Subject: [PATCH 2/6 v2] spmi: msm: add arbiter version 5 support
From b65826c49fee93dd7ded11a848814d8fa79fdb2e Mon Sep 17 00:00:00 2001
From: Dzmitry Sankouski dsankouski@gmail.com Date: Sat, 28 Aug 2021 13:53:42 +0300 Subject: [PATCH 2/6 v2] spmi: msm: add arbiter version 5 support
Currently driver supports only version 1 and 2. Version 5 has slightly different registers structure
Signed-off-by: Dzmitry Sankouski dsankouski@gmail.com Cc: Ramon Fried rfried.dev@gmail.com --- Changes for v2: - change string formats in debug statements
MAINTAINERS | 1 + drivers/spmi/spmi-msm.c | 156 +++++++++++++++++++++++++++------------- 2 files changed, 107 insertions(+), 50 deletions(-)
diff --git a/MAINTAINERS b/MAINTAINERS index 52ddc99cda..6b8b0783d2 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -392,6 +392,7 @@ F: drivers/phy/msm8916-usbh-phy.c F: drivers/serial/serial_msm.c F: drivers/serial/serial_msm_geni.c F: drivers/smem/msm_smem.c +F: drivers/spmi/spmi-msm.c F: drivers/usb/host/ehci-msm.c
ARM STI diff --git a/drivers/spmi/spmi-msm.c b/drivers/spmi/spmi-msm.c index 5a335e50aa..c5bc55bc6f 100644 --- a/drivers/spmi/spmi-msm.c +++ b/drivers/spmi/spmi-msm.c @@ -19,39 +19,63 @@ DECLARE_GLOBAL_DATA_PTR;
/* PMIC Arbiter configuration registers */ -#define PMIC_ARB_VERSION 0x0000 -#define PMIC_ARB_VERSION_V2_MIN 0x20010000 - -#define ARB_CHANNEL_OFFSET(n) (0x4 * (n)) -#define SPMI_CH_OFFSET(chnl) ((chnl) * 0x8000) - -#define SPMI_REG_CMD0 0x0 -#define SPMI_REG_CONFIG 0x4 -#define SPMI_REG_STATUS 0x8 -#define SPMI_REG_WDATA 0x10 -#define SPMI_REG_RDATA 0x18 - -#define SPMI_CMD_OPCODE_SHIFT 27 -#define SPMI_CMD_SLAVE_ID_SHIFT 20 -#define SPMI_CMD_ADDR_SHIFT 12 -#define SPMI_CMD_ADDR_OFFSET_SHIFT 4 -#define SPMI_CMD_BYTE_CNT_SHIFT 0 - -#define SPMI_CMD_EXT_REG_WRITE_LONG 0x00 -#define SPMI_CMD_EXT_REG_READ_LONG 0x01 - -#define SPMI_STATUS_DONE 0x1 +#define PMIC_ARB_VERSION 0x0000 +#define PMIC_ARB_VERSION_V2_MIN 0x20010000 +#define PMIC_ARB_VERSION_V3_MIN 0x30000000 +#define PMIC_ARB_VERSION_V5_MIN 0x50000000 + +#define APID_MAP_OFFSET_V1_V2_V3 (0x800) +#define APID_MAP_OFFSET_V5 (0x900) +#define ARB_CHANNEL_OFFSET(n) (0x4 * (n)) +#define SPMI_CH_OFFSET(chnl) ((chnl) * 0x8000) +#define SPMI_V5_OBS_CH_OFFSET(chnl) ((chnl) * 0x80) +#define SPMI_V5_RW_CH_OFFSET(chnl) ((chnl) * 0x10000) + +#define SPMI_REG_CMD0 0x0 +#define SPMI_REG_CONFIG 0x4 +#define SPMI_REG_STATUS 0x8 +#define SPMI_REG_WDATA 0x10 +#define SPMI_REG_RDATA 0x18 + +#define SPMI_CMD_OPCODE_SHIFT 27 +#define SPMI_CMD_SLAVE_ID_SHIFT 20 +#define SPMI_CMD_ADDR_SHIFT 12 +#define SPMI_CMD_ADDR_OFFSET_SHIFT 4 +#define SPMI_CMD_BYTE_CNT_SHIFT 0 + +#define SPMI_CMD_EXT_REG_WRITE_LONG 0x00 +#define SPMI_CMD_EXT_REG_READ_LONG 0x01 + +#define SPMI_STATUS_DONE 0x1 + +#define SPMI_MAX_CHANNELS 128 +#define SPMI_MAX_SLAVES 16 +#define SPMI_MAX_PERIPH 256 + +enum arb_ver { + V1 = 1, + V2, + V3, + V5 = 5 +};
-#define SPMI_MAX_CHANNELS 128 -#define SPMI_MAX_SLAVES 16 -#define SPMI_MAX_PERIPH 256 +/* + * PMIC arbiter version 5 uses different register offsets for read/write vs + * observer channels. + */ +enum pmic_arb_channel { + PMIC_ARB_CHANNEL_RW, + PMIC_ARB_CHANNEL_OBS, +};
struct msm_spmi_priv { - phys_addr_t arb_chnl; /* ARB channel mapping base */ + phys_addr_t arb_chnl; /* ARB channel mapping base */ phys_addr_t spmi_core; /* SPMI core */ - phys_addr_t spmi_obs; /* SPMI observer */ + phys_addr_t spmi_obs; /* SPMI observer */ /* SPMI channel map */ uint8_t channel_map[SPMI_MAX_SLAVES][SPMI_MAX_PERIPH]; + /* SPMI bus arbiter version */ + u32 arb_ver; };
static int msm_spmi_write(struct udevice *dev, int usid, int pid, int off, @@ -59,6 +83,7 @@ static int msm_spmi_write(struct udevice *dev, int usid, int pid, int off, { struct msm_spmi_priv *priv = dev_get_priv(dev); unsigned channel; + unsigned int ch_offset; uint32_t reg = 0;
if (usid >= SPMI_MAX_SLAVES) @@ -69,8 +94,8 @@ static int msm_spmi_write(struct udevice *dev, int usid, int pid, int off, channel = priv->channel_map[usid][pid];
/* Disable IRQ mode for the current channel*/ - writel(0x0, priv->spmi_core + SPMI_CH_OFFSET(channel) + - SPMI_REG_CONFIG); + writel(0x0, + priv->spmi_core + SPMI_CH_OFFSET(channel) + SPMI_REG_CONFIG);
/* Write single byte */ writel(val, priv->spmi_core + SPMI_CH_OFFSET(channel) + SPMI_REG_WDATA); @@ -82,6 +107,12 @@ static int msm_spmi_write(struct udevice *dev, int usid, int pid, int off, reg |= (off << SPMI_CMD_ADDR_OFFSET_SHIFT); reg |= 1; /* byte count */
+ if (priv->arb_ver == V5) { + ch_offset = SPMI_V5_RW_CH_OFFSET(channel); + } else { + ch_offset = SPMI_CH_OFFSET(channel); + } + /* Send write command */ writel(reg, priv->spmi_core + SPMI_CH_OFFSET(channel) + SPMI_REG_CMD0);
@@ -104,6 +135,7 @@ static int msm_spmi_read(struct udevice *dev, int usid, int pid, int off) { struct msm_spmi_priv *priv = dev_get_priv(dev); unsigned channel; + unsigned int ch_offset; uint32_t reg = 0;
if (usid >= SPMI_MAX_SLAVES) @@ -113,8 +145,14 @@ static int msm_spmi_read(struct udevice *dev, int usid, int pid, int off)
+ if (priv->arb_ver == V5) { + ch_offset = SPMI_V5_OBS_CH_OFFSET(channel); + } else { + ch_offset = SPMI_CH_OFFSET(channel); + } + /* Disable IRQ mode for the current channel*/ - writel(0x0, priv->spmi_obs + SPMI_CH_OFFSET(channel) + SPMI_REG_CONFIG); + writel(0x0, priv->spmi_obs + ch_offset + SPMI_REG_CONFIG);
/* Prepare read command */ reg |= SPMI_CMD_EXT_REG_READ_LONG << SPMI_CMD_OPCODE_SHIFT; @@ -124,13 +162,12 @@ static int msm_spmi_read(struct udevice *dev, int usid, int pid, int off) reg |= 1; /* byte count */
/* Request read */ - writel(reg, priv->spmi_obs + SPMI_CH_OFFSET(channel) + SPMI_REG_CMD0); + writel(reg, priv->spmi_obs + ch_offset + SPMI_REG_CMD0);
/* Wait till CMD DONE status */ reg = 0; while (!reg) { - reg = readl(priv->spmi_obs + SPMI_CH_OFFSET(channel) + - SPMI_REG_STATUS); + reg = readl(priv->spmi_obs + ch_offset + SPMI_REG_STATUS); }
if (reg ^ SPMI_STATUS_DONE) { @@ -139,8 +176,8 @@ static int msm_spmi_read(struct udevice *dev, int usid, int pid, int off) }
/* Read the data */ - return readl(priv->spmi_obs + SPMI_CH_OFFSET(channel) + - SPMI_REG_RDATA) & 0xFF; + return readl(priv->spmi_obs + ch_offset + + SPMI_REG_RDATA) & 0xFF; }
static struct dm_spmi_ops msm_spmi_ops = { @@ -150,31 +187,50 @@ static struct dm_spmi_ops msm_spmi_ops = {
static int msm_spmi_probe(struct udevice *dev) { - struct udevice *parent = dev->parent; struct msm_spmi_priv *priv = dev_get_priv(dev); - int node = dev_of_offset(dev); + u32 config_addr; u32 hw_ver; - bool is_v1; + u32 version; int i; + int err; + + config_addr = dev_read_addr_index(dev, 0); + priv->spmi_core = dev_read_addr_index(dev, 1); + priv->spmi_obs = dev_read_addr_index(dev, 2); + + hw_ver = readl(config_addr + PMIC_ARB_VERSION); + + if (hw_ver < PMIC_ARB_VERSION_V3_MIN) { + priv->arb_ver = V2; + version = 2; + priv->arb_chnl = config_addr + APID_MAP_OFFSET_V1_V2_V3; + } else if (hw_ver < PMIC_ARB_VERSION_V5_MIN) { + priv->arb_ver = V3; + version = 3; + priv->arb_chnl = config_addr + APID_MAP_OFFSET_V1_V2_V3; + } else { + priv->arb_ver = V5; + version = 5; + priv->arb_chnl = config_addr + APID_MAP_OFFSET_V5; + + if (err) { + dev_err(dev, "could not read APID->PPID mapping table, rc= %d\n", err); + return -1; + } + }
- priv->arb_chnl = dev_read_addr(dev); - priv->spmi_core = fdtdec_get_addr_size_auto_parent(gd->fdt_blob, - dev_of_offset(parent), node, "reg", 1, NULL, false); - priv->spmi_obs = fdtdec_get_addr_size_auto_parent(gd->fdt_blob, - dev_of_offset(parent), node, "reg", 2, NULL, false); - - hw_ver = readl(priv->arb_chnl + PMIC_ARB_VERSION - 0x800); - is_v1 = (hw_ver < PMIC_ARB_VERSION_V2_MIN); - - dev_dbg(dev, "PMIC Arb Version-%d (0x%x)\n", (is_v1 ? 1 : 2), hw_ver); + dev_dbg(dev, "PMIC Arb Version-%d (0x%x)\n", version, hw_ver);
if (priv->arb_chnl == FDT_ADDR_T_NONE || priv->spmi_core == FDT_ADDR_T_NONE || priv->spmi_obs == FDT_ADDR_T_NONE) return -EINVAL;
+ dev_dbg(dev, "priv->arb_chnl address (%llu)\n", priv->arb_chnl); + dev_dbg(dev, "priv->spmi_core address (%llu)\n", priv->spmi_core); + dev_dbg(dev, "priv->spmi_obs address (%llu)\n", priv->spmi_obs); /* Scan peripherals connected to each SPMI channel */ - for (i = 0; i < SPMI_MAX_PERIPH ; i++) { + for (i = 0; i < SPMI_MAX_PERIPH; i++) { uint32_t periph = readl(priv->arb_chnl + ARB_CHANNEL_OFFSET(i)); uint8_t slave_id = (periph & 0xf0000) >> 16; uint8_t pid = (periph & 0xff00) >> 8; @@ -195,5 +251,5 @@ U_BOOT_DRIVER(msm_spmi) = { .of_match = msm_spmi_ids, .ops = &msm_spmi_ops, .probe = msm_spmi_probe, - .priv_auto = sizeof(struct msm_spmi_priv), + .priv_auto = sizeof(struct msm_spmi_priv), };
On Tue, Aug 31, 2021 at 11:43 AM Дмитрий Санковский dsankouski@gmail.com wrote:
From b65826c49fee93dd7ded11a848814d8fa79fdb2e Mon Sep 17 00:00:00 2001 From: Dzmitry Sankouski dsankouski@gmail.com Date: Sat, 28 Aug 2021 13:53:42 +0300 Subject: [PATCH 2/6 v2] spmi: msm: add arbiter version 5 support
Changes for v2:
+enum arb_ver {
- V1 = 1,
- V2,
- V3,
- V5 = 5
- PMIC arbiter version 5 uses different register offsets for read/write vs
- observer channels.
- PMIC_ARB_CHANNEL_RW,
- PMIC_ARB_CHANNEL_OBS,
- phys_addr_t arb_chnl; /* ARB channel mapping base */ phys_addr_t spmi_core; /* SPMI core */
- phys_addr_t spmi_obs; /* SPMI observer */ /* SPMI channel map */ uint8_t channel_map[SPMI_MAX_SLAVES][SPMI_MAX_PERIPH];
- /* SPMI bus arbiter version */
- u32 arb_ver;
SPMI_REG_CONFIG);
writel(0x0,
- if (priv->arb_ver == V5) {
- ch_offset = SPMI_V5_RW_CH_OFFSET(channel);
- } else {
- ch_offset = SPMI_CH_OFFSET(channel);
- /* Send write command */ writel(reg, priv->spmi_core + SPMI_CH_OFFSET(channel) + SPMI_REG_CMD0);
- ch_offset = SPMI_V5_OBS_CH_OFFSET(channel);
- } else {
- /* Disable IRQ mode for the current channel*/
/* Request read */
- SPMI_REG_STATUS);
/* Read the data */
- return readl(priv->spmi_obs + ch_offset +
- u32 config_addr; u32 hw_ver;
- bool is_v1;
- u32 version; int i;
- int err;
- config_addr = dev_read_addr_index(dev, 0);
- priv->spmi_core = dev_read_addr_index(dev, 1);
- priv->spmi_obs = dev_read_addr_index(dev, 2);
- hw_ver = readl(config_addr + PMIC_ARB_VERSION);
- if (hw_ver < PMIC_ARB_VERSION_V3_MIN) {
- priv->arb_ver = V2;
- version = 2;
- priv->arb_chnl = config_addr + APID_MAP_OFFSET_V1_V2_V3;
- } else if (hw_ver < PMIC_ARB_VERSION_V5_MIN) {
- priv->arb_ver = V3;
- version = 3;
- } else {
- priv->arb_ver = V5;
- version = 5;
- priv->arb_chnl = config_addr + APID_MAP_OFFSET_V5;
- if (err) {
- dev_err(dev, "could not read APID->PPID mapping table, rc= %d\n", err);
- return -1;
- for (i = 0; i < SPMI_MAX_PERIPH; i++) { uint32_t periph = readl(priv->arb_chnl + ARB_CHANNEL_OFFSET(i)); uint8_t slave_id = (periph & 0xf0000) >> 16; uint8_t pid = (periph & 0xff00) >> 8;
Is there a reason for the above two changes, I don't see code change here.
2.20.1
Ramon Fried
Дмитрий Санковский
