[U-Boot] [PATCH] ARM: fix arch/arm/Makefile for Tegra
Since commit 79d75d752717 (ARM: move -march=* and -mtune= options to arch/arm/Makefile), all the Tegra boards are broken because the SPL is built for ARMv7.
Insert Tegra-specific code to arch/arm/Makefile to set compiler flags for an earlier ARM architecture.
Note: The patch for commit 79d75d752717 *was* correct when it was posted. Notice it was written for multi .config configuration where Kconfig set CONFIG_CPU_V7/CONFIG_CPU_ARM720T for Tegra U-Boot Main/SPL, respectively. But, it look long until that patch was merged into the mainline, and finally, it was overtaken by commit e02ee2548afe (kconfig: switch to single .config configuration).
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com Reported-by: Stephen Warren swarren@nvidia.com Reported-by: Jan Kiszka jan.kiszka@web.de ---
I just did build test for all the Tegra boards.
Stephen, Could you do run-test?
Tom, Please hold back the v2015.04 release until we confim this problem is fixed.
arch/arm/Makefile | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/arm/Makefile b/arch/arm/Makefile index 6463c19..bd4749c 100644 --- a/arch/arm/Makefile +++ b/arch/arm/Makefile @@ -2,6 +2,11 @@ # SPDX-License-Identifier: GPL-2.0+ #
+ifeq ($(CONFIG_SPL_BUILD)$(CONFIG_TEGRA),yy) +CONFIG_CPU_V7= +CONFIG_CPU_ARM720T=y +endif + # This selects which instruction set is used. arch-$(CONFIG_CPU_ARM720T) =-march=armv4 arch-$(CONFIG_CPU_ARM920T) =-march=armv4
Tested-by: Jan Kiszka jan.kiszka@siemens.com
Thanks for the quick solution! Jan
Jan Kiszka
Masahiro Yamada
