Pull request efi-2023-07-rc2
Dear Tom,
The following changes since commit 2440719d258a97824395532cb4a775752b423f63:
Merge tag 'u-boot-imx-20230503' of https://gitlab.denx.de/u-boot/custodians/u-boot-imx (2023-05-03 13:15:12 -0400)
https://source.denx.de/u-boot/custodians/u-boot-efi.git tags/efi-2023-07-rc2
for you to fetch changes up to 8a6414d1e410ab65780a4c5eb99e79e5b9bc21c1:
CI: treat documentation warnings as errors (2023-05-04 11:15:12 +0200)
Gitlab CI showed no issues: https://source.denx.de/u-boot/custodians/u-boot-efi/-/pipelines/16241
---------------------------------------------------------------- Pull request efi-2023-07-rc2
Documentation:
* treat documentation warnings as errors in CI * adjust StarFive VisionFive 2 and SiFive Unmatched documentation * man-page for cp * correct description of uclass_get_device_by_of_path * correct proftool usage
UEFI
* Fix documentation of EFI Python tests * Rename efi_selftest Python test
---------------------------------------------------------------- Alexander Shirokov (1): doc: mmc: drop 0x prefixes in read/write examples
Heinrich Schuchardt (8): tools: fix TestFdtUtil() dm: core: fix introduce uclass_get_device_by_of_path doc: Indicate required OpenSBI release for VisionFive 2 doc: fix StarFive VisionFive v2 documentation doc: correct HiFive Unmatched boot description test: fix pydoc issues for EFI tests doc: man-page for cp CI: treat documentation warnings as errors
Pavel Skripkin (1): docs: fix wrong proftool usage
Simon Glass (1): efi: Rename the base efi self-test
.azure-pipelines.yml | 2 +- .gitlab-ci.yml | 2 +- doc/board/sifive/unmatched.rst | 6 +- doc/board/starfive/visionfive2.rst | 23 ++++--- doc/develop/trace.rst | 2 +- doc/usage/cmd/cp.rst | 83 ++++++++++++++++++++++++++ doc/usage/cmd/mmc.rst | 4 +- doc/usage/index.rst | 1 + include/dm/uclass.h | 2 +- test/py/tests/test_efi_bootmgr/conftest.py | 6 +- test/py/tests/test_efi_capsule/capsule_defs.py | 2 + test/py/tests/test_efi_capsule/conftest.py | 11 ++-- test/py/tests/test_efi_secboot/conftest.py | 6 +- test/py/tests/test_efi_secboot/defs.py | 2 + test/py/tests/test_efi_selftest.py | 2 +- tools/dtoc/test_fdt.py | 4 +- 16 files changed, 129 insertions(+), 29 deletions(-) create mode 100644 doc/usage/cmd/cp.rst
On Thu, May 04, 2023 at 01:16:02PM +0200, Heinrich Schuchardt wrote:
Dear Tom,
