[U-Boot] [PATCH v7 17/17] doc: SPI: Update status.txt
Updated current SPI subsyetem status.
Signed-off-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com --- doc/SPI/status.txt | 11 ++++++----- 1 file changed, 6 insertions(+), 5 deletions(-)
diff --git a/doc/SPI/status.txt b/doc/SPI/status.txt index 62c3c85..13889f5 100644 --- a/doc/SPI/status.txt +++ b/doc/SPI/status.txt @@ -11,6 +11,11 @@ SPI FLASH (drivers/mtd/spi): - Bank Address Register (Accessing flashes > 16Mbytes in 3-byte addressing) - Added memory_mapped support for read operations. - Common probe support for all supported flash vendors except, ramtron. +- Extended read commands support(dual read, dual IO read) +- Quad Page Program support. +- Quad Read support(quad fast read, quad IO read) +- Dual flash connection topology support(accessing two spi flash memories with single cs) +- Banking support on dual flash connection topology.
SPI DRIVERS (drivers/spi): - @@ -18,14 +23,10 @@ SPI DRIVERS (drivers/spi): TODO: - Runtime detection of spi_flash params, SFDP(if possible) - Add support for multibus build/accessing. -- Extended read commands support(dual read, dual IO read) -- Quad Page Program support. -- Quad Read support(quad fast read, quad IO read) -- Dual flash connection topology support(accessing two spi flash memories with single cs) -- Banking support on dual flash connection topology. - Need proper cleanups on spi_flash and drivers.
-- Jagannadha Sutradharudu Teki jagannadh.teki@gmail.com 18-09-2013. 07-10-2013. +08-01-2014.
