[PATCH v3 0/6] imx93-11x11-evk: convert to OF_UPSTREAM
To support OF_UPSTREAM, a few driver changes are included. For TMU, still use U-Boot node, I will prepare a kernel update, then back to U-Boot support. Add the pmic nodes to x-u-boot.dtsi, since upstream still not has it. imx93.dtsi still kept because other boards still use it as of now.
Signed-off-by: Peng Fan peng.fan@nxp.com --- Changes in v3: - Update patch 5, to drop the imx8mp-evk changes which are wrongly included - Link to v2: https://lore.kernel.org/r/20240328-imx93-of-v2-0-909f5d37da87@nxp.com
Changes in v2: - Add a new patch to sync clock header to avoid breaking - Drop the Makefile change which change including order - Link to v1: https://lore.kernel.org/r/20240327-imx93-of-v1-0-afab6b31422a@nxp.com
--- Peng Fan (6): gpio: imx_rgpio2p: support one address serial: lpuart: use ipg clk for i.MX7ULP cpu: drop imx9_cpu clk: imx93: fix anatop base dt-bindings: imx93: sync clock header imx: imx93-11x11-evk: convert to OF_UPSTREAM
arch/arm/dts/Makefile | 1 - arch/arm/dts/imx93-11x11-evk-u-boot.dtsi | 118 +++++++++++ arch/arm/dts/imx93-11x11-evk.dts | 322 ------------------------------- arch/arm/dts/imx93-u-boot.dtsi | 15 ++ arch/arm/mach-imx/imx9/Kconfig | 1 + configs/imx93_11x11_evk_defconfig | 2 +- configs/imx93_11x11_evk_ld_defconfig | 2 +- drivers/clk/imx/clk-imx93.c | 2 +- drivers/cpu/imx9_cpu.c | 224 --------------------- drivers/gpio/imx_rgpio2p.c | 42 +++- drivers/serial/serial_lpuart.c | 9 +- include/dt-bindings/clock/imx93-clock.h | 3 +- 12 files changed, 185 insertions(+), 556 deletions(-) --- base-commit: ab8d9ca3044acf51d8ff3bf3c4718c48f30ad606 change-id: 20240327-imx93-of-56ef2b96f2e2
The i.MX8ULP/93 gpio dt-schema have been updated to only have one address entry, update the driver to support it.
Signed-off-by: Peng Fan peng.fan@nxp.com --- drivers/gpio/imx_rgpio2p.c | 42 ++++++++++++++++++++++++++++++++++++++---- 1 file changed, 38 insertions(+), 4 deletions(-)
diff --git a/drivers/gpio/imx_rgpio2p.c b/drivers/gpio/imx_rgpio2p.c index 175e460aff5..3227a8d5b57 100644 --- a/drivers/gpio/imx_rgpio2p.c +++ b/drivers/gpio/imx_rgpio2p.c @@ -21,6 +21,12 @@ enum imx_rgpio2p_direction {
#define GPIO_PER_BANK 32
+struct imx_rgpio2p_soc_data { + bool have_dual_base; +}; + +#define IMX8ULP_GPIO_BASE_OFF 0x40 + struct imx_rgpio2p_data { struct gpio_regs *regs; }; @@ -165,6 +171,9 @@ static int imx_rgpio2p_probe(struct udevice *dev) static int imx_rgpio2p_bind(struct udevice *dev) { struct imx_rgpio2p_plat *plat = dev_get_plat(dev); + struct imx_rgpio2p_soc_data *data = + (struct imx_rgpio2p_soc_data *)dev_get_driver_data(dev); + bool dual_base = data->have_dual_base; fdt_addr_t addr;
/* @@ -176,9 +185,26 @@ static int imx_rgpio2p_bind(struct udevice *dev) if (plat) return 0;
- addr = devfdt_get_addr_index(dev, 1); - if (addr == FDT_ADDR_T_NONE) - return -EINVAL; + /* + * Handle legacy compatible combinations which used two reg values + * for the i.MX8ULP and i.MX93. + */ + if (device_is_compatible(dev, "fsl,imx7ulp-gpio") && + (device_is_compatible(dev, "fsl,imx93-gpio") || + (device_is_compatible(dev, "fsl,imx8ulp-gpio")))) + dual_base = true; + + if (dual_base) { + addr = devfdt_get_addr_index(dev, 1); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + } else { + addr = devfdt_get_addr_index(dev, 0); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + + addr += IMX8ULP_GPIO_BASE_OFF; + }
/* * TODO: @@ -202,9 +228,17 @@ static int imx_rgpio2p_bind(struct udevice *dev) return 0; }
+static struct imx_rgpio2p_soc_data imx7ulp_data = { + .have_dual_base = true, +}; + +static struct imx_rgpio2p_soc_data imx8ulp_data = { + .have_dual_base = false, +};
static const struct udevice_id imx_rgpio2p_ids[] = { - { .compatible = "fsl,imx7ulp-gpio" }, + { .compatible = "fsl,imx7ulp-gpio", .data = (ulong)&imx7ulp_data }, + { .compatible = "fsl,imx8ulp-gpio", .data = (ulong)&imx8ulp_data }, { } };
To i.MX7ULP compatible lpuart, there is only ipg clk, no per clk. So add a devtype check for i.MX7ULP.
Signed-off-by: Peng Fan peng.fan@nxp.com --- drivers/serial/serial_lpuart.c | 9 ++++++++- 1 file changed, 8 insertions(+), 1 deletion(-)
diff --git a/drivers/serial/serial_lpuart.c b/drivers/serial/serial_lpuart.c index ce08a6b4486..653ff99e67b 100644 --- a/drivers/serial/serial_lpuart.c +++ b/drivers/serial/serial_lpuart.c @@ -111,11 +111,18 @@ u32 __weak get_lpuart_clk(void) #if CONFIG_IS_ENABLED(CLK) static int get_lpuart_clk_rate(struct udevice *dev, u32 *clk) { + struct lpuart_serial_plat *plat = dev_get_plat(dev); struct clk per_clk; ulong rate; int ret; + char *name;
- ret = clk_get_by_name(dev, "per", &per_clk); + if (plat->devtype == DEV_MX7ULP) + name = "ipg"; + else + name = "per"; + + ret = clk_get_by_name(dev, name, &per_clk); if (ret) { dev_err(dev, "Failed to get per clk: %d\n", ret); return ret;
Please rename from "per_clk" to "clk".
This was wrongly committed, no user, remove it.
Signed-off-by: Peng Fan peng.fan@nxp.com --- drivers/cpu/imx9_cpu.c | 224 ------------------------------------------------- 1 file changed, 224 deletions(-)
diff --git a/drivers/cpu/imx9_cpu.c b/drivers/cpu/imx9_cpu.c deleted file mode 100644 index 66534fe6d17..00000000000 --- a/drivers/cpu/imx9_cpu.c +++ /dev/null @@ -1,224 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright 2019 NXP - */ - -#include <common.h> -#include <cpu.h> -#include <dm.h> -#include <thermal.h> -#include <asm/global_data.h> -#include <asm/system.h> -#include <firmware/linux/imx/sci/sci.h> -#include <asm/arch/sys_proto.h> -#include <asm/arch-imx/cpu.h> -#include <asm/armv8/cpu.h> -#include <linux/bitops.h> - -DECLARE_GLOBAL_DATA_PTR; - -struct cpu_imx_plat { - const char *name; - const char *rev; - const char *type; - u32 cpu_rsrc; - u32 cpurev; - u32 freq_mhz; - u32 mpidr; -}; - -const char *get_imx9_type(u32 imxtype) -{ - switch (imxtype) { - case MXC_CPU_IMX93: - return "93"; - default: - return "??"; - } -} - -const char *get_imx9_rev(u32 rev) -{ - switch (rev) { - case CHIP_REV_1_0: - return "1."; - case CHIP_REV_B: - return "B"; - case CHIP_REV_C: - return "C"; - default: - return "?"; - } -} - -static void set_core_data(struct udevice *dev) -{ - struct cpu_imx_plat *plat = dev_get_plat(dev); - - if (device_is_compatible(dev, "arm,cortex-a35")) - plat->name = "A35"; - else - plat->name = "?"; -} - -#if IS_ENABLED(CONFIG_IMX_SCU_THERMAL) -static int cpu_imx_get_temp(struct cpu_imx_plat *plat) -{ - struct udevice *thermal_dev; - int cpu_tmp, ret; - int idx = 1; /* use "cpu-thermal0" device */ - - if (plat->cpu_rsrc == SC_R_A72) - idx = 2; /* use "cpu-thermal1" device */ - - ret = uclass_get_device(UCLASS_THERMAL, idx, &thermal_dev); - if (!ret) { - ret = thermal_get_temp(thermal_dev, &cpu_tmp); - if (ret) - return 0xdeadbeef; - } else { - return 0xdeadbeef; - } - - return cpu_tmp; -} -#else -static int cpu_imx_get_temp(struct cpu_imx_plat *plat) -{ - return 0; -} -#endif - -int cpu_imx_get_desc(const struct udevice *dev, char *buf, int size) -{ - struct cpu_imx_plat *plat = dev_get_plat(dev); - int ret, temp; - - if (size < 100) - return -ENOSPC; - - ret = snprintf(buf, size, "NXP i.MX8%s Rev%s %s at %u MHz", - plat->type, plat->rev, plat->name, plat->freq_mhz); - - if (IS_ENABLED(CONFIG_IMX_SCU_THERMAL)) { - temp = cpu_imx_get_temp(plat); - buf = buf + ret; - size = size - ret; - if (temp != 0xdeadbeef) - ret = snprintf(buf, size, " at %dC", temp); - else - ret = snprintf(buf, size, " - invalid sensor data"); - } - - snprintf(buf + ret, size - ret, "\n"); - - return 0; -} - -static int cpu_imx_get_info(const struct udevice *dev, struct cpu_info *info) -{ - struct cpu_imx_plat *plat = dev_get_plat(dev); - - info->cpu_freq = plat->freq_mhz * 1000; - info->features = BIT(CPU_FEAT_L1_CACHE) | BIT(CPU_FEAT_MMU); - return 0; -} - -static int cpu_imx_get_count(const struct udevice *dev) -{ - ofnode node; - int num = 0; - - ofnode_for_each_subnode(node, dev_ofnode(dev->parent)) { - const char *device_type; - - if (!ofnode_is_enabled(node)) - continue; - - device_type = ofnode_read_string(node, "device_type"); - if (!device_type) - continue; - - if (!strcmp(device_type, "cpu")) - num++; - } - - return num; -} - -static int cpu_imx_get_vendor(const struct udevice *dev, char *buf, int size) -{ - snprintf(buf, size, "NXP"); - return 0; -} - -static int cpu_imx_is_current(struct udevice *dev) -{ - struct cpu_imx_plat *plat = dev_get_plat(dev); - - if (plat->mpidr == (read_mpidr() & 0xffff)) - return 1; - - return 0; -} - -static const struct cpu_ops cpu_imx9_ops = { - .get_desc = cpu_imx_get_desc, - .get_info = cpu_imx_get_info, - .get_count = cpu_imx_get_count, - .get_vendor = cpu_imx_get_vendor, - .is_current = cpu_imx_is_current, -}; - -static const struct udevice_id cpu_imx9_ids[] = { - { .compatible = "arm,cortex-a35" }, - { .compatible = "arm,cortex-a53" }, - { .compatible = "arm,cortex-a72" }, - { } -}; - -static ulong imx9_get_cpu_rate(struct udevice *dev) -{ - struct cpu_imx_plat *plat = dev_get_plat(dev); - ulong rate; - int ret; - - ret = sc_pm_get_clock_rate(-1, plat->cpu_rsrc, SC_PM_CLK_CPU, - (sc_pm_clock_rate_t *)&rate); - if (ret) { - printf("Could not read CPU frequency: %d\n", ret); - return 0; - } - - return rate; -} - -static int imx9_cpu_probe(struct udevice *dev) -{ - struct cpu_imx_plat *plat = dev_get_plat(dev); - u32 cpurev; - - set_core_data(dev); - cpurev = get_cpu_rev(); - plat->cpurev = cpurev; - plat->rev = get_imx9_rev(cpurev & 0xFFF); - plat->type = get_imx9_type((cpurev & 0xFF000) >> 12); - plat->freq_mhz = imx9_get_cpu_rate(dev) / 1000000; - plat->mpidr = dev_read_addr(dev); - if (plat->mpidr == FDT_ADDR_T_NONE) { - printf("%s: Failed to get CPU reg property\n", __func__); - return -EINVAL; - } - - return 0; -} - -U_BOOT_DRIVER(cpu_imx9_drv) = { - .name = "imx9x_cpu", - .id = UCLASS_CPU, - .of_match = cpu_imx9_ids, - .ops = &cpu_imx9_ops, - .probe = imx9_cpu_probe, - .plat_auto = sizeof(struct cpu_imx_plat), - .flags = DM_FLAG_PRE_RELOC, -};
The PLL clk needs use anatop base, otherwise wrong PLL address will be used.
Fixes: 9c153e46661b ("clk: imx: add i.MX93 CCF driver") Signed-off-by: Peng Fan peng.fan@nxp.com --- drivers/clk/imx/clk-imx93.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/clk/imx/clk-imx93.c b/drivers/clk/imx/clk-imx93.c index ce10d795316..f0cb797d975 100644 --- a/drivers/clk/imx/clk-imx93.c +++ b/drivers/clk/imx/clk-imx93.c @@ -289,7 +289,7 @@ static int imx93_clk_probe(struct udevice *dev) clk_dm(IMX93_CLK_SYS_PLL_PFD2_DIV2, imx_clk_fixed_factor("sys_pll_pfd2_div2", "sys_pll_pfd2", 1, 2));
- base = (void *)ANATOP_BASE_ADDR; + anatop_base = (void *)ANATOP_BASE_ADDR;
clk_dm(IMX93_CLK_ARM_PLL, imx_clk_fracn_gppll_integer("arm_pll", "clock-osc-24m",
Sync clock header with kernel 6.8
Signed-off-by: Peng Fan peng.fan@nxp.com --- include/dt-bindings/clock/imx93-clock.h | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/include/dt-bindings/clock/imx93-clock.h b/include/dt-bindings/clock/imx93-clock.h index 35a1f62053a..787c9e74dc9 100644 --- a/include/dt-bindings/clock/imx93-clock.h +++ b/include/dt-bindings/clock/imx93-clock.h @@ -203,6 +203,7 @@ #define IMX93_CLK_ARM_PLL 198 #define IMX93_CLK_A55_SEL 199 #define IMX93_CLK_A55_CORE 200 -#define IMX93_CLK_END 201 +#define IMX93_CLK_PDM_IPG 201 +#define IMX93_CLK_END 202
#endif
Convert to OF_UPSTREAM for i.MX93 11x11 EVK.
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/dts/Makefile | 1 - arch/arm/dts/imx93-11x11-evk-u-boot.dtsi | 118 +++++++++++ arch/arm/dts/imx93-11x11-evk.dts | 322 ------------------------------- arch/arm/dts/imx93-u-boot.dtsi | 15 ++ arch/arm/mach-imx/imx9/Kconfig | 1 + configs/imx93_11x11_evk_defconfig | 2 +- configs/imx93_11x11_evk_ld_defconfig | 2 +- 7 files changed, 136 insertions(+), 325 deletions(-)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index d85a33055c9..71c2facfb5e 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1115,7 +1115,6 @@ dtb-$(CONFIG_ARCH_IMX8M) += \ imx8mq-librem5-r4.dtb
dtb-$(CONFIG_ARCH_IMX9) += \ - imx93-11x11-evk.dtb \ imx93-var-som-symphony.dtb \ imx93-phyboard-segin.dtb
diff --git a/arch/arm/dts/imx93-11x11-evk-u-boot.dtsi b/arch/arm/dts/imx93-11x11-evk-u-boot.dtsi index a99ba99bfb4..408e601bc90 100644 --- a/arch/arm/dts/imx93-11x11-evk-u-boot.dtsi +++ b/arch/arm/dts/imx93-11x11-evk-u-boot.dtsi @@ -26,6 +26,111 @@ bootph-pre-ram; };
+&lpi2c2 { + #address-cells = <1>; + #size-cells = <0>; + clock-frequency = <400000>; + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&pinctrl_lpi2c2>; + pinctrl-1 = <&pinctrl_lpi2c2>; + status = "okay"; + + pmic@25 { + compatible = "nxp,pca9451a"; + reg = <0x25>; + interrupt-parent = <&pcal6524>; + interrupts = <11 IRQ_TYPE_LEVEL_LOW>; + + regulators { + buck1: BUCK1 { + regulator-name = "BUCK1"; + regulator-min-microvolt = <650000>; + regulator-max-microvolt = <2237500>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <3125>; + }; + + buck2: BUCK2 { + regulator-name = "BUCK2"; + regulator-min-microvolt = <600000>; + regulator-max-microvolt = <2187500>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <3125>; + }; + + buck4: BUCK4{ + regulator-name = "BUCK4"; + regulator-min-microvolt = <600000>; + regulator-max-microvolt = <3400000>; + regulator-boot-on; + regulator-always-on; + }; + + buck5: BUCK5{ + regulator-name = "BUCK5"; + regulator-min-microvolt = <600000>; + regulator-max-microvolt = <3400000>; + regulator-boot-on; + regulator-always-on; + }; + + buck6: BUCK6 { + regulator-name = "BUCK6"; + regulator-min-microvolt = <600000>; + regulator-max-microvolt = <3400000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo1: LDO1 { + regulator-name = "LDO1"; + regulator-min-microvolt = <1600000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo4: LDO4 { + regulator-name = "LDO4"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo5: LDO5 { + regulator-name = "LDO5"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + }; + }; + + pcal6524: gpio@22 { + compatible = "nxp,pcal6524"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pcal6524>; + reg = <0x22>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + interrupt-parent = <&gpio3>; + interrupts = <27 IRQ_TYPE_LEVEL_LOW>; + }; + + adp5585gpio: gpio@34 { + compatible = "adp5585"; + reg = <0x34>; + gpio-controller; + #gpio-cells = <2>; + }; +}; + &aips1 { bootph-pre-ram; bootph-all; @@ -44,6 +149,19 @@ &iomuxc { bootph-pre-ram; bootph-some-ram; + + pinctrl_lpi2c2: lpi2c2grp { + fsl,pins = < + MX93_PAD_I2C2_SCL__LPI2C2_SCL 0x40000b9e + MX93_PAD_I2C2_SDA__LPI2C2_SDA 0x40000b9e + >; + }; + + pinctrl_pcal6524: pcal6524grp { + fsl,pins = < + MX93_PAD_CCM_CLKO2__GPIO3_IO27 0x31e + >; + }; };
®_usdhc2_vmmc { diff --git a/arch/arm/dts/imx93-11x11-evk.dts b/arch/arm/dts/imx93-11x11-evk.dts deleted file mode 100644 index 4322cc3e11b..00000000000 --- a/arch/arm/dts/imx93-11x11-evk.dts +++ /dev/null @@ -1,322 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright 2022 NXP - */ - -/dts-v1/; - -#include "imx93.dtsi" - -/ { - model = "NXP i.MX93 11X11 EVK board"; - compatible = "fsl,imx93-11x11-evk", "fsl,imx93"; - - chosen { - stdout-path = &lpuart1; - }; - - reg_vref_1v8: regulator-adc-vref { - compatible = "regulator-fixed"; - regulator-name = "vref_1v8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - }; - - reg_usdhc2_vmmc: regulator-usdhc2 { - compatible = "regulator-fixed"; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_reg_usdhc2_vmmc>; - regulator-name = "VSD_3V3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - gpio = <&gpio3 7 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; -}; - -&adc1 { - vref-supply = <®_vref_1v8>; - status = "okay"; -}; - -&mu1 { - status = "okay"; -}; - -&mu2 { - status = "okay"; -}; - -&eqos { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_eqos>; - phy-mode = "rgmii-id"; - phy-handle = <ðphy1>; - status = "okay"; - - mdio { - compatible = "snps,dwmac-mdio"; - #address-cells = <1>; - #size-cells = <0>; - clock-frequency = <5000000>; - - ethphy1: ethernet-phy@1 { - reg = <1>; - eee-broken-1000t; - }; - }; -}; - -&fec { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_fec>; - phy-mode = "rgmii-id"; - phy-handle = <ðphy2>; - fsl,magic-packet; - status = "okay"; - - mdio { - #address-cells = <1>; - #size-cells = <0>; - clock-frequency = <5000000>; - - ethphy2: ethernet-phy@2 { - reg = <2>; - eee-broken-1000t; - }; - }; -}; - -&lpi2c2 { - #address-cells = <1>; - #size-cells = <0>; - clock-frequency = <400000>; - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&pinctrl_lpi2c2>; - pinctrl-1 = <&pinctrl_lpi2c2>; - status = "okay"; - - pmic@25 { - compatible = "nxp,pca9451a"; - reg = <0x25>; - interrupt-parent = <&pcal6524>; - interrupts = <11 IRQ_TYPE_LEVEL_LOW>; - - regulators { - buck1: BUCK1 { - regulator-name = "BUCK1"; - regulator-min-microvolt = <650000>; - regulator-max-microvolt = <2237500>; - regulator-boot-on; - regulator-always-on; - regulator-ramp-delay = <3125>; - }; - - buck2: BUCK2 { - regulator-name = "BUCK2"; - regulator-min-microvolt = <600000>; - regulator-max-microvolt = <2187500>; - regulator-boot-on; - regulator-always-on; - regulator-ramp-delay = <3125>; - }; - - buck4: BUCK4{ - regulator-name = "BUCK4"; - regulator-min-microvolt = <600000>; - regulator-max-microvolt = <3400000>; - regulator-boot-on; - regulator-always-on; - }; - - buck5: BUCK5{ - regulator-name = "BUCK5"; - regulator-min-microvolt = <600000>; - regulator-max-microvolt = <3400000>; - regulator-boot-on; - regulator-always-on; - }; - - buck6: BUCK6 { - regulator-name = "BUCK6"; - regulator-min-microvolt = <600000>; - regulator-max-microvolt = <3400000>; - regulator-boot-on; - regulator-always-on; - }; - - ldo1: LDO1 { - regulator-name = "LDO1"; - regulator-min-microvolt = <1600000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - regulator-always-on; - }; - - ldo4: LDO4 { - regulator-name = "LDO4"; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - regulator-always-on; - }; - - ldo5: LDO5 { - regulator-name = "LDO5"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - regulator-always-on; - }; - }; - }; - - pcal6524: gpio@22 { - compatible = "nxp,pcal6524"; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_pcal6524>; - reg = <0x22>; - gpio-controller; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - interrupt-parent = <&gpio3>; - interrupts = <27 IRQ_TYPE_LEVEL_LOW>; - }; - - adp5585gpio: gpio@34 { - compatible = "adp5585"; - reg = <0x34>; - gpio-controller; - #gpio-cells = <2>; - }; -}; - -&lpuart1 { /* console */ - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_uart1>; - status = "okay"; -}; - -&usdhc1 { - pinctrl-names = "default", "state_100mhz", "state_200mhz"; - pinctrl-0 = <&pinctrl_usdhc1>; - pinctrl-1 = <&pinctrl_usdhc1>; - pinctrl-2 = <&pinctrl_usdhc1>; - bus-width = <8>; - non-removable; - status = "okay"; -}; - -&usdhc2 { - pinctrl-names = "default", "state_100mhz", "state_200mhz"; - pinctrl-0 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>; - pinctrl-1 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>; - pinctrl-2 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>; - cd-gpios = <&gpio3 00 GPIO_ACTIVE_LOW>; - vmmc-supply = <®_usdhc2_vmmc>; - bus-width = <4>; - status = "okay"; - no-sdio; - no-mmc; -}; - -&iomuxc { - pinctrl_lpi2c2: lpi2c2grp { - fsl,pins = < - MX93_PAD_I2C2_SCL__LPI2C2_SCL 0x40000b9e - MX93_PAD_I2C2_SDA__LPI2C2_SDA 0x40000b9e - >; - }; - - pinctrl_pcal6524: pcal6524grp { - fsl,pins = < - MX93_PAD_CCM_CLKO2__GPIO3_IO27 0x31e - >; - }; - - pinctrl_eqos: eqosgrp { - fsl,pins = < - MX93_PAD_ENET1_MDC__ENET_QOS_MDC 0x57e - MX93_PAD_ENET1_MDIO__ENET_QOS_MDIO 0x57e - MX93_PAD_ENET1_RD0__ENET_QOS_RGMII_RD0 0x57e - MX93_PAD_ENET1_RD1__ENET_QOS_RGMII_RD1 0x57e - MX93_PAD_ENET1_RD2__ENET_QOS_RGMII_RD2 0x57e - MX93_PAD_ENET1_RD3__ENET_QOS_RGMII_RD3 0x57e - MX93_PAD_ENET1_RXC__CCM_ENET_QOS_CLOCK_GENERATE_RX_CLK 0x5fe - MX93_PAD_ENET1_RX_CTL__ENET_QOS_RGMII_RX_CTL 0x57e - MX93_PAD_ENET1_TD0__ENET_QOS_RGMII_TD0 0x57e - MX93_PAD_ENET1_TD1__ENET_QOS_RGMII_TD1 0x57e - MX93_PAD_ENET1_TD2__ENET_QOS_RGMII_TD2 0x57e - MX93_PAD_ENET1_TD3__ENET_QOS_RGMII_TD3 0x57e - MX93_PAD_ENET1_TXC__CCM_ENET_QOS_CLOCK_GENERATE_TX_CLK 0x5fe - MX93_PAD_ENET1_TX_CTL__ENET_QOS_RGMII_TX_CTL 0x57e - >; - }; - - pinctrl_fec: fecgrp { - fsl,pins = < - MX93_PAD_ENET2_MDC__ENET1_MDC 0x57e - MX93_PAD_ENET2_MDIO__ENET1_MDIO 0x57e - MX93_PAD_ENET2_RD0__ENET1_RGMII_RD0 0x57e - MX93_PAD_ENET2_RD1__ENET1_RGMII_RD1 0x57e - MX93_PAD_ENET2_RD2__ENET1_RGMII_RD2 0x57e - MX93_PAD_ENET2_RD3__ENET1_RGMII_RD3 0x57e - MX93_PAD_ENET2_RXC__ENET1_RGMII_RXC 0x5fe - MX93_PAD_ENET2_RX_CTL__ENET1_RGMII_RX_CTL 0x57e - MX93_PAD_ENET2_TD0__ENET1_RGMII_TD0 0x57e - MX93_PAD_ENET2_TD1__ENET1_RGMII_TD1 0x57e - MX93_PAD_ENET2_TD2__ENET1_RGMII_TD2 0x57e - MX93_PAD_ENET2_TD3__ENET1_RGMII_TD3 0x57e - MX93_PAD_ENET2_TXC__ENET1_RGMII_TXC 0x5fe - MX93_PAD_ENET2_TX_CTL__ENET1_RGMII_TX_CTL 0x57e - >; - }; - - pinctrl_uart1: uart1grp { - fsl,pins = < - MX93_PAD_UART1_RXD__LPUART1_RX 0x31e - MX93_PAD_UART1_TXD__LPUART1_TX 0x31e - >; - }; - - pinctrl_usdhc1: usdhc1grp { - fsl,pins = < - MX93_PAD_SD1_CLK__USDHC1_CLK 0x15fe - MX93_PAD_SD1_CMD__USDHC1_CMD 0x13fe - MX93_PAD_SD1_DATA0__USDHC1_DATA0 0x13fe - MX93_PAD_SD1_DATA1__USDHC1_DATA1 0x13fe - MX93_PAD_SD1_DATA2__USDHC1_DATA2 0x13fe - MX93_PAD_SD1_DATA3__USDHC1_DATA3 0x13fe - MX93_PAD_SD1_DATA4__USDHC1_DATA4 0x13fe - MX93_PAD_SD1_DATA5__USDHC1_DATA5 0x13fe - MX93_PAD_SD1_DATA6__USDHC1_DATA6 0x13fe - MX93_PAD_SD1_DATA7__USDHC1_DATA7 0x13fe - MX93_PAD_SD1_STROBE__USDHC1_STROBE 0x15fe - >; - }; - - pinctrl_reg_usdhc2_vmmc: regusdhc2vmmcgrp { - fsl,pins = < - MX93_PAD_SD2_RESET_B__GPIO3_IO07 0x31e - >; - }; - - pinctrl_usdhc2_gpio: usdhc2gpiogrp { - fsl,pins = < - MX93_PAD_SD2_CD_B__GPIO3_IO00 0x31e - >; - }; - - pinctrl_usdhc2: usdhc2grp { - fsl,pins = < - MX93_PAD_SD2_CLK__USDHC2_CLK 0x15fe - MX93_PAD_SD2_CMD__USDHC2_CMD 0x13fe - MX93_PAD_SD2_DATA0__USDHC2_DATA0 0x13fe - MX93_PAD_SD2_DATA1__USDHC2_DATA1 0x13fe - MX93_PAD_SD2_DATA2__USDHC2_DATA2 0x13fe - MX93_PAD_SD2_DATA3__USDHC2_DATA3 0x13fe - MX93_PAD_SD2_VSELECT__USDHC2_VSELECT 0x51e - >; - }; -}; diff --git a/arch/arm/dts/imx93-u-boot.dtsi b/arch/arm/dts/imx93-u-boot.dtsi index 40e17bbc5ae..289aba17584 100644 --- a/arch/arm/dts/imx93-u-boot.dtsi +++ b/arch/arm/dts/imx93-u-boot.dtsi @@ -86,3 +86,18 @@ }; }; }; + +&tmu { + compatible = "fsl,imx93-tmu"; + reg = <0x44482000 0x1000>; + clocks = <&clk IMX93_CLK_TMC_GATE>; + little-endian; + fsl,tmu-calibration = <0x0000000e 0x800000da + 0x00000029 0x800000e9 + 0x00000056 0x80000102 + 0x000000a2 0x8000012a + 0x00000116 0x80000166 + 0x00000195 0x800001a7 + 0x000001b2 0x800001b6>; + #thermal-sensor-cells = <1>; +}; diff --git a/arch/arm/mach-imx/imx9/Kconfig b/arch/arm/mach-imx/imx9/Kconfig index b79485f1f75..e892da80fe8 100644 --- a/arch/arm/mach-imx/imx9/Kconfig +++ b/arch/arm/mach-imx/imx9/Kconfig @@ -31,6 +31,7 @@ choice config TARGET_IMX93_11X11_EVK bool "imx93_11x11_evk" select IMX93 + imply OF_UPSTREAM
config TARGET_IMX93_VAR_SOM bool "imx93_var_som" diff --git a/configs/imx93_11x11_evk_defconfig b/configs/imx93_11x11_evk_defconfig index 63613477c7f..a671de7ca40 100644 --- a/configs/imx93_11x11_evk_defconfig +++ b/configs/imx93_11x11_evk_defconfig @@ -10,7 +10,7 @@ CONFIG_ENV_SIZE=0x4000 CONFIG_ENV_OFFSET=0x700000 CONFIG_IMX_CONFIG="arch/arm/mach-imx/imx9/imximage.cfg" CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="imx93-11x11-evk" +CONFIG_DEFAULT_DEVICE_TREE="freescale/imx93-11x11-evk" CONFIG_SPL_TEXT_BASE=0x2049A000 CONFIG_TARGET_IMX93_11X11_EVK=y CONFIG_SYS_MONITOR_LEN=524288 diff --git a/configs/imx93_11x11_evk_ld_defconfig b/configs/imx93_11x11_evk_ld_defconfig index 4e3bbdd0cf5..4e1f162e35a 100644 --- a/configs/imx93_11x11_evk_ld_defconfig +++ b/configs/imx93_11x11_evk_ld_defconfig @@ -10,7 +10,7 @@ CONFIG_ENV_SIZE=0x4000 CONFIG_ENV_OFFSET=0x400000 CONFIG_IMX_CONFIG="arch/arm/mach-imx/imx9/imximage.cfg" CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="imx93-11x11-evk" +CONFIG_DEFAULT_DEVICE_TREE="freescale/imx93-11x11-evk" CONFIG_SPL_TEXT_BASE=0x2049A000 CONFIG_IMX9_LOW_DRIVE_MODE=y CONFIG_TARGET_IMX93_11X11_EVK=y
+&lpi2c2 {
#size-cells = <0>;
status = "okay";
pmic@25 {
reg = <0x34>;
gpio-controller;
#gpio-cells = <2>;
Please add a comment saying these nodes are already available in 6.9-rc1.
imply OF_UPSTREAM
Sumit and I asked you to add OF_UPSTREAM to all imx93 boards, not just this one.
Please don't ignore review comments.
Subject: Re: [PATCH v3 6/6] imx: imx93-11x11-evk: convert to OF_UPSTREAM
+&lpi2c2 {
#size-cells = <0>;
status = "okay";
pmic@25 {
reg = <0x34>;
gpio-controller;
#gpio-cells = <2>;
imply OF_UPSTREAM
I could help convert all imx93 boards, but I could only test nxp imx93 boards, not able to test others.
Thanks, Peng.
Hi Peng,
Just copy the board maintainers in your patch and they could help test the conversion to OF_UPSTREAM.
Thanks!
Hi Peng,
ok, I need use v6.9-rc1-dts for the dts upstream. Some dts not in v6.8-dts.
Thanks, Peng.
Thanks!
+&lpi2c2 {
#size-cells = <0>;
status = "okay";
pmic@25 {
reg = <0x34>;
gpio-controller;
#gpio-cells = <2>;
Just gave a check on linux-next/master, the nodes are not there.
Thanks, Peng
imply OF_UPSTREAM
Fabio Estevam
Peng Fan
Peng Fan (OSS)
