[U-Boot] [PATCH v2 ] spi: cadence_qspi: Support specifying the sample edge used
Whilst at it, move the code to read the "sram-size" property into the other code that reads properties from the node, rather than the SF subnode.
Also change the code to use a bool for the bypass arg.
Signed-off-by: Phil Edworthy phil.edworthy@renesas.com
--- v2: Change name of DT prop and provide details of what it does. Whilst at it, move the code to read the "sram-size" property into the other code that reads properties from the node, rather than the SF subnode.
Also changed the code to use a bool for the bypass arg.
Note: I didn't explicitly state that the prop is optional as all of the props listed in that section are optional. --- doc/device-tree-bindings/spi/spi-cadence.txt | 2 ++ drivers/spi/cadence_qspi.c | 13 +++++++++---- drivers/spi/cadence_qspi.h | 3 ++- drivers/spi/cadence_qspi_apb.c | 8 +++++++- 4 files changed, 20 insertions(+), 6 deletions(-)
diff --git a/doc/device-tree-bindings/spi/spi-cadence.txt b/doc/device-tree-bindings/spi/spi-cadence.txt index c1e2233..94c800b 100644 --- a/doc/device-tree-bindings/spi/spi-cadence.txt +++ b/doc/device-tree-bindings/spi/spi-cadence.txt @@ -26,3 +26,5 @@ connected flash properties select (n_ss_out). - tslch-ns : Delay in master reference clocks between setting n_ss_out low and first bit transfer +- sample-edge-rising : Data outputs from flash memory will be sampled on the + rising edge. Default is falling edge. diff --git a/drivers/spi/cadence_qspi.c b/drivers/spi/cadence_qspi.c index 1051afb..16fb18e 100644 --- a/drivers/spi/cadence_qspi.c +++ b/drivers/spi/cadence_qspi.c @@ -39,8 +39,10 @@ static int cadence_spi_write_speed(struct udevice *bus, uint hz) /* Calibration sequence to determine the read data capture delay register */ static int spi_calibration(struct udevice *bus, uint hz) { + struct cadence_spi_platdata *plat = bus->platdata; struct cadence_spi_priv *priv = dev_get_priv(bus); void *base = priv->regbase; + bool edge = plat->sample_edge_rising; u8 opcode_rdid = 0x9F; unsigned int idcode = 0, temp = 0; int err = 0, i, range_lo = -1, range_hi = -1; @@ -49,7 +51,7 @@ static int spi_calibration(struct udevice *bus, uint hz) cadence_spi_write_speed(bus, 1000000);
/* configure the read data capture delay register to 0 */ - cadence_qspi_apb_readdata_capture(base, 1, 0); + cadence_qspi_apb_readdata_capture(base, true, edge, 0);
/* Enable QSPI */ cadence_qspi_apb_controller_enable(base); @@ -69,7 +71,7 @@ static int spi_calibration(struct udevice *bus, uint hz) cadence_qspi_apb_controller_disable(base);
/* reconfigure the read data capture delay register */ - cadence_qspi_apb_readdata_capture(base, 1, i); + cadence_qspi_apb_readdata_capture(base, true, edge, i);
/* Enable back QSPI */ cadence_qspi_apb_controller_enable(base); @@ -105,7 +107,8 @@ static int spi_calibration(struct udevice *bus, uint hz) cadence_qspi_apb_controller_disable(base);
/* configure the final value for read data capture delay register */ - cadence_qspi_apb_readdata_capture(base, 1, (range_hi + range_lo) / 2); + cadence_qspi_apb_readdata_capture(base, true, edge, + (range_hi + range_lo) / 2); debug("SF: Read data capture delay calibrated to %i (%i - %i)\n", (range_hi + range_lo) / 2, range_lo, range_hi);
@@ -298,6 +301,7 @@ static int cadence_spi_ofdata_to_platdata(struct udevice *bus)
plat->regbase = (void *)data[0]; plat->ahbbase = (void *)data[2]; + plat->sram_size = fdtdec_get_int(blob, node, "sram-size", 128);
/* All other paramters are embedded in the child node */ subnode = fdt_first_subnode(blob, node); @@ -317,7 +321,8 @@ static int cadence_spi_ofdata_to_platdata(struct udevice *bus) plat->tsd2d_ns = fdtdec_get_int(blob, subnode, "tsd2d-ns", 255); plat->tchsh_ns = fdtdec_get_int(blob, subnode, "tchsh-ns", 20); plat->tslch_ns = fdtdec_get_int(blob, subnode, "tslch-ns", 20); - plat->sram_size = fdtdec_get_int(blob, node, "sram-size", 128); + plat->sample_edge_rising = fdtdec_get_bool(blob, subnode, + "sample-edge-rising");
debug("%s: regbase=%p ahbbase=%p max-frequency=%d page-size=%d\n", __func__, plat->regbase, plat->ahbbase, plat->max_hz, diff --git a/drivers/spi/cadence_qspi.h b/drivers/spi/cadence_qspi.h index a849f7b..ad1dbae 100644 --- a/drivers/spi/cadence_qspi.h +++ b/drivers/spi/cadence_qspi.h @@ -26,6 +26,7 @@ struct cadence_spi_platdata { u32 tchsh_ns; u32 tslch_ns; u32 sram_size; + bool sample_edge_rising; };
struct cadence_spi_priv { @@ -73,6 +74,6 @@ void cadence_qspi_apb_delay(void *reg_base, unsigned int tchsh_ns, unsigned int tslch_ns); void cadence_qspi_apb_enter_xip(void *reg_base, char xip_dummy); void cadence_qspi_apb_readdata_capture(void *reg_base, - unsigned int bypass, unsigned int delay); + bool bypass, bool edge, unsigned int delay);
#endif /* __CADENCE_QSPI_H__ */ diff --git a/drivers/spi/cadence_qspi_apb.c b/drivers/spi/cadence_qspi_apb.c index 4a6b76e..7cc6411 100644 --- a/drivers/spi/cadence_qspi_apb.c +++ b/drivers/spi/cadence_qspi_apb.c @@ -98,6 +98,7 @@ #define CQSPI_REG_RD_DATA_CAPTURE_BYPASS BIT(0) #define CQSPI_REG_RD_DATA_CAPTURE_DELAY_LSB 1 #define CQSPI_REG_RD_DATA_CAPTURE_DELAY_MASK 0xF +#define CQSPI_REG_RD_DATA_CAPTURE_EDGE BIT(5)
#define CQSPI_REG_SIZE 0x14 #define CQSPI_REG_SIZE_ADDRESS_LSB 0 @@ -237,7 +238,7 @@ static unsigned int cadence_qspi_wait_idle(void *reg_base) }
void cadence_qspi_apb_readdata_capture(void *reg_base, - unsigned int bypass, unsigned int delay) + bool bypass, bool edge, unsigned int delay) { unsigned int reg; cadence_qspi_apb_controller_disable(reg_base); @@ -249,6 +250,11 @@ void cadence_qspi_apb_readdata_capture(void *reg_base, else reg &= ~CQSPI_REG_RD_DATA_CAPTURE_BYPASS;
+ if (edge) + reg |= CQSPI_REG_RD_DATA_CAPTURE_EDGE; + else + reg &= ~CQSPI_REG_RD_DATA_CAPTURE_EDGE; + reg &= ~(CQSPI_REG_RD_DATA_CAPTURE_DELAY_MASK << CQSPI_REG_RD_DATA_CAPTURE_DELAY_LSB);
Phil Edworthy
