[PATCH] clk: rockchip: rk3399: implement getting wdt/alive clocks
In order to correctly calculate the designware watchdog timeouts, the watchdog clock is required. Implement required clocks to facilitate this.
Signed-off-by: Jack Mitchell ml@embed.me.uk --- drivers/clk/rockchip/clk_rk3399.c | 20 ++++++++++++++++++++ 1 file changed, 20 insertions(+)
diff --git a/drivers/clk/rockchip/clk_rk3399.c b/drivers/clk/rockchip/clk_rk3399.c index c8075e3dd2..4caa3bbdf5 100644 --- a/drivers/clk/rockchip/clk_rk3399.c +++ b/drivers/clk/rockchip/clk_rk3399.c @@ -241,6 +241,10 @@ enum { DCLK_VOP_DIV_CON_MASK = 0xff, DCLK_VOP_DIV_CON_SHIFT = 0,
+ /* CLKSEL_CON57 */ + PCLK_ALIVE_DIV_CON_SHIFT = 0, + PCLK_ALIVE_DIV_CON_MASK = 0x1f << PCLK_ALIVE_DIV_CON_SHIFT, + /* CLKSEL_CON58 */ CLK_SPI_PLL_SEL_WIDTH = 1, CLK_SPI_PLL_SEL_MASK = ((1 < CLK_SPI_PLL_SEL_WIDTH) - 1), @@ -875,6 +879,17 @@ static ulong rk3399_ddr_set_clk(struct rockchip_cru *cru, return set_rate; }
+static ulong rk3399_alive_get_clk(struct rockchip_cru *cru) +{ + u32 div, val; + + val = readl(&cru->clksel_con[57]); + div = (val & PCLK_ALIVE_DIV_CON_MASK) >> + PCLK_ALIVE_DIV_CON_SHIFT; + + return DIV_TO_RATE(GPLL_HZ, div); +} + static ulong rk3399_saradc_get_clk(struct rockchip_cru *cru) { u32 div, val; @@ -944,6 +959,10 @@ static ulong rk3399_clk_get_rate(struct clk *clk) case ACLK_GIC_PRE: case PCLK_DDR: break; + case PCLK_ALIVE: + case PCLK_WDT: + rate = rk3399_alive_get_clk(priv->cru); + break; default: log_debug("Unknown clock %lu\n", clk->id); return -ENOENT; @@ -1510,6 +1529,7 @@ static ulong rk3399_pmuclk_get_rate(struct clk *clk) case PLL_PPLL: return PPLL_HZ; case PCLK_RKPWM_PMU: + case PCLK_WDT_M0_PMU: rate = rk3399_pwm_get_clk(priv->pmucru); break; case SCLK_I2C0_PMU:
Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks,
- Kever
- /* CLKSEL_CON57 */
- PCLK_ALIVE_DIV_CON_SHIFT = 0,
- PCLK_ALIVE_DIV_CON_MASK = 0x1f << PCLK_ALIVE_DIV_CON_SHIFT,
- /* CLKSEL_CON58 */ CLK_SPI_PLL_SEL_WIDTH = 1, CLK_SPI_PLL_SEL_MASK = ((1 < CLK_SPI_PLL_SEL_WIDTH) - 1),
u32 div, val;
- static ulong rk3399_saradc_get_clk(struct rockchip_cru *cru) { u32 div, val;
- case PCLK_ALIVE:
- case PCLK_WDT:
default: log_debug("Unknown clock %lu\n", clk->id); return -ENOENT;break;
- case PCLK_WDT_M0_PMU: rate = rk3399_pwm_get_clk(priv->pmucru); break; case SCLK_I2C0_PMU:
Jack Mitchell
Kever Yang
Philipp Tomsich
