[U-Boot] [PATCH V2] MMC: DWMMC: Fix FIFO_DEPTH calculation
Current DWMMC driver used to give FIFO underrun/overrun error every 3rd time for mmc rescan command. In current code FIFO_DEPTH is getting calculated after reading the default FIFOTH register and extracting the RX_WMARK bits from it i.e (RX_WMARK = FIFO_DEPTH/2 -1). Instead of storing the correct value, we were recalculating the FIFO_DEPT each time which is not correct.
Based on "[PATCH V9 3/9] DWMMC: Initialise dwmci and resolve EMMC read write issues" http://permalink.gmane.org/gmane.comp.boot-loaders.u-boot/160247
Signed-off-by: Hatim Ali hatim.rv@samsung.com Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com --- Changes in V2: - remove fifoth_val local variable - Rebased on top of "[PATCH V9 3/9] DWMMC: Initialise dwmci and resolve EMMC read write issues". drivers/mmc/dw_mmc.c | 14 ++++++-------- 1 files changed, 6 insertions(+), 8 deletions(-)
diff --git a/drivers/mmc/dw_mmc.c b/drivers/mmc/dw_mmc.c index 1307b12..5da20ed 100644 --- a/drivers/mmc/dw_mmc.c +++ b/drivers/mmc/dw_mmc.c @@ -312,7 +312,7 @@ static void dwmci_set_ios(struct mmc *mmc) static int dwmci_init(struct mmc *mmc) { struct dwmci_host *host = (struct dwmci_host *)mmc->priv; - u32 fifo_size, fifoth_val; + u32 fifo_size;
dwmci_writel(host, DWMCI_PWREN, 1);
@@ -332,15 +332,13 @@ static int dwmci_init(struct mmc *mmc) dwmci_writel(host, DWMCI_IDINTEN, 0); dwmci_writel(host, DWMCI_BMOD, 1);
- fifo_size = dwmci_readl(host, DWMCI_FIFOTH); - fifo_size = ((fifo_size & RX_WMARK_MASK) >> RX_WMARK_SHIFT) + 1; - if (host->fifoth_val) { - fifoth_val = host->fifoth_val; - } else { - fifoth_val = MSIZE(0x2) | RX_WMARK(fifo_size / 2 - 1) | + if (!host->fifoth_val) { + fifo_size = dwmci_readl(host, DWMCI_FIFOTH); + fifo_size = ((fifo_size & RX_WMARK_MASK) >> RX_WMARK_SHIFT) + 1; + host->fifoth_val = MSIZE(0x2) | RX_WMARK(fifo_size / 2 - 1) | TX_WMARK(fifo_size / 2); } - dwmci_writel(host, DWMCI_FIFOTH, fifoth_val); + dwmci_writel(host, DWMCI_FIFOTH, host->fifoth_val);
dwmci_writel(host, DWMCI_CLKENA, 0); dwmci_writel(host, DWMCI_CLKSRC, 0);
On Fri, May 24, 2013 at 5:45 AM, Rajeshwari Shinde <rajeshwari.s@samsung.com
DEPTH
Tested on pit using 'mmc rescan' and saw no problems now.
Tested-by: Simon Glass sjg@chromium.org
u32 fifo_size; dwmci_writel(host, DWMCI_PWREN, 1);
} else {
- | TX_WMARK(fifo_size / 2); }
dwmci_writel(host, DWMCI_FIFOTH, host->fifoth_val); dwmci_writel(host, DWMCI_CLKENA, 0); dwmci_writel(host, DWMCI_CLKSRC, 0);
-- 1.7.4.4
Acked-by: Jaehoon Chung jh80.chung@samsung.com
Thanks, Jaehoon Chung
On 05/27/2013 05:32 AM, Simon Glass wrote:
On Fri, May 24, 2013 at 5:45 AM, Rajeshwari Shinde <rajeshwari.s@samsung.com mailto:rajeshwari.s@samsung.com> wrote:
DEPTH
time which is not correct. Based on "[PATCH V9 3/9] DWMMC: Initialise dwmci and resolve EMMC read write issues" http://permalink.gmane.org/gmane.comp.boot-loaders.u-boot/160247 Signed-off-by: Hatim Ali <hatim.rv@samsung.com <mailto:hatim.rv@samsung.com>> Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com <mailto:rajeshwari.s@samsung.com>>
Acked-by: Simon Glass <sjg@chromium.org mailto:sjg@chromium.org>
Tested-by: Simon Glass <sjg@chromium.org mailto:sjg@chromium.org>
--- Changes in V2: - remove fifoth_val local variable - Rebased on top of "[PATCH V9 3/9] DWMMC: Initialise dwmci and resolve EMMC read write issues". drivers/mmc/dw_mmc.c | 14 ++++++-------- 1 files changed, 6 insertions(+), 8 deletions(-) diff --git a/drivers/mmc/dw_mmc.c b/drivers/mmc/dw_mmc.c index 1307b12..5da20ed 100644 --- a/drivers/mmc/dw_mmc.c +++ b/drivers/mmc/dw_mmc.c @@ -312,7 +312,7 @@ static void dwmci_set_ios(struct mmc *mmc) static int dwmci_init(struct mmc *mmc) { struct dwmci_host *host = (struct dwmci_host *)mmc->priv; - u32 fifo_size, fifoth_val; + u32 fifo_size; dwmci_writel(host, DWMCI_PWREN, 1); @@ -332,15 +332,13 @@ static int dwmci_init(struct mmc *mmc) dwmci_writel(host, DWMCI_IDINTEN, 0); dwmci_writel(host, DWMCI_BMOD, 1); - fifo_size = dwmci_readl(host, DWMCI_FIFOTH); - fifo_size = ((fifo_size & RX_WMARK_MASK) >> RX_WMARK_SHIFT) + 1; - if (host->fifoth_val) { - fifoth_val = host->fifoth_val; - } else { - fifoth_val = MSIZE(0x2) | RX_WMARK(fifo_size / 2 - 1) | + if (!host->fifoth_val) { + fifo_size = dwmci_readl(host, DWMCI_FIFOTH); + fifo_size = ((fifo_size & RX_WMARK_MASK) >> RX_WMARK_SHIFT) + 1; + host->fifoth_val = MSIZE(0x2) | RX_WMARK(fifo_size / 2 - 1) | TX_WMARK(fifo_size / 2); } - dwmci_writel(host, DWMCI_FIFOTH, fifoth_val); + dwmci_writel(host, DWMCI_FIFOTH, host->fifoth_val); dwmci_writel(host, DWMCI_CLKENA, 0); dwmci_writel(host, DWMCI_CLKSRC, 0); -- 1.7.4.4
Signed-off-by: Hatim Ali hatim.rv@samsung.com Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com Acked-by: Simon Glass sjg@chromium.org Tested-by: Simon Glass sjg@chromium.org Acked-by: Jaehoon Chung jh80.chung@samsung.com
Acked-by: Andy Fleming afleming@freescale.com
Looks like the patch this is based on is already accepted, but not yet upstream, so I'm going to delegate the patch to Minkyu Kang
applied to u-boot-samsung.
Thanks, Minkyu Kang.
participants (5)
Andy Fleming
Jaehoon Chung
Minkyu Kang
Rajeshwari Shinde
