[U-Boot] [PATCH v1 0/5] mtd: nand: omap: clean omap_gpmc.h headers
(resending *only* to u-boot maillist as earlier message was moderated as below) [PATCH v1 0/5] mtd: nand: omap: clean omap_gpmc.h headers Is being held until the list moderator can review it for approval. The reason it is being held: Too many recipients to the message
This patch series aims are cleaning and consolidationg GPMC declarations and macros in common file by:
(1) Merges multiple omap_gpmc.h header files - arch/arm/include/asm/arch-xx/omap_gpmc.h: for individual SoC platform - arch/arm/include/asm/arch/omap_gpmc.h: common for all ARM SoC platform
(2) removes legacy board configs and #defines macros which are no more used
(3) consolidate common GPMC macros and declarations spread in platform specific header files. (like arch/arm/include/asm/arch-xx/cpu.h)
(4) move consolidate header file arch/omap_gpmc.h to linux/mtd/omap_gpmc.h to make it architecture independent
(5) move arch/omap_elm.h to linux/mtd/omap_elm.h) to make it architecture independent
This patch series is build tested using following utility ./MAKEALL -s am33xx -s omap3 -s omap4 -s omap5
Note: Though this patch series is functionally independent. But it should be applied above previous series given below, otherwise there would be minor conflict seen in file arch/arm/include/asm/omap_gpmc.h http://lists.denx.de/pipermail/u-boot/2013-November/167445.html
Pekon Gupta (5): mtd: nand: omap: remove redundant platform specific header: arch-xx/omap_gpmc.h mtd: nand: omap: remove unused #defines from common omap_gpmc.h mtd: nand: omap: merge duplicate GPMC data from different arch-xx headers into common omap_gpmc.h mtd: nand: omap: move omap_gpmc.h from arch/arm/include/asm to drivers/mtd/nand mtd: nand: omap: move omap_elm.h from arch/arm/include/asm to drivers/mtd/nand
arch/arm/include/asm/arch-am33xx/cpu.h | 51 ------------- arch/arm/include/asm/arch-am33xx/omap_gpmc.h | 48 ------------- arch/arm/include/asm/arch-am33xx/sys_proto.h | 1 + arch/arm/include/asm/arch-omap3/cpu.h | 54 +------------- arch/arm/include/asm/arch-omap3/mem.h | 10 +++ arch/arm/include/asm/arch-omap3/omap_gpmc.h | 36 ---------- arch/arm/include/asm/arch-omap3/sys_proto.h | 1 + arch/arm/include/asm/arch-omap4/cpu.h | 45 ------------ arch/arm/include/asm/arch-omap4/sys_proto.h | 1 + arch/arm/include/asm/arch-omap5/cpu.h | 45 ------------ arch/arm/include/asm/arch-omap5/sys_proto.h | 1 + arch/arm/include/asm/omap_gpmc.h | 80 --------------------- board/isee/igep00x0/igep00x0.c | 1 - board/overo/overo.c | 1 - drivers/mtd/nand/omap_elm.c | 6 +- drivers/mtd/nand/omap_gpmc.c | 5 +- include/configs/am335x_evm.h | 1 - include/configs/am335x_igep0033.h | 1 - include/configs/am3517_crane.h | 1 - include/configs/am3517_evm.h | 1 - include/configs/cm_t35.h | 2 - include/configs/devkit8000.h | 2 - include/configs/dig297.h | 2 - include/configs/mcx.h | 1 - include/configs/omap3_beagle.h | 2 - include/configs/omap3_evm_common.h | 1 - include/configs/omap3_igep00x0.h | 1 - include/configs/omap3_logic.h | 1 - include/configs/omap3_overo.h | 2 - include/configs/omap3_pandora.h | 2 - include/configs/omap3_zoom1.h | 2 - include/configs/omap3_zoom2.h | 1 - include/configs/siemens-am33x-common.h | 1 - include/configs/tam3517-common.h | 1 - include/configs/tricorder.h | 2 - .../include/asm => include/linux/mtd}/omap_elm.h | 0 include/linux/mtd/omap_gpmc.h | 84 ++++++++++++++++++++++ 37 files changed, 104 insertions(+), 393 deletions(-) delete mode 100644 arch/arm/include/asm/arch-am33xx/omap_gpmc.h delete mode 100644 arch/arm/include/asm/arch-omap3/omap_gpmc.h delete mode 100644 arch/arm/include/asm/omap_gpmc.h rename {arch/arm/include/asm => include/linux/mtd}/omap_elm.h (100%) create mode 100644 include/linux/mtd/omap_gpmc.h
Currently there are two sets of omap_gpmc.h header files (a) arch/arm/include/asm/omap_gpmc.h common header file for all platforms, containing defines and declarations used by GPMC NAND driver.
(b) arch/arm/include/asm/arch-xx/omap_gpmc.h SoC platform specific header file containing defines like ECC layout.
This patch removes platform specific arch-xx/omap_gpmc.c because: - GPMC hardware engine is common for all SoC platforms hence only (a) is enough - ECC layout is now defined in omap_nand.c driver itself based on ecc-scheme selected. Hence all ECC layout declarations in (b) are redundant.
Build tested using: ./MAKEALL -s am33xx -s omap3 -s omap4 -s omap5
Signed-off-by: Pekon Gupta pekon@ti.com --- arch/arm/include/asm/arch-am33xx/omap_gpmc.h | 48 ---------------------------- arch/arm/include/asm/arch-omap3/mem.h | 10 ++++++ arch/arm/include/asm/arch-omap3/omap_gpmc.h | 36 --------------------- arch/arm/include/asm/omap_gpmc.h | 2 -- 4 files changed, 10 insertions(+), 86 deletions(-) delete mode 100644 arch/arm/include/asm/arch-am33xx/omap_gpmc.h delete mode 100644 arch/arm/include/asm/arch-omap3/omap_gpmc.h
diff --git a/arch/arm/include/asm/arch-am33xx/omap_gpmc.h b/arch/arm/include/asm/arch-am33xx/omap_gpmc.h deleted file mode 100644 index 00ad1d0..0000000 --- a/arch/arm/include/asm/arch-am33xx/omap_gpmc.h +++ /dev/null @@ -1,48 +0,0 @@ -/* - * (C) Copyright 2004-2008 Texas Instruments, <www.ti.com> - * Rohit Choraria rohitkc@ti.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ -#ifndef __ASM_ARCH_OMAP_GPMC_H -#define __ASM_ARCH_OMAP_GPMC_H - -/* These GPMC_NAND_HW_BCHx_ECC_LAYOUT defines are based on AM33xx ELM */ -#define GPMC_NAND_HW_BCH4_ECC_LAYOUT {\ - .eccbytes = 32,\ - .eccpos = {2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15,\ - 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27,\ - 28, 29, 30, 31, 32, 33},\ - .oobfree = {\ - {.offset = 34,\ - .length = 30 } } \ -} - -#define GPMC_NAND_HW_BCH8_ECC_LAYOUT {\ - .eccbytes = 56,\ - .eccpos = {2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15,\ - 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27,\ - 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39,\ - 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51,\ - 52, 53, 54, 55, 56, 57},\ - .oobfree = {\ - {.offset = 58,\ - .length = 6 } } \ -} - -#define GPMC_NAND_HW_BCH16_ECC_LAYOUT {\ - .eccbytes = 104,\ - .eccpos = {2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15,\ - 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27,\ - 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39,\ - 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51,\ - 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63,\ - 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75,\ - 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87,\ - 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99,\ - 100, 101, 102, 103, 104, 105},\ - .oobfree = {\ - {.offset = 106,\ - .length = 8 } } \ -} -#endif /* __ASM_ARCH_OMAP_GPMC_H */ diff --git a/arch/arm/include/asm/arch-omap3/mem.h b/arch/arm/include/asm/arch-omap3/mem.h index bcc22c4..1804191 100644 --- a/arch/arm/include/asm/arch-omap3/mem.h +++ b/arch/arm/include/asm/arch-omap3/mem.h @@ -419,6 +419,16 @@ enum { #define NET_GPMC_CONFIG6 0x00000FCF #define NET_GPMC_CONFIG7 0x00000f6c
+/* GPMC CS configuration for an SMSC LAN9221 ethernet controller */ +#define NET_LAN9221_GPMC_CONFIG1 0x00001000 +#define NET_LAN9221_GPMC_CONFIG2 0x00060700 +#define NET_LAN9221_GPMC_CONFIG3 0x00020201 +#define NET_LAN9221_GPMC_CONFIG4 0x06000700 +#define NET_LAN9221_GPMC_CONFIG5 0x0006090A +#define NET_LAN9221_GPMC_CONFIG6 0x87030000 +#define NET_LAN9221_GPMC_CONFIG7 0x00000f6c + + /* max number of GPMC Chip Selects */ #define GPMC_MAX_CS 8 /* max number of GPMC regs */ diff --git a/arch/arm/include/asm/arch-omap3/omap_gpmc.h b/arch/arm/include/asm/arch-omap3/omap_gpmc.h deleted file mode 100644 index bf23219..0000000 --- a/arch/arm/include/asm/arch-omap3/omap_gpmc.h +++ /dev/null @@ -1,36 +0,0 @@ -/* - * (C) Copyright 2004-2008 Texas Instruments, <www.ti.com> - * Rohit Choraria rohitkc@ti.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ -#ifndef __ASM_ARCH_OMAP_GPMC_H -#define __ASM_ARCH_OMAP_GPMC_H - -/* - * These GPMC_NAND_HW_BCHx_ECC_LAYOUT defines using the BCH library. - * The OOB layout was first defined by linx kernel in commit - * 0e618ef0a6a33cf7ef96c2c824402088dd8ef48c, we have to reuse it here cause - * we want to be compatible. - */ -#define GPMC_NAND_HW_BCH8_ECC_LAYOUT {\ - .eccbytes = 56,\ - .eccpos = {12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22,\ - 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36,\ - 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50,\ - 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63},\ - .oobfree = {\ - {.offset = 2,\ - .length = 10 } } \ -} - -/* GPMC CS configuration for an SMSC LAN9221 ethernet controller */ -#define NET_LAN9221_GPMC_CONFIG1 0x00001000 -#define NET_LAN9221_GPMC_CONFIG2 0x00060700 -#define NET_LAN9221_GPMC_CONFIG3 0x00020201 -#define NET_LAN9221_GPMC_CONFIG4 0x06000700 -#define NET_LAN9221_GPMC_CONFIG5 0x0006090A -#define NET_LAN9221_GPMC_CONFIG6 0x87030000 -#define NET_LAN9221_GPMC_CONFIG7 0x00000f6c - -#endif /* __ASM_ARCH_OMAP_GPMC_H */ diff --git a/arch/arm/include/asm/omap_gpmc.h b/arch/arm/include/asm/omap_gpmc.h index 6ce5e65..5250109 100644 --- a/arch/arm/include/asm/omap_gpmc.h +++ b/arch/arm/include/asm/omap_gpmc.h @@ -9,8 +9,6 @@ #ifndef __ASM_OMAP_GPMC_H #define __ASM_OMAP_GPMC_H
-#include <asm/arch/omap_gpmc.h> - #define GPMC_BUF_EMPTY 0 #define GPMC_BUF_FULL 1
OMAP NAND driver can detect Page-size and OOB-size of NAND device from ONFI params or nand_id[] table. And based on that it defines ECC layout. This patch 1) removes following board configs used for defining NAND ECC layout - GPMC_NAND_ECC_LP_x16_LAYOUT (for large page x16 NAND) - GPMC_NAND_ECC_LP_x8_LAYOUT (for large page x8 NAND) - GPMC_NAND_ECC_SP_x16_LAYOUT (for small page x16 NAND) - GPMC_NAND_ECC_SP_x8_LAYOUT (for small page x8 NAND)
2) removes unused #defines in common omap_gpmc.h depending on above configs
Signed-off-by: Pekon Gupta pekon@ti.com --- arch/arm/include/asm/omap_gpmc.h | 47 ---------------------------------- include/configs/am335x_evm.h | 1 - include/configs/am335x_igep0033.h | 1 - include/configs/am3517_crane.h | 1 - include/configs/am3517_evm.h | 1 - include/configs/cm_t35.h | 2 -- include/configs/devkit8000.h | 2 -- include/configs/dig297.h | 2 -- include/configs/mcx.h | 1 - include/configs/omap3_beagle.h | 2 -- include/configs/omap3_evm_common.h | 1 - include/configs/omap3_igep00x0.h | 1 - include/configs/omap3_logic.h | 1 - include/configs/omap3_overo.h | 2 -- include/configs/omap3_pandora.h | 2 -- include/configs/omap3_zoom1.h | 2 -- include/configs/omap3_zoom2.h | 1 - include/configs/siemens-am33x-common.h | 1 - include/configs/tam3517-common.h | 1 - include/configs/tricorder.h | 2 -- 20 files changed, 74 deletions(-)
diff --git a/arch/arm/include/asm/omap_gpmc.h b/arch/arm/include/asm/omap_gpmc.h index 5250109..3caaed8 100644 --- a/arch/arm/include/asm/omap_gpmc.h +++ b/arch/arm/include/asm/omap_gpmc.h @@ -12,53 +12,6 @@ #define GPMC_BUF_EMPTY 0 #define GPMC_BUF_FULL 1
-/* Generic ECC Layouts */ -/* Large Page x8 NAND device Layout */ -#ifdef GPMC_NAND_ECC_LP_x8_LAYOUT -#define GPMC_NAND_HW_ECC_LAYOUT {\ - .eccbytes = 12,\ - .eccpos = {1, 2, 3, 4, 5, 6, 7, 8,\ - 9, 10, 11, 12},\ - .oobfree = {\ - {.offset = 13,\ - .length = 51 } } \ -} -#endif - -/* Large Page x16 NAND device Layout */ -#ifdef GPMC_NAND_ECC_LP_x16_LAYOUT -#define GPMC_NAND_HW_ECC_LAYOUT {\ - .eccbytes = 12,\ - .eccpos = {2, 3, 4, 5, 6, 7, 8, 9,\ - 10, 11, 12, 13},\ - .oobfree = {\ - {.offset = 14,\ - .length = 50 } } \ -} -#endif - -/* Small Page x8 NAND device Layout */ -#ifdef GPMC_NAND_ECC_SP_x8_LAYOUT -#define GPMC_NAND_HW_ECC_LAYOUT {\ - .eccbytes = 3,\ - .eccpos = {1, 2, 3},\ - .oobfree = {\ - {.offset = 4,\ - .length = 12 } } \ -} -#endif - -/* Small Page x16 NAND device Layout */ -#ifdef GPMC_NAND_ECC_SP_x16_LAYOUT -#define GPMC_NAND_HW_ECC_LAYOUT {\ - .eccbytes = 3,\ - .eccpos = {2, 3, 4},\ - .oobfree = {\ - {.offset = 5,\ - .length = 11 } } \ -} -#endif - enum omap_ecc { /* 1-bit ECC calculation by Software, Error detection by Software */ OMAP_ECC_HAM1_CODE_SW = 1, /* avoid un-initialized int can be 0x0 */ diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index d75df92..9ccbc20 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -381,7 +381,6 @@ /* NAND support */ #ifdef CONFIG_NAND #define CONFIG_CMD_NAND -#define GPMC_NAND_ECC_LP_x16_LAYOUT 1 #if !defined(CONFIG_SPI_BOOT) && !defined(CONFIG_NOR_BOOT) #define MTDIDS_DEFAULT "nand0=omap2-nand.0" #define MTDPARTS_DEFAULT "mtdparts=omap2-nand.0:128k(SPL)," \ diff --git a/include/configs/am335x_igep0033.h b/include/configs/am335x_igep0033.h index 115d1b3..c00d54f 100644 --- a/include/configs/am335x_igep0033.h +++ b/include/configs/am335x_igep0033.h @@ -188,7 +188,6 @@ #define CONFIG_NAND #define CONFIG_NAND_OMAP_GPMC #define CONFIG_NAND_OMAP_ELM -#define GPMC_NAND_ECC_LP_x16_LAYOUT 1 #define CONFIG_SYS_NAND_BASE (0x08000000) /* phys address CS0 */ #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_ONFI_DETECTION 1 diff --git a/include/configs/am3517_crane.h b/include/configs/am3517_crane.h index 468fb43..4407b45 100644 --- a/include/configs/am3517_crane.h +++ b/include/configs/am3517_crane.h @@ -268,7 +268,6 @@ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE
#define CONFIG_NAND_OMAP_GPMC -#define GPMC_NAND_ECC_LP_x16_LAYOUT 1 #define CONFIG_ENV_IS_IN_NAND 1 #define SMNAND_ENV_OFFSET 0x260000 /* environment starts here */
diff --git a/include/configs/am3517_evm.h b/include/configs/am3517_evm.h index a3473b5..7f52ce4 100644 --- a/include/configs/am3517_evm.h +++ b/include/configs/am3517_evm.h @@ -262,7 +262,6 @@ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE
diff --git a/include/configs/cm_t35.h b/include/configs/cm_t35.h index f4ecd0d..52a1f05 100644 --- a/include/configs/cm_t35.h +++ b/include/configs/cm_t35.h @@ -165,8 +165,6 @@ #define CONFIG_SYS_NAND_BASE NAND_BASE /* physical address */ /* to access nand at */ /* CS0 */ -#define GPMC_NAND_ECC_LP_x8_LAYOUT - #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND */ /* devices */ /* Environment information */ diff --git a/include/configs/devkit8000.h b/include/configs/devkit8000.h index 4f43ba9..16a00eb 100644 --- a/include/configs/devkit8000.h +++ b/include/configs/devkit8000.h @@ -116,8 +116,6 @@ #define CONFIG_SYS_NAND_BASE NAND_BASE /* physical address */ /* to access nand at */ /* CS0 */ -#define GPMC_NAND_ECC_LP_x16_LAYOUT 1 - #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND */ /* devices */ #define CONFIG_JFFS2_NAND diff --git a/include/configs/dig297.h b/include/configs/dig297.h index 5049afc..af6f56b 100644 --- a/include/configs/dig297.h +++ b/include/configs/dig297.h @@ -143,8 +143,6 @@ #define CONFIG_SYS_NAND_BASE NAND_BASE /* physical address */ /* to access nand at */ /* CS0 */ -#define GPMC_NAND_ECC_LP_x16_LAYOUT - #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND */
#if defined(CONFIG_CMD_NET) diff --git a/include/configs/mcx.h b/include/configs/mcx.h index dcd29ce..dd4afb8 100644 --- a/include/configs/mcx.h +++ b/include/configs/mcx.h @@ -321,7 +321,6 @@ #define PISMO1_NAND_SIZE GPMC_SIZE_128M
#define CONFIG_NAND_OMAP_GPMC -#define GPMC_NAND_ECC_LP_x16_LAYOUT #define CONFIG_ENV_IS_IN_NAND #define SMNAND_ENV_OFFSET 0x180000 /* environment starts here */
diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index 9eab190..8127f87 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -183,8 +183,6 @@ #define CONFIG_SYS_NAND_BASE NAND_BASE /* physical address */ /* to access nand at */ /* CS0 */ -#define GPMC_NAND_ECC_LP_x16_LAYOUT 1 - #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND */ /* devices */
diff --git a/include/configs/omap3_evm_common.h b/include/configs/omap3_evm_common.h index 43616e2..7f3424b 100644 --- a/include/configs/omap3_evm_common.h +++ b/include/configs/omap3_evm_common.h @@ -208,7 +208,6 @@ #define CONFIG_SYS_FLASH_BASE PISMO1_NAND_BASE
#define CONFIG_NAND_OMAP_GPMC -#define GPMC_NAND_ECC_LP_x16_LAYOUT #define CONFIG_ENV_OFFSET SMNAND_ENV_OFFSET #elif defined(CONFIG_CMD_ONENAND) #define CONFIG_SYS_FLASH_BASE PISMO1_ONEN_BASE diff --git a/include/configs/omap3_igep00x0.h b/include/configs/omap3_igep00x0.h index 71062a6..172c3a3 100644 --- a/include/configs/omap3_igep00x0.h +++ b/include/configs/omap3_igep00x0.h @@ -267,7 +267,6 @@ #define PISMO1_NAND_SIZE GPMC_SIZE_128M /* Configure the PISMO */ #define CONFIG_NAND_OMAP_GPMC #define CONFIG_SYS_NAND_BASE NAND_BASE -#define GPMC_NAND_ECC_LP_x16_LAYOUT 1 #define CONFIG_ENV_OFFSET 0x260000 /* environment starts here */ #define CONFIG_ENV_IS_IN_NAND 1 #define CONFIG_ENV_SIZE (512 << 10) /* Total Size Environment */ diff --git a/include/configs/omap3_logic.h b/include/configs/omap3_logic.h index bedd6f9..0d03c75 100644 --- a/include/configs/omap3_logic.h +++ b/include/configs/omap3_logic.h @@ -295,7 +295,6 @@
#if defined(CONFIG_CMD_NAND) #define CONFIG_NAND_OMAP_GPMC -#define GPMC_NAND_ECC_LP_x16_LAYOUT 1 #define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET SMNAND_ENV_OFFSET #endif diff --git a/include/configs/omap3_overo.h b/include/configs/omap3_overo.h index e0f0262..007e27f 100644 --- a/include/configs/omap3_overo.h +++ b/include/configs/omap3_overo.h @@ -119,8 +119,6 @@ #define CONFIG_SYS_NAND_BASE NAND_BASE /* physical address */ /* to access nand */ /* at CS0 */ -#define GPMC_NAND_ECC_LP_x16_LAYOUT - #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND */ /* devices */ #define CONFIG_JFFS2_NAND diff --git a/include/configs/omap3_pandora.h b/include/configs/omap3_pandora.h index eacdfaa..da67787 100644 --- a/include/configs/omap3_pandora.h +++ b/include/configs/omap3_pandora.h @@ -131,8 +131,6 @@ #define CONFIG_SYS_NAND_BASE NAND_BASE /* physical address */ /* to access nand */ /* at CS0 */ -#define GPMC_NAND_ECC_LP_x16_LAYOUT 1 - #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND */ /* devices */
diff --git a/include/configs/omap3_zoom1.h b/include/configs/omap3_zoom1.h index 1dd53fa..f0fa96e 100644 --- a/include/configs/omap3_zoom1.h +++ b/include/configs/omap3_zoom1.h @@ -138,8 +138,6 @@ #define CONFIG_SYS_NAND_BASE NAND_BASE /* physical address */ /* to access nand at */ /* CS0 */ -#define GPMC_NAND_ECC_LP_x16_LAYOUT 1 - #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND */ /* devices */ #define CONFIG_JFFS2_NAND diff --git a/include/configs/omap3_zoom2.h b/include/configs/omap3_zoom2.h index f749740..8b0ac3d 100644 --- a/include/configs/omap3_zoom2.h +++ b/include/configs/omap3_zoom2.h @@ -158,7 +158,6 @@ #define CONFIG_SYS_NAND_BASE NAND_BASE /* physical address */ /* to access nand at */ /* CS0 */ -#define GPMC_NAND_ECC_LP_x16_LAYOUT 1 #define CONFIG_SYS_MAX_NAND_DEVICE 1
/* Environment information */ diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index f37653f..018e22b 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -432,7 +432,6 @@
#define CONFIG_NAND_OMAP_GPMC #define CONFIG_NAND_OMAP_ELM -#define GPMC_NAND_ECC_LP_x16_LAYOUT 1 #define CONFIG_SYS_NAND_BASE (0x08000000) /* physical address */ /* to access nand at */ /* CS0 */ diff --git a/include/configs/tam3517-common.h b/include/configs/tam3517-common.h index 439fc47..d3f9a4e 100644 --- a/include/configs/tam3517-common.h +++ b/include/configs/tam3517-common.h @@ -186,7 +186,6 @@ #define PISMO1_NAND_SIZE GPMC_SIZE_128M
diff --git a/include/configs/tricorder.h b/include/configs/tricorder.h index b38b955..5940c03 100644 --- a/include/configs/tricorder.h +++ b/include/configs/tricorder.h @@ -134,8 +134,6 @@ #define CONFIG_SYS_NAND_BASE NAND_BASE /* physical address */ /* to access nand at */ /* CS0 */ -#define GPMC_NAND_ECC_LP_x16_LAYOUT 1 - #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND */ /* devices */ #define CONFIG_BCH
Each SoC platform (AM33xx, OMAP3, OMAP4, OMAP5) has its own copy of GPMC related defines and declarations scattered in SoC platform specific header files like include/asm/arch-xx/cpu.h However, GPMC hardware remains same across all platforms thus this patch merges GPMC data scattered across different arch-xx specific header files into single header file include/asm/arch/omap_gpmc.h
Signed-off-by: Pekon Gupta pekon@ti.com --- arch/arm/include/asm/arch-am33xx/cpu.h | 51 -------------------------- arch/arm/include/asm/arch-am33xx/sys_proto.h | 1 + arch/arm/include/asm/arch-omap3/cpu.h | 54 +--------------------------- arch/arm/include/asm/arch-omap3/sys_proto.h | 1 + arch/arm/include/asm/arch-omap4/cpu.h | 45 ----------------------- arch/arm/include/asm/arch-omap4/sys_proto.h | 1 + arch/arm/include/asm/arch-omap5/cpu.h | 45 ----------------------- arch/arm/include/asm/arch-omap5/sys_proto.h | 1 + arch/arm/include/asm/omap_gpmc.h | 53 +++++++++++++++++++++++++++ drivers/mtd/nand/omap_elm.c | 2 +- drivers/mtd/nand/omap_gpmc.c | 1 - 11 files changed, 59 insertions(+), 196 deletions(-)
diff --git a/arch/arm/include/asm/arch-am33xx/cpu.h b/arch/arm/include/asm/arch-am33xx/cpu.h index 05752ce..bdc634d 100644 --- a/arch/arm/include/asm/arch-am33xx/cpu.h +++ b/arch/arm/include/asm/arch-am33xx/cpu.h @@ -78,58 +78,7 @@
#ifndef __KERNEL_STRICT_NAMES #ifndef __ASSEMBLY__ -struct gpmc_cs { - u32 config1; /* 0x00 */ - u32 config2; /* 0x04 */ - u32 config3; /* 0x08 */ - u32 config4; /* 0x0C */ - u32 config5; /* 0x10 */ - u32 config6; /* 0x14 */ - u32 config7; /* 0x18 */ - u32 nand_cmd; /* 0x1C */ - u32 nand_adr; /* 0x20 */ - u32 nand_dat; /* 0x24 */ - u8 res[8]; /* blow up to 0x30 byte */ -}; - -struct bch_res_0_3 { - u32 bch_result_x[4]; -}; - -struct gpmc { - u8 res1[0x10]; - u32 sysconfig; /* 0x10 */ - u8 res2[0x4]; - u32 irqstatus; /* 0x18 */ - u32 irqenable; /* 0x1C */ - u8 res3[0x20]; - u32 timeout_control; /* 0x40 */ - u8 res4[0xC]; - u32 config; /* 0x50 */ - u32 status; /* 0x54 */ - u8 res5[0x8]; /* 0x58 */ - struct gpmc_cs cs[8]; /* 0x60, 0x90, .. */ - u8 res6[0x14]; /* 0x1E0 */ - u32 ecc_config; /* 0x1F4 */ - u32 ecc_control; /* 0x1F8 */ - u32 ecc_size_config; /* 0x1FC */ - u32 ecc1_result; /* 0x200 */ - u32 ecc2_result; /* 0x204 */ - u32 ecc3_result; /* 0x208 */ - u32 ecc4_result; /* 0x20C */ - u32 ecc5_result; /* 0x210 */ - u32 ecc6_result; /* 0x214 */ - u32 ecc7_result; /* 0x218 */ - u32 ecc8_result; /* 0x21C */ - u32 ecc9_result; /* 0x220 */ - u8 res7[12]; /* 0x224 */ - u32 testmomde_ctrl; /* 0x230 */ - u8 res8[12]; /* 0x234 */ - struct bch_res_0_3 bch_result_0_3[2]; /* 0x240 */ -};
-/* Used for board specific gpmc initialization */ -extern struct gpmc *gpmc_cfg;
#ifndef CONFIG_AM43XX /* Encapsulating core pll registers */ diff --git a/arch/arm/include/asm/arch-am33xx/sys_proto.h b/arch/arm/include/asm/arch-am33xx/sys_proto.h index 87b7d36..c427909 100644 --- a/arch/arm/include/asm/arch-am33xx/sys_proto.h +++ b/arch/arm/include/asm/arch-am33xx/sys_proto.h @@ -10,6 +10,7 @@
#ifndef _SYS_PROTO_H_ #define _SYS_PROTO_H_ +#include <asm/omap_gpmc.h> #include <asm/arch/cpu.h>
#define BOARD_REV_ID 0x0 diff --git a/arch/arm/include/asm/arch-omap3/cpu.h b/arch/arm/include/asm/arch-omap3/cpu.h index 61ec8f2..4d06ef8 100644 --- a/arch/arm/include/asm/arch-omap3/cpu.h +++ b/arch/arm/include/asm/arch-omap3/cpu.h @@ -77,59 +77,7 @@ struct ctrl_id { #define GPMC_CONFIG_CS0_BASE (GPMC_BASE + GPMC_CONFIG_CS0)
#ifndef __KERNEL_STRICT_NAMES -#ifndef __ASSEMBLY__ -struct gpmc_cs { - u32 config1; /* 0x00 */ - u32 config2; /* 0x04 */ - u32 config3; /* 0x08 */ - u32 config4; /* 0x0C */ - u32 config5; /* 0x10 */ - u32 config6; /* 0x14 */ - u32 config7; /* 0x18 */ - u32 nand_cmd; /* 0x1C */ - u32 nand_adr; /* 0x20 */ - u32 nand_dat; /* 0x24 */ - u8 res[8]; /* blow up to 0x30 byte */ -}; - -struct bch_res_0_3 { - u32 bch_result_x[4]; -}; - -struct gpmc { - u8 res1[0x10]; - u32 sysconfig; /* 0x10 */ - u8 res2[0x4]; - u32 irqstatus; /* 0x18 */ - u32 irqenable; /* 0x1C */ - u8 res3[0x20]; - u32 timeout_control; /* 0x40 */ - u8 res4[0xC]; - u32 config; /* 0x50 */ - u32 status; /* 0x54 */ - u8 res5[0x8]; /* 0x58 */ - struct gpmc_cs cs[8]; /* 0x60, 0x90, .. */ - u8 res6[0x14]; /* 0x1E0 */ - u32 ecc_config; /* 0x1F4 */ - u32 ecc_control; /* 0x1F8 */ - u32 ecc_size_config; /* 0x1FC */ - u32 ecc1_result; /* 0x200 */ - u32 ecc2_result; /* 0x204 */ - u32 ecc3_result; /* 0x208 */ - u32 ecc4_result; /* 0x20C */ - u32 ecc5_result; /* 0x210 */ - u32 ecc6_result; /* 0x214 */ - u32 ecc7_result; /* 0x218 */ - u32 ecc8_result; /* 0x21C */ - u32 ecc9_result; /* 0x220 */ - u8 res7[0x1C]; /* fill up to 0x240 */ - struct bch_res_0_3 bch_result_0_3[7]; /* 0x240 */ -}; - -/* Used for board specific gpmc initialization */ -extern struct gpmc *gpmc_cfg; - -#else /* __ASSEMBLY__ */ +#ifdef __ASSEMBLY__ #define GPMC_CONFIG1 0x00 #define GPMC_CONFIG2 0x04 #define GPMC_CONFIG3 0x08 diff --git a/arch/arm/include/asm/arch-omap3/sys_proto.h b/arch/arm/include/asm/arch-omap3/sys_proto.h index 43b54f7..83d7f11 100644 --- a/arch/arm/include/asm/arch-omap3/sys_proto.h +++ b/arch/arm/include/asm/arch-omap3/sys_proto.h @@ -7,6 +7,7 @@ */ #ifndef _SYS_PROTO_H_ #define _SYS_PROTO_H_ +#include <asm/omap_gpmc.h>
typedef struct { u32 mtype; diff --git a/arch/arm/include/asm/arch-omap4/cpu.h b/arch/arm/include/asm/arch-omap4/cpu.h index 545d9d9..c21fb54 100644 --- a/arch/arm/include/asm/arch-omap4/cpu.h +++ b/arch/arm/include/asm/arch-omap4/cpu.h @@ -14,51 +14,6 @@
#ifndef __KERNEL_STRICT_NAMES #ifndef __ASSEMBLY__ -struct gpmc_cs { - u32 config1; /* 0x00 */ - u32 config2; /* 0x04 */ - u32 config3; /* 0x08 */ - u32 config4; /* 0x0C */ - u32 config5; /* 0x10 */ - u32 config6; /* 0x14 */ - u32 config7; /* 0x18 */ - u32 nand_cmd; /* 0x1C */ - u32 nand_adr; /* 0x20 */ - u32 nand_dat; /* 0x24 */ - u8 res[8]; /* blow up to 0x30 byte */ -}; - -struct gpmc { - u8 res1[0x10]; - u32 sysconfig; /* 0x10 */ - u8 res2[0x4]; - u32 irqstatus; /* 0x18 */ - u32 irqenable; /* 0x1C */ - u8 res3[0x20]; - u32 timeout_control; /* 0x40 */ - u8 res4[0xC]; - u32 config; /* 0x50 */ - u32 status; /* 0x54 */ - u8 res5[0x8]; /* 0x58 */ - struct gpmc_cs cs[8]; /* 0x60, 0x90, .. */ - u8 res6[0x14]; /* 0x1E0 */ - u32 ecc_config; /* 0x1F4 */ - u32 ecc_control; /* 0x1F8 */ - u32 ecc_size_config; /* 0x1FC */ - u32 ecc1_result; /* 0x200 */ - u32 ecc2_result; /* 0x204 */ - u32 ecc3_result; /* 0x208 */ - u32 ecc4_result; /* 0x20C */ - u32 ecc5_result; /* 0x210 */ - u32 ecc6_result; /* 0x214 */ - u32 ecc7_result; /* 0x218 */ - u32 ecc8_result; /* 0x21C */ - u32 ecc9_result; /* 0x220 */ -}; - -/* Used for board specific gpmc initialization */ -extern struct gpmc *gpmc_cfg; - struct gptimer { u32 tidr; /* 0x00 r */ u8 res[0xc]; diff --git a/arch/arm/include/asm/arch-omap4/sys_proto.h b/arch/arm/include/asm/arch-omap4/sys_proto.h index 39c5316..768453d 100644 --- a/arch/arm/include/asm/arch-omap4/sys_proto.h +++ b/arch/arm/include/asm/arch-omap4/sys_proto.h @@ -12,6 +12,7 @@ #include <asm/arch/clock.h> #include <asm/io.h> #include <asm/omap_common.h> +#include <asm/omap_gpmc.h> #include <asm/arch/mux_omap4.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/arch/arm/include/asm/arch-omap5/cpu.h b/arch/arm/include/asm/arch-omap5/cpu.h index fb5a568..5f1d745 100644 --- a/arch/arm/include/asm/arch-omap5/cpu.h +++ b/arch/arm/include/asm/arch-omap5/cpu.h @@ -16,51 +16,6 @@
#ifndef __KERNEL_STRICT_NAMES #ifndef __ASSEMBLY__ -struct gpmc_cs { - u32 config1; /* 0x00 */ - u32 config2; /* 0x04 */ - u32 config3; /* 0x08 */ - u32 config4; /* 0x0C */ - u32 config5; /* 0x10 */ - u32 config6; /* 0x14 */ - u32 config7; /* 0x18 */ - u32 nand_cmd; /* 0x1C */ - u32 nand_adr; /* 0x20 */ - u32 nand_dat; /* 0x24 */ - u8 res[8]; /* blow up to 0x30 byte */ -}; - -struct gpmc { - u8 res1[0x10]; - u32 sysconfig; /* 0x10 */ - u8 res2[0x4]; - u32 irqstatus; /* 0x18 */ - u32 irqenable; /* 0x1C */ - u8 res3[0x20]; - u32 timeout_control; /* 0x40 */ - u8 res4[0xC]; - u32 config; /* 0x50 */ - u32 status; /* 0x54 */ - u8 res5[0x8]; /* 0x58 */ - struct gpmc_cs cs[8]; /* 0x60, 0x90, .. */ - u8 res6[0x14]; /* 0x1E0 */ - u32 ecc_config; /* 0x1F4 */ - u32 ecc_control; /* 0x1F8 */ - u32 ecc_size_config; /* 0x1FC */ - u32 ecc1_result; /* 0x200 */ - u32 ecc2_result; /* 0x204 */ - u32 ecc3_result; /* 0x208 */ - u32 ecc4_result; /* 0x20C */ - u32 ecc5_result; /* 0x210 */ - u32 ecc6_result; /* 0x214 */ - u32 ecc7_result; /* 0x218 */ - u32 ecc8_result; /* 0x21C */ - u32 ecc9_result; /* 0x220 */ -}; - -/* Used for board specific gpmc initialization */ -extern struct gpmc *gpmc_cfg; - struct gptimer { u32 tidr; /* 0x00 r */ u8 res1[0xc]; diff --git a/arch/arm/include/asm/arch-omap5/sys_proto.h b/arch/arm/include/asm/arch-omap5/sys_proto.h index 9e70d48..5ed7e6a 100644 --- a/arch/arm/include/asm/arch-omap5/sys_proto.h +++ b/arch/arm/include/asm/arch-omap5/sys_proto.h @@ -12,6 +12,7 @@ #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/omap_common.h> +#include <asm/omap_gpmc.h> #include <asm/arch/clock.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/arch/arm/include/asm/omap_gpmc.h b/arch/arm/include/asm/omap_gpmc.h index 3caaed8..22f6573 100644 --- a/arch/arm/include/asm/omap_gpmc.h +++ b/arch/arm/include/asm/omap_gpmc.h @@ -28,4 +28,57 @@ enum omap_ecc { OMAP_ECC_BCH8_CODE_HW, };
+struct gpmc_cs { + u32 config1; /* 0x00 */ + u32 config2; /* 0x04 */ + u32 config3; /* 0x08 */ + u32 config4; /* 0x0C */ + u32 config5; /* 0x10 */ + u32 config6; /* 0x14 */ + u32 config7; /* 0x18 */ + u32 nand_cmd; /* 0x1C */ + u32 nand_adr; /* 0x20 */ + u32 nand_dat; /* 0x24 */ + u8 res[8]; /* blow up to 0x30 byte */ +}; + +struct bch_res_0_3 { + u32 bch_result_x[4]; +}; + +struct gpmc { + u8 res1[0x10]; + u32 sysconfig; /* 0x10 */ + u8 res2[0x4]; + u32 irqstatus; /* 0x18 */ + u32 irqenable; /* 0x1C */ + u8 res3[0x20]; + u32 timeout_control; /* 0x40 */ + u8 res4[0xC]; + u32 config; /* 0x50 */ + u32 status; /* 0x54 */ + u8 res5[0x8]; /* 0x58 */ + struct gpmc_cs cs[8]; /* 0x60, 0x90, .. */ + u8 res6[0x14]; /* 0x1E0 */ + u32 ecc_config; /* 0x1F4 */ + u32 ecc_control; /* 0x1F8 */ + u32 ecc_size_config; /* 0x1FC */ + u32 ecc1_result; /* 0x200 */ + u32 ecc2_result; /* 0x204 */ + u32 ecc3_result; /* 0x208 */ + u32 ecc4_result; /* 0x20C */ + u32 ecc5_result; /* 0x210 */ + u32 ecc6_result; /* 0x214 */ + u32 ecc7_result; /* 0x218 */ + u32 ecc8_result; /* 0x21C */ + u32 ecc9_result; /* 0x220 */ + u8 res7[12]; /* 0x224 */ + u32 testmomde_ctrl; /* 0x230 */ + u8 res8[12]; /* 0x234 */ + struct bch_res_0_3 bch_result_0_3[2]; /* 0x240 */ +}; + +/* Used for board specific gpmc initialization */ +extern struct gpmc *gpmc_cfg; + #endif /* __ASM_OMAP_GPMC_H */ diff --git a/drivers/mtd/nand/omap_elm.c b/drivers/mtd/nand/omap_elm.c index 2aa7807..64dca4f 100644 --- a/drivers/mtd/nand/omap_elm.c +++ b/drivers/mtd/nand/omap_elm.c @@ -16,9 +16,9 @@ #include <common.h> #include <asm/io.h> #include <asm/errno.h> -#include <asm/arch/cpu.h> #include <asm/omap_gpmc.h> #include <asm/omap_elm.h> +#include <asm/arch/hardware.h>
#define ELM_DEFAULT_POLY (0)
diff --git a/drivers/mtd/nand/omap_gpmc.c b/drivers/mtd/nand/omap_gpmc.c index 3bf4fb0..5bcb242 100644 --- a/drivers/mtd/nand/omap_gpmc.c +++ b/drivers/mtd/nand/omap_gpmc.c @@ -9,7 +9,6 @@ #include <asm/io.h> #include <asm/errno.h> #include <asm/arch/mem.h> -#include <asm/arch/cpu.h> #include <asm/omap_gpmc.h> #include <linux/mtd/nand_ecc.h> #include <linux/bch.h>
omap_gpmc.h is a generic header used by OMAP NAND driver for all TI platfoms. Hence this file should be present in generic folder instead of architecture specific include folder. Build tested using: ./MAKEALL -s am33xx -s omap3 -s omap4 -s omap5
Signed-off-by: Pekon Gupta pekon@ti.com --- arch/arm/include/asm/arch-am33xx/sys_proto.h | 2 +- arch/arm/include/asm/arch-omap3/sys_proto.h | 2 +- arch/arm/include/asm/arch-omap4/sys_proto.h | 2 +- arch/arm/include/asm/arch-omap5/sys_proto.h | 2 +- board/isee/igep00x0/igep00x0.c | 1 - board/overo/overo.c | 1 - drivers/mtd/nand/omap_elm.c | 2 +- drivers/mtd/nand/omap_gpmc.c | 2 +- {arch/arm/include/asm => include/linux/mtd}/omap_gpmc.h | 0 9 files changed, 6 insertions(+), 8 deletions(-) rename {arch/arm/include/asm => include/linux/mtd}/omap_gpmc.h (100%)
diff --git a/arch/arm/include/asm/arch-am33xx/sys_proto.h b/arch/arm/include/asm/arch-am33xx/sys_proto.h index c427909..f785bb9 100644 --- a/arch/arm/include/asm/arch-am33xx/sys_proto.h +++ b/arch/arm/include/asm/arch-am33xx/sys_proto.h @@ -10,7 +10,7 @@
#ifndef _SYS_PROTO_H_ #define _SYS_PROTO_H_ -#include <asm/omap_gpmc.h> +#include <linux/mtd/omap_gpmc.h> #include <asm/arch/cpu.h>
#define BOARD_REV_ID 0x0 diff --git a/arch/arm/include/asm/arch-omap3/sys_proto.h b/arch/arm/include/asm/arch-omap3/sys_proto.h index 83d7f11..44fa66f 100644 --- a/arch/arm/include/asm/arch-omap3/sys_proto.h +++ b/arch/arm/include/asm/arch-omap3/sys_proto.h @@ -7,7 +7,7 @@ */ #ifndef _SYS_PROTO_H_ #define _SYS_PROTO_H_ -#include <asm/omap_gpmc.h> +#include <linux/mtd/omap_gpmc.h>
typedef struct { u32 mtype; diff --git a/arch/arm/include/asm/arch-omap4/sys_proto.h b/arch/arm/include/asm/arch-omap4/sys_proto.h index 768453d..eb9a104 100644 --- a/arch/arm/include/asm/arch-omap4/sys_proto.h +++ b/arch/arm/include/asm/arch-omap4/sys_proto.h @@ -12,7 +12,7 @@ #include <asm/arch/clock.h> #include <asm/io.h> #include <asm/omap_common.h> -#include <asm/omap_gpmc.h> +#include <linux/mtd/omap_gpmc.h> #include <asm/arch/mux_omap4.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/arch/arm/include/asm/arch-omap5/sys_proto.h b/arch/arm/include/asm/arch-omap5/sys_proto.h index 5ed7e6a..9097303 100644 --- a/arch/arm/include/asm/arch-omap5/sys_proto.h +++ b/arch/arm/include/asm/arch-omap5/sys_proto.h @@ -12,7 +12,7 @@ #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/omap_common.h> -#include <asm/omap_gpmc.h> +#include <linux/mtd/omap_gpmc.h> #include <asm/arch/clock.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/isee/igep00x0/igep00x0.c b/board/isee/igep00x0/igep00x0.c index 7a7500b..3b2b1f1 100644 --- a/board/isee/igep00x0/igep00x0.c +++ b/board/isee/igep00x0/igep00x0.c @@ -8,7 +8,6 @@ #include <twl4030.h> #include <netdev.h> #include <asm/gpio.h> -#include <asm/omap_gpmc.h> #include <asm/io.h> #include <asm/arch/mem.h> #include <asm/arch/mmc_host_def.h> diff --git a/board/overo/overo.c b/board/overo/overo.c index 9ac35d2..1192d02 100644 --- a/board/overo/overo.c +++ b/board/overo/overo.c @@ -21,7 +21,6 @@ #include <asm/arch/mux.h> #include <asm/arch/mem.h> #include <asm/arch/sys_proto.h> -#include <asm/omap_gpmc.h> #include <asm/gpio.h> #include <asm/mach-types.h> #include "overo.h" diff --git a/drivers/mtd/nand/omap_elm.c b/drivers/mtd/nand/omap_elm.c index 64dca4f..55a631d 100644 --- a/drivers/mtd/nand/omap_elm.c +++ b/drivers/mtd/nand/omap_elm.c @@ -16,7 +16,7 @@ #include <common.h> #include <asm/io.h> #include <asm/errno.h> -#include <asm/omap_gpmc.h> +#include <linux/mtd/omap_gpmc.h> #include <asm/omap_elm.h> #include <asm/arch/hardware.h>
diff --git a/drivers/mtd/nand/omap_gpmc.c b/drivers/mtd/nand/omap_gpmc.c index 5bcb242..6bf8242 100644 --- a/drivers/mtd/nand/omap_gpmc.c +++ b/drivers/mtd/nand/omap_gpmc.c @@ -9,7 +9,7 @@ #include <asm/io.h> #include <asm/errno.h> #include <asm/arch/mem.h> -#include <asm/omap_gpmc.h> +#include <linux/mtd/omap_gpmc.h> #include <linux/mtd/nand_ecc.h> #include <linux/bch.h> #include <linux/compiler.h> diff --git a/arch/arm/include/asm/omap_gpmc.h b/include/linux/mtd/omap_gpmc.h similarity index 100% rename from arch/arm/include/asm/omap_gpmc.h rename to include/linux/mtd/omap_gpmc.h
omap_elm.h is a generic header used by OMAP ELM driver for all TI platfoms. Hence this file should be present in generic folder instead of architecture specific include folder. Build tested using: ./MAKEALL -s am33xx -s omap3 -s omap4 -s omap5
Signed-off-by: Pekon Gupta pekon@ti.com --- drivers/mtd/nand/omap_elm.c | 2 +- drivers/mtd/nand/omap_gpmc.c | 2 +- {arch/arm/include/asm => include/linux/mtd}/omap_elm.h | 0 3 files changed, 2 insertions(+), 2 deletions(-) rename {arch/arm/include/asm => include/linux/mtd}/omap_elm.h (100%)
diff --git a/drivers/mtd/nand/omap_elm.c b/drivers/mtd/nand/omap_elm.c index 55a631d..47b1f1b 100644 --- a/drivers/mtd/nand/omap_elm.c +++ b/drivers/mtd/nand/omap_elm.c @@ -17,7 +17,7 @@ #include <asm/io.h> #include <asm/errno.h> #include <linux/mtd/omap_gpmc.h> -#include <asm/omap_elm.h> +#include <linux/mtd/omap_elm.h> #include <asm/arch/hardware.h>
#define ELM_DEFAULT_POLY (0) diff --git a/drivers/mtd/nand/omap_gpmc.c b/drivers/mtd/nand/omap_gpmc.c index 6bf8242..c1ce771 100644 --- a/drivers/mtd/nand/omap_gpmc.c +++ b/drivers/mtd/nand/omap_gpmc.c @@ -14,7 +14,7 @@ #include <linux/bch.h> #include <linux/compiler.h> #include <nand.h> -#include <asm/omap_elm.h> +#include <linux/mtd/omap_elm.h>
#define BADBLOCK_MARKER_LENGTH 2 #define SECTOR_BYTES 512 diff --git a/arch/arm/include/asm/omap_elm.h b/include/linux/mtd/omap_elm.h similarity index 100% rename from arch/arm/include/asm/omap_elm.h rename to include/linux/mtd/omap_elm.h
Pekon Gupta
