[GIT PULL] Clock changes for v2024.04
The following changes since commit 6faba41927bdc8973b59678649ef83c564cc421e:
Prepare v2024.04-rc1 (2024-01-29 20:53:19 -0500)
https://source.denx.de/u-boot/custodians/u-boot-clk.git tags/clk-2024.04-rc2
for you to fetch changes up to a8dc4965f09d28a59c156437673ddb66860c847e:
clk: clk-gpio: add actual gated clock (2024-01-29 22:35:34 -0500)
---------------------------------------------------------------- Clock changes for v2024.04
This pull has the usual fixes and new (clock-adjacent) drivers. It also has some cleanups for the clock API; in particular removing the unused rfree callback.
CI: https://source.denx.de/u-boot/custodians/u-boot-clk/-/pipelines/19486
---------------------------------------------------------------- Julien Masson (1): clk: fix clk_get_rate() always return ulong
Neil Armstrong (1): clk: meson: add Hardware Clock measure driver
Sean Anderson (3): clk: Remove rfree treewide: Remove clk_free clk: Document clk_ops return codes and behavior
Svyatoslav Ryhel (1): clk: clk-gpio: add actual gated clock
arch/arm/mach-rockchip/rk3288/rk3288.c | 2 - arch/arm/mach-socfpga/clock_manager_agilex.c | 2 - arch/arm/mach-socfpga/clock_manager_arria10.c | 7 +- arch/arm/mach-socfpga/clock_manager_n5x.c | 2 - arch/arm/mach-zynq/clk.c | 2 - arch/mips/mach-pic32/cpu.c | 7 +- arch/sandbox/include/asm/clk.h | 8 -- board/microchip/pic32mzda/pic32mzda.c | 2 - board/sipeed/maix/maix.c | 1 - board/synopsys/hsdk/clk-lib.c | 2 - drivers/clk/aspeed/clk_ast2600.c | 2 - drivers/clk/at91/compat.c | 14 +- drivers/clk/clk-gpio.c | 38 +++++- drivers/clk/clk-uclass.c | 47 +------ drivers/clk/clk-xlnx-clock-wizard.c | 1 - drivers/clk/clk_sandbox.c | 12 -- drivers/clk/clk_sandbox_test.c | 12 -- drivers/clk/clk_versaclock.c | 12 +- drivers/clk/clk_zynq.c | 2 - drivers/clk/clk_zynqmp.c | 2 - drivers/clk/imx/clk-imx8.c | 2 - drivers/clk/meson/Kconfig | 10 ++ drivers/clk/meson/Makefile | 1 + drivers/clk/meson/clk-measure.c | 634 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/clk/mvebu/armada-37xx-periph.c | 2 - drivers/cpu/riscv_cpu.c | 2 - drivers/dma/bcm6348-iudma.c | 2 - drivers/gpio/at91_gpio.c | 2 - drivers/gpio/atmel_pio4.c | 2 - drivers/gpio/gpio-rcar.c | 1 - drivers/hwspinlock/stm32_hwspinlock.c | 6 +- drivers/i2c/at91_i2c.c | 2 - drivers/i2c/designware_i2c.c | 2 - drivers/i2c/i2c-microchip.c | 2 - drivers/i2c/npcm_i2c.c | 1 - drivers/i2c/ocores_i2c.c | 2 - drivers/i2c/stm32f7_i2c.c | 4 +- drivers/mailbox/stm32-ipcc.c | 7 +- drivers/misc/ls2_sfp.c | 1 - drivers/mmc/arm_pl180_mmci.c | 1 - drivers/mmc/aspeed_sdhci.c | 4 +- drivers/mmc/atmel_sdhci.c | 2 - drivers/mmc/gen_atmel_mci.c | 19 +-- drivers/mmc/msm_sdhci.c | 1 - drivers/mmc/pic32_sdhci.c | 1 - drivers/mmc/renesas-sdhi.c | 21 +-- drivers/mmc/snps_dw_mmc.c | 8 +- drivers/mmc/socfpga_dw_mmc.c | 1 - drivers/mmc/stm32_sdmmc2.c | 4 +- drivers/mmc/uniphier-sd.c | 1 - drivers/mtd/nand/raw/atmel/nand-controller.c | 4 +- drivers/mtd/renesas_rpc_hf.c | 1 - drivers/net/bcm6348-eth.c | 2 - drivers/net/bcm6368-eth.c | 2 - drivers/net/designware.c | 1 - drivers/net/dwc_eth_qos.c | 43 +----- drivers/net/dwc_eth_qos_imx.c | 21 +-- drivers/net/dwc_eth_qos_qcom.c | 1 - drivers/net/dwc_eth_qos_rockchip.c | 6 +- drivers/net/sni_ave.c | 5 +- drivers/net/ti/am65-cpsw-nuss.c | 1 - drivers/phy/bcm6318-usbh-phy.c | 2 - drivers/phy/bcm6348-usbh-phy.c | 2 - drivers/phy/bcm6368-usbh-phy.c | 4 - drivers/phy/meson-axg-mipi-dphy.c | 1 - drivers/phy/meson-g12a-usb3-pcie.c | 1 - drivers/phy/meson-gxl-usb2.c | 1 - drivers/phy/phy-rcar-gen2.c | 1 - drivers/phy/phy-rcar-gen3.c | 1 - drivers/pinctrl/pinctrl-k210.c | 20 +-- drivers/power/domain/imx8mp-hsiomix.c | 4 +- drivers/rtc/stm32_rtc.c | 16 +-- drivers/serial/atmel_usart.c | 2 - drivers/serial/serial_bcm6345.c | 1 - drivers/serial/serial_msm.c | 1 - drivers/serial/serial_pic32.c | 1 - drivers/spi/atcspi200_spi.c | 1 - drivers/spi/atmel-quadspi.c | 14 +- drivers/spi/atmel_spi.c | 2 - drivers/spi/bcm63xx_hsspi.c | 4 - drivers/spi/bcm63xx_spi.c | 2 - drivers/spi/bcmbca_hsspi.c | 4 - drivers/spi/cadence_qspi.c | 1 - drivers/spi/designware_spi.c | 5 - drivers/spi/meson_spifc_a1.c | 10 -- drivers/spi/mvebu_a3700_spi.c | 10 -- drivers/spi/spi-aspeed-smc.c | 1 - drivers/spi/stm32_spi.c | 19 +-- drivers/timer/dw-apb-timer.c | 2 - drivers/timer/ostm_timer.c | 2 - drivers/usb/dwc3/dwc3-meson-g12a.c | 4 +- drivers/usb/dwc3/dwc3-meson-gxl.c | 4 +- drivers/usb/host/ehci-atmel.c | 8 +- drivers/usb/host/ohci-da8xx.c | 1 - drivers/usb/host/xhci-rcar.c | 5 +- drivers/video/atmel_hlcdfb.c | 2 - drivers/video/mali_dp.c | 11 +- drivers/video/rockchip/rk3288_hdmi.c | 4 +- drivers/video/rockchip/rk_edp.c | 8 +- drivers/watchdog/designware_wdt.c | 18 +-- drivers/watchdog/meson_gxbb_wdt.c | 4 +- include/clk-uclass.h | 123 ++++++++++++++--- include/clk.h | 31 ----- test/dm/clk.c | 9 -- 104 files changed, 853 insertions(+), 526 deletions(-) create mode 100644 drivers/clk/meson/clk-measure.c
Sean Anderson
