[U-Boot] [PATCH v3 1/2] linux/bitops: Move BIT definitions at top
Since it's a copy from Linux, this patch moved all BIT definitions to top so-that it looks same as Linux file.
Cc: Tom Rini trini@konsulko.com Cc: Albert ARIBAUD albert.u.boot@aribaud.net Signed-off-by: Jagan Teki jteki@openedev.com --- Changes for v3: - Fix typo defination -> definition. - Used definitions instead of definition as more BIT definitions are moved Changes for v2: - Added tab space for BIT(nr)
include/linux/bitops.h | 7 +++---- 1 file changed, 3 insertions(+), 4 deletions(-)
diff --git a/include/linux/bitops.h b/include/linux/bitops.h index 7d30ace..e9bb827 100644 --- a/include/linux/bitops.h +++ b/include/linux/bitops.h @@ -3,7 +3,9 @@
#include <asm/types.h>
-#define BIT(nr) (1UL << (nr)) +#define BIT(nr) (1UL << (nr)) +#define BIT_MASK(nr) (1UL << ((nr) % BITS_PER_LONG)) +#define BIT_WORD(nr) ((nr) / BITS_PER_LONG)
/* * ffs: find first bit set. This is defined the same way as @@ -106,9 +108,6 @@ static inline unsigned int generic_hweight8(unsigned int w) return (res & 0x0F) + ((res >> 4) & 0x0F); }
-#define BIT_MASK(nr) (1UL << ((nr) % BITS_PER_LONG)) -#define BIT_WORD(nr) ((nr) / BITS_PER_LONG) - #include <asm/bitops.h>
/* linux/include/asm-generic/bitops/non-atomic.h */
Jagan Teki
