[U-Boot-Users] fdt_find_compatible_node() and friends
Hi Jerry,
before re-coding fdt_find_compatible_node(), some more comments.
After browsing more carefully the FDT related code of "arch/powerpc" I think we also need, apart from fdt_find_compatible_node() and fdt_path_offset(), fdt_find_node_by_type() and maybe fdt_find_node_by_name(). These functions do a sequential scan of all devices starting at the beginning or after a specified node. They actually ignore the hierarchy. Do you agree? BTW: any reason why not using the more compatible name fdt_find_node_by_path() for fdt_path_offset()?
Wolfgang.
Wolfgang Grandegger wrote:
Hi Jerry,
Wolfgang.
Hi WolfganG,
I'm not an expert, I just fake it on email ;-). With that disclaimer, I would agree with you WRT all the "find" functions. The original libfdt code does not support any "find" functions, so we will need to add them.
WRT to fdt_find_node_by_path() vs. fdt_path_offset(), I vaguely recall some renames happening in the kernel source, but I cannot find them so my memory likely is faulty[1]. I would be strongly in favor of following the kernel's lead and renaming that function since we are already divergent from the original libfdt. The kernel's name is a much better description.
Best regards, gvb
[1] My mind is like a steel trap... unfortunately its been soaking it in beer for years now.
Hi Jerry,
Hi Jerry,
Wolfgang.
Hi WolfganG,
OK, I have attached two new patches replacing fdt_path_offset() with fdt_find_node_by_path() and implementing fdt_find_node_by_type() and fdt_find_compatible_node(). This version does not use static variables any more to scan the nodes without re-scanning, but looks for the end tag. I think it's (almost) good enough to be applied.
Wolfgang.
Hi Jerry,
any intention to merge these patches?
Thanks,
Wolfgang.
Hi Jerry,
Hi Jerry,
Wolfgang.
Hi WolfganG,
Wolfgang.
Replace fdt_node_offset() with fdt_find_node_by_path().
The new name matches more closely the kernel's name, which is also a much better description.
board/mpc8360emds/mpc8360emds.c | 2 +- board/mpc8360emds/pci.c | 2 +- common/cmd_fdt.c | 6 +++--- common/fdt_support.c | 10 +++++----- cpu/mpc83xx/cpu.c | 2 +- include/libfdt.h | 2 +- libfdt/fdt_ro.c | 2 +- 7 files changed, 13 insertions(+), 13 deletions(-)
diff --git a/board/mpc8360emds/mpc8360emds.c b/board/mpc8360emds/mpc8360emds.c index 562eb8b..3f87f09 100644 --- a/board/mpc8360emds/mpc8360emds.c +++ b/board/mpc8360emds/mpc8360emds.c @@ -681,7 +681,7 @@ ft_board_setup(void *blob, bd_t *bd) int nodeoffset; int tmp[2];
- nodeoffset = fdt_path_offset (fdt, "/memory");
- nodeoffset = fdt_find_node_by_path (fdt, "/memory"); if (nodeoffset >= 0) { tmp[0] = cpu_to_be32(bd->bi_memstart); tmp[1] = cpu_to_be32(bd->bi_memsize);
diff --git a/board/mpc8360emds/pci.c b/board/mpc8360emds/pci.c index 158effe..4c7a82b 100644 --- a/board/mpc8360emds/pci.c +++ b/board/mpc8360emds/pci.c @@ -311,7 +311,7 @@ ft_pci_setup(void *blob, bd_t *bd) int err; int tmp[2];
- nodeoffset = fdt_path_offset (fdt, "/" OF_SOC "/pci@8500");
- nodeoffset = fdt_find_node_by_path (fdt, "/" OF_SOC "/pci@8500"); if (nodeoffset >= 0) { tmp[0] = cpu_to_be32(hose[0].first_busno); tmp[1] = cpu_to_be32(hose[0].last_busno);
diff --git a/common/cmd_fdt.c b/common/cmd_fdt.c index 08fe351..7058197 100644 --- a/common/cmd_fdt.c +++ b/common/cmd_fdt.c @@ -177,7 +177,7 @@ int do_fdt (cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) if (strcmp(pathp, "/") == 0) { nodeoffset = 0; } else {
nodeoffset = fdt_path_offset (fdt, pathp);
nodeoffset = fdt_find_node_by_path (fdt, pathp); if (nodeoffset < 0) { /* * Not found or something else bad happened.
@@ -306,7 +306,7 @@ int do_fdt (cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) nodeoffset = 0; printf("/"); } else {
@@ -405,7 +405,7 @@ int do_fdt (cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) if (strcmp(argv[2], "/") == 0) { nodeoffset = 0; } else {
nodeoffset = fdt_path_offset (fdt, argv[2]);
nodeoffset = fdt_find_node_by_path (fdt, argv[2]); if (nodeoffset < 0) { /* * Not found or something else bad happened.
diff --git a/common/fdt_support.c b/common/fdt_support.c index 69099c4..05bf939 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -92,7 +92,7 @@ int fdt_chosen(void *fdt, ulong initrd_start, ulong initrd_end, int force) /* * Find the "chosen" node. */
- nodeoffset = fdt_path_offset (fdt, "/chosen");
nodeoffset = fdt_find_node_by_path (fdt, "/chosen");
- If we have a "chosen" node already the "force the writing"
@@ -140,7 +140,7 @@ int fdt_chosen(void *fdt, ulong initrd_start, ulong initrd_end, int force) printf("libfdt: %s\n", fdt_strerror(err)); #endif
- nodeoffset = fdt_path_offset (fdt, "/cpus");
- nodeoffset = fdt_find_node_by_path (fdt, "/cpus"); if (nodeoffset >= 0) { clock = cpu_to_be32(bd->bi_intfreq); err = fdt_setprop(fdt, nodeoffset, "clock-frequency", &clock, 4);
@@ -148,7 +148,7 @@ int fdt_chosen(void *fdt, ulong initrd_start, ulong initrd_end, int force) printf("libfdt: %s\n", fdt_strerror(err)); } #ifdef OF_TBCLK
- nodeoffset = fdt_path_offset (fdt, "/cpus/" OF_CPU "/timebase-frequency");
- nodeoffset = fdt_find_node_by_path (fdt, "/cpus/" OF_CPU "/timebase-frequency"); if (nodeoffset >= 0) { clock = cpu_to_be32(OF_TBCLK); err = fdt_setprop(fdt, nodeoffset, "clock-frequency", &clock, 4);
@@ -185,7 +185,7 @@ int fdt_env(void *fdt) * See if we already have a "u-boot-env" node, delete it if so. * Then create a new empty node. */
- nodeoffset = fdt_path_offset (fdt, "/u-boot-env");
- nodeoffset = fdt_find_node_by_path (fdt, "/u-boot-env"); if (nodeoffset >= 0) { err = fdt_del_node(fdt, nodeoffset); if (err < 0) {
@@ -305,7 +305,7 @@ int fdt_bd_t(void *fdt) * See if we already have a "bd_t" node, delete it if so. * Then create a new empty node. */
- nodeoffset = fdt_path_offset (fdt, "/bd_t");
- nodeoffset = fdt_find_node_by_path (fdt, "/bd_t"); if (nodeoffset >= 0) { err = fdt_del_node(fdt, nodeoffset); if (err < 0) {
diff --git a/cpu/mpc83xx/cpu.c b/cpu/mpc83xx/cpu.c index e934ba6..ef44581 100644 --- a/cpu/mpc83xx/cpu.c +++ b/cpu/mpc83xx/cpu.c @@ -460,7 +460,7 @@ ft_cpu_setup(void *blob, bd_t *bd) int j;
for (j = 0; j < (sizeof(fixup_props) / sizeof(fixup_props[0])); j++) {
nodeoffset = fdt_path_offset(fdt, fixup_props[j].node);
if (nodeoffset >= 0) { err = (*fixup_props[j].set_fn)(blob, nodeoffset, fixup_props[j].prop, bd); if (err < 0)nodeoffset = fdt_find_node_by_path(fdt, fixup_props[j].node);
diff --git a/include/libfdt.h b/include/libfdt.h index f8bac73..e080028 100644 --- a/include/libfdt.h +++ b/include/libfdt.h @@ -77,7 +77,7 @@ int fdt_subnode_offset_namelen(const void *fdt, int parentoffset, const char *name, int namelen); int fdt_subnode_offset(const void *fdt, int parentoffset, const char *name);
-int fdt_path_offset(const void *fdt, const char *path); +int fdt_find_node_by_path(const void *fdt, const char *path);
struct fdt_property *fdt_get_property(const void *fdt, int nodeoffset, const char *name, int *lenp); diff --git a/libfdt/fdt_ro.c b/libfdt/fdt_ro.c index 4e2c325..e5518c6 100644 --- a/libfdt/fdt_ro.c +++ b/libfdt/fdt_ro.c @@ -129,7 +129,7 @@ int fdt_subnode_offset(const void *fdt, int parentoffset,
- Searches for the node corresponding to the given path and returns the
- offset of that node.
*/ -int fdt_path_offset(const void *fdt, const char *path) +int fdt_find_node_by_path(const void *fdt, const char *path) { const char *end = path + strlen(path); const char *p = path;
Add fdt_find_node_by_type() and fdt_find_compatible_node() to LIBFDT
include/libfdt.h | 6 ++ libfdt/fdt_ro.c | 161 ++++++++++++++++++++++++++++++++++++++++++++++++------ 2 files changed, 149 insertions(+), 18 deletions(-)
diff --git a/include/libfdt.h b/include/libfdt.h index e080028..340e89d 100644 --- a/include/libfdt.h +++ b/include/libfdt.h @@ -78,6 +78,12 @@ int fdt_subnode_offset_namelen(const void *fdt, int parentoffset, int fdt_subnode_offset(const void *fdt, int parentoffset, const char *name);
int fdt_find_node_by_path(const void *fdt, const char *path); +int fdt_find_node_by_type(const void *fdt, int nodeoffset, const char *type);
+int fdt_node_is_compatible(const void *fdt, int nodeoffset,
const char *compat);
+int fdt_find_compatible_node(const void *fdt, int nodeoffset,
const char *type, const char *compat);
struct fdt_property *fdt_get_property(const void *fdt, int nodeoffset, const char *name, int *lenp); diff --git a/libfdt/fdt_ro.c b/libfdt/fdt_ro.c index e5518c6..e379fc2 100644 --- a/libfdt/fdt_ro.c +++ b/libfdt/fdt_ro.c @@ -48,6 +48,33 @@ static int offset_streq(const void *fdt, int offset, }
- Checks if the property name matches.
+static int prop_name_eq(const void *fdt, int offset, const char *name,
struct fdt_property **prop, int *lenp)
- int namestroff, len;
- *prop = fdt_offset_ptr_typed(fdt, offset, *prop);
- if (! *prop)
return -FDT_ERR_BADSTRUCTURE;
- namestroff = fdt32_to_cpu((*prop)->nameoff);
- if (streq(fdt_string(fdt, namestroff), name)) {
len = fdt32_to_cpu((*prop)->len);
*prop = fdt_offset_ptr(fdt, offset,
sizeof(**prop) + len);
if (*prop) {
if (lenp)
*lenp = len;
return 1;
} else
- Return a pointer to the string at the given string offset.
*/ char *fdt_string(const void *fdt, int stroffset) @@ -56,6 +83,118 @@ char *fdt_string(const void *fdt, int stroffset) }
- Check if the specified node is compatible by comparing the tokens
- in its "compatible" property with the specified string:
- nodeoffset - starting place of the node
- compat - the string to match to one of the tokens in the
"compatible" list.
const char *compat)
- const char* cp;
- int cplen, len;
- cp = fdt_getprop(fdt, nodeoffset, "compatible", &cplen);
- if (cp == NULL)
- while (cplen > 0) {
if (strncmp(cp, compat, strlen(compat)) == 0)
return 1;
len = strlen(cp) + 1;
cp += len;
cplen -= len;
- Find a node by its device type property. On success, the offset of that
- node is returned or an error code otherwise:
- nodeoffset - the node to start searching from or 0, the node you pass
will not be searched, only the next one will; typically,
you pass 0 to start the search and then what the previous
call returned.
- type - the device type string to match against.
+int fdt_find_node_by_type(const void *fdt, int nodeoffset, const char *type) +{
- int offset, nextoffset;
- struct fdt_property *prop;
- uint32_t tag;
- int len, ret;
- CHECK_HEADER(fdt);
- tag = fdt_next_tag(fdt, nodeoffset, &nextoffset, NULL);
- if (tag != FDT_BEGIN_NODE)
return -FDT_ERR_BADOFFSET;
- if (nodeoffset)
nodeoffset = 0; /* start searching with next node */
- while (1) {
offset = nextoffset;
tag = fdt_next_tag(fdt, offset, &nextoffset, NULL);
switch (tag) {
case FDT_BEGIN_NODE:
nodeoffset = offset;
break;
case FDT_PROP:
if (nodeoffset == 0)
break;
ret = prop_name_eq(fdt, offset, "device_type",
&prop, &len);
if (ret < 0)
return ret;
else if (ret > 0 &&
strncmp(prop->data, type, len - 1) == 0)
return nodeoffset;
break;
case FDT_END_NODE:
case FDT_NOP:
break;
case FDT_END:
return -FDT_ERR_NOTFOUND;
default:
- Find a node based on its device type and one of the tokens in its its
- "compatible" property. On success, the offset of that node is returned
- or an error code otherwise:
call returned.
"compatible" list.
- int offset;
- offset = fdt_find_node_by_type(fdt, nodeoffset, type);
- if (offset < 0 || fdt_node_is_compatible(fdt, offset, compat))
return offset;
- return -FDT_ERR_NOTFOUND;
- Return the node offset of the node specified by:
- parentoffset - starting place (0 to start at the root)
- name - name being searched for
@@ -184,7 +323,6 @@ struct fdt_property *fdt_get_property(const void *fdt, int level = 0; uint32_t tag; struct fdt_property *prop;
- int namestroff; int offset, nextoffset; int err;
@@ -224,24 +362,11 @@ struct fdt_property *fdt_get_property(const void *fdt, if (level != 0) continue;
err = -FDT_ERR_BADSTRUCTURE;
prop = fdt_offset_ptr_typed(fdt, offset, prop);
if (! prop)
goto fail;
namestroff = fdt32_to_cpu(prop->nameoff);
/* Found it! */
int len = fdt32_to_cpu(prop->len);
sizeof(*prop)+len);
if (! prop)
goto fail;
if (lenp)
*lenp = len;
err = prop_name_eq(fdt, offset, name, &prop, lenp);
if (err > 0) return prop;
else if (err < 0)
goto fail; break;
case FDT_NOP:
This SF.net email is sponsored by DB2 Express Download DB2 Express C - the FREE version of DB2 express and take control of your XML. No limits. Just data. Click to get it now. http://sourceforge.net/powerbar/db2/
U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Hi Jerry,
Thanks,
Wolfgang.
Hi Wolfgang,
Yes. I have to apologize for my lack of responsiveness, the first two weeks of every month are busy for me. Fortunately, we are in Week Three now. ;-)
I have some minor cleanup of my own to do (line length VIOLATIONS ;-) and I'll merge in your patch and push it uphill. http://en.wikipedia.org/wiki/Sisyphus
Thanks, gvb
Hi Jerry,
Hi Jerry,
Wolfgang.
Hi WolfganG,
Wolfgang.
4); @@ -148,7 +148,7 @@ int fdt_chosen(void *fdt, ulong initrd_start, ulong initrd_end, int force) printf("libfdt: %s\n", fdt_strerror(err)); } #ifdef OF_TBCLK
"/timebase-frequency"); if (nodeoffset >= 0) { clock = cpu_to_be32(OF_TBCLK); err = fdt_setprop(fdt, nodeoffset, "clock-frequency", &clock, 4); @@ -185,7 +185,7 @@ int fdt_env(void *fdt) * See if we already have a "u-boot-env" node, delete it if so. * Then create a new empty node. */
j++) {
nodeoffset = fdt_find_node_by_path(fdt, fixup_props[j].node); if (nodeoffset >= 0) { err = (*fixup_props[j].set_fn)(blob, nodeoffset,
fixup_props[j].prop, bd); if (err < 0) diff --git a/include/libfdt.h b/include/libfdt.h index f8bac73..e080028 100644 --- a/include/libfdt.h +++ b/include/libfdt.h @@ -77,7 +77,7 @@ int fdt_subnode_offset_namelen(const void *fdt, int parentoffset, const char *name, int namelen); int fdt_subnode_offset(const void *fdt, int parentoffset, const char *name);
- if (! *prop)
if (*prop) {
if (lenp)
*lenp = len;
return 1;
} else
"compatible" list.
const char *compat)
- const char* cp;
- int cplen, len;
- if (cp == NULL)
return 1;
cp += len;
cplen -= len;
that
pass
typically,
previous
call returned.
- uint32_t tag;
- int len, ret;
- if (nodeoffset)
- while (1) {
switch (tag) {
break;
case FDT_PROP:
break;
&prop, &len);
if (ret < 0)
return ret;
else if (ret > 0 &&
return nodeoffset;
break;
case FDT_END_NODE:
case FDT_NOP:
break;
case FDT_END:
default:
returned
pass
typically,
previous
call returned.
"compatible" list.
- int offset;
return offset;
if (! prop)
goto fail;
/* Found it! */
sizeof(*prop)+len);
if (! prop)
goto fail;
if (lenp)
*lenp = len;
else if (err < 0)
goto fail; break; case FDT_NOP:
CAUTION: This message was sent via the Public Internet and its authenticity cannot be guaranteed. ______________________________________________________
Hi Jerry,
Hi Jerry,
Wolfgang.
Hi WolfganG,
Wolfgang.
Hi Wolfgang G,
I've applied your patches to my local (working) repository and will push the changes tonight (my tonight, your tomorrow ;-). I created a subroutine out of three snippets of code in cmd_fdt.c which your fdt_find_node_by_path() change fixed up so I had to fix one line in the new subroutine by hand. Not bad at all considering the changes I made in that file.
Your patches have a From: line rather than a Signed-off-by: line, I presume it is OK (and desirable) for me to change it into a Signed-off-by: line (I'll add my own Acked-by: line).
Thanks, gvb
Hi Jerry,
Jerry Van Baren wrote: [...]
Hi Wolfgang G,
Thanks. In the meantime I observed, that
fdt_find_node_by_path(fdt, 0, "/");
returns an error. Is that by purpose?
That's fine, of course.
Wolfgang.
Hi Jerry,
Hi Wolfgang G,
[snip]
Wolfgang.
Hmm, interesting observation. The character '/' is a figment of our imagination, offset 0 in the tree is the root node. The character '/' is the path separator and doesn't actually exist anywhere in the fdt - when parsing paths, the stuff between the slashes is searched for and the slashes themselves are skipped over.
What you asked in the above call is a node with no name under the root node, i.e. "//" in human-speak. That wasn't found, of course. On the other hand, it is a pretty obvious "mistake" (I was guilty of making the same mistake when I first tried to use fdt_path_offset()).
It seems like I was forever doing a conditional:
59 if (strcmp(pathp, "/") == 0) { 60 nodeoffset = 0; 61 } else { 62 nodeoffset = fdt_path_offset (fdt, pathp); 63 if (nodeoffset < 0) {
Trivia: Your patch we are discussing changed exactly this fdt_path_offset() into fdt_find_node_by_path() - this is the one place your patch didn't apply, because I refactored the three conditionals into a single wrapper subroutine.
At the risk of being accused of codling our users, I would propose we add the equivalent "/" detection code (above) to fdt_find_node_by_path(), (I will do that tonight unless you beat me to it). It seems silly to have the caller replicate or wrap the conditional since it is going to be such a common idiom/mistake.
Thanks, gvb
Hi Jerry,
Hi Wolfgang G,
[snip]
Wolfgang.
And it is frequently used in the kernel as the following command reveals:
$ find . -name '*.c' | xargs grep find_node_by_path | grep '"/"'
I actually wanted to get the string for the property "model" and yes, fdt_getprop(fdt, 0, "model", NULL) does work.
Thanks... and no hurry.
Wolfgang.
Jerry Van Baren
Jerry Van Baren
Wolfgang Grandegger
