x500>; - interrupts = <GIC_SPI 95 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP1_QUP1_I2C_APPS_CLK>, - <&gcc GCC_BLSP1_AHB_CLK>; - clock-names = "core", "iface"; - dmas = <&blsp_dma 4>, <&blsp_dma 5>; - dma-names = "tx", "rx"; - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&blsp_i2c1_default>; - pinctrl-1 = <&blsp_i2c1_sleep>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - blsp_spi1: spi@78b5000 { - compatible = "qcom,spi-qup-v2.2.1"; - reg = <0x078b5000 0x500>; - interrupts = <GIC_SPI 95 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP1_QUP1_SPI_APPS_CLK>, - <&gcc GCC_BLSP1_AHB_CLK>; - clock-names = "core", "iface"; - dmas = <&blsp_dma 4>, <&blsp_dma 5>; - dma-names = "tx", "rx"; - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&blsp_spi1_default>; - pinctrl-1 = <&blsp_spi1_sleep>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - blsp_i2c2: i2c@78b6000 { - compatible = "qcom,i2c-qup-v2.2.1"; - reg = <0x078b6000 0x500>; - interrupts = <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP1_QUP2_I2C_APPS_CLK>, - <&gcc GCC_BLSP1_AHB_CLK>; - clock-names = "core", "iface"; - dmas = <&blsp_dma 6>, <&blsp_dma 7>; - dma-names = "tx", "rx"; - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&blsp_i2c2_default>; - pinctrl-1 = <&blsp_i2c2_sleep>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - blsp_spi2: spi@78b6000 { - compatible = "qcom,spi-qup-v2.2.1"; - reg = <0x078b6000 0x500>; - interrupts = <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP1_QUP2_SPI_APPS_CLK>, - <&gcc GCC_BLSP1_AHB_CLK>; - clock-names = "core", "iface"; - dmas = <&blsp_dma 6>, <&blsp_dma 7>; - dma-names = "tx", "rx"; - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&blsp_spi2_default>; - pinctrl-1 = <&blsp_spi2_sleep>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - blsp_i2c3: i2c@78b7000 { - compatible = "qcom,i2c-qup-v2.2.1"; - reg = <0x078b7000 0x500>; - interrupts = <GIC_SPI 97 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP1_QUP3_I2C_APPS_CLK>, - <&gcc GCC_BLSP1_AHB_CLK>; - clock-names = "core", "iface"; - dmas = <&blsp_dma 8>, <&blsp_dma 9>; - dma-names = "tx", "rx"; - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&blsp_i2c3_default>; - pinctrl-1 = <&blsp_i2c3_sleep>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - blsp_spi3: spi@78b7000 { - compatible = "qcom,spi-qup-v2.2.1"; - reg = <0x078b7000 0x500>; - interrupts = <GIC_SPI 97 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP1_QUP3_SPI_APPS_CLK>, - <&gcc GCC_BLSP1_AHB_CLK>; - clock-names = "core", "iface"; - dmas = <&blsp_dma 8>, <&blsp_dma 9>; - dma-names = "tx", "rx"; - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&blsp_spi3_default>; - pinctrl-1 = <&blsp_spi3_sleep>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - blsp_i2c4: i2c@78b8000 { - compatible = "qcom,i2c-qup-v2.2.1"; - reg = <0x078b8000 0x500>; - interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP1_QUP4_I2C_APPS_CLK>, - <&gcc GCC_BLSP1_AHB_CLK>; - clock-names = "core", "iface"; - dmas = <&blsp_dma 10>, <&blsp_dma 11>; - dma-names = "tx", "rx"; - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&blsp_i2c4_default>; - pinctrl-1 = <&blsp_i2c4_sleep>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - blsp_spi4: spi@78b8000 { - compatible = "qcom,spi-qup-v2.2.1"; - reg = <0x078b8000 0x500>; - interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP1_QUP4_SPI_APPS_CLK>, - <&gcc GCC_BLSP1_AHB_CLK>; - clock-names = "core", "iface"; - dmas = <&blsp_dma 10>, <&blsp_dma 11>; - dma-names = "tx", "rx"; - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&blsp_spi4_default>; - pinctrl-1 = <&blsp_spi4_sleep>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - blsp_i2c5: i2c@78b9000 { - compatible = "qcom,i2c-qup-v2.2.1"; - reg = <0x078b9000 0x500>; - interrupts = <GIC_SPI 99 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP1_QUP5_I2C_APPS_CLK>, - <&gcc GCC_BLSP1_AHB_CLK>; - clock-names = "core", "iface"; - dmas = <&blsp_dma 12>, <&blsp_dma 13>; - dma-names = "tx", "rx"; - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&blsp_i2c5_default>; - pinctrl-1 = <&blsp_i2c5_sleep>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - blsp_spi5: spi@78b9000 { - compatible = "qcom,spi-qup-v2.2.1"; - reg = <0x078b9000 0x500>; - interrupts = <GIC_SPI 99 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP1_QUP5_SPI_APPS_CLK>, - <&gcc GCC_BLSP1_AHB_CLK>; - clock-names = "core", "iface"; - dmas = <&blsp_dma 12>, <&blsp_dma 13>; - dma-names = "tx", "rx"; - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&blsp_spi5_default>; - pinctrl-1 = <&blsp_spi5_sleep>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - blsp_i2c6: i2c@78ba000 { - compatible = "qcom,i2c-qup-v2.2.1"; - reg = <0x078ba000 0x500>; - interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP1_QUP6_I2C_APPS_CLK>, - <&gcc GCC_BLSP1_AHB_CLK>; - clock-names = "core", "iface"; - dmas = <&blsp_dma 14>, <&blsp_dma 15>; - dma-names = "tx", "rx"; - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&blsp_i2c6_default>; - pinctrl-1 = <&blsp_i2c6_sleep>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - blsp_spi6: spi@78ba000 { - compatible = "qcom,spi-qup-v2.2.1"; - reg = <0x078ba000 0x500>; - interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP1_QUP6_SPI_APPS_CLK>, - <&gcc GCC_BLSP1_AHB_CLK>; - clock-names = "core", "iface"; - dmas = <&blsp_dma 14>, <&blsp_dma 15>; - dma-names = "tx", "rx"; - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&blsp_spi6_default>; - pinctrl-1 = <&blsp_spi6_sleep>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - usb: usb@78d9000 { - compatible = "qcom,ci-hdrc"; - reg = <0x078d9000 0x200>, - <0x078d9200 0x200>; - interrupts = <GIC_SPI 134 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 140 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_USB_HS_AHB_CLK>, - <&gcc GCC_USB_HS_SYSTEM_CLK>; - clock-names = "iface", "core"; - assigned-clocks = <&gcc GCC_USB_HS_SYSTEM_CLK>; - assigned-clock-rates = <80000000>; - resets = <&gcc GCC_USB_HS_BCR>; - reset-names = "core"; - phy_type = "ulpi"; - dr_mode = "otg"; - hnp-disable; - srp-disable; - adp-disable; - ahb-burst-config = <0>; - phy-names = "usb-phy"; - phys = <&usb_hs_phy>; - status = "disabled"; - #reset-cells = <1>; - - ulpi { - usb_hs_phy: phy { - compatible = "qcom,usb-hs-phy-msm8916", - "qcom,usb-hs-phy"; - #phy-cells = <0>; - clocks = <&xo_board>, <&gcc GCC_USB2A_PHY_SLEEP_CLK>; - clock-names = "ref", "sleep"; - resets = <&gcc GCC_USB2A_PHY_BCR>, <&usb 0>; - reset-names = "phy", "por"; - qcom,init-seq = /bits/ 8 <0x0 0x44>, - <0x1 0x6b>, - <0x2 0x24>, - <0x3 0x13>; - }; - }; - }; - - wcnss: remoteproc@a204000 { - compatible = "qcom,pronto-v2-pil", "qcom,pronto"; - reg = <0x0a204000 0x2000>, <0x0a202000 0x1000>, <0x0a21b000 0x3000>; - reg-names = "ccu", "dxe", "pmu"; - - memory-region = <&wcnss_mem>; - - interrupts-extended = <&intc GIC_SPI 149 IRQ_TYPE_EDGE_RISING>, - <&wcnss_smp2p_in 0 IRQ_TYPE_EDGE_RISING>, - <&wcnss_smp2p_in 1 IRQ_TYPE_EDGE_RISING>, - <&wcnss_smp2p_in 2 IRQ_TYPE_EDGE_RISING>, - <&wcnss_smp2p_in 3 IRQ_TYPE_EDGE_RISING>; - interrupt-names = "wdog", "fatal", "ready", "handover", "stop-ack"; - - power-domains = <&rpmpd MSM8916_VDDCX>, - <&rpmpd MSM8916_VDDMX>; - power-domain-names = "cx", "mx"; - - qcom,smem-states = <&wcnss_smp2p_out 0>; - qcom,smem-state-names = "stop"; - - pinctrl-names = "default"; - pinctrl-0 = <&wcss_wlan_default>; - - status = "disabled"; - - wcnss_iris: iris { - /* Separate chip, compatible is board-specific */ - clocks = <&rpmcc RPM_SMD_RF_CLK2>; - clock-names = "xo"; - }; - - smd-edge { - interrupts = <GIC_SPI 142 IRQ_TYPE_EDGE_RISING>; - - qcom,ipc = <&apcs 8 17>; - qcom,smd-edge = <6>; - qcom,remote-pid = <4>; - - label = "pronto"; - - wcnss_ctrl: wcnss { - compatible = "qcom,wcnss"; - qcom,smd-channels = "WCNSS_CTRL"; - - qcom,mmio = <&wcnss>; - - wcnss_bt: bluetooth { - compatible = "qcom,wcnss-bt"; - }; - - wcnss_wifi: wifi { - compatible = "qcom,wcnss-wlan"; - - interrupts = <GIC_SPI 145 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 146 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "tx", "rx"; - - qcom,smem-states = <&apps_smsm 10>, <&apps_smsm 9>; - qcom,smem-state-names = "tx-enable", "tx-rings-empty"; - }; - }; - }; - }; - - intc: interrupt-controller@b000000 { - compatible = "qcom,msm-qgic2"; - interrupt-controller; - #interrupt-cells = <3>; - reg = <0x0b000000 0x1000>, <0x0b002000 0x2000>, - <0x0b001000 0x1000>, <0x0b004000 0x2000>; - interrupts = <GIC_PPI 0 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; - }; - - apcs: mailbox@b011000 { - compatible = "qcom,msm8916-apcs-kpss-global", "syscon"; - reg = <0x0b011000 0x1000>; - #mbox-cells = <1>; - clocks = <&a53pll>, <&gcc GPLL0_VOTE>; - clock-names = "pll", "aux"; - #clock-cells = <0>; - }; - - a53pll: clock@b016000 { - compatible = "qcom,msm8916-a53pll"; - reg = <0x0b016000 0x40>; - #clock-cells = <0>; - clocks = <&xo_board>; - clock-names = "xo"; - }; - - timer@b020000 { - #address-cells = <1>; - #size-cells = <1>; - ranges; - compatible = "arm,armv7-timer-mem"; - reg = <0x0b020000 0x1000>; - clock-frequency = <19200000>; - - frame@b021000 { - frame-number = <0>; - interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; - reg = <0x0b021000 0x1000>, - <0x0b022000 0x1000>; - }; - - frame@b023000 { - frame-number = <1>; - interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; - reg = <0x0b023000 0x1000>; - status = "disabled"; - }; - - frame@b024000 { - frame-number = <2>; - interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; - reg = <0x0b024000 0x1000>; - status = "disabled"; - }; - - frame@b025000 { - frame-number = <3>; - interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; - reg = <0x0b025000 0x1000>; - status = "disabled"; - }; - - frame@b026000 { - frame-number = <4>; - interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>; - reg = <0x0b026000 0x1000>; - status = "disabled"; - }; - - frame@b027000 { - frame-number = <5>; - interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>; - reg = <0x0b027000 0x1000>; - status = "disabled"; - }; - - frame@b028000 { - frame-number = <6>; - interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; - reg = <0x0b028000 0x1000>; - status = "disabled"; - }; - }; - - cpu0_acc: power-manager@b088000 { - compatible = "qcom,msm8916-acc"; - reg = <0x0b088000 0x1000>; - status = "reserved"; /* Controlled by PSCI firmware */ - }; - - cpu0_saw: power-manager@b089000 { - compatible = "qcom,msm8916-saw2-v3.0-cpu", "qcom,saw2"; - reg = <0x0b089000 0x1000>; - status = "reserved"; /* Controlled by PSCI firmware */ - }; - - cpu1_acc: power-manager@b098000 { - compatible = "qcom,msm8916-acc"; - reg = <0x0b098000 0x1000>; - status = "reserved"; /* Controlled by PSCI firmware */ - }; - - cpu1_saw: power-manager@b099000 { - compatible = "qcom,msm8916-saw2-v3.0-cpu", "qcom,saw2"; - reg = <0x0b099000 0x1000>; - status = "reserved"; /* Controlled by PSCI firmware */ - }; - - cpu2_acc: power-manager@b0a8000 { - compatible = "qcom,msm8916-acc"; - reg = <0x0b0a8000 0x1000>; - status = "reserved"; /* Controlled by PSCI firmware */ - }; - - cpu2_saw: power-manager@b0a9000 { - compatible = "qcom,msm8916-saw2-v3.0-cpu", "qcom,saw2"; - reg = <0x0b0a9000 0x1000>; - status = "reserved"; /* Controlled by PSCI firmware */ - }; - - cpu3_acc: power-manager@b0b8000 { - compatible = "qcom,msm8916-acc"; - reg = <0x0b0b8000 0x1000>; - status = "reserved"; /* Controlled by PSCI firmware */ - }; - - cpu3_saw: power-manager@b0b9000 { - compatible = "qcom,msm8916-saw2-v3.0-cpu", "qcom,saw2"; - reg = <0x0b0b9000 0x1000>; - status = "reserved"; /* Controlled by PSCI firmware */ - }; - }; - - thermal-zones { - cpu0-1-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens 5>; - - trips { - cpu0_1_alert0: trip-point0 { - temperature = <75000>; - hysteresis = <2000>; - type = "passive"; - }; - cpu0_1_crit: cpu-crit { - temperature = <110000>; - hysteresis = <2000>; - type = "critical"; - }; - }; - - cooling-maps { - map0 { - trip = <&cpu0_1_alert0>; - cooling-device = <&CPU0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, - <&CPU1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, - <&CPU2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, - <&CPU3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; - }; - }; - }; - - cpu2-3-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens 4>; - - trips { - cpu2_3_alert0: trip-point0 { - temperature = <75000>; - hysteresis = <2000>; - type = "passive"; - }; - cpu2_3_crit: cpu-crit { - temperature = <110000>; - hysteresis = <2000>; - type = "critical"; - }; - }; - - cooling-maps { - map0 { - trip = <&cpu2_3_alert0>; - cooling-device = <&CPU0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, - <&CPU1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, - <&CPU2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, - <&CPU3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; - }; - }; - }; - - gpu-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens 2>; - - trips { - gpu_alert0: trip-point0 { - temperature = <75000>; - hysteresis = <2000>; - type = "passive"; - }; - gpu_crit: gpu-crit { - temperature = <95000>; - hysteresis = <2000>; - type = "critical"; - }; - }; - }; - - camera-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens 1>; - - trips { - cam_alert0: trip-point0 { - temperature = <75000>; - hysteresis = <2000>; - type = "hot"; - }; - }; - }; - - modem-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens 0>; - - trips { - modem_alert0: trip-point0 { - temperature = <85000>; - hysteresis = <2000>; - type = "hot"; - }; - }; - }; - }; - - timer { - compatible = "arm,armv8-timer"; - interrupts = <GIC_PPI 2 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 3 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 4 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 1 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>; - }; -}; diff --git a/arch/arm/dts/msm8996.dtsi b/arch/arm/dts/msm8996.dtsi deleted file mode 100644 index 6ba9da9e6a8b..000000000000 --- a/arch/arm/dts/msm8996.dtsi +++ /dev/null @@ -1,3884 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-only -/* - * Copyright (c) 2014-2015, The Linux Foundation. All rights reserved. - */ - -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/clock/qcom,gcc-msm8996.h> -#include <dt-bindings/clock/qcom,mmcc-msm8996.h> -#include <dt-bindings/clock/qcom,rpmcc.h> -#include <dt-bindings/interconnect/qcom,msm8996.h> -#include <dt-bindings/interconnect/qcom,msm8996-cbf.h> -#include <dt-bindings/firmware/qcom,scm.h> -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/power/qcom-rpmpd.h> -#include <dt-bindings/soc/qcom,apr.h> -#include <dt-bindings/thermal/thermal.h> - -/ { - interrupt-parent = <&intc>; - - #address-cells = <2>; - #size-cells = <2>; - - chosen { }; - - clocks { - xo_board: xo-board { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <19200000>; - clock-output-names = "xo_board"; - }; - - sleep_clk: sleep-clk { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <32764>; - clock-output-names = "sleep_clk"; - }; - }; - - cpus { - #address-cells = <2>; - #size-cells = <0>; - - CPU0: cpu@0 { - device_type = "cpu"; - compatible = "qcom,kryo"; - reg = <0x0 0x0>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_0>; - capacity-dmips-mhz = <1024>; - clocks = <&kryocc 0>; - interconnects = <&cbf MASTER_CBF_M4M &cbf SLAVE_CBF_M4M>; - operating-points-v2 = <&cluster0_opp>; - #cooling-cells = <2>; - next-level-cache = <&L2_0>; - L2_0: l2-cache { - compatible = "cache"; - cache-level = <2>; - cache-unified; - }; - }; - - CPU1: cpu@1 { - device_type = "cpu"; - compatible = "qcom,kryo"; - reg = <0x0 0x1>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_0>; - capacity-dmips-mhz = <1024>; - clocks = <&kryocc 0>; - interconnects = <&cbf MASTER_CBF_M4M &cbf SLAVE_CBF_M4M>; - operating-points-v2 = <&cluster0_opp>; - #cooling-cells = <2>; - next-level-cache = <&L2_0>; - }; - - CPU2: cpu@100 { - device_type = "cpu"; - compatible = "qcom,kryo"; - reg = <0x0 0x100>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_0>; - capacity-dmips-mhz = <1024>; - clocks = <&kryocc 1>; - interconnects = <&cbf MASTER_CBF_M4M &cbf SLAVE_CBF_M4M>; - operating-points-v2 = <&cluster1_opp>; - #cooling-cells = <2>; - next-level-cache = <&L2_1>; - L2_1: l2-cache { - compatible = "cache"; - cache-level = <2>; - cache-unified; - }; - }; - - CPU3: cpu@101 { - device_type = "cpu"; - compatible = "qcom,kryo"; - reg = <0x0 0x101>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_0>; - capacity-dmips-mhz = <1024>; - clocks = <&kryocc 1>; - interconnects = <&cbf MASTER_CBF_M4M &cbf SLAVE_CBF_M4M>; - operating-points-v2 = <&cluster1_opp>; - #cooling-cells = <2>; - next-level-cache = <&L2_1>; - }; - - cpu-map { - cluster0 { - core0 { - cpu = <&CPU0>; - }; - - core1 { - cpu = <&CPU1>; - }; - }; - - cluster1 { - core0 { - cpu = <&CPU2>; - }; - - core1 { - cpu = <&CPU3>; - }; - }; - }; - - idle-states { - entry-method = "psci"; - - CPU_SLEEP_0: cpu-sleep-0 { - compatible = "arm,idle-state"; - idle-state-name = "standalone-power-collapse"; - arm,psci-suspend-param = <0x00000004>; - entry-latency-us = <130>; - exit-latency-us = <80>; - min-residency-us = <300>; - }; - }; - }; - - cluster0_opp: opp-table-cluster0 { - compatible = "operating-points-v2-kryo-cpu"; - nvmem-cells = <&speedbin_efuse>; - opp-shared; - - /* Nominal fmax for now */ - opp-307200000 { - opp-hz = /bits/ 64 <307200000>; - opp-supported-hw = <0xf>; - clock-latency-ns = <200000>; - opp-peak-kBps = <307200>; - }; - opp-422400000 { - opp-hz = /bits/ 64 <422400000>; - opp-supported-hw = <0xf>; - clock-latency-ns = <200000>; - opp-peak-kBps = <307200>; - }; - opp-480000000 { - opp-hz = /bits/ 64 <480000000>; - opp-supported-hw = <0xf>; - clock-latency-ns = <200000>; - opp-peak-kBps = <307200>; - }; - opp-556800000 { - opp-hz = /bits/ 64 <556800000>; - opp-supported-hw = <0xf>; - clock-latency-ns = <200000>; - opp-peak-kBps = <307200>; - }; - opp-652800000 { - opp-hz = /bits/ 64 <652800000>; - opp-supported-hw = <0xf>; - clock-latency-ns = <200000>; - opp-peak-kBps = <384000>; - }; - opp-729600000 { - opp-hz = /bits/ 64 <729600000>; - opp-supported-hw = <0xf>; - clock-latency-ns = <200000>; - opp-peak-kBps = <460800>; - }; - opp-844800000 { - opp-hz = /bits/ 64 <844800000>; - opp-supported-hw = <0xf>; - clock-latency-ns = <200000>; - opp-peak-kBps = <537600>; - }; - opp-960000000 { - opp-hz = /bits/ 64 <960000000>; - opp-supported-hw = <0xf>; - clock-latency-ns = <200000>; - opp-peak-kBps = <672000>; - }; - opp-1036800000 { - opp-hz = /bits/ 64 <1036800000>; - opp-supported-hw = <0xf>; - clock-latency-ns = <200000>; - opp-peak-kBps = <672000>; - }; - opp-1113600000 { - opp-hz = /bits/ 64 <1113600000>; - opp-supported-hw = <0xf>; - clock-latency-ns = <200000>; - opp-peak-kBps = <825600>; - }; - opp-1190400000 { - opp-hz = /bits/ 64 <1190400000>; - opp-supported-hw = <0xf>; - clock-latency-ns = <200000>; - opp-peak-kBps = <825600>; - }; - opp-1228800000 { - opp-hz = /bits/ 64 <1228800000>; - opp-supported-hw = <0xf>; - clock-latency-ns = <200000>; - opp-peak-kBps = <902400>; - }; - opp-1324800000 { - opp-hz = /bits/ 64 <1324800000>; - opp-supported-hw = <0xd>; - clock-latency-ns = <200000>; - opp-peak-kBps = <1056000>; - }; - opp-1363200000 { - opp-hz = /bits/ 64 <1363200000>; - opp-supported-hw = <0x2>; - clock-latency-ns = <200000>; - opp-peak-kBps = <1132800>; - }; - opp-1401600000 { - opp-hz = /bits/ 64 <1401600000>; - opp-supported-hw = <0xd>; - clock-latency-ns = <200000>; - opp-peak-kBps = <1132800>; - }; - opp-1478400000 { - opp-hz = /bits/ 64 <1478400000>; - opp-supported-hw = <0x9>; - clock-latency-ns = <200000>; - opp-peak-kBps = <1190400>; - }; - opp-1497600000 { - opp-hz = /bits/ 64 <1497600000>; - opp-supported-hw = <0x04>; - clock-latency-ns = <200000>; - opp-peak-kBps = <1305600>; - }; - opp-1593600000 { - opp-hz = /bits/ 64 <1593600000>; - opp-supported-hw = <0x9>; - clock-latency-ns = <200000>; - opp-peak-kBps = <1382400>; - }; - }; - - cluster1_opp: opp-table-cluster1 { - compatible = "operating-points-v2-kryo-cpu"; - nvmem-cells = <&speedbin_efuse>; - opp-shared; - - /* Nominal fmax for now */ - opp-307200000 { - opp-hz = /bits/ 64 <307200000>; - opp-supported-hw = <0xf>; - clock-latency-ns = <200000>; - opp-peak-kBps = <307200>; - }; - opp-403200000 { - opp-hz = /bits/ 64 <403200000>; - opp-supported-hw = <0xf>; - clock-latency-ns = <200000>; - opp-peak-kBps = <307200>; - }; - opp-480000000 { - opp-hz = /bits/ 64 <480000000>; - opp-supported-hw = <0xf>; - clock-latency-ns = <200000>; - opp-peak-kBps = <307200>; - }; - opp-556800000 { - opp-hz = /bits/ 64 <556800000>; - opp-supported-hw = <0xf>; - clock-latency-ns = <200000>; - opp-peak-kBps = <307200>; - }; - opp-652800000 { - opp-hz = /bits/ 64 <652800000>; - opp-supported-hw = <0xf>; - clock-latency-ns = <200000>; - opp-peak-kBps = <307200>; - }; - opp-729600000 { - opp-hz = /bits/ 64 <729600000>; - opp-supported-hw = <0xf>; - clock-latency-ns = <200000>; - opp-peak-kBps = <307200>; - }; - opp-806400000 { - opp-hz = /bits/ 64 <806400000>; - opp-supported-hw = <0xf>; - clock-latency-ns = <200000>; - opp-peak-kBps = <384000>; - }; - opp-883200000 { - opp-hz = /bits/ 64 <883200000>; - opp-supported-hw = <0xf>; - clock-latency-ns = <200000>; - opp-peak-kBps = <460800>; - }; - opp-940800000 { - opp-hz = /bits/ 64 <940800000>; - opp-supported-hw = <0xf>; - clock-latency-ns = <200000>; - opp-peak-kBps = <537600>; - }; - opp-1036800000 { - opp-hz = /bits/ 64 <1036800000>; - opp-supported-hw = <0xf>; - clock-latency-ns = <200000>; - opp-peak-kBps = <595200>; - }; - opp-1113600000 { - opp-hz = /bits/ 64 <1113600000>; - opp-supported-hw = <0xf>; - clock-latency-ns = <200000>; - opp-peak-kBps = <672000>; - }; - opp-1190400000 { - opp-hz = /bits/ 64 <1190400000>; - opp-supported-hw = <0xf>; - clock-latency-ns = <200000>; - opp-peak-kBps = <672000>; - }; - opp-1248000000 { - opp-hz = /bits/ 64 <1248000000>; - opp-supported-hw = <0xf>; - clock-latency-ns = <200000>; - opp-peak-kBps = <748800>; - }; - opp-1324800000 { - opp-hz = /bits/ 64 <1324800000>; - opp-supported-hw = <0xf>; - clock-latency-ns = <200000>; - opp-peak-kBps = <825600>; - }; - opp-1401600000 { - opp-hz = /bits/ 64 <1401600000>; - opp-supported-hw = <0xf>; - clock-latency-ns = <200000>; - opp-peak-kBps = <902400>; - }; - opp-1478400000 { - opp-hz = /bits/ 64 <1478400000>; - opp-supported-hw = <0xf>; - clock-latency-ns = <200000>; - opp-peak-kBps = <979200>; - }; - opp-1555200000 { - opp-hz = /bits/ 64 <1555200000>; - opp-supported-hw = <0xf>; - clock-latency-ns = <200000>; - opp-peak-kBps = <1056000>; - }; - opp-1632000000 { - opp-hz = /bits/ 64 <1632000000>; - opp-supported-hw = <0xf>; - clock-latency-ns = <200000>; - opp-peak-kBps = <1190400>; - }; - opp-1708800000 { - opp-hz = /bits/ 64 <1708800000>; - opp-supported-hw = <0xf>; - clock-latency-ns = <200000>; - opp-peak-kBps = <1228800>; - }; - opp-1785600000 { - opp-hz = /bits/ 64 <1785600000>; - opp-supported-hw = <0xf>; - clock-latency-ns = <200000>; - opp-peak-kBps = <1305600>; - }; - opp-1804800000 { - opp-hz = /bits/ 64 <1804800000>; - opp-supported-hw = <0xe>; - clock-latency-ns = <200000>; - opp-peak-kBps = <1305600>; - }; - opp-1824000000 { - opp-hz = /bits/ 64 <1824000000>; - opp-supported-hw = <0x1>; - clock-latency-ns = <200000>; - opp-peak-kBps = <1382400>; - }; - opp-1900800000 { - opp-hz = /bits/ 64 <1900800000>; - opp-supported-hw = <0x4>; - clock-latency-ns = <200000>; - opp-peak-kBps = <1305600>; - }; - opp-1920000000 { - opp-hz = /bits/ 64 <1920000000>; - opp-supported-hw = <0x1>; - clock-latency-ns = <200000>; - opp-peak-kBps = <1459200>; - }; - opp-1996800000 { - opp-hz = /bits/ 64 <1996800000>; - opp-supported-hw = <0x1>; - clock-latency-ns = <200000>; - opp-peak-kBps = <1593600>; - }; - opp-2073600000 { - opp-hz = /bits/ 64 <2073600000>; - opp-supported-hw = <0x1>; - clock-latency-ns = <200000>; - opp-peak-kBps = <1593600>; - }; - opp-2150400000 { - opp-hz = /bits/ 64 <2150400000>; - opp-supported-hw = <0x1>; - clock-latency-ns = <200000>; - opp-peak-kBps = <1593600>; - }; - }; - - firmware { - scm { - compatible = "qcom,scm-msm8996", "qcom,scm"; - qcom,dload-mode = <&tcsr_2 0x13000>; - }; - }; - - memory@80000000 { - device_type = "memory"; - /* We expect the bootloader to fill in the reg */ - reg = <0x0 0x80000000 0x0 0x0>; - }; - - psci { - compatible = "arm,psci-1.0"; - method = "smc"; - }; - - rpm: remoteproc { - compatible = "qcom,msm8996-rpm-proc", "qcom,rpm-proc"; - - glink-edge { - compatible = "qcom,glink-rpm"; - interrupts = <GIC_SPI 168 IRQ_TYPE_EDGE_RISING>; - qcom,rpm-msg-ram = <&rpm_msg_ram>; - mboxes = <&apcs_glb 0>; - - rpm_requests: rpm-requests { - compatible = "qcom,rpm-msm8996"; - qcom,glink-channels = "rpm_requests"; - - rpmcc: clock-controller { - compatible = "qcom,rpmcc-msm8996", "qcom,rpmcc"; - #clock-cells = <1>; - clocks = <&xo_board>; - clock-names = "xo"; - }; - - rpmpd: power-controller { - compatible = "qcom,msm8996-rpmpd"; - #power-domain-cells = <1>; - operating-points-v2 = <&rpmpd_opp_table>; - - rpmpd_opp_table: opp-table { - compatible = "operating-points-v2"; - - rpmpd_opp1: opp1 { - opp-level = <1>; - }; - - rpmpd_opp2: opp2 { - opp-level = <2>; - }; - - rpmpd_opp3: opp3 { - opp-level = <3>; - }; - - rpmpd_opp4: opp4 { - opp-level = <4>; - }; - - rpmpd_opp5: opp5 { - opp-level = <5>; - }; - - rpmpd_opp6: opp6 { - opp-level = <6>; - }; - }; - }; - }; - }; - }; - - reserved-memory { - #address-cells = <2>; - #size-cells = <2>; - ranges; - - hyp_mem: memory@85800000 { - reg = <0x0 0x85800000 0x0 0x600000>; - no-map; - }; - - xbl_mem: memory@85e00000 { - reg = <0x0 0x85e00000 0x0 0x200000>; - no-map; - }; - - smem_mem: smem-mem@86000000 { - reg = <0x0 0x86000000 0x0 0x200000>; - no-map; - }; - - tz_mem: memory@86200000 { - reg = <0x0 0x86200000 0x0 0x2600000>; - no-map; - }; - - rmtfs_mem: rmtfs { - compatible = "qcom,rmtfs-mem"; - - size = <0x0 0x200000>; - alloc-ranges = <0x0 0xa0000000 0x0 0x2000000>; - no-map; - - qcom,client-id = <1>; - qcom,vmid = <QCOM_SCM_VMID_MSS_MSA>; - }; - - mpss_mem: mpss@88800000 { - reg = <0x0 0x88800000 0x0 0x6200000>; - no-map; - }; - - adsp_mem: adsp@8ea00000 { - reg = <0x0 0x8ea00000 0x0 0x1b00000>; - no-map; - }; - - slpi_mem: slpi@90500000 { - reg = <0x0 0x90500000 0x0 0xa00000>; - no-map; - }; - - gpu_mem: gpu@90f00000 { - compatible = "shared-dma-pool"; - reg = <0x0 0x90f00000 0x0 0x100000>; - no-map; - }; - - venus_mem: venus@91000000 { - reg = <0x0 0x91000000 0x0 0x500000>; - no-map; - }; - - mba_mem: mba@91500000 { - reg = <0x0 0x91500000 0x0 0x200000>; - no-map; - }; - - mdata_mem: mpss-metadata { - alloc-ranges = <0x0 0xa0000000 0x0 0x20000000>; - size = <0x0 0x4000>; - no-map; - }; - }; - - smem { - compatible = "qcom,smem"; - memory-region = <&smem_mem>; - hwlocks = <&tcsr_mutex 3>; - }; - - smp2p-adsp { - compatible = "qcom,smp2p"; - qcom,smem = <443>, <429>; - - interrupts = <GIC_SPI 158 IRQ_TYPE_EDGE_RISING>; - - mboxes = <&apcs_glb 10>; - - qcom,local-pid = <0>; - qcom,remote-pid = <2>; - - adsp_smp2p_out: master-kernel { - qcom,entry-name = "master-kernel"; - #qcom,smem-state-cells = <1>; - }; - - adsp_smp2p_in: slave-kernel { - qcom,entry-name = "slave-kernel"; - - interrupt-controller; - #interrupt-cells = <2>; - }; - }; - - smp2p-mpss { - compatible = "qcom,smp2p"; - qcom,smem = <435>, <428>; - - interrupts = <GIC_SPI 451 IRQ_TYPE_EDGE_RISING>; - - mboxes = <&apcs_glb 14>; - - qcom,local-pid = <0>; - qcom,remote-pid = <1>; - - mpss_smp2p_out: master-kernel { - qcom,entry-name = "master-kernel"; - #qcom,smem-state-cells = <1>; - }; - - mpss_smp2p_in: slave-kernel { - qcom,entry-name = "slave-kernel"; - - interrupt-controller; - #interrupt-cells = <2>; - }; - }; - - smp2p-slpi { - compatible = "qcom,smp2p"; - qcom,smem = <481>, <430>; - - interrupts = <GIC_SPI 178 IRQ_TYPE_EDGE_RISING>; - - mboxes = <&apcs_glb 26>; - - qcom,local-pid = <0>; - qcom,remote-pid = <3>; - - slpi_smp2p_out: master-kernel { - qcom,entry-name = "master-kernel"; - #qcom,smem-state-cells = <1>; - }; - - slpi_smp2p_in: slave-kernel { - qcom,entry-name = "slave-kernel"; - - interrupt-controller; - #interrupt-cells = <2>; - }; - }; - - soc: soc@0 { - #address-cells = <1>; - #size-cells = <1>; - ranges = <0 0 0 0xffffffff>; - compatible = "simple-bus"; - - pcie_phy: phy-wrapper@34000 { - compatible = "qcom,msm8996-qmp-pcie-phy"; - reg = <0x00034000 0x488>; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0x0 0x00034000 0x4000>; - - clocks = <&gcc GCC_PCIE_PHY_AUX_CLK>, - <&gcc GCC_PCIE_PHY_CFG_AHB_CLK>, - <&gcc GCC_PCIE_CLKREF_CLK>; - clock-names = "aux", "cfg_ahb", "ref"; - - resets = <&gcc GCC_PCIE_PHY_BCR>, - <&gcc GCC_PCIE_PHY_COM_BCR>, - <&gcc GCC_PCIE_PHY_COM_NOCSR_BCR>; - reset-names = "phy", "common", "cfg"; - - status = "disabled"; - - pciephy_0: phy@1000 { - reg = <0x1000 0x130>, - <0x1200 0x200>, - <0x1400 0x1dc>; - - clocks = <&gcc GCC_PCIE_0_PIPE_CLK>; - clock-names = "pipe0"; - resets = <&gcc GCC_PCIE_0_PHY_BCR>; - reset-names = "lane0"; - - #clock-cells = <0>; - clock-output-names = "pcie_0_pipe_clk_src"; - - #phy-cells = <0>; - }; - - pciephy_1: phy@2000 { - reg = <0x2000 0x130>, - <0x2200 0x200>, - <0x2400 0x1dc>; - - clocks = <&gcc GCC_PCIE_1_PIPE_CLK>; - clock-names = "pipe1"; - resets = <&gcc GCC_PCIE_1_PHY_BCR>; - reset-names = "lane1"; - - #clock-cells = <0>; - clock-output-names = "pcie_1_pipe_clk_src"; - - #phy-cells = <0>; - }; - - pciephy_2: phy@3000 { - reg = <0x3000 0x130>, - <0x3200 0x200>, - <0x3400 0x1dc>; - - clocks = <&gcc GCC_PCIE_2_PIPE_CLK>; - clock-names = "pipe2"; - resets = <&gcc GCC_PCIE_2_PHY_BCR>; - reset-names = "lane2"; - - #clock-cells = <0>; - clock-output-names = "pcie_2_pipe_clk_src"; - - #phy-cells = <0>; - }; - }; - - rpm_msg_ram: sram@68000 { - compatible = "qcom,rpm-msg-ram"; - reg = <0x00068000 0x6000>; - }; - - qfprom@74000 { - compatible = "qcom,msm8996-qfprom", "qcom,qfprom"; - reg = <0x00074000 0x8ff>; - #address-cells = <1>; - #size-cells = <1>; - - qusb2p_hstx_trim: hstx_trim@24e { - reg = <0x24e 0x2>; - bits = <5 4>; - }; - - qusb2s_hstx_trim: hstx_trim@24f { - reg = <0x24f 0x1>; - bits = <1 4>; - }; - - speedbin_efuse: speedbin@133 { - reg = <0x133 0x1>; - bits = <5 3>; - }; - }; - - rng: rng@83000 { - compatible = "qcom,prng-ee"; - reg = <0x00083000 0x1000>; - clocks = <&gcc GCC_PRNG_AHB_CLK>; - clock-names = "core"; - }; - - gcc: clock-controller@300000 { - compatible = "qcom,gcc-msm8996"; - #clock-cells = <1>; - #reset-cells = <1>; - #power-domain-cells = <1>; - reg = <0x00300000 0x90000>; - - clocks = <&rpmcc RPM_SMD_XO_CLK_SRC>, - <&rpmcc RPM_SMD_LN_BB_CLK>, - <&sleep_clk>, - <&pciephy_0>, - <&pciephy_1>, - <&pciephy_2>, - <&ssusb_phy_0>, - <&ufsphy_lane 0>, - <&ufsphy_lane 1>, - <&ufsphy_lane 2>; - clock-names = "cxo", - "cxo2", - "sleep_clk", - "pcie_0_pipe_clk_src", - "pcie_1_pipe_clk_src", - "pcie_2_pipe_clk_src", - "usb3_phy_pipe_clk_src", - "ufs_rx_symbol_0_clk_src", - "ufs_rx_symbol_1_clk_src", - "ufs_tx_symbol_0_clk_src"; - }; - - bimc: interconnect@408000 { - compatible = "qcom,msm8996-bimc"; - reg = <0x00408000 0x5a000>; - #interconnect-cells = <1>; - clock-names = "bus", "bus_a"; - clocks = <&rpmcc RPM_SMD_BIMC_CLK>, - <&rpmcc RPM_SMD_BIMC_A_CLK>; - }; - - tsens0: thermal-sensor@4a9000 { - compatible = "qcom,msm8996-tsens", "qcom,tsens-v2"; - reg = <0x004a9000 0x1000>, /* TM */ - <0x004a8000 0x1000>; /* SROT */ - #qcom,sensors = <13>; - interrupts = <GIC_SPI 458 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 445 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "uplow", "critical"; - #thermal-sensor-cells = <1>; - }; - - tsens1: thermal-sensor@4ad000 { - compatible = "qcom,msm8996-tsens", "qcom,tsens-v2"; - reg = <0x004ad000 0x1000>, /* TM */ - <0x004ac000 0x1000>; /* SROT */ - #qcom,sensors = <8>; - interrupts = <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 430 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "uplow", "critical"; - #thermal-sensor-cells = <1>; - }; - - cryptobam: dma-controller@644000 { - compatible = "qcom,bam-v1.7.0"; - reg = <0x00644000 0x24000>; - interrupts = <GIC_SPI 206 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_CE1_CLK>; - clock-names = "bam_clk"; - #dma-cells = <1>; - qcom,ee = <0>; - qcom,controlled-remotely; - }; - - crypto: crypto@67a000 { - compatible = "qcom,crypto-v5.4"; - reg = <0x0067a000 0x6000>; - clocks = <&gcc GCC_CE1_AHB_CLK>, - <&gcc GCC_CE1_AXI_CLK>, - <&gcc GCC_CE1_CLK>; - clock-names = "iface", "bus", "core"; - dmas = <&cryptobam 6>, <&cryptobam 7>; - dma-names = "rx", "tx"; - }; - - cnoc: interconnect@500000 { - compatible = "qcom,msm8996-cnoc"; - reg = <0x00500000 0x1000>; - #interconnect-cells = <1>; - clock-names = "bus", "bus_a"; - clocks = <&rpmcc RPM_SMD_CNOC_CLK>, - <&rpmcc RPM_SMD_CNOC_A_CLK>; - }; - - snoc: interconnect@524000 { - compatible = "qcom,msm8996-snoc"; - reg = <0x00524000 0x1c000>; - #interconnect-cells = <1>; - clock-names = "bus", "bus_a"; - clocks = <&rpmcc RPM_SMD_SNOC_CLK>, - <&rpmcc RPM_SMD_SNOC_A_CLK>; - }; - - a0noc: interconnect@543000 { - compatible = "qcom,msm8996-a0noc"; - reg = <0x00543000 0x6000>; - #interconnect-cells = <1>; - clock-names = "aggre0_snoc_axi", - "aggre0_cnoc_ahb", - "aggre0_noc_mpu_cfg"; - clocks = <&gcc GCC_AGGRE0_SNOC_AXI_CLK>, - <&gcc GCC_AGGRE0_CNOC_AHB_CLK>, - <&gcc GCC_AGGRE0_NOC_MPU_CFG_AHB_CLK>; - power-domains = <&gcc AGGRE0_NOC_GDSC>; - }; - - a1noc: interconnect@562000 { - compatible = "qcom,msm8996-a1noc"; - reg = <0x00562000 0x5000>; - #interconnect-cells = <1>; - clock-names = "bus", "bus_a"; - clocks = <&rpmcc RPM_SMD_AGGR1_NOC_CLK>, - <&rpmcc RPM_SMD_AGGR1_NOC_A_CLK>; - }; - - a2noc: interconnect@583000 { - compatible = "qcom,msm8996-a2noc"; - reg = <0x00583000 0x7000>; - #interconnect-cells = <1>; - clock-names = "bus", "bus_a", "aggre2_ufs_axi", "ufs_axi"; - clocks = <&rpmcc RPM_SMD_AGGR2_NOC_CLK>, - <&rpmcc RPM_SMD_AGGR2_NOC_A_CLK>, - <&gcc GCC_AGGRE2_UFS_AXI_CLK>, - <&gcc GCC_UFS_AXI_CLK>; - }; - - mnoc: interconnect@5a4000 { - compatible = "qcom,msm8996-mnoc"; - reg = <0x005a4000 0x1c000>; - #interconnect-cells = <1>; - clock-names = "bus", "bus_a", "iface"; - clocks = <&rpmcc RPM_SMD_MMAXI_CLK>, - <&rpmcc RPM_SMD_MMAXI_A_CLK>, - <&mmcc AHB_CLK_SRC>; - }; - - pnoc: interconnect@5c0000 { - compatible = "qcom,msm8996-pnoc"; - reg = <0x005c0000 0x3000>; - #interconnect-cells = <1>; - clock-names = "bus", "bus_a"; - clocks = <&rpmcc RPM_SMD_PCNOC_CLK>, - <&rpmcc RPM_SMD_PCNOC_A_CLK>; - }; - - tcsr_mutex: hwlock@740000 { - compatible = "qcom,tcsr-mutex"; - reg = <0x00740000 0x20000>; - #hwlock-cells = <1>; - }; - - tcsr_1: syscon@760000 { - compatible = "qcom,tcsr-msm8996", "syscon"; - reg = <0x00760000 0x20000>; - }; - - tcsr_2: syscon@7a0000 { - compatible = "qcom,tcsr-msm8996", "syscon"; - reg = <0x007a0000 0x18000>; - }; - - mmcc: clock-controller@8c0000 { - compatible = "qcom,mmcc-msm8996"; - #clock-cells = <1>; - #reset-cells = <1>; - #power-domain-cells = <1>; - reg = <0x008c0000 0x40000>; - clocks = <&xo_board>, - <&gcc GPLL0>, - <&gcc GCC_MMSS_NOC_CFG_AHB_CLK>, - <&mdss_dsi0_phy 1>, - <&mdss_dsi0_phy 0>, - <&mdss_dsi1_phy 1>, - <&mdss_dsi1_phy 0>, - <&mdss_hdmi_phy>; - clock-names = "xo", - "gpll0", - "gcc_mmss_noc_cfg_ahb_clk", - "dsi0pll", - "dsi0pllbyte", - "dsi1pll", - "dsi1pllbyte", - "hdmipll"; - assigned-clocks = <&mmcc MMPLL9_PLL>, - <&mmcc MMPLL1_PLL>, - <&mmcc MMPLL3_PLL>, - <&mmcc MMPLL4_PLL>, - <&mmcc MMPLL5_PLL>; - assigned-clock-rates = <624000000>, - <810000000>, - <980000000>, - <960000000>, - <825000000>; - }; - - mdss: display-subsystem@900000 { - compatible = "qcom,mdss"; - - reg = <0x00900000 0x1000>, - <0x009b0000 0x1040>, - <0x009b8000 0x1040>; - reg-names = "mdss_phys", - "vbif_phys", - "vbif_nrt_phys"; - - power-domains = <&mmcc MDSS_GDSC>; - interrupts = <GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>; - - interrupt-controller; - #interrupt-cells = <1>; - - clocks = <&mmcc MDSS_AHB_CLK>, - <&mmcc MDSS_MDP_CLK>; - clock-names = "iface", "core"; - - #address-cells = <1>; - #size-cells = <1>; - ranges; - - status = "disabled"; - - mdp: display-controller@901000 { - compatible = "qcom,msm8996-mdp5", "qcom,mdp5"; - reg = <0x00901000 0x90000>; - reg-names = "mdp_phys"; - - interrupt-parent = <&mdss>; - interrupts = <0>; - - clocks = <&mmcc MDSS_AHB_CLK>, - <&mmcc MDSS_AXI_CLK>, - <&mmcc MDSS_MDP_CLK>, - <&mmcc SMMU_MDP_AXI_CLK>, - <&mmcc MDSS_VSYNC_CLK>; - clock-names = "iface", - "bus", - "core", - "iommu", - "vsync"; - - iommus = <&mdp_smmu 0>; - - assigned-clocks = <&mmcc MDSS_MDP_CLK>, - <&mmcc MDSS_VSYNC_CLK>; - assigned-clock-rates = <300000000>, - <19200000>; - - interconnects = <&mnoc MASTER_MDP_PORT0 &bimc SLAVE_EBI_CH0>, - <&mnoc MASTER_MDP_PORT1 &bimc SLAVE_EBI_CH0>, - <&mnoc MASTER_ROTATOR &bimc SLAVE_EBI_CH0>; - interconnect-names = "mdp0-mem", "mdp1-mem", "rotator-mem"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - mdp5_intf3_out: endpoint { - remote-endpoint = <&mdss_hdmi_in>; - }; - }; - - port@1 { - reg = <1>; - mdp5_intf1_out: endpoint { - remote-endpoint = <&mdss_dsi0_in>; - }; - }; - - port@2 { - reg = <2>; - mdp5_intf2_out: endpoint { - remote-endpoint = <&mdss_dsi1_in>; - }; - }; - }; - }; - - mdss_dsi0: dsi@994000 { - compatible = "qcom,msm8996-dsi-ctrl", - "qcom,mdss-dsi-ctrl"; - reg = <0x00994000 0x400>; - reg-names = "dsi_ctrl"; - - interrupt-parent = <&mdss>; - interrupts = <4>; - - clocks = <&mmcc MDSS_MDP_CLK>, - <&mmcc MDSS_BYTE0_CLK>, - <&mmcc MDSS_AHB_CLK>, - <&mmcc MDSS_AXI_CLK>, - <&mmcc MMSS_MISC_AHB_CLK>, - <&mmcc MDSS_PCLK0_CLK>, - <&mmcc MDSS_ESC0_CLK>; - clock-names = "mdp_core", - "byte", - "iface", - "bus", - "core_mmss", - "pixel", - "core"; - assigned-clocks = <&mmcc BYTE0_CLK_SRC>, <&mmcc PCLK0_CLK_SRC>; - assigned-clock-parents = <&mdss_dsi0_phy 0>, <&mdss_dsi0_phy 1>; - - phys = <&mdss_dsi0_phy>; - status = "disabled"; - - #address-cells = <1>; - #size-cells = <0>; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - mdss_dsi0_in: endpoint { - remote-endpoint = <&mdp5_intf1_out>; - }; - }; - - port@1 { - reg = <1>; - mdss_dsi0_out: endpoint { - }; - }; - }; - }; - - mdss_dsi0_phy: phy@994400 { - compatible = "qcom,dsi-phy-14nm"; - reg = <0x00994400 0x100>, - <0x00994500 0x300>, - <0x00994800 0x188>; - reg-names = "dsi_phy", - "dsi_phy_lane", - "dsi_pll"; - - #clock-cells = <1>; - #phy-cells = <0>; - - clocks = <&mmcc MDSS_AHB_CLK>, <&rpmcc RPM_SMD_XO_CLK_SRC>; - clock-names = "iface", "ref"; - status = "disabled"; - }; - - mdss_dsi1: dsi@996000 { - compatible = "qcom,msm8996-dsi-ctrl", - "qcom,mdss-dsi-ctrl"; - reg = <0x00996000 0x400>; - reg-names = "dsi_ctrl"; - - interrupt-parent = <&mdss>; - interrupts = <5>; - - clocks = <&mmcc MDSS_MDP_CLK>, - <&mmcc MDSS_BYTE1_CLK>, - <&mmcc MDSS_AHB_CLK>, - <&mmcc MDSS_AXI_CLK>, - <&mmcc MMSS_MISC_AHB_CLK>, - <&mmcc MDSS_PCLK1_CLK>, - <&mmcc MDSS_ESC1_CLK>; - clock-names = "mdp_core", - "byte", - "iface", - "bus", - "core_mmss", - "pixel", - "core"; - assigned-clocks = <&mmcc BYTE1_CLK_SRC>, <&mmcc PCLK1_CLK_SRC>; - assigned-clock-parents = <&mdss_dsi1_phy 0>, <&mdss_dsi1_phy 1>; - - phys = <&mdss_dsi1_phy>; - status = "disabled"; - - #address-cells = <1>; - #size-cells = <0>; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - mdss_dsi1_in: endpoint { - remote-endpoint = <&mdp5_intf2_out>; - }; - }; - - port@1 { - reg = <1>; - mdss_dsi1_out: endpoint { - }; - }; - }; - }; - - mdss_dsi1_phy: phy@996400 { - compatible = "qcom,dsi-phy-14nm"; - reg = <0x00996400 0x100>, - <0x00996500 0x300>, - <0x00996800 0x188>; - reg-names = "dsi_phy", - "dsi_phy_lane", - "dsi_pll"; - - #clock-cells = <1>; - #phy-cells = <0>; - - clocks = <&mmcc MDSS_AHB_CLK>, <&rpmcc RPM_SMD_XO_CLK_SRC>; - clock-names = "iface", "ref"; - status = "disabled"; - }; - - mdss_hdmi: hdmi-tx@9a0000 { - compatible = "qcom,hdmi-tx-8996"; - reg = <0x009a0000 0x50c>, - <0x00070000 0x6158>, - <0x009e0000 0xfff>; - reg-names = "core_physical", - "qfprom_physical", - "hdcp_physical"; - - interrupt-parent = <&mdss>; - interrupts = <8>; - - clocks = <&mmcc MDSS_MDP_CLK>, - <&mmcc MDSS_AHB_CLK>, - <&mmcc MDSS_HDMI_CLK>, - <&mmcc MDSS_HDMI_AHB_CLK>, - <&mmcc MDSS_EXTPCLK_CLK>; - clock-names = - "mdp_core", - "iface", - "core", - "alt_iface", - "extp"; - - phys = <&mdss_hdmi_phy>; - #sound-dai-cells = <1>; - - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - mdss_hdmi_in: endpoint { - remote-endpoint = <&mdp5_intf3_out>; - }; - }; - }; - }; - - mdss_hdmi_phy: phy@9a0600 { - #phy-cells = <0>; - compatible = "qcom,hdmi-phy-8996"; - reg = <0x009a0600 0x1c4>, - <0x009a0a00 0x124>, - <0x009a0c00 0x124>, - <0x009a0e00 0x124>, - <0x009a1000 0x124>, - <0x009a1200 0x0c8>; - reg-names = "hdmi_pll", - "hdmi_tx_l0", - "hdmi_tx_l1", - "hdmi_tx_l2", - "hdmi_tx_l3", - "hdmi_phy"; - - clocks = <&mmcc MDSS_AHB_CLK>, - <&gcc GCC_HDMI_CLKREF_CLK>, - <&xo_board>; - clock-names = "iface", - "ref", - "xo"; - - #clock-cells = <0>; - - status = "disabled"; - }; - }; - - gpu: gpu@b00000 { - compatible = "qcom,adreno-530.2", "qcom,adreno"; - - reg = <0x00b00000 0x3f000>; - reg-names = "kgsl_3d0_reg_memory"; - - interrupts = <GIC_SPI 300 IRQ_TYPE_LEVEL_HIGH>; - - clocks = <&mmcc GPU_GX_GFX3D_CLK>, - <&mmcc GPU_AHB_CLK>, - <&mmcc GPU_GX_RBBMTIMER_CLK>, - <&gcc GCC_BIMC_GFX_CLK>, - <&gcc GCC_MMSS_BIMC_GFX_CLK>; - - clock-names = "core", - "iface", - "rbbmtimer", - "mem", - "mem_iface"; - - interconnects = <&bimc MASTER_GRAPHICS_3D &bimc SLAVE_EBI_CH0>; - interconnect-names = "gfx-mem"; - - power-domains = <&mmcc GPU_GX_GDSC>; - iommus = <&adreno_smmu 0>; - - nvmem-cells = <&speedbin_efuse>; - nvmem-cell-names = "speed_bin"; - - operating-points-v2 = <&gpu_opp_table>; - - status = "disabled"; - - #cooling-cells = <2>; - - gpu_opp_table: opp-table { - compatible = "operating-points-v2"; - - /* - * 624Mhz is only available on speed bins 0 and 3. - * 560Mhz is only available on speed bins 0, 2 and 3. - * All the rest are available on all bins of the hardware. - */ - opp-624000000 { - opp-hz = /bits/ 64 <624000000>; - opp-supported-hw = <0x09>; - }; - opp-560000000 { - opp-hz = /bits/ 64 <560000000>; - opp-supported-hw = <0x0d>; - }; - opp-510000000 { - opp-hz = /bits/ 64 <510000000>; - opp-supported-hw = <0xff>; - }; - opp-401800000 { - opp-hz = /bits/ 64 <401800000>; - opp-supported-hw = <0xff>; - }; - opp-315000000 { - opp-hz = /bits/ 64 <315000000>; - opp-supported-hw = <0xff>; - }; - opp-214000000 { - opp-hz = /bits/ 64 <214000000>; - opp-supported-hw = <0xff>; - }; - opp-133000000 { - opp-hz = /bits/ 64 <133000000>; - opp-supported-hw = <0xff>; - }; - }; - - zap-shader { - memory-region = <&gpu_mem>; - }; - }; - - tlmm: pinctrl@1010000 { - compatible = "qcom,msm8996-pinctrl"; - reg = <0x01010000 0x300000>; - interrupts = <GIC_SPI 208 IRQ_TYPE_LEVEL_HIGH>; - gpio-controller; - gpio-ranges = <&tlmm 0 0 150>; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - - blsp1_spi1_default: blsp1-spi1-default-state { - spi-pins { - pins = "gpio0", "gpio1", "gpio3"; - function = "blsp_spi1"; - drive-strength = <12>; - bias-disable; - }; - - cs-pins { - pins = "gpio2"; - function = "gpio"; - drive-strength = <16>; - bias-disable; - output-high; - }; - }; - - blsp1_spi1_sleep: blsp1-spi1-sleep-state { - pins = "gpio0", "gpio1", "gpio2", "gpio3"; - function = "gpio"; - drive-strength = <2>; - bias-pull-down; - }; - - blsp2_uart2_2pins_default: blsp2-uart2-2pins-state { - pins = "gpio4", "gpio5"; - function = "blsp_uart8"; - drive-strength = <16>; - bias-disable; - }; - - blsp2_uart2_2pins_sleep: blsp2-uart2-2pins-sleep-state { - pins = "gpio4", "gpio5"; - function = "gpio"; - drive-strength = <2>; - bias-disable; - }; - - blsp2_i2c2_default: blsp2-i2c2-state { - pins = "gpio6", "gpio7"; - function = "blsp_i2c8"; - drive-strength = <16>; - bias-disable; - }; - - blsp2_i2c2_sleep: blsp2-i2c2-sleep-state { - pins = "gpio6", "gpio7"; - function = "gpio"; - drive-strength = <2>; - bias-disable; - }; - - blsp1_i2c6_default: blsp1-i2c6-state { - pins = "gpio27", "gpio28"; - function = "blsp_i2c6"; - drive-strength = <16>; - bias-disable; - }; - - blsp1_i2c6_sleep: blsp1-i2c6-sleep-state { - pins = "gpio27", "gpio28"; - function = "gpio"; - drive-strength = <2>; - bias-pull-up; - }; - - cci0_default: cci0-default-state { - pins = "gpio17", "gpio18"; - function = "cci_i2c"; - drive-strength = <16>; - bias-disable; - }; - - camera0_state_on: - camera_rear_default: camera-rear-default-state { - camera0_mclk: mclk0-pins { - pins = "gpio13"; - function = "cam_mclk"; - drive-strength = <16>; - bias-disable; - }; - - camera0_rst: rst-pins { - pins = "gpio25"; - function = "gpio"; - drive-strength = <16>; - bias-disable; - }; - - camera0_pwdn: pwdn-pins { - pins = "gpio26"; - function = "gpio"; - drive-strength = <16>; - bias-disable; - }; - }; - - cci1_default: cci1-default-state { - pins = "gpio19", "gpio20"; - function = "cci_i2c"; - drive-strength = <16>; - bias-disable; - }; - - camera1_state_on: - camera_board_default: camera-board-default-state { - mclk1-pins { - pins = "gpio14"; - function = "cam_mclk"; - drive-strength = <16>; - bias-disable; - }; - - pwdn-pins { - pins = "gpio98"; - function = "gpio"; - drive-strength = <16>; - bias-disable; - }; - - rst-pins { - pins = "gpio104"; - function = "gpio"; - drive-strength = <16>; - bias-disable; - }; - }; - - camera2_state_on: - camera_front_default: camera-front-default-state { - camera2_mclk: mclk2-pins { - pins = "gpio15"; - function = "cam_mclk"; - drive-strength = <16>; - bias-disable; - }; - - camera2_rst: rst-pins { - pins = "gpio23"; - function = "gpio"; - drive-strength = <16>; - bias-disable; - }; - - pwdn-pins { - pins = "gpio133"; - function = "gpio"; - drive-strength = <16>; - bias-disable; - }; - }; - - pcie0_state_on: pcie0-state-on-state { - perst-pins { - pins = "gpio35"; - function = "gpio"; - drive-strength = <2>; - bias-pull-down; - }; - - clkreq-pins { - pins = "gpio36"; - function = "pci_e0"; - drive-strength = <2>; - bias-pull-up; - }; - - wake-pins { - pins = "gpio37"; - function = "gpio"; - drive-strength = <2>; - bias-pull-up; - }; - }; - - pcie0_state_off: pcie0-state-off-state { - perst-pins { - pins = "gpio35"; - function = "gpio"; - drive-strength = <2>; - bias-pull-down; - }; - - clkreq-pins { - pins = "gpio36"; - function = "gpio"; - drive-strength = <2>; - bias-disable; - }; - - wake-pins { - pins = "gpio37"; - function = "gpio"; - drive-strength = <2>; - bias-disable; - }; - }; - - blsp1_uart2_default: blsp1-uart2-default-state { - pins = "gpio41", "gpio42", "gpio43", "gpio44"; - function = "blsp_uart2"; - drive-strength = <16>; - bias-disable; - }; - - blsp1_uart2_sleep: blsp1-uart2-sleep-state { - pins = "gpio41", "gpio42", "gpio43", "gpio44"; - function = "gpio"; - drive-strength = <2>; - bias-disable; - }; - - blsp1_i2c3_default: blsp1-i2c3-default-state { - pins = "gpio47", "gpio48"; - function = "blsp_i2c3"; - drive-strength = <16>; - bias-disable; - }; - - blsp1_i2c3_sleep: blsp1-i2c3-sleep-state { - pins = "gpio47", "gpio48"; - function = "gpio"; - drive-strength = <2>; - bias-disable; - }; - - blsp2_uart3_4pins_default: blsp2-uart3-4pins-state { - pins = "gpio49", "gpio50", "gpio51", "gpio52"; - function = "blsp_uart9"; - drive-strength = <16>; - bias-disable; - }; - - blsp2_uart3_4pins_sleep: blsp2-uart3-4pins-sleep-state { - pins = "gpio49", "gpio50", "gpio51", "gpio52"; - function = "blsp_uart9"; - drive-strength = <2>; - bias-disable; - }; - - blsp2_i2c3_default: blsp2-i2c3-state-state { - pins = "gpio51", "gpio52"; - function = "blsp_i2c9"; - drive-strength = <16>; - bias-disable; - }; - - blsp2_i2c3_sleep: blsp2-i2c3-sleep-state { - pins = "gpio51", "gpio52"; - function = "gpio"; - drive-strength = <2>; - bias-disable; - }; - - wcd_intr_default: wcd-intr-default-state { - pins = "gpio54"; - function = "gpio"; - drive-strength = <2>; - bias-pull-down; - }; - - blsp2_i2c1_default: blsp2-i2c1-state { - pins = "gpio55", "gpio56"; - function = "blsp_i2c7"; - drive-strength = <16>; - bias-disable; - }; - - blsp2_i2c1_sleep: blsp2-i2c1-sleep-state { - pins = "gpio55", "gpio56"; - function = "gpio"; - drive-strength = <2>; - bias-disable; - }; - - blsp2_i2c5_default: blsp2-i2c5-state { - pins = "gpio60", "gpio61"; - function = "blsp_i2c11"; - drive-strength = <2>; - bias-disable; - }; - - /* Sleep state for BLSP2_I2C5 is missing.. */ - - cdc_reset_active: cdc-reset-active-state { - pins = "gpio64"; - function = "gpio"; - drive-strength = <16>; - bias-pull-down; - output-high; - }; - - cdc_reset_sleep: cdc-reset-sleep-state { - pins = "gpio64"; - function = "gpio"; - drive-strength = <16>; - bias-disable; - output-low; - }; - - blsp2_spi6_default: blsp2-spi6-default-state { - spi-pins { - pins = "gpio85", "gpio86", "gpio88"; - function = "blsp_spi12"; - drive-strength = <12>; - bias-disable; - }; - - cs-pins { - pins = "gpio87"; - function = "gpio"; - drive-strength = <16>; - bias-disable; - output-high; - }; - }; - - blsp2_spi6_sleep: blsp2-spi6-sleep-state { - pins = "gpio85", "gpio86", "gpio87", "gpio88"; - function = "gpio"; - drive-strength = <2>; - bias-pull-down; - }; - - blsp2_i2c6_default: blsp2-i2c6-state { - pins = "gpio87", "gpio88"; - function = "blsp_i2c12"; - drive-strength = <16>; - bias-disable; - }; - - blsp2_i2c6_sleep: blsp2-i2c6-sleep-state { - pins = "gpio87", "gpio88"; - function = "gpio"; - drive-strength = <2>; - bias-disable; - }; - - pcie1_state_on: pcie1-on-state { - perst-pins { - pins = "gpio130"; - function = "gpio"; - drive-strength = <2>; - bias-pull-down; - }; - - clkreq-pins { - pins = "gpio131"; - function = "pci_e1"; - drive-strength = <2>; - bias-pull-up; - }; - - wake-pins { - pins = "gpio132"; - function = "gpio"; - drive-strength = <2>; - bias-pull-down; - }; - }; - - pcie1_state_off: pcie1-off-state { - /* Perst is missing? */ - clkreq-pins { - pins = "gpio131"; - function = "gpio"; - drive-strength = <2>; - bias-disable; - }; - - wake-pins { - pins = "gpio132"; - function = "gpio"; - drive-strength = <2>; - bias-disable; - }; - }; - - pcie2_state_on: pcie2-on-state { - perst-pins { - pins = "gpio114"; - function = "gpio"; - drive-strength = <2>; - bias-pull-down; - }; - - clkreq-pins { - pins = "gpio115"; - function = "pci_e2"; - drive-strength = <2>; - bias-pull-up; - }; - - wake-pins { - pins = "gpio116"; - function = "gpio"; - drive-strength = <2>; - bias-pull-down; - }; - }; - - pcie2_state_off: pcie2-off-state { - /* Perst is missing? */ - clkreq-pins { - pins = "gpio115"; - function = "gpio"; - drive-strength = <2>; - bias-disable; - }; - - wake-pins { - pins = "gpio116"; - function = "gpio"; - drive-strength = <2>; - bias-disable; - }; - }; - - sdc1_state_on: sdc1-on-state { - clk-pins { - pins = "sdc1_clk"; - bias-disable; - drive-strength = <16>; - }; - - cmd-pins { - pins = "sdc1_cmd"; - bias-pull-up; - drive-strength = <10>; - }; - - data-pins { - pins = "sdc1_data"; - bias-pull-up; - drive-strength = <10>; - }; - - rclk-pins { - pins = "sdc1_rclk"; - bias-pull-down; - }; - }; - - sdc1_state_off: sdc1-off-state { - clk-pins { - pins = "sdc1_clk"; - bias-disable; - drive-strength = <2>; - }; - - cmd-pins { - pins = "sdc1_cmd"; - bias-pull-up; - drive-strength = <2>; - }; - - data-pins { - pins = "sdc1_data"; - bias-pull-up; - drive-strength = <2>; - }; - - rclk-pins { - pins = "sdc1_rclk"; - bias-pull-down; - }; - }; - - sdc2_state_on: sdc2-on-state { - clk-pins { - pins = "sdc2_clk"; - bias-disable; - drive-strength = <16>; - }; - - cmd-pins { - pins = "sdc2_cmd"; - bias-pull-up; - drive-strength = <10>; - }; - - data-pins { - pins = "sdc2_data"; - bias-pull-up; - drive-strength = <10>; - }; - }; - - sdc2_state_off: sdc2-off-state { - clk-pins { - pins = "sdc2_clk"; - bias-disable; - drive-strength = <2>; - }; - - cmd-pins { - pins = "sdc2_cmd"; - bias-pull-up; - drive-strength = <2>; - }; - - data-pins { - pins = "sdc2_data"; - bias-pull-up; - drive-strength = <2>; - }; - }; - }; - - sram@290000 { - compatible = "qcom,rpm-stats"; - reg = <0x00290000 0x10000>; - }; - - spmi_bus: spmi@400f000 { - compatible = "qcom,spmi-pmic-arb"; - reg = <0x0400f000 0x1000>, - <0x04400000 0x800000>, - <0x04c00000 0x800000>, - <0x05800000 0x200000>, - <0x0400a000 0x002100>; - reg-names = "core", "chnls", "obsrvr", "intr", "cnfg"; - interrupt-names = "periph_irq"; - interrupts = <GIC_SPI 326 IRQ_TYPE_LEVEL_HIGH>; - qcom,ee = <0>; - qcom,channel = <0>; - #address-cells = <2>; - #size-cells = <0>; - interrupt-controller; - #interrupt-cells = <4>; - }; - - bus@0 { - power-domains = <&gcc AGGRE0_NOC_GDSC>; - compatible = "simple-pm-bus"; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0x0 0x0 0xffffffff>; - - pcie0: pcie@600000 { - compatible = "qcom,pcie-msm8996"; - status = "disabled"; - power-domains = <&gcc PCIE0_GDSC>; - bus-range = <0x00 0xff>; - num-lanes = <1>; - - reg = <0x00600000 0x2000>, - <0x0c000000 0xf1d>, - <0x0c000f20 0xa8>, - <0x0c100000 0x100000>; - reg-names = "parf", "dbi", "elbi","config"; - - phys = <&pciephy_0>; - phy-names = "pciephy"; - - #address-cells = <3>; - #size-cells = <2>; - ranges = <0x01000000 0x0 0x00000000 0x0c200000 0x0 0x100000>, - <0x02000000 0x0 0x0c300000 0x0c300000 0x0 0xd00000>; - - device_type = "pci"; - - interrupts = <GIC_SPI 405 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "msi"; - #interrupt-cells = <1>; - interrupt-map-mask = <0 0 0 0x7>; - interrupt-map = <0 0 0 1 &intc 0 244 IRQ_TYPE_LEVEL_HIGH>, /* int_a */ - <0 0 0 2 &intc 0 245 IRQ_TYPE_LEVEL_HIGH>, /* int_b */ - <0 0 0 3 &intc 0 247 IRQ_TYPE_LEVEL_HIGH>, /* int_c */ - <0 0 0 4 &intc 0 248 IRQ_TYPE_LEVEL_HIGH>; /* int_d */ - - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&pcie0_state_on>; - pinctrl-1 = <&pcie0_state_off>; - - linux,pci-domain = <0>; - - clocks = <&gcc GCC_PCIE_0_PIPE_CLK>, - <&gcc GCC_PCIE_0_AUX_CLK>, - <&gcc GCC_PCIE_0_CFG_AHB_CLK>, - <&gcc GCC_PCIE_0_MSTR_AXI_CLK>, - <&gcc GCC_PCIE_0_SLV_AXI_CLK>; - - clock-names = "pipe", - "aux", - "cfg", - "bus_master", - "bus_slave"; - }; - - pcie1: pcie@608000 { - compatible = "qcom,pcie-msm8996"; - power-domains = <&gcc PCIE1_GDSC>; - bus-range = <0x00 0xff>; - num-lanes = <1>; - - status = "disabled"; - - reg = <0x00608000 0x2000>, - <0x0d000000 0xf1d>, - <0x0d000f20 0xa8>, - <0x0d100000 0x100000>; - - reg-names = "parf", "dbi", "elbi","config"; - - phys = <&pciephy_1>; - phy-names = "pciephy"; - - #address-cells = <3>; - #size-cells = <2>; - ranges = <0x01000000 0x0 0x00000000 0x0d200000 0x0 0x100000>, - <0x02000000 0x0 0x0d300000 0x0d300000 0x0 0xd00000>; - - device_type = "pci"; - - interrupts = <GIC_SPI 413 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "msi"; - #interrupt-cells = <1>; - interrupt-map-mask = <0 0 0 0x7>; - interrupt-map = <0 0 0 1 &intc 0 272 IRQ_TYPE_LEVEL_HIGH>, /* int_a */ - <0 0 0 2 &intc 0 273 IRQ_TYPE_LEVEL_HIGH>, /* int_b */ - <0 0 0 3 &intc 0 274 IRQ_TYPE_LEVEL_HIGH>, /* int_c */ - <0 0 0 4 &intc 0 275 IRQ_TYPE_LEVEL_HIGH>; /* int_d */ - - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&pcie1_state_on>; - pinctrl-1 = <&pcie1_state_off>; - - linux,pci-domain = <1>; - - clocks = <&gcc GCC_PCIE_1_PIPE_CLK>, - <&gcc GCC_PCIE_1_AUX_CLK>, - <&gcc GCC_PCIE_1_CFG_AHB_CLK>, - <&gcc GCC_PCIE_1_MSTR_AXI_CLK>, - <&gcc GCC_PCIE_1_SLV_AXI_CLK>; - - clock-names = "pipe", - "aux", - "cfg", - "bus_master", - "bus_slave"; - }; - - pcie2: pcie@610000 { - compatible = "qcom,pcie-msm8996"; - power-domains = <&gcc PCIE2_GDSC>; - bus-range = <0x00 0xff>; - num-lanes = <1>; - status = "disabled"; - reg = <0x00610000 0x2000>, - <0x0e000000 0xf1d>, - <0x0e000f20 0xa8>, - <0x0e100000 0x100000>; - - reg-names = "parf", "dbi", "elbi","config"; - - phys = <&pciephy_2>; - phy-names = "pciephy"; - - #address-cells = <3>; - #size-cells = <2>; - ranges = <0x01000000 0x0 0x00000000 0x0e200000 0x0 0x100000>, - <0x02000000 0x0 0x0e300000 0x0e300000 0x0 0x1d00000>; - - device_type = "pci"; - - interrupts = <GIC_SPI 421 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "msi"; - #interrupt-cells = <1>; - interrupt-map-mask = <0 0 0 0x7>; - interrupt-map = <0 0 0 1 &intc 0 142 IRQ_TYPE_LEVEL_HIGH>, /* int_a */ - <0 0 0 2 &intc 0 143 IRQ_TYPE_LEVEL_HIGH>, /* int_b */ - <0 0 0 3 &intc 0 144 IRQ_TYPE_LEVEL_HIGH>, /* int_c */ - <0 0 0 4 &intc 0 145 IRQ_TYPE_LEVEL_HIGH>; /* int_d */ - - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&pcie2_state_on>; - pinctrl-1 = <&pcie2_state_off>; - - linux,pci-domain = <2>; - clocks = <&gcc GCC_PCIE_2_PIPE_CLK>, - <&gcc GCC_PCIE_2_AUX_CLK>, - <&gcc GCC_PCIE_2_CFG_AHB_CLK>, - <&gcc GCC_PCIE_2_MSTR_AXI_CLK>, - <&gcc GCC_PCIE_2_SLV_AXI_CLK>; - - clock-names = "pipe", - "aux", - "cfg", - "bus_master", - "bus_slave"; - }; - }; - - ufshc: ufshc@624000 { - compatible = "qcom,msm8996-ufshc", "qcom,ufshc", - "jedec,ufs-2.0"; - reg = <0x00624000 0x2500>; - interrupts = <GIC_SPI 265 IRQ_TYPE_LEVEL_HIGH>; - - phys = <&ufsphy_lane>; - phy-names = "ufsphy"; - - power-domains = <&gcc UFS_GDSC>; - - clock-names = - "core_clk_src", - "core_clk", - "bus_clk", - "bus_aggr_clk", - "iface_clk", - "core_clk_unipro_src", - "core_clk_unipro", - "core_clk_ice", - "ref_clk", - "tx_lane0_sync_clk", - "rx_lane0_sync_clk"; - clocks = - <&gcc UFS_AXI_CLK_SRC>, - <&gcc GCC_UFS_AXI_CLK>, - <&gcc GCC_SYS_NOC_UFS_AXI_CLK>, - <&gcc GCC_AGGRE2_UFS_AXI_CLK>, - <&gcc GCC_UFS_AHB_CLK>, - <&gcc UFS_ICE_CORE_CLK_SRC>, - <&gcc GCC_UFS_UNIPRO_CORE_CLK>, - <&gcc GCC_UFS_ICE_CORE_CLK>, - <&rpmcc RPM_SMD_LN_BB_CLK>, - <&gcc GCC_UFS_TX_SYMBOL_0_CLK>, - <&gcc GCC_UFS_RX_SYMBOL_0_CLK>; - freq-table-hz = - <100000000 200000000>, - <0 0>, - <0 0>, - <0 0>, - <0 0>, - <150000000 300000000>, - <0 0>, - <0 0>, - <0 0>, - <0 0>, - <0 0>; - - interconnects = <&a2noc MASTER_UFS &bimc SLAVE_EBI_CH0>, - <&bimc MASTER_AMPSS_M0 &cnoc SLAVE_UFS_CFG>; - interconnect-names = "ufs-ddr", "cpu-ufs"; - - lanes-per-direction = <1>; - #reset-cells = <1>; - status = "disabled"; - }; - - ufsphy: phy@627000 { - compatible = "qcom,msm8996-qmp-ufs-phy"; - reg = <0x00627000 0x1c4>; - #address-cells = <1>; - #size-cells = <1>; - ranges; - - clocks = <&gcc GCC_UFS_CLKREF_CLK>; - clock-names = "ref"; - - resets = <&ufshc 0>; - reset-names = "ufsphy"; - status = "disabled"; - - ufsphy_lane: phy@627400 { - reg = <0x627400 0x12c>, - <0x627600 0x200>, - <0x627c00 0x1b4>; - #clock-cells = <1>; - #phy-cells = <0>; - }; - }; - - camss: camss@a34000 { - compatible = "qcom,msm8996-camss"; - reg = <0x00a34000 0x1000>, - <0x00a00030 0x4>, - <0x00a35000 0x1000>, - <0x00a00038 0x4>, - <0x00a36000 0x1000>, - <0x00a00040 0x4>, - <0x00a30000 0x100>, - <0x00a30400 0x100>, - <0x00a30800 0x100>, - <0x00a30c00 0x100>, - <0x00a31000 0x500>, - <0x00a00020 0x10>, - <0x00a10000 0x1000>, - <0x00a14000 0x1000>; - reg-names = "csiphy0", - "csiphy0_clk_mux", - "csiphy1", - "csiphy1_clk_mux", - "csiphy2", - "csiphy2_clk_mux", - "csid0", - "csid1", - "csid2", - "csid3", - "ispif", - "csi_clk_mux", - "vfe0", - "vfe1"; - interrupts = <GIC_SPI 78 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 79 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 80 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 296 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 297 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 298 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 299 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 309 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 314 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 315 IRQ_TYPE_EDGE_RISING>; - interrupt-names = "csiphy0", - "csiphy1", - "csiphy2", - "csid0", - "csid1", - "csid2", - "csid3", - "ispif", - "vfe0", - "vfe1"; - power-domains = <&mmcc VFE0_GDSC>, - <&mmcc VFE1_GDSC>; - clocks = <&mmcc CAMSS_TOP_AHB_CLK>, - <&mmcc CAMSS_ISPIF_AHB_CLK>, - <&mmcc CAMSS_CSI0PHYTIMER_CLK>, - <&mmcc CAMSS_CSI1PHYTIMER_CLK>, - <&mmcc CAMSS_CSI2PHYTIMER_CLK>, - <&mmcc CAMSS_CSI0_AHB_CLK>, - <&mmcc CAMSS_CSI0_CLK>, - <&mmcc CAMSS_CSI0PHY_CLK>, - <&mmcc CAMSS_CSI0PIX_CLK>, - <&mmcc CAMSS_CSI0RDI_CLK>, - <&mmcc CAMSS_CSI1_AHB_CLK>, - <&mmcc CAMSS_CSI1_CLK>, - <&mmcc CAMSS_CSI1PHY_CLK>, - <&mmcc CAMSS_CSI1PIX_CLK>, - <&mmcc CAMSS_CSI1RDI_CLK>, - <&mmcc CAMSS_CSI2_AHB_CLK>, - <&mmcc CAMSS_CSI2_CLK>, - <&mmcc CAMSS_CSI2PHY_CLK>, - <&mmcc CAMSS_CSI2PIX_CLK>, - <&mmcc CAMSS_CSI2RDI_CLK>, - <&mmcc CAMSS_CSI3_AHB_CLK>, - <&mmcc CAMSS_CSI3_CLK>, - <&mmcc CAMSS_CSI3PHY_CLK>, - <&mmcc CAMSS_CSI3PIX_CLK>, - <&mmcc CAMSS_CSI3RDI_CLK>, - <&mmcc CAMSS_AHB_CLK>, - <&mmcc CAMSS_VFE0_CLK>, - <&mmcc CAMSS_CSI_VFE0_CLK>, - <&mmcc CAMSS_VFE0_AHB_CLK>, - <&mmcc CAMSS_VFE0_STREAM_CLK>, - <&mmcc CAMSS_VFE1_CLK>, - <&mmcc CAMSS_CSI_VFE1_CLK>, - <&mmcc CAMSS_VFE1_AHB_CLK>, - <&mmcc CAMSS_VFE1_STREAM_CLK>, - <&mmcc CAMSS_VFE_AHB_CLK>, - <&mmcc CAMSS_VFE_AXI_CLK>; - clock-names = "top_ahb", - "ispif_ahb", - "csiphy0_timer", - "csiphy1_timer", - "csiphy2_timer", - "csi0_ahb", - "csi0", - "csi0_phy", - "csi0_pix", - "csi0_rdi", - "csi1_ahb", - "csi1", - "csi1_phy", - "csi1_pix", - "csi1_rdi", - "csi2_ahb", - "csi2", - "csi2_phy", - "csi2_pix", - "csi2_rdi", - "csi3_ahb", - "csi3", - "csi3_phy", - "csi3_pix", - "csi3_rdi", - "ahb", - "vfe0", - "csi_vfe0", - "vfe0_ahb", - "vfe0_stream", - "vfe1", - "csi_vfe1", - "vfe1_ahb", - "vfe1_stream", - "vfe_ahb", - "vfe_axi"; - iommus = <&vfe_smmu 0>, - <&vfe_smmu 1>, - <&vfe_smmu 2>, - <&vfe_smmu 3>; - status = "disabled"; - ports { - #address-cells = <1>; - #size-cells = <0>; - }; - }; - - cci: cci@a0c000 { - compatible = "qcom,msm8996-cci"; - #address-cells = <1>; - #size-cells = <0>; - reg = <0xa0c000 0x1000>; - interrupts = <GIC_SPI 295 IRQ_TYPE_EDGE_RISING>; - power-domains = <&mmcc CAMSS_GDSC>; - clocks = <&mmcc CAMSS_TOP_AHB_CLK>, - <&mmcc CAMSS_CCI_AHB_CLK>, - <&mmcc CAMSS_CCI_CLK>, - <&mmcc CAMSS_AHB_CLK>; - clock-names = "camss_top_ahb", - "cci_ahb", - "cci", - "camss_ahb"; - assigned-clocks = <&mmcc CAMSS_CCI_AHB_CLK>, - <&mmcc CAMSS_CCI_CLK>; - assigned-clock-rates = <80000000>, <37500000>; - pinctrl-names = "default"; - pinctrl-0 = <&cci0_default &cci1_default>; - status = "disabled"; - - cci_i2c0: i2c-bus@0 { - reg = <0>; - clock-frequency = <400000>; - #address-cells = <1>; - #size-cells = <0>; - }; - - cci_i2c1: i2c-bus@1 { - reg = <1>; - clock-frequency = <400000>; - #address-cells = <1>; - #size-cells = <0>; - }; - }; - - adreno_smmu: iommu@b40000 { - compatible = "qcom,msm8996-smmu-v2", "qcom,adreno-smmu", "qcom,smmu-v2"; - reg = <0x00b40000 0x10000>; - - #global-interrupts = <1>; - interrupts = <GIC_SPI 334 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 329 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 330 IRQ_TYPE_LEVEL_HIGH>; - #iommu-cells = <1>; - - clocks = <&gcc GCC_MMSS_BIMC_GFX_CLK>, - <&mmcc GPU_AHB_CLK>; - clock-names = "bus", "iface"; - - power-domains = <&mmcc GPU_GDSC>; - }; - - venus: video-codec@c00000 { - compatible = "qcom,msm8996-venus"; - reg = <0x00c00000 0xff000>; - interrupts = <GIC_SPI 287 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&mmcc VENUS_GDSC>; - clocks = <&mmcc VIDEO_CORE_CLK>, - <&mmcc VIDEO_AHB_CLK>, - <&mmcc VIDEO_AXI_CLK>, - <&mmcc VIDEO_MAXI_CLK>; - clock-names = "core", "iface", "bus", "mbus"; - interconnects = <&mnoc MASTER_VIDEO_P0 &bimc SLAVE_EBI_CH0>, - <&bimc MASTER_AMPSS_M0 &mnoc SLAVE_VENUS_CFG>; - interconnect-names = "video-mem", "cpu-cfg"; - iommus = <&venus_smmu 0x00>, - <&venus_smmu 0x01>, - <&venus_smmu 0x0a>, - <&venus_smmu 0x07>, - <&venus_smmu 0x0e>, - <&venus_smmu 0x0f>, - <&venus_smmu 0x08>, - <&venus_smmu 0x09>, - <&venus_smmu 0x0b>, - <&venus_smmu 0x0c>, - <&venus_smmu 0x0d>, - <&venus_smmu 0x10>, - <&venus_smmu 0x11>, - <&venus_smmu 0x21>, - <&venus_smmu 0x28>, - <&venus_smmu 0x29>, - <&venus_smmu 0x2b>, - <&venus_smmu 0x2c>, - <&venus_smmu 0x2d>, - <&venus_smmu 0x31>; - memory-region = <&venus_mem>; - status = "disabled"; - - video-decoder { - compatible = "venus-decoder"; - clocks = <&mmcc VIDEO_SUBCORE0_CLK>; - clock-names = "core"; - power-domains = <&mmcc VENUS_CORE0_GDSC>; - }; - - video-encoder { - compatible = "venus-encoder"; - clocks = <&mmcc VIDEO_SUBCORE1_CLK>; - clock-names = "core"; - power-domains = <&mmcc VENUS_CORE1_GDSC>; - }; - }; - - mdp_smmu: iommu@d00000 { - compatible = "qcom,msm8996-smmu-v2", "qcom,smmu-v2"; - reg = <0x00d00000 0x10000>; - - #global-interrupts = <1>; - interrupts = <GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 320 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 321 IRQ_TYPE_LEVEL_HIGH>; - #iommu-cells = <1>; - clocks = <&mmcc SMMU_MDP_AXI_CLK>, - <&mmcc SMMU_MDP_AHB_CLK>; - clock-names = "bus", "iface"; - - power-domains = <&mmcc MDSS_GDSC>; - }; - - venus_smmu: iommu@d40000 { - compatible = "qcom,msm8996-smmu-v2", "qcom,smmu-v2"; - reg = <0x00d40000 0x20000>; - #global-interrupts = <1>; - interrupts = <GIC_SPI 286 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 335 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 336 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 337 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 338 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 339 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 340 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 341 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&mmcc MMAGIC_VIDEO_GDSC>; - clocks = <&mmcc SMMU_VIDEO_AXI_CLK>, - <&mmcc SMMU_VIDEO_AHB_CLK>; - clock-names = "bus", "iface"; - #iommu-cells = <1>; - status = "okay"; - }; - - vfe_smmu: iommu@da0000 { - compatible = "qcom,msm8996-smmu-v2", "qcom,smmu-v2"; - reg = <0x00da0000 0x10000>; - - #global-interrupts = <1>; - interrupts = <GIC_SPI 76 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 343 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 344 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&mmcc MMAGIC_CAMSS_GDSC>; - clocks = <&mmcc SMMU_VFE_AXI_CLK>, - <&mmcc SMMU_VFE_AHB_CLK>; - clock-names = "bus", "iface"; - #iommu-cells = <1>; - }; - - lpass_q6_smmu: iommu@1600000 { - compatible = "qcom,msm8996-smmu-v2", "qcom,smmu-v2"; - reg = <0x01600000 0x20000>; - #iommu-cells = <1>; - power-domains = <&gcc HLOS1_VOTE_LPASS_CORE_GDSC>; - - #global-interrupts = <1>; - interrupts = <GIC_SPI 404 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 226 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 393 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 394 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 395 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 396 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 397 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 398 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 399 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 400 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 401 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 402 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 403 IRQ_TYPE_LEVEL_HIGH>; - - clocks = <&gcc GCC_HLOS1_VOTE_LPASS_ADSP_SMMU_CLK>, - <&gcc GCC_HLOS1_VOTE_LPASS_CORE_SMMU_CLK>; - clock-names = "bus", "iface"; - }; - - slpi_pil: remoteproc@1c00000 { - compatible = "qcom,msm8996-slpi-pil"; - reg = <0x01c00000 0x4000>; - - interrupts-extended = <&intc 0 390 IRQ_TYPE_EDGE_RISING>, - <&slpi_smp2p_in 0 IRQ_TYPE_EDGE_RISING>, - <&slpi_smp2p_in 1 IRQ_TYPE_EDGE_RISING>, - <&slpi_smp2p_in 2 IRQ_TYPE_EDGE_RISING>, - <&slpi_smp2p_in 3 IRQ_TYPE_EDGE_RISING>; - interrupt-names = "wdog", - "fatal", - "ready", - "handover", - "stop-ack"; - - clocks = <&xo_board>, - <&rpmcc RPM_SMD_AGGR2_NOC_CLK>; - clock-names = "xo", "aggre2"; - - memory-region = <&slpi_mem>; - - qcom,smem-states = <&slpi_smp2p_out 0>; - qcom,smem-state-names = "stop"; - - power-domains = <&rpmpd MSM8996_VDDSSCX>; - power-domain-names = "ssc_cx"; - - status = "disabled"; - - smd-edge { - interrupts = <GIC_SPI 176 IRQ_TYPE_EDGE_RISING>; - - label = "dsps"; - mboxes = <&apcs_glb 25>; - qcom,smd-edge = <3>; - qcom,remote-pid = <3>; - }; - }; - - mss_pil: remoteproc@2080000 { - compatible = "qcom,msm8996-mss-pil"; - reg = <0x2080000 0x100>, - <0x2180000 0x020>; - reg-names = "qdsp6", "rmb"; - - interrupts-extended = <&intc 0 448 IRQ_TYPE_EDGE_RISING>, - <&mpss_smp2p_in 0 IRQ_TYPE_EDGE_RISING>, - <&mpss_smp2p_in 1 IRQ_TYPE_EDGE_RISING>, - <&mpss_smp2p_in 2 IRQ_TYPE_EDGE_RISING>, - <&mpss_smp2p_in 3 IRQ_TYPE_EDGE_RISING>, - <&mpss_smp2p_in 7 IRQ_TYPE_EDGE_RISING>; - interrupt-names = "wdog", "fatal", "ready", - "handover", "stop-ack", - "shutdown-ack"; - - clocks = <&gcc GCC_MSS_CFG_AHB_CLK>, - <&gcc GCC_MSS_Q6_BIMC_AXI_CLK>, - <&gcc GCC_BOOT_ROM_AHB_CLK>, - <&xo_board>, - <&gcc GCC_MSS_GPLL0_DIV_CLK>, - <&gcc GCC_MSS_SNOC_AXI_CLK>, - <&gcc GCC_MSS_MNOC_BIMC_AXI_CLK>, - <&rpmcc RPM_SMD_PCNOC_CLK>, - <&rpmcc RPM_SMD_QDSS_CLK>; - clock-names = "iface", "bus", "mem", "xo", "gpll0_mss", - "snoc_axi", "mnoc_axi", "pnoc", "qdss"; - - resets = <&gcc GCC_MSS_RESTART>; - reset-names = "mss_restart"; - - power-domains = <&rpmpd MSM8996_VDDCX>, - <&rpmpd MSM8996_VDDMX>; - power-domain-names = "cx", "mx"; - - qcom,smem-states = <&mpss_smp2p_out 0>; - qcom,smem-state-names = "stop"; - - qcom,halt-regs = <&tcsr_1 0x3000 0x5000 0x4000>; - - status = "disabled"; - - mba { - memory-region = <&mba_mem>; - }; - - mpss { - memory-region = <&mpss_mem>; - }; - - metadata { - memory-region = <&mdata_mem>; - }; - - smd-edge { - interrupts = <GIC_SPI 449 IRQ_TYPE_EDGE_RISING>; - - label = "mpss"; - mboxes = <&apcs_glb 12>; - qcom,smd-edge = <0>; - qcom,remote-pid = <1>; - }; - }; - - stm@3002000 { - compatible = "arm,coresight-stm", "arm,primecell"; - reg = <0x3002000 0x1000>, - <0x8280000 0x180000>; - reg-names = "stm-base", "stm-stimulus-base"; - - clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; - clock-names = "apb_pclk", "atclk"; - - out-ports { - port { - stm_out: endpoint { - remote-endpoint = - <&funnel0_in>; - }; - }; - }; - }; - - tpiu@3020000 { - compatible = "arm,coresight-tpiu", "arm,primecell"; - reg = <0x3020000 0x1000>; - - clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; - clock-names = "apb_pclk", "atclk"; - - in-ports { - port { - tpiu_in: endpoint { - remote-endpoint = - <&replicator_out1>; - }; - }; - }; - }; - - funnel@3021000 { - compatible = "arm,coresight-dynamic-funnel", "arm,primecell"; - reg = <0x3021000 0x1000>; - - clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; - clock-names = "apb_pclk", "atclk"; - - in-ports { - #address-cells = <1>; - #size-cells = <0>; - - port@7 { - reg = <7>; - funnel0_in: endpoint { - remote-endpoint = - <&stm_out>; - }; - }; - }; - - out-ports { - port { - funnel0_out: endpoint { - remote-endpoint = - <&merge_funnel_in0>; - }; - }; - }; - }; - - funnel@3022000 { - compatible = "arm,coresight-dynamic-funnel", "arm,primecell"; - reg = <0x3022000 0x1000>; - - clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; - clock-names = "apb_pclk", "atclk"; - - in-ports { - #address-cells = <1>; - #size-cells = <0>; - - port@6 { - reg = <6>; - funnel1_in: endpoint { - remote-endpoint = - <&apss_merge_funnel_out>; - }; - }; - }; - - out-ports { - port { - funnel1_out: endpoint { - remote-endpoint = - <&merge_funnel_in1>; - }; - }; - }; - }; - - funnel@3023000 { - compatible = "arm,coresight-dynamic-funnel", "arm,primecell"; - reg = <0x3023000 0x1000>; - - clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; - clock-names = "apb_pclk", "atclk"; - - - out-ports { - port { - funnel2_out: endpoint { - remote-endpoint = - <&merge_funnel_in2>; - }; - }; - }; - }; - - funnel@3025000 { - compatible = "arm,coresight-dynamic-funnel", "arm,primecell"; - reg = <0x3025000 0x1000>; - - clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; - clock-names = "apb_pclk", "atclk"; - - in-ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - merge_funnel_in0: endpoint { - remote-endpoint = - <&funnel0_out>; - }; - }; - - port@1 { - reg = <1>; - merge_funnel_in1: endpoint { - remote-endpoint = - <&funnel1_out>; - }; - }; - - port@2 { - reg = <2>; - merge_funnel_in2: endpoint { - remote-endpoint = - <&funnel2_out>; - }; - }; - }; - - out-ports { - port { - merge_funnel_out: endpoint { - remote-endpoint = - <&etf_in>; - }; - }; - }; - }; - - replicator@3026000 { - compatible = "arm,coresight-dynamic-replicator", "arm,primecell"; - reg = <0x3026000 0x1000>; - - clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; - clock-names = "apb_pclk", "atclk"; - - in-ports { - port { - replicator_in: endpoint { - remote-endpoint = - <&etf_out>; - }; - }; - }; - - out-ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - replicator_out0: endpoint { - remote-endpoint = - <&etr_in>; - }; - }; - - port@1 { - reg = <1>; - replicator_out1: endpoint { - remote-endpoint = - <&tpiu_in>; - }; - }; - }; - }; - - etf@3027000 { - compatible = "arm,coresight-tmc", "arm,primecell"; - reg = <0x3027000 0x1000>; - - clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; - clock-names = "apb_pclk", "atclk"; - - in-ports { - port { - etf_in: endpoint { - remote-endpoint = - <&merge_funnel_out>; - }; - }; - }; - - out-ports { - port { - etf_out: endpoint { - remote-endpoint = - <&replicator_in>; - }; - }; - }; - }; - - etr@3028000 { - compatible = "arm,coresight-tmc", "arm,primecell"; - reg = <0x3028000 0x1000>; - - clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; - clock-names = "apb_pclk", "atclk"; - arm,scatter-gather; - - in-ports { - port { - etr_in: endpoint { - remote-endpoint = - <&replicator_out0>; - }; - }; - }; - }; - - debug@3810000 { - compatible = "arm,coresight-cpu-debug", "arm,primecell"; - reg = <0x3810000 0x1000>; - - clocks = <&rpmcc RPM_QDSS_CLK>; - clock-names = "apb_pclk"; - - cpu = <&CPU0>; - }; - - etm@3840000 { - compatible = "arm,coresight-etm4x", "arm,primecell"; - reg = <0x3840000 0x1000>; - - clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; - clock-names = "apb_pclk", "atclk"; - - cpu = <&CPU0>; - - out-ports { - port { - etm0_out: endpoint { - remote-endpoint = - <&apss_funnel0_in0>; - }; - }; - }; - }; - - debug@3910000 { - compatible = "arm,coresight-cpu-debug", "arm,primecell"; - reg = <0x3910000 0x1000>; - - clocks = <&rpmcc RPM_QDSS_CLK>; - clock-names = "apb_pclk"; - - cpu = <&CPU1>; - }; - - etm@3940000 { - compatible = "arm,coresight-etm4x", "arm,primecell"; - reg = <0x3940000 0x1000>; - - clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; - clock-names = "apb_pclk", "atclk"; - - cpu = <&CPU1>; - - out-ports { - port { - etm1_out: endpoint { - remote-endpoint = - <&apss_funnel0_in1>; - }; - }; - }; - }; - - funnel@39b0000 { /* APSS Funnel 0 */ - compatible = "arm,coresight-dynamic-funnel", "arm,primecell"; - reg = <0x39b0000 0x1000>; - - clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; - clock-names = "apb_pclk", "atclk"; - - in-ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - apss_funnel0_in0: endpoint { - remote-endpoint = <&etm0_out>; - }; - }; - - port@1 { - reg = <1>; - apss_funnel0_in1: endpoint { - remote-endpoint = <&etm1_out>; - }; - }; - }; - - out-ports { - port { - apss_funnel0_out: endpoint { - remote-endpoint = - <&apss_merge_funnel_in0>; - }; - }; - }; - }; - - debug@3a10000 { - compatible = "arm,coresight-cpu-debug", "arm,primecell"; - reg = <0x3a10000 0x1000>; - - clocks = <&rpmcc RPM_QDSS_CLK>; - clock-names = "apb_pclk"; - - cpu = <&CPU2>; - }; - - etm@3a40000 { - compatible = "arm,coresight-etm4x", "arm,primecell"; - reg = <0x3a40000 0x1000>; - - clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; - clock-names = "apb_pclk", "atclk"; - - cpu = <&CPU2>; - - out-ports { - port { - etm2_out: endpoint { - remote-endpoint = - <&apss_funnel1_in0>; - }; - }; - }; - }; - - debug@3b10000 { - compatible = "arm,coresight-cpu-debug", "arm,primecell"; - reg = <0x3b10000 0x1000>; - - clocks = <&rpmcc RPM_QDSS_CLK>; - clock-names = "apb_pclk"; - - cpu = <&CPU3>; - }; - - etm@3b40000 { - compatible = "arm,coresight-etm4x", "arm,primecell"; - reg = <0x3b40000 0x1000>; - - clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; - clock-names = "apb_pclk", "atclk"; - - cpu = <&CPU3>; - - out-ports { - port { - etm3_out: endpoint { - remote-endpoint = - <&apss_funnel1_in1>; - }; - }; - }; - }; - - funnel@3bb0000 { /* APSS Funnel 1 */ - compatible = "arm,coresight-dynamic-funnel", "arm,primecell"; - reg = <0x3bb0000 0x1000>; - - clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; - clock-names = "apb_pclk", "atclk"; - - in-ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - apss_funnel1_in0: endpoint { - remote-endpoint = <&etm2_out>; - }; - }; - - port@1 { - reg = <1>; - apss_funnel1_in1: endpoint { - remote-endpoint = <&etm3_out>; - }; - }; - }; - - out-ports { - port { - apss_funnel1_out: endpoint { - remote-endpoint = - <&apss_merge_funnel_in1>; - }; - }; - }; - }; - - funnel@3bc0000 { - compatible = "arm,coresight-dynamic-funnel", "arm,primecell"; - reg = <0x3bc0000 0x1000>; - - clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; - clock-names = "apb_pclk", "atclk"; - - in-ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - apss_merge_funnel_in0: endpoint { - remote-endpoint = - <&apss_funnel0_out>; - }; - }; - - port@1 { - reg = <1>; - apss_merge_funnel_in1: endpoint { - remote-endpoint = - <&apss_funnel1_out>; - }; - }; - }; - - out-ports { - port { - apss_merge_funnel_out: endpoint { - remote-endpoint = - <&funnel1_in>; - }; - }; - }; - }; - - kryocc: clock-controller@6400000 { - compatible = "qcom,msm8996-apcc"; - reg = <0x06400000 0x90000>; - - clock-names = "xo", "sys_apcs_aux"; - clocks = <&rpmcc RPM_SMD_XO_A_CLK_SRC>, <&apcs_glb>; - - #clock-cells = <1>; - }; - - usb3: usb@6af8800 { - compatible = "qcom,msm8996-dwc3", "qcom,dwc3"; - reg = <0x06af8800 0x400>; - #address-cells = <1>; - #size-cells = <1>; - ranges; - - interrupts = <GIC_SPI 347 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 243 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "hs_phy_irq", "ss_phy_irq"; - - clocks = <&gcc GCC_SYS_NOC_USB3_AXI_CLK>, - <&gcc GCC_USB30_MASTER_CLK>, - <&gcc GCC_AGGRE2_USB3_AXI_CLK>, - <&gcc GCC_USB30_SLEEP_CLK>, - <&gcc GCC_USB30_MOCK_UTMI_CLK>; - clock-names = "cfg_noc", - "core", - "iface", - "sleep", - "mock_utmi"; - - assigned-clocks = <&gcc GCC_USB30_MOCK_UTMI_CLK>, - <&gcc GCC_USB30_MASTER_CLK>; - assigned-clock-rates = <19200000>, <120000000>; - - interconnects = <&a2noc MASTER_USB3 &bimc SLAVE_EBI_CH0>, - <&bimc MASTER_AMPSS_M0 &snoc SLAVE_USB3>; - interconnect-names = "usb-ddr", "apps-usb"; - - power-domains = <&gcc USB30_GDSC>; - status = "disabled"; - - usb3_dwc3: usb@6a00000 { - compatible = "snps,dwc3"; - reg = <0x06a00000 0xcc00>; - interrupts = <GIC_SPI 131 IRQ_TYPE_LEVEL_HIGH>; - phys = <&hsusb_phy1>, <&ssusb_phy_0>; - phy-names = "usb2-phy", "usb3-phy"; - snps,hird-threshold = /bits/ 8 <0>; - snps,dis_u2_susphy_quirk; - snps,dis_enblslpm_quirk; - snps,is-utmi-l1-suspend; - tx-fifo-resize; - }; - }; - - usb3phy: phy@7410000 { - compatible = "qcom,msm8996-qmp-usb3-phy"; - reg = <0x07410000 0x1c4>; - #address-cells = <1>; - #size-cells = <1>; - ranges; - - clocks = <&gcc GCC_USB3_PHY_AUX_CLK>, - <&gcc GCC_USB_PHY_CFG_AHB2PHY_CLK>, - <&gcc GCC_USB3_CLKREF_CLK>; - clock-names = "aux", "cfg_ahb", "ref"; - - resets = <&gcc GCC_USB3_PHY_BCR>, - <&gcc GCC_USB3PHY_PHY_BCR>; - reset-names = "phy", "common"; - status = "disabled"; - - ssusb_phy_0: phy@7410200 { - reg = <0x07410200 0x200>, - <0x07410400 0x130>, - <0x07410600 0x1a8>; - #phy-cells = <0>; - - #clock-cells = <0>; - clock-output-names = "usb3_phy_pipe_clk_src"; - clocks = <&gcc GCC_USB3_PHY_PIPE_CLK>; - clock-names = "pipe0"; - }; - }; - - hsusb_phy1: phy@7411000 { - compatible = "qcom,msm8996-qusb2-phy"; - reg = <0x07411000 0x180>; - #phy-cells = <0>; - - clocks = <&gcc GCC_USB_PHY_CFG_AHB2PHY_CLK>, - <&gcc GCC_RX1_USB2_CLKREF_CLK>; - clock-names = "cfg_ahb", "ref"; - - resets = <&gcc GCC_QUSB2PHY_PRIM_BCR>; - nvmem-cells = <&qusb2p_hstx_trim>; - status = "disabled"; - }; - - hsusb_phy2: phy@7412000 { - compatible = "qcom,msm8996-qusb2-phy"; - reg = <0x07412000 0x180>; - #phy-cells = <0>; - - clocks = <&gcc GCC_USB_PHY_CFG_AHB2PHY_CLK>, - <&gcc GCC_RX2_USB2_CLKREF_CLK>; - clock-names = "cfg_ahb", "ref"; - - resets = <&gcc GCC_QUSB2PHY_SEC_BCR>; - nvmem-cells = <&qusb2s_hstx_trim>; - status = "disabled"; - }; - - sdhc1: mmc@7464900 { - compatible = "qcom,msm8996-sdhci", "qcom,sdhci-msm-v4"; - reg = <0x07464900 0x11c>, <0x07464000 0x800>; - reg-names = "hc", "core"; - - interrupts = <GIC_SPI 141 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 134 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "hc_irq", "pwr_irq"; - - clock-names = "iface", "core", "xo"; - clocks = <&gcc GCC_SDCC1_AHB_CLK>, - <&gcc GCC_SDCC1_APPS_CLK>, - <&rpmcc RPM_SMD_XO_CLK_SRC>; - resets = <&gcc GCC_SDCC1_BCR>; - - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&sdc1_state_on>; - pinctrl-1 = <&sdc1_state_off>; - - bus-width = <8>; - non-removable; - status = "disabled"; - }; - - sdhc2: mmc@74a4900 { - compatible = "qcom,msm8996-sdhci", "qcom,sdhci-msm-v4"; - reg = <0x074a4900 0x314>, <0x074a4000 0x800>; - reg-names = "hc", "core"; - - interrupts = <GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 221 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "hc_irq", "pwr_irq"; - - clock-names = "iface", "core", "xo"; - clocks = <&gcc GCC_SDCC2_AHB_CLK>, - <&gcc GCC_SDCC2_APPS_CLK>, - <&rpmcc RPM_SMD_XO_CLK_SRC>; - resets = <&gcc GCC_SDCC2_BCR>; - - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&sdc2_state_on>; - pinctrl-1 = <&sdc2_state_off>; - - bus-width = <4>; - status = "disabled"; - }; - - blsp1_dma: dma-controller@7544000 { - compatible = "qcom,bam-v1.7.0"; - reg = <0x07544000 0x2b000>; - interrupts = <GIC_SPI 238 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP1_AHB_CLK>; - clock-names = "bam_clk"; - qcom,controlled-remotely; - #dma-cells = <1>; - qcom,ee = <0>; - }; - - blsp1_uart2: serial@7570000 { - compatible = "qcom,msm-uartdm-v1.4", "qcom,msm-uartdm"; - reg = <0x07570000 0x1000>; - interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP1_UART2_APPS_CLK>, - <&gcc GCC_BLSP1_AHB_CLK>; - clock-names = "core", "iface"; - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&blsp1_uart2_default>; - pinctrl-1 = <&blsp1_uart2_sleep>; - dmas = <&blsp1_dma 2>, <&blsp1_dma 3>; - dma-names = "tx", "rx"; - status = "disabled"; - }; - - blsp1_spi1: spi@7575000 { - compatible = "qcom,spi-qup-v2.2.1"; - reg = <0x07575000 0x600>; - interrupts = <GIC_SPI 95 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP1_QUP1_SPI_APPS_CLK>, - <&gcc GCC_BLSP1_AHB_CLK>; - clock-names = "core", "iface"; - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&blsp1_spi1_default>; - pinctrl-1 = <&blsp1_spi1_sleep>; - dmas = <&blsp1_dma 12>, <&blsp1_dma 13>; - dma-names = "tx", "rx"; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - blsp1_i2c3: i2c@7577000 { - compatible = "qcom,i2c-qup-v2.2.1"; - reg = <0x07577000 0x1000>; - interrupts = <GIC_SPI 97 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP1_QUP3_I2C_APPS_CLK>, - <&gcc GCC_BLSP1_AHB_CLK>; - clock-names = "core", "iface"; - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&blsp1_i2c3_default>; - pinctrl-1 = <&blsp1_i2c3_sleep>; - dmas = <&blsp1_dma 16>, <&blsp1_dma 17>; - dma-names = "tx", "rx"; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - blsp1_i2c6: i2c@757a000 { - compatible = "qcom,i2c-qup-v2.2.1"; - reg = <0x757a000 0x1000>; - interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP1_QUP6_I2C_APPS_CLK>, - <&gcc GCC_BLSP1_AHB_CLK>; - clock-names = "core", "iface"; - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&blsp1_i2c6_default>; - pinctrl-1 = <&blsp1_i2c6_sleep>; - dmas = <&blsp1_dma 22>, <&blsp1_dma 23>; - dma-names = "tx", "rx"; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - blsp2_dma: dma-controller@7584000 { - compatible = "qcom,bam-v1.7.0"; - reg = <0x07584000 0x2b000>; - interrupts = <GIC_SPI 239 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP2_AHB_CLK>; - clock-names = "bam_clk"; - qcom,controlled-remotely; - #dma-cells = <1>; - qcom,ee = <0>; - }; - - blsp2_uart2: serial@75b0000 { - compatible = "qcom,msm-uartdm-v1.4", "qcom,msm-uartdm"; - reg = <0x075b0000 0x1000>; - interrupts = <GIC_SPI 114 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP2_UART2_APPS_CLK>, - <&gcc GCC_BLSP2_AHB_CLK>; - clock-names = "core", "iface"; - status = "disabled"; - }; - - blsp2_uart3: serial@75b1000 { - compatible = "qcom,msm-uartdm-v1.4", "qcom,msm-uartdm"; - reg = <0x075b1000 0x1000>; - interrupts = <GIC_SPI 115 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP2_UART3_APPS_CLK>, - <&gcc GCC_BLSP2_AHB_CLK>; - clock-names = "core", "iface"; - status = "disabled"; - }; - - blsp2_i2c1: i2c@75b5000 { - compatible = "qcom,i2c-qup-v2.2.1"; - reg = <0x075b5000 0x1000>; - interrupts = <GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP2_QUP1_I2C_APPS_CLK>, - <&gcc GCC_BLSP2_AHB_CLK>; - clock-names = "core", "iface"; - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&blsp2_i2c1_default>; - pinctrl-1 = <&blsp2_i2c1_sleep>; - dmas = <&blsp2_dma 12>, <&blsp2_dma 13>; - dma-names = "tx", "rx"; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - blsp2_i2c2: i2c@75b6000 { - compatible = "qcom,i2c-qup-v2.2.1"; - reg = <0x075b6000 0x1000>; - interrupts = <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP2_QUP2_I2C_APPS_CLK>, - <&gcc GCC_BLSP2_AHB_CLK>; - clock-names = "core", "iface"; - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&blsp2_i2c2_default>; - pinctrl-1 = <&blsp2_i2c2_sleep>; - dmas = <&blsp2_dma 14>, <&blsp2_dma 15>; - dma-names = "tx", "rx"; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - blsp2_i2c3: i2c@75b7000 { - compatible = "qcom,i2c-qup-v2.2.1"; - reg = <0x075b7000 0x1000>; - interrupts = <GIC_SPI 103 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP2_QUP3_I2C_APPS_CLK>, - <&gcc GCC_BLSP2_AHB_CLK>; - clock-names = "core", "iface"; - clock-frequency = <400000>; - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&blsp2_i2c3_default>; - pinctrl-1 = <&blsp2_i2c3_sleep>; - dmas = <&blsp2_dma 16>, <&blsp2_dma 17>; - dma-names = "tx", "rx"; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - blsp2_i2c5: i2c@75b9000 { - compatible = "qcom,i2c-qup-v2.2.1"; - reg = <0x75b9000 0x1000>; - interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP2_QUP5_I2C_APPS_CLK>, - <&gcc GCC_BLSP2_AHB_CLK>; - clock-names = "core", "iface"; - pinctrl-names = "default"; - pinctrl-0 = <&blsp2_i2c5_default>; - dmas = <&blsp2_dma 20>, <&blsp2_dma 21>; - dma-names = "tx", "rx"; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - blsp2_i2c6: i2c@75ba000 { - compatible = "qcom,i2c-qup-v2.2.1"; - reg = <0x75ba000 0x1000>; - interrupts = <GIC_SPI 106 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP2_QUP6_I2C_APPS_CLK>, - <&gcc GCC_BLSP2_AHB_CLK>; - clock-names = "core", "iface"; - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&blsp2_i2c6_default>; - pinctrl-1 = <&blsp2_i2c6_sleep>; - dmas = <&blsp2_dma 22>, <&blsp2_dma 23>; - dma-names = "tx", "rx"; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - blsp2_spi6: spi@75ba000 { - compatible = "qcom,spi-qup-v2.2.1"; - reg = <0x075ba000 0x600>; - interrupts = <GIC_SPI 106 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP2_QUP6_SPI_APPS_CLK>, - <&gcc GCC_BLSP2_AHB_CLK>; - clock-names = "core", "iface"; - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&blsp2_spi6_default>; - pinctrl-1 = <&blsp2_spi6_sleep>; - dmas = <&blsp2_dma 22>, <&blsp2_dma 23>; - dma-names = "tx", "rx"; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - usb2: usb@76f8800 { - compatible = "qcom,msm8996-dwc3", "qcom,dwc3"; - reg = <0x076f8800 0x400>; - #address-cells = <1>; - #size-cells = <1>; - ranges; - - interrupts = <GIC_SPI 352 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "hs_phy_irq"; - - clocks = <&gcc GCC_PERIPH_NOC_USB20_AHB_CLK>, - <&gcc GCC_USB20_MASTER_CLK>, - <&gcc GCC_USB20_MOCK_UTMI_CLK>, - <&gcc GCC_USB20_SLEEP_CLK>, - <&gcc GCC_USB_PHY_CFG_AHB2PHY_CLK>; - clock-names = "cfg_noc", - "core", - "iface", - "sleep", - "mock_utmi"; - - assigned-clocks = <&gcc GCC_USB20_MOCK_UTMI_CLK>, - <&gcc GCC_USB20_MASTER_CLK>; - assigned-clock-rates = <19200000>, <60000000>; - - power-domains = <&gcc USB30_GDSC>; - qcom,select-utmi-as-pipe-clk; - status = "disabled"; - - usb2_dwc3: usb@7600000 { - compatible = "snps,dwc3"; - reg = <0x07600000 0xcc00>; - interrupts = <GIC_SPI 138 IRQ_TYPE_LEVEL_HIGH>; - phys = <&hsusb_phy2>; - phy-names = "usb2-phy"; - maximum-speed = "high-speed"; - snps,dis_u2_susphy_quirk; - snps,dis_enblslpm_quirk; - }; - }; - - slimbam: dma-controller@9184000 { - compatible = "qcom,bam-v1.7.0"; - qcom,controlled-remotely; - reg = <0x09184000 0x32000>; - num-channels = <31>; - interrupts = <GIC_SPI 164 IRQ_TYPE_LEVEL_HIGH>; - #dma-cells = <1>; - qcom,ee = <1>; - qcom,num-ees = <2>; - }; - - slim_msm: slim-ngd@91c0000 { - compatible = "qcom,slim-ngd-v1.5.0"; - reg = <0x091c0000 0x2c000>; - interrupts = <GIC_SPI 163 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&slimbam 3>, <&slimbam 4>; - dma-names = "rx", "tx"; - #address-cells = <1>; - #size-cells = <0>; - - status = "disabled"; - }; - - adsp_pil: remoteproc@9300000 { - compatible = "qcom,msm8996-adsp-pil"; - reg = <0x09300000 0x80000>; - - interrupts-extended = <&intc 0 162 IRQ_TYPE_EDGE_RISING>, - <&adsp_smp2p_in 0 IRQ_TYPE_EDGE_RISING>, - <&adsp_smp2p_in 1 IRQ_TYPE_EDGE_RISING>, - <&adsp_smp2p_in 2 IRQ_TYPE_EDGE_RISING>, - <&adsp_smp2p_in 3 IRQ_TYPE_EDGE_RISING>; - interrupt-names = "wdog", "fatal", "ready", - "handover", "stop-ack"; - - clocks = <&rpmcc RPM_SMD_XO_CLK_SRC>; - clock-names = "xo"; - - memory-region = <&adsp_mem>; - - qcom,smem-states = <&adsp_smp2p_out 0>; - qcom,smem-state-names = "stop"; - - power-domains = <&rpmpd MSM8996_VDDCX>; - power-domain-names = "cx"; - - status = "disabled"; - - smd-edge { - interrupts = <GIC_SPI 156 IRQ_TYPE_EDGE_RISING>; - - label = "lpass"; - mboxes = <&apcs_glb 8>; - qcom,smd-edge = <1>; - qcom,remote-pid = <2>; - - apr { - power-domains = <&gcc HLOS1_VOTE_LPASS_ADSP_GDSC>; - compatible = "qcom,apr-v2"; - qcom,smd-channels = "apr_audio_svc"; - qcom,domain = <APR_DOMAIN_ADSP>; - #address-cells = <1>; - #size-cells = <0>; - - service@3 { - reg = <APR_SVC_ADSP_CORE>; - compatible = "qcom,q6core"; - }; - - q6afe: service@4 { - compatible = "qcom,q6afe"; - reg = <APR_SVC_AFE>; - q6afedai: dais { - compatible = "qcom,q6afe-dais"; - #address-cells = <1>; - #size-cells = <0>; - #sound-dai-cells = <1>; - dai@1 { - reg = <1>; - }; - }; - }; - - q6asm: service@7 { - compatible = "qcom,q6asm"; - reg = <APR_SVC_ASM>; - q6asmdai: dais { - compatible = "qcom,q6asm-dais"; - #address-cells = <1>; - #size-cells = <0>; - #sound-dai-cells = <1>; - iommus = <&lpass_q6_smmu 1>; - }; - }; - - q6adm: service@8 { - compatible = "qcom,q6adm"; - reg = <APR_SVC_ADM>; - q6routing: routing { - compatible = "qcom,q6adm-routing"; - #sound-dai-cells = <0>; - }; - }; - }; - }; - }; - - apcs_glb: mailbox@9820000 { - compatible = "qcom,msm8996-apcs-hmss-global"; - reg = <0x09820000 0x1000>; - - #mbox-cells = <1>; - #clock-cells = <0>; - }; - - timer@9840000 { - #address-cells = <1>; - #size-cells = <1>; - ranges; - compatible = "arm,armv7-timer-mem"; - reg = <0x09840000 0x1000>; - clock-frequency = <19200000>; - - frame@9850000 { - frame-number = <0>; - interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; - reg = <0x09850000 0x1000>, - <0x09860000 0x1000>; - }; - - frame@9870000 { - frame-number = <1>; - interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; - reg = <0x09870000 0x1000>; - status = "disabled"; - }; - - frame@9880000 { - frame-number = <2>; - interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; - reg = <0x09880000 0x1000>; - status = "disabled"; - }; - - frame@9890000 { - frame-number = <3>; - interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>; - reg = <0x09890000 0x1000>; - status = "disabled"; - }; - - frame@98a0000 { - frame-number = <4>; - interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>; - reg = <0x098a0000 0x1000>; - status = "disabled"; - }; - - frame@98b0000 { - frame-number = <5>; - interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>; - reg = <0x098b0000 0x1000>; - status = "disabled"; - }; - - frame@98c0000 { - frame-number = <6>; - interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>; - reg = <0x098c0000 0x1000>; - status = "disabled"; - }; - }; - - saw3: syscon@9a10000 { - compatible = "syscon"; - reg = <0x09a10000 0x1000>; - }; - - cbf: clock-controller@9a11000 { - compatible = "qcom,msm8996-cbf"; - reg = <0x09a11000 0x10000>; - clocks = <&rpmcc RPM_SMD_XO_A_CLK_SRC>, <&apcs_glb>; - #clock-cells = <0>; - #interconnect-cells = <1>; - }; - - intc: interrupt-controller@9bc0000 { - compatible = "qcom,msm8996-gic-v3", "arm,gic-v3"; - #interrupt-cells = <3>; - interrupt-controller; - #redistributor-regions = <1>; - redistributor-stride = <0x0 0x40000>; - reg = <0x09bc0000 0x10000>, - <0x09c00000 0x100000>; - interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH>; - }; - }; - - sound: sound { - }; - - thermal-zones { - cpu0-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens0 3>; - - trips { - cpu0_alert0: trip-point0 { - temperature = <75000>; - hysteresis = <2000>; - type = "passive"; - }; - - cpu0_crit: cpu-crit { - temperature = <110000>; - hysteresis = <2000>; - type = "critical"; - }; - }; - }; - - cpu1-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens0 5>; - - trips { - cpu1_alert0: trip-point0 { - temperature = <75000>; - hysteresis = <2000>; - type = "passive"; - }; - - cpu1_crit: cpu-crit { - temperature = <110000>; - hysteresis = <2000>; - type = "critical"; - }; - }; - }; - - cpu2-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens0 8>; - - trips { - cpu2_alert0: trip-point0 { - temperature = <75000>; - hysteresis = <2000>; - type = "passive"; - }; - - cpu2_crit: cpu-crit { - temperature = <110000>; - hysteresis = <2000>; - type = "critical"; - }; - }; - }; - - cpu3-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens0 10>; - - trips { - cpu3_alert0: trip-point0 { - temperature = <75000>; - hysteresis = <2000>; - type = "passive"; - }; - - cpu3_crit: cpu-crit { - temperature = <110000>; - hysteresis = <2000>; - type = "critical"; - }; - }; - }; - - gpu-top-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens1 6>; - - trips { - gpu1_alert0: trip-point0 { - temperature = <90000>; - hysteresis = <2000>; - type = "passive"; - }; - }; - - cooling-maps { - map0 { - trip = <&gpu1_alert0>; - cooling-device = <&gpu THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; - }; - }; - }; - - gpu-bottom-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens1 7>; - - trips { - gpu2_alert0: trip-point0 { - temperature = <90000>; - hysteresis = <2000>; - type = "passive"; - }; - }; - - cooling-maps { - map0 { - trip = <&gpu2_alert0>; - cooling-device = <&gpu THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; - }; - }; - }; - - m4m-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens0 1>; - - trips { - m4m_alert0: trip-point0 { - temperature = <90000>; - hysteresis = <2000>; - type = "hot"; - }; - }; - }; - - l3-or-venus-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens0 2>; - - trips { - l3_or_venus_alert0: trip-point0 { - temperature = <90000>; - hysteresis = <2000>; - type = "hot"; - }; - }; - }; - - cluster0-l2-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens0 7>; - - trips { - cluster0_l2_alert0: trip-point0 { - temperature = <90000>; - hysteresis = <2000>; - type = "hot"; - }; - }; - }; - - cluster1-l2-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens0 12>; - - trips { - cluster1_l2_alert0: trip-point0 { - temperature = <90000>; - hysteresis = <2000>; - type = "hot"; - }; - }; - }; - - camera-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens1 1>; - - trips { - camera_alert0: trip-point0 { - temperature = <90000>; - hysteresis = <2000>; - type = "hot"; - }; - }; - }; - - q6-dsp-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens1 2>; - - trips { - q6_dsp_alert0: trip-point0 { - temperature = <90000>; - hysteresis = <2000>; - type = "hot"; - }; - }; - }; - - mem-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens1 3>; - - trips { - mem_alert0: trip-point0 { - temperature = <90000>; - hysteresis = <2000>; - type = "hot"; - }; - }; - }; - - modemtx-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens1 4>; - - trips { - modemtx_alert0: trip-point0 { - temperature = <90000>; - hysteresis = <2000>; - type = "hot"; - }; - }; - }; - }; - - timer { - compatible = "arm,armv8-timer"; - interrupts = <GIC_PPI 13 IRQ_TYPE_LEVEL_LOW>, - <GIC_PPI 14 IRQ_TYPE_LEVEL_LOW>, - <GIC_PPI 11 IRQ_TYPE_LEVEL_LOW>, - <GIC_PPI 10 IRQ_TYPE_LEVEL_LOW>; - }; -}; diff --git a/arch/arm/dts/pm8916.dtsi b/arch/arm/dts/pm8916.dtsi deleted file mode 100644 index f4de86787743..000000000000 --- a/arch/arm/dts/pm8916.dtsi +++ /dev/null @@ -1,178 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -#include <dt-bindings/iio/qcom,spmi-vadc.h> -#include <dt-bindings/input/linux-event-codes.h> -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/spmi/spmi.h> - -&spmi_bus { - - pm8916_0: pmic@0 { - compatible = "qcom,pm8916", "qcom,spmi-pmic"; - reg = <0x0 SPMI_USID>; - #address-cells = <1>; - #size-cells = <0>; - - pon@800 { - compatible = "qcom,pm8916-pon"; - reg = <0x800>; - mode-bootloader = <0x2>; - mode-recovery = <0x1>; - - pwrkey { - compatible = "qcom,pm8941-pwrkey"; - interrupts = <0x0 0x8 0 IRQ_TYPE_EDGE_BOTH>; - debounce = <15625>; - bias-pull-up; - linux,code = <KEY_POWER>; - }; - - pm8916_resin: resin { - compatible = "qcom,pm8941-resin"; - interrupts = <0x0 0x8 1 IRQ_TYPE_EDGE_BOTH>; - debounce = <15625>; - bias-pull-up; - status = "disabled"; - }; - - watchdog { - compatible = "qcom,pm8916-wdt"; - interrupts = <0x0 0x8 6 IRQ_TYPE_EDGE_RISING>; - timeout-sec = <60>; - }; - }; - - pm8916_usbin: usb-detect@1300 { - compatible = "qcom,pm8941-misc"; - reg = <0x1300>; - interrupts = <0x0 0x13 1 IRQ_TYPE_EDGE_BOTH>; - interrupt-names = "usb_vbus"; - status = "disabled"; - }; - - pm8916_temp: temp-alarm@2400 { - compatible = "qcom,spmi-temp-alarm"; - reg = <0x2400>; - interrupts = <0 0x24 0 IRQ_TYPE_EDGE_RISING>; - io-channels = <&pm8916_vadc VADC_DIE_TEMP>; - io-channel-names = "thermal"; - #thermal-sensor-cells = <0>; - }; - - pm8916_vadc: adc@3100 { - compatible = "qcom,spmi-vadc"; - reg = <0x3100>; - interrupts = <0x0 0x31 0x0 IRQ_TYPE_EDGE_RISING>; - #address-cells = <1>; - #size-cells = <0>; - #io-channel-cells = <1>; - - channel@0 { - reg = <VADC_USBIN>; - qcom,pre-scaling = <1 10>; - }; - channel@7 { - reg = <VADC_VSYS>; - qcom,pre-scaling = <1 3>; - }; - channel@8 { - reg = <VADC_DIE_TEMP>; - }; - channel@9 { - reg = <VADC_REF_625MV>; - }; - channel@a { - reg = <VADC_REF_1250MV>; - }; - channel@e { - reg = <VADC_GND_REF>; - }; - channel@f { - reg = <VADC_VDD_VADC>; - }; - }; - - rtc@6000 { - compatible = "qcom,pm8941-rtc"; - reg = <0x6000>, <0x6100>; - reg-names = "rtc", "alarm"; - interrupts = <0x0 0x61 0x1 IRQ_TYPE_EDGE_RISING>; - }; - - pm8916_mpps: mpps@a000 { - compatible = "qcom,pm8916-mpp", "qcom,spmi-mpp"; - reg = <0xa000>; - gpio-controller; - #gpio-cells = <2>; - gpio-ranges = <&pm8916_mpps 0 0 4>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - pm8916_gpios: gpio@c000 { - compatible = "qcom,pm8916-gpio", "qcom,spmi-gpio"; - reg = <0xc000>; - gpio-controller; - gpio-ranges = <&pm8916_gpios 0 0 4>; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - }; - }; - - pm8916_1: pmic@1 { - compatible = "qcom,pm8916", "qcom,spmi-pmic"; - reg = <0x1 SPMI_USID>; - #address-cells = <1>; - #size-cells = <0>; - - pm8916_pwm: pwm { - compatible = "qcom,pm8916-pwm"; - - #pwm-cells = <2>; - - status = "disabled"; - }; - - pm8916_vib: vibrator@c000 { - compatible = "qcom,pm8916-vib"; - reg = <0xc000>; - status = "disabled"; - }; - - pm8916_codec: audio-codec@f000 { - compatible = "qcom,pm8916-wcd-analog-codec"; - reg = <0xf000>; - interrupt-parent = <&spmi_bus>; - interrupts = <0x1 0xf0 0x0 IRQ_TYPE_NONE>, - <0x1 0xf0 0x1 IRQ_TYPE_NONE>, - <0x1 0xf0 0x2 IRQ_TYPE_NONE>, - <0x1 0xf0 0x3 IRQ_TYPE_NONE>, - <0x1 0xf0 0x4 IRQ_TYPE_NONE>, - <0x1 0xf0 0x5 IRQ_TYPE_NONE>, - <0x1 0xf0 0x6 IRQ_TYPE_NONE>, - <0x1 0xf0 0x7 IRQ_TYPE_NONE>, - <0x1 0xf1 0x0 IRQ_TYPE_NONE>, - <0x1 0xf1 0x1 IRQ_TYPE_NONE>, - <0x1 0xf1 0x2 IRQ_TYPE_NONE>, - <0x1 0xf1 0x3 IRQ_TYPE_NONE>, - <0x1 0xf1 0x4 IRQ_TYPE_NONE>, - <0x1 0xf1 0x5 IRQ_TYPE_NONE>; - interrupt-names = "cdc_spk_cnp_int", - "cdc_spk_clip_int", - "cdc_spk_ocp_int", - "mbhc_ins_rem_det1", - "mbhc_but_rel_det", - "mbhc_but_press_det", - "mbhc_ins_rem_det", - "mbhc_switch_int", - "cdc_ear_ocp_int", - "cdc_hphr_ocp_int", - "cdc_hphl_ocp_det", - "cdc_ear_cnp_int", - "cdc_hphr_cnp_int", - "cdc_hphl_cnp_int"; - #sound-dai-cells = <1>; - status = "disabled"; - }; - }; -}; diff --git a/arch/arm/dts/pm8994.dtsi b/arch/arm/dts/pm8994.dtsi deleted file mode 100644 index d44a95caf04a..000000000000 --- a/arch/arm/dts/pm8994.dtsi +++ /dev/null @@ -1,152 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -#include <dt-bindings/iio/qcom,spmi-vadc.h> -#include <dt-bindings/input/linux-event-codes.h> -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/spmi/spmi.h> - -/ { - thermal-zones { - pm8994-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&pm8994_temp>; - - trips { - pm8994_alert0: pm8994-alert0 { - temperature = <95000>; - hysteresis = <2000>; - type = "passive"; - }; - pm8994_crit: pm8994-crit { - temperature = <125000>; - hysteresis = <2000>; - type = "critical"; - }; - }; - }; - }; -}; - -&spmi_bus { - - pmic@0 { - compatible = "qcom,pm8994", "qcom,spmi-pmic"; - reg = <0x0 SPMI_USID>; - #address-cells = <1>; - #size-cells = <0>; - - rtc@6000 { - compatible = "qcom,pm8941-rtc"; - reg = <0x6000>, <0x6100>; - reg-names = "rtc", "alarm"; - interrupts = <0x0 0x61 0x1 IRQ_TYPE_EDGE_RISING>; - }; - - pm8994_pon: pon@800 { - compatible = "qcom,pm8916-pon"; - reg = <0x800>; - mode-bootloader = <0x2>; - mode-recovery = <0x1>; - - pwrkey { - compatible = "qcom,pm8941-pwrkey"; - interrupts = <0x0 0x8 0 IRQ_TYPE_EDGE_BOTH>; - debounce = <15625>; - bias-pull-up; - linux,code = <KEY_POWER>; - }; - - pm8994_resin: resin { - compatible = "qcom,pm8941-resin"; - interrupts = <0x0 0x8 1 IRQ_TYPE_EDGE_BOTH>; - debounce = <15625>; - bias-pull-up; - status = "disabled"; - }; - }; - - pm8994_temp: temp-alarm@2400 { - compatible = "qcom,spmi-temp-alarm"; - reg = <0x2400>; - interrupts = <0x0 0x24 0x0 IRQ_TYPE_EDGE_RISING>; - io-channels = <&pm8994_vadc VADC_DIE_TEMP>; - io-channel-names = "thermal"; - #thermal-sensor-cells = <0>; - }; - - pm8994_vadc: adc@3100 { - compatible = "qcom,spmi-vadc"; - reg = <0x3100>; - interrupts = <0x0 0x31 0x0 IRQ_TYPE_EDGE_RISING>; - #address-cells = <1>; - #size-cells = <0>; - #io-channel-cells = <1>; - - channel@7 { - reg = <VADC_VSYS>; - qcom,pre-scaling = <1 3>; - label = "vph_pwr"; - }; - channel@8 { - reg = <VADC_DIE_TEMP>; - label = "die_temp"; - }; - channel@9 { - reg = <VADC_REF_625MV>; - label = "ref_625mv"; - }; - channel@a { - reg = <VADC_REF_1250MV>; - label = "ref_1250mv"; - }; - channel@e { - reg = <VADC_GND_REF>; - }; - channel@f { - reg = <VADC_VDD_VADC>; - }; - }; - - pm8994_gpios: gpio@c000 { - compatible = "qcom,pm8994-gpio", "qcom,spmi-gpio"; - reg = <0xc000>; - gpio-controller; - gpio-ranges = <&pm8994_gpios 0 0 22>; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - pm8994_mpps: mpps@a000 { - compatible = "qcom,pm8994-mpp", "qcom,spmi-mpp"; - reg = <0xa000>; - gpio-controller; - #gpio-cells = <2>; - gpio-ranges = <&pm8994_mpps 0 0 8>; - interrupt-controller; - #interrupt-cells = <2>; - }; - }; - - pmic@1 { - compatible = "qcom,pm8994", "qcom,spmi-pmic"; - reg = <0x1 SPMI_USID>; - #address-cells = <1>; - #size-cells = <0>; - - pm8994_lpg: pwm { - compatible = "qcom,pm8994-lpg"; - - #address-cells = <1>; - #size-cells = <0>; - #pwm-cells = <2>; - - status = "disabled"; - }; - - pm8994_spmi_regulators: regulators { - compatible = "qcom,pm8994-regulators"; - }; - }; -}; diff --git a/arch/arm/dts/pm8998.dtsi b/arch/arm/dts/pm8998.dtsi deleted file mode 100644 index 3f82715392c6..000000000000 --- a/arch/arm/dts/pm8998.dtsi +++ /dev/null @@ -1,130 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* Copyright 2018 Google LLC. */ - -#include <dt-bindings/iio/qcom,spmi-vadc.h> -#include <dt-bindings/input/linux-event-codes.h> -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/spmi/spmi.h> -#include <dt-bindings/thermal/thermal.h> - -/ { - thermal-zones { - pm8998-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&pm8998_temp>; - - trips { - pm8998_alert0: pm8998-alert0 { - temperature = <105000>; - hysteresis = <2000>; - type = "passive"; - }; - pm8998_crit: pm8998-crit { - temperature = <125000>; - hysteresis = <2000>; - type = "critical"; - }; - }; - }; - }; -}; - -&spmi_bus { - pm8998_lsid0: pmic@0 { - compatible = "qcom,pm8998", "qcom,spmi-pmic"; - reg = <0x0 SPMI_USID>; - #address-cells = <1>; - #size-cells = <0>; - - pm8998_pon: pon@800 { - compatible = "qcom,pm8998-pon"; - - reg = <0x800>; - mode-bootloader = <0x2>; - mode-recovery = <0x1>; - - pm8998_pwrkey: pwrkey { - compatible = "qcom,pm8941-pwrkey"; - interrupts = <0x0 0x8 0 IRQ_TYPE_EDGE_BOTH>; - debounce = <15625>; - bias-pull-up; - linux,code = <KEY_POWER>; - }; - - pm8998_resin: resin { - compatible = "qcom,pm8941-resin"; - interrupts = <0x0 0x8 1 IRQ_TYPE_EDGE_BOTH>; - debounce = <15625>; - bias-pull-up; - status = "disabled"; - }; - }; - - pm8998_temp: temp-alarm@2400 { - compatible = "qcom,spmi-temp-alarm"; - reg = <0x2400>; - interrupts = <0x0 0x24 0x0 IRQ_TYPE_EDGE_RISING>; - io-channels = <&pm8998_adc ADC5_DIE_TEMP>; - io-channel-names = "thermal"; - #thermal-sensor-cells = <0>; - }; - - pm8998_coincell: charger@2800 { - compatible = "qcom,pm8998-coincell", "qcom,pm8941-coincell"; - reg = <0x2800>; - - status = "disabled"; - }; - - pm8998_adc: adc@3100 { - compatible = "qcom,spmi-adc-rev2"; - reg = <0x3100>; - interrupts = <0x0 0x31 0x0 IRQ_TYPE_EDGE_RISING>; - #address-cells = <1>; - #size-cells = <0>; - #io-channel-cells = <1>; - - channel@6 { - reg = <ADC5_DIE_TEMP>; - label = "die_temp"; - }; - }; - - pm8998_adc_tm: adc-tm@3400 { - compatible = "qcom,spmi-adc-tm-hc"; - reg = <0x3400>; - interrupts = <0x0 0x34 0x0 IRQ_TYPE_EDGE_RISING>; - #thermal-sensor-cells = <1>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - rtc@6000 { - compatible = "qcom,pm8941-rtc"; - reg = <0x6000>, <0x6100>; - reg-names = "rtc", "alarm"; - interrupts = <0x0 0x61 0x1 IRQ_TYPE_EDGE_RISING>; - }; - - pm8998_gpios: gpio@c000 { - compatible = "qcom,pm8998-gpio", "qcom,spmi-gpio"; - reg = <0xc000>; - gpio-controller; - gpio-ranges = <&pm8998_gpios 0 0 26>; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - }; - - pm8998_lsid1: pmic@1 { - compatible = "qcom,pm8998", "qcom,spmi-pmic"; - reg = <0x1 SPMI_USID>; - #address-cells = <1>; - #size-cells = <0>; - }; -}; diff --git a/arch/arm/dts/pmi8994.dtsi b/arch/arm/dts/pmi8994.dtsi deleted file mode 100644 index 36d6a1fb553a..000000000000 --- a/arch/arm/dts/pmi8994.dtsi +++ /dev/null @@ -1,65 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/spmi/spmi.h> - -&spmi_bus { - - pmic@2 { - compatible = "qcom,pmi8994", "qcom,spmi-pmic"; - reg = <0x2 SPMI_USID>; - #address-cells = <1>; - #size-cells = <0>; - - pmi8994_gpios: gpio@c000 { - compatible = "qcom,pmi8994-gpio", "qcom,spmi-gpio"; - reg = <0xc000>; - gpio-controller; - gpio-ranges = <&pmi8994_gpios 0 0 10>; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - pmi8994_mpps: mpps@a000 { - compatible = "qcom,pmi8994-mpp", "qcom,spmi-mpp"; - reg = <0xa000>; - gpio-controller; - gpio-ranges = <&pmi8994_mpps 0 0 4>; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - }; - }; - - pmic@3 { - compatible = "qcom,pmi8994", "qcom,spmi-pmic"; - reg = <0x3 SPMI_USID>; - #address-cells = <1>; - #size-cells = <0>; - - pmi8994_lpg: pwm { - compatible = "qcom,pmi8994-lpg"; - - #address-cells = <1>; - #size-cells = <0>; - #pwm-cells = <2>; - - status = "disabled"; - }; - - pmi8994_spmi_regulators: regulators { - compatible = "qcom,pmi8994-regulators"; - }; - - pmi8994_wled: wled@d800 { - compatible = "qcom,pmi8994-wled"; - reg = <0xd800>, <0xd900>; - interrupts = <0x3 0xd8 0x1 IRQ_TYPE_EDGE_RISING>, - <0x3 0xd8 0x2 IRQ_TYPE_EDGE_RISING>; - interrupt-names = "ovp", "short"; - qcom,cabc; - qcom,external-pfet; - status = "disabled"; - }; - }; -}; diff --git a/arch/arm/dts/pmi8998.dtsi b/arch/arm/dts/pmi8998.dtsi deleted file mode 100644 index cd3f0790fd42..000000000000 --- a/arch/arm/dts/pmi8998.dtsi +++ /dev/null @@ -1,98 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/spmi/spmi.h> - -&spmi_bus { - pmi8998_lsid0: pmic@2 { - compatible = "qcom,pmi8998", "qcom,spmi-pmic"; - reg = <0x2 SPMI_USID>; - #address-cells = <1>; - #size-cells = <0>; - - pmi8998_charger: charger@1000 { - compatible = "qcom,pmi8998-charger"; - reg = <0x1000>; - - interrupts = <0x2 0x13 0x4 IRQ_TYPE_EDGE_BOTH>, - <0x2 0x12 0x2 IRQ_TYPE_EDGE_BOTH>, - <0x2 0x16 0x1 IRQ_TYPE_EDGE_RISING>, - <0x2 0x13 0x6 IRQ_TYPE_EDGE_RISING>; - interrupt-names = "usb-plugin", - "bat-ov", - "wdog-bark", - "usbin-icl-change"; - - io-channels = <&pmi8998_rradc 3>, - <&pmi8998_rradc 4>; - io-channel-names = "usbin_i", "usbin_v"; - - status = "disabled"; - }; - - pmi8998_gpios: gpio@c000 { - compatible = "qcom,pmi8998-gpio", "qcom,spmi-gpio"; - reg = <0xc000>; - gpio-controller; - gpio-ranges = <&pmi8998_gpios 0 0 14>; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - pmi8998_rradc: adc@4500 { - compatible = "qcom,pmi8998-rradc"; - reg = <0x4500>; - #io-channel-cells = <1>; - }; - }; - - pmi8998_lsid1: pmic@3 { - compatible = "qcom,pmi8998", "qcom,spmi-pmic"; - reg = <0x3 SPMI_USID>; - #address-cells = <1>; - #size-cells = <0>; - - labibb { - compatible = "qcom,pmi8998-lab-ibb"; - - ibb: ibb { - interrupts = <0x3 0xdc 0x2 IRQ_TYPE_EDGE_RISING>, - <0x3 0xdc 0x0 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "sc-err", "ocp"; - }; - - lab: lab { - interrupts = <0x3 0xde 0x1 IRQ_TYPE_EDGE_RISING>, - <0x3 0xde 0x0 IRQ_TYPE_LEVEL_LOW>; - interrupt-names = "sc-err", "ocp"; - }; - }; - - pmi8998_lpg: pwm { - compatible = "qcom,pmi8998-lpg"; - - #address-cells = <1>; - #size-cells = <0>; - #pwm-cells = <2>; - - status = "disabled"; - }; - - pmi8998_flash: led-controller@d300 { - compatible = "qcom,pmi8998-flash-led", "qcom,spmi-flash-led"; - reg = <0xd300>; - status = "disabled"; - }; - - pmi8998_wled: leds@d800 { - compatible = "qcom,pmi8998-wled"; - reg = <0xd800>, <0xd900>; - interrupts = <0x3 0xd8 0x1 IRQ_TYPE_EDGE_RISING>, - <0x3 0xd8 0x2 IRQ_TYPE_EDGE_RISING>; - interrupt-names = "ovp", "short"; - label = "backlight"; - - status = "disabled"; - }; - }; -}; diff --git a/arch/arm/dts/pms405.dtsi b/arch/arm/dts/pms405.dtsi deleted file mode 100644 index 461ad97032f7..000000000000 --- a/arch/arm/dts/pms405.dtsi +++ /dev/null @@ -1,149 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Copyright (c) 2018, Linaro Limited - */ - -#include <dt-bindings/spmi/spmi.h> -#include <dt-bindings/input/linux-event-codes.h> -#include <dt-bindings/iio/qcom,spmi-vadc.h> -#include <dt-bindings/thermal/thermal.h> - -/ { - thermal-zones { - pms405-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&pms405_temp>; - - trips { - pms405_alert0: pms405-alert0 { - temperature = <105000>; - hysteresis = <2000>; - type = "passive"; - }; - pms405_crit: pms405-crit { - temperature = <125000>; - hysteresis = <2000>; - type = "critical"; - }; - }; - }; - }; -}; - -&spmi_bus { - pms405_0: pms405@0 { - compatible = "qcom,pms405", "qcom,spmi-pmic"; - reg = <0x0 SPMI_USID>; - #address-cells = <1>; - #size-cells = <0>; - - pms405_gpios: gpio@c000 { - compatible = "qcom,pms405-gpio", "qcom,spmi-gpio"; - reg = <0xc000>; - gpio-controller; - gpio-ranges = <&pms405_gpios 0 0 12>; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - pon@800 { - compatible = "qcom,pms405-pon"; - reg = <0x0800>; - mode-bootloader = <0x2>; - mode-recovery = <0x1>; - - pwrkey { - compatible = "qcom,pm8941-pwrkey"; - interrupts = <0x0 0x8 0 IRQ_TYPE_EDGE_BOTH>; - debounce = <15625>; - bias-pull-up; - linux,code = <KEY_POWER>; - }; - }; - - pms405_temp: temp-alarm@2400 { - compatible = "qcom,spmi-temp-alarm"; - reg = <0x2400>; - interrupts = <0 0x24 0 IRQ_TYPE_EDGE_RISING>; - io-channels = <&pms405_adc ADC5_DIE_TEMP>; - io-channel-names = "thermal"; - #thermal-sensor-cells = <0>; - }; - - pms405_adc: adc@3100 { - compatible = "qcom,pms405-adc", "qcom,spmi-adc-rev2"; - reg = <0x3100>; - interrupts = <0x0 0x31 0x0 IRQ_TYPE_EDGE_RISING>; - #address-cells = <1>; - #size-cells = <0>; - #io-channel-cells = <1>; - - channel@0 { - reg = <ADC5_REF_GND>; - qcom,pre-scaling = <1 1>; - label = "ref_gnd"; - }; - - channel@1 { - reg = <ADC5_1P25VREF>; - qcom,pre-scaling = <1 1>; - label = "vref_1p25"; - }; - - channel@131 { - reg = <ADC5_VPH_PWR>; - qcom,pre-scaling = <1 3>; - label = "vph_pwr"; - }; - - channel@6 { - reg = <ADC5_DIE_TEMP>; - qcom,pre-scaling = <1 1>; - label = "die_temp"; - }; - - channel@77 { - reg = <ADC5_AMUX_THM1_100K_PU>; - qcom,ratiometric; - qcom,hw-settle-time = <200>; - qcom,pre-scaling = <1 1>; - label = "pa_therm1"; - }; - - channel@79 { - reg = <ADC5_AMUX_THM3_100K_PU>; - qcom,ratiometric; - qcom,hw-settle-time = <200>; - qcom,pre-scaling = <1 1>; - label = "pa_therm3"; - }; - - channel@76 { - reg = <ADC5_XO_THERM_100K_PU>; - qcom,ratiometric; - qcom,hw-settle-time = <200>; - qcom,pre-scaling = <1 1>; - label = "xo_therm"; - }; - }; - - rtc@6000 { - compatible = "qcom,pm8941-rtc"; - reg = <0x6000>, <0x6100>; - reg-names = "rtc", "alarm"; - interrupts = <0x0 0x61 0x1 IRQ_TYPE_NONE>; - }; - }; - - pms405_1: pms405@1 { - compatible = "qcom,pms405", "qcom,spmi-pmic"; - reg = <0x1 SPMI_USID>; - - pms405_spmi_regulators: regulators { - compatible = "qcom,pms405-regulators"; - }; - }; -}; diff --git a/arch/arm/dts/qcs404-evb-4000.dts b/arch/arm/dts/qcs404-evb-4000.dts deleted file mode 100644 index 358827c2fbd3..000000000000 --- a/arch/arm/dts/qcs404-evb-4000.dts +++ /dev/null @@ -1,96 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Copyright (c) 2018, Linaro Limited - */ - -/dts-v1/; - -#include <dt-bindings/gpio/gpio.h> -#include "qcs404-evb.dtsi" - -/ { - model = "Qualcomm Technologies, Inc. QCS404 EVB 4000"; - compatible = "qcom,qcs404-evb-4000", "qcom,qcs404-evb", - "qcom,qcs404"; -}; - -ðernet { - status = "okay"; - - snps,reset-gpio = <&tlmm 60 GPIO_ACTIVE_LOW>; - snps,reset-active-low; - snps,reset-delays-us = <0 10000 10000>; - - pinctrl-names = "default"; - pinctrl-0 = <ðernet_defaults>; - - phy-handle = <&phy1>; - phy-mode = "rgmii"; - mdio { - #address-cells = <1>; - #size-cells = <0>; - compatible = "snps,dwmac-mdio"; - phy1: phy@4 { - compatible = "ethernet-phy-ieee802.3-c22"; - device_type = "ethernet-phy"; - reg = <0x4>; - }; - }; -}; - -&tlmm { - ethernet_defaults: ethernet-defaults-state { - int-pins { - pins = "gpio61"; - function = "rgmii_int"; - bias-disable; - drive-strength = <2>; - }; - mdc-pins { - pins = "gpio76"; - function = "rgmii_mdc"; - bias-pull-up; - }; - mdio-pins { - pins = "gpio75"; - function = "rgmii_mdio"; - bias-pull-up; - }; - tx-pins { - pins = "gpio67", "gpio66", "gpio65", "gpio64"; - function = "rgmii_tx"; - bias-pull-up; - drive-strength = <16>; - }; - rx-pins { - pins = "gpio73", "gpio72", "gpio71", "gpio70"; - function = "rgmii_rx"; - bias-disable; - drive-strength = <2>; - }; - tx-ctl-pins { - pins = "gpio68"; - function = "rgmii_ctl"; - bias-pull-up; - drive-strength = <16>; - }; - rx-ctl-pins { - pins = "gpio74"; - function = "rgmii_ctl"; - bias-disable; - drive-strength = <2>; - }; - tx-ck-pins { - pins = "gpio63"; - function = "rgmii_ck"; - bias-pull-up; - drive-strength = <16>; - }; - rx-ck-pins { - pins = "gpio69"; - function = "rgmii_ck"; - bias-disable; - drive-strength = <2>; - }; - }; -}; diff --git a/arch/arm/dts/qcs404-evb.dtsi b/arch/arm/dts/qcs404-evb.dtsi deleted file mode 100644 index 10655401528e..000000000000 --- a/arch/arm/dts/qcs404-evb.dtsi +++ /dev/null @@ -1,389 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Copyright (c) 2018, Linaro Limited - */ - -#include <dt-bindings/gpio/gpio.h> -#include "qcs404.dtsi" -#include "pms405.dtsi" -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/pinctrl/qcom,pmic-gpio.h> - -/ { - aliases { - serial0 = &blsp1_uart2; - serial1 = &blsp1_uart3; - }; - - chosen { - stdout-path = "serial0"; - }; - - vph_pwr: vph-pwr-regulator { - compatible = "regulator-fixed"; - regulator-name = "vph_pwr"; - regulator-always-on; - regulator-boot-on; - }; - - vdd_ch0_3p3: - vdd_esmps3_3p3: vdd-esmps3-3p3-regulator { - compatible = "regulator-fixed"; - regulator-name = "eSMPS3_3P3"; - - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - }; - - usb3_vbus_reg: regulator-usb3-vbus { - compatible = "regulator-fixed"; - regulator-name = "VBUS_BOOST_5V"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - gpio = <&pms405_gpios 3 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&usb_vbus_boost_pin>; - vin-supply = <&vph_pwr>; - enable-active-high; - - /* TODO: Drop this when introducing role switching */ - regulator-always-on; - }; -}; - -&blsp1_uart3 { - status = "okay"; - - bluetooth { - compatible = "qcom,wcn3990-bt"; - vddio-supply = <&vreg_l6_1p8>; - vddxo-supply = <&vreg_l5_1p8>; - vddrf-supply = <&vreg_l1_1p3>; - vddch0-supply = <&vdd_ch0_3p3>; - - local-bd-address = [ 02 00 00 00 5a ad ]; - - max-speed = <3200000>; - }; -}; - -&blsp1_dma { - qcom,controlled-remotely; -}; - -&blsp2_dma { - qcom,controlled-remotely; -}; - -&gcc { - protected-clocks = <GCC_BIMC_CDSP_CLK>, - <GCC_CDSP_CFG_AHB_CLK>, - <GCC_CDSP_BIMC_CLK_SRC>, - <GCC_CDSP_TBU_CLK>, - <141>, /* GCC_WCSS_Q6_AHB_CLK */ - <142>; /* GCC_WCSS_Q6_AXIM_CLK */ -}; - -&pms405_spmi_regulators { - vdd_s3-supply = <&vph_pwr>; - - pms405_s3: s3 { - regulator-always-on; - regulator-boot-on; - regulator-name = "vdd_apc"; - regulator-initial-mode = <1>; - regulator-min-microvolt = <1048000>; - regulator-max-microvolt = <1384000>; - }; -}; - -&pcie { - status = "okay"; - - perst-gpios = <&tlmm 43 GPIO_ACTIVE_LOW>; - - pinctrl-names = "default"; - pinctrl-0 = <&perst_state>; -}; - -&pcie_phy { - status = "okay"; - - vdda-vp-supply = <&vreg_l3_1p05>; - vdda-vph-supply = <&vreg_l5_1p8>; -}; - -&remoteproc_adsp { - status = "okay"; -}; - -&remoteproc_cdsp { - status = "okay"; -}; - -&remoteproc_wcss { - status = "okay"; -}; - -&rpm_requests { - regulators { - compatible = "qcom,rpm-pms405-regulators"; - - vdd_s1-supply = <&vph_pwr>; - vdd_s2-supply = <&vph_pwr>; - vdd_s3-supply = <&vph_pwr>; - vdd_s4-supply = <&vph_pwr>; - vdd_s5-supply = <&vph_pwr>; - vdd_l1_l2-supply = <&vreg_s5_1p35>; - vdd_l3_l8-supply = <&vreg_s5_1p35>; - vdd_l4-supply = <&vreg_s5_1p35>; - vdd_l5_l6-supply = <&vreg_s4_1p8>; - vdd_l7-supply = <&vph_pwr>; - vdd_l9-supply = <&vreg_s5_1p35>; - vdd_l10_l11_l12_l13-supply = <&vph_pwr>; - - vreg_s4_1p8: s4 { - regulator-min-microvolt = <1728000>; - regulator-max-microvolt = <1920000>; - }; - - vreg_s5_1p35: s5 { - regulator-min-microvolt = <1352000>; - regulator-max-microvolt = <1352000>; - }; - - vreg_l1_1p3: l1 { - regulator-min-microvolt = <1240000>; - regulator-max-microvolt = <1352000>; - }; - - vreg_l2_1p275: l2 { - regulator-min-microvolt = <1048000>; - regulator-max-microvolt = <1280000>; - }; - - vreg_l3_1p05: l3 { - regulator-min-microvolt = <1048000>; - regulator-max-microvolt = <1160000>; - }; - - vreg_l4_1p2: l4 { - regulator-min-microvolt = <1144000>; - regulator-max-microvolt = <1256000>; - }; - - vreg_l5_1p8: l5 { - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - }; - - vreg_l6_1p8: l6 { - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - }; - - vreg_l7_1p8: l7 { - regulator-min-microvolt = <1616000>; - regulator-max-microvolt = <3000000>; - }; - - vreg_l8_1p2: l8 { - regulator-min-microvolt = <1136000>; - regulator-max-microvolt = <1352000>; - }; - - vreg_l10_3p3: l10 { - regulator-min-microvolt = <2936000>; - regulator-max-microvolt = <3088000>; - }; - - vreg_l11_sdc2: l11 { - regulator-min-microvolt = <2696000>; - regulator-max-microvolt = <3304000>; - }; - - vreg_l12_3p3: l12 { - regulator-min-microvolt = <3050000>; - regulator-max-microvolt = <3300000>; - }; - - vreg_l13_3p3: l13 { - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3300000>; - }; - }; -}; - -&sdcc1 { - status = "okay"; - - supports-cqe; - mmc-ddr-1_8v; - mmc-hs400-1_8v; - bus-width = <8>; - non-removable; - - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&sdc1_on>; - pinctrl-1 = <&sdc1_off>; -}; - -&tlmm { - perst_state: perst-state { - pins = "gpio43"; - function = "gpio"; - - drive-strength = <2>; - bias-disable; - output-low; - }; - - sdc1_on: sdc1-on-state { - clk-pins { - pins = "sdc1_clk"; - bias-disable; - drive-strength = <16>; - }; - - cmd-pins { - pins = "sdc1_cmd"; - bias-pull-up; - drive-strength = <10>; - }; - - data-pins { - pins = "sdc1_data"; - bias-pull-up; - drive-strength = <10>; - }; - - rclk-pins { - pins = "sdc1_rclk"; - bias-pull-down; - }; - }; - - sdc1_off: sdc1-off-state { - clk-pins { - pins = "sdc1_clk"; - bias-disable; - drive-strength = <2>; - }; - - cmd-pins { - pins = "sdc1_cmd"; - bias-pull-up; - drive-strength = <2>; - }; - - data-pins { - pins = "sdc1_data"; - bias-pull-up; - drive-strength = <2>; - }; - - rclk-pins { - pins = "sdc1_rclk"; - bias-pull-down; - }; - }; - - usb3_id_pin: usb3-id-state { - pins = "gpio116"; - function = "gpio"; - - drive-strength = <2>; - bias-pull-up; - }; -}; - -&pms405_gpios { - usb_vbus_boost_pin: usb-vbus-boost-state { - pinconf { - pins = "gpio3"; - function = PMIC_GPIO_FUNC_NORMAL; - output-low; - power-source = <1>; - }; - }; - usb3_vbus_pin: usb3-vbus-state { - pinconf { - pins = "gpio12"; - function = PMIC_GPIO_FUNC_NORMAL; - input-enable; - bias-pull-down; - power-source = <1>; - }; - }; -}; - -&usb2 { - status = "okay"; -}; - -&usb2_phy_sec { - vdd-supply = <&vreg_l4_1p2>; - vdda1p8-supply = <&vreg_l5_1p8>; - vdda3p3-supply = <&vreg_l12_3p3>; - status = "okay"; -}; - -&usb3 { - status = "okay"; - -}; - -&usb3_dwc3 { - dr_mode = "host"; -}; - -&usb2_phy_prim { - vdd-supply = <&vreg_l4_1p2>; - vdda1p8-supply = <&vreg_l5_1p8>; - vdda3p3-supply = <&vreg_l12_3p3>; - status = "okay"; -}; - -&usb3_phy { - vdd-supply = <&vreg_l3_1p05>; - vdda1p8-supply = <&vreg_l5_1p8>; - status = "okay"; -}; - -&wifi { - status = "okay"; - vdd-0.8-cx-mx-supply = <&vreg_l2_1p275>; - vdd-1.8-xo-supply = <&vreg_l5_1p8>; - vdd-1.3-rfa-supply = <&vreg_l1_1p3>; -}; - -/* PINCTRL - additions to nodes defined in qcs404.dtsi */ - -&blsp1_uart2_default { - rx-pins { - drive-strength = <2>; - bias-disable; - }; - - tx-pins { - drive-strength = <2>; - bias-disable; - }; -}; - -&blsp1_uart3_default { - cts-pins { - bias-disable; - }; - - rts-tx-pins { - drive-strength = <2>; - bias-disable; - }; - - rx-pins { - bias-pull-up; - }; -}; diff --git a/arch/arm/dts/qcs404.dtsi b/arch/arm/dts/qcs404.dtsi deleted file mode 100644 index 2721f32dfb71..000000000000 --- a/arch/arm/dts/qcs404.dtsi +++ /dev/null @@ -1,1829 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Copyright (c) 2018, Linaro Limited - */ - -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/clock/qcom,gcc-qcs404.h> -#include <dt-bindings/clock/qcom,turingcc-qcs404.h> -#include <dt-bindings/clock/qcom,rpmcc.h> -#include <dt-bindings/power/qcom-rpmpd.h> -#include <dt-bindings/thermal/thermal.h> - -/ { - interrupt-parent = <&intc>; - - #address-cells = <2>; - #size-cells = <2>; - - chosen { }; - - clocks { - xo_board: xo-board { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <19200000>; - }; - - sleep_clk: sleep-clk { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <32768>; - }; - }; - - cpus { - #address-cells = <1>; - #size-cells = <0>; - - CPU0: cpu@100 { - device_type = "cpu"; - compatible = "arm,cortex-a53"; - reg = <0x100>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_0>; - next-level-cache = <&L2_0>; - #cooling-cells = <2>; - clocks = <&apcs_glb>; - operating-points-v2 = <&cpu_opp_table>; - power-domains = <&cpr>; - power-domain-names = "cpr"; - }; - - CPU1: cpu@101 { - device_type = "cpu"; - compatible = "arm,cortex-a53"; - reg = <0x101>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_0>; - next-level-cache = <&L2_0>; - #cooling-cells = <2>; - clocks = <&apcs_glb>; - operating-points-v2 = <&cpu_opp_table>; - power-domains = <&cpr>; - power-domain-names = "cpr"; - }; - - CPU2: cpu@102 { - device_type = "cpu"; - compatible = "arm,cortex-a53"; - reg = <0x102>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_0>; - next-level-cache = <&L2_0>; - #cooling-cells = <2>; - clocks = <&apcs_glb>; - operating-points-v2 = <&cpu_opp_table>; - power-domains = <&cpr>; - power-domain-names = "cpr"; - }; - - CPU3: cpu@103 { - device_type = "cpu"; - compatible = "arm,cortex-a53"; - reg = <0x103>; - enable-method = "psci"; - cpu-idle-states = <&CPU_SLEEP_0>; - next-level-cache = <&L2_0>; - #cooling-cells = <2>; - clocks = <&apcs_glb>; - operating-points-v2 = <&cpu_opp_table>; - power-domains = <&cpr>; - power-domain-names = "cpr"; - }; - - L2_0: l2-cache { - compatible = "cache"; - cache-level = <2>; - cache-unified; - }; - - idle-states { - entry-method = "psci"; - - CPU_SLEEP_0: cpu-sleep-0 { - compatible = "arm,idle-state"; - idle-state-name = "standalone-power-collapse"; - arm,psci-suspend-param = <0x40000003>; - entry-latency-us = <125>; - exit-latency-us = <180>; - min-residency-us = <595>; - local-timer-stop; - }; - }; - }; - - cpu_opp_table: opp-table-cpu { - compatible = "operating-points-v2-kryo-cpu"; - opp-shared; - - opp-1094400000 { - opp-hz = /bits/ 64 <1094400000>; - required-opps = <&cpr_opp1>; - }; - opp-1248000000 { - opp-hz = /bits/ 64 <1248000000>; - required-opps = <&cpr_opp2>; - }; - opp-1401600000 { - opp-hz = /bits/ 64 <1401600000>; - required-opps = <&cpr_opp3>; - }; - }; - - cpr_opp_table: opp-table-cpr { - compatible = "operating-points-v2-qcom-level"; - - cpr_opp1: opp1 { - opp-level = <1>; - qcom,opp-fuse-level = <1>; - }; - cpr_opp2: opp2 { - opp-level = <2>; - qcom,opp-fuse-level = <2>; - }; - cpr_opp3: opp3 { - opp-level = <3>; - qcom,opp-fuse-level = <3>; - }; - }; - - firmware { - scm: scm { - compatible = "qcom,scm-qcs404", "qcom,scm"; - #reset-cells = <1>; - }; - }; - - memory@80000000 { - device_type = "memory"; - /* We expect the bootloader to fill in the size */ - reg = <0 0x80000000 0 0>; - }; - - psci { - compatible = "arm,psci-1.0"; - method = "smc"; - }; - - rpm: remoteproc { - compatible = "qcom,qcs404-rpm-proc", "qcom,rpm-proc"; - - glink-edge { - compatible = "qcom,glink-rpm"; - - interrupts = <GIC_SPI 168 IRQ_TYPE_EDGE_RISING>; - qcom,rpm-msg-ram = <&rpm_msg_ram>; - mboxes = <&apcs_glb 0>; - - rpm_requests: rpm-requests { - compatible = "qcom,rpm-qcs404"; - qcom,glink-channels = "rpm_requests"; - - rpmcc: clock-controller { - compatible = "qcom,rpmcc-qcs404", "qcom,rpmcc"; - #clock-cells = <1>; - clocks = <&xo_board>; - clock-names = "xo"; - }; - - rpmpd: power-controller { - compatible = "qcom,qcs404-rpmpd"; - #power-domain-cells = <1>; - operating-points-v2 = <&rpmpd_opp_table>; - - rpmpd_opp_table: opp-table { - compatible = "operating-points-v2"; - - rpmpd_opp_ret: opp1 { - opp-level = <16>; - }; - - rpmpd_opp_ret_plus: opp2 { - opp-level = <32>; - }; - - rpmpd_opp_min_svs: opp3 { - opp-level = <48>; - }; - - rpmpd_opp_low_svs: opp4 { - opp-level = <64>; - }; - - rpmpd_opp_svs: opp5 { - opp-level = <128>; - }; - - rpmpd_opp_svs_plus: opp6 { - opp-level = <192>; - }; - - rpmpd_opp_nom: opp7 { - opp-level = <256>; - }; - - rpmpd_opp_nom_plus: opp8 { - opp-level = <320>; - }; - - rpmpd_opp_turbo: opp9 { - opp-level = <384>; - }; - - rpmpd_opp_turbo_no_cpr: opp10 { - opp-level = <416>; - }; - - rpmpd_opp_turbo_plus: opp11 { - opp-level = <512>; - }; - }; - }; - }; - }; - }; - - reserved-memory { - #address-cells = <2>; - #size-cells = <2>; - ranges; - - tz_apps_mem: memory@85900000 { - reg = <0 0x85900000 0 0x500000>; - no-map; - }; - - xbl_mem: memory@85e00000 { - reg = <0 0x85e00000 0 0x100000>; - no-map; - }; - - smem_region: memory@85f00000 { - reg = <0 0x85f00000 0 0x200000>; - no-map; - }; - - tz_mem: memory@86100000 { - reg = <0 0x86100000 0 0x300000>; - no-map; - }; - - wlan_fw_mem: memory@86400000 { - reg = <0 0x86400000 0 0x1100000>; - no-map; - }; - - adsp_fw_mem: memory@87500000 { - reg = <0 0x87500000 0 0x1a00000>; - no-map; - }; - - cdsp_fw_mem: memory@88f00000 { - reg = <0 0x88f00000 0 0x600000>; - no-map; - }; - - wlan_msa_mem: memory@89500000 { - reg = <0 0x89500000 0 0x100000>; - no-map; - }; - - uefi_mem: memory@9f800000 { - reg = <0 0x9f800000 0 0x800000>; - no-map; - }; - }; - - smem { - compatible = "qcom,smem"; - - memory-region = <&smem_region>; - qcom,rpm-msg-ram = <&rpm_msg_ram>; - - hwlocks = <&tcsr_mutex 3>; - }; - - soc: soc@0 { - #address-cells = <1>; - #size-cells = <1>; - ranges = <0 0 0 0xffffffff>; - compatible = "simple-bus"; - - turingcc: clock-controller@800000 { - compatible = "qcom,qcs404-turingcc"; - reg = <0x00800000 0x30000>; - clocks = <&gcc GCC_CDSP_CFG_AHB_CLK>; - - #clock-cells = <1>; - #reset-cells = <1>; - - status = "disabled"; - }; - - rpm_msg_ram: sram@60000 { - compatible = "qcom,rpm-msg-ram"; - reg = <0x00060000 0x6000>; - }; - - usb3_phy: phy@78000 { - compatible = "qcom,usb-ss-28nm-phy"; - reg = <0x00078000 0x400>; - #phy-cells = <0>; - clocks = <&rpmcc RPM_SMD_LN_BB_CLK>, - <&gcc GCC_USB_HS_PHY_CFG_AHB_CLK>, - <&gcc GCC_USB3_PHY_PIPE_CLK>; - clock-names = "ref", "ahb", "pipe"; - resets = <&gcc GCC_USB3_PHY_BCR>, - <&gcc GCC_USB3PHY_PHY_BCR>; - reset-names = "com", "phy"; - status = "disabled"; - }; - - usb2_phy_prim: phy@7a000 { - compatible = "qcom,usb-hs-28nm-femtophy"; - reg = <0x0007a000 0x200>; - #phy-cells = <0>; - clocks = <&rpmcc RPM_SMD_LN_BB_CLK>, - <&gcc GCC_USB_HS_PHY_CFG_AHB_CLK>, - <&gcc GCC_USB2A_PHY_SLEEP_CLK>; - clock-names = "ref", "ahb", "sleep"; - resets = <&gcc GCC_USB_HS_PHY_CFG_AHB_BCR>, - <&gcc GCC_USB2A_PHY_BCR>; - reset-names = "phy", "por"; - status = "disabled"; - }; - - usb2_phy_sec: phy@7c000 { - compatible = "qcom,usb-hs-28nm-femtophy"; - reg = <0x0007c000 0x200>; - #phy-cells = <0>; - clocks = <&rpmcc RPM_SMD_LN_BB_CLK>, - <&gcc GCC_USB_HS_PHY_CFG_AHB_CLK>, - <&gcc GCC_USB2A_PHY_SLEEP_CLK>; - clock-names = "ref", "ahb", "sleep"; - resets = <&gcc GCC_QUSB2_PHY_BCR>, - <&gcc GCC_USB2_HS_PHY_ONLY_BCR>; - reset-names = "phy", "por"; - status = "disabled"; - }; - - qfprom: qfprom@a4000 { - compatible = "qcom,qcs404-qfprom", "qcom,qfprom"; - reg = <0x000a4000 0x1000>; - #address-cells = <1>; - #size-cells = <1>; - cpr_efuse_speedbin: speedbin@13c { - reg = <0x13c 0x4>; - bits = <2 3>; - }; - - tsens_s0_p1: s0-p1@1f8 { - reg = <0x1f8 0x1>; - bits = <0 6>; - }; - - tsens_s0_p2: s0-p2@1f8 { - reg = <0x1f8 0x2>; - bits = <6 6>; - }; - - tsens_s1_p1: s1-p1@1f9 { - reg = <0x1f9 0x2>; - bits = <4 6>; - }; - - tsens_s1_p2: s1-p2@1fa { - reg = <0x1fa 0x1>; - bits = <2 6>; - }; - - tsens_s2_p1: s2-p1@1fb { - reg = <0x1fb 0x1>; - bits = <0 6>; - }; - - tsens_s2_p2: s2-p2@1fb { - reg = <0x1fb 0x2>; - bits = <6 6>; - }; - - tsens_s3_p1: s3-p1@1fc { - reg = <0x1fc 0x2>; - bits = <4 6>; - }; - - tsens_s3_p2: s3-p2@1fd { - reg = <0x1fd 0x1>; - bits = <2 6>; - }; - - tsens_s4_p1: s4-p1@1fe { - reg = <0x1fe 0x1>; - bits = <0 6>; - }; - - tsens_s4_p2: s4-p2@1fe { - reg = <0x1fe 0x2>; - bits = <6 6>; - }; - - tsens_s5_p1: s5-p1@200 { - reg = <0x200 0x1>; - bits = <0 6>; - }; - - tsens_s5_p2: s5-p2@200 { - reg = <0x200 0x2>; - bits = <6 6>; - }; - - tsens_s6_p1: s6-p1@201 { - reg = <0x201 0x2>; - bits = <4 6>; - }; - - tsens_s6_p2: s6-p2@202 { - reg = <0x202 0x1>; - bits = <2 6>; - }; - - tsens_s7_p1: s7-p1@203 { - reg = <0x203 0x1>; - bits = <0 6>; - }; - - tsens_s7_p2: s7-p2@203 { - reg = <0x203 0x2>; - bits = <6 6>; - }; - - tsens_s8_p1: s8-p1@204 { - reg = <0x204 0x2>; - bits = <4 6>; - }; - - tsens_s8_p2: s8-p2@205 { - reg = <0x205 0x1>; - bits = <2 6>; - }; - - tsens_s9_p1: s9-p1@206 { - reg = <0x206 0x1>; - bits = <0 6>; - }; - - tsens_s9_p2: s9-p2@206 { - reg = <0x206 0x2>; - bits = <6 6>; - }; - - tsens_mode: mode@208 { - reg = <0x208 1>; - bits = <0 3>; - }; - - tsens_base1: base1@208 { - reg = <0x208 2>; - bits = <3 8>; - }; - - tsens_base2: base2@208 { - reg = <0x209 2>; - bits = <3 8>; - }; - - cpr_efuse_quot_offset1: qoffset1@231 { - reg = <0x231 0x4>; - bits = <4 7>; - }; - cpr_efuse_quot_offset2: qoffset2@232 { - reg = <0x232 0x4>; - bits = <3 7>; - }; - cpr_efuse_quot_offset3: qoffset3@233 { - reg = <0x233 0x4>; - bits = <2 7>; - }; - cpr_efuse_init_voltage1: ivoltage1@229 { - reg = <0x229 0x4>; - bits = <4 6>; - }; - cpr_efuse_init_voltage2: ivoltage2@22a { - reg = <0x22a 0x4>; - bits = <2 6>; - }; - cpr_efuse_init_voltage3: ivoltage3@22b { - reg = <0x22b 0x4>; - bits = <0 6>; - }; - cpr_efuse_quot1: quot1@22b { - reg = <0x22b 0x4>; - bits = <6 12>; - }; - cpr_efuse_quot2: quot2@22d { - reg = <0x22d 0x4>; - bits = <2 12>; - }; - cpr_efuse_quot3: quot3@230 { - reg = <0x230 0x4>; - bits = <0 12>; - }; - cpr_efuse_ring1: ring1@228 { - reg = <0x228 0x4>; - bits = <0 3>; - }; - cpr_efuse_ring2: ring2@228 { - reg = <0x228 0x4>; - bits = <4 3>; - }; - cpr_efuse_ring3: ring3@229 { - reg = <0x229 0x4>; - bits = <0 3>; - }; - cpr_efuse_revision: revision@218 { - reg = <0x218 0x4>; - bits = <3 3>; - }; - }; - - rng: rng@e3000 { - compatible = "qcom,prng-ee"; - reg = <0x000e3000 0x1000>; - clocks = <&gcc GCC_PRNG_AHB_CLK>; - clock-names = "core"; - }; - - bimc: interconnect@400000 { - reg = <0x00400000 0x80000>; - compatible = "qcom,qcs404-bimc"; - #interconnect-cells = <1>; - clock-names = "bus", "bus_a"; - clocks = <&rpmcc RPM_SMD_BIMC_CLK>, - <&rpmcc RPM_SMD_BIMC_A_CLK>; - }; - - tsens: thermal-sensor@4a9000 { - compatible = "qcom,qcs404-tsens", "qcom,tsens-v1"; - reg = <0x004a9000 0x1000>, /* TM */ - <0x004a8000 0x1000>; /* SROT */ - nvmem-cells = <&tsens_mode>, - <&tsens_base1>, <&tsens_base2>, - <&tsens_s0_p1>, <&tsens_s0_p2>, - <&tsens_s1_p1>, <&tsens_s1_p2>, - <&tsens_s2_p1>, <&tsens_s2_p2>, - <&tsens_s3_p1>, <&tsens_s3_p2>, - <&tsens_s4_p1>, <&tsens_s4_p2>, - <&tsens_s5_p1>, <&tsens_s5_p2>, - <&tsens_s6_p1>, <&tsens_s6_p2>, - <&tsens_s7_p1>, <&tsens_s7_p2>, - <&tsens_s8_p1>, <&tsens_s8_p2>, - <&tsens_s9_p1>, <&tsens_s9_p2>; - nvmem-cell-names = "mode", - "base1", "base2", - "s0_p1", "s0_p2", - "s1_p1", "s1_p2", - "s2_p1", "s2_p2", - "s3_p1", "s3_p2", - "s4_p1", "s4_p2", - "s5_p1", "s5_p2", - "s6_p1", "s6_p2", - "s7_p1", "s7_p2", - "s8_p1", "s8_p2", - "s9_p1", "s9_p2"; - #qcom,sensors = <10>; - interrupts = <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "uplow"; - #thermal-sensor-cells = <1>; - }; - - pcnoc: interconnect@500000 { - reg = <0x00500000 0x15080>; - compatible = "qcom,qcs404-pcnoc"; - #interconnect-cells = <1>; - clock-names = "bus", "bus_a"; - clocks = <&rpmcc RPM_SMD_PNOC_CLK>, - <&rpmcc RPM_SMD_PNOC_A_CLK>; - }; - - snoc: interconnect@580000 { - reg = <0x00580000 0x23080>; - compatible = "qcom,qcs404-snoc"; - #interconnect-cells = <1>; - clock-names = "bus", "bus_a"; - clocks = <&rpmcc RPM_SMD_SNOC_CLK>, - <&rpmcc RPM_SMD_SNOC_A_CLK>; - }; - - remoteproc_cdsp: remoteproc@b00000 { - compatible = "qcom,qcs404-cdsp-pas"; - reg = <0x00b00000 0x4040>; - - interrupts-extended = <&intc GIC_SPI 229 IRQ_TYPE_EDGE_RISING>, - <&cdsp_smp2p_in 0 IRQ_TYPE_EDGE_RISING>, - <&cdsp_smp2p_in 1 IRQ_TYPE_EDGE_RISING>, - <&cdsp_smp2p_in 2 IRQ_TYPE_EDGE_RISING>, - <&cdsp_smp2p_in 3 IRQ_TYPE_EDGE_RISING>; - interrupt-names = "wdog", "fatal", "ready", - "handover", "stop-ack"; - - clocks = <&xo_board>; - clock-names = "xo"; - - /* - * If the node was using the PIL binding, then include properties: - * clocks = <&xo_board>, - * <&gcc GCC_CDSP_CFG_AHB_CLK>, - * <&gcc GCC_CDSP_TBU_CLK>, - * <&gcc GCC_BIMC_CDSP_CLK>, - * <&turingcc TURING_WRAPPER_AON_CLK>, - * <&turingcc TURING_Q6SS_AHBS_AON_CLK>, - * <&turingcc TURING_Q6SS_AHBM_AON_CLK>, - * <&turingcc TURING_Q6SS_Q6_AXIM_CLK>; - * clock-names = "xo", - * "sway", - * "tbu", - * "bimc", - * "ahb_aon", - * "q6ss_slave", - * "q6ss_master", - * "q6_axim"; - * resets = <&gcc GCC_CDSP_RESTART>; - * reset-names = "restart"; - * qcom,halt-regs = <&tcsr 0x19004>; - */ - - memory-region = <&cdsp_fw_mem>; - - qcom,smem-states = <&cdsp_smp2p_out 0>; - qcom,smem-state-names = "stop"; - - status = "disabled"; - - glink-edge { - interrupts = <GIC_SPI 141 IRQ_TYPE_EDGE_RISING>; - - qcom,remote-pid = <5>; - mboxes = <&apcs_glb 12>; - - label = "cdsp"; - }; - }; - - usb3: usb@7678800 { - compatible = "qcom,qcs404-dwc3", "qcom,dwc3"; - reg = <0x07678800 0x400>; - #address-cells = <1>; - #size-cells = <1>; - ranges; - clocks = <&gcc GCC_USB30_MASTER_CLK>, - <&gcc GCC_SYS_NOC_USB3_CLK>, - <&gcc GCC_USB30_SLEEP_CLK>, - <&gcc GCC_USB30_MOCK_UTMI_CLK>; - clock-names = "core", "iface", "sleep", "mock_utmi"; - assigned-clocks = <&gcc GCC_USB20_MOCK_UTMI_CLK>, - <&gcc GCC_USB30_MASTER_CLK>; - assigned-clock-rates = <19200000>, <200000000>; - status = "disabled"; - - usb3_dwc3: usb@7580000 { - compatible = "snps,dwc3"; - reg = <0x07580000 0xcd00>; - interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; - phys = <&usb2_phy_prim>, <&usb3_phy>; - phy-names = "usb2-phy", "usb3-phy"; - snps,has-lpm-erratum; - snps,hird-threshold = /bits/ 8 <0x10>; - snps,usb3_lpm_capable; - dr_mode = "otg"; - }; - }; - - usb2: usb@79b8800 { - compatible = "qcom,qcs404-dwc3", "qcom,dwc3"; - reg = <0x079b8800 0x400>; - #address-cells = <1>; - #size-cells = <1>; - ranges; - clocks = <&gcc GCC_USB_HS_SYSTEM_CLK>, - <&gcc GCC_PCNOC_USB2_CLK>, - <&gcc GCC_USB_HS_INACTIVITY_TIMERS_CLK>, - <&gcc GCC_USB20_MOCK_UTMI_CLK>; - clock-names = "core", "iface", "sleep", "mock_utmi"; - assigned-clocks = <&gcc GCC_USB20_MOCK_UTMI_CLK>, - <&gcc GCC_USB_HS_SYSTEM_CLK>; - assigned-clock-rates = <19200000>, <133333333>; - status = "disabled"; - - usb@78c0000 { - compatible = "snps,dwc3"; - reg = <0x078c0000 0xcc00>; - interrupts = <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>; - phys = <&usb2_phy_sec>; - phy-names = "usb2-phy"; - snps,has-lpm-erratum; - snps,hird-threshold = /bits/ 8 <0x10>; - snps,usb3_lpm_capable; - dr_mode = "peripheral"; - }; - }; - - tlmm: pinctrl@1000000 { - compatible = "qcom,qcs404-pinctrl"; - reg = <0x01000000 0x200000>, - <0x01300000 0x200000>, - <0x07b00000 0x200000>; - reg-names = "south", "north", "east"; - interrupts = <GIC_SPI 208 IRQ_TYPE_LEVEL_HIGH>; - gpio-ranges = <&tlmm 0 0 120>; - gpio-controller; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - - blsp1_i2c0_default: blsp1-i2c0-default-state { - pins = "gpio32", "gpio33"; - function = "blsp_i2c0"; - }; - - blsp1_i2c1_default: blsp1-i2c1-default-state { - pins = "gpio24", "gpio25"; - function = "blsp_i2c1"; - }; - - blsp1_i2c2_default: blsp1-i2c2-default-state { - sda-pins { - pins = "gpio19"; - function = "blsp_i2c_sda_a2"; - }; - - scl-pins { - pins = "gpio20"; - function = "blsp_i2c_scl_a2"; - }; - }; - - blsp1_i2c3_default: blsp1-i2c3-default-state { - pins = "gpio84", "gpio85"; - function = "blsp_i2c3"; - }; - - blsp1_i2c4_default: blsp1-i2c4-default-state { - pins = "gpio117", "gpio118"; - function = "blsp_i2c4"; - }; - - blsp1_uart0_default: blsp1-uart0-default-state { - pins = "gpio30", "gpio31", "gpio32", "gpio33"; - function = "blsp_uart0"; - }; - - blsp1_uart1_default: blsp1-uart1-default-state { - pins = "gpio22", "gpio23"; - function = "blsp_uart1"; - }; - - blsp1_uart2_default: blsp1-uart2-default-state { - rx-pins { - pins = "gpio18"; - function = "blsp_uart_rx_a2"; - }; - - tx-pins { - pins = "gpio17"; - function = "blsp_uart_tx_a2"; - }; - }; - - blsp1_uart3_default: blsp1-uart3-default-state { - cts-pins { - pins = "gpio84"; - function = "blsp_uart3"; - }; - - rts-tx-pins { - pins = "gpio85", "gpio82"; - function = "blsp_uart3"; - }; - - rx-pins { - pins = "gpio83"; - function = "blsp_uart3"; - }; - }; - - blsp2_i2c0_default: blsp2-i2c0-default-state { - pins = "gpio28", "gpio29"; - function = "blsp_i2c5"; - }; - - blsp1_spi0_default: blsp1-spi0-default-state { - pins = "gpio30", "gpio31", "gpio32", "gpio33"; - function = "blsp_spi0"; - }; - - blsp1_spi1_default: blsp1-spi1-default-state { - mosi-pins { - pins = "gpio22"; - function = "blsp_spi_mosi_a1"; - }; - - miso-pins { - pins = "gpio23"; - function = "blsp_spi_miso_a1"; - }; - - cs-n-pins { - pins = "gpio24"; - function = "blsp_spi_cs_n_a1"; - }; - - clk-pins { - pins = "gpio25"; - function = "blsp_spi_clk_a1"; - }; - }; - - blsp1_spi2_default: blsp1-spi2-default-state { - pins = "gpio17", "gpio18", "gpio19", "gpio20"; - function = "blsp_spi2"; - }; - - blsp1_spi3_default: blsp1-spi3-default-state { - pins = "gpio82", "gpio83", "gpio84", "gpio85"; - function = "blsp_spi3"; - }; - - blsp1_spi4_default: blsp1-spi4-default-state { - pins = "gpio37", "gpio38", "gpio117", "gpio118"; - function = "blsp_spi4"; - }; - - blsp2_spi0_default: blsp2-spi0-default-state { - pins = "gpio26", "gpio27", "gpio28", "gpio29"; - function = "blsp_spi5"; - }; - - blsp2_uart0_default: blsp2-uart0-default-state { - pins = "gpio26", "gpio27", "gpio28", "gpio29"; - function = "blsp_uart5"; - }; - }; - - gcc: clock-controller@1800000 { - compatible = "qcom,gcc-qcs404"; - reg = <0x01800000 0x80000>; - #clock-cells = <1>; - #reset-cells = <1>; - #power-domain-cells = <1>; - - clocks = <&xo_board>, - <&sleep_clk>, - <&pcie_phy>, - <0>, - <0>, - <0>; - - assigned-clocks = <&gcc GCC_APSS_AHB_CLK_SRC>; - assigned-clock-rates = <19200000>; - }; - - tcsr_mutex: hwlock@1905000 { - compatible = "qcom,tcsr-mutex"; - reg = <0x01905000 0x20000>; - #hwlock-cells = <1>; - }; - - tcsr: syscon@1937000 { - compatible = "qcom,qcs404-tcsr", "syscon"; - reg = <0x01937000 0x25000>; - }; - - sram@290000 { - compatible = "qcom,rpm-stats"; - reg = <0x00290000 0x10000>; - }; - - spmi_bus: spmi@200f000 { - compatible = "qcom,spmi-pmic-arb"; - reg = <0x0200f000 0x001000>, - <0x02400000 0x800000>, - <0x02c00000 0x800000>, - <0x03800000 0x200000>, - <0x0200a000 0x002100>; - reg-names = "core", "chnls", "obsrvr", "intr", "cnfg"; - interrupt-names = "periph_irq"; - interrupts = <GIC_SPI 190 IRQ_TYPE_LEVEL_HIGH>; - qcom,ee = <0>; - qcom,channel = <0>; - #address-cells = <2>; - #size-cells = <0>; - interrupt-controller; - #interrupt-cells = <4>; - }; - - remoteproc_wcss: remoteproc@7400000 { - compatible = "qcom,qcs404-wcss-pas"; - reg = <0x07400000 0x4040>; - - interrupts-extended = <&intc GIC_SPI 153 IRQ_TYPE_EDGE_RISING>, - <&wcss_smp2p_in 0 IRQ_TYPE_EDGE_RISING>, - <&wcss_smp2p_in 1 IRQ_TYPE_EDGE_RISING>, - <&wcss_smp2p_in 2 IRQ_TYPE_EDGE_RISING>, - <&wcss_smp2p_in 3 IRQ_TYPE_EDGE_RISING>; - interrupt-names = "wdog", "fatal", "ready", - "handover", "stop-ack"; - - clocks = <&xo_board>; - clock-names = "xo"; - - memory-region = <&wlan_fw_mem>; - - qcom,smem-states = <&wcss_smp2p_out 0>; - qcom,smem-state-names = "stop"; - - status = "disabled"; - - glink-edge { - interrupts = <GIC_SPI 156 IRQ_TYPE_EDGE_RISING>; - - qcom,remote-pid = <1>; - mboxes = <&apcs_glb 16>; - - label = "wcss"; - }; - }; - - pcie_phy: phy@7786000 { - compatible = "qcom,qcs404-pcie2-phy", "qcom,pcie2-phy"; - reg = <0x07786000 0xb8>; - - clocks = <&gcc GCC_PCIE_0_PIPE_CLK>; - resets = <&gcc GCC_PCIEPHY_0_PHY_BCR>, - <&gcc GCC_PCIE_0_PIPE_ARES>; - reset-names = "phy", "pipe"; - - clock-output-names = "pcie_0_pipe_clk"; - #clock-cells = <0>; - #phy-cells = <0>; - - status = "disabled"; - }; - - sdcc1: mmc@7804000 { - compatible = "qcom,qcs404-sdhci", "qcom,sdhci-msm-v5"; - reg = <0x07804000 0x1000>, <0x7805000 0x1000>; - reg-names = "hc", "cqhci"; - - interrupts = <GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 138 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "hc_irq", "pwr_irq"; - - clocks = <&gcc GCC_SDCC1_AHB_CLK>, - <&gcc GCC_SDCC1_APPS_CLK>, - <&xo_board>; - clock-names = "iface", "core", "xo"; - - status = "disabled"; - }; - - blsp1_dma: dma-controller@7884000 { - compatible = "qcom,bam-v1.7.0"; - reg = <0x07884000 0x25000>; - interrupts = <GIC_SPI 238 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP1_AHB_CLK>; - clock-names = "bam_clk"; - #dma-cells = <1>; - qcom,ee = <0>; - status = "okay"; - }; - - blsp1_uart0: serial@78af000 { - compatible = "qcom,msm-uartdm-v1.4", "qcom,msm-uartdm"; - reg = <0x078af000 0x200>; - interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP1_UART0_APPS_CLK>, <&gcc GCC_BLSP1_AHB_CLK>; - clock-names = "core", "iface"; - dmas = <&blsp1_dma 0>, <&blsp1_dma 1>; - dma-names = "tx", "rx"; - pinctrl-names = "default"; - pinctrl-0 = <&blsp1_uart0_default>; - status = "disabled"; - }; - - blsp1_uart1: serial@78b0000 { - compatible = "qcom,msm-uartdm-v1.4", "qcom,msm-uartdm"; - reg = <0x078b0000 0x200>; - interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP1_UART1_APPS_CLK>, <&gcc GCC_BLSP1_AHB_CLK>; - clock-names = "core", "iface"; - dmas = <&blsp1_dma 2>, <&blsp1_dma 3>; - dma-names = "tx", "rx"; - pinctrl-names = "default"; - pinctrl-0 = <&blsp1_uart1_default>; - status = "disabled"; - }; - - blsp1_uart2: serial@78b1000 { - compatible = "qcom,msm-uartdm-v1.4", "qcom,msm-uartdm"; - reg = <0x078b1000 0x200>; - interrupts = <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP1_UART2_APPS_CLK>, <&gcc GCC_BLSP1_AHB_CLK>; - clock-names = "core", "iface"; - dmas = <&blsp1_dma 4>, <&blsp1_dma 5>; - dma-names = "tx", "rx"; - pinctrl-names = "default"; - pinctrl-0 = <&blsp1_uart2_default>; - status = "okay"; - }; - - ethernet: ethernet@7a80000 { - compatible = "qcom,qcs404-ethqos"; - reg = <0x07a80000 0x10000>, - <0x07a96000 0x100>; - reg-names = "stmmaceth", "rgmii"; - clock-names = "stmmaceth", "pclk", "ptp_ref", "rgmii"; - clocks = <&gcc GCC_ETH_AXI_CLK>, - <&gcc GCC_ETH_SLAVE_AHB_CLK>, - <&gcc GCC_ETH_PTP_CLK>, - <&gcc GCC_ETH_RGMII_CLK>; - interrupts = <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "macirq", "eth_lpi"; - - snps,tso; - rx-fifo-depth = <4096>; - tx-fifo-depth = <4096>; - - status = "disabled"; - }; - - wifi: wifi@a000000 { - compatible = "qcom,wcn3990-wifi"; - reg = <0xa000000 0x800000>; - reg-names = "membase"; - memory-region = <&wlan_msa_mem>; - interrupts = <GIC_SPI 277 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 278 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 279 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 280 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 281 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 282 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 283 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 284 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 285 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 286 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 287 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 288 IRQ_TYPE_LEVEL_HIGH>; - status = "disabled"; - }; - - blsp1_uart3: serial@78b2000 { - compatible = "qcom,msm-uartdm-v1.4", "qcom,msm-uartdm"; - reg = <0x078b2000 0x200>; - interrupts = <GIC_SPI 119 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP1_UART3_APPS_CLK>, <&gcc GCC_BLSP1_AHB_CLK>; - clock-names = "core", "iface"; - dmas = <&blsp1_dma 6>, <&blsp1_dma 7>; - dma-names = "tx", "rx"; - pinctrl-names = "default"; - pinctrl-0 = <&blsp1_uart3_default>; - status = "disabled"; - }; - - blsp1_i2c0: i2c@78b5000 { - compatible = "qcom,i2c-qup-v2.2.1"; - reg = <0x078b5000 0x600>; - interrupts = <GIC_SPI 95 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP1_QUP0_I2C_APPS_CLK>, - <&gcc GCC_BLSP1_AHB_CLK>; - clock-names = "core", "iface"; - pinctrl-names = "default"; - pinctrl-0 = <&blsp1_i2c0_default>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - blsp1_spi0: spi@78b5000 { - compatible = "qcom,spi-qup-v2.2.1"; - reg = <0x078b5000 0x600>; - interrupts = <GIC_SPI 95 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP1_QUP0_SPI_APPS_CLK>, - <&gcc GCC_BLSP1_AHB_CLK>; - clock-names = "core", "iface"; - pinctrl-names = "default"; - pinctrl-0 = <&blsp1_spi0_default>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - blsp1_i2c1: i2c@78b6000 { - compatible = "qcom,i2c-qup-v2.2.1"; - reg = <0x078b6000 0x600>; - interrupts = <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP1_QUP1_I2C_APPS_CLK>, - <&gcc GCC_BLSP1_AHB_CLK>; - clock-names = "core", "iface"; - pinctrl-names = "default"; - pinctrl-0 = <&blsp1_i2c1_default>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - blsp1_spi1: spi@78b6000 { - compatible = "qcom,spi-qup-v2.2.1"; - reg = <0x078b6000 0x600>; - interrupts = <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP1_QUP1_SPI_APPS_CLK>, - <&gcc GCC_BLSP1_AHB_CLK>; - clock-names = "core", "iface"; - pinctrl-names = "default"; - pinctrl-0 = <&blsp1_spi1_default>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - blsp1_i2c2: i2c@78b7000 { - compatible = "qcom,i2c-qup-v2.2.1"; - reg = <0x078b7000 0x600>; - interrupts = <GIC_SPI 97 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP1_QUP2_I2C_APPS_CLK>, - <&gcc GCC_BLSP1_AHB_CLK>; - clock-names = "core", "iface"; - pinctrl-names = "default"; - pinctrl-0 = <&blsp1_i2c2_default>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - blsp1_spi2: spi@78b7000 { - compatible = "qcom,spi-qup-v2.2.1"; - reg = <0x078b7000 0x600>; - interrupts = <GIC_SPI 97 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP1_QUP2_SPI_APPS_CLK>, - <&gcc GCC_BLSP1_AHB_CLK>; - clock-names = "core", "iface"; - pinctrl-names = "default"; - pinctrl-0 = <&blsp1_spi2_default>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - blsp1_i2c3: i2c@78b8000 { - compatible = "qcom,i2c-qup-v2.2.1"; - reg = <0x078b8000 0x600>; - interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP1_QUP3_I2C_APPS_CLK>, - <&gcc GCC_BLSP1_AHB_CLK>; - clock-names = "core", "iface"; - pinctrl-names = "default"; - pinctrl-0 = <&blsp1_i2c3_default>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - blsp1_spi3: spi@78b8000 { - compatible = "qcom,spi-qup-v2.2.1"; - reg = <0x078b8000 0x600>; - interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP1_QUP3_SPI_APPS_CLK>, - <&gcc GCC_BLSP1_AHB_CLK>; - clock-names = "core", "iface"; - pinctrl-names = "default"; - pinctrl-0 = <&blsp1_spi3_default>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - blsp1_i2c4: i2c@78b9000 { - compatible = "qcom,i2c-qup-v2.2.1"; - reg = <0x078b9000 0x600>; - interrupts = <GIC_SPI 99 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP1_QUP4_I2C_APPS_CLK>, - <&gcc GCC_BLSP1_AHB_CLK>; - clock-names = "core", "iface"; - pinctrl-names = "default"; - pinctrl-0 = <&blsp1_i2c4_default>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - blsp1_spi4: spi@78b9000 { - compatible = "qcom,spi-qup-v2.2.1"; - reg = <0x078b9000 0x600>; - interrupts = <GIC_SPI 99 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP1_QUP4_SPI_APPS_CLK>, - <&gcc GCC_BLSP1_AHB_CLK>; - clock-names = "core", "iface"; - pinctrl-names = "default"; - pinctrl-0 = <&blsp1_spi4_default>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - blsp2_dma: dma-controller@7ac4000 { - compatible = "qcom,bam-v1.7.0"; - reg = <0x07ac4000 0x17000>; - interrupts = <GIC_SPI 239 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP2_AHB_CLK>; - clock-names = "bam_clk"; - #dma-cells = <1>; - qcom,ee = <0>; - status = "disabled"; - }; - - blsp2_uart0: serial@7aef000 { - compatible = "qcom,msm-uartdm-v1.4", "qcom,msm-uartdm"; - reg = <0x07aef000 0x200>; - interrupts = <GIC_SPI 297 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP2_UART0_APPS_CLK>, <&gcc GCC_BLSP2_AHB_CLK>; - clock-names = "core", "iface"; - dmas = <&blsp2_dma 0>, <&blsp2_dma 1>; - dma-names = "tx", "rx"; - pinctrl-names = "default"; - pinctrl-0 = <&blsp2_uart0_default>; - status = "disabled"; - }; - - blsp2_i2c0: i2c@7af5000 { - compatible = "qcom,i2c-qup-v2.2.1"; - reg = <0x07af5000 0x600>; - interrupts = <GIC_SPI 299 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP2_QUP0_I2C_APPS_CLK>, - <&gcc GCC_BLSP2_AHB_CLK>; - clock-names = "core", "iface"; - pinctrl-names = "default"; - pinctrl-0 = <&blsp2_i2c0_default>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - blsp2_spi0: spi@7af5000 { - compatible = "qcom,spi-qup-v2.2.1"; - reg = <0x07af5000 0x600>; - interrupts = <GIC_SPI 299 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_BLSP2_QUP0_SPI_APPS_CLK>, - <&gcc GCC_BLSP2_AHB_CLK>; - clock-names = "core", "iface"; - pinctrl-names = "default"; - pinctrl-0 = <&blsp2_spi0_default>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - sram@8600000 { - compatible = "qcom,qcs404-imem", "syscon", "simple-mfd"; - reg = <0x08600000 0x1000>; - - #address-cells = <1>; - #size-cells = <1>; - - ranges = <0 0x08600000 0x1000>; - - pil-reloc@94c { - compatible = "qcom,pil-reloc-info"; - reg = <0x94c 0xc8>; - }; - }; - - intc: interrupt-controller@b000000 { - compatible = "qcom,msm-qgic2"; - interrupt-controller; - #interrupt-cells = <3>; - reg = <0x0b000000 0x1000>, - <0x0b002000 0x1000>; - }; - - apcs_glb: mailbox@b011000 { - compatible = "qcom,qcs404-apcs-apps-global", - "qcom,msm8916-apcs-kpss-global", "syscon"; - reg = <0x0b011000 0x1000>; - #mbox-cells = <1>; - clocks = <&apcs_hfpll>, <&gcc GCC_GPLL0_AO_OUT_MAIN>; - clock-names = "pll", "aux"; - #clock-cells = <0>; - }; - - apcs_hfpll: clock-controller@b016000 { - compatible = "qcom,hfpll"; - reg = <0x0b016000 0x30>; - #clock-cells = <0>; - clock-output-names = "apcs_hfpll"; - clocks = <&xo_board>; - clock-names = "xo"; - }; - - watchdog@b017000 { - compatible = "qcom,apss-wdt-qcs404", "qcom,kpss-wdt"; - reg = <0x0b017000 0x1000>; - clocks = <&sleep_clk>; - }; - - cpr: power-controller@b018000 { - compatible = "qcom,qcs404-cpr", "qcom,cpr"; - reg = <0x0b018000 0x1000>; - interrupts = <0 15 IRQ_TYPE_EDGE_RISING>; - clocks = <&xo_board>; - clock-names = "ref"; - vdd-apc-supply = <&pms405_s3>; - #power-domain-cells = <0>; - operating-points-v2 = <&cpr_opp_table>; - acc-syscon = <&tcsr>; - - nvmem-cells = <&cpr_efuse_quot_offset1>, - <&cpr_efuse_quot_offset2>, - <&cpr_efuse_quot_offset3>, - <&cpr_efuse_init_voltage1>, - <&cpr_efuse_init_voltage2>, - <&cpr_efuse_init_voltage3>, - <&cpr_efuse_quot1>, - <&cpr_efuse_quot2>, - <&cpr_efuse_quot3>, - <&cpr_efuse_ring1>, - <&cpr_efuse_ring2>, - <&cpr_efuse_ring3>, - <&cpr_efuse_revision>; - nvmem-cell-names = "cpr_quotient_offset1", - "cpr_quotient_offset2", - "cpr_quotient_offset3", - "cpr_init_voltage1", - "cpr_init_voltage2", - "cpr_init_voltage3", - "cpr_quotient1", - "cpr_quotient2", - "cpr_quotient3", - "cpr_ring_osc1", - "cpr_ring_osc2", - "cpr_ring_osc3", - "cpr_fuse_revision"; - }; - - timer@b120000 { - #address-cells = <1>; - #size-cells = <1>; - ranges; - compatible = "arm,armv7-timer-mem"; - reg = <0x0b120000 0x1000>; - clock-frequency = <19200000>; - - frame@b121000 { - frame-number = <0>; - interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; - reg = <0x0b121000 0x1000>, - <0x0b122000 0x1000>; - }; - - frame@b123000 { - frame-number = <1>; - interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; - reg = <0x0b123000 0x1000>; - status = "disabled"; - }; - - frame@b124000 { - frame-number = <2>; - interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; - reg = <0x0b124000 0x1000>; - status = "disabled"; - }; - - frame@b125000 { - frame-number = <3>; - interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; - reg = <0x0b125000 0x1000>; - status = "disabled"; - }; - - frame@b126000 { - frame-number = <4>; - interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>; - reg = <0x0b126000 0x1000>; - status = "disabled"; - }; - - frame@b127000 { - frame-number = <5>; - interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>; - reg = <0xb127000 0x1000>; - status = "disabled"; - }; - - frame@b128000 { - frame-number = <6>; - interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; - reg = <0x0b128000 0x1000>; - status = "disabled"; - }; - }; - - remoteproc_adsp: remoteproc@c700000 { - compatible = "qcom,qcs404-adsp-pas"; - reg = <0x0c700000 0x4040>; - - interrupts-extended = <&intc GIC_SPI 293 IRQ_TYPE_EDGE_RISING>, - <&adsp_smp2p_in 0 IRQ_TYPE_EDGE_RISING>, - <&adsp_smp2p_in 1 IRQ_TYPE_EDGE_RISING>, - <&adsp_smp2p_in 2 IRQ_TYPE_EDGE_RISING>, - <&adsp_smp2p_in 3 IRQ_TYPE_EDGE_RISING>; - interrupt-names = "wdog", "fatal", "ready", - "handover", "stop-ack"; - - clocks = <&xo_board>; - clock-names = "xo"; - - memory-region = <&adsp_fw_mem>; - - qcom,smem-states = <&adsp_smp2p_out 0>; - qcom,smem-state-names = "stop"; - - status = "disabled"; - - glink-edge { - interrupts = <GIC_SPI 289 IRQ_TYPE_EDGE_RISING>; - - qcom,remote-pid = <2>; - mboxes = <&apcs_glb 8>; - - label = "adsp"; - }; - }; - - pcie: pci@10000000 { - compatible = "qcom,pcie-qcs404"; - reg = <0x10000000 0xf1d>, - <0x10000f20 0xa8>, - <0x07780000 0x2000>, - <0x10001000 0x2000>; - reg-names = "dbi", "elbi", "parf", "config"; - device_type = "pci"; - linux,pci-domain = <0>; - bus-range = <0x00 0xff>; - num-lanes = <1>; - #address-cells = <3>; - #size-cells = <2>; - - ranges = <0x81000000 0x0 0x00000000 0x10003000 0x0 0x00010000>, /* I/O */ - <0x82000000 0x0 0x10013000 0x10013000 0x0 0x007ed000>; /* memory */ - - interrupts = <GIC_SPI 266 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "msi"; - #interrupt-cells = <1>; - interrupt-map-mask = <0 0 0 0x7>; - interrupt-map = <0 0 0 1 &intc GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>, /* int_a */ - <0 0 0 2 &intc GIC_SPI 224 IRQ_TYPE_LEVEL_HIGH>, /* int_b */ - <0 0 0 3 &intc GIC_SPI 267 IRQ_TYPE_LEVEL_HIGH>, /* int_c */ - <0 0 0 4 &intc GIC_SPI 268 IRQ_TYPE_LEVEL_HIGH>; /* int_d */ - clocks = <&gcc GCC_PCIE_0_CFG_AHB_CLK>, - <&gcc GCC_PCIE_0_AUX_CLK>, - <&gcc GCC_PCIE_0_MSTR_AXI_CLK>, - <&gcc GCC_PCIE_0_SLV_AXI_CLK>; - clock-names = "iface", "aux", "master_bus", "slave_bus"; - - resets = <&gcc GCC_PCIE_0_AXI_MASTER_ARES>, - <&gcc GCC_PCIE_0_AXI_SLAVE_ARES>, - <&gcc GCC_PCIE_0_AXI_MASTER_STICKY_ARES>, - <&gcc GCC_PCIE_0_CORE_STICKY_ARES>, - <&gcc GCC_PCIE_0_BCR>, - <&gcc GCC_PCIE_0_AHB_ARES>; - reset-names = "axi_m", - "axi_s", - "axi_m_sticky", - "pipe_sticky", - "pwr", - "ahb"; - - phys = <&pcie_phy>; - phy-names = "pciephy"; - - status = "disabled"; - }; - }; - - timer { - compatible = "arm,armv8-timer"; - interrupts = <GIC_PPI 2 0xff08>, - <GIC_PPI 3 0xff08>, - <GIC_PPI 4 0xff08>, - <GIC_PPI 1 0xff08>; - }; - - smp2p-adsp { - compatible = "qcom,smp2p"; - qcom,smem = <443>, <429>; - interrupts = <GIC_SPI 291 IRQ_TYPE_EDGE_RISING>; - mboxes = <&apcs_glb 10>; - qcom,local-pid = <0>; - qcom,remote-pid = <2>; - - adsp_smp2p_out: master-kernel { - qcom,entry-name = "master-kernel"; - #qcom,smem-state-cells = <1>; - }; - - adsp_smp2p_in: slave-kernel { - qcom,entry-name = "slave-kernel"; - interrupt-controller; - #interrupt-cells = <2>; - }; - }; - - smp2p-cdsp { - compatible = "qcom,smp2p"; - qcom,smem = <94>, <432>; - interrupts = <GIC_SPI 143 IRQ_TYPE_EDGE_RISING>; - mboxes = <&apcs_glb 14>; - qcom,local-pid = <0>; - qcom,remote-pid = <5>; - - cdsp_smp2p_out: master-kernel { - qcom,entry-name = "master-kernel"; - #qcom,smem-state-cells = <1>; - }; - - cdsp_smp2p_in: slave-kernel { - qcom,entry-name = "slave-kernel"; - interrupt-controller; - #interrupt-cells = <2>; - }; - }; - - smp2p-wcss { - compatible = "qcom,smp2p"; - qcom,smem = <435>, <428>; - interrupts = <GIC_SPI 158 IRQ_TYPE_EDGE_RISING>; - mboxes = <&apcs_glb 18>; - qcom,local-pid = <0>; - qcom,remote-pid = <1>; - - wcss_smp2p_out: master-kernel { - qcom,entry-name = "master-kernel"; - #qcom,smem-state-cells = <1>; - }; - - wcss_smp2p_in: slave-kernel { - qcom,entry-name = "slave-kernel"; - interrupt-controller; - #interrupt-cells = <2>; - }; - }; - - thermal-zones { - aoss-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens 0>; - - trips { - aoss_alert0: trip-point0 { - temperature = <105000>; - hysteresis = <2000>; - type = "hot"; - }; - }; - }; - - q6-hvx-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens 1>; - - trips { - q6_hvx_alert0: trip-point0 { - temperature = <105000>; - hysteresis = <2000>; - type = "hot"; - }; - }; - }; - - lpass-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens 2>; - - trips { - lpass_alert0: trip-point0 { - temperature = <105000>; - hysteresis = <2000>; - type = "hot"; - }; - }; - }; - - wlan-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens 3>; - - trips { - wlan_alert0: trip-point0 { - temperature = <105000>; - hysteresis = <2000>; - type = "hot"; - }; - }; - }; - - cluster-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens 4>; - - trips { - cluster_alert0: trip-point0 { - temperature = <95000>; - hysteresis = <2000>; - type = "hot"; - }; - cluster_alert1: trip-point1 { - temperature = <105000>; - hysteresis = <2000>; - type = "passive"; - }; - cluster_crit: cluster-crit { - temperature = <120000>; - hysteresis = <2000>; - type = "critical"; - }; - }; - cooling-maps { - map0 { - trip = <&cluster_alert1>; - cooling-device = <&CPU0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, - <&CPU1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, - <&CPU2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, - <&CPU3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; - }; - }; - }; - - cpu0-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens 5>; - - trips { - cpu0_alert0: trip-point0 { - temperature = <95000>; - hysteresis = <2000>; - type = "hot"; - }; - cpu0_alert1: trip-point1 { - temperature = <105000>; - hysteresis = <2000>; - type = "passive"; - }; - cpu0_crit: cpu-crit { - temperature = <120000>; - hysteresis = <2000>; - type = "critical"; - }; - }; - cooling-maps { - map0 { - trip = <&cpu0_alert1>; - cooling-device = <&CPU0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, - <&CPU1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, - <&CPU2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, - <&CPU3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; - }; - }; - }; - - cpu1-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens 6>; - - trips { - cpu1_alert0: trip-point0 { - temperature = <95000>; - hysteresis = <2000>; - type = "hot"; - }; - cpu1_alert1: trip-point1 { - temperature = <105000>; - hysteresis = <2000>; - type = "passive"; - }; - cpu1_crit: cpu-crit { - temperature = <120000>; - hysteresis = <2000>; - type = "critical"; - }; - }; - cooling-maps { - map0 { - trip = <&cpu1_alert1>; - cooling-device = <&CPU0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, - <&CPU1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, - <&CPU2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, - <&CPU3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; - }; - }; - }; - - cpu2-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens 7>; - - trips { - cpu2_alert0: trip-point0 { - temperature = <95000>; - hysteresis = <2000>; - type = "hot"; - }; - cpu2_alert1: trip-point1 { - temperature = <105000>; - hysteresis = <2000>; - type = "passive"; - }; - cpu2_crit: cpu-crit { - temperature = <120000>; - hysteresis = <2000>; - type = "critical"; - }; - }; - cooling-maps { - map0 { - trip = <&cpu2_alert1>; - cooling-device = <&CPU0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, - <&CPU1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, - <&CPU2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, - <&CPU3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; - }; - }; - }; - - cpu3-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens 8>; - - trips { - cpu3_alert0: trip-point0 { - temperature = <95000>; - hysteresis = <2000>; - type = "hot"; - }; - cpu3_alert1: trip-point1 { - temperature = <105000>; - hysteresis = <2000>; - type = "passive"; - }; - cpu3_crit: cpu-crit { - temperature = <120000>; - hysteresis = <2000>; - type = "critical"; - }; - }; - cooling-maps { - map0 { - trip = <&cpu3_alert1>; - cooling-device = <&CPU0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, - <&CPU1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, - <&CPU2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, - <&CPU3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; - }; - }; - }; - - gpu-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens 9>; - - trips { - gpu_alert0: trip-point0 { - temperature = <95000>; - hysteresis = <2000>; - type = "hot"; - }; - }; - }; - }; -}; diff --git a/arch/arm/dts/sdm845-db845c.dts b/arch/arm/dts/sdm845-db845c.dts deleted file mode 100644 index c7eba6c491be..000000000000 --- a/arch/arm/dts/sdm845-db845c.dts +++ /dev/null @@ -1,1190 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Copyright (c) 2019, Linaro Ltd. - */ - -/dts-v1/; - -#include <dt-bindings/leds/common.h> -#include <dt-bindings/pinctrl/qcom,pmic-gpio.h> -#include <dt-bindings/regulator/qcom,rpmh-regulator.h> -#include <dt-bindings/sound/qcom,q6afe.h> -#include <dt-bindings/sound/qcom,q6asm.h> -#include "sdm845.dtsi" -#include "sdm845-wcd9340.dtsi" -#include "pm8998.dtsi" -#include "pmi8998.dtsi" - -/ { - model = "Thundercomm Dragonboard 845c"; - compatible = "thundercomm,db845c", "qcom,sdm845"; - qcom,msm-id = <341 0x20001>; - qcom,board-id = <8 0>; - - aliases { - serial0 = &uart9; - serial1 = &uart6; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - /* Fixed crystal oscillator dedicated to MCP2517FD */ - clk40M: can-clock { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <40000000>; - }; - - dc12v: dc12v-regulator { - compatible = "regulator-fixed"; - regulator-name = "DC12V"; - regulator-min-microvolt = <12000000>; - regulator-max-microvolt = <12000000>; - regulator-always-on; - }; - - gpio-keys { - compatible = "gpio-keys"; - autorepeat; - - pinctrl-names = "default"; - pinctrl-0 = <&vol_up_pin_a>; - - key-vol-up { - label = "Volume Up"; - linux,code = <KEY_VOLUMEUP>; - gpios = <&pm8998_gpios 6 GPIO_ACTIVE_LOW>; - }; - }; - - leds { - compatible = "gpio-leds"; - - led-0 { - label = "green:user4"; - function = LED_FUNCTION_INDICATOR; - color = <LED_COLOR_ID_GREEN>; - gpios = <&pm8998_gpios 13 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "panic-indicator"; - default-state = "off"; - }; - - led-1 { - label = "yellow:wlan"; - function = LED_FUNCTION_WLAN; - color = <LED_COLOR_ID_YELLOW>; - gpios = <&pm8998_gpios 9 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "phy0tx"; - default-state = "off"; - }; - - led-2 { - label = "blue:bt"; - function = LED_FUNCTION_BLUETOOTH; - color = <LED_COLOR_ID_BLUE>; - gpios = <&pm8998_gpios 5 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "bluetooth-power"; - default-state = "off"; - }; - }; - - hdmi-out { - compatible = "hdmi-connector"; - type = "a"; - - port { - hdmi_con: endpoint { - remote-endpoint = <<9611_out>; - }; - }; - }; - - reserved-memory { - /* Cont splash region set up by the bootloader */ - cont_splash_mem: framebuffer@9d400000 { - reg = <0x0 0x9d400000 0x0 0x2400000>; - no-map; - }; - }; - - lt9611_1v8: lt9611-vdd18-regulator { - compatible = "regulator-fixed"; - regulator-name = "LT9611_1V8"; - - vin-supply = <&vdc_5v>; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - gpio = <&tlmm 89 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; - - lt9611_3v3: lt9611-3v3 { - compatible = "regulator-fixed"; - regulator-name = "LT9611_3V3"; - - vin-supply = <&vdc_3v3>; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - - /* - * TODO: make it possible to drive same GPIO from two clients - * gpio = <&tlmm 89 GPIO_ACTIVE_HIGH>; - * enable-active-high; - */ - }; - - pcie0_1p05v: pcie-0-1p05v-regulator { - compatible = "regulator-fixed"; - regulator-name = "PCIE0_1.05V"; - - vin-supply = <&vbat>; - regulator-min-microvolt = <1050000>; - regulator-max-microvolt = <1050000>; - - /* - * TODO: make it possible to drive same GPIO from two clients - * gpio = <&tlmm 90 GPIO_ACTIVE_HIGH>; - * enable-active-high; - */ - }; - - cam0_dvdd_1v2: cam0-dvdd-1v2-regulator { - compatible = "regulator-fixed"; - regulator-name = "CAM0_DVDD_1V2"; - regulator-min-microvolt = <1200000>; - regulator-max-microvolt = <1200000>; - enable-active-high; - gpio = <&pm8998_gpios 12 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&cam0_dvdd_1v2_en_default>; - vin-supply = <&vbat>; - }; - - cam0_avdd_2v8: cam0-avdd-2v8-regulator { - compatible = "regulator-fixed"; - regulator-name = "CAM0_AVDD_2V8"; - regulator-min-microvolt = <2800000>; - regulator-max-microvolt = <2800000>; - enable-active-high; - gpio = <&pm8998_gpios 10 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&cam0_avdd_2v8_en_default>; - vin-supply = <&vbat>; - }; - - /* This regulator is enabled when the VREG_LVS1A_1P8 trace is enabled */ - cam3_avdd_2v8: cam3-avdd-2v8-regulator { - compatible = "regulator-fixed"; - regulator-name = "CAM3_AVDD_2V8"; - regulator-min-microvolt = <2800000>; - regulator-max-microvolt = <2800000>; - regulator-always-on; - vin-supply = <&vbat>; - }; - - pcie0_3p3v_dual: vldo-3v3-regulator { - compatible = "regulator-fixed"; - regulator-name = "VLDO_3V3"; - - vin-supply = <&vbat>; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - - gpio = <&tlmm 90 GPIO_ACTIVE_HIGH>; - enable-active-high; - - pinctrl-names = "default"; - pinctrl-0 = <&pcie0_pwren_state>; - }; - - v5p0_hdmiout: v5p0-hdmiout-regulator { - compatible = "regulator-fixed"; - regulator-name = "V5P0_HDMIOUT"; - - vin-supply = <&vdc_5v>; - regulator-min-microvolt = <500000>; - regulator-max-microvolt = <500000>; - - /* - * TODO: make it possible to drive same GPIO from two clients - * gpio = <&tlmm 89 GPIO_ACTIVE_HIGH>; - * enable-active-high; - */ - }; - - vbat: vbat-regulator { - compatible = "regulator-fixed"; - regulator-name = "VBAT"; - - vin-supply = <&dc12v>; - regulator-min-microvolt = <4200000>; - regulator-max-microvolt = <4200000>; - regulator-always-on; - }; - - vbat_som: vbat-som-regulator { - compatible = "regulator-fixed"; - regulator-name = "VBAT_SOM"; - - vin-supply = <&dc12v>; - regulator-min-microvolt = <4200000>; - regulator-max-microvolt = <4200000>; - regulator-always-on; - }; - - vdc_3v3: vdc-3v3-regulator { - compatible = "regulator-fixed"; - regulator-name = "VDC_3V3"; - vin-supply = <&dc12v>; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - }; - - vdc_5v: vdc-5v-regulator { - compatible = "regulator-fixed"; - regulator-name = "VDC_5V"; - - vin-supply = <&dc12v>; - regulator-min-microvolt = <500000>; - regulator-max-microvolt = <500000>; - regulator-always-on; - }; - - vreg_s4a_1p8: vreg-s4a-1p8 { - compatible = "regulator-fixed"; - regulator-name = "vreg_s4a_1p8"; - - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - }; - - vph_pwr: vph-pwr-regulator { - compatible = "regulator-fixed"; - regulator-name = "vph_pwr"; - - vin-supply = <&vbat_som>; - }; -}; - -&adsp_pas { - status = "okay"; - - firmware-name = "qcom/sdm845/adsp.mbn"; -}; - -&apps_rsc { - regulators-0 { - compatible = "qcom,pm8998-rpmh-regulators"; - qcom,pmic-id = "a"; - vdd-s1-supply = <&vph_pwr>; - vdd-s2-supply = <&vph_pwr>; - vdd-s3-supply = <&vph_pwr>; - vdd-s4-supply = <&vph_pwr>; - vdd-s5-supply = <&vph_pwr>; - vdd-s6-supply = <&vph_pwr>; - vdd-s7-supply = <&vph_pwr>; - vdd-s8-supply = <&vph_pwr>; - vdd-s9-supply = <&vph_pwr>; - vdd-s10-supply = <&vph_pwr>; - vdd-s11-supply = <&vph_pwr>; - vdd-s12-supply = <&vph_pwr>; - vdd-s13-supply = <&vph_pwr>; - vdd-l1-l27-supply = <&vreg_s7a_1p025>; - vdd-l2-l8-l17-supply = <&vreg_s3a_1p35>; - vdd-l3-l11-supply = <&vreg_s7a_1p025>; - vdd-l4-l5-supply = <&vreg_s7a_1p025>; - vdd-l6-supply = <&vph_pwr>; - vdd-l7-l12-l14-l15-supply = <&vreg_s5a_2p04>; - vdd-l9-supply = <&vreg_bob>; - vdd-l10-l23-l25-supply = <&vreg_bob>; - vdd-l13-l19-l21-supply = <&vreg_bob>; - vdd-l16-l28-supply = <&vreg_bob>; - vdd-l18-l22-supply = <&vreg_bob>; - vdd-l20-l24-supply = <&vreg_bob>; - vdd-l26-supply = <&vreg_s3a_1p35>; - vin-lvs-1-2-supply = <&vreg_s4a_1p8>; - - vreg_s3a_1p35: smps3 { - regulator-min-microvolt = <1352000>; - regulator-max-microvolt = <1352000>; - }; - - vreg_s5a_2p04: smps5 { - regulator-min-microvolt = <1904000>; - regulator-max-microvolt = <2040000>; - }; - - vreg_s7a_1p025: smps7 { - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <1028000>; - }; - - vreg_l1a_0p875: ldo1 { - regulator-min-microvolt = <880000>; - regulator-max-microvolt = <880000>; - regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; - }; - - vreg_l5a_0p8: ldo5 { - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <800000>; - regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; - }; - - vreg_l12a_1p8: ldo12 { - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; - }; - - vreg_l7a_1p8: ldo7 { - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; - }; - - vreg_l13a_2p95: ldo13 { - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <2960000>; - regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; - }; - - vreg_l17a_1p3: ldo17 { - regulator-min-microvolt = <1304000>; - regulator-max-microvolt = <1304000>; - regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; - }; - - vreg_l20a_2p95: ldo20 { - regulator-min-microvolt = <2960000>; - regulator-max-microvolt = <2968000>; - regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; - }; - - vreg_l21a_2p95: ldo21 { - regulator-min-microvolt = <2960000>; - regulator-max-microvolt = <2968000>; - regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; - }; - - vreg_l24a_3p075: ldo24 { - regulator-min-microvolt = <3088000>; - regulator-max-microvolt = <3088000>; - regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; - }; - - vreg_l25a_3p3: ldo25 { - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3312000>; - regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; - }; - - vreg_l26a_1p2: ldo26 { - regulator-min-microvolt = <1200000>; - regulator-max-microvolt = <1200000>; - regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; - }; - - vreg_lvs1a_1p8: lvs1 { - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - }; - - vreg_lvs2a_1p8: lvs2 { - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - }; - }; - - regulators-1 { - compatible = "qcom,pmi8998-rpmh-regulators"; - qcom,pmic-id = "b"; - - vdd-bob-supply = <&vph_pwr>; - - vreg_bob: bob { - regulator-min-microvolt = <3312000>; - regulator-max-microvolt = <3600000>; - regulator-initial-mode = <RPMH_REGULATOR_MODE_AUTO>; - regulator-allow-bypass; - }; - }; -}; - -&camss { - status = "okay"; - - vdda-phy-supply = <&vreg_l1a_0p875>; - vdda-pll-supply = <&vreg_l26a_1p2>; -}; - -&cdsp_pas { - status = "okay"; - firmware-name = "qcom/sdm845/cdsp.mbn"; -}; - -&gcc { - protected-clocks = <GCC_QSPI_CORE_CLK>, - <GCC_QSPI_CORE_CLK_SRC>, - <GCC_QSPI_CNOC_PERIPH_AHB_CLK>, - <GCC_LPASS_Q6_AXI_CLK>, - <GCC_LPASS_SWAY_CLK>; -}; - -&gmu { - status = "okay"; -}; - -&gpi_dma0 { - status = "okay"; -}; - -&gpi_dma1 { - status = "okay"; -}; - -&gpu { - status = "okay"; - zap-shader { - memory-region = <&gpu_mem>; - firmware-name = "qcom/sdm845/a630_zap.mbn"; - }; -}; - -&i2c10 { - status = "okay"; - clock-frequency = <400000>; - - lt9611_codec: hdmi-bridge@3b { - compatible = "lontium,lt9611"; - reg = <0x3b>; - #sound-dai-cells = <1>; - - interrupts-extended = <&tlmm 84 IRQ_TYPE_EDGE_FALLING>; - - reset-gpios = <&tlmm 128 GPIO_ACTIVE_HIGH>; - - vdd-supply = <<9611_1v8>; - vcc-supply = <<9611_3v3>; - - pinctrl-names = "default"; - pinctrl-0 = <<9611_irq_pin>, <&dsi_sw_sel>; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - - lt9611_a: endpoint { - remote-endpoint = <&mdss_dsi0_out>; - }; - }; - - port@1 { - reg = <1>; - - lt9611_b: endpoint { - remote-endpoint = <&mdss_dsi1_out>; - }; - }; - - port@2 { - reg = <2>; - - lt9611_out: endpoint { - remote-endpoint = <&hdmi_con>; - }; - }; - }; - }; -}; - -&i2c11 { - /* On Low speed expansion */ - clock-frequency = <100000>; - status = "okay"; -}; - -&i2c14 { - /* On Low speed expansion */ - clock-frequency = <100000>; - status = "okay"; -}; - -&mdss { - memory-region = <&cont_splash_mem>; - status = "okay"; -}; - -&mdss_dsi0 { - status = "okay"; - vdda-supply = <&vreg_l26a_1p2>; - - qcom,dual-dsi-mode; - qcom,master-dsi; - - ports { - port@1 { - endpoint { - remote-endpoint = <<9611_a>; - data-lanes = <0 1 2 3>; - }; - }; - }; -}; - -&mdss_dsi0_phy { - status = "okay"; - vdds-supply = <&vreg_l1a_0p875>; -}; - -&mdss_dsi1 { - vdda-supply = <&vreg_l26a_1p2>; - - qcom,dual-dsi-mode; - - /* DSI1 is slave, so use DSI0 clocks */ - assigned-clock-parents = <&mdss_dsi0_phy 0>, <&mdss_dsi0_phy 1>; - - status = "okay"; - - ports { - port@1 { - endpoint { - remote-endpoint = <<9611_b>; - data-lanes = <0 1 2 3>; - }; - }; - }; -}; - -&mdss_dsi1_phy { - vdds-supply = <&vreg_l1a_0p875>; - status = "okay"; -}; - -&mss_pil { - status = "okay"; - firmware-name = "qcom/sdm845/mba.mbn", "qcom/sdm845/modem.mbn"; -}; - -&pcie0 { - status = "okay"; - perst-gpios = <&tlmm 35 GPIO_ACTIVE_LOW>; - enable-gpio = <&tlmm 134 GPIO_ACTIVE_HIGH>; - - vddpe-3v3-supply = <&pcie0_3p3v_dual>; - - pinctrl-names = "default"; - pinctrl-0 = <&pcie0_default_state>; -}; - -&pcie0_phy { - status = "okay"; - - vdda-phy-supply = <&vreg_l1a_0p875>; - vdda-pll-supply = <&vreg_l26a_1p2>; -}; - -&pcie1 { - status = "okay"; - perst-gpios = <&tlmm 102 GPIO_ACTIVE_LOW>; - - pinctrl-names = "default"; - pinctrl-0 = <&pcie1_default_state>; -}; - -&pcie1_phy { - status = "okay"; - - vdda-phy-supply = <&vreg_l1a_0p875>; - vdda-pll-supply = <&vreg_l26a_1p2>; -}; - -&pm8998_gpios { - gpio-line-names = - "NC", - "NC", - "WLAN_SW_CTRL", - "NC", - "PM_GPIO5_BLUE_BT_LED", - "VOL_UP_N", - "NC", - "ADC_IN1", - "PM_GPIO9_YEL_WIFI_LED", - "CAM0_AVDD_EN", - "NC", - "CAM0_DVDD_EN", - "PM_GPIO13_GREEN_U4_LED", - "DIV_CLK2", - "NC", - "NC", - "NC", - "SMB_STAT", - "NC", - "NC", - "ADC_IN2", - "OPTION1", - "WCSS_PWR_REQ", - "PM845_GPIO24", - "OPTION2", - "PM845_SLB"; - - cam0_dvdd_1v2_en_default: cam0-dvdd-1v2-en-state { - pins = "gpio12"; - function = "normal"; - - bias-pull-up; - drive-push-pull; - qcom,drive-strength = <PMIC_GPIO_STRENGTH_HIGH>; - }; - - cam0_avdd_2v8_en_default: cam0-avdd-2v8-en-state { - pins = "gpio10"; - function = "normal"; - - bias-pull-up; - drive-push-pull; - qcom,drive-strength = <PMIC_GPIO_STRENGTH_HIGH>; - }; - - vol_up_pin_a: vol-up-active-state { - pins = "gpio6"; - function = "normal"; - input-enable; - bias-pull-up; - qcom,drive-strength = <PMIC_GPIO_STRENGTH_NO>; - }; -}; - -&pm8998_resin { - linux,code = <KEY_VOLUMEDOWN>; - status = "okay"; -}; - -&pmi8998_lpg { - status = "okay"; - - qcom,power-source = <1>; - - led@3 { - reg = <3>; - color = <LED_COLOR_ID_GREEN>; - function = LED_FUNCTION_HEARTBEAT; - function-enumerator = <3>; - - linux,default-trigger = "heartbeat"; - default-state = "on"; - }; - - led@4 { - reg = <4>; - color = <LED_COLOR_ID_GREEN>; - function = LED_FUNCTION_INDICATOR; - function-enumerator = <2>; - }; - - led@5 { - reg = <5>; - color = <LED_COLOR_ID_GREEN>; - function = LED_FUNCTION_INDICATOR; - function-enumerator = <1>; - }; -}; - -/* QUAT I2S Uses 4 I2S SD Lines for audio on LT9611 HDMI Bridge */ -&q6afedai { - dai@22 { - reg = <QUATERNARY_MI2S_RX>; - qcom,sd-lines = <0 1 2 3>; - }; -}; - -&q6asmdai { - dai@0 { - reg = <0>; - }; - - dai@1 { - reg = <1>; - }; - - dai@2 { - reg = <2>; - }; - - dai@3 { - reg = <3>; - direction = <2>; - is-compress-dai; - }; -}; - -&qupv3_id_0 { - status = "okay"; -}; - -&qupv3_id_1 { - status = "okay"; -}; - -&sdhc_2 { - status = "okay"; - - pinctrl-names = "default"; - pinctrl-0 = <&sdc2_default_state &sdc2_card_det_n>; - - vmmc-supply = <&vreg_l21a_2p95>; - vqmmc-supply = <&vreg_l13a_2p95>; - - bus-width = <4>; - cd-gpios = <&tlmm 126 GPIO_ACTIVE_LOW>; -}; - -&sound { - compatible = "qcom,db845c-sndcard", "qcom,sdm845-sndcard"; - pinctrl-0 = <&quat_mi2s_active - &quat_mi2s_sd0_active - &quat_mi2s_sd1_active - &quat_mi2s_sd2_active - &quat_mi2s_sd3_active>; - pinctrl-names = "default"; - model = "DB845c"; - audio-routing = - "RX_BIAS", "MCLK", - "AMIC1", "MIC BIAS1", - "AMIC2", "MIC BIAS2", - "DMIC0", "MIC BIAS1", - "DMIC1", "MIC BIAS1", - "DMIC2", "MIC BIAS3", - "DMIC3", "MIC BIAS3", - "SpkrLeft IN", "SPK1 OUT", - "SpkrRight IN", "SPK2 OUT", - "MM_DL1", "MultiMedia1 Playback", - "MM_DL2", "MultiMedia2 Playback", - "MM_DL4", "MultiMedia4 Playback", - "MultiMedia3 Capture", "MM_UL3"; - - mm1-dai-link { - link-name = "MultiMedia1"; - cpu { - sound-dai = <&q6asmdai MSM_FRONTEND_DAI_MULTIMEDIA1>; - }; - }; - - mm2-dai-link { - link-name = "MultiMedia2"; - cpu { - sound-dai = <&q6asmdai MSM_FRONTEND_DAI_MULTIMEDIA2>; - }; - }; - - mm3-dai-link { - link-name = "MultiMedia3"; - cpu { - sound-dai = <&q6asmdai MSM_FRONTEND_DAI_MULTIMEDIA3>; - }; - }; - - mm4-dai-link { - link-name = "MultiMedia4"; - cpu { - sound-dai = <&q6asmdai MSM_FRONTEND_DAI_MULTIMEDIA4>; - }; - }; - - hdmi-dai-link { - link-name = "HDMI Playback"; - cpu { - sound-dai = <&q6afedai QUATERNARY_MI2S_RX>; - }; - - platform { - sound-dai = <&q6routing>; - }; - - codec { - sound-dai = <<9611_codec 0>; - }; - }; - - slim-dai-link { - link-name = "SLIM Playback"; - cpu { - sound-dai = <&q6afedai SLIMBUS_0_RX>; - }; - - platform { - sound-dai = <&q6routing>; - }; - - codec { - sound-dai = <&left_spkr>, <&right_spkr>, <&swm 0>, <&wcd9340 0>; - }; - }; - - slimcap-dai-link { - link-name = "SLIM Capture"; - cpu { - sound-dai = <&q6afedai SLIMBUS_0_TX>; - }; - - platform { - sound-dai = <&q6routing>; - }; - - codec { - sound-dai = <&wcd9340 1>; - }; - }; -}; - -&spi0 { - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&qup_spi0_default>; - cs-gpios = <&tlmm 3 GPIO_ACTIVE_LOW>; - - can@0 { - compatible = "microchip,mcp2517fd"; - reg = <0>; - clocks = <&clk40M>; - interrupts-extended = <&tlmm 104 IRQ_TYPE_LEVEL_LOW>; - spi-max-frequency = <10000000>; - vdd-supply = <&vdc_5v>; - xceiver-supply = <&vdc_5v>; - }; -}; - -&spi2 { - /* On Low speed expansion */ - status = "okay"; -}; - -&tlmm { - cam0_default: cam0-default-state { - rst-pins { - pins = "gpio9"; - function = "gpio"; - - drive-strength = <16>; - bias-disable; - }; - - mclk0-pins { - pins = "gpio13"; - function = "cam_mclk"; - - drive-strength = <16>; - bias-disable; - }; - }; - - cam3_default: cam3-default-state { - rst-pins { - function = "gpio"; - pins = "gpio21"; - - drive-strength = <16>; - bias-disable; - }; - - mclk3-pins { - function = "cam_mclk"; - pins = "gpio16"; - - drive-strength = <16>; - bias-disable; - }; - }; - - dsi_sw_sel: dsi-sw-sel-state { - pins = "gpio120"; - function = "gpio"; - - drive-strength = <2>; - bias-disable; - output-high; - }; - - lt9611_irq_pin: lt9611-irq-state { - pins = "gpio84"; - function = "gpio"; - bias-disable; - }; - - pcie0_default_state: pcie0-default-state { - clkreq-pins { - pins = "gpio36"; - function = "pci_e0"; - bias-pull-up; - }; - - reset-n-pins { - pins = "gpio35"; - function = "gpio"; - - drive-strength = <2>; - output-low; - bias-pull-down; - }; - - wake-n-pins { - pins = "gpio37"; - function = "gpio"; - - drive-strength = <2>; - bias-pull-up; - }; - }; - - pcie0_pwren_state: pcie0-pwren-state { - pins = "gpio90"; - function = "gpio"; - - drive-strength = <2>; - bias-disable; - }; - - pcie1_default_state: pcie1-default-state { - perst-n-pins { - pins = "gpio102"; - function = "gpio"; - - drive-strength = <16>; - bias-disable; - }; - - clkreq-pins { - pins = "gpio103"; - function = "pci_e1"; - bias-pull-up; - }; - - wake-n-pins { - pins = "gpio11"; - function = "gpio"; - - drive-strength = <2>; - bias-pull-up; - }; - - reset-n-pins { - pins = "gpio75"; - function = "gpio"; - - drive-strength = <16>; - bias-pull-up; - output-high; - }; - }; - - sdc2_default_state: sdc2-default-state { - clk-pins { - pins = "sdc2_clk"; - bias-disable; - - /* - * It seems that mmc_test reports errors if drive - * strength is not 16 on clk, cmd, and data pins. - */ - drive-strength = <16>; - }; - - cmd-pins { - pins = "sdc2_cmd"; - bias-pull-up; - drive-strength = <10>; - }; - - data-pins { - pins = "sdc2_data"; - bias-pull-up; - drive-strength = <10>; - }; - }; - - sdc2_card_det_n: sd-card-det-n-state { - pins = "gpio126"; - function = "gpio"; - bias-pull-up; - }; -}; - -&uart3 { - label = "LS-UART0"; - pinctrl-0 = <&qup_uart3_4pin>; - - status = "disabled"; -}; - -&uart6 { - status = "okay"; - - pinctrl-0 = <&qup_uart6_4pin>; - - bluetooth { - compatible = "qcom,wcn3990-bt"; - - vddio-supply = <&vreg_s4a_1p8>; - vddxo-supply = <&vreg_l7a_1p8>; - vddrf-supply = <&vreg_l17a_1p3>; - vddch0-supply = <&vreg_l25a_3p3>; - max-speed = <3200000>; - }; -}; - -&uart9 { - label = "LS-UART1"; - status = "okay"; -}; - -&usb_1 { - status = "okay"; -}; - -&usb_1_dwc3 { - dr_mode = "peripheral"; -}; - -&usb_1_hsphy { - status = "okay"; - - vdd-supply = <&vreg_l1a_0p875>; - vdda-pll-supply = <&vreg_l12a_1p8>; - vdda-phy-dpdm-supply = <&vreg_l24a_3p075>; - - qcom,imp-res-offset-value = <8>; - qcom,hstx-trim-value = <QUSB2_V2_HSTX_TRIM_21_6_MA>; - qcom,preemphasis-level = <QUSB2_V2_PREEMPHASIS_5_PERCENT>; - qcom,preemphasis-width = <QUSB2_V2_PREEMPHASIS_WIDTH_HALF_BIT>; -}; - -&usb_1_qmpphy { - status = "okay"; - - vdda-phy-supply = <&vreg_l26a_1p2>; - vdda-pll-supply = <&vreg_l1a_0p875>; -}; - -&usb_2 { - status = "okay"; -}; - -&usb_2_dwc3 { - dr_mode = "host"; -}; - -&usb_2_hsphy { - status = "okay"; - - vdd-supply = <&vreg_l1a_0p875>; - vdda-pll-supply = <&vreg_l12a_1p8>; - vdda-phy-dpdm-supply = <&vreg_l24a_3p075>; - - qcom,imp-res-offset-value = <8>; - qcom,hstx-trim-value = <QUSB2_V2_HSTX_TRIM_22_8_MA>; -}; - -&usb_2_qmpphy { - status = "okay"; - - vdda-phy-supply = <&vreg_l26a_1p2>; - vdda-pll-supply = <&vreg_l1a_0p875>; -}; - -&ufs_mem_hc { - status = "okay"; - - reset-gpios = <&tlmm 150 GPIO_ACTIVE_LOW>; - - vcc-supply = <&vreg_l20a_2p95>; - vcc-max-microamp = <800000>; -}; - -&ufs_mem_phy { - status = "okay"; - - vdda-phy-supply = <&vreg_l1a_0p875>; - vdda-pll-supply = <&vreg_l26a_1p2>; -}; - -&venus { - status = "okay"; -}; - -&wcd9340 { - reset-gpios = <&tlmm 64 GPIO_ACTIVE_HIGH>; - vdd-buck-supply = <&vreg_s4a_1p8>; - vdd-buck-sido-supply = <&vreg_s4a_1p8>; - vdd-tx-supply = <&vreg_s4a_1p8>; - vdd-rx-supply = <&vreg_s4a_1p8>; - vdd-io-supply = <&vreg_s4a_1p8>; - - swm: swm@c85 { - left_spkr: speaker@0,1 { - compatible = "sdw10217201000"; - reg = <0 1>; - powerdown-gpios = <&wcdgpio 1 GPIO_ACTIVE_HIGH>; - #thermal-sensor-cells = <0>; - sound-name-prefix = "SpkrLeft"; - #sound-dai-cells = <0>; - }; - - right_spkr: speaker@0,2 { - compatible = "sdw10217201000"; - powerdown-gpios = <&wcdgpio 1 GPIO_ACTIVE_HIGH>; - reg = <0 2>; - #thermal-sensor-cells = <0>; - sound-name-prefix = "SpkrRight"; - #sound-dai-cells = <0>; - }; - }; -}; - -&wifi { - status = "okay"; - - vdd-0.8-cx-mx-supply = <&vreg_l5a_0p8>; - vdd-1.8-xo-supply = <&vreg_l7a_1p8>; - vdd-1.3-rfa-supply = <&vreg_l17a_1p3>; - vdd-3.3-ch0-supply = <&vreg_l25a_3p3>; - - qcom,snoc-host-cap-8bit-quirk; - qcom,ath10k-calibration-variant = "Thundercomm_DB845C"; -}; - -/* PINCTRL - additions to nodes defined in sdm845.dtsi */ -&qup_spi2_default { - drive-strength = <16>; -}; - -&qup_i2c10_default { - drive-strength = <2>; - bias-disable; -}; - -&qup_uart9_rx { - drive-strength = <2>; - bias-pull-up; -}; - -&qup_uart9_tx { - drive-strength = <2>; - bias-disable; -}; - -/* PINCTRL - additions to nodes defined in sdm845.dtsi */ -&qup_spi0_default { - drive-strength = <6>; - bias-disable; -}; diff --git a/arch/arm/dts/sdm845-samsung-starqltechn.dts b/arch/arm/dts/sdm845-samsung-starqltechn.dts deleted file mode 100644 index d37a433130b9..000000000000 --- a/arch/arm/dts/sdm845-samsung-starqltechn.dts +++ /dev/null @@ -1,460 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * SDM845 Samsung S9 (SM-G9600) (starqltechn / star2qltechn) common device tree source - * - * Copyright (c) 2020, The Linux Foundation. All rights reserved. - */ - -/dts-v1/; - -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/regulator/qcom,rpmh-regulator.h> -#include "sdm845.dtsi" - -/ { - chassis-type = "handset"; - model = "Samsung Galaxy S9 SM-G9600"; - compatible = "samsung,starqltechn", "qcom,sdm845"; - - chosen { - #address-cells = <2>; - #size-cells = <2>; - ranges; - framebuffer: framebuffer@9d400000 { - compatible = "simple-framebuffer"; - reg = <0 0x9d400000 0 (2960 * 1440 * 4)>;//2400000 - width = <1440>; - height = <2960>; - stride = <(1440 * 4)>; - format = "a8r8g8b8"; - }; - }; - - vph_pwr: vph-pwr-regulator { - compatible = "regulator-fixed"; - regulator-name = "vph_pwr"; - regulator-min-microvolt = <3700000>; - regulator-max-microvolt = <3700000>; - }; - - /* - * Apparently RPMh does not provide support for PM8998 S4 because it - * is always-on; model it as a fixed regulator. - */ - vreg_s4a_1p8: pm8998-smps4 { - compatible = "regulator-fixed"; - regulator-name = "vreg_s4a_1p8"; - - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-always-on; - regulator-boot-on; - - vin-supply = <&vph_pwr>; - }; - - reserved-memory { - memory@9d400000 { - reg = <0x0 0x9d400000 0x0 0x02400000>; - no-map; - }; - - memory@a1300000 { - compatible = "ramoops"; - reg = <0x0 0xa1300000 0x0 0x100000>; - record-size = <0x40000>; - console-size = <0x40000>; - ftrace-size = <0x40000>; - pmsg-size = <0x40000>; - }; - }; -}; - - -&apps_rsc { - regulators-0 { - compatible = "qcom,pm8998-rpmh-regulators"; - qcom,pmic-id = "a"; - - vdd-s1-supply = <&vph_pwr>; - vdd-s2-supply = <&vph_pwr>; - vdd-s3-supply = <&vph_pwr>; - vdd-s4-supply = <&vph_pwr>; - vdd-s5-supply = <&vph_pwr>; - vdd-s6-supply = <&vph_pwr>; - vdd-s7-supply = <&vph_pwr>; - vdd-s8-supply = <&vph_pwr>; - vdd-s9-supply = <&vph_pwr>; - vdd-s10-supply = <&vph_pwr>; - vdd-s11-supply = <&vph_pwr>; - vdd-s12-supply = <&vph_pwr>; - vdd-s13-supply = <&vph_pwr>; - vdd-l1-l27-supply = <&vreg_s7a_1p025>; - vdd-l2-l8-l17-supply = <&vreg_s3a_1p35>; - vdd-l3-l11-supply = <&vreg_s7a_1p025>; - vdd-l4-l5-supply = <&vreg_s7a_1p025>; - vdd-l6-supply = <&vph_pwr>; - vdd-l7-l12-l14-l15-supply = <&vreg_s5a_2p04>; - vdd-l26-supply = <&vreg_s3a_1p35>; - vin-lvs-1-2-supply = <&vreg_s4a_1p8>; - - vreg_s2a_1p125: smps2 { - regulator-min-microvolt = <1100000>; - regulator-max-microvolt = <1100000>; - }; - - vreg_s3a_1p35: smps3 { - regulator-min-microvolt = <1352000>; - regulator-max-microvolt = <1352000>; - }; - - vreg_s5a_2p04: smps5 { - regulator-min-microvolt = <1904000>; - regulator-max-microvolt = <2040000>; - }; - - vreg_s7a_1p025: smps7 { - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <1028000>; - }; - - vdd_qusb_hs0: - vdda_hp_pcie_core: - vdda_mipi_csi0_0p9: - vdda_mipi_csi1_0p9: - vdda_mipi_csi2_0p9: - vdda_mipi_dsi0_pll: - vdda_mipi_dsi1_pll: - vdda_qlink_lv: - vdda_qlink_lv_ck: - vdda_qrefs_0p875: - vdda_pcie_core: - vdda_pll_cc_ebi01: - vdda_pll_cc_ebi23: - vdda_sp_sensor: - vdda_ufs1_core: - vdda_ufs2_core: - vdda_usb1_ss_core: - vdda_usb2_ss_core: - vreg_l1a_0p875: ldo1 { - regulator-min-microvolt = <880000>; - regulator-max-microvolt = <880000>; - regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; - }; - - vddpx_10: - vreg_l2a_1p2: ldo2 { - regulator-min-microvolt = <1200000>; - regulator-max-microvolt = <1200000>; - regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; - regulator-always-on; - }; - - vreg_l3a_1p0: ldo3 { - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; - }; - - vdd_wcss_cx: - vdd_wcss_mx: - vdda_wcss_pll: - vreg_l5a_0p8: ldo5 { - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <800000>; - regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; - }; - - vddpx_13: - vreg_l6a_1p8: ldo6 { - regulator-min-microvolt = <1856000>; - regulator-max-microvolt = <1856000>; - regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; - }; - - vreg_l7a_1p8: ldo7 { - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; - }; - - vreg_l8a_1p2: ldo8 { - regulator-min-microvolt = <1200000>; - regulator-max-microvolt = <1248000>; - regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; - }; - - vreg_l9a_1p8: ldo9 { - regulator-min-microvolt = <1704000>; - regulator-max-microvolt = <2928000>; - regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; - }; - - vreg_l10a_1p8: ldo10 { - regulator-min-microvolt = <1704000>; - regulator-max-microvolt = <2928000>; - regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; - }; - - vreg_l11a_1p0: ldo11 { - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1048000>; - regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; - }; - - vdd_qfprom: - vdd_qfprom_sp: - vdda_apc1_cs_1p8: - vdda_gfx_cs_1p8: - vdda_qrefs_1p8: - vdda_qusb_hs0_1p8: - vddpx_11: - vreg_l12a_1p8: ldo12 { - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; - }; - - vddpx_2: - vreg_l13a_2p95: ldo13 { - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <2960000>; - regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; - }; - - vreg_l14a_1p88: ldo14 { - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; - }; - - vreg_l15a_1p8: ldo15 { - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; - }; - - vreg_l16a_2p7: ldo16 { - regulator-min-microvolt = <2704000>; - regulator-max-microvolt = <2704000>; - regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; - }; - - vreg_l17a_1p3: ldo17 { - regulator-min-microvolt = <1304000>; - regulator-max-microvolt = <1304000>; - regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; - }; - - vreg_l18a_2p7: ldo18 { - regulator-min-microvolt = <2704000>; - regulator-max-microvolt = <2960000>; - regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; - }; - - vreg_l19a_3p0: ldo19 { - regulator-min-microvolt = <2856000>; - regulator-max-microvolt = <3104000>; - regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; - }; - - vreg_l20a_2p95: ldo20 { - regulator-min-microvolt = <2704000>; - regulator-max-microvolt = <2960000>; - regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; - }; - - vreg_l21a_2p95: ldo21 { - regulator-min-microvolt = <2704000>; - regulator-max-microvolt = <2960000>; - regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; - }; - - vreg_l22a_2p85: ldo22 { - regulator-min-microvolt = <2864000>; - regulator-max-microvolt = <3312000>; - regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; - }; - - vreg_l23a_3p3: ldo23 { - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3312000>; - regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; - }; - - vdda_qusb_hs0_3p1: - vreg_l24a_3p075: ldo24 { - regulator-min-microvolt = <3088000>; - regulator-max-microvolt = <3088000>; - regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; - }; - - vreg_l25a_3p3: ldo25 { - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3312000>; - regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; - }; - - vdda_hp_pcie_1p2: - vdda_hv_ebi0: - vdda_hv_ebi1: - vdda_hv_ebi2: - vdda_hv_ebi3: - vdda_mipi_csi_1p25: - vdda_mipi_dsi0_1p2: - vdda_mipi_dsi1_1p2: - vdda_pcie_1p2: - vdda_ufs1_1p2: - vdda_ufs2_1p2: - vdda_usb1_ss_1p2: - vdda_usb2_ss_1p2: - vreg_l26a_1p2: ldo26 { - regulator-min-microvolt = <1200000>; - regulator-max-microvolt = <1200000>; - regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; - }; - - vreg_l28a_3p0: ldo28 { - regulator-min-microvolt = <2856000>; - regulator-max-microvolt = <3008000>; - regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; - }; - - vreg_lvs1a_1p8: lvs1 { - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - }; - - vreg_lvs2a_1p8: lvs2 { - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - }; - }; - - regulators-1 { - compatible = "qcom,pm8005-rpmh-regulators"; - qcom,pmic-id = "c"; - - vdd-s1-supply = <&vph_pwr>; - vdd-s2-supply = <&vph_pwr>; - vdd-s3-supply = <&vph_pwr>; - vdd-s4-supply = <&vph_pwr>; - - vreg_s3c_0p6: smps3 { - regulator-min-microvolt = <600000>; - regulator-max-microvolt = <600000>; - }; - }; -}; - -&gcc { - protected-clocks = <GCC_QSPI_CORE_CLK>, - <GCC_QSPI_CORE_CLK_SRC>, - <GCC_QSPI_CNOC_PERIPH_AHB_CLK>, - <GCC_LPASS_Q6_AXI_CLK>, - <GCC_LPASS_SWAY_CLK>; -}; - -&i2c10 { - clock-frequency = <400000>; - status = "okay"; -}; - -&qupv3_id_1 { - status = "okay"; -}; - -&uart9 { - status = "okay"; -}; - -&ufs_mem_hc { - reset-gpios = <&tlmm 150 GPIO_ACTIVE_LOW>; - vcc-supply = <&vreg_l20a_2p95>; - vcc-max-microamp = <600000>; - status = "okay"; -}; - -&ufs_mem_phy { - vdda-phy-supply = <&vdda_ufs1_core>; - vdda-pll-supply = <&vdda_ufs1_1p2>; - status = "okay"; -}; - -&sdhc_2 { - pinctrl-names = "default"; - pinctrl-0 = <&sdc2_clk_state &sdc2_cmd_state &sdc2_data_state &sd_card_det_n_state>; - cd-gpios = <&tlmm 126 GPIO_ACTIVE_LOW>; - vmmc-supply = <&vreg_l21a_2p95>; - vqmmc-supply = <&vddpx_2>; - status = "okay"; -}; - -&usb_1 { - status = "okay"; -}; - -&usb_1_dwc3 { - /* Until we have Type C hooked up we'll force this as peripheral. */ - dr_mode = "peripheral"; -}; - -&usb_1_hsphy { - vdd-supply = <&vdda_usb1_ss_core>; - vdda-pll-supply = <&vdda_qusb_hs0_1p8>; - vdda-phy-dpdm-supply = <&vdda_qusb_hs0_3p1>; - - qcom,imp-res-offset-value = <8>; - qcom,hstx-trim-value = <QUSB2_V2_HSTX_TRIM_21_6_MA>; - qcom,preemphasis-level = <QUSB2_V2_PREEMPHASIS_5_PERCENT>; - qcom,preemphasis-width = <QUSB2_V2_PREEMPHASIS_WIDTH_HALF_BIT>; - status = "okay"; -}; - -&usb_1_qmpphy { - vdda-phy-supply = <&vdda_usb1_ss_1p2>; - vdda-pll-supply = <&vdda_usb1_ss_core>; - status = "okay"; -}; - -&wifi { - vdd-0.8-cx-mx-supply = <&vreg_l5a_0p8>; - vdd-1.8-xo-supply = <&vreg_l7a_1p8>; - vdd-1.3-rfa-supply = <&vreg_l17a_1p3>; - vdd-3.3-ch0-supply = <&vreg_l25a_3p3>; - status = "okay"; -}; - -&tlmm { - gpio-reserved-ranges = <0 4>, <27 4>, <81 4>, <85 4>; - - sdc2_clk_state: sdc2-clk-state { - pins = "sdc2_clk"; - bias-disable; - - /* - * It seems that mmc_test reports errors if drive - * strength is not 16 on clk, cmd, and data pins. - */ - drive-strength = <16>; - }; - - sdc2_cmd_state: sdc2-cmd-state { - pins = "sdc2_cmd"; - bias-pull-up; - drive-strength = <16>; - }; - - sdc2_data_state: sdc2-data-state { - pins = "sdc2_data"; - bias-pull-up; - drive-strength = <16>; - }; - - sd_card_det_n_state: sd-card-det-n-state { - pins = "gpio126"; - function = "gpio"; - bias-pull-up; - }; -}; diff --git a/arch/arm/dts/sdm845-wcd9340.dtsi b/arch/arm/dts/sdm845-wcd9340.dtsi deleted file mode 100644 index c15d48860646..000000000000 --- a/arch/arm/dts/sdm845-wcd9340.dtsi +++ /dev/null @@ -1,86 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * SDM845 SoC device tree source - * - * Copyright (c) 2018, The Linux Foundation. All rights reserved. - */ - -&slim { - status = "okay"; - - slim@1 { - reg = <1>; - #address-cells = <2>; - #size-cells = <0>; - - wcd9340_ifd: ifd@0,0 { - compatible = "slim217,250"; - reg = <0 0>; - }; - - wcd9340: codec@1,0 { - compatible = "slim217,250"; - reg = <1 0>; - slim-ifc-dev = <&wcd9340_ifd>; - - #sound-dai-cells = <1>; - - interrupts-extended = <&tlmm 54 IRQ_TYPE_LEVEL_HIGH>; - interrupt-controller; - #interrupt-cells = <1>; - - clock-names = "extclk"; - clocks = <&rpmhcc RPMH_LN_BB_CLK2>; - - #clock-cells = <0>; - clock-frequency = <9600000>; - clock-output-names = "mclk"; - - pinctrl-0 = <&wcd_intr_default>; - pinctrl-names = "default"; - - qcom,micbias1-microvolt = <1800000>; - qcom,micbias2-microvolt = <1800000>; - qcom,micbias3-microvolt = <1800000>; - qcom,micbias4-microvolt = <1800000>; - - #address-cells = <1>; - #size-cells = <1>; - - wcdgpio: gpio-controller@42 { - compatible = "qcom,wcd9340-gpio"; - gpio-controller; - #gpio-cells = <2>; - reg = <0x42 0x2>; - }; - - swm: swm@c85 { - compatible = "qcom,soundwire-v1.3.0"; - reg = <0xc85 0x40>; - interrupts-extended = <&wcd9340 20>; - - qcom,dout-ports = <6>; - qcom,din-ports = <2>; - qcom,ports-sinterval-low = /bits/ 8 <0x07 0x1f 0x3f 0x7 0x1f 0x3f 0x0f 0x0f>; - qcom,ports-offset1 = /bits/ 8 <0x01 0x02 0x0c 0x6 0x12 0x0d 0x07 0x0a>; - qcom,ports-offset2 = /bits/ 8 <0x00 0x00 0x1f 0x00 0x00 0x1f 0x00 0x00>; - - #sound-dai-cells = <1>; - clocks = <&wcd9340>; - clock-names = "iface"; - #address-cells = <2>; - #size-cells = <0>; - }; - }; - }; -}; - -&tlmm { - wcd_intr_default: wcd-intr-default-state { - pins = "gpio54"; - function = "gpio"; - - bias-pull-down; - drive-strength = <2>; - }; -}; diff --git a/arch/arm/dts/sdm845.dtsi b/arch/arm/dts/sdm845.dtsi deleted file mode 100644 index bf5e6eb9d313..000000000000 --- a/arch/arm/dts/sdm845.dtsi +++ /dev/null @@ -1,5752 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * SDM845 SoC device tree source - * - * Copyright (c) 2018, The Linux Foundation. All rights reserved. - */ - -#include <dt-bindings/clock/qcom,camcc-sdm845.h> -#include <dt-bindings/clock/qcom,dispcc-sdm845.h> -#include <dt-bindings/clock/qcom,gcc-sdm845.h> -#include <dt-bindings/clock/qcom,gpucc-sdm845.h> -#include <dt-bindings/clock/qcom,lpass-sdm845.h> -#include <dt-bindings/clock/qcom,rpmh.h> -#include <dt-bindings/clock/qcom,videocc-sdm845.h> -#include <dt-bindings/dma/qcom-gpi.h> -#include <dt-bindings/firmware/qcom,scm.h> -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/interconnect/qcom,osm-l3.h> -#include <dt-bindings/interconnect/qcom,sdm845.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/phy/phy-qcom-qmp.h> -#include <dt-bindings/phy/phy-qcom-qusb2.h> -#include <dt-bindings/power/qcom-rpmpd.h> -#include <dt-bindings/reset/qcom,sdm845-aoss.h> -#include <dt-bindings/reset/qcom,sdm845-pdc.h> -#include <dt-bindings/soc/qcom,apr.h> -#include <dt-bindings/soc/qcom,rpmh-rsc.h> -#include <dt-bindings/clock/qcom,gcc-sdm845.h> -#include <dt-bindings/thermal/thermal.h> - -/ { - interrupt-parent = <&intc>; - - #address-cells = <2>; - #size-cells = <2>; - - aliases { - i2c0 = &i2c0; - i2c1 = &i2c1; - i2c2 = &i2c2; - i2c3 = &i2c3; - i2c4 = &i2c4; - i2c5 = &i2c5; - i2c6 = &i2c6; - i2c7 = &i2c7; - i2c8 = &i2c8; - i2c9 = &i2c9; - i2c10 = &i2c10; - i2c11 = &i2c11; - i2c12 = &i2c12; - i2c13 = &i2c13; - i2c14 = &i2c14; - i2c15 = &i2c15; - spi0 = &spi0; - spi1 = &spi1; - spi2 = &spi2; - spi3 = &spi3; - spi4 = &spi4; - spi5 = &spi5; - spi6 = &spi6; - spi7 = &spi7; - spi8 = &spi8; - spi9 = &spi9; - spi10 = &spi10; - spi11 = &spi11; - spi12 = &spi12; - spi13 = &spi13; - spi14 = &spi14; - spi15 = &spi15; - }; - - chosen { }; - - clocks { - xo_board: xo-board { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <38400000>; - clock-output-names = "xo_board"; - }; - - sleep_clk: sleep-clk { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <32764>; - }; - }; - - cpus: cpus { - #address-cells = <2>; - #size-cells = <0>; - - CPU0: cpu@0 { - device_type = "cpu"; - compatible = "qcom,kryo385"; - reg = <0x0 0x0>; - clocks = <&cpufreq_hw 0>; - enable-method = "psci"; - capacity-dmips-mhz = <611>; - dynamic-power-coefficient = <154>; - qcom,freq-domain = <&cpufreq_hw 0>; - operating-points-v2 = <&cpu0_opp_table>; - interconnects = <&gladiator_noc MASTER_APPSS_PROC 3 &mem_noc SLAVE_EBI1 3>, - <&osm_l3 MASTER_OSM_L3_APPS &osm_l3 SLAVE_OSM_L3>; - power-domains = <&CPU_PD0>; - power-domain-names = "psci"; - #cooling-cells = <2>; - next-level-cache = <&L2_0>; - L2_0: l2-cache { - compatible = "cache"; - cache-level = <2>; - cache-unified; - next-level-cache = <&L3_0>; - L3_0: l3-cache { - compatible = "cache"; - cache-level = <3>; - cache-unified; - }; - }; - }; - - CPU1: cpu@100 { - device_type = "cpu"; - compatible = "qcom,kryo385"; - reg = <0x0 0x100>; - clocks = <&cpufreq_hw 0>; - enable-method = "psci"; - capacity-dmips-mhz = <611>; - dynamic-power-coefficient = <154>; - qcom,freq-domain = <&cpufreq_hw 0>; - operating-points-v2 = <&cpu0_opp_table>; - interconnects = <&gladiator_noc MASTER_APPSS_PROC 3 &mem_noc SLAVE_EBI1 3>, - <&osm_l3 MASTER_OSM_L3_APPS &osm_l3 SLAVE_OSM_L3>; - power-domains = <&CPU_PD1>; - power-domain-names = "psci"; - #cooling-cells = <2>; - next-level-cache = <&L2_100>; - L2_100: l2-cache { - compatible = "cache"; - cache-level = <2>; - cache-unified; - next-level-cache = <&L3_0>; - }; - }; - - CPU2: cpu@200 { - device_type = "cpu"; - compatible = "qcom,kryo385"; - reg = <0x0 0x200>; - clocks = <&cpufreq_hw 0>; - enable-method = "psci"; - capacity-dmips-mhz = <611>; - dynamic-power-coefficient = <154>; - qcom,freq-domain = <&cpufreq_hw 0>; - operating-points-v2 = <&cpu0_opp_table>; - interconnects = <&gladiator_noc MASTER_APPSS_PROC 3 &mem_noc SLAVE_EBI1 3>, - <&osm_l3 MASTER_OSM_L3_APPS &osm_l3 SLAVE_OSM_L3>; - power-domains = <&CPU_PD2>; - power-domain-names = "psci"; - #cooling-cells = <2>; - next-level-cache = <&L2_200>; - L2_200: l2-cache { - compatible = "cache"; - cache-level = <2>; - cache-unified; - next-level-cache = <&L3_0>; - }; - }; - - CPU3: cpu@300 { - device_type = "cpu"; - compatible = "qcom,kryo385"; - reg = <0x0 0x300>; - clocks = <&cpufreq_hw 0>; - enable-method = "psci"; - capacity-dmips-mhz = <611>; - dynamic-power-coefficient = <154>; - qcom,freq-domain = <&cpufreq_hw 0>; - operating-points-v2 = <&cpu0_opp_table>; - interconnects = <&gladiator_noc MASTER_APPSS_PROC 3 &mem_noc SLAVE_EBI1 3>, - <&osm_l3 MASTER_OSM_L3_APPS &osm_l3 SLAVE_OSM_L3>; - #cooling-cells = <2>; - power-domains = <&CPU_PD3>; - power-domain-names = "psci"; - next-level-cache = <&L2_300>; - L2_300: l2-cache { - compatible = "cache"; - cache-level = <2>; - cache-unified; - next-level-cache = <&L3_0>; - }; - }; - - CPU4: cpu@400 { - device_type = "cpu"; - compatible = "qcom,kryo385"; - reg = <0x0 0x400>; - clocks = <&cpufreq_hw 1>; - enable-method = "psci"; - capacity-dmips-mhz = <1024>; - dynamic-power-coefficient = <442>; - qcom,freq-domain = <&cpufreq_hw 1>; - operating-points-v2 = <&cpu4_opp_table>; - interconnects = <&gladiator_noc MASTER_APPSS_PROC 3 &mem_noc SLAVE_EBI1 3>, - <&osm_l3 MASTER_OSM_L3_APPS &osm_l3 SLAVE_OSM_L3>; - power-domains = <&CPU_PD4>; - power-domain-names = "psci"; - #cooling-cells = <2>; - next-level-cache = <&L2_400>; - L2_400: l2-cache { - compatible = "cache"; - cache-level = <2>; - cache-unified; - next-level-cache = <&L3_0>; - }; - }; - - CPU5: cpu@500 { - device_type = "cpu"; - compatible = "qcom,kryo385"; - reg = <0x0 0x500>; - clocks = <&cpufreq_hw 1>; - enable-method = "psci"; - capacity-dmips-mhz = <1024>; - dynamic-power-coefficient = <442>; - qcom,freq-domain = <&cpufreq_hw 1>; - operating-points-v2 = <&cpu4_opp_table>; - interconnects = <&gladiator_noc MASTER_APPSS_PROC 3 &mem_noc SLAVE_EBI1 3>, - <&osm_l3 MASTER_OSM_L3_APPS &osm_l3 SLAVE_OSM_L3>; - power-domains = <&CPU_PD5>; - power-domain-names = "psci"; - #cooling-cells = <2>; - next-level-cache = <&L2_500>; - L2_500: l2-cache { - compatible = "cache"; - cache-level = <2>; - cache-unified; - next-level-cache = <&L3_0>; - }; - }; - - CPU6: cpu@600 { - device_type = "cpu"; - compatible = "qcom,kryo385"; - reg = <0x0 0x600>; - clocks = <&cpufreq_hw 1>; - enable-method = "psci"; - capacity-dmips-mhz = <1024>; - dynamic-power-coefficient = <442>; - qcom,freq-domain = <&cpufreq_hw 1>; - operating-points-v2 = <&cpu4_opp_table>; - interconnects = <&gladiator_noc MASTER_APPSS_PROC 3 &mem_noc SLAVE_EBI1 3>, - <&osm_l3 MASTER_OSM_L3_APPS &osm_l3 SLAVE_OSM_L3>; - power-domains = <&CPU_PD6>; - power-domain-names = "psci"; - #cooling-cells = <2>; - next-level-cache = <&L2_600>; - L2_600: l2-cache { - compatible = "cache"; - cache-level = <2>; - cache-unified; - next-level-cache = <&L3_0>; - }; - }; - - CPU7: cpu@700 { - device_type = "cpu"; - compatible = "qcom,kryo385"; - reg = <0x0 0x700>; - clocks = <&cpufreq_hw 1>; - enable-method = "psci"; - capacity-dmips-mhz = <1024>; - dynamic-power-coefficient = <442>; - qcom,freq-domain = <&cpufreq_hw 1>; - operating-points-v2 = <&cpu4_opp_table>; - interconnects = <&gladiator_noc MASTER_APPSS_PROC 3 &mem_noc SLAVE_EBI1 3>, - <&osm_l3 MASTER_OSM_L3_APPS &osm_l3 SLAVE_OSM_L3>; - power-domains = <&CPU_PD7>; - power-domain-names = "psci"; - #cooling-cells = <2>; - next-level-cache = <&L2_700>; - L2_700: l2-cache { - compatible = "cache"; - cache-level = <2>; - cache-unified; - next-level-cache = <&L3_0>; - }; - }; - - cpu-map { - cluster0 { - core0 { - cpu = <&CPU0>; - }; - - core1 { - cpu = <&CPU1>; - }; - - core2 { - cpu = <&CPU2>; - }; - - core3 { - cpu = <&CPU3>; - }; - - core4 { - cpu = <&CPU4>; - }; - - core5 { - cpu = <&CPU5>; - }; - - core6 { - cpu = <&CPU6>; - }; - - core7 { - cpu = <&CPU7>; - }; - }; - }; - - cpu_idle_states: idle-states { - entry-method = "psci"; - - LITTLE_CPU_SLEEP_0: cpu-sleep-0-0 { - compatible = "arm,idle-state"; - idle-state-name = "little-rail-power-collapse"; - arm,psci-suspend-param = <0x40000004>; - entry-latency-us = <350>; - exit-latency-us = <461>; - min-residency-us = <1890>; - local-timer-stop; - }; - - BIG_CPU_SLEEP_0: cpu-sleep-1-0 { - compatible = "arm,idle-state"; - idle-state-name = "big-rail-power-collapse"; - arm,psci-suspend-param = <0x40000004>; - entry-latency-us = <264>; - exit-latency-us = <621>; - min-residency-us = <952>; - local-timer-stop; - }; - }; - - domain-idle-states { - CLUSTER_SLEEP_0: cluster-sleep-0 { - compatible = "domain-idle-state"; - arm,psci-suspend-param = <0x4100c244>; - entry-latency-us = <3263>; - exit-latency-us = <6562>; - min-residency-us = <9987>; - }; - }; - }; - - firmware { - scm { - compatible = "qcom,scm-sdm845", "qcom,scm"; - }; - }; - - memory@80000000 { - device_type = "memory"; - /* We expect the bootloader to fill in the size */ - reg = <0 0x80000000 0 0>; - }; - - cpu0_opp_table: opp-table-cpu0 { - compatible = "operating-points-v2"; - opp-shared; - - cpu0_opp1: opp-300000000 { - opp-hz = /bits/ 64 <300000000>; - opp-peak-kBps = <800000 4800000>; - }; - - cpu0_opp2: opp-403200000 { - opp-hz = /bits/ 64 <403200000>; - opp-peak-kBps = <800000 4800000>; - }; - - cpu0_opp3: opp-480000000 { - opp-hz = /bits/ 64 <480000000>; - opp-peak-kBps = <800000 6451200>; - }; - - cpu0_opp4: opp-576000000 { - opp-hz = /bits/ 64 <576000000>; - opp-peak-kBps = <800000 6451200>; - }; - - cpu0_opp5: opp-652800000 { - opp-hz = /bits/ 64 <652800000>; - opp-peak-kBps = <800000 7680000>; - }; - - cpu0_opp6: opp-748800000 { - opp-hz = /bits/ 64 <748800000>; - opp-peak-kBps = <1804000 9216000>; - }; - - cpu0_opp7: opp-825600000 { - opp-hz = /bits/ 64 <825600000>; - opp-peak-kBps = <1804000 9216000>; - }; - - cpu0_opp8: opp-902400000 { - opp-hz = /bits/ 64 <902400000>; - opp-peak-kBps = <1804000 10444800>; - }; - - cpu0_opp9: opp-979200000 { - opp-hz = /bits/ 64 <979200000>; - opp-peak-kBps = <1804000 11980800>; - }; - - cpu0_opp10: opp-1056000000 { - opp-hz = /bits/ 64 <1056000000>; - opp-peak-kBps = <1804000 11980800>; - }; - - cpu0_opp11: opp-1132800000 { - opp-hz = /bits/ 64 <1132800000>; - opp-peak-kBps = <2188000 13516800>; - }; - - cpu0_opp12: opp-1228800000 { - opp-hz = /bits/ 64 <1228800000>; - opp-peak-kBps = <2188000 15052800>; - }; - - cpu0_opp13: opp-1324800000 { - opp-hz = /bits/ 64 <1324800000>; - opp-peak-kBps = <2188000 16588800>; - }; - - cpu0_opp14: opp-1420800000 { - opp-hz = /bits/ 64 <1420800000>; - opp-peak-kBps = <3072000 18124800>; - }; - - cpu0_opp15: opp-1516800000 { - opp-hz = /bits/ 64 <1516800000>; - opp-peak-kBps = <3072000 19353600>; - }; - - cpu0_opp16: opp-1612800000 { - opp-hz = /bits/ 64 <1612800000>; - opp-peak-kBps = <4068000 19353600>; - }; - - cpu0_opp17: opp-1689600000 { - opp-hz = /bits/ 64 <1689600000>; - opp-peak-kBps = <4068000 20889600>; - }; - - cpu0_opp18: opp-1766400000 { - opp-hz = /bits/ 64 <1766400000>; - opp-peak-kBps = <4068000 22425600>; - }; - }; - - cpu4_opp_table: opp-table-cpu4 { - compatible = "operating-points-v2"; - opp-shared; - - cpu4_opp1: opp-300000000 { - opp-hz = /bits/ 64 <300000000>; - opp-peak-kBps = <800000 4800000>; - }; - - cpu4_opp2: opp-403200000 { - opp-hz = /bits/ 64 <403200000>; - opp-peak-kBps = <800000 4800000>; - }; - - cpu4_opp3: opp-480000000 { - opp-hz = /bits/ 64 <480000000>; - opp-peak-kBps = <1804000 4800000>; - }; - - cpu4_opp4: opp-576000000 { - opp-hz = /bits/ 64 <576000000>; - opp-peak-kBps = <1804000 4800000>; - }; - - cpu4_opp5: opp-652800000 { - opp-hz = /bits/ 64 <652800000>; - opp-peak-kBps = <1804000 4800000>; - }; - - cpu4_opp6: opp-748800000 { - opp-hz = /bits/ 64 <748800000>; - opp-peak-kBps = <1804000 4800000>; - }; - - cpu4_opp7: opp-825600000 { - opp-hz = /bits/ 64 <825600000>; - opp-peak-kBps = <2188000 9216000>; - }; - - cpu4_opp8: opp-902400000 { - opp-hz = /bits/ 64 <902400000>; - opp-peak-kBps = <2188000 9216000>; - }; - - cpu4_opp9: opp-979200000 { - opp-hz = /bits/ 64 <979200000>; - opp-peak-kBps = <2188000 9216000>; - }; - - cpu4_opp10: opp-1056000000 { - opp-hz = /bits/ 64 <1056000000>; - opp-peak-kBps = <3072000 9216000>; - }; - - cpu4_opp11: opp-1132800000 { - opp-hz = /bits/ 64 <1132800000>; - opp-peak-kBps = <3072000 11980800>; - }; - - cpu4_opp12: opp-1209600000 { - opp-hz = /bits/ 64 <1209600000>; - opp-peak-kBps = <4068000 11980800>; - }; - - cpu4_opp13: opp-1286400000 { - opp-hz = /bits/ 64 <1286400000>; - opp-peak-kBps = <4068000 11980800>; - }; - - cpu4_opp14: opp-1363200000 { - opp-hz = /bits/ 64 <1363200000>; - opp-peak-kBps = <4068000 15052800>; - }; - - cpu4_opp15: opp-1459200000 { - opp-hz = /bits/ 64 <1459200000>; - opp-peak-kBps = <4068000 15052800>; - }; - - cpu4_opp16: opp-1536000000 { - opp-hz = /bits/ 64 <1536000000>; - opp-peak-kBps = <5412000 15052800>; - }; - - cpu4_opp17: opp-1612800000 { - opp-hz = /bits/ 64 <1612800000>; - opp-peak-kBps = <5412000 15052800>; - }; - - cpu4_opp18: opp-1689600000 { - opp-hz = /bits/ 64 <1689600000>; - opp-peak-kBps = <5412000 19353600>; - }; - - cpu4_opp19: opp-1766400000 { - opp-hz = /bits/ 64 <1766400000>; - opp-peak-kBps = <6220000 19353600>; - }; - - cpu4_opp20: opp-1843200000 { - opp-hz = /bits/ 64 <1843200000>; - opp-peak-kBps = <6220000 19353600>; - }; - - cpu4_opp21: opp-1920000000 { - opp-hz = /bits/ 64 <1920000000>; - opp-peak-kBps = <7216000 19353600>; - }; - - cpu4_opp22: opp-1996800000 { - opp-hz = /bits/ 64 <1996800000>; - opp-peak-kBps = <7216000 20889600>; - }; - - cpu4_opp23: opp-2092800000 { - opp-hz = /bits/ 64 <2092800000>; - opp-peak-kBps = <7216000 20889600>; - }; - - cpu4_opp24: opp-2169600000 { - opp-hz = /bits/ 64 <2169600000>; - opp-peak-kBps = <7216000 20889600>; - }; - - cpu4_opp25: opp-2246400000 { - opp-hz = /bits/ 64 <2246400000>; - opp-peak-kBps = <7216000 20889600>; - }; - - cpu4_opp26: opp-2323200000 { - opp-hz = /bits/ 64 <2323200000>; - opp-peak-kBps = <7216000 20889600>; - }; - - cpu4_opp27: opp-2400000000 { - opp-hz = /bits/ 64 <2400000000>; - opp-peak-kBps = <7216000 22425600>; - }; - - cpu4_opp28: opp-2476800000 { - opp-hz = /bits/ 64 <2476800000>; - opp-peak-kBps = <7216000 22425600>; - }; - - cpu4_opp29: opp-2553600000 { - opp-hz = /bits/ 64 <2553600000>; - opp-peak-kBps = <7216000 22425600>; - }; - - cpu4_opp30: opp-2649600000 { - opp-hz = /bits/ 64 <2649600000>; - opp-peak-kBps = <7216000 22425600>; - }; - - cpu4_opp31: opp-2745600000 { - opp-hz = /bits/ 64 <2745600000>; - opp-peak-kBps = <7216000 25497600>; - }; - - cpu4_opp32: opp-2803200000 { - opp-hz = /bits/ 64 <2803200000>; - opp-peak-kBps = <7216000 25497600>; - }; - }; - - dsi_opp_table: opp-table-dsi { - compatible = "operating-points-v2"; - - opp-19200000 { - opp-hz = /bits/ 64 <19200000>; - required-opps = <&rpmhpd_opp_min_svs>; - }; - - opp-180000000 { - opp-hz = /bits/ 64 <180000000>; - required-opps = <&rpmhpd_opp_low_svs>; - }; - - opp-275000000 { - opp-hz = /bits/ 64 <275000000>; - required-opps = <&rpmhpd_opp_svs>; - }; - - opp-328580000 { - opp-hz = /bits/ 64 <328580000>; - required-opps = <&rpmhpd_opp_svs_l1>; - }; - - opp-358000000 { - opp-hz = /bits/ 64 <358000000>; - required-opps = <&rpmhpd_opp_nom>; - }; - }; - - qspi_opp_table: opp-table-qspi { - compatible = "operating-points-v2"; - - opp-19200000 { - opp-hz = /bits/ 64 <19200000>; - required-opps = <&rpmhpd_opp_min_svs>; - }; - - opp-100000000 { - opp-hz = /bits/ 64 <100000000>; - required-opps = <&rpmhpd_opp_low_svs>; - }; - - opp-150000000 { - opp-hz = /bits/ 64 <150000000>; - required-opps = <&rpmhpd_opp_svs>; - }; - - opp-300000000 { - opp-hz = /bits/ 64 <300000000>; - required-opps = <&rpmhpd_opp_nom>; - }; - }; - - qup_opp_table: opp-table-qup { - compatible = "operating-points-v2"; - - opp-50000000 { - opp-hz = /bits/ 64 <50000000>; - required-opps = <&rpmhpd_opp_min_svs>; - }; - - opp-75000000 { - opp-hz = /bits/ 64 <75000000>; - required-opps = <&rpmhpd_opp_low_svs>; - }; - - opp-100000000 { - opp-hz = /bits/ 64 <100000000>; - required-opps = <&rpmhpd_opp_svs>; - }; - - opp-128000000 { - opp-hz = /bits/ 64 <128000000>; - required-opps = <&rpmhpd_opp_nom>; - }; - }; - - pmu { - compatible = "arm,armv8-pmuv3"; - interrupts = <GIC_PPI 5 IRQ_TYPE_LEVEL_HIGH>; - }; - - psci: psci { - compatible = "arm,psci-1.0"; - method = "smc"; - - CPU_PD0: power-domain-cpu0 { - #power-domain-cells = <0>; - power-domains = <&CLUSTER_PD>; - domain-idle-states = <&LITTLE_CPU_SLEEP_0>; - }; - - CPU_PD1: power-domain-cpu1 { - #power-domain-cells = <0>; - power-domains = <&CLUSTER_PD>; - domain-idle-states = <&LITTLE_CPU_SLEEP_0>; - }; - - CPU_PD2: power-domain-cpu2 { - #power-domain-cells = <0>; - power-domains = <&CLUSTER_PD>; - domain-idle-states = <&LITTLE_CPU_SLEEP_0>; - }; - - CPU_PD3: power-domain-cpu3 { - #power-domain-cells = <0>; - power-domains = <&CLUSTER_PD>; - domain-idle-states = <&LITTLE_CPU_SLEEP_0>; - }; - - CPU_PD4: power-domain-cpu4 { - #power-domain-cells = <0>; - power-domains = <&CLUSTER_PD>; - domain-idle-states = <&BIG_CPU_SLEEP_0>; - }; - - CPU_PD5: power-domain-cpu5 { - #power-domain-cells = <0>; - power-domains = <&CLUSTER_PD>; - domain-idle-states = <&BIG_CPU_SLEEP_0>; - }; - - CPU_PD6: power-domain-cpu6 { - #power-domain-cells = <0>; - power-domains = <&CLUSTER_PD>; - domain-idle-states = <&BIG_CPU_SLEEP_0>; - }; - - CPU_PD7: power-domain-cpu7 { - #power-domain-cells = <0>; - power-domains = <&CLUSTER_PD>; - domain-idle-states = <&BIG_CPU_SLEEP_0>; - }; - - CLUSTER_PD: power-domain-cluster { - #power-domain-cells = <0>; - domain-idle-states = <&CLUSTER_SLEEP_0>; - }; - }; - - reserved-memory { - #address-cells = <2>; - #size-cells = <2>; - ranges; - - hyp_mem: hyp-mem@85700000 { - reg = <0 0x85700000 0 0x600000>; - no-map; - }; - - xbl_mem: xbl-mem@85e00000 { - reg = <0 0x85e00000 0 0x100000>; - no-map; - }; - - aop_mem: aop-mem@85fc0000 { - reg = <0 0x85fc0000 0 0x20000>; - no-map; - }; - - aop_cmd_db_mem: aop-cmd-db-mem@85fe0000 { - compatible = "qcom,cmd-db"; - reg = <0x0 0x85fe0000 0 0x20000>; - no-map; - }; - - smem@86000000 { - compatible = "qcom,smem"; - reg = <0x0 0x86000000 0 0x200000>; - no-map; - hwlocks = <&tcsr_mutex 3>; - }; - - tz_mem: tz@86200000 { - reg = <0 0x86200000 0 0x2d00000>; - no-map; - }; - - rmtfs_mem: rmtfs@88f00000 { - compatible = "qcom,rmtfs-mem"; - reg = <0 0x88f00000 0 0x200000>; - no-map; - - qcom,client-id = <1>; - qcom,vmid = <QCOM_SCM_VMID_MSS_MSA>; - }; - - qseecom_mem: qseecom@8ab00000 { - reg = <0 0x8ab00000 0 0x1400000>; - no-map; - }; - - camera_mem: camera-mem@8bf00000 { - reg = <0 0x8bf00000 0 0x500000>; - no-map; - }; - - ipa_fw_mem: ipa-fw@8c400000 { - reg = <0 0x8c400000 0 0x10000>; - no-map; - }; - - ipa_gsi_mem: ipa-gsi@8c410000 { - reg = <0 0x8c410000 0 0x5000>; - no-map; - }; - - gpu_mem: gpu@8c415000 { - reg = <0 0x8c415000 0 0x2000>; - no-map; - }; - - adsp_mem: adsp@8c500000 { - reg = <0 0x8c500000 0 0x1a00000>; - no-map; - }; - - wlan_msa_mem: wlan-msa@8df00000 { - reg = <0 0x8df00000 0 0x100000>; - no-map; - }; - - mpss_region: mpss@8e000000 { - reg = <0 0x8e000000 0 0x7800000>; - no-map; - }; - - venus_mem: venus@95800000 { - reg = <0 0x95800000 0 0x500000>; - no-map; - }; - - cdsp_mem: cdsp@95d00000 { - reg = <0 0x95d00000 0 0x800000>; - no-map; - }; - - mba_region: mba@96500000 { - reg = <0 0x96500000 0 0x200000>; - no-map; - }; - - slpi_mem: slpi@96700000 { - reg = <0 0x96700000 0 0x1400000>; - no-map; - }; - - spss_mem: spss@97b00000 { - reg = <0 0x97b00000 0 0x100000>; - no-map; - }; - - mdata_mem: mpss-metadata { - alloc-ranges = <0 0xa0000000 0 0x20000000>; - size = <0 0x4000>; - no-map; - }; - - fastrpc_mem: fastrpc { - compatible = "shared-dma-pool"; - alloc-ranges = <0x0 0x00000000 0x0 0xffffffff>; - alignment = <0x0 0x400000>; - size = <0x0 0x1000000>; - reusable; - }; - }; - - adsp_pas: remoteproc-adsp { - compatible = "qcom,sdm845-adsp-pas"; - - interrupts-extended = <&intc GIC_SPI 162 IRQ_TYPE_EDGE_RISING>, - <&adsp_smp2p_in 0 IRQ_TYPE_EDGE_RISING>, - <&adsp_smp2p_in 1 IRQ_TYPE_EDGE_RISING>, - <&adsp_smp2p_in 2 IRQ_TYPE_EDGE_RISING>, - <&adsp_smp2p_in 3 IRQ_TYPE_EDGE_RISING>; - interrupt-names = "wdog", "fatal", "ready", - "handover", "stop-ack"; - - clocks = <&rpmhcc RPMH_CXO_CLK>; - clock-names = "xo"; - - memory-region = <&adsp_mem>; - - qcom,qmp = <&aoss_qmp>; - - qcom,smem-states = <&adsp_smp2p_out 0>; - qcom,smem-state-names = "stop"; - - status = "disabled"; - - glink-edge { - interrupts = <GIC_SPI 156 IRQ_TYPE_EDGE_RISING>; - label = "lpass"; - qcom,remote-pid = <2>; - mboxes = <&apss_shared 8>; - - apr { - compatible = "qcom,apr-v2"; - qcom,glink-channels = "apr_audio_svc"; - qcom,domain = <APR_DOMAIN_ADSP>; - #address-cells = <1>; - #size-cells = <0>; - qcom,intents = <512 20>; - - service@3 { - reg = <APR_SVC_ADSP_CORE>; - compatible = "qcom,q6core"; - qcom,protection-domain = "avs/audio", "msm/adsp/audio_pd"; - }; - - q6afe: service@4 { - compatible = "qcom,q6afe"; - reg = <APR_SVC_AFE>; - qcom,protection-domain = "avs/audio", "msm/adsp/audio_pd"; - q6afedai: dais { - compatible = "qcom,q6afe-dais"; - #address-cells = <1>; - #size-cells = <0>; - #sound-dai-cells = <1>; - }; - }; - - q6asm: service@7 { - compatible = "qcom,q6asm"; - reg = <APR_SVC_ASM>; - qcom,protection-domain = "avs/audio", "msm/adsp/audio_pd"; - q6asmdai: dais { - compatible = "qcom,q6asm-dais"; - #address-cells = <1>; - #size-cells = <0>; - #sound-dai-cells = <1>; - iommus = <&apps_smmu 0x1821 0x0>; - }; - }; - - q6adm: service@8 { - compatible = "qcom,q6adm"; - reg = <APR_SVC_ADM>; - qcom,protection-domain = "avs/audio", "msm/adsp/audio_pd"; - q6routing: routing { - compatible = "qcom,q6adm-routing"; - #sound-dai-cells = <0>; - }; - }; - }; - - fastrpc { - compatible = "qcom,fastrpc"; - qcom,glink-channels = "fastrpcglink-apps-dsp"; - label = "adsp"; - qcom,non-secure-domain; - #address-cells = <1>; - #size-cells = <0>; - - compute-cb@3 { - compatible = "qcom,fastrpc-compute-cb"; - reg = <3>; - iommus = <&apps_smmu 0x1823 0x0>; - }; - - compute-cb@4 { - compatible = "qcom,fastrpc-compute-cb"; - reg = <4>; - iommus = <&apps_smmu 0x1824 0x0>; - }; - }; - }; - }; - - cdsp_pas: remoteproc-cdsp { - compatible = "qcom,sdm845-cdsp-pas"; - - interrupts-extended = <&intc GIC_SPI 578 IRQ_TYPE_EDGE_RISING>, - <&cdsp_smp2p_in 0 IRQ_TYPE_EDGE_RISING>, - <&cdsp_smp2p_in 1 IRQ_TYPE_EDGE_RISING>, - <&cdsp_smp2p_in 2 IRQ_TYPE_EDGE_RISING>, - <&cdsp_smp2p_in 3 IRQ_TYPE_EDGE_RISING>; - interrupt-names = "wdog", "fatal", "ready", - "handover", "stop-ack"; - - clocks = <&rpmhcc RPMH_CXO_CLK>; - clock-names = "xo"; - - memory-region = <&cdsp_mem>; - - qcom,qmp = <&aoss_qmp>; - - qcom,smem-states = <&cdsp_smp2p_out 0>; - qcom,smem-state-names = "stop"; - - status = "disabled"; - - glink-edge { - interrupts = <GIC_SPI 574 IRQ_TYPE_EDGE_RISING>; - label = "turing"; - qcom,remote-pid = <5>; - mboxes = <&apss_shared 4>; - fastrpc { - compatible = "qcom,fastrpc"; - qcom,glink-channels = "fastrpcglink-apps-dsp"; - label = "cdsp"; - qcom,non-secure-domain; - #address-cells = <1>; - #size-cells = <0>; - - compute-cb@1 { - compatible = "qcom,fastrpc-compute-cb"; - reg = <1>; - iommus = <&apps_smmu 0x1401 0x30>; - }; - - compute-cb@2 { - compatible = "qcom,fastrpc-compute-cb"; - reg = <2>; - iommus = <&apps_smmu 0x1402 0x30>; - }; - - compute-cb@3 { - compatible = "qcom,fastrpc-compute-cb"; - reg = <3>; - iommus = <&apps_smmu 0x1403 0x30>; - }; - - compute-cb@4 { - compatible = "qcom,fastrpc-compute-cb"; - reg = <4>; - iommus = <&apps_smmu 0x1404 0x30>; - }; - - compute-cb@5 { - compatible = "qcom,fastrpc-compute-cb"; - reg = <5>; - iommus = <&apps_smmu 0x1405 0x30>; - }; - - compute-cb@6 { - compatible = "qcom,fastrpc-compute-cb"; - reg = <6>; - iommus = <&apps_smmu 0x1406 0x30>; - }; - - compute-cb@7 { - compatible = "qcom,fastrpc-compute-cb"; - reg = <7>; - iommus = <&apps_smmu 0x1407 0x30>; - }; - - compute-cb@8 { - compatible = "qcom,fastrpc-compute-cb"; - reg = <8>; - iommus = <&apps_smmu 0x1408 0x30>; - }; - }; - }; - }; - - smp2p-cdsp { - compatible = "qcom,smp2p"; - qcom,smem = <94>, <432>; - - interrupts = <GIC_SPI 576 IRQ_TYPE_EDGE_RISING>; - - mboxes = <&apss_shared 6>; - - qcom,local-pid = <0>; - qcom,remote-pid = <5>; - - cdsp_smp2p_out: master-kernel { - qcom,entry-name = "master-kernel"; - #qcom,smem-state-cells = <1>; - }; - - cdsp_smp2p_in: slave-kernel { - qcom,entry-name = "slave-kernel"; - - interrupt-controller; - #interrupt-cells = <2>; - }; - }; - - smp2p-lpass { - compatible = "qcom,smp2p"; - qcom,smem = <443>, <429>; - - interrupts = <GIC_SPI 158 IRQ_TYPE_EDGE_RISING>; - - mboxes = <&apss_shared 10>; - - qcom,local-pid = <0>; - qcom,remote-pid = <2>; - - adsp_smp2p_out: master-kernel { - qcom,entry-name = "master-kernel"; - #qcom,smem-state-cells = <1>; - }; - - adsp_smp2p_in: slave-kernel { - qcom,entry-name = "slave-kernel"; - - interrupt-controller; - #interrupt-cells = <2>; - }; - }; - - smp2p-mpss { - compatible = "qcom,smp2p"; - qcom,smem = <435>, <428>; - interrupts = <GIC_SPI 451 IRQ_TYPE_EDGE_RISING>; - mboxes = <&apss_shared 14>; - qcom,local-pid = <0>; - qcom,remote-pid = <1>; - - modem_smp2p_out: master-kernel { - qcom,entry-name = "master-kernel"; - #qcom,smem-state-cells = <1>; - }; - - modem_smp2p_in: slave-kernel { - qcom,entry-name = "slave-kernel"; - interrupt-controller; - #interrupt-cells = <2>; - }; - - ipa_smp2p_out: ipa-ap-to-modem { - qcom,entry-name = "ipa"; - #qcom,smem-state-cells = <1>; - }; - - ipa_smp2p_in: ipa-modem-to-ap { - qcom,entry-name = "ipa"; - interrupt-controller; - #interrupt-cells = <2>; - }; - }; - - smp2p-slpi { - compatible = "qcom,smp2p"; - qcom,smem = <481>, <430>; - interrupts = <GIC_SPI 172 IRQ_TYPE_EDGE_RISING>; - mboxes = <&apss_shared 26>; - qcom,local-pid = <0>; - qcom,remote-pid = <3>; - - slpi_smp2p_out: master-kernel { - qcom,entry-name = "master-kernel"; - #qcom,smem-state-cells = <1>; - }; - - slpi_smp2p_in: slave-kernel { - qcom,entry-name = "slave-kernel"; - interrupt-controller; - #interrupt-cells = <2>; - }; - }; - - soc: soc@0 { - #address-cells = <2>; - #size-cells = <2>; - ranges = <0 0 0 0 0x10 0>; - dma-ranges = <0 0 0 0 0x10 0>; - compatible = "simple-bus"; - - gcc: clock-controller@100000 { - compatible = "qcom,gcc-sdm845"; - reg = <0 0x00100000 0 0x1f0000>; - clocks = <&rpmhcc RPMH_CXO_CLK>, - <&rpmhcc RPMH_CXO_CLK_A>, - <&sleep_clk>, - <&pcie0_phy>, - <&pcie1_phy>; - clock-names = "bi_tcxo", - "bi_tcxo_ao", - "sleep_clk", - "pcie_0_pipe_clk", - "pcie_1_pipe_clk"; - #clock-cells = <1>; - #reset-cells = <1>; - #power-domain-cells = <1>; - power-domains = <&rpmhpd SDM845_CX>; - }; - - qfprom@784000 { - compatible = "qcom,sdm845-qfprom", "qcom,qfprom"; - reg = <0 0x00784000 0 0x8ff>; - #address-cells = <1>; - #size-cells = <1>; - - qusb2p_hstx_trim: hstx-trim-primary@1eb { - reg = <0x1eb 0x1>; - bits = <1 4>; - }; - - qusb2s_hstx_trim: hstx-trim-secondary@1eb { - reg = <0x1eb 0x2>; - bits = <6 4>; - }; - }; - - rng: rng@793000 { - compatible = "qcom,prng-ee"; - reg = <0 0x00793000 0 0x1000>; - clocks = <&gcc GCC_PRNG_AHB_CLK>; - clock-names = "core"; - }; - - gpi_dma0: dma-controller@800000 { - #dma-cells = <3>; - compatible = "qcom,sdm845-gpi-dma"; - reg = <0 0x00800000 0 0x60000>; - interrupts = <GIC_SPI 244 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 245 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 246 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 247 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 248 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 249 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 250 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 251 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 252 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 253 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 254 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 255 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 256 IRQ_TYPE_LEVEL_HIGH>; - dma-channels = <13>; - dma-channel-mask = <0xfa>; - iommus = <&apps_smmu 0x0016 0x0>; - status = "disabled"; - }; - - qupv3_id_0: geniqup@8c0000 { - compatible = "qcom,geni-se-qup"; - reg = <0 0x008c0000 0 0x6000>; - clock-names = "m-ahb", "s-ahb"; - clocks = <&gcc GCC_QUPV3_WRAP_0_M_AHB_CLK>, - <&gcc GCC_QUPV3_WRAP_0_S_AHB_CLK>; - iommus = <&apps_smmu 0x3 0x0>; - #address-cells = <2>; - #size-cells = <2>; - ranges; - interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>; - interconnect-names = "qup-core"; - status = "disabled"; - - i2c0: i2c@880000 { - compatible = "qcom,geni-i2c"; - reg = <0 0x00880000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP0_S0_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_i2c0_default>; - interrupts = <GIC_SPI 601 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&rpmhpd SDM845_CX>; - operating-points-v2 = <&qup_opp_table>; - interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>, - <&aggre1_noc MASTER_QUP_1 0 &mem_noc SLAVE_EBI1 0>; - interconnect-names = "qup-core", "qup-config", "qup-memory"; - dmas = <&gpi_dma0 0 0 QCOM_GPI_I2C>, - <&gpi_dma0 1 0 QCOM_GPI_I2C>; - dma-names = "tx", "rx"; - status = "disabled"; - }; - - spi0: spi@880000 { - compatible = "qcom,geni-spi"; - reg = <0 0x00880000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP0_S0_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_spi0_default>; - interrupts = <GIC_SPI 601 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>; - interconnect-names = "qup-core", "qup-config"; - dmas = <&gpi_dma0 0 0 QCOM_GPI_SPI>, - <&gpi_dma0 1 0 QCOM_GPI_SPI>; - dma-names = "tx", "rx"; - status = "disabled"; - }; - - uart0: serial@880000 { - compatible = "qcom,geni-uart"; - reg = <0 0x00880000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP0_S0_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_uart0_default>; - interrupts = <GIC_SPI 601 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&rpmhpd SDM845_CX>; - operating-points-v2 = <&qup_opp_table>; - interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>; - interconnect-names = "qup-core", "qup-config"; - status = "disabled"; - }; - - i2c1: i2c@884000 { - compatible = "qcom,geni-i2c"; - reg = <0 0x00884000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP0_S1_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_i2c1_default>; - interrupts = <GIC_SPI 602 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&rpmhpd SDM845_CX>; - operating-points-v2 = <&qup_opp_table>; - interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>, - <&aggre1_noc MASTER_QUP_1 0 &mem_noc SLAVE_EBI1 0>; - interconnect-names = "qup-core", "qup-config", "qup-memory"; - dmas = <&gpi_dma0 0 1 QCOM_GPI_I2C>, - <&gpi_dma0 1 1 QCOM_GPI_I2C>; - dma-names = "tx", "rx"; - status = "disabled"; - }; - - spi1: spi@884000 { - compatible = "qcom,geni-spi"; - reg = <0 0x00884000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP0_S1_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_spi1_default>; - interrupts = <GIC_SPI 602 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>; - interconnect-names = "qup-core", "qup-config"; - dmas = <&gpi_dma0 0 1 QCOM_GPI_SPI>, - <&gpi_dma0 1 1 QCOM_GPI_SPI>; - dma-names = "tx", "rx"; - status = "disabled"; - }; - - uart1: serial@884000 { - compatible = "qcom,geni-uart"; - reg = <0 0x00884000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP0_S1_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_uart1_default>; - interrupts = <GIC_SPI 602 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&rpmhpd SDM845_CX>; - operating-points-v2 = <&qup_opp_table>; - interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>; - interconnect-names = "qup-core", "qup-config"; - status = "disabled"; - }; - - i2c2: i2c@888000 { - compatible = "qcom,geni-i2c"; - reg = <0 0x00888000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP0_S2_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_i2c2_default>; - interrupts = <GIC_SPI 603 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&rpmhpd SDM845_CX>; - operating-points-v2 = <&qup_opp_table>; - interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>, - <&aggre1_noc MASTER_QUP_1 0 &mem_noc SLAVE_EBI1 0>; - interconnect-names = "qup-core", "qup-config", "qup-memory"; - dmas = <&gpi_dma0 0 2 QCOM_GPI_I2C>, - <&gpi_dma0 1 2 QCOM_GPI_I2C>; - dma-names = "tx", "rx"; - status = "disabled"; - }; - - spi2: spi@888000 { - compatible = "qcom,geni-spi"; - reg = <0 0x00888000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP0_S2_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_spi2_default>; - interrupts = <GIC_SPI 603 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>; - interconnect-names = "qup-core", "qup-config"; - dmas = <&gpi_dma0 0 2 QCOM_GPI_SPI>, - <&gpi_dma0 1 2 QCOM_GPI_SPI>; - dma-names = "tx", "rx"; - status = "disabled"; - }; - - uart2: serial@888000 { - compatible = "qcom,geni-uart"; - reg = <0 0x00888000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP0_S2_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_uart2_default>; - interrupts = <GIC_SPI 603 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&rpmhpd SDM845_CX>; - operating-points-v2 = <&qup_opp_table>; - interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>; - interconnect-names = "qup-core", "qup-config"; - status = "disabled"; - }; - - i2c3: i2c@88c000 { - compatible = "qcom,geni-i2c"; - reg = <0 0x0088c000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP0_S3_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_i2c3_default>; - interrupts = <GIC_SPI 604 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&rpmhpd SDM845_CX>; - operating-points-v2 = <&qup_opp_table>; - interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>, - <&aggre1_noc MASTER_QUP_1 0 &mem_noc SLAVE_EBI1 0>; - interconnect-names = "qup-core", "qup-config", "qup-memory"; - dmas = <&gpi_dma0 0 3 QCOM_GPI_I2C>, - <&gpi_dma0 1 3 QCOM_GPI_I2C>; - dma-names = "tx", "rx"; - status = "disabled"; - }; - - spi3: spi@88c000 { - compatible = "qcom,geni-spi"; - reg = <0 0x0088c000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP0_S3_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_spi3_default>; - interrupts = <GIC_SPI 604 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>; - interconnect-names = "qup-core", "qup-config"; - dmas = <&gpi_dma0 0 3 QCOM_GPI_SPI>, - <&gpi_dma0 1 3 QCOM_GPI_SPI>; - dma-names = "tx", "rx"; - status = "disabled"; - }; - - uart3: serial@88c000 { - compatible = "qcom,geni-uart"; - reg = <0 0x0088c000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP0_S3_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_uart3_default>; - interrupts = <GIC_SPI 604 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&rpmhpd SDM845_CX>; - operating-points-v2 = <&qup_opp_table>; - interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>; - interconnect-names = "qup-core", "qup-config"; - status = "disabled"; - }; - - i2c4: i2c@890000 { - compatible = "qcom,geni-i2c"; - reg = <0 0x00890000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP0_S4_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_i2c4_default>; - interrupts = <GIC_SPI 605 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&rpmhpd SDM845_CX>; - operating-points-v2 = <&qup_opp_table>; - interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>, - <&aggre1_noc MASTER_QUP_1 0 &mem_noc SLAVE_EBI1 0>; - interconnect-names = "qup-core", "qup-config", "qup-memory"; - dmas = <&gpi_dma0 0 4 QCOM_GPI_I2C>, - <&gpi_dma0 1 4 QCOM_GPI_I2C>; - dma-names = "tx", "rx"; - status = "disabled"; - }; - - spi4: spi@890000 { - compatible = "qcom,geni-spi"; - reg = <0 0x00890000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP0_S4_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_spi4_default>; - interrupts = <GIC_SPI 605 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>; - interconnect-names = "qup-core", "qup-config"; - dmas = <&gpi_dma0 0 4 QCOM_GPI_SPI>, - <&gpi_dma0 1 4 QCOM_GPI_SPI>; - dma-names = "tx", "rx"; - status = "disabled"; - }; - - uart4: serial@890000 { - compatible = "qcom,geni-uart"; - reg = <0 0x00890000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP0_S4_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_uart4_default>; - interrupts = <GIC_SPI 605 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&rpmhpd SDM845_CX>; - operating-points-v2 = <&qup_opp_table>; - interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>; - interconnect-names = "qup-core", "qup-config"; - status = "disabled"; - }; - - i2c5: i2c@894000 { - compatible = "qcom,geni-i2c"; - reg = <0 0x00894000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP0_S5_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_i2c5_default>; - interrupts = <GIC_SPI 606 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&rpmhpd SDM845_CX>; - operating-points-v2 = <&qup_opp_table>; - interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>, - <&aggre1_noc MASTER_QUP_1 0 &mem_noc SLAVE_EBI1 0>; - interconnect-names = "qup-core", "qup-config", "qup-memory"; - dmas = <&gpi_dma0 0 5 QCOM_GPI_I2C>, - <&gpi_dma0 1 5 QCOM_GPI_I2C>; - dma-names = "tx", "rx"; - status = "disabled"; - }; - - spi5: spi@894000 { - compatible = "qcom,geni-spi"; - reg = <0 0x00894000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP0_S5_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_spi5_default>; - interrupts = <GIC_SPI 606 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>; - interconnect-names = "qup-core", "qup-config"; - dmas = <&gpi_dma0 0 5 QCOM_GPI_SPI>, - <&gpi_dma0 1 5 QCOM_GPI_SPI>; - dma-names = "tx", "rx"; - status = "disabled"; - }; - - uart5: serial@894000 { - compatible = "qcom,geni-uart"; - reg = <0 0x00894000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP0_S5_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_uart5_default>; - interrupts = <GIC_SPI 606 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&rpmhpd SDM845_CX>; - operating-points-v2 = <&qup_opp_table>; - interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>; - interconnect-names = "qup-core", "qup-config"; - status = "disabled"; - }; - - i2c6: i2c@898000 { - compatible = "qcom,geni-i2c"; - reg = <0 0x00898000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP0_S6_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_i2c6_default>; - interrupts = <GIC_SPI 607 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&rpmhpd SDM845_CX>; - operating-points-v2 = <&qup_opp_table>; - interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>, - <&aggre1_noc MASTER_QUP_1 0 &mem_noc SLAVE_EBI1 0>; - interconnect-names = "qup-core", "qup-config", "qup-memory"; - dmas = <&gpi_dma0 0 6 QCOM_GPI_I2C>, - <&gpi_dma0 1 6 QCOM_GPI_I2C>; - dma-names = "tx", "rx"; - status = "disabled"; - }; - - spi6: spi@898000 { - compatible = "qcom,geni-spi"; - reg = <0 0x00898000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP0_S6_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_spi6_default>; - interrupts = <GIC_SPI 607 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>; - interconnect-names = "qup-core", "qup-config"; - dmas = <&gpi_dma0 0 6 QCOM_GPI_SPI>, - <&gpi_dma0 1 6 QCOM_GPI_SPI>; - dma-names = "tx", "rx"; - status = "disabled"; - }; - - uart6: serial@898000 { - compatible = "qcom,geni-uart"; - reg = <0 0x00898000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP0_S6_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_uart6_default>; - interrupts = <GIC_SPI 607 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&rpmhpd SDM845_CX>; - operating-points-v2 = <&qup_opp_table>; - interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>; - interconnect-names = "qup-core", "qup-config"; - status = "disabled"; - }; - - i2c7: i2c@89c000 { - compatible = "qcom,geni-i2c"; - reg = <0 0x0089c000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP0_S7_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_i2c7_default>; - interrupts = <GIC_SPI 608 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&rpmhpd SDM845_CX>; - operating-points-v2 = <&qup_opp_table>; - status = "disabled"; - }; - - spi7: spi@89c000 { - compatible = "qcom,geni-spi"; - reg = <0 0x0089c000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP0_S7_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_spi7_default>; - interrupts = <GIC_SPI 608 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>; - interconnect-names = "qup-core", "qup-config"; - dmas = <&gpi_dma0 0 7 QCOM_GPI_SPI>, - <&gpi_dma0 1 7 QCOM_GPI_SPI>; - dma-names = "tx", "rx"; - status = "disabled"; - }; - - uart7: serial@89c000 { - compatible = "qcom,geni-uart"; - reg = <0 0x0089c000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP0_S7_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_uart7_default>; - interrupts = <GIC_SPI 608 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&rpmhpd SDM845_CX>; - operating-points-v2 = <&qup_opp_table>; - interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>; - interconnect-names = "qup-core", "qup-config"; - status = "disabled"; - }; - }; - - gpi_dma1: dma-controller@a00000 { - #dma-cells = <3>; - compatible = "qcom,sdm845-gpi-dma"; - reg = <0 0x00a00000 0 0x60000>; - interrupts = <GIC_SPI 279 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 280 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 281 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 282 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 283 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 284 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 293 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 294 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 295 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 296 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 297 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 298 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 299 IRQ_TYPE_LEVEL_HIGH>; - dma-channels = <13>; - dma-channel-mask = <0xfa>; - iommus = <&apps_smmu 0x06d6 0x0>; - status = "disabled"; - }; - - qupv3_id_1: geniqup@ac0000 { - compatible = "qcom,geni-se-qup"; - reg = <0 0x00ac0000 0 0x6000>; - clock-names = "m-ahb", "s-ahb"; - clocks = <&gcc GCC_QUPV3_WRAP_1_M_AHB_CLK>, - <&gcc GCC_QUPV3_WRAP_1_S_AHB_CLK>; - iommus = <&apps_smmu 0x6c3 0x0>; - #address-cells = <2>; - #size-cells = <2>; - ranges; - interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>; - interconnect-names = "qup-core"; - status = "disabled"; - - i2c8: i2c@a80000 { - compatible = "qcom,geni-i2c"; - reg = <0 0x00a80000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP1_S0_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_i2c8_default>; - interrupts = <GIC_SPI 353 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&rpmhpd SDM845_CX>; - operating-points-v2 = <&qup_opp_table>; - interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>, - <&aggre2_noc MASTER_QUP_2 0 &mem_noc SLAVE_EBI1 0>; - interconnect-names = "qup-core", "qup-config", "qup-memory"; - dmas = <&gpi_dma1 0 0 QCOM_GPI_I2C>, - <&gpi_dma1 1 0 QCOM_GPI_I2C>; - dma-names = "tx", "rx"; - status = "disabled"; - }; - - spi8: spi@a80000 { - compatible = "qcom,geni-spi"; - reg = <0 0x00a80000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP1_S0_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_spi8_default>; - interrupts = <GIC_SPI 353 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>; - interconnect-names = "qup-core", "qup-config"; - dmas = <&gpi_dma1 0 0 QCOM_GPI_SPI>, - <&gpi_dma1 1 0 QCOM_GPI_SPI>; - dma-names = "tx", "rx"; - status = "disabled"; - }; - - uart8: serial@a80000 { - compatible = "qcom,geni-uart"; - reg = <0 0x00a80000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP1_S0_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_uart8_default>; - interrupts = <GIC_SPI 353 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&rpmhpd SDM845_CX>; - operating-points-v2 = <&qup_opp_table>; - interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>; - interconnect-names = "qup-core", "qup-config"; - status = "disabled"; - }; - - i2c9: i2c@a84000 { - compatible = "qcom,geni-i2c"; - reg = <0 0x00a84000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP1_S1_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_i2c9_default>; - interrupts = <GIC_SPI 354 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&rpmhpd SDM845_CX>; - operating-points-v2 = <&qup_opp_table>; - interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>, - <&aggre2_noc MASTER_QUP_2 0 &mem_noc SLAVE_EBI1 0>; - interconnect-names = "qup-core", "qup-config", "qup-memory"; - dmas = <&gpi_dma1 0 1 QCOM_GPI_I2C>, - <&gpi_dma1 1 1 QCOM_GPI_I2C>; - dma-names = "tx", "rx"; - status = "disabled"; - }; - - spi9: spi@a84000 { - compatible = "qcom,geni-spi"; - reg = <0 0x00a84000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP1_S1_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_spi9_default>; - interrupts = <GIC_SPI 354 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>; - interconnect-names = "qup-core", "qup-config"; - dmas = <&gpi_dma1 0 1 QCOM_GPI_SPI>, - <&gpi_dma1 1 1 QCOM_GPI_SPI>; - dma-names = "tx", "rx"; - status = "disabled"; - }; - - uart9: serial@a84000 { - compatible = "qcom,geni-debug-uart"; - reg = <0 0x00a84000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP1_S1_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_uart9_default>; - interrupts = <GIC_SPI 354 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&rpmhpd SDM845_CX>; - operating-points-v2 = <&qup_opp_table>; - interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>; - interconnect-names = "qup-core", "qup-config"; - status = "disabled"; - }; - - i2c10: i2c@a88000 { - compatible = "qcom,geni-i2c"; - reg = <0 0x00a88000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP1_S2_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_i2c10_default>; - interrupts = <GIC_SPI 355 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&rpmhpd SDM845_CX>; - operating-points-v2 = <&qup_opp_table>; - interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>, - <&aggre2_noc MASTER_QUP_2 0 &mem_noc SLAVE_EBI1 0>; - interconnect-names = "qup-core", "qup-config", "qup-memory"; - dmas = <&gpi_dma1 0 2 QCOM_GPI_I2C>, - <&gpi_dma1 1 2 QCOM_GPI_I2C>; - dma-names = "tx", "rx"; - status = "disabled"; - }; - - spi10: spi@a88000 { - compatible = "qcom,geni-spi"; - reg = <0 0x00a88000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP1_S2_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_spi10_default>; - interrupts = <GIC_SPI 355 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>; - interconnect-names = "qup-core", "qup-config"; - dmas = <&gpi_dma1 0 2 QCOM_GPI_SPI>, - <&gpi_dma1 1 2 QCOM_GPI_SPI>; - dma-names = "tx", "rx"; - status = "disabled"; - }; - - uart10: serial@a88000 { - compatible = "qcom,geni-uart"; - reg = <0 0x00a88000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP1_S2_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_uart10_default>; - interrupts = <GIC_SPI 355 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&rpmhpd SDM845_CX>; - operating-points-v2 = <&qup_opp_table>; - interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>; - interconnect-names = "qup-core", "qup-config"; - status = "disabled"; - }; - - i2c11: i2c@a8c000 { - compatible = "qcom,geni-i2c"; - reg = <0 0x00a8c000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP1_S3_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_i2c11_default>; - interrupts = <GIC_SPI 356 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&rpmhpd SDM845_CX>; - operating-points-v2 = <&qup_opp_table>; - interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>, - <&aggre2_noc MASTER_QUP_2 0 &mem_noc SLAVE_EBI1 0>; - interconnect-names = "qup-core", "qup-config", "qup-memory"; - dmas = <&gpi_dma1 0 3 QCOM_GPI_I2C>, - <&gpi_dma1 1 3 QCOM_GPI_I2C>; - dma-names = "tx", "rx"; - status = "disabled"; - }; - - spi11: spi@a8c000 { - compatible = "qcom,geni-spi"; - reg = <0 0x00a8c000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP1_S3_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_spi11_default>; - interrupts = <GIC_SPI 356 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>; - interconnect-names = "qup-core", "qup-config"; - dmas = <&gpi_dma1 0 3 QCOM_GPI_SPI>, - <&gpi_dma1 1 3 QCOM_GPI_SPI>; - dma-names = "tx", "rx"; - status = "disabled"; - }; - - uart11: serial@a8c000 { - compatible = "qcom,geni-uart"; - reg = <0 0x00a8c000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP1_S3_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_uart11_default>; - interrupts = <GIC_SPI 356 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&rpmhpd SDM845_CX>; - operating-points-v2 = <&qup_opp_table>; - interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>; - interconnect-names = "qup-core", "qup-config"; - status = "disabled"; - }; - - i2c12: i2c@a90000 { - compatible = "qcom,geni-i2c"; - reg = <0 0x00a90000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP1_S4_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_i2c12_default>; - interrupts = <GIC_SPI 357 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&rpmhpd SDM845_CX>; - operating-points-v2 = <&qup_opp_table>; - interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>, - <&aggre2_noc MASTER_QUP_2 0 &mem_noc SLAVE_EBI1 0>; - interconnect-names = "qup-core", "qup-config", "qup-memory"; - dmas = <&gpi_dma1 0 4 QCOM_GPI_I2C>, - <&gpi_dma1 1 4 QCOM_GPI_I2C>; - dma-names = "tx", "rx"; - status = "disabled"; - }; - - spi12: spi@a90000 { - compatible = "qcom,geni-spi"; - reg = <0 0x00a90000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP1_S4_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_spi12_default>; - interrupts = <GIC_SPI 357 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>; - interconnect-names = "qup-core", "qup-config"; - dmas = <&gpi_dma1 0 4 QCOM_GPI_SPI>, - <&gpi_dma1 1 4 QCOM_GPI_SPI>; - dma-names = "tx", "rx"; - status = "disabled"; - }; - - uart12: serial@a90000 { - compatible = "qcom,geni-uart"; - reg = <0 0x00a90000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP1_S4_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_uart12_default>; - interrupts = <GIC_SPI 357 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&rpmhpd SDM845_CX>; - operating-points-v2 = <&qup_opp_table>; - interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>; - interconnect-names = "qup-core", "qup-config"; - status = "disabled"; - }; - - i2c13: i2c@a94000 { - compatible = "qcom,geni-i2c"; - reg = <0 0x00a94000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP1_S5_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_i2c13_default>; - interrupts = <GIC_SPI 358 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&rpmhpd SDM845_CX>; - operating-points-v2 = <&qup_opp_table>; - interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>, - <&aggre2_noc MASTER_QUP_2 0 &mem_noc SLAVE_EBI1 0>; - interconnect-names = "qup-core", "qup-config", "qup-memory"; - dmas = <&gpi_dma1 0 5 QCOM_GPI_I2C>, - <&gpi_dma1 1 5 QCOM_GPI_I2C>; - dma-names = "tx", "rx"; - status = "disabled"; - }; - - spi13: spi@a94000 { - compatible = "qcom,geni-spi"; - reg = <0 0x00a94000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP1_S5_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_spi13_default>; - interrupts = <GIC_SPI 358 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>; - interconnect-names = "qup-core", "qup-config"; - dmas = <&gpi_dma1 0 5 QCOM_GPI_SPI>, - <&gpi_dma1 1 5 QCOM_GPI_SPI>; - dma-names = "tx", "rx"; - status = "disabled"; - }; - - uart13: serial@a94000 { - compatible = "qcom,geni-uart"; - reg = <0 0x00a94000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP1_S5_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_uart13_default>; - interrupts = <GIC_SPI 358 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&rpmhpd SDM845_CX>; - operating-points-v2 = <&qup_opp_table>; - interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>; - interconnect-names = "qup-core", "qup-config"; - status = "disabled"; - }; - - i2c14: i2c@a98000 { - compatible = "qcom,geni-i2c"; - reg = <0 0x00a98000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP1_S6_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_i2c14_default>; - interrupts = <GIC_SPI 359 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&rpmhpd SDM845_CX>; - operating-points-v2 = <&qup_opp_table>; - interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>, - <&aggre2_noc MASTER_QUP_2 0 &mem_noc SLAVE_EBI1 0>; - interconnect-names = "qup-core", "qup-config", "qup-memory"; - dmas = <&gpi_dma1 0 6 QCOM_GPI_I2C>, - <&gpi_dma1 1 6 QCOM_GPI_I2C>; - dma-names = "tx", "rx"; - status = "disabled"; - }; - - spi14: spi@a98000 { - compatible = "qcom,geni-spi"; - reg = <0 0x00a98000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP1_S6_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_spi14_default>; - interrupts = <GIC_SPI 359 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>; - interconnect-names = "qup-core", "qup-config"; - dmas = <&gpi_dma1 0 6 QCOM_GPI_SPI>, - <&gpi_dma1 1 6 QCOM_GPI_SPI>; - dma-names = "tx", "rx"; - status = "disabled"; - }; - - uart14: serial@a98000 { - compatible = "qcom,geni-uart"; - reg = <0 0x00a98000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP1_S6_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_uart14_default>; - interrupts = <GIC_SPI 359 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&rpmhpd SDM845_CX>; - operating-points-v2 = <&qup_opp_table>; - interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>; - interconnect-names = "qup-core", "qup-config"; - status = "disabled"; - }; - - i2c15: i2c@a9c000 { - compatible = "qcom,geni-i2c"; - reg = <0 0x00a9c000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP1_S7_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_i2c15_default>; - interrupts = <GIC_SPI 360 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&rpmhpd SDM845_CX>; - operating-points-v2 = <&qup_opp_table>; - status = "disabled"; - interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>, - <&aggre2_noc MASTER_QUP_2 0 &mem_noc SLAVE_EBI1 0>; - interconnect-names = "qup-core", "qup-config", "qup-memory"; - dmas = <&gpi_dma1 0 7 QCOM_GPI_I2C>, - <&gpi_dma1 1 7 QCOM_GPI_I2C>; - dma-names = "tx", "rx"; - }; - - spi15: spi@a9c000 { - compatible = "qcom,geni-spi"; - reg = <0 0x00a9c000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP1_S7_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_spi15_default>; - interrupts = <GIC_SPI 360 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>; - interconnect-names = "qup-core", "qup-config"; - dmas = <&gpi_dma1 0 7 QCOM_GPI_SPI>, - <&gpi_dma1 1 7 QCOM_GPI_SPI>; - dma-names = "tx", "rx"; - status = "disabled"; - }; - - uart15: serial@a9c000 { - compatible = "qcom,geni-uart"; - reg = <0 0x00a9c000 0 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP1_S7_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_uart15_default>; - interrupts = <GIC_SPI 360 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&rpmhpd SDM845_CX>; - operating-points-v2 = <&qup_opp_table>; - interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>; - interconnect-names = "qup-core", "qup-config"; - status = "disabled"; - }; - }; - - llcc: system-cache-controller@1100000 { - compatible = "qcom,sdm845-llcc"; - reg = <0 0x01100000 0 0x45000>, <0 0x01180000 0 0x50000>, - <0 0x01200000 0 0x50000>, <0 0x01280000 0 0x50000>, - <0 0x01300000 0 0x50000>; - reg-names = "llcc0_base", "llcc1_base", "llcc2_base", - "llcc3_base", "llcc_broadcast_base"; - interrupts = <GIC_SPI 582 IRQ_TYPE_LEVEL_HIGH>; - }; - - dma@10a2000 { - compatible = "qcom,sdm845-dcc", "qcom,dcc"; - reg = <0x0 0x010a2000 0x0 0x1000>, - <0x0 0x010ae000 0x0 0x2000>; - }; - - pmu@114a000 { - compatible = "qcom,sdm845-llcc-bwmon"; - reg = <0 0x0114a000 0 0x1000>; - interrupts = <GIC_SPI 580 IRQ_TYPE_LEVEL_HIGH>; - interconnects = <&mem_noc MASTER_LLCC 3 &mem_noc SLAVE_EBI1 3>; - - operating-points-v2 = <&llcc_bwmon_opp_table>; - - llcc_bwmon_opp_table: opp-table { - compatible = "operating-points-v2"; - - /* - * The interconnect path bandwidth taken from - * cpu4_opp_table bandwidth for gladiator_noc-mem_noc - * interconnect. This also matches the - * bandwidth table of qcom,llccbw (qcom,bw-tbl, - * bus width: 4 bytes) from msm-4.9 downstream - * kernel. - */ - opp-0 { - opp-peak-kBps = <800000>; - }; - opp-1 { - opp-peak-kBps = <1804000>; - }; - opp-2 { - opp-peak-kBps = <3072000>; - }; - opp-3 { - opp-peak-kBps = <5412000>; - }; - opp-4 { - opp-peak-kBps = <7216000>; - }; - }; - }; - - pmu@1436400 { - compatible = "qcom,sdm845-cpu-bwmon", "qcom,sdm845-bwmon"; - reg = <0 0x01436400 0 0x600>; - interrupts = <GIC_SPI 581 IRQ_TYPE_LEVEL_HIGH>; - interconnects = <&gladiator_noc MASTER_APPSS_PROC 3 &mem_noc SLAVE_LLCC 3>; - - operating-points-v2 = <&cpu_bwmon_opp_table>; - - cpu_bwmon_opp_table: opp-table { - compatible = "operating-points-v2"; - - /* - * The interconnect path bandwidth taken from - * cpu4_opp_table bandwidth for OSM L3 - * interconnect. This also matches the OSM L3 - * from bandwidth table of qcom,cpu4-l3lat-mon - * (qcom,core-dev-table, bus width: 16 bytes) - * from msm-4.9 downstream kernel. - */ - opp-0 { - opp-peak-kBps = <4800000>; - }; - opp-1 { - opp-peak-kBps = <9216000>; - }; - opp-2 { - opp-peak-kBps = <15052800>; - }; - opp-3 { - opp-peak-kBps = <20889600>; - }; - opp-4 { - opp-peak-kBps = <25497600>; - }; - }; - }; - - pcie0: pci@1c00000 { - compatible = "qcom,pcie-sdm845"; - reg = <0 0x01c00000 0 0x2000>, - <0 0x60000000 0 0xf1d>, - <0 0x60000f20 0 0xa8>, - <0 0x60100000 0 0x100000>, - <0 0x01c07000 0 0x1000>; - reg-names = "parf", "dbi", "elbi", "config", "mhi"; - device_type = "pci"; - linux,pci-domain = <0>; - bus-range = <0x00 0xff>; - num-lanes = <1>; - - #address-cells = <3>; - #size-cells = <2>; - - ranges = <0x01000000 0x0 0x00000000 0x0 0x60200000 0x0 0x100000>, - <0x02000000 0x0 0x60300000 0x0 0x60300000 0x0 0xd00000>; - - interrupts = <GIC_SPI 141 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "msi"; - #interrupt-cells = <1>; - interrupt-map-mask = <0 0 0 0x7>; - interrupt-map = <0 0 0 1 &intc 0 0 0 149 IRQ_TYPE_LEVEL_HIGH>, /* int_a */ - <0 0 0 2 &intc 0 0 0 150 IRQ_TYPE_LEVEL_HIGH>, /* int_b */ - <0 0 0 3 &intc 0 0 0 151 IRQ_TYPE_LEVEL_HIGH>, /* int_c */ - <0 0 0 4 &intc 0 0 0 152 IRQ_TYPE_LEVEL_HIGH>; /* int_d */ - - clocks = <&gcc GCC_PCIE_0_PIPE_CLK>, - <&gcc GCC_PCIE_0_AUX_CLK>, - <&gcc GCC_PCIE_0_CFG_AHB_CLK>, - <&gcc GCC_PCIE_0_MSTR_AXI_CLK>, - <&gcc GCC_PCIE_0_SLV_AXI_CLK>, - <&gcc GCC_PCIE_0_SLV_Q2A_AXI_CLK>, - <&gcc GCC_AGGRE_NOC_PCIE_TBU_CLK>; - clock-names = "pipe", - "aux", - "cfg", - "bus_master", - "bus_slave", - "slave_q2a", - "tbu"; - - iommu-map = <0x0 &apps_smmu 0x1c10 0x1>, - <0x100 &apps_smmu 0x1c11 0x1>, - <0x200 &apps_smmu 0x1c12 0x1>, - <0x300 &apps_smmu 0x1c13 0x1>, - <0x400 &apps_smmu 0x1c14 0x1>, - <0x500 &apps_smmu 0x1c15 0x1>, - <0x600 &apps_smmu 0x1c16 0x1>, - <0x700 &apps_smmu 0x1c17 0x1>, - <0x800 &apps_smmu 0x1c18 0x1>, - <0x900 &apps_smmu 0x1c19 0x1>, - <0xa00 &apps_smmu 0x1c1a 0x1>, - <0xb00 &apps_smmu 0x1c1b 0x1>, - <0xc00 &apps_smmu 0x1c1c 0x1>, - <0xd00 &apps_smmu 0x1c1d 0x1>, - <0xe00 &apps_smmu 0x1c1e 0x1>, - <0xf00 &apps_smmu 0x1c1f 0x1>; - - resets = <&gcc GCC_PCIE_0_BCR>; - reset-names = "pci"; - - power-domains = <&gcc PCIE_0_GDSC>; - - phys = <&pcie0_phy>; - phy-names = "pciephy"; - - status = "disabled"; - }; - - pcie0_phy: phy@1c06000 { - compatible = "qcom,sdm845-qmp-pcie-phy"; - reg = <0 0x01c06000 0 0x1000>; - clocks = <&gcc GCC_PCIE_PHY_AUX_CLK>, - <&gcc GCC_PCIE_0_CFG_AHB_CLK>, - <&gcc GCC_PCIE_0_CLKREF_CLK>, - <&gcc GCC_PCIE_PHY_REFGEN_CLK>, - <&gcc GCC_PCIE_0_PIPE_CLK>; - clock-names = "aux", - "cfg_ahb", - "ref", - "refgen", - "pipe"; - - clock-output-names = "pcie_0_pipe_clk"; - #clock-cells = <0>; - - #phy-cells = <0>; - - resets = <&gcc GCC_PCIE_0_PHY_BCR>; - reset-names = "phy"; - - assigned-clocks = <&gcc GCC_PCIE_PHY_REFGEN_CLK>; - assigned-clock-rates = <100000000>; - - status = "disabled"; - }; - - pcie1: pci@1c08000 { - compatible = "qcom,pcie-sdm845"; - reg = <0 0x01c08000 0 0x2000>, - <0 0x40000000 0 0xf1d>, - <0 0x40000f20 0 0xa8>, - <0 0x40100000 0 0x100000>, - <0 0x01c0c000 0 0x1000>; - reg-names = "parf", "dbi", "elbi", "config", "mhi"; - device_type = "pci"; - linux,pci-domain = <1>; - bus-range = <0x00 0xff>; - num-lanes = <1>; - - #address-cells = <3>; - #size-cells = <2>; - - ranges = <0x01000000 0x0 0x00000000 0x0 0x40200000 0x0 0x100000>, - <0x02000000 0x0 0x40300000 0x0 0x40300000 0x0 0x1fd00000>; - - interrupts = <GIC_SPI 307 IRQ_TYPE_EDGE_RISING>; - interrupt-names = "msi"; - #interrupt-cells = <1>; - interrupt-map-mask = <0 0 0 0x7>; - interrupt-map = <0 0 0 1 &intc 0 0 0 434 IRQ_TYPE_LEVEL_HIGH>, /* int_a */ - <0 0 0 2 &intc 0 0 0 435 IRQ_TYPE_LEVEL_HIGH>, /* int_b */ - <0 0 0 3 &intc 0 0 0 438 IRQ_TYPE_LEVEL_HIGH>, /* int_c */ - <0 0 0 4 &intc 0 0 0 439 IRQ_TYPE_LEVEL_HIGH>; /* int_d */ - - clocks = <&gcc GCC_PCIE_1_PIPE_CLK>, - <&gcc GCC_PCIE_1_AUX_CLK>, - <&gcc GCC_PCIE_1_CFG_AHB_CLK>, - <&gcc GCC_PCIE_1_MSTR_AXI_CLK>, - <&gcc GCC_PCIE_1_SLV_AXI_CLK>, - <&gcc GCC_PCIE_1_SLV_Q2A_AXI_CLK>, - <&gcc GCC_PCIE_1_CLKREF_CLK>, - <&gcc GCC_AGGRE_NOC_PCIE_TBU_CLK>; - clock-names = "pipe", - "aux", - "cfg", - "bus_master", - "bus_slave", - "slave_q2a", - "ref", - "tbu"; - - assigned-clocks = <&gcc GCC_PCIE_1_AUX_CLK>; - assigned-clock-rates = <19200000>; - - iommu-map = <0x0 &apps_smmu 0x1c00 0x1>, - <0x100 &apps_smmu 0x1c01 0x1>, - <0x200 &apps_smmu 0x1c02 0x1>, - <0x300 &apps_smmu 0x1c03 0x1>, - <0x400 &apps_smmu 0x1c04 0x1>, - <0x500 &apps_smmu 0x1c05 0x1>, - <0x600 &apps_smmu 0x1c06 0x1>, - <0x700 &apps_smmu 0x1c07 0x1>, - <0x800 &apps_smmu 0x1c08 0x1>, - <0x900 &apps_smmu 0x1c09 0x1>, - <0xa00 &apps_smmu 0x1c0a 0x1>, - <0xb00 &apps_smmu 0x1c0b 0x1>, - <0xc00 &apps_smmu 0x1c0c 0x1>, - <0xd00 &apps_smmu 0x1c0d 0x1>, - <0xe00 &apps_smmu 0x1c0e 0x1>, - <0xf00 &apps_smmu 0x1c0f 0x1>; - - resets = <&gcc GCC_PCIE_1_BCR>; - reset-names = "pci"; - - power-domains = <&gcc PCIE_1_GDSC>; - - phys = <&pcie1_phy>; - phy-names = "pciephy"; - - status = "disabled"; - }; - - pcie1_phy: phy@1c0a000 { - compatible = "qcom,sdm845-qhp-pcie-phy"; - reg = <0 0x01c0a000 0 0x2000>; - clocks = <&gcc GCC_PCIE_PHY_AUX_CLK>, - <&gcc GCC_PCIE_1_CFG_AHB_CLK>, - <&gcc GCC_PCIE_1_CLKREF_CLK>, - <&gcc GCC_PCIE_PHY_REFGEN_CLK>, - <&gcc GCC_PCIE_1_PIPE_CLK>; - clock-names = "aux", - "cfg_ahb", - "ref", - "refgen", - "pipe"; - - clock-output-names = "pcie_1_pipe_clk"; - #clock-cells = <0>; - - #phy-cells = <0>; - - resets = <&gcc GCC_PCIE_1_PHY_BCR>; - reset-names = "phy"; - - assigned-clocks = <&gcc GCC_PCIE_PHY_REFGEN_CLK>; - assigned-clock-rates = <100000000>; - - status = "disabled"; - }; - - mem_noc: interconnect@1380000 { - compatible = "qcom,sdm845-mem-noc"; - reg = <0 0x01380000 0 0x27200>; - #interconnect-cells = <2>; - qcom,bcm-voters = <&apps_bcm_voter>; - }; - - dc_noc: interconnect@14e0000 { - compatible = "qcom,sdm845-dc-noc"; - reg = <0 0x014e0000 0 0x400>; - #interconnect-cells = <2>; - qcom,bcm-voters = <&apps_bcm_voter>; - }; - - config_noc: interconnect@1500000 { - compatible = "qcom,sdm845-config-noc"; - reg = <0 0x01500000 0 0x5080>; - #interconnect-cells = <2>; - qcom,bcm-voters = <&apps_bcm_voter>; - }; - - system_noc: interconnect@1620000 { - compatible = "qcom,sdm845-system-noc"; - reg = <0 0x01620000 0 0x18080>; - #interconnect-cells = <2>; - qcom,bcm-voters = <&apps_bcm_voter>; - }; - - aggre1_noc: interconnect@16e0000 { - compatible = "qcom,sdm845-aggre1-noc"; - reg = <0 0x016e0000 0 0x15080>; - #interconnect-cells = <2>; - qcom,bcm-voters = <&apps_bcm_voter>; - }; - - aggre2_noc: interconnect@1700000 { - compatible = "qcom,sdm845-aggre2-noc"; - reg = <0 0x01700000 0 0x1f300>; - #interconnect-cells = <2>; - qcom,bcm-voters = <&apps_bcm_voter>; - }; - - mmss_noc: interconnect@1740000 { - compatible = "qcom,sdm845-mmss-noc"; - reg = <0 0x01740000 0 0x1c100>; - #interconnect-cells = <2>; - qcom,bcm-voters = <&apps_bcm_voter>; - }; - - ufs_mem_hc: ufshc@1d84000 { - compatible = "qcom,sdm845-ufshc", "qcom,ufshc", - "jedec,ufs-2.0"; - reg = <0 0x01d84000 0 0x2500>, - <0 0x01d90000 0 0x8000>; - reg-names = "std", "ice"; - interrupts = <GIC_SPI 265 IRQ_TYPE_LEVEL_HIGH>; - phys = <&ufs_mem_phy_lanes>; - phy-names = "ufsphy"; - lanes-per-direction = <2>; - power-domains = <&gcc UFS_PHY_GDSC>; - #reset-cells = <1>; - resets = <&gcc GCC_UFS_PHY_BCR>; - reset-names = "rst"; - - iommus = <&apps_smmu 0x100 0xf>; - - clock-names = - "core_clk", - "bus_aggr_clk", - "iface_clk", - "core_clk_unipro", - "ref_clk", - "tx_lane0_sync_clk", - "rx_lane0_sync_clk", - "rx_lane1_sync_clk", - "ice_core_clk"; - clocks = - <&gcc GCC_UFS_PHY_AXI_CLK>, - <&gcc GCC_AGGRE_UFS_PHY_AXI_CLK>, - <&gcc GCC_UFS_PHY_AHB_CLK>, - <&gcc GCC_UFS_PHY_UNIPRO_CORE_CLK>, - <&rpmhcc RPMH_CXO_CLK>, - <&gcc GCC_UFS_PHY_TX_SYMBOL_0_CLK>, - <&gcc GCC_UFS_PHY_RX_SYMBOL_0_CLK>, - <&gcc GCC_UFS_PHY_RX_SYMBOL_1_CLK>, - <&gcc GCC_UFS_PHY_ICE_CORE_CLK>; - freq-table-hz = - <50000000 200000000>, - <0 0>, - <0 0>, - <37500000 150000000>, - <0 0>, - <0 0>, - <0 0>, - <0 0>, - <75000000 300000000>; - - interconnects = <&aggre1_noc MASTER_UFS_MEM 0 &mem_noc SLAVE_EBI1 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_UFS_MEM_CFG 0>; - interconnect-names = "ufs-ddr", "cpu-ufs"; - - status = "disabled"; - }; - - ufs_mem_phy: phy@1d87000 { - compatible = "qcom,sdm845-qmp-ufs-phy"; - reg = <0 0x01d87000 0 0x18c>; - #address-cells = <2>; - #size-cells = <2>; - ranges; - clock-names = "ref", - "ref_aux"; - clocks = <&gcc GCC_UFS_MEM_CLKREF_CLK>, - <&gcc GCC_UFS_PHY_PHY_AUX_CLK>; - - resets = <&ufs_mem_hc 0>; - reset-names = "ufsphy"; - status = "disabled"; - - ufs_mem_phy_lanes: phy@1d87400 { - reg = <0 0x01d87400 0 0x108>, - <0 0x01d87600 0 0x1e0>, - <0 0x01d87c00 0 0x1dc>, - <0 0x01d87800 0 0x108>, - <0 0x01d87a00 0 0x1e0>; - #phy-cells = <0>; - }; - }; - - cryptobam: dma-controller@1dc4000 { - compatible = "qcom,bam-v1.7.4", "qcom,bam-v1.7.0"; - reg = <0 0x01dc4000 0 0x24000>; - interrupts = <GIC_SPI 272 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&rpmhcc RPMH_CE_CLK>; - clock-names = "bam_clk"; - #dma-cells = <1>; - qcom,ee = <0>; - qcom,controlled-remotely; - iommus = <&apps_smmu 0x704 0x1>, - <&apps_smmu 0x706 0x1>, - <&apps_smmu 0x714 0x1>, - <&apps_smmu 0x716 0x1>; - }; - - crypto: crypto@1dfa000 { - compatible = "qcom,crypto-v5.4"; - reg = <0 0x01dfa000 0 0x6000>; - clocks = <&gcc GCC_CE1_AHB_CLK>, - <&gcc GCC_CE1_AXI_CLK>, - <&rpmhcc RPMH_CE_CLK>; - clock-names = "iface", "bus", "core"; - dmas = <&cryptobam 6>, <&cryptobam 7>; - dma-names = "rx", "tx"; - iommus = <&apps_smmu 0x704 0x1>, - <&apps_smmu 0x706 0x1>, - <&apps_smmu 0x714 0x1>, - <&apps_smmu 0x716 0x1>; - }; - - ipa: ipa@1e40000 { - compatible = "qcom,sdm845-ipa"; - - iommus = <&apps_smmu 0x720 0x0>, - <&apps_smmu 0x722 0x0>; - reg = <0 0x01e40000 0 0x7000>, - <0 0x01e47000 0 0x2000>, - <0 0x01e04000 0 0x2c000>; - reg-names = "ipa-reg", - "ipa-shared", - "gsi"; - - interrupts-extended = <&intc GIC_SPI 311 IRQ_TYPE_EDGE_RISING>, - <&intc GIC_SPI 432 IRQ_TYPE_LEVEL_HIGH>, - <&ipa_smp2p_in 0 IRQ_TYPE_EDGE_RISING>, - <&ipa_smp2p_in 1 IRQ_TYPE_EDGE_RISING>; - interrupt-names = "ipa", - "gsi", - "ipa-clock-query", - "ipa-setup-ready"; - - clocks = <&rpmhcc RPMH_IPA_CLK>; - clock-names = "core"; - - interconnects = <&aggre2_noc MASTER_IPA 0 &mem_noc SLAVE_EBI1 0>, - <&aggre2_noc MASTER_IPA 0 &system_noc SLAVE_IMEM 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_IPA_CFG 0>; - interconnect-names = "memory", - "imem", - "config"; - - qcom,smem-states = <&ipa_smp2p_out 0>, - <&ipa_smp2p_out 1>; - qcom,smem-state-names = "ipa-clock-enabled-valid", - "ipa-clock-enabled"; - - status = "disabled"; - }; - - tcsr_mutex: hwlock@1f40000 { - compatible = "qcom,tcsr-mutex"; - reg = <0 0x01f40000 0 0x20000>; - #hwlock-cells = <1>; - }; - - tcsr_regs_1: syscon@1f60000 { - compatible = "qcom,sdm845-tcsr", "syscon"; - reg = <0 0x01f60000 0 0x20000>; - }; - - tlmm: pinctrl@3400000 { - compatible = "qcom,sdm845-pinctrl"; - reg = <0 0x03400000 0 0xc00000>; - interrupts = <GIC_SPI 208 IRQ_TYPE_LEVEL_HIGH>; - gpio-controller; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - gpio-ranges = <&tlmm 0 0 151>; - wakeup-parent = <&pdc_intc>; - - cci0_default: cci0-default-state { - /* SDA, SCL */ - pins = "gpio17", "gpio18"; - function = "cci_i2c"; - - bias-pull-up; - drive-strength = <2>; /* 2 mA */ - }; - - cci0_sleep: cci0-sleep-state { - /* SDA, SCL */ - pins = "gpio17", "gpio18"; - function = "cci_i2c"; - - drive-strength = <2>; /* 2 mA */ - bias-pull-down; - }; - - cci1_default: cci1-default-state { - /* SDA, SCL */ - pins = "gpio19", "gpio20"; - function = "cci_i2c"; - - bias-pull-up; - drive-strength = <2>; /* 2 mA */ - }; - - cci1_sleep: cci1-sleep-state { - /* SDA, SCL */ - pins = "gpio19", "gpio20"; - function = "cci_i2c"; - - drive-strength = <2>; /* 2 mA */ - bias-pull-down; - }; - - qspi_clk: qspi-clk-state { - pins = "gpio95"; - function = "qspi_clk"; - }; - - qspi_cs0: qspi-cs0-state { - pins = "gpio90"; - function = "qspi_cs"; - }; - - qspi_cs1: qspi-cs1-state { - pins = "gpio89"; - function = "qspi_cs"; - }; - - qspi_data0: qspi-data0-state { - pins = "gpio91"; - function = "qspi_data"; - }; - - qspi_data1: qspi-data1-state { - pins = "gpio92"; - function = "qspi_data"; - }; - - qspi_data23: qspi-data23-state { - pins = "gpio93", "gpio94"; - function = "qspi_data"; - }; - - qup_i2c0_default: qup-i2c0-default-state { - pins = "gpio0", "gpio1"; - function = "qup0"; - }; - - qup_i2c1_default: qup-i2c1-default-state { - pins = "gpio17", "gpio18"; - function = "qup1"; - }; - - qup_i2c2_default: qup-i2c2-default-state { - pins = "gpio27", "gpio28"; - function = "qup2"; - }; - - qup_i2c3_default: qup-i2c3-default-state { - pins = "gpio41", "gpio42"; - function = "qup3"; - }; - - qup_i2c4_default: qup-i2c4-default-state { - pins = "gpio89", "gpio90"; - function = "qup4"; - }; - - qup_i2c5_default: qup-i2c5-default-state { - pins = "gpio85", "gpio86"; - function = "qup5"; - }; - - qup_i2c6_default: qup-i2c6-default-state { - pins = "gpio45", "gpio46"; - function = "qup6"; - }; - - qup_i2c7_default: qup-i2c7-default-state { - pins = "gpio93", "gpio94"; - function = "qup7"; - }; - - qup_i2c8_default: qup-i2c8-default-state { - pins = "gpio65", "gpio66"; - function = "qup8"; - }; - - qup_i2c9_default: qup-i2c9-default-state { - pins = "gpio6", "gpio7"; - function = "qup9"; - }; - - qup_i2c10_default: qup-i2c10-default-state { - pins = "gpio55", "gpio56"; - function = "qup10"; - }; - - qup_i2c11_default: qup-i2c11-default-state { - pins = "gpio31", "gpio32"; - function = "qup11"; - }; - - qup_i2c12_default: qup-i2c12-default-state { - pins = "gpio49", "gpio50"; - function = "qup12"; - }; - - qup_i2c13_default: qup-i2c13-default-state { - pins = "gpio105", "gpio106"; - function = "qup13"; - }; - - qup_i2c14_default: qup-i2c14-default-state { - pins = "gpio33", "gpio34"; - function = "qup14"; - }; - - qup_i2c15_default: qup-i2c15-default-state { - pins = "gpio81", "gpio82"; - function = "qup15"; - }; - - qup_spi0_default: qup-spi0-default-state { - pins = "gpio0", "gpio1", "gpio2", "gpio3"; - function = "qup0"; - }; - - qup_spi1_default: qup-spi1-default-state { - pins = "gpio17", "gpio18", "gpio19", "gpio20"; - function = "qup1"; - }; - - qup_spi2_default: qup-spi2-default-state { - pins = "gpio27", "gpio28", "gpio29", "gpio30"; - function = "qup2"; - }; - - qup_spi3_default: qup-spi3-default-state { - pins = "gpio41", "gpio42", "gpio43", "gpio44"; - function = "qup3"; - }; - - qup_spi4_default: qup-spi4-default-state { - pins = "gpio89", "gpio90", "gpio91", "gpio92"; - function = "qup4"; - }; - - qup_spi5_default: qup-spi5-default-state { - pins = "gpio85", "gpio86", "gpio87", "gpio88"; - function = "qup5"; - }; - - qup_spi6_default: qup-spi6-default-state { - pins = "gpio45", "gpio46", "gpio47", "gpio48"; - function = "qup6"; - }; - - qup_spi7_default: qup-spi7-default-state { - pins = "gpio93", "gpio94", "gpio95", "gpio96"; - function = "qup7"; - }; - - qup_spi8_default: qup-spi8-default-state { - pins = "gpio65", "gpio66", "gpio67", "gpio68"; - function = "qup8"; - }; - - qup_spi9_default: qup-spi9-default-state { - pins = "gpio6", "gpio7", "gpio4", "gpio5"; - function = "qup9"; - }; - - qup_spi10_default: qup-spi10-default-state { - pins = "gpio55", "gpio56", "gpio53", "gpio54"; - function = "qup10"; - }; - - qup_spi11_default: qup-spi11-default-state { - pins = "gpio31", "gpio32", "gpio33", "gpio34"; - function = "qup11"; - }; - - qup_spi12_default: qup-spi12-default-state { - pins = "gpio49", "gpio50", "gpio51", "gpio52"; - function = "qup12"; - }; - - qup_spi13_default: qup-spi13-default-state { - pins = "gpio105", "gpio106", "gpio107", "gpio108"; - function = "qup13"; - }; - - qup_spi14_default: qup-spi14-default-state { - pins = "gpio33", "gpio34", "gpio31", "gpio32"; - function = "qup14"; - }; - - qup_spi15_default: qup-spi15-default-state { - pins = "gpio81", "gpio82", "gpio83", "gpio84"; - function = "qup15"; - }; - - qup_uart0_default: qup-uart0-default-state { - qup_uart0_tx: tx-pins { - pins = "gpio2"; - function = "qup0"; - }; - - qup_uart0_rx: rx-pins { - pins = "gpio3"; - function = "qup0"; - }; - }; - - qup_uart1_default: qup-uart1-default-state { - qup_uart1_tx: tx-pins { - pins = "gpio19"; - function = "qup1"; - }; - - qup_uart1_rx: rx-pins { - pins = "gpio20"; - function = "qup1"; - }; - }; - - qup_uart2_default: qup-uart2-default-state { - qup_uart2_tx: tx-pins { - pins = "gpio29"; - function = "qup2"; - }; - - qup_uart2_rx: rx-pins { - pins = "gpio30"; - function = "qup2"; - }; - }; - - qup_uart3_default: qup-uart3-default-state { - qup_uart3_tx: tx-pins { - pins = "gpio43"; - function = "qup3"; - }; - - qup_uart3_rx: rx-pins { - pins = "gpio44"; - function = "qup3"; - }; - }; - - qup_uart3_4pin: qup-uart3-4pin-state { - qup_uart3_4pin_cts: cts-pins { - pins = "gpio41"; - function = "qup3"; - }; - - qup_uart3_4pin_rts_tx: rts-tx-pins { - pins = "gpio42", "gpio43"; - function = "qup3"; - }; - - qup_uart3_4pin_rx: rx-pins { - pins = "gpio44"; - function = "qup3"; - }; - }; - - qup_uart4_default: qup-uart4-default-state { - qup_uart4_tx: tx-pins { - pins = "gpio91"; - function = "qup4"; - }; - - qup_uart4_rx: rx-pins { - pins = "gpio92"; - function = "qup4"; - }; - }; - - qup_uart5_default: qup-uart5-default-state { - qup_uart5_tx: tx-pins { - pins = "gpio87"; - function = "qup5"; - }; - - qup_uart5_rx: rx-pins { - pins = "gpio88"; - function = "qup5"; - }; - }; - - qup_uart6_default: qup-uart6-default-state { - qup_uart6_tx: tx-pins { - pins = "gpio47"; - function = "qup6"; - }; - - qup_uart6_rx: rx-pins { - pins = "gpio48"; - function = "qup6"; - }; - }; - - qup_uart6_4pin: qup-uart6-4pin-state { - qup_uart6_4pin_cts: cts-pins { - pins = "gpio45"; - function = "qup6"; - bias-pull-down; - }; - - qup_uart6_4pin_rts_tx: rts-tx-pins { - pins = "gpio46", "gpio47"; - function = "qup6"; - drive-strength = <2>; - bias-disable; - }; - - qup_uart6_4pin_rx: rx-pins { - pins = "gpio48"; - function = "qup6"; - bias-pull-up; - }; - }; - - qup_uart7_default: qup-uart7-default-state { - qup_uart7_tx: tx-pins { - pins = "gpio95"; - function = "qup7"; - }; - - qup_uart7_rx: rx-pins { - pins = "gpio96"; - function = "qup7"; - }; - }; - - qup_uart8_default: qup-uart8-default-state { - qup_uart8_tx: tx-pins { - pins = "gpio67"; - function = "qup8"; - }; - - qup_uart8_rx: rx-pins { - pins = "gpio68"; - function = "qup8"; - }; - }; - - qup_uart9_default: qup-uart9-default-state { - qup_uart9_tx: tx-pins { - pins = "gpio4"; - function = "qup9"; - }; - - qup_uart9_rx: rx-pins { - pins = "gpio5"; - function = "qup9"; - }; - }; - - qup_uart10_default: qup-uart10-default-state { - qup_uart10_tx: tx-pins { - pins = "gpio53"; - function = "qup10"; - }; - - qup_uart10_rx: rx-pins { - pins = "gpio54"; - function = "qup10"; - }; - }; - - qup_uart11_default: qup-uart11-default-state { - qup_uart11_tx: tx-pins { - pins = "gpio33"; - function = "qup11"; - }; - - qup_uart11_rx: rx-pins { - pins = "gpio34"; - function = "qup11"; - }; - }; - - qup_uart12_default: qup-uart12-default-state { - qup_uart12_tx: tx-pins { - pins = "gpio51"; - function = "qup0"; - }; - - qup_uart12_rx: rx-pins { - pins = "gpio52"; - function = "qup0"; - }; - }; - - qup_uart13_default: qup-uart13-default-state { - qup_uart13_tx: tx-pins { - pins = "gpio107"; - function = "qup13"; - }; - - qup_uart13_rx: rx-pins { - pins = "gpio108"; - function = "qup13"; - }; - }; - - qup_uart14_default: qup-uart14-default-state { - qup_uart14_tx: tx-pins { - pins = "gpio31"; - function = "qup14"; - }; - - qup_uart14_rx: rx-pins { - pins = "gpio32"; - function = "qup14"; - }; - }; - - qup_uart15_default: qup-uart15-default-state { - qup_uart15_tx: tx-pins { - pins = "gpio83"; - function = "qup15"; - }; - - qup_uart15_rx: rx-pins { - pins = "gpio84"; - function = "qup15"; - }; - }; - - quat_mi2s_sleep: quat-mi2s-sleep-state { - pins = "gpio58", "gpio59"; - function = "gpio"; - drive-strength = <2>; - bias-pull-down; - }; - - quat_mi2s_active: quat-mi2s-active-state { - pins = "gpio58", "gpio59"; - function = "qua_mi2s"; - drive-strength = <8>; - bias-disable; - output-high; - }; - - quat_mi2s_sd0_sleep: quat-mi2s-sd0-sleep-state { - pins = "gpio60"; - function = "gpio"; - drive-strength = <2>; - bias-pull-down; - }; - - quat_mi2s_sd0_active: quat-mi2s-sd0-active-state { - pins = "gpio60"; - function = "qua_mi2s"; - drive-strength = <8>; - bias-disable; - }; - - quat_mi2s_sd1_sleep: quat-mi2s-sd1-sleep-state { - pins = "gpio61"; - function = "gpio"; - drive-strength = <2>; - bias-pull-down; - }; - - quat_mi2s_sd1_active: quat-mi2s-sd1-active-state { - pins = "gpio61"; - function = "qua_mi2s"; - drive-strength = <8>; - bias-disable; - }; - - quat_mi2s_sd2_sleep: quat-mi2s-sd2-sleep-state { - pins = "gpio62"; - function = "gpio"; - drive-strength = <2>; - bias-pull-down; - }; - - quat_mi2s_sd2_active: quat-mi2s-sd2-active-state { - pins = "gpio62"; - function = "qua_mi2s"; - drive-strength = <8>; - bias-disable; - }; - - quat_mi2s_sd3_sleep: quat-mi2s-sd3-sleep-state { - pins = "gpio63"; - function = "gpio"; - drive-strength = <2>; - bias-pull-down; - }; - - quat_mi2s_sd3_active: quat-mi2s-sd3-active-state { - pins = "gpio63"; - function = "qua_mi2s"; - drive-strength = <8>; - bias-disable; - }; - }; - - mss_pil: remoteproc@4080000 { - compatible = "qcom,sdm845-mss-pil"; - reg = <0 0x04080000 0 0x408>, <0 0x04180000 0 0x48>; - reg-names = "qdsp6", "rmb"; - - interrupts-extended = - <&intc GIC_SPI 266 IRQ_TYPE_EDGE_RISING>, - <&modem_smp2p_in 0 IRQ_TYPE_EDGE_RISING>, - <&modem_smp2p_in 1 IRQ_TYPE_EDGE_RISING>, - <&modem_smp2p_in 2 IRQ_TYPE_EDGE_RISING>, - <&modem_smp2p_in 3 IRQ_TYPE_EDGE_RISING>, - <&modem_smp2p_in 7 IRQ_TYPE_EDGE_RISING>; - interrupt-names = "wdog", "fatal", "ready", - "handover", "stop-ack", - "shutdown-ack"; - - clocks = <&gcc GCC_MSS_CFG_AHB_CLK>, - <&gcc GCC_MSS_Q6_MEMNOC_AXI_CLK>, - <&gcc GCC_BOOT_ROM_AHB_CLK>, - <&gcc GCC_MSS_GPLL0_DIV_CLK_SRC>, - <&gcc GCC_MSS_SNOC_AXI_CLK>, - <&gcc GCC_MSS_MFAB_AXIS_CLK>, - <&gcc GCC_PRNG_AHB_CLK>, - <&rpmhcc RPMH_CXO_CLK>; - clock-names = "iface", "bus", "mem", "gpll0_mss", - "snoc_axi", "mnoc_axi", "prng", "xo"; - - qcom,qmp = <&aoss_qmp>; - - qcom,smem-states = <&modem_smp2p_out 0>; - qcom,smem-state-names = "stop"; - - resets = <&aoss_reset AOSS_CC_MSS_RESTART>, - <&pdc_reset PDC_MODEM_SYNC_RESET>; - reset-names = "mss_restart", "pdc_reset"; - - qcom,halt-regs = <&tcsr_regs_1 0x3000 0x5000 0x4000>; - - power-domains = <&rpmhpd SDM845_CX>, - <&rpmhpd SDM845_MX>, - <&rpmhpd SDM845_MSS>; - power-domain-names = "cx", "mx", "mss"; - - status = "disabled"; - - mba { - memory-region = <&mba_region>; - }; - - mpss { - memory-region = <&mpss_region>; - }; - - metadata { - memory-region = <&mdata_mem>; - }; - - glink-edge { - interrupts = <GIC_SPI 449 IRQ_TYPE_EDGE_RISING>; - label = "modem"; - qcom,remote-pid = <1>; - mboxes = <&apss_shared 12>; - }; - }; - - gpucc: clock-controller@5090000 { - compatible = "qcom,sdm845-gpucc"; - reg = <0 0x05090000 0 0x9000>; - #clock-cells = <1>; - #reset-cells = <1>; - #power-domain-cells = <1>; - clocks = <&rpmhcc RPMH_CXO_CLK>, - <&gcc GCC_GPU_GPLL0_CLK_SRC>, - <&gcc GCC_GPU_GPLL0_DIV_CLK_SRC>; - clock-names = "bi_tcxo", - "gcc_gpu_gpll0_clk_src", - "gcc_gpu_gpll0_div_clk_src"; - }; - - slpi_pas: remoteproc@5c00000 { - compatible = "qcom,sdm845-slpi-pas"; - reg = <0 0x5c00000 0 0x4000>; - - interrupts-extended = <&intc GIC_SPI 494 IRQ_TYPE_EDGE_RISING>, - <&slpi_smp2p_in 0 IRQ_TYPE_EDGE_RISING>, - <&slpi_smp2p_in 1 IRQ_TYPE_EDGE_RISING>, - <&slpi_smp2p_in 2 IRQ_TYPE_EDGE_RISING>, - <&slpi_smp2p_in 3 IRQ_TYPE_EDGE_RISING>; - interrupt-names = "wdog", "fatal", "ready", - "handover", "stop-ack"; - - clocks = <&rpmhcc RPMH_CXO_CLK>; - clock-names = "xo"; - - qcom,qmp = <&aoss_qmp>; - - power-domains = <&rpmhpd SDM845_CX>, - <&rpmhpd SDM845_MX>; - power-domain-names = "lcx", "lmx"; - - memory-region = <&slpi_mem>; - - qcom,smem-states = <&slpi_smp2p_out 0>; - qcom,smem-state-names = "stop"; - - status = "disabled"; - - glink-edge { - interrupts = <GIC_SPI 170 IRQ_TYPE_EDGE_RISING>; - label = "dsps"; - qcom,remote-pid = <3>; - mboxes = <&apss_shared 24>; - - fastrpc { - compatible = "qcom,fastrpc"; - qcom,glink-channels = "fastrpcglink-apps-dsp"; - label = "sdsp"; - qcom,non-secure-domain; - qcom,vmids = <QCOM_SCM_VMID_HLOS QCOM_SCM_VMID_MSS_MSA - QCOM_SCM_VMID_SSC_Q6 QCOM_SCM_VMID_ADSP_Q6>; - memory-region = <&fastrpc_mem>; - #address-cells = <1>; - #size-cells = <0>; - - compute-cb@0 { - compatible = "qcom,fastrpc-compute-cb"; - reg = <0>; - }; - }; - }; - }; - - stm@6002000 { - compatible = "arm,coresight-stm", "arm,primecell"; - reg = <0 0x06002000 0 0x1000>, - <0 0x16280000 0 0x180000>; - reg-names = "stm-base", "stm-stimulus-base"; - - clocks = <&aoss_qmp>; - clock-names = "apb_pclk"; - - out-ports { - port { - stm_out: endpoint { - remote-endpoint = - <&funnel0_in7>; - }; - }; - }; - }; - - funnel@6041000 { - compatible = "arm,coresight-dynamic-funnel", "arm,primecell"; - reg = <0 0x06041000 0 0x1000>; - - clocks = <&aoss_qmp>; - clock-names = "apb_pclk"; - - out-ports { - port { - funnel0_out: endpoint { - remote-endpoint = - <&merge_funnel_in0>; - }; - }; - }; - - in-ports { - #address-cells = <1>; - #size-cells = <0>; - - port@7 { - reg = <7>; - funnel0_in7: endpoint { - remote-endpoint = <&stm_out>; - }; - }; - }; - }; - - funnel@6043000 { - compatible = "arm,coresight-dynamic-funnel", "arm,primecell"; - reg = <0 0x06043000 0 0x1000>; - - clocks = <&aoss_qmp>; - clock-names = "apb_pclk"; - - out-ports { - port { - funnel2_out: endpoint { - remote-endpoint = - <&merge_funnel_in2>; - }; - }; - }; - - in-ports { - #address-cells = <1>; - #size-cells = <0>; - - port@5 { - reg = <5>; - funnel2_in5: endpoint { - remote-endpoint = - <&apss_merge_funnel_out>; - }; - }; - }; - }; - - funnel@6045000 { - compatible = "arm,coresight-dynamic-funnel", "arm,primecell"; - reg = <0 0x06045000 0 0x1000>; - - clocks = <&aoss_qmp>; - clock-names = "apb_pclk"; - - out-ports { - port { - merge_funnel_out: endpoint { - remote-endpoint = <&etf_in>; - }; - }; - }; - - in-ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - merge_funnel_in0: endpoint { - remote-endpoint = - <&funnel0_out>; - }; - }; - - port@2 { - reg = <2>; - merge_funnel_in2: endpoint { - remote-endpoint = - <&funnel2_out>; - }; - }; - }; - }; - - replicator@6046000 { - compatible = "arm,coresight-dynamic-replicator", "arm,primecell"; - reg = <0 0x06046000 0 0x1000>; - - clocks = <&aoss_qmp>; - clock-names = "apb_pclk"; - - out-ports { - port { - replicator_out: endpoint { - remote-endpoint = <&etr_in>; - }; - }; - }; - - in-ports { - port { - replicator_in: endpoint { - remote-endpoint = <&etf_out>; - }; - }; - }; - }; - - etf@6047000 { - compatible = "arm,coresight-tmc", "arm,primecell"; - reg = <0 0x06047000 0 0x1000>; - - clocks = <&aoss_qmp>; - clock-names = "apb_pclk"; - - out-ports { - port { - etf_out: endpoint { - remote-endpoint = - <&replicator_in>; - }; - }; - }; - - in-ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - reg = <1>; - etf_in: endpoint { - remote-endpoint = - <&merge_funnel_out>; - }; - }; - }; - }; - - etr@6048000 { - compatible = "arm,coresight-tmc", "arm,primecell"; - reg = <0 0x06048000 0 0x1000>; - - clocks = <&aoss_qmp>; - clock-names = "apb_pclk"; - arm,scatter-gather; - - in-ports { - port { - etr_in: endpoint { - remote-endpoint = - <&replicator_out>; - }; - }; - }; - }; - - etm@7040000 { - compatible = "arm,coresight-etm4x", "arm,primecell"; - reg = <0 0x07040000 0 0x1000>; - - cpu = <&CPU0>; - - clocks = <&aoss_qmp>; - clock-names = "apb_pclk"; - arm,coresight-loses-context-with-cpu; - - out-ports { - port { - etm0_out: endpoint { - remote-endpoint = - <&apss_funnel_in0>; - }; - }; - }; - }; - - etm@7140000 { - compatible = "arm,coresight-etm4x", "arm,primecell"; - reg = <0 0x07140000 0 0x1000>; - - cpu = <&CPU1>; - - clocks = <&aoss_qmp>; - clock-names = "apb_pclk"; - arm,coresight-loses-context-with-cpu; - - out-ports { - port { - etm1_out: endpoint { - remote-endpoint = - <&apss_funnel_in1>; - }; - }; - }; - }; - - etm@7240000 { - compatible = "arm,coresight-etm4x", "arm,primecell"; - reg = <0 0x07240000 0 0x1000>; - - cpu = <&CPU2>; - - clocks = <&aoss_qmp>; - clock-names = "apb_pclk"; - arm,coresight-loses-context-with-cpu; - - out-ports { - port { - etm2_out: endpoint { - remote-endpoint = - <&apss_funnel_in2>; - }; - }; - }; - }; - - etm@7340000 { - compatible = "arm,coresight-etm4x", "arm,primecell"; - reg = <0 0x07340000 0 0x1000>; - - cpu = <&CPU3>; - - clocks = <&aoss_qmp>; - clock-names = "apb_pclk"; - arm,coresight-loses-context-with-cpu; - - out-ports { - port { - etm3_out: endpoint { - remote-endpoint = - <&apss_funnel_in3>; - }; - }; - }; - }; - - etm@7440000 { - compatible = "arm,coresight-etm4x", "arm,primecell"; - reg = <0 0x07440000 0 0x1000>; - - cpu = <&CPU4>; - - clocks = <&aoss_qmp>; - clock-names = "apb_pclk"; - arm,coresight-loses-context-with-cpu; - - out-ports { - port { - etm4_out: endpoint { - remote-endpoint = - <&apss_funnel_in4>; - }; - }; - }; - }; - - etm@7540000 { - compatible = "arm,coresight-etm4x", "arm,primecell"; - reg = <0 0x07540000 0 0x1000>; - - cpu = <&CPU5>; - - clocks = <&aoss_qmp>; - clock-names = "apb_pclk"; - arm,coresight-loses-context-with-cpu; - - out-ports { - port { - etm5_out: endpoint { - remote-endpoint = - <&apss_funnel_in5>; - }; - }; - }; - }; - - etm@7640000 { - compatible = "arm,coresight-etm4x", "arm,primecell"; - reg = <0 0x07640000 0 0x1000>; - - cpu = <&CPU6>; - - clocks = <&aoss_qmp>; - clock-names = "apb_pclk"; - arm,coresight-loses-context-with-cpu; - - out-ports { - port { - etm6_out: endpoint { - remote-endpoint = - <&apss_funnel_in6>; - }; - }; - }; - }; - - etm@7740000 { - compatible = "arm,coresight-etm4x", "arm,primecell"; - reg = <0 0x07740000 0 0x1000>; - - cpu = <&CPU7>; - - clocks = <&aoss_qmp>; - clock-names = "apb_pclk"; - arm,coresight-loses-context-with-cpu; - - out-ports { - port { - etm7_out: endpoint { - remote-endpoint = - <&apss_funnel_in7>; - }; - }; - }; - }; - - funnel@7800000 { /* APSS Funnel */ - compatible = "arm,coresight-dynamic-funnel", "arm,primecell"; - reg = <0 0x07800000 0 0x1000>; - - clocks = <&aoss_qmp>; - clock-names = "apb_pclk"; - - out-ports { - port { - apss_funnel_out: endpoint { - remote-endpoint = - <&apss_merge_funnel_in>; - }; - }; - }; - - in-ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - apss_funnel_in0: endpoint { - remote-endpoint = - <&etm0_out>; - }; - }; - - port@1 { - reg = <1>; - apss_funnel_in1: endpoint { - remote-endpoint = - <&etm1_out>; - }; - }; - - port@2 { - reg = <2>; - apss_funnel_in2: endpoint { - remote-endpoint = - <&etm2_out>; - }; - }; - - port@3 { - reg = <3>; - apss_funnel_in3: endpoint { - remote-endpoint = - <&etm3_out>; - }; - }; - - port@4 { - reg = <4>; - apss_funnel_in4: endpoint { - remote-endpoint = - <&etm4_out>; - }; - }; - - port@5 { - reg = <5>; - apss_funnel_in5: endpoint { - remote-endpoint = - <&etm5_out>; - }; - }; - - port@6 { - reg = <6>; - apss_funnel_in6: endpoint { - remote-endpoint = - <&etm6_out>; - }; - }; - - port@7 { - reg = <7>; - apss_funnel_in7: endpoint { - remote-endpoint = - <&etm7_out>; - }; - }; - }; - }; - - funnel@7810000 { - compatible = "arm,coresight-dynamic-funnel", "arm,primecell"; - reg = <0 0x07810000 0 0x1000>; - - clocks = <&aoss_qmp>; - clock-names = "apb_pclk"; - - out-ports { - port { - apss_merge_funnel_out: endpoint { - remote-endpoint = - <&funnel2_in5>; - }; - }; - }; - - in-ports { - port { - apss_merge_funnel_in: endpoint { - remote-endpoint = - <&apss_funnel_out>; - }; - }; - }; - }; - - sdhc_2: mmc@8804000 { - compatible = "qcom,sdm845-sdhci", "qcom,sdhci-msm-v5"; - reg = <0 0x08804000 0 0x1000>; - - interrupts = <GIC_SPI 204 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 222 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "hc_irq", "pwr_irq"; - - clocks = <&gcc GCC_SDCC2_AHB_CLK>, - <&gcc GCC_SDCC2_APPS_CLK>, - <&rpmhcc RPMH_CXO_CLK>; - clock-names = "iface", "core", "xo"; - iommus = <&apps_smmu 0xa0 0xf>; - power-domains = <&rpmhpd SDM845_CX>; - operating-points-v2 = <&sdhc2_opp_table>; - - status = "disabled"; - - sdhc2_opp_table: opp-table { - compatible = "operating-points-v2"; - - opp-9600000 { - opp-hz = /bits/ 64 <9600000>; - required-opps = <&rpmhpd_opp_min_svs>; - }; - - opp-19200000 { - opp-hz = /bits/ 64 <19200000>; - required-opps = <&rpmhpd_opp_low_svs>; - }; - - opp-100000000 { - opp-hz = /bits/ 64 <100000000>; - required-opps = <&rpmhpd_opp_svs>; - }; - - opp-201500000 { - opp-hz = /bits/ 64 <201500000>; - required-opps = <&rpmhpd_opp_svs_l1>; - }; - }; - }; - - qspi: spi@88df000 { - compatible = "qcom,sdm845-qspi", "qcom,qspi-v1"; - reg = <0 0x088df000 0 0x600>; - iommus = <&apps_smmu 0x160 0x0>; - #address-cells = <1>; - #size-cells = <0>; - interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&gcc GCC_QSPI_CNOC_PERIPH_AHB_CLK>, - <&gcc GCC_QSPI_CORE_CLK>; - clock-names = "iface", "core"; - power-domains = <&rpmhpd SDM845_CX>; - operating-points-v2 = <&qspi_opp_table>; - status = "disabled"; - }; - - slim: slim-ngd@171c0000 { - compatible = "qcom,slim-ngd-v2.1.0"; - reg = <0 0x171c0000 0 0x2c000>; - interrupts = <GIC_SPI 163 IRQ_TYPE_LEVEL_HIGH>; - - dmas = <&slimbam 3>, <&slimbam 4>; - dma-names = "rx", "tx"; - - iommus = <&apps_smmu 0x1806 0x0>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - lmh_cluster1: lmh@17d70800 { - compatible = "qcom,sdm845-lmh"; - reg = <0 0x17d70800 0 0x400>; - interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; - cpus = <&CPU4>; - qcom,lmh-temp-arm-millicelsius = <65000>; - qcom,lmh-temp-low-millicelsius = <94500>; - qcom,lmh-temp-high-millicelsius = <95000>; - interrupt-controller; - #interrupt-cells = <1>; - }; - - lmh_cluster0: lmh@17d78800 { - compatible = "qcom,sdm845-lmh"; - reg = <0 0x17d78800 0 0x400>; - interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; - cpus = <&CPU0>; - qcom,lmh-temp-arm-millicelsius = <65000>; - qcom,lmh-temp-low-millicelsius = <94500>; - qcom,lmh-temp-high-millicelsius = <95000>; - interrupt-controller; - #interrupt-cells = <1>; - }; - - usb_1_hsphy: phy@88e2000 { - compatible = "qcom,sdm845-qusb2-phy", "qcom,qusb2-v2-phy"; - reg = <0 0x088e2000 0 0x400>; - status = "disabled"; - #phy-cells = <0>; - - clocks = <&gcc GCC_USB_PHY_CFG_AHB2PHY_CLK>, - <&rpmhcc RPMH_CXO_CLK>; - clock-names = "cfg_ahb", "ref"; - - resets = <&gcc GCC_QUSB2PHY_PRIM_BCR>; - - nvmem-cells = <&qusb2p_hstx_trim>; - }; - - usb_2_hsphy: phy@88e3000 { - compatible = "qcom,sdm845-qusb2-phy", "qcom,qusb2-v2-phy"; - reg = <0 0x088e3000 0 0x400>; - status = "disabled"; - #phy-cells = <0>; - - clocks = <&gcc GCC_USB_PHY_CFG_AHB2PHY_CLK>, - <&rpmhcc RPMH_CXO_CLK>; - clock-names = "cfg_ahb", "ref"; - - resets = <&gcc GCC_QUSB2PHY_SEC_BCR>; - - nvmem-cells = <&qusb2s_hstx_trim>; - }; - - usb_1_qmpphy: phy@88e8000 { - compatible = "qcom,sdm845-qmp-usb3-dp-phy"; - reg = <0 0x088e8000 0 0x3000>; - status = "disabled"; - - clocks = <&gcc GCC_USB3_PRIM_PHY_AUX_CLK>, - <&gcc GCC_USB3_PRIM_CLKREF_CLK>, - <&gcc GCC_USB3_PRIM_PHY_COM_AUX_CLK>, - <&gcc GCC_USB3_PRIM_PHY_PIPE_CLK>, - <&gcc GCC_USB_PHY_CFG_AHB2PHY_CLK>; - clock-names = "aux", - "ref", - "com_aux", - "usb3_pipe", - "cfg_ahb"; - - resets = <&gcc GCC_USB3_PHY_PRIM_BCR>, - <&gcc GCC_USB3_DP_PHY_PRIM_BCR>; - reset-names = "phy", "common"; - - #clock-cells = <1>; - #phy-cells = <1>; - }; - - usb_2_qmpphy: phy@88eb000 { - compatible = "qcom,sdm845-qmp-usb3-uni-phy"; - reg = <0 0x088eb000 0 0x18c>; - status = "disabled"; - #address-cells = <2>; - #size-cells = <2>; - ranges; - - clocks = <&gcc GCC_USB3_SEC_PHY_AUX_CLK>, - <&gcc GCC_USB_PHY_CFG_AHB2PHY_CLK>, - <&gcc GCC_USB3_SEC_CLKREF_CLK>, - <&gcc GCC_USB3_SEC_PHY_COM_AUX_CLK>; - clock-names = "aux", "cfg_ahb", "ref", "com_aux"; - - resets = <&gcc GCC_USB3PHY_PHY_SEC_BCR>, - <&gcc GCC_USB3_PHY_SEC_BCR>; - reset-names = "phy", "common"; - - usb_2_ssphy: phy@88eb200 { - reg = <0 0x088eb200 0 0x128>, - <0 0x088eb400 0 0x1fc>, - <0 0x088eb800 0 0x218>, - <0 0x088eb600 0 0x70>; - #clock-cells = <0>; - #phy-cells = <0>; - clocks = <&gcc GCC_USB3_SEC_PHY_PIPE_CLK>; - clock-names = "pipe0"; - clock-output-names = "usb3_uni_phy_pipe_clk_src"; - }; - }; - - usb_1: usb@a6f8800 { - compatible = "qcom,sdm845-dwc3", "qcom,dwc3"; - reg = <0 0x0a6f8800 0 0x400>; - status = "disabled"; - #address-cells = <2>; - #size-cells = <2>; - ranges; - dma-ranges; - - clocks = <&gcc GCC_CFG_NOC_USB3_PRIM_AXI_CLK>, - <&gcc GCC_USB30_PRIM_MASTER_CLK>, - <&gcc GCC_AGGRE_USB3_PRIM_AXI_CLK>, - <&gcc GCC_USB30_PRIM_SLEEP_CLK>, - <&gcc GCC_USB30_PRIM_MOCK_UTMI_CLK>; - clock-names = "cfg_noc", - "core", - "iface", - "sleep", - "mock_utmi"; - - assigned-clocks = <&gcc GCC_USB30_PRIM_MOCK_UTMI_CLK>, - <&gcc GCC_USB30_PRIM_MASTER_CLK>; - assigned-clock-rates = <19200000>, <150000000>; - - interrupts = <GIC_SPI 131 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 486 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 488 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 489 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "hs_phy_irq", "ss_phy_irq", - "dm_hs_phy_irq", "dp_hs_phy_irq"; - - power-domains = <&gcc USB30_PRIM_GDSC>; - - resets = <&gcc GCC_USB30_PRIM_BCR>; - - interconnects = <&aggre2_noc MASTER_USB3_0 0 &mem_noc SLAVE_EBI1 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_USB3_0 0>; - interconnect-names = "usb-ddr", "apps-usb"; - - usb_1_dwc3: usb@a600000 { - compatible = "snps,dwc3"; - reg = <0 0x0a600000 0 0xcd00>; - interrupts = <GIC_SPI 133 IRQ_TYPE_LEVEL_HIGH>; - iommus = <&apps_smmu 0x740 0>; - snps,dis_u2_susphy_quirk; - snps,dis_enblslpm_quirk; - phys = <&usb_1_hsphy>, <&usb_1_qmpphy QMP_USB43DP_USB3_PHY>; - phy-names = "usb2-phy", "usb3-phy"; - }; - }; - - usb_2: usb@a8f8800 { - compatible = "qcom,sdm845-dwc3", "qcom,dwc3"; - reg = <0 0x0a8f8800 0 0x400>; - status = "disabled"; - #address-cells = <2>; - #size-cells = <2>; - ranges; - dma-ranges; - - clocks = <&gcc GCC_CFG_NOC_USB3_SEC_AXI_CLK>, - <&gcc GCC_USB30_SEC_MASTER_CLK>, - <&gcc GCC_AGGRE_USB3_SEC_AXI_CLK>, - <&gcc GCC_USB30_SEC_SLEEP_CLK>, - <&gcc GCC_USB30_SEC_MOCK_UTMI_CLK>; - clock-names = "cfg_noc", - "core", - "iface", - "sleep", - "mock_utmi"; - - assigned-clocks = <&gcc GCC_USB30_SEC_MOCK_UTMI_CLK>, - <&gcc GCC_USB30_SEC_MASTER_CLK>; - assigned-clock-rates = <19200000>, <150000000>; - - interrupts = <GIC_SPI 136 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 487 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 490 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 491 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "hs_phy_irq", "ss_phy_irq", - "dm_hs_phy_irq", "dp_hs_phy_irq"; - - power-domains = <&gcc USB30_SEC_GDSC>; - - resets = <&gcc GCC_USB30_SEC_BCR>; - - interconnects = <&aggre2_noc MASTER_USB3_1 0 &mem_noc SLAVE_EBI1 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_USB3_1 0>; - interconnect-names = "usb-ddr", "apps-usb"; - - usb_2_dwc3: usb@a800000 { - compatible = "snps,dwc3"; - reg = <0 0x0a800000 0 0xcd00>; - interrupts = <GIC_SPI 138 IRQ_TYPE_LEVEL_HIGH>; - iommus = <&apps_smmu 0x760 0>; - snps,dis_u2_susphy_quirk; - snps,dis_enblslpm_quirk; - phys = <&usb_2_hsphy>, <&usb_2_ssphy>; - phy-names = "usb2-phy", "usb3-phy"; - }; - }; - - venus: video-codec@aa00000 { - compatible = "qcom,sdm845-venus-v2"; - reg = <0 0x0aa00000 0 0xff000>; - interrupts = <GIC_SPI 174 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&videocc VENUS_GDSC>, - <&videocc VCODEC0_GDSC>, - <&videocc VCODEC1_GDSC>, - <&rpmhpd SDM845_CX>; - power-domain-names = "venus", "vcodec0", "vcodec1", "cx"; - operating-points-v2 = <&venus_opp_table>; - clocks = <&videocc VIDEO_CC_VENUS_CTL_CORE_CLK>, - <&videocc VIDEO_CC_VENUS_AHB_CLK>, - <&videocc VIDEO_CC_VENUS_CTL_AXI_CLK>, - <&videocc VIDEO_CC_VCODEC0_CORE_CLK>, - <&videocc VIDEO_CC_VCODEC0_AXI_CLK>, - <&videocc VIDEO_CC_VCODEC1_CORE_CLK>, - <&videocc VIDEO_CC_VCODEC1_AXI_CLK>; - clock-names = "core", "iface", "bus", - "vcodec0_core", "vcodec0_bus", - "vcodec1_core", "vcodec1_bus"; - iommus = <&apps_smmu 0x10a0 0x8>, - <&apps_smmu 0x10b0 0x0>; - memory-region = <&venus_mem>; - interconnects = <&mmss_noc MASTER_VIDEO_P0 0 &mem_noc SLAVE_EBI1 0>, - <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_VENUS_CFG 0>; - interconnect-names = "video-mem", "cpu-cfg"; - - status = "disabled"; - - video-core0 { - compatible = "venus-decoder"; - }; - - video-core1 { - compatible = "venus-encoder"; - }; - - venus_opp_table: opp-table { - compatible = "operating-points-v2"; - - opp-100000000 { - opp-hz = /bits/ 64 <100000000>; - required-opps = <&rpmhpd_opp_min_svs>; - }; - - opp-200000000 { - opp-hz = /bits/ 64 <200000000>; - required-opps = <&rpmhpd_opp_low_svs>; - }; - - opp-320000000 { - opp-hz = /bits/ 64 <320000000>; - required-opps = <&rpmhpd_opp_svs>; - }; - - opp-380000000 { - opp-hz = /bits/ 64 <380000000>; - required-opps = <&rpmhpd_opp_svs_l1>; - }; - - opp-444000000 { - opp-hz = /bits/ 64 <444000000>; - required-opps = <&rpmhpd_opp_nom>; - }; - - opp-533000097 { - opp-hz = /bits/ 64 <533000097>; - required-opps = <&rpmhpd_opp_turbo>; - }; - }; - }; - - videocc: clock-controller@ab00000 { - compatible = "qcom,sdm845-videocc"; - reg = <0 0x0ab00000 0 0x10000>; - clocks = <&rpmhcc RPMH_CXO_CLK>; - clock-names = "bi_tcxo"; - #clock-cells = <1>; - #power-domain-cells = <1>; - #reset-cells = <1>; - }; - - camss: camss@acb3000 { - compatible = "qcom,sdm845-camss"; - - reg = <0 0x0acb3000 0 0x1000>, - <0 0x0acba000 0 0x1000>, - <0 0x0acc8000 0 0x1000>, - <0 0x0ac65000 0 0x1000>, - <0 0x0ac66000 0 0x1000>, - <0 0x0ac67000 0 0x1000>, - <0 0x0ac68000 0 0x1000>, - <0 0x0acaf000 0 0x4000>, - <0 0x0acb6000 0 0x4000>, - <0 0x0acc4000 0 0x4000>; - reg-names = "csid0", - "csid1", - "csid2", - "csiphy0", - "csiphy1", - "csiphy2", - "csiphy3", - "vfe0", - "vfe1", - "vfe_lite"; - - interrupts = <GIC_SPI 464 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 466 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 468 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 477 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 478 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 479 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 448 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 465 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 467 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 469 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "csid0", - "csid1", - "csid2", - "csiphy0", - "csiphy1", - "csiphy2", - "csiphy3", - "vfe0", - "vfe1", - "vfe_lite"; - - power-domains = <&clock_camcc IFE_0_GDSC>, - <&clock_camcc IFE_1_GDSC>, - <&clock_camcc TITAN_TOP_GDSC>; - - clocks = <&clock_camcc CAM_CC_CAMNOC_AXI_CLK>, - <&clock_camcc CAM_CC_CPAS_AHB_CLK>, - <&clock_camcc CAM_CC_CPHY_RX_CLK_SRC>, - <&clock_camcc CAM_CC_IFE_0_CSID_CLK>, - <&clock_camcc CAM_CC_IFE_0_CSID_CLK_SRC>, - <&clock_camcc CAM_CC_IFE_1_CSID_CLK>, - <&clock_camcc CAM_CC_IFE_1_CSID_CLK_SRC>, - <&clock_camcc CAM_CC_IFE_LITE_CSID_CLK>, - <&clock_camcc CAM_CC_IFE_LITE_CSID_CLK_SRC>, - <&clock_camcc CAM_CC_CSIPHY0_CLK>, - <&clock_camcc CAM_CC_CSI0PHYTIMER_CLK>, - <&clock_camcc CAM_CC_CSI0PHYTIMER_CLK_SRC>, - <&clock_camcc CAM_CC_CSIPHY1_CLK>, - <&clock_camcc CAM_CC_CSI1PHYTIMER_CLK>, - <&clock_camcc CAM_CC_CSI1PHYTIMER_CLK_SRC>, - <&clock_camcc CAM_CC_CSIPHY2_CLK>, - <&clock_camcc CAM_CC_CSI2PHYTIMER_CLK>, - <&clock_camcc CAM_CC_CSI2PHYTIMER_CLK_SRC>, - <&clock_camcc CAM_CC_CSIPHY3_CLK>, - <&clock_camcc CAM_CC_CSI3PHYTIMER_CLK>, - <&clock_camcc CAM_CC_CSI3PHYTIMER_CLK_SRC>, - <&gcc GCC_CAMERA_AHB_CLK>, - <&gcc GCC_CAMERA_AXI_CLK>, - <&clock_camcc CAM_CC_SLOW_AHB_CLK_SRC>, - <&clock_camcc CAM_CC_SOC_AHB_CLK>, - <&clock_camcc CAM_CC_IFE_0_AXI_CLK>, - <&clock_camcc CAM_CC_IFE_0_CLK>, - <&clock_camcc CAM_CC_IFE_0_CPHY_RX_CLK>, - <&clock_camcc CAM_CC_IFE_0_CLK_SRC>, - <&clock_camcc CAM_CC_IFE_1_AXI_CLK>, - <&clock_camcc CAM_CC_IFE_1_CLK>, - <&clock_camcc CAM_CC_IFE_1_CPHY_RX_CLK>, - <&clock_camcc CAM_CC_IFE_1_CLK_SRC>, - <&clock_camcc CAM_CC_IFE_LITE_CLK>, - <&clock_camcc CAM_CC_IFE_LITE_CPHY_RX_CLK>, - <&clock_camcc CAM_CC_IFE_LITE_CLK_SRC>; - clock-names = "camnoc_axi", - "cpas_ahb", - "cphy_rx_src", - "csi0", - "csi0_src", - "csi1", - "csi1_src", - "csi2", - "csi2_src", - "csiphy0", - "csiphy0_timer", - "csiphy0_timer_src", - "csiphy1", - "csiphy1_timer", - "csiphy1_timer_src", - "csiphy2", - "csiphy2_timer", - "csiphy2_timer_src", - "csiphy3", - "csiphy3_timer", - "csiphy3_timer_src", - "gcc_camera_ahb", - "gcc_camera_axi", - "slow_ahb_src", - "soc_ahb", - "vfe0_axi", - "vfe0", - "vfe0_cphy_rx", - "vfe0_src", - "vfe1_axi", - "vfe1", - "vfe1_cphy_rx", - "vfe1_src", - "vfe_lite", - "vfe_lite_cphy_rx", - "vfe_lite_src"; - - iommus = <&apps_smmu 0x0808 0x0>, - <&apps_smmu 0x0810 0x8>, - <&apps_smmu 0x0c08 0x0>, - <&apps_smmu 0x0c10 0x8>; - - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - }; - - port@1 { - reg = <1>; - }; - - port@2 { - reg = <2>; - }; - - port@3 { - reg = <3>; - }; - }; - }; - - cci: cci@ac4a000 { - compatible = "qcom,sdm845-cci", "qcom,msm8996-cci"; - #address-cells = <1>; - #size-cells = <0>; - - reg = <0 0x0ac4a000 0 0x4000>; - interrupts = <GIC_SPI 460 IRQ_TYPE_EDGE_RISING>; - power-domains = <&clock_camcc TITAN_TOP_GDSC>; - - clocks = <&clock_camcc CAM_CC_CAMNOC_AXI_CLK>, - <&clock_camcc CAM_CC_SOC_AHB_CLK>, - <&clock_camcc CAM_CC_SLOW_AHB_CLK_SRC>, - <&clock_camcc CAM_CC_CPAS_AHB_CLK>, - <&clock_camcc CAM_CC_CCI_CLK>, - <&clock_camcc CAM_CC_CCI_CLK_SRC>; - clock-names = "camnoc_axi", - "soc_ahb", - "slow_ahb_src", - "cpas_ahb", - "cci", - "cci_src"; - - assigned-clocks = <&clock_camcc CAM_CC_CAMNOC_AXI_CLK>, - <&clock_camcc CAM_CC_CCI_CLK>; - assigned-clock-rates = <80000000>, <37500000>; - - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&cci0_default &cci1_default>; - pinctrl-1 = <&cci0_sleep &cci1_sleep>; - - status = "disabled"; - - cci_i2c0: i2c-bus@0 { - reg = <0>; - clock-frequency = <1000000>; - #address-cells = <1>; - #size-cells = <0>; - }; - - cci_i2c1: i2c-bus@1 { - reg = <1>; - clock-frequency = <1000000>; - #address-cells = <1>; - #size-cells = <0>; - }; - }; - - clock_camcc: clock-controller@ad00000 { - compatible = "qcom,sdm845-camcc"; - reg = <0 0x0ad00000 0 0x10000>; - #clock-cells = <1>; - #reset-cells = <1>; - #power-domain-cells = <1>; - clocks = <&rpmhcc RPMH_CXO_CLK>; - clock-names = "bi_tcxo"; - }; - - mdss: display-subsystem@ae00000 { - compatible = "qcom,sdm845-mdss"; - reg = <0 0x0ae00000 0 0x1000>; - reg-names = "mdss"; - - power-domains = <&dispcc MDSS_GDSC>; - - clocks = <&dispcc DISP_CC_MDSS_AHB_CLK>, - <&dispcc DISP_CC_MDSS_MDP_CLK>; - clock-names = "iface", "core"; - - interrupts = <GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>; - interrupt-controller; - #interrupt-cells = <1>; - - interconnects = <&mmss_noc MASTER_MDP0 0 &mem_noc SLAVE_EBI1 0>, - <&mmss_noc MASTER_MDP1 0 &mem_noc SLAVE_EBI1 0>; - interconnect-names = "mdp0-mem", "mdp1-mem"; - - iommus = <&apps_smmu 0x880 0x8>, - <&apps_smmu 0xc80 0x8>; - - status = "disabled"; - - #address-cells = <2>; - #size-cells = <2>; - ranges; - - mdss_mdp: display-controller@ae01000 { - compatible = "qcom,sdm845-dpu"; - reg = <0 0x0ae01000 0 0x8f000>, - <0 0x0aeb0000 0 0x2008>; - reg-names = "mdp", "vbif"; - - clocks = <&gcc GCC_DISP_AXI_CLK>, - <&dispcc DISP_CC_MDSS_AHB_CLK>, - <&dispcc DISP_CC_MDSS_AXI_CLK>, - <&dispcc DISP_CC_MDSS_MDP_CLK>, - <&dispcc DISP_CC_MDSS_VSYNC_CLK>; - clock-names = "gcc-bus", "iface", "bus", "core", "vsync"; - - assigned-clocks = <&dispcc DISP_CC_MDSS_VSYNC_CLK>; - assigned-clock-rates = <19200000>; - operating-points-v2 = <&mdp_opp_table>; - power-domains = <&rpmhpd SDM845_CX>; - - interrupt-parent = <&mdss>; - interrupts = <0>; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - dpu_intf0_out: endpoint { - remote-endpoint = <&dp_in>; - }; - }; - - port@1 { - reg = <1>; - dpu_intf1_out: endpoint { - remote-endpoint = <&mdss_dsi0_in>; - }; - }; - - port@2 { - reg = <2>; - dpu_intf2_out: endpoint { - remote-endpoint = <&mdss_dsi1_in>; - }; - }; - }; - - mdp_opp_table: opp-table { - compatible = "operating-points-v2"; - - opp-19200000 { - opp-hz = /bits/ 64 <19200000>; - required-opps = <&rpmhpd_opp_min_svs>; - }; - - opp-171428571 { - opp-hz = /bits/ 64 <171428571>; - required-opps = <&rpmhpd_opp_low_svs>; - }; - - opp-344000000 { - opp-hz = /bits/ 64 <344000000>; - required-opps = <&rpmhpd_opp_svs_l1>; - }; - - opp-430000000 { - opp-hz = /bits/ 64 <430000000>; - required-opps = <&rpmhpd_opp_nom>; - }; - }; - }; - - mdss_dp: displayport-controller@ae90000 { - status = "disabled"; - compatible = "qcom,sdm845-dp"; - - reg = <0 0x0ae90000 0 0x200>, - <0 0x0ae90200 0 0x200>, - <0 0x0ae90400 0 0x600>, - <0 0x0ae90a00 0 0x600>, - <0 0x0ae91000 0 0x600>; - - interrupt-parent = <&mdss>; - interrupts = <12>; - - clocks = <&dispcc DISP_CC_MDSS_AHB_CLK>, - <&dispcc DISP_CC_MDSS_DP_AUX_CLK>, - <&dispcc DISP_CC_MDSS_DP_LINK_CLK>, - <&dispcc DISP_CC_MDSS_DP_LINK_INTF_CLK>, - <&dispcc DISP_CC_MDSS_DP_PIXEL_CLK>; - clock-names = "core_iface", "core_aux", "ctrl_link", - "ctrl_link_iface", "stream_pixel"; - assigned-clocks = <&dispcc DISP_CC_MDSS_DP_LINK_CLK_SRC>, - <&dispcc DISP_CC_MDSS_DP_PIXEL_CLK_SRC>; - assigned-clock-parents = <&usb_1_qmpphy QMP_USB43DP_DP_LINK_CLK>, - <&usb_1_qmpphy QMP_USB43DP_DP_VCO_DIV_CLK>; - phys = <&usb_1_qmpphy QMP_USB43DP_DP_PHY>; - phy-names = "dp"; - - operating-points-v2 = <&dp_opp_table>; - power-domains = <&rpmhpd SDM845_CX>; - - ports { - #address-cells = <1>; - #size-cells = <0>; - port@0 { - reg = <0>; - dp_in: endpoint { - remote-endpoint = <&dpu_intf0_out>; - }; - }; - - port@1 { - reg = <1>; - dp_out: endpoint { }; - }; - }; - - dp_opp_table: opp-table { - compatible = "operating-points-v2"; - - opp-162000000 { - opp-hz = /bits/ 64 <162000000>; - required-opps = <&rpmhpd_opp_low_svs>; - }; - - opp-270000000 { - opp-hz = /bits/ 64 <270000000>; - required-opps = <&rpmhpd_opp_svs>; - }; - - opp-540000000 { - opp-hz = /bits/ 64 <540000000>; - required-opps = <&rpmhpd_opp_svs_l1>; - }; - - opp-810000000 { - opp-hz = /bits/ 64 <810000000>; - required-opps = <&rpmhpd_opp_nom>; - }; - }; - }; - - mdss_dsi0: dsi@ae94000 { - compatible = "qcom,sdm845-dsi-ctrl", - "qcom,mdss-dsi-ctrl"; - reg = <0 0x0ae94000 0 0x400>; - reg-names = "dsi_ctrl"; - - interrupt-parent = <&mdss>; - interrupts = <4>; - - clocks = <&dispcc DISP_CC_MDSS_BYTE0_CLK>, - <&dispcc DISP_CC_MDSS_BYTE0_INTF_CLK>, - <&dispcc DISP_CC_MDSS_PCLK0_CLK>, - <&dispcc DISP_CC_MDSS_ESC0_CLK>, - <&dispcc DISP_CC_MDSS_AHB_CLK>, - <&dispcc DISP_CC_MDSS_AXI_CLK>; - clock-names = "byte", - "byte_intf", - "pixel", - "core", - "iface", - "bus"; - assigned-clocks = <&dispcc DISP_CC_MDSS_BYTE0_CLK_SRC>, <&dispcc DISP_CC_MDSS_PCLK0_CLK_SRC>; - assigned-clock-parents = <&mdss_dsi0_phy 0>, <&mdss_dsi0_phy 1>; - - operating-points-v2 = <&dsi_opp_table>; - power-domains = <&rpmhpd SDM845_CX>; - - phys = <&mdss_dsi0_phy>; - - status = "disabled"; - - #address-cells = <1>; - #size-cells = <0>; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - mdss_dsi0_in: endpoint { - remote-endpoint = <&dpu_intf1_out>; - }; - }; - - port@1 { - reg = <1>; - mdss_dsi0_out: endpoint { - }; - }; - }; - }; - - mdss_dsi0_phy: phy@ae94400 { - compatible = "qcom,dsi-phy-10nm"; - reg = <0 0x0ae94400 0 0x200>, - <0 0x0ae94600 0 0x280>, - <0 0x0ae94a00 0 0x1e0>; - reg-names = "dsi_phy", - "dsi_phy_lane", - "dsi_pll"; - - #clock-cells = <1>; - #phy-cells = <0>; - - clocks = <&dispcc DISP_CC_MDSS_AHB_CLK>, - <&rpmhcc RPMH_CXO_CLK>; - clock-names = "iface", "ref"; - - status = "disabled"; - }; - - mdss_dsi1: dsi@ae96000 { - compatible = "qcom,sdm845-dsi-ctrl", - "qcom,mdss-dsi-ctrl"; - reg = <0 0x0ae96000 0 0x400>; - reg-names = "dsi_ctrl"; - - interrupt-parent = <&mdss>; - interrupts = <5>; - - clocks = <&dispcc DISP_CC_MDSS_BYTE1_CLK>, - <&dispcc DISP_CC_MDSS_BYTE1_INTF_CLK>, - <&dispcc DISP_CC_MDSS_PCLK1_CLK>, - <&dispcc DISP_CC_MDSS_ESC1_CLK>, - <&dispcc DISP_CC_MDSS_AHB_CLK>, - <&dispcc DISP_CC_MDSS_AXI_CLK>; - clock-names = "byte", - "byte_intf", - "pixel", - "core", - "iface", - "bus"; - assigned-clocks = <&dispcc DISP_CC_MDSS_BYTE1_CLK_SRC>, <&dispcc DISP_CC_MDSS_PCLK1_CLK_SRC>; - assigned-clock-parents = <&mdss_dsi1_phy 0>, <&mdss_dsi1_phy 1>; - - operating-points-v2 = <&dsi_opp_table>; - power-domains = <&rpmhpd SDM845_CX>; - - phys = <&mdss_dsi1_phy>; - - status = "disabled"; - - #address-cells = <1>; - #size-cells = <0>; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - mdss_dsi1_in: endpoint { - remote-endpoint = <&dpu_intf2_out>; - }; - }; - - port@1 { - reg = <1>; - mdss_dsi1_out: endpoint { - }; - }; - }; - }; - - mdss_dsi1_phy: phy@ae96400 { - compatible = "qcom,dsi-phy-10nm"; - reg = <0 0x0ae96400 0 0x200>, - <0 0x0ae96600 0 0x280>, - <0 0x0ae96a00 0 0x10e>; - reg-names = "dsi_phy", - "dsi_phy_lane", - "dsi_pll"; - - #clock-cells = <1>; - #phy-cells = <0>; - - clocks = <&dispcc DISP_CC_MDSS_AHB_CLK>, - <&rpmhcc RPMH_CXO_CLK>; - clock-names = "iface", "ref"; - - status = "disabled"; - }; - }; - - gpu: gpu@5000000 { - compatible = "qcom,adreno-630.2", "qcom,adreno"; - - reg = <0 0x05000000 0 0x40000>, <0 0x509e000 0 0x10>; - reg-names = "kgsl_3d0_reg_memory", "cx_mem"; - - /* - * Look ma, no clocks! The GPU clocks and power are - * controlled entirely by the GMU - */ - - interrupts = <GIC_SPI 300 IRQ_TYPE_LEVEL_HIGH>; - - iommus = <&adreno_smmu 0>; - - operating-points-v2 = <&gpu_opp_table>; - - qcom,gmu = <&gmu>; - - interconnects = <&mem_noc MASTER_GFX3D 0 &mem_noc SLAVE_EBI1 0>; - interconnect-names = "gfx-mem"; - - status = "disabled"; - - gpu_opp_table: opp-table { - compatible = "operating-points-v2"; - - opp-710000000 { - opp-hz = /bits/ 64 <710000000>; - opp-level = <RPMH_REGULATOR_LEVEL_TURBO_L1>; - opp-peak-kBps = <7216000>; - }; - - opp-675000000 { - opp-hz = /bits/ 64 <675000000>; - opp-level = <RPMH_REGULATOR_LEVEL_TURBO>; - opp-peak-kBps = <7216000>; - }; - - opp-596000000 { - opp-hz = /bits/ 64 <596000000>; - opp-level = <RPMH_REGULATOR_LEVEL_NOM_L1>; - opp-peak-kBps = <6220000>; - }; - - opp-520000000 { - opp-hz = /bits/ 64 <520000000>; - opp-level = <RPMH_REGULATOR_LEVEL_NOM>; - opp-peak-kBps = <6220000>; - }; - - opp-414000000 { - opp-hz = /bits/ 64 <414000000>; - opp-level = <RPMH_REGULATOR_LEVEL_SVS_L1>; - opp-peak-kBps = <4068000>; - }; - - opp-342000000 { - opp-hz = /bits/ 64 <342000000>; - opp-level = <RPMH_REGULATOR_LEVEL_SVS>; - opp-peak-kBps = <2724000>; - }; - - opp-257000000 { - opp-hz = /bits/ 64 <257000000>; - opp-level = <RPMH_REGULATOR_LEVEL_LOW_SVS>; - opp-peak-kBps = <1648000>; - }; - }; - }; - - adreno_smmu: iommu@5040000 { - compatible = "qcom,sdm845-smmu-v2", "qcom,adreno-smmu", "qcom,smmu-v2"; - reg = <0 0x05040000 0 0x10000>; - #iommu-cells = <1>; - #global-interrupts = <2>; - interrupts = <GIC_SPI 229 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 231 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 364 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 365 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 366 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 367 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 368 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 369 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 370 IRQ_TYPE_EDGE_RISING>, - <GIC_SPI 371 IRQ_TYPE_EDGE_RISING>; - clocks = <&gcc GCC_GPU_MEMNOC_GFX_CLK>, - <&gcc GCC_GPU_CFG_AHB_CLK>; - clock-names = "bus", "iface"; - - power-domains = <&gpucc GPU_CX_GDSC>; - }; - - gmu: gmu@506a000 { - compatible = "qcom,adreno-gmu-630.2", "qcom,adreno-gmu"; - - reg = <0 0x0506a000 0 0x30000>, - <0 0x0b280000 0 0x10000>, - <0 0x0b480000 0 0x10000>; - reg-names = "gmu", "gmu_pdc", "gmu_pdc_seq"; - - interrupts = <GIC_SPI 304 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 305 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "hfi", "gmu"; - - clocks = <&gpucc GPU_CC_CX_GMU_CLK>, - <&gpucc GPU_CC_CXO_CLK>, - <&gcc GCC_DDRSS_GPU_AXI_CLK>, - <&gcc GCC_GPU_MEMNOC_GFX_CLK>; - clock-names = "gmu", "cxo", "axi", "memnoc"; - - power-domains = <&gpucc GPU_CX_GDSC>, - <&gpucc GPU_GX_GDSC>; - power-domain-names = "cx", "gx"; - - iommus = <&adreno_smmu 5>; - - operating-points-v2 = <&gmu_opp_table>; - - status = "disabled"; - - gmu_opp_table: opp-table { - compatible = "operating-points-v2"; - - opp-400000000 { - opp-hz = /bits/ 64 <400000000>; - opp-level = <RPMH_REGULATOR_LEVEL_SVS>; - }; - - opp-200000000 { - opp-hz = /bits/ 64 <200000000>; - opp-level = <RPMH_REGULATOR_LEVEL_MIN_SVS>; - }; - }; - }; - - dispcc: clock-controller@af00000 { - compatible = "qcom,sdm845-dispcc"; - reg = <0 0x0af00000 0 0x10000>; - clocks = <&rpmhcc RPMH_CXO_CLK>, - <&gcc GCC_DISP_GPLL0_CLK_SRC>, - <&gcc GCC_DISP_GPLL0_DIV_CLK_SRC>, - <&mdss_dsi0_phy 0>, - <&mdss_dsi0_phy 1>, - <&mdss_dsi1_phy 0>, - <&mdss_dsi1_phy 1>, - <&usb_1_qmpphy QMP_USB43DP_DP_LINK_CLK>, - <&usb_1_qmpphy QMP_USB43DP_DP_VCO_DIV_CLK>; - clock-names = "bi_tcxo", - "gcc_disp_gpll0_clk_src", - "gcc_disp_gpll0_div_clk_src", - "dsi0_phy_pll_out_byteclk", - "dsi0_phy_pll_out_dsiclk", - "dsi1_phy_pll_out_byteclk", - "dsi1_phy_pll_out_dsiclk", - "dp_link_clk_divsel_ten", - "dp_vco_divided_clk_src_mux"; - #clock-cells = <1>; - #reset-cells = <1>; - #power-domain-cells = <1>; - }; - - pdc_intc: interrupt-controller@b220000 { - compatible = "qcom,sdm845-pdc", "qcom,pdc"; - reg = <0 0x0b220000 0 0x30000>; - qcom,pdc-ranges = <0 480 94>, <94 609 15>, <115 630 7>; - #interrupt-cells = <2>; - interrupt-parent = <&intc>; - interrupt-controller; - }; - - pdc_reset: reset-controller@b2e0000 { - compatible = "qcom,sdm845-pdc-global"; - reg = <0 0x0b2e0000 0 0x20000>; - #reset-cells = <1>; - }; - - tsens0: thermal-sensor@c263000 { - compatible = "qcom,sdm845-tsens", "qcom,tsens-v2"; - reg = <0 0x0c263000 0 0x1ff>, /* TM */ - <0 0x0c222000 0 0x1ff>; /* SROT */ - #qcom,sensors = <13>; - interrupts = <GIC_SPI 506 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 508 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "uplow", "critical"; - #thermal-sensor-cells = <1>; - }; - - tsens1: thermal-sensor@c265000 { - compatible = "qcom,sdm845-tsens", "qcom,tsens-v2"; - reg = <0 0x0c265000 0 0x1ff>, /* TM */ - <0 0x0c223000 0 0x1ff>; /* SROT */ - #qcom,sensors = <8>; - interrupts = <GIC_SPI 507 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 509 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "uplow", "critical"; - #thermal-sensor-cells = <1>; - }; - - aoss_reset: reset-controller@c2a0000 { - compatible = "qcom,sdm845-aoss-cc"; - reg = <0 0x0c2a0000 0 0x31000>; - #reset-cells = <1>; - }; - - aoss_qmp: power-management@c300000 { - compatible = "qcom,sdm845-aoss-qmp", "qcom,aoss-qmp"; - reg = <0 0x0c300000 0 0x400>; - interrupts = <GIC_SPI 389 IRQ_TYPE_EDGE_RISING>; - mboxes = <&apss_shared 0>; - - #clock-cells = <0>; - - cx_cdev: cx { - #cooling-cells = <2>; - }; - - ebi_cdev: ebi { - #cooling-cells = <2>; - }; - }; - - sram@c3f0000 { - compatible = "qcom,sdm845-rpmh-stats"; - reg = <0 0x0c3f0000 0 0x400>; - }; - - spmi_bus: spmi@c440000 { - compatible = "qcom,spmi-pmic-arb"; - reg = <0 0x0c440000 0 0x1100>, - <0 0x0c600000 0 0x2000000>, - <0 0x0e600000 0 0x100000>, - <0 0x0e700000 0 0xa0000>, - <0 0x0c40a000 0 0x26000>; - reg-names = "core", "chnls", "obsrvr", "intr", "cnfg"; - interrupt-names = "periph_irq"; - interrupts = <GIC_SPI 481 IRQ_TYPE_LEVEL_HIGH>; - qcom,ee = <0>; - qcom,channel = <0>; - #address-cells = <2>; - #size-cells = <0>; - interrupt-controller; - #interrupt-cells = <4>; - }; - - sram@146bf000 { - compatible = "qcom,sdm845-imem", "syscon", "simple-mfd"; - reg = <0 0x146bf000 0 0x1000>; - - #address-cells = <1>; - #size-cells = <1>; - - ranges = <0 0 0x146bf000 0x1000>; - - pil-reloc@94c { - compatible = "qcom,pil-reloc-info"; - reg = <0x94c 0xc8>; - }; - }; - - apps_smmu: iommu@15000000 { - compatible = "qcom,sdm845-smmu-500", "arm,mmu-500"; - reg = <0 0x15000000 0 0x80000>; - #iommu-cells = <2>; - #global-interrupts = <1>; - interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 97 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 99 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 103 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 104 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 106 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 111 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 113 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 114 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 115 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 181 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 182 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 183 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 185 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 187 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 189 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 190 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 191 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 192 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 315 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 316 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 317 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 318 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 319 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 320 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 321 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 322 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 323 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 324 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 325 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 326 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 327 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 328 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 329 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 330 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 331 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 332 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 333 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 334 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 335 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 336 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 337 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 338 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 339 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 340 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 341 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 342 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 343 IRQ_TYPE_LEVEL_HIGH>; - }; - - lpasscc: clock-controller@17014000 { - compatible = "qcom,sdm845-lpasscc"; - reg = <0 0x17014000 0 0x1f004>, <0 0x17300000 0 0x200>; - reg-names = "cc", "qdsp6ss"; - #clock-cells = <1>; - status = "disabled"; - }; - - gladiator_noc: interconnect@17900000 { - compatible = "qcom,sdm845-gladiator-noc"; - reg = <0 0x17900000 0 0xd080>; - #interconnect-cells = <2>; - qcom,bcm-voters = <&apps_bcm_voter>; - }; - - watchdog@17980000 { - compatible = "qcom,apss-wdt-sdm845", "qcom,kpss-wdt"; - reg = <0 0x17980000 0 0x1000>; - clocks = <&sleep_clk>; - interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>; - }; - - apss_shared: mailbox@17990000 { - compatible = "qcom,sdm845-apss-shared"; - reg = <0 0x17990000 0 0x1000>; - #mbox-cells = <1>; - }; - - apps_rsc: rsc@179c0000 { - label = "apps_rsc"; - compatible = "qcom,rpmh-rsc"; - reg = <0 0x179c0000 0 0x10000>, - <0 0x179d0000 0 0x10000>, - <0 0x179e0000 0 0x10000>; - reg-names = "drv-0", "drv-1", "drv-2"; - interrupts = <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>; - qcom,tcs-offset = <0xd00>; - qcom,drv-id = <2>; - qcom,tcs-config = <ACTIVE_TCS 2>, - <SLEEP_TCS 3>, - <WAKE_TCS 3>, - <CONTROL_TCS 1>; - power-domains = <&CLUSTER_PD>; - - apps_bcm_voter: bcm-voter { - compatible = "qcom,bcm-voter"; - }; - - rpmhcc: clock-controller { - compatible = "qcom,sdm845-rpmh-clk"; - #clock-cells = <1>; - clock-names = "xo"; - clocks = <&xo_board>; - }; - - rpmhpd: power-controller { - compatible = "qcom,sdm845-rpmhpd"; - #power-domain-cells = <1>; - operating-points-v2 = <&rpmhpd_opp_table>; - - rpmhpd_opp_table: opp-table { - compatible = "operating-points-v2"; - - rpmhpd_opp_ret: opp1 { - opp-level = <RPMH_REGULATOR_LEVEL_RETENTION>; - }; - - rpmhpd_opp_min_svs: opp2 { - opp-level = <RPMH_REGULATOR_LEVEL_MIN_SVS>; - }; - - rpmhpd_opp_low_svs: opp3 { - opp-level = <RPMH_REGULATOR_LEVEL_LOW_SVS>; - }; - - rpmhpd_opp_svs: opp4 { - opp-level = <RPMH_REGULATOR_LEVEL_SVS>; - }; - - rpmhpd_opp_svs_l1: opp5 { - opp-level = <RPMH_REGULATOR_LEVEL_SVS_L1>; - }; - - rpmhpd_opp_nom: opp6 { - opp-level = <RPMH_REGULATOR_LEVEL_NOM>; - }; - - rpmhpd_opp_nom_l1: opp7 { - opp-level = <RPMH_REGULATOR_LEVEL_NOM_L1>; - }; - - rpmhpd_opp_nom_l2: opp8 { - opp-level = <RPMH_REGULATOR_LEVEL_NOM_L2>; - }; - - rpmhpd_opp_turbo: opp9 { - opp-level = <RPMH_REGULATOR_LEVEL_TURBO>; - }; - - rpmhpd_opp_turbo_l1: opp10 { - opp-level = <RPMH_REGULATOR_LEVEL_TURBO_L1>; - }; - }; - }; - }; - - intc: interrupt-controller@17a00000 { - compatible = "arm,gic-v3"; - #address-cells = <2>; - #size-cells = <2>; - ranges; - #interrupt-cells = <3>; - interrupt-controller; - reg = <0 0x17a00000 0 0x10000>, /* GICD */ - <0 0x17a60000 0 0x100000>; /* GICR * 8 */ - interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH>; - - msi-controller@17a40000 { - compatible = "arm,gic-v3-its"; - msi-controller; - #msi-cells = <1>; - reg = <0 0x17a40000 0 0x20000>; - status = "disabled"; - }; - }; - - slimbam: dma-controller@17184000 { - compatible = "qcom,bam-v1.7.4", "qcom,bam-v1.7.0"; - qcom,controlled-remotely; - reg = <0 0x17184000 0 0x2a000>; - num-channels = <31>; - interrupts = <GIC_SPI 164 IRQ_TYPE_LEVEL_HIGH>; - #dma-cells = <1>; - qcom,ee = <1>; - qcom,num-ees = <2>; - iommus = <&apps_smmu 0x1806 0x0>; - }; - - timer@17c90000 { - #address-cells = <1>; - #size-cells = <1>; - ranges = <0 0 0 0x20000000>; - compatible = "arm,armv7-timer-mem"; - reg = <0 0x17c90000 0 0x1000>; - - frame@17ca0000 { - frame-number = <0>; - interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; - reg = <0x17ca0000 0x1000>, - <0x17cb0000 0x1000>; - }; - - frame@17cc0000 { - frame-number = <1>; - interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; - reg = <0x17cc0000 0x1000>; - status = "disabled"; - }; - - frame@17cd0000 { - frame-number = <2>; - interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; - reg = <0x17cd0000 0x1000>; - status = "disabled"; - }; - - frame@17ce0000 { - frame-number = <3>; - interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; - reg = <0x17ce0000 0x1000>; - status = "disabled"; - }; - - frame@17cf0000 { - frame-number = <4>; - interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; - reg = <0x17cf0000 0x1000>; - status = "disabled"; - }; - - frame@17d00000 { - frame-number = <5>; - interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>; - reg = <0x17d00000 0x1000>; - status = "disabled"; - }; - - frame@17d10000 { - frame-number = <6>; - interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>; - reg = <0x17d10000 0x1000>; - status = "disabled"; - }; - }; - - osm_l3: interconnect@17d41000 { - compatible = "qcom,sdm845-osm-l3", "qcom,osm-l3"; - reg = <0 0x17d41000 0 0x1400>; - - clocks = <&rpmhcc RPMH_CXO_CLK>, <&gcc GPLL0>; - clock-names = "xo", "alternate"; - - #interconnect-cells = <1>; - }; - - cpufreq_hw: cpufreq@17d43000 { - compatible = "qcom,sdm845-cpufreq-hw", "qcom,cpufreq-hw"; - reg = <0 0x17d43000 0 0x1400>, <0 0x17d45800 0 0x1400>; - reg-names = "freq-domain0", "freq-domain1"; - - interrupts-extended = <&lmh_cluster0 0>, <&lmh_cluster1 0>; - - clocks = <&rpmhcc RPMH_CXO_CLK>, <&gcc GPLL0>; - clock-names = "xo", "alternate"; - - #freq-domain-cells = <1>; - #clock-cells = <1>; - }; - - wifi: wifi@18800000 { - compatible = "qcom,wcn3990-wifi"; - status = "disabled"; - reg = <0 0x18800000 0 0x800000>; - reg-names = "membase"; - memory-region = <&wlan_msa_mem>; - clock-names = "cxo_ref_clk_pin"; - clocks = <&rpmhcc RPMH_RF_CLK2>; - interrupts = - <GIC_SPI 414 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 415 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 416 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 417 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 418 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 419 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 420 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 421 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 422 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 423 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 424 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 425 IRQ_TYPE_LEVEL_HIGH>; - iommus = <&apps_smmu 0x0040 0x1>; - }; - }; - - sound: sound { - }; - - thermal-zones { - cpu0-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens0 1>; - - trips { - cpu0_alert0: trip-point0 { - temperature = <90000>; - hysteresis = <2000>; - type = "passive"; - }; - - cpu0_alert1: trip-point1 { - temperature = <95000>; - hysteresis = <2000>; - type = "passive"; - }; - - cpu0_crit: cpu-crit { - temperature = <110000>; - hysteresis = <1000>; - type = "critical"; - }; - }; - }; - - cpu1-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens0 2>; - - trips { - cpu1_alert0: trip-point0 { - temperature = <90000>; - hysteresis = <2000>; - type = "passive"; - }; - - cpu1_alert1: trip-point1 { - temperature = <95000>; - hysteresis = <2000>; - type = "passive"; - }; - - cpu1_crit: cpu-crit { - temperature = <110000>; - hysteresis = <1000>; - type = "critical"; - }; - }; - }; - - cpu2-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens0 3>; - - trips { - cpu2_alert0: trip-point0 { - temperature = <90000>; - hysteresis = <2000>; - type = "passive"; - }; - - cpu2_alert1: trip-point1 { - temperature = <95000>; - hysteresis = <2000>; - type = "passive"; - }; - - cpu2_crit: cpu-crit { - temperature = <110000>; - hysteresis = <1000>; - type = "critical"; - }; - }; - }; - - cpu3-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens0 4>; - - trips { - cpu3_alert0: trip-point0 { - temperature = <90000>; - hysteresis = <2000>; - type = "passive"; - }; - - cpu3_alert1: trip-point1 { - temperature = <95000>; - hysteresis = <2000>; - type = "passive"; - }; - - cpu3_crit: cpu-crit { - temperature = <110000>; - hysteresis = <1000>; - type = "critical"; - }; - }; - }; - - cpu4-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens0 7>; - - trips { - cpu4_alert0: trip-point0 { - temperature = <90000>; - hysteresis = <2000>; - type = "passive"; - }; - - cpu4_alert1: trip-point1 { - temperature = <95000>; - hysteresis = <2000>; - type = "passive"; - }; - - cpu4_crit: cpu-crit { - temperature = <110000>; - hysteresis = <1000>; - type = "critical"; - }; - }; - }; - - cpu5-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens0 8>; - - trips { - cpu5_alert0: trip-point0 { - temperature = <90000>; - hysteresis = <2000>; - type = "passive"; - }; - - cpu5_alert1: trip-point1 { - temperature = <95000>; - hysteresis = <2000>; - type = "passive"; - }; - - cpu5_crit: cpu-crit { - temperature = <110000>; - hysteresis = <1000>; - type = "critical"; - }; - }; - }; - - cpu6-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens0 9>; - - trips { - cpu6_alert0: trip-point0 { - temperature = <90000>; - hysteresis = <2000>; - type = "passive"; - }; - - cpu6_alert1: trip-point1 { - temperature = <95000>; - hysteresis = <2000>; - type = "passive"; - }; - - cpu6_crit: cpu-crit { - temperature = <110000>; - hysteresis = <1000>; - type = "critical"; - }; - }; - }; - - cpu7-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens0 10>; - - trips { - cpu7_alert0: trip-point0 { - temperature = <90000>; - hysteresis = <2000>; - type = "passive"; - }; - - cpu7_alert1: trip-point1 { - temperature = <95000>; - hysteresis = <2000>; - type = "passive"; - }; - - cpu7_crit: cpu-crit { - temperature = <110000>; - hysteresis = <1000>; - type = "critical"; - }; - }; - }; - - aoss0-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens0 0>; - - trips { - aoss0_alert0: trip-point0 { - temperature = <90000>; - hysteresis = <2000>; - type = "hot"; - }; - }; - }; - - cluster0-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens0 5>; - - trips { - cluster0_alert0: trip-point0 { - temperature = <90000>; - hysteresis = <2000>; - type = "hot"; - }; - cluster0_crit: cluster0_crit { - temperature = <110000>; - hysteresis = <2000>; - type = "critical"; - }; - }; - }; - - cluster1-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens0 6>; - - trips { - cluster1_alert0: trip-point0 { - temperature = <90000>; - hysteresis = <2000>; - type = "hot"; - }; - cluster1_crit: cluster1_crit { - temperature = <110000>; - hysteresis = <2000>; - type = "critical"; - }; - }; - }; - - gpu-top-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens0 11>; - - trips { - gpu1_alert0: trip-point0 { - temperature = <90000>; - hysteresis = <2000>; - type = "hot"; - }; - }; - }; - - gpu-bottom-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens0 12>; - - trips { - gpu2_alert0: trip-point0 { - temperature = <90000>; - hysteresis = <2000>; - type = "hot"; - }; - }; - }; - - aoss1-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens1 0>; - - trips { - aoss1_alert0: trip-point0 { - temperature = <90000>; - hysteresis = <2000>; - type = "hot"; - }; - }; - }; - - q6-modem-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens1 1>; - - trips { - q6_modem_alert0: trip-point0 { - temperature = <90000>; - hysteresis = <2000>; - type = "hot"; - }; - }; - }; - - mem-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens1 2>; - - trips { - mem_alert0: trip-point0 { - temperature = <90000>; - hysteresis = <2000>; - type = "hot"; - }; - }; - }; - - wlan-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens1 3>; - - trips { - wlan_alert0: trip-point0 { - temperature = <90000>; - hysteresis = <2000>; - type = "hot"; - }; - }; - }; - - q6-hvx-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens1 4>; - - trips { - q6_hvx_alert0: trip-point0 { - temperature = <90000>; - hysteresis = <2000>; - type = "hot"; - }; - }; - }; - - camera-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens1 5>; - - trips { - camera_alert0: trip-point0 { - temperature = <90000>; - hysteresis = <2000>; - type = "hot"; - }; - }; - }; - - video-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens1 6>; - - trips { - video_alert0: trip-point0 { - temperature = <90000>; - hysteresis = <2000>; - type = "hot"; - }; - }; - }; - - modem-thermal { - polling-delay-passive = <250>; - polling-delay = <1000>; - - thermal-sensors = <&tsens1 7>; - - trips { - modem_alert0: trip-point0 { - temperature = <90000>; - hysteresis = <2000>; - type = "hot"; - }; - }; - }; - }; - - timer { - compatible = "arm,armv8-timer"; - interrupts = <GIC_PPI 1 IRQ_TYPE_LEVEL_LOW>, - <GIC_PPI 2 IRQ_TYPE_LEVEL_LOW>, - <GIC_PPI 3 IRQ_TYPE_LEVEL_LOW>, - <GIC_PPI 0 IRQ_TYPE_LEVEL_LOW>; - }; -};
On 18/04/2024 19:24, Caleb Connolly wrote:
These files are all identical (or older) than those in dts/upstream. Drop them as we now use upstream DTS files with OF_UPSTREAM.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org
arch/arm/dts/apq8016-sbc.dts | 729 ---- arch/arm/dts/apq8096-db820c.dts | 1137 ------ arch/arm/dts/msm8916-pm8916.dtsi | 157 - arch/arm/dts/msm8916.dtsi | 2702 ------------- arch/arm/dts/msm8996.dtsi | 3884 ------------------ arch/arm/dts/pm8916.dtsi | 178 - arch/arm/dts/pm8994.dtsi | 152 - arch/arm/dts/pm8998.dtsi | 130 - arch/arm/dts/pmi8994.dtsi | 65 - arch/arm/dts/pmi8998.dtsi | 98 - arch/arm/dts/pms405.dtsi | 149 - arch/arm/dts/qcs404-evb-4000.dts | 96 - arch/arm/dts/qcs404-evb.dtsi | 389 -- arch/arm/dts/qcs404.dtsi | 1829 --------- arch/arm/dts/sdm845-db845c.dts | 1190 ------ arch/arm/dts/sdm845-samsung-starqltechn.dts | 460 --- arch/arm/dts/sdm845-wcd9340.dtsi | 86 - arch/arm/dts/sdm845.dtsi | 5752 --------------------------- 18 files changed, 19183 deletions(-)
Reviewed-by: Neil Armstrong neil.armstrong@linaro.org
Give us lots of room for the appended FDT.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- configs/qcom_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/qcom_defconfig b/configs/qcom_defconfig index 218a9a769682..7b589f0bf7a7 100644 --- a/configs/qcom_defconfig +++ b/configs/qcom_defconfig @@ -3,8 +3,9 @@ CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_POSITION_INDEPENDENT=y CONFIG_ARCH_SNAPDRAGON=y CONFIG_DEFAULT_DEVICE_TREE="qcom/sdm845-db845c" CONFIG_SYS_LOAD_ADDR=0x0 +CONFIG_SYS_INIT_SP_BSS_OFFSET=1572864 CONFIG_BUTTON_CMD=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_BOOTSTD_FULL=y
On Thu, 18 Apr 2024 at 10:24, Caleb Connolly caleb.connolly@linaro.org wrote:
This series does the initial switch to OF_UPSTREAM for Qualcomm platforms. The DT files we have in U-Boot are outdated by now, so drop them and move to upstream.
Patch 2 drops all the Qualcomm dts files that are now provided in dts/upstream. As some of the files exceed the 100k size limit by themselves I thought it would be easier to just lump them together rather than trying to split them up.
The associated qcom headers will be cleaned up in future patches.
Caleb Connolly (3): mach-snapdragon: use OF_UPSTREAM arm: dts: drop qcom dts files qcom_defconfig: set SYS_INIT_SP_BSS_OFFSET
Reviewed-by: Sumit Garg sumit.garg@linaro.org
-Sumit
MAINTAINERS | 4 - arch/arm/Kconfig | 1 + arch/arm/dts/apq8016-sbc.dts | 729 ---- arch/arm/dts/apq8096-db820c.dts | 1137 ------ arch/arm/dts/msm8916-pm8916.dtsi | 157 - arch/arm/dts/msm8916.dtsi | 2702 ------------- arch/arm/dts/msm8996.dtsi | 3884 ------------------ arch/arm/dts/pm8916.dtsi | 178 - arch/arm/dts/pm8994.dtsi | 152 - arch/arm/dts/pm8998.dtsi | 130 - arch/arm/dts/pmi8994.dtsi | 65 - arch/arm/dts/pmi8998.dtsi | 98 - arch/arm/dts/pms405.dtsi | 149 - arch/arm/dts/qcs404-evb-4000.dts | 96 - arch/arm/dts/qcs404-evb.dtsi | 389 -- arch/arm/dts/qcs404.dtsi | 1829 --------- arch/arm/dts/sdm845-db845c.dts | 1190 ------ arch/arm/dts/sdm845-samsung-starqltechn.dts | 460 --- arch/arm/dts/sdm845-wcd9340.dtsi | 86 - arch/arm/dts/sdm845.dtsi | 5752 --------------------------- configs/dragonboard410c_defconfig | 2 +- configs/dragonboard820c_defconfig | 2 +- configs/qcom_defconfig | 3 +- 23 files changed, 5 insertions(+), 19190 deletions(-)
base-commit: d5460b082cd6afd0e07c0ec0e5a82d1af8dc09f7
// Caleb (they/them)
Applied, thanks!
[1/3] mach-snapdragon: use OF_UPSTREAM commit: a149974d3cf81dfc11254e3093f645bec3d5d88e [2/3] arm: dts: drop qcom dts files commit: 4a30052dee8726cfa9b1f6873496389ae1732ba4 [3/3] qcom_defconfig: set SYS_INIT_SP_BSS_OFFSET commit: 813bc424871caf3decffb50119906bcdbf33d973
Caleb Connolly
Neil Armstrong
Sumit Garg
