[U-Boot] [PATCH V2] drivers:power:max77686: add function to set voltage and mode
This patch add new functions to pmic max77686 to set voltage and mode.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com CC: Minkyu Kang mk7.kang@samsung.com CC: Rajeshwari Shinde rajeshwari.s@samsung.com
Acked-by: Rajeshwari Shinde rajeshwari.s@samsung.com --- Changes in v2: - changed printf to debug
drivers/power/pmic/pmic_max77686.c | 186 ++++++++++++++++++++++++++++++++++++ include/power/max77686_pmic.h | 11 +++ 2 files changed, 197 insertions(+)
diff --git a/drivers/power/pmic/pmic_max77686.c b/drivers/power/pmic/pmic_max77686.c index 7fcb4c0..dabd6b6 100644 --- a/drivers/power/pmic/pmic_max77686.c +++ b/drivers/power/pmic/pmic_max77686.c @@ -30,6 +30,192 @@
DECLARE_GLOBAL_DATA_PTR;
+static const char max77686_buck_addr[] = { + 0xff, 0x10, 0x12, 0x1c, 0x26, 0x30, 0x32, 0x34, 0x36, 0x38 +}; + +static unsigned int max77686_ldo_volt2hex(int ldo, ulong uV) +{ + unsigned int hex = 0; + const unsigned int max_hex = 0x3f; + + switch (ldo) { + case 1: + case 2: + case 6: + case 7: + case 8: + case 15: + hex = (uV - 800000) / 25000; + break; + default: + hex = (uV - 800000) / 50000; + } + + if (0 <= hex && hex <= max_hex) + return hex; + + debug("%s: %ld is wrong voltage value for LDO%d\n", __func__, uV, ldo); + return 0; +} + +int max77686_set_ldo_voltage(struct pmic *p, int ldo, ulong uV) +{ + unsigned int val, ret, hex, adr, mask; + + if (ldo < 1 && 26 < ldo) { + printf("%s: %d is wrong ldo number\n", __func__, ldo); + return -1; + } + + adr = MAX77686_REG_PMIC_LDO1CTRL1 + ldo - 1; + mask = 0x3f; + hex = max77686_ldo_volt2hex(ldo, uV); + + if (!hex) + return -1; + + ret = pmic_reg_read(p, adr, &val); + val &= ~mask; + val |= hex; + ret |= pmic_reg_write(p, adr, val); + + return ret; +} + +int max77686_set_ldo_mode(struct pmic *p, int ldo, char opmode) +{ + unsigned int val, ret, mask, adr, mode; + + if (ldo < 1 && 26 < ldo) { + printf("%s: %d is wrong ldo number\n", __func__, ldo); + return -1; + } + + adr = MAX77686_REG_PMIC_LDO1CTRL1 + ldo - 1; + + /* mask */ + mask = 0xc0; + + /* mode */ + if (opmode == OPMODE_OFF) { + mode = 0x00; + } else if (opmode == OPMODE_STANDBY) { + switch (ldo) { + case 2: + case 6: + case 7: + case 8: + case 10: + case 11: + case 12: + case 14: + case 15: + case 16: + mode = 0x40; + break; + default: + mode = 0xff; + } + } else if (opmode == OPMODE_LPM) { + mode = 0x80; + } else if (opmode == OPMODE_ON) { + mode = 0xc0; + } else { + mode = 0xff; + } + + if (mode == 0xff) { + printf("%s: %d is not supported on LDO%d\n", + __func__, opmode, ldo); + return -1; + } + + ret = pmic_reg_read(p, adr, &val); + val &= ~mask; + val |= mode; + ret |= pmic_reg_write(p, adr, val); + + return ret; +} + +int max77686_set_buck_mode(struct pmic *p, int buck, char opmode) +{ + unsigned int val, ret, mask, adr, size, mode; + + size = sizeof(max77686_buck_addr) / sizeof(*max77686_buck_addr); + if (buck >= size) { + printf("%s: %d is wrong buck number\n", __func__, buck); + return -1; + } + + adr = max77686_buck_addr[buck]; + + /* mask */ + switch (buck) { + case 2: + case 3: + case 4: + mask = 0x30; + break; + default: + mask = 0x03; + } + + /* mode */ + if (opmode == OPMODE_OFF) { + mode = 0x00; + } else if (opmode == OPMODE_STANDBY) { + switch (buck) { + case 1: + mode = 0x01; + break; + case 2: + case 3: + case 4: + mode = 0x10; + break; + default: + mode = 0xff; + } + } else if (opmode == OPMODE_LPM) { + switch (buck) { + case 2: + case 3: + case 4: + mode = 0x20; + break; + default: + mode = 0xff; + } + } else if (opmode == OPMODE_ON) { + switch (buck) { + case 2: + case 3: + case 4: + mode = 0x30; + break; + default: + mode = 0x03; + } + } else { + mode = 0xff; + } + + if (mode == 0xff) { + printf("%s: %d is not supported on BUCK%d\n", + __func__, opmode, buck); + return -1; + } + + ret = pmic_reg_read(p, adr, &val); + val &= ~mask; + val |= mode; + ret |= pmic_reg_write(p, adr, val); + + return ret; +} + int pmic_init(unsigned char bus) { static const char name[] = "MAX77686_PMIC"; diff --git a/include/power/max77686_pmic.h b/include/power/max77686_pmic.h index fdc7ca9..ce58c02 100644 --- a/include/power/max77686_pmic.h +++ b/include/power/max77686_pmic.h @@ -155,6 +155,17 @@ enum { EN_LDO = (0x3 << 6), };
+enum { + OPMODE_OFF = 0, + OPMODE_STANDBY, + OPMODE_LPM, + OPMODE_ON, +}; + +int max77686_set_ldo_voltage(struct pmic *p, int ldo, ulong uV); +int max77686_set_ldo_mode(struct pmic *p, int ldo, char opmode); +int max77686_set_buck_mode(struct pmic *p, int buck, char opmode); + /* Buck1 1 volt value */ #define MAX77686_BUCK1OUT_1V 0x5 #define MAX77686_BUCK1CTRL_EN (3 << 0)
Dear Piotr Wilczek,
Changes in v2:
Is it constant? then please define it.
switch (ldo) {
case 1:
case 2:
case 6:
case 7:
case 8:
case 15:
break;
default:
I think, hex >= 0 looks more comfortable.
return hex;
ldo);
ditto.
return -1;
mask = 0x3f;
if (!hex)
return -1;
I think.. if you got error while read the register then please return error without writing.
+ val &= ~mask;
val |= hex;
return ret;
return -1;
/* mask */
mask = 0xc0;
/* mode */
mode = 0x00;
switch (ldo) {
case 2:
case 6:
case 7:
case 8:
case 10:
case 11:
case 12:
case 14:
case 15:
case 16:
mode = 0x40;
+ break;
default:
mode = 0xff;
mode = 0x80;
mode = 0xc0;
} else {
mode = 0xff;
switch case? What means 0x40 and 0x80, 0xc0?
There are so many magic values in this patch. I'll not mentioned about it anymore. Please fix it globally.
if (mode == 0xff) {
return -1;
ditto.
val &= ~mask;
val |= mode;
return ret;
ARRAY_SIZE()?
if (buck >= size) {
return -1;
/* mask */
switch (buck) {
case 2:
case 3:
case 4:
mask = 0x30;
break;
default:
mask = 0x03;
/* mode */
mode = 0x00;
switch (buck) {
case 1:
mode = 0x01;
break;
case 2:
case 3:
case 4:
mode = 0x10;
break;
default:
mode = 0xff;
switch (buck) {
case 2:
case 3:
case 4:
mode = 0x20;
break;
default:
mode = 0xff;
switch (buck) {
case 2:
case 3:
case 4:
mode = 0x30;
break;
default:
mode = 0x03;
} else {
mode = 0xff;
if (mode == 0xff) {
return -1;
val &= ~mask;
val |= mode;
return ret;
+enum {
OPMODE_OFF = 0,
OPMODE_STANDBY,
OPMODE_LPM,
OPMODE_ON,
1.7.9.5
Thanks, Minkyu Kang.
Dear Minkyu Kang,
Thank you for comments. I agree with all of them.
Piotr Wilczek
From: Minkyu Kang [mailto:promsoft@gmail.com] Sent: Friday, June 21, 2013 6:24 PM To: Piotr Wilczek Cc: u-boot@lists.denx.de; Kyungmin Park; Rajeshwari Shinde Subject: Re: [U-Boot] [PATCH V2] drivers:power:max77686: add function to set voltage and mode
Dear Piotr Wilczek,
ditto.
switch case?
ditto.
ARRAY_SIZE()?
+enum { + OPMODE_OFF = 0, + OPMODE_STANDBY, + OPMODE_LPM, + OPMODE_ON, +}; + +int max77686_set_ldo_voltage(struct pmic *p, int ldo, ulong uV); +int max77686_set_ldo_mode(struct pmic *p, int ldo, char opmode); +int max77686_set_buck_mode(struct pmic *p, int buck, char opmode); + /* Buck1 1 volt value */ #define MAX77686_BUCK1OUT_1V 0x5 #define MAX77686_BUCK1CTRL_EN (3 << 0) -- 1.7.9.5
_______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Thanks,
Minkyu Kang.
Acked-by: Rajeshwari Shinde rajeshwari.s@samsung.com --- Changes in v3: - removed magic values - used ARRAY_SIZE() for array size calculation - used switch case instead if else if - added return when pmic read error occurs
drivers/power/pmic/pmic_max77686.c | 192 ++++++++++++++++++++++++++++++++++++ include/power/max77686_pmic.h | 26 +++++ 2 files changed, 218 insertions(+)
diff --git a/drivers/power/pmic/pmic_max77686.c b/drivers/power/pmic/pmic_max77686.c index 7fcb4c0..3960ca9 100644 --- a/drivers/power/pmic/pmic_max77686.c +++ b/drivers/power/pmic/pmic_max77686.c @@ -30,6 +30,198 @@
+static const char max77686_buck_addr[] = { + 0xff, 0x10, 0x12, 0x1c, 0x26, 0x30, 0x32, 0x34, 0x36, 0x38 +}; + +static unsigned int max77686_ldo_volt2hex(int ldo, ulong uV) +{ + unsigned int hex = 0; + + switch (ldo) { + case 1: + case 2: + case 6: + case 7: + case 8: + case 15: + hex = (uV - 800000) / 25000; + break; + default: + hex = (uV - 800000) / 50000; + } + + if (hex >= 0 && hex <= MAX77686_LDO_VOLT_MAX_HEX) + return hex; + + debug("%s: %ld is wrong voltage value for LDO%d\n", __func__, uV, ldo); + return 0; +} + +int max77686_set_ldo_voltage(struct pmic *p, int ldo, ulong uV) +{ + unsigned int val, ret, hex, adr; + + if (ldo < 1 && ldo > 26) { + printf("%s: %d is wrong ldo number\n", __func__, ldo); + return -1; + } + + adr = MAX77686_REG_PMIC_LDO1CTRL1 + ldo - 1; + hex = max77686_ldo_volt2hex(ldo, uV); + + if (!hex) + return -1; + + ret = pmic_reg_read(p, adr, &val); + if (ret) + return ret; + + val &= ~MAX77686_LDO_VOLT_MASK; + val |= hex; + ret |= pmic_reg_write(p, adr, val); + + return ret; +} + +int max77686_set_ldo_mode(struct pmic *p, int ldo, char opmode) +{ + unsigned int val, ret, adr, mode; + + if (ldo < 1 && 26 < ldo) { + printf("%s: %d is wrong ldo number\n", __func__, ldo); + return -1; + } + + adr = MAX77686_REG_PMIC_LDO1CTRL1 + ldo - 1; + + /* mode */ + switch (opmode) { + case OPMODE_OFF: + mode = MAX77686_LDO_MODE_OFF; + break; + case OPMODE_STANDBY: + switch (ldo) { + case 2: + case 6: + case 7: + case 8: + case 10: + case 11: + case 12: + case 14: + case 15: + case 16: + mode = MAX77686_LDO_MODE_STANDBY; + break; + default: + mode = 0xff; + } + break; + case OPMODE_LPM: + mode = MAX77686_LDO_MODE_LPM; + break; + case OPMODE_ON: + mode = MAX77686_LDO_MODE_ON; + break; + default: + mode = 0xff; + } + + if (mode == 0xff) { + printf("%s: %d is not supported on LDO%d\n", + __func__, opmode, ldo); + return -1; + } + + ret = pmic_reg_read(p, adr, &val); + if (ret) + return ret; + + val &= ~MAX77686_LDO_MODE_MASK; + val |= mode; + ret |= pmic_reg_write(p, adr, val); + + return ret; +} + +int max77686_set_buck_mode(struct pmic *p, int buck, char opmode) +{ + unsigned int val, ret, mask, adr, size, mode, mode_shift; + + size = ARRAY_SIZE(max77686_buck_addr); + if (buck >= size) { + printf("%s: %d is wrong buck number\n", __func__, buck); + return -1; + } + + adr = max77686_buck_addr[buck]; + + /* mask */ + switch (buck) { + case 2: + case 3: + case 4: + mode_shift = MAX77686_BUCK_MODE_SHIFT_2; + break; + default: + mode_shift = MAX77686_BUCK_MODE_SHIFT_1; + } + + mask = MAX77686_BUCK_MODE_MASK << mode_shift; + + /* mode */ + switch (opmode) { + case OPMODE_OFF: + mode = MAX77686_BUCK_MODE_OFF; + break; + case OPMODE_STANDBY: + switch (buck) { + case 1: + case 2: + case 3: + case 4: + mode = MAX77686_BUCK_MODE_STANDBY << mode_shift; + break; + default: + mode = 0xff; + } + break; + case OPMODE_LPM: + switch (buck) { + case 2: + case 3: + case 4: + mode = MAX77686_BUCK_MODE_LPM << mode_shift; + break; + default: + mode = 0xff; + } + break; + case OPMODE_ON: + mode = MAX77686_BUCK_MODE_ON << mode_shift; + break; + default: + mode = 0xff; + } + + if (mode == 0xff) { + printf("%s: %d is not supported on BUCK%d\n", + __func__, opmode, buck); + return -1; + } + + ret = pmic_reg_read(p, adr, &val); + if (ret) + return ret; + + val &= ~mask; + val |= mode; + ret |= pmic_reg_write(p, adr, val); + + return ret; +} + int pmic_init(unsigned char bus) { static const char name[] = "MAX77686_PMIC"; diff --git a/include/power/max77686_pmic.h b/include/power/max77686_pmic.h index 1c374a9..7339a3e 100644 --- a/include/power/max77686_pmic.h +++ b/include/power/max77686_pmic.h @@ -155,6 +155,32 @@ enum { EN_LDO = (0x3 << 6), };
+enum { + OPMODE_OFF = 0, + OPMODE_STANDBY, + OPMODE_LPM, + OPMODE_ON, +}; + +int max77686_set_ldo_voltage(struct pmic *p, int ldo, ulong uV); +int max77686_set_ldo_mode(struct pmic *p, int ldo, char opmode); +int max77686_set_buck_mode(struct pmic *p, int buck, char opmode); + +#define MAX77686_LDO_VOLT_MAX_HEX 0x3f +#define MAX77686_LDO_VOLT_MASK 0x3f +#define MAX77686_LDO_MODE_MASK 0xc0 +#define MAX77686_LDO_MODE_OFF (0x00 << 0x06) +#define MAX77686_LDO_MODE_STANDBY (0x01 << 0x06) +#define MAX77686_LDO_MODE_LPM (0x02 << 0x06) +#define MAX77686_LDO_MODE_ON (0x03 << 0x06) +#define MAX77686_BUCK_MODE_MASK 0x03 +#define MAX77686_BUCK_MODE_SHIFT_1 0x00 +#define MAX77686_BUCK_MODE_SHIFT_2 0x04 +#define MAX77686_BUCK_MODE_OFF 0x00 +#define MAX77686_BUCK_MODE_STANDBY 0x01 +#define MAX77686_BUCK_MODE_LPM 0x02 +#define MAX77686_BUCK_MODE_ON 0x03 + /* Buck1 1 volt value */ #define MAX77686_BUCK1OUT_1V 0x5 /* Buck1 1.05 volt value */
Dear Minkyu Kang,
Please let me know if you have any more comments on this patch.
Also, there is another patchset to review: http://patchwork.ozlabs.org/patch/245307/
Best regards, Piotr Wilczek
-----Original Message----- From: Piotr Wilczek [mailto:p.wilczek@samsung.com] Sent: Tuesday, June 25, 2013 10:00 AM To: u-boot@lists.denx.de Cc: Minkyu Kang; Kyungmin Park; Lukasz Majewski; Piotr Wilczek; Rajeshwari Shinde Subject: [PATCH v3] drivers:power:max77686: add function to set voltage and mode
Changes in v3:
Changes in v2:
- 0xff, 0x10, 0x12, 0x1c, 0x26, 0x30, 0x32, 0x34, 0x36, 0x38 };
+static unsigned int max77686_ldo_volt2hex(int ldo, ulong uV) {
- unsigned int hex = 0;
- switch (ldo) {
- case 1:
- case 2:
- case 6:
- case 7:
- case 8:
- case 15:
break;
- default:
- if (hex >= 0 && hex <= MAX77686_LDO_VOLT_MAX_HEX)
return hex;
- debug("%s: %ld is wrong voltage value for LDO%d\n", __func__, uV,
ldo);
+int max77686_set_ldo_voltage(struct pmic *p, int ldo, ulong uV) {
- unsigned int val, ret, hex, adr;
- if (ldo < 1 && ldo > 26) {
return -1;
- adr = MAX77686_REG_PMIC_LDO1CTRL1 + ldo - 1;
- hex = max77686_ldo_volt2hex(ldo, uV);
- if (!hex)
return -1;
- ret = pmic_reg_read(p, adr, &val);
- if (ret)
return ret;
- val &= ~MAX77686_LDO_VOLT_MASK;
- val |= hex;
- ret |= pmic_reg_write(p, adr, val);
- return ret;
+int max77686_set_ldo_mode(struct pmic *p, int ldo, char opmode) {
- unsigned int val, ret, adr, mode;
- if (ldo < 1 && 26 < ldo) {
return -1;
- /* mode */
- switch (opmode) {
- case OPMODE_OFF:
break;
- case OPMODE_STANDBY:
switch (ldo) {
case 2:
case 6:
case 7:
case 8:
case 10:
case 11:
case 12:
case 14:
case 15:
case 16:
break;
default:
mode = 0xff;
break;
- case OPMODE_LPM:
break;
- case OPMODE_ON:
break;
- default:
mode = 0xff;
- if (mode == 0xff) {
return -1;
- if (ret)
return ret;
- val &= ~MAX77686_LDO_MODE_MASK;
- val |= mode;
- return ret;
+int max77686_set_buck_mode(struct pmic *p, int buck, char opmode) {
- unsigned int val, ret, mask, adr, size, mode, mode_shift;
- size = ARRAY_SIZE(max77686_buck_addr);
- if (buck >= size) {
return -1;
- adr = max77686_buck_addr[buck];
- /* mask */
- switch (buck) {
- case 2:
- case 3:
- case 4:
break;
- default:
- mask = MAX77686_BUCK_MODE_MASK << mode_shift;
- /* mode */
- switch (opmode) {
- case OPMODE_OFF:
break;
switch (buck) {
case 1:
case 2:
case 3:
case 4:
break;
default:
mode = 0xff;
break;
- case OPMODE_LPM:
switch (buck) {
case 2:
case 3:
case 4:
break;
default:
mode = 0xff;
break;
- case OPMODE_ON:
break;
- default:
mode = 0xff;
return -1;
- if (ret)
return ret;
- val &= ~mask;
- val |= mode;
- return ret;
+enum {
- OPMODE_OFF = 0,
- OPMODE_STANDBY,
- OPMODE_LPM,
- OPMODE_ON,
+int max77686_set_ldo_voltage(struct pmic *p, int ldo, ulong uV); int +max77686_set_ldo_mode(struct pmic *p, int ldo, char opmode); int +max77686_set_buck_mode(struct pmic *p, int buck, char opmode);
/* Buck1 1 volt value */ #define MAX77686_BUCK1OUT_1V 0x5 /* Buck1 1.05 volt value */ -- 1.7.9.5
Dear Tom,
This patch is delegated to you. Could you review this patch for the next release?
-- Samsung R&D Institute Poland (SRPOL)
Changes in v3:
Changes in v2:
- switch (ldo) {
- case 1:
- case 2:
- case 6:
- case 7:
- case 8:
- case 15:
break;
- default:
return hex;
- debug("%s: %ld is wrong voltage value for LDO%d\n", __func__, uV, ldo);
return -1;
- if (!hex)
return -1;
- if (ret)
return ret;
- val |= hex;
- return ret;
return -1;
- /* mode */
- switch (opmode) {
- case OPMODE_OFF:
break;
switch (ldo) {
case 2:
case 6:
case 7:
case 8:
case 10:
case 11:
case 12:
case 14:
case 15:
case 16:
break;
default:
mode = 0xff;
break;
- case OPMODE_LPM:
break;
- case OPMODE_ON:
break;
- default:
mode = 0xff;
return -1;
- if (ret)
return ret;
- val |= mode;
- return ret;
return -1;
- /* mask */
- switch (buck) {
- case 2:
- case 3:
- case 4:
break;
- default:
- /* mode */
- switch (opmode) {
- case OPMODE_OFF:
break;
switch (buck) {
case 1:
case 2:
case 3:
case 4:
break;
default:
mode = 0xff;
break;
- case OPMODE_LPM:
switch (buck) {
case 2:
case 3:
case 4:
break;
default:
mode = 0xff;
break;
- case OPMODE_ON:
break;
- default:
mode = 0xff;
return -1;
- if (ret)
return ret;
- val &= ~mask;
- val |= mode;
- return ret;
- int pmic_init(unsigned char bus) { static const char name[] = "MAX77686_PMIC";
+enum {
- OPMODE_OFF = 0,
- OPMODE_STANDBY,
- OPMODE_LPM,
- OPMODE_ON,
- /* Buck1 1 volt value */ #define MAX77686_BUCK1OUT_1V 0x5 /* Buck1 1.05 volt value */
Acked-by: Tom Rini trini@ti.com
And re-assigned to Minkyu as I assume there's other patches needed that enable this on a samsung board of some sort.
applied to u-boot-samsung.
Minkyu Kang
Minkyu Kang
Piotr Wilczek
