[U-Boot] [RFC PATCH] tools: add a generic config for native tools building
The motivation for this is to allow distributions to distribute all possible tools in a generic way, avoiding the need of specific tools building for each machine.
Especially on OpenEmbedded / Yocto Project ecosystem, it is very common each BSP to end providing their specific tools when they need to generate images for some SoC (e.g MX23 / MX28 in meta-freescale case).
Using this, we can package the tools doing:
$: make tools-only_defconfig $: make tools-only
Signed-off-by: Otavio Salvador otavio@ossystems.com.br ---
configs/tools-only_defconfig | 3 +++ tools/Makefile | 2 +- 2 files changed, 4 insertions(+), 1 deletion(-) create mode 100644 configs/tools-only_defconfig
diff --git a/configs/tools-only_defconfig b/configs/tools-only_defconfig new file mode 100644 index 0000000000..be69bdf43a --- /dev/null +++ b/configs/tools-only_defconfig @@ -0,0 +1,3 @@ +CONFIG_SYS_TEXT_BASE=0 +CONFIG_FIT=y +CONFIG_FIT_SIGNATURE=y diff --git a/tools/Makefile b/tools/Makefile index 3c0521f655..e916d0cebb 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -124,7 +124,7 @@ fit_info-objs := $(dumpimage-mkimage-objs) fit_info.o fit_check_sign-objs := $(dumpimage-mkimage-objs) fit_check_sign.o file2include-objs := file2include.o
-ifneq ($(CONFIG_MX23)$(CONFIG_MX28),) +ifneq ($(CONFIG_MX23)$(CONFIG_MX28)$(CONFIG_FIT_SIGNATURE),) # Add CONFIG_MXS into host CFLAGS, so we can check whether or not register # the mxsimage support within tools/mxsimage.c . HOSTCFLAGS_mxsimage.o += -DCONFIG_MXS
Adding in Peter since Fedora had this same problem crop up. Does something like this work for you guys? Also adding in Vagrant Cascadian since Debian might want to switch to this too. Thoughts? Thanks!
Thanks.
The u-boot packages in Debian include similar patches and workarounds that I've been meaning to submit upstream for quite some time now... so glad to see someone else started the process!
I'll try to follow-up and check if these patches work for Debian.
live well, vagrant
We currently use the tools-all option, details below, to build the tools, which broken in 2018.11 on non arm/x86 platforms due to the sandbox dep being added in there. I'm happy to adjust as necessary to fix that but I'm not sure the difference between tools-all vs the above.
make CROSS_COMPILE="" defconfig V=1 O=builds/ make CROSS_COMPILE="" tools-all V=1 O=builds/
Well, with the above you would do tools-only_defconfig then tools-all, and we would make sure to _not_ enable options in tools-only_defconfig that may not build on some host platforms as it's intended only for building tools rather than the myriad of things sandbox is used for.
fit_info.o
register
Cascadian
That would be fine as far as I'm concerned.
Thanks Peter
fit_info.o
register
Cascadian
If people are likely to use tools-all, we may use tools-all_defconfig so we connect both. What do you think guys?
On Sat, Dec 1, 2018 at 2:34 PM Otavio Salvador otavio.salvador@ossystems.com.br wrote:
fit_info.o
register
Cascadian
That seems fine to me, let me know when there's something you'd like me to test.
Peter
participants (5)
Otavio Salvador
Otavio Salvador
Peter Robinson
Vagrant Cascadian
