[U-Boot] [PATCH 0/5] fix apalis-tk1 pcie gigabit ethernet operation
This series addresses a gigabit Ethernet reliability issue as observed on Apalis TK1 related to a PCIe reset timing violation.
This series depends on Simon's work available at u-boot-dm/master plus my previous series "move apalis t30/tk1, colibri t20/t30 to livetree".
This series is available at http://git.toradex.com/cgit/u-boot-toradex.git/log/?h=for-next
Marcel Ziswiler (4): apalis-tk1: add missing as3722 gpio0 configuration pci: tegra: make tegra_pcie_port_reset weak function with explicit index power: as3722: add as3722_ldo_set_voltage signature to header file apalis-tk1: fix pcie reset for reliable gigabit ethernet operation
Sanchayan Maity (1): configs: apalis-tk1: fix boot failure using ext4 rootfs
arch/arm/dts/tegra124-apalis.dts | 6 +- board/toradex/apalis-tk1/apalis-tk1.c | 241 ++++++++++++++++++++-------------- drivers/pci/pci_tegra.c | 7 +- include/configs/apalis-tk1.h | 4 +- include/power/as3722.h | 1 + 5 files changed, 156 insertions(+), 103 deletions(-)
Trying to boot from an ext4 rootfs fails due to us defaulting to ext3. While the downstream T20/T30 L4T kernel has issues with ext4 later TK1 L4T should work just fine with it. Hence enable ext4 for sdboot and usbboot on TK1.
Signed-off-by: Sanchayan Maity maitysanchayan@gmail.com Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com ---
include/configs/apalis-tk1.h | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/configs/apalis-tk1.h b/include/configs/apalis-tk1.h index d6b226c..bb46768 100644 --- a/include/configs/apalis-tk1.h +++ b/include/configs/apalis-tk1.h @@ -87,7 +87,7 @@ "&& setenv dtbparam ${fdt_addr_r}\0"
#define SD_BOOTCMD \ - "sdargs=ip=off root=/dev/mmcblk1p2 rw rootfstype=ext3 rootwait\0" \ + "sdargs=ip=off root=/dev/mmcblk1p2 rw rootfstype=ext4 rootwait\0" \ "sdboot=run setup; setenv bootargs ${defargs} ${sdargs} ${setupargs} " \ "${vidargs}; echo Booting from SD card in 8bit slot...; " \ "run sddtbload; load mmc 1:1 ${kernel_addr_r} " \ @@ -98,7 +98,7 @@ "&& setenv dtbparam ${fdt_addr_r}\0"
#define USB_BOOTCMD \ - "usbargs=ip=off root=/dev/sda2 rw rootfstype=ext3 rootwait\0" \ + "usbargs=ip=off root=/dev/sda2 rw rootfstype=ext4 rootwait\0" \ "usbboot=run setup; setenv bootargs ${defargs} ${setupargs} " \ "${usbargs} ${vidargs}; echo Booting from USB stick...; " \ "usb start && run usbdtbload; load usb 0:1 ${kernel_addr_r} " \
As the AS3722 GPIO0 is also a not connected on our Apalis TK1 module explicitly configure it to high-impedance as well.
Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com ---
arch/arm/dts/tegra124-apalis.dts | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm/dts/tegra124-apalis.dts b/arch/arm/dts/tegra124-apalis.dts index 2fc0384..fe08d3e 100644 --- a/arch/arm/dts/tegra124-apalis.dts +++ b/arch/arm/dts/tegra124-apalis.dts @@ -1683,9 +1683,9 @@ bias-pull-up; };
- gpio1_3_4_5_6 { - pins = "gpio1", "gpio3", "gpio4", - "gpio5", "gpio6"; + gpio0_1_3_4_5_6 { + pins = "gpio0", "gpio1", "gpio3", + "gpio4", "gpio5", "gpio6"; bias-high-impedance; }; };
Make tegra_pcie_port_reset() a weak function with an explicit index parameter. This allows overriding the PCIe port reset functionality from board specific code as e.g. required for Apalis TK1.
drivers/pci/pci_tegra.c | 7 ++++--- 1 file changed, 4 insertions(+), 3 deletions(-)
diff --git a/drivers/pci/pci_tegra.c b/drivers/pci/pci_tegra.c index cb5cf8b..d373a88 100644 --- a/drivers/pci/pci_tegra.c +++ b/drivers/pci/pci_tegra.c @@ -893,7 +893,8 @@ static unsigned long tegra_pcie_port_get_pex_ctrl(struct tegra_pcie_port *port) return ret; }
-static void tegra_pcie_port_reset(struct tegra_pcie_port *port) +void __weak tegra_pcie_port_reset(struct tegra_pcie_port *port, + unsigned int index) { unsigned long ctrl = tegra_pcie_port_get_pex_ctrl(port); unsigned long value; @@ -928,7 +929,7 @@ static void tegra_pcie_port_enable(struct tegra_pcie_port *port)
afi_writel(pcie, value, ctrl);
- tegra_pcie_port_reset(port); + tegra_pcie_port_reset(port, port->index);
if (soc->force_pca_enable) { value = rp_readl(port, RP_VEND_CTL2); @@ -979,7 +980,7 @@ static bool tegra_pcie_port_check_link(struct tegra_pcie_port *port) } while (--timeout);
retry: - tegra_pcie_port_reset(port); + tegra_pcie_port_reset(port, port->index); } while (--retries);
return false;
I think this change should be implemented differently.
Does the patch description mean that:
a) This change allows the board code to know which port is being reset.
If so, simply have the board-specific implementation access port->index since it's already being passed port, and all callers are passing port->index as the index parameter. If the type isn't available, then you can add a tegra_pcie_port_index_of_port() function to retrieve it through the opaque type.
or:
b) That by changing the function signature code is able to choose between calling the board-specific reset override function and the PCIe driver low-level reset function?
If so, let's just have two different function names, have all callers call the board-specific function only, and have the board-specific function call the driver function. There can be a weak default board-specific implementation that simply calls the driver function.
Hi Stephen
index
I did of course know that the port struct already contained that information but did not think of any such elegant way to do it as you describe outside of adding an explicit index. So I agree and will just implement and make use of such a new tegra_pcie_port_index_of_port() function.
or:
Initially that was not really my intention but I believe you bring up a very valid point and it could be useful to use the default reset behaviour on certain ports while using a custom one on others. This would e.g. be the case on Apalis T30 where the on-module PCIe gigabit Ethernet chip is using the standard out-of-band signalling while the PCIe switch on the Apalis Evaluation board requires the same special reset work-around as optionally implemented for Apalis TK1. I will therefore implement it this way as well leaving it completely up to board code which way to go.
Thanks again for your valuable input.
Cheers
Marcel
Just like the already present as3722_sd_set_voltage() add the currently missing signature of the as3722_ldo_set_voltage() function to its header file.
include/power/as3722.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/power/as3722.h b/include/power/as3722.h index cb4b188..43af9b2 100644 --- a/include/power/as3722.h +++ b/include/power/as3722.h @@ -25,5 +25,6 @@ #define AS3722_GPIO_CONTROL_INVERT (1 << 7)
int as3722_sd_set_voltage(struct udevice *dev, unsigned int sd, u8 value); +int as3722_ldo_set_voltage(struct udevice *dev, unsigned int ldo, u8 value);
#endif /* __POWER_AS3722_H__ */
It turns out that the current PCIe reset implementation in the PCIe board init function is not quite working reliably due to PCIe reset timing violations. Fix this by overriding the tegra_pcie_port_reset() function.
Also allow optionally bringing up the PCIe switch as found on the Apalis Evaluation board. Note however that the Apalis PCIe port is also left disabled in the device tree by default.
board/toradex/apalis-tk1/apalis-tk1.c | 241 ++++++++++++++++++++-------------- 1 file changed, 146 insertions(+), 95 deletions(-)
diff --git a/board/toradex/apalis-tk1/apalis-tk1.c b/board/toradex/apalis-tk1/apalis-tk1.c index 5de61e7..13449ce 100644 --- a/board/toradex/apalis-tk1/apalis-tk1.c +++ b/board/toradex/apalis-tk1/apalis-tk1.c @@ -5,17 +5,25 @@ */
#include <common.h> +#include <dm.h> #include <asm/arch-tegra/ap.h> #include <asm/gpio.h> #include <asm/io.h> #include <asm/arch/gpio.h> #include <asm/arch/pinmux.h> #include <power/as3722.h> +#include <power/pmic.h>
#include "../common/tdx-common.h" #include "pinmux-config-apalis-tk1.h"
-#define LAN_RESET_N TEGRA_GPIO(S, 2) +#define LAN_DEV_OFF_N TEGRA_GPIO(O, 6) +#define LAN_RESET_N TEGRA_GPIO(S, 2) +#define LAN_WAKE_N TEGRA_GPIO(O, 5) +#ifdef APALIS_TK1_PCIE_EVALBOARD_INIT +#define PEX_PERST_N TEGRA_GPIO(DD, 1) /* Apalis GPIO7 */ +#define RESET_MOCI_CTRL TEGRA_GPIO(U, 4) +#endif /* APALIS_TK1_PCIE_EVALBOARD_INIT */
int arch_misc_init(void) { @@ -59,123 +67,166 @@ void pinmux_init(void) }
#ifdef CONFIG_PCI_TEGRA -int tegra_pcie_board_init(void) +/* TODO: Convert to driver model */ +static int as3722_sd_enable(struct udevice *pmic, unsigned int sd) { - /* TODO: Convert to driver model - struct udevice *pmic; int err;
- err = as3722_init(&pmic); - if (err) { - error("failed to initialize AS3722 PMIC: %d\n", err); - return err; - } + if (sd > 6) + return -EINVAL;
- err = as3722_sd_enable(pmic, 4); - if (err < 0) { - error("failed to enable SD4: %d\n", err); + err = pmic_clrsetbits(pmic, AS3722_SD_CONTROL, 0, 1 << sd); + if (err) { + error("failed to update SD control register: %d", err); return err; }
- err = as3722_sd_set_voltage(pmic, 4, 0x24); - if (err < 0) { - error("failed to set SD4 voltage: %d\n", err); - return err; - } + return 0; +}
- err = as3722_gpio_configure(pmic, 1, AS3722_GPIO_OUTPUT_VDDH | - AS3722_GPIO_INVERT); - if (err < 0) { - error("failed to configure GPIO#1 as output: %d\n", err); - return err; - } +/* TODO: Convert to driver model */ +static int as3722_ldo_enable(struct udevice *pmic, unsigned int ldo) +{ + int err;
- err = as3722_gpio_direction_output(pmic, 2, 1); - if (err < 0) { - error("failed to set GPIO#2 high: %d\n", err); - return err; - } - */ + if (ldo > 11) + return -EINVAL;
- /* Reset I210 Gigabit Ethernet Controller */ - gpio_request(LAN_RESET_N, "LAN_RESET_N"); - gpio_direction_output(LAN_RESET_N, 0); - - /* - * Make sure we don't get any back feeding from LAN_WAKE_N resp. - * DEV_OFF_N - */ - gpio_request(TEGRA_GPIO(O, 5), "LAN_WAKE_N"); - gpio_direction_output(TEGRA_GPIO(O, 5), 0); - - gpio_request(TEGRA_GPIO(O, 6), "LAN_DEV_OFF_N"); - gpio_direction_output(TEGRA_GPIO(O, 6), 0); - - /* Make sure LDO9 and LDO10 are initially enabled @ 0V */ - /* TODO: Convert to driver model - err = as3722_ldo_enable(pmic, 9); - if (err < 0) { - error("failed to enable LDO9: %d\n", err); - return err; - } - err = as3722_ldo_enable(pmic, 10); - if (err < 0) { - error("failed to enable LDO10: %d\n", err); - return err; - } - err = as3722_ldo_set_voltage(pmic, 9, 0x80); - if (err < 0) { - error("failed to set LDO9 voltage: %d\n", err); - return err; - } - err = as3722_ldo_set_voltage(pmic, 10, 0x80); - if (err < 0) { - error("failed to set LDO10 voltage: %d\n", err); + err = pmic_clrsetbits(pmic, AS3722_LDO_CONTROL, 0, 1 << ldo); + if (err) { + error("failed to update LDO control register: %d", err); return err; } - */
- mdelay(100); + return 0; +}
- /* Make sure controller gets enabled by disabling DEV_OFF_N */ - gpio_set_value(TEGRA_GPIO(O, 6), 1); +int tegra_pcie_board_init(void) +{ + struct udevice *dev; + int ret; + + ret = uclass_get_device_by_driver(UCLASS_PMIC, + DM_GET_DRIVER(pmic_as3722), &dev); + if (ret) { + debug("%s: Failed to find PMIC\n", __func__); + return ret; + }
- /* Enable LDO9 and LDO10 for +V3.3_ETH on patched prototypes */ - /* TODO: Convert to driver model - err = as3722_ldo_set_voltage(pmic, 9, 0xff); - if (err < 0) { - error("failed to set LDO9 voltage: %d\n", err); - return err; + ret = as3722_sd_enable(dev, 4); + if (ret < 0) { + error("failed to enable SD4: %d\n", ret); + return ret; } - err = as3722_ldo_set_voltage(pmic, 10, 0xff); - if (err < 0) { - error("failed to set LDO10 voltage: %d\n", err); - return err; + + ret = as3722_sd_set_voltage(dev, 4, 0x24); + if (ret < 0) { + error("failed to set SD4 voltage: %d\n", ret); + return ret; } - */
- mdelay(100); - gpio_set_value(LAN_RESET_N, 1); + gpio_request(LAN_DEV_OFF_N, "LAN_DEV_OFF_N"); + gpio_request(LAN_RESET_N, "LAN_RESET_N"); + gpio_request(LAN_WAKE_N, "LAN_WAKE_N");
#ifdef APALIS_TK1_PCIE_EVALBOARD_INIT -#define PEX_PERST_N TEGRA_GPIO(DD, 1) /* Apalis GPIO7 */ -#define RESET_MOCI_CTRL TEGRA_GPIO(U, 4) - - /* Reset PLX PEX 8605 PCIe Switch plus PCIe devices on Apalis Evaluation - Board */ gpio_request(PEX_PERST_N, "PEX_PERST_N"); gpio_request(RESET_MOCI_CTRL, "RESET_MOCI_CTRL"); - gpio_direction_output(PEX_PERST_N, 0); - gpio_direction_output(RESET_MOCI_CTRL, 0); - /* Must be asserted for 100 ms after power and clocks are stable */ - mdelay(100); - gpio_set_value(PEX_PERST_N, 1); - /* Err_5: PEX_REFCLK_OUTpx/nx Clock Outputs is not Guaranteed Until - 900 us After PEX_PERST# De-assertion */ - mdelay(1); - gpio_set_value(RESET_MOCI_CTRL, 1); -#endif /* APALIS_T30_PCIE_EVALBOARD_INIT */ +#endif /* APALIS_TK1_PCIE_EVALBOARD_INIT */
return 0; } + +void tegra_pcie_port_reset(void *port, unsigned int index) +{ + if (index == 1) { /* I210 Gigabit Ethernet Controller (On-module) */ + struct udevice *dev; + int ret; + + ret = uclass_get_device_by_driver(UCLASS_PMIC, + DM_GET_DRIVER(pmic_as3722), + &dev); + if (ret) { + debug("%s: Failed to find PMIC\n", __func__); + return; + } + + /* Reset I210 Gigabit Ethernet Controller */ + gpio_direction_output(LAN_RESET_N, 0); + + /* + * Make sure we don't get any back feeding from DEV_OFF_N resp. + * LAN_WAKE_N + */ + gpio_direction_output(LAN_DEV_OFF_N, 0); + gpio_direction_output(LAN_WAKE_N, 0); + + /* Make sure LDO9 and LDO10 are initially enabled @ 0V */ + ret = as3722_ldo_enable(dev, 9); + if (ret < 0) { + error("failed to enable LDO9: %d\n", ret); + return; + } + ret = as3722_ldo_enable(dev, 10); + if (ret < 0) { + error("failed to enable LDO10: %d\n", ret); + return; + } + ret = as3722_ldo_set_voltage(dev, 9, 0x80); + if (ret < 0) { + error("failed to set LDO9 voltage: %d\n", ret); + return; + } + ret = as3722_ldo_set_voltage(dev, 10, 0x80); + if (ret < 0) { + error("failed to set LDO10 voltage: %d\n", ret); + return; + } + + /* Make sure controller gets enabled by disabling DEV_OFF_N */ + gpio_set_value(LAN_DEV_OFF_N, 1); + + /* Enable LDO9 and LDO10 for +V3.3_ETH on patched prototypes */ + ret = as3722_ldo_set_voltage(dev, 9, 0xff); + if (ret < 0) { + error("failed to set LDO9 voltage: %d\n", ret); + return; + } + ret = as3722_ldo_set_voltage(dev, 10, 0xff); + if (ret < 0) { + error("failed to set LDO10 voltage: %d\n", ret); + return; + } + + /* + * Must be asserted for 100 ms after power and clocks are stable + */ + mdelay(100); + + gpio_set_value(LAN_RESET_N, 1); + + } else if (index == 0) { /* Apalis PCIe */ +#ifdef APALIS_TK1_PCIE_EVALBOARD_INIT + /* + * Reset PLX PEX 8605 PCIe Switch plus PCIe devices on Apalis + * Evaluation Board + */ + gpio_direction_output(PEX_PERST_N, 0); + gpio_direction_output(RESET_MOCI_CTRL, 0); + + /* + * Must be asserted for 100 ms after power and clocks are stable + */ + mdelay(100); + + gpio_set_value(PEX_PERST_N, 1); + /* + * Err_5: PEX_REFCLK_OUTpx/nx Clock Outputs is not Guaranteed + * Until 900 us After PEX_PERST# De-assertion + */ + mdelay(1); + gpio_set_value(RESET_MOCI_CTRL, 1); +#endif /* APALIS_TK1_PCIE_EVALBOARD_INIT */ + } +} #endif /* CONFIG_PCI_TEGRA */
Marcel Ziswiler
Marcel Ziswiler
Stephen Warren
