[U-Boot] [PATCH] powerpc/mpc85xx: Add workaround to enable TDM on T1040
This is a workaround for 32 bit hardware limitation of TDM. T1040 has 36 bit physical addressing, TDM DMAC register are 32 bit wide but need to store address of CCSR space which lies beyond 32 bit address range. This workaround creats a LAW to enable access of TDM DMA to CCSR by mapping CCSR to overlap with DDR. A hole of 16M is created in memory using device tree. This workaround law is set only if "tdm" is defined in hwconfig. Also disable POST tests and add LIODN for TDM
Signed-off-by: Sandeep Singh Sandeep@freescale.com Cc: York Sun yorksun@freescale.com --- arch/powerpc/cpu/mpc85xx/cpu_init.c | 29 +++++++++++++++++++++++++++++ arch/powerpc/cpu/mpc85xx/fdt.c | 26 ++++++++++++++++++++++++++ arch/powerpc/cpu/mpc85xx/t1040_ids.c | 1 + arch/powerpc/include/asm/fsl_law.h | 1 + arch/powerpc/include/asm/fsl_liodn.h | 4 ++++ arch/powerpc/include/asm/immap_85xx.h | 4 +++- include/configs/T1040QDS.h | 6 ++++++ include/configs/T104xRDB.h | 6 ++++++ 8 files changed, 76 insertions(+), 1 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init.c b/arch/powerpc/cpu/mpc85xx/cpu_init.c index d6cf885..78316a6 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init.c @@ -225,6 +225,32 @@ static void disable_cpc_sram(void) } #endif
+#if defined(T1040_TDM_QUIRK_CCSR_BASE) +#ifdef CONFIG_POST +#error POST memory test cannot be enabled with TDM +#endif +static void enable_tdm_law(void) +{ + int ret; + char buffer[HWCONFIG_BUFFER_SIZE] = {0}; + int tdm_hwconfig_enabled = 0; + + /* + * Extract hwconfig from environment since environment + * is not setup properly yet. Search for tdm entry in + * hwconfig. + */ + ret = getenv_f("hwconfig", buffer, sizeof(buffer)); + if (ret > 0) { + tdm_hwconfig_enabled = hwconfig_f("tdm", buffer); + /* If tdm is defined in hwconfig, set law for tdm workaround */ + if (tdm_hwconfig_enabled) + set_next_law(T1040_TDM_QUIRK_CCSR_BASE, LAW_SIZE_16M, + LAW_TRGT_IF_CCSR); + } +} +#endif + static void enable_cpc(void) { int i; @@ -729,6 +755,9 @@ skip_l2: disable_cpc_sram(); #endif enable_cpc(); +#if defined(T1040_TDM_QUIRK_CCSR_BASE) + enable_tdm_law(); +#endif
#ifndef CONFIG_SYS_FSL_NO_SERDES /* needs to be in ram since code uses global static vars */ diff --git a/arch/powerpc/cpu/mpc85xx/fdt.c b/arch/powerpc/cpu/mpc85xx/fdt.c index ed80a84..85dfa5b 100644 --- a/arch/powerpc/cpu/mpc85xx/fdt.c +++ b/arch/powerpc/cpu/mpc85xx/fdt.c @@ -14,6 +14,7 @@ #include <linux/ctype.h> #include <asm/io.h> #include <asm/fsl_portals.h> +#include <hwconfig.h> #ifdef CONFIG_FSL_ESDHC #include <fsl_esdhc.h> #endif @@ -35,6 +36,11 @@ void ft_fixup_cpu(void *blob, u64 memory_limit) u32 bootpg = determine_mp_bootpg(NULL); u32 id = get_my_id(); const char *enable_method; +#if defined(T1040_TDM_QUIRK_CCSR_BASE) + int ret; + int tdm_hwconfig_enabled = 0; + char buffer[HWCONFIG_BUFFER_SIZE] = {0}; +#endif
off = fdt_node_offset_by_prop_value(blob, -1, "device_type", "cpu", 4); while (off != -FDT_ERR_NOTFOUND) { @@ -77,6 +83,26 @@ void ft_fixup_cpu(void *blob, u64 memory_limit) "device_type", "cpu", 4); }
+#if defined(T1040_TDM_QUIRK_CCSR_BASE) +#define CONFIG_MEM_HOLE_16M 0x1000000 + /* + * Extract hwconfig from environment. + * Search for tdm entry in hwconfig. + */ + ret = getenv_f("hwconfig", buffer, sizeof(buffer)); + if (ret > 0) + tdm_hwconfig_enabled = hwconfig_f("tdm", buffer); + + /* Reserve the memory hole created by TDM LAW, so OSes dont use it */ + if (tdm_hwconfig_enabled) { + off = fdt_add_mem_rsv(blob, T1040_TDM_QUIRK_CCSR_BASE, + CONFIG_MEM_HOLE_16M); + if (off < 0) + printf("Failed to reserve memory for tdm: %s\n", + fdt_strerror(off)); + } +#endif + /* Reserve the boot page so OSes dont use it */ if ((u64)bootpg < memory_limit) { off = fdt_add_mem_rsv(blob, bootpg, (u64)4096); diff --git a/arch/powerpc/cpu/mpc85xx/t1040_ids.c b/arch/powerpc/cpu/mpc85xx/t1040_ids.c index 1034cd4..a5dfb81 100644 --- a/arch/powerpc/cpu/mpc85xx/t1040_ids.c +++ b/arch/powerpc/cpu/mpc85xx/t1040_ids.c @@ -47,6 +47,7 @@ struct liodn_id_table liodn_tbl[] = {
/* SET_NEXUS_LIODN(557), -- not yet implemented */ SET_QE_LIODN(559), + SET_TDM_LIODN(560), }; int liodn_tbl_sz = ARRAY_SIZE(liodn_tbl);
diff --git a/arch/powerpc/include/asm/fsl_law.h b/arch/powerpc/include/asm/fsl_law.h index 37d3a22..3b50487 100644 --- a/arch/powerpc/include/asm/fsl_law.h +++ b/arch/powerpc/include/asm/fsl_law.h @@ -68,6 +68,7 @@ enum law_trgt_if { LAW_TRGT_IF_DDR_INTLV_1234 = 0x16, LAW_TRGT_IF_BMAN = 0x18, LAW_TRGT_IF_DCSR = 0x1d, + LAW_TRGT_IF_CCSR = 0x1e, LAW_TRGT_IF_LBC = 0x1f, LAW_TRGT_IF_QMAN = 0x3c,
diff --git a/arch/powerpc/include/asm/fsl_liodn.h b/arch/powerpc/include/asm/fsl_liodn.h index f658bcb..adfbb66 100644 --- a/arch/powerpc/include/asm/fsl_liodn.h +++ b/arch/powerpc/include/asm/fsl_liodn.h @@ -103,6 +103,10 @@ extern void fdt_fixup_liodn(void *blob); SET_GUTS_LIODN("fsl,qe", liodn, qeliodnr,\ CONFIG_SYS_MPC85xx_QE_OFFSET)
+#define SET_TDM_LIODN(liodn) \ + SET_GUTS_LIODN("fsl,tdm1.0", liodn, tdmliodnr,\ + CONFIG_SYS_MPC85xx_TDM_OFFSET) + #define SET_QMAN_LIODN(liodn) \ SET_LIODN_ENTRY_1("fsl,qman", liodn, offsetof(ccsr_qman_t, liodnr) + \ CONFIG_SYS_FSL_QMAN_OFFSET, \ diff --git a/arch/powerpc/include/asm/immap_85xx.h b/arch/powerpc/include/asm/immap_85xx.h index eff573b..8642209 100644 --- a/arch/powerpc/include/asm/immap_85xx.h +++ b/arch/powerpc/include/asm/immap_85xx.h @@ -1899,7 +1899,8 @@ defined(CONFIG_PPC_T1020) || defined(CONFIG_PPC_T1022) u32 sata2liodnr; /* SATA 2 LIODN */ u32 sata3liodnr; /* SATA 3 LIODN */ u32 sata4liodnr; /* SATA 4 LIODN */ - u8 res22[24]; + u8 res22[20]; + u32 tdmliodnr; /* TDM LIODN */ u32 qeliodnr; /* QE LIODN */ u8 res_57c[4]; u32 dma1liodnr; /* DMA 1 LIODN */ @@ -2889,6 +2890,7 @@ struct ccsr_pman { #define CONFIG_SYS_MPC85xx_LBC_OFFSET 0x124000 #define CONFIG_SYS_MPC85xx_IFC_OFFSET 0x124000 #define CONFIG_SYS_MPC85xx_GPIO_OFFSET 0x130000 +#define CONFIG_SYS_MPC85xx_TDM_OFFSET 0x185000 #define CONFIG_SYS_MPC85xx_QE_OFFSET 0x140000 #define CONFIG_SYS_FSL_CORENET_RMAN_OFFSET 0x1e0000 #if defined(CONFIG_SYS_FSL_QORIQ_CHASSIS2) && !defined(CONFIG_PPC_B4860)\ diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index 2215ac8..f2a75ae 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -201,6 +201,12 @@ unsigned long get_board_ddr_clk(void); CSPR_MSEL_NOR | \ CSPR_V) #define CONFIG_SYS_NOR_AMASK IFC_AMASK(128*1024*1024) + +/* + * TDM Definition + */ +#define T1040_TDM_QUIRK_CCSR_BASE 0xfe000000 + /* NOR Flash Timing Params */ #define CONFIG_SYS_NOR_CSOR CSOR_NAND_TRHZ_80 #define CONFIG_SYS_NOR_FTIM0 (FTIM0_NOR_TACSE(0x4) | \ diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index e564cb7..8d6c51b 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -230,6 +230,12 @@ CSPR_MSEL_NOR | \ CSPR_V) #define CONFIG_SYS_NOR_AMASK IFC_AMASK(128*1024*1024) + +/* + * TDM Definition + */ +#define T1040_TDM_QUIRK_CCSR_BASE 0xfe000000 + /* NOR Flash Timing Params */ #define CONFIG_SYS_NOR_CSOR CSOR_NAND_TRHZ_80 #define CONFIG_SYS_NOR_FTIM0 (FTIM0_NOR_TACSE(0x4) | \
Applied to u-boot-mpc85xx. Sorry for the late notice.
York
Sandeep Singh
York Sun
