[U-Boot] [PATCH] ARM: dts: sun6i: Add defconfig and dts file for tablets using the inet-q972 PCB
Add a defconfig and dts file for tablets using the generic inet-q972 PCB.
Tablets with this PCB feature a mini-hdmi output, micro-usb usb-host, micro-usb usb-otg, 3.5mm headphone jack, a micro sd slot, (mini) power-barrel and an usb wifi module.
This has been tested on a 9.7" 1024x768 qware qw tb9718-qhd tablet.
The dts files are identical to the ones submitted to the upstream kernel.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- arch/arm/dts/Makefile | 1 + .../arm/dts/sun6i-a31-reference-design-tablet.dtsi | 193 +++++++++++++++++++++ arch/arm/dts/sun6i-a31s-inet-q972.dts | 100 +++++++++++ board/sunxi/MAINTAINERS | 1 + configs/inet_q972_defconfig | 23 +++ 5 files changed, 318 insertions(+) create mode 100644 arch/arm/dts/sun6i-a31-reference-design-tablet.dtsi create mode 100644 arch/arm/dts/sun6i-a31s-inet-q972.dts create mode 100644 configs/inet_q972_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index d93fabc..29d5567 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -200,6 +200,7 @@ dtb-$(CONFIG_MACH_SUN6I) += \ sun6i-a31-mixtile-loftq.dtb \ sun6i-a31s-colorfly-e708-q1.dtb \ sun6i-a31s-cs908.dtb \ + sun6i-a31s-inet-q972.dtb \ sun6i-a31s-primo81.dtb \ sun6i-a31s-sina31s.dtb \ sun6i-a31s-sinovoip-bpi-m2.dtb \ diff --git a/arch/arm/dts/sun6i-a31-reference-design-tablet.dtsi b/arch/arm/dts/sun6i-a31-reference-design-tablet.dtsi new file mode 100644 index 0000000..0c43430 --- /dev/null +++ b/arch/arm/dts/sun6i-a31-reference-design-tablet.dtsi @@ -0,0 +1,193 @@ +/* + * Copyright 2016 Hans de Goede hdegoede@redhat.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +#include "sunxi-common-regulators.dtsi" + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/input/input.h> +#include <dt-bindings/pinctrl/sun4i-a10.h> + +/ { + aliases { + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; +}; + +&cpu0 { + cpu-supply = <®_dcdc3>; +}; + +&ehci0 { + /* Wifi is connected here */ + status = "okay"; +}; + +&mmc0 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin_e708_q1>; + vmmc-supply = <®_dcdc1>; + bus-width = <4>; + cd-gpios = <&pio 0 8 GPIO_ACTIVE_HIGH>; /* PA8 */ + cd-inverted; + status = "okay"; +}; + +&pio { + mmc0_cd_pin_e708_q1: mmc0_cd_pin@0 { + allwinner,pins = "PA8"; + allwinner,function = "gpio_in"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_PULL_UP>; + }; + + usb0_id_detect_pin: usb0_id_detect_pin@0 { + allwinner,pins = "PA15"; + allwinner,function = "gpio_in"; + allwinner,drive = <SUN4I_PINCTRL_10_MA>; + allwinner,pull = <SUN4I_PINCTRL_PULL_UP>; + }; +}; + +&p2wi { + status = "okay"; + + axp22x: pmic@68 { + compatible = "x-powers,axp221"; + reg = <0x68>; + interrupt-parent = <&nmi_intc>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + drivevbus-supply = <®_vcc5v0>; + x-powers,drive-vbus-en; + }; +}; + +#include "axp22x.dtsi" + +®_aldo3 { + regulator-always-on; + regulator-min-microvolt = <2700000>; + regulator-max-microvolt = <3300000>; + regulator-name = "avcc"; +}; + +®_dc1sw { + regulator-name = "vcc-lcd"; +}; + +®_dc5ldo { + regulator-always-on; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1320000>; + regulator-name = "vdd-cpus"; /* This is an educated guess */ +}; + +®_dcdc1 { + regulator-always-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-name = "vcc-3v0"; +}; + +®_dcdc2 { + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1320000>; + regulator-name = "vdd-gpu"; +}; + +®_dcdc3 { + regulator-always-on; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1320000>; + regulator-name = "vdd-cpu"; +}; + +®_dcdc4 { + regulator-always-on; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1320000>; + regulator-name = "vdd-sys-dll"; +}; + +®_dcdc5 { + regulator-always-on; + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1500000>; + regulator-name = "vcc-dram"; +}; + +®_dldo1 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-wifi"; +}; + +®_drivevbus { + regulator-name = "usb0-vbus"; + status = "okay"; +}; + +&simplefb_lcd { + vcc-lcd-supply = <®_dc1sw>; +}; + +&usb_otg { + dr_mode = "otg"; + status = "okay"; +}; + +&usb_power_supply { + status = "okay"; +}; + +&usbphy { + pinctrl-names = "default"; + pinctrl-0 = <&usb0_id_detect_pin>; + usb0_id_det-gpio = <&pio 0 15 GPIO_ACTIVE_HIGH>; /* PA15 */ + usb0_vbus_power-supply = <&usb_power_supply>; + usb0_vbus-supply = <®_drivevbus>; + usb1_vbus-supply = <®_dldo1>; + status = "okay"; +}; diff --git a/arch/arm/dts/sun6i-a31s-inet-q972.dts b/arch/arm/dts/sun6i-a31s-inet-q972.dts new file mode 100644 index 0000000..b115533 --- /dev/null +++ b/arch/arm/dts/sun6i-a31s-inet-q972.dts @@ -0,0 +1,100 @@ +/* + * Copyright 2016 Hans de Goede hdegoede@redhat.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; +#include "sun6i-a31s.dtsi" +#include "sun6i-a31-reference-design-tablet.dtsi" + +/ { + model = "iNet Q972 tablet"; + compatible = "inet-tek,inet-q972", "allwinner,sun6i-a31s"; +}; + +&ehci1 { + status = "okay"; +}; + +&i2c1 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c1_pins_a>; + status = "okay"; + + ft5406ee8: touchscreen@38 { + compatible = "edt,edt-ft5406"; + reg = <0x38>; + interrupt-parent = <&pio>; + interrupts = <0 3 IRQ_TYPE_LEVEL_HIGH>; /* PA3 */ + touchscreen-size-x = <768>; + touchscreen-size-y = <1024>; + touchscreen-swapped-x-y; + }; +}; + +&lradc { + vref-supply = <®_aldo3>; + status = "okay"; + + button@200 { + label = "Volume Down"; + linux,code = <KEY_VOLUMEDOWN>; + channel = <0>; + voltage = <200000>; + }; + + button@900 { + label = "Volume Up"; + linux,code = <KEY_VOLUMEUP>; + channel = <0>; + voltage = <900000>; + }; + + button@1200 { + label = "Back"; + linux,code = <KEY_BACK>; + channel = <0>; + voltage = <1200000>; + }; +}; + +&ohci1 { + status = "okay"; +}; diff --git a/board/sunxi/MAINTAINERS b/board/sunxi/MAINTAINERS index de719cd..c1d0f55 100644 --- a/board/sunxi/MAINTAINERS +++ b/board/sunxi/MAINTAINERS @@ -37,6 +37,7 @@ F: configs/Wobo_i5_defconfig F: include/configs/sun6i.h F: configs/colorfly_e708_q1_defconfig F: configs/CSQ_CS908_defconfig +F: configs/inet_q972_defconfig F: configs/Mele_A1000G_quad_defconfig F: configs/Mele_M9_defconfig F: configs/Sinovoip_BPI_M2_defconfig diff --git a/configs/inet_q972_defconfig b/configs/inet_q972_defconfig new file mode 100644 index 0000000..fdbbd6a --- /dev/null +++ b/configs/inet_q972_defconfig @@ -0,0 +1,23 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_MACH_SUN6I=y +CONFIG_DRAM_CLK=384 +CONFIG_DRAM_ZQ=251 +CONFIG_MMC0_CD_PIN="PA8" +CONFIG_USB0_VBUS_PIN="AXP0-VBUS-ENABLE" +CONFIG_USB0_VBUS_DET="AXP0-VBUS-DETECT" +CONFIG_USB0_ID_DET="PA15" +CONFIG_AXP_GPIO=y +CONFIG_VIDEO_LCD_MODE="x:1024,y:768,depth:18,pclk_khz:65000,le:280,ri:20,up:22,lo:8,hs:20,vs:8,sync:3,vmode:0" +CONFIG_VIDEO_LCD_DCLK_PHASE=0 +CONFIG_VIDEO_LCD_BL_EN="PA25" +CONFIG_VIDEO_LCD_BL_PWM="PH13" +CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-inet-q972" +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL=y +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_FPGA is not set +CONFIG_AXP_DLDO1_VOLT=3300 +CONFIG_USB_MUSB_HOST=y +CONFIG_USB_EHCI_HCD=y
Acked-by: Ian Campbell ijc@hellion.org.uk
Hans de Goede
Ian Campbell
